RTEMS  5.1
capture.h
1
11 /*
12  ------------------------------------------------------------------------
13
14  Copyright 2002, 2016 Chris Johns <chrisj@rtems.org>.
15  All rights reserved.
16
17  COPYRIGHT (c) 1989-2014
18  On-Line Applications Research Corporation (OAR).
19
20  The license and distribution terms for this file may be
21  found in the file LICENSE in this distribution.
22
23  This software with is provided ``as is'' and with NO WARRANTY.
24
25  ------------------------------------------------------------------------
26
27  RTEMS Performance Monitoring and Measurement Framework.
28  This is the Capture Engine component.
29
30 */
31
32 #ifndef __CAPTURE_H_
33 #define __CAPTURE_H_
34
35 #include <rtems.h>
36 #include <rtems/rtems/tasksimpl.h>
37
38 #include <string.h>
39
48 #ifdef __cplusplus
49 extern "C" {
50 #endif
51
52 /*
53  * Global capture flags.
54  */
55 #define RTEMS_CAPTURE_INIT (1u << 0)
56 #define RTEMS_CAPTURE_ON (1U << 1)
57 #define RTEMS_CAPTURE_NO_MEMORY (1U << 2)
58 #define RTEMS_CAPTURE_TRIGGERED (1U << 3)
59 #define RTEMS_CAPTURE_GLOBAL_WATCH (1U << 4)
60 #define RTEMS_CAPTURE_ONLY_MONITOR (1U << 5)
61
62 /*
63  * Per-CPU capture flags.
64  */
65 #define RTEMS_CAPTURE_OVERFLOW (1U << 0)
66 #define RTEMS_CAPTURE_READER_ACTIVE (1U << 1)
67 #define RTEMS_CAPTURE_READER_WAITING (1U << 2)
68
72 #define RTEMS_CAPTURE_TRIGGER_TASKS (32)
73
79 typedef uint64_t rtems_capture_time;
80
90 typedef struct rtems_capture_from
91 {
92  rtems_name name;
93  rtems_id id;
94  uint32_t trigger;
96
108 typedef struct rtems_capture_control
109 {
110  rtems_name name;
111  rtems_id id;
112  uint32_t flags;
113  uint32_t to_triggers;
114  uint32_t from_triggers;
115  uint32_t by_triggers;
116  uint32_t by_valid;
118  struct rtems_capture_control* next;
120
124 #define RTEMS_CAPTURE_CONTROL_FROM_MASK(_s) \
125  (UINT32_C(1) << (RTEMS_CAPTURE_TRIGGER_TASKS - ((_s) + 1)))
126
130 #define RTEMS_CAPTURE_WATCH (1U << 0)
131
135 #define RTEMS_CAPTURE_SWITCH (1 << 0)
136 #define RTEMS_CAPTURE_CREATE (1 << 1)
137 #define RTEMS_CAPTURE_START (1 << 2)
138 #define RTEMS_CAPTURE_RESTART (1 << 3)
139 #define RTEMS_CAPTURE_DELETE (1 << 4)
140 #define RTEMS_CAPTURE_BEGIN (1 << 5)
141 #define RTEMS_CAPTURE_EXITTED (1 << 6)
142 #define RTEMS_CAPTURE_TERMINATED (1 << 7)
143
144 #define RTEMS_CAPTURE_FROM_TRIGS (RTEMS_CAPTURE_SWITCH | \
145  RTEMS_CAPTURE_CREATE | \
146  RTEMS_CAPTURE_START | \
147  RTEMS_CAPTURE_RESTART | \
148  RTEMS_CAPTURE_DELETE)
149
150 #define RTEMS_CAPTURE_TO_TRIGS (RTEMS_CAPTURE_SWITCH | \
151  RTEMS_CAPTURE_CREATE | \
152  RTEMS_CAPTURE_START | \
153  RTEMS_CAPTURE_RESTART | \
154  RTEMS_CAPTURE_DELETE | \
155  RTEMS_CAPTURE_BEGIN | \
156  RTEMS_CAPTURE_EXITTED)
157
161 #define RTEMS_CAPTURE_TRACED (1U << 0)
162 #define RTEMS_CAPTURE_INIT_TASK (1U << 1)
163 #define RTEMS_CAPTURE_RECORD_TASK (1U << 2)
164
165 /*
166  * @brief Capture record.
167  *
168  * This is a record that is written into
169  * the buffer. The events includes the priority of the task
170  * at the time of the context switch.
171  */
172 typedef struct rtems_capture_record
173 {
174  size_t size;
175  uint32_t events;
176  rtems_id task_id;
177  rtems_capture_time time;
179
180 /*
181  * @brief Capture task record.
182  *
183  * This is a record that is written into
184  * the buffer. The events includes the priority of the task
185  * at the time of the context switch.
186  */
188 {
189  rtems_name name;
190  rtems_task_priority start_priority;
191  uint32_t stack_size;
193
197 #define RTEMS_CAPTURE_REAL_PRI_EVENT_MASK UINT32_C (0x000000ff)
198 #define RTEMS_CAPTURE_CURR_PRI_EVENT_MASK UINT32_C (0x0000ff00)
199 #define RTEMS_CAPTURE_REAL_PRIORITY_EVENT (0)
200 #define RTEMS_CAPTURE_CURR_PRIORITY_EVENT (8)
201 #define RTEMS_CAPTURE_EVENT_START (16)
202 #define RTEMS_CAPTURE_CREATED_BY_EVENT UINT32_C (0x00010000)
203 #define RTEMS_CAPTURE_CREATED_EVENT UINT32_C (0x00020000)
204 #define RTEMS_CAPTURE_STARTED_BY_EVENT UINT32_C (0x00040000)
205 #define RTEMS_CAPTURE_STARTED_EVENT UINT32_C (0x00080000)
206 #define RTEMS_CAPTURE_RESTARTED_BY_EVENT UINT32_C (0x00100000)
207 #define RTEMS_CAPTURE_RESTARTED_EVENT UINT32_C (0x00200000)
208 #define RTEMS_CAPTURE_DELETED_BY_EVENT UINT32_C (0x00400000)
209 #define RTEMS_CAPTURE_DELETED_EVENT UINT32_C (0x00800000)
210 #define RTEMS_CAPTURE_TERMINATED_EVENT UINT32_C (0x01000000)
211 #define RTEMS_CAPTURE_BEGIN_EVENT UINT32_C (0x02000000)
212 #define RTEMS_CAPTURE_EXITTED_EVENT UINT32_C (0x04000000)
213 #define RTEMS_CAPTURE_SWITCHED_OUT_EVENT UINT32_C (0x08000000)
214 #define RTEMS_CAPTURE_SWITCHED_IN_EVENT UINT32_C (0x10000000)
215 #define RTEMS_CAPTURE_TIMESTAMP UINT32_C (0x20000000)
216 #define RTEMS_CAPTURE_EVENT_END (29)
217
224 {
225  rtems_capture_to_any,
226  rtems_capture_from_any,
227  rtems_capture_from_to
229
236 {
237  rtems_capture_switch,
238  rtems_capture_create,
239  rtems_capture_start,
240  rtems_capture_restart,
241  rtems_capture_delete,
242  rtems_capture_begin,
243  rtems_capture_exitted,
244  rtems_capture_terminated
246
256
270 typedef struct {
271  rtems_interrupt_lock_context lock_context;
272  rtems_interrupt_lock* lock;
274
292  rtems_capture_timestamp timestamp);
293
305
318
333
334 /*
335  * @brief Capture flush trace buffer.
336  *
337  * This function flushes the trace buffer. The prime parameter allows the
338  * capture engine to also be primed again.
339  *
340  * @param[in] prime The prime after flush flag.
341  *
342  * @retval This method returns RTEMS_SUCCESSFUL if there was not an
343  * error. Otherwise, a status code is returned indicating the
344  * source of the error.
345  */
346 rtems_status_code rtems_capture_flush (bool prime);
347
364
380
396  rtems_id id,
397  bool enable);
398
413
423
440
450
467
477
508  rtems_id from_id,
509  rtems_name to_name,
510  rtems_id to_id,
512  rtems_capture_trigger trigger);
513
534  rtems_id from_id,
535  rtems_name to_name,
536  rtems_id to_id,
538  rtems_capture_trigger trigger);
539
565  size_t* read,
566  const void** recs);
567
580 rtems_status_code rtems_capture_release (uint32_t cpu, uint32_t count);
581
594 bool rtems_capture_filter (rtems_tcb* task, uint32_t events);
595
608
620 const char* rtems_capture_event_text (int event);
621
630
639
649
658
676  uint32_t events,
677  size_t size,
679
689
701 static inline void*
702 rtems_capture_record_append (void* rec, const void* data, size_t size)
703 {
704  memcpy (rec, data, size);
705  return ((uint8_t*) rec) + size;
706 }
707
719 static inline void*
720 rtems_capture_record_extract (const void* rec, void* data, size_t size)
721 {
722  memcpy (data, rec, size);
723  return ((uint8_t*) rec) + size;
724 }
725
734 static inline bool rtems_capture_task_recorded (rtems_tcb* tcb) {
735  return ((tcb->Capture.flags & RTEMS_CAPTURE_RECORD_TASK) != 0);
736 }
737
746 static inline bool rtems_capture_task_initialized (rtems_tcb* tcb) {
747  return ((tcb->Capture.flags & RTEMS_CAPTURE_INIT_TASK) != 0);
748 }
749
759 static inline rtems_id
760 rtems_capture_task_id (rtems_tcb* tcb)
761 {
762  return tcb->Object.id;
763 }
764
774 static inline int
775 rtems_capture_task_api (rtems_id id)
776 {
777  return _Objects_Get_API (id);
778 }
779
789 static inline States_Control
790 rtems_capture_task_state (rtems_tcb* tcb)
791 {
792  if (tcb)
793  return tcb->current_state;
794  return 0;
795 }
796
806 static inline rtems_name
807 rtems_capture_task_name (rtems_tcb* tcb)
808 {
809  rtems_name name;
810  rtems_object_get_classic_name( tcb->Object.id, &name );
811  return name;
812 }
813
823 static inline uint32_t
824 rtems_capture_task_flags (rtems_tcb* tcb)
825 {
826  return tcb->Capture.flags;
827 }
828
838 static inline rtems_capture_control*
839 rtems_capture_task_control (rtems_tcb* tcb)
840 {
841  return tcb->Capture.control;
842 }
843
853 static inline uint32_t
854 rtems_capture_task_control_flags (rtems_tcb* tcb)
855 {
856  rtems_capture_control* control = tcb->Capture.control;
857  if (!control)
858  return 0;
859  return control->flags;
860 }
861
873 static inline rtems_task_priority
874 rtems_capture_task_start_priority (rtems_tcb* tcb)
875 {
877  tcb->Start.initial_priority);
878 }
879
889 static inline rtems_task_priority
890 rtems_capture_task_real_priority (rtems_tcb* tcb)
891 {
893 }
894
904 static inline rtems_task_priority
905 rtems_capture_task_curr_priority (rtems_tcb* tcb)
906 {
907  return _Thread_Get_unmapped_priority (tcb);
908 }
909
921
933 static inline rtems_capture_control*
934 rtems_capture_next_control (rtems_capture_control* control)
935 {
936  return control->next;
937 }
938
948 static inline rtems_id
949 rtems_capture_control_id (rtems_capture_control* control)
950 {
951  return control->id;
952 }
953
963 static inline rtems_name
964 rtems_capture_control_name (rtems_capture_control* control)
965 {
966  return control->name;
967 }
968
978 static inline uint32_t
979 rtems_capture_control_flags (rtems_capture_control* control)
980 {
981  return control->flags;
982 }
983
993 static inline uint32_t
994 rtems_capture_control_to_triggers (rtems_capture_control* control)
995 {
996  return control->to_triggers;
997 }
998
1008 static inline uint32_t
1009 rtems_capture_control_from_triggers (rtems_capture_control* control)
1010 {
1011  return control->from_triggers;
1012 }
1013
1023 static inline uint32_t
1024 rtems_capture_control_all_by_triggers (rtems_capture_control* control)
1025 {
1026  return control->by_triggers;
1027 }
1028
1039 static inline int
1040 rtems_capture_control_by_valid (rtems_capture_control* control, int slot)
1041 {
1042  return control->by_valid & RTEMS_CAPTURE_CONTROL_FROM_MASK (slot);
1043 }
1044
1055 static inline rtems_name
1056 rtems_capture_control_by_name (rtems_capture_control* control, int by)
1057 {
1058  if (by < RTEMS_CAPTURE_TRIGGER_TASKS)
1059  return control->by[by].name;
1060  return control->by[0].name;
1061 }
1062
1070 static inline rtems_id
1071 rtems_capture_control_by_id (rtems_capture_control* control, int by)
1072 {
1073  if (by < RTEMS_CAPTURE_TRIGGER_TASKS)
1074  return control->by[by].id;
1075  return control->by[0].id;
1076 }
1077
1085 static inline uint32_t
1086 rtems_capture_control_by_triggers (rtems_capture_control* control,
1087  int by)
1088 {
1089  if (by < RTEMS_CAPTURE_TRIGGER_TASKS)
1090  return control->by[by].trigger;
1091  return control->by[0].trigger;
1092 }
1093
1103 static inline uint32_t
1104 rtems_capture_control_count (void)
1105 {
1107  uint32_t count = 0;
1108
1109  while (control)
1110  {
1111  count++;
1112  control = rtems_capture_next_control (control);
1113  }
1114
1115  return count;
1116 }
1117
1118 #ifdef __cplusplus
1119 }
1120 #endif
1121
1123 #endif
rtems_status_code rtems_capture_watch_floor(rtems_task_priority floor)
Capture set watch floor.
Definition: capture.c:997
struct rtems_capture_from rtems_capture_from
Task id and mask for the from trigger.
rtems_status_code rtems_capture_set_monitor(bool enable)
Capture monitor enable/disable.
Definition: capture.c:731
rtems_status_code rtems_capture_clear_trigger(rtems_name from_name, rtems_id from_id, rtems_name to_name, rtems_id to_id, rtems_capture_trigger_mode mode, rtems_capture_trigger trigger)
Capture clear trigger.
Definition: capture.c:1135
ssize_t read(int fd, void *buffer, size_t count)
Definition: read.c:27
void(* rtems_capture_timestamp)(rtems_capture_time *time)
Capture timestamp callout handler.
Definition: capture.h:255
Definition: capture.h:90
Capture control structure for a group of tasks.
Definition: capture.h:108
rtems_status_code rtems_capture_watch_del(rtems_name name, rtems_id id)
Capture delete watch.
Definition: capture.c:848
rtems_status_code rtems_capture_watch_global(bool enable)
Capture enable/disable global watch.
Definition: capture.c:939
rtems_status_code rtems_capture_set_control(bool enable)
Capture control trace enable/disable.
Definition: capture.c:703
struct rtems_capture_control rtems_capture_control
uint32_t rtems_name
Classic API object name type.
Definition: types.h:77
A capture timestamp.
Definition: capture.h:79
Thread_Start_information Start
Definition: thread.h:832
void rtems_capture_record_task(rtems_tcb *tcb)
Capture record task.
Definition: capture.c:452
bool rtems_capture_watch_global_on(void)
Get global watch state.
Definition: capture.c:963
Capture trigger.
Definition: capture.h:235
rtems_capture_control * rtems_capture_get_control_list(void)
Capture get control list.
Definition: capture.c:1367
rtems_status_code rtems_capture_close(void)
Capture close.
Definition: capture.c:643
rtems_status_code rtems_capture_release(uint32_t cpu, uint32_t count)
Capture release records.
Definition: capture.c:1288
Definition: capture.h:72
RTEMS_INLINE_ROUTINE Priority_Control _Thread_Get_unmapped_priority(const Thread_Control *the_thread)
Returns the unmapped priority of the thread.
Definition: threadimpl.h:1601
rtems_status_code rtems_capture_watch_add(rtems_name name, rtems_id id)
Capture add watch.
Definition: capture.c:817
rtems_status_code rtems_capture_read(uint32_t cpu, size_t *read, const void **recs)
Capture read records from capture buffer.
Definition: capture.c:1234
ISR lock control.
Definition: isrlock.h:56
void rtems_capture_record_close(rtems_capture_record_lock_context *context)
Capture record close.
Definition: capture.c:418
RTEMS_INLINE_ROUTINE Objects_APIs _Objects_Get_API(Objects_Id id)
Returns the API portion of the ID.
Definition: object.h:255
uint32_t States_Control
Definition: states.h:46
void rtems_capture_record_lock(rtems_capture_record_lock_context *context)
Capture record lock.
Definition: capture.c:356
rtems_status_code
Classic API Status.
Definition: status.h:43
Definition: thread.h:732
rtems_task_priority rtems_capture_watch_get_floor(void)
Definition: capture.c:1007
RTEMS_INLINE_ROUTINE Priority_Control _Thread_Get_unmapped_real_priority(const Thread_Control *the_thread)
Returns the unmapped real priority of the thread.
Definition: threadimpl.h:1615
Objects_Control Object
Definition: thread.h:734
void rtems_capture_initialize_task(rtems_tcb *tcb)
Capture initialize task.
Definition: capture.c:424
States_Control current_state
Definition: thread.h:756
rtems_status_code rtems_capture_set_trigger(rtems_name from_name, rtems_id from_id, rtems_name to_name, rtems_id to_id, rtems_capture_trigger_mode mode, rtems_capture_trigger trigger)
Capture set trigger.
Definition: capture.c:1057
Capture trigger modes.
Definition: capture.h:223
Used for passing and retrieving registers content to/from real mode interrupt call.
Definition: realmode_int.h:43
Definition: intercom.c:74
rtems_status_code rtems_capture_watch_ctrl(rtems_name name, rtems_id id, bool enable)
Capture enable/disable watch.
Definition: capture.c:897
Priority_Control initial_priority
Definition: thread.h:201
rtems_status_code rtems_object_get_classic_name(rtems_id id, rtems_name *name)
Obtain Name of Object.
Definition: rtemsobjectgetclassicname.c:25
void * rtems_capture_record_open(rtems_tcb *task, uint32_t events, size_t size, rtems_capture_record_lock_context *context)
Capture record open.
Definition: capture.c:372
rtems_task_priority rtems_capture_watch_get_ceiling(void)
Get watch ceiling.
Definition: capture.c:985
void rtems_capture_record_unlock(rtems_capture_record_lock_context *context)
Capture record unlock.
Definition: capture.c:366
const char * rtems_capture_event_text(int event)
Capture get event text.
Definition: capture.c:1355
RTEMS_INLINE_ROUTINE const Scheduler_Control * _Thread_Scheduler_get_home(const Thread_Control *the_thread)
Gets the home scheduler of the thread.
Definition: threadimpl.h:1393
unsigned context
Definition: tlb.h:108
Capture record lock context.
Definition: capture.h:270
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
Definition: capture.h:187
Definition: capture.h:124
Local ISR lock context for acquire and release pairs.
Definition: isrlock.h:65
rtems_status_code rtems_capture_watch_ceiling(rtems_task_priority ceiling)
Set watch ceiling.
Definition: capture.c:975
RTEMS_INLINE_ROUTINE rtems_task_priority _RTEMS_Priority_From_core(const Scheduler_Control *scheduler, Priority_Control priority)
Converts the SuperCore priority to the corresponding RTEMS API priority.
Definition: tasksimpl.h:105
unsigned size
Definition: tte.h:74
Definition: capture.h:172
void rtems_capture_get_time(rtems_capture_time *time)
Capture returns the current time.
Definition: capture.c:148
rtems_status_code rtems_capture_open(uint32_t size, rtems_capture_timestamp timestamp)
Capture open.
Definition: capture.c:587
bool rtems_capture_filter(rtems_tcb *task, uint32_t events)
Capture filter.
Definition: capture.c:486
Classic Tasks Manager Implementation.
Objects_Id id
Definition: objectdata.h:43
uint32_t rtems_task_priority
Definition: tasks.h:55
