RTEMS  5.1
flashdisk.c File Reference
Flash Disk Block Device Implementation. More...
#include <rtems/libio.h>
#include <unistd.h>
#include <inttypes.h>
#include <rtems/blkdev.h>
#include <rtems/flashdisk.h>
#include <rtems/thread.h>
struct  rtems_fdisk_page_desc
struct  rtems_fdisk_segment_ctl
struct  rtems_fdisk_segment_ctl_queue
struct  rtems_fdisk_device_ctl
struct  rtems_fdisk_block_ctl
struct  rtems_flashdisk
#define RTEMS_FDISK_TRACE   1
#define RTEMS_FDISK_PAGE_ACTIVE   (1 << 0)
#define RTEMS_FDISK_PAGE_USED   (1 << 1)
#define rtems_fdisk_calc_crc16(_b, _c)   rtems_fdisk_crc16_factor[((_b) ^ ((_c) & 0xff)) & 0xff] ^ (((_c) >> 8) & 0xff)
typedef struct rtems_fdisk_page_desc rtems_fdisk_page_desc
typedef struct rtems_fdisk_segment_ctl rtems_fdisk_segment_ctl
typedef struct rtems_fdisk_segment_ctl_queue rtems_fdisk_segment_ctl_queue
typedef struct rtems_fdisk_device_ctl rtems_fdisk_device_ctl
typedef struct rtems_fdisk_block_ctl rtems_fdisk_block_ctl
typedef struct rtems_flashdisk rtems_flashdisk
rtems_device_driver rtems_fdisk_initialize (rtems_device_major_number major, rtems_device_minor_number minor, void *arg RTEMS_UNUSED)
◆ rtems_fdisk_calc_crc16
#define rtems_fdisk_calc_crc16 (   _b,
  _c
Calculate the CRC16 checksum.
Parameters
_bThe byte to checksum.
_cThe current checksum.
◆ RTEMS_FDISK_PAGE_ACTIVE
Flag the page as active.
◆ RTEMS_FDISK_PAGE_USED
Flag the page as used.
◆ RTEMS_FDISK_TRACE
Control tracing. It can be compiled out of the code for small footprint targets. Leave in by default.
Typedef Documentation
◆ rtems_fdisk_block_ctl
The Block control holds the segment and page with the data.
◆ rtems_fdisk_device_ctl
Flash Device Control holds the segment controls
◆ rtems_fdisk_page_desc
The start of a segment has a segment control table. This hold the CRC and block number for the page.
Todo:
A sequence number for the block could be added. This would mean a larger descriptor size. Need to make the sequence large like 20+ bits so a large file system would not have more blocks available than the sequence number.
◆ rtems_fdisk_segment_ctl
Flash Segment Control holds the pointer to the segment, number of pages, various page stats and the memory copy of the page descriptors.
◆ rtems_fdisk_segment_ctl_queue
Segment control table queue.
◆ rtems_flashdisk
The virtual block table holds the mapping for blocks as seen by the disk drivers to the device, segment and page numbers of the physical device.
◆ rtems_fdisk_initialize()
rtems_device_driver rtems_fdisk_initialize ( rtems_device_major_number  major,
Flash disk device driver initialization.
Todo:
Memory clean up on error is really badly handled.
Parameters
majorFlash disk major device number.
minorMinor device number, not applicable.
argInitialization argument, not applicable.
