RTEMS 6.2
Modules | Files | Data Structures | Macros | Typedefs | Enumerations | Functions
Heap Handler
This group contains the Heap Handler implementation. More...
 Protected Heap Handler
 This group contains the Protected Heap Handler implementation.
file  heap.h
 This header file provides interfaces of the Heap Handler which are used by the implementation and the Application Configuration.
file  heapimpl.h
 This header file provides interfaces of the Barrier Handler which are only used by the implementation.
file  heapinfo.h
 This header file provides interfaces of the Barrier Handler which are used by the implementation and the API.
file  heap.c
 This source file contains the implementation of _Heap_Initialize() and _Heap_Block_allocate().
file  heapallocate.c
 This source file contains the implementation of _Heap_Allocate_aligned_with_boundary().
file  heapextend.c
 This source file contains the implementation of _Heap_Extend().
file  heapfree.c
 This source file contains the implementation of _Heap_Free().
file  heapgetfreeinfo.c
 This source file contains the implementation of _Heap_Get_free_information().
file  heapgetinfo.c
 This source file contains the implementation of _Heap_Get_information().
file  heapgreedy.c
 This source file contains the implementation of _Heap_Greedy_allocate(), _Heap_Greedy_allocate_all_except_largest(), and _Heap_Greedy_free().
file  heapiterate.c
 This source file contains the implementation of _Heap_Iterate().
file  heapnoextend.c
 This source file contains the implementation of _Heap_No_extend().
file  heapresizeblock.c
 This source file contains the implementation of _Heap_Resize_block().
file  heapsizeofuserarea.c
 This source file contains the implementation of _Heap_Size_of_alloc_area().
file  heapwalk.c
 This source file contains the implementation of _Heap_Walk().
struct  Heap_Error_context
 Context of a heap error. More...
struct  Heap_Block
 Description for free or used blocks. More...
struct  Heap_Control
 Control block used to manage a heap. More...
struct  Heap_Area
 Heap area structure for table based heap initialization and extension. More...
struct  Heap_Statistics
 Run-time heap statistics. More...
struct  Heap_Information
 Information about blocks. More...
struct  Heap_Information_block
 Information block returned by _Heap_Get_information(). More...
#define HEAP_PROTECTION_HEADER_SIZE   0
#define HEAP_BLOCK_HEADER_SIZE    (2 * sizeof(uintptr_t) + HEAP_PROTECTION_HEADER_SIZE)
 The block header consists of the two size fields (Heap_Block::prev_size and Heap_Block::size_and_flag).
#define HEAP_PREV_BLOCK_USED   ((uintptr_t) 1)
 See also Heap_Block::size_and_flag.
#define HEAP_ALLOC_BONUS   sizeof(uintptr_t)
 Size of the part at the block begin which may be used for allocation in charge of the previous block.
#define _Heap_Protection_block_initialize(heap, block)   ((void) 0)
#define _Heap_Protection_block_check(heap, block)   ((void) 0)
#define _Heap_Protection_block_error(heap, block, reason)   ((void) 0)
#define _Heap_Protection_free_all_delayed_blocks(heap)   ((void) 0)
#define _HAssert(cond)   ((void) 0)
typedef struct Heap_Control Heap_Control
typedef struct Heap_Block Heap_Block
typedef uintptr_t(* Heap_Initialization_or_extend_handler) (Heap_Control *heap, void *area_begin, uintptr_t area_size, uintptr_t page_size_or_unused)
 Heap initialization and extend handler type.
typedef bool(* Heap_Block_visitor) (const Heap_Block *block, uintptr_t block_size, bool block_is_used, void *visitor_arg)
 Heap block visitor.
enum  Heap_Error_reason {
  HEAP_ERROR_BROKEN_PROTECTOR , HEAP_ERROR_FREE_PATTERN , HEAP_ERROR_DOUBLE_FREE , HEAP_ERROR_BAD_USED_BLOCK ,
  HEAP_ERROR_BAD_FREE_BLOCK
 The heap error reason. More...
enum  Heap_Resize_status { HEAP_RESIZE_SUCCESSFUL , HEAP_RESIZE_UNSATISFIED , HEAP_RESIZE_FATAL_ERROR }
 See _Heap_Resize_block().
uintptr_t _Heap_Extend (Heap_Control *heap, void *area_begin, uintptr_t area_size, uintptr_t unused)
 Extends the memory available for the heap.
uintptr_t _Heap_No_extend (Heap_Control *unused_0, void *unused_1, uintptr_t unused_2, uintptr_t unused_3)
 This function returns always zero.
bool _Heap_Get_first_and_last_block (uintptr_t heap_area_begin, uintptr_t heap_area_size, uintptr_t page_size, uintptr_t min_block_size, Heap_Block **first_block_ptr, Heap_Block **last_block_ptr)
 Gets the first and last block for the heap area.
uintptr_t _Heap_Initialize (Heap_Control *heap, void *area_begin, uintptr_t area_size, uintptr_t page_size)
 Initializes the heap control block.
void * _Heap_Allocate_aligned_with_boundary (Heap_Control *heap, uintptr_t size, uintptr_t alignment, uintptr_t boundary)
 Allocates an aligned memory area with boundary constraint.
bool _Heap_Free (Heap_Control *heap, void *addr)
 Frees the allocated memory area.
bool _Heap_Walk (Heap_Control *heap, int source, bool dump)
 Verifies the integrity of the heap.
void _Heap_Iterate (Heap_Control *heap, Heap_Block_visitor visitor, void *visitor_arg)
 Iterates over all blocks of the heap.
Heap_Block_Heap_Greedy_allocate (Heap_Control *heap, const uintptr_t *block_sizes, size_t block_count)
 Greedily allocates and empties the heap.
Heap_Block_Heap_Greedy_allocate_all_except_largest (Heap_Control *heap, uintptr_t *allocatable_size)
 Greedily allocates all blocks except the largest free block.
void _Heap_Greedy_free (Heap_Control *heap, Heap_Block *blocks)
 Frees blocks of a greedy allocation.
void _Heap_Get_information (Heap_Control *heap, Heap_Information_block *info)
 Returns information about used and free blocks for the heap.
void _Heap_Get_free_information (Heap_Control *heap, Heap_Information *info)
 Returns information about free blocks for the heap.
bool _Heap_Size_of_alloc_area (Heap_Control *heap, void *addr, uintptr_t *size)
 Returns the size of the allocatable memory area.
Heap_Resize_status _Heap_Resize_block (Heap_Control *heap, void *addr, uintptr_t size, uintptr_t *old_size, uintptr_t *new_size)
 Resizes the block of the allocated memory area.
Heap_Block_Heap_Block_allocate (Heap_Control *heap, Heap_Block *block, uintptr_t alloc_begin, uintptr_t alloc_size)
 Allocates the memory area. starting at alloc_begin of size alloc_size bytes in the block block.
A heap is a doubly linked list of variable size blocks which are allocated using the first fit method. Garbage collection is performed each time a block is returned to the heap by coalescing neighbor blocks. Control information for both allocated and free blocks is contained in the heap area. A heap control structure contains control information for the heap.
The alignment routines could be made faster should we require only powers of two to be supported for page size, alignment and boundary arguments. The minimum alignment requirement for pages is currently CPU_ALIGNMENT and this value is only required to be multiple of two and explicitly not required to be a power of two.
There are two kinds of blocks. One sort describes a free block from which we can allocate memory. The other blocks are used and provide an allocated memory area. The free blocks are accessible via a list of free blocks.
Blocks or areas cover a continuous set of memory addresses. They have a begin and end address. The end address is not part of the set. The size of a block or area equals the distance between the begin and end address in units of bytes.
Free blocks look like:
Heap_Blockprevious block size in case the previous block is free,
otherwise it may contain data used by the previous block
block size and a flag which indicates if the previous block is free or used,
this field contains always valid data regardless of the block usage
pointer to next block (this field is page size aligned)
pointer to previous block
free space
Used blocks look like:
begin of allocated area (this field is page size aligned)
allocated space
allocated space
The heap area after initialization contains two blocks and looks like:
LabelContent
heap->area_beginheap area begin address
first_block->prev_size subordinate heap area end address (this will be used to maintain a linked list of scattered heap areas)
first_block->size size available for allocation | HEAP_PREV_BLOCK_USED
first_block->next_Heap_Free_list_tail(heap) memory area available for allocation
first_block->prev_Heap_Free_list_head(heap)
last_block->prev_sizesize of first block
last_block->size first block begin address - last block begin address
heap->area_endheap area end address
The next block of the last block is the first block. Since the first block indicates that the previous block is used, this ensures that the last block appears as used for the _Heap_Is_used() and _Heap_Is_free() functions.
Typedef Documentation
◆ Heap_Block_visitor
Heap block visitor.
See also
_Heap_Iterate().
Return values
trueStop the iteration.
falseContinue the iteration.
◆ Heap_Initialization_or_extend_handler
This helps to do a table based heap initialization and extension. Create a table of Heap_Area elements and iterate through it. Set the handler to _Heap_Initialize() in the first iteration and then to _Heap_Extend().
See also
Heap_Area, _Heap_Initialize(), _Heap_Extend(), or _Heap_No_extend().
◆ Heap_Error_reason
See also
_Heap_Protection_block_error().
There is an unexpected value in the heap block protector area.
There is an unexpected value in the free pattern of a free heap block.
There is was an attempt to free the same block twice.
The next block of a supposed to be used block does not indicate that the block is used.
A supposed to be free block is not inside the heap memory area.
◆ _Heap_Allocate_aligned_with_boundary()
void * _Heap_Allocate_aligned_with_boundary ( Heap_Control heap,
uintptr_t  size,
uintptr_t  boundary
A size value of zero will return a unique address which may be freed with _Heap_Free().
Parameters
[in,out]heapThe heap to allocate a memory are from.
sizeThe size of the desired memory are in bytes.
alignmentThe allocated memory area will begin at an address aligned by this value.
boundaryThe allocated memory area will fulfill a boundary constraint, if this value is not equal to zero. The boundary value specifies the set of addresses which are aligned by the boundary value. The interior of the allocated memory area will not contain an element of this set. The begin or end address of the area may be a member of the set.
Return values
pointerThe starting address of the allocated memory area.
NULLNo memory is available of the parameters are inconsistent.
◆ _Heap_Block_allocate()
Heap_Block * _Heap_Block_allocate ( Heap_Control heap,
Heap_Block block,
The block may be split up into multiple blocks. The previous and next block may be used or free. Free block parts which form a vaild new block will be inserted into the free list or merged with an adjacent free block. If the block is used, they will be inserted after the free list head. If the block is free, they will be inserted after the previous block in the free list.
Inappropriate values for alloc_begin or alloc_size may corrupt the heap.
Parameters
[in,out]heapThe heap to operate upon.
blockThe block in which the memory area should be allocated
alloc_beginThe starting address of the memory area that shall be allocated.
alloc_sizeThe size of the desired allocated area in bytes.
Returns
The block containing the allocated memory area.
◆ _Heap_Extend()
uintptr_t _Heap_Extend ( Heap_Control heap,
void *  area_begin,
uintptr_t  unused
There are no alignment requirements for the memory area. The memory area must be big enough to contain some maintenance blocks. It must not overlap parts of the current heap memory areas. Disconnected memory areas added to the heap will lead to used blocks which cover the gaps. Extending with an inappropriate memory area will corrupt the heap resulting in undefined behaviour.
Parameters
[in,out]heapThe heap to extend.
[out]area_beginThe start address of the area to extend the heap with.
area_sizeThe size of the area in bytes.
unusedIs not used, only provided to have the same signature as _Heap_Initialize().
Return values
some_valueThe extended space available for allocation after successful extension.
0The heap extension failed.
See also
Heap_Initialization_or_extend_handler.
◆ _Heap_Free()
bool _Heap_Free ( Heap_Control heap,
void *  addr
Inappropriate values for addr may corrupt the heap.
Parameters
[in,out]heapThe heap of the allocated memory area.
addrThe starting address of the memory area to be freed.
Return values
trueThe allocated memory area was successfully freed.
falseThe method failed.
◆ _Heap_Get_first_and_last_block()
bool _Heap_Get_first_and_last_block ( uintptr_t  heap_area_begin,
Heap_Block **  first_block_ptr,
Heap_Block **  last_block_ptr
Nothing will be written to this area.
Parameters
heap_area_beginThe starting address of the heap area.
heap_area_sizeThe size of the heap area.
page_sizeThe page size for the calculation.
min_block_sizeThe minimal block size for the calculation.
[out]first_block_ptrThe pointer to the first block in the case of success
[out]last_block_ptrThe pointer to the last block in the case of success
Return values
trueThe area is big enough.
falseThe area is not big enough.
◆ _Heap_Get_free_information()
void _Heap_Get_free_information ( Heap_Control heap,
Heap_Information info
Parameters
heapThe heap to get the information from.
[out]infoStores the information about free blocks of heap after the method call.
◆ _Heap_Get_information()
void _Heap_Get_information ( Heap_Control heap,
Heap_Information_block info
Parameters
[out]infoStores the information of the heap after the method call.
◆ _Heap_Greedy_allocate()
Heap_Block * _Heap_Greedy_allocate ( Heap_Control heap,
const uintptr_t *  block_sizes,
size_t  block_count
Afterwards, the heap has at most block_count allocatable blocks of sizes specified by block_sizes. All other blocks are used.
Parameters
block_sizesThe sizes of the allocatable blocks. Must point to an array with block_count members.
block_countThe maximum number of allocatable blocks of sizes specified by @block_sizes.
Returns
Pointer to the first allocated block.
See also
◆ _Heap_Greedy_allocate_all_except_largest()
Heap_Block * _Heap_Greedy_allocate_all_except_largest ( Heap_Control heap,
uintptr_t *  allocatable_size
Afterwards the heap has at most one allocatable block. This block is the largest free block if it exists. All other blocks are used.
Parameters
[out]allocatable_sizeStores the size of the largest free block of the heap after the method call.
Returns
See also
◆ _Heap_Greedy_free()
void _Heap_Greedy_free ( Heap_Control heap,
Heap_Block blocks
Parameters
blocksMust be the return value of _Heap_Greedy_allocate().
◆ _Heap_Initialize()
uintptr_t _Heap_Initialize ( Heap_Control heap,
void *  area_begin,
uintptr_t  page_size
Blocks of memory are allocated from the heap in multiples of page_size byte units. If the page_size is equal to zero or is not multiple of CPU_ALIGNMENT, it is aligned up to the nearest CPU_ALIGNMENT boundary.
Parameters
[out]heapThe heap control block to manage the area.
area_beginThe starting address of the area.
Return values
some_valueThe maximum memory available.
0The initialization failed.
See also
◆ _Heap_Iterate()
void _Heap_Iterate ( Heap_Control heap,
void *  visitor_arg
Parameters
[in,out]heapThe heap to iterate over.
visitorThis will be called for each heap block with the argument visitor_arg.
[in,out]visitor_argThe argument for all calls of visitor.
◆ _Heap_No_extend()
uintptr_t _Heap_No_extend ( Heap_Control unused_0,
void *  unused_1,
uintptr_t  unused_2,
uintptr_t  unused_3
This function only returns zero and does nothing else.
Parameters
unused_0This parameter does nothing.
unused_1This parameter does nothing.
unused_2This parameter does nothing.
unused_3This parameter does nothing.
See also
◆ _Heap_Resize_block()
Heap_Resize_status _Heap_Resize_block ( Heap_Control heap,
void *  addr,
uintptr_t  size,
uintptr_t *  old_size,
uintptr_t *  new_size
Parameters
addrThe starting address of the allocated memory area to be resized.
sizeThe least possible size for the new memory area. Resize may be impossible and depends on the current heap usage.
[out]old_sizeStores the size available for allocation in the current block before the resize after the method call.
[out]new_sizeStores the size available for allocation in the resized block after the method call. In the case of an unsuccessful resize, zero is returned in this parameter
Return values
HEAP_RESIZE_SUCCESSFULThe resize was successful.
HEAP_RESIZE_UNSATISFIEDThe least possible size size was too big. Resize not possible.
HEAP_RESIZE_FATAL_ERRORThe block starting at addr is not part of the heap.
◆ _Heap_Size_of_alloc_area()
bool _Heap_Size_of_alloc_area ( Heap_Control heap,
void *  addr,
uintptr_t *  size
The size value may be greater than the initially requested size in _Heap_Allocate_aligned_with_boundary().
Inappropriate values for addr will not corrupt the heap, but may yield invalid size values.
Parameters
addrThe starting address of the allocatable memory area.
[out]sizeStores the size of the allocatable memory area after the method call.
Return values
trueThe operation was successful.
falseThe operation was not successful.
◆ _Heap_Walk()
bool _Heap_Walk ( Heap_Control heap,
int  source,
bool  dump
Walks the heap to verify its integrity.
Parameters
heapThe heap whose integrity is to be verified.
sourceIf dump is true, this is used to mark the output lines.
dumpIndicates whether diagnostic messages will be printed to standard output.
Return values
trueNo errors occurred, the heap“s integrity is not violated.
falseThe heap is corrupt.
