RTEMS  5.1
bsp.h
1
9 /*
10  * Copyright (C) 1999 Eric Valette. valette@crf.canon.fr
11  *
12  * The license and distribution terms for this file may be
13  * found in the file LICENSE in this distribution or at
14  * http://www.rtems.org/license/LICENSE.
15  *
16  * (C) S. Kate Feng 2003-2007 : Modified it to support the mvme5500 BSP.
17  */
18
19 #ifndef LIBBSP_POWERPC_MVME5500_BSP_H
20 #define LIBBSP_POWERPC_MVME5500_BSP_H
21
32 #ifndef ASM
33
34 #include <bspopts.h>
36
37 #include <rtems.h>
38 #include <libcpu/io.h>
39 #include <bsp/vectors.h>
40
41 /* Board type */
42 typedef enum {
43  undefined = 0,
44  MVME5500,
45  MVME6100
46 } BSP_BoardTypes;
47
48 BSP_BoardTypes BSP_getBoardType(void);
49
50 /* Board type */
51 typedef enum {
52  Undefined,
53  UNIVERSE2,
54  TSI148,
55 } BSP_VMEchipTypes;
56
57 BSP_VMEchipTypes BSP_getVMEchipType(void);
58
59 /* The version of Discovery system controller */
60
61 typedef enum {
62  notdefined,
63  GT64260A,
64  GT64260B,
65  MV64360,
66 } DiscoveryChipVersion;
67
68 DiscoveryChipVersion BSP_getDiscoveryChipVersion(void);
69
70 #define _256M 0x10000000
71 #define _512M 0x20000000
72
73 #define GT64x60_REG_BASE 0xf1000000 /* Base of GT64260 Reg Space */
74 #define GT64x60_REG_SPACE_SIZE 0x10000 /* 64Kb Internal Reg Space */
75
76 #define GT64x60_DEV1_BASE 0xf1100000 /* Device bank1(chip select 1) base
77  */
78 #define GT64260_DEV1_SIZE 0x00100000 /* Device bank size */
79
80 /* fundamental addresses for this BSP (PREPxxx are from libcpu/io.h) */
81 #define _IO_BASE GT64x60_REG_BASE
82
83 #define BSP_NVRAM_BASE_ADDR 0xf1110000
84
85 #define BSP_RTC_INTA_REG 0x7ff0
86 #define BSP_RTC_SECOND 0x7ff2
87 #define BSP_RTC_MINUTE 0x7ff3
88 #define BSP_RTC_HOUR 0x7ff4
89 #define BSP_RTC_DATE 0x7ff5
90 #define BSP_RTC_INTERRUPTS 0x7ff6
91 #define BSP_RTC_WATCHDOG 0x7ff7
92
93 /* PCI0 Domain I/O space */
94 #define PCI0_IO_BASE 0xf0000000
95 #define PCI1_IO_BASE 0xf0800000
96
97 /* PCI 0 memory space as seen from the CPU */
98 #define PCI0_MEM_BASE 0x80000000
99 #define PCI_MEM_BASE 0 /* glue for vmeUniverse */
100 #define PCI_MEM_BASE_ADJUSTMENT 0
101
102 /* address of our ram on the PCI bus */
103 #define PCI_DRAM_OFFSET 0
104
105 /* PCI 1 memory space as seen from the CPU */
106 #define PCI1_MEM_BASE 0xe0000000
107 #define PCI1_MEM_SIZE 0x10000000
108
109 /* Needed for hot adding via PMCspan on the PCI0 local bus.
110  * This is board dependent, only because mvme5500
111  * supports hot adding and has more than one local PCI
112  * bus.
113  */
114 #define BSP_MAX_PCI_BUS_ON_PCI0 8
115 #define BSP_MAX_PCI_BUS_ON_PCI1 2
116 #define BSP_MAX_PCI_BUS (BSP_MAX_PCI_BUS_ON_PCI0+BSP_MAX_PCI_BUS_ON_PCI1)
117
118
119 /* The glues to Till's vmeUniverse, although the name does not
120  * actually reflect the relevant architect of the MVME5500.
121  */
122 #define BSP_PCI_IRQ0 BSP_GPP_IRQ_LOWEST_OFFSET
123
124 /*
125  * confdefs.h overrides for this BSP:
126  * - Interrupt stack space is not minimum if defined.
127  */
128 #define BSP_INTERRUPT_STACK_SIZE (16 * 1024) /* <skf> 2/09 wants it to be adjustable by BSP */
129
130 /* uart.c uses out_8 instead of outb */
131 #define BSP_UART_IOBASE_COM1 GT64x60_DEV1_BASE + 0x20000
132 #define BSP_UART_IOBASE_COM2 GT64x60_DEV1_BASE + 0x21000
133
134 #define BSP_CONSOLE_PORT BSP_UART_COM1 /* console */
135 #define BSP_UART_BAUD_BASE 115200
136
137 /*
138  * Total memory using RESIDUAL DATA
139  */
140 extern unsigned int BSP_mem_size;
141 /*
142  * PCI Bus Frequency
143  */
144 extern unsigned int BSP_bus_frequency;
145 /*
146  * processor clock frequency
147  */
148 extern unsigned int BSP_processor_frequency;
149 /*
150  * Time base divisior (how many tick for 1 second).
151  */
152 extern unsigned int BSP_time_base_divisor;
153
154 #define BSP_Convert_decrementer( _value ) \
155  ((unsigned long long) ((((unsigned long long)BSP_time_base_divisor) * 1000000ULL) /((unsigned long long) BSP_bus_frequency)) * ((unsigned long long) (_value)))
156
157 extern void bsp_reset(void);
158 /* extern int printk(const char *, ...) __attribute__((format(printf, 1, 2))); */
159 extern int BSP_disconnect_clock_handler(void);
160 extern int BSP_connect_clock_handler(void);
161
162 unsigned long _BSP_clear_hostbridge_errors(int enableMCP, int quiet);
163
164 /*
165  * Prototypes for methods called only from .S for dependency tracking
166  */
167 char *save_boot_params(
168  void *r3,
169  void *r4,
170  void *r5,
171  char *cmdline_start,
172  char *cmdline_end
173 );
174 void zero_bss(void);
175
176 /*
177  * Prototypes for methods in the BSP that cross file boundaries
178  */
179 uint32_t probeMemoryEnd(void);
180 void pci_interface(void);
181 void BSP_printPicIsrTbl(void);
182 int I2Cread_eeprom(
183  unsigned char I2cBusAddr,
184  uint32_t devA2A1A0,
185  uint32_t AddrBytes,
186  unsigned char *pBuff,
187  uint32_t numBytes
188 );
189
190 #if 0
191 #define RTEMS_BSP_NETWORK_DRIVER_NAME "gt1"
192 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_GT64260eth_driver_attach
193 #else
194 #define RTEMS_BSP_NETWORK_DRIVER_NAME "wmG1"
195 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_i82544EI_driver_attach
196 #endif
197
198 struct rtems_bsdnet_ifconfig;
199
200 extern int RTEMS_BSP_NETWORK_DRIVER_ATTACH(struct rtems_bsdnet_ifconfig *, int);
201
202 #define gccMemBar() RTEMS_COMPILER_MEMORY_BARRIER()
203
204 static inline void lwmemBar(void)
205 {
206  __asm__ volatile("lwsync":::"memory");
207 }
208
209 static inline void io_flush(void)
210 {
211  __asm__ volatile("isync":::"memory");
212 }
213
214 static inline void memBar(void)
215 {
216  __asm__ volatile("sync":::"memory");
217 }
218
219 static inline void ioBar(void)
220 {
221  __asm__ volatile("eieio":::"memory");
222 }
223
224 #endif
225
228 #endif /* !ASM */
DEFAULT_INITIAL_EXTENSION Support.
PowerPC Exceptions API.
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
Standard network driver attach and detach function.
Definition: bsp.h:77
Clock Tick Device Driver.
Definition: p_clock.c:37
