RTEMS  5.1
ratemonimpl.h
1
9 /* COPYRIGHT (c) 1989-2008.
10  * On-Line Applications Research Corporation (OAR).
11  * Copyright (c) 2016 embedded brains GmbH.
12  * COPYRIGHT (c) 2016 Kuan-Hsun Chen.
13  *
14  * The license and distribution terms for this file may be
15  * found in the file LICENSE in this distribution or at
16  * http://www.rtems.org/license/LICENSE.
17  */
18
19 #ifndef _RTEMS_RTEMS_RATEMONIMPL_H
20 #define _RTEMS_RTEMS_RATEMONIMPL_H
21
23 #include <rtems/score/objectimpl.h>
25 #include <rtems/score/threadimpl.h>
27
28 #include <string.h>
29
30 #ifdef __cplusplus
31 extern "C" {
32 #endif
33
42 #define RATE_MONOTONIC_INTEND_TO_BLOCK \
43  ( THREAD_WAIT_CLASS_PERIOD | THREAD_WAIT_STATE_INTEND_TO_BLOCK )
44
45 #define RATE_MONOTONIC_BLOCKED \
46  ( THREAD_WAIT_CLASS_PERIOD | THREAD_WAIT_STATE_BLOCKED )
47
48 #define RATE_MONOTONIC_READY_AGAIN \
49  ( THREAD_WAIT_CLASS_PERIOD | THREAD_WAIT_STATE_READY_AGAIN )
50
59 {
60  return (Rate_monotonic_Control *)
62 }
63
64 RTEMS_INLINE_ROUTINE void _Rate_monotonic_Acquire_critical(
65  Rate_monotonic_Control *the_period,
66  ISR_lock_Context *lock_context
67 )
68 {
69  _ISR_lock_Acquire( &the_period->Lock, lock_context );
70 }
71
72 RTEMS_INLINE_ROUTINE void _Rate_monotonic_Release(
73  Rate_monotonic_Control *the_period,
74  ISR_lock_Context *lock_context
75 )
76 {
77  _ISR_lock_Release_and_ISR_enable( &the_period->Lock, lock_context );
78 }
79
80 RTEMS_INLINE_ROUTINE Rate_monotonic_Control *_Rate_monotonic_Get(
81  Objects_Id id,
82  ISR_lock_Context *lock_context
83 )
84 {
85  return (Rate_monotonic_Control *)
86  _Objects_Get( id, lock_context, &_Rate_monotonic_Information );
87 }
88
89 void _Rate_monotonic_Timeout( Watchdog_Control *watchdog );
90
107  const Rate_monotonic_Control *the_period,
108  Timestamp_Control *wall_since_last_period,
109  Timestamp_Control *cpu_since_last_period
110 );
111
112 void _Rate_monotonic_Restart(
113  Rate_monotonic_Control *the_period,
114  Thread_Control *owner,
115  ISR_lock_Context *lock_context
116 );
117
118 void _Rate_monotonic_Cancel(
119  Rate_monotonic_Control *the_period,
120  Thread_Control *owner,
121  ISR_lock_Context *lock_context
122 );
123
124 RTEMS_INLINE_ROUTINE void _Rate_monotonic_Reset_min_time(
125  Timestamp_Control *min_time
126 )
127 {
128  _Timestamp_Set( min_time, 0x7fffffff, 0x7fffffff );
129 }
130
131 RTEMS_INLINE_ROUTINE void _Rate_monotonic_Reset_statistics(
132  Rate_monotonic_Control *the_period
133 )
134 {
135  Rate_monotonic_Statistics *statistics;
136
137  statistics = &the_period->Statistics;
138  memset( statistics, 0, sizeof( *statistics ) );
139  _Rate_monotonic_Reset_min_time( &statistics->min_wall_time );
140  _Rate_monotonic_Reset_min_time( &statistics->min_cpu_time );
141 }
142
145 #ifdef __cplusplus
146 }
147 #endif
148
149 #endif
150 /* end of include file */
int64_t Timestamp_Control
Definition: timestamp.h:57
Timestamp_Control min_cpu_time
Definition: ratemondata.h:47
#define _ISR_lock_Release_and_ISR_enable(_lock, _context)
Releases an ISR lock.
Definition: isrlock.h:263
Objects_Information _Rate_monotonic_Information
The Classic Rate Monotonic objects information.
Inlined Routines in the Watchdog Handler.
Inlined Routines Associated with the Manipulation of the Scheduler.
The control block used to manage each watchdog timer.
Definition: watchdog.h:90
Objects_Control * _Objects_Allocate(Objects_Information *information)
Allocates an object.
Definition: objectallocate.c:42
Classic Rate Monotonic Scheduler Data Structures.
Definition: thread.h:732
Definition: ratemondata.h:40
Timestamp_Control min_wall_time
Definition: ratemondata.h:54
bool _Rate_monotonic_Get_status(const Rate_monotonic_Control *the_period, Timestamp_Control *wall_since_last_period, Timestamp_Control *cpu_since_last_period)
Definition: ratemonperiod.c:27
#define _ISR_lock_Acquire(_lock, _context)
Acquires an ISR lock inside an ISR disabled section.
Definition: isrlock.h:293
Rate_monotonic_Statistics Statistics
Definition: ratemondata.h:118
The following structure defines the control block used to manage each period.
Definition: ratemondata.h:69
RTEMS_INLINE_ROUTINE void _Timestamp_Set(Timestamp_Control *_time, time_t _seconds, long _nanoseconds)
Sets timestamp to specified seconds and nanoseconds.
Definition: timestampimpl.h:48
Inlined Routines from the Thread Handler.
uint32_t Objects_Id
Definition: object.h:80
Objects_Control * _Objects_Get(Objects_Id id, ISR_lock_Context *lock_context, const Objects_Information *information)
Maps the specified object identifier to the associated local object control block.
Definition: objectgetlocal.c:28
Local ISR lock context for acquire and release pairs.
Definition: isrlock.h:65
Inlined Routines in the Object Handler.
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
RTEMS_INLINE_ROUTINE Rate_monotonic_Control * _Rate_monotonic_Allocate(void)
Allocates a period control block from the inactive chain of free period control blocks.
Definition: ratemonimpl.h:58
