RTEMS
5.1
The configuration of a new thread to initialize. More...
#include <threadimpl.h>
Data Fields | |
const struct _Scheduler_Control * | scheduler |
The scheduler control instance for the thread. | |
void * | stack_area |
The starting address of the stack area. | |
size_t | stack_size |
The size of the stack area in bytes. | |
void * | allocated_stack |
The address of the allocated stack area or NULL. | |
Priority_Control | priority |
The new thread's priority. | |
Thread_CPU_budget_algorithms | budget_algorithm |
The thread's budget algorithm. | |
Thread_CPU_budget_algorithm_callout | budget_callout |
The thread's initial budget callout. | |
Objects_Name | name |
Name of the object for the thread. | |
uint32_t | isr_level |
The thread's initial ISR level. | |
bool | is_fp |
Indicates whether the thread needs a floating-point area. | |
bool | is_preemptible |
Indicates whether the new thread is preemptible. | |
