RTEMS  5.1
pthreadimpl.h
1
10 /*
11  * COPYRIGHT (c) 1989-2011.
12  * On-Line Applications Research Corporation (OAR).
13  *
14  * The license and distribution terms for this file may be
15  * found in the file LICENSE in this distribution or at
16  * http://www.rtems.org/license/LICENSE.
17  */
18
19 #ifndef _RTEMS_POSIX_PTHREADIMPL_H
20 #define _RTEMS_POSIX_PTHREADIMPL_H
21
22 #include <rtems/posix/pthread.h>
23 #include <rtems/posix/threadsup.h>
24 #include <rtems/score/assert.h>
25 #include <rtems/score/objectimpl.h>
26 #include <rtems/score/timespec.h>
27 #include <rtems/score/threadimpl.h>
29
30 #ifdef __cplusplus
31 extern "C" {
32 #endif
33
42 #define PTHREAD_MINIMUM_STACK_SIZE _POSIX_Threads_Minimum_stack_size
43
44 #if defined(RTEMS_POSIX_API)
45 RTEMS_INLINE_ROUTINE void _POSIX_Threads_Sporadic_timer_insert(
46  Thread_Control *the_thread,
47  POSIX_API_Control *api
48 )
49 {
50  the_thread->cpu_time_budget =
51  _Timespec_To_ticks( &api->Sporadic.sched_ss_init_budget );
52
54  &api->Sporadic.Timer,
55  _Per_CPU_Get(),
56  _Timespec_To_ticks( &api->Sporadic.sched_ss_repl_period )
57  );
58 }
59 #endif
60
61 void _POSIX_Threads_Sporadic_timer( Watchdog_Control *watchdog );
62
72  Thread_Control *the_thread
73 );
74
75 int _POSIX_Thread_Translate_to_sched_policy(
76  Thread_CPU_budget_algorithms budget_algorithm
77 );
78
94  int policy,
95  const struct sched_param *param,
96  Thread_CPU_budget_algorithms *budget_algorithm,
98 );
99
100 RTEMS_INLINE_ROUTINE Thread_Control *_POSIX_Threads_Allocate(void)
101 {
103
105
106  return (Thread_Control *)
108 }
109
110 RTEMS_INLINE_ROUTINE void _POSIX_Threads_Free (
111  Thread_Control *the_pthread
112 )
113 {
115 }
116
119 #ifdef __cplusplus
120 }
121 #endif
122
123 #endif
124 /* end of include file */
RTEMS_INLINE_ROUTINE Objects_Control * _Objects_Allocate_unprotected(Objects_Information *information)
Allocates an object without locking the allocator mutex.
Definition: objectimpl.h:874
uint32_t _Timespec_To_ticks(const struct timespec *time)
Converts timespec to number of ticks.
Definition: timespectoticks.c:27
void _Thread_Kill_zombies(void)
Kills all zombie threads in the system.
Definition: threadrestart.c:216
Inlined Routines in the Watchdog Handler.
The control block used to manage each watchdog timer.
Definition: watchdog.h:90
POSIX Threads Private Support.
POSIX Thread API Support.
Objects_Information Objects
The object information.
Definition: thread.h:1001
Information for the Assert Handler.
Definition: thread.h:732
Objects_Control Object
Definition: thread.h:734
void _POSIX_Threads_Sporadic_budget_callout(Thread_Control *the_thread)
POSIX threads sporadic budget callout.
Definition: thread.h:164
RTEMS_INLINE_ROUTINE void _Objects_Free(Objects_Information *information, Objects_Control *the_object)
Frees an object.
Definition: objectimpl.h:930
Thread_Information _POSIX_Threads_Information
int _POSIX_Thread_Translate_sched_param(int policy, const struct sched_param *param, Thread_CPU_budget_algorithms *budget_algorithm, Thread_CPU_budget_algorithm_callout *budget_callout)
Translate sched_param into SuperCore terms.
Definition: psxtransschedparam.c:44
void(* Thread_CPU_budget_algorithm_callout)(Thread_Control *)
Definition: thread.h:178
Inlined Routines from the Thread Handler.
Contains Helpers for Manipulating Timespecs.
RTEMS_INLINE_ROUTINE void _Objects_Allocator_lock(void)
Locks the object allocator mutex.
Definition: objectimpl.h:831
Inlined Routines in the Object Handler.
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Per_CPU_insert_ticks(Watchdog_Control *the_watchdog, Per_CPU_Control *cpu, Watchdog_Interval ticks)
Sets the watchdog's cpu to the given instance and sets its expiration time to the watchdog expiration...
Definition: watchdogimpl.h:593
uint32_t cpu_time_budget
Definition: thread.h:816
