12. Condition Variable Manager
12.1. Introduction
The condition variable manager …
The directives provided by the condition variable manager are:
12.2. Background
There is currently no text in this section.
12.3. Operations
12.4. Directives
This section details the condition variable manager’s directives. A subsection is dedicated to each of this manager’s directives and describes the calling sequence, related constants, usage, and status codes.
12.4.1. pthread_condattr_init - Initialize a Condition Variable Attribute Set
CALLING SEQUENCE:
#include <pthread.h>
int pthread_condattr_init(
    pthread_condattr_t *attr
STATUS CODES:
    • ENOMEM
    • Insufficient memory is available to initialize the condition variable attributes object.
DESCRIPTION:
NOTES:
12.4.2. pthread_condattr_destroy - Destroy a Condition Variable Attribute Set
CALLING SEQUENCE:
int pthread_condattr_destroy(
STATUS CODES:
EINVAL The attribute object specified is invalid.
DESCRIPTION:
NOTES:
12.4.3. pthread_condattr_setpshared - Set Process Shared Attribute
CALLING SEQUENCE:
int pthread_condattr_setpshared(
    pthread_condattr_t *attr,
    int                 pshared
STATUS CODES:
EINVAL Invalid argument passed.
DESCRIPTION:
NOTES:
12.4.4. pthread_condattr_getpshared - Get Process Shared Attribute
CALLING SEQUENCE:
int pthread_condattr_getpshared(
    const pthread_condattr_t *attr,
    int                      *pshared
STATUS CODES:
DESCRIPTION:
NOTES:
12.4.5. pthread_cond_init - Initialize a Condition Variable
CALLING SEQUENCE:
int pthread_cond_init(
    pthread_cond_t           *cond,
STATUS CODES:
EAGAIN The system lacked a resource other than memory necessary to create the initialize the condition variable object.
ENOMEM Insufficient memory is available to initialize the condition variable object.
EBUSY The specified condition variable has already been initialized.
EINVAL The specified attribute value is invalid.
DESCRIPTION:
NOTES:
12.4.6. pthread_cond_destroy - Destroy a Condition Variable
CALLING SEQUENCE:
int pthread_cond_destroy(
STATUS CODES:
EINVAL The specified condition variable is invalid.
EBUSY The specified condition variable is currently in use.
DESCRIPTION:
NOTES:
12.4.7. pthread_cond_signal - Signal a Condition Variable
CALLING SEQUENCE:
int pthread_cond_signal(
STATUS CODES:
EINVAL The specified condition variable is not valid.
DESCRIPTION:
NOTES:
This routine should not be invoked from a handler from an asynchronous signal handler or an interrupt service routine.
12.4.8. pthread_cond_broadcast - Broadcast a Condition Variable
CALLING SEQUENCE:
int pthread_cond_broadcast(
STATUS CODES:
DESCRIPTION:
NOTES:
12.4.9. pthread_cond_wait - Wait on a Condition Variable
CALLING SEQUENCE:
int pthread_cond_wait(
    pthread_mutex_t *mutex
STATUS CODES:
EINVAL The specified condition variable or mutex is not initialized OR different mutexes were specified for concurrent pthread_cond_wait() and pthread_cond_timedwait() operations on the same condition variable OR the mutex was not owned by the current thread at the time of the call.
DESCRIPTION:
NOTES:
12.4.10. pthread_cond_timedwait - Wait with Timeout a Condition Variable
CALLING SEQUENCE:
int pthread_cond_timedwait(
    pthread_mutex_t       *mutex,
    const struct timespec *abstime
STATUS CODES:
EINVAL The nanoseconds field of timeout is invalid.
ETIMEDOUT The specified time has elapsed without the condition variable being satisfied.
DESCRIPTION:
NOTES:
