RTEMS
5.1
NXP MPC83XX Board Support Package. More...
Files | |
file | bsp.h |
Global BSP definitions. | |
#define | BSP_FEATURE_IRQ_EXTENSION |
#define | BSP_ARRAY_CNT(arr) (sizeof(arr)/sizeof(arr[0])) |
#define | BSP_IDLE_TASK_BODY bsp_idle_thread |
#define | RTEMS_BSP_NETWORK_DRIVER_ATTACH BSP_tsec_attach |
#define | RTEMS_BSP_NETWORK_DRIVER_NAME "tsec1" |
#define | RTEMS_BSP_NETWORK_DRIVER_NAME2 "tsec2" |
#define | BSP_Convert_decrementer(_value) ((int) (((_value) * 10) / bsp_clicks_per_usec)) |
LINKER_SYMBOL (bsp_ram_start) | |
LINKER_SYMBOL (bsp_ram_end) | |
LINKER_SYMBOL (bsp_ram_size) | |
LINKER_SYMBOL (bsp_rom_start) | |
LINKER_SYMBOL (bsp_rom_end) | |
LINKER_SYMBOL (bsp_rom_size) | |
LINKER_SYMBOL (bsp_section_text_start) | |
LINKER_SYMBOL (bsp_section_text_end) | |
LINKER_SYMBOL (bsp_section_text_size) | |
LINKER_SYMBOL (bsp_section_data_start) | |
LINKER_SYMBOL (bsp_section_data_end) | |
LINKER_SYMBOL (bsp_section_data_size) | |
LINKER_SYMBOL (bsp_section_bss_start) | |
LINKER_SYMBOL (bsp_section_bss_end) | |
LINKER_SYMBOL (bsp_section_bss_size) | |
LINKER_SYMBOL (bsp_work_area_start) | |
LINKER_SYMBOL (IMMRBAR) | |
void * | bsp_idle_thread (uintptr_t ignored) |
Optimized idle task. More... | |
rtems_status_code | bsp_register_i2c (void) |
rtems_status_code | bsp_register_spi (void) |
int | BSP_tsec_attach (struct rtems_bsdnet_ifconfig *config, int attaching) |
void | mpc83xx_zero_4 (void *dest, size_t n) |
void | cpu_init (void) |
void | bsp_restart (void *addr) |
unsigned int | BSP_bus_frequency |
uint32_t | bsp_clicks_per_usec |
void* bsp_idle_thread | ( | uintptr_t | ignored | ) |
This BSP provides its own IDLE thread to override the RTEMS one.
This idle task sets the power mode to idle. This causes the processor clock to be stopped, while on-chip peripherals remain active. Any enabled interrupt from a peripheral or an external interrupt source will cause the processor to resume execution.
To enable the idle task use the following in the system configuration:
The MSR[POW] bit is set to put the CPU into the low power mode defined in HID0. HID0 is set during starup in start.S.
