RTEMS 6.1
- _ -
- __pad0__ : tlb.h, tte.h
- __pad1__ : tte.h
- _AArch32_PMSA_Section_count : pmsa-sections.c, aarch32-pmsa.h
- _AArch32_PMSA_Sections : pmsa-sections.c, aarch32-pmsa.h
- _Barrier_Information : barrierdata.h
- _Base64_Decoding : base64-decode.c, base64.h
- _Base64_Encoding : base64-encode.c, base64.h
- _Base64url_Encoding : base64-encode.c, base64.h
- _binary_appstart_bin_start : smp-imps.h
- _Bitfield_Leading_zeros : prioritybitmapimpl.h, log2table.c
- _Copyright_Notice : copyrt.h
- _CORE_barrier_Thread_queue_operations : corebarrierimpl.h, corebarrierwait.c
- _CPU_Null_fp_context : cpu.h, cpu.c, cpu.h
- _CPU_Trap_slot_template : cpu.h, sparc-isr-install.c, cpu.c, cpu.h
- _Dual_ported_memory_Information : dpmemdata.h
- _Extension_Information : extensiondata.h
- _ISR_Stack_area_begin : isr.h
- _ISR_Stack_area_end : isr.h
- _ISR_Stack_size_object : isr.h, isr.c
- _Memory_Noinit_begin : memory.h
- _Memory_Noinit_end : memory.h
- _Memory_Zero_before_use : memory.h, memoryzerobeforeuse.c
- _Message_queue_Information : messagedata.h
- _MPCI_Configuration : mpci.h, mpcidefault.c
- _MPCI_Packet_processors : mpciimpl.h, mpci.c
- _MPCI_Receive_server_stack : mpci.h
- _MPCI_Receive_server_tcb : mpciimpl.h, mpci.c
- _MPCI_Remote_blocked_threads : mpciimpl.h, mpci.c
- _MPCI_Semaphore : mpci.c
- _MPCI_table : mpciimpl.h, mpci.c
- _Nios2_ISR_Status_bits : nios2-utility.h
- _Nios2_ISR_Status_mask : nios2-utility.h
- _Objects_Information_table : objectimpl.h
- _Objects_MP_Maximum_global_objects : objectmp.h, objectmp.c
- _Partition_Information : partdata.h
- _Per_CPU_Information : percpu.h, asm.h, percpu.c
- _POSIX_Condition_variables_Default_attributes : condimpl.h, conddefaultattributes.c
- _POSIX_Keys_Information : key.h
- _POSIX_Keys_Key_value_pair_maximum : key.h
- _POSIX_Keys_Key_value_pairs : key.h
- _POSIX_Keys_Keypool : keyimpl.h, keycreate.c
- _POSIX_Message_queue_Information : mqueue.h
- _POSIX_Mutex_Default_attributes : muteximpl.h, mutexinit.c
- _POSIX_Semaphore_Information : semaphore.h
- _POSIX_Shm_Information : shm.h
- _POSIX_Threads_Default_attributes : pthreadattrimpl.h, pthreadattrdefault.c
- _POSIX_Threads_Information : pthread.h
- _POSIX_Threads_Sporadic_budget : pthreadimpl.h
- _POSIX_Threads_User_thread_table : pthread.h
- _POSIX_Timer_Information : timer.h
- _PPC_INTERRUPT_DISABLE_MASK : registers.h
- _Rate_monotonic_Information : ratemondata.h
- _Region_Information : regiondata.h
- _RTEMS_tasks_Information : tasksdata.h
- _RTEMS_tasks_User_task_config : tasksdata.h
- _RTEMS_tasks_User_task_table : tasksdata.h, taskinitdefault.c
- _RTEMS_version : rtems-version.c, copyrt.h
- _rtld_debug : rtl.h, rtl-debugger.c
- _Scheduler_CBS_Budget : schedulercbs.h, schedulercbs.c
- _Scheduler_CBS_Maximum_servers : schedulercbs.h
- _Scheduler_CBS_Server_list : schedulercbs.h
- _Scheduler_Table : scheduler.h
- _Semaphore_Information : semdata.h
- _Stack_Allocator_allocate : stack.h, stackallocator.c
- _Stack_Allocator_allocate_for_idle : stack.h
- _Stack_Allocator_allocate_for_idle_storage_areas : stack.h
- _Stack_Allocator_allocate_for_idle_storage_size : stack.h
- _Stack_Allocator_avoids_workspace : stack.h, stackallocator.c
- _Stack_Allocator_free : stack.h, stackallocatorfree.c
- _Stack_Allocator_initialize : stack.h
- _Stack_Space_size : stack.h
- _Thread_Allocated_fp : threadimpl.h, threaddispatch.c
- _Thread_Control_add_on_count : thread.h
- _Thread_Control_add_ons : thread.h
- _Thread_CPU_budget_exhaust_timeslice : threadcpubudget.h, threadexhausttimeslice.c
- _Thread_CPU_budget_reset_timeslice : threadcpubudget.h, threadresettimeslice.c
- _Thread_Global_constructor : threadimpl.h, threadhandler.c
- _Thread_Idle_body : threadidledata.h, threadidledefault.c
- _Thread_Idle_stack_size : threadidledata.h
- _Thread_Information : thread.h
- _Thread_Initial_thread_count : thread.h
- _Thread_Maximum_name_size : thread.h
- _Thread_Maximum_TLS_size : thread.h
- _Thread_queue_Object_name : threadqimpl.h, threadq.c
- _Thread_queue_Operations_default : threadqimpl.h, threadqops.c
- _Thread_queue_Operations_FIFO : threadqimpl.h, threadqops.c
- _Thread_queue_Operations_priority : threadqimpl.h, threadqops.c
- _Thread_queue_Operations_priority_inherit : threadqimpl.h, threadqops.c
- _Thread_Zombies : threadimpl.h, threadrestart.c
- _Timecounter : timecounter.h
- _Timecounter_Time_second : timecounter.h
- _Timecounter_Time_uptime : timecounter.h
- _Timer_Information : timerdata.h
- _Timer_server : timerimpl.h, timercreate.c
- _TLS_Alignment : tlsallocsize.c
- _TLS_Configuration : tls.h, tlsallocsize.c
- _TOD : todimpl.h, coretod.c
- _TOD_Days_to_date : todimpl.h, clocktodtoseconds.c
- _TOD_Hooks : todimpl.h, coretodhookdata.c
- _User_extensions_Initial_count : userextdata.h
- _User_extensions_Initial_extensions : userextdata.h
- _User_extensions_Initial_switch_controls : userextdata.h
- _User_extensions_List : userextimpl.h, userextiterate.c
- _User_extensions_Switches_list : userextimpl.h
- _Watchdog_Microseconds_per_tick : watchdogticks.h
- _Watchdog_Nanoseconds_per_tick : watchdogticks.h
- _Watchdog_Ticks_per_second : watchdogticks.h
- _Watchdog_Ticks_per_timeslice : watchdogticks.h, watchdogtimeslicedefault.c
- _Watchdog_Ticks_since_boot : watchdogticks.h, watchdogtickssinceboot.c
- _Workspace_Area : wkspace.h, wkspace.c
- _Workspace_Is_unified : wkspacedata.h, wkspaceisunifieddefault.c
- _Workspace_Malloc_initializer : wkspacedata.h, wkspacemallocinitdefault.c
- _Workspace_Size : wkspacedata.h
