RTEMS
5.1
Global BSP definitions. More...
#include <bspopts.h>
#include <libcpu/powerpc-utility.h>
#include <bsp/hwreg_vals.h>
#include <bsp/vectors.h>
#include <bsp/irq.h>
#include <bsp/default-initial-extension.h>
#define | BSP_FEATURE_IRQ_EXTENSION |
#define | BSP_ARRAY_CNT(arr) (sizeof(arr)/sizeof(arr[0])) |
#define | BSP_IDLE_TASK_BODY bsp_idle_thread |
#define | RTEMS_BSP_NETWORK_DRIVER_ATTACH BSP_tsec_attach |
#define | RTEMS_BSP_NETWORK_DRIVER_NAME "tsec1" |
#define | RTEMS_BSP_NETWORK_DRIVER_NAME2 "tsec2" |
#define | BSP_Convert_decrementer(_value) ((int) (((_value) * 10) / bsp_clicks_per_usec)) |
LINKER_SYMBOL (bsp_ram_start) | |
LINKER_SYMBOL (bsp_ram_end) | |
LINKER_SYMBOL (bsp_ram_size) | |
LINKER_SYMBOL (bsp_rom_start) | |
LINKER_SYMBOL (bsp_rom_end) | |
LINKER_SYMBOL (bsp_rom_size) | |
LINKER_SYMBOL (bsp_section_text_start) | |
LINKER_SYMBOL (bsp_section_text_end) | |
LINKER_SYMBOL (bsp_section_text_size) | |
LINKER_SYMBOL (bsp_section_data_start) | |
LINKER_SYMBOL (bsp_section_data_end) | |
LINKER_SYMBOL (bsp_section_data_size) | |
LINKER_SYMBOL (bsp_section_bss_start) | |
LINKER_SYMBOL (bsp_section_bss_end) | |
LINKER_SYMBOL (bsp_section_bss_size) | |
LINKER_SYMBOL (bsp_work_area_start) | |
LINKER_SYMBOL (IMMRBAR) | |
void * | bsp_idle_thread (uintptr_t ignored) |
Optimized idle task. More... | |
rtems_status_code | bsp_register_i2c (void) |
rtems_status_code | bsp_register_spi (void) |
int | BSP_tsec_attach (struct rtems_bsdnet_ifconfig *config, int attaching) |
void | mpc83xx_zero_4 (void *dest, size_t n) |
void | cpu_init (void) |
void | bsp_restart (void *addr) |
unsigned int | BSP_bus_frequency |
uint32_t | bsp_clicks_per_usec |
