7. Device- and Class- Specific Functions Manager
7.1. Introduction
The device- and class- specific functions manager is …
The directives provided by the device- and class- specific functions manager are:
7.2. Background
There is currently no text in this section.
7.3. Operations
7.4. Directives
This section details the device- and class- specific functions manager’s directives. A subsection is dedicated to each of this manager’s directives and describes the calling sequence, related constants, usage, and status codes.
7.4.1. cfgetispeed - Reads terminal input baud rate
CALLING SEQUENCE:
#include <termios.h>
speed_t cfgetispeed(
    const struct termios *termios_p
STATUS CODES:
The cfgetispeed() function returns a code for baud rate.
DESCRIPTION:
The cfsetispeed() function stores a code for the terminal speed stored in a struct termios. The codes are defined in <termios.h> by the macros BO, B50, B75, B110, B134, B150, B200, B300, B600, B1200, B1800, B2400, B4800, B9600, B19200, and B38400.
The cfsetispeed() function does not do anything to the hardware. It merely stores a value for use by tcsetattr().
NOTES:
Baud rates are defined by symbols, such as B110, B1200, B2400. The actual number returned for any given speed may change from system to system.
7.4.2. cfgetospeed - Reads terminal output baud rate
CALLING SEQUENCE:
speed_t cfgetospeed(
STATUS CODES:
The cfgetospeed() function returns the termios code for the baud rate.
DESCRIPTION:
The cfgetospeed() function returns a code for the terminal speed stored in a struct termios. The codes are defined in <termios.h> by the macros BO, B50, B75, B110, B134, B150, B200, B300, B600, B1200, B1800, B2400, B4800, B9600, B19200, and B38400.
The cfgetospeed() function does not do anything to the hardware. It merely returns the value stored by a previous call to tcgetattr().
NOTES:
7.4.3. cfsetispeed - Sets terminal input baud rate
CALLING SEQUENCE:
int cfsetispeed(
    struct termios *termios_p,
    speed_t speed
STATUS CODES:
The cfsetispeed() function returns a zero when successful and returns -1 when an error occurs.
DESCRIPTION:
NOTES:
This function merely stores a value in the termios structure. It does not change the terminal speed until a tcsetattr() is done. It does not detect impossible terminal speeds.
7.4.4. cfsetospeed - Sets terminal output baud rate
CALLING SEQUENCE:
int cfsetospeed(
    speed_t speed
STATUS CODES:
The cfsetospeed() function returns a zero when successful and returns -1 when an error occurs.
DESCRIPTION:
The cfsetospeed() function stores a code for the terminal speed stored in a struct termios. The codes are defiined in <termios.h> by the macros BO, B50, B75, B110, B134, B150, B200, B300, B600, B1200, B1800, B2400, B4800, B9600, B19200, and B38400.
The cfsetospeed() function does not do anything to the hardware. It merely stores a value for use by tcsetattr().
NOTES:
7.4.5. tcgetattr - Gets terminal attributes
CALLING SEQUENCE:
int tcgetattr(
    int fildes,
STATUS CODES:
EBADF Invalid file descriptor
ENOOTY Terminal control function attempted for a file that is not a terminal.
DESCRIPTION:
The tcgetattr() gets the parameters associated with the terminal referred to by fildes and stores them into the termios() structure pointed to by termios_p.
NOTES:
NONE
7.4.6. tcsetattr - Set terminal attributes
CALLING SEQUENCE:
int tcsetattr(
    int fildes,
    int optional_actions,
STATUS CODES:
E The
DESCRIPTION:
NOTES:
7.4.7. tcsendbreak - Sends a break to a terminal
CALLING SEQUENCE:
int tcsendbreak(
    int fildes,
    int duration
STATUS CODES:
E The
DESCRIPTION:
NOTES:
This routine is not currently supported by RTEMS but could be in a future version.
7.4.8. tcdrain - Waits for all output to be transmitted to the terminal.
CALLING SEQUENCE:
int tcdrain(
    int fildes
STATUS CODES:
EINTR Function was interrupted by a signal
ENOTTY Terminal control function attempted for a file that is not a terminal.
DESCRIPTION:
The tcdrain() function waits until all output written to fildes has been transmitted.
NOTES:
NONE
7.4.9. tcflush - Discards terminal data
CALLING SEQUENCE:
int tcflush(
    int fildes,
    int queue_selector
STATUS CODES:
E The
DESCRIPTION:
NOTES:
7.4.10. tcflow - Suspends/restarts terminal output.
CALLING SEQUENCE:
int tcflow(
    int fildes,
    int action
STATUS CODES:
E The
DESCRIPTION:
NOTES:
7.4.11. tcgetpgrp - Gets foreground process group ID
CALLING SEQUENCE:
#include <unistd.h>
pid_t tcgetpgrp(
    int fildes
STATUS CODES:
E The
DESCRIPTION:
NOTES:
7.4.12. tcsetpgrp - Sets foreground process group ID
CALLING SEQUENCE:
#include <unistd.h>
int tcsetpgrp(
    int fildes,
    pid_t pgid_id
STATUS CODES:
E The
DESCRIPTION:
NOTES:
