RTEMS  5.1
schedulerpriorityimpl.h
1
13 /*
14  * Copyright (C) 2010 Gedare Bloom.
15  * Copyright (C) 2011 On-Line Applications Research Corporation (OAR).
16  *
17  * The license and distribution terms for this file may be
18  * found in the file LICENSE in this distribution or at
19  * http://www.rtems.org/license/LICENSE.
20  */
21
22 #ifndef _RTEMS_SCORE_SCHEDULERPRIORITYIMPL_H
23 #define _RTEMS_SCORE_SCHEDULERPRIORITYIMPL_H
24
26 #include <rtems/score/chainimpl.h>
29 #include <rtems/score/thread.h>
30
31 #ifdef __cplusplus
32 extern "C" {
33 #endif
34
50 {
51  return (Scheduler_priority_Context *) _Scheduler_Get_context( scheduler );
52 }
53
62  Thread_Control *the_thread
63 )
64 {
66 }
67
76  Scheduler_Node *node
77 )
78 {
79  return (Scheduler_priority_Node *) node;
80 }
81
91  Chain_Control *ready_queues,
92  Priority_Control maximum_priority
93 )
94 {
95  size_t index;
96
97  for ( index = 0 ; index <= (size_t) maximum_priority ; ++index ) {
98  _Chain_Initialize_empty( &ready_queues[ index ] );
99  }
100 }
101
112  Chain_Node *node,
113  Scheduler_priority_Ready_queue *ready_queue,
114  Priority_bit_map_Control *bit_map
115 )
116 {
117  Chain_Control *ready_chain = ready_queue->ready_chain;
118
119  _Chain_Append_unprotected( ready_chain, node );
120  _Priority_bit_map_Add( bit_map, &ready_queue->Priority_map );
121 }
122
133  Chain_Node *node,
134  Scheduler_priority_Ready_queue *ready_queue,
135  Priority_bit_map_Control *bit_map
136 )
137 {
138  Chain_Control *ready_chain = ready_queue->ready_chain;
139
140  _Chain_Prepend_unprotected( ready_chain, node );
141  _Priority_bit_map_Add( bit_map, &ready_queue->Priority_map );
142 }
143
152  Chain_Node *node,
153  Scheduler_priority_Ready_queue *ready_queue,
154  Priority_bit_map_Control *bit_map
155 )
156 {
157  Chain_Control *ready_chain = ready_queue->ready_chain;
158
159  if ( _Chain_Has_only_one_node( ready_chain ) ) {
160  _Chain_Initialize_empty( ready_chain );
161  _Chain_Initialize_node( node );
162  _Priority_bit_map_Remove( bit_map, &ready_queue->Priority_map );
163  } else {
165  }
166 }
167
176  const Scheduler_Control *scheduler,
177  Thread_Control *the_thread,
178  Scheduler_Node *node
179 )
180 {
182  Scheduler_priority_Node *the_node;
183
185  the_node = _Scheduler_priority_Node_downcast( node );
186
188  &the_thread->Object.Node,
189  &the_node->Ready_queue,
190  &context->Bit_map
191  );
192 }
193
205  Priority_bit_map_Control *bit_map,
206  Chain_Control *ready_queues
207 )
208 {
210  Chain_Node *first = _Chain_First( &ready_queues[ index ] );
211
212  _Assert( first != _Chain_Tail( &ready_queues[ index ] ) );
213
214  return first;
215 }
216
229  const Scheduler_Control *scheduler,
230  Thread_Control *the_thread,
231  bool force_dispatch
232 )
233 {
235  _Scheduler_priority_Get_context( scheduler );
236  Thread_Control *heir = (Thread_Control *)
238  &context->Bit_map,
239  &context->Ready[ 0 ]
240  );
241
242  ( void ) the_thread;
243
244  _Scheduler_Update_heir( heir, force_dispatch );
245 }
246
257  Scheduler_priority_Ready_queue *ready_queue,
258  unsigned int new_priority,
259  Priority_bit_map_Control *bit_map,
260  Chain_Control *ready_queues
261 )
262 {
263  ready_queue->current_priority = new_priority;
264  ready_queue->ready_chain = &ready_queues[ new_priority ];
265
267  bit_map,
268  &ready_queue->Priority_map,
269  new_priority
270  );
271 }
272
275 #ifdef __cplusplus
276 }
277 #endif
278
279 #endif
280 /* end of include file */
RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_enqueue(Chain_Node *node, Scheduler_priority_Ready_queue *ready_queue, Priority_bit_map_Control *bit_map)
Enqueues a node on the specified ready queue.
Definition: schedulerpriorityimpl.h:111
Definition: chain.h:68
RTEMS_INLINE_ROUTINE void _Chain_Extract_unprotected(Chain_Node *the_node)
Extracts this node (unprotected).
Definition: chainimpl.h:558
RTEMS_INLINE_ROUTINE void _Chain_Initialize_node(Chain_Node *the_node)
Initializes a chain node.
Definition: chainimpl.h:122
RTEMS_INLINE_ROUTINE Scheduler_Context * _Scheduler_Get_context(const Scheduler_Control *scheduler)
Gets the context of the scheduler.
Definition: schedulerimpl.h:58
RTEMS_INLINE_ROUTINE Chain_Node * _Chain_Tail(Chain_Control *the_chain)
Returns pointer to chain tail.
Definition: chainimpl.h:227
uint64_t Priority_Control
The thread priority control.
Definition: priority.h:70
Chain_Control * ready_chain
Definition: schedulerpriority.h:92
Definition: schedulerpriority.h:65
Definition: prioritybitmap.h:42
RTEMS_INLINE_ROUTINE void _Priority_bit_map_Add(Priority_bit_map_Control *bit_map, Priority_bit_map_Information *bit_map_info)
Adds Priority queue bit map information.
Definition: prioritybitmapimpl.h:162
Priority_bit_map_Information Priority_map
Definition: schedulerpriority.h:95
Inlined Routines Associated with the Manipulation of the Scheduler.
RTEMS_INLINE_ROUTINE void _Scheduler_priority_Schedule_body(const Scheduler_Control *scheduler, Thread_Control *the_thread, bool force_dispatch)
Scheduling decision logic.
Definition: schedulerpriorityimpl.h:228
Definition: chain.h:86
RTEMS_INLINE_ROUTINE void _Chain_Initialize_empty(Chain_Control *the_chain)
Initializes this chain as empty.
Definition: chainimpl.h:505
unsigned int current_priority
The thread priority currently used by the scheduler.
Definition: schedulerpriority.h:89
RTEMS_INLINE_ROUTINE Chain_Node * _Scheduler_priority_Ready_queue_first(Priority_bit_map_Control *bit_map, Chain_Control *ready_queues)
Returns a pointer to the first node.
Definition: schedulerpriorityimpl.h:204
RTEMS_INLINE_ROUTINE Scheduler_priority_Context * _Scheduler_priority_Get_context(const Scheduler_Control *scheduler)
Definition: schedulerpriorityimpl.h:49
Thread Manipulation with the Priority-Based Scheduler.
RTEMS_INLINE_ROUTINE void _Priority_bit_map_Remove(Priority_bit_map_Control *bit_map, Priority_bit_map_Information *bit_map_info)
Removes Priority queue bit map information.
Definition: prioritybitmapimpl.h:179
RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_initialize(Chain_Control *ready_queues, Priority_Control maximum_priority)
Ready queue initialization.
Definition: schedulerpriorityimpl.h:90
Inlined Routines in the Priority Handler Bit Map Implementation.
RTEMS_INLINE_ROUTINE void _Scheduler_Update_heir(Thread_Control *new_heir, bool force_dispatch)
Updates the heir.
Definition: schedulerimpl.h:1184
RTEMS_INLINE_ROUTINE Chain_Node * _Chain_First(const Chain_Control *the_chain)
Returns pointer to chain's first node.
Definition: chainimpl.h:260
Definition: thread.h:732
Data for ready queue operations.
Definition: schedulerpriority.h:85
Scheduler_priority_Ready_queue Ready_queue
The associated ready queue of this node.
Definition: schedulerpriority.h:110
Chain_Node Node
Definition: objectdata.h:41
Objects_Control Object
Definition: thread.h:734
RTEMS_INLINE_ROUTINE unsigned int _Priority_bit_map_Get_highest(const Priority_bit_map_Control *bit_map)
Gets highest portion of Priority queue bit map.
Definition: prioritybitmapimpl.h:196
RTEMS_INLINE_ROUTINE bool _Chain_Has_only_one_node(const Chain_Control *the_chain)
Checks if this chain has only one node.
Definition: chainimpl.h:450
Scheduler node specialization for Deterministic Priority schedulers.
Definition: schedulerpriority.h:101
RTEMS_INLINE_ROUTINE Scheduler_priority_Node * _Scheduler_priority_Thread_get_node(Thread_Control *the_thread)
Gets the scheduler node of the thread.
Definition: schedulerpriorityimpl.h:61
Chain Handler API.
RTEMS_INLINE_ROUTINE void _Chain_Append_unprotected(Chain_Control *the_chain, Chain_Node *the_node)
Appends a node (unprotected).
Definition: chainimpl.h:680
RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_update(Scheduler_priority_Ready_queue *ready_queue, unsigned int new_priority, Priority_bit_map_Control *bit_map, Chain_Control *ready_queues)
Updates the specified ready queue data according to the new priority value.
Definition: schedulerpriorityimpl.h:256
unsigned context
Definition: tlb.h:108
Scheduler control.
Definition: scheduler.h:269
Scheduler node for per-thread data.
Definition: schedulernode.h:79
RTEMS_INLINE_ROUTINE void _Priority_bit_map_Initialize_information(Priority_bit_map_Control *bit_map, Priority_bit_map_Information *bit_map_info, unsigned int new_priority)
Initializes the bit map information.
Definition: prioritybitmapimpl.h:234
RTEMS_INLINE_ROUTINE void _Scheduler_priority_Extract_body(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Extracts a node from the context of the scheduler.
Definition: schedulerpriorityimpl.h:175
RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_enqueue_first(Chain_Node *node, Scheduler_priority_Ready_queue *ready_queue, Priority_bit_map_Control *bit_map)
Enqueues a node on the specified ready queue as first.
Definition: schedulerpriorityimpl.h:132
RTEMS_INLINE_ROUTINE Scheduler_priority_Node * _Scheduler_priority_Node_downcast(Scheduler_Node *node)
Gets the priority node of the scheduler node.
Definition: schedulerpriorityimpl.h:75
RTEMS_INLINE_ROUTINE void _Chain_Prepend_unprotected(Chain_Control *the_chain, Chain_Node *the_node)
Prepends a node (unprotected).
Definition: chainimpl.h:732
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
Constants and Structures Related with the Thread Control Block.
#define _Assert(_e)
Assertion similar to assert() controlled via RTEMS_DEBUG instead of NDEBUG.
Definition: assert.h:100
RTEMS_INLINE_ROUTINE Scheduler_Node * _Thread_Scheduler_get_home_node(const Thread_Control *the_thread)
Gets the scheduler's home node.
Definition: threadimpl.h:1412
RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_extract(Chain_Node *node, Scheduler_priority_Ready_queue *ready_queue, Priority_bit_map_Control *bit_map)
Extracts a node from the specified ready queue.
Definition: schedulerpriorityimpl.h:151
