RTEMS  5.1
Files | Data Structures | Typedefs | Enumerations | Functions | Variables
Time of Day Handler Action Hooks
Time of Day Handler Action Hooks. More...
file  coretodhookdata.c
 TOD Hook Set.
file  coretodhookregister.c
 Register Hook to be in TOD Hook Set.
file  coretodhookrun.c
 Run TOD Hook Set.
file  coretodhookunregister.c
 Remove Hook from TOD Hook Set.
struct  TOD_Hook
 Structure to manage each TOD action hook. More...
typedef struct TOD_Hook TOD_Hook
enum  TOD_Action { TOD_ACTION_SET_CLOCK }
 Possible actions where a registered hook could be invoked. More...
void _TOD_Hook_Register (TOD_Hook *hook)
 Add a TOD Action Hook. More...
void _TOD_Hook_Unregister (TOD_Hook *hook)
 Remove a TOD Action Hook. More...
Status_Control _TOD_Hook_Run (TOD_Action action, const struct timespec *tod)
 Run the TOD Action Hooks. More...
Chain_Control _TOD_Hooks
 Set of registered methods for TOD Actions.
The following support registering a hook which is invoked when the TOD is set. These can be used by a paravirtualized BSP to mirror time changes to the hosting environment or a regular BSP to program a real-time clock when the RTEMS TOD is set.
◆ TOD_Action
enum TOD_Action
Constant to indicate the TOD is being set.
◆ _TOD_Hook_Register()
void _TOD_Hook_Register ( TOD_Hook hook)
This method is used to add a hook to the TOD action set.
hook is the action hook to register.
◆ _TOD_Hook_Run()
Status_Control _TOD_Hook_Run ( TOD_Action  action,
const struct timespec *  tod
This method is used to invoke the set of TOD action hooks.
action The action which triggered this run. tod The current time of day.
Return values
STATUS_SUCCESSFULSuccessful operation.
otherSome error occurred.
◆ _TOD_Hook_Unregister()
void _TOD_Hook_Unregister ( TOD_Hook hook)
This method is used to remove a hook from the TOD action set.
hook is the action hook to unregister.
