RTEMS
5.1
struct | QspiMemCmd_t |
qspi command structure More... | |
struct | QspiBuffer_t |
qspi buffer structure More... | |
struct | QspiInstFrame_t |
qspi frame structure for QSPI mode More... | |
union | QspiInstFrame_t::_QspiInstFrame |
struct | QspiInstFrame_t::_QspiInstFrame::_QspiInstFrameBM |
struct | Qspid_t |
qspi driver structure More... | |
#define | QSPI_SCBR(baudrate, masterClock) ((uint32_t) (masterClock / baudrate) << 8) |
#define | QSPI_DLYBS(delay, masterClock) ((uint32_t) (((masterClock / 1000000) * delay) / 1000) << 16) |
#define | QSPI_DLYBCT(delay, masterClock) ((uint32_t) (((masterClock / 1000000) * delay) / 32000) << 24) |
Enumerations | |
enum | Access_t { CmdAccess = 0, ReadAccess, WriteAccess } |
qspi access modes | |
enum | QspiMode_t { SpiMode = QSPI_MR_SMM_SPI, QspiMemMode = QSPI_MR_SMM_MEMORY } |
qspi modes SPI or QSPI | |
enum | QspiClockMode_t { ClockMode_00 = 0, ClockMode_10, ClockMode_01, ClockMode_11 } |
qspi clock modes , regarding clock phase and clock polarity | |
enum | QspidStatus_t { QSPI_SUCCESS = 0, QSPI_BUSY, QSPI_BUSY_SENDING, QSPI_READ_ERROR, QSPI_WRITE_ERROR, QSPI_UNKNOWN_ERROR, QSPI_INIT_ERROR, QSPI_INPUT_ERROR, QSPI_TOTAL_ERROR } |
qspi status codes | |
enum | QspiStatus_t { IsReceived = QSPI_SR_RDRF, IsTxSent = QSPI_SR_TDRE, IsTxEmpty = QSPI_SR_TXEMPTY, IsOverrun = QSPI_SR_OVRES, IsCsRise = QSPI_SR_CSR, IsCsAsserted = QSPI_SR_CSS, IsEofInst = QSPI_SR_INSTRE, IsEnabled = QSPI_SR_QSPIENS } |
qspi status regiter bits | |
void | QSPI_SwReset (Qspi *pQspi) |
Resets a QSPI peripheral. More... | |
void | QSPI_Disable (Qspi *pQspi) |
Disables a QSPI peripheral. More... | |
void | QSPI_Enable (Qspi *pQspi) |
Enables a QSPI peripheral. More... | |
QspidStatus_t | QSPI_EndTransfer (Qspi *pQspi) |
Ends ongoing transfer by releasing CS of QSPI peripheral. More... | |
uint32_t | QSPI_GetStatus (Qspi *pQspi, const QspiStatus_t rStatus) |
Get the current status register of the given QSPI peripheral. More... | |
void | QSPI_ConfigureClock (Qspi *pQspi, QspiClockMode_t ClockMode, uint32_t dwClockCfg) |
Configures peripheral clock of a QSPI/SPI peripheral. More... | |
QspidStatus_t | QSPI_SingleReadSPI (Qspid_t *pQspid, uint16_t *const pData) |
Reads the data received by a SPI peripheral. This method must be called after a successful SPI_Write call. More... | |
QspidStatus_t | QSPI_MultiReadSPI (Qspid_t *pQspid, uint16_t *const pData, uint32_t NumOfBytes) |
Reads multiple data received by a SPI peripheral. This method must be called after a successful SPI_Write call. More... | |
QspidStatus_t | QSPI_SingleWriteSPI (Qspid_t *pQspid, uint16_t const *pData) |
Sends a single data through a SPI peripheral. More... | |
QspidStatus_t | QSPI_MultiWriteSPI (Qspid_t *pQspid, uint16_t const *pData, uint32_t NumOfBytes) |
Sends multiple data through a SPI peripheral. More... | |
QspidStatus_t | QSPI_EnableIt (Qspi *pQspi, uint32_t dwSources) |
Enables one or more interrupt sources of a QSPI peripheral. More... | |
QspidStatus_t | QSPI_DisableIt (Qspi *pQspi, uint32_t dwSources) |
Disables one or more interrupt sources of a QSPI peripheral. More... | |
uint32_t | QSPI_GetItMask (Qspi *pQspi) |
Return the interrupt mask register. More... | |
uint32_t | QSPI_GetEnabledItStatus (Qspi *pQspi) |
Returns enabled interrupt status. More... | |
QspidStatus_t | QSPI_ConfigureInterface (Qspid_t *pQspid, QspiMode_t Mode, uint32_t dwConfiguration) |
Configures QSPI/SPI. More... | |
QspidStatus_t | QSPI_SendCommand (Qspid_t *pQspi, uint8_t const KeepCfg) |
Send an instruction over QSPI (oly a flash command no data) More... | |
QspidStatus_t | QSPI_SendCommandWithData (Qspid_t *pQspi, uint8_t const KeepCfg) |
Send instruction over QSPI with data. More... | |
QspidStatus_t | QSPI_ReadCommand (Qspid_t *pQspi, uint8_t const KeepCfg) |
Send instruction over QSPI to read data. More... | |
QspidStatus_t | QSPI_EnableMemAccess (Qspid_t *pQspi, uint8_t const KeepCfg, uint8_t ScrambleFlag) |
Sends an instruction over QSPI and configures other related address like Addr , Frame and synchronise bus access before data read or write. More... | |
QspidStatus_t | QSPI_ReadWriteMem (Qspid_t *pQspid, Access_t const ReadWrite) |
Writes or reads the QSPI memory (0x80000000) to transmit or receive data from Flash memory. More... | |
Interface for Serial Peripheral Interface (SPI) controller.
#define QSPI_DLYBCT | ( | delay, | |
masterClock | |||
) | ((uint32_t) (((masterClock / 1000000) * delay) / 32000) << 24) |
Calculates the value of the CSR DLYBCT field given the desired delay (in ns)
#define QSPI_DLYBS | ( | delay, | |
masterClock | |||
) | ((uint32_t) (((masterClock / 1000000) * delay) / 1000) << 16) |
Calculates the value of the CSR DLYBS field given the desired delay (in ns)
#define QSPI_SCBR | ( | baudrate, | |
masterClock | |||
) | ((uint32_t) (masterClock / baudrate) << 8) |
Here are several macros which should be used when configuring a SPI peripheral.
void QSPI_ConfigureClock | ( | Qspi * | pQspi, |
QspiClockMode_t | ClockMode, | ||
uint32_t | dwClockCfg | ||
pQspi | Pointer to an Qspi instance. |
dwConfiguration | Desired clock configuration. |
QspidStatus_t QSPI_ConfigureInterface | ( | Qspid_t * | pQspid, |
QspiMode_t | Mode, | ||
uint32_t | dwConfiguration | ||
Mode | Mode for QSPI or SPI |
dwConfiguration | Config of SPI or QSPI mode |
void QSPI_Disable | ( | Qspi * | pQspi | ) |
pQspi | Pointer to a Qspi instance. |
QspidStatus_t QSPI_DisableIt | ( | Qspi * | pQspi, |
uint32_t | dwSources | ||
sources | Bitwise OR of selected interrupt sources. |
void QSPI_Enable | ( | Qspi * | pQspi | ) |
QspidStatus_t QSPI_EnableIt | ( | Qspi * | pQspi, |
QspidStatus_t QSPI_EnableMemAccess | ( | Qspid_t * | pQspid, |
uint8_t const | KeepCfg, | ||
uint8_t | ScrambleFlag | ||
KeepCfg | To keep Instruction from value or resets to zero |
ScrambleFlag | Enable or disable scramble on QSPI |
QspidStatus_t QSPI_EndTransfer | ( | Qspi * | pQspi | ) |
uint32_t QSPI_GetEnabledItStatus | ( | Qspi * | pQspi | ) |
uint32_t QSPI_GetItMask | ( | Qspi * | pQspi | ) |
uint32_t QSPI_GetStatus | ( | Qspi * | pQspi, |
const QspiStatus_t | rStatus | ||
rStatus | Compare status with given status bit |
QspidStatus_t QSPI_MultiReadSPI | ( | Qspid_t * | pQspid, |
uint16_t *const | pData, | ||
uint32_t | NumOfBytes | ||
QspidStatus_t QSPI_MultiWriteSPI | ( | Qspid_t * | pQspid, |
uint16_t const * | pData, | ||
pQspid | Pointer to a Qspi instance. |
pData | Pointer to a Tx buffer |
NumOfBytes | Num of data to send. |
QspidStatus_t QSPI_ReadCommand | ( | Qspid_t * | pQspid, |
uint8_t const | KeepCfg | ||
QspidStatus_t QSPI_ReadWriteMem | ( | Qspid_t * | pQspid, |
Access_t const | ReadWrite | ||
ReadWrite | Flag to indicate read/write QSPI memory access |
QspidStatus_t QSPI_SendCommand | ( | Qspid_t * | pQspid, |
KeepCfg | To keep Instruction fram value or restes to zero |
QspidStatus_t QSPI_SendCommandWithData | ( | Qspid_t * | pQspid, |
QspidStatus_t QSPI_SingleReadSPI | ( | Qspid_t * | pQspid, |
uint16_t *const | pData | ||
QspidStatus_t QSPI_SingleWriteSPI | ( | Qspid_t * | pQspid, |
uint16_t const * | pData | ||
