#define | LPC176X_TMR0_BASE_ADDR 0x40004000U |
#define | LPC176X_T0IR |
#define | LPC176X_T0TCR |
#define | LPC176X_T0TC |
#define | LPC176X_T0PR |
#define | LPC176X_T0PC |
#define | LPC176X_T0MCR |
#define | LPC176X_T0MR0 |
#define | LPC176X_T0MR1 |
#define | LPC176X_T0MR2 |
#define | LPC176X_T0MR3 |
#define | LPC176X_T0CCR |
#define | LPC176X_T0CR0 |
#define | LPC176X_T0CR1 |
#define | LPC176X_T0CR2 |
#define | LPC176X_T0CR3 |
#define | LPC176X_T0EMR |
#define | LPC176X_T0CTCR |
#define | LPC176X_TMR1_BASE_ADDR 0x40008000U |
#define | LPC176X_T1IR |
#define | LPC176X_T1TCR |
#define | LPC176X_T1TC |
#define | LPC176X_T1PR |
#define | LPC176X_T1PC |
#define | LPC176X_T1MCR |
#define | LPC176X_T1MR0 |
#define | LPC176X_T1MR1 |
#define | LPC176X_T1MR2 |
#define | LPC176X_T1MR3 |
#define | LPC176X_T1CCR |
#define | LPC176X_T1CR0 |
#define | LPC176X_T1CR1 |
#define | LPC176X_T1CR2 |
#define | LPC176X_T1CR3 |
#define | LPC176X_T1EMR |
#define | LPC176X_T1CTCR |
#define | LPC176X_TMR2_BASE_ADDR 0x40090000U |
#define | LPC176X_T2IR |
#define | LPC176X_T2TCR |
#define | LPC176X_T2TC |
#define | LPC176X_T2PR |
#define | LPC176X_T2PC |
#define | LPC176X_T2MCR |
#define | LPC176X_T2MR0 |
#define | LPC176X_T2MR1 |
#define | LPC176X_T2MR2 |
#define | LPC176X_T2MR3 |
#define | LPC176X_T2CCR |
#define | LPC176X_T2CR0 |
#define | LPC176X_T2CR1 |
#define | LPC176X_T2CR2 |
#define | LPC176X_T2CR3 |
#define | LPC176X_T2EMR |
#define | LPC176X_T2CTCR |
#define | LPC176X_TMR3_BASE_ADDR 0x40094000U |
#define | LPC176X_T3IR |
#define | LPC176X_T3TCR |
#define | LPC176X_T3TC |
#define | LPC176X_T3PR |
#define | LPC176X_T3PC |
#define | LPC176X_T3MCR |
#define | LPC176X_T3MR0 |
#define | LPC176X_T3MR1 |
#define | LPC176X_T3MR2 |
#define | LPC176X_T3MR3 |
#define | LPC176X_T3CCR |
#define | LPC176X_T3CR0 |
#define | LPC176X_T3CR1 |
#define | LPC176X_T3CR2 |
#define | LPC176X_T3CR3 |
#define | LPC176X_T3EMR |
#define | LPC176X_T3CTCR |
#define | LPC176X_PIN_SELECT_TIMER 3U |
#define | LPC176X_PINSEL_NO_PORT 999U |
#define | LPC176X_TIMER_RESET ( 1U << 1U ) |
#define | LPC176X_TIMER_START 1U |
#define | LPC176X_TIMER_MODE_COUNTER_SOURCE_CAP0 0U |
#define | LPC176X_TIMER_MODE_COUNTER_SOURCE_CAP1 ( 1U << 2U ) |
#define | LPC176X_TIMER0_CAPTURE_PORTS { 58U, 59U } |
#define | LPC176X_TIMER1_CAPTURE_PORTS { 50U, 51U } |
#define | LPC176X_TIMER2_CAPTURE_PORTS { 4U, 5U } |
#define | LPC176X_TIMER3_CAPTURE_PORTS { 23U, 24U } |
#define | LPC176X_TIMER0_EMATCH_PORTS |
#define | LPC176X_TIMER1_EMATCH_PORTS |
#define | LPC176X_TIMER2_EMATCH_PORTS { 6U, 7U, 8U, 9U } |
#define | LPC176X_TIMER3_EMATCH_PORTS |
#define | LPC176X_TIMER_DEFAULT_RESOLUTION 1U |
#define | LPC176X_TIMER_MCR_MASK 7U |
#define | LPC176X_TIMER_MCR_MASK_SIZE 3U |
#define | LPC176X_TIMER_CCR_MASK 7U |
#define | LPC176X_TIMER_CCR_MASK_SIZE 3U |
#define | LPC176X_TIMER_EMR_MASK 3U |
#define | LPC176X_TIMER_EMR_MASK_SIZE 2U |
#define | LPC176X_TIMER_EMR_MASK_OFFSET 4U |
#define | LPC176X_TIMER_CLEAR_FUNCTION 0U |
#define | LPC176X_TIMER_PRESCALER_DIVISOR 1000000U |
#define | LPC176X_TIMER_VECTOR_NUMBER(timernumber) ( timernumber + 1U ) |
#define | LPC176X_TIMER_INTERRUPT_SOURCE_BIT(i) ( 1U << i ) |
#define | LPC176X_TIMER_MATCH_FUNCTION_COUNT 8U |
#define | LPC176X_TIMER_CAPTURE_FUNCTION_COUNT 8U |
#define | LPC176X_ISR_NAME_STRING_SIZE 10U |
#define | LPC176X_SET_MCR(mcr, match_port, function) |
#define | LPC176X_SET_CCR(mcr, capture_port, function) |
#define | LPC176X_SET_EMR(mcr, match_port, function) |
