RTEMS 6.2
Data Structures | Macros | Typedefs | Enumerations | Functions
heap.h File Reference
This header file provides interfaces of the Heap Handler which are used by the implementation and the Application Configuration. More...
#include <rtems/score/cpu.h>
#include <rtems/score/heapinfo.h>
struct  Heap_Error_context
 Context of a heap error. More...
struct  Heap_Block
 Description for free or used blocks. More...
struct  Heap_Control
 Control block used to manage a heap. More...
struct  Heap_Area
 Heap area structure for table based heap initialization and extension. More...
#define HEAP_PROTECTION_HEADER_SIZE   0
#define HEAP_BLOCK_HEADER_SIZE    (2 * sizeof(uintptr_t) + HEAP_PROTECTION_HEADER_SIZE)
 The block header consists of the two size fields (Heap_Block::prev_size and Heap_Block::size_and_flag).
typedef struct Heap_Control Heap_Control
typedef struct Heap_Block Heap_Block
typedef uintptr_t(* Heap_Initialization_or_extend_handler) (Heap_Control *heap, void *area_begin, uintptr_t area_size, uintptr_t page_size_or_unused)
 Heap initialization and extend handler type.
enum  Heap_Error_reason {
  HEAP_ERROR_BROKEN_PROTECTOR , HEAP_ERROR_FREE_PATTERN , HEAP_ERROR_DOUBLE_FREE , HEAP_ERROR_BAD_USED_BLOCK ,
  HEAP_ERROR_BAD_FREE_BLOCK
 The heap error reason. More...
uintptr_t _Heap_Extend (Heap_Control *heap, void *area_begin, uintptr_t area_size, uintptr_t unused)
 Extends the memory available for the heap.
uintptr_t _Heap_No_extend (Heap_Control *unused_0, void *unused_1, uintptr_t unused_2, uintptr_t unused_3)
 This function returns always zero.
