RTEMS  5.1
alt_dma_program.h
1
7 /******************************************************************************
8  *
9  * Copyright 2013 Altera Corporation. All Rights Reserved.
10  *
11  * Redistribution and use in source and binary forms, with or without
12  * modification, are permitted provided that the following conditions are met:
13  *
14  * 1. Redistributions of source code must retain the above copyright notice,
15  * this list of conditions and the following disclaimer.
16  *
17  * 2. Redistributions in binary form must reproduce the above copyright notice,
18  * this list of conditions and the following disclaimer in the documentation
19  * and/or other materials provided with the distribution.
20  *
21  * 3. The name of the author may not be used to endorse or promote products
22  * derived from this software without specific prior written permission.
23  *
24  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER "AS IS" AND ANY EXPRESS OR
25  * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
26  * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ARE DISCLAIMED. IN NO
27  * EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
28  * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
29  * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
32  * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
33  * OF SUCH DAMAGE.
34  *
35  ******************************************************************************/
36
37 #ifndef __ALT_DMA_PROGRAM_H__
38 #define __ALT_DMA_PROGRAM_H__
39
40 #include "hwlib.h"
41 #include "alt_dma_common.h"
42
43 #ifdef __cplusplus
44 extern "C"
45 {
46 #endif /* __cplusplus */
47
78 #define ALT_DMA_PROGRAM_CACHE_LINE_SIZE (32)
79
86 #define ALT_DMA_PROGRAM_CACHE_LINE_COUNT (16)
87
101 #ifndef ALT_DMA_PROGRAM_PROVISION_BUFFER_SIZE
102 #define ALT_DMA_PROGRAM_PROVISION_BUFFER_SIZE (ALT_DMA_PROGRAM_CACHE_LINE_SIZE * ALT_DMA_PROGRAM_CACHE_LINE_COUNT)
103 #endif
104
110 typedef struct ALT_DMA_PROGRAM_s
111 {
112  uint32_t flag;
113
114  uint16_t buffer_start;
115  uint16_t code_size;
116
117  uint16_t loop0;
118  uint16_t loop1;
119
120  uint16_t sar;
121  uint16_t dar;
122
123  /*
124  * Add a little extra space so that regardless of where this structure
125  * sits in memory, a suitable start address can be aligned to the cache
126  * line stride while providing the requested buffer space.
127  */
128  uint8_t program[ALT_DMA_PROGRAM_PROVISION_BUFFER_SIZE +
130 }
132
138 {
141
144
147 }
149
171 {
177
184
191
197 }
199
212
224
236
250
286  uint32_t current, uint32_t * progress);
287
310  ALT_DMA_PROGRAM_REG_t reg, uint32_t val);
311
334 // Assembler Syntax: DMAADDH <address_register>, <16-bit immediate>
336  ALT_DMA_PROGRAM_REG_t addr_reg, uint16_t val);
337
357 // Assembler Syntax: DMAADNH <address_register>, <16-bit immediate>
359  ALT_DMA_PROGRAM_REG_t addr_reg, uint16_t val);
360
371 // Assembler Syntax: DMAEND
373
388 // Assembler Syntax: DMAFLUSHP <peripheral>
390  ALT_DMA_PERIPH_t periph);
391
412 // Assembler Syntax: DMAGO <channel_number>, <32-bit_immediate> [, ns]
414  ALT_DMA_CHANNEL_t channel, uint32_t val,
415  ALT_DMA_SECURITY_t sec);
416
427 // Assembler Syntax: DMAKILL
429
446 // Assembler Syntax: DMALD[S|B]
449
470 // Assembler Syntax: DMALDP<S|B> <peripheral>
473
489 // Assembler Syntax: DMALP [<LC0>|<LC1>] <loop_iterations>
491  uint32_t iterations);
492
513 // Assembler Syntax: DMALPEND[S|B]
516
528 // Assembler Syntax: DMALPFE
530
550 // Assembler Syntax: DMAMOV <destination_register>, <32-bit_immediate>
552  ALT_DMA_PROGRAM_REG_t chan_reg, uint32_t val);
553
564 // Assembler Syntax: DMANOP
566
577 // Assembler Syntax: DMARMB
579
594 // Assembler Syntax: DMASEV <event_num>
596  ALT_DMA_EVENT_t evt);
597
613 // Assembler Syntax: DMAST[S|B]
616
637 // Assembler Syntax: DMASTP<S|B> <peripheral>
640
651 // Assembler Syntax: DMASTZ
653
673 // Assembler Syntax: DMAWFE <event_num>[, invalid]
675  ALT_DMA_EVENT_t evt, bool invalid);
676
698 // Assembler Syntax: DMAWFP <peripheral>, <single|burst|periph>
701
712 // Assembler Syntax: DMAWMB
714
761 /*
762  * Source Address {Fixed,Incrementing}
763  */
765 #define ALT_DMA_CCR_OPT_SAF (0 << 0)
766
767 #define ALT_DMA_CCR_OPT_SAI (1 << 0)
768
769 #define ALT_DMA_CCR_OPT_SA_DEFAULT ALT_DMA_CCR_OPT_SAI
770
771 /*
772  * Source burst Size (in bits)
773  */
775 #define ALT_DMA_CCR_OPT_SS8 (0 << 1)
776
777 #define ALT_DMA_CCR_OPT_SS16 (1 << 1)
778
779 #define ALT_DMA_CCR_OPT_SS32 (2 << 1)
780
781 #define ALT_DMA_CCR_OPT_SS64 (3 << 1)
782
783 #define ALT_DMA_CCR_OPT_SS128 (4 << 1)
784
785 #define ALT_DMA_CCR_OPT_SS_DEFAULT ALT_DMA_CCR_OPT_SS8
786
787 /*
788  * Source burst Length (in transfer(s))
789  */
791 #define ALT_DMA_CCR_OPT_SB1 (0x0 << 4)
792
793 #define ALT_DMA_CCR_OPT_SB2 (0x1 << 4)
794
795 #define ALT_DMA_CCR_OPT_SB3 (0x2 << 4)
796
797 #define ALT_DMA_CCR_OPT_SB4 (0x3 << 4)
798
799 #define ALT_DMA_CCR_OPT_SB5 (0x4 << 4)
800
801 #define ALT_DMA_CCR_OPT_SB6 (0x5 << 4)
802
803 #define ALT_DMA_CCR_OPT_SB7 (0x6 << 4)
804
805 #define ALT_DMA_CCR_OPT_SB8 (0x7 << 4)
806
807 #define ALT_DMA_CCR_OPT_SB9 (0x8 << 4)
808
809 #define ALT_DMA_CCR_OPT_SB10 (0x9 << 4)
810
811 #define ALT_DMA_CCR_OPT_SB11 (0xa << 4)
812
813 #define ALT_DMA_CCR_OPT_SB12 (0xb << 4)
814
815 #define ALT_DMA_CCR_OPT_SB13 (0xc << 4)
816
817 #define ALT_DMA_CCR_OPT_SB14 (0xd << 4)
818
819 #define ALT_DMA_CCR_OPT_SB15 (0xe << 4)
820
821 #define ALT_DMA_CCR_OPT_SB16 (0xf << 4)
822
823 #define ALT_DMA_CCR_OPT_SB_DEFAULT ALT_DMA_CCR_OPT_SB1
824
825 /*
826  * Source Protection
827  */
829 #define ALT_DMA_CCR_OPT_SP(imm3) ((imm3) << 8)
830
831 #define ALT_DMA_CCR_OPT_SP_DEFAULT ALT_DMA_CCR_OPT_SP(0)
832
833 /*
834  * Source cache
835  */
837 #define ALT_DMA_CCR_OPT_SC(imm4) ((imm4) << 11)
838
839 #define ALT_DMA_CCR_OPT_SC_DEFAULT ALT_DMA_CCR_OPT_SC(0)
840
841 /*
842  * Destination Address {Fixed,Incrementing}
843  */
845 #define ALT_DMA_CCR_OPT_DAF (0 << 14)
846
847 #define ALT_DMA_CCR_OPT_DAI (1 << 14)
848
849 #define ALT_DMA_CCR_OPT_DA_DEFAULT ALT_DMA_CCR_OPT_DAI
850
851 /*
852  * Destination burst Size (in bits)
853  */
855 #define ALT_DMA_CCR_OPT_DS8 (0 << 15)
856
857 #define ALT_DMA_CCR_OPT_DS16 (1 << 15)
858
859 #define ALT_DMA_CCR_OPT_DS32 (2 << 15)
860
861 #define ALT_DMA_CCR_OPT_DS64 (3 << 15)
862
863 #define ALT_DMA_CCR_OPT_DS128 (4 << 15)
864
865 #define ALT_DMA_CCR_OPT_DS_DEFAULT ALT_DMA_CCR_OPT_DS8
866
867 /*
868  * Destination Burst length (in transfer(s))
869  */
871 #define ALT_DMA_CCR_OPT_DB1 (0x0 << 18)
872
873 #define ALT_DMA_CCR_OPT_DB2 (0x1 << 18)
874
875 #define ALT_DMA_CCR_OPT_DB3 (0x2 << 18)
876
877 #define ALT_DMA_CCR_OPT_DB4 (0x3 << 18)
878
879 #define ALT_DMA_CCR_OPT_DB5 (0x4 << 18)
880
881 #define ALT_DMA_CCR_OPT_DB6 (0x5 << 18)
882
883 #define ALT_DMA_CCR_OPT_DB7 (0x6 << 18)
884
885 #define ALT_DMA_CCR_OPT_DB8 (0x7 << 18)
886
887 #define ALT_DMA_CCR_OPT_DB9 (0x8 << 18)
888
889 #define ALT_DMA_CCR_OPT_DB10 (0x9 << 18)
890
891 #define ALT_DMA_CCR_OPT_DB11 (0xa << 18)
892
893 #define ALT_DMA_CCR_OPT_DB12 (0xb << 18)
894
895 #define ALT_DMA_CCR_OPT_DB13 (0xc << 18)
896
897 #define ALT_DMA_CCR_OPT_DB14 (0xd << 18)
898
899 #define ALT_DMA_CCR_OPT_DB15 (0xe << 18)
900
901 #define ALT_DMA_CCR_OPT_DB16 (0xf << 18)
902
903 #define ALT_DMA_CCR_OPT_DB_DEFAULT ALT_DMA_CCR_OPT_DB1
904
905 /*
906  * Destination Protection
907  */
909 #define ALT_DMA_CCR_OPT_DP(imm3) ((imm3) << 22)
910
911 #define ALT_DMA_CCR_OPT_DP_DEFAULT ALT_DMA_CCR_OPT_DP(0)
912
913 /*
914  * Destination Cache
915  */
917 #define ALT_DMA_CCR_OPT_DC(imm4) ((imm4) << 25)
918
919 #define ALT_DMA_CCR_OPT_DC_DEFAULT ALT_DMA_CCR_OPT_DC(0)
920
921 /*
922  * Endian Swap size (in bits)
923  */
925 #define ALT_DMA_CCR_OPT_ES8 (0 << 28)
926
927 #define ALT_DMA_CCR_OPT_ES16 (1 << 28)
928
929 #define ALT_DMA_CCR_OPT_ES32 (2 << 28)
930
931 #define ALT_DMA_CCR_OPT_ES64 (3 << 28)
932
933 #define ALT_DMA_CCR_OPT_ES128 (4 << 28)
934
935 #define ALT_DMA_CCR_OPT_ES_DEFAULT ALT_DMA_CCR_OPT_ES8
936
938 #define ALT_DMA_CCR_OPT_DEFAULT \
939  (ALT_DMA_CCR_OPT_SB1 | ALT_DMA_CCR_OPT_SS8 | ALT_DMA_CCR_OPT_SAI | \
940  ALT_DMA_CCR_OPT_SP(0) | ALT_DMA_CCR_OPT_SC(0) | \
941  ALT_DMA_CCR_OPT_DB1 | ALT_DMA_CCR_OPT_DS8 | ALT_DMA_CCR_OPT_DAI | \
942  ALT_DMA_CCR_OPT_DP(0) | ALT_DMA_CCR_OPT_DC(0) | \
943  ALT_DMA_CCR_OPT_ES8)
944
953 #ifdef __cplusplus
954 }
955 #endif /* __cplusplus */
956
957 #endif /* __ALT_DMA_PROGRAM_H__ */
ALT_STATUS_CODE alt_dma_program_DMAWFP(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PERIPH_t periph, ALT_DMA_PROGRAM_INST_MOD_t mod)
Definition: alt_dma_program.c:1003
ALT_STATUS_CODE alt_dma_program_update_reg(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_REG_t reg, uint32_t val)
Definition: alt_dma_program.c:187
ALT_STATUS_CODE alt_dma_program_DMAST(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_INST_MOD_t mod)
Definition: alt_dma_program.c:849
ALT_STATUS_CODE alt_dma_program_DMANOP(ALT_DMA_PROGRAM_t *pgm)
Definition: alt_dma_program.c:764
enum ALT_DMA_EVENT_e ALT_DMA_EVENT_t
ALT_STATUS_CODE alt_dma_program_DMAGO(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_CHANNEL_t channel, uint32_t val, ALT_DMA_SECURITY_t sec)
Definition: alt_dma_program.c:355
ALT_STATUS_CODE alt_dma_program_progress_reg(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_REG_t reg, uint32_t current, uint32_t *progress)
Definition: alt_dma_program.c:147
ALT_STATUS_CODE alt_dma_program_uninit(ALT_DMA_PROGRAM_t *pgm)
Definition: alt_dma_program.c:98
Definition: alt_dma_program.h:176
ALT_STATUS_CODE alt_dma_program_DMARMB(ALT_DMA_PROGRAM_t *pgm)
Definition: alt_dma_program.c:786
ALT_STATUS_CODE alt_dma_program_DMAWFE(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_EVENT_t evt, bool invalid)
Definition: alt_dma_program.c:955
enum ALT_DMA_PROGRAM_INST_MOD_e ALT_DMA_PROGRAM_INST_MOD_t
ALT_STATUS_CODE alt_dma_program_DMASTZ(ALT_DMA_PROGRAM_t *pgm)
Definition: alt_dma_program.c:933
Definition: alt_dma_program.h:78
enum ALT_DMA_PERIPH_e ALT_DMA_PERIPH_t
Definition: alt_dma_program.h:196
ALT_STATUS_CODE alt_dma_program_DMAWMB(ALT_DMA_PROGRAM_t *pgm)
Definition: alt_dma_program.c:1050
Definition: alt_dma_program.h:170
ALT_STATUS_CODE alt_dma_program_DMAADDH(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_REG_t addr_reg, uint16_t val)
Definition: alt_dma_program.c:222
ALT_STATUS_CODE alt_dma_program_DMAADNH(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_REG_t addr_reg, uint16_t val)
Definition: alt_dma_program.c:261
Definition: alt_dma_program.h:190
ALT_STATUS_CODE alt_dma_program_DMALP(ALT_DMA_PROGRAM_t *pgm, uint32_t iterations)
Definition: alt_dma_program.c:521
enum ALT_DMA_CHANNEL_e ALT_DMA_CHANNEL_t
ALT_DMA_PROGRAM_REG_e
Definition: alt_dma_program.h:137
enum ALT_DMA_SECURITY_e ALT_DMA_SECURITY_t
ALT_STATUS_CODE alt_dma_program_DMAKILL(ALT_DMA_PROGRAM_t *pgm)
Definition: alt_dma_program.c:415
ALT_STATUS_CODE alt_dma_program_DMALD(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_INST_MOD_t mod)
Definition: alt_dma_program.c:437
Definition: alt_dma_program.h:183
ALT_STATUS_CODE alt_dma_program_DMASEV(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_EVENT_t evt)
Definition: alt_dma_program.c:808
ALT_STATUS_CODE alt_dma_program_DMAFLUSHP(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PERIPH_t periph)
Definition: alt_dma_program.c:325
ALT_STATUS_CODE alt_dma_program_DMAMOV(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_REG_t chan_reg, uint32_t val)
Definition: alt_dma_program.c:703
ALT_STATUS_CODE alt_dma_program_init(ALT_DMA_PROGRAM_t *pgm)
Definition: alt_dma_program.h:146
ALT_STATUS_CODE alt_dma_program_DMASTP(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_INST_MOD_t mod, ALT_DMA_PERIPH_t periph)
Definition: alt_dma_program.c:889
Definition: alt_dma_program.h:102
ALT_STATUS_CODE alt_dma_program_clear(ALT_DMA_PROGRAM_t *pgm)
Definition: alt_dma_program.c:103
ALT_STATUS_CODE alt_dma_program_DMALPEND(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_INST_MOD_t mod)
Definition: alt_dma_program.c:574
struct ALT_DMA_PROGRAM_s ALT_DMA_PROGRAM_t
int32_t ALT_STATUS_CODE
Definition: hwlib.h:60
Definition: alt_dma_program.h:110
enum ALT_DMA_PROGRAM_REG_e ALT_DMA_PROGRAM_REG_t
Definition: alt_dma_program.h:143
ALT_STATUS_CODE alt_dma_program_validate(const ALT_DMA_PROGRAM_t *pgm)
Definition: alt_dma_program.c:117
ALT_STATUS_CODE alt_dma_program_DMAEND(ALT_DMA_PROGRAM_t *pgm)
Definition: alt_dma_program.c:300
ALT_STATUS_CODE alt_dma_program_DMALPFE(ALT_DMA_PROGRAM_t *pgm)
Definition: alt_dma_program.c:672
Definition: alt_dma_program.h:140
ALT_STATUS_CODE alt_dma_program_DMALDP(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_INST_MOD_t mod, ALT_DMA_PERIPH_t periph)
Definition: alt_dma_program.c:477
