RTEMS  5.1
schedulerstrongapa.h
1
9 /*
10  * Copyright (c) 2013, 2018 embedded brains GmbH. All rights reserved.
11  *
12  * embedded brains GmbH
13  * Dornierstr. 4
14  * 82178 Puchheim
15  * Germany
16  * <rtems@embedded-brains.de>
17  *
18  * The license and distribution terms for this file may be
19  * found in the file LICENSE in this distribution or at
20  * http://www.rtems.org/license/LICENSE.
21  */
22
23 #ifndef _RTEMS_SCORE_SCHEDULERSTRONGAPA_H
24 #define _RTEMS_SCORE_SCHEDULERSTRONGAPA_H
25
26 #include <rtems/score/scheduler.h>
29
30 #ifdef __cplusplus
31 extern "C" {
32 #endif /* __cplusplus */
33
56 typedef struct {
59  Chain_Control Ready[ RTEMS_ZERO_LENGTH_ARRAY ];
61
66 typedef struct {
71
77
81 #define SCHEDULER_STRONG_APA_ENTRY_POINTS \
82  { \
83  _Scheduler_strong_APA_Initialize, \
84  _Scheduler_default_Schedule, \
85  _Scheduler_strong_APA_Yield, \
86  _Scheduler_strong_APA_Block, \
87  _Scheduler_strong_APA_Unblock, \
88  _Scheduler_strong_APA_Update_priority, \
89  _Scheduler_default_Map_priority, \
90  _Scheduler_default_Unmap_priority, \
91  _Scheduler_strong_APA_Ask_for_help, \
92  _Scheduler_strong_APA_Reconsider_help_request, \
93  _Scheduler_strong_APA_Withdraw_node, \
94  _Scheduler_default_Pin_or_unpin, \
95  _Scheduler_default_Pin_or_unpin, \
96  _Scheduler_strong_APA_Add_processor, \
97  _Scheduler_strong_APA_Remove_processor, \
98  _Scheduler_strong_APA_Node_initialize, \
99  _Scheduler_default_Node_destroy, \
100  _Scheduler_default_Release_job, \
101  _Scheduler_default_Cancel_job, \
102  _Scheduler_default_Tick, \
103  _Scheduler_SMP_Start_idle \
104  SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY \
105  }
106
112 void _Scheduler_strong_APA_Initialize( const Scheduler_Control *scheduler );
113
123  const Scheduler_Control *scheduler,
124  Scheduler_Node *node,
125  Thread_Control *the_thread,
126  Priority_Control priority
127 );
128
137  const Scheduler_Control *scheduler,
138  Thread_Control *the_thread,
139  Scheduler_Node *node
140 );
141
150  const Scheduler_Control *scheduler,
151  Thread_Control *the_thread,
152  Scheduler_Node *node
153 );
154
163  const Scheduler_Control *scheduler,
164  Thread_Control *the_thread,
165  Scheduler_Node *node
166 );
167
179  const Scheduler_Control *scheduler,
180  Thread_Control *the_thread,
181  Scheduler_Node *node
182 );
183
192  const Scheduler_Control *scheduler,
193  Thread_Control *the_thread,
194  Scheduler_Node *node
195 );
196
206  const Scheduler_Control *scheduler,
207  Thread_Control *the_thread,
208  Scheduler_Node *node,
209  Thread_Scheduler_state next_state
210 );
211
219  const Scheduler_Control *scheduler,
220  Thread_Control *idle
221 );
222
232  const Scheduler_Control *scheduler,
233  struct Per_CPU_Control *cpu
234 );
235
244  const Scheduler_Control *scheduler,
245  Thread_Control *the_thread,
246  Scheduler_Node *node
247 );
248
251 #ifdef __cplusplus
252 }
253 #endif /* __cplusplus */
254
255 #endif /* _RTEMS_SCORE_SCHEDULERSTRONGAPA_H */
Scheduler context specialization for SMP schedulers.
Definition: schedulersmp.h:46
SMP Scheduler API.
uint64_t Priority_Control
The thread priority control.
Definition: priority.h:70
void _Scheduler_strong_APA_Add_processor(const Scheduler_Control *scheduler, Thread_Control *idle)
Adds the idle thread to a processor.
Definition: schedulerstrongapa.c:388
Definition: prioritybitmap.h:42
bool _Scheduler_strong_APA_Ask_for_help(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Asks for help.
Definition: schedulerstrongapa.c:340
Definition: chain.h:86
void _Scheduler_strong_APA_Node_initialize(const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority)
Initializes the node with the given priority.
Definition: schedulerstrongapa.c:172
Thread Manipulation with the Priority-Based Scheduler.
Scheduler_priority_Ready_queue Ready_queue
The associated ready queue of this node.
Definition: schedulerstrongapa.h:75
Scheduler_SMP_Node Base
SMP scheduler node.
Definition: schedulerstrongapa.h:70
Thread_Control * _Scheduler_strong_APA_Remove_processor(const Scheduler_Control *scheduler, struct Per_CPU_Control *cpu)
Removes an idle thread from the given cpu.
Definition: schedulerstrongapa.c:404
void _Scheduler_strong_APA_Withdraw_node(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, Thread_Scheduler_state next_state)
Withdraws the node.
Definition: schedulerstrongapa.c:367
Definition: thread.h:732
Per CPU Core Structure.
Definition: percpu.h:347
Data for ready queue operations.
Definition: schedulerpriority.h:85
Scheduler context specialization for Strong APA schedulers.
Definition: schedulerstrongapa.h:56
Scheduler node specialization for SMP schedulers.
Definition: schedulersmp.h:100
void _Scheduler_strong_APA_Update_priority(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Updates the priority of the node.
Definition: schedulerstrongapa.c:320
Scheduler node specialization for Strong APA schedulers.
Definition: schedulerstrongapa.h:66
Scheduler control.
Definition: scheduler.h:269
Scheduler node for per-thread data.
Definition: schedulernode.h:79
void _Scheduler_strong_APA_Block(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Blocks the thread.
Definition: schedulerstrongapa.c:225
void _Scheduler_strong_APA_Initialize(const Scheduler_Control *scheduler)
Initializes the scheduler.
Definition: schedulerstrongapa.c:159
Constants and Structures Associated with the Scheduler.
void _Scheduler_strong_APA_Unblock(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Unblocks the thread.
Definition: schedulerstrongapa.c:284
void _Scheduler_strong_APA_Reconsider_help_request(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Reconsiders help request.
Definition: schedulerstrongapa.c:351
void _Scheduler_strong_APA_Yield(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Performs a yield operation.
Definition: schedulerstrongapa.c:419
