RTEMS  5.1
Typedefs | Enumerations
DMA Controller Common API Definitions
typedef enum ALT_DMA_CHANNEL_e ALT_DMA_CHANNEL_t
typedef enum ALT_DMA_PERIPH_e ALT_DMA_PERIPH_t
typedef enum ALT_DMA_SECURITY_e ALT_DMA_SECURITY_t
typedef enum ALT_DMA_EVENT_e ALT_DMA_EVENT_t
enum  ALT_DMA_CHANNEL_e {
  ALT_DMA_CHANNEL_0 = 0, ALT_DMA_CHANNEL_1 = 1, ALT_DMA_CHANNEL_2 = 2, ALT_DMA_CHANNEL_3 = 3,
  ALT_DMA_CHANNEL_4 = 4, ALT_DMA_CHANNEL_5 = 5, ALT_DMA_CHANNEL_6 = 6, ALT_DMA_CHANNEL_7 = 7
enum  ALT_DMA_PERIPH_e {
  ALT_DMA_PERIPH_FPGA_0 = 0, ALT_DMA_PERIPH_FPGA_1 = 1, ALT_DMA_PERIPH_FPGA_2 = 2, ALT_DMA_PERIPH_FPGA_3 = 3,
  ALT_DMA_PERIPH_FPGA_4_OR_CAN0_IF1 = 4, ALT_DMA_PERIPH_FPGA_5_OR_CAN0_IF2 = 5, ALT_DMA_PERIPH_FPGA_6_OR_CAN1_IF1 = 6, ALT_DMA_PERIPH_FPGA_7_OR_CAN1_IF2 = 7,
  ALT_DMA_PERIPH_FPGA_4 = 4, ALT_DMA_PERIPH_FPGA_5 = 5, ALT_DMA_PERIPH_FPGA_6 = 6, ALT_DMA_PERIPH_FPGA_7 = 7,
  ALT_DMA_PERIPH_CAN0_IF1 = 4, ALT_DMA_PERIPH_CAN0_IF2 = 5, ALT_DMA_PERIPH_CAN1_IF1 = 6, ALT_DMA_PERIPH_CAN1_IF2 = 7,
  ALT_DMA_PERIPH_I2C0_TX = 8, ALT_DMA_PERIPH_I2C0_RX = 9, ALT_DMA_PERIPH_I2C1_TX = 10, ALT_DMA_PERIPH_I2C1_RX = 11,
  ALT_DMA_PERIPH_I2C2_TX = 12, ALT_DMA_PERIPH_I2C2_RX = 13, ALT_DMA_PERIPH_I2C3_TX = 14, ALT_DMA_PERIPH_I2C3_RX = 15,
  ALT_DMA_PERIPH_SPI0_MASTER_TX = 16, ALT_DMA_PERIPH_SPI0_MASTER_RX = 17, ALT_DMA_PERIPH_SPI0_SLAVE_TX = 18, ALT_DMA_PERIPH_SPI0_SLAVE_RX = 19,
  ALT_DMA_PERIPH_SPI1_MASTER_TX = 20, ALT_DMA_PERIPH_SPI1_MASTER_RX = 21, ALT_DMA_PERIPH_SPI1_SLAVE_TX = 22, ALT_DMA_PERIPH_SPI1_SLAVE_RX = 23,
  ALT_DMA_PERIPH_QSPI_FLASH_TX = 24, ALT_DMA_PERIPH_QSPI_FLASH_RX = 25, ALT_DMA_PERIPH_STM = 26, ALT_DMA_PERIPH_RESERVED = 27,
  ALT_DMA_PERIPH_UART0_TX = 28, ALT_DMA_PERIPH_UART0_RX = 29, ALT_DMA_PERIPH_UART1_TX = 30, ALT_DMA_PERIPH_UART1_RX = 31
enum  ALT_DMA_SECURITY_e { ALT_DMA_SECURITY_DEFAULT = 0, ALT_DMA_SECURITY_SECURE = 1, ALT_DMA_SECURITY_NONSECURE = 2 }
enum  ALT_DMA_EVENT_e {
  ALT_DMA_EVENT_0 = 0, ALT_DMA_EVENT_1 = 1, ALT_DMA_EVENT_2 = 2, ALT_DMA_EVENT_3 = 3,
  ALT_DMA_EVENT_4 = 4, ALT_DMA_EVENT_5 = 5, ALT_DMA_EVENT_6 = 6, ALT_DMA_EVENT_7 = 7,
  ALT_DMA_EVENT_ABORT = 8
This module contains the common definitions for the DMA controller related APIs.
Typedef Documentation
◆ ALT_DMA_CHANNEL_t
This type definition enumerates the DMA controller channel threads.
◆ ALT_DMA_EVENT_t
This type definition enumerates the DMA event-interrupt resources.
◆ ALT_DMA_PERIPH_t
This type definition enumerates the SoC system peripherals implementing the required request interface that enables direct DMA transfers to/from the device.
FPGA soft IP interface to the DMA are required to comply with the Synopsys protocol.
Request interface numbers 4 through 7 are multiplexed between the CAN controllers and soft logic implemented in the FPGA fabric. The selection between the CAN controller and FPGA interfaces is determined at DMA initialization.
◆ ALT_DMA_SECURITY_t
This type enumerates the DMA security state options available.
◆ ALT_DMA_CHANNEL_e
ALT_DMA_CHANNEL_0
DMA Channel Thread 0
ALT_DMA_CHANNEL_1
DMA Channel Thread 1
ALT_DMA_CHANNEL_2
DMA Channel Thread 2
ALT_DMA_CHANNEL_3
DMA Channel Thread 3
ALT_DMA_CHANNEL_4
DMA Channel Thread 4
ALT_DMA_CHANNEL_5
DMA Channel Thread 5
ALT_DMA_CHANNEL_6
DMA Channel Thread 6
ALT_DMA_CHANNEL_7
DMA Channel Thread 7
◆ ALT_DMA_EVENT_e
ALT_DMA_EVENT_0
DMA Event 0
ALT_DMA_EVENT_1
DMA Event 1
ALT_DMA_EVENT_2
DMA Event 2
ALT_DMA_EVENT_3
DMA Event 3
ALT_DMA_EVENT_4
DMA Event 4
ALT_DMA_EVENT_5
DMA Event 5
ALT_DMA_EVENT_6
DMA Event 6
ALT_DMA_EVENT_7
DMA Event 7
ALT_DMA_EVENT_ABORT
DMA Abort Event
◆ ALT_DMA_PERIPH_e
FPGA soft IP interface 0
FPGA soft IP interface 1
FPGA soft IP interface 2
FPGA soft IP interface 3
Selectively MUXed FPGA 4 or CAN 0 interface 1
Selectively MUXed FPGA 5 or CAN 0 interface 2
Selectively MUXed FPGA 6 or CAN 1 interface 1
Selectively MUXed FPGA 7 or CAN 1 interface 2
Alias for ALT_DMA_PERIPH_FPGA_4_OR_CAN0_IF1
Alias for ALT_DMA_PERIPH_FPGA_5_OR_CAN0_IF2
Alias for ALT_DMA_PERIPH_FPGA_6_OR_CAN1_IF1
Alias for ALT_DMA_PERIPH_FPGA_7_OR_CAN1_IF2
I2C 0 TX
I2C 0 RX
I2C 1 TX
I2C 1 RX
I2C 2 TX
I2C 2 RX
I2C 3 TX
I2C 3 RX
SPI 0 Master TX
SPI 0 Master RX
SPI 0 Slave TX
SPI 0 Slave RX
SPI 1 Master TX
SPI 1 Master RX
SPI 1 Slave TX
SPI 1 Slave RX
QSPI Flash TX
QSPI Flash RX
ALT_DMA_PERIPH_STM
System Trace Macrocell
Reserved
UART 0 TX
UART 0 RX
UART 1 TX
UART 1 RX
◆ ALT_DMA_SECURITY_e
Use the default security value (e.g. reset default)
Secure
Non-secure
