RTEMS  5.1
IMFS Generic Nodes
Generic nodes are an alternative to standard drivers in RTEMS. More...
struct  IMFS_node_control
 IMFS node control. More...
struct  IMFS_mknod_control
#define IMFS_GENERIC_INITIALIZER(handlers, init, destroy)   IMFS_NODE_CONTROL_INITIALIZER( handlers, init, destroy )
#define IMFS_GENERIC_CONTROL_INITIALIZER(handlers, init, destroy)   IMFS_NODE_CONTROL_INITIALIZER( handlers, init, destroy )
 Initializer for a generic node control. More...
#define IMFS_GENERIC_NODE_INITIALIZER(node_control, name, namelen, mode)   { IMFS_NODE_INITIALIZER( node_control, name, namelen, mode ), NULL }
 Initializer for a generic node. More...
typedef IMFS_jnode_t *(* IMFS_node_control_initialize) (IMFS_jnode_t *node, void *arg)
 Initializes an IMFS node. More...
typedef IMFS_jnode_t *(* IMFS_node_control_remove) (IMFS_jnode_t *node)
 Prepares the removal of an IMFS node from its parent directory. More...
typedef void(* IMFS_node_control_destroy) (IMFS_jnode_t *node)
 Destroys an IMFS node. More...
IMFS_jnode_tIMFS_node_initialize_default (IMFS_jnode_t *node, void *arg)
 Returns the node and does nothing else. More...
IMFS_jnode_tIMFS_node_initialize_directory (IMFS_jnode_t *node, void *arg)
IMFS_jnode_tIMFS_node_initialize_generic (IMFS_jnode_t *node, void *arg)
 Returns the node and sets the generic node context. More...
IMFS_jnode_tIMFS_node_remove_default (IMFS_jnode_t *node)
IMFS_jnode_tIMFS_node_remove_directory (IMFS_jnode_t *node)
void IMFS_node_destroy_default (IMFS_jnode_t *node)
 Frees the node. More...
void IMFS_do_nothing_destroy (IMFS_jnode_t *node)
 Does nothing. More...
int IMFS_make_generic_node (const char *path, mode_t mode, const IMFS_node_control *node_control, void *context)
 Makes a generic IMFS node. More...
The handlers of a generic node are called with less overhead compared to the standard driver operations. The usage of file system node handlers enable more features like support for fsync() and fdatasync(). The generic nodes use the reference counting of the IMFS. This provides automatic node destruction when the last reference vanishes.
◆ IMFS_GENERIC_CONTROL_INITIALIZER
#define IMFS_GENERIC_CONTROL_INITIALIZER (   handlers,
  init,
  destroy
Parameters
handlersThe file system node handlers.
initThe node initialization method.
destroyThe node destruction method.
◆ IMFS_GENERIC_NODE_INITIALIZER
#define IMFS_GENERIC_NODE_INITIALIZER (   node_control,
  name,
  namelen,
  mode
Initialize the node control with IMFS_GENERIC_CONTROL_INITIALIZER().
Parameters
node_controlThe node control of the IMFS generic node.
nameThe name of the IMFS generic node.
namelenThe length of the name of the IMFS generic node.
modeThe mode of the IMFS generic node.
Typedef Documentation
◆ IMFS_node_control_destroy
Parameters
[in]nodeThe IMFS node.
See also
IMFS_node_control and IMFS_node_destroy_default().
◆ IMFS_node_control_initialize
typedef IMFS_jnode_t*(* IMFS_node_control_initialize) (IMFS_jnode_t *node, void *arg)
Parameters
[in]argThe user provided argument pointer. It may contain node specific initialization information.
Return values
nodeSuccessful operation.
NULLAn error occurred. The errno indicates the error. This will abort the make operation.
See also
IMFS_node_control, IMFS_node_initialize_default(), and IMFS_node_initialize_generic().
◆ IMFS_node_control_remove
typedef IMFS_jnode_t*(* IMFS_node_control_remove) (IMFS_jnode_t *node)
Parameters
Return values
NULLAn error occurred. The errno indicates the error. This will abort the removal operation.
See also
IMFS_node_control and IMFS_node_remove_default().
◆ IMFS_do_nothing_destroy()
void IMFS_do_nothing_destroy ( IMFS_jnode_t node)
Does nothing.
Parameters
nodeThe IMFS node.
See also
IMFS_node_control.
◆ IMFS_make_generic_node()
int IMFS_make_generic_node ( const char *  path,
mode_t  mode,
const IMFS_node_control node_control,
void *  context
Parameters
[in]pathThe path to the new generic IMFS node.
[in]modeThe node mode.
[in]node_controlThe node control.
[in]contextThe node control handler context.
Return values
0Successful operation.
-1An error occurred. The errno indicates the error.
#include <sys/stat.h>
#include <assert.h>
#include <fcntl.h>
#include <rtems/imfs.h>
static const rtems_filesystem_file_handlers_r some_node_handlers = {
static IMFS_jnode_t *some_node_init(IMFS_jnode_t *node, void *arg)
void *context;
node = IMFS_node_initialize_generic(node, arg);
context = IMFS_generic_get_context_by_node(node);
return node;
static void some_node_destroy(IMFS_jnode_t *node)
void *context = IMFS_generic_get_context_by_node(node);
static const IMFS_node_control
&some_node_handlers,
some_node_init,
some_node_destroy
void example(void *some_node_context)
int rv;
"/path/to/some/generic/node",
S_IFCHR | S_IRWXU | S_IRWXG | S_IRWXO,
&some_node_control,
some_node_context
assert(rv == 0);
◆ IMFS_node_destroy_default()
void IMFS_node_destroy_default ( IMFS_jnode_t node)
Frees the node.
Parameters
See also
IMFS_node_control.
◆ IMFS_node_initialize_default()
IMFS_jnode_t* IMFS_node_initialize_default ( IMFS_jnode_t node,
void *  arg
Parameters
[in]argThe user provided argument pointer. It is not used.
Return values
nodeReturns always the node passed as parameter.
See also
IMFS_node_control.
◆ IMFS_node_initialize_generic()
IMFS_jnode_t* IMFS_node_initialize_generic ( IMFS_jnode_t node,
void *  arg
Parameters
[in]argThe user provided argument pointer. It must contain the generic context.
Return values
See also
IMFS_node_control.
◆ IMFS_node_remove_default()
IMFS_jnode_t* IMFS_node_remove_default ( IMFS_jnode_t node)
Parameters
Return values
See also
IMFS_node_control.
