RTEMS  5.1
posixapi.h
1
10 /*
11  * COPYRIGHT (c) 1989-2011.
12  * On-Line Applications Research Corporation (OAR).
13  *
14  * The license and distribution terms for this file may be
15  * found in the file LICENSE in this distribution or at
16  * http://www.rtems.org/license/LICENSE.
17  */
18
19 #ifndef _RTEMS_POSIX_POSIXAPI_H
20 #define _RTEMS_POSIX_POSIXAPI_H
21
22 #include <rtems/config.h>
23 #include <rtems/score/assert.h>
24 #include <rtems/score/objectimpl.h>
25 #include <rtems/score/threadimpl.h>
26 #include <rtems/seterr.h>
27
28 #include <pthread.h>
29
43 typedef enum {
47
56 void _POSIX_Fatal_error( POSIX_Fatal_domain domain, int eno );
57
58 extern const int _POSIX_Get_by_name_error_table[ 3 ];
59
60 RTEMS_INLINE_ROUTINE int _POSIX_Get_by_name_error(
61  Objects_Get_by_name_error error
62 )
63 {
64  _Assert( (size_t) error < RTEMS_ARRAY_SIZE( _POSIX_Get_by_name_error_table ) );
65  return _POSIX_Get_by_name_error_table[ error ];
66 }
67
68 RTEMS_INLINE_ROUTINE int _POSIX_Get_error( Status_Control status )
69 {
70  return STATUS_GET_POSIX( status );
71 }
72
73 RTEMS_INLINE_ROUTINE int _POSIX_Get_error_after_wait(
74  const Thread_Control *executing
75 )
76 {
77  return _POSIX_Get_error( _Thread_Wait_get_status( executing ) );
78 }
79
80 RTEMS_INLINE_ROUTINE int _POSIX_Zero_or_minus_one_plus_errno(
81  Status_Control status
82 )
83 {
84  if ( status == STATUS_SUCCESSFUL ) {
85  return 0;
86  }
87
88  rtems_set_errno_and_return_minus_one( _POSIX_Get_error( status ) );
89 }
90
91 /*
92  * See also The Open Group Base Specifications Issue 7, IEEE Std 1003.1-2008,
93  * 2016 Edition, subsection 2.9.9, Synchronization Object Copies and
94  * Alternative Mappings.
95  *
96  * http://pubs.opengroup.org/onlinepubs/9699919799/functions/V2_chap02.html#tag_15_09_09
97  */
98 RTEMS_INLINE_ROUTINE bool _POSIX_Is_valid_pshared( int pshared )
99 {
100  return pshared == PTHREAD_PROCESS_PRIVATE ||
101  pshared == PTHREAD_PROCESS_SHARED;
102 }
103
106 #endif
107 /* end of include file */
RTEMS_INLINE_ROUTINE Status_Control _Thread_Wait_get_status(const Thread_Control *the_thread)
Get the status of the wait return code of the thread.
Definition: threadimpl.h:2328
Data which Ease the Burden of Consistently Setting Errno.
void _POSIX_Fatal_error(POSIX_Fatal_domain domain, int eno)
POSIX API Fatal error.
Definition: posixapi.c:174
POSIX Threads Private Support.
Information for the Assert Handler.
POSIX_Fatal_domain
POSIX API Fatal domains.
Definition: posixapi.h:43
Definition: thread.h:732
Definition: posixapi.h:44
Definition: posixapi.h:45
Inlined Routines from the Thread Handler.
#define rtems_set_errno_and_return_minus_one(_error)
Definition: seterr.h:48
Inlined Routines in the Object Handler.
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
#define _Assert(_e)
Assertion similar to assert() controlled via RTEMS_DEBUG instead of NDEBUG.
Definition: assert.h:100
