RTEMS  5.1
sem.h
1
9 /*
10  * COPYRIGHT (c) 1989-2008, 2016.
11  * On-Line Applications Research Corporation (OAR).
12  *
13  * The license and distribution terms for this file may be
14  * found in the file LICENSE in this distribution or at
15  * http://www.rtems.org/license/LICENSE.
16  */
17
18 #ifndef _RTEMS_RTEMS_SEM_H
19 #define _RTEMS_RTEMS_SEM_H
20
21 #include <rtems/rtems/attr.h>
22 #include <rtems/rtems/options.h>
23 #include <rtems/rtems/tasks.h>
24 #include <rtems/rtems/types.h>
25
26 #ifdef __cplusplus
27 extern "C" {
28 #endif
29
50  rtems_name name,
51  uint32_t count,
52  rtems_attribute attribute_set,
53  rtems_task_priority priority_ceiling,
54  rtems_id *id
55 );
56
76  rtems_name name,
77  uint32_t node,
78  rtems_id *id
79 );
80
94  rtems_id id
95 );
96
117  rtems_id id,
118  rtems_option option_set,
119  rtems_interval timeout
120 );
121
132  rtems_id id
133 );
134
149  rtems_id id
150 );
151
187  rtems_id semaphore_id,
188  rtems_id scheduler_id,
189  rtems_task_priority new_priority,
190  rtems_task_priority *old_priority
191 );
192
195 #ifdef __cplusplus
196 }
197 #endif
198
199 #endif
200 /* end of include file */
rtems_status_code rtems_semaphore_set_priority(rtems_id semaphore_id, rtems_id scheduler_id, rtems_task_priority new_priority, rtems_task_priority *old_priority)
Sets the priority value with respect to the specified scheduler of a semaphore.
Definition: semsetpriority.c:127
uint32_t rtems_attribute
Definition: attr.h:41
Watchdog_Interval rtems_interval
Used to manage and manipulate intervals specified by clock ticks.
Definition: types.h:127
uint32_t rtems_name
Classic API object name type.
Definition: types.h:77
rtems_status_code rtems_semaphore_delete(rtems_id id)
RTEMS Delete Semaphore.
Definition: semdelete.c:24
rtems_status_code rtems_semaphore_ident(rtems_name name, uint32_t node, rtems_id *id)
RTEMS Semaphore Name to Id.
Definition: semident.c:24
rtems_status_code
Classic API Status.
Definition: status.h:43
rtems_status_code rtems_semaphore_release(rtems_id id)
RTEMS Semaphore Release.
Definition: semrelease.c:28
rtems_status_code rtems_semaphore_obtain(rtems_id id, rtems_option option_set, rtems_interval timeout)
RTEMS Obtain Semaphore.
Definition: semobtain.c:51
uint32_t rtems_option
Definition: options.h:42
Classic Task Manager API.
rtems_status_code rtems_semaphore_flush(rtems_id id)
RTEMS Semaphore Flush.
Definition: semflush.c:23
rtems_status_code rtems_semaphore_create(rtems_name name, uint32_t count, rtems_attribute attribute_set, rtems_task_priority priority_ceiling, rtems_id *id)
Definition: semcreate.c:34
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
uint32_t rtems_task_priority
Definition: tasks.h:55
