RTEMS  5.1
Files | Data Structures | Macros | Typedefs | Functions | Variables
MM. More...
file  cache_spec.h
file  frame.h
file  mmu.h
file  page.h
file  frame.h
file  mmu.h
file  page.h
file  tlb.h
file  tte.h
file  tlb.h
file  tte.h
union  tlb_context_reg
union  tlb_tag_read_reg
union  tlb_demap_addr
union  tlb_sfsr_reg
union  tte_tag
union  tte_data
#define DCACHE_LINE_SIZE   32
#define MMU_PAGE_WIDTH   MMU_FRAME_WIDTH
#define MMU_PAGE_SIZE   MMU_FRAME_SIZE
#define PAGE_WIDTH   FRAME_WIDTH
#define PAGE_SIZE   FRAME_SIZE
#define MMU_PAGES_PER_PAGE   (1 << (PAGE_WIDTH - MMU_PAGE_WIDTH))
#define MMU_FRAME_WIDTH   13 /* 8K */
#define MMU_FRAME_SIZE   (1 << MMU_FRAME_WIDTH)
#define FRAME_WIDTH   14 /* 16K */
#define FRAME_SIZE   (1 << FRAME_WIDTH)
#define ASI_IMMU   0x50
#define ASI_IMMU_TSB_8KB_PTR_REG   0x51
#define ASI_IMMU_TSB_64KB_PTR_REG   0x52
#define ASI_ITLB_DATA_IN_REG   0x54
#define ASI_ITLB_DATA_ACCESS_REG   0x55
#define ASI_ITLB_TAG_READ_REG   0x56
#define ASI_IMMU_DEMAP   0x57
#define VA_IMMU_TSB_TAG_TARGET   0x0
#define VA_IMMU_SFSR   0x18
#define VA_IMMU_TSB_BASE   0x28
#define VA_IMMU_TAG_ACCESS   0x30
#define ASI_DMMU   0x58
#define ASI_DMMU_TSB_8KB_PTR_REG   0x59
#define ASI_DMMU_TSB_64KB_PTR_REG   0x5a
#define ASI_DMMU_TSB_DIRECT_PTR_REG   0x5b
#define ASI_DTLB_DATA_IN_REG   0x5c
#define ASI_DTLB_DATA_ACCESS_REG   0x5d
#define ASI_DTLB_TAG_READ_REG   0x5e
#define ASI_DMMU_DEMAP   0x5f
#define VA_DMMU_TSB_TAG_TARGET   0x0
#define VA_PRIMARY_CONTEXT_REG   0x8
#define VA_SECONDARY_CONTEXT_REG   0x10
#define VA_DMMU_SFSR   0x18
#define VA_DMMU_SFAR   0x20
#define VA_DMMU_TSB_BASE   0x28
#define VA_DMMU_TAG_ACCESS   0x30
#define VA_DMMU_VA_WATCHPOINT_REG   0x38
#define VA_DMMU_PA_WATCHPOINT_REG   0x40
#define MEM_CONTEXT_KERNEL   0
#define MEM_CONTEXT_TEMP   1
#define PAGESIZE_8K   0
#define PAGESIZE_64K   1
#define PAGESIZE_512K   2
#define PAGESIZE_4M   3
#define KERNEL_PAGE_WIDTH   22 /* 4M */
#define TLB_DEMAP_PAGE   0
#define TLB_DEMAP_CONTEXT   1
#define TLB_DEMAP_TYPE_SHIFT   6
#define TLB_DEMAP_PRIMARY   0
#define TLB_DEMAP_SECONDARY   1
#define TLB_DEMAP_NUCLEUS   2
#define TLB_DEMAP_CONTEXT_SHIFT   4
#define TLB_TAG_ACCESS_CONTEXT_SHIFT   0
#define TLB_TAG_ACCESS_CONTEXT_MASK   ((1 << 13) - 1)
#define TLB_TAG_ACCESS_VPN_SHIFT   13
#define TTE_G   (1 << 0)
#define TTE_W   (1 << 1)
#define TTE_P   (1 << 2)
#define TTE_E   (1 << 3)
#define TTE_CV   (1 << 4)
#define TTE_CP   (1 << 5)
#define TTE_L   (1 << 6)
#define TTE_V_SHIFT   63
#define TTE_SIZE_SHIFT   61
#define VA_TAG_PAGE_SHIFT   22
typedef union tlb_context_reg tlb_context_reg_t
typedef tte_data_t tlb_data_t
typedef union tlb_tag_read_reg tlb_tag_read_reg_t
typedef union tlb_tag_read_reg tlb_tag_access_reg_t
typedef union tlb_demap_addr tlb_demap_addr_t
typedef union tlb_sfsr_reg tlb_sfsr_reg_t
typedef union tte_tag tte_tag_t
typedef union tte_data tte_data_t
void fast_instruction_access_mmu_miss (unative_t, istate_t *)
void fast_data_access_mmu_miss (tlb_tag_access_reg_t, istate_t *)
void fast_data_access_protection (tlb_tag_access_reg_t, istate_t *)
void dtlb_insert_mapping (uintptr_t, uintptr_t, int, bool, bool)
void dump_sfsr_and_sfar (void)
void describe_dmmu_fault (void)
union tte_tag __attribute__
MM.
◆ KERNEL_PAGE_WIDTH
Bit width of the TLB-locked portion of kernel address space.
◆ MEM_CONTEXT_KERNEL
TLB_DSMALL is the only of the three DMMUs that can hold locked entries.
◆ PAGESIZE_8K
Page sizes.
◆ VA_DMMU_PA_WATCHPOINT_REG
DMMU PA data watchpoint register.
◆ VA_DMMU_SFAR
DMMU sync fault address register.
◆ VA_DMMU_SFSR
DMMU sync fault status register.
◆ VA_DMMU_TAG_ACCESS
DMMU TLB tag access register.
◆ VA_DMMU_TSB_BASE
DMMU TSB base register.
◆ VA_DMMU_TSB_TAG_TARGET
DMMU TSB tag target register.
◆ VA_DMMU_VA_WATCHPOINT_REG
DMMU VA data watchpoint register.
◆ VA_IMMU_SFSR
IMMU sync fault status register.
◆ VA_IMMU_TAG_ACCESS
IMMU TLB tag access register.
◆ VA_IMMU_TSB_BASE
IMMU TSB base register.
◆ VA_IMMU_TSB_TAG_TARGET
IMMU TSB tag target register.
◆ VA_PRIMARY_CONTEXT_REG
DMMU primary context register.
◆ VA_SECONDARY_CONTEXT_REG
DMMU secondary context register.
Typedef Documentation
◆ tlb_data_t
I-/D-TLB Data In/Access Register type.
