RTEMS
5.1
Files | |
file | i2c-bus.c |
Inter-Integrated Circuit (I2C) Bus Implementation. | |
struct | i2c_bus |
I2C bus control. More... | |
#define | I2C_BUS_CLOCK_DEFAULT 100000 |
Default I2C bus clock in Hz. | |
int | i2c_bus_init (i2c_bus *bus) |
Initializes a bus control. More... | |
i2c_bus * | i2c_bus_alloc_and_init (size_t size) |
Allocates a bus control from the heap and initializes it. More... | |
void | i2c_bus_destroy (i2c_bus *bus) |
Destroys a bus control. More... | |
void | i2c_bus_destroy_and_free (i2c_bus *bus) |
Destroys a bus control and frees its memory. More... | |
int | i2c_bus_register (i2c_bus *bus, const char *bus_path) |
Registers a bus control. More... | |
void | i2c_bus_obtain (i2c_bus *bus) |
Obtains the bus. More... | |
void | i2c_bus_release (i2c_bus *bus) |
Releases the bus. More... | |
int | i2c_bus_transfer (i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count) |
Transfers I2C messages. More... | |
I2C IO Control Commands | |
#define | I2C_BUS_OBTAIN 0x800 |
#define | I2C_BUS_RELEASE 0x801 |
#define | I2C_BUS_GET_CONTROL 0x802 |
Gets the bus control. More... | |
#define | I2C_BUS_SET_CLOCK 0x803 |
Sets the bus clock in Hz. More... | |
#define I2C_BUS_GET_CONTROL 0x802 |
The argument type is a pointer to i2c_bus pointer.
#define I2C_BUS_OBTAIN 0x800 |
Obtains the bus.
This command has no argument.
#define I2C_BUS_RELEASE 0x801 |
Releases the bus.
#define I2C_BUS_SET_CLOCK 0x803 |
The argument type is unsigned long.
i2c_bus* i2c_bus_alloc_and_init | ( | size_t | size | ) |
After a sucessful allocation and initialization the bus control must be destroyed via i2c_bus_destroy_and_free(). A registered bus control will be automatically destroyed in case the device file is unlinked. Make sure to call i2c_bus_destroy_and_free() in a custom destruction handler.
[in] | size | The size of the bus control. This enables the addition of bus controller specific data to the base bus control. The bus control is zero initialized. |
non-NULL | The new bus control. |
NULL | An error occurred. The errno is set to indicate the error. |
void i2c_bus_destroy | ( | i2c_bus * | bus | ) |
[in] | bus | The bus control. |
void i2c_bus_destroy_and_free | ( | i2c_bus * | bus | ) |
int i2c_bus_init | ( | i2c_bus * | bus | ) |
After a sucessful initialization the bus control must be destroyed via i2c_bus_destroy(). A registered bus control will be automatically destroyed in case the device file is unlinked. Make sure to call i2c_bus_destroy() in a custom destruction handler.
0 | Successful operation. |
-1 | An error occurred. The errno is set to indicate the error. |
void i2c_bus_obtain | ( | i2c_bus * | bus | ) |
Obtains the bus.
int i2c_bus_register | ( | i2c_bus * | bus, |
const char * | bus_path | ||
This function claims ownership of the bus control regardless if the registration is successful or not.
[in] | bus_path | The path to the bus device file. |
void i2c_bus_release | ( | i2c_bus * | bus | ) |
Releases the bus.
The bus is obtained before the transfer and released afterwards.
[in] | msgs | The messages to transfer. |
[in] | msg_count | The count of messages to transfer. It must be positive. |
negative | Negative error number in case of an error. |
