RTEMS  5.1
imfs.h
1
7 /*
8  * COPYRIGHT (c) 1989-2011.
9  * On-Line Applications Research Corporation (OAR).
10  *
11  * The license and distribution terms for this file may be
12  * found in the file LICENSE in this distribution or at
13  * http://www.rtems.org/license/LICENSE.
14  */
15
16 #ifndef _RTEMS_IMFS_H
17 #define _RTEMS_IMFS_H
18
19 #include <sys/time.h>
20 #include <limits.h>
21
22 #include <rtems/libio_.h>
23 #include <rtems/pipe.h>
25
35 #ifdef __cplusplus
36 extern "C" {
37 #endif
38
39 /*
40  * Data types
41  */
42
43 struct IMFS_jnode_tt;
44 typedef struct IMFS_jnode_tt IMFS_jnode_t;
45
68 #define IMFS_MEMFILE_DEFAULT_BYTES_PER_BLOCK 128
69  extern const int imfs_memfile_bytes_per_block;
70
71 #define IMFS_MEMFILE_BYTES_PER_BLOCK imfs_memfile_bytes_per_block
72 #define IMFS_MEMFILE_BLOCK_SLOTS \
73  (IMFS_MEMFILE_BYTES_PER_BLOCK / sizeof(void *))
74
75 typedef uint8_t *block_p;
76 typedef block_p *block_ptr;
77
78 /*
79  * Important block numbers for "memfiles"
80  */
81 #define FIRST_INDIRECT (0)
82 #define LAST_INDIRECT (IMFS_MEMFILE_BLOCK_SLOTS - 1)
83
84 #define FIRST_DOUBLY_INDIRECT (LAST_INDIRECT + 1)
85 #define LAST_DOUBLY_INDIRECT \
86  (LAST_INDIRECT + \
87  (IMFS_MEMFILE_BLOCK_SLOTS * IMFS_MEMFILE_BLOCK_SLOTS))
88
89 #define FIRST_TRIPLY_INDIRECT (LAST_DOUBLY_INDIRECT + 1)
90 #define LAST_TRIPLY_INDIRECT \
91  (LAST_DOUBLY_INDIRECT +\
92  (IMFS_MEMFILE_BLOCK_SLOTS * \
93  IMFS_MEMFILE_BLOCK_SLOTS * IMFS_MEMFILE_BLOCK_SLOTS))
94
95 #define IMFS_MEMFILE_MAXIMUM_SIZE \
96  (LAST_TRIPLY_INDIRECT * IMFS_MEMFILE_BYTES_PER_BLOCK)
97
119 typedef IMFS_jnode_t *(*IMFS_node_control_initialize)(
120  IMFS_jnode_t *node,
121  void *arg
122 );
123
135  IMFS_jnode_t *node,
136  void *arg
137 );
138
139 IMFS_jnode_t *IMFS_node_initialize_directory(
140  IMFS_jnode_t *node,
141  void *arg
142 );
143
156  IMFS_jnode_t *node,
157  void *arg
158 );
159
171 typedef IMFS_jnode_t *(*IMFS_node_control_remove)(
172  IMFS_jnode_t *node
173 );
174
185  IMFS_jnode_t *node
186 );
187
188 IMFS_jnode_t *IMFS_node_remove_directory( IMFS_jnode_t *node );
189
197 typedef void (*IMFS_node_control_destroy)( IMFS_jnode_t *node );
198
207
216
220 typedef struct {
221  const rtems_filesystem_file_handlers_r *handlers;
222  IMFS_node_control_initialize node_initialize;
223  IMFS_node_control_remove node_remove;
224  IMFS_node_control_destroy node_destroy;
226
227 typedef struct {
228  IMFS_node_control node_control;
229  size_t node_size;
231
239 /*
240  * Maximum length of a "basename" of an IMFS file/node.
241  */
242
243 #define IMFS_NAME_MAX _POSIX_NAME_MAX
244
245 /*
246
247  * The control structure for an IMFS jnode.
248  */
249
251  rtems_chain_node Node; /* for chaining them together */
252  IMFS_jnode_t *Parent; /* Parent node */
253  const char *name; /* "basename" (not \0 terminated) */
254  uint16_t namelen; /* Length of "basename" */
255  mode_t st_mode; /* File mode */
256  unsigned short reference_count;
257  nlink_t st_nlink; /* Link count */
258
259  uid_t st_uid; /* User ID of owner */
260  gid_t st_gid; /* Group ID of owner */
261
262  time_t stat_atime; /* Time of last access */
263  time_t stat_mtime; /* Time of last modification */
264  time_t stat_ctime; /* Time of last status change */
265  const IMFS_node_control *control;
266 };
267
268 typedef struct {
269  IMFS_jnode_t Node;
270  rtems_chain_control Entries;
273
274 typedef struct {
275  IMFS_jnode_t Node;
276  rtems_device_major_number major;
277  rtems_device_minor_number minor;
278 } IMFS_device_t;
279
280 typedef struct {
281  IMFS_jnode_t Node;
282  IMFS_jnode_t *link_node;
283 } IMFS_link_t;
284
285 typedef struct {
286  IMFS_jnode_t Node;
287  char *name;
289
290 typedef struct {
291  IMFS_jnode_t Node;
292  size_t size; /* size of file in bytes */
294
295 typedef struct {
296  IMFS_filebase_t File;
297  block_ptr indirect; /* array of 128 data blocks pointers */
298  block_ptr doubly_indirect; /* 128 indirect blocks */
299  block_ptr triply_indirect; /* 128 doubly indirect blocks */
301
302 typedef struct {
303  IMFS_filebase_t File;
304  block_p direct; /* pointer to file image */
306
307 /* Support copy on write for linear files */
308 typedef union {
309  IMFS_jnode_t Node;
310  IMFS_filebase_t File;
311  IMFS_memfile_t Memfile;
312  IMFS_linearfile_t Linearfile;
313 } IMFS_file_t;
314
315 typedef struct {
316  IMFS_jnode_t Node;
317  pipe_control_t *pipe;
318 } IMFS_fifo_t;
319
320 typedef struct {
321  IMFS_jnode_t Node;
322  void *context;
324
325 typedef struct {
326  const void *data;
327  size_t size;
329
330 static inline IMFS_jnode_t *IMFS_iop_to_node( const rtems_libio_t *iop )
331 {
332  return (IMFS_jnode_t *) iop->pathinfo.node_access;
333 }
334
335 static inline IMFS_directory_t *IMFS_iop_to_directory(
336  const rtems_libio_t *iop
337 )
338 {
339  return (IMFS_directory_t *) iop->pathinfo.node_access;
340 }
341
342 static inline IMFS_device_t *IMFS_iop_to_device( const rtems_libio_t *iop )
343 {
344  return (IMFS_device_t *) iop->pathinfo.node_access;
345 }
346
347 static inline IMFS_file_t *IMFS_iop_to_file( const rtems_libio_t *iop )
348 {
349  return (IMFS_file_t *) iop->pathinfo.node_access;
350 }
351
352 static inline IMFS_memfile_t *IMFS_iop_to_memfile( const rtems_libio_t *iop )
353 {
354  return (IMFS_memfile_t *) iop->pathinfo.node_access;
355 }
356
357 static inline time_t _IMFS_get_time( void )
358 {
359  struct bintime now;
360
361  /* Use most efficient way to get the time in seconds (CLOCK_REALTIME) */
362  _Timecounter_Getbintime( &now );
363
364  return now.sec;
365 }
366
367 static inline void IMFS_update_atime( IMFS_jnode_t *jnode )
368 {
369  jnode->stat_atime = _IMFS_get_time();
370 }
371
372 static inline void IMFS_update_mtime( IMFS_jnode_t *jnode )
373 {
374  jnode->stat_mtime = _IMFS_get_time();
375 }
376
377 static inline void IMFS_update_ctime( IMFS_jnode_t *jnode )
378 {
379  jnode->stat_ctime = _IMFS_get_time();
380 }
381
382 static inline void IMFS_mtime_ctime_update( IMFS_jnode_t *jnode )
383 {
384  time_t now;
385
386  now = _IMFS_get_time();
387
388  jnode->stat_mtime = now;
389  jnode->stat_ctime = now;
390 }
391
392 typedef struct {
393  const IMFS_mknod_control *directory;
394  const IMFS_mknod_control *device;
395  const IMFS_mknod_control *file;
396  const IMFS_mknod_control *fifo;
398
399 typedef struct {
400  IMFS_directory_t Root_directory;
401  const IMFS_mknod_controls *mknod_controls;
403
404 typedef struct {
405  IMFS_fs_info_t *fs_info;
407  const IMFS_mknod_controls *mknod_controls;
409
410 /*
411  * Shared Data
412  */
413
414 extern const IMFS_mknod_control IMFS_mknod_control_dir_default;
415 extern const IMFS_mknod_control IMFS_mknod_control_dir_minimal;
416 extern const IMFS_mknod_control IMFS_mknod_control_device;
417 extern const IMFS_mknod_control IMFS_mknod_control_memfile;
418 extern const IMFS_node_control IMFS_node_control_linfile;
419 extern const IMFS_mknod_control IMFS_mknod_control_fifo;
420 extern const IMFS_mknod_control IMFS_mknod_control_enosys;
421
422 extern const rtems_filesystem_limits_and_options_t IMFS_LIMITS_AND_OPTIONS;
423
424 /*
425  * Routines
426  */
427
428 extern int IMFS_initialize(
430  const void *data
431 );
432
433 extern int IMFS_initialize_support(
435  const void *data
436 );
437
441 extern void IMFS_fsunmount(
443 );
444
496 extern int rtems_tarfs_load(
497  const char *mountpoint,
498  uint8_t *tar_image,
499  size_t tar_size
500 );
501
505 extern void IMFS_node_destroy( IMFS_jnode_t *node );
506
511
515 extern void IMFS_node_free( const rtems_filesystem_location_info_t *loc );
516
522 extern int IMFS_stat(
524  struct stat *buf
525 );
526
527 extern int IMFS_stat_file(
529  struct stat *buf
530 );
531
535 extern void IMFS_eval_path(
537 );
538
542 extern void IMFS_eval_path_devfs(
544 );
545
553 extern int IMFS_link(
554  const rtems_filesystem_location_info_t *parentloc,
555  const rtems_filesystem_location_info_t *targetloc,
556  const char *name,
557  size_t namelen
558 );
559
566 extern int IMFS_chown(
568  uid_t owner,
569  gid_t group
570 );
571
577 extern int IMFS_mknod(
578  const rtems_filesystem_location_info_t *parentloc,
579  const char *name,
580  size_t namelen,
581  mode_t mode,
582  dev_t dev
583 );
584
585 extern IMFS_jnode_t *IMFS_initialize_node(
586  IMFS_jnode_t *node,
587  const IMFS_node_control *node_control,
588  const char *name,
589  size_t namelen,
590  mode_t mode,
591  void *arg
592 );
593
601  const rtems_filesystem_location_info_t *parentloc,
602  const IMFS_node_control *node_control,
603  size_t node_size,
604  const char *name,
605  size_t namelen,
606  mode_t mode,
607  void *arg
608 );
609
610 static inline bool IMFS_is_imfs_instance(
612 )
613 {
614  return loc->mt_entry->ops->clonenod_h == IMFS_node_clone;
615 }
616
624 #define IMFS_NODE_CONTROL_INITIALIZER( handlers, init, destroy ) \
625  { \
626  ( handlers ), \
627  ( init ), \
628  IMFS_node_remove_default, \
629  ( destroy ) \
630  }
631
644 #define IMFS_NODE_INITIALIZER( node_control, name, namelen, mode ) \
645  { \
646  { NULL, NULL }, \
647  NULL, \
648  ( name ), \
649  ( namelen ), \
650  ( mode ), \
651  0, \
652  0, \
653  0, \
654  0, \
655  0, \
656  0, \
657  0, \
658  ( node_control ) \
659  }
660
674 static inline void IMFS_node_preinitialize(
675  IMFS_jnode_t *node,
676  const IMFS_node_control *node_control,
677  const char *name,
678  size_t namelen,
679  mode_t mode
680 )
681 {
682  node->control = node_control;
683  node->name = name;
684  node->namelen = namelen;
685  node->st_mode = mode;
686 }
687
701 int IMFS_add_node( const char *path, IMFS_jnode_t *node, void *arg );
702
703 extern int IMFS_make_node(
704  const char *path,
705  mode_t mode,
706  const IMFS_node_control *node_control,
707  size_t node_size,
708  void *context
709 );
710
722 extern int IMFS_make_linearfile(
723  const char *path,
724  mode_t mode,
725  const void *data,
726  size_t size
727 );
728
747 /* Provided for backward compatibility */
748 #define IMFS_GENERIC_INITIALIZER( handlers, init, destroy ) \
749  IMFS_NODE_CONTROL_INITIALIZER( handlers, init, destroy )
750
758 #define IMFS_GENERIC_CONTROL_INITIALIZER( handlers, init, destroy ) \
759  IMFS_NODE_CONTROL_INITIALIZER( handlers, init, destroy )
760
771 #define IMFS_GENERIC_NODE_INITIALIZER( node_control, name, namelen, mode ) \
772  { IMFS_NODE_INITIALIZER( node_control, name, namelen, mode ), NULL }
773
787 static inline void IMFS_generic_node_preinitialize(
788  IMFS_generic_t *node,
789  const IMFS_node_control *node_control,
790  const char *name,
791  size_t namelen,
792  mode_t mode
793 )
794 {
795  IMFS_node_preinitialize( &node->Node, node_control, name, namelen, mode );
796 }
797
858 extern int IMFS_make_generic_node(
859  const char *path,
860  mode_t mode,
861  const IMFS_node_control *node_control,
862  void *context
863 );
864
875 extern int IMFS_mount(
876  rtems_filesystem_mount_table_entry_t *mt_entry /* IN */
877 );
878
882 extern int IMFS_unmount(
883  rtems_filesystem_mount_table_entry_t *mt_entry /* IN */
884 );
885
897 extern ssize_t IMFS_memfile_write(
898  IMFS_memfile_t *memfile,
899  off_t start,
900  const unsigned char *source,
901  unsigned int length
902 );
903
914 extern int device_open(
915  rtems_libio_t *iop, /* IN */
916  const char *pathname, /* IN */
917  int oflag, /* IN */
918  mode_t mode /* IN */
919 );
920
921 extern int device_close(
922  rtems_libio_t *iop /* IN */
923 );
924
925 extern ssize_t device_read(
926  rtems_libio_t *iop, /* IN */
927  void *buffer, /* IN */
928  size_t count /* IN */
929 );
930
931 extern ssize_t device_write(
932  rtems_libio_t *iop, /* IN */
933  const void *buffer, /* IN */
934  size_t count /* IN */
935 );
936
937 extern int device_ioctl(
938  rtems_libio_t *iop,
939  ioctl_command_t command,
940  void *buffer
941 );
942
943 extern int device_ftruncate(
944  rtems_libio_t *iop, /* IN */
945  off_t length /* IN */
946 );
947
957 extern int IMFS_utime(
959  time_t actime,
960  time_t modtime
961 );
962
966 extern int IMFS_fchmod(
968  mode_t mode
969 );
970
978 extern int IMFS_symlink(
979  const rtems_filesystem_location_info_t *parentloc,
980  const char *name,
981  size_t namelen,
982  const char *target
983 );
984
992 extern ssize_t IMFS_readlink(
994  char *buf,
995  size_t bufsize
996 );
997
1004 extern int IMFS_rename(
1005  const rtems_filesystem_location_info_t *oldparentloc,
1006  const rtems_filesystem_location_info_t *oldloc,
1007  const rtems_filesystem_location_info_t *newparentloc,
1008  const char *name,
1009  size_t namelen
1010 );
1017 extern int IMFS_rmnod(
1018  const rtems_filesystem_location_info_t *parentloc,
1020 );
1021
1022 /*
1023  * Turn on IMFS assertions when RTEMS_DEBUG is defined.
1024  */
1025 #ifdef RTEMS_DEBUG
1026  #include <assert.h>
1027
1028  #define IMFS_assert(_x) assert(_x)
1029 #else
1030  #define IMFS_assert(_x)
1031 #endif
1032
1033 static inline void IMFS_Set_handlers( rtems_filesystem_location_info_t *loc )
1034 {
1035  IMFS_jnode_t *node = (IMFS_jnode_t *) loc->node_access;
1036
1037  loc->handlers = node->control->handlers;
1038 }
1039
1040 static inline void IMFS_add_to_directory(
1041  IMFS_jnode_t *dir_node,
1042  IMFS_jnode_t *entry_node
1043 )
1044 {
1045  IMFS_directory_t *dir = (IMFS_directory_t *) dir_node;
1046
1047  entry_node->Parent = dir_node;
1048  rtems_chain_append_unprotected( &dir->Entries, &entry_node->Node );
1049 }
1050
1051 static inline void IMFS_remove_from_directory( IMFS_jnode_t *node )
1052 {
1053  IMFS_assert( node->Parent != NULL );
1054  node->Parent = NULL;
1055  rtems_chain_extract_unprotected( &node->Node );
1056 }
1057
1058 static inline bool IMFS_is_directory( const IMFS_jnode_t *node )
1059 {
1060  return S_ISDIR( node->st_mode );
1061 }
1062
1063 #define IMFS_STAT_FMT_HARD_LINK 0
1064
1065 static inline bool IMFS_is_hard_link( mode_t mode )
1066 {
1067  return ( mode & S_IFMT ) == IMFS_STAT_FMT_HARD_LINK;
1068 }
1069
1070 static inline ino_t IMFS_node_to_ino( const IMFS_jnode_t *node )
1071 {
1072  return (ino_t) ((uintptr_t) node);
1073 }
1074
1082 static inline void *IMFS_generic_get_context_by_node(
1083  const IMFS_jnode_t *node
1084 )
1085 {
1086  const IMFS_generic_t *generic = (const IMFS_generic_t *) node;
1087
1088  return generic->context;
1089 }
1090
1091 static inline void *IMFS_generic_get_context_by_location(
1093 )
1094 {
1095  return loc->node_access_2;
1096 }
1097
1098 static inline void *IMFS_generic_get_context_by_iop(
1099  const rtems_libio_t *iop
1100 )
1101 {
1102  return IMFS_generic_get_context_by_location( &iop->pathinfo );
1103 }
1104
1105 static inline dev_t IMFS_generic_get_device_identifier_by_node(
1106  const IMFS_jnode_t *node
1107 )
1108 {
1109  return rtems_filesystem_make_dev_t_from_pointer( node );
1110 }
1111
1112 #ifdef __cplusplus
1113 }
1114 #endif
1115
1116 #endif
1117 /* end of include file */
void IMFS_fsunmount(rtems_filesystem_mount_table_entry_t *mt_entry)
Unmount this instance of IMFS.
Definition: imfs_fsunmount.c:36
Definition: chain.h:68
Contain file system specific information which is required to support fpathconf().
Definition: libio.h:1289
POSIX FIFO/pipe File System Support.
Definition: imfs.h:268
IMFS_jnode_t * IMFS_node_remove_default(IMFS_jnode_t *node)
Returns the node and does nothing else.
Definition: imfs_node.c:99
int IMFS_add_node(const char *path, IMFS_jnode_t *node, void *arg)
Adds an IMFS node.
Definition: imfs_add_node.c:42
RTEMS_INLINE_ROUTINE void rtems_chain_extract_unprotected(rtems_chain_node *the_node)
Extract the specified node from a chain (unprotected).
Definition: chain.h:590
Definition: imfs.h:399
int IMFS_link(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *targetloc, const char *name, size_t namelen)
Create a new IMFS link node.
Definition: imfs_link.c:26
Definition: imfs.h:325
IMFS_jnode_t *(* IMFS_node_control_initialize)(IMFS_jnode_t *node, void *arg)
Initializes an IMFS node.
Definition: imfs.h:119
int IMFS_mount(rtems_filesystem_mount_table_entry_t *mt_entry)
Mount an IMFS.
Definition: imfs_mount.c:27
void IMFS_node_free(const rtems_filesystem_location_info_t *loc)
Free an IMFS node.
Definition: imfs_node.c:88
Definition: imfs.h:308
Definition: chain.h:86
int IMFS_make_linearfile(const char *path, mode_t mode, const void *data, size_t size)
Makes a linear IMFS file.
Definition: imfs_make_linfile.c:34
IMFS_jnode_t * IMFS_node_initialize_default(IMFS_jnode_t *node, void *arg)
Definition: imfs_initsupp.c:72
Definition: imfs.h:295
Definition: imfs.h:404
Definition: rtemscompat1.h:15
File system node operations table.
Definition: libio.h:1005
Definition: imfs.h:302
void IMFS_eval_path(rtems_filesystem_eval_path_context_t *ctx)
IMFS evaluation node support.
Definition: imfs_eval.c:176
RTEMS_INLINE_ROUTINE void rtems_chain_append_unprotected(rtems_chain_control *the_chain, rtems_chain_node *the_node)
Append a node on the end of a chain (unprotected).
Definition: chain.h:679
int IMFS_node_clone(rtems_filesystem_location_info_t *loc)
Clone an IMFS node.
Definition: imfs_node.c:72
IMFS node control.
Definition: imfs.h:220
Information for the Assert Handler.
void(* IMFS_node_control_destroy)(IMFS_jnode_t *node)
Destroys an IMFS node.
Definition: imfs.h:197
Definition: imfs.h:227
int IMFS_stat(const rtems_filesystem_location_info_t *loc, struct stat *buf)
Perform a status processing for the IMFS.
Definition: imfs_stat.c:27
IMFS_jnode_t * IMFS_node_initialize_generic(IMFS_jnode_t *node, void *arg)
Returns the node and sets the generic node context.
Definition: imfs_make_generic_node.c:31
int IMFS_mknod(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, mode_t mode, dev_t dev)
Create an IMFS node.
Definition: imfs_mknod.c:44
Definition: imfs.h:250
void IMFS_node_destroy_default(IMFS_jnode_t *node)
Frees the node.
Definition: imfs_node_destroy_default.c:44
Definition: imfs.h:290
int IMFS_fchmod(const rtems_filesystem_location_info_t *loc, mode_t mode)
Change the IMFS file mode.
Definition: imfs_fchmod.c:24
int rtems_tarfs_load(const char *mountpoint, uint8_t *tar_image, size_t tar_size)
RTEMS load tarfs.
Definition: imfs_load_tar.c:27
int IMFS_chown(const rtems_filesystem_location_info_t *loc, uid_t owner, gid_t group)
Change the owner of IMFS.
Definition: imfs_chown.c:28
int IMFS_symlink(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, const char *target)
Create a new IMFS symbolic link node.
Definition: imfs_symlink.c:28
Definition: intercom.c:74
IMFS_jnode_t *(* IMFS_node_control_remove)(IMFS_jnode_t *node)
Prepares the removal of an IMFS node from its parent directory.
Definition: imfs.h:171
void IMFS_do_nothing_destroy(IMFS_jnode_t *node)
Does nothing.
Definition: imfs_node.c:106
Mount table entry.
Definition: libio.h:1604
void IMFS_node_destroy(IMFS_jnode_t *node)
Destroy an IMFS node.
Definition: imfs_node.c:81
int IMFS_unmount(rtems_filesystem_mount_table_entry_t *mt_entry)
Unmount an IMFS.
Definition: imfs_unmount.c:27
File system operations table.
Definition: libio.h:472
LibIO Internal Interface.
int IMFS_rmnod(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *loc)
IMFS node removal handler.
Definition: imfs_rmnod.c:27
Definition: pipe.h:38
ssize_t IMFS_readlink(const rtems_filesystem_location_info_t *loc, char *buf, size_t bufsize)
Put IMFS symbolic link into buffer.
Definition: imfs_symlink.c:57
Path evaluation context.
Definition: libio.h:84
int IMFS_utime(const rtems_filesystem_location_info_t *loc, time_t actime, time_t modtime)
Set IMFS file access and modification times.
Definition: imfs_utime.c:26
Definition: imfs.h:392
unsigned context
Definition: tlb.h:108
void _Timecounter_Getbintime(struct bintime *bt)
Returns the wall clock time in the bintime format.
An open file data structure.
Definition: libio.h:1320
void IMFS_eval_path_devfs(rtems_filesystem_eval_path_context_t *ctx)
IMFS device filesystem evaluation node support.
Definition: imfs_eval_devfs.c:123
unsigned size
Definition: tte.h:74
Definition: imfs.h:315
Definition: imfs.h:320
int IMFS_make_generic_node(const char *path, mode_t mode, const IMFS_node_control *node_control, void *context)
Makes a generic IMFS node.
Definition: imfs_make_generic_node.c:43
Timecounter API.
Definition: imfs.h:274
int IMFS_rename(const rtems_filesystem_location_info_t *oldparentloc, const rtems_filesystem_location_info_t *oldloc, const rtems_filesystem_location_info_t *newparentloc, const char *name, size_t namelen)
Rename the IMFS.
Definition: imfs_rename.c:50
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
File system location.
Definition: fs.h:53
Definition: mongoose.c:442
IMFS_jnode_t * IMFS_create_node(const rtems_filesystem_location_info_t *parentloc, const IMFS_node_control *node_control, size_t node_size, const char *name, size_t namelen, mode_t mode, void *arg)
Definition: imfs_creat.c:26
