6. Input and Output Primitives Manager¶
6.1. Introduction¶
The input and output primitives manager is …
The directives provided by the input and output primitives manager are:
- pipe - Create an Inter-Process Channel
- dup - Duplicates an open file descriptor
- dup2 - Duplicates an open file descriptor
- close - Closes a file
- read - Reads from a file
- write - Writes to a file
- fcntl - Manipulates an open file descriptor
- lseek - Reposition read/write file offset
- fsync - Synchronize file complete in-core state with that on disk
- fdatasync - Synchronize file in-core data with that on disk
- sync - Schedule file system updates
- mount - Mount a file system
- unmount - Unmount file systems
- readv - Vectored read from a file
- writev - Vectored write to a file
- aio_read - Asynchronous Read
- aio_write - Asynchronous Write
- lio_listio - List Directed I/O
- aio_error - Retrieve Error Status of Asynchronous I/O Operation
- aio_return - Retrieve Return Status Asynchronous I/O Operation
- aio_cancel - Cancel Asynchronous I/O Request
- aio_suspend - Wait for Asynchronous I/O Request
- aio_fsync - Asynchronous File Synchronization
6.2. Background¶
There is currently no text in this section.
6.3. Operations¶
6.4. Directives¶
This section details the input and output primitives manager’s directives. A subsection is dedicated to each of this manager’s directives and describes the calling sequence, related constants, usage, and status codes.
6.4.1. pipe - Create an Inter-Process Channel¶
CALLING SEQUENCE:
#include <unistd.h>
int pipe(
int fildes[2]
STATUS CODES:
E |
The |
DESCRIPTION:
NOTES:
This routine is not currently supported by RTEMS but could be in a future version.
6.4.2. dup - Duplicates an open file descriptor¶
CALLING SEQUENCE:
#include <unistd.h>
int dup(
int fildes
STATUS CODES:
EBADF |
Invalid file descriptor. |
EINTR |
Function was interrupted by a signal. |
EMFILE |
The process already has the maximum number of file descriptors open and tried to open a new one. |
DESCRIPTION:
The dup function returns the lowest numbered available file
descriptor. This new desciptor refers to the same open file as the original
descriptor and shares any locks.
NOTES:
NONE
6.4.3. dup2 - Duplicates an open file descriptor¶
CALLING SEQUENCE:
#include <unistd.h>
int dup2(
int fildes,
int fildes2
STATUS CODES:
EBADF |
EINTR |
EMFILE |
DESCRIPTION:
dup2 creates a copy of the file descriptor oldfd.
The old and new descriptors may be used interchangeably. They share locks, file
position pointers and flags; for example, if the file position is modified by
using lseek on one of the descriptors, the position is also changed for the
other.
NOTES:
NONE
6.4.4. close - Closes a file¶
CALLING SEQUENCE:
#include <unistd.h>
int close(
int fildes
STATUS CODES:
EBADF |
Invalid file descriptor |
EINTR |
DESCRIPTION:
The close() function deallocates the file descriptor named by fildes
and makes it available for reuse. All outstanding record locks owned by this
process for the file are unlocked.
NOTES:
A signal can interrupt the close() function. In that case, close()
returns -1 with errno set to EINTR. The file may or may not be closed.
6.4.5. read - Reads from a file¶
CALLING SEQUENCE:
#include <unistd.h>
ssize_t read(
int fildes,
void *buf,
size_t nbyte
STATUS CODES:
On error, this routine returns -1 and sets errno to one of the following:
EAGAIN |
The O_NONBLOCK flag is set for a file descriptor and the process would be delayed in the I/O operation. |
EBADF |
EINTR |
EIO |
Input or output error |
EINVAL |
Bad buffer pointer |
DESCRIPTION:
The read() function reads nbyte bytes from the file associated with
fildes into the buffer pointed to by buf.
The read() function returns the number of bytes actually read and placed in
the buffer. This will be less than nbyte if:
- The number of bytes left in the file is less than
nbyte. - The
read()request was interrupted by a signal. - The file is a pipe or FIFO or special file with less than
nbytesimmediately available for reading.
When attempting to read from any empty pipe or FIFO:
- If no process has the pipe open for writing, zero is returned to indicate end-of-file.
- If some process has the pipe open for writing and O_NONBLOCK is set,
-1 is returned and
errnois set to EAGAIN. - If some process has the pipe open for writing and O_NONBLOCK is clear,
read()waits for some data to be written or the pipe to be closed.
When attempting to read from a file other than a pipe or FIFO and no data is available.
- If O_NONBLOCK is set, -1 is returned and
errnois set to EAGAIN. - If O_NONBLOCK is clear,
read()waits for some data to become available. - The O_NONBLOCK flag is ignored if data is available.
NOTES:
NONE
6.4.6. write - Writes to a file¶
CALLING SEQUENCE:
#include <unistd.h>
ssize_t write(
int fildes,
const void *buf,
size_t nbyte
STATUS CODES:
EAGAIN |
EBADF |
EFBIG |
An attempt was made to write to a file that exceeds the maximum file size |
EINTR |
The function was interrupted by a signal. |
EIO |
Input or output error. |
ENOSPC |
No space left on disk. |
EPIPE |
Attempt to write to a pope or FIFO with no reader. |
EINVAL |
DESCRIPTION:
The write() function writes nbyte from the array pointed to by buf
into the file associated with fildes.
If nybte is zero and the file is a regular file, the write() function
returns zero and has no other effect. If nbyte is zero and the file is a
special file, te results are not portable.
The write() function returns the number of bytes written. This number will
be less than nbytes if there is an error. It will never be greater than
nbytes.
NOTES:
NONE
6.4.7. fcntl - Manipulates an open file descriptor¶
CALLING SEQUENCE:
#include <fcntl.h>
int fcntl(
int fildes,
int cmd,
STATUS CODES:
EACCESS |
Search permission is denied for a direcotry in a file’s path prefix. |
EAGAIN |
EBADF |
EDEADLK |
An fcntl with function F_SETLKW would cause a deadlock. |
EINTR |
The functioin was interrupted by a signal. |
EINVAL |
Invalid argument |
EMFILE |
Too many file descriptor or in use by the process. |
ENOLCK |
No locks available |
DESCRIPTION:
fcntl() performs one of various miscellaneous operations on``fd``. The
operation in question is determined by cmd:
F_DUPFD |
Makes arg be a copy of fd, closing fd first if necessary. The
same functionality can be more easily achieved by using dup2(). The
file position pointers and flags; for example, if the file position is
modified by using lseek() on one of the descriptors, the position is
also changed for the other. The two descriptors do not share the
close-on-exec flag, however. The close-on-exec flag of the copy is off,
meaning that it will be closed on exec. On success, the new descriptor is
returned. |
F_GETFD |
Read the close-on-exec flag. If the low-order bit is 0, the file will remain open across exec, otherwise it will be closed. |
F_SETFD |
Set the close-on-exec flag to the value specified by arg (only the
least significant bit is used). |
F_GETFL |
Read the descriptor’s flags (all flags (as set by open()) are returned). |
F_SETFL |
Set the descriptor’s flags to the value specified by
arg. Only``O_APPEND`` and O_NONBLOCK may be set. The flags are
shared between copies (made with dup() etc.) of the same file
descriptor. The flags and their semantics are described in open(). |
F_GETLK, F_SETLK and F_SETLKW |
Manage discretionary file locks. The third argument arg is a pointer
to a struct flock (that may be overwritten by this call). |
F_GETLK |
Return the flock structure that prevents us from obtaining the lock, or
set the``l_type`` field of the lock to F_UNLCK if there is no
obstruction. |
F_SETLK |
The lock is set (when l_type is F_RDLCK or F_WRLCK) or cleared
(when it is F_UNLCK. If lock is held by someone else, this call
returns -1 and sets errno to EACCES or EAGAIN. |
F_SETLKW |
Like F_SETLK, but instead of returning an error we wait for the lock
to be released. |
F_GETOWN |
Get the process ID (or process group) of the owner of a socket. Process groups are returned as negative values. |
F_SETOWN |
Set the process or process group that owns a socket. For these commands,
ownership means receiving SIGIO or SIGURG signals. Process groups
are specified using negative values. |
NOTES:
The errors returned by dup2 are different from those returned by F_DUPFD.
6.4.8. lseek - Reposition read/write file offset¶
CALLING SEQUENCE:
#include <unistd.h>
off_t lseek(
int fildes,
off_t offset,
int whence
STATUS CODES:
EBADF |
fildes is not an open file descriptor. |
ESPIPE |
fildes is associated with a pipe, socket or FIFO. |
EINVAL |
whence is not a proper value. |
DESCRIPTION:
The lseek function repositions the offset of the file descriptor fildes
to the argument offset according to the directive whence. The argument
fildes must be an open file descriptor. Lseek repositions the file
pointer fildes as follows:
- If
whenceis SEEK_SET, the offset is set tooffsetbytes. - If
whenceis SEEK_CUR, the offset is set to its current location plus offset bytes. - If
whenceis SEEK_END, the offset is set to the size of the file plusoffsetbytes.
The lseek function allows the file offset to be set beyond the end of the
existing end-of-file of the file. If data is later written at this point,
subsequent reads of the data in the gap return bytes of zeros (until data is
actually written into the gap).
Some devices are incapable of seeking. The value of the pointer associated with such a device is undefined.
NOTES:
NONE
6.4.9. fsync - Synchronize file complete in-core state with that on disk¶
CALLING SEQUENCE:
#include <unistd.h>
int fsync(
int fildes
STATUS CODES:
On success, zero is returned. On error, -1 is returned, and errno is set
appropriately.
EBADF |
fd is not a valid descriptor open for writing |
EINVAL |
EROFS |
EIO |
An error occurred during synchronization |
DESCRIPTION:
fsync copies all in-core parts of a file to disk.
NOTES:
NONE
6.4.10. fdatasync - Synchronize file in-core data with that on disk¶
CALLING SEQUENCE:
#include <unistd.h>
int fdatasync(
int fildes
STATUS CODES:
appropriately.
EBADF |
fd is not a valid file descriptor open for writing. |
EINVAL |
fd is bound to a special file which does not support synchronization. |
EIO |
An error occurred during synchronization. |
EROFS |
fd is bound to a special file which dows not support synchronization. |
DESCRIPTION:
fdatasync flushes all data buffers of a file to disk (before the system
call returns). It resembles fsync but is not required to update the
metadata such as access time.
Applications that access databases or log files often write a tiny data
fragment (e.g., one line in a log file) and then call fsync immediately in
order to ensure that the written data is physically stored on the
harddisk. Unfortunately, fsync will always initiate two write operations: one
for the newly written data and another one in order to update the modification
time stored in the inode. If the modification time is not a part of the
transaction concept fdatasync can be used to avoid unnecessary inode disk
write operations.
NOTES:
NONE
6.4.11. sync - Schedule file system updates¶
CALLING SEQUENCE:
#include <unistd.h>
void sync(
void
STATUS CODES:
NONE
DESCRIPTION:
The sync service causes all information in memory that updates file systems
to be scheduled for writing out to all file systems.
NOTES:
The writing of data to the file systems is only guaranteed to be scheduled upon
return. It is not necessarily complete upon return from sync.
6.4.12. mount - Mount a file system¶
CALLING SEQUENCE:
#include <libio.h>
int mount(
rtems_filesystem_mount_table_entry_t **mt_entry,
rtems_filesystem_operations_table *fs_ops,
rtems_filesystem_options_t fsoptions,
char *device,
char *mount_point
STATUS CODES:
ENOMEM- Unable to allocate memory needed.
EINVAL- The filesystem does not support being mounted.
EINVAL- Attempt to mount a read-only filesystem as writeable.
DESCRIPTION:
The mount routines mounts the filesystem class which uses the filesystem
operations specified by fs_ops and fsoptions. The filesystem is
mounted at the directory mount_point and the mode of the mounted filesystem
is specified by fsoptions. If this filesystem class requires a device,
then the name of the device must be specified by device.
If this operation succeeds, the mount table entry for the mounted filesystem is
returned in mt_entry.
NOTES:
This method is not defined in the POSIX standard.
6.4.13. unmount - Unmount file systems¶
CALLING SEQUENCE:
#include <libio.h>
int unmount(
const char *mount_path
STATUS CODES:
EBUSY- Filesystem is in use or the root filesystem.
EACCESS- Unable to allocate memory needed.
DESCRIPTION:
The unmount routine removes the attachment of the filesystem specified by
mount_path.
NOTES:
6.4.14. readv - Vectored read from a file¶
CALLING SEQUENCE:
#include <sys/uio.h>
ssize_t readv(
int fildes,
const struct iovec *iov,
int iovcnt
STATUS CODES:
In addition to the errors detected by Input and Output Primitives Manager
read - Reads from a file, read(), this routine may return -1 and sets
errno based upon the following errors:
EINVAL |
The sum of the iov_len values in the iov array overflowed
an ssize_t. |
EINVAL |
The iovcnt argument was less than or equal to 0, or greater than
IOV_MAX. |
DESCRIPTION:
The readv() function is equivalent to read() except as described
here. The readv() function shall place the input data into the iovcnt
buffers specified by the members of the iov array: iov[0], iov[1], ...,
iov[iovcnt-1].
Each iovec entry specifies the base address and length of an area in memory
where data should be placed. The readv() function always fills an area
completely before proceeding to the next.
NOTES:
NONE
6.4.15. writev - Vectored write to a file¶
CALLING SEQUENCE:
ssize_t writev(
int fildes,
int iovcnt
STATUS CODES:
write - Write to a file, write(), this routine may return -1 and sets
EINVAL |
an ssize_t. |
EINVAL |
IOV_MAX. |
DESCRIPTION:
The writev() function is equivalent to write(), except as noted
here. The writev() function gathers output data from the iovcnt buffers
iov[iovcnt-1]. The iovcnt argument is valid if greater than 0 and less
than or equal to IOV_MAX.
from which data should be written. The writev() function always writes a
complete area before proceeding to the next.
If fd refers to a regular file and all of the iov_len members in the
array pointed to by iov are 0, writev() returns 0 and has no other
effect. For other file types, the behavior is unspecified by POSIX.
NOTES:
NONE
6.4.16. aio_read - Asynchronous Read¶
CALLING SEQUENCE:
#include <aio.h>
int aio_read(
struct aiocb *aiocbp
STATUS CODES:
E |
The |
DESCRIPTION:
NOTES:
6.4.17. aio_write - Asynchronous Write¶
CALLING SEQUENCE:
#include <aio.h>
int aio_write(
STATUS CODES:
E |
The |
DESCRIPTION:
NOTES:
6.4.18. lio_listio - List Directed I/O¶
CALLING SEQUENCE:
#include <aio.h>
int lio_listio(
int mode,
struct aiocb *restrict const list[restrict],
int nent,
struct sigevent *restrict sig
STATUS CODES:
E |
The |
DESCRIPTION:
NOTES:
6.4.19. aio_error - Retrieve Error Status of Asynchronous I/O Operation¶
CALLING SEQUENCE:
#include <aio.h>
int aio_error(
const struct aiocb *aiocbp
STATUS CODES:
E |
The |
DESCRIPTION:
NOTES:
6.4.20. aio_return - Retrieve Return Status Asynchronous I/O Operation¶
CALLING SEQUENCE:
#include <aio.h>
ssize_t aio_return(
STATUS CODES:
E |
The |
DESCRIPTION:
NOTES:
6.4.21. aio_cancel - Cancel Asynchronous I/O Request¶
CALLING SEQUENCE:
#include <aio.h>
int aio_cancel(
int fildes,
STATUS CODES:
E |
The |
DESCRIPTION:
NOTES:
6.4.22. aio_suspend - Wait for Asynchronous I/O Request¶
CALLING SEQUENCE:
#include <aio.h>
int aio_suspend(
const struct aiocb *const list[],
int nent,
const struct timespec *timeout
STATUS CODES:
E |
The |
DESCRIPTION:
NOTES:
6.4.23. aio_fsync - Asynchronous File Synchronization¶
CALLING SEQUENCE:
#include <aio.h>
int aio_fsync(
int op,
STATUS CODES:
E |
The |
DESCRIPTION:
NOTES:
