RTEMS  5.1
Macros | Functions
qspi.c File Reference
#include "chip.h"
#include "stdlib.h"
#include "string.h"
#include <stdint.h>
#include <bsp/iocopy.h>
#define SCRAMBLE_KEY   0x0BADDEAD
__STATIC_INLINE void QSPI_ConfigureMode (Qspi *pQspi, uint8_t dMode)
 Configure QSPI/SPI mode. More...
__STATIC_INLINE void QSPI_Configure (Qspi *pQspi, uint32_t dwConfiguration)
 Configure mode register of QSPI. More...
__STATIC_INLINE void QSPI_SetInstAddr (Qspi *pQspi, uint32_t dwAddr)
 Configures a instruction address for QSPI in QSPI mode. More...
__STATIC_INLINE void QSPI_SetInst (Qspi *pQspi, uint8_t dwInst, uint8_t dwOpt)
 Configures instruction register with a given command for QSPI. More...
__STATIC_INLINE void QSPI_SetInstFrame (Qspi *pQspi, QspiInstFrame_t *pInstFrame)
 Configures instruction frame register of QSPI. More...
__STATIC_INLINE uint32_t QSPI_GetInstFrame (Qspi *pQspi)
 Reads the Instruction frame of QSPI. More...
__STATIC_INLINE uint16_t QSPI_ReadSPI (Qspi *pQspi)
 Read QSPI RDR register for SPI mode. More...
__STATIC_INLINE void QSPI_WriteSPI (Qspi *pQspi, uint16_t wData)
 Write to QSPI Tx register in SPI mode. More...
__STATIC_INLINE void QSPI_ScrambleData (Qspi *pQspi, uint32_t wKey, uint8_t EnableFlag, uint8_t Random)
 Configures QSPI scrambling with a given Key. More...
void QSPI_Enable (Qspi *pQspi)
 Enables a QSPI peripheral. More...
void QSPI_Disable (Qspi *pQspi)
 Disables a QSPI peripheral. More...
void QSPI_SwReset (Qspi *pQspi)
 Resets a QSPI peripheral. More...
QspidStatus_t QSPI_EnableIt (Qspi *pQspi, uint32_t dwSources)
 Enables one or more interrupt sources of a QSPI peripheral. More...
QspidStatus_t QSPI_DisableIt (Qspi *pQspi, uint32_t dwSources)
 Disables one or more interrupt sources of a QSPI peripheral. More...
uint32_t QSPI_GetItMask (Qspi *pQspi)
 Return the interrupt mask register. More...
uint32_t QSPI_GetEnabledItStatus (Qspi *pQspi)
 Returns enabled interrupt status. More...
uint32_t QSPI_GetStatus (Qspi *pQspi, const QspiStatus_t rStatus)
 Get the current status register of the given QSPI peripheral. More...
void QSPI_ConfigureClock (Qspi *pQspi, QspiClockMode_t ClockMode, uint32_t dwClockCfg)
 Configures peripheral clock of a QSPI/SPI peripheral. More...
QspidStatus_t QSPI_ConfigureInterface (Qspid_t *pQspid, QspiMode_t Mode, uint32_t dwConfiguration)
 Configures QSPI/SPI. More...
QspidStatus_t QSPI_EndTransfer (Qspi *pQspi)
 Ends ongoing transfer by releasing CS of QSPI peripheral. More...
QspidStatus_t QSPI_SingleReadSPI (Qspid_t *pQspid, uint16_t *const pData)
 Reads the data received by a SPI peripheral. This method must be called after a successful SPI_Write call. More...
QspidStatus_t QSPI_MultiReadSPI (Qspid_t *pQspid, uint16_t *const pData, uint32_t NumOfBytes)
 Reads multiple data received by a SPI peripheral. This method must be called after a successful SPI_Write call. More...
QspidStatus_t QSPI_SingleWriteSPI (Qspid_t *pQspid, uint16_t const *pData)
 Sends a single data through a SPI peripheral. More...
QspidStatus_t QSPI_MultiWriteSPI (Qspid_t *pQspid, uint16_t const *pData, uint32_t NumOfBytes)
 Sends multiple data through a SPI peripheral. More...
QspidStatus_t QSPI_SendCommand (Qspid_t *pQspid, uint8_t const KeepCfg)
 Send an instruction over QSPI (oly a flash command no data) More...
QspidStatus_t QSPI_SendCommandWithData (Qspid_t *pQspid, uint8_t const KeepCfg)
 Send instruction over QSPI with data. More...
QspidStatus_t QSPI_ReadCommand (Qspid_t *pQspid, uint8_t const KeepCfg)
 Send instruction over QSPI to read data. More...
QspidStatus_t QSPI_EnableMemAccess (Qspid_t *pQspid, uint8_t const KeepCfg, uint8_t ScrambleFlag)
 Sends an instruction over QSPI and configures other related address like Addr , Frame and synchronise bus access before data read or write. More...
QspidStatus_t QSPI_ReadWriteMem (Qspid_t *pQspid, Access_t const ReadWrite)
 Writes or reads the QSPI memory (0x80000000) to transmit or receive data from Flash memory. More...
Implementation of Serial Peripheral Interface (QSPI) controller.
◆ QSPI_Configure()
__STATIC_INLINE void QSPI_Configure ( Qspi pQspi,
Parameters
pQspiPointer to a Qspi instance.
◆ QSPI_ConfigureClock()
void QSPI_ConfigureClock ( Qspi pQspi,
uint32_t  dwClockCfg
Parameters
pQspiPointer to an Qspi instance.
dwConfigurationDesired clock configuration.
◆ QSPI_ConfigureInterface()
QspidStatus_t QSPI_ConfigureInterface ( Qspid_t pQspid,
QspiMode_t  Mode,
Parameters
ModeMode for QSPI or SPI
dwConfigurationConfig of SPI or QSPI mode
◆ QSPI_ConfigureMode()
__STATIC_INLINE void QSPI_ConfigureMode ( Qspi pQspi,
uint8_t  dMode
Parameters
◆ QSPI_Disable()
void QSPI_Disable ( Qspi pQspi)
Parameters
◆ QSPI_DisableIt()
QspidStatus_t QSPI_DisableIt ( Qspi pQspi,
uint32_t  dwSources
Parameters
sourcesBitwise OR of selected interrupt sources.
◆ QSPI_Enable()
void QSPI_Enable ( Qspi pQspi)
Parameters
◆ QSPI_EnableIt()
QspidStatus_t QSPI_EnableIt ( Qspi pQspi,
uint32_t  dwSources
Parameters
◆ QSPI_EnableMemAccess()
QspidStatus_t QSPI_EnableMemAccess ( Qspid_t pQspid,
Parameters
KeepCfgTo keep Instruction from value or resets to zero
ScrambleFlagEnable or disable scramble on QSPI
Returns
Returns 1 if At least one instruction end has been detected since the last read of QSPI_SR.; otherwise returns 0.
◆ QSPI_EndTransfer()
QspidStatus_t QSPI_EndTransfer ( Qspi pQspi)
Parameters
◆ QSPI_GetEnabledItStatus()
uint32_t QSPI_GetEnabledItStatus ( Qspi pQspi)
Returns
Qspi interrupt mask register.
◆ QSPI_GetInstFrame()
__STATIC_INLINE uint32_t QSPI_GetInstFrame ( Qspi pQspi)
Parameters
◆ QSPI_GetItMask()
uint32_t QSPI_GetItMask ( Qspi pQspi)
Returns
◆ QSPI_GetStatus()
uint32_t QSPI_GetStatus ( Qspi pQspi,
Note
This resets the internal value of the status register, so further read may yield different values.
Parameters
rStatusCompare status with given status bit
Returns
QSPI status register.
◆ QSPI_MultiReadSPI()
QspidStatus_t QSPI_MultiReadSPI ( Qspid_t pQspid,
uint32_t  NumOfBytes
Parameters
pQspidPointer to a Qspi instance.
pDataPointer to read buffer
NumOfBytesNum of bytes to read
Returns
Qspi status
◆ QSPI_MultiWriteSPI()
QspidStatus_t QSPI_MultiWriteSPI ( Qspid_t pQspid,
uint16_t const *  pData,
uint32_t  NumOfBytes
Parameters
pDataPointer to a Tx buffer
NumOfBytesNum of data to send.
◆ QSPI_ReadCommand()
QspidStatus_t QSPI_ReadCommand ( Qspid_t pQspid,
Parameters
Returns
◆ QSPI_ReadSPI()
__STATIC_INLINE uint16_t QSPI_ReadSPI ( Qspi pQspi)
Parameters
◆ QSPI_ReadWriteMem()
QspidStatus_t QSPI_ReadWriteMem ( Qspid_t pQspid,
Parameters
ReadWriteFlag to indicate read/write QSPI memory access
Returns
◆ QSPI_ScrambleData()
__STATIC_INLINE void QSPI_ScrambleData ( Qspi pQspi,
uint32_t  wKey,
uint8_t  EnableFlag,
uint8_t  Random
Parameters
wKeyKey for scramble/unscramble
EnableFlagEnable/disable scramble
RandomAdd random value with given key
◆ QSPI_SendCommand()
QspidStatus_t QSPI_SendCommand ( Qspid_t pQspid,
Parameters
KeepCfgTo keep Instruction fram value or restes to zero
Returns
◆ QSPI_SendCommandWithData()
QspidStatus_t QSPI_SendCommandWithData ( Qspid_t pQspid,
Parameters
Returns
◆ QSPI_SetInst()
__STATIC_INLINE void QSPI_SetInst ( Qspi pQspi,
uint8_t  dwInst,
uint8_t  dwOpt
Parameters
dwInstInstruction Code
dwOptInstruction Code option
◆ QSPI_SetInstAddr()
__STATIC_INLINE void QSPI_SetInstAddr ( Qspi pQspi,
uint32_t  dwAddr
Parameters
dwAddrInstruction Address
◆ QSPI_SetInstFrame()
__STATIC_INLINE void QSPI_SetInstFrame ( Qspi pQspi,
QspiInstFrame_t pInstFrame
Parameters
pInstFrameInstruction Frame configuration
◆ QSPI_SingleReadSPI()
QspidStatus_t QSPI_SingleReadSPI ( Qspid_t pQspid,
Parameters
pDataBuffer to put read value
Returns
Qspi status
◆ QSPI_SingleWriteSPI()
QspidStatus_t QSPI_SingleWriteSPI ( Qspid_t pQspid,
Parameters
pDataPointer to Tx data
Returns
Qspi status
◆ QSPI_SwReset()
void QSPI_SwReset ( Qspi pQspi)
Parameters
◆ QSPI_WriteSPI()
__STATIC_INLINE void QSPI_WriteSPI ( Qspi pQspi,
uint16_t  wData
Parameters
wDataData to transmit
