RTEMS  5.1
Files | Functions
BSD Compatibility Support
file  bsd.h
 BSD Compatibility API.
RTEMS_INLINE_ROUTINE void rtems_bsd_bintime (struct bintime *bt)
 Returns the wall clock time in the bintime format. More...
RTEMS_INLINE_ROUTINE void rtems_bsd_nanotime (struct timespec *ts)
 Returns the wall clock time in the timespec format. More...
RTEMS_INLINE_ROUTINE void rtems_bsd_microtime (struct timeval *tv)
 Returns the wall clock time in the timeval format. More...
RTEMS_INLINE_ROUTINE void rtems_bsd_binuptime (struct bintime *bt)
 Returns the uptime in the bintime format. More...
RTEMS_INLINE_ROUTINE void rtems_bsd_nanouptime (struct timespec *ts)
 Returns the uptime in the timespec format. More...
RTEMS_INLINE_ROUTINE void rtems_bsd_microuptime (struct timeval *tv)
RTEMS_INLINE_ROUTINE void rtems_bsd_getbintime (struct bintime *bt)
RTEMS_INLINE_ROUTINE void rtems_bsd_getnanotime (struct timespec *ts)
RTEMS_INLINE_ROUTINE void rtems_bsd_getmicrotime (struct timeval *tv)
RTEMS_INLINE_ROUTINE void rtems_bsd_getbinuptime (struct bintime *bt)
RTEMS_INLINE_ROUTINE void rtems_bsd_getnanouptime (struct timespec *ts)
RTEMS_INLINE_ROUTINE void rtems_bsd_getmicrouptime (struct timeval *tv)
 Returns the uptime in the timeval format. More...
◆ rtems_bsd_bintime()
RTEMS_INLINE_ROUTINE void rtems_bsd_bintime ( struct bintime *  bt)
Parameters
[out]btReturns the wall clock time.
◆ rtems_bsd_binuptime()
RTEMS_INLINE_ROUTINE void rtems_bsd_binuptime ( struct bintime *  bt)
Parameters
[out]btReturns the uptime.
◆ rtems_bsd_getbintime()
RTEMS_INLINE_ROUTINE void rtems_bsd_getbintime ( struct bintime *  bt)
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Bintime() variant.
Parameters
[out]tsReturns the wall clock time.
◆ rtems_bsd_getbinuptime()
RTEMS_INLINE_ROUTINE void rtems_bsd_getbinuptime ( struct bintime *  bt)
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Binuptime() variant.
Parameters
[out]tsReturns the uptime.
◆ rtems_bsd_getmicrotime()
RTEMS_INLINE_ROUTINE void rtems_bsd_getmicrotime ( struct timeval *  tv)
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Microtime() variant.
Parameters
[out]tvReturns the wall clock time.
See also
_Timecounter_Getbintime().
◆ rtems_bsd_getmicrouptime()
RTEMS_INLINE_ROUTINE void rtems_bsd_getmicrouptime ( struct timeval *  tv)
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Microuptime() variant.
Parameters
[out]tvReturns the uptime.
◆ rtems_bsd_getnanotime()
RTEMS_INLINE_ROUTINE void rtems_bsd_getnanotime ( struct timespec *  ts)
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Nanotime() variant.
Parameters
See also
◆ rtems_bsd_getnanouptime()
RTEMS_INLINE_ROUTINE void rtems_bsd_getnanouptime ( struct timespec *  ts)
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Nanouptime() variant.
Parameters
◆ rtems_bsd_microtime()
RTEMS_INLINE_ROUTINE void rtems_bsd_microtime ( struct timeval *  tv)
Parameters
◆ rtems_bsd_microuptime()
RTEMS_INLINE_ROUTINE void rtems_bsd_microuptime ( struct timeval *  tv)
Parameters
◆ rtems_bsd_nanotime()
RTEMS_INLINE_ROUTINE void rtems_bsd_nanotime ( struct timespec *  ts)
Parameters
◆ rtems_bsd_nanouptime()
RTEMS_INLINE_ROUTINE void rtems_bsd_nanouptime ( struct timespec *  ts)
Parameters
