RTEMS 6.2
Application Configuration
The application configuration defines system parameters according to configuration options (defines) provided by the application. More...
file  bdbuf.h
 This header file evaluates configuration options related to the block device cache configuration.
file  bsp.h
 This header file evaluates configuration options related to the BSP configuration.
file  clock.h
 This header file evaluates configuration options related to the clock driver configuration.
file  console.h
 This header file evaluates configuration options related to the console driver configuration.
file  extensions.h
 This header file evaluates configuration options related to the user extensions configuration.
file  face.h
 This header file evaluates configuration options related to the FACE Technical Standard.
file  inittask.h
 This header file evaluates configuration options related to the Classic API initialization task configuration.
file  initthread.h
 This header file evaluates configuration options related to the POSIX initialization thread configuration.
file  iodrivers.h
 This header file evaluates configuration options related to the I/O driver configuration.
file  libio.h
 This header file evaluates configuration options related to the I/O library configuration.
file  libpci.h
 This header file evaluates configuration options related to the PCI library configuration.
file  malloc.h
 This header file evaluates configuration options related to the C Program Heap configuration.
file  mpci.h
 This header file evaluates configuration options related to the MPCI configuration.
file  newlib.h
 This header file evaluates configuration options related to the Newlib C Library configuration.
file  objectsclassic.h
 This header file evaluates configuration options related to the Classic API objects configuration.
file  objectsposix.h
 This header file evaluates configuration options related to the POSIX API objects configuration.
file  obsolete.h
 This header file evaluates configuration options related to obsolete configuration options.
file  percpu.h
 This header file evaluates configuration options related to the per-CPU configuration.
file  scheduler.h
 This header file evaluates configuration options related to the scheduler configuration.
file  threads.h
 This header file evaluates configuration options related to the thread configuration.
file  unlimited.h
 This header file evaluates configuration options related to the unlimited objects configuration.
file  wkspace.h
 This header file evaluates configuration options related to the RTEMS Workspace configuration.
file  wkspacesupport.h
 This header file provides support macros to evaluate configuration options related to the RTEMS Workspace configuration.
