13. Memory Management Manager¶
13.1. Introduction¶
The memory management manager is …
The directives provided by the memory management manager are:
- mlockall - Lock the Address Space of a Process
- munlockall - Unlock the Address Space of a Process
- mlock - Lock a Range of the Process Address Space
- munlock - Unlock a Range of the Process Address Space
- mmap - Map Process Addresses to a Memory Object
- munmap - Unmap Previously Mapped Addresses
- mprotect - Change Memory Protection
- msync - Memory Object Synchronization
- shm_open - Open a Shared Memory Object
- shm_unlink - Remove a Shared Memory Object
13.2. Background¶
There is currently no text in this section.
13.3. Operations¶
13.4. Directives¶
This section details the memory management manager’s directives. A subsection is dedicated to each of this manager’s directives and describes the calling sequence, related constants, usage, and status codes.
13.4.1. mlockall - Lock the Address Space of a Process¶
CALLING SEQUENCE:
#include <sys/mman.h>
int mlockall(
int flags
STATUS CODES:
E |
The |
DESCRIPTION:
NOTES:
13.4.2. munlockall - Unlock the Address Space of a Process¶
CALLING SEQUENCE:
int munlockall(
void
STATUS CODES:
E |
The |
DESCRIPTION:
NOTES:
13.4.3. mlock - Lock a Range of the Process Address Space¶
CALLING SEQUENCE:
int mlock(
const void *addr,
size_t len
STATUS CODES:
E |
The |
DESCRIPTION:
NOTES:
13.4.4. munlock - Unlock a Range of the Process Address Space¶
CALLING SEQUENCE:
int munlock(
const void *addr,
size_t len
STATUS CODES:
E |
The |
DESCRIPTION:
NOTES:
13.4.5. mmap - Map Process Addresses to a Memory Object¶
CALLING SEQUENCE:
void *mmap(
void *addr,
size_t len,
int prot,
int flags,
int fildes,
off_t off
STATUS CODES:
EBADF |
The fildes argument is not a valid open file descriptor. |
EINVAL |
The value of len is zero. |
EINVAL |
The value of flags is invalid (neither MAP_PRIVATE nor MAP_SHARED is set). |
EINVAL |
The addr argument (if MAP_FIXED was specified) or off is not a multiple of the page size as returned by sysconf(), or is considered invalid by the implementation. |
ENODEV |
The fildes argument refers to a file whose type is not supported by mmap. |
ENOMEM |
MAP_FIXED was specified, and the range [addr,addr+len) exceeds that allowed for the address space of a process; or, if MAP_FIXED was not specified and there is insufficient room in the address space to effect the mapping. |
ENOTSUP |
MAP_FIXED or MAP_PRIVATE was specified in the flags argument and the implementation does not support this functionality. |
ENOTSUP |
The implementation does not support the combination of accesses requested in the prot argument. |
ENXIO |
Addresses in the range [off,off+len) are invalid for the object specified by fildes. |
ENXIO |
MAP_FIXED was specified in flags and the combination of addr, len, and off is invalid for the object specified by fildes. |
EOVERFLOW |
The file is a regular file and the value of off plus len exceeds the offset maximum established in the open file description associated with fildes. |
DESCRIPTION:
mmap establishes a mapping between an address pa for len bytes to
the memory object represented by the file descriptor fildes at offset
off for len bytes. The value of pa is an implementation-defined
function of the parameter addr and the values of flags. A successful
mmap() call shall return pa as its result. An unsuccessful call returns
MAP_FAILED and sets errno accordingly.
NOTES:
RTEMS is a single address space operating system without privilege separation
between the kernel and user space. Therefore, the implementation of mmap
has a number of implementation-specific issues to be aware of:
- Read, write and execute permissions are allowed because the memory in RTEMS does not normally have protections but we cannot hide access to memory. Thus, the use of
PROT_NONEfor theprotargument is not supported. Similarly, there is no restriction of write access, soPROT_WRITEmust be in theprotargument.- Anonymous mappings must have
fildesset to -1 andoffset to 0. Shared mappings are not supported with Anonymous mappings.MAP_FIXEDis not supported for shared memory objects withMAP_SHARED.- Support for shared mappings is dependent on the underlying object’s filesystem implementation of an
mmap_hfile operation handler.
13.4.6. munmap - Unmap Previously Mapped Addresses¶
CALLING SEQUENCE:
int munmap(
void *addr,
size_t len
STATUS CODES:
EINVAL |
Addresses in the range [addr,addr+len) are outside the valid range for the address space. |
EINVAL |
The len argument is 0. |
DESCRIPTION:
The munmap() function shall remove any mappings for those entire pages
containing any part of the address space of the process starting at addr
and continuing for len bytes. If there are no mappings in the specified
address range, then munmap() has no effect.
Upon successful completion, munmap() shall return 0; otherwise, it shall
return -1 and set errno to indicate the error.
NOTES:
13.4.7. mprotect - Change Memory Protection¶
CALLING SEQUENCE:
int mprotect(
void *addr,
size_t len,
int prot
STATUS CODES:
E |
The |
DESCRIPTION:
NOTES:
13.4.8. msync - Memory Object Synchronization¶
CALLING SEQUENCE:
int msync(
void *addr,
size_t len,
int flags
STATUS CODES:
E |
The |
DESCRIPTION:
NOTES:
