RTEMS  5.1
rtems_filesystem_eval_path_context_t Struct Reference
Path evaluation context. More...
#include <libio.h>
const char * path
size_t pathlen
const char * token
size_t tokenlen
int flags
int recursionlevel
rtems_filesystem_location_info_t currentloc
rtems_filesystem_global_location_trootloc
rtems_filesystem_global_location_tstartloc
Field Documentation
◆ currentloc
rtems_filesystem_location_info_t rtems_filesystem_eval_path_context_t::currentloc
This is the current file system location of the evaluation process. Tokens are evaluated with respect to the current location. The token interpretation may change the current location. The purpose of the path evaluation is to change the start location into a final current location according to the path.
◆ flags
int rtems_filesystem_eval_path_context_t::flags
The path evaluation is controlled by the following flags
  • RTEMS_FS_PERMS_READ,
  • RTEMS_FS_PERMS_WRITE,
  • RTEMS_FS_PERMS_EXEC,
  • RTEMS_FS_FOLLOW_HARD_LINK,
  • RTEMS_FS_FOLLOW_SYM_LINK,
  • RTEMS_FS_MAKE,
  • RTEMS_FS_EXCLUSIVE,
  • RTEMS_FS_ACCEPT_RESIDUAL_DELIMITERS, and
  • RTEMS_FS_REJECT_TERMINAL_DOT.
◆ path
const char* rtems_filesystem_eval_path_context_t::path
The contents of the remaining path to be evaluated.
◆ pathlen
size_t rtems_filesystem_eval_path_context_t::pathlen
The length of the remaining path to be evaluated.
◆ recursionlevel
int rtems_filesystem_eval_path_context_t::recursionlevel
Symbolic link evaluation is a recursive operation. This field helps to limit the recursion level and thus prevents a stack overflow. The recursion level is limited by RTEMS_FILESYSTEM_SYMLOOP_MAX.
◆ rootloc
rtems_filesystem_global_location_t* rtems_filesystem_eval_path_context_t::rootloc
The location of the root directory of the user environment during the evaluation start.
◆ startloc
rtems_filesystem_global_location_t* rtems_filesystem_eval_path_context_t::startloc
The start location of the evaluation process. The start location my change during symbolic link evaluation.
◆ token
const char* rtems_filesystem_eval_path_context_t::token
The contents of the token to be evaluated with respect to the current location.
◆ tokenlen
size_t rtems_filesystem_eval_path_context_t::tokenlen
The length of the token to be evaluated with respect to the current location.
