RTEMS  5.1
semimpl.h
1
9 /* COPYRIGHT (c) 1989-2008.
10  * On-Line Applications Research Corporation (OAR).
11  *
12  * The license and distribution terms for this file may be
13  * found in the file LICENSE in this distribution or at
14  * http://www.rtems.org/license/LICENSE.
15  */
16
17 #ifndef _RTEMS_RTEMS_SEMIMPL_H
18 #define _RTEMS_RTEMS_SEMIMPL_H
19
20 #include <rtems/rtems/semdata.h>
23 #include <rtems/score/mrspimpl.h>
24
25 #ifdef __cplusplus
26 extern "C" {
27 #endif
28
42 typedef enum {
43  SEMAPHORE_VARIANT_MUTEX_INHERIT_PRIORITY,
44  SEMAPHORE_VARIANT_MUTEX_PRIORITY_CEILING,
45  SEMAPHORE_VARIANT_MUTEX_NO_PROTOCOL,
46  SEMAPHORE_VARIANT_SIMPLE_BINARY,
47  SEMAPHORE_VARIANT_COUNTING
48 #if defined(RTEMS_SMP)
49  ,
50  SEMAPHORE_VARIANT_MRSP
51 #endif
53
54 typedef enum {
55  SEMAPHORE_DISCIPLINE_PRIORITY,
56  SEMAPHORE_DISCIPLINE_FIFO
57 } Semaphore_Discipline;
58
59 RTEMS_INLINE_ROUTINE uintptr_t _Semaphore_Get_flags(
60  const Semaphore_Control *the_semaphore
61 )
62 {
63  _Assert( _Chain_Is_node_off_chain( &the_semaphore->Object.Node ) );
64  return (uintptr_t) the_semaphore->Object.Node.previous;
65 }
66
67 RTEMS_INLINE_ROUTINE void _Semaphore_Set_flags(
68  Semaphore_Control *the_semaphore,
69  uintptr_t flags
70 )
71 {
72  _Assert( _Chain_Is_node_off_chain( &the_semaphore->Object.Node ) );
73  the_semaphore->Object.Node.previous = (Chain_Node *) flags;
74 }
75
76 RTEMS_INLINE_ROUTINE Semaphore_Variant _Semaphore_Get_variant(
77  uintptr_t flags
78 )
79 {
80  return (Semaphore_Discipline) ( flags & 0x7 );
81 }
82
83 RTEMS_INLINE_ROUTINE uintptr_t _Semaphore_Set_variant(
84  uintptr_t flags,
85  Semaphore_Variant variant
86 )
87 {
88  return flags | variant;
89 }
90
91 RTEMS_INLINE_ROUTINE Semaphore_Discipline _Semaphore_Get_discipline(
92  uintptr_t flags
93 )
94 {
95  return (Semaphore_Discipline) ( ( flags >> 3 ) & 0x1 );
96 }
97
98 RTEMS_INLINE_ROUTINE uintptr_t _Semaphore_Set_discipline(
99  uintptr_t flags,
100  Semaphore_Discipline discipline
101 )
102 {
103  return flags | ( discipline << 3 );
104 }
105
106 #if defined(RTEMS_MULTIPROCESSING)
107 RTEMS_INLINE_ROUTINE bool _Semaphore_Is_global(
108  uintptr_t flags
109 )
110 {
111  return ( flags & 0x10 ) != 0;
112 }
113
114 RTEMS_INLINE_ROUTINE uintptr_t _Semaphore_Make_global( uintptr_t flags )
115 {
116  return flags | 0x10;
117 }
118 #endif
119
120 RTEMS_INLINE_ROUTINE const Thread_queue_Operations *_Semaphore_Get_operations(
121  uintptr_t flags
122 )
123 {
124  if (
125  _Semaphore_Get_variant( flags ) == SEMAPHORE_VARIANT_MUTEX_INHERIT_PRIORITY
126  ) {
127  return &_Thread_queue_Operations_priority_inherit;
128  }
129
130  if ( _Semaphore_Get_discipline( flags ) == SEMAPHORE_DISCIPLINE_PRIORITY ) {
131  return &_Thread_queue_Operations_priority;
132  }
133
134  return &_Thread_queue_Operations_FIFO;
135 }
136
145 {
147 }
148
157  Semaphore_Control *the_semaphore
158 )
159 {
160  _Objects_Free( &_Semaphore_Information, &the_semaphore->Object );
161 }
162
164  Objects_Id id,
165  Thread_queue_Context *queue_context
166 )
167 {
168  _Thread_queue_Context_initialize( queue_context );
169  return (Semaphore_Control *) _Objects_Get(
170  id,
171  &queue_context->Lock_context.Lock_context,
173  );
174 }
175
178 #ifdef __cplusplus
179 }
180 #endif
181
182 #ifdef RTEMS_MULTIPROCESSING
183 #include <rtems/rtems/semmp.h>
184 #endif
185
186 #endif
187 /* end of include file */
Definition: chain.h:68
CORE Mutex Implementation.
Chain_Node * previous
Definition: chain.h:72
Thread queue context for the thread queue methods.
Definition: threadq.h:198
Definitions for Multiprocessor Resource Sharing Protocol (MrsP) Implementation.
Classic Semaphore Manager Data Structures.
Objects_Control Object
The object management portion of a semaphore instance.
Definition: semdata.h:50
RTEMS_INLINE_ROUTINE Semaphore_Control * _Semaphore_Allocate(void)
Allocates a semaphore control block from the inactive chain of free semaphore control blocks.
Definition: semimpl.h:144
Objects_Control * _Objects_Allocate(Objects_Information *information)
Allocates an object.
Definition: objectallocate.c:42
Thread queue operations.
Definition: threadq.h:517
Chain_Node Node
Definition: objectdata.h:41
Definition: semdata.h:40
Thread_queue_Lock_context Lock_context
The lock context for the thread queue acquire and release operations.
Definition: threadq.h:203
RTEMS_INLINE_ROUTINE void _Objects_Free(Objects_Information *information, Objects_Control *the_object)
Frees an object.
Definition: objectimpl.h:930
RTEMS_INLINE_ROUTINE void _Semaphore_Free(Semaphore_Control *the_semaphore)
Frees a semaphore control block to the inactive chain of free semaphore control blocks.
Definition: semimpl.h:156
RTEMS_INLINE_ROUTINE void _Thread_queue_Context_initialize(Thread_queue_Context *queue_context)
Initializes a thread queue context.
Definition: threadqimpl.h:152
uint32_t Objects_Id
Definition: object.h:80
Inlined Routines Associated with the SuperCore Semaphore.
Objects_Information _Semaphore_Information
The Classic Semaphore objects information.
Objects_Control * _Objects_Get(Objects_Id id, ISR_lock_Context *lock_context, const Objects_Information *information)
Maps the specified object identifier to the associated local object control block.
Definition: objectgetlocal.c:28
ISR_lock_Context Lock_context
Definition: threadq.h:130
RTEMS_INLINE_ROUTINE bool _Chain_Is_node_off_chain(const Chain_Node *node)
Checks if the node is off chain.
Definition: chainimpl.h:142
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
Semaphore_Variant
Classic semaphore variants.
Definition: semimpl.h:42
#define _Assert(_e)
Assertion similar to assert() controlled via RTEMS_DEBUG instead of NDEBUG.
Definition: assert.h:100
