RTEMS  5.1
vectors.h
1
10 /*
11  * Copyright (C) 1999 Eric Valette (valette@crf.canon.fr)
12  * Canon Centre Recherche France.
13  *
14  * Copyright (C) 2007 Till Straumann <strauman@slac.stanford.edu>
15  *
16  * Copyright (C) 2009 embedded brains GmbH.
17  *
18  * Enhanced by Jay Kulpinski <jskulpin@eng01.gdds.com>
19  * to support 603, 603e, 604, 604e exceptions
20  *
21  * Moved to "libcpu/powerpc/new-exceptions" and consolidated
22  * by Thomas Doerfler <Thomas.Doerfler@embedded-brains.de>
23  * to be common for all PPCs with new exceptions.
24  *
25  * Derived from file "libcpu/powerpc/new-exceptions/raw_exception.h".
26  * Derived from file "libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_bspsupp.h".
27  *
28  * The license and distribution terms for this file may be
29  * found in the file LICENSE in this distribution or at
30  * http://www.rtems.org/license/LICENSE.
31  */
32
33 /* DO NOT INTRODUCE #ifdef <cpu_flavor> in this file */
34
35 #ifndef LIBCPU_VECTORS_H
36 #define LIBCPU_VECTORS_H
37
38 #include <bspopts.h>
39 #include <rtems/score/cpuimpl.h>
40 #include <libcpu/powerpc-utility.h>
41
42 #ifdef __cplusplus
43 extern "C" {
44 #endif
45
54 #define ASM_RESET_VECTOR 0x01
55 #define ASM_MACH_VECTOR 0x02
56 #define ASM_PROT_VECTOR 0x03
57 #define ASM_ISI_VECTOR 0x04
58 #define ASM_EXT_VECTOR 0x05
59 #define ASM_ALIGN_VECTOR 0x06
60 #define ASM_PROG_VECTOR 0x07
61 #define ASM_FLOAT_VECTOR 0x08
62 #define ASM_DEC_VECTOR 0x09
63 #define ASM_SYS_VECTOR 0x0C
64 #define ASM_TRACE_VECTOR 0x0D
65
66 #define ASM_PPC405_APU_UNAVAIL_VECTOR ASM_60X_VEC_ASSIST_VECTOR
67
68 #define ASM_8XX_FLOATASSIST_VECTOR 0x0E
69 #define ASM_8XX_SOFTEMUL_VECTOR 0x10
70 #define ASM_8XX_ITLBMISS_VECTOR 0x11
71 #define ASM_8XX_DTLBMISS_VECTOR 0x12
72 #define ASM_8XX_ITLBERROR_VECTOR 0x13
73 #define ASM_8XX_DTLBERROR_VECTOR 0x14
74 #define ASM_8XX_DBREAK_VECTOR 0x1C
75 #define ASM_8XX_IBREAK_VECTOR 0x1D
76 #define ASM_8XX_PERIFBREAK_VECTOR 0x1E
77 #define ASM_8XX_DEVPORT_VECTOR 0x1F
78
79 #define ASM_5XX_FLOATASSIST_VECTOR 0x0E
80 #define ASM_5XX_SOFTEMUL_VECTOR 0x10
81 #define ASM_5XX_IPROT_VECTOR 0x13
82 #define ASM_5XX_DPROT_VECTOR 0x14
83 #define ASM_5XX_DBREAK_VECTOR 0x1C
84 #define ASM_5XX_IBREAK_VECTOR 0x1D
85 #define ASM_5XX_MEBREAK_VECTOR 0x1E
86 #define ASM_5XX_NMEBREAK_VECTOR 0x1F
87
88 #define ASM_60X_VEC_VECTOR 0x0A
89 #define ASM_60X_PERFMON_VECTOR 0x0F
90 #define ASM_60X_IMISS_VECTOR 0x10
91 #define ASM_60X_DLMISS_VECTOR 0x11
92 #define ASM_60X_DSMISS_VECTOR 0x12
93 #define ASM_60X_ADDR_VECTOR 0x13
94 #define ASM_60X_SYSMGMT_VECTOR 0x14
95 #define ASM_60X_VEC_ASSIST_VECTOR 0x16
96 #define ASM_60X_ITM_VECTOR 0x17
97
98 /* Book E */
99 #define ASM_BOOKE_CRIT_VECTOR 0x01
100 /* We could use the std. decrementer vector # on bookE, too,
101  * but the bookE decrementer has slightly different semantics
102  * so we use a different vector (which happens to be
103  * the PIT vector on the 405 which is like the booke decrementer)
104  */
105 #define ASM_BOOKE_DEC_VECTOR 0x10
106 #define ASM_BOOKE_ITLBMISS_VECTOR 0x11
107 #define ASM_BOOKE_DTLBMISS_VECTOR 0x12
108 #define ASM_BOOKE_FIT_VECTOR 0x13
109 #define ASM_BOOKE_WDOG_VECTOR 0x14
110 #define ASM_BOOKE_APU_VECTOR 0x18
111 #define ASM_BOOKE_DEBUG_VECTOR ASM_TRACE_VECTOR
112
113 /* e200 and e500 */
114 #define ASM_E500_SPE_UNAVAILABLE_VECTOR ASM_60X_VEC_VECTOR
115 #define ASM_E500_EMB_FP_DATA_VECTOR 0x19
116 #define ASM_E500_EMB_FP_ROUND_VECTOR 0x1A
117 #define ASM_E500_PERFMON_VECTOR ASM_60X_PERFMON_VECTOR
118
119 /* e300 */
120 #define ASM_E300_CRIT_VECTOR 0x0A
121 #define ASM_E300_PERFMON_VECTOR ASM_60X_PERFMON_VECTOR
122 #define ASM_E300_IMISS_VECTOR ASM_60X_IMISS_VECTOR /* Special case: Shadowed GPRs */
123 #define ASM_E300_DLMISS_VECTOR ASM_60X_DLMISS_VECTOR /* Special case: Shadowed GPRs */
124 #define ASM_E300_DSMISS_VECTOR ASM_60X_DSMISS_VECTOR /* Special case: Shadowed GPRs */
125 #define ASM_E300_ADDR_VECTOR ASM_60X_ADDR_VECTOR
126 #define ASM_E300_SYSMGMT_VECTOR ASM_60X_SYSMGMT_VECTOR
127
128 /*
129  * If you change that number make sure to adjust the wrapper code in ppc_exc.S
130  * and that ppc_exc_handler_table will be correctly initialized.
131  */
132 #define LAST_VALID_EXC 0x1F
133
134 /* DO NOT USE -- this symbol is DEPRECATED
135  * (only used by libbsp/shared/vectors/vectors.S
136  * which should not be used by new BSPs).
137  */
138 #define ASM_60X_VEC_VECTOR_OFFSET 0xf20
139
140 #define ASM_PPC405_FIT_VECTOR_OFFSET 0x1010
141 #define ASM_PPC405_WDOG_VECTOR_OFFSET 0x1020
142 #define ASM_PPC405_TRACE_VECTOR_OFFSET 0x2000
143
154 /*
155  * The callee (high level exception code written in C)
156  * will store the Link Registers (return address) at entry r1 + 4 !!!.
157  * So let room for it!!!.
158  */
159 #define LINK_REGISTER_CALLEE_UPDATE_ROOM 4
160
161 #define EXC_GENERIC_SIZE (PPC_EXC_FRAME_SIZE + PPC_STACK_RED_ZONE_SIZE)
162
163 #define PPC_EXC_INTERRUPT_FRAME_SIZE CPU_INTERRUPT_FRAME_SIZE
164
165 #if defined(__ALTIVEC__) && !defined(PPC_MULTILIB_ALTIVEC)
166 #define EXC_VEC_OFFSET EXC_GENERIC_SIZE
167 #ifndef PPC_CACHE_ALIGNMENT
168 #error "Missing include file!"
169 #endif
170 /* 20 volatile registers
171  * + cache-aligned area for vcsr, vrsave
172  * + area for alignment
173  */
174 #define EXC_VEC_SIZE (16*20 + 2*PPC_CACHE_ALIGNMENT)
175 #else
176 #define EXC_VEC_SIZE (0)
177 #endif
178
179 /*
180  * maintain the EABI requested 8 bytes aligment
181  * As SVR4 ABI requires 16, make it 16 (as some
182  * exception may need more registers to be processed...)
183  */
184 #define EXCEPTION_FRAME_END (EXC_GENERIC_SIZE + EXC_VEC_SIZE)
185
188 #ifndef ASM
189
197
210
215
216 void BSP_printStackTrace(const BSP_Exception_frame *excPtr);
217
226 typedef enum {
227  PPC_EXC_INVALID = 0,
228  PPC_EXC_ASYNC = 1,
229  PPC_EXC_CLASSIC = 2,
230  PPC_EXC_CLASSIC_ASYNC = PPC_EXC_CLASSIC | PPC_EXC_ASYNC,
231  PPC_EXC_405_CRITICAL = 4,
232  PPC_EXC_405_CRITICAL_ASYNC = PPC_EXC_405_CRITICAL | PPC_EXC_ASYNC,
233  PPC_EXC_BOOKE_CRITICAL = 6,
234  PPC_EXC_BOOKE_CRITICAL_ASYNC = PPC_EXC_BOOKE_CRITICAL | PPC_EXC_ASYNC,
235  PPC_EXC_E500_MACHCHK = 8,
236  PPC_EXC_E500_MACHCHK_ASYNC = PPC_EXC_E500_MACHCHK | PPC_EXC_ASYNC,
237  PPC_EXC_NAKED = 10
239
243 typedef uint8_t ppc_exc_categories [LAST_VALID_EXC + 1];
244
245 static inline bool ppc_exc_is_valid_category(ppc_exc_category category)
246 {
247  return (unsigned) category <= (unsigned) PPC_EXC_NAKED;
248 }
249
256 void *ppc_exc_vector_address(unsigned vector, void *vector_base);
257
262 const ppc_exc_categories *ppc_exc_categories_for_cpu(ppc_cpu_id_t cpu);
263
268 static inline const ppc_exc_categories *ppc_exc_current_categories(void)
269 {
270  return ppc_exc_categories_for_cpu(ppc_cpu_current());
271 }
272
278  const ppc_exc_categories *categories,
279  unsigned vector
280 );
281
296  unsigned vector,
297  void *vector_base,
298  ppc_exc_category category,
299  uint32_t *prologue,
300  size_t *prologue_size
301 );
302
303 static inline void ppc_exc_initialize_interrupt_stack(uintptr_t stack_begin)
304 {
305  uintptr_t stack_size = rtems_configuration_get_interrupt_stack_size();
306  uintptr_t stack_end = stack_begin + stack_size;
307  uintptr_t stack_pointer = stack_end - PPC_MINIMUM_STACK_FRAME_SIZE;
308
309  /* Ensure proper interrupt stack alignment */
310  stack_pointer &= ~((uintptr_t) CPU_STACK_ALIGNMENT - 1);
311
312  /* Tag interrupt stack bottom */
313  *(uint32_t *) stack_pointer = 0;
314
315  /* Move interrupt stack values to special purpose registers */
316  PPC_SET_SPECIAL_PURPOSE_REGISTER(SPRG1, stack_pointer);
317  PPC_SET_SPECIAL_PURPOSE_REGISTER(SPRG2, stack_begin);
318 }
319
326  uintptr_t interrupt_stack_begin,
327  void *vector_base
328 );
329
343 static inline void ppc_exc_initialize(void)
344 {
346  (uintptr_t) _ISR_Stack_area_begin,
347  NULL
348  );
349 }
350
359 typedef int (*ppc_exc_handler_t)(BSP_Exception_frame *f, unsigned vector);
360
366 int ppc_exc_handler_default(BSP_Exception_frame *f, unsigned int vector);
367
368 #ifndef PPC_EXC_CONFIG_BOOKE_ONLY
369
380 extern uint32_t ppc_exc_msr_bits;
381
382 #endif /* PPC_EXC_CONFIG_BOOKE_ONLY */
383
397 extern uint32_t ppc_exc_cache_wb_check;
398
399 #ifndef PPC_EXC_CONFIG_USE_FIXED_HANDLER
400
403  extern ppc_exc_handler_t ppc_exc_handler_table [LAST_VALID_EXC + 1];
404
409 #else /* PPC_EXC_CONFIG_USE_FIXED_HANDLER */
410
413  extern const ppc_exc_handler_t ppc_exc_handler_table [LAST_VALID_EXC + 1];
414
418  void bsp_interrupt_dispatch(uintptr_t exception_number);
419 #endif /* PPC_EXC_CONFIG_USE_FIXED_HANDLER */
420
444
448 ppc_exc_handler_t ppc_exc_get_handler(unsigned vector);
449
460 extern uint32_t (*ppc_exc_get_DAR)(void);
461
462 void
463 ppc_exc_wrapup(BSP_Exception_frame *f);
464
471 int ppc_exc_alignment_handler(BSP_Exception_frame *frame, unsigned excNum);
472
475 /*
476  * Compatibility with pc386
477  */
478 typedef exception_handler_t cpuExcHandlerType;
479
480 #endif /* ASM */
481
482 #ifdef __cplusplus
483 }
484 #endif
485
486 #endif /* LIBCPU_VECTORS_H */
void bsp_interrupt_dispatch(void)
Interrupt dispatch.
Definition: irq.c:83
Default high-level exception handler.
Definition: ppc_exc_hdl.c:45
char _ISR_Stack_area_begin[]
The interrupt stack area begin.
ppc_exc_category ppc_exc_category_for_vector(const ppc_exc_categories *categories, unsigned vector)
Returns the category for the vector vector using the category set categories.
Definition: ppc_exc_categories.c:318
#define PPC_SET_SPECIAL_PURPOSE_REGISTER(spr, val)
Sets the Special Purpose Register with number spr to the value in val.
Definition: powerpc-utility.h:576
exception_handler_t globalExceptHdl
Global exception handler.
Definition: ppc_exc_hdl.c:52
uint8_t ppc_exc_categories[LAST_VALID_EXC+1]
Categorie set type.
Definition: vectors.h:243
void * ppc_exc_vector_address(unsigned vector, void *vector_base)
Returns the entry address of the vector.
Definition: ppc_exc_address.c:60
General purpose assembler macros, linker command file support and some inline functions for direct re...
rtems_status_code
Classic API Status.
Definition: status.h:43
void(* exception_handler_t)(BSP_Exception_frame *)
Global exception handler type.
Definition: vectors.h:209
Bits for MSR update.
Definition: ppc_exc_hdl.c:41
rtems_status_code ppc_exc_set_handler(unsigned vector, ppc_exc_handler_t hdl)
Set high-level exception handler.
Definition: ppc_exc_hdl.c:73
const ppc_exc_categories * ppc_exc_categories_for_cpu(ppc_cpu_id_t cpu)
Returns the category set for a CPU of type cpu, or NULL if there is no category set available for thi...
Definition: ppc_exc_categories.c:252
void ppc_exc_initialize_with_vector_base(uintptr_t interrupt_stack_begin, void *vector_base)
Initializes the exception handling.
Definition: ppc_exc_initialize.c:83
void C_exception_handler(BSP_Exception_frame *excPtr)
Default global exception handler.
Definition: ppc_exc_global_handler.c:22
uint32_t(* ppc_exc_get_DAR)(void)
Function for DAR access.
Definition: ppc_exc_print.c:60
ppc_exc_category
Exception categories.
Definition: vectors.h:226
ppc_exc_handler_t ppc_exc_handler_table[LAST_VALID_EXC+1]
High-level exception handler table.
Definition: ppc_exc_hdl.c:55
int(* ppc_exc_handler_t)(BSP_Exception_frame *f, unsigned vector)
High-level exception handler type.
Definition: vectors.h:359
Returns the currently active high-level exception handler.
Definition: ppc_exc_hdl.c:61
The set of registers that specifies the complete processor state.
Definition: cpu.h:629
Standard aligment handler.
Definition: ppc_exc_alignment.c:18
Cache write back check flag.
Definition: ppc_exc_initialize.c:30
rtems_status_code ppc_exc_make_prologue(unsigned vector, void *vector_base, ppc_exc_category category, uint32_t *prologue, size_t *prologue_size)
Makes a minimal prologue for the vector vector with the category category.
Definition: ppc_exc_prologue.c:104
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
