RTEMS 6.1
stm32h7xx_hal_timebase_tim_template.c File Reference
HAL time base based on the hardware TIM. More...
#include "stm32h7xx_hal.h"
void TIM6_DAC_IRQHandler (void)
 This function handles TIM interrupt request.
HAL_StatusTypeDef HAL_InitTick (uint32_t TickPriority)
 This function configures the TIM6 as a time base source. The time source is configured to have 1ms time base with a dedicated Tick interrupt priority.
void HAL_SuspendTick (void)
 Suspend Tick increment.
void HAL_ResumeTick (void)
 Resume Tick increment.
void HAL_TIM_PeriodElapsedCallback (TIM_HandleTypeDef *htim)
 Period elapsed callback in non blocking mode.
Author
MCD Application Team
     This file overrides the native HAL time base functions (defined as weak)
     the TIM time base:
      + Initializes the TIM peripheral generate a Period elapsed Event each 1ms
      + HAL_IncTick is called inside HAL_TIM_PeriodElapsedCallback ie each 1ms
Attention
                       ##### How to use this driver #####
   This file must be copied to the application folder and modified as follows:
   (#) Rename it to 'stm32h7xx_hal_timebase_tim.c'
   (#) Add this file and the TIM HAL drivers to your project and uncomment
      HAL_TIM_MODULE_ENABLED define in stm32h7xx_hal_conf.h
◆ HAL_InitTick()
HAL_StatusTypeDef HAL_InitTick ( uint32_t  TickPriority)
Note
This function is called automatically at the beginning of program after reset by HAL_Init() or at any time when clock is configured, by HAL_RCC_ClockConfig().
Parameters
TickPriorityTick interrupt priority.
Return values
HALstatus
◆ TIM6_DAC_IRQHandler()
void TIM6_DAC_IRQHandler ( void  )
Parameters
None
Return values
None
