RTEMS
5.1
Capture record lock context. More...
#include <capture.h>
Data Fields | |
rtems_interrupt_lock_context | lock_context |
rtems_interrupt_lock * | lock |
This structure is used to lock a per CPU buffer when opeining recording. The per CPU buffer is held locked until the record close is called. Locking masks interrupts so use this lock only when needed and do not hold it for long.
The lock first masks the CPU interrupt before taking the interrupt lock. This stops a thread context taking the lock and then an interrupt on the same CPU attempting to take the lock so creating a deadlock.
