RTEMS  5.1
bsp.h
1
9 /*===============================================================*\
10 | Project: RTEMS generic MPC83xx BSP |
11 +-----------------------------------------------------------------+
12 | Copyright (c) 2007 |
13 | Embedded Brains GmbH |
14 | Obere Lagerstr. 30 |
15 | D-82178 Puchheim |
16 | Germany |
17 | rtems@embedded-brains.de |
18 +-----------------------------------------------------------------+
19 | The license and distribution terms for this file may be |
20 | found in the file LICENSE in this distribution or at |
21 | |
22 | http://www.rtems.org/license/LICENSE. |
23 | |
24 +-----------------------------------------------------------------+
25 | this file contains board specific definitions |
26 \*===============================================================*/
27
28
29 #ifndef LIBBSP_POWERPC_GEN83XX_BSP_H
30 #define LIBBSP_POWERPC_GEN83XX_BSP_H
31
42 #define BSP_FEATURE_IRQ_EXTENSION
43
44 #include <bspopts.h>
45
46 #include <libcpu/powerpc-utility.h>
47
48 #include <bsp/hwreg_vals.h>
49
50 /*
51  * Some symbols defined in the linker command file.
52  */
53
54 LINKER_SYMBOL(bsp_ram_start);
55 LINKER_SYMBOL(bsp_ram_end);
56 LINKER_SYMBOL(bsp_ram_size);
57
58 LINKER_SYMBOL(bsp_rom_start);
59 LINKER_SYMBOL(bsp_rom_end);
60 LINKER_SYMBOL(bsp_rom_size);
61
62 LINKER_SYMBOL(bsp_section_text_start);
63 LINKER_SYMBOL(bsp_section_text_end);
64 LINKER_SYMBOL(bsp_section_text_size);
65
66 LINKER_SYMBOL(bsp_section_data_start);
67 LINKER_SYMBOL(bsp_section_data_end);
68 LINKER_SYMBOL(bsp_section_data_size);
69
70 LINKER_SYMBOL(bsp_section_bss_start);
71 LINKER_SYMBOL(bsp_section_bss_end);
72 LINKER_SYMBOL(bsp_section_bss_size);
73
74 LINKER_SYMBOL(bsp_work_area_start);
75
76 LINKER_SYMBOL(IMMRBAR);
77
78 #ifndef ASM
79
80 #include <rtems.h>
81 #include <bsp/vectors.h>
82 #include <bsp/irq.h>
84
85 #ifdef __cplusplus
86 extern "C" {
87 #endif
88
89 /*
90  * indicate, that BSP has no IDE driver
91  */
92 #undef RTEMS_BSP_HAS_IDE_DRIVER
93
94 /* misc macros */
95 #define BSP_ARRAY_CNT(arr) (sizeof(arr)/sizeof(arr[0]))
96
97 void *bsp_idle_thread( uintptr_t ignored );
98 #define BSP_IDLE_TASK_BODY bsp_idle_thread
99
100 /* functions */
101 rtems_status_code bsp_register_i2c(void);
102 rtems_status_code bsp_register_spi(void);
103
104 /*
105  * Network driver configuration
106  */
107 struct rtems_bsdnet_ifconfig;
108 extern int BSP_tsec_attach(struct rtems_bsdnet_ifconfig *config,int attaching);
109 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH BSP_tsec_attach
110
111 #ifdef MPC83XX_BOARD_MPC8313ERDB
112  #define RTEMS_BSP_NETWORK_DRIVER_NAME "tsec2"
113  #define RTEMS_BSP_NETWORK_DRIVER_NAME2 "tsec1"
114 #else
115  #define RTEMS_BSP_NETWORK_DRIVER_NAME "tsec1"
116  #define RTEMS_BSP_NETWORK_DRIVER_NAME2 "tsec2"
117 #endif
118
119 #if defined(MPC83XX_BOARD_MPC8349EAMDS)
120 /*
121  * i2c EEPROM device name
122  */
123 #define RTEMS_BSP_I2C_EEPROM_DEVICE_NAME "eeprom"
124 #define RTEMS_BSP_I2C_EEPROM_DEVICE_PATH "/dev/i2c1.eeprom"
125
126 /*
127  * SPI Flash device name
128  */
129 #define RTEMS_BSP_SPI_FLASH_DEVICE_NAME "flash"
130 #define RTEMS_BSP_SPI_FLASH_DEVICE_PATH "/dev/spi.flash"
131 #endif /* defined(MPC83XX_BOARD_MPC8349EAMDS) */
132
133 #if defined(MPC83XX_BOARD_HSC_CM01)
134 /*
135  * i2c EEPROM device name
136  */
137 #define RTEMS_BSP_I2C_EEPROM_DEVICE_NAME "eeprom"
138 #define RTEMS_BSP_I2C_EEPROM_DEVICE_PATH "/dev/i2c1.eeprom"
139
140 /*
141  * SPI FRAM device name
142  */
143 #define RTEMS_BSP_SPI_FRAM_DEVICE_NAME "fram"
144 #define RTEMS_BSP_SPI_FRAM_DEVICE_PATH "/dev/spi.fram"
145 #endif /* defined(MPC83XX_BOARD_HSC_CM01) */
146
147 extern unsigned int BSP_bus_frequency;
148
149 extern uint32_t bsp_clicks_per_usec;
150
151 /*
152  * Convert decrementer value to tenths of microseconds (used by shared timer
153  * driver).
154  */
155 #define BSP_Convert_decrementer( _value ) \
156  ((int) (((_value) * 10) / bsp_clicks_per_usec))
157
158 void mpc83xx_zero_4( void *dest, size_t n);
159
160 void cpu_init( void);
161
162 void bsp_restart(void *addr);
163
164 #if defined(HAS_UBOOT)
165  /* Routine to obtain U-Boot environment variables */
166  const char *bsp_uboot_getenv(
167  const char *name
168  );
169 #endif
170
171 #ifdef __cplusplus
172 }
173 #endif
174
175 #endif /* ASM */
176
179 #endif /* GEN83xx */
Definition: deflate.c:115
Time base clicks per micro second.
Definition: bspstart.c:99
DEFAULT_INITIAL_EXTENSION Support.
PowerPC Exceptions API.
General purpose assembler macros, linker command file support and some inline functions for direct re...
rtems_status_code
Classic API Status.
Definition: status.h:43
void * bsp_idle_thread(uintptr_t ignored)
Optimized idle task.
Definition: bspidle.c:26
void bsp_restart(const void *addr)
Restarts the bsp with "addr" address.
Definition: restart.c:25
