RTEMS 6.1
- o -
- O6_SP_OFFSET : cpu.h
- O7_OFFSET : cpu.h
- OB_BOOT_ADD0 : stm32h7xx_hal_flash_ex.h
- OB_BOOT_ADD1 : stm32h7xx_hal_flash_ex.h
- OB_BOOT_ADD_BOTH : stm32h7xx_hal_flash_ex.h
- OB_BOOTADDR_AXIM_FLASH : stm32h7xx_hal_flash_ex.h
- OB_BOOTADDR_DTCM_RAM : stm32h7xx_hal_flash_ex.h
- OB_BOOTADDR_ITCM_FLASH : stm32h7xx_hal_flash_ex.h
- OB_BOOTADDR_ITCM_RAM : stm32h7xx_hal_flash_ex.h
- OB_BOOTADDR_SRAM1 : stm32h7xx_hal_flash_ex.h
- OB_BOOTADDR_SRAM2 : stm32h7xx_hal_flash_ex.h
- OB_BOOTADDR_SYSTEM : stm32h7xx_hal_flash_ex.h
- OB_BOR_LEVEL0 : stm32h7xx_hal_flash_ex.h
- OB_BOR_LEVEL1 : stm32h7xx_hal_flash_ex.h
- OB_BOR_LEVEL2 : stm32h7xx_hal_flash_ex.h
- OB_BOR_LEVEL3 : stm32h7xx_hal_flash_ex.h
- OB_IOHSLV_DISABLE : stm32h7xx_hal_flash_ex.h
- OB_IOHSLV_ENABLE : stm32h7xx_hal_flash_ex.h
- OB_IWDG1_HW : stm32h7xx_hal_flash_ex.h
- OB_IWDG1_SW : stm32h7xx_hal_flash_ex.h
- OB_IWDG_HW : stm32h7xx_hal_flash_ex.h
- OB_IWDG_STDBY_ACTIVE : stm32h7xx_hal_flash_ex.h
- OB_IWDG_STDBY_FREEZE : stm32h7xx_hal_flash_ex.h
- OB_IWDG_STOP_ACTIVE : stm32h7xx_hal_flash_ex.h
- OB_IWDG_STOP_FREEZE : stm32h7xx_hal_flash_ex.h
- OB_IWDG_SW : stm32h7xx_hal_flash_ex.h
- OB_PCROP_RDP_ERASE : stm32h7xx_hal_flash_ex.h
- OB_PCROP_RDP_NOT_ERASE : stm32h7xx_hal_flash_ex.h
- OB_RDP_LEVEL_2 : stm32h7xx_hal_flash_ex.h
- OB_SECURE_RDP_ERASE : stm32h7xx_hal_flash_ex.h
- OB_SECURE_RDP_NOT_ERASE : stm32h7xx_hal_flash_ex.h
- OB_SECURITY_DISABLE : stm32h7xx_hal_flash_ex.h
- OB_SECURITY_ENABLE : stm32h7xx_hal_flash_ex.h
- OB_ST_RAM_SIZE_16KB : stm32h7xx_hal_flash_ex.h
- OB_ST_RAM_SIZE_2KB : stm32h7xx_hal_flash_ex.h
- OB_ST_RAM_SIZE_4KB : stm32h7xx_hal_flash_ex.h
- OB_ST_RAM_SIZE_8KB : stm32h7xx_hal_flash_ex.h
- OB_STDBY_NO_RST : stm32h7xx_hal_flash_ex.h
- OB_STDBY_NO_RST_D1 : stm32h7xx_hal_flash_ex.h
- OB_STDBY_RST : stm32h7xx_hal_flash_ex.h
- OB_STDBY_RST_D1 : stm32h7xx_hal_flash_ex.h
- OB_STOP_NO_RST : stm32h7xx_hal_flash_ex.h
- OB_STOP_NO_RST_D1 : stm32h7xx_hal_flash_ex.h
- OB_STOP_RST : stm32h7xx_hal_flash_ex.h
- OB_STOP_RST_D1 : stm32h7xx_hal_flash_ex.h
- OB_USER_IOHSLV : stm32h7xx_hal_flash_ex.h
- OB_USER_IWDG1_SW : stm32h7xx_hal_flash_ex.h
- OB_USER_IWDG_STDBY : stm32h7xx_hal_flash_ex.h
- OB_USER_IWDG_STOP : stm32h7xx_hal_flash_ex.h
- OB_USER_NRST_STDBY_D1 : stm32h7xx_hal_flash_ex.h
- OB_USER_NRST_STOP_D1 : stm32h7xx_hal_flash_ex.h
- OB_USER_SECURITY : stm32h7xx_hal_flash_ex.h
- OB_USER_ST_RAM_SIZE : stm32h7xx_hal_flash_ex.h
- OB_WRP_SECTOR_0 : stm32h7xx_hal_flash_ex.h
- OB_WRP_SECTOR_1 : stm32h7xx_hal_flash_ex.h
- OB_WRP_SECTOR_2 : stm32h7xx_hal_flash_ex.h
- OB_WRP_SECTOR_3 : stm32h7xx_hal_flash_ex.h
- OB_WRP_SECTOR_4 : stm32h7xx_hal_flash_ex.h
- OB_WRP_SECTOR_5 : stm32h7xx_hal_flash_ex.h
- OB_WRP_SECTOR_6 : stm32h7xx_hal_flash_ex.h
- OB_WRP_SECTOR_7 : stm32h7xx_hal_flash_ex.h
- OB_WRP_SECTOR_ALL : stm32h7xx_hal_flash_ex.h
- OB_WRPSTATE_DISABLE : stm32h7xx_hal_flash_ex.h
- OB_WRPSTATE_ENABLE : stm32h7xx_hal_flash_ex.h
- OBJECT_NAME : tx-support.h
- OBJECTS_API_MASK : object.h
- OBJECTS_API_START_BIT : object.h
- OBJECTS_API_VALID_BITS : object.h
- OBJECTS_APIS_LAST : object.h
- OBJECTS_CLASS_MASK : object.h
- OBJECTS_CLASS_START_BIT : object.h
- OBJECTS_CLASS_VALID_BITS : object.h
- OBJECTS_ID_FINAL : object.h
- OBJECTS_ID_FINAL_INDEX : object.h
- OBJECTS_ID_INITIAL : object.h
- OBJECTS_ID_INITIAL_INDEX : object.h
- OBJECTS_ID_NONE : object.h
- OBJECTS_ID_OF_SELF : object.h
- OBJECTS_INDEX_MASK : object.h
- OBJECTS_INDEX_MINIMUM : objectimpl.h
- OBJECTS_INDEX_START_BIT : object.h
- OBJECTS_INDEX_VALID_BITS : object.h
- OBJECTS_INFORMATION_DEFINE : objectdata.h
- OBJECTS_INFORMATION_DEFINE_ZERO : objectdata.h
- OBJECTS_INTERNAL_CLASSES_LAST : objectimpl.h
- OBJECTS_NO_STRING_NAME : objectdata.h
- OBJECTS_NODE_MASK : object.h
- OBJECTS_NODE_START_BIT : object.h
- OBJECTS_NODE_VALID_BITS : object.h
- OBJECTS_POSIX_CLASSES_LAST : objectimpl.h
- OBJECTS_RTEMS_CLASSES_LAST : objectimpl.h
- OBJECTS_SEARCH_ALL_NODES : object.h
- OBJECTS_SEARCH_LOCAL_NODE : object.h
- OBJECTS_SEARCH_OTHER_NODES : object.h
- OBJECTS_UNLIMITED_OBJECTS : object.h
- OBJECTS_WHO_AM_I : object.h
- OCOTP : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_ANA0_BITS : MIMXRT1052.h
- OCOTP_ANA1_BITS : MIMXRT1052.h
- OCOTP_ANA2_BITS : MIMXRT1052.h
- OCOTP_BASE : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_BASE_ADDRS : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_BASE_PTRS : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_CFG0_BITS : MIMXRT1052.h
- OCOTP_CFG1_BITS : MIMXRT1052.h
- OCOTP_CFG2_BITS : MIMXRT1052.h
- OCOTP_CFG3_BITS : MIMXRT1052.h
- OCOTP_CFG4_BITS : MIMXRT1052.h
- OCOTP_CFG5_BITS : MIMXRT1052.h
- OCOTP_CFG6_BITS : MIMXRT1052.h
- OCOTP_CLOCKS : fsl_clock.h
- OCOTP_CTRL_ADDR : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_CTRL_BUSY : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_CTRL_CLR_ADDR : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_CTRL_CLR_BUSY : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_CTRL_CLR_ERROR : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_CTRL_CLR_RELOAD_SHADOWS : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_CTRL_CLR_WORDLOCK : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_CTRL_CLR_WR_UNLOCK : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_CTRL_ERROR : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_CTRL_RELOAD_SHADOWS : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_CTRL_SET_ADDR : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_CTRL_SET_BUSY : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_CTRL_SET_ERROR : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_CTRL_SET_RELOAD_SHADOWS : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_CTRL_SET_WORDLOCK : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_CTRL_SET_WR_UNLOCK : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_CTRL_TOG_ADDR : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_CTRL_TOG_BUSY : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_CTRL_TOG_ERROR : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_CTRL_TOG_RELOAD_SHADOWS : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_CTRL_TOG_WORDLOCK : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_CTRL_TOG_WR_UNLOCK : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_CTRL_WORDLOCK : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_CTRL_WR_UNLOCK : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_DATA_DATA : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_FUSE_BITS : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_GP1_BITS : MIMXRT1052.h
- OCOTP_GP2_BITS : MIMXRT1052.h
- OCOTP_GP3_BITS : MIMXRT1052.h
- OCOTP_LOCK_ANALOG : MIMXRT1052.h
- OCOTP_LOCK_BOOT_CFG : MIMXRT1052.h
- OCOTP_LOCK_FIELD_RETURN : MIMXRT1052.h
- OCOTP_LOCK_GP1 : MIMXRT1052.h
- OCOTP_LOCK_GP2 : MIMXRT1052.h
- OCOTP_LOCK_GP3 : MIMXRT1052.h
- OCOTP_LOCK_MAC_ADDR : MIMXRT1052.h
- OCOTP_LOCK_MISC_CONF : MIMXRT1052.h
- OCOTP_LOCK_SJC_RESP : MIMXRT1052.h
- OCOTP_LOCK_SW_GP1 : MIMXRT1052.h
- OCOTP_LOCK_SW_GP2_LOCK : MIMXRT1052.h
- OCOTP_LOCK_SW_GP2_RLOCK : MIMXRT1052.h
- OCOTP_MAC0_BITS : MIMXRT1052.h
- OCOTP_MAC1_BITS : MIMXRT1052.h
- OCOTP_MEM0_BITS : MIMXRT1052.h
- OCOTP_MEM1_BITS : MIMXRT1052.h
- OCOTP_MEM2_BITS : MIMXRT1052.h
- OCOTP_MEM3_BITS : MIMXRT1052.h
- OCOTP_MEM4_BITS : MIMXRT1052.h
- OCOTP_MISC_CONF0_BITS : MIMXRT1052.h
- OCOTP_MISC_CONF1_BITS : MIMXRT1052.h
- OCOTP_OUT_STATUS_ACK : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_CALIBRATED : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_CLR_ACK : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_CLR_CALIBRATED : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_CLR_DED : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_CLR_DED0 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_CLR_DED1 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_CLR_DED2 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_CLR_DED3 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_CLR_DED_RELOAD : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_CLR_FLAGSTATE : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_CLR_LOCKED : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_CLR_PROGFAIL : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_CLR_PWOK : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_CLR_READ_DONE_INTR : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_CLR_READ_ERROR_INTR : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_CLR_SEC : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_CLR_SEC_RELOAD : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_DED : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_DED0 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_DED1 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_DED2 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_DED3 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_DED_RELOAD : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_FLAGSTATE : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_LOCKED : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_PROGFAIL : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_PWOK : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_READ_DONE_INTR : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_READ_ERROR_INTR : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_SEC : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_SEC_RELOAD : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_SET_ACK : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_SET_CALIBRATED : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_SET_DED : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_SET_DED0 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_SET_DED1 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_SET_DED2 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_SET_DED3 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_SET_DED_RELOAD : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_SET_FLAGSTATE : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_SET_LOCKED : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_SET_PROGFAIL : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_SET_PWOK : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_SET_READ_DONE_INTR : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_SET_READ_ERROR_INTR : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_SET_SEC : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_SET_SEC_RELOAD : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_TOG_ACK : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_TOG_CALIBRATED : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_TOG_DED : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_TOG_DED0 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_TOG_DED1 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_TOG_DED2 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_TOG_DED3 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_TOG_DED_RELOAD : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_TOG_FLAGSTATE : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_TOG_LOCKED : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_TOG_PROGFAIL : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_TOG_PWOK : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_TOG_READ_DONE_INTR : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_TOG_READ_ERROR_INTR : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_TOG_SEC : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_OUT_STATUS_TOG_SEC_RELOAD : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_PDN_PDN : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_READ_CTRL_READ_FUSE : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_READ_CTRL_READ_FUSE_CNTR : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_READ_CTRL_READ_FUSE_DONE_INTR_ENA : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_READ_CTRL_READ_FUSE_ERROR_INTR_ENA : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_READ_FUSE_DATA_DATA : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_SCS_CLR_HAB_JDE : MIMXRT1052.h
- OCOTP_SCS_CLR_LOCK : MIMXRT1052.h
- OCOTP_SCS_CLR_SPARE : MIMXRT1052.h
- OCOTP_SCS_HAB_JDE : MIMXRT1052.h
- OCOTP_SCS_LOCK : MIMXRT1052.h
- OCOTP_SCS_SET_HAB_JDE : MIMXRT1052.h
- OCOTP_SCS_SET_LOCK : MIMXRT1052.h
- OCOTP_SCS_SET_SPARE : MIMXRT1052.h
- OCOTP_SCS_SPARE : MIMXRT1052.h
- OCOTP_SCS_TOG_HAB_JDE : MIMXRT1052.h
- OCOTP_SCS_TOG_LOCK : MIMXRT1052.h
- OCOTP_SCS_TOG_SPARE : MIMXRT1052.h
- OCOTP_SJC_RESP0_BITS : MIMXRT1052.h
- OCOTP_SJC_RESP1_BITS : MIMXRT1052.h
- OCOTP_SRK0_BITS : MIMXRT1052.h
- OCOTP_SRK1_BITS : MIMXRT1052.h
- OCOTP_SRK2_BITS : MIMXRT1052.h
- OCOTP_SRK3_BITS : MIMXRT1052.h
- OCOTP_SRK4_BITS : MIMXRT1052.h
- OCOTP_SRK5_BITS : MIMXRT1052.h
- OCOTP_SRK6_BITS : MIMXRT1052.h
- OCOTP_SRK7_BITS : MIMXRT1052.h
- OCOTP_SRK_REVOKE_BITS : MIMXRT1052.h
- OCOTP_SW_GP1_BITS : MIMXRT1052.h
- OCOTP_SW_GP20_BITS : MIMXRT1052.h
- OCOTP_SW_GP21_BITS : MIMXRT1052.h
- OCOTP_SW_GP22_BITS : MIMXRT1052.h
- OCOTP_SW_GP23_BITS : MIMXRT1052.h
- OCOTP_SW_STICKY_FIELD_RETURN_LOCK : MIMXRT1052.h
- OCOTP_SW_STICKY_SRK_REVOKE_LOCK : MIMXRT1052.h
- OCOTP_TIMING2_RELAX_PROG : MIMXRT1052.h
- OCOTP_TIMING2_RELAX_READ : MIMXRT1052.h
- OCOTP_TIMING_RELAX : MIMXRT1052.h
- OCOTP_TIMING_STROBE_PROG : MIMXRT1052.h
- OCOTP_TIMING_STROBE_READ : MIMXRT1052.h
- OCOTP_TIMING_WAIT : MIMXRT1052.h
- OCOTP_VERSION_MAJOR : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_VERSION_MINOR : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCOTP_VERSION_STEP : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OCRAM_EXSC_CLOCKS : fsl_clock.h
- OCTOSPI1_BASE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI2_BASE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_ABR_ALTERNATE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_ABR_ALTERNATE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_AR_ADDRESS : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_AR_ADDRESS_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_ABDTR : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_ABDTR_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_ABMODE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_ABMODE_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_ABMODE_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_ABMODE_2 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_ABMODE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_ABSIZE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_ABSIZE_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_ABSIZE_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_ABSIZE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_ADDTR : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_ADDTR_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_ADMODE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_ADMODE_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_ADMODE_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_ADMODE_2 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_ADMODE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_ADSIZE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_ADSIZE_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_ADSIZE_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_ADSIZE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_DDTR : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_DDTR_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_DMODE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_DMODE_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_DMODE_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_DMODE_2 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_DMODE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_DQSE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_DQSE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_IDTR : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_IDTR_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_IMODE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_IMODE_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_IMODE_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_IMODE_2 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_IMODE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_ISIZE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_ISIZE_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_ISIZE_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_ISIZE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_SIOO : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CCR_SIOO_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_ABORT : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_ABORT_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_APMS : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_APMS_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_DMAEN : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_DMAEN_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_DQM : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_DQM_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_EN : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_EN_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_FMODE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_FMODE_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_FMODE_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_FMODE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_FSEL : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_FSEL_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_FTHRES : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_FTHRES_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_FTIE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_FTIE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_PMM : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_PMM_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_SMIE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_SMIE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_TCEN : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_TCEN_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_TCIE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_TCIE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_TEIE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_TEIE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_TOIE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_CR_TOIE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR1_CKCSHT : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR1_CKCSHT_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR1_CKMODE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR1_CKMODE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR1_CSHT : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR1_CSHT_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR1_DEVSIZE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR1_DEVSIZE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR1_DLYBYP : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR1_DLYBYP_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR1_FRCK : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR1_FRCK_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR1_MTYP : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR1_MTYP_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR1_MTYP_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR1_MTYP_2 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR1_MTYP_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR2_PRESCALER : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR2_PRESCALER_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR2_WRAPSIZE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR2_WRAPSIZE_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR2_WRAPSIZE_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR2_WRAPSIZE_2 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR2_WRAPSIZE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR3_CSBOUND : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR3_CSBOUND_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR3_MAXTRAN : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR3_MAXTRAN_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR4_REFRESH : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DCR4_REFRESH_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DLR_DL : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DLR_DL_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DR_DATA : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_DR_DATA_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_FCR_CSMF : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_FCR_CSMF_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_FCR_CTCF : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_FCR_CTCF_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_FCR_CTEF : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_FCR_CTEF_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_FCR_CTOF : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_FCR_CTOF_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_HLCR_LM : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_HLCR_LM_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_HLCR_TACC : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_HLCR_TACC_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_HLCR_TRWR : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_HLCR_TRWR_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_HLCR_WZL : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_HLCR_WZL_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_ID_ID : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_ID_ID_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_IR_INSTRUCTION : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_IR_INSTRUCTION_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_LPTR_TIMEOUT : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_LPTR_TIMEOUT_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_MID_MID : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_MID_MID_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_PIR_INTERVAL : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_PIR_INTERVAL_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_PSMAR_MATCH : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_PSMAR_MATCH_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_PSMKR_MASK : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_PSMKR_MASK_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_SR_BUSY : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_SR_BUSY_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_SR_FLEVEL : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_SR_FLEVEL_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_SR_FTF : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_SR_FTF_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_SR_SMF : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_SR_SMF_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_SR_TCF : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_SR_TCF_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_SR_TEF : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_SR_TEF_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_SR_TOF : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_SR_TOF_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_TCR_DCYC : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_TCR_DCYC_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_TCR_DHQC : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_TCR_DHQC_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_TCR_SSHIFT : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_TCR_SSHIFT_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_VER_VER : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_VER_VER_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WABR_ALTERNATE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WABR_ALTERNATE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_ABDTR : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_ABDTR_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_ABMODE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_ABMODE_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_ABMODE_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_ABMODE_2 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_ABMODE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_ABSIZE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_ABSIZE_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_ABSIZE_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_ABSIZE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_ADDTR : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_ADDTR_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_ADMODE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_ADMODE_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_ADMODE_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_ADMODE_2 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_ADMODE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_ADSIZE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_ADSIZE_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_ADSIZE_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_ADSIZE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_DDTR : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_DDTR_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_DMODE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_DMODE_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_DMODE_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_DMODE_2 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_DMODE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_DQSE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_DQSE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_IDTR : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_IDTR_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_IMODE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_IMODE_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_IMODE_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_IMODE_2 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_IMODE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_ISIZE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_ISIZE_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_ISIZE_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_ISIZE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_SIOO : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WCCR_SIOO_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WIR_INSTRUCTION : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WIR_INSTRUCTION_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPABR_ALTERNATE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPABR_ALTERNATE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_ABDTR : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_ABDTR_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_ABMODE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_ABMODE_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_ABMODE_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_ABMODE_2 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_ABMODE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_ABSIZE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_ABSIZE_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_ABSIZE_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_ABSIZE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_ADDTR : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_ADDTR_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_ADMODE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_ADMODE_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_ADMODE_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_ADMODE_2 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_ADMODE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_ADSIZE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_ADSIZE_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_ADSIZE_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_ADSIZE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_DDTR : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_DDTR_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_DMODE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_DMODE_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_DMODE_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_DMODE_2 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_DMODE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_DQSE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_DQSE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_IDTR : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_IDTR_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_IMODE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_IMODE_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_IMODE_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_IMODE_2 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_IMODE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_ISIZE : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_ISIZE_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_ISIZE_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_ISIZE_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_SIOO : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPCCR_SIOO_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPIR_INSTRUCTION : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPIR_INSTRUCTION_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPTCR_DCYC : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPTCR_DCYC_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPTCR_DHQC : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPTCR_DHQC_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPTCR_SSHIFT : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WPTCR_SSHIFT_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WTCR_DCYC : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPI_WTCR_DCYC_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPIM_BASE : stm32h723xx.h, stm32h725xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPIM_CR_MUXEN : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPIM_CR_MUXEN_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPIM_CR_REQ2ACK_TIME : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPIM_CR_REQ2ACK_TIME_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPIM_PCR_CLKEN : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPIM_PCR_CLKEN_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPIM_PCR_CLKSRC : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPIM_PCR_CLKSRC_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPIM_PCR_DQSEN : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPIM_PCR_DQSEN_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPIM_PCR_DQSSRC : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPIM_PCR_DQSSRC_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPIM_PCR_IOHEN : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPIM_PCR_IOHEN_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPIM_PCR_IOHSRC : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPIM_PCR_IOHSRC_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPIM_PCR_IOHSRC_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPIM_PCR_IOHSRC_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPIM_PCR_IOLEN : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPIM_PCR_IOLEN_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPIM_PCR_IOLSRC : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPIM_PCR_IOLSRC_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPIM_PCR_IOLSRC_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPIM_PCR_IOLSRC_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPIM_PCR_NCSEN : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPIM_PCR_NCSEN_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPIM_PCR_NCSSRC : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OCTOSPIM_PCR_NCSSRC_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- ODD_PARITY : bsp.h
- OE : uart.h
- ONFI_CMD_BLK_ERASE1 : xnandpsu_onfi.h
- ONFI_CMD_BLK_ERASE2 : xnandpsu_onfi.h
- ONFI_CMD_BLK_ERASE_INTRLVD2 : xnandpsu_onfi.h
- ONFI_CMD_CHNG_RD_COL1 : xnandpsu_onfi.h
- ONFI_CMD_CHNG_RD_COL2 : xnandpsu_onfi.h
- ONFI_CMD_CHNG_RD_COL_ENHCD1 : xnandpsu_onfi.h
- ONFI_CMD_CHNG_RD_COL_ENHCD2 : xnandpsu_onfi.h
- ONFI_CMD_CHNG_ROW_ADDR : xnandpsu_onfi.h
- ONFI_CMD_CHNG_WR_COL : xnandpsu_onfi.h
- ONFI_CMD_CPBK_PROG1 : xnandpsu_onfi.h
- ONFI_CMD_CPBK_PROG2 : xnandpsu_onfi.h
- ONFI_CMD_CPBK_RD1 : xnandpsu_onfi.h
- ONFI_CMD_CPBK_RD2 : xnandpsu_onfi.h
- ONFI_CMD_GET_FEATURES : xnandpsu_onfi.h
- ONFI_CMD_INVALID : xnandpsu_onfi.h
- ONFI_CMD_LUN_GET_FEATURES : xnandpsu_onfi.h
- ONFI_CMD_LUN_SET_FEATURES : xnandpsu_onfi.h
- ONFI_CMD_MUL_BLK_ERASE1 : xnandpsu_onfi.h
- ONFI_CMD_MUL_BLK_ERASE2 : xnandpsu_onfi.h
- ONFI_CMD_MUL_CPBK_PROG1 : xnandpsu_onfi.h
- ONFI_CMD_MUL_CPBK_PROG2 : xnandpsu_onfi.h
- ONFI_CMD_MUL_PG_PROG1 : xnandpsu_onfi.h
- ONFI_CMD_MUL_PG_PROG2 : xnandpsu_onfi.h
- ONFI_CMD_MUL_RD1 : xnandpsu_onfi.h
- ONFI_CMD_MUL_RD2 : xnandpsu_onfi.h
- ONFI_CMD_ODT_CONF : xnandpsu_onfi.h
- ONFI_CMD_PG_CACHE_PROG1 : xnandpsu_onfi.h
- ONFI_CMD_PG_CACHE_PROG2 : xnandpsu_onfi.h
- ONFI_CMD_PG_PROG1 : xnandpsu_onfi.h
- ONFI_CMD_PG_PROG2 : xnandpsu_onfi.h
- ONFI_CMD_RD1 : xnandpsu_onfi.h
- ONFI_CMD_RD2 : xnandpsu_onfi.h
- ONFI_CMD_RD_CACHE_END : xnandpsu_onfi.h
- ONFI_CMD_RD_CACHE_RND1 : xnandpsu_onfi.h
- ONFI_CMD_RD_CACHE_RND2 : xnandpsu_onfi.h
- ONFI_CMD_RD_CACHE_SEQ : xnandpsu_onfi.h
- ONFI_CMD_RD_ID : xnandpsu_onfi.h
- ONFI_CMD_RD_PRM_PG : xnandpsu_onfi.h
- ONFI_CMD_RD_STS : xnandpsu_onfi.h
- ONFI_CMD_RD_STS_ENHCD : xnandpsu_onfi.h
- ONFI_CMD_RD_UNIQID : xnandpsu_onfi.h
- ONFI_CMD_RST : xnandpsu_onfi.h
- ONFI_CMD_RST_LUN : xnandpsu_onfi.h
- ONFI_CMD_SET_FEATURES : xnandpsu_onfi.h
- ONFI_CMD_SMALL_DATA_MV1 : xnandpsu_onfi.h
- ONFI_CMD_SMALL_DATA_MV2 : xnandpsu_onfi.h
- ONFI_CMD_SYN_RST : xnandpsu_onfi.h
- ONFI_CMD_VOL_SEL : xnandpsu_onfi.h
- ONFI_CRC_LEN : xnandpsu_onfi.h
- ONFI_MND_PRM_PGS : xnandpsu_onfi.h
- ONFI_PRM_PG_ADDR_CYCLES : xnandpsu_onfi.h
- ONFI_PRM_PG_LEN : xnandpsu_onfi.h
- ONFI_READ_ID_ADDR : xnandpsu_onfi.h
- ONFI_READ_ID_ADDR_CYCLES : xnandpsu_onfi.h
- ONFI_READ_ID_LEN : xnandpsu_onfi.h
- ONFI_SIG_LEN : xnandpsu_onfi.h
- ONFI_STS_ARDY : xnandpsu_onfi.h
- ONFI_STS_CSP : xnandpsu_onfi.h
- ONFI_STS_FAIL : xnandpsu_onfi.h
- ONFI_STS_FAILC : xnandpsu_onfi.h
- ONFI_STS_RDY : xnandpsu_onfi.h
- ONFI_STS_VSP : xnandpsu_onfi.h
- ONFI_STS_WP : xnandpsu_onfi.h
- OP_BLTZ : mips_opcode.h
- OPAMP1_CSR_CALON : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_CALON_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_CALOUT : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_CALOUT_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_CALSEL : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_CALSEL_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_CALSEL_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_CALSEL_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_FORCEVP : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_FORCEVP_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_OPAEN : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_OPAEN_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_OPAHSM : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_OPAHSM_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_PGGAIN : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_PGGAIN_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_PGGAIN_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_PGGAIN_2 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_PGGAIN_3 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_PGGAIN_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_TSTREF : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_TSTREF_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_USERTRIM : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_USERTRIM_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_VMSEL : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_VMSEL_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_VMSEL_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_VMSEL_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_VPSEL : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_VPSEL_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_VPSEL_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_CSR_VPSEL_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_HSOTR_TRIMHSOFFSETN : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_HSOTR_TRIMHSOFFSETN_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_HSOTR_TRIMHSOFFSETP : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_HSOTR_TRIMHSOFFSETP_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_OTR_TRIMOFFSETN : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_OTR_TRIMOFFSETN_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_OTR_TRIMOFFSETP : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP1_OTR_TRIMOFFSETP_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_CALON : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_CALON_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_CALOUT : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_CALOUT_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_CALSEL : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_CALSEL_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_CALSEL_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_CALSEL_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_FORCEVP : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_FORCEVP_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_OPAEN : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_OPAEN_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_OPAHSM : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_OPAHSM_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_PGGAIN : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_PGGAIN_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_PGGAIN_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_PGGAIN_2 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_PGGAIN_3 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_PGGAIN_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_TSTREF : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_TSTREF_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_USERTRIM : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_USERTRIM_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_VMSEL : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_VMSEL_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_VMSEL_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_VMSEL_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_VPSEL : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_VPSEL_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_VPSEL_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_CSR_VPSEL_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_HSOTR_TRIMHSOFFSETN : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_HSOTR_TRIMHSOFFSETN_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_HSOTR_TRIMHSOFFSETP : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_HSOTR_TRIMHSOFFSETP_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_OTR_TRIMOFFSETN : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_OTR_TRIMOFFSETN_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_OTR_TRIMOFFSETP : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP2_OTR_TRIMOFFSETP_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_CALON : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_CALON_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_CALOUT : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_CALOUT_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_CALSEL : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_CALSEL_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_CALSEL_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_CALSEL_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_FORCEVP : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_FORCEVP_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_OPAHSM : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_OPAHSM_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_OPAMPxEN : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_OPAMPxEN_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_PGGAIN : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_PGGAIN_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_PGGAIN_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_PGGAIN_2 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_PGGAIN_3 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_PGGAIN_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_TSTREF : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_TSTREF_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_USERTRIM : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_USERTRIM_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_VMSEL : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_VMSEL_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_VMSEL_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_VMSEL_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_VPSEL : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_VPSEL_0 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_VPSEL_1 : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_CSR_VPSEL_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_FACTORYTRIMMING_DUMMY : stm32h7xx_hal_opamp.h
- OPAMP_FACTORYTRIMMING_N : stm32h7xx_hal_opamp.h
- OPAMP_FACTORYTRIMMING_P : stm32h7xx_hal_opamp.h
- OPAMP_FOLLOWER_MODE : stm32h7xx_hal_opamp.h
- OPAMP_HSOTR_TRIMHSOFFSETN : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_HSOTR_TRIMHSOFFSETN_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_HSOTR_TRIMHSOFFSETP : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_HSOTR_TRIMHSOFFSETP_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_INPUT_NONINVERTING : stm32h7xx_hal_opamp.h
- OPAMP_INVERTINGINPUT_IO0 : stm32h7xx_hal_opamp.h
- OPAMP_INVERTINGINPUT_IO1 : stm32h7xx_hal_opamp.h
- OPAMP_NONINVERTINGINPUT_DAC_CH : stm32h7xx_hal_opamp.h
- OPAMP_NONINVERTINGINPUT_IO0 : stm32h7xx_hal_opamp.h
- OPAMP_OTR_TRIMOFFSETN : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_OTR_TRIMOFFSETN_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_OTR_TRIMOFFSETP : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_OTR_TRIMOFFSETP_Msk : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OPAMP_PGA_CONNECT_INVERTINGINPUT_IO0 : stm32h7xx_hal_opamp.h
- OPAMP_PGA_CONNECT_INVERTINGINPUT_IO0_BIAS : stm32h7xx_hal_opamp.h
- OPAMP_PGA_CONNECT_INVERTINGINPUT_IO0_IO1_BIAS : stm32h7xx_hal_opamp.h
- OPAMP_PGA_CONNECT_INVERTINGINPUT_NO : stm32h7xx_hal_opamp.h
- OPAMP_PGA_GAIN_16_OR_MINUS_15 : stm32h7xx_hal_opamp.h
- OPAMP_PGA_GAIN_2_OR_MINUS_1 : stm32h7xx_hal_opamp.h
- OPAMP_PGA_GAIN_4_OR_MINUS_3 : stm32h7xx_hal_opamp.h
- OPAMP_PGA_GAIN_8_OR_MINUS_7 : stm32h7xx_hal_opamp.h
- OPAMP_PGA_MODE : stm32h7xx_hal_opamp.h
- OPAMP_STANDALONE_MODE : stm32h7xx_hal_opamp.h
- OPAMP_TRIMMING_FACTORY : stm32h7xx_hal_opamp.h
- OPAMP_TRIMMING_USER : stm32h7xx_hal_opamp.h
- OPAMP_VREF_10VDDA : stm32h7xx_hal_opamp.h
- OPAMP_VREF_3VDDA : stm32h7xx_hal_opamp.h
- OPAMP_VREF_50VDDA : stm32h7xx_hal_opamp.h
- OPAMP_VREF_90VDDA : stm32h7xx_hal_opamp.h
- OPTIONBYTE_ALL : stm32h7xx_hal_flash_ex.h
- OPTIONBYTE_BOOTADD : stm32h7xx_hal_flash_ex.h
- OPTIONBYTE_BOR : stm32h7xx_hal_flash_ex.h
- OPTIONBYTE_PCROP : stm32h7xx_hal_flash_ex.h
- OPTIONBYTE_RDP : stm32h7xx_hal_flash_ex.h
- OPTIONBYTE_SECURE_AREA : stm32h7xx_hal_flash_ex.h
- OPTIONBYTE_USER : stm32h7xx_hal_flash_ex.h
- OPTIONBYTE_WRP : stm32h7xx_hal_flash_ex.h
- OR1K_BSP_UART_REG_INT_ID_MSI : irq.h
- OSC_RC_400M : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OSC_RC_400M_BASE : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OSC_RC_400M_BASE_ADDRS : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OSC_RC_400M_BASE_PTRS : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OSC_RC_400M_CTRL0_REF_CLK_DIV : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OSC_RC_400M_CTRL1_HYST_MINUS : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OSC_RC_400M_CTRL1_HYST_PLUS : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OSC_RC_400M_CTRL1_TARGET_COUNT : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OSC_RC_400M_CTRL2_OSC_TUNE_VAL : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OSC_RC_400M_CTRL2_TUNE_BYP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OSC_RC_400M_CTRL2_TUNE_EN : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OSC_RC_400M_CTRL2_TUNE_START : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OSC_RC_400M_CTRL3_CLR_ERR : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OSC_RC_400M_CTRL3_COUNT_1M_CLK : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OSC_RC_400M_CTRL3_EN_1M_CLK : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OSC_RC_400M_CTRL3_MUX_1M_CLK : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OSC_RC_400M_STAT0_CLK1M_ERR : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OSC_RC_400M_STAT1_CURR_COUNT_VAL : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OSC_RC_400M_STAT2_CURR_OSC_TUNE_VAL : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD1 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD1_BASE : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD2 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD2_BASE : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_BASE_ADDRS : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_BASE_PTRS : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_CR_FERR : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_CR_FLDM : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_CR_GE : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_CR_KBPE : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_CR_KBSE : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_CR_RRAE : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_CR_SKBP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_CTR_CTR : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_KEY_KEY : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_RGD_W0_SRTADDR : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_RGD_W1_ADE : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_RGD_W1_ENDADDR : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_RGD_W1_RO : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_RGD_W1_VLD : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_SR_CTXER0 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_SR_CTXER1 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_SR_CTXER2 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_SR_CTXER3 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_SR_CTXIE0 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_SR_CTXIE1 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_SR_CTXIE2 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_SR_CTXIE3 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_SR_GEM : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_SR_HRL : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_SR_KBD : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_SR_KBERR : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_SR_KBPE : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_SR_MDPCP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_SR_MODE : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_SR_NCTX : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFAD_SR_RRAM : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- OTFDEC2_REGION4_BASE : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h
- OTFDEC_CR_ENC : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_CR_ENC_Msk : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_ICR_KEIF : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_ICR_KEIF_Msk : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_ICR_SEIF : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_ICR_SEIF_Msk : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_ICR_XONEIF : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_ICR_XONEIF_Msk : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_IER_KEIE_Msk : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_IER_SEIE : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_IER_SEIE_Msk : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_IER_XONEIE : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_IER_XONEIE_Msk : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_ISR_KEIF : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_ISR_KEIF_Msk : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_ISR_SEIF : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_ISR_SEIF_Msk : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_ISR_XONEIF : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_ISR_XONEIF_Msk : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_PRIVCFGR_PRIV : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_PRIVCFGR_PRIV_Msk : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_CONFIGR_CONFIGLOCK : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_CONFIGR_CONFIGLOCK_Msk : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_CONFIGR_KEYCRC : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_CONFIGR_KEYCRC_Msk : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_CONFIGR_KEYLOCK : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_CONFIGR_KEYLOCK_Msk : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_CONFIGR_MODE : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_CONFIGR_MODE_0 : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_CONFIGR_MODE_1 : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_CONFIGR_MODE_Msk : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_CONFIGR_REG_EN : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_CONFIGR_REG_EN_Msk : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_CONFIGR_VERSION : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_CONFIGR_VERSION_Msk : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_END_ADDR : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_END_ADDR_Msk : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_KEYR0 : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_KEYR0_Msk : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_KEYR1 : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_KEYR1_Msk : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_KEYR2 : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_KEYR2_Msk : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_KEYR3 : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_KEYR3_Msk : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_NONCER0 : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_NONCER0_Msk : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_NONCER1 : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_NONCER1_Msk : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_START_ADDR : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OTFDEC_REG_START_ADDR_Msk : stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- OUT_1 : uart.h
- OUT_2 : uart.h
