RTEMS
5.1
Global BSP definitions. More...
#include <bspopts.h>
#include <bsp/default-initial-extension.h>
#include <libcpu/io.h>
#include <bsp/vectors.h>
#define | _256M 0x10000000 |
#define | _512M 0x20000000 |
#define | GT64x60_REG_BASE 0xf1000000 /* Base of GT64260 Reg Space */ |
#define | GT64x60_REG_SPACE_SIZE 0x10000 /* 64Kb Internal Reg Space */ |
#define | GT64x60_DEV1_BASE |
#define | GT64260_DEV1_SIZE 0x00100000 /* Device bank size */ |
#define | _IO_BASE GT64x60_REG_BASE |
#define | BSP_NVRAM_BASE_ADDR 0xf1110000 |
#define | BSP_RTC_INTA_REG 0x7ff0 |
#define | BSP_RTC_SECOND 0x7ff2 |
#define | BSP_RTC_MINUTE 0x7ff3 |
#define | BSP_RTC_HOUR 0x7ff4 |
#define | BSP_RTC_DATE 0x7ff5 |
#define | BSP_RTC_INTERRUPTS 0x7ff6 |
#define | BSP_RTC_WATCHDOG 0x7ff7 |
#define | PCI0_IO_BASE 0xf0000000 |
#define | PCI1_IO_BASE 0xf0800000 |
#define | PCI0_MEM_BASE 0x80000000 |
#define | PCI_MEM_BASE 0 /* glue for vmeUniverse */ |
#define | PCI_MEM_BASE_ADJUSTMENT 0 |
#define | PCI_DRAM_OFFSET 0 |
#define | PCI1_MEM_BASE 0xe0000000 |
#define | PCI1_MEM_SIZE 0x10000000 |
#define | BSP_MAX_PCI_BUS_ON_PCI0 8 |
#define | BSP_MAX_PCI_BUS_ON_PCI1 2 |
#define | BSP_MAX_PCI_BUS (BSP_MAX_PCI_BUS_ON_PCI0+BSP_MAX_PCI_BUS_ON_PCI1) |
#define | BSP_PCI_IRQ0 BSP_GPP_IRQ_LOWEST_OFFSET |
#define | BSP_INTERRUPT_STACK_SIZE (16 * 1024) /* <skf> 2/09 wants it to be adjustable by BSP */ |
#define | BSP_UART_IOBASE_COM1 GT64x60_DEV1_BASE + 0x20000 |
#define | BSP_UART_IOBASE_COM2 GT64x60_DEV1_BASE + 0x21000 |
#define | BSP_CONSOLE_PORT BSP_UART_COM1 /* console */ |
#define | BSP_UART_BAUD_BASE 115200 |
#define | BSP_Convert_decrementer(_value) ((unsigned long long) ((((unsigned long long)BSP_time_base_divisor) * 1000000ULL) /((unsigned long long) BSP_bus_frequency)) * ((unsigned long long) (_value))) |
#define | RTEMS_BSP_NETWORK_DRIVER_NAME "wmG1" |
#define | RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_i82544EI_driver_attach |
#define | gccMemBar() RTEMS_COMPILER_MEMORY_BARRIER() |
Enumerations | |
enum | BSP_BoardTypes { undefined = 0, MVME5500, MVME6100 } |
enum | BSP_VMEchipTypes { Undefined, UNIVERSE2, TSI148 } |
enum | DiscoveryChipVersion { notdefined, GT64260A, GT64260B, MV64360 } |
unsigned int | BSP_mem_size |
unsigned int | BSP_bus_frequency |
unsigned int | BSP_processor_frequency |
unsigned int | BSP_time_base_divisor |
