RTEMS
5.1
Private Inlined Routines for POSIX Semaphores. More...
#include <rtems/posix/semaphore.h>
#include <rtems/posix/posixapi.h>
#include <rtems/score/semaphoreimpl.h>
#include <rtems/seterr.h>
#define | POSIX_SEMAPHORE_MAGIC 0x5d367fe7UL |
This is a random number used to check if a semaphore object is properly initialized. | |
#define | POSIX_SEMAPHORE_VALIDATE_OBJECT(sem) |
RTEMS_INLINE_ROUTINE POSIX_Semaphore_Control * | _POSIX_Semaphore_Allocate_unprotected (void) |
RTEMS_INLINE_ROUTINE void | _POSIX_Semaphore_Free (POSIX_Semaphore_Control *the_semaphore) |
POSIX Semaphore Free. More... | |
RTEMS_INLINE_ROUTINE POSIX_Semaphore_Control * | _POSIX_Semaphore_Get (sem_t *sem) |
RTEMS_INLINE_ROUTINE bool | _POSIX_Semaphore_Is_named (const sem_t *sem) |
RTEMS_INLINE_ROUTINE bool | _POSIX_Semaphore_Is_busy (const sem_t *sem) |
RTEMS_INLINE_ROUTINE void | _POSIX_Semaphore_Initialize (sem_t *sem, const char *name, unsigned int value) |
RTEMS_INLINE_ROUTINE void | _POSIX_Semaphore_Destroy (sem_t *sem) |
void | _POSIX_Semaphore_Delete (POSIX_Semaphore_Control *the_semaphore) |
POSIX Semaphore Delete. More... | |
RTEMS_INLINE_ROUTINE void | _POSIX_Semaphore_Namespace_remove (POSIX_Semaphore_Control *the_semaphore) |
POSIX Semaphore Namespace Remove. | |
RTEMS_INLINE_ROUTINE POSIX_Semaphore_Control * | _POSIX_Semaphore_Get_by_name (const char *name, size_t *name_length_p, Objects_Get_by_name_error *error) |
This include file contains the static inline implementation of the private inlined routines for POSIX Semaphores.
#define POSIX_SEMAPHORE_VALIDATE_OBJECT | ( | sem | ) |
void _POSIX_Semaphore_Delete | ( | POSIX_Semaphore_Control * | the_semaphore | ) |
This routine supports the sem_close and sem_unlink routines.
RTEMS_INLINE_ROUTINE void _POSIX_Semaphore_Free | ( | POSIX_Semaphore_Control * | the_semaphore | ) |
This routine frees a semaphore control block to the inactive chain of free semaphore control blocks.
