RTEMS  5.1
I2C bus control. More...
#include <i2c.h>
int(* transfer )(i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count)
 Transfers I2C messages. More...
int(* set_clock )(i2c_bus *bus, unsigned long clock)
 Sets the bus clock. More...
void(* destroy )(i2c_bus *bus)
 Destroys the bus. More...
rtems_recursive_mutex mutex
 Mutex to protect the bus access.
uint16_t default_address
 Default slave device address.
bool ten_bit_address
 Use 10-bit addresses.
bool use_pec
 Use SMBus PEC.
unsigned long retries
 Transfer retry count.
rtems_interval timeout
 Transaction timeout in ticks.
unsigned long functionality
 Controller functionality.
I2C bus control.
Field Documentation
◆ destroy
void(* i2c_bus::destroy) (i2c_bus *bus)
Destroys the bus.
Parameters
[in]busThe bus control.
◆ set_clock
int(* i2c_bus::set_clock) (i2c_bus *bus, unsigned long clock)
Sets the bus clock.
Parameters
[in]clockThe desired bus clock in Hz.
Return values
0Successful operation.
negativeNegative error number in case of an error.
◆ transfer
int(* i2c_bus::transfer) (i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count)
Parameters
[in]msgsThe messages to transfer.
[in]msg_countThe count of messages to transfer. It must be positive.
Return values
