RTEMS  5.1
smpimpl.h
1
9 /*
10  * COPYRIGHT (c) 1989-2011.
11  * On-Line Applications Research Corporation (OAR).
12  *
13  * The license and distribution terms for this file may be
14  * found in the file LICENSE in this distribution or at
15  * http://www.rtems.org/license/LICENSE.
16  */
17
18 #ifndef _RTEMS_SCORE_SMPIMPL_H
19 #define _RTEMS_SCORE_SMPIMPL_H
20
21 #include <rtems/score/smp.h>
22 #include <rtems/score/percpu.h>
24 #include <rtems/fatal.h>
25
26 #ifdef __cplusplus
27 extern "C" {
28 #endif
29
43 #define SMP_MESSAGE_SHUTDOWN 0x1UL
44
50 #define SMP_MESSAGE_PERFORM_JOBS 0x2UL
51
55 typedef enum {
56  SMP_FATAL_BOOT_PROCESSOR_NOT_ASSIGNED_TO_SCHEDULER,
57  SMP_FATAL_MANDATORY_PROCESSOR_NOT_PRESENT,
58  SMP_FATAL_MULTITASKING_START_ON_INVALID_PROCESSOR,
59  SMP_FATAL_MULTITASKING_START_ON_UNASSIGNED_PROCESSOR,
60  SMP_FATAL_SHUTDOWN,
61  SMP_FATAL_SHUTDOWN_RESPONSE,
62  SMP_FATAL_START_OF_MANDATORY_PROCESSOR_FAILED,
63  SMP_FATAL_SCHEDULER_PIN_OR_UNPIN_NOT_SUPPORTED,
64  SMP_FATAL_WRONG_CPU_STATE_TO_PERFORM_JOBS
66
72 static inline void _SMP_Fatal( SMP_Fatal_code code )
73 {
75 }
76
82 #if defined( RTEMS_SMP )
83  void _SMP_Handler_initialize( void );
84 #else
85  #define _SMP_Handler_initialize() \
86  do { } while ( 0 )
87 #endif
88
89 #if defined( RTEMS_SMP )
90
99 extern Processor_mask _SMP_Online_processors;
100
127 void _SMP_Start_multitasking_on_secondary_processor(
128  Per_CPU_Control *cpu_self
130
138 static inline long unsigned _SMP_Inter_processor_interrupt_handler(
139  Per_CPU_Control *cpu_self
140 )
141 {
142  unsigned long message;
143
144  /*
145  * In the common case the inter-processor interrupt is issued to carry out a
146  * thread dispatch.
147  */
148  cpu_self->dispatch_necessary = true;
149
150  message = _Atomic_Exchange_ulong(
151  &cpu_self->message,
152  0,
153  ATOMIC_ORDER_ACQUIRE
154  );
155
156  if ( RTEMS_PREDICT_FALSE( message != 0 ) ) {
157  if ( ( message & SMP_MESSAGE_SHUTDOWN ) != 0 ) {
158  _SMP_Fatal( SMP_FATAL_SHUTDOWN_RESPONSE );
159  /* does not continue past here */
160  }
161
162  if ( ( message & SMP_MESSAGE_PERFORM_JOBS ) != 0 ) {
163  _Per_CPU_Perform_jobs( cpu_self );
164  }
165  }
166
167  return message;
168 }
169
178 bool _SMP_Should_start_processor( uint32_t cpu_index );
179
188 void _SMP_Send_message( uint32_t cpu_index, unsigned long message );
189
195 void _SMP_Send_message_broadcast(
196  unsigned long message
197 );
198
207 void _SMP_Send_message_multicast(
208  const Processor_mask *targets,
209  unsigned long message
210 );
211
212 typedef void ( *SMP_Action_handler )( void *arg );
213
227 void _SMP_Multicast_action(
228  const Processor_mask *targets,
229  SMP_Action_handler handler,
230  void *arg
231 );
232
243 void _SMP_Broadcast_action(
244  SMP_Action_handler handler,
245  void *arg
246 );
247
258 void _SMP_Othercast_action(
259  SMP_Action_handler handler,
260  void *arg
261 );
262
272 void _SMP_Unicast_action(
273  uint32_t cpu_index,
274  SMP_Action_handler handler,
275  void *arg
276 );
277
284 void _SMP_Synchronize( void );
285
286 #endif /* defined( RTEMS_SMP ) */
287
292 #if defined( RTEMS_SMP )
293  void _SMP_Request_start_multitasking( void );
294 #else
295  #define _SMP_Request_start_multitasking() \
296  do { } while ( 0 )
297 #endif
298
306 #if defined( RTEMS_SMP )
307  void _SMP_Request_shutdown( void );
308 #else
309  #define _SMP_Request_shutdown() \
310  do { } while ( 0 )
311 #endif
312
319 {
320 #if defined(RTEMS_SMP)
321  return &_SMP_Online_processors;
322 #else
323  return &_Processor_mask_The_one_and_only;
324 #endif
325 }
326
334 {
335  /*
336  * Use the configured processor maximum instead of the actual to allow
337  * testing on uni-processor systems.
338  */
340 }
341
344 #ifdef __cplusplus
345 }
346 #endif
347
348 #endif
349 /* end of include file */
Initializes SMP Handler.
Definition: smpimpl.h:85
Definition: media-server.c:33
RTEMS_INLINE_ROUTINE const Processor_mask * _SMP_Get_online_processors(void)
Gets all online processors.
Definition: smpimpl.h:318
Fatal source of SMP domain.
Definition: interr.h:126
#define _SMP_Processor_configured_maximum
The configured processor maximum.
Definition: smp.h:49
void _Terminate(Internal_errors_Source the_source, Internal_errors_t the_error) RTEMS_NO_RETURN
Initiates system termination.
Definition: interr.c:31
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
Requests a shutdown of all processors.
Definition: smpimpl.h:309
Requests a multitasking start on all configured and available processors.
Definition: smpimpl.h:295
SuperCore SMP Support API.
SMP message to perform per-processor jobs.
Definition: smpimpl.h:50
Per CPU Core Structure.
Definition: percpu.h:347
SMP message to request a processor shutdown.
Definition: smpimpl.h:43
volatile bool dispatch_necessary
This is set to true when this processor needs to run the thread dispatcher.
Definition: percpu.h:400
Definition: inftrees.h:24
RTEMS_INLINE_ROUTINE const bool _SMP_Need_inter_processor_interrupts(void)
Indicate if inter-processor interrupts are needed.
Definition: smpimpl.h:333
Processor Mask API.
#define RTEMS_PREDICT_FALSE(_exp)
Returns the value of the specified integral expression and tells the compiler that the predicted valu...
Definition: basedefs.h:388
Fatal API.
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
SMP_Fatal_code
SMP fatal codes.
Definition: smpimpl.h:55
