RTEMS  5.1
tlb.h File Reference
#include <arch/mm/tte.h>
#include <arch/mm/mmu.h>
#include <arch/mm/page.h>
#include <arch/asm.h>
#include <arch/barrier.h>
#include <arch/types.h>
#include <arch/register.h>
#include <arch/cpu.h>
union  tlb_context_reg
union  tlb_tag_read_reg
union  tlb_demap_addr
union  tlb_sfsr_reg
#define MEM_CONTEXT_KERNEL   0
#define MEM_CONTEXT_TEMP   1
#define PAGESIZE_8K   0
#define PAGESIZE_64K   1
#define PAGESIZE_512K   2
#define PAGESIZE_4M   3
#define KERNEL_PAGE_WIDTH   22 /* 4M */
#define TLB_DEMAP_PAGE   0
#define TLB_DEMAP_CONTEXT   1
#define TLB_DEMAP_TYPE_SHIFT   6
#define TLB_DEMAP_PRIMARY   0
#define TLB_DEMAP_SECONDARY   1
#define TLB_DEMAP_NUCLEUS   2
#define TLB_DEMAP_CONTEXT_SHIFT   4
#define TLB_TAG_ACCESS_CONTEXT_SHIFT   0
#define TLB_TAG_ACCESS_CONTEXT_MASK   ((1 << 13) - 1)
#define TLB_TAG_ACCESS_VPN_SHIFT   13
typedef union tlb_context_reg tlb_context_reg_t
typedef tte_data_t tlb_data_t
typedef union tlb_tag_read_reg tlb_tag_read_reg_t
typedef union tlb_tag_read_reg tlb_tag_access_reg_t
typedef union tlb_demap_addr tlb_demap_addr_t
typedef union tlb_sfsr_reg tlb_sfsr_reg_t
void fast_instruction_access_mmu_miss (unative_t, istate_t *)
void fast_data_access_mmu_miss (tlb_tag_access_reg_t, istate_t *)
void fast_data_access_protection (tlb_tag_access_reg_t, istate_t *)
void dtlb_insert_mapping (uintptr_t, uintptr_t, int, bool, bool)
void dump_sfsr_and_sfar (void)
void describe_dmmu_fault (void)
unsigned long
unsigned context
uint64_t vpn
unsigned __pad0__
unsigned e
unsigned ct
unsigned pr
unsigned w
unsigned ow
unsigned fv
Variable Documentation
◆ __pad0__
unsigned __pad0__
Zero.
◆ context
unsigned context
Context/ASID.
Context identifier.
Context register selection.
◆ ct
unsigned ct
Context Register selection.
◆ e
unsigned e
Side-effect bit.
◆ fv
unsigned fv
Fault Valid bit.
◆ ow
unsigned ow
Overwrite bit.
◆ pr
unsigned pr
Privilege bit.
◆ vpn
uint64_t vpn
Virtual Address bits 63:13.
◆ w
unsigned w
Write bit.
