RTEMS
5.1
Constants and Structures Associated with the Scheduler. More...
struct | Scheduler_Operations |
The scheduler operations. More... | |
struct | Scheduler_Context |
Scheduler context. More... | |
struct | _Scheduler_Control |
Scheduler control. More... | |
#define | _Scheduler_Count ( (size_t) 1 ) |
Count of registered schedulers. More... | |
#define | SCHEDULER_OPERATION_DEFAULT_ASK_FOR_HELP |
#define | SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY |
#define | PRIORITY_MAXIMUM ( _Scheduler_Table[ 0 ].maximum_priority ) |
This defines the lowest (least important) thread priority of the first scheduler instance. | |
Typedefs | |
typedef struct _Scheduler_Control | Scheduler_Control |
typedef struct Scheduler_Context | Scheduler_Context |
Priority_Control | _Scheduler_default_Map_priority (const Scheduler_Control *scheduler, Priority_Control priority) |
Returns the scheduler internal thread priority mapped by SCHEDULER_PRIORITY_MAP(). More... | |
Priority_Control | _Scheduler_default_Unmap_priority (const Scheduler_Control *scheduler, Priority_Control priority) |
Returns the user visible thread priority unmapped by SCHEDULER_PRIORITY_UNMAP(). More... | |
void | _Scheduler_default_Schedule (const Scheduler_Control *scheduler, Thread_Control *the_thread) |
Does nothing. More... | |
void | _Scheduler_default_Node_initialize (const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority) |
Performs the scheduler base node initialization. More... | |
void | _Scheduler_default_Node_destroy (const Scheduler_Control *scheduler, Scheduler_Node *node) |
void | _Scheduler_default_Release_job (const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, uint64_t deadline, Thread_queue_Context *queue_context) |
void | _Scheduler_default_Cancel_job (const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context) |
void | _Scheduler_default_Tick (const Scheduler_Control *scheduler, Thread_Control *executing) |
Performs tick operations depending on the CPU budget algorithm for each executing thread. More... | |
void | _Scheduler_default_Start_idle (const Scheduler_Control *scheduler, Thread_Control *the_thread, struct Per_CPU_Control *cpu) |
Starts an idle thread. More... | |
const Scheduler_Control | _Scheduler_Table [] |
Registered schedulers. More... | |
This include file contains all the constants and structures associated with the scheduler.
