file | _execve.c |
| _execve()
file | adjtime.c |
| Adjust the Time to Synchronize the System Clock.
file | aio_error.c |
| Returns the error status for the Asynchronous I/O request.
file | aio_fsync.c |
| Syncing of all Outstanding Asynchronous I/O Operations.
file | aio_misc.c |
| Actual request being processed.
file | aio_read.c |
| Asynchronously reads Data from a File.
file | aio_return.c |
| Final return status for Asynchronous I/O request pointed to by aiobcp.
file | aio_suspend.c |
| Suspends Process until Asynchronous I/O Operation completes.
file | aio_write.c |
| Function queues I/O request described by buffer pointed by aiocb.
file | alarm.c |
| System Generates Signal for process after realtime seconds elapsed.
file | barrierattrdestroy.c |
| Function shall Destroy a Barrier Attribues Object.
file | barrierattrgetpshared.c |
| Barrier Attributes Get Process Shared.
file | barrierattrinit.c |
| Initialize the Barrier Attributes Object.
file | barrierattrsetpshared.c |
| Set the Process-Shared Attribute of the Barrier Attributes Object.
file | cancel.c |
| Canceling Execution of a Thread.
file | cleanuppush.c |
| POSIX Cleanup Support.
file | clockgetcpuclockid.c |
| Function Returns Clock ID of CPU-time Clock of process specified.
file | clockgetres.c |
| Function Returns the Resolution of any Clock.
file | clockgettime.c |
| Retrieves the Specified Clock Time.
file | clocksettime.c |
| Set Time of Clock.
file | condattrdestroy.c |
| Destroy Condition Attribute.
file | condattrgetclock.c |
| Get the Clock Condition Variable Attributes.
file | condattrgetpshared.c |
| Get the Process-Shared Condition Variable Attributes.
file | condattrinit.c |
| Initialization of Conditional Attributes.
file | condattrsetclock.c |
| Set the Clock Condition Variable Attributes.
file | condattrsetpshared.c |
| Set the Process-Shared Condition Variable Attributes.
file | condbroadcast.c |
| Broadcast a Condition.
file | conddefaultattributes.c |
| Condition variable Attributes structure.
file | conddestroy.c |
| Destroy a Condition Variable.
file | condinit.c |
| Initialize a Condition Variable.
file | condsignal.c |
| Signal a Condition.
file | condtimedwait.c |
| Waiting on a Condition.
file | condwait.c |
file | fork.c |
| Inoperable implementation of fork() for POSIX threads.
file | getitimer.c |
| Function Gets Value of an Interval Timer.
file | keycreate.c |
| Thread-Specific Data Key Create.
file | keydelete.c |
| Deletes Thread-specific Data Key Previously Returned by keycreate.c.
file | keygetspecific.c |
| Thread-Specific Data Management.
file | keysetspecific.c |
| Set Specific Key.
file | kill.c |
| Send a Signal to a Process.
file | kill_r.c |
file | killinfo.c |
file | lio_listio.c |
| Function Initiates a List of I/O Requests with Single Function Call.
file | mprotect.c |
| Change Memory Protection.
file | mqueueclose.c |
| Function closes the Message Queue.
file | mqueuegetattr.c |
| Message Queue Attributes.
file | mqueueopen.c |
| Creates a new POSIX Message Queue or Opens an Existing Queue.
file | mqueuesend.c |
| Adds Message Pointed by msg_ptr to Message Queue Reffered by mqdes.
file | mqueuesendsupp.c |
| POSIX Message Queue and Send Support.
file | mqueuetimedreceive.c |
| Receive Message from Message Queue.
file | mutexattrdestroy.c |
| Destroy Mutex Attributes Object.
file | mutexattrgetprioceiling.c |
| Mutex Initialization Scheduling Attributes.
file | mutexattrgetprotocol.c |
| Get protocol Attribute of Mutex Attribute Obect.
file | mutexattrgetpshared.c |
| Obtaining process-shared Attribute Value from the Attributes Object.
file | mutexattrgettype.c |
| Function gets the Mutex Type Attribute.
file | mutexattrinit.c |
| Mutex Initialization Attribute.
file | mutexattrsetprioceiling.c |
file | mutexattrsetprotocol.c |
file | mutexattrsetpshared.c |
| Function sets Current pshared Attribute for Mutex Attributes Object.
file | mutexattrsettype.c |
| Set a Mutex Type.
file | mutexdestroy.c |
| Initializing and Destroying a Mutex.
file | mutexgetprioceiling.c |
| Returns the Current Priority Ceiling of the Mutex.
file | mutexinit.c |
| Initialize a Mutex.
file | mutexlock.c |
| Call to function enables locking of Mutex Object referenced by mutex.
file | mutexlocksupp.c |
| Support Call to function Enables Locking of Mutex Object.
file | mutexsetprioceiling.c |
| Changes the Priority Ceiling of a Mutex and Releases it.
file | mutextimedlock.c |
| Mutex Timed Lock.
file | mutextrylock.c |
| Try to Lock Mutex.
file | mutexunlock.c |
| Locking and Unlocking a Mutex.
file | nanosleep.c |
| Suspends Execution of calling thread until Time elapses.
file | pause.c |
| Suspend Process Execution.
file | pbarrierdestroy.c |
| Destroy a Barrier Object.
file | pbarrierinit.c |
| Call to Function Enables Reinitializing of the Barrier.
file | pbarrierwait.c |
| Wait at a Barrier.
file | prwlockdestroy.c |
| Destroy a RWLock.
file | prwlockinit.c |
| Allocate resources to use the read-write lock and Initialize it.
file | prwlockrdlock.c |
| Obtain a Read Lock on a RWLock Instance.
file | prwlocktimedrdlock.c |
| Attempt to Obtain a Read Lock on a RWLock Instance.
file | prwlocktimedwrlock.c |
| Function applies a Write lock to RWLock referenced by rwlock.
file | prwlocktryrdlock.c |
file | prwlocktrywrlock.c |
| Attempt to Obtain a Write Lock on a RWLock Instance.
file | prwlockunlock.c |
| Function Releases a lock held on RWLock object referenced by rwlock.
file | prwlockwrlock.c |
| Obtain a Write Lock on a RWlock Instance.
file | psignalclearprocesssignals.c |
| POSIX_signals clear_process_signals.
file | pspindestroy.c |
| Destroy a Spinlock.
file | pspininit.c |
| POSIX Function Initializes a Spinlock Instance.
file | pspinlock.c |
| Wait at a Spinlock.
file | pspinunlock.c |
| Function Unlocks a Spin Lock Object.
file | psxnametoid.c |
| POSIX Name to ID.
file | psxtimerdelete.c |
| Deletes a POSIX Interval Timer.
file | pthreadatfork.c |
| Register Fork Handlers.
file | pthreadattrdestroy.c |
| Thread Creation Attributes.
file | pthreadattrgetaffinitynp.c |
| Pthread Attribute Get Affinity.
file | pthreadattrgetdetachstate.c |
| Function gets the detachstate Attribute in the attr Object.
file | pthreadattrgetguardsize.c |
file | pthreadattrgetinheritsched.c |
| Thread Creation Scheduling Attributes.
file | pthreadattrgetschedparam.c |
| Returns Scheduling Parameter Attributes of Thread Attributes Object.
file | pthreadattrgetschedpolicy.c |
| Get The Schedpolicy Attribute.
file | pthreadattrgetscope.c |
| Function gets the Contentionscope Attribute in the attr object.
file | pthreadattrgetstack.c |
| Function Gets the Thread Creation Stack Attributes in the attr.
file | pthreadattrgetstackaddr.c |
file | pthreadattrgetstacksize.c |
file | pthreadattrinit.c |
| Thread Attributes Creation.
file | pthreadattrsetaffinitynp.c |
| Pthread Attribute Set Affinity.
file | pthreadattrsetdetachstate.c |
file | pthreadattrsetguardsize.c |
file | pthreadattrsetinheritsched.c |
| Function sets the inheritsched Attribute in the attr Argument.
file | pthreadattrsetschedparam.c |
| Thread Creation Scheduling Parameters.
file | pthreadattrsetschedpolicy.c |
| Sets Scheduling policy Attributes of Thread Attributes Object.
file | pthreadattrsetscope.c |
| Function Sets the Contentionscope Attribute in the attr Object.
file | pthreadattrsetstack.c |
| Function Sets Thread Creation Stack Attributes in the attr object.
file | pthreadattrsetstackaddr.c |
| Sets the Thread Creation stackaddr Attribute in the attr Object.
file | pthreadattrsetstacksize.c |
| Sets the Thread Creation Stacksize Attribute in the attr object.
file | pthreadconcurrency.c |
| Pthread Get/Set Concurrency.
file | pthreadcreate.c |
| Function Starts a New Thread in The Calling Process.
file | pthreaddetach.c |
| Detaching a Thread.
file | pthreadequal.c |
| Compare Thread IDs.
file | pthreadgetaffinitynp.c |
| Pthread Get Affinity.
file | pthreadgetattrnp.c |
| Pthread Get Attribute.
file | pthreadgetcpuclockid.c |
| Returns Clock ID for CPU time clock of the thread.
file | pthreadgetschedparam.c |
| Gets Scheduling Policy and Parameters of Individual Threads.
file | pthreadjoin.c |
| Suspends Execution of Calling Thread until Target Thread Terminates.
file | pthreadkill.c |
| Sends a signal Asynchronously directed to a thread.
file | pthreadonce.c |
| Call to function by Thread will call init_routine with no Arguments.
file | pthreadself.c |
| Function returns the ID of the Calling Thread.
file | pthreadsetaffinitynp.c |
| Pthread Set Affinity.
file | pthreadsetschedparam.c |
| Function sets scheduling policy and parameters of the thread.
file | pthreadsigmask.c |
| Examine and/or change the calling thread's signal mask.
file | rwlockattrdestroy.c |
| Function Destroys a read-write lock Attributes object.
file | rwlockattrgetpshared.c |
| Get the Process-Shared Attribute of the RWLock.
file | rwlockattrinit.c |
| Initialises a RWLock Attributes object attr with the default value.
file | rwlockattrsetpshared.c |
| RWLock Attributes Set Process Shared.
file | sched_getparam.c |
| Set Scheduling Parameters.
file | sched_getprioritymax.c |
| Returns the Appropriate Maximum for Scheduling policy.
file | sched_getprioritymin.c |
| Get the Minimum Priority Limit.
file | sched_getscheduler.c |
| Function Returns Scheduling Policy of the process specified by pid.
file | sched_rr_get_interval.c |
| Limits for Scheduling Parameter.
file | sched_setparam.c |
| Sets Scheduling Parameters Associated with Scheduling Policies.
file | sched_setscheduler.c |
| Set Scheduling Policy and Scheduling Parameters.
file | sched_yield.c |
| Yield Processor.
file | seminit.c |
| Initializing of an Unnamed Semaphore.
file | semopen.c |
| Function Creates New POSIX semaphore or Opens an existing Semaphore.
file | setcancelstate.c |
| Setting Cancelability State.
file | setcanceltype.c |
| Sets the Cancelability Type of Calling Thread to value given in type.
file | setitimer.c |
| Set the Timer.
file | sigaction.c |
| Allows calling process to examine action of a Specific Signal.
file | sigaddset.c |
| Function Adds Signal from Set.
file | sigdelset.c |
| Deleted Signal from Set.
file | sigemptyset.c |
| Manipulate Signal Sets.
file | sigfillset.c |
file | sigismember.c |
file | signal_2.c |
| POSIX Function Installs signal Handler.
file | sigpending.c |
| Examine Pending Signals.
file | sigprocmask.c |
| Examine and Change Blocked Signals.
file | sigqueue.c |
| Queue a Signal to a Process.
file | sigsuspend.c |
| Replacing signal mask with *sigmask and suspending calling process.
file | sigtimedwait.c |
| Wait for Queued Signals.
file | sigwait.c |
| Synchronously Accept a Signal.
file | sysconf.c |
| Get Configurable System Variables.
file | testcancel.c |
| Setting test on Cancelability State.
file | timergettime.c |
| Function Fetches State of POSIX Per-Process Timers.
file | timersettime.c |
| Function Arms or Disarms the Timer Identified by timerid.
file | ualarm.c |
| Schedule Alarm.
file | vfork.c |
| Creates Child process Of The Calling process.
file | wait.c |
| Wait for Process to Change State.
file | waitpid.c |
