RTEMS 7.0-rc1
Data Structures | Macros | Typedefs | Enumerations
stm32u5g9xx.h File Reference
CMSIS STM32U5G9xx Device Peripheral Access Layer Header File. More...
#include <core_cm33.h>
#include "system_stm32u5xx.h"
struct  CRC_TypeDef
 CRC calculation unit. More...
struct  I2C_TypeDef
 Inter-integrated Circuit Interface. More...
struct  DAC_TypeDef
 DAC. More...
struct  CRS_TypeDef
 Clock Recovery System. More...
struct  AES_TypeDef
 AES hardware accelerator. More...
struct  HASH_TypeDef
 HASH. More...
struct  HASH_DIGEST_TypeDef
 HASH_DIGEST. More...
struct  RNG_TypeDef
 RNG. More...
struct  DBGMCU_TypeDef
 Debug MCU. More...
struct  DCMI_TypeDef
 DCMI. More...
struct  DMA_TypeDef
 DMA Controller. More...
struct  DMA_Channel_TypeDef
struct  DMA2D_TypeDef
 DMA2D Controller. More...
struct  DSI_TypeDef
 DSI Controller. More...
struct  EXTI_TypeDef
 Asynch Interrupt/Event Controller (EXTI) More...
struct  FLASH_TypeDef
 FLASH Registers. More...
struct  FMAC_TypeDef
 FMAC. More...
struct  GFXMMU_TypeDef
 GFXMMU registers. More...
struct  GPIO_TypeDef
 General Purpose I/O. More...
struct  GTZC_TZSC_TypeDef
 Global TrustZone Controller. More...
struct  GTZC_MPCBB_TypeDef
struct  GTZC_TZIC_TypeDef
struct  GFXTIM_TypeDef
 GFXTIM. More...
struct  JPEG_TypeDef
 JPEG Codec. More...
struct  LTDC_TypeDef
 LCD-TFT Display Controller. More...
struct  LTDC_Layer_TypeDef
 LCD-TFT Display layer x Controller. More...
struct  ICACHE_TypeDef
 Instruction Cache. More...
struct  DCACHE_TypeDef
 Data Cache. More...
struct  PSSI_TypeDef
 PSSI. More...
struct  TIM_TypeDef
 TIM. More...
struct  LPTIM_TypeDef
 LPTIMER. More...
struct  COMP_TypeDef
 Comparator. More...
struct  COMP_Common_TypeDef
struct  OPAMP_TypeDef
 Operational Amplifier (OPAMP) More...
struct  OPAMP_Common_TypeDef
struct  MDF_TypeDef
 MDF/ADF. More...
struct  MDF_Filter_TypeDef
 MDF/ADF filter. More...
struct  XSPI_TypeDef
 HEXA and OCTO Serial Peripheral Interface. More...
struct  OTFDEC_Region_TypeDef
 OTFDEC register. More...
struct  OTFDEC_TypeDef
struct  XSPIM_TypeDef
 Serial Peripheral Interface IO Manager. More...
struct  PWR_TypeDef
 Power Control. More...
struct  RAMCFG_TypeDef
 SRAMs configuration controller. More...
struct  RCC_TypeDef
 Reset and Clock Control. More...
struct  PKA_TypeDef
 PKA. More...
struct  RTC_TypeDef
 Real-Time Clock. More...
struct  TAMP_TypeDef
 Tamper and backup registers. More...
struct  USART_TypeDef
 Universal Synchronous Asynchronous Receiver Transmitter. More...
struct  SAI_TypeDef
 Serial Audio Interface. More...
struct  SAI_Block_TypeDef
struct  SYSCFG_TypeDef
 System configuration controller. More...
struct  SDMMC_TypeDef
 Secure digital input/output Interface. More...
struct  DLYB_TypeDef
 Delay Block DLYB. More...
struct  UCPD_TypeDef
 UCPD. More...
struct  USB_OTG_GlobalTypeDef
 USB_OTG_Core_register. More...
struct  USB_OTG_DeviceTypeDef
 USB_OTG_device_Registers. More...
struct  USB_OTG_INEndpointTypeDef
 USB_OTG_IN_Endpoint-Specific_Register. More...
struct  USB_OTG_OUTEndpointTypeDef
 USB_OTG_OUT_Endpoint-Specific_Registers. More...
struct  USB_OTG_HostTypeDef
 USB_OTG_Host_Mode_Register_Structures. More...
struct  USB_OTG_HostChannelTypeDef
 USB_OTG_Host_Channel_Specific_Registers. More...
struct  FDCAN_GlobalTypeDef
 FD Controller Area Network. More...
struct  FDCAN_Config_TypeDef
 FD Controller Area Network Configuration. More...
struct  FMC_Bank1_TypeDef
 Flexible Memory Controller. More...
struct  FMC_Bank1E_TypeDef
 Flexible Memory Controller Bank1E. More...
struct  FMC_Bank3_TypeDef
 Flexible Memory Controller Bank3. More...
struct  VREFBUF_TypeDef
 VREFBUF. More...
struct  ADC_TypeDef
 ADC. More...
struct  ADC_Common_TypeDef
struct  CORDIC_TypeDef
 CORDIC. More...
struct  IWDG_TypeDef
 IWDG. More...
struct  SPI_TypeDef
 SPI. More...
struct  TSC_TypeDef
 Touch Sensing Controller (TSC) More...
struct  WWDG_TypeDef
 WWDG. More...
struct  NSC_pFuncTypeDef
 RSSLib non-secure callable function pointer structure. More...
struct  S_pFuncTypeDef
 RSSLib secure callable function pointer structure. More...
struct  RSSLIB_pFunc_TypeDef
 RSSLib function pointer structure. More...
#define __CM33_REV   0x0000U /* Core revision r0p1 */
#define __SAUREGION_PRESENT   1U /* SAU regions present */
#define __MPU_PRESENT   1U /* MPU present */
#define __VTOR_PRESENT   1U /* VTOR present */
#define __NVIC_PRIO_BITS   4U /* Number of Bits used for Priority Levels */
#define __Vendor_SysTickConfig   0U /* Set to 1 if different SysTick Config is used */
#define __FPU_PRESENT   1U /* FPU present */
#define __DSP_PRESENT   1U /* DSP extension present */
#define __ICACHE_PRESENT   1U /* ICACHE present */
#define __DCACHE_PRESENT   1U /* DCACHE present */
#define RTC_BKP_NB   32U
#define RTC_TAMP_NB   8U
#define PW   PWRR
#define SRAM1_SIZE   (0xC0000UL)
#define SRAM2_SIZE   (0x10000UL)
#define SRAM3_SIZE   (0xD0000UL)
#define SRAM4_SIZE   (0x04000UL)
#define SRAM5_SIZE   (0xD0000UL)
#define SRAM6_SIZE   (0x80000UL)
#define FMC_BASE   (0x60000000UL)
#define OCTOSPI2_BASE   (0x70000000UL)
#define OCTOSPI1_BASE   (0x90000000UL)
#define HSPI1_BASE   (0xA0000000UL)
#define FMC_BANK1   FMC_BASE
#define FMC_BANK1_1   FMC_BANK1
#define FMC_BANK1_2   (FMC_BANK1 + 0x04000000UL)
#define FMC_BANK1_3   (FMC_BANK1 + 0x08000000UL)
#define FMC_BANK1_4   (FMC_BANK1 + 0x0C000000UL)
#define FMC_BANK3   (FMC_BASE + 0x20000000UL)
#define FLASH_BASE_NS   (0x08000000UL)
#define SRAM1_BASE_NS   (0x20000000UL)
#define SRAM2_BASE_NS   (0x200C0000UL)
#define SRAM3_BASE_NS   (0x200D0000UL)
#define SRAM4_BASE_NS   (0x28000000UL)
#define SRAM5_BASE_NS   (0x201A0000UL)
#define SRAM6_BASE_NS   (0x20270000UL)
#define PERIPH_BASE_NS   (0x40000000UL)
#define APB1PERIPH_BASE_NS   PERIPH_BASE_NS
#define APB2PERIPH_BASE_NS   (PERIPH_BASE_NS + 0x00010000UL)
#define AHB1PERIPH_BASE_NS   (PERIPH_BASE_NS + 0x00020000UL)
#define AHB2PERIPH_BASE_NS   (PERIPH_BASE_NS + 0x02020000UL)
#define APB3PERIPH_BASE_NS   (PERIPH_BASE_NS + 0x06000000UL)
#define AHB3PERIPH_BASE_NS   (PERIPH_BASE_NS + 0x06020000UL)
#define TIM2_BASE_NS   (APB1PERIPH_BASE_NS + 0x0000UL)
#define TIM3_BASE_NS   (APB1PERIPH_BASE_NS + 0x0400UL)
#define TIM4_BASE_NS   (APB1PERIPH_BASE_NS + 0x0800UL)
#define TIM5_BASE_NS   (APB1PERIPH_BASE_NS + 0x0C00UL)
#define TIM6_BASE_NS   (APB1PERIPH_BASE_NS + 0x1000UL)
#define TIM7_BASE_NS   (APB1PERIPH_BASE_NS + 0x1400UL)
#define WWDG_BASE_NS   (APB1PERIPH_BASE_NS + 0x2C00UL)
#define IWDG_BASE_NS   (APB1PERIPH_BASE_NS + 0x3000UL)
#define SPI2_BASE_NS   (APB1PERIPH_BASE_NS + 0x3800UL)
#define USART2_BASE_NS   (APB1PERIPH_BASE_NS + 0x4400UL)
#define USART3_BASE_NS   (APB1PERIPH_BASE_NS + 0x4800UL)
#define UART4_BASE_NS   (APB1PERIPH_BASE_NS + 0x4C00UL)
#define UART5_BASE_NS   (APB1PERIPH_BASE_NS + 0x5000UL)
#define I2C1_BASE_NS   (APB1PERIPH_BASE_NS + 0x5400UL)
#define I2C2_BASE_NS   (APB1PERIPH_BASE_NS + 0x5800UL)
#define CRS_BASE_NS   (APB1PERIPH_BASE_NS + 0x6000UL)
#define USART6_BASE_NS   (APB1PERIPH_BASE_NS + 0x6400UL)
#define I2C4_BASE_NS   (APB1PERIPH_BASE_NS + 0x8400UL)
#define LPTIM2_BASE_NS   (APB1PERIPH_BASE_NS + 0x9400UL)
#define I2C5_BASE_NS   (APB1PERIPH_BASE_NS + 0x9800UL)
#define I2C6_BASE_NS   (APB1PERIPH_BASE_NS + 0x9C00UL)
#define FDCAN1_BASE_NS   (APB1PERIPH_BASE_NS + 0xA400UL)
#define FDCAN_CONFIG_BASE_NS   (APB1PERIPH_BASE_NS + 0xA500UL)
#define SRAMCAN_BASE_NS   (APB1PERIPH_BASE_NS + 0xAC00UL)
#define UCPD1_BASE_NS   (APB1PERIPH_BASE_NS + 0xDC00UL)
#define TIM1_BASE_NS   (APB2PERIPH_BASE_NS + 0x2C00UL)
#define SPI1_BASE_NS   (APB2PERIPH_BASE_NS + 0x3000UL)
#define TIM8_BASE_NS   (APB2PERIPH_BASE_NS + 0x3400UL)
#define USART1_BASE_NS   (APB2PERIPH_BASE_NS + 0x3800UL)
#define TIM15_BASE_NS   (APB2PERIPH_BASE_NS + 0x4000UL)
#define TIM16_BASE_NS   (APB2PERIPH_BASE_NS + 0x4400UL)
#define TIM17_BASE_NS   (APB2PERIPH_BASE_NS + 0x4800UL)
#define SAI1_BASE_NS   (APB2PERIPH_BASE_NS + 0x5400UL)
#define SAI1_Block_A_BASE_NS   (SAI1_BASE_NS + 0x004UL)
#define SAI1_Block_B_BASE_NS   (SAI1_BASE_NS + 0x024UL)
#define SAI2_BASE_NS   (APB2PERIPH_BASE_NS + 0x5800UL)
#define SAI2_Block_A_BASE_NS   (SAI2_BASE_NS + 0x004UL)
#define SAI2_Block_B_BASE_NS   (SAI2_BASE_NS + 0x024UL)
#define LTDC_BASE_NS   (APB2PERIPH_BASE_NS + 0x6800UL)
#define LTDC_Layer1_BASE_NS   (LTDC_BASE_NS + 0x0084UL)
#define LTDC_Layer2_BASE_NS   (LTDC_BASE_NS + 0x0104UL)
#define GFXTIM_BASE_NS   (APB2PERIPH_BASE_NS + 0x6400UL)
#define DSI_BASE_NS   (APB2PERIPH_BASE_NS + 0x6C00UL)
#define REFBIAS_BASE_NS   (DSI_BASE_NS + 0x800UL)
#define DPHY_BASE_NS   (DSI_BASE_NS + 0xC00UL)
#define SYSCFG_BASE_NS   (APB3PERIPH_BASE_NS + 0x0400UL)
#define SPI3_BASE_NS   (APB3PERIPH_BASE_NS + 0x2000UL)
#define LPUART1_BASE_NS   (APB3PERIPH_BASE_NS + 0x2400UL)
#define I2C3_BASE_NS   (APB3PERIPH_BASE_NS + 0x2800UL)
#define LPTIM1_BASE_NS   (APB3PERIPH_BASE_NS + 0x4400UL)
#define LPTIM3_BASE_NS   (APB3PERIPH_BASE_NS + 0x4800UL)
#define LPTIM4_BASE_NS   (APB3PERIPH_BASE_NS + 0x4C00UL)
#define OPAMP_BASE_NS   (APB3PERIPH_BASE_NS + 0x5000UL)
#define OPAMP1_BASE_NS   (APB3PERIPH_BASE_NS + 0x5000UL)
#define OPAMP2_BASE_NS   (APB3PERIPH_BASE_NS + 0x5010UL)
#define COMP12_BASE_NS   (APB3PERIPH_BASE_NS + 0x5400UL)
#define COMP1_BASE_NS   (COMP12_BASE_NS)
#define COMP2_BASE_NS   (COMP12_BASE_NS + 0x04UL)
#define VREFBUF_BASE_NS   (APB3PERIPH_BASE_NS + 0x7400UL)
#define RTC_BASE_NS   (APB3PERIPH_BASE_NS + 0x7800UL)
#define TAMP_BASE_NS   (APB3PERIPH_BASE_NS + 0x7C00UL)
#define GPDMA1_BASE_NS   (AHB1PERIPH_BASE_NS)
#define GPDMA1_Channel0_BASE_NS   (GPDMA1_BASE_NS + 0x0050UL)
#define GPDMA1_Channel1_BASE_NS   (GPDMA1_BASE_NS + 0x00D0UL)
#define GPDMA1_Channel2_BASE_NS   (GPDMA1_BASE_NS + 0x0150UL)
#define GPDMA1_Channel3_BASE_NS   (GPDMA1_BASE_NS + 0x01D0UL)
#define GPDMA1_Channel4_BASE_NS   (GPDMA1_BASE_NS + 0x0250UL)
#define GPDMA1_Channel5_BASE_NS   (GPDMA1_BASE_NS + 0x02D0UL)
#define GPDMA1_Channel6_BASE_NS   (GPDMA1_BASE_NS + 0x0350UL)
#define GPDMA1_Channel7_BASE_NS   (GPDMA1_BASE_NS + 0x03D0UL)
#define GPDMA1_Channel8_BASE_NS   (GPDMA1_BASE_NS + 0x0450UL)
#define GPDMA1_Channel9_BASE_NS   (GPDMA1_BASE_NS + 0x04D0UL)
#define GPDMA1_Channel10_BASE_NS   (GPDMA1_BASE_NS + 0x0550UL)
#define GPDMA1_Channel11_BASE_NS   (GPDMA1_BASE_NS + 0x05D0UL)
#define GPDMA1_Channel12_BASE_NS   (GPDMA1_BASE_NS + 0x0650UL)
#define GPDMA1_Channel13_BASE_NS   (GPDMA1_BASE_NS + 0x06D0UL)
#define GPDMA1_Channel14_BASE_NS   (GPDMA1_BASE_NS + 0x0750UL)
#define GPDMA1_Channel15_BASE_NS   (GPDMA1_BASE_NS + 0x07D0UL)
#define CORDIC_BASE_NS   (AHB1PERIPH_BASE_NS + 0x01000UL)
#define FMAC_BASE_NS   (AHB1PERIPH_BASE_NS + 0x01400UL)
#define FLASH_R_BASE_NS   (AHB1PERIPH_BASE_NS + 0x02000UL)
#define CRC_BASE_NS   (AHB1PERIPH_BASE_NS + 0x03000UL)
#define TSC_BASE_NS   (AHB1PERIPH_BASE_NS + 0x04000UL)
#define MDF1_BASE_NS   (AHB1PERIPH_BASE_NS + 0x05000UL)
#define MDF1_Filter0_BASE_NS   (MDF1_BASE_NS + 0x80UL)
#define MDF1_Filter1_BASE_NS   (MDF1_BASE_NS + 0x100UL)
#define MDF1_Filter2_BASE_NS   (MDF1_BASE_NS + 0x180UL)
#define MDF1_Filter3_BASE_NS   (MDF1_BASE_NS + 0x200UL)
#define MDF1_Filter4_BASE_NS   (MDF1_BASE_NS + 0x280UL)
#define MDF1_Filter5_BASE_NS   (MDF1_BASE_NS + 0x300UL)
#define RAMCFG_BASE_NS   (AHB1PERIPH_BASE_NS + 0x06000UL)
#define RAMCFG_SRAM1_BASE_NS   (RAMCFG_BASE_NS)
#define RAMCFG_SRAM2_BASE_NS   (RAMCFG_BASE_NS + 0x0040UL)
#define RAMCFG_SRAM3_BASE_NS   (RAMCFG_BASE_NS + 0x0080UL)
#define RAMCFG_SRAM4_BASE_NS   (RAMCFG_BASE_NS + 0x00C0UL)
#define RAMCFG_BKPRAM_BASE_NS   (RAMCFG_BASE_NS + 0x0100UL)
#define RAMCFG_SRAM5_BASE_NS   (RAMCFG_BASE_NS + 0x0140UL)
#define RAMCFG_SRAM6_BASE_NS   (RAMCFG_BASE_NS + 0x0180UL)
#define JPEG_BASE_NS   (AHB1PERIPH_BASE_NS + 0x0A000UL)
#define DMA2D_BASE_NS   (AHB1PERIPH_BASE_NS + 0x0B000UL)
#define GFXMMU_BASE_NS   (AHB1PERIPH_BASE_NS + 0x0C000UL)
#define GPU2D_BASE_NS   (AHB1PERIPH_BASE_NS + 0x0F000UL)
#define ICACHE_BASE_NS   (AHB1PERIPH_BASE_NS + 0x10400UL)
#define DCACHE1_BASE_NS   (AHB1PERIPH_BASE_NS + 0x11400UL)
#define DCACHE2_BASE_NS   (AHB1PERIPH_BASE_NS + 0x11800UL)
#define GTZC_TZSC1_BASE_NS   (AHB1PERIPH_BASE_NS + 0x12400UL)
#define GTZC_TZIC1_BASE_NS   (AHB1PERIPH_BASE_NS + 0x12800UL)
#define GTZC_MPCBB1_BASE_NS   (AHB1PERIPH_BASE_NS + 0x12C00UL)
#define GTZC_MPCBB2_BASE_NS   (AHB1PERIPH_BASE_NS + 0x13000UL)
#define GTZC_MPCBB3_BASE_NS   (AHB1PERIPH_BASE_NS + 0x13400UL)
#define GTZC_MPCBB5_BASE_NS   (AHB1PERIPH_BASE_NS + 0x13800UL)
#define GTZC_MPCBB6_BASE_NS   (AHB1PERIPH_BASE_NS + 0x13C00UL)
#define BKPSRAM_BASE_NS   (AHB1PERIPH_BASE_NS + 0x16400UL)
#define GPIOA_BASE_NS   (AHB2PERIPH_BASE_NS + 0x00000UL)
#define GPIOB_BASE_NS   (AHB2PERIPH_BASE_NS + 0x00400UL)
#define GPIOC_BASE_NS   (AHB2PERIPH_BASE_NS + 0x00800UL)
#define GPIOD_BASE_NS   (AHB2PERIPH_BASE_NS + 0x00C00UL)
#define GPIOE_BASE_NS   (AHB2PERIPH_BASE_NS + 0x01000UL)
#define GPIOF_BASE_NS   (AHB2PERIPH_BASE_NS + 0x01400UL)
#define GPIOG_BASE_NS   (AHB2PERIPH_BASE_NS + 0x01800UL)
#define GPIOH_BASE_NS   (AHB2PERIPH_BASE_NS + 0x01C00UL)
#define GPIOI_BASE_NS   (AHB2PERIPH_BASE_NS + 0x02000UL)
#define GPIOJ_BASE_NS   (AHB2PERIPH_BASE_NS + 0x02400UL)
#define ADC1_BASE_NS   (AHB2PERIPH_BASE_NS + 0x08000UL)
#define ADC2_BASE_NS   (AHB2PERIPH_BASE_NS + 0x08100UL)
#define ADC12_COMMON_BASE_NS   (AHB2PERIPH_BASE_NS + 0x08300UL)
#define DCMI_BASE_NS   (AHB2PERIPH_BASE_NS + 0x0C000UL)
#define PSSI_BASE_NS   (AHB2PERIPH_BASE_NS + 0x0C400UL)
#define USB_OTG_HS_BASE_NS   (AHB2PERIPH_BASE_NS + 0x20000UL)
#define AES_BASE_NS   (AHB2PERIPH_BASE_NS + 0xA0000UL)
#define HASH_BASE_NS   (AHB2PERIPH_BASE_NS + 0xA0400UL)
#define HASH_DIGEST_BASE_NS   (AHB2PERIPH_BASE_NS + 0xA0710UL)
#define RNG_BASE_NS   (AHB2PERIPH_BASE_NS + 0xA0800UL)
#define SAES_BASE_NS   (AHB2PERIPH_BASE_NS + 0xA0C00UL)
#define PKA_BASE_NS   (AHB2PERIPH_BASE_NS + 0xA2000UL)
#define PKA_RAM_BASE_NS   (AHB2PERIPH_BASE_NS + 0xA2400UL)
#define OCTOSPIM_R_BASE_NS   (AHB2PERIPH_BASE_NS + 0xA4000UL)
#define OTFDEC1_BASE_NS   (AHB2PERIPH_BASE_NS + 0xA5000UL)
#define OTFDEC1_REGION1_BASE_NS   (OTFDEC1_BASE_NS + 0x20UL)
#define OTFDEC1_REGION2_BASE_NS   (OTFDEC1_BASE_NS + 0x50UL)
#define OTFDEC1_REGION3_BASE_NS   (OTFDEC1_BASE_NS + 0x80UL)
#define OTFDEC1_REGION4_BASE_NS   (OTFDEC1_BASE_NS + 0xB0UL)
#define OTFDEC2_BASE_NS   (AHB2PERIPH_BASE_NS + 0xA5400UL)
#define OTFDEC2_REGION1_BASE_NS   (OTFDEC2_BASE_NS + 0x20UL)
#define OTFDEC2_REGION2_BASE_NS   (OTFDEC2_BASE_NS + 0x50UL)
#define OTFDEC2_REGION3_BASE_NS   (OTFDEC2_BASE_NS + 0x80UL)
#define OTFDEC2_REGION4_BASE_NS   (OTFDEC2_BASE_NS + 0xB0UL)
#define SDMMC1_BASE_NS   (AHB2PERIPH_BASE_NS + 0xA8000UL)
#define SDMMC2_BASE_NS   (AHB2PERIPH_BASE_NS + 0xA8C00UL)
#define DLYB_SDMMC1_BASE_NS   (AHB2PERIPH_BASE_NS + 0xA8400UL)
#define DLYB_SDMMC2_BASE_NS   (AHB2PERIPH_BASE_NS + 0xA8800UL)
#define DLYB_OCTOSPI1_BASE_NS   (AHB2PERIPH_BASE_NS + 0xAF000UL)
#define DLYB_OCTOSPI2_BASE_NS   (AHB2PERIPH_BASE_NS + 0xAF400UL)
#define FMC_R_BASE_NS   (AHB2PERIPH_BASE_NS + 0xB0400UL)
#define FMC_Bank1_R_BASE_NS   (FMC_R_BASE_NS + 0x0000UL)
#define FMC_Bank1E_R_BASE_NS   (FMC_R_BASE_NS + 0x0104UL)
#define FMC_Bank3_R_BASE_NS   (FMC_R_BASE_NS + 0x0080UL)
#define OCTOSPI1_R_BASE_NS   (AHB2PERIPH_BASE_NS + 0xB1400UL)
#define OCTOSPI2_R_BASE_NS   (AHB2PERIPH_BASE_NS + 0xB2400UL)
#define HSPI1_R_BASE_NS   (AHB2PERIPH_BASE_NS + 0xB3400UL)
#define LPGPIO1_BASE_NS   (AHB3PERIPH_BASE_NS)
#define PWR_BASE_NS   (AHB3PERIPH_BASE_NS + 0x0800UL)
#define RCC_BASE_NS   (AHB3PERIPH_BASE_NS + 0x0C00UL)
#define ADC4_BASE_NS   (AHB3PERIPH_BASE_NS + 0x1000UL)
#define ADC4_COMMON_BASE_NS   (AHB3PERIPH_BASE_NS + 0x1300UL)
#define DAC1_BASE_NS   (AHB3PERIPH_BASE_NS + 0x1800UL)
#define EXTI_BASE_NS   (AHB3PERIPH_BASE_NS + 0x2000UL)
#define GTZC_TZSC2_BASE_NS   (AHB3PERIPH_BASE_NS + 0x3000UL)
#define GTZC_TZIC2_BASE_NS   (AHB3PERIPH_BASE_NS + 0x3400UL)
#define GTZC_MPCBB4_BASE_NS   (AHB3PERIPH_BASE_NS + 0x3800UL)
#define ADF1_BASE_NS   (AHB3PERIPH_BASE_NS + 0x4000UL)
#define ADF1_Filter0_BASE_NS   (ADF1_BASE_NS + 0x80UL)
#define LPDMA1_BASE_NS   (AHB3PERIPH_BASE_NS + 0x5000UL)
#define LPDMA1_Channel0_BASE_NS   (LPDMA1_BASE_NS + 0x0050UL)
#define LPDMA1_Channel1_BASE_NS   (LPDMA1_BASE_NS + 0x00D0UL)
#define LPDMA1_Channel2_BASE_NS   (LPDMA1_BASE_NS + 0x0150UL)
#define LPDMA1_Channel3_BASE_NS   (LPDMA1_BASE_NS + 0x01D0UL)
#define GFXMMU_VIRTUAL_BUFFERS_BASE_NS   (0x24000000UL)
#define GFXMMU_VIRTUAL_BUFFER0_BASE_NS   (GFXMMU_VIRTUAL_BUFFERS_BASE_NS)
#define GFXMMU_VIRTUAL_BUFFER1_BASE_NS   (GFXMMU_VIRTUAL_BUFFERS_BASE_NS + 0x400000UL)
#define GFXMMU_VIRTUAL_BUFFER2_BASE_NS   (GFXMMU_VIRTUAL_BUFFERS_BASE_NS + 0x800000UL)
#define GFXMMU_VIRTUAL_BUFFER3_BASE_NS   (GFXMMU_VIRTUAL_BUFFERS_BASE_NS + 0xC00000UL)
#define FLASH_BASE_S   (0x0C000000UL)
#define SRAM1_BASE_S   (0x30000000UL)
#define SRAM2_BASE_S   (0x300C0000UL)
#define SRAM3_BASE_S   (0x300D0000UL)
#define SRAM4_BASE_S   (0x38000000UL)
#define SRAM5_BASE_S   (0x301A0000UL)
#define PERIPH_BASE_S   (0x50000000UL)
#define SRAM6_BASE_S   (0x30270000UL)
#define APB1PERIPH_BASE_S   PERIPH_BASE_S
#define APB2PERIPH_BASE_S   (PERIPH_BASE_S + 0x00010000UL)
#define AHB1PERIPH_BASE_S   (PERIPH_BASE_S + 0x00020000UL)
#define AHB2PERIPH_BASE_S   (PERIPH_BASE_S + 0x02020000UL)
#define APB3PERIPH_BASE_S   (PERIPH_BASE_S + 0x06000000UL)
#define AHB3PERIPH_BASE_S   (PERIPH_BASE_S + 0x06020000UL)
#define TIM2_BASE_S   (APB1PERIPH_BASE_S + 0x0000UL)
#define TIM3_BASE_S   (APB1PERIPH_BASE_S + 0x0400UL)
#define TIM4_BASE_S   (APB1PERIPH_BASE_S + 0x0800UL)
#define TIM5_BASE_S   (APB1PERIPH_BASE_S + 0x0C00UL)
#define TIM6_BASE_S   (APB1PERIPH_BASE_S + 0x1000UL)
#define TIM7_BASE_S   (APB1PERIPH_BASE_S + 0x1400UL)
#define WWDG_BASE_S   (APB1PERIPH_BASE_S + 0x2C00UL)
#define IWDG_BASE_S   (APB1PERIPH_BASE_S + 0x3000UL)
#define SPI2_BASE_S   (APB1PERIPH_BASE_S + 0x3800UL)
#define USART2_BASE_S   (APB1PERIPH_BASE_S + 0x4400UL)
#define USART3_BASE_S   (APB1PERIPH_BASE_S + 0x4800UL)
#define UART4_BASE_S   (APB1PERIPH_BASE_S + 0x4C00UL)
#define UART5_BASE_S   (APB1PERIPH_BASE_S + 0x5000UL)
#define I2C1_BASE_S   (APB1PERIPH_BASE_S + 0x5400UL)
#define I2C2_BASE_S   (APB1PERIPH_BASE_S + 0x5800UL)
#define USART6_BASE_S   (APB1PERIPH_BASE_S + 0x6400UL)
#define I2C4_BASE_S   (APB1PERIPH_BASE_S + 0x8400UL)
#define CRS_BASE_S   (APB1PERIPH_BASE_S + 0x6000UL)
#define LPTIM2_BASE_S   (APB1PERIPH_BASE_S + 0x9400UL)
#define I2C5_BASE_S   (APB1PERIPH_BASE_S + 0x9800UL)
#define I2C6_BASE_S   (APB1PERIPH_BASE_S + 0x9C00UL)
#define FDCAN1_BASE_S   (APB1PERIPH_BASE_S + 0xA400UL)
#define FDCAN_CONFIG_BASE_S   (APB1PERIPH_BASE_S + 0xA500UL)
#define SRAMCAN_BASE_S   (APB1PERIPH_BASE_S + 0xAC00UL)
#define UCPD1_BASE_S   (APB1PERIPH_BASE_S + 0xDC00UL)
#define TIM1_BASE_S   (APB2PERIPH_BASE_S + 0x2C00UL)
#define SPI1_BASE_S   (APB2PERIPH_BASE_S + 0x3000UL)
#define TIM8_BASE_S   (APB2PERIPH_BASE_S + 0x3400UL)
#define USART1_BASE_S   (APB2PERIPH_BASE_S + 0x3800UL)
#define TIM15_BASE_S   (APB2PERIPH_BASE_S + 0x4000UL)
#define TIM16_BASE_S   (APB2PERIPH_BASE_S + 0x4400UL)
#define TIM17_BASE_S   (APB2PERIPH_BASE_S + 0x4800UL)
#define SAI1_BASE_S   (APB2PERIPH_BASE_S + 0x5400UL)
#define SAI1_Block_A_BASE_S   (SAI1_BASE_S + 0x004UL)
#define SAI1_Block_B_BASE_S   (SAI1_BASE_S + 0x024UL)
#define SAI2_BASE_S   (APB2PERIPH_BASE_S + 0x5800UL)
#define SAI2_Block_A_BASE_S   (SAI2_BASE_S + 0x004UL)
#define SAI2_Block_B_BASE_S   (SAI2_BASE_S + 0x024UL)
#define GFXTIM_BASE_S   (APB2PERIPH_BASE_S + 0x6400UL)
#define LTDC_BASE_S   (APB2PERIPH_BASE_S + 0x6800UL)
#define LTDC_Layer1_BASE_S   (LTDC_BASE_S + 0x0084UL)
#define LTDC_Layer2_BASE_S   (LTDC_BASE_S + 0x0104UL)
#define DSI_BASE_S   (APB2PERIPH_BASE_S + 0x6C00UL)
#define REFBIAS_BASE_S   (DSI_BASE_S + 0x800UL)
#define DPHY_BASE_S   (DSI_BASE_S + 0xC00UL)
#define SYSCFG_BASE_S   (APB3PERIPH_BASE_S + 0x0400UL)
#define SPI3_BASE_S   (APB3PERIPH_BASE_S + 0x2000UL)
#define LPUART1_BASE_S   (APB3PERIPH_BASE_S + 0x2400UL)
#define I2C3_BASE_S   (APB3PERIPH_BASE_S + 0x2800UL)
#define LPTIM1_BASE_S   (APB3PERIPH_BASE_S + 0x4400UL)
#define LPTIM3_BASE_S   (APB3PERIPH_BASE_S + 0x4800UL)
#define LPTIM4_BASE_S   (APB3PERIPH_BASE_S + 0x4C00UL)
#define OPAMP_BASE_S   (APB3PERIPH_BASE_S + 0x5000UL)
#define OPAMP1_BASE_S   (APB3PERIPH_BASE_S + 0x5000UL)
#define OPAMP2_BASE_S   (APB3PERIPH_BASE_S + 0x5010UL)
#define COMP12_BASE_S   (APB3PERIPH_BASE_S + 0x5400UL)
#define COMP1_BASE_S   (COMP12_BASE_S)
#define COMP2_BASE_S   (COMP12_BASE_S + 0x04UL)
#define VREFBUF_BASE_S   (APB3PERIPH_BASE_S + 0x7400UL)
#define RTC_BASE_S   (APB3PERIPH_BASE_S + 0x7800UL)
#define TAMP_BASE_S   (APB3PERIPH_BASE_S + 0x7C00UL)
#define GPDMA1_BASE_S   (AHB1PERIPH_BASE_S)
#define GPDMA1_Channel0_BASE_S   (GPDMA1_BASE_S + 0x0050UL)
#define GPDMA1_Channel1_BASE_S   (GPDMA1_BASE_S + 0x00D0UL)
#define GPDMA1_Channel2_BASE_S   (GPDMA1_BASE_S + 0x0150UL)
#define GPDMA1_Channel3_BASE_S   (GPDMA1_BASE_S + 0x01D0UL)
#define GPDMA1_Channel4_BASE_S   (GPDMA1_BASE_S + 0x0250UL)
#define GPDMA1_Channel5_BASE_S   (GPDMA1_BASE_S + 0x02D0UL)
#define GPDMA1_Channel6_BASE_S   (GPDMA1_BASE_S + 0x0350UL)
#define GPDMA1_Channel7_BASE_S   (GPDMA1_BASE_S + 0x03D0UL)
#define GPDMA1_Channel8_BASE_S   (GPDMA1_BASE_S + 0x0450UL)
#define GPDMA1_Channel9_BASE_S   (GPDMA1_BASE_S + 0x04D0UL)
#define GPDMA1_Channel10_BASE_S   (GPDMA1_BASE_S + 0x0550UL)
#define GPDMA1_Channel11_BASE_S   (GPDMA1_BASE_S + 0x05D0UL)
#define GPDMA1_Channel12_BASE_S   (GPDMA1_BASE_S + 0x0650UL)
#define GPDMA1_Channel13_BASE_S   (GPDMA1_BASE_S + 0x06D0UL)
#define GPDMA1_Channel14_BASE_S   (GPDMA1_BASE_S + 0x0750UL)
#define GPDMA1_Channel15_BASE_S   (GPDMA1_BASE_S + 0x07D0UL)
#define CORDIC_BASE_S   (AHB1PERIPH_BASE_S + 0x01000UL)
#define FMAC_BASE_S   (AHB1PERIPH_BASE_S + 0x01400UL)
#define FLASH_R_BASE_S   (AHB1PERIPH_BASE_S + 0x02000UL)
#define CRC_BASE_S   (AHB1PERIPH_BASE_S + 0x03000UL)
#define TSC_BASE_S   (AHB1PERIPH_BASE_S + 0x04000UL)
#define MDF1_BASE_S   (AHB1PERIPH_BASE_S + 0x05000UL)
#define MDF1_Filter0_BASE_S   (MDF1_BASE_S + 0x80UL)
#define MDF1_Filter1_BASE_S   (MDF1_BASE_S + 0x100UL)
#define MDF1_Filter2_BASE_S   (MDF1_BASE_S + 0x180UL)
#define MDF1_Filter3_BASE_S   (MDF1_BASE_S + 0x200UL)
#define MDF1_Filter4_BASE_S   (MDF1_BASE_S + 0x280UL)
#define MDF1_Filter5_BASE_S   (MDF1_BASE_S + 0x300UL)
#define RAMCFG_BASE_S   (AHB1PERIPH_BASE_S + 0x06000UL)
#define RAMCFG_SRAM1_BASE_S   (RAMCFG_BASE_S)
#define RAMCFG_SRAM2_BASE_S   (RAMCFG_BASE_S + 0x0040UL)
#define RAMCFG_SRAM3_BASE_S   (RAMCFG_BASE_S + 0x0080UL)
#define RAMCFG_SRAM4_BASE_S   (RAMCFG_BASE_S + 0x00C0UL)
#define RAMCFG_BKPRAM_BASE_S   (RAMCFG_BASE_S + 0x0100UL)
#define RAMCFG_SRAM5_BASE_S   (RAMCFG_BASE_S + 0x0140UL)
#define RAMCFG_SRAM6_BASE_S   (RAMCFG_BASE_S + 0x0180UL)
#define JPEG_BASE_S   (AHB1PERIPH_BASE_S + 0x0A00UL)
#define DMA2D_BASE_S   (AHB1PERIPH_BASE_S + 0x0B000UL)
#define GFXMMU_BASE_S   (AHB1PERIPH_BASE_S + 0x0C000UL)
#define GPU2D_BASE_S   (AHB1PERIPH_BASE_S + 0x0F000UL)
#define ICACHE_BASE_S   (AHB1PERIPH_BASE_S + 0x10400UL)
#define DCACHE1_BASE_S   (AHB1PERIPH_BASE_S + 0x11400UL)
#define DCACHE2_BASE_S   (AHB1PERIPH_BASE_S + 0x11800UL)
#define GTZC_TZSC1_BASE_S   (AHB1PERIPH_BASE_S + 0x12400UL)
#define GTZC_TZIC1_BASE_S   (AHB1PERIPH_BASE_S + 0x12800UL)
#define GTZC_MPCBB1_BASE_S   (AHB1PERIPH_BASE_S + 0x12C00UL)
#define GTZC_MPCBB2_BASE_S   (AHB1PERIPH_BASE_S + 0x13000UL)
#define GTZC_MPCBB3_BASE_S   (AHB1PERIPH_BASE_S + 0x13400UL)
#define GTZC_MPCBB5_BASE_S   (AHB1PERIPH_BASE_S + 0x13800UL)
#define GTZC_MPCBB6_BASE_S   (AHB1PERIPH_BASE_S + 0x13C00UL)
#define BKPSRAM_BASE_S   (AHB1PERIPH_BASE_S + 0x16400UL)
#define GPIOA_BASE_S   (AHB2PERIPH_BASE_S + 0x00000UL)
#define GPIOB_BASE_S   (AHB2PERIPH_BASE_S + 0x00400UL)
#define GPIOC_BASE_S   (AHB2PERIPH_BASE_S + 0x00800UL)
#define GPIOD_BASE_S   (AHB2PERIPH_BASE_S + 0x00C00UL)
#define GPIOE_BASE_S   (AHB2PERIPH_BASE_S + 0x01000UL)
#define GPIOF_BASE_S   (AHB2PERIPH_BASE_S + 0x01400UL)
#define GPIOG_BASE_S   (AHB2PERIPH_BASE_S + 0x01800UL)
#define GPIOH_BASE_S   (AHB2PERIPH_BASE_S + 0x01C00UL)
#define GPIOI_BASE_S   (AHB2PERIPH_BASE_S + 0x02000UL)
#define GPIOJ_BASE_S   (AHB2PERIPH_BASE_S + 0x02400UL)
#define ADC1_BASE_S   (AHB2PERIPH_BASE_S + 0x08000UL)
#define ADC2_BASE_S   (AHB2PERIPH_BASE_S + 0x08100UL)
#define ADC12_COMMON_BASE_S   (AHB2PERIPH_BASE_S + 0x08300UL)
#define DCMI_BASE_S   (AHB2PERIPH_BASE_S + 0x0C000UL)
#define PSSI_BASE_S   (AHB2PERIPH_BASE_S + 0x0C400UL)
#define USB_OTG_HS_BASE_S   (AHB2PERIPH_BASE_S + 0x20000UL)
#define AES_BASE_S   (AHB2PERIPH_BASE_S + 0xA0000UL)
#define HASH_BASE_S   (AHB2PERIPH_BASE_S + 0xA0400UL)
#define HASH_DIGEST_BASE_S   (AHB2PERIPH_BASE_S + 0xA0710UL)
#define RNG_BASE_S   (AHB2PERIPH_BASE_S + 0xA0800UL)
#define SAES_BASE_S   (AHB2PERIPH_BASE_S + 0xA0C00UL)
#define PKA_BASE_S   (AHB2PERIPH_BASE_S + 0xA2000UL)
#define PKA_RAM_BASE_S   (AHB2PERIPH_BASE_S + 0xA2400UL)
#define OTFDEC1_BASE_S   (AHB2PERIPH_BASE_S + 0xA5000UL)
#define OTFDEC1_REGION1_BASE_S   (OTFDEC1_BASE_S + 0x20UL)
#define OTFDEC1_REGION2_BASE_S   (OTFDEC1_BASE_S + 0x50UL)
#define OTFDEC1_REGION3_BASE_S   (OTFDEC1_BASE_S + 0x80UL)
#define OTFDEC1_REGION4_BASE_S   (OTFDEC1_BASE_S + 0xB0UL)
#define OTFDEC2_BASE_S   (AHB2PERIPH_BASE_S + 0xA5400UL)
#define OTFDEC2_REGION1_BASE_S   (OTFDEC2_BASE_S + 0x20UL)
#define OTFDEC2_REGION2_BASE_S   (OTFDEC2_BASE_S + 0x50UL)
#define OTFDEC2_REGION3_BASE_S   (OTFDEC2_BASE_S + 0x80UL)
#define OTFDEC2_REGION4_BASE_S   (OTFDEC2_BASE_S + 0xB0UL)
#define OCTOSPIM_R_BASE_S   (AHB2PERIPH_BASE_S + 0xA4000UL)
#define SDMMC1_BASE_S   (AHB2PERIPH_BASE_S + 0xA8000UL)
#define SDMMC2_BASE_S   (AHB2PERIPH_BASE_S + 0xA8C00UL)
#define DLYB_SDMMC1_BASE_S   (AHB2PERIPH_BASE_S + 0xA8400UL)
#define DLYB_SDMMC2_BASE_S   (AHB2PERIPH_BASE_S + 0xA8800UL)
#define DLYB_OCTOSPI1_BASE_S   (AHB2PERIPH_BASE_S + 0xAF000UL)
#define DLYB_OCTOSPI2_BASE_S   (AHB2PERIPH_BASE_S + 0xAF400UL)
#define FMC_R_BASE_S   (AHB2PERIPH_BASE_S + 0xB0400UL)
#define HSPI1_R_BASE_S   (AHB2PERIPH_BASE_S + 0xB3400UL)
#define FMC_Bank1_R_BASE_S   (FMC_R_BASE_S + 0x0000UL)
#define FMC_Bank1E_R_BASE_S   (FMC_R_BASE_S + 0x0104UL)
#define FMC_Bank3_R_BASE_S   (FMC_R_BASE_S + 0x0080UL)
#define OCTOSPI1_R_BASE_S   (AHB2PERIPH_BASE_S + 0xB1400UL)
#define OCTOSPI2_R_BASE_S   (AHB2PERIPH_BASE_S + 0xB2400UL)
#define LPGPIO1_BASE_S   (AHB3PERIPH_BASE_S)
#define PWR_BASE_S   (AHB3PERIPH_BASE_S + 0x0800UL)
#define RCC_BASE_S   (AHB3PERIPH_BASE_S + 0x0C00UL)
#define ADC4_BASE_S   (AHB3PERIPH_BASE_S + 0x1000UL)
#define ADC4_COMMON_BASE_S   (AHB3PERIPH_BASE_S + 0x1300UL)
#define DAC1_BASE_S   (AHB3PERIPH_BASE_S + 0x1800UL)
#define EXTI_BASE_S   (AHB3PERIPH_BASE_S + 0x2000UL)
#define GTZC_TZSC2_BASE_S   (AHB3PERIPH_BASE_S + 0x3000UL)
#define GTZC_TZIC2_BASE_S   (AHB3PERIPH_BASE_S + 0x3400UL)
#define GTZC_MPCBB4_BASE_S   (AHB3PERIPH_BASE_S + 0x3800UL)
#define ADF1_BASE_S   (AHB3PERIPH_BASE_S + 0x4000UL)
#define ADF1_Filter0_BASE_S   (ADF1_BASE_S + 0x80UL)
#define LPDMA1_BASE_S   (AHB3PERIPH_BASE_S + 0x5000UL)
#define LPDMA1_Channel0_BASE_S   (LPDMA1_BASE_S + 0x0050UL)
#define LPDMA1_Channel1_BASE_S   (LPDMA1_BASE_S + 0x00D0UL)
#define LPDMA1_Channel2_BASE_S   (LPDMA1_BASE_S + 0x0150UL)
#define LPDMA1_Channel3_BASE_S   (LPDMA1_BASE_S + 0x01D0UL)
#define GFXMMU_VIRTUAL_BUFFERS_BASE_S   (0x34000000UL)
#define GFXMMU_VIRTUAL_BUFFER0_BASE_S   (GFXMMU_VIRTUAL_BUFFERS_BASE_S)
#define GFXMMU_VIRTUAL_BUFFER1_BASE_S   (GFXMMU_VIRTUAL_BUFFERS_BASE_S + 0x400000UL)
#define GFXMMU_VIRTUAL_BUFFER2_BASE_S   (GFXMMU_VIRTUAL_BUFFERS_BASE_S + 0x800000UL)
#define GFXMMU_VIRTUAL_BUFFER3_BASE_S   (GFXMMU_VIRTUAL_BUFFERS_BASE_S + 0xC00000UL)
#define DBGMCU_BASE   (0xE0044000UL)
#define PACKAGE_BASE   (0x0BFA0500UL)
#define UID_BASE   (0x0BFA0700UL)
#define FLASHSIZE_BASE   (0x0BFA07A0UL)
#define FLASH_OTP_BASE   (0x0BFA0000UL)
#define FLASH_OTP_SIZE   (0x200U)
#define USB_OTG_GLOBAL_BASE   (0x0000UL)
#define USB_OTG_DEVICE_BASE   (0x0800UL)
#define USB_OTG_IN_ENDPOINT_BASE   (0x0900UL)
#define USB_OTG_OUT_ENDPOINT_BASE   (0x0B00UL)
#define USB_OTG_EP_REG_SIZE   (0x0020UL)
#define USB_OTG_HOST_BASE   (0x0400UL)
#define USB_OTG_HOST_PORT_BASE   (0x0440UL)
#define USB_OTG_HOST_CHANNEL_BASE   (0x0500UL)
#define USB_OTG_HOST_CHANNEL_SIZE   (0x0020UL)
#define USB_OTG_PCGCCTL_BASE   (0x0E00UL)
#define USB_OTG_FIFO_BASE   (0x1000UL)
#define USB_OTG_FIFO_SIZE   (0x1000UL)
#define RSSLIB_SYS_FLASH_NS_PFUNC_START   (0x0BF99E40UL)
#define RSSLIB_SYS_FLASH_NS_PFUNC_END   (0x0BF99EFFUL)
#define RSSLIB_ERROR   (0xF5F5F5F5UL)
#define RSSLIB_SUCCESS   (0xEAEAEAEAUL)
#define RSSLIB_PFUNC_BASE   RSSLIB_SYS_FLASH_NS_PFUNC_START
#define RSSLIB_PFUNC   ((RSSLIB_pFunc_TypeDef *)RSSLIB_PFUNC_BASE)
#define RSSLIB_HDP_AREA_Pos   (0U)
#define RSSLIB_HDP_AREA_Msk   (0x3UL << RSSLIB_HDP_AREA_Pos )
#define RSSLIB_HDP_AREA1_Pos   (0U)
#define RSSLIB_HDP_AREA1_Msk   (0x1UL << RSSLIB_HDP_AREA1_Pos )
#define RSSLIB_HDP_AREA2_Pos   (1U)
#define RSSLIB_HDP_AREA2_Msk   (0x1UL << RSSLIB_HDP_AREA2_Pos )
#define TIM2_NS   ((TIM_TypeDef *) TIM2_BASE_NS)
#define TIM3_NS   ((TIM_TypeDef *) TIM3_BASE_NS)
#define TIM4_NS   ((TIM_TypeDef *) TIM4_BASE_NS)
#define TIM5_NS   ((TIM_TypeDef *) TIM5_BASE_NS)
#define TIM6_NS   ((TIM_TypeDef *) TIM6_BASE_NS)
#define TIM7_NS   ((TIM_TypeDef *) TIM7_BASE_NS)
#define WWDG_NS   ((WWDG_TypeDef *) WWDG_BASE_NS)
#define IWDG_NS   ((IWDG_TypeDef *) IWDG_BASE_NS)
#define SPI2_NS   ((SPI_TypeDef *) SPI2_BASE_NS)
#define USART2_NS   ((USART_TypeDef *) USART2_BASE_NS)
#define USART3_NS   ((USART_TypeDef *) USART3_BASE_NS)
#define UART4_NS   ((USART_TypeDef *) UART4_BASE_NS)
#define UART5_NS   ((USART_TypeDef *) UART5_BASE_NS)
#define I2C1_NS   ((I2C_TypeDef *) I2C1_BASE_NS)
#define I2C2_NS   ((I2C_TypeDef *) I2C2_BASE_NS)
#define CRS_NS   ((CRS_TypeDef *) CRS_BASE_NS)
#define USART6_NS   ((USART_TypeDef *) USART6_BASE_NS)
#define I2C5_NS   ((I2C_TypeDef *) I2C5_BASE_NS)
#define I2C6_NS   ((I2C_TypeDef *) I2C6_BASE_NS)
#define I2C4_NS   ((I2C_TypeDef *) I2C4_BASE_NS)
#define LPTIM2_NS   ((LPTIM_TypeDef *) LPTIM2_BASE_NS)
#define FDCAN1_NS   ((FDCAN_GlobalTypeDef *) FDCAN1_BASE_NS)
#define FDCAN_CONFIG_NS   ((FDCAN_Config_TypeDef *) FDCAN_CONFIG_BASE_NS)
#define UCPD1_NS   ((UCPD_TypeDef *) UCPD1_BASE_NS)
#define TIM1_NS   ((TIM_TypeDef *) TIM1_BASE_NS)
#define SPI1_NS   ((SPI_TypeDef *) SPI1_BASE_NS)
#define TIM8_NS   ((TIM_TypeDef *) TIM8_BASE_NS)
#define USART1_NS   ((USART_TypeDef *) USART1_BASE_NS)
#define TIM15_NS   ((TIM_TypeDef *) TIM15_BASE_NS)
#define TIM16_NS   ((TIM_TypeDef *) TIM16_BASE_NS)
#define TIM17_NS   ((TIM_TypeDef *) TIM17_BASE_NS)
#define SAI1_NS   ((SAI_TypeDef *) SAI1_BASE_NS)
#define SAI1_Block_A_NS   ((SAI_Block_TypeDef *)SAI1_Block_A_BASE_NS)
#define SAI1_Block_B_NS   ((SAI_Block_TypeDef *)SAI1_Block_B_BASE_NS)
#define SAI2_NS   ((SAI_TypeDef *) SAI2_BASE_NS)
#define SAI2_Block_A_NS   ((SAI_Block_TypeDef *)SAI2_Block_A_BASE_NS)
#define SAI2_Block_B_NS   ((SAI_Block_TypeDef *)SAI2_Block_B_BASE_NS)
#define LTDC_NS   ((LTDC_TypeDef *) LTDC_BASE_NS)
#define LTDC_Layer1_NS   ((LTDC_Layer_TypeDef *) LTDC_Layer1_BASE_NS)
#define LTDC_Layer2_NS   ((LTDC_Layer_TypeDef *) LTDC_Layer2_BASE_NS)
#define DSI_NS   ((DSI_TypeDef *) DSI_BASE_NS)
#define REFBIAS_NS   ((REFBIAS_TypeDef *) REFBIAS_BASE_NS)
#define DPHY_NS   ((DPHY_TypeDef *) DPHY_BASE_NS)
#define GFXTIM_NS   ((GFXTIM_TypeDef *) GFXTIM_BASE_NS)
#define SYSCFG_NS   ((SYSCFG_TypeDef *) SYSCFG_BASE_NS)
#define SPI3_NS   ((SPI_TypeDef *) SPI3_BASE_NS)
#define LPUART1_NS   ((USART_TypeDef *) LPUART1_BASE_NS)
#define I2C3_NS   ((I2C_TypeDef *) I2C3_BASE_NS)
#define LPTIM1_NS   ((LPTIM_TypeDef *) LPTIM1_BASE_NS)
#define LPTIM3_NS   ((LPTIM_TypeDef *) LPTIM3_BASE_NS)
#define LPTIM4_NS   ((LPTIM_TypeDef *) LPTIM4_BASE_NS)
#define OPAMP_NS   ((OPAMP_TypeDef *) OPAMP_BASE_NS)
#define OPAMP1_NS   ((OPAMP_TypeDef *) OPAMP1_BASE_NS)
#define OPAMP2_NS   ((OPAMP_TypeDef *) OPAMP2_BASE_NS)
#define OPAMP12_COMMON_NS   ((OPAMP_Common_TypeDef *) OPAMP1_BASE_NS)
#define COMP12_NS   ((COMP_TypeDef *) COMP12_BASE_NS)
#define COMP1_NS   ((COMP_TypeDef *) COMP1_BASE_NS)
#define COMP2_NS   ((COMP_TypeDef *) COMP2_BASE_NS)
#define COMP12_COMMON_NS   ((COMP_Common_TypeDef *) COMP1_BASE_NS)
#define VREFBUF_NS   ((VREFBUF_TypeDef *) VREFBUF_BASE_NS)
#define RTC_NS   ((RTC_TypeDef *) RTC_BASE_NS)
#define TAMP_NS   ((TAMP_TypeDef *) TAMP_BASE_NS)
#define GPDMA1_NS   ((DMA_TypeDef *) GPDMA1_BASE_NS)
#define GPDMA1_Channel0_NS   ((DMA_Channel_TypeDef *) GPDMA1_Channel0_BASE_NS)
#define GPDMA1_Channel1_NS   ((DMA_Channel_TypeDef *) GPDMA1_Channel1_BASE_NS)
#define GPDMA1_Channel2_NS   ((DMA_Channel_TypeDef *) GPDMA1_Channel2_BASE_NS)
#define GPDMA1_Channel3_NS   ((DMA_Channel_TypeDef *) GPDMA1_Channel3_BASE_NS)
#define GPDMA1_Channel4_NS   ((DMA_Channel_TypeDef *) GPDMA1_Channel4_BASE_NS)
#define GPDMA1_Channel5_NS   ((DMA_Channel_TypeDef *) GPDMA1_Channel5_BASE_NS)
#define GPDMA1_Channel6_NS   ((DMA_Channel_TypeDef *) GPDMA1_Channel6_BASE_NS)
#define GPDMA1_Channel7_NS   ((DMA_Channel_TypeDef *) GPDMA1_Channel7_BASE_NS)
#define GPDMA1_Channel8_NS   ((DMA_Channel_TypeDef *) GPDMA1_Channel8_BASE_NS)
#define GPDMA1_Channel9_NS   ((DMA_Channel_TypeDef *) GPDMA1_Channel9_BASE_NS)
#define GPDMA1_Channel10_NS   ((DMA_Channel_TypeDef *) GPDMA1_Channel10_BASE_NS)
#define GPDMA1_Channel11_NS   ((DMA_Channel_TypeDef *) GPDMA1_Channel11_BASE_NS)
#define GPDMA1_Channel12_NS   ((DMA_Channel_TypeDef *) GPDMA1_Channel12_BASE_NS)
#define GPDMA1_Channel13_NS   ((DMA_Channel_TypeDef *) GPDMA1_Channel13_BASE_NS)
#define GPDMA1_Channel14_NS   ((DMA_Channel_TypeDef *) GPDMA1_Channel14_BASE_NS)
#define GPDMA1_Channel15_NS   ((DMA_Channel_TypeDef *) GPDMA1_Channel15_BASE_NS)
#define CORDIC_NS   ((CORDIC_TypeDef *) CORDIC_BASE_NS)
#define FMAC_NS   ((FMAC_TypeDef *) FMAC_BASE_NS)
#define FLASH_NS   ((FLASH_TypeDef *) FLASH_R_BASE_NS)
#define CRC_NS   ((CRC_TypeDef *) CRC_BASE_NS)
#define TSC_NS   ((TSC_TypeDef *) TSC_BASE_NS)
#define MDF1_NS   ((MDF_TypeDef *) MDF1_BASE_NS)
#define MDF1_Filter0_NS   ((MDF_Filter_TypeDef*) MDF1_Filter0_BASE_NS)
#define MDF1_Filter1_NS   ((MDF_Filter_TypeDef*) MDF1_Filter1_BASE_NS)
#define MDF1_Filter2_NS   ((MDF_Filter_TypeDef*) MDF1_Filter2_BASE_NS)
#define MDF1_Filter3_NS   ((MDF_Filter_TypeDef*) MDF1_Filter3_BASE_NS)
#define MDF1_Filter4_NS   ((MDF_Filter_TypeDef*) MDF1_Filter4_BASE_NS)
#define MDF1_Filter5_NS   ((MDF_Filter_TypeDef*) MDF1_Filter5_BASE_NS)
#define RAMCFG_SRAM1_NS   ((RAMCFG_TypeDef *) RAMCFG_SRAM1_BASE_NS)
#define RAMCFG_SRAM2_NS   ((RAMCFG_TypeDef *) RAMCFG_SRAM2_BASE_NS)
#define RAMCFG_SRAM3_NS   ((RAMCFG_TypeDef *) RAMCFG_SRAM3_BASE_NS)
#define RAMCFG_SRAM4_NS   ((RAMCFG_TypeDef *) RAMCFG_SRAM4_BASE_NS)
#define RAMCFG_SRAM5_NS   ((RAMCFG_TypeDef *) RAMCFG_SRAM5_BASE_NS)
#define RAMCFG_SRAM6_NS   ((RAMCFG_TypeDef *) RAMCFG_SRAM6_BASE_NS)
#define JPEG_NS   ((JPEG_TypeDef *) JPEG_BASE_NS)
#define RAMCFG_BKPRAM_NS   ((RAMCFG_TypeDef *) RAMCFG_BKPRAM_BASE_NS)
#define DMA2D_NS   ((DMA2D_TypeDef *) DMA2D_BASE_NS)
#define ICACHE_NS   ((ICACHE_TypeDef *) ICACHE_BASE_NS)
#define DCACHE1_NS   ((DCACHE_TypeDef *) DCACHE1_BASE_NS)
#define DCACHE2_NS   ((DCACHE_TypeDef *) DCACHE2_BASE_NS)
#define GTZC_TZSC1_NS   ((GTZC_TZSC_TypeDef *) GTZC_TZSC1_BASE_NS)
#define GTZC_TZIC1_NS   ((GTZC_TZIC_TypeDef *) GTZC_TZIC1_BASE_NS)
#define GTZC_MPCBB1_NS   ((GTZC_MPCBB_TypeDef *) GTZC_MPCBB1_BASE_NS)
#define GTZC_MPCBB2_NS   ((GTZC_MPCBB_TypeDef *) GTZC_MPCBB2_BASE_NS)
#define GTZC_MPCBB3_NS   ((GTZC_MPCBB_TypeDef *) GTZC_MPCBB3_BASE_NS)
#define GTZC_MPCBB5_NS   ((GTZC_MPCBB_TypeDef *) GTZC_MPCBB5_BASE_NS)
#define GTZC_MPCBB6_NS   ((GTZC_MPCBB_TypeDef *) GTZC_MPCBB6_BASE_NS)
#define GFXMMU_NS   ((GFXMMU_TypeDef *) GFXMMU_BASE_NS)
#define GPIOA_NS   ((GPIO_TypeDef *) GPIOA_BASE_NS)
#define GPIOB_NS   ((GPIO_TypeDef *) GPIOB_BASE_NS)
#define GPIOC_NS   ((GPIO_TypeDef *) GPIOC_BASE_NS)
#define GPIOD_NS   ((GPIO_TypeDef *) GPIOD_BASE_NS)
#define GPIOE_NS   ((GPIO_TypeDef *) GPIOE_BASE_NS)
#define GPIOF_NS   ((GPIO_TypeDef *) GPIOF_BASE_NS)
#define GPIOG_NS   ((GPIO_TypeDef *) GPIOG_BASE_NS)
#define GPIOH_NS   ((GPIO_TypeDef *) GPIOH_BASE_NS)
#define GPIOI_NS   ((GPIO_TypeDef *) GPIOI_BASE_NS)
#define GPIOJ_NS   ((GPIO_TypeDef *) GPIOJ_BASE_NS)
#define ADC1_NS   ((ADC_TypeDef *) ADC1_BASE_NS)
#define ADC2_NS   ((ADC_TypeDef *) ADC2_BASE_NS)
#define ADC12_COMMON_NS   ((ADC_Common_TypeDef *) ADC12_COMMON_BASE_NS)
#define DCMI_NS   ((DCMI_TypeDef *) DCMI_BASE_NS)
#define PSSI_NS   ((PSSI_TypeDef *) PSSI_BASE_NS)
#define USB_OTG_HS_NS   ((USB_OTG_GlobalTypeDef *) USB_OTG_HS_BASE_NS)
#define AES_NS   ((AES_TypeDef *) AES_BASE_NS)
#define HASH_NS   ((HASH_TypeDef *) HASH_BASE_NS)
#define HASH_DIGEST_NS   ((HASH_DIGEST_TypeDef *) HASH_DIGEST_BASE_NS)
#define RNG_NS   ((RNG_TypeDef *) RNG_BASE_NS)
#define SAES_NS   ((AES_TypeDef *) SAES_BASE_NS)
#define PKA_NS   ((PKA_TypeDef *) PKA_BASE_NS)
#define OTFDEC1_NS   ((OTFDEC_TypeDef *) OTFDEC1_BASE_NS)
#define OTFDEC1_REGION1_NS   ((OTFDEC_Region_TypeDef *) OTFDEC1_REGION1_BASE_NS)
#define OTFDEC1_REGION2_NS   ((OTFDEC_Region_TypeDef *) OTFDEC1_REGION2_BASE_NS)
#define OTFDEC1_REGION3_NS   ((OTFDEC_Region_TypeDef *) OTFDEC1_REGION3_BASE_NS)
#define OTFDEC1_REGION4_NS   ((OTFDEC_Region_TypeDef *) OTFDEC1_REGION4_BASE_NS)
#define OTFDEC2_NS   ((OTFDEC_TypeDef *) OTFDEC2_BASE_NS)
#define OTFDEC2_REGION1_NS   ((OTFDEC_Region_TypeDef *) OTFDEC2_REGION1_BASE_NS)
#define OTFDEC2_REGION2_NS   ((OTFDEC_Region_TypeDef *) OTFDEC2_REGION2_BASE_NS)
#define OTFDEC2_REGION3_NS   ((OTFDEC_Region_TypeDef *) OTFDEC2_REGION3_BASE_NS)
#define OTFDEC2_REGION4_NS   ((OTFDEC_Region_TypeDef *) OTFDEC2_REGION4_BASE_NS)
#define SDMMC1_NS   ((SDMMC_TypeDef *) SDMMC1_BASE_NS)
#define SDMMC2_NS   ((SDMMC_TypeDef *) SDMMC2_BASE_NS)
#define DLYB_SDMMC1_NS   ((DLYB_TypeDef *) DLYB_SDMMC1_BASE_NS)
#define DLYB_SDMMC2_NS   ((DLYB_TypeDef *) DLYB_SDMMC2_BASE_NS)
#define DLYB_OCTOSPI1_NS   ((DLYB_TypeDef *) DLYB_OCTOSPI1_BASE_NS)
#define DLYB_OCTOSPI2_NS   ((DLYB_TypeDef *) DLYB_OCTOSPI2_BASE_NS)
#define FMC_Bank1_R_NS   ((FMC_Bank1_TypeDef *) FMC_Bank1_R_BASE_NS)
#define FMC_Bank1E_R_NS   ((FMC_Bank1E_TypeDef *) FMC_Bank1E_R_BASE_NS)
#define FMC_Bank3_R_NS   ((FMC_Bank3_TypeDef *) FMC_Bank3_R_BASE_NS)
#define OCTOSPIM_NS   ((OCTOSPIM_TypeDef *) OCTOSPIM_R_BASE_NS)
#define OCTOSPI1_NS   ((OCTOSPI_TypeDef *) OCTOSPI1_R_BASE_NS)
#define OCTOSPI2_NS   ((OCTOSPI_TypeDef *) OCTOSPI2_R_BASE_NS)
#define HSPI1_NS   ((HSPI_TypeDef *) HSPI1_R_BASE_NS)
#define LPGPIO1_NS   ((GPIO_TypeDef *) LPGPIO1_BASE_NS)
#define PWR_NS   ((PWR_TypeDef *) PWR_BASE_NS)
#define RCC_NS   ((RCC_TypeDef *) RCC_BASE_NS)
#define ADC4_NS   ((ADC_TypeDef *) ADC4_BASE_NS)
#define ADC4_COMMON_NS   ((ADC_Common_TypeDef *) ADC4_COMMON_BASE_NS)
#define DAC1_NS   ((DAC_TypeDef *) DAC1_BASE_NS)
#define EXTI_NS   ((EXTI_TypeDef *) EXTI_BASE_NS)
#define GTZC_TZSC2_NS   ((GTZC_TZSC_TypeDef *) GTZC_TZSC2_BASE_NS)
#define GTZC_TZIC2_NS   ((GTZC_TZIC_TypeDef *) GTZC_TZIC2_BASE_NS)
#define GTZC_MPCBB4_NS   ((GTZC_MPCBB_TypeDef *) GTZC_MPCBB4_BASE_NS)
#define ADF1_NS   ((MDF_TypeDef *) ADF1_BASE_NS)
#define ADF1_Filter0_NS   ((MDF_Filter_TypeDef*) ADF1_Filter0_BASE_NS)
#define LPDMA1_NS   ((DMA_TypeDef *) LPDMA1_BASE_NS)
#define LPDMA1_Channel0_NS   ((DMA_Channel_TypeDef *) LPDMA1_Channel0_BASE_NS)
#define LPDMA1_Channel1_NS   ((DMA_Channel_TypeDef *) LPDMA1_Channel1_BASE_NS)
#define LPDMA1_Channel2_NS   ((DMA_Channel_TypeDef *) LPDMA1_Channel2_BASE_NS)
#define LPDMA1_Channel3_NS   ((DMA_Channel_TypeDef *) LPDMA1_Channel3_BASE_NS)
#define TIM2_S   ((TIM_TypeDef *) TIM2_BASE_S)
#define TIM3_S   ((TIM_TypeDef *) TIM3_BASE_S)
#define TIM4_S   ((TIM_TypeDef *) TIM4_BASE_S)
#define TIM5_S   ((TIM_TypeDef *) TIM5_BASE_S)
#define TIM6_S   ((TIM_TypeDef *) TIM6_BASE_S)
#define TIM7_S   ((TIM_TypeDef *) TIM7_BASE_S)
#define WWDG_S   ((WWDG_TypeDef *) WWDG_BASE_S)
#define IWDG_S   ((IWDG_TypeDef *) IWDG_BASE_S)
#define SPI2_S   ((SPI_TypeDef *) SPI2_BASE_S)
#define USART2_S   ((USART_TypeDef *) USART2_BASE_S)
#define USART3_S   ((USART_TypeDef *) USART3_BASE_S)
#define UART4_S   ((USART_TypeDef *) UART4_BASE_S)
#define UART5_S   ((USART_TypeDef *) UART5_BASE_S)
#define I2C1_S   ((I2C_TypeDef *) I2C1_BASE_S)
#define I2C2_S   ((I2C_TypeDef *) I2C2_BASE_S)
#define CRS_S   ((CRS_TypeDef *) CRS_BASE_S)
#define USART6_S   ((USART_TypeDef *) USART6_BASE_S)
#define I2C5_S   ((I2C_TypeDef *) I2C5_BASE_S)
#define I2C6_S   ((I2C_TypeDef *) I2C6_BASE_S)
#define I2C4_S   ((I2C_TypeDef *) I2C4_BASE_S)
#define LPTIM2_S   ((LPTIM_TypeDef *) LPTIM2_BASE_S)
#define FDCAN1_S   ((FDCAN_GlobalTypeDef *) FDCAN1_BASE_S)
#define FDCAN_CONFIG_S   ((FDCAN_Config_TypeDef *) FDCAN_CONFIG_BASE_S)
#define UCPD1_S   ((UCPD_TypeDef *) UCPD1_BASE_S)
#define TIM1_S   ((TIM_TypeDef *) TIM1_BASE_S)
#define SPI1_S   ((SPI_TypeDef *) SPI1_BASE_S)
#define TIM8_S   ((TIM_TypeDef *) TIM8_BASE_S)
#define USART1_S   ((USART_TypeDef *) USART1_BASE_S)
#define TIM15_S   ((TIM_TypeDef *) TIM15_BASE_S)
#define TIM16_S   ((TIM_TypeDef *) TIM16_BASE_S)
#define TIM17_S   ((TIM_TypeDef *) TIM17_BASE_S)
#define SAI1_S   ((SAI_TypeDef *) SAI1_BASE_S)
#define SAI1_Block_A_S   ((SAI_Block_TypeDef *)SAI1_Block_A_BASE_S)
#define SAI1_Block_B_S   ((SAI_Block_TypeDef *)SAI1_Block_B_BASE_S)
#define SAI2_S   ((SAI_TypeDef *) SAI2_BASE_S)
#define SAI2_Block_A_S   ((SAI_Block_TypeDef *)SAI2_Block_A_BASE_S)
#define SAI2_Block_B_S   ((SAI_Block_TypeDef *)SAI2_Block_B_BASE_S)
#define LTDC_S   ((LTDC_TypeDef *) LTDC_BASE_S)
#define LTDC_Layer1_S   ((LTDC_Layer_TypeDef *) LTDC_Layer1_BASE_S)
#define LTDC_Layer2_S   ((LTDC_Layer_TypeDef *) LTDC_Layer2_BASE_S)
#define DSI_S   ((DSI_TypeDef *) DSI_BASE_S)
#define REFBIAS_S   ((REFBIAS_TypeDef *) REFBIAS_BASE_S)
#define DPHY_S   ((DPHY_TypeDef *) DPHY_BASE_S)
#define GFXTIM_S   ((GFXTIM_TypeDef *) GFXTIM_BASE_S)
#define SYSCFG_S   ((SYSCFG_TypeDef *) SYSCFG_BASE_S)
#define SPI3_S   ((SPI_TypeDef *) SPI3_BASE_S)
#define LPUART1_S   ((USART_TypeDef *) LPUART1_BASE_S)
#define I2C3_S   ((I2C_TypeDef *) I2C3_BASE_S)
#define LPTIM1_S   ((LPTIM_TypeDef *) LPTIM1_BASE_S)
#define LPTIM3_S   ((LPTIM_TypeDef *) LPTIM3_BASE_S)
#define LPTIM4_S   ((LPTIM_TypeDef *) LPTIM4_BASE_S)
#define OPAMP_S   ((OPAMP_TypeDef *) OPAMP_BASE_S)
#define OPAMP1_S   ((OPAMP_TypeDef *) OPAMP1_BASE_S)
#define OPAMP2_S   ((OPAMP_TypeDef *) OPAMP2_BASE_S)
#define OPAMP12_COMMON_S   ((OPAMP_Common_TypeDef *) OPAMP1_BASE_S)
#define COMP12_S   ((COMP_TypeDef *) COMP12_BASE_S)
#define COMP1_S   ((COMP_TypeDef *) COMP1_BASE_S)
#define COMP2_S   ((COMP_TypeDef *) COMP2_BASE_S)
#define COMP12_COMMON_S   ((COMP_Common_TypeDef *) COMP1_BASE_S)
#define VREFBUF_S   ((VREFBUF_TypeDef *) VREFBUF_BASE_S)
#define RTC_S   ((RTC_TypeDef *) RTC_BASE_S)
#define TAMP_S   ((TAMP_TypeDef *) TAMP_BASE_S)
#define GPDMA1_S   ((DMA_TypeDef *) GPDMA1_BASE_S)
#define GPDMA1_Channel0_S   ((DMA_Channel_TypeDef *) GPDMA1_Channel0_BASE_S)
#define GPDMA1_Channel1_S   ((DMA_Channel_TypeDef *) GPDMA1_Channel1_BASE_S)
#define GPDMA1_Channel2_S   ((DMA_Channel_TypeDef *) GPDMA1_Channel2_BASE_S)
#define GPDMA1_Channel3_S   ((DMA_Channel_TypeDef *) GPDMA1_Channel3_BASE_S)
#define GPDMA1_Channel4_S   ((DMA_Channel_TypeDef *) GPDMA1_Channel4_BASE_S)
#define GPDMA1_Channel5_S   ((DMA_Channel_TypeDef *) GPDMA1_Channel5_BASE_S)
#define GPDMA1_Channel6_S   ((DMA_Channel_TypeDef *) GPDMA1_Channel6_BASE_S)
#define GPDMA1_Channel7_S   ((DMA_Channel_TypeDef *) GPDMA1_Channel7_BASE_S)
#define GPDMA1_Channel8_S   ((DMA_Channel_TypeDef *) GPDMA1_Channel8_BASE_S)
#define GPDMA1_Channel9_S   ((DMA_Channel_TypeDef *) GPDMA1_Channel9_BASE_S)
#define GPDMA1_Channel10_S   ((DMA_Channel_TypeDef *) GPDMA1_Channel10_BASE_S)
#define GPDMA1_Channel11_S   ((DMA_Channel_TypeDef *) GPDMA1_Channel11_BASE_S)
#define GPDMA1_Channel12_S   ((DMA_Channel_TypeDef *) GPDMA1_Channel12_BASE_S)
#define GPDMA1_Channel13_S   ((DMA_Channel_TypeDef *) GPDMA1_Channel13_BASE_S)
#define GPDMA1_Channel14_S   ((DMA_Channel_TypeDef *) GPDMA1_Channel14_BASE_S)
#define GPDMA1_Channel15_S   ((DMA_Channel_TypeDef *) GPDMA1_Channel15_BASE_S)
#define CORDIC_S   ((CORDIC_TypeDef *) CORDIC_BASE_S)
#define FMAC_S   ((FMAC_TypeDef *) FMAC_BASE_S)
#define FLASH_S   ((FLASH_TypeDef *) FLASH_R_BASE_S)
#define CRC_S   ((CRC_TypeDef *) CRC_BASE_S)
#define TSC_S   ((TSC_TypeDef *) TSC_BASE_S)
#define MDF1_S   ((MDF_TypeDef *) MDF1_BASE_S)
#define MDF1_Filter0_S   ((MDF_Filter_TypeDef*) MDF1_Filter0_BASE_S)
#define MDF1_Filter1_S   ((MDF_Filter_TypeDef*) MDF1_Filter1_BASE_S)
#define MDF1_Filter2_S   ((MDF_Filter_TypeDef*) MDF1_Filter2_BASE_S)
#define MDF1_Filter3_S   ((MDF_Filter_TypeDef*) MDF1_Filter3_BASE_S)
#define MDF1_Filter4_S   ((MDF_Filter_TypeDef*) MDF1_Filter4_BASE_S)
#define MDF1_Filter5_S   ((MDF_Filter_TypeDef*) MDF1_Filter5_BASE_S)
#define RAMCFG_SRAM1_S   ((RAMCFG_TypeDef *) RAMCFG_SRAM1_BASE_S)
#define RAMCFG_SRAM2_S   ((RAMCFG_TypeDef *) RAMCFG_SRAM2_BASE_S)
#define RAMCFG_SRAM3_S   ((RAMCFG_TypeDef *) RAMCFG_SRAM3_BASE_S)
#define RAMCFG_SRAM4_S   ((RAMCFG_TypeDef *) RAMCFG_SRAM4_BASE_S)
#define RAMCFG_SRAM5_S   ((RAMCFG_TypeDef *) RAMCFG_SRAM5_BASE_S)
#define RAMCFG_SRAM6_S   ((RAMCFG_TypeDef *) RAMCFG_SRAM6_BASE_S)
#define JPEG_S   ((JPEG_TypeDef *) JPEG_BASE_S)
#define RAMCFG_BKPRAM_S   ((RAMCFG_TypeDef *) RAMCFG_BKPRAM_BASE_S)
#define DMA2D_S   ((DMA2D_TypeDef *) DMA2D_BASE_S)
#define ICACHE_S   ((ICACHE_TypeDef *) ICACHE_BASE_S)
#define DCACHE1_S   ((DCACHE_TypeDef *) DCACHE1_BASE_S)
#define DCACHE2_S   ((DCACHE_TypeDef *) DCACHE2_BASE_S)
#define GTZC_TZSC1_S   ((GTZC_TZSC_TypeDef *) GTZC_TZSC1_BASE_S)
#define GTZC_TZIC1_S   ((GTZC_TZIC_TypeDef *) GTZC_TZIC1_BASE_S)
#define GTZC_MPCBB1_S   ((GTZC_MPCBB_TypeDef *) GTZC_MPCBB1_BASE_S)
#define GTZC_MPCBB2_S   ((GTZC_MPCBB_TypeDef *) GTZC_MPCBB2_BASE_S)
#define GTZC_MPCBB3_S   ((GTZC_MPCBB_TypeDef *) GTZC_MPCBB3_BASE_S)
#define GTZC_MPCBB5_S   ((GTZC_MPCBB_TypeDef *) GTZC_MPCBB5_BASE_S)
#define GTZC_MPCBB6_S   ((GTZC_MPCBB_TypeDef *) GTZC_MPCBB6_BASE_S)
#define GFXMMU_S   ((GFXMMU_TypeDef *) GFXMMU_BASE_S)
#define GPIOA_S   ((GPIO_TypeDef *) GPIOA_BASE_S)
#define GPIOB_S   ((GPIO_TypeDef *) GPIOB_BASE_S)
#define GPIOC_S   ((GPIO_TypeDef *) GPIOC_BASE_S)
#define GPIOD_S   ((GPIO_TypeDef *) GPIOD_BASE_S)
#define GPIOE_S   ((GPIO_TypeDef *) GPIOE_BASE_S)
#define GPIOF_S   ((GPIO_TypeDef *) GPIOF_BASE_S)
#define GPIOG_S   ((GPIO_TypeDef *) GPIOG_BASE_S)
#define GPIOH_S   ((GPIO_TypeDef *) GPIOH_BASE_S)
#define GPIOI_S   ((GPIO_TypeDef *) GPIOI_BASE_S)
#define GPIOJ_S   ((GPIO_TypeDef *) GPIOJ_BASE_S)
#define ADC1_S   ((ADC_TypeDef *) ADC1_BASE_S)
#define ADC2_S   ((ADC_TypeDef *) ADC2_BASE_S)
#define ADC12_COMMON_S   ((ADC_Common_TypeDef *) ADC12_COMMON_BASE_S)
#define DCMI_S   ((DCMI_TypeDef *) DCMI_BASE_S)
#define PSSI_S   ((PSSI_TypeDef *) PSSI_BASE_S)
#define USB_OTG_HS_S   ((USB_OTG_GlobalTypeDef *) USB_OTG_HS_BASE_S)
#define AES_S   ((AES_TypeDef *) AES_BASE_S)
#define HASH_S   ((HASH_TypeDef *) HASH_BASE_S)
#define HASH_DIGEST_S   ((HASH_DIGEST_TypeDef *) HASH_DIGEST_BASE_S)
#define RNG_S   ((RNG_TypeDef *) RNG_BASE_S)
#define SAES_S   ((AES_TypeDef *) SAES_BASE_S)
#define PKA_S   ((PKA_TypeDef *) PKA_BASE_S)
#define OTFDEC1_S   ((OTFDEC_TypeDef *) OTFDEC1_BASE_S)
#define OTFDEC1_REGION1_S   ((OTFDEC_Region_TypeDef *) OTFDEC1_REGION1_BASE_S)
#define OTFDEC1_REGION2_S   ((OTFDEC_Region_TypeDef *) OTFDEC1_REGION2_BASE_S)
#define OTFDEC1_REGION3_S   ((OTFDEC_Region_TypeDef *) OTFDEC1_REGION3_BASE_S)
#define OTFDEC1_REGION4_S   ((OTFDEC_Region_TypeDef *) OTFDEC1_REGION4_BASE_S)
#define OTFDEC2_S   ((OTFDEC_TypeDef *) OTFDEC2_BASE_S)
#define OTFDEC2_REGION1_S   ((OTFDEC_Region_TypeDef *) OTFDEC2_REGION1_BASE_S)
#define OTFDEC2_REGION2_S   ((OTFDEC_Region_TypeDef *) OTFDEC2_REGION2_BASE_S)
#define OTFDEC2_REGION3_S   ((OTFDEC_Region_TypeDef *) OTFDEC2_REGION3_BASE_S)
#define OTFDEC2_REGION4_S   ((OTFDEC_Region_TypeDef *) OTFDEC2_REGION4_BASE_S)
#define SDMMC1_S   ((SDMMC_TypeDef *) SDMMC1_BASE_S)
#define SDMMC2_S   ((SDMMC_TypeDef *) SDMMC2_BASE_S)
#define DLYB_SDMMC1_S   ((DLYB_TypeDef *) DLYB_SDMMC1_BASE_S)
#define DLYB_SDMMC2_S   ((DLYB_TypeDef *) DLYB_SDMMC2_BASE_S)
#define DLYB_OCTOSPI1_S   ((DLYB_TypeDef *) DLYB_OCTOSPI1_BASE_S)
#define DLYB_OCTOSPI2_S   ((DLYB_TypeDef *) DLYB_OCTOSPI2_BASE_S)
#define FMC_Bank1_R_S   ((FMC_Bank1_TypeDef *) FMC_Bank1_R_BASE_S)
#define FMC_Bank1E_R_S   ((FMC_Bank1E_TypeDef *) FMC_Bank1E_R_BASE_S)
#define FMC_Bank3_R_S   ((FMC_Bank3_TypeDef *) FMC_Bank3_R_BASE_S)
#define OCTOSPIM_S   ((OCTOSPIM_TypeDef *) OCTOSPIM_R_BASE_S)
#define OCTOSPI1_S   ((OCTOSPI_TypeDef *) OCTOSPI1_R_BASE_S)
#define OCTOSPI2_S   ((OCTOSPI_TypeDef *) OCTOSPI2_R_BASE_S)
#define HSPI1_S   ((HSPI_TypeDef *) HSPI1_R_BASE_S)
#define LPGPIO1_S   ((GPIO_TypeDef *) LPGPIO1_BASE_S)
#define PWR_S   ((PWR_TypeDef *) PWR_BASE_S)
#define RCC_S   ((RCC_TypeDef *) RCC_BASE_S)
#define ADC4_S   ((ADC_TypeDef *) ADC4_BASE_S)
#define ADC4_COMMON_S   ((ADC_Common_TypeDef *) ADC4_COMMON_BASE_S)
#define DAC1_S   ((DAC_TypeDef *) DAC1_BASE_S)
#define EXTI_S   ((EXTI_TypeDef *) EXTI_BASE_S)
#define GTZC_TZSC2_S   ((GTZC_TZSC_TypeDef *) GTZC_TZSC2_BASE_S)
#define GTZC_TZIC2_S   ((GTZC_TZIC_TypeDef *) GTZC_TZIC2_BASE_S)
#define GTZC_MPCBB4_S   ((GTZC_MPCBB_TypeDef *) GTZC_MPCBB4_BASE_S)
#define ADF1_S   ((MDF_TypeDef *) ADF1_BASE_S)
#define ADF1_Filter0_S   ((MDF_Filter_TypeDef*) ADF1_Filter0_BASE_S)
#define LPDMA1_S   ((DMA_TypeDef *) LPDMA1_BASE_S)
#define LPDMA1_Channel0_S   ((DMA_Channel_TypeDef *) LPDMA1_Channel0_BASE_S)
#define LPDMA1_Channel1_S   ((DMA_Channel_TypeDef *) LPDMA1_Channel1_BASE_S)
#define LPDMA1_Channel2_S   ((DMA_Channel_TypeDef *) LPDMA1_Channel2_BASE_S)
#define LPDMA1_Channel3_S   ((DMA_Channel_TypeDef *) LPDMA1_Channel3_BASE_S)
#define DBGMCU   ((DBGMCU_TypeDef *) DBGMCU_BASE)
#define FLASH_BASE   FLASH_BASE_NS
#define SRAM1_BASE   SRAM1_BASE_NS
#define SRAM2_BASE   SRAM2_BASE_NS
#define SRAM3_BASE   SRAM3_BASE_NS
#define SRAM4_BASE   SRAM4_BASE_NS
#define SRAM5_BASE   SRAM5_BASE_NS
#define BKPSRAM_BASE   BKPSRAM_BASE_NS
#define SRAM6_BASE   SRAM6_BASE_NS
#define PERIPH_BASE   PERIPH_BASE_NS
#define APB1PERIPH_BASE   APB1PERIPH_BASE_NS
#define APB2PERIPH_BASE   APB2PERIPH_BASE_NS
#define AHB1PERIPH_BASE   AHB1PERIPH_BASE_NS
#define AHB2PERIPH_BASE   AHB2PERIPH_BASE_NS
#define CORDIC   CORDIC_NS
#define CORDIC_BASE   CORDIC_BASE_NS
#define RCC   RCC_NS
#define RCC_BASE   RCC_BASE_NS
#define DMA2D   DMA2D_NS
#define DMA2D_BASE   DMA2D_BASE_NS
#define DCMI   DCMI_NS
#define DCMI_BASE   DCMI_BASE_NS
#define PSSI   PSSI_NS
#define PSSI_BASE   PSSI_BASE_NS
#define FLASH   FLASH_NS
#define FLASH_R_BASE   FLASH_R_BASE_NS
#define FMAC   FMAC_NS
#define FMAC_BASE   FMAC_BASE_NS
#define GPDMA1   GPDMA1_NS
#define GPDMA1_BASE   GPDMA1_BASE_NS
#define GPDMA1_Channel0   GPDMA1_Channel0_NS
#define GPDMA1_Channel0_BASE   GPDMA1_Channel0_BASE_NS
#define GPDMA1_Channel1   GPDMA1_Channel1_NS
#define GPDMA1_Channel1_BASE   GPDMA1_Channel1_BASE_NS
#define GPDMA1_Channel2   GPDMA1_Channel2_NS
#define GPDMA1_Channel2_BASE   GPDMA1_Channel2_BASE_NS
#define GPDMA1_Channel3   GPDMA1_Channel3_NS
#define GPDMA1_Channel3_BASE   GPDMA1_Channel3_BASE_NS
#define GPDMA1_Channel4   GPDMA1_Channel4_NS
#define GPDMA1_Channel4_BASE   GPDMA1_Channel4_BASE_NS
#define GPDMA1_Channel5   GPDMA1_Channel5_NS
#define GPDMA1_Channel5_BASE   GPDMA1_Channel5_BASE_NS
#define GPDMA1_Channel6   GPDMA1_Channel6_NS
#define GPDMA1_Channel6_BASE   GPDMA1_Channel6_BASE_NS
#define GPDMA1_Channel7   GPDMA1_Channel7_NS
#define GPDMA1_Channel7_BASE   GPDMA1_Channel7_BASE_NS
#define GPDMA1_Channel8   GPDMA1_Channel8_NS
#define GPDMA1_Channel8_BASE   GPDMA1_Channel8_BASE_NS
#define GPDMA1_Channel9   GPDMA1_Channel9_NS
#define GPDMA1_Channel9_BASE   GPDMA1_Channel9_BASE_NS
#define GPDMA1_Channel10   GPDMA1_Channel10_NS
#define GPDMA1_Channel10_BASE   GPDMA1_Channel10_BASE_NS
#define GPDMA1_Channel11   GPDMA1_Channel11_NS
#define GPDMA1_Channel11_BASE   GPDMA1_Channel11_BASE_NS
#define GPDMA1_Channel12   GPDMA1_Channel12_NS
#define GPDMA1_Channel12_BASE   GPDMA1_Channel12_BASE_NS
#define GPDMA1_Channel13   GPDMA1_Channel13_NS
#define GPDMA1_Channel13_BASE   GPDMA1_Channel13_BASE_NS
#define GPDMA1_Channel14   GPDMA1_Channel14_NS
#define GPDMA1_Channel14_BASE   GPDMA1_Channel14_BASE_NS
#define GPDMA1_Channel15   GPDMA1_Channel15_NS
#define GPDMA1_Channel15_BASE   GPDMA1_Channel15_BASE_NS
#define LPDMA1   LPDMA1_NS
#define LPDMA1_BASE   LPDMA1_BASE_NS
#define LPDMA1_Channel0   LPDMA1_Channel0_NS
#define LPDMA1_Channel0_BASE   LPDMA1_Channel0_BASE_NS
#define LPDMA1_Channel1   LPDMA1_Channel1_NS
#define LPDMA1_Channel1_BASE   LPDMA1_Channel1_BASE_NS
#define LPDMA1_Channel2   LPDMA1_Channel2_NS
#define LPDMA1_Channel2_BASE   LPDMA1_Channel2_BASE_NS
#define LPDMA1_Channel3   LPDMA1_Channel3_NS
#define LPDMA1_Channel3_BASE   LPDMA1_Channel3_BASE_NS
#define GPIOA   GPIOA_NS
#define GPIOA_BASE   GPIOA_BASE_NS
#define GPIOB   GPIOB_NS
#define GPIOB_BASE   GPIOB_BASE_NS
#define GPIOC   GPIOC_NS
#define GPIOC_BASE   GPIOC_BASE_NS
#define GPIOD   GPIOD_NS
#define GPIOD_BASE   GPIOD_BASE_NS
#define GPIOE   GPIOE_NS
#define GPIOE_BASE   GPIOE_BASE_NS
#define GPIOF   GPIOF_NS
#define GPIOF_BASE   GPIOF_BASE_NS
#define GPIOG   GPIOG_NS
#define GPIOG_BASE   GPIOG_BASE_NS
#define GPIOH   GPIOH_NS
#define GPIOH_BASE   GPIOH_BASE_NS
#define GPIOI   GPIOI_NS
#define GPIOI_BASE   GPIOI_BASE_NS
#define GPIOJ   GPIOJ_NS
#define GPIOJ_BASE   GPIOJ_BASE_NS
#define LPGPIO1   LPGPIO1_NS
#define LPGPIO1_BASE   LPGPIO1_BASE_NS
#define PWR   PWR_NS
#define PWR_BASE   PWR_BASE_NS
#define RAMCFG_SRAM1   RAMCFG_SRAM1_NS
#define RAMCFG_SRAM1_BASE   RAMCFG_SRAM1_BASE_NS
#define RAMCFG_SRAM2   RAMCFG_SRAM2_NS
#define RAMCFG_SRAM2_BASE   RAMCFG_SRAM2_BASE_NS
#define RAMCFG_SRAM3   RAMCFG_SRAM3_NS
#define RAMCFG_SRAM3_BASE   RAMCFG_SRAM3_BASE_NS
#define RAMCFG_SRAM4   RAMCFG_SRAM4_NS
#define RAMCFG_SRAM4_BASE   RAMCFG_SRAM4_BASE_NS
#define RAMCFG_SRAM5   RAMCFG_SRAM5_NS
#define RAMCFG_SRAM5_BASE   RAMCFG_SRAM5_BASE_NS
#define RAMCFG_BKPRAM   RAMCFG_BKPRAM_NS
#define RAMCFG_BKPRAM_BASE   RAMCFG_BKPRAM_BASE_NS
#define RAMCFG_SRAM6   RAMCFG_SRAM6_NS
#define RAMCFG_SRAM6_BASE   RAMCFG_SRAM6_BASE_NS
#define EXTI   EXTI_NS
#define EXTI_BASE   EXTI_BASE_NS
#define ICACHE   ICACHE_NS
#define ICACHE_BASE   ICACHE_BASE_NS
#define DCACHE1   DCACHE1_NS
#define DCACHE1_BASE   DCACHE1_BASE_NS
#define DCACHE2   DCACHE2_NS
#define DCACHE2_BASE   DCACHE2_BASE_NS
#define GTZC_TZSC1   GTZC_TZSC1_NS
#define GTZC_TZSC1_BASE   GTZC_TZSC1_BASE_NS
#define GTZC_TZSC2   GTZC_TZSC2_NS
#define GTZC_TZSC2_BASE   GTZC_TZSC2_BASE_NS
#define GTZC_TZIC1   GTZC_TZIC1_NS
#define GTZC_TZIC1_BASE   GTZC_TZIC1_BASE_NS
#define GTZC_TZIC2   GTZC_TZIC2_NS
#define GTZC_TZIC2_BASE   GTZC_TZIC2_BASE_NS
#define GTZC_MPCBB1   GTZC_MPCBB1_NS
#define GTZC_MPCBB1_BASE   GTZC_MPCBB1_BASE_NS
#define GTZC_MPCBB2   GTZC_MPCBB2_NS
#define GTZC_MPCBB2_BASE   GTZC_MPCBB2_BASE_NS
#define GTZC_MPCBB3   GTZC_MPCBB3_NS
#define GTZC_MPCBB3_BASE   GTZC_MPCBB3_BASE_NS
#define GTZC_MPCBB4   GTZC_MPCBB4_NS
#define GTZC_MPCBB4_BASE   GTZC_MPCBB4_BASE_NS
#define GTZC_MPCBB5   GTZC_MPCBB5_NS
#define GTZC_MPCBB5_BASE   GTZC_MPCBB5_BASE_NS
#define GTZC_MPCBB6   GTZC_MPCBB6_NS
#define GTZC_MPCBB6_BASE   GTZC_MPCBB6_BASE_NS
#define RTC   RTC_NS
#define RTC_BASE   RTC_BASE_NS
#define TAMP   TAMP_NS
#define TAMP_BASE   TAMP_BASE_NS
#define TIM1   TIM1_NS
#define TIM1_BASE   TIM1_BASE_NS
#define TIM2   TIM2_NS
#define TIM2_BASE   TIM2_BASE_NS
#define TIM3   TIM3_NS
#define TIM3_BASE   TIM3_BASE_NS
#define TIM4   TIM4_NS
#define TIM4_BASE   TIM4_BASE_NS
#define TIM5   TIM5_NS
#define TIM5_BASE   TIM5_BASE_NS
#define TIM6   TIM6_NS
#define TIM6_BASE   TIM6_BASE_NS
#define TIM7   TIM7_NS
#define TIM7_BASE   TIM7_BASE_NS
#define TIM8   TIM8_NS
#define TIM8_BASE   TIM8_BASE_NS
#define TIM15   TIM15_NS
#define TIM15_BASE   TIM15_BASE_NS
#define TIM16   TIM16_NS
#define TIM16_BASE   TIM16_BASE_NS
#define TIM17   TIM17_NS
#define TIM17_BASE   TIM17_BASE_NS
#define WWDG   WWDG_NS
#define WWDG_BASE   WWDG_BASE_NS
#define IWDG   IWDG_NS
#define IWDG_BASE   IWDG_BASE_NS
#define SPI1   SPI1_NS
#define SPI1_BASE   SPI1_BASE_NS
#define SPI2   SPI2_NS
#define SPI2_BASE   SPI2_BASE_NS
#define SPI3   SPI3_NS
#define SPI3_BASE   SPI3_BASE_NS
#define USART1   USART1_NS
#define USART1_BASE   USART1_BASE_NS
#define USART2   USART2_NS
#define USART2_BASE   USART2_BASE_NS
#define USART3   USART3_NS
#define USART3_BASE   USART3_BASE_NS
#define UART4   UART4_NS
#define UART4_BASE   UART4_BASE_NS
#define UART5   UART5_NS
#define UART5_BASE   UART5_BASE_NS
#define USART6   USART6_NS
#define USART6_BASE   USART6_BASE_NS
#define I2C1   I2C1_NS
#define I2C1_BASE   I2C1_BASE_NS
#define I2C2   I2C2_NS
#define I2C2_BASE   I2C2_BASE_NS
#define I2C3   I2C3_NS
#define I2C3_BASE   I2C3_BASE_NS
#define I2C4   I2C4_NS
#define I2C4_BASE   I2C4_BASE_NS
#define I2C5   I2C5_NS
#define I2C5_BASE   I2C5_BASE_NS
#define I2C6   I2C6_NS
#define I2C6_BASE   I2C6_BASE_NS
#define CRS   CRS_NS
#define CRS_BASE   CRS_BASE_NS
#define FDCAN1   FDCAN1_NS
#define FDCAN1_BASE   FDCAN1_BASE_NS
#define FDCAN_CONFIG   FDCAN_CONFIG_NS
#define FDCAN_CONFIG_BASE   FDCAN_CONFIG_BASE_NS
#define SRAMCAN_BASE   SRAMCAN_BASE_NS
#define DAC1   DAC1_NS
#define DAC1_BASE   DAC1_BASE_NS
#define OPAMP   OPAMP_NS
#define OPAMP_BASE   OPAMP_BASE_NS
#define OPAMP1   OPAMP1_NS
#define OPAMP1_BASE   OPAMP1_BASE_NS
#define OPAMP2   OPAMP2_NS
#define OPAMP2_BASE   OPAMP2_BASE_NS
#define OPAMP12_COMMON   OPAMP12_COMMON_NS
#define OPAMP12_COMMON_BASE   OPAMP12_COMMON_BASE_NS
#define LPTIM1   LPTIM1_NS
#define LPTIM1_BASE   LPTIM1_BASE_NS
#define LPTIM2   LPTIM2_NS
#define LPTIM2_BASE   LPTIM2_BASE_NS
#define LPTIM3   LPTIM3_NS
#define LPTIM3_BASE   LPTIM3_BASE_NS
#define LPTIM4   LPTIM4_NS
#define LPTIM4_BASE   LPTIM4_BASE_NS
#define LPUART1   LPUART1_NS
#define LPUART1_BASE   LPUART1_BASE_NS
#define UCPD1   UCPD1_NS
#define UCPD1_BASE   UCPD1_BASE_NS
#define SYSCFG   SYSCFG_NS
#define SYSCFG_BASE   SYSCFG_BASE_NS
#define VREFBUF   VREFBUF_NS
#define VREFBUF_BASE   VREFBUF_BASE_NS
#define COMP12   COMP12_NS
#define COMP12_BASE   COMP12_BASE_NS
#define COMP1   COMP1_NS
#define COMP1_BASE   COMP1_BASE_NS
#define COMP2   COMP2_NS
#define COMP2_BASE   COMP2_BASE_NS
#define COMP12_COMMON   COMP12_COMMON_NS
#define COMP12_COMMON_BASE   COMP1_BASE_NS
#define SAI1   SAI1_NS
#define SAI1_BASE   SAI1_BASE_NS
#define SAI1_Block_A   SAI1_Block_A_NS
#define SAI1_Block_A_BASE   SAI1_Block_A_BASE_NS
#define SAI1_Block_B   SAI1_Block_B_NS
#define SAI1_Block_B_BASE   SAI1_Block_B_BASE_NS
#define SAI2   SAI2_NS
#define SAI2_BASE   SAI2_BASE_NS
#define SAI2_Block_A   SAI2_Block_A_NS
#define SAI2_Block_A_BASE   SAI2_Block_A_BASE_NS
#define SAI2_Block_B   SAI2_Block_B_NS
#define SAI2_Block_B_BASE   SAI2_Block_B_BASE_NS
#define CRC   CRC_NS
#define CRC_BASE   CRC_BASE_NS
#define TSC   TSC_NS
#define TSC_BASE   TSC_BASE_NS
#define ADC1   ADC1_NS
#define ADC1_BASE   ADC1_BASE_NS
#define ADC2   ADC2_NS
#define ADC2_BASE   ADC2_BASE_NS
#define ADC12_COMMON   ADC12_COMMON_NS
#define ADC12_COMMON_BASE   ADC12_COMMON_BASE_NS
#define ADC4   ADC4_NS
#define ADC4_BASE   ADC4_BASE_NS
#define ADC4_COMMON   ADC4_COMMON_NS
#define ADC4_COMMON_BASE   ADC4_COMMON_BASE_NS
#define HASH   HASH_NS
#define HASH_BASE   HASH_BASE_NS
#define HASH_DIGEST   HASH_DIGEST_NS
#define HASH_DIGEST_BASE   HASH_DIGEST_BASE_NS
#define AES   AES_NS
#define AES_BASE   AES_BASE_NS
#define RNG   RNG_NS
#define RNG_BASE   RNG_BASE_NS
#define SAES   SAES_NS
#define SAES_BASE   SAES_BASE_NS
#define PKA   PKA_NS
#define PKA_BASE   PKA_BASE_NS
#define PKA_RAM_BASE   PKA_RAM_BASE_NS
#define OTFDEC1   OTFDEC1_NS
#define OTFDEC1_BASE   OTFDEC1_BASE_NS
#define OTFDEC1_REGION1   OTFDEC1_REGION1_NS
#define OTFDEC1_REGION1_BASE   OTFDEC1_REGION1_BASE_NS
#define OTFDEC1_REGION2   OTFDEC1_REGION2_NS
#define OTFDEC1_REGION2_BASE   OTFDEC1_REGION2_BASE_NS
#define OTFDEC1_REGION3   OTFDEC1_REGION3_NS
#define OTFDEC1_REGION3_BASE   OTFDEC1_REGION3_BASE_NS
#define OTFDEC1_REGION4   OTFDEC1_REGION4_NS
#define OTFDEC1_REGION4_BASE   OTFDEC1_REGION4_BASE_NS
#define OTFDEC2   OTFDEC2_NS
#define OTFDEC2_BASE   OTFDEC2_BASE_NS
#define OTFDEC2_REGION1   OTFDEC2_REGION1_NS
#define OTFDEC2_REGION1_BASE   OTFDEC2_REGION1_BASE_NS
#define OTFDEC2_REGION2   OTFDEC2_REGION2_NS
#define OTFDEC2_REGION2_BASE   OTFDEC2_REGION2_BASE_NS
#define OTFDEC2_REGION3   OTFDEC2_REGION3_NS
#define OTFDEC2_REGION3_BASE   OTFDEC2_REGION3_BASE_NS
#define OTFDEC2_REGION4   OTFDEC2_REGION4_NS
#define OTFDEC2_REGION4_BASE   OTFDEC2_REGION4_BASE_NS
#define SDMMC1   SDMMC1_NS
#define SDMMC1_BASE   SDMMC1_BASE_NS
#define SDMMC2   SDMMC2_NS
#define SDMMC2_BASE   SDMMC2_BASE_NS
#define FMC_Bank1_R   FMC_Bank1_R_NS
#define FMC_Bank1_R_BASE   FMC_Bank1_R_BASE_NS
#define FMC_Bank1E_R   FMC_Bank1E_R_NS
#define FMC_Bank1E_R_BASE   FMC_Bank1E_R_BASE_NS
#define FMC_Bank3_R   FMC_Bank3_R_NS
#define FMC_Bank3_R_BASE   FMC_Bank3_R_BASE_NS
#define OCTOSPI1   OCTOSPI1_NS
#define OCTOSPI1_R_BASE   OCTOSPI1_R_BASE_NS
#define OCTOSPI2   OCTOSPI2_NS
#define OCTOSPI2_R_BASE   OCTOSPI2_R_BASE_NS
#define OCTOSPIM   OCTOSPIM_NS
#define OCTOSPIM_R_BASE   OCTOSPIM_R_BASE_NS
#define DLYB_SDMMC1   DLYB_SDMMC1_NS
#define DLYB_SDMMC1_BASE   DLYB_SDMMC1_BASE_NS
#define DLYB_SDMMC2   DLYB_SDMMC2_NS
#define DLYB_SDMMC2_BASE   DLYB_SDMMC2_BASE_NS
#define DLYB_OCTOSPI1   DLYB_OCTOSPI1_NS
#define DLYB_OCTOSPI1_BASE   DLYB_OCTOSPI1_BASE_NS
#define DLYB_OCTOSPI2   DLYB_OCTOSPI2_NS
#define DLYB_OCTOSPI2_BASE   DLYB_OCTOSPI2_BASE_NS
#define HSPI1   HSPI1_NS
#define HSPI1_R_BASE   HSPI1_R_BASE_NS
#define USB_OTG_HS   USB_OTG_HS_NS
#define USB_OTG_HS_BASE   USB_OTG_HS_BASE_NS
#define MDF1   MDF1_NS
#define MDF1_BASE   MDF1_BASE_NS
#define MDF1_Filter0   MDF1_Filter0_NS
#define MDF1_Filter0_BASE   MDF1_Filter0_BASE_NS
#define MDF1_Filter1   MDF1_Filter1_NS
#define MDF1_Filter1_BASE   MDF1_Filter1_BASE_NS
#define MDF1_Filter2   MDF1_Filter2_NS
#define MDF1_Filter2_BASE   MDF1_Filter2_BASE_NS
#define MDF1_Filter3   MDF1_Filter3_NS
#define MDF1_Filter3_BASE   MDF1_Filter3_BASE_NS
#define MDF1_Filter4   MDF1_Filter4_NS
#define MDF1_Filter4_BASE   MDF1_Filter4_BASE_NS
#define MDF1_Filter5   MDF1_Filter5_NS
#define MDF1_Filter5_BASE   MDF1_Filter5_BASE_NS
#define ADF1   ADF1_NS
#define ADF1_BASE   ADF1_BASE_NS
#define ADF1_Filter0   ADF1_Filter0_NS
#define ADF1_Filter0_BASE   ADF1_Filter0_BASE_NS
#define GFXMMU   GFXMMU_NS
#define GFXMMU_BASE   GFXMMU_BASE_NS
#define GFXMMU_VIRTUAL_BUFFERS_BASE   GFXMMU_VIRTUAL_BUFFERS_BASE_NS
#define GFXMMU_VIRTUAL_BUFFER0_BASE   GFXMMU_VIRTUAL_BUFFER0_BASE_NS
#define GFXMMU_VIRTUAL_BUFFER1_BASE   GFXMMU_VIRTUAL_BUFFER1_BASE_NS
#define GFXMMU_VIRTUAL_BUFFER2_BASE   GFXMMU_VIRTUAL_BUFFER2_BASE_NS
#define GFXMMU_VIRTUAL_BUFFER3_BASE   GFXMMU_VIRTUAL_BUFFER3_BASE_NS
#define GPU2D   GPU2D_BASE_NS
#define LTDC   LTDC_NS
#define LTDC_BASE   LTDC_BASE_NS
#define LTDC_Layer1   LTDC_Layer1_NS
#define LTDC_Layer1_BASE   LTDC_Layer1_BASE_NS
#define LTDC_Layer2   LTDC_Layer2_NS
#define LTDC_Layer2_BASE   LTDC_Layer2_BASE_NS
#define DSI   DSI_NS
#define DSI_BASE   DSI_BASE_NS
#define REFBIAS   REFBIAS_NS
#define REFBIAS_BASE   REFBIAS_BASE_NS
#define DPHY   DPHY_NS
#define DPHY_BASE   DPHY_BASE_NS
#define JPEG   JPEG_NS
#define JPEG_BASE   JPEG_BASE_NS
#define GFXTIM   GFXTIM_NS
#define GFXTIM_BASE   GFXTIM_BASE_NS
#define LSI_STARTUP_TIME   260U
#define ADC_VER_V5_X
#define ADC_MULTIMODE_SUPPORT
#define ADC_ISR_ADRDY_Pos   (0U)
#define ADC_ISR_ADRDY_Msk   (0x1UL << ADC_ISR_ADRDY_Pos)
#define ADC_ISR_ADRDY   ADC_ISR_ADRDY_Msk
#define ADC_ISR_EOSMP_Pos   (1U)
#define ADC_ISR_EOSMP_Msk   (0x1UL << ADC_ISR_EOSMP_Pos)
#define ADC_ISR_EOSMP   ADC_ISR_EOSMP_Msk
#define ADC_ISR_EOC_Pos   (2U)
#define ADC_ISR_EOC_Msk   (0x1UL << ADC_ISR_EOC_Pos)
#define ADC_ISR_EOC   ADC_ISR_EOC_Msk
#define ADC_ISR_EOS_Pos   (3U)
#define ADC_ISR_EOS_Msk   (0x1UL << ADC_ISR_EOS_Pos)
#define ADC_ISR_EOS   ADC_ISR_EOS_Msk
#define ADC_ISR_OVR_Pos   (4U)
#define ADC_ISR_OVR_Msk   (0x1UL << ADC_ISR_OVR_Pos)
#define ADC_ISR_OVR   ADC_ISR_OVR_Msk
#define ADC_ISR_JEOC_Pos   (5U)
#define ADC_ISR_JEOC_Msk   (0x1UL << ADC_ISR_JEOC_Pos)
#define ADC_ISR_JEOC   ADC_ISR_JEOC_Msk
#define ADC_ISR_JEOS_Pos   (6U)
#define ADC_ISR_JEOS_Msk   (0x1UL << ADC_ISR_JEOS_Pos)
#define ADC_ISR_JEOS   ADC_ISR_JEOS_Msk
#define ADC_ISR_AWD1_Pos   (7U)
#define ADC_ISR_AWD1_Msk   (0x1UL << ADC_ISR_AWD1_Pos)
#define ADC_ISR_AWD1   ADC_ISR_AWD1_Msk
#define ADC_ISR_AWD2_Pos   (8U)
#define ADC_ISR_AWD2_Msk   (0x1UL << ADC_ISR_AWD2_Pos)
#define ADC_ISR_AWD2   ADC_ISR_AWD2_Msk
#define ADC_ISR_AWD3_Pos   (9U)
#define ADC_ISR_AWD3_Msk   (0x1UL << ADC_ISR_AWD3_Pos)
#define ADC_ISR_AWD3   ADC_ISR_AWD3_Msk
#define ADC_ISR_JQOVF_Pos   (10U)
#define ADC_ISR_JQOVF_Msk   (0x1UL << ADC_ISR_JQOVF_Pos)
#define ADC_ISR_JQOVF   ADC_ISR_JQOVF_Msk
#define ADC_ISR_EOCAL_Pos   (11U)
#define ADC_ISR_EOCAL_Msk   (0x1UL << ADC_ISR_EOCAL_Pos)
#define ADC_ISR_EOCAL   ADC_ISR_EOCAL_Msk
#define ADC_ISR_LDORDY_Pos   (12U)
#define ADC_ISR_LDORDY_Msk   (0x1UL << ADC_ISR_LDORDY_Pos)
#define ADC_ISR_LDORDY   ADC_ISR_LDORDY_Msk
#define ADC_IER_ADRDYIE_Pos   (0U)
#define ADC_IER_ADRDYIE_Msk   (0x1UL << ADC_IER_ADRDYIE_Pos)
#define ADC_IER_ADRDYIE   ADC_IER_ADRDYIE_Msk
#define ADC_IER_EOSMPIE_Pos   (1U)
#define ADC_IER_EOSMPIE_Msk   (0x1UL << ADC_IER_EOSMPIE_Pos)
#define ADC_IER_EOSMPIE   ADC_IER_EOSMPIE_Msk
#define ADC_IER_EOCIE_Pos   (2U)
#define ADC_IER_EOCIE_Msk   (0x1UL << ADC_IER_EOCIE_Pos)
#define ADC_IER_EOCIE   ADC_IER_EOCIE_Msk
#define ADC_IER_EOSIE_Pos   (3U)
#define ADC_IER_EOSIE_Msk   (0x1UL << ADC_IER_EOSIE_Pos)
#define ADC_IER_EOSIE   ADC_IER_EOSIE_Msk
#define ADC_IER_OVRIE_Pos   (4U)
#define ADC_IER_OVRIE_Msk   (0x1UL << ADC_IER_OVRIE_Pos)
#define ADC_IER_OVRIE   ADC_IER_OVRIE_Msk
#define ADC_IER_JEOCIE_Pos   (5U)
#define ADC_IER_JEOCIE_Msk   (0x1UL << ADC_IER_JEOCIE_Pos)
#define ADC_IER_JEOCIE   ADC_IER_JEOCIE_Msk
#define ADC_IER_JEOSIE_Pos   (6U)
#define ADC_IER_JEOSIE_Msk   (0x1UL << ADC_IER_JEOSIE_Pos)
#define ADC_IER_JEOSIE   ADC_IER_JEOSIE_Msk
#define ADC_IER_AWD1IE_Pos   (7U)
#define ADC_IER_AWD1IE_Msk   (0x1UL << ADC_IER_AWD1IE_Pos)
#define ADC_IER_AWD1IE   ADC_IER_AWD1IE_Msk
#define ADC_IER_AWD2IE_Pos   (8U)
#define ADC_IER_AWD2IE_Msk   (0x1UL << ADC_IER_AWD2IE_Pos)
#define ADC_IER_AWD2IE   ADC_IER_AWD2IE_Msk
#define ADC_IER_AWD3IE_Pos   (9U)
#define ADC_IER_AWD3IE_Msk   (0x1UL << ADC_IER_AWD3IE_Pos)
#define ADC_IER_AWD3IE   ADC_IER_AWD3IE_Msk
#define ADC_IER_JQOVFIE_Pos   (10U)
#define ADC_IER_JQOVFIE_Msk   (0x1UL << ADC_IER_JQOVFIE_Pos)
#define ADC_IER_JQOVFIE   ADC_IER_JQOVFIE_Msk
#define ADC_IER_EOCALIE_Pos   (11U)
#define ADC_IER_EOCALIE_Msk   (0x1UL << ADC_IER_EOCALIE_Pos)
#define ADC_IER_EOCALIE   ADC_IER_EOCALIE_Msk
#define ADC_IER_LDORDYIE_Pos   (12U)
#define ADC_IER_LDORDYIE_Msk   (0x1UL << ADC_IER_LDORDYIE_Pos)
#define ADC_IER_LDORDYIE   ADC_IER_LDORDYIE_Msk
#define ADC_CR_ADEN_Pos   (0U)
#define ADC_CR_ADEN_Msk   (0x1UL << ADC_CR_ADEN_Pos)
#define ADC_CR_ADEN   ADC_CR_ADEN_Msk
#define ADC_CR_ADDIS_Pos   (1U)
#define ADC_CR_ADDIS_Msk   (0x1UL << ADC_CR_ADDIS_Pos)
#define ADC_CR_ADDIS   ADC_CR_ADDIS_Msk
#define ADC_CR_ADSTART_Pos   (2U)
#define ADC_CR_ADSTART_Msk   (0x1UL << ADC_CR_ADSTART_Pos)
#define ADC_CR_ADSTART   ADC_CR_ADSTART_Msk
#define ADC_CR_JADSTART_Pos   (3U)
#define ADC_CR_JADSTART_Msk   (0x1UL << ADC_CR_JADSTART_Pos)
#define ADC_CR_JADSTART   ADC_CR_JADSTART_Msk
#define ADC_CR_ADSTP_Pos   (4U)
#define ADC_CR_ADSTP_Msk   (0x1UL << ADC_CR_ADSTP_Pos)
#define ADC_CR_ADSTP   ADC_CR_ADSTP_Msk
#define ADC_CR_JADSTP_Pos   (5U)
#define ADC_CR_JADSTP_Msk   (0x1UL << ADC_CR_JADSTP_Pos)
#define ADC_CR_JADSTP   ADC_CR_JADSTP_Msk
#define ADC_CR_ADCALLIN_Pos   (16U)
#define ADC_CR_ADCALLIN_Msk   (0x1UL << ADC_CR_ADCALLIN_Pos)
#define ADC_CR_ADCALLIN   ADC_CR_ADCALLIN_Msk
#define ADC_CR_CALINDEX_Pos   (24U)
#define ADC_CR_CALINDEX_Msk   (0xFUL << ADC_CR_CALINDEX_Pos)
#define ADC_CR_CALINDEX   ADC_CR_CALINDEX_Msk
#define ADC_CR_CALINDEX0_Pos   (24U)
#define ADC_CR_CALINDEX0_Msk   (0x1UL << ADC_CR_CALINDEX0_Pos)
#define ADC_CR_CALINDEX0   ADC_CR_CALINDEX0_Msk
#define ADC_CR_CALINDEX1_Pos   (25U)
#define ADC_CR_CALINDEX1_Msk   (0x1UL << ADC_CR_CALINDEX1_Pos)
#define ADC_CR_CALINDEX1   ADC_CR_CALINDEX1_Msk
#define ADC_CR_CALINDEX2_Pos   (26U)
#define ADC_CR_CALINDEX2_Msk   (0x1UL << ADC_CR_CALINDEX2_Pos)
#define ADC_CR_CALINDEX2   ADC_CR_CALINDEX2_Msk
#define ADC_CR_CALINDEX3_Pos   (27U)
#define ADC_CR_CALINDEX3_Msk   (0x1UL << ADC_CR_CALINDEX3_Pos)
#define ADC_CR_CALINDEX3   ADC_CR_CALINDEX3_Msk
#define ADC_CR_ADVREGEN_Pos   (28U)
#define ADC_CR_ADVREGEN_Msk   (0x1UL << ADC_CR_ADVREGEN_Pos)
#define ADC_CR_ADVREGEN   ADC_CR_ADVREGEN_Msk
#define ADC_CR_DEEPPWD_Pos   (29U)
#define ADC_CR_DEEPPWD_Msk   (0x1UL << ADC_CR_DEEPPWD_Pos)
#define ADC_CR_DEEPPWD   ADC_CR_DEEPPWD_Msk
#define ADC_CR_ADCAL_Pos   (31U)
#define ADC_CR_ADCAL_Msk   (0x1UL << ADC_CR_ADCAL_Pos)
#define ADC_CR_ADCAL   ADC_CR_ADCAL_Msk
#define ADC_CFGR1_DMNGT_Pos   (0U)
#define ADC_CFGR1_DMNGT_Msk   (0x3UL << ADC_CFGR1_DMNGT_Pos)
#define ADC_CFGR1_DMNGT   ADC_CFGR1_DMNGT_Msk
#define ADC_CFGR1_DMNGT_0   (0x1UL << ADC_CFGR1_DMNGT_Pos)
#define ADC_CFGR1_DMNGT_1   (0x2UL << ADC_CFGR1_DMNGT_Pos)
#define ADC_CFGR1_RES_Pos   (2U)
#define ADC_CFGR1_RES_Msk   (0x3UL << ADC_CFGR1_RES_Pos)
#define ADC_CFGR1_RES   ADC_CFGR1_RES_Msk
#define ADC_CFGR1_RES_0   (0x1UL << ADC_CFGR1_RES_Pos)
#define ADC_CFGR1_RES_1   (0x2UL << ADC_CFGR1_RES_Pos)
#define ADC4_CFGR1_DMAEN_Pos   (0U)
#define ADC4_CFGR1_DMAEN_Msk   (0x1UL << ADC4_CFGR1_DMAEN_Pos)
#define ADC4_CFGR1_DMAEN   ADC4_CFGR1_DMAEN_Msk
#define ADC4_CFGR1_DMACFG_Pos   (1U)
#define ADC4_CFGR1_DMACFG_Msk   (0x1UL << ADC4_CFGR1_DMACFG_Pos)
#define ADC4_CFGR1_DMACFG   ADC4_CFGR1_DMACFG_Msk
#define ADC4_CFGR1_SCANDIR_Pos   (4U)
#define ADC4_CFGR1_SCANDIR_Msk   (0x1UL << ADC4_CFGR1_SCANDIR_Pos)
#define ADC4_CFGR1_SCANDIR   ADC4_CFGR1_SCANDIR_Msk
#define ADC4_CFGR1_ALIGN_Pos   (5U)
#define ADC4_CFGR1_ALIGN_Msk   (0x1UL << ADC4_CFGR1_ALIGN_Pos)
#define ADC4_CFGR1_ALIGN   ADC4_CFGR1_ALIGN_Msk
#define ADC_CFGR1_EXTSEL_Pos   (5U)
#define ADC_CFGR1_EXTSEL_Msk   (0x1FUL << ADC_CFGR1_EXTSEL_Pos)
#define ADC_CFGR1_EXTSEL   ADC_CFGR1_EXTSEL_Msk
#define ADC_CFGR1_EXTSEL_0   (0x01UL << ADC_CFGR1_EXTSEL_Pos)
#define ADC_CFGR1_EXTSEL_1   (0x02UL << ADC_CFGR1_EXTSEL_Pos)
#define ADC_CFGR1_EXTSEL_2   (0x04UL << ADC_CFGR1_EXTSEL_Pos)
#define ADC_CFGR1_EXTSEL_3   (0x08UL << ADC_CFGR1_EXTSEL_Pos)
#define ADC_CFGR1_EXTSEL_4   (0x10UL << ADC_CFGR1_EXTSEL_Pos)
#define ADC_CFGR1_EXTEN_Pos   (10U)
#define ADC_CFGR1_EXTEN_Msk   (0x3UL << ADC_CFGR1_EXTEN_Pos)
#define ADC_CFGR1_EXTEN   ADC_CFGR1_EXTEN_Msk
#define ADC_CFGR1_EXTEN_0   (0x1UL << ADC_CFGR1_EXTEN_Pos)
#define ADC_CFGR1_EXTEN_1   (0x2UL << ADC_CFGR1_EXTEN_Pos)
#define ADC_CFGR1_OVRMOD_Pos   (12U)
#define ADC_CFGR1_OVRMOD_Msk   (0x1UL << ADC_CFGR1_OVRMOD_Pos)
#define ADC_CFGR1_OVRMOD   ADC_CFGR1_OVRMOD_Msk
#define ADC_CFGR1_CONT_Pos   (13U)
#define ADC_CFGR1_CONT_Msk   (0x1UL << ADC_CFGR1_CONT_Pos)
#define ADC_CFGR1_CONT   ADC_CFGR1_CONT_Msk
#define ADC_CFGR1_AUTDLY_Pos   (14U)
#define ADC_CFGR1_AUTDLY_Msk   (0x1UL << ADC_CFGR1_AUTDLY_Pos)
#define ADC_CFGR1_AUTDLY   ADC_CFGR1_AUTDLY_Msk
#define ADC4_CFGR1_WAIT_Pos   (14U)
#define ADC4_CFGR1_WAIT_Msk   (0x1UL << ADC4_CFGR1_WAIT_Pos)
#define ADC4_CFGR1_WAIT   ADC4_CFGR1_WAIT_Msk
#define ADC_CFGR1_DISCEN_Pos   (16U)
#define ADC_CFGR1_DISCEN_Msk   (0x1UL << ADC_CFGR1_DISCEN_Pos)
#define ADC_CFGR1_DISCEN   ADC_CFGR1_DISCEN_Msk
#define ADC_CFGR1_DISCNUM_Pos   (17U)
#define ADC_CFGR1_DISCNUM_Msk   (0x7UL << ADC_CFGR1_DISCNUM_Pos)
#define ADC_CFGR1_DISCNUM   ADC_CFGR1_DISCNUM_Msk
#define ADC_CFGR1_DISCNUM_0   (0x1UL << ADC_CFGR1_DISCNUM_Pos)
#define ADC_CFGR1_DISCNUM_1   (0x2UL << ADC_CFGR1_DISCNUM_Pos)
#define ADC_CFGR1_DISCNUM_2   (0x4UL << ADC_CFGR1_DISCNUM_Pos)
#define ADC_CFGR1_JDISCEN_Pos   (20U)
#define ADC_CFGR1_JDISCEN_Msk   (0x1UL << ADC_CFGR1_JDISCEN_Pos)
#define ADC_CFGR1_JDISCEN   ADC_CFGR1_JDISCEN_Msk
#define ADC_CFGR1_AWD1SGL_Pos   (22U)
#define ADC_CFGR1_AWD1SGL_Msk   (0x1UL << ADC_CFGR1_AWD1SGL_Pos)
#define ADC_CFGR1_AWD1SGL   ADC_CFGR1_AWD1SGL_Msk
#define ADC_CFGR1_AWD1EN_Pos   (23U)
#define ADC_CFGR1_AWD1EN_Msk   (0x1UL << ADC_CFGR1_AWD1EN_Pos)
#define ADC_CFGR1_AWD1EN   ADC_CFGR1_AWD1EN_Msk
#define ADC_CFGR1_JAWD1EN_Pos   (24U)
#define ADC_CFGR1_JAWD1EN_Msk   (0x1UL << ADC_CFGR1_JAWD1EN_Pos)
#define ADC_CFGR1_JAWD1EN   ADC_CFGR1_JAWD1EN_Msk
#define ADC_CFGR1_JAUTO_Pos   (25U)
#define ADC_CFGR1_JAUTO_Msk   (0x1UL << ADC_CFGR1_JAUTO_Pos)
#define ADC_CFGR1_JAUTO   ADC_CFGR1_JAUTO_Msk
#define ADC4_CFGR1_EXTSEL_Pos   (6U)
#define ADC4_CFGR1_EXTSEL_Msk   (0x7UL << ADC4_CFGR1_EXTSEL_Pos)
#define ADC4_CFGR1_EXTSEL   ADC4_CFGR1_EXTSEL_Msk
#define ADC4_CFGR1_EXTSEL_0   (0x01UL << ADC4_CFGR1_EXTSEL_Pos)
#define ADC4_CFGR1_EXTSEL_1   (0x02UL << ADC4_CFGR1_EXTSEL_Pos)
#define ADC4_CFGR1_EXTSEL_2   (0x04UL << ADC4_CFGR1_EXTSEL_Pos)
#define ADC4_CFGR1_CHSELRMOD_Pos   (21U)
#define ADC4_CFGR1_CHSELRMOD_Msk   (0x1UL << ADC4_CFGR1_CHSELRMOD_Pos)
#define ADC4_CFGR1_CHSELRMOD   ADC4_CFGR1_CHSELRMOD_Msk
#define ADC_CFGR1_AWD1CH_Pos   (26U)
#define ADC_CFGR1_AWD1CH_Msk   (0x1FUL << ADC_CFGR1_AWD1CH_Pos)
#define ADC_CFGR1_AWD1CH   ADC_CFGR1_AWD1CH_Msk
#define ADC_CFGR1_AWD1CH_0   (0x01UL << ADC_CFGR1_AWD1CH_Pos)
#define ADC_CFGR1_AWD1CH_1   (0x02UL << ADC_CFGR1_AWD1CH_Pos)
#define ADC_CFGR1_AWD1CH_2   (0x04UL << ADC_CFGR1_AWD1CH_Pos)
#define ADC_CFGR1_AWD1CH_3   (0x08UL << ADC_CFGR1_AWD1CH_Pos)
#define ADC_CFGR1_AWD1CH_4   (0x10UL << ADC_CFGR1_AWD1CH_Pos)
#define ADC_CFGR2_ROVSE_Pos   (0U)
#define ADC_CFGR2_ROVSE_Msk   (0x1UL << ADC_CFGR2_ROVSE_Pos)
#define ADC_CFGR2_ROVSE   ADC_CFGR2_ROVSE_Msk
#define ADC_CFGR2_JOVSE_Pos   (1U)
#define ADC_CFGR2_JOVSE_Msk   (0x1UL << ADC_CFGR2_JOVSE_Pos)
#define ADC_CFGR2_JOVSE   ADC_CFGR2_JOVSE_Msk
#define ADC_CFGR2_OVSS_Pos   (5U)
#define ADC_CFGR2_OVSS_Msk   (0xFUL << ADC_CFGR2_OVSS_Pos)
#define ADC_CFGR2_OVSS   ADC_CFGR2_OVSS_Msk
#define ADC_CFGR2_OVSS_0   (0x1UL << ADC_CFGR2_OVSS_Pos)
#define ADC_CFGR2_OVSS_1   (0x2UL << ADC_CFGR2_OVSS_Pos)
#define ADC_CFGR2_OVSS_2   (0x4UL << ADC_CFGR2_OVSS_Pos)
#define ADC_CFGR2_OVSS_3   (0x8UL << ADC_CFGR2_OVSS_Pos)
#define ADC_CFGR2_TROVS_Pos   (9U)
#define ADC_CFGR2_TROVS_Msk   (0x1UL << ADC_CFGR2_TROVS_Pos)
#define ADC_CFGR2_TROVS   ADC_CFGR2_TROVS_Msk
#define ADC_CFGR2_ROVSM_Pos   (10U)
#define ADC_CFGR2_ROVSM_Msk   (0x1UL << ADC_CFGR2_ROVSM_Pos)
#define ADC_CFGR2_ROVSM   ADC_CFGR2_ROVSM_Msk
#define ADC_CFGR2_OVSR_Pos   (16U)
#define ADC_CFGR2_OVSR_Msk   (0x3FFUL << ADC_CFGR2_OVSR_Pos)
#define ADC_CFGR2_OVSR   ADC_CFGR2_OVSR_Msk
#define ADC_CFGR2_OVSR_0   (0x001UL << ADC_CFGR2_OVSR_Pos)
#define ADC_CFGR2_OVSR_1   (0x002UL << ADC_CFGR2_OVSR_Pos)
#define ADC_CFGR2_OVSR_2   (0x004UL << ADC_CFGR2_OVSR_Pos)
#define ADC_CFGR2_OVSR_3   (0x008UL << ADC_CFGR2_OVSR_Pos)
#define ADC_CFGR2_OVSR_4   (0x010UL << ADC_CFGR2_OVSR_Pos)
#define ADC_CFGR2_OVSR_5   (0x020UL << ADC_CFGR2_OVSR_Pos)
#define ADC_CFGR2_OVSR_6   (0x040UL << ADC_CFGR2_OVSR_Pos)
#define ADC_CFGR2_OVSR_7   (0x080UL << ADC_CFGR2_OVSR_Pos)
#define ADC_CFGR2_OVSR_8   (0x100UL << ADC_CFGR2_OVSR_Pos)
#define ADC_CFGR2_OVSR_9   (0x200UL << ADC_CFGR2_OVSR_Pos)
#define ADC_CFGR2_BULB_Pos   (13U)
#define ADC_CFGR2_BULB_Msk   (0x1UL << ADC_CFGR2_BULB_Pos)
#define ADC_CFGR2_BULB   ADC_CFGR2_BULB_Msk
#define ADC_CFGR2_SWTRIG_Pos   (14U)
#define ADC_CFGR2_SWTRIG_Msk   (0x1UL << ADC_CFGR2_SWTRIG_Pos)
#define ADC_CFGR2_SWTRIG   ADC_CFGR2_SWTRIG_Msk
#define ADC_CFGR2_SMPTRIG_Pos   (15U)
#define ADC_CFGR2_SMPTRIG_Msk   (0x1UL << ADC_CFGR2_SMPTRIG_Pos)
#define ADC_CFGR2_SMPTRIG   ADC_CFGR2_SMPTRIG_Msk
#define ADC_CFGR2_LFTRIG_Pos   (27U)
#define ADC_CFGR2_LFTRIG_Msk   (0x1UL << ADC_CFGR2_LFTRIG_Pos)
#define ADC_CFGR2_LFTRIG   ADC_CFGR2_LFTRIG_Msk
#define ADC_CFGR2_LSHIFT_Pos   (28U)
#define ADC_CFGR2_LSHIFT_Msk   (0xFUL << ADC_CFGR2_LSHIFT_Pos)
#define ADC_CFGR2_LSHIFT   ADC_CFGR2_LSHIFT_Msk
#define ADC_CFGR2_LSHIFT_0   (0x1UL << ADC_CFGR2_LSHIFT_Pos)
#define ADC_CFGR2_LSHIFT_1   (0x2UL << ADC_CFGR2_LSHIFT_Pos)
#define ADC_CFGR2_LSHIFT_2   (0x4UL << ADC_CFGR2_LSHIFT_Pos)
#define ADC_CFGR2_LSHIFT_3   (0x8UL << ADC_CFGR2_LSHIFT_Pos)
#define ADC4_CFGR2_OVSR_Pos   (2U)
#define ADC4_CFGR2_OVSR_Msk   (0x7UL << ADC4_CFGR2_OVSR_Pos)
#define ADC4_CFGR2_OVSR   ADC4_CFGR2_OVSR_Msk
#define ADC4_CFGR2_OVSR_0   (0x1UL << ADC4_CFGR2_OVSR_Pos)
#define ADC4_CFGR2_OVSR_1   (0x2UL << ADC4_CFGR2_OVSR_Pos)
#define ADC4_CFGR2_OVSR_2   (0x4UL << ADC4_CFGR2_OVSR_Pos)
#define ADC4_CFGR2_LFTRIG_Pos   (29U)
#define ADC4_CFGR2_LFTRIG_Msk   (0x1UL << ADC4_CFGR2_LFTRIG_Pos)
#define ADC4_CFGR2_LFTRIG   ADC4_CFGR2_LFTRIG_Msk
#define ADC_SMPR1_SMP0_Pos   (0U)
#define ADC_SMPR1_SMP0_Msk   (0x7UL << ADC_SMPR1_SMP0_Pos)
#define ADC_SMPR1_SMP0   ADC_SMPR1_SMP0_Msk
#define ADC_SMPR1_SMP0_0   (0x1UL << ADC_SMPR1_SMP0_Pos)
#define ADC_SMPR1_SMP0_1   (0x2UL << ADC_SMPR1_SMP0_Pos)
#define ADC_SMPR1_SMP0_2   (0x4UL << ADC_SMPR1_SMP0_Pos)
#define ADC_SMPR1_SMP1_Pos   (3U)
#define ADC_SMPR1_SMP1_Msk   (0x7UL << ADC_SMPR1_SMP1_Pos)
#define ADC_SMPR1_SMP1   ADC_SMPR1_SMP1_Msk
#define ADC_SMPR1_SMP1_0   (0x1UL << ADC_SMPR1_SMP1_Pos)
#define ADC_SMPR1_SMP1_1   (0x2UL << ADC_SMPR1_SMP1_Pos)
#define ADC_SMPR1_SMP1_2   (0x4UL << ADC_SMPR1_SMP1_Pos)
#define ADC_SMPR1_SMP2_Pos   (6U)
#define ADC_SMPR1_SMP2_Msk   (0x7UL << ADC_SMPR1_SMP2_Pos)
#define ADC_SMPR1_SMP2   ADC_SMPR1_SMP2_Msk
#define ADC_SMPR1_SMP2_0   (0x1UL << ADC_SMPR1_SMP2_Pos)
#define ADC_SMPR1_SMP2_1   (0x2UL << ADC_SMPR1_SMP2_Pos)
#define ADC_SMPR1_SMP2_2   (0x4UL << ADC_SMPR1_SMP2_Pos)
#define ADC_SMPR1_SMP3_Pos   (9U)
#define ADC_SMPR1_SMP3_Msk   (0x7UL << ADC_SMPR1_SMP3_Pos)
#define ADC_SMPR1_SMP3   ADC_SMPR1_SMP3_Msk
#define ADC_SMPR1_SMP3_0   (0x1UL << ADC_SMPR1_SMP3_Pos)
#define ADC_SMPR1_SMP3_1   (0x2UL << ADC_SMPR1_SMP3_Pos)
#define ADC_SMPR1_SMP3_2   (0x4UL << ADC_SMPR1_SMP3_Pos)
#define ADC_SMPR1_SMP4_Pos   (12U)
#define ADC_SMPR1_SMP4_Msk   (0x7UL << ADC_SMPR1_SMP4_Pos)
#define ADC_SMPR1_SMP4   ADC_SMPR1_SMP4_Msk
#define ADC_SMPR1_SMP4_0   (0x1UL << ADC_SMPR1_SMP4_Pos)
#define ADC_SMPR1_SMP4_1   (0x2UL << ADC_SMPR1_SMP4_Pos)
#define ADC_SMPR1_SMP4_2   (0x4UL << ADC_SMPR1_SMP4_Pos)
#define ADC_SMPR1_SMP5_Pos   (15U)
#define ADC_SMPR1_SMP5_Msk   (0x7UL << ADC_SMPR1_SMP5_Pos)
#define ADC_SMPR1_SMP5   ADC_SMPR1_SMP5_Msk
#define ADC_SMPR1_SMP5_0   (0x1UL << ADC_SMPR1_SMP5_Pos)
#define ADC_SMPR1_SMP5_1   (0x2UL << ADC_SMPR1_SMP5_Pos)
#define ADC_SMPR1_SMP5_2   (0x4UL << ADC_SMPR1_SMP5_Pos)
#define ADC_SMPR1_SMP6_Pos   (18U)
#define ADC_SMPR1_SMP6_Msk   (0x7UL << ADC_SMPR1_SMP6_Pos)
#define ADC_SMPR1_SMP6   ADC_SMPR1_SMP6_Msk
#define ADC_SMPR1_SMP6_0   (0x1UL << ADC_SMPR1_SMP6_Pos)
#define ADC_SMPR1_SMP6_1   (0x2UL << ADC_SMPR1_SMP6_Pos)
#define ADC_SMPR1_SMP6_2   (0x4UL << ADC_SMPR1_SMP6_Pos)
#define ADC_SMPR1_SMP7_Pos   (21U)
#define ADC_SMPR1_SMP7_Msk   (0x7UL << ADC_SMPR1_SMP7_Pos)
#define ADC_SMPR1_SMP7   ADC_SMPR1_SMP7_Msk
#define ADC_SMPR1_SMP7_0   (0x1UL << ADC_SMPR1_SMP7_Pos)
#define ADC_SMPR1_SMP7_1   (0x2UL << ADC_SMPR1_SMP7_Pos)
#define ADC_SMPR1_SMP7_2   (0x4UL << ADC_SMPR1_SMP7_Pos)
#define ADC_SMPR1_SMP8_Pos   (24U)
#define ADC_SMPR1_SMP8_Msk   (0x7UL << ADC_SMPR1_SMP8_Pos)
#define ADC_SMPR1_SMP8   ADC_SMPR1_SMP8_Msk
#define ADC_SMPR1_SMP8_0   (0x1UL << ADC_SMPR1_SMP8_Pos)
#define ADC_SMPR1_SMP8_1   (0x2UL << ADC_SMPR1_SMP8_Pos)
#define ADC_SMPR1_SMP8_2   (0x4UL << ADC_SMPR1_SMP8_Pos)
#define ADC_SMPR1_SMP9_Pos   (27U)
#define ADC_SMPR1_SMP9_Msk   (0x7UL << ADC_SMPR1_SMP9_Pos)
#define ADC_SMPR1_SMP9   ADC_SMPR1_SMP9_Msk
#define ADC_SMPR1_SMP9_0   (0x1UL << ADC_SMPR1_SMP9_Pos)
#define ADC_SMPR1_SMP9_1   (0x2UL << ADC_SMPR1_SMP9_Pos)
#define ADC_SMPR1_SMP9_2   (0x4UL << ADC_SMPR1_SMP9_Pos)
#define ADC4_SMPR_SMP1_Pos   (0U)
#define ADC4_SMPR_SMP1_Msk   (0x7UL << ADC4_SMPR_SMP1_Pos)
#define ADC4_SMPR_SMP1   ADC4_SMPR_SMP1_Msk
#define ADC4_SMPR_SMP1_0   (0x1UL << ADC4_SMPR_SMP1_Pos)
#define ADC4_SMPR_SMP1_1   (0x2UL << ADC4_SMPR_SMP1_Pos)
#define ADC4_SMPR_SMP1_2   (0x4UL << ADC4_SMPR_SMP1_Pos)
#define ADC4_SMPR_SMP2_Pos   (4U)
#define ADC4_SMPR_SMP2_Msk   (0x7UL << ADC4_SMPR_SMP2_Pos)
#define ADC4_SMPR_SMP2   ADC4_SMPR_SMP2_Msk
#define ADC4_SMPR_SMP2_0   (0x1UL << ADC4_SMPR_SMP2_Pos)
#define ADC4_SMPR_SMP2_1   (0x2UL << ADC4_SMPR_SMP2_Pos)
#define ADC4_SMPR_SMP2_2   (0x4UL << ADC4_SMPR_SMP2_Pos)
#define ADC4_SMPR_SMPSEL_Pos   (8U)
#define ADC4_SMPR_SMPSEL_Msk   (0xFFFFFFUL << ADC4_SMPR_SMPSEL_Pos)
#define ADC4_SMPR_SMPSEL   ADC4_SMPR_SMPSEL_Msk
#define ADC4_SMPR_SMPSEL0_Pos   (8U)
#define ADC4_SMPR_SMPSEL0_Msk   (0x1UL << ADC4_SMPR_SMPSEL0_Pos)
#define ADC4_SMPR_SMPSEL0   ADC4_SMPR_SMPSEL0_Msk
#define ADC4_SMPR_SMPSEL1_Pos   (9U)
#define ADC4_SMPR_SMPSEL1_Msk   (0x1UL << ADC4_SMPR_SMPSEL1_Pos)
#define ADC4_SMPR_SMPSEL1   ADC4_SMPR_SMPSEL1_Msk
#define ADC4_SMPR_SMPSEL2_Pos   (10U)
#define ADC4_SMPR_SMPSEL2_Msk   (0x1UL << ADC4_SMPR_SMPSEL2_Pos)
#define ADC4_SMPR_SMPSEL2   ADC4_SMPR_SMPSEL2_Msk
#define ADC4_SMPR_SMPSEL3_Pos   (11U)
#define ADC4_SMPR_SMPSEL3_Msk   (0x1UL << ADC4_SMPR_SMPSEL3_Pos)
#define ADC4_SMPR_SMPSEL3   ADC4_SMPR_SMPSEL3_Msk
#define ADC4_SMPR_SMPSEL4_Pos   (12U)
#define ADC4_SMPR_SMPSEL4_Msk   (0x1UL << ADC4_SMPR_SMPSEL4_Pos)
#define ADC4_SMPR_SMPSEL4   ADC4_SMPR_SMPSEL4_Msk
#define ADC4_SMPR_SMPSEL5_Pos   (13U)
#define ADC4_SMPR_SMPSEL5_Msk   (0x1UL << ADC4_SMPR_SMPSEL5_Pos)
#define ADC4_SMPR_SMPSEL5   ADC4_SMPR_SMPSEL5_Msk
#define ADC4_SMPR_SMPSEL6_Pos   (14U)
#define ADC4_SMPR_SMPSEL6_Msk   (0x1UL << ADC4_SMPR_SMPSEL6_Pos)
#define ADC4_SMPR_SMPSEL6   ADC4_SMPR_SMPSEL6_Msk
#define ADC4_SMPR_SMPSEL7_Pos   (15U)
#define ADC4_SMPR_SMPSEL7_Msk   (0x1UL << ADC4_SMPR_SMPSEL7_Pos)
#define ADC4_SMPR_SMPSEL7   ADC4_SMPR_SMPSEL7_Msk
#define ADC4_SMPR_SMPSEL8_Pos   (16U)
#define ADC4_SMPR_SMPSEL8_Msk   (0x1UL << ADC4_SMPR_SMPSEL8_Pos)
#define ADC4_SMPR_SMPSEL8   ADC4_SMPR_SMPSEL8_Msk
#define ADC4_SMPR_SMPSEL9_Pos   (17U)
#define ADC4_SMPR_SMPSEL9_Msk   (0x1UL << ADC4_SMPR_SMPSEL9_Pos)
#define ADC4_SMPR_SMPSEL9   ADC4_SMPR_SMPSEL9_Msk
#define ADC4_SMPR_SMPSEL10_Pos   (18U)
#define ADC4_SMPR_SMPSEL10_Msk   (0x1UL << ADC4_SMPR_SMPSEL10_Pos)
#define ADC4_SMPR_SMPSEL10   ADC4_SMPR_SMPSEL10_Msk
#define ADC4_SMPR_SMPSEL11_Pos   (19U)
#define ADC4_SMPR_SMPSEL11_Msk   (0x1UL << ADC4_SMPR_SMPSEL11_Pos)
#define ADC4_SMPR_SMPSEL11   ADC4_SMPR_SMPSEL11_Msk
#define ADC4_SMPR_SMPSEL12_Pos   (20U)
#define ADC4_SMPR_SMPSEL12_Msk   (0x1UL << ADC4_SMPR_SMPSEL12_Pos)
#define ADC4_SMPR_SMPSEL12   ADC4_SMPR_SMPSEL12_Msk
#define ADC4_SMPR_SMPSEL13_Pos   (21U)
#define ADC4_SMPR_SMPSEL13_Msk   (0x1UL << ADC4_SMPR_SMPSEL13_Pos)
#define ADC4_SMPR_SMPSEL13   ADC4_SMPR_SMPSEL13_Msk
#define ADC4_SMPR_SMPSEL14_Pos   (22U)
#define ADC4_SMPR_SMPSEL14_Msk   (0x1UL << ADC4_SMPR_SMPSEL14_Pos)
#define ADC4_SMPR_SMPSEL14   ADC4_SMPR_SMPSEL14_Msk
#define ADC4_SMPR_SMPSEL15_Pos   (23U)
#define ADC4_SMPR_SMPSEL15_Msk   (0x1UL << ADC4_SMPR_SMPSEL15_Pos)
#define ADC4_SMPR_SMPSEL15   ADC4_SMPR_SMPSEL15_Msk
#define ADC4_SMPR_SMPSEL16_Pos   (24U)
#define ADC4_SMPR_SMPSEL16_Msk   (0x1UL << ADC4_SMPR_SMPSEL16_Pos)
#define ADC4_SMPR_SMPSEL16   ADC4_SMPR_SMPSEL16_Msk
#define ADC4_SMPR_SMPSEL17_Pos   (25U)
#define ADC4_SMPR_SMPSEL17_Msk   (0x1UL << ADC4_SMPR_SMPSEL17_Pos)
#define ADC4_SMPR_SMPSEL17   ADC4_SMPR_SMPSEL17_Msk
#define ADC4_SMPR_SMPSEL18_Pos   (26U)
#define ADC4_SMPR_SMPSEL18_Msk   (0x1UL << ADC4_SMPR_SMPSEL18_Pos)
#define ADC4_SMPR_SMPSEL18   ADC4_SMPR_SMPSEL18_Msk
#define ADC4_SMPR_SMPSEL19_Pos   (27U)
#define ADC4_SMPR_SMPSEL19_Msk   (0x1UL << ADC4_SMPR_SMPSEL19_Pos)
#define ADC4_SMPR_SMPSEL19   ADC4_SMPR_SMPSEL19_Msk
#define ADC4_SMPR_SMPSEL20_Pos   (26U)
#define ADC4_SMPR_SMPSEL20_Msk   (0x1UL << ADC4_SMPR_SMPSEL20_Pos)
#define ADC4_SMPR_SMPSEL20   ADC4_SMPR_SMPSEL20_Msk
#define ADC4_SMPR_SMPSEL21_Pos   (26U)
#define ADC4_SMPR_SMPSEL21_Msk   (0x1UL << ADC4_SMPR_SMPSEL21_Pos)
#define ADC4_SMPR_SMPSEL21   ADC4_SMPR_SMPSEL21_Msk
#define ADC4_SMPR_SMPSEL22_Pos   (30U)
#define ADC4_SMPR_SMPSEL22_Msk   (0x1UL << ADC4_SMPR_SMPSEL22_Pos)
#define ADC4_SMPR_SMPSEL22   ADC4_SMPR_SMPSEL22_Msk
#define ADC4_SMPR_SMPSEL23_Pos   (31U)
#define ADC4_SMPR_SMPSEL23_Msk   (0x1UL << ADC4_SMPR_SMPSEL23_Pos)
#define ADC4_SMPR_SMPSEL23   ADC4_SMPR_SMPSEL23_Msk
#define ADC_SMPR2_SMP10_Pos   (0U)
#define ADC_SMPR2_SMP10_Msk   (0x7UL << ADC_SMPR2_SMP10_Pos)
#define ADC_SMPR2_SMP10   ADC_SMPR2_SMP10_Msk
#define ADC_SMPR2_SMP10_0   (0x1UL << ADC_SMPR2_SMP10_Pos)
#define ADC_SMPR2_SMP10_1   (0x2UL << ADC_SMPR2_SMP10_Pos)
#define ADC_SMPR2_SMP10_2   (0x4UL << ADC_SMPR2_SMP10_Pos)
#define ADC_SMPR2_SMP11_Pos   (3U)
#define ADC_SMPR2_SMP11_Msk   (0x7UL << ADC_SMPR2_SMP11_Pos)
#define ADC_SMPR2_SMP11   ADC_SMPR2_SMP11_Msk
#define ADC_SMPR2_SMP11_0   (0x1UL << ADC_SMPR2_SMP11_Pos)
#define ADC_SMPR2_SMP11_1   (0x2UL << ADC_SMPR2_SMP11_Pos)
#define ADC_SMPR2_SMP11_2   (0x4UL << ADC_SMPR2_SMP11_Pos)
#define ADC_SMPR2_SMP12_Pos   (6U)
#define ADC_SMPR2_SMP12_Msk   (0x7UL << ADC_SMPR2_SMP12_Pos)
#define ADC_SMPR2_SMP12   ADC_SMPR2_SMP12_Msk
#define ADC_SMPR2_SMP12_0   (0x1UL << ADC_SMPR2_SMP12_Pos)
#define ADC_SMPR2_SMP12_1   (0x2UL << ADC_SMPR2_SMP12_Pos)
#define ADC_SMPR2_SMP12_2   (0x4UL << ADC_SMPR2_SMP12_Pos)
#define ADC_SMPR2_SMP13_Pos   (9U)
#define ADC_SMPR2_SMP13_Msk   (0x7UL << ADC_SMPR2_SMP13_Pos)
#define ADC_SMPR2_SMP13   ADC_SMPR2_SMP13_Msk
#define ADC_SMPR2_SMP13_0   (0x1UL << ADC_SMPR2_SMP13_Pos)
#define ADC_SMPR2_SMP13_1   (0x2UL << ADC_SMPR2_SMP13_Pos)
#define ADC_SMPR2_SMP13_2   (0x4UL << ADC_SMPR2_SMP13_Pos)
#define ADC_SMPR2_SMP14_Pos   (12U)
#define ADC_SMPR2_SMP14_Msk   (0x7UL << ADC_SMPR2_SMP14_Pos)
#define ADC_SMPR2_SMP14   ADC_SMPR2_SMP14_Msk
#define ADC_SMPR2_SMP14_0   (0x1UL << ADC_SMPR2_SMP14_Pos)
#define ADC_SMPR2_SMP14_1   (0x2UL << ADC_SMPR2_SMP14_Pos)
#define ADC_SMPR2_SMP14_2   (0x4UL << ADC_SMPR2_SMP14_Pos)
#define ADC_SMPR2_SMP15_Pos   (15U)
#define ADC_SMPR2_SMP15_Msk   (0x7UL << ADC_SMPR2_SMP15_Pos)
#define ADC_SMPR2_SMP15   ADC_SMPR2_SMP15_Msk
#define ADC_SMPR2_SMP15_0   (0x1UL << ADC_SMPR2_SMP15_Pos)
#define ADC_SMPR2_SMP15_1   (0x2UL << ADC_SMPR2_SMP15_Pos)
#define ADC_SMPR2_SMP15_2   (0x4UL << ADC_SMPR2_SMP15_Pos)
#define ADC_SMPR2_SMP16_Pos   (18U)
#define ADC_SMPR2_SMP16_Msk   (0x7UL << ADC_SMPR2_SMP16_Pos)
#define ADC_SMPR2_SMP16   ADC_SMPR2_SMP16_Msk
#define ADC_SMPR2_SMP16_0   (0x1UL << ADC_SMPR2_SMP16_Pos)
#define ADC_SMPR2_SMP16_1   (0x2UL << ADC_SMPR2_SMP16_Pos)
#define ADC_SMPR2_SMP16_2   (0x4UL << ADC_SMPR2_SMP16_Pos)
#define ADC_SMPR2_SMP17_Pos   (21U)
#define ADC_SMPR2_SMP17_Msk   (0x7UL << ADC_SMPR2_SMP17_Pos)
#define ADC_SMPR2_SMP17   ADC_SMPR2_SMP17_Msk
#define ADC_SMPR2_SMP17_0   (0x1UL << ADC_SMPR2_SMP17_Pos)
#define ADC_SMPR2_SMP17_1   (0x2UL << ADC_SMPR2_SMP17_Pos)
#define ADC_SMPR2_SMP17_2   (0x4UL << ADC_SMPR2_SMP17_Pos)
#define ADC_SMPR2_SMP18_Pos   (24U)
#define ADC_SMPR2_SMP18_Msk   (0x7UL << ADC_SMPR2_SMP18_Pos)
#define ADC_SMPR2_SMP18   ADC_SMPR2_SMP18_Msk
#define ADC_SMPR2_SMP18_0   (0x1UL << ADC_SMPR2_SMP18_Pos)
#define ADC_SMPR2_SMP18_1   (0x2UL << ADC_SMPR2_SMP18_Pos)
#define ADC_SMPR2_SMP18_2   (0x4UL << ADC_SMPR2_SMP18_Pos)
#define ADC_SMPR2_SMP19_Pos   (27U)
#define ADC_SMPR2_SMP19_Msk   (0x7UL << ADC_SMPR2_SMP19_Pos)
#define ADC_SMPR2_SMP19   ADC_SMPR2_SMP19_Msk
#define ADC_SMPR2_SMP19_0   (0x1UL << ADC_SMPR2_SMP19_Pos)
#define ADC_SMPR2_SMP19_1   (0x2UL << ADC_SMPR2_SMP19_Pos)
#define ADC_SMPR2_SMP19_2   (0x4UL << ADC_SMPR2_SMP19_Pos)
#define ADC_PCSEL_PCSEL_Pos   (0U)
#define ADC_PCSEL_PCSEL_Msk   (0xFFFFFUL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL   ADC_PCSEL_PCSEL_Msk
#define ADC_PCSEL_PCSEL_0   (0x00001UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_1   (0x00002UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_2   (0x00004UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_3   (0x00008UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_4   (0x00010UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_5   (0x00020UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_6   (0x00040UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_7   (0x00080UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_8   (0x00100UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_9   (0x00200UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_10   (0x00400UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_11   (0x00800UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_12   (0x01000UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_13   (0x02000UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_14   (0x04000UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_15   (0x08000UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_16   (0x10000UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_17   (0x20000UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_18   (0x40000UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_19   (0x80000UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_LTR_LT_Pos   (0U)
#define ADC_LTR_LT_Msk   (0x01FFFFFFUL << ADC_LTR_LT_Pos)
#define ADC_LTR_LT   ADC_LTR_LT_Msk
#define ADC_HTR_HT_Pos   (0U)
#define ADC_HTR_HT_Msk   (0x01FFFFFFUL << ADC_HTR_HT_Pos)
#define ADC_HTR_HT   ADC_HTR_HT_Msk
#define ADC_HTR_AWDFILT_Pos   (29U)
#define ADC_HTR_AWDFILT_Msk   (0x7UL << ADC_HTR_AWDFILT_Pos)
#define ADC_HTR_AWDFILT   ADC_HTR_AWDFILT_Msk
#define ADC_HTR_AWDFILT_0   (0x1UL << ADC_HTR_AWDFILT_Pos)
#define ADC_HTR_AWDFILT_1   (0x2UL << ADC_HTR_AWDFILT_Pos)
#define ADC_HTR_AWDFILT_2   (0x4UL << ADC_HTR_AWDFILT_Pos)
#define ADC_SQR1_L_Pos   (0U)
#define ADC_SQR1_L_Msk   (0xFUL << ADC_SQR1_L_Pos)
#define ADC_SQR1_L   ADC_SQR1_L_Msk
#define ADC_SQR1_L_0   (0x1UL << ADC_SQR1_L_Pos)
#define ADC_SQR1_L_1   (0x2UL << ADC_SQR1_L_Pos)
#define ADC_SQR1_L_2   (0x4UL << ADC_SQR1_L_Pos)
#define ADC_SQR1_L_3   (0x8UL << ADC_SQR1_L_Pos)
#define ADC_SQR1_SQ1_Pos   (6U)
#define ADC_SQR1_SQ1_Msk   (0x1FUL << ADC_SQR1_SQ1_Pos)
#define ADC_SQR1_SQ1   ADC_SQR1_SQ1_Msk
#define ADC_SQR1_SQ1_0   (0x01UL << ADC_SQR1_SQ1_Pos)
#define ADC_SQR1_SQ1_1   (0x02UL << ADC_SQR1_SQ1_Pos)
#define ADC_SQR1_SQ1_2   (0x04UL << ADC_SQR1_SQ1_Pos)
#define ADC_SQR1_SQ1_3   (0x08UL << ADC_SQR1_SQ1_Pos)
#define ADC_SQR1_SQ1_4   (0x10UL << ADC_SQR1_SQ1_Pos)
#define ADC_SQR1_SQ2_Pos   (12U)
#define ADC_SQR1_SQ2_Msk   (0x1FUL << ADC_SQR1_SQ2_Pos)
#define ADC_SQR1_SQ2   ADC_SQR1_SQ2_Msk
#define ADC_SQR1_SQ2_0   (0x01UL << ADC_SQR1_SQ2_Pos)
#define ADC_SQR1_SQ2_1   (0x02UL << ADC_SQR1_SQ2_Pos)
#define ADC_SQR1_SQ2_2   (0x04UL << ADC_SQR1_SQ2_Pos)
#define ADC_SQR1_SQ2_3   (0x08UL << ADC_SQR1_SQ2_Pos)
#define ADC_SQR1_SQ2_4   (0x10UL << ADC_SQR1_SQ2_Pos)
#define ADC_SQR1_SQ3_Pos   (18U)
#define ADC_SQR1_SQ3_Msk   (0x1FUL << ADC_SQR1_SQ3_Pos)
#define ADC_SQR1_SQ3   ADC_SQR1_SQ3_Msk
#define ADC_SQR1_SQ3_0   (0x01UL << ADC_SQR1_SQ3_Pos)
#define ADC_SQR1_SQ3_1   (0x02UL << ADC_SQR1_SQ3_Pos)
#define ADC_SQR1_SQ3_2   (0x04UL << ADC_SQR1_SQ3_Pos)
#define ADC_SQR1_SQ3_3   (0x08UL << ADC_SQR1_SQ3_Pos)
#define ADC_SQR1_SQ3_4   (0x10UL << ADC_SQR1_SQ3_Pos)
#define ADC_SQR1_SQ4_Pos   (24U)
#define ADC_SQR1_SQ4_Msk   (0x1FUL << ADC_SQR1_SQ4_Pos)
#define ADC_SQR1_SQ4   ADC_SQR1_SQ4_Msk
#define ADC_SQR1_SQ4_0   (0x01UL << ADC_SQR1_SQ4_Pos)
#define ADC_SQR1_SQ4_1   (0x02UL << ADC_SQR1_SQ4_Pos)
#define ADC_SQR1_SQ4_2   (0x04UL << ADC_SQR1_SQ4_Pos)
#define ADC_SQR1_SQ4_3   (0x08UL << ADC_SQR1_SQ4_Pos)
#define ADC_SQR1_SQ4_4   (0x10UL << ADC_SQR1_SQ4_Pos)
#define ADC_SQR2_SQ5_Pos   (0U)
#define ADC_SQR2_SQ5_Msk   (0x1FUL << ADC_SQR2_SQ5_Pos)
#define ADC_SQR2_SQ5   ADC_SQR2_SQ5_Msk
#define ADC_SQR2_SQ5_0   (0x01UL << ADC_SQR2_SQ5_Pos)
#define ADC_SQR2_SQ5_1   (0x02UL << ADC_SQR2_SQ5_Pos)
#define ADC_SQR2_SQ5_2   (0x04UL << ADC_SQR2_SQ5_Pos)
#define ADC_SQR2_SQ5_3   (0x08UL << ADC_SQR2_SQ5_Pos)
#define ADC_SQR2_SQ5_4   (0x10UL << ADC_SQR2_SQ5_Pos)
#define ADC_SQR2_SQ6_Pos   (6U)
#define ADC_SQR2_SQ6_Msk   (0x1FUL << ADC_SQR2_SQ6_Pos)
#define ADC_SQR2_SQ6   ADC_SQR2_SQ6_Msk
#define ADC_SQR2_SQ6_0   (0x01UL << ADC_SQR2_SQ6_Pos)
#define ADC_SQR2_SQ6_1   (0x02UL << ADC_SQR2_SQ6_Pos)
#define ADC_SQR2_SQ6_2   (0x04UL << ADC_SQR2_SQ6_Pos)
#define ADC_SQR2_SQ6_3   (0x08UL << ADC_SQR2_SQ6_Pos)
#define ADC_SQR2_SQ6_4   (0x10UL << ADC_SQR2_SQ6_Pos)
#define ADC_SQR2_SQ7_Pos   (12U)
#define ADC_SQR2_SQ7_Msk   (0x1FUL << ADC_SQR2_SQ7_Pos)
#define ADC_SQR2_SQ7   ADC_SQR2_SQ7_Msk
#define ADC_SQR2_SQ7_0   (0x01UL << ADC_SQR2_SQ7_Pos)
#define ADC_SQR2_SQ7_1   (0x02UL << ADC_SQR2_SQ7_Pos)
#define ADC_SQR2_SQ7_2   (0x04UL << ADC_SQR2_SQ7_Pos)
#define ADC_SQR2_SQ7_3   (0x08UL << ADC_SQR2_SQ7_Pos)
#define ADC_SQR2_SQ7_4   (0x10UL << ADC_SQR2_SQ7_Pos)
#define ADC_SQR2_SQ8_Pos   (18U)
#define ADC_SQR2_SQ8_Msk   (0x1FUL << ADC_SQR2_SQ8_Pos)
#define ADC_SQR2_SQ8   ADC_SQR2_SQ8_Msk
#define ADC_SQR2_SQ8_0   (0x01UL << ADC_SQR2_SQ8_Pos)
#define ADC_SQR2_SQ8_1   (0x02UL << ADC_SQR2_SQ8_Pos)
#define ADC_SQR2_SQ8_2   (0x04UL << ADC_SQR2_SQ8_Pos)
#define ADC_SQR2_SQ8_3   (0x08UL << ADC_SQR2_SQ8_Pos)
#define ADC_SQR2_SQ8_4   (0x10UL << ADC_SQR2_SQ8_Pos)
#define ADC_SQR2_SQ9_Pos   (24U)
#define ADC_SQR2_SQ9_Msk   (0x1FUL << ADC_SQR2_SQ9_Pos)
#define ADC_SQR2_SQ9   ADC_SQR2_SQ9_Msk
#define ADC_SQR2_SQ9_0   (0x01UL << ADC_SQR2_SQ9_Pos)
#define ADC_SQR2_SQ9_1   (0x02UL << ADC_SQR2_SQ9_Pos)
#define ADC_SQR2_SQ9_2   (0x04UL << ADC_SQR2_SQ9_Pos)
#define ADC_SQR2_SQ9_3   (0x08UL << ADC_SQR2_SQ9_Pos)
#define ADC_SQR2_SQ9_4   (0x10UL << ADC_SQR2_SQ9_Pos)
#define ADC_SQR3_SQ10_Pos   (0U)
#define ADC_SQR3_SQ10_Msk   (0x1FUL << ADC_SQR3_SQ10_Pos)
#define ADC_SQR3_SQ10   ADC_SQR3_SQ10_Msk
#define ADC_SQR3_SQ10_0   (0x01UL << ADC_SQR3_SQ10_Pos)
#define ADC_SQR3_SQ10_1   (0x02UL << ADC_SQR3_SQ10_Pos)
#define ADC_SQR3_SQ10_2   (0x04UL << ADC_SQR3_SQ10_Pos)
#define ADC_SQR3_SQ10_3   (0x08UL << ADC_SQR3_SQ10_Pos)
#define ADC_SQR3_SQ10_4   (0x10UL << ADC_SQR3_SQ10_Pos)
#define ADC_SQR3_SQ11_Pos   (6U)
#define ADC_SQR3_SQ11_Msk   (0x1FUL << ADC_SQR3_SQ11_Pos)
#define ADC_SQR3_SQ11   ADC_SQR3_SQ11_Msk
#define ADC_SQR3_SQ11_0   (0x01UL << ADC_SQR3_SQ11_Pos)
#define ADC_SQR3_SQ11_1   (0x02UL << ADC_SQR3_SQ11_Pos)
#define ADC_SQR3_SQ11_2   (0x04UL << ADC_SQR3_SQ11_Pos)
#define ADC_SQR3_SQ11_3   (0x08UL << ADC_SQR3_SQ11_Pos)
#define ADC_SQR3_SQ11_4   (0x10UL << ADC_SQR3_SQ11_Pos)
#define ADC_SQR3_SQ12_Pos   (12U)
#define ADC_SQR3_SQ12_Msk   (0x1FUL << ADC_SQR3_SQ12_Pos)
#define ADC_SQR3_SQ12   ADC_SQR3_SQ12_Msk
#define ADC_SQR3_SQ12_0   (0x01UL << ADC_SQR3_SQ12_Pos)
#define ADC_SQR3_SQ12_1   (0x02UL << ADC_SQR3_SQ12_Pos)
#define ADC_SQR3_SQ12_2   (0x04UL << ADC_SQR3_SQ12_Pos)
#define ADC_SQR3_SQ12_3   (0x08UL << ADC_SQR3_SQ12_Pos)
#define ADC_SQR3_SQ12_4   (0x10UL << ADC_SQR3_SQ12_Pos)
#define ADC_SQR3_SQ13_Pos   (18U)
#define ADC_SQR3_SQ13_Msk   (0x1FUL << ADC_SQR3_SQ13_Pos)
#define ADC_SQR3_SQ13   ADC_SQR3_SQ13_Msk
#define ADC_SQR3_SQ13_0   (0x01UL << ADC_SQR3_SQ13_Pos)
#define ADC_SQR3_SQ13_1   (0x02UL << ADC_SQR3_SQ13_Pos)
#define ADC_SQR3_SQ13_2   (0x04UL << ADC_SQR3_SQ13_Pos)
#define ADC_SQR3_SQ13_3   (0x08UL << ADC_SQR3_SQ13_Pos)
#define ADC_SQR3_SQ13_4   (0x10UL << ADC_SQR3_SQ13_Pos)
#define ADC_SQR3_SQ14_Pos   (24U)
#define ADC_SQR3_SQ14_Msk   (0x1FUL << ADC_SQR3_SQ14_Pos)
#define ADC_SQR3_SQ14   ADC_SQR3_SQ14_Msk
#define ADC_SQR3_SQ14_0   (0x01UL << ADC_SQR3_SQ14_Pos)
#define ADC_SQR3_SQ14_1   (0x02UL << ADC_SQR3_SQ14_Pos)
#define ADC_SQR3_SQ14_2   (0x04UL << ADC_SQR3_SQ14_Pos)
#define ADC_SQR3_SQ14_3   (0x08UL << ADC_SQR3_SQ14_Pos)
#define ADC_SQR3_SQ14_4   (0x10UL << ADC_SQR3_SQ14_Pos)
#define ADC_SQR4_SQ15_Pos   (0U)
#define ADC_SQR4_SQ15_Msk   (0x1FUL << ADC_SQR4_SQ15_Pos)
#define ADC_SQR4_SQ15   ADC_SQR4_SQ15_Msk
#define ADC_SQR4_SQ15_0   (0x01UL << ADC_SQR4_SQ15_Pos)
#define ADC_SQR4_SQ15_1   (0x02UL << ADC_SQR4_SQ15_Pos)
#define ADC_SQR4_SQ15_2   (0x04UL << ADC_SQR4_SQ15_Pos)
#define ADC_SQR4_SQ15_3   (0x08UL << ADC_SQR4_SQ15_Pos)
#define ADC_SQR4_SQ15_4   (0x10UL << ADC_SQR4_SQ15_Pos)
#define ADC_SQR4_SQ16_Pos   (6U)
#define ADC_SQR4_SQ16_Msk   (0x1FUL << ADC_SQR4_SQ16_Pos)
#define ADC_SQR4_SQ16   ADC_SQR4_SQ16_Msk
#define ADC_SQR4_SQ16_0   (0x01UL << ADC_SQR4_SQ16_Pos)
#define ADC_SQR4_SQ16_1   (0x02UL << ADC_SQR4_SQ16_Pos)
#define ADC_SQR4_SQ16_2   (0x04UL << ADC_SQR4_SQ16_Pos)
#define ADC_SQR4_SQ16_3   (0x08UL << ADC_SQR4_SQ16_Pos)
#define ADC_SQR4_SQ16_4   (0x10UL << ADC_SQR4_SQ16_Pos)
#define ADC_DR_RDATA_Pos   (0U)
#define ADC_DR_RDATA_Msk   (0xFFFFFFFFUL << ADC_DR_RDATA_Pos)
#define ADC_DR_RDATA   ADC_DR_RDATA_Msk
#define ADC4_PWRR_AUTOFF_Pos   (0U)
#define ADC4_PWRR_AUTOFF_Msk   (0x1UL << ADC4_PWRR_AUTOFF_Pos)
#define ADC4_PWRR_AUTOFF   ADC4_PWRR_AUTOFF_Msk
#define ADC4_PWRR_DPD_Pos   (1U)
#define ADC4_PWRR_DPD_Msk   (0x1UL << ADC4_PWRR_DPD_Pos)
#define ADC4_PWRR_DPD   ADC4_PWRR_DPD_Msk
#define ADC4_PWRR_VREFPROT_Pos   (2U)
#define ADC4_PWRR_VREFPROT_Msk   (0x1UL << ADC4_PWRR_VREFPROT_Pos)
#define ADC4_PWRR_VREFPROT   ADC4_PWRR_VREFPROT_Msk
#define ADC4_PWRR_VREFSECSMP_Pos   (3U)
#define ADC4_PWRR_VREFSECSMP_Msk   (0x1UL << ADC4_PWRR_VREFSECSMP_Pos)
#define ADC4_PWRR_VREFSECSMP   ADC4_PWRR_VREFSECSMP_Msk
#define ADC4_PW_AUTOFF_Pos   ADC4_PWRR_AUTOFF_Pos
#define ADC4_PW_AUTOFF_Msk   ADC4_PWRR_AUTOFF_Msk
#define ADC4_PW_AUTOFF   ADC4_PWRR_AUTOFF
#define ADC4_PW_DPD_Pos   ADC4_PWRR_DPD_Pos
#define ADC4_PW_DPD_Msk   ADC4_PWRR_DPD_Msk
#define ADC4_PW_DPD   ADC4_PWRR_DPD
#define ADC4_PW_VREFPROT_Pos   ADC4_PWRR_VREFPROT_Pos
#define ADC4_PW_VREFPROT_Msk   ADC4_PWRR_VREFPROT_Msk
#define ADC4_PW_VREFPROT   ADC4_PWRR_VREFPROT
#define ADC4_PW_VREFSECSMP_Pos   ADC4_PWRR_VREFSECSMP_Pos
#define ADC4_PW_VREFSECSMP_Msk   ADC4_PWRR_VREFSECSMP_Msk
#define ADC4_PW_VREFSECSMP   ADC4_PWRR_VREFSECSMP
#define ADC_JSQR_JL_Pos   (0U)
#define ADC_JSQR_JL_Msk   (0x3UL << ADC_JSQR_JL_Pos)
#define ADC_JSQR_JL   ADC_JSQR_JL_Msk
#define ADC_JSQR_JL_0   (0x1UL << ADC_JSQR_JL_Pos)
#define ADC_JSQR_JL_1   (0x2UL << ADC_JSQR_JL_Pos)
#define ADC_JSQR_JEXTSEL_Pos   (2U)
#define ADC_JSQR_JEXTSEL_Msk   (0x1FUL << ADC_JSQR_JEXTSEL_Pos)
#define ADC_JSQR_JEXTSEL   ADC_JSQR_JEXTSEL_Msk
#define ADC_JSQR_JEXTSEL_0   (0x01UL << ADC_JSQR_JEXTSEL_Pos)
#define ADC_JSQR_JEXTSEL_1   (0x02UL << ADC_JSQR_JEXTSEL_Pos)
#define ADC_JSQR_JEXTSEL_2   (0x04UL << ADC_JSQR_JEXTSEL_Pos)
#define ADC_JSQR_JEXTSEL_3   (0x08UL << ADC_JSQR_JEXTSEL_Pos)
#define ADC_JSQR_JEXTSEL_4   (0x10UL << ADC_JSQR_JEXTSEL_Pos)
#define ADC_JSQR_JEXTEN_Pos   (7U)
#define ADC_JSQR_JEXTEN_Msk   (0x3UL << ADC_JSQR_JEXTEN_Pos)
#define ADC_JSQR_JEXTEN   ADC_JSQR_JEXTEN_Msk
#define ADC_JSQR_JEXTEN_0   (0x1UL << ADC_JSQR_JEXTEN_Pos)
#define ADC_JSQR_JEXTEN_1   (0x2UL << ADC_JSQR_JEXTEN_Pos)
#define ADC_JSQR_JSQ1_Pos   (9U)
#define ADC_JSQR_JSQ1_Msk   (0x1FUL << ADC_JSQR_JSQ1_Pos)
#define ADC_JSQR_JSQ1   ADC_JSQR_JSQ1_Msk
#define ADC_JSQR_JSQ1_0   (0x01UL << ADC_JSQR_JSQ1_Pos)
#define ADC_JSQR_JSQ1_1   (0x02UL << ADC_JSQR_JSQ1_Pos)
#define ADC_JSQR_JSQ1_2   (0x04UL << ADC_JSQR_JSQ1_Pos)
#define ADC_JSQR_JSQ1_3   (0x08UL << ADC_JSQR_JSQ1_Pos)
#define ADC_JSQR_JSQ1_4   (0x10UL << ADC_JSQR_JSQ1_Pos)
#define ADC_JSQR_JSQ2_Pos   (15U)
#define ADC_JSQR_JSQ2_Msk   (0x1FUL << ADC_JSQR_JSQ2_Pos)
#define ADC_JSQR_JSQ2   ADC_JSQR_JSQ2_Msk
#define ADC_JSQR_JSQ2_0   (0x01UL << ADC_JSQR_JSQ2_Pos)
#define ADC_JSQR_JSQ2_1   (0x02UL << ADC_JSQR_JSQ2_Pos)
#define ADC_JSQR_JSQ2_2   (0x04UL << ADC_JSQR_JSQ2_Pos)
#define ADC_JSQR_JSQ2_3   (0x08UL << ADC_JSQR_JSQ2_Pos)
#define ADC_JSQR_JSQ2_4   (0x10UL << ADC_JSQR_JSQ2_Pos)
#define ADC_JSQR_JSQ3_Pos   (21U)
#define ADC_JSQR_JSQ3_Msk   (0x1FUL << ADC_JSQR_JSQ3_Pos)
#define ADC_JSQR_JSQ3   ADC_JSQR_JSQ3_Msk
#define ADC_JSQR_JSQ3_0   (0x01UL << ADC_JSQR_JSQ3_Pos)
#define ADC_JSQR_JSQ3_1   (0x02UL << ADC_JSQR_JSQ3_Pos)
#define ADC_JSQR_JSQ3_2   (0x04UL << ADC_JSQR_JSQ3_Pos)
#define ADC_JSQR_JSQ3_3   (0x08UL << ADC_JSQR_JSQ3_Pos)
#define ADC_JSQR_JSQ3_4   (0x10UL << ADC_JSQR_JSQ3_Pos)
#define ADC_JSQR_JSQ4_Pos   (27U)
#define ADC_JSQR_JSQ4_Msk   (0x1FUL << ADC_JSQR_JSQ4_Pos)
#define ADC_JSQR_JSQ4   ADC_JSQR_JSQ4_Msk
#define ADC_JSQR_JSQ4_0   (0x01UL << ADC_JSQR_JSQ4_Pos)
#define ADC_JSQR_JSQ4_1   (0x02UL << ADC_JSQR_JSQ4_Pos)
#define ADC_JSQR_JSQ4_2   (0x04UL << ADC_JSQR_JSQ4_Pos)
#define ADC_JSQR_JSQ4_3   (0x08UL << ADC_JSQR_JSQ4_Pos)
#define ADC_JSQR_JSQ4_4   (0x10UL << ADC_JSQR_JSQ4_Pos)
#define ADC_OFR1_OFFSET1_Pos   (0U)
#define ADC_OFR1_OFFSET1_Msk   (0x00FFFFFFUL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1   ADC_OFR1_OFFSET1_Msk
#define ADC_OFR1_OFFSET1_0   (0x0000001UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_1   (0x0000002UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_2   (0x0000004UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_3   (0x0000008UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_4   (0x0000010UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_5   (0x0000020UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_6   (0x0000040UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_7   (0x0000080UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_8   (0x0000100UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_9   (0x0000200UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_10   (0x0000400UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_11   (0x0000800UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_12   (0x0001000UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_13   (0x0002000UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_14   (0x0004000UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_15   (0x0008000UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_16   (0x0010000UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_17   (0x0020000UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_18   (0x0040000UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_19   (0x0080000UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_20   (0x0100000UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_21   (0x0200000UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_22   (0x0400000UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_23   (0x0800000UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSETPOS_Pos   (24U)
#define ADC_OFR1_OFFSETPOS_Msk   (0x1UL << ADC_OFR1_OFFSETPOS_Pos)
#define ADC_OFR1_OFFSETPOS   ADC_OFR1_OFFSETPOS_Msk
#define ADC_OFR1_USAT_Pos   (25U)
#define ADC_OFR1_USAT_Msk   (0x1UL << ADC_OFR1_USAT_Pos)
#define ADC_OFR1_USAT   ADC_OFR1_USAT_Msk
#define ADC_OFR1_SSAT_Pos   (26U)
#define ADC_OFR1_SSAT_Msk   (0x1UL << ADC_OFR1_SSAT_Pos)
#define ADC_OFR1_SSAT   ADC_OFR1_SSAT_Msk
#define ADC_OFR1_OFFSET1_CH_Pos   (27U)
#define ADC_OFR1_OFFSET1_CH_Msk   (0x1FUL << ADC_OFR1_OFFSET1_CH_Pos)
#define ADC_OFR1_OFFSET1_CH   ADC_OFR1_OFFSET1_CH_Msk
#define ADC_OFR1_OFFSET1_CH_0   (0x01UL << ADC_OFR1_OFFSET1_CH_Pos)
#define ADC_OFR1_OFFSET1_CH_1   (0x02UL << ADC_OFR1_OFFSET1_CH_Pos)
#define ADC_OFR1_OFFSET1_CH_2   (0x04UL << ADC_OFR1_OFFSET1_CH_Pos)
#define ADC_OFR1_OFFSET1_CH_3   (0x08UL << ADC_OFR1_OFFSET1_CH_Pos)
#define ADC_OFR1_OFFSET1_CH_4   (0x10UL << ADC_OFR1_OFFSET1_CH_Pos)
#define ADC_OFR2_OFFSET2_Pos   (0U)
#define ADC_OFR2_OFFSET2_Msk   (0x00FFFFFFUL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2   ADC_OFR2_OFFSET2_Msk
#define ADC_OFR2_OFFSET2_0   (0x0000001UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_1   (0x0000002UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_2   (0x0000004UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_3   (0x0000008UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_4   (0x0000010UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_5   (0x0000020UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_6   (0x0000040UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_7   (0x0000080UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_8   (0x0000100UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_9   (0x0000200UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_10   (0x0000400UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_11   (0x0000800UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_12   (0x0001000UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_13   (0x0002000UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_14   (0x0004000UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_15   (0x0008000UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_16   (0x0010000UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_17   (0x0020000UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_18   (0x0040000UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_19   (0x0080000UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_20   (0x0100000UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_21   (0x0200000UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_22   (0x0400000UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_23   (0x0800000UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSETPOS_Pos   (24U)
#define ADC_OFR2_OFFSETPOS_Msk   (0x1UL << ADC_OFR2_OFFSETPOS_Pos)
#define ADC_OFR2_OFFSETPOS   ADC_OFR2_OFFSETPOS_Msk
#define ADC_OFR2_USAT_Pos   (25U)
#define ADC_OFR2_USAT_Msk   (0x1UL << ADC_OFR2_USAT_Pos)
#define ADC_OFR2_USAT   ADC_OFR2_USAT_Msk
#define ADC_OFR2_SSAT_Pos   (26U)
#define ADC_OFR2_SSAT_Msk   (0x1UL << ADC_OFR2_SSAT_Pos)
#define ADC_OFR2_SSAT   ADC_OFR2_SSAT_Msk
#define ADC_OFR2_OFFSET2_CH_Pos   (27U)
#define ADC_OFR2_OFFSET2_CH_Msk   (0x1FUL << ADC_OFR2_OFFSET2_CH_Pos)
#define ADC_OFR2_OFFSET2_CH   ADC_OFR2_OFFSET2_CH_Msk
#define ADC_OFR2_OFFSET2_CH_0   (0x01UL << ADC_OFR2_OFFSET2_CH_Pos)
#define ADC_OFR2_OFFSET2_CH_1   (0x02UL << ADC_OFR2_OFFSET2_CH_Pos)
#define ADC_OFR2_OFFSET2_CH_2   (0x04UL << ADC_OFR2_OFFSET2_CH_Pos)
#define ADC_OFR2_OFFSET2_CH_3   (0x08UL << ADC_OFR2_OFFSET2_CH_Pos)
#define ADC_OFR2_OFFSET2_CH_4   (0x10UL << ADC_OFR2_OFFSET2_CH_Pos)
#define ADC_OFR3_OFFSET3_Pos   (0U)
#define ADC_OFR3_OFFSET3_Msk   (0x00FFFFFFUL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3   ADC_OFR3_OFFSET3_Msk
#define ADC_OFR3_OFFSET3_0   (0x0000001UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_1   (0x0000002UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_2   (0x0000004UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_3   (0x0000008UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_4   (0x0000010UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_5   (0x0000020UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_6   (0x0000040UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_7   (0x0000080UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_8   (0x0000100UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_9   (0x0000200UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_10   (0x0000400UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_11   (0x0000800UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_12   (0x0001000UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_13   (0x0002000UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_14   (0x0004000UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_15   (0x0008000UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_16   (0x0010000UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_17   (0x0020000UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_18   (0x0040000UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_19   (0x0080000UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_20   (0x0100000UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_21   (0x0200000UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_22   (0x0400000UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_23   (0x0800000UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSETPOS_Pos   (24U)
#define ADC_OFR3_OFFSETPOS_Msk   (0x1UL << ADC_OFR3_OFFSETPOS_Pos)
#define ADC_OFR3_OFFSETPOS   ADC_OFR3_OFFSETPOS_Msk
#define ADC_OFR3_USAT_Pos   (25U)
#define ADC_OFR3_USAT_Msk   (0x1UL << ADC_OFR3_USAT_Pos)
#define ADC_OFR3_USAT   ADC_OFR3_USAT_Msk
#define ADC_OFR3_SSAT_Pos   (26U)
#define ADC_OFR3_SSAT_Msk   (0x1UL << ADC_OFR3_SSAT_Pos)
#define ADC_OFR3_SSAT   ADC_OFR3_SSAT_Msk
#define ADC_OFR3_OFFSET3_CH_Pos   (27U)
#define ADC_OFR3_OFFSET3_CH_Msk   (0x1FUL << ADC_OFR3_OFFSET3_CH_Pos)
#define ADC_OFR3_OFFSET3_CH   ADC_OFR3_OFFSET3_CH_Msk
#define ADC_OFR3_OFFSET3_CH_0   (0x01UL << ADC_OFR3_OFFSET3_CH_Pos)
#define ADC_OFR3_OFFSET3_CH_1   (0x02UL << ADC_OFR3_OFFSET3_CH_Pos)
#define ADC_OFR3_OFFSET3_CH_2   (0x04UL << ADC_OFR3_OFFSET3_CH_Pos)
#define ADC_OFR3_OFFSET3_CH_3   (0x08UL << ADC_OFR3_OFFSET3_CH_Pos)
#define ADC_OFR3_OFFSET3_CH_4   (0x10UL << ADC_OFR3_OFFSET3_CH_Pos)
#define ADC_OFR4_OFFSET4_Pos   (0U)
#define ADC_OFR4_OFFSET4_Msk   (0x00FFFFFFUL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4   ADC_OFR4_OFFSET4_Msk
#define ADC_OFR4_OFFSET4_0   (0x0000001UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_1   (0x0000002UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_2   (0x0000004UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_3   (0x0000008UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_4   (0x0000010UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_5   (0x0000020UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_6   (0x0000040UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_7   (0x0000080UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_8   (0x0000100UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_9   (0x0000200UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_10   (0x0000400UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_11   (0x0000800UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_12   (0x0001000UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_13   (0x0002000UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_14   (0x0004000UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_15   (0x0008000UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_16   (0x0010000UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_17   (0x0020000UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_18   (0x0040000UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_19   (0x0080000UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_20   (0x0100000UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_21   (0x0200000UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_22   (0x0400000UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_23   (0x0800000UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSETPOS_Pos   (24U)
#define ADC_OFR4_OFFSETPOS_Msk   (0x1UL << ADC_OFR4_OFFSETPOS_Pos)
#define ADC_OFR4_OFFSETPOS   ADC_OFR4_OFFSETPOS_Msk
#define ADC_OFR4_USAT_Pos   (25U)
#define ADC_OFR4_USAT_Msk   (0x1UL << ADC_OFR4_USAT_Pos)
#define ADC_OFR4_USAT   ADC_OFR4_USAT_Msk
#define ADC_OFR4_SSAT_Pos   (26U)
#define ADC_OFR4_SSAT_Msk   (0x1UL << ADC_OFR4_SSAT_Pos)
#define ADC_OFR4_SSAT   ADC_OFR4_SSAT_Msk
#define ADC_OFR4_OFFSET4_CH_Pos   (27U)
#define ADC_OFR4_OFFSET4_CH_Msk   (0x1FUL << ADC_OFR4_OFFSET4_CH_Pos)
#define ADC_OFR4_OFFSET4_CH   ADC_OFR4_OFFSET4_CH_Msk
#define ADC_OFR4_OFFSET4_CH_0   (0x01UL << ADC_OFR4_OFFSET4_CH_Pos)
#define ADC_OFR4_OFFSET4_CH_1   (0x02UL << ADC_OFR4_OFFSET4_CH_Pos)
#define ADC_OFR4_OFFSET4_CH_2   (0x04UL << ADC_OFR4_OFFSET4_CH_Pos)
#define ADC_OFR4_OFFSET4_CH_3   (0x08UL << ADC_OFR4_OFFSET4_CH_Pos)
#define ADC_OFR4_OFFSET4_CH_4   (0x10UL << ADC_OFR4_OFFSET4_CH_Pos)
#define ADC_GCOMP_GCOMPCOEFF_Pos   (0U)
#define ADC_GCOMP_GCOMPCOEFF_Msk   (0x3FFFUL << ADC_GCOMP_GCOMPCOEFF_Pos)
#define ADC_GCOMP_GCOMPCOEFF   ADC_GCOMP_GCOMPCOEFF_Msk
#define ADC_GCOMP_GCOMP_Pos   (31U)
#define ADC_GCOMP_GCOMP_Msk   (0x1UL << ADC_GCOMP_GCOMP_Pos)
#define ADC_GCOMP_GCOMP   ADC_GCOMP_GCOMP_Msk
#define ADC_JDR1_JDATA_Pos   (0U)
#define ADC_JDR1_JDATA_Msk   (0xFFFFFFFFUL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA   ADC_JDR1_JDATA_Msk
#define ADC_JDR1_JDATA_0   (0x00000001UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_1   (0x00000002UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_2   (0x00000004UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_3   (0x00000008UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_4   (0x00000010UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_5   (0x00000020UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_6   (0x00000040UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_7   (0x00000080UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_8   (0x00000100UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_9   (0x00000200UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_10   (0x00000400UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_11   (0x00000800UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_12   (0x00001000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_13   (0x00002000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_14   (0x00004000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_15   (0x00008000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_16   (0x00010000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_17   (0x00020000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_18   (0x00040000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_19   (0x00080000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_20   (0x00100000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_21   (0x00200000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_22   (0x00400000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_23   (0x00800000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_24   (0x01000000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_25   (0x02000000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_26   (0x04000000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_27   (0x08000000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_28   (0x10000000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_29   (0x20000000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_30   (0x40000000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_31   (0x80000000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR2_JDATA_Pos   (0U)
#define ADC_JDR2_JDATA_Msk   (0xFFFFFFFFUL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA   ADC_JDR2_JDATA_Msk
#define ADC_JDR2_JDATA_0   (0x00000001UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_1   (0x00000002UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_2   (0x00000004UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_3   (0x00000008UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_4   (0x00000010UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_5   (0x00000020UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_6   (0x00000040UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_7   (0x00000080UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_8   (0x00000100UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_9   (0x00000200UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_10   (0x00000400UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_11   (0x00000800UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_12   (0x00001000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_13   (0x00002000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_14   (0x00004000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_15   (0x00008000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_16   (0x00010000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_17   (0x00020000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_18   (0x00040000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_19   (0x00080000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_20   (0x00100000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_21   (0x00200000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_22   (0x00400000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_23   (0x00800000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_24   (0x01000000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_25   (0x02000000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_26   (0x04000000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_27   (0x08000000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_28   (0x10000000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_29   (0x20000000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_30   (0x40000000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_31   (0x80000000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR3_JDATA_Pos   (0U)
#define ADC_JDR3_JDATA_Msk   (0xFFFFFFFFUL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA   ADC_JDR3_JDATA_Msk
#define ADC_JDR3_JDATA_0   (0x00000001UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_1   (0x00000002UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_2   (0x00000004UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_3   (0x00000008UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_4   (0x00000010UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_5   (0x00000020UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_6   (0x00000040UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_7   (0x00000080UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_8   (0x00000100UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_9   (0x00000200UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_10   (0x00000400UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_11   (0x00000800UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_12   (0x00001000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_13   (0x00002000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_14   (0x00004000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_15   (0x00008000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_16   (0x00010000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_17   (0x00020000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_18   (0x00040000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_19   (0x00080000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_20   (0x00100000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_21   (0x00200000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_22   (0x00400000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_23   (0x00800000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_24   (0x01000000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_25   (0x02000000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_26   (0x04000000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_27   (0x08000000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_28   (0x10000000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_29   (0x20000000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_30   (0x40000000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_31   (0x80000000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR4_JDATA_Pos   (0U)
#define ADC_JDR4_JDATA_Msk   (0xFFFFFFFFUL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA   ADC_JDR4_JDATA_Msk
#define ADC_JDR4_JDATA_0   (0x00000001UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_1   (0x00000002UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_2   (0x00000004UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_3   (0x00000008UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_4   (0x00000010UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_5   (0x00000020UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_6   (0x00000040UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_7   (0x00000080UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_8   (0x00000100UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_9   (0x00000200UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_10   (0x00000400UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_11   (0x00000800UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_12   (0x00001000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_13   (0x00002000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_14   (0x00004000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_15   (0x00008000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_16   (0x00010000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_17   (0x00020000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_18   (0x00040000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_19   (0x00080000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_20   (0x00100000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_21   (0x00200000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_22   (0x00400000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_23   (0x00800000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_24   (0x01000000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_25   (0x02000000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_26   (0x04000000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_27   (0x08000000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_28   (0x10000000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_29   (0x20000000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_30   (0x40000000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_31   (0x80000000UL << ADC_JDR4_JDATA_Pos)
#define ADC_AWD2CR_AWD2CH_Pos   (0U)
#define ADC_AWD2CR_AWD2CH_Msk   (0xFFFFFFUL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH   ADC_AWD2CR_AWD2CH_Msk
#define ADC_AWD2CR_AWD2CH_0   (0x00001UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_1   (0x00002UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_2   (0x00004UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_3   (0x00008UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_4   (0x00010UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_5   (0x00020UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_6   (0x00040UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_7   (0x00080UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_8   (0x00100UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_9   (0x00200UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_10   (0x00400UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_11   (0x00800UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_12   (0x01000UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_13   (0x02000UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_14   (0x04000UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_15   (0x08000UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_16   (0x10000UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_17   (0x20000UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_18   (0x40000UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_19   (0x80000UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_20   (0x100000UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_21   (0x200000UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_22   (0x400000UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_23   (0x800000UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD1TR_LT1_Pos   (0U)
#define ADC_AWD1TR_LT1_Msk   (0xFFFUL << ADC_AWD1TR_LT1_Pos)
#define ADC_AWD1TR_LT1   ADC_AWD1TR_LT1_Msk
#define ADC_AWD1TR_LT1_0   (0x001UL << ADC_AWD1TR_LT1_Pos)
#define ADC_AWD1TR_LT1_1   (0x002UL << ADC_AWD1TR_LT1_Pos)
#define ADC_AWD1TR_LT1_2   (0x004UL << ADC_AWD1TR_LT1_Pos)
#define ADC_AWD1TR_LT1_3   (0x008UL << ADC_AWD1TR_LT1_Pos)
#define ADC_AWD1TR_LT1_4   (0x010UL << ADC_AWD1TR_LT1_Pos)
#define ADC_AWD1TR_LT1_5   (0x020UL << ADC_AWD1TR_LT1_Pos)
#define ADC_AWD1TR_LT1_6   (0x040UL << ADC_AWD1TR_LT1_Pos)
#define ADC_AWD1TR_LT1_7   (0x080UL << ADC_AWD1TR_LT1_Pos)
#define ADC_AWD1TR_LT1_8   (0x100UL << ADC_AWD1TR_LT1_Pos)
#define ADC_AWD1TR_LT1_9   (0x200UL << ADC_AWD1TR_LT1_Pos)
#define ADC_AWD1TR_LT1_10   (0x400UL << ADC_AWD1TR_LT1_Pos)
#define ADC_AWD1TR_LT1_11   (0x800UL << ADC_AWD1TR_LT1_Pos)
#define ADC_AWD1TR_HT1_Pos   (16U)
#define ADC_AWD1TR_HT1_Msk   (0xFFFUL << ADC_AWD1TR_HT1_Pos)
#define ADC_AWD1TR_HT1   ADC_AWD1TR_HT1_Msk
#define ADC_AWD1TR_HT1_0   (0x001UL << ADC_AWD1TR_HT1_Pos)
#define ADC_AWD1TR_HT1_1   (0x002UL << ADC_AWD1TR_HT1_Pos)
#define ADC_AWD1TR_HT1_2   (0x004UL << ADC_AWD1TR_HT1_Pos)
#define ADC_AWD1TR_HT1_3   (0x008UL << ADC_AWD1TR_HT1_Pos)
#define ADC_AWD1TR_HT1_4   (0x010UL << ADC_AWD1TR_HT1_Pos)
#define ADC_AWD1TR_HT1_5   (0x020UL << ADC_AWD1TR_HT1_Pos)
#define ADC_AWD1TR_HT1_6   (0x040UL << ADC_AWD1TR_HT1_Pos)
#define ADC_AWD1TR_HT1_7   (0x080UL << ADC_AWD1TR_HT1_Pos)
#define ADC_AWD1TR_HT1_8   (0x100UL << ADC_AWD1TR_HT1_Pos)
#define ADC_AWD1TR_HT1_9   (0x200UL << ADC_AWD1TR_HT1_Pos)
#define ADC_AWD1TR_HT1_10   (0x400UL << ADC_AWD1TR_HT1_Pos)
#define ADC_AWD1TR_HT1_11   (0x800UL << ADC_AWD1TR_HT1_Pos)
#define ADC_AWD2TR_LT2_Pos   (0U)
#define ADC_AWD2TR_LT2_Msk   (0xFFFUL << ADC_AWD2TR_LT2_Pos)
#define ADC_AWD2TR_LT2   ADC_AWD2TR_LT2_Msk
#define ADC_AWD2TR_LT2_0   (0x001UL << ADC_AWD2TR_LT2_Pos)
#define ADC_AWD2TR_LT2_1   (0x002UL << ADC_AWD2TR_LT2_Pos)
#define ADC_AWD2TR_LT2_2   (0x004UL << ADC_AWD2TR_LT2_Pos)
#define ADC_AWD2TR_LT2_3   (0x008UL << ADC_AWD2TR_LT2_Pos)
#define ADC_AWD2TR_LT2_4   (0x010UL << ADC_AWD2TR_LT2_Pos)
#define ADC_AWD2TR_LT2_5   (0x020UL << ADC_AWD2TR_LT2_Pos)
#define ADC_AWD2TR_LT2_6   (0x040UL << ADC_AWD2TR_LT2_Pos)
#define ADC_AWD2TR_LT2_7   (0x080UL << ADC_AWD2TR_LT2_Pos)
#define ADC_AWD2TR_LT2_8   (0x100UL << ADC_AWD2TR_LT2_Pos)
#define ADC_AWD2TR_LT2_9   (0x200UL << ADC_AWD2TR_LT2_Pos)
#define ADC_AWD2TR_LT2_10   (0x400UL << ADC_AWD2TR_LT2_Pos)
#define ADC_AWD2TR_LT2_11   (0x800UL << ADC_AWD2TR_LT2_Pos)
#define ADC_AWD2TR_HT2_Pos   (16U)
#define ADC_AWD2TR_HT2_Msk   (0xFFFUL << ADC_AWD2TR_HT2_Pos)
#define ADC_AWD2TR_HT2   ADC_AWD2TR_HT2_Msk
#define ADC_AWD2TR_HT2_0   (0x001UL << ADC_AWD2TR_HT2_Pos)
#define ADC_AWD2TR_HT2_1   (0x002UL << ADC_AWD2TR_HT2_Pos)
#define ADC_AWD2TR_HT2_2   (0x004UL << ADC_AWD2TR_HT2_Pos)
#define ADC_AWD2TR_HT2_3   (0x008UL << ADC_AWD2TR_HT2_Pos)
#define ADC_AWD2TR_HT2_4   (0x010UL << ADC_AWD2TR_HT2_Pos)
#define ADC_AWD2TR_HT2_5   (0x020UL << ADC_AWD2TR_HT2_Pos)
#define ADC_AWD2TR_HT2_6   (0x040UL << ADC_AWD2TR_HT2_Pos)
#define ADC_AWD2TR_HT2_7   (0x080UL << ADC_AWD2TR_HT2_Pos)
#define ADC_AWD2TR_HT2_8   (0x100UL << ADC_AWD2TR_HT2_Pos)
#define ADC_AWD2TR_HT2_9   (0x200UL << ADC_AWD2TR_HT2_Pos)
#define ADC_AWD2TR_HT2_10   (0x400UL << ADC_AWD2TR_HT2_Pos)
#define ADC_AWD2TR_HT2_11   (0x800UL << ADC_AWD2TR_HT2_Pos)
#define ADC_CHSELR_CHSEL_Pos   (0U)
#define ADC_CHSELR_CHSEL_Msk   (0xFFFFFFUL << ADC_CHSELR_CHSEL_Pos)
#define ADC_CHSELR_CHSEL   ADC_CHSELR_CHSEL_Msk
#define ADC_CHSELR_CHSEL0_Pos   (0U)
#define ADC_CHSELR_CHSEL0_Msk   (0x1UL << ADC_CHSELR_CHSEL0_Pos)
#define ADC_CHSELR_CHSEL0   ADC_CHSELR_CHSEL0_Msk
#define ADC_CHSELR_CHSEL1_Pos   (1U)
#define ADC_CHSELR_CHSEL1_Msk   (0x1UL << ADC_CHSELR_CHSEL1_Pos)
#define ADC_CHSELR_CHSEL1   ADC_CHSELR_CHSEL1_Msk
#define ADC_CHSELR_CHSEL2_Pos   (2U)
#define ADC_CHSELR_CHSEL2_Msk   (0x1UL << ADC_CHSELR_CHSEL2_Pos)
#define ADC_CHSELR_CHSEL2   ADC_CHSELR_CHSEL2_Msk
#define ADC_CHSELR_CHSEL3_Pos   (3U)
#define ADC_CHSELR_CHSEL3_Msk   (0x1UL << ADC_CHSELR_CHSEL3_Pos)
#define ADC_CHSELR_CHSEL3   ADC_CHSELR_CHSEL3_Msk
#define ADC_CHSELR_CHSEL4_Pos   (4U)
#define ADC_CHSELR_CHSEL4_Msk   (0x1UL << ADC_CHSELR_CHSEL4_Pos)
#define ADC_CHSELR_CHSEL4   ADC_CHSELR_CHSEL4_Msk
#define ADC_CHSELR_CHSEL5_Pos   (5U)
#define ADC_CHSELR_CHSEL5_Msk   (0x1UL << ADC_CHSELR_CHSEL5_Pos)
#define ADC_CHSELR_CHSEL5   ADC_CHSELR_CHSEL5_Msk
#define ADC_CHSELR_CHSEL6_Pos   (6U)
#define ADC_CHSELR_CHSEL6_Msk   (0x1UL << ADC_CHSELR_CHSEL6_Pos)
#define ADC_CHSELR_CHSEL6   ADC_CHSELR_CHSEL6_Msk
#define ADC_CHSELR_CHSEL7_Pos   (7U)
#define ADC_CHSELR_CHSEL7_Msk   (0x1UL << ADC_CHSELR_CHSEL7_Pos)
#define ADC_CHSELR_CHSEL7   ADC_CHSELR_CHSEL7_Msk
#define ADC_CHSELR_CHSEL8_Pos   (8U)
#define ADC_CHSELR_CHSEL8_Msk   (0x1UL << ADC_CHSELR_CHSEL8_Pos)
#define ADC_CHSELR_CHSEL8   ADC_CHSELR_CHSEL8_Msk
#define ADC_CHSELR_CHSEL9_Pos   (9U)
#define ADC_CHSELR_CHSEL9_Msk   (0x1UL << ADC_CHSELR_CHSEL9_Pos)
#define ADC_CHSELR_CHSEL9   ADC_CHSELR_CHSEL9_Msk
#define ADC_CHSELR_CHSEL10_Pos   (10U)
#define ADC_CHSELR_CHSEL10_Msk   (0x1UL << ADC_CHSELR_CHSEL10_Pos)
#define ADC_CHSELR_CHSEL10   ADC_CHSELR_CHSEL10_Msk
#define ADC_CHSELR_CHSEL11_Pos   (11U)
#define ADC_CHSELR_CHSEL11_Msk   (0x1UL << ADC_CHSELR_CHSEL11_Pos)
#define ADC_CHSELR_CHSEL11   ADC_CHSELR_CHSEL11_Msk
#define ADC_CHSELR_CHSEL12_Pos   (12U)
#define ADC_CHSELR_CHSEL12_Msk   (0x1UL << ADC_CHSELR_CHSEL12_Pos)
#define ADC_CHSELR_CHSEL12   ADC_CHSELR_CHSEL12_Msk
#define ADC_CHSELR_CHSEL13_Pos   (13U)
#define ADC_CHSELR_CHSEL13_Msk   (0x1UL << ADC_CHSELR_CHSEL13_Pos)
#define ADC_CHSELR_CHSEL13   ADC_CHSELR_CHSEL13_Msk
#define ADC_CHSELR_CHSEL14_Pos   (14U)
#define ADC_CHSELR_CHSEL14_Msk   (0x1UL << ADC_CHSELR_CHSEL14_Pos)
#define ADC_CHSELR_CHSEL14   ADC_CHSELR_CHSEL14_Msk
#define ADC_CHSELR_CHSEL15_Pos   (15U)
#define ADC_CHSELR_CHSEL15_Msk   (0x1UL << ADC_CHSELR_CHSEL15_Pos)
#define ADC_CHSELR_CHSEL15   ADC_CHSELR_CHSEL15_Msk
#define ADC_CHSELR_CHSEL16_Pos   (16U)
#define ADC_CHSELR_CHSEL16_Msk   (0x1UL << ADC_CHSELR_CHSEL16_Pos)
#define ADC_CHSELR_CHSEL16   ADC_CHSELR_CHSEL16_Msk
#define ADC_CHSELR_CHSEL17_Pos   (17U)
#define ADC_CHSELR_CHSEL17_Msk   (0x1UL << ADC_CHSELR_CHSEL17_Pos)
#define ADC_CHSELR_CHSEL17   ADC_CHSELR_CHSEL17_Msk
#define ADC_CHSELR_CHSEL18_Pos   (18U)
#define ADC_CHSELR_CHSEL18_Msk   (0x1UL << ADC_CHSELR_CHSEL18_Pos)
#define ADC_CHSELR_CHSEL18   ADC_CHSELR_CHSEL18_Msk
#define ADC_CHSELR_CHSEL19_Pos   (19U)
#define ADC_CHSELR_CHSEL19_Msk   (0x1UL << ADC_CHSELR_CHSEL19_Pos)
#define ADC_CHSELR_CHSEL19   ADC_CHSELR_CHSEL19_Msk
#define ADC_CHSELR_CHSEL20_Pos   (20U)
#define ADC_CHSELR_CHSEL20_Msk   (0x1UL << ADC_CHSELR_CHSEL20_Pos)
#define ADC_CHSELR_CHSEL20   ADC_CHSELR_CHSEL20_Msk
#define ADC_CHSELR_CHSEL21_Pos   (21U)
#define ADC_CHSELR_CHSEL21_Msk   (0x1UL << ADC_CHSELR_CHSEL21_Pos)
#define ADC_CHSELR_CHSEL21   ADC_CHSELR_CHSEL21_Msk
#define ADC_CHSELR_CHSEL22_Pos   (22U)
#define ADC_CHSELR_CHSEL22_Msk   (0x1UL << ADC_CHSELR_CHSEL22_Pos)
#define ADC_CHSELR_CHSEL22   ADC_CHSELR_CHSEL22_Msk
#define ADC_CHSELR_CHSEL23_Pos   (23U)
#define ADC_CHSELR_CHSEL23_Msk   (0x1UL << ADC_CHSELR_CHSEL23_Pos)
#define ADC_CHSELR_CHSEL23   ADC_CHSELR_CHSEL23_Msk
#define ADC_CHSELR_SQ_ALL_Pos   (0U)
#define ADC_CHSELR_SQ_ALL_Msk   (0xFFFFFFFFUL << ADC_CHSELR_SQ_ALL_Pos)
#define ADC_CHSELR_SQ_ALL   ADC_CHSELR_SQ_ALL_Msk
#define ADC_CHSELR_SQ1_Pos   (0U)
#define ADC_CHSELR_SQ1_Msk   (0xFUL << ADC_CHSELR_SQ1_Pos)
#define ADC_CHSELR_SQ1   ADC_CHSELR_SQ1_Msk
#define ADC_CHSELR_SQ1_0   (0x1UL << ADC_CHSELR_SQ1_Pos)
#define ADC_CHSELR_SQ1_1   (0x2UL << ADC_CHSELR_SQ1_Pos)
#define ADC_CHSELR_SQ1_2   (0x4UL << ADC_CHSELR_SQ1_Pos)
#define ADC_CHSELR_SQ1_3   (0x8UL << ADC_CHSELR_SQ1_Pos)
#define ADC_CHSELR_SQ2_Pos   (4U)
#define ADC_CHSELR_SQ2_Msk   (0xFUL << ADC_CHSELR_SQ2_Pos)
#define ADC_CHSELR_SQ2   ADC_CHSELR_SQ2_Msk
#define ADC_CHSELR_SQ2_0   (0x1UL << ADC_CHSELR_SQ2_Pos)
#define ADC_CHSELR_SQ2_1   (0x2UL << ADC_CHSELR_SQ2_Pos)
#define ADC_CHSELR_SQ2_2   (0x4UL << ADC_CHSELR_SQ2_Pos)
#define ADC_CHSELR_SQ2_3   (0x8UL << ADC_CHSELR_SQ2_Pos)
#define ADC_CHSELR_SQ3_Pos   (8U)
#define ADC_CHSELR_SQ3_Msk   (0xFUL << ADC_CHSELR_SQ3_Pos)
#define ADC_CHSELR_SQ3   ADC_CHSELR_SQ3_Msk
#define ADC_CHSELR_SQ3_0   (0x1UL << ADC_CHSELR_SQ3_Pos)
#define ADC_CHSELR_SQ3_1   (0x2UL << ADC_CHSELR_SQ3_Pos)
#define ADC_CHSELR_SQ3_2   (0x4UL << ADC_CHSELR_SQ3_Pos)
#define ADC_CHSELR_SQ3_3   (0x8UL << ADC_CHSELR_SQ3_Pos)
#define ADC_CHSELR_SQ4_Pos   (12U)
#define ADC_CHSELR_SQ4_Msk   (0xFUL << ADC_CHSELR_SQ4_Pos)
#define ADC_CHSELR_SQ4   ADC_CHSELR_SQ4_Msk
#define ADC_CHSELR_SQ4_0   (0x1UL << ADC_CHSELR_SQ4_Pos)
#define ADC_CHSELR_SQ4_1   (0x2UL << ADC_CHSELR_SQ4_Pos)
#define ADC_CHSELR_SQ4_2   (0x4UL << ADC_CHSELR_SQ4_Pos)
#define ADC_CHSELR_SQ4_3   (0x8UL << ADC_CHSELR_SQ4_Pos)
#define ADC_CHSELR_SQ5_Pos   (16U)
#define ADC_CHSELR_SQ5_Msk   (0xFUL << ADC_CHSELR_SQ5_Pos)
#define ADC_CHSELR_SQ5   ADC_CHSELR_SQ5_Msk
#define ADC_CHSELR_SQ5_0   (0x1UL << ADC_CHSELR_SQ5_Pos)
#define ADC_CHSELR_SQ5_1   (0x2UL << ADC_CHSELR_SQ5_Pos)
#define ADC_CHSELR_SQ5_2   (0x4UL << ADC_CHSELR_SQ5_Pos)
#define ADC_CHSELR_SQ5_3   (0x8UL << ADC_CHSELR_SQ5_Pos)
#define ADC_CHSELR_SQ6_Pos   (20U)
#define ADC_CHSELR_SQ6_Msk   (0xFUL << ADC_CHSELR_SQ6_Pos)
#define ADC_CHSELR_SQ6   ADC_CHSELR_SQ6_Msk
#define ADC_CHSELR_SQ6_0   (0x1UL << ADC_CHSELR_SQ6_Pos)
#define ADC_CHSELR_SQ6_1   (0x2UL << ADC_CHSELR_SQ6_Pos)
#define ADC_CHSELR_SQ6_2   (0x4UL << ADC_CHSELR_SQ6_Pos)
#define ADC_CHSELR_SQ6_3   (0x8UL << ADC_CHSELR_SQ6_Pos)
#define ADC_CHSELR_SQ7_Pos   (24U)
#define ADC_CHSELR_SQ7_Msk   (0xFUL << ADC_CHSELR_SQ7_Pos)
#define ADC_CHSELR_SQ7   ADC_CHSELR_SQ7_Msk
#define ADC_CHSELR_SQ7_0   (0x1UL << ADC_CHSELR_SQ7_Pos)
#define ADC_CHSELR_SQ7_1   (0x2UL << ADC_CHSELR_SQ7_Pos)
#define ADC_CHSELR_SQ7_2   (0x4UL << ADC_CHSELR_SQ7_Pos)
#define ADC_CHSELR_SQ7_3   (0x8UL << ADC_CHSELR_SQ7_Pos)
#define ADC_CHSELR_SQ8_Pos   (28U)
#define ADC_CHSELR_SQ8_Msk   (0xFUL << ADC_CHSELR_SQ8_Pos)
#define ADC_CHSELR_SQ8   ADC_CHSELR_SQ8_Msk
#define ADC_CHSELR_SQ8_0   (0x1UL << ADC_CHSELR_SQ8_Pos)
#define ADC_CHSELR_SQ8_1   (0x2UL << ADC_CHSELR_SQ8_Pos)
#define ADC_CHSELR_SQ8_2   (0x4UL << ADC_CHSELR_SQ8_Pos)
#define ADC_CHSELR_SQ8_3   (0x8UL << ADC_CHSELR_SQ8_Pos)
#define ADC_AWD3TR_LT3_Pos   (0U)
#define ADC_AWD3TR_LT3_Msk   (0xFFFUL << ADC_AWD3TR_LT3_Pos)
#define ADC_AWD3TR_LT3   ADC_AWD3TR_LT3_Msk
#define ADC_AWD3TR_LT3_0   (0x001UL << ADC_AWD3TR_LT3_Pos)
#define ADC_AWD3TR_LT3_1   (0x002UL << ADC_AWD3TR_LT3_Pos)
#define ADC_AWD3TR_LT3_2   (0x004UL << ADC_AWD3TR_LT3_Pos)
#define ADC_AWD3TR_LT3_3   (0x008UL << ADC_AWD3TR_LT3_Pos)
#define ADC_AWD3TR_LT3_4   (0x010UL << ADC_AWD3TR_LT3_Pos)
#define ADC_AWD3TR_LT3_5   (0x020UL << ADC_AWD3TR_LT3_Pos)
#define ADC_AWD3TR_LT3_6   (0x040UL << ADC_AWD3TR_LT3_Pos)
#define ADC_AWD3TR_LT3_7   (0x080UL << ADC_AWD3TR_LT3_Pos)
#define ADC_AWD3TR_LT3_8   (0x100UL << ADC_AWD3TR_LT3_Pos)
#define ADC_AWD3TR_LT3_9   (0x200UL << ADC_AWD3TR_LT3_Pos)
#define ADC_AWD3TR_LT3_10   (0x400UL << ADC_AWD3TR_LT3_Pos)
#define ADC_AWD3TR_LT3_11   (0x800UL << ADC_AWD3TR_LT3_Pos)
#define ADC_AWD3TR_HT3_Pos   (16U)
#define ADC_AWD3TR_HT3_Msk   (0xFFFUL << ADC_AWD3TR_HT3_Pos)
#define ADC_AWD3TR_HT3   ADC_AWD3TR_HT3_Msk
#define ADC_AWD3TR_HT3_0   (0x001UL << ADC_AWD3TR_HT3_Pos)
#define ADC_AWD3TR_HT3_1   (0x002UL << ADC_AWD3TR_HT3_Pos)
#define ADC_AWD3TR_HT3_2   (0x004UL << ADC_AWD3TR_HT3_Pos)
#define ADC_AWD3TR_HT3_3   (0x008UL << ADC_AWD3TR_HT3_Pos)
#define ADC_AWD3TR_HT3_4   (0x010UL << ADC_AWD3TR_HT3_Pos)
#define ADC_AWD3TR_HT3_5   (0x020UL << ADC_AWD3TR_HT3_Pos)
#define ADC_AWD3TR_HT3_6   (0x040UL << ADC_AWD3TR_HT3_Pos)
#define ADC_AWD3TR_HT3_7   (0x080UL << ADC_AWD3TR_HT3_Pos)
#define ADC_AWD3TR_HT3_8   (0x100UL << ADC_AWD3TR_HT3_Pos)
#define ADC_AWD3TR_HT3_9   (0x200UL << ADC_AWD3TR_HT3_Pos)
#define ADC_AWD3TR_HT3_10   (0x400UL << ADC_AWD3TR_HT3_Pos)
#define ADC_AWD3TR_HT3_11   (0x800UL << ADC_AWD3TR_HT3_Pos)
#define ADC_AWD3CR_AWD3CH_Pos   (0U)
#define ADC_AWD3CR_AWD3CH_Msk   (0xFFFFFFUL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH   ADC_AWD3CR_AWD3CH_Msk
#define ADC_AWD3CR_AWD3CH_0   (0x00001UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_1   (0x00002UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_2   (0x00004UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_3   (0x00008UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_4   (0x00010UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_5   (0x00020UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_6   (0x00040UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_7   (0x00080UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_8   (0x00100UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_9   (0x00200UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_10   (0x00400UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_11   (0x00800UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_12   (0x01000UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_13   (0x02000UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_14   (0x04000UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_15   (0x08000UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_16   (0x10000UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_17   (0x20000UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_18   (0x40000UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_19   (0x80000UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD2CH_20   (0x100000UL << ADC_AWD3CR_AWD2CH_Pos)
#define ADC_AWD3CR_AWD2CH_21   (0x200000UL << ADC_AWD3CR_AWD2CH_Pos)
#define ADC_AWD3CR_AWD2CH_22   (0x400000UL << ADC_AWD3CR_AWD2CH_Pos)
#define ADC_AWD3CR_AWD2CH_23   (0x800000UL << ADC_AWD3CR_AWD2CH_Pos)
#define ADC_DIFSEL_DIFSEL_Pos   (0U)
#define ADC_DIFSEL_DIFSEL_Msk   (0xFFFFFUL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL   ADC_DIFSEL_DIFSEL_Msk
#define ADC_DIFSEL_DIFSEL_0   (0x00001UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_1   (0x00002UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_2   (0x00004UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_3   (0x00008UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_4   (0x00010UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_5   (0x00020UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_6   (0x00040UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_7   (0x00080UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_8   (0x00100UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_9   (0x00200UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_10   (0x00400UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_11   (0x00800UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_12   (0x01000UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_13   (0x02000UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_14   (0x04000UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_15   (0x08000UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_16   (0x10000UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_17   (0x20000UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_18   (0x40000UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_19   (0x80000UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_CALFACT_I_APB_ADDR_Pos   (0U)
#define ADC_CALFACT_I_APB_ADDR_Msk   (0xFFUL << ADC_CALFACT_I_APB_ADDR_Pos)
#define ADC_CALFACT_I_APB_ADDR   ADC_CALFACT_I_APB_ADDR_Msk
#define ADC_CALFACT_I_APB_ADDR_0   (0x001U << ADC_CALFACT_I_APB_ADDR_Pos)
#define ADC_CALFACT_I_APB_ADDR_1   (0x002U << ADC_CALFACT_I_APB_ADDR_Pos)
#define ADC_CALFACT_I_APB_ADDR_2   (0x004U << ADC_CALFACT_I_APB_ADDR_Pos)
#define ADC_CALFACT_I_APB_ADDR_3   (0x008U << ADC_CALFACT_I_APB_ADDR_Pos)
#define ADC_CALFACT_I_APB_ADDR_4   (0x010U << ADC_CALFACT_I_APB_ADDR_Pos)
#define ADC_CALFACT_I_APB_ADDR_5   (0x020U << ADC_CALFACT_I_APB_ADDR_Pos)
#define ADC_CALFACT_I_APB_ADDR_6   (0x040U << ADC_CALFACT_I_APB_ADDR_Pos)
#define ADC_CALFACT_I_APB_ADDR_7   (0x080U << ADC_CALFACT_I_APB_ADDR_Pos)
#define ADC_CALFACT_I_APB_DATA_Pos   (08U)
#define ADC_CALFACT_I_APB_DATA_Msk   (0xFFUL << ADC_CALFACT_I_APB_DATA_Pos)
#define ADC_CALFACT_I_APB_DATA   ADC_CALFACT_I_APB_DATA_Msk
#define ADC_CALFACT_APB_DATA_0   (0x001U << ADC_CALFACT_APB_DATA_Pos)
#define ADC_CALFACT_APB_DATA_1   (0x002U << ADC_CALFACT_APB_DATA_Pos)
#define ADC_CALFACT_APB_DATA_2   (0x004U << ADC_CALFACT_APB_DATA_Pos)
#define ADC_CALFACT_APB_DATA_3   (0x008U << ADC_CALFACT_APB_DATA_Pos)
#define ADC_CALFACT_APB_DATA_4   (0x010U << ADC_CALFACT_APB_DATA_Pos)
#define ADC_CALFACT_APB_DATA_5   (0x020U << ADC_CALFACT_APB_DATA_Pos)
#define ADC_CALFACT_APB_DATA_6   (0x040U << ADC_CALFACT_APB_DATA_Pos)
#define ADC_CALFACT_APB_DATA_7   (0x080U << ADC_CALFACT_APB_DATA_Pos)
#define ADC_CALFACT_VALIDITY_Pos   (16U)
#define ADC_CALFACT_VALIDITY_Msk   (0x1UL << ADC_CALFACT_VALIDITY_Pos)
#define ADC_CALFACT_VALIDITY   ADC_CALFACT_VALIDITY_Msk
#define ADC_CALFACT_LATCH_COEF_Pos   (24U)
#define ADC_CALFACT_LATCH_COEF_Msk   (0x1UL << ADC_CALFACT_LATCH_COEF_Pos)
#define ADC_CALFACT_LATCH_COEF   ADC_CALFACT_LATCH_COEF_Msk
#define ADC_CALFACT_CAPTURE_COEF_Pos   (25U)
#define ADC_CALFACT_CAPTURE_COEF_Msk   (0x1UL << ADC_CALFACT_CAPTURE_COEF_Pos)
#define ADC_CALFACT_CAPTURE_COEF   ADC_CALFACT_CAPTURE_COEF_Msk
#define ADC4_CALFACT_CALFACT_Pos   (0U)
#define ADC4_CALFACT_CALFACT_Msk   (0x7FUL << ADC4_CALFACT_CALFACT_Pos)
#define ADC4_CALFACT_CALFACT   ADC4_CALFACT_CALFACT_Msk
#define ADC4_CALFACT_CALFACT_0   (0x01UL << ADC4_CALFACT_CALFACT_Pos)
#define ADC4_CALFACT_CALFACT_1   (0x02UL << ADC4_CALFACT_CALFACT_Pos)
#define ADC4_CALFACT_CALFACT_2   (0x04UL << ADC4_CALFACT_CALFACT_Pos)
#define ADC4_CALFACT_CALFACT_3   (0x08UL << ADC4_CALFACT_CALFACT_Pos)
#define ADC4_CALFACT_CALFACT_4   (0x10UL << ADC4_CALFACT_CALFACT_Pos)
#define ADC4_CALFACT_CALFACT_5   (0x20UL << ADC4_CALFACT_CALFACT_Pos)
#define ADC4_CALFACT_CALFACT_6   (0x40UL << ADC4_CALFACT_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_Pos   (0U)
#define ADC_CALFACT2_CALFACT_Msk   (0xFFFFFFFFUL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT   ADC_CALFACT2_CALFACT_Msk
#define ADC_CALFACT2_CALFACT_0   (0x00000001UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_1   (0x00000002UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_2   (0x00000004UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_3   (0x00000008UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_4   (0x00000010UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_5   (0x00000020UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_6   (0x00000040UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_7   (0x00000080UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_8   (0x00000100UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_9   (0x00000200UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_10   (0x00000400UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_11   (0x00000800UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_12   (0x00001000UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_13   (0x00002000UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_14   (0x00004000UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_15   (0x00008000UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_16   (0x00010000UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_17   (0x00020000UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_18   (0x00040000UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_19   (0x00080000UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_20   (0x00100000UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_21   (0x00200000UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_22   (0x00400000UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_23   (0x00800000UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_24   (0x01000000UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_25   (0x02000000UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_26   (0x04000000UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_27   (0x08000000UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_28   (0x10000000UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_29   (0x20000000UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_30   (0x40000000UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_CALFACT2_CALFACT_31   (0x80000000UL << ADC_CALFACT2_CALFACT_Pos)
#define ADC_OR_CHN0SEL_Pos   (0U)
#define ADC_OR_CHN0SEL_Msk   (0x1UL << ADC_OR_CHN0SEL_Pos)
#define ADC_OR_CHN0SEL   ADC_OR_CHN0SEL_Msk
#define ADC_CSR_ADRDY_MST_Pos   (0U)
#define ADC_CSR_ADRDY_MST_Msk   (0x1UL << ADC_CSR_ADRDY_MST_Pos)
#define ADC_CSR_ADRDY_MST   ADC_CSR_ADRDY_MST_Msk
#define ADC_CSR_EOSMP_MST_Pos   (1U)
#define ADC_CSR_EOSMP_MST_Msk   (0x1UL << ADC_CSR_EOSMP_MST_Pos)
#define ADC_CSR_EOSMP_MST   ADC_CSR_EOSMP_MST_Msk
#define ADC_CSR_EOC_MST_Pos   (2U)
#define ADC_CSR_EOC_MST_Msk   (0x1UL << ADC_CSR_EOC_MST_Pos)
#define ADC_CSR_EOC_MST   ADC_CSR_EOC_MST_Msk
#define ADC_CSR_EOS_MST_Pos   (3U)
#define ADC_CSR_EOS_MST_Msk   (0x1UL << ADC_CSR_EOS_MST_Pos)
#define ADC_CSR_EOS_MST   ADC_CSR_EOS_MST_Msk
#define ADC_CSR_OVR_MST_Pos   (4U)
#define ADC_CSR_OVR_MST_Msk   (0x1UL << ADC_CSR_OVR_MST_Pos)
#define ADC_CSR_OVR_MST   ADC_CSR_OVR_MST_Msk
#define ADC_CSR_JEOC_MST_Pos   (5U)
#define ADC_CSR_JEOC_MST_Msk   (0x1UL << ADC_CSR_JEOC_MST_Pos)
#define ADC_CSR_JEOC_MST   ADC_CSR_JEOC_MST_Msk
#define ADC_CSR_JEOS_MST_Pos   (6U)
#define ADC_CSR_JEOS_MST_Msk   (0x1UL << ADC_CSR_JEOS_MST_Pos)
#define ADC_CSR_JEOS_MST   ADC_CSR_JEOS_MST_Msk
#define ADC_CSR_AWD1_MST_Pos   (7U)
#define ADC_CSR_AWD1_MST_Msk   (0x1UL << ADC_CSR_AWD1_MST_Pos)
#define ADC_CSR_AWD1_MST   ADC_CSR_AWD1_MST_Msk
#define ADC_CSR_AWD2_MST_Pos   (8U)
#define ADC_CSR_AWD2_MST_Msk   (0x1UL << ADC_CSR_AWD2_MST_Pos)
#define ADC_CSR_AWD2_MST   ADC_CSR_AWD2_MST_Msk
#define ADC_CSR_AWD3_MST_Pos   (9U)
#define ADC_CSR_AWD3_MST_Msk   (0x1UL << ADC_CSR_AWD3_MST_Pos)
#define ADC_CSR_AWD3_MST   ADC_CSR_AWD3_MST_Msk
#define ADC_CSR_JQOVF_MST_Pos   (10U)
#define ADC_CSR_JQOVF_MST_Msk   (0x1UL << ADC_CSR_JQOVF_MST_Pos)
#define ADC_CSR_JQOVF_MST   ADC_CSR_JQOVF_MST_Msk
#define ADC_CSR_LDORDY_MST_Pos   (12U)
#define ADC_CSR_LDORDY_MST_Msk   (0x1UL << ADC_CSR_LDORDY_MST_Pos)
#define ADC_CSR_LDORDY_MST   ADC_CSR_LDORDY_MST_Msk
#define ADC_CSR_ADRDY_SLV_Pos   (16U)
#define ADC_CSR_ADRDY_SLV_Msk   (0x1UL << ADC_CSR_ADRDY_SLV_Pos)
#define ADC_CSR_ADRDY_SLV   ADC_CSR_ADRDY_SLV_Msk
#define ADC_CSR_EOSMP_SLV_Pos   (17U)
#define ADC_CSR_EOSMP_SLV_Msk   (0x1UL << ADC_CSR_EOSMP_SLV_Pos)
#define ADC_CSR_EOSMP_SLV   ADC_CSR_EOSMP_SLV_Msk
#define ADC_CSR_EOC_SLV_Pos   (18U)
#define ADC_CSR_EOC_SLV_Msk   (0x1UL << ADC_CSR_EOC_SLV_Pos)
#define ADC_CSR_EOC_SLV   ADC_CSR_EOC_SLV_Msk
#define ADC_CSR_EOS_SLV_Pos   (19U)
#define ADC_CSR_EOS_SLV_Msk   (0x1UL << ADC_CSR_EOS_SLV_Pos)
#define ADC_CSR_EOS_SLV   ADC_CSR_EOS_SLV_Msk
#define ADC_CSR_OVR_SLV_Pos   (20U)
#define ADC_CSR_OVR_SLV_Msk   (0x1UL << ADC_CSR_OVR_SLV_Pos)
#define ADC_CSR_OVR_SLV   ADC_CSR_OVR_SLV_Msk
#define ADC_CSR_JEOC_SLV_Pos   (21U)
#define ADC_CSR_JEOC_SLV_Msk   (0x1UL << ADC_CSR_JEOC_SLV_Pos)
#define ADC_CSR_JEOC_SLV   ADC_CSR_JEOC_SLV_Msk
#define ADC_CSR_JEOS_SLV_Pos   (22U)
#define ADC_CSR_JEOS_SLV_Msk   (0x1UL << ADC_CSR_JEOS_SLV_Pos)
#define ADC_CSR_JEOS_SLV   ADC_CSR_JEOS_SLV_Msk
#define ADC_CSR_AWD1_SLV_Pos   (23U)
#define ADC_CSR_AWD1_SLV_Msk   (0x1UL << ADC_CSR_AWD1_SLV_Pos)
#define ADC_CSR_AWD1_SLV   ADC_CSR_AWD1_SLV_Msk
#define ADC_CSR_AWD2_SLV_Pos   (24U)
#define ADC_CSR_AWD2_SLV_Msk   (0x1UL << ADC_CSR_AWD2_SLV_Pos)
#define ADC_CSR_AWD2_SLV   ADC_CSR_AWD2_SLV_Msk
#define ADC_CSR_AWD3_SLV_Pos   (25U)
#define ADC_CSR_AWD3_SLV_Msk   (0x1UL << ADC_CSR_AWD3_SLV_Pos)
#define ADC_CSR_AWD3_SLV   ADC_CSR_AWD3_SLV_Msk
#define ADC_CSR_JQOVF_SLV_Pos   (26U)
#define ADC_CSR_JQOVF_SLV_Msk   (0x1UL << ADC_CSR_JQOVF_SLV_Pos)
#define ADC_CSR_JQOVF_SLV   ADC_CSR_JQOVF_SLV_Msk
#define ADC_CSR_LDORDY_SLV_Pos   (28U)
#define ADC_CSR_LDORDY_SLV_Msk   (0x1UL << ADC_CSR_LDORDY_SLV_Pos)
#define ADC_CSR_LDORDY_SLV   ADC_CSR_LDORDY_SLV_Msk
#define ADC_CCR_DUAL_Pos   (0U)
#define ADC_CCR_DUAL_Msk   (0x1FUL << ADC_CCR_DUAL_Pos)
#define ADC_CCR_DUAL   ADC_CCR_DUAL_Msk
#define ADC_CCR_DUAL_0   (0x01UL << ADC_CCR_DUAL_Pos)
#define ADC_CCR_DUAL_1   (0x02UL << ADC_CCR_DUAL_Pos)
#define ADC_CCR_DUAL_2   (0x04UL << ADC_CCR_DUAL_Pos)
#define ADC_CCR_DUAL_3   (0x08UL << ADC_CCR_DUAL_Pos)
#define ADC_CCR_DUAL_4   (0x10UL << ADC_CCR_DUAL_Pos)
#define ADC_CCR_DELAY_Pos   (8U)
#define ADC_CCR_DELAY_Msk   (0xFUL << ADC_CCR_DELAY_Pos)
#define ADC_CCR_DELAY   ADC_CCR_DELAY_Msk
#define ADC_CCR_DELAY_0   (0x1UL << ADC_CCR_DELAY_Pos)
#define ADC_CCR_DELAY_1   (0x2UL << ADC_CCR_DELAY_Pos)
#define ADC_CCR_DELAY_2   (0x4UL << ADC_CCR_DELAY_Pos)
#define ADC_CCR_DELAY_3   (0x8UL << ADC_CCR_DELAY_Pos)
#define ADC_CCR_DAMDF_Pos   (14U)
#define ADC_CCR_DAMDF_Msk   (0x3UL << ADC_CCR_DAMDF_Pos)
#define ADC_CCR_DAMDF   ADC_CCR_DAMDF_Msk
#define ADC_CCR_DAMDF_0   (0x1UL << ADC_CCR_DAMDF_Pos)
#define ADC_CCR_DAMDF_1   (0x2UL << ADC_CCR_DAMDF_Pos)
#define ADC_CCR_PRESC_Pos   (18U)
#define ADC_CCR_PRESC_Msk   (0xFUL << ADC_CCR_PRESC_Pos)
#define ADC_CCR_PRESC   ADC_CCR_PRESC_Msk
#define ADC_CCR_PRESC_0   (0x1UL << ADC_CCR_PRESC_Pos)
#define ADC_CCR_PRESC_1   (0x2UL << ADC_CCR_PRESC_Pos)
#define ADC_CCR_PRESC_2   (0x4UL << ADC_CCR_PRESC_Pos)
#define ADC_CCR_PRESC_3   (0x8UL << ADC_CCR_PRESC_Pos)
#define ADC_CCR_VREFEN_Pos   (22U)
#define ADC_CCR_VREFEN_Msk   (0x1UL << ADC_CCR_VREFEN_Pos)
#define ADC_CCR_VREFEN   ADC_CCR_VREFEN_Msk
#define ADC_CCR_VSENSEEN_Pos   (23U)
#define ADC_CCR_VSENSEEN_Msk   (0x1UL << ADC_CCR_VSENSEEN_Pos)
#define ADC_CCR_VSENSEEN   ADC_CCR_VSENSEEN_Msk
#define ADC_CCR_VBATEN_Pos   (24U)
#define ADC_CCR_VBATEN_Msk   (0x1UL << ADC_CCR_VBATEN_Pos)
#define ADC_CCR_VBATEN   ADC_CCR_VBATEN_Msk
#define ADC_CCR_LFMEN_Pos   (25U)
#define ADC_CCR_LFMEN_Msk   (0x1UL << ADC_CCR_LFMEN_Pos)
#define ADC_CCR_LFMEN   ADC_CCR_LFMEN_Msk
#define ADC_CCR_VDDCOREN_Pos   (26U)
#define ADC_CCR_VDDCOREN_Msk   (0x1UL << ADC_CCR_VDDCOREN_Pos)
#define ADC_CCR_VDDCOREN   ADC_CCR_VDDCOREN_Msk
#define ADC_CDR_RDATA_MST_Pos   (0U)
#define ADC_CDR_RDATA_MST_Msk   (0xFFFFUL << ADC_CDR_RDATA_MST_Pos)
#define ADC_CDR_RDATA_MST   ADC_CDR_RDATA_MST_Msk
#define ADC_CDR_RDATA_SLV_Pos   (16U)
#define ADC_CDR_RDATA_SLV_Msk   (0xFFFFUL << ADC_CDR_RDATA_SLV_Pos)
#define ADC_CDR_RDATA_SLV   ADC_CDR_RDATA_SLV_Msk
#define ADC_CDR2_RDATA_ALT_Pos   (0U)
#define ADC_CDR2_RDATA_ALT_Msk   (0xFFFFFFFFUL << ADC_CDR2_RDATA_ALT_Pos)
#define ADC_CDR2_RDATA_ALT   ADC_CDR2_RDATA_ALT_Msk
#define CORDIC_CSR_FUNC_Pos   (0U)
#define CORDIC_CSR_FUNC_Msk   (0xFUL << CORDIC_CSR_FUNC_Pos)
#define CORDIC_CSR_FUNC   CORDIC_CSR_FUNC_Msk
#define CORDIC_CSR_FUNC_0   (0x1UL << CORDIC_CSR_FUNC_Pos)
#define CORDIC_CSR_FUNC_1   (0x2UL << CORDIC_CSR_FUNC_Pos)
#define CORDIC_CSR_FUNC_2   (0x4UL << CORDIC_CSR_FUNC_Pos)
#define CORDIC_CSR_FUNC_3   (0x8UL << CORDIC_CSR_FUNC_Pos)
#define CORDIC_CSR_PRECISION_Pos   (4U)
#define CORDIC_CSR_PRECISION_Msk   (0xFUL << CORDIC_CSR_PRECISION_Pos)
#define CORDIC_CSR_PRECISION   CORDIC_CSR_PRECISION_Msk
#define CORDIC_CSR_PRECISION_0   (0x1UL << CORDIC_CSR_PRECISION_Pos)
#define CORDIC_CSR_PRECISION_1   (0x2UL << CORDIC_CSR_PRECISION_Pos)
#define CORDIC_CSR_PRECISION_2   (0x4UL << CORDIC_CSR_PRECISION_Pos)
#define CORDIC_CSR_PRECISION_3   (0x8UL << CORDIC_CSR_PRECISION_Pos)
#define CORDIC_CSR_SCALE_Pos   (8U)
#define CORDIC_CSR_SCALE_Msk   (0x7UL << CORDIC_CSR_SCALE_Pos)
#define CORDIC_CSR_SCALE   CORDIC_CSR_SCALE_Msk
#define CORDIC_CSR_SCALE_0   (0x1UL << CORDIC_CSR_SCALE_Pos)
#define CORDIC_CSR_SCALE_1   (0x2UL << CORDIC_CSR_SCALE_Pos)
#define CORDIC_CSR_SCALE_2   (0x4UL << CORDIC_CSR_SCALE_Pos)
#define CORDIC_CSR_IEN_Pos   (16U)
#define CORDIC_CSR_IEN_Msk   (0x1UL << CORDIC_CSR_IEN_Pos)
#define CORDIC_CSR_IEN   CORDIC_CSR_IEN_Msk
#define CORDIC_CSR_DMAREN_Pos   (17U)
#define CORDIC_CSR_DMAREN_Msk   (0x1UL << CORDIC_CSR_DMAREN_Pos)
#define CORDIC_CSR_DMAREN   CORDIC_CSR_DMAREN_Msk
#define CORDIC_CSR_DMAWEN_Pos   (18U)
#define CORDIC_CSR_DMAWEN_Msk   (0x1UL << CORDIC_CSR_DMAWEN_Pos)
#define CORDIC_CSR_DMAWEN   CORDIC_CSR_DMAWEN_Msk
#define CORDIC_CSR_NRES_Pos   (19U)
#define CORDIC_CSR_NRES_Msk   (0x1UL << CORDIC_CSR_NRES_Pos)
#define CORDIC_CSR_NRES   CORDIC_CSR_NRES_Msk
#define CORDIC_CSR_NARGS_Pos   (20U)
#define CORDIC_CSR_NARGS_Msk   (0x1UL << CORDIC_CSR_NARGS_Pos)
#define CORDIC_CSR_NARGS   CORDIC_CSR_NARGS_Msk
#define CORDIC_CSR_RESSIZE_Pos   (21U)
#define CORDIC_CSR_RESSIZE_Msk   (0x1UL << CORDIC_CSR_RESSIZE_Pos)
#define CORDIC_CSR_RESSIZE   CORDIC_CSR_RESSIZE_Msk
#define CORDIC_CSR_ARGSIZE_Pos   (22U)
#define CORDIC_CSR_ARGSIZE_Msk   (0x1UL << CORDIC_CSR_ARGSIZE_Pos)
#define CORDIC_CSR_ARGSIZE   CORDIC_CSR_ARGSIZE_Msk
#define CORDIC_CSR_RRDY_Pos   (31U)
#define CORDIC_CSR_RRDY_Msk   (0x1UL << CORDIC_CSR_RRDY_Pos)
#define CORDIC_CSR_RRDY   CORDIC_CSR_RRDY_Msk
#define CORDIC_WDATA_ARG_Pos   (0U)
#define CORDIC_WDATA_ARG_Msk   (0xFFFFFFFFUL << CORDIC_WDATA_ARG_Pos)
#define CORDIC_WDATA_ARG   CORDIC_WDATA_ARG_Msk
#define CORDIC_RDATA_RES_Pos   (0U)
#define CORDIC_RDATA_RES_Msk   (0xFFFFFFFFUL << CORDIC_RDATA_RES_Pos)
#define CORDIC_RDATA_RES   CORDIC_RDATA_RES_Msk
#define CRC_DR_DR_Pos   (0U)
#define CRC_DR_DR_Msk   (0xFFFFFFFFUL << CRC_DR_DR_Pos)
#define CRC_DR_DR   CRC_DR_DR_Msk
#define CRC_IDR_IDR_Pos   (0U)
#define CRC_IDR_IDR_Msk   (0xFFFFFFFFUL << CRC_IDR_IDR_Pos)
#define CRC_IDR_IDR   CRC_IDR_IDR_Msk
#define CRC_CR_RESET_Pos   (0U)
#define CRC_CR_RESET_Msk   (0x1UL << CRC_CR_RESET_Pos)
#define CRC_CR_RESET   CRC_CR_RESET_Msk
#define CRC_CR_POLYSIZE_Pos   (3U)
#define CRC_CR_POLYSIZE_Msk   (0x3UL << CRC_CR_POLYSIZE_Pos)
#define CRC_CR_POLYSIZE   CRC_CR_POLYSIZE_Msk
#define CRC_CR_POLYSIZE_0   (0x1UL << CRC_CR_POLYSIZE_Pos)
#define CRC_CR_POLYSIZE_1   (0x2UL << CRC_CR_POLYSIZE_Pos)
#define CRC_CR_REV_IN_Pos   (5U)
#define CRC_CR_REV_IN_Msk   (0x3UL << CRC_CR_REV_IN_Pos)
#define CRC_CR_REV_IN   CRC_CR_REV_IN_Msk
#define CRC_CR_REV_IN_0   (0x1UL << CRC_CR_REV_IN_Pos)
#define CRC_CR_REV_IN_1   (0x2UL << CRC_CR_REV_IN_Pos)
#define CRC_CR_REV_OUT_Pos   (7U)
#define CRC_CR_REV_OUT_Msk   (0x1UL << CRC_CR_REV_OUT_Pos)
#define CRC_CR_REV_OUT   CRC_CR_REV_OUT_Msk
#define CRC_INIT_INIT_Pos   (0U)
#define CRC_INIT_INIT_Msk   (0xFFFFFFFFUL << CRC_INIT_INIT_Pos)
#define CRC_INIT_INIT   CRC_INIT_INIT_Msk
#define CRC_POL_POL_Pos   (0U)
#define CRC_POL_POL_Msk   (0xFFFFFFFFUL << CRC_POL_POL_Pos)
#define CRC_POL_POL   CRC_POL_POL_Msk
#define CRS_CR_SYNCOKIE_Pos   (0U)
#define CRS_CR_SYNCOKIE_Msk   (0x1UL << CRS_CR_SYNCOKIE_Pos)
#define CRS_CR_SYNCOKIE   CRS_CR_SYNCOKIE_Msk
#define CRS_CR_SYNCWARNIE_Pos   (1U)
#define CRS_CR_SYNCWARNIE_Msk   (0x1UL << CRS_CR_SYNCWARNIE_Pos)
#define CRS_CR_SYNCWARNIE   CRS_CR_SYNCWARNIE_Msk
#define CRS_CR_ERRIE_Pos   (2U)
#define CRS_CR_ERRIE_Msk   (0x1UL << CRS_CR_ERRIE_Pos)
#define CRS_CR_ERRIE   CRS_CR_ERRIE_Msk
#define CRS_CR_ESYNCIE_Pos   (3U)
#define CRS_CR_ESYNCIE_Msk   (0x1UL << CRS_CR_ESYNCIE_Pos)
#define CRS_CR_ESYNCIE   CRS_CR_ESYNCIE_Msk
#define CRS_CR_CEN_Pos   (5U)
#define CRS_CR_CEN_Msk   (0x1UL << CRS_CR_CEN_Pos)
#define CRS_CR_CEN   CRS_CR_CEN_Msk
#define CRS_CR_AUTOTRIMEN_Pos   (6U)
#define CRS_CR_AUTOTRIMEN_Msk   (0x1UL << CRS_CR_AUTOTRIMEN_Pos)
#define CRS_CR_AUTOTRIMEN   CRS_CR_AUTOTRIMEN_Msk
#define CRS_CR_SWSYNC_Pos   (7U)
#define CRS_CR_SWSYNC_Msk   (0x1UL << CRS_CR_SWSYNC_Pos)
#define CRS_CR_SWSYNC   CRS_CR_SWSYNC_Msk
#define CRS_CR_TRIM_Pos   (8U)
#define CRS_CR_TRIM_Msk   (0x7FUL << CRS_CR_TRIM_Pos)
#define CRS_CR_TRIM   CRS_CR_TRIM_Msk
#define CRS_CFGR_RELOAD_Pos   (0U)
#define CRS_CFGR_RELOAD_Msk   (0xFFFFUL << CRS_CFGR_RELOAD_Pos)
#define CRS_CFGR_RELOAD   CRS_CFGR_RELOAD_Msk
#define CRS_CFGR_FELIM_Pos   (16U)
#define CRS_CFGR_FELIM_Msk   (0xFFUL << CRS_CFGR_FELIM_Pos)
#define CRS_CFGR_FELIM   CRS_CFGR_FELIM_Msk
#define CRS_CFGR_SYNCDIV_Pos   (24U)
#define CRS_CFGR_SYNCDIV_Msk   (0x7UL << CRS_CFGR_SYNCDIV_Pos)
#define CRS_CFGR_SYNCDIV   CRS_CFGR_SYNCDIV_Msk
#define CRS_CFGR_SYNCDIV_0   (0x1UL << CRS_CFGR_SYNCDIV_Pos)
#define CRS_CFGR_SYNCDIV_1   (0x2UL << CRS_CFGR_SYNCDIV_Pos)
#define CRS_CFGR_SYNCDIV_2   (0x4UL << CRS_CFGR_SYNCDIV_Pos)
#define CRS_CFGR_SYNCSRC_Pos   (28U)
#define CRS_CFGR_SYNCSRC_Msk   (0x3UL << CRS_CFGR_SYNCSRC_Pos)
#define CRS_CFGR_SYNCSRC   CRS_CFGR_SYNCSRC_Msk
#define CRS_CFGR_SYNCSRC_0   (0x1UL << CRS_CFGR_SYNCSRC_Pos)
#define CRS_CFGR_SYNCSRC_1   (0x2UL << CRS_CFGR_SYNCSRC_Pos)
#define CRS_CFGR_SYNCPOL_Pos   (31U)
#define CRS_CFGR_SYNCPOL_Msk   (0x1UL << CRS_CFGR_SYNCPOL_Pos)
#define CRS_CFGR_SYNCPOL   CRS_CFGR_SYNCPOL_Msk
#define CRS_ISR_SYNCOKF_Pos   (0U)
#define CRS_ISR_SYNCOKF_Msk   (0x1UL << CRS_ISR_SYNCOKF_Pos)
#define CRS_ISR_SYNCOKF   CRS_ISR_SYNCOKF_Msk
#define CRS_ISR_SYNCWARNF_Pos   (1U)
#define CRS_ISR_SYNCWARNF_Msk   (0x1UL << CRS_ISR_SYNCWARNF_Pos)
#define CRS_ISR_SYNCWARNF   CRS_ISR_SYNCWARNF_Msk
#define CRS_ISR_ERRF_Pos   (2U)
#define CRS_ISR_ERRF_Msk   (0x1UL << CRS_ISR_ERRF_Pos)
#define CRS_ISR_ERRF   CRS_ISR_ERRF_Msk
#define CRS_ISR_ESYNCF_Pos   (3U)
#define CRS_ISR_ESYNCF_Msk   (0x1UL << CRS_ISR_ESYNCF_Pos)
#define CRS_ISR_ESYNCF   CRS_ISR_ESYNCF_Msk
#define CRS_ISR_SYNCERR_Pos   (8U)
#define CRS_ISR_SYNCERR_Msk   (0x1UL << CRS_ISR_SYNCERR_Pos)
#define CRS_ISR_SYNCERR   CRS_ISR_SYNCERR_Msk
#define CRS_ISR_SYNCMISS_Pos   (9U)
#define CRS_ISR_SYNCMISS_Msk   (0x1UL << CRS_ISR_SYNCMISS_Pos)
#define CRS_ISR_SYNCMISS   CRS_ISR_SYNCMISS_Msk
#define CRS_ISR_TRIMOVF_Pos   (10U)
#define CRS_ISR_TRIMOVF_Msk   (0x1UL << CRS_ISR_TRIMOVF_Pos)
#define CRS_ISR_TRIMOVF   CRS_ISR_TRIMOVF_Msk
#define CRS_ISR_FEDIR_Pos   (15U)
#define CRS_ISR_FEDIR_Msk   (0x1UL << CRS_ISR_FEDIR_Pos)
#define CRS_ISR_FEDIR   CRS_ISR_FEDIR_Msk
#define CRS_ISR_FECAP_Pos   (16U)
#define CRS_ISR_FECAP_Msk   (0xFFFFUL << CRS_ISR_FECAP_Pos)
#define CRS_ISR_FECAP   CRS_ISR_FECAP_Msk
#define CRS_ICR_SYNCOKC_Pos   (0U)
#define CRS_ICR_SYNCOKC_Msk   (0x1UL << CRS_ICR_SYNCOKC_Pos)
#define CRS_ICR_SYNCOKC   CRS_ICR_SYNCOKC_Msk
#define CRS_ICR_SYNCWARNC_Pos   (1U)
#define CRS_ICR_SYNCWARNC_Msk   (0x1UL << CRS_ICR_SYNCWARNC_Pos)
#define CRS_ICR_SYNCWARNC   CRS_ICR_SYNCWARNC_Msk
#define CRS_ICR_ERRC_Pos   (2U)
#define CRS_ICR_ERRC_Msk   (0x1UL << CRS_ICR_ERRC_Pos)
#define CRS_ICR_ERRC   CRS_ICR_ERRC_Msk
#define CRS_ICR_ESYNCC_Pos   (3U)
#define CRS_ICR_ESYNCC_Msk   (0x1UL << CRS_ICR_ESYNCC_Pos)
#define CRS_ICR_ESYNCC   CRS_ICR_ESYNCC_Msk
#define RNG_CR_RNGEN_Pos   (2U)
#define RNG_CR_RNGEN_Msk   (0x1UL << RNG_CR_RNGEN_Pos)
#define RNG_CR_RNGEN   RNG_CR_RNGEN_Msk
#define RNG_CR_IE_Pos   (3U)
#define RNG_CR_IE_Msk   (0x1UL << RNG_CR_IE_Pos)
#define RNG_CR_IE   RNG_CR_IE_Msk
#define RNG_CR_CED_Pos   (5U)
#define RNG_CR_CED_Msk   (0x1UL << RNG_CR_CED_Pos)
#define RNG_CR_CED   RNG_CR_CED_Msk
#define RNG_CR_ARDIS_Pos   (7U)
#define RNG_CR_ARDIS_Msk   (0x1UL << RNG_CR_ARDIS_Pos)
#define RNG_CR_ARDIS   RNG_CR_ARDIS_Msk
#define RNG_CR_RNG_CONFIG3_Pos   (8U)
#define RNG_CR_RNG_CONFIG3_Msk   (0xFUL << RNG_CR_RNG_CONFIG3_Pos)
#define RNG_CR_RNG_CONFIG3   RNG_CR_RNG_CONFIG3_Msk
#define RNG_CR_NISTC_Pos   (12U)
#define RNG_CR_NISTC_Msk   (0x1UL << RNG_CR_NISTC_Pos)
#define RNG_CR_NISTC   RNG_CR_NISTC_Msk
#define RNG_CR_RNG_CONFIG2_Pos   (13U)
#define RNG_CR_RNG_CONFIG2_Msk   (0x7UL << RNG_CR_RNG_CONFIG2_Pos)
#define RNG_CR_RNG_CONFIG2   RNG_CR_RNG_CONFIG2_Msk
#define RNG_CR_CLKDIV_Pos   (16U)
#define RNG_CR_CLKDIV_Msk   (0xFUL << RNG_CR_CLKDIV_Pos)
#define RNG_CR_CLKDIV   RNG_CR_CLKDIV_Msk
#define RNG_CR_CLKDIV_0   (0x1UL << RNG_CR_CLKDIV_Pos)
#define RNG_CR_CLKDIV_1   (0x2UL << RNG_CR_CLKDIV_Pos)
#define RNG_CR_CLKDIV_2   (0x4UL << RNG_CR_CLKDIV_Pos)
#define RNG_CR_CLKDIV_3   (0x8UL << RNG_CR_CLKDIV_Pos)
#define RNG_CR_RNG_CONFIG1_Pos   (20U)
#define RNG_CR_RNG_CONFIG1_Msk   (0x3FUL << RNG_CR_RNG_CONFIG1_Pos)
#define RNG_CR_RNG_CONFIG1   RNG_CR_RNG_CONFIG1_Msk
#define RNG_CR_CONDRST_Pos   (30U)
#define RNG_CR_CONDRST_Msk   (0x1UL << RNG_CR_CONDRST_Pos)
#define RNG_CR_CONDRST   RNG_CR_CONDRST_Msk
#define RNG_CR_CONFIGLOCK_Pos   (31U)
#define RNG_CR_CONFIGLOCK_Msk   (0x1UL << RNG_CR_CONFIGLOCK_Pos)
#define RNG_CR_CONFIGLOCK   RNG_CR_CONFIGLOCK_Msk
#define RNG_SR_DRDY_Pos   (0U)
#define RNG_SR_DRDY_Msk   (0x1UL << RNG_SR_DRDY_Pos)
#define RNG_SR_DRDY   RNG_SR_DRDY_Msk
#define RNG_SR_CECS_Pos   (1U)
#define RNG_SR_CECS_Msk   (0x1UL << RNG_SR_CECS_Pos)
#define RNG_SR_CECS   RNG_SR_CECS_Msk
#define RNG_SR_SECS_Pos   (2U)
#define RNG_SR_SECS_Msk   (0x1UL << RNG_SR_SECS_Pos)
#define RNG_SR_SECS   RNG_SR_SECS_Msk
#define RNG_SR_CEIS_Pos   (5U)
#define RNG_SR_CEIS_Msk   (0x1UL << RNG_SR_CEIS_Pos)
#define RNG_SR_CEIS   RNG_SR_CEIS_Msk
#define RNG_SR_SEIS_Pos   (6U)
#define RNG_SR_SEIS_Msk   (0x1UL << RNG_SR_SEIS_Pos)
#define RNG_SR_SEIS   RNG_SR_SEIS_Msk
#define RNG_NSCR_EN_OSC1_Pos   (0U)
#define RNG_NSCR_EN_OSC1_Msk   (0x7UL << RNG_NSCR_EN_OSC1_Pos)
#define RNG_NSCR_EN_OSC1   RNG_NSCR_EN_OSC1_Msk
#define RNG_NSCR_EN_OSC2_Pos   (3U)
#define RNG_NSCR_EN_OSC2_Msk   (0x7UL << RNG_NSCR_EN_OSC2_Pos)
#define RNG_NSCR_EN_OSC2   RNG_NSCR_EN_OSC2_Msk
#define RNG_NSCR_EN_OSC3_Pos   (6U)
#define RNG_NSCR_EN_OSC3_Msk   (0x7UL << RNG_NSCR_EN_OSC3_Pos)
#define RNG_NSCR_EN_OSC3   RNG_NSCR_EN_OSC3_Msk
#define RNG_NSCR_EN_OSC4_Pos   (9U)
#define RNG_NSCR_EN_OSC4_Msk   (0x7UL << RNG_NSCR_EN_OSC4_Pos)
#define RNG_NSCR_EN_OSC4   RNG_NSCR_EN_OSC4_Msk
#define RNG_NSCR_EN_OSC5_Pos   (12U)
#define RNG_NSCR_EN_OSC5_Msk   (0x7UL << RNG_NSCR_EN_OSC5_Pos)
#define RNG_NSCR_EN_OSC5   RNG_NSCR_EN_OSC5_Msk
#define RNG_NSCR_EN_OSC6_Pos   (15U)
#define RNG_NSCR_EN_OSC6_Msk   (0x7UL << RNG_NSCR_EN_OSC6_Pos)
#define RNG_NSCR_EN_OSC6   RNG_NSCR_EN_OSC6_Msk
#define RNG_HTCR_HTCFG_Pos   (0U)
#define RNG_HTCR_HTCFG_Msk   (0xFFFFFFFFUL << RNG_HTCR_HTCFG_Pos)
#define RNG_HTCR_HTCFG   RNG_HTCR_HTCFG_Msk
#define DAC_CHANNEL2_SUPPORT
#define DAC_CR_EN1_Pos   (0U)
#define DAC_CR_EN1_Msk   (0x1UL << DAC_CR_EN1_Pos)
#define DAC_CR_EN1   DAC_CR_EN1_Msk
#define DAC_CR_TEN1_Pos   (1U)
#define DAC_CR_TEN1_Msk   (0x1UL << DAC_CR_TEN1_Pos)
#define DAC_CR_TEN1   DAC_CR_TEN1_Msk
#define DAC_CR_TSEL1_Pos   (2U)
#define DAC_CR_TSEL1_Msk   (0xFUL << DAC_CR_TSEL1_Pos)
#define DAC_CR_TSEL1   DAC_CR_TSEL1_Msk
#define DAC_CR_TSEL1_0   (0x1UL << DAC_CR_TSEL1_Pos)
#define DAC_CR_TSEL1_1   (0x2UL << DAC_CR_TSEL1_Pos)
#define DAC_CR_TSEL1_2   (0x4UL << DAC_CR_TSEL1_Pos)
#define DAC_CR_TSEL1_3   (0x8UL << DAC_CR_TSEL1_Pos)
#define DAC_CR_WAVE1_Pos   (6U)
#define DAC_CR_WAVE1_Msk   (0x3UL << DAC_CR_WAVE1_Pos)
#define DAC_CR_WAVE1   DAC_CR_WAVE1_Msk
#define DAC_CR_WAVE1_0   (0x1UL << DAC_CR_WAVE1_Pos)
#define DAC_CR_WAVE1_1   (0x2UL << DAC_CR_WAVE1_Pos)
#define DAC_CR_MAMP1_Pos   (8U)
#define DAC_CR_MAMP1_Msk   (0xFUL << DAC_CR_MAMP1_Pos)
#define DAC_CR_MAMP1   DAC_CR_MAMP1_Msk
#define DAC_CR_MAMP1_0   (0x1UL << DAC_CR_MAMP1_Pos)
#define DAC_CR_MAMP1_1   (0x2UL << DAC_CR_MAMP1_Pos)
#define DAC_CR_MAMP1_2   (0x4UL << DAC_CR_MAMP1_Pos)
#define DAC_CR_MAMP1_3   (0x8UL << DAC_CR_MAMP1_Pos)
#define DAC_CR_DMAEN1_Pos   (12U)
#define DAC_CR_DMAEN1_Msk   (0x1UL << DAC_CR_DMAEN1_Pos)
#define DAC_CR_DMAEN1   DAC_CR_DMAEN1_Msk
#define DAC_CR_DMAUDRIE1_Pos   (13U)
#define DAC_CR_DMAUDRIE1_Msk   (0x1UL << DAC_CR_DMAUDRIE1_Pos)
#define DAC_CR_DMAUDRIE1   DAC_CR_DMAUDRIE1_Msk
#define DAC_CR_CEN1_Pos   (14U)
#define DAC_CR_CEN1_Msk   (0x1UL << DAC_CR_CEN1_Pos)
#define DAC_CR_CEN1   DAC_CR_CEN1_Msk
#define DAC_CR_EN2_Pos   (16U)
#define DAC_CR_EN2_Msk   (0x1UL << DAC_CR_EN2_Pos)
#define DAC_CR_EN2   DAC_CR_EN2_Msk
#define DAC_CR_TEN2_Pos   (17U)
#define DAC_CR_TEN2_Msk   (0x1UL << DAC_CR_TEN2_Pos)
#define DAC_CR_TEN2   DAC_CR_TEN2_Msk
#define DAC_CR_TSEL2_Pos   (18U)
#define DAC_CR_TSEL2_Msk   (0xFUL << DAC_CR_TSEL2_Pos)
#define DAC_CR_TSEL2   DAC_CR_TSEL2_Msk
#define DAC_CR_TSEL2_0   (0x1UL << DAC_CR_TSEL2_Pos)
#define DAC_CR_TSEL2_1   (0x2UL << DAC_CR_TSEL2_Pos)
#define DAC_CR_TSEL2_2   (0x4UL << DAC_CR_TSEL2_Pos)
#define DAC_CR_TSEL2_3   (0x8UL << DAC_CR_TSEL2_Pos)
#define DAC_CR_WAVE2_Pos   (22U)
#define DAC_CR_WAVE2_Msk   (0x3UL << DAC_CR_WAVE2_Pos)
#define DAC_CR_WAVE2   DAC_CR_WAVE2_Msk
#define DAC_CR_WAVE2_0   (0x1UL << DAC_CR_WAVE2_Pos)
#define DAC_CR_WAVE2_1   (0x2UL << DAC_CR_WAVE2_Pos)
#define DAC_CR_MAMP2_Pos   (24U)
#define DAC_CR_MAMP2_Msk   (0xFUL << DAC_CR_MAMP2_Pos)
#define DAC_CR_MAMP2   DAC_CR_MAMP2_Msk
#define DAC_CR_MAMP2_0   (0x1UL << DAC_CR_MAMP2_Pos)
#define DAC_CR_MAMP2_1   (0x2UL << DAC_CR_MAMP2_Pos)
#define DAC_CR_MAMP2_2   (0x4UL << DAC_CR_MAMP2_Pos)
#define DAC_CR_MAMP2_3   (0x8UL << DAC_CR_MAMP2_Pos)
#define DAC_CR_DMAEN2_Pos   (28U)
#define DAC_CR_DMAEN2_Msk   (0x1UL << DAC_CR_DMAEN2_Pos)
#define DAC_CR_DMAEN2   DAC_CR_DMAEN2_Msk
#define DAC_CR_DMAUDRIE2_Pos   (29U)
#define DAC_CR_DMAUDRIE2_Msk   (0x1UL << DAC_CR_DMAUDRIE2_Pos)
#define DAC_CR_DMAUDRIE2   DAC_CR_DMAUDRIE2_Msk
#define DAC_CR_CEN2_Pos   (30U)
#define DAC_CR_CEN2_Msk   (0x1UL << DAC_CR_CEN2_Pos)
#define DAC_CR_CEN2   DAC_CR_CEN2_Msk
#define DAC_SWTRIGR_SWTRIG1_Pos   (0U)
#define DAC_SWTRIGR_SWTRIG1_Msk   (0x1UL << DAC_SWTRIGR_SWTRIG1_Pos)
#define DAC_SWTRIGR_SWTRIG1   DAC_SWTRIGR_SWTRIG1_Msk
#define DAC_SWTRIGR_SWTRIG2_Pos   (1U)
#define DAC_SWTRIGR_SWTRIG2_Msk   (0x1UL << DAC_SWTRIGR_SWTRIG2_Pos)
#define DAC_SWTRIGR_SWTRIG2   DAC_SWTRIGR_SWTRIG2_Msk
#define DAC_SWTRIGR_SWTRIGB1_Pos   (16U)
#define DAC_SWTRIGR_SWTRIGB1_Msk   (0x1UL << DAC_SWTRIGR_SWTRIGB1_Pos)
#define DAC_SWTRIGR_SWTRIGB1   DAC_SWTRIGR_SWTRIGB1_Msk
#define DAC_SWTRIGR_SWTRIGB2_Pos   (17U)
#define DAC_SWTRIGR_SWTRIGB2_Msk   (0x1UL << DAC_SWTRIGR_SWTRIGB2_Pos)
#define DAC_SWTRIGR_SWTRIGB2   DAC_SWTRIGR_SWTRIGB2_Msk
#define DAC_DHR12R1_DACC1DHR_Pos   (0U)
#define DAC_DHR12R1_DACC1DHR_Msk   (0xFFFUL << DAC_DHR12R1_DACC1DHR_Pos)
#define DAC_DHR12R1_DACC1DHR   DAC_DHR12R1_DACC1DHR_Msk
#define DAC_DHR12R1_DACC1DHRB_Pos   (16U)
#define DAC_DHR12R1_DACC1DHRB_Msk   (0xFFFUL << DAC_DHR12R1_DACC1DHRB_Pos)
#define DAC_DHR12R1_DACC1DHRB   DAC_DHR12R1_DACC1DHRB_Msk
#define DAC_DHR12L1_DACC1DHR_Pos   (4U)
#define DAC_DHR12L1_DACC1DHR_Msk   (0xFFFUL << DAC_DHR12L1_DACC1DHR_Pos)
#define DAC_DHR12L1_DACC1DHR   DAC_DHR12L1_DACC1DHR_Msk
#define DAC_DHR12L1_DACC1DHRB_Pos   (20U)
#define DAC_DHR12L1_DACC1DHRB_Msk   (0xFFFUL << DAC_DHR12L1_DACC1DHRB_Pos)
#define DAC_DHR12L1_DACC1DHRB   DAC_DHR12L1_DACC1DHRB_Msk
#define DAC_DHR8R1_DACC1DHR_Pos   (0U)
#define DAC_DHR8R1_DACC1DHR_Msk   (0xFFUL << DAC_DHR8R1_DACC1DHR_Pos)
#define DAC_DHR8R1_DACC1DHR   DAC_DHR8R1_DACC1DHR_Msk
#define DAC_DHR8R1_DACC1DHRB_Pos   (8U)
#define DAC_DHR8R1_DACC1DHRB_Msk   (0xFFUL << DAC_DHR8R1_DACC1DHRB_Pos)
#define DAC_DHR8R1_DACC1DHRB   DAC_DHR8R1_DACC1DHRB_Msk
#define DAC_DHR12R2_DACC2DHR_Pos   (0U)
#define DAC_DHR12R2_DACC2DHR_Msk   (0xFFFUL << DAC_DHR12R2_DACC2DHR_Pos)
#define DAC_DHR12R2_DACC2DHR   DAC_DHR12R2_DACC2DHR_Msk
#define DAC_DHR12R2_DACC2DHRB_Pos   (16U)
#define DAC_DHR12R2_DACC2DHRB_Msk   (0xFFFUL << DAC_DHR12R2_DACC2DHRB_Pos)
#define DAC_DHR12R2_DACC2DHRB   DAC_DHR12R2_DACC2DHRB_Msk
#define DAC_DHR12L2_DACC2DHR_Pos   (4U)
#define DAC_DHR12L2_DACC2DHR_Msk   (0xFFFUL << DAC_DHR12L2_DACC2DHR_Pos)
#define DAC_DHR12L2_DACC2DHR   DAC_DHR12L2_DACC2DHR_Msk
#define DAC_DHR12L2_DACC2DHRB_Pos   (20U)
#define DAC_DHR12L2_DACC2DHRB_Msk   (0xFFFUL << DAC_DHR12L2_DACC2DHRB_Pos)
#define DAC_DHR12L2_DACC2DHRB   DAC_DHR12L2_DACC2DHRB_Msk
#define DAC_DHR8R2_DACC2DHR_Pos   (0U)
#define DAC_DHR8R2_DACC2DHR_Msk   (0xFFUL << DAC_DHR8R2_DACC2DHR_Pos)
#define DAC_DHR8R2_DACC2DHR   DAC_DHR8R2_DACC2DHR_Msk
#define DAC_DHR8R2_DACC2DHRB_Pos   (8U)
#define DAC_DHR8R2_DACC2DHRB_Msk   (0xFFUL << DAC_DHR8R2_DACC2DHRB_Pos)
#define DAC_DHR8R2_DACC2DHRB   DAC_DHR8R2_DACC2DHRB_Msk
#define DAC_DHR12RD_DACC1DHR_Pos   (0U)
#define DAC_DHR12RD_DACC1DHR_Msk   (0xFFFUL << DAC_DHR12RD_DACC1DHR_Pos)
#define DAC_DHR12RD_DACC1DHR   DAC_DHR12RD_DACC1DHR_Msk
#define DAC_DHR12RD_DACC2DHR_Pos   (16U)
#define DAC_DHR12RD_DACC2DHR_Msk   (0xFFFUL << DAC_DHR12RD_DACC2DHR_Pos)
#define DAC_DHR12RD_DACC2DHR   DAC_DHR12RD_DACC2DHR_Msk
#define DAC_DHR12LD_DACC1DHR_Pos   (4U)
#define DAC_DHR12LD_DACC1DHR_Msk   (0xFFFUL << DAC_DHR12LD_DACC1DHR_Pos)
#define DAC_DHR12LD_DACC1DHR   DAC_DHR12LD_DACC1DHR_Msk
#define DAC_DHR12LD_DACC2DHR_Pos   (20U)
#define DAC_DHR12LD_DACC2DHR_Msk   (0xFFFUL << DAC_DHR12LD_DACC2DHR_Pos)
#define DAC_DHR12LD_DACC2DHR   DAC_DHR12LD_DACC2DHR_Msk
#define DAC_DHR8RD_DACC1DHR_Pos   (0U)
#define DAC_DHR8RD_DACC1DHR_Msk   (0xFFUL << DAC_DHR8RD_DACC1DHR_Pos)
#define DAC_DHR8RD_DACC1DHR   DAC_DHR8RD_DACC1DHR_Msk
#define DAC_DHR8RD_DACC2DHR_Pos   (8U)
#define DAC_DHR8RD_DACC2DHR_Msk   (0xFFUL << DAC_DHR8RD_DACC2DHR_Pos)
#define DAC_DHR8RD_DACC2DHR   DAC_DHR8RD_DACC2DHR_Msk
#define DAC_DOR1_DACC1DOR_Pos   (0U)
#define DAC_DOR1_DACC1DOR_Msk   (0xFFFUL << DAC_DOR1_DACC1DOR_Pos)
#define DAC_DOR1_DACC1DOR   DAC_DOR1_DACC1DOR_Msk
#define DAC_DOR1_DACC1DORB_Pos   (16U)
#define DAC_DOR1_DACC1DORB_Msk   (0xFFFUL << DAC_DOR1_DACC1DORB_Pos)
#define DAC_DOR1_DACC1DORB   DAC_DOR1_DACC1DORB_Msk
#define DAC_DOR2_DACC2DOR_Pos   (0U)
#define DAC_DOR2_DACC2DOR_Msk   (0xFFFUL << DAC_DOR2_DACC2DOR_Pos)
#define DAC_DOR2_DACC2DOR   DAC_DOR2_DACC2DOR_Msk
#define DAC_DOR2_DACC2DORB_Pos   (16U)
#define DAC_DOR2_DACC2DORB_Msk   (0xFFFUL << DAC_DOR2_DACC2DORB_Pos)
#define DAC_DOR2_DACC2DORB   DAC_DOR2_DACC2DORB_Msk
#define DAC_SR_DAC1RDY_Pos   (11U)
#define DAC_SR_DAC1RDY_Msk   (0x1UL << DAC_SR_DAC1RDY_Pos)
#define DAC_SR_DAC1RDY   DAC_SR_DAC1RDY_Msk
#define DAC_SR_DORSTAT1_Pos   (12U)
#define DAC_SR_DORSTAT1_Msk   (0x1UL << DAC_SR_DORSTAT1_Pos)
#define DAC_SR_DORSTAT1   DAC_SR_DORSTAT1_Msk
#define DAC_SR_DMAUDR1_Pos   (13U)
#define DAC_SR_DMAUDR1_Msk   (0x1UL << DAC_SR_DMAUDR1_Pos)
#define DAC_SR_DMAUDR1   DAC_SR_DMAUDR1_Msk
#define DAC_SR_CAL_FLAG1_Pos   (14U)
#define DAC_SR_CAL_FLAG1_Msk   (0x1UL << DAC_SR_CAL_FLAG1_Pos)
#define DAC_SR_CAL_FLAG1   DAC_SR_CAL_FLAG1_Msk
#define DAC_SR_BWST1_Pos   (15U)
#define DAC_SR_BWST1_Msk   (0x1UL << DAC_SR_BWST1_Pos)
#define DAC_SR_BWST1   DAC_SR_BWST1_Msk
#define DAC_SR_DAC2RDY_Pos   (27U)
#define DAC_SR_DAC2RDY_Msk   (0x1UL << DAC_SR_DAC2RDY_Pos)
#define DAC_SR_DAC2RDY   DAC_SR_DAC2RDY_Msk
#define DAC_SR_DORSTAT2_Pos   (28U)
#define DAC_SR_DORSTAT2_Msk   (0x1UL << DAC_SR_DORSTAT2_Pos)
#define DAC_SR_DORSTAT2   DAC_SR_DORSTAT2_Msk
#define DAC_SR_DMAUDR2_Pos   (29U)
#define DAC_SR_DMAUDR2_Msk   (0x1UL << DAC_SR_DMAUDR2_Pos)
#define DAC_SR_DMAUDR2   DAC_SR_DMAUDR2_Msk
#define DAC_SR_CAL_FLAG2_Pos   (30U)
#define DAC_SR_CAL_FLAG2_Msk   (0x1UL << DAC_SR_CAL_FLAG2_Pos)
#define DAC_SR_CAL_FLAG2   DAC_SR_CAL_FLAG2_Msk
#define DAC_SR_BWST2_Pos   (31U)
#define DAC_SR_BWST2_Msk   (0x1UL << DAC_SR_BWST2_Pos)
#define DAC_SR_BWST2   DAC_SR_BWST2_Msk
#define DAC_CCR_OTRIM1_Pos   (0U)
#define DAC_CCR_OTRIM1_Msk   (0x1FUL << DAC_CCR_OTRIM1_Pos)
#define DAC_CCR_OTRIM1   DAC_CCR_OTRIM1_Msk
#define DAC_CCR_OTRIM2_Pos   (16U)
#define DAC_CCR_OTRIM2_Msk   (0x1FUL << DAC_CCR_OTRIM2_Pos)
#define DAC_CCR_OTRIM2   DAC_CCR_OTRIM2_Msk
#define DAC_MCR_MODE1_Pos   (0U)
#define DAC_MCR_MODE1_Msk   (0x7UL << DAC_MCR_MODE1_Pos)
#define DAC_MCR_MODE1   DAC_MCR_MODE1_Msk
#define DAC_MCR_MODE1_0   (0x1UL << DAC_MCR_MODE1_Pos)
#define DAC_MCR_MODE1_1   (0x2UL << DAC_MCR_MODE1_Pos)
#define DAC_MCR_MODE1_2   (0x4UL << DAC_MCR_MODE1_Pos)
#define DAC_MCR_DMADOUBLE1_Pos   (8U)
#define DAC_MCR_DMADOUBLE1_Msk   (0x1UL << DAC_MCR_DMADOUBLE1_Pos)
#define DAC_MCR_DMADOUBLE1   DAC_MCR_DMADOUBLE1_Msk
#define DAC_MCR_SINFORMAT1_Pos   (9U)
#define DAC_MCR_SINFORMAT1_Msk   (0x1UL << DAC_MCR_SINFORMAT1_Pos)
#define DAC_MCR_SINFORMAT1   DAC_MCR_SINFORMAT1_Msk
#define DAC_MCR_HFSEL_Pos   (14U)
#define DAC_MCR_HFSEL_Msk   (0x3UL << DAC_MCR_HFSEL_Pos)
#define DAC_MCR_HFSEL   DAC_MCR_HFSEL_Msk
#define DAC_MCR_HFSEL_0   (0x1UL << DAC_MCR_HFSEL_Pos)
#define DAC_MCR_HFSEL_1   (0x2UL << DAC_MCR_HFSEL_Pos)
#define DAC_MCR_MODE2_Pos   (16U)
#define DAC_MCR_MODE2_Msk   (0x7UL << DAC_MCR_MODE2_Pos)
#define DAC_MCR_MODE2   DAC_MCR_MODE2_Msk
#define DAC_MCR_MODE2_0   (0x1UL << DAC_MCR_MODE2_Pos)
#define DAC_MCR_MODE2_1   (0x2UL << DAC_MCR_MODE2_Pos)
#define DAC_MCR_MODE2_2   (0x4UL << DAC_MCR_MODE2_Pos)
#define DAC_MCR_DMADOUBLE2_Pos   (24U)
#define DAC_MCR_DMADOUBLE2_Msk   (0x1UL << DAC_MCR_DMADOUBLE2_Pos)
#define DAC_MCR_DMADOUBLE2   DAC_MCR_DMADOUBLE2_Msk
#define DAC_MCR_SINFORMAT2_Pos   (25U)
#define DAC_MCR_SINFORMAT2_Msk   (0x1UL << DAC_MCR_SINFORMAT2_Pos)
#define DAC_MCR_SINFORMAT2   DAC_MCR_SINFORMAT2_Msk
#define DAC_SHSR1_TSAMPLE1_Pos   (0U)
#define DAC_SHSR1_TSAMPLE1_Msk   (0x3FFUL << DAC_SHSR1_TSAMPLE1_Pos)
#define DAC_SHSR1_TSAMPLE1   DAC_SHSR1_TSAMPLE1_Msk
#define DAC_SHSR2_TSAMPLE2_Pos   (0U)
#define DAC_SHSR2_TSAMPLE2_Msk   (0x3FFUL << DAC_SHSR2_TSAMPLE2_Pos)
#define DAC_SHSR2_TSAMPLE2   DAC_SHSR2_TSAMPLE2_Msk
#define DAC_SHHR_THOLD1_Pos   (0U)
#define DAC_SHHR_THOLD1_Msk   (0x3FFUL << DAC_SHHR_THOLD1_Pos)
#define DAC_SHHR_THOLD1   DAC_SHHR_THOLD1_Msk
#define DAC_SHHR_THOLD2_Pos   (16U)
#define DAC_SHHR_THOLD2_Msk   (0x3FFUL << DAC_SHHR_THOLD2_Pos)
#define DAC_SHHR_THOLD2   DAC_SHHR_THOLD2_Msk
#define DAC_SHRR_TREFRESH1_Pos   (0U)
#define DAC_SHRR_TREFRESH1_Msk   (0xFFUL << DAC_SHRR_TREFRESH1_Pos)
#define DAC_SHRR_TREFRESH1   DAC_SHRR_TREFRESH1_Msk
#define DAC_SHRR_TREFRESH2_Pos   (16U)
#define DAC_SHRR_TREFRESH2_Msk   (0xFFUL << DAC_SHRR_TREFRESH2_Pos)
#define DAC_SHRR_TREFRESH2   DAC_SHRR_TREFRESH2_Msk
#define DAC_AUTOCR_AUTOMODE_Pos   (22U)
#define DAC_AUTOCR_AUTOMODE_Msk   (0x1UL << DAC_AUTOCR_AUTOMODE_Pos)
#define DAC_AUTOCR_AUTOMODE   DAC_AUTOCR_AUTOMODE_Msk
#define AES_CR_EN_Pos   (0U)
#define AES_CR_EN_Msk   (0x1UL << AES_CR_EN_Pos)
#define AES_CR_EN   AES_CR_EN_Msk
#define AES_CR_DATATYPE_Pos   (1U)
#define AES_CR_DATATYPE_Msk   (0x3UL << AES_CR_DATATYPE_Pos)
#define AES_CR_DATATYPE   AES_CR_DATATYPE_Msk
#define AES_CR_DATATYPE_0   (0x1UL << AES_CR_DATATYPE_Pos)
#define AES_CR_DATATYPE_1   (0x2UL << AES_CR_DATATYPE_Pos)
#define AES_CR_MODE_Pos   (3U)
#define AES_CR_MODE_Msk   (0x3UL << AES_CR_MODE_Pos)
#define AES_CR_MODE   AES_CR_MODE_Msk
#define AES_CR_MODE_0   (0x1UL << AES_CR_MODE_Pos)
#define AES_CR_MODE_1   (0x2UL << AES_CR_MODE_Pos)
#define AES_CR_CHMOD_Pos   (5U)
#define AES_CR_CHMOD_Msk   (0x803UL << AES_CR_CHMOD_Pos)
#define AES_CR_CHMOD   AES_CR_CHMOD_Msk
#define AES_CR_CHMOD_0   (0x001UL << AES_CR_CHMOD_Pos)
#define AES_CR_CHMOD_1   (0x002UL << AES_CR_CHMOD_Pos)
#define AES_CR_CHMOD_2   (0x800UL << AES_CR_CHMOD_Pos)
#define AES_CR_DMAINEN_Pos   (11U)
#define AES_CR_DMAINEN_Msk   (0x1UL << AES_CR_DMAINEN_Pos)
#define AES_CR_DMAINEN   AES_CR_DMAINEN_Msk
#define AES_CR_DMAOUTEN_Pos   (12U)
#define AES_CR_DMAOUTEN_Msk   (0x1UL << AES_CR_DMAOUTEN_Pos)
#define AES_CR_DMAOUTEN   AES_CR_DMAOUTEN_Msk
#define AES_CR_GCMPH_Pos   (13U)
#define AES_CR_GCMPH_Msk   (0x3UL << AES_CR_GCMPH_Pos)
#define AES_CR_GCMPH   AES_CR_GCMPH_Msk
#define AES_CR_GCMPH_0   (0x1UL << AES_CR_GCMPH_Pos)
#define AES_CR_GCMPH_1   (0x2UL << AES_CR_GCMPH_Pos)
#define AES_CR_KEYSIZE_Pos   (18U)
#define AES_CR_KEYSIZE_Msk   (0x1UL << AES_CR_KEYSIZE_Pos)
#define AES_CR_KEYSIZE   AES_CR_KEYSIZE_Msk
#define AES_CR_KEYPROT_Pos   (19U)
#define AES_CR_KEYPROT_Msk   (0x1UL << AES_CR_KEYPROT_Pos)
#define AES_CR_KEYPROT   AES_CR_KEYPROT_Msk
#define AES_CR_NPBLB_Pos   (20U)
#define AES_CR_NPBLB_Msk   (0xFUL << AES_CR_NPBLB_Pos)
#define AES_CR_NPBLB   AES_CR_NPBLB_Msk
#define AES_CR_NPBLB_0   (0x1UL << AES_CR_NPBLB_Pos)
#define AES_CR_NPBLB_1   (0x2UL << AES_CR_NPBLB_Pos)
#define AES_CR_NPBLB_2   (0x4UL << AES_CR_NPBLB_Pos)
#define AES_CR_NPBLB_3   (0x8UL << AES_CR_NPBLB_Pos)
#define AES_CR_KMOD_Pos   (24U)
#define AES_CR_KMOD_Msk   (0x3UL << AES_CR_KMOD_Pos)
#define AES_CR_KMOD   AES_CR_KMOD_Msk
#define AES_CR_KMOD_0   (0x1UL << AES_CR_KMOD_Pos)
#define AES_CR_KMOD_1   (0x2UL << AES_CR_KMOD_Pos)
#define AES_CR_KSHAREID_Pos   (26U)
#define AES_CR_KSHAREID_Msk   (0x3UL << AES_CR_KSHAREID_Pos)
#define AES_CR_KSHAREID   AES_CR_KSHAREID_Msk
#define AES_CR_KEYSEL_Pos   (28U)
#define AES_CR_KEYSEL_Msk   (0x7UL << AES_CR_KEYSEL_Pos)
#define AES_CR_KEYSEL   AES_CR_KEYSEL_Msk
#define AES_CR_KEYSEL_0   (0x1UL << AES_CR_KEYSEL_Pos)
#define AES_CR_KEYSEL_1   (0x2UL << AES_CR_KEYSEL_Pos)
#define AES_CR_KEYSEL_2   (0x4UL << AES_CR_KEYSEL_Pos)
#define AES_CR_IPRST_Pos   (31U)
#define AES_CR_IPRST_Msk   (0x1UL << AES_CR_IPRST_Pos)
#define AES_CR_IPRST   AES_CR_IPRST_Msk
#define AES_SR_CCF_Pos   (0U)
#define AES_SR_CCF_Msk   (0x1UL << AES_SR_CCF_Pos)
#define AES_SR_CCF   AES_SR_CCF_Msk
#define AES_SR_RDERR_Pos   (1U)
#define AES_SR_RDERR_Msk   (0x1UL << AES_SR_RDERR_Pos)
#define AES_SR_RDERR   AES_SR_RDERR_Msk
#define AES_SR_WRERR_Pos   (2U)
#define AES_SR_WRERR_Msk   (0x1UL << AES_SR_WRERR_Pos)
#define AES_SR_WRERR   AES_SR_WRERR_Msk
#define AES_SR_BUSY_Pos   (3U)
#define AES_SR_BUSY_Msk   (0x1UL << AES_SR_BUSY_Pos)
#define AES_SR_BUSY   AES_SR_BUSY_Msk
#define AES_SR_KEYVALID_Pos   (7U)
#define AES_SR_KEYVALID_Msk   (0x1UL << AES_SR_KEYVALID_Pos)
#define AES_SR_KEYVALID   AES_SR_KEYVALID_Msk
#define AES_DINR_Pos   (0U)
#define AES_DINR_Msk   (0xFFFFFFFFUL << AES_DINR_Pos)
#define AES_DINR   AES_DINR_Msk
#define AES_DOUTR_Pos   (0U)
#define AES_DOUTR_Msk   (0xFFFFFFFFUL << AES_DOUTR_Pos)
#define AES_DOUTR   AES_DOUTR_Msk
#define AES_KEYR0_Pos   (0U)
#define AES_KEYR0_Msk   (0xFFFFFFFFUL << AES_KEYR0_Pos)
#define AES_KEYR0   AES_KEYR0_Msk
#define AES_KEYR1_Pos   (0U)
#define AES_KEYR1_Msk   (0xFFFFFFFFUL << AES_KEYR1_Pos)
#define AES_KEYR1   AES_KEYR1_Msk
#define AES_KEYR2_Pos   (0U)
#define AES_KEYR2_Msk   (0xFFFFFFFFUL << AES_KEYR2_Pos)
#define AES_KEYR2   AES_KEYR2_Msk
#define AES_KEYR3_Pos   (0U)
#define AES_KEYR3_Msk   (0xFFFFFFFFUL << AES_KEYR3_Pos)
#define AES_KEYR3   AES_KEYR3_Msk
#define AES_KEYR4_Pos   (0U)
#define AES_KEYR4_Msk   (0xFFFFFFFFUL << AES_KEYR4_Pos)
#define AES_KEYR4   AES_KEYR4_Msk
#define AES_KEYR5_Pos   (0U)
#define AES_KEYR5_Msk   (0xFFFFFFFFUL << AES_KEYR5_Pos)
#define AES_KEYR5   AES_KEYR5_Msk
#define AES_KEYR6_Pos   (0U)
#define AES_KEYR6_Msk   (0xFFFFFFFFUL << AES_KEYR6_Pos)
#define AES_KEYR6   AES_KEYR6_Msk
#define AES_KEYR7_Pos   (0U)
#define AES_KEYR7_Msk   (0xFFFFFFFFUL << AES_KEYR7_Pos)
#define AES_KEYR7   AES_KEYR7_Msk
#define AES_IVR0_Pos   (0U)
#define AES_IVR0_Msk   (0xFFFFFFFFUL << AES_IVR0_Pos)
#define AES_IVR0   AES_IVR0_Msk
#define AES_IVR1_Pos   (0U)
#define AES_IVR1_Msk   (0xFFFFFFFFUL << AES_IVR1_Pos)
#define AES_IVR1   AES_IVR1_Msk
#define AES_IVR2_Pos   (0U)
#define AES_IVR2_Msk   (0xFFFFFFFFUL << AES_IVR2_Pos)
#define AES_IVR2   AES_IVR2_Msk
#define AES_IVR3_Pos   (0U)
#define AES_IVR3_Msk   (0xFFFFFFFFUL << AES_IVR3_Pos)
#define AES_IVR3   AES_IVR3_Msk
#define AES_SUSP0R_Pos   (0U)
#define AES_SUSP0R_Msk   (0xFFFFFFFFUL << AES_SUSP0R_Pos)
#define AES_SUSP0R   AES_SUSP0R_Msk
#define AES_SUSP1R_Pos   (0U)
#define AES_SUSP1R_Msk   (0xFFFFFFFFUL << AES_SUSP1R_Pos)
#define AES_SUSP1R   AES_SUSP1R_Msk
#define AES_SUSP2R_Pos   (0U)
#define AES_SUSP2R_Msk   (0xFFFFFFFFUL << AES_SUSP2R_Pos)
#define AES_SUSP2R   AES_SUSP2R_Msk
#define AES_SUSP3R_Pos   (0U)
#define AES_SUSP3R_Msk   (0xFFFFFFFFUL << AES_SUSP3R_Pos)
#define AES_SUSP3R   AES_SUSP3R_Msk
#define AES_SUSP4R_Pos   (0U)
#define AES_SUSP4R_Msk   (0xFFFFFFFFUL << AES_SUSP4R_Pos)
#define AES_SUSP4R   AES_SUSP4R_Msk
#define AES_SUSP5R_Pos   (0U)
#define AES_SUSP5R_Msk   (0xFFFFFFFFUL << AES_SUSP5R_Pos)
#define AES_SUSP5R   AES_SUSP5R_Msk
#define AES_SUSP6R_Pos   (0U)
#define AES_SUSP6R_Msk   (0xFFFFFFFFUL << AES_SUSP6R_Pos)
#define AES_SUSP6R   AES_SUSP6R_Msk
#define AES_SUSP7R_Pos   (0U)
#define AES_SUSP7R_Msk   (0xFFFFFFFFUL << AES_SUSP7R_Pos)
#define AES_SUSP7R   AES_SUSP7R_Msk
#define AES_IER_CCFIE_Pos   (0U)
#define AES_IER_CCFIE_Msk   (0x1UL << AES_IER_CCFIE_Pos)
#define AES_IER_CCFIE   AES_IER_CCFIE_Msk
#define AES_IER_RWEIE_Pos   (1U)
#define AES_IER_RWEIE_Msk   (0x1UL << AES_IER_RWEIE_Pos)
#define AES_IER_RWEIE   AES_IER_RWEIE_Msk
#define AES_IER_KEIE_Pos   (2U)
#define AES_IER_KEIE_Msk   (0x1UL << AES_IER_KEIE_Pos)
#define AES_IER_KEIE   AES_IER_KEIE_Msk
#define AES_IER_RNGEIE_Pos   (3U)
#define AES_IER_RNGEIE_Msk   (0x1UL << AES_IER_RNGEIE_Pos)
#define AES_IER_RNGEIE   AES_IER_RNGEIE_Msk
#define AES_ISR_CCF_Pos   (0U)
#define AES_ISR_CCF_Msk   (0x1UL << AES_ISR_CCF_Pos)
#define AES_ISR_CCF   AES_ISR_CCF_Msk
#define AES_ISR_RWEIF_Pos   (1U)
#define AES_ISR_RWEIF_Msk   (0x1UL << AES_ISR_RWEIF_Pos)
#define AES_ISR_RWEIF   AES_ISR_RWEIF_Msk
#define AES_ISR_KEIF_Pos   (2U)
#define AES_ISR_KEIF_Msk   (0x1UL << AES_ISR_KEIF_Pos)
#define AES_ISR_KEIF   AES_ISR_KEIF_Msk
#define AES_ISR_RNGEIF_Pos   (3U)
#define AES_ISR_RNGEIF_Msk   (0x1UL << AES_ISR_RNGEIF_Pos)
#define AES_ISR_RNGEIF   AES_ISR_RNGEIF_Msk
#define AES_ICR_CCF_Pos   (0U)
#define AES_ICR_CCF_Msk   (0x1UL << AES_ICR_CCF_Pos)
#define AES_ICR_CCF   AES_ICR_CCF_Msk
#define AES_ICR_RWEIF_Pos   (1U)
#define AES_ICR_RWEIF_Msk   (0x1UL << AES_ICR_RWEIF_Pos)
#define AES_ICR_RWEIF   AES_ICR_RWEIF_Msk
#define AES_ICR_KEIF_Pos   (2U)
#define AES_ICR_KEIF_Msk   (0x1UL << AES_ICR_KEIF_Pos)
#define AES_ICR_KEIF   AES_ICR_KEIF_Msk
#define AES_ICR_RNGEIF_Pos   (3U)
#define AES_ICR_RNGEIF_Msk   (0x1UL << AES_ICR_RNGEIF_Pos)
#define AES_ICR_RNGEIF   AES_ICR_RNGEIF_Msk
#define HASH_CR_INIT_Pos   (2U)
#define HASH_CR_INIT_Msk   (0x1UL << HASH_CR_INIT_Pos)
#define HASH_CR_INIT   HASH_CR_INIT_Msk
#define HASH_CR_DMAE_Pos   (3U)
#define HASH_CR_DMAE_Msk   (0x1UL << HASH_CR_DMAE_Pos)
#define HASH_CR_DMAE   HASH_CR_DMAE_Msk
#define HASH_CR_DATATYPE_Pos   (4U)
#define HASH_CR_DATATYPE_Msk   (0x3UL << HASH_CR_DATATYPE_Pos)
#define HASH_CR_DATATYPE   HASH_CR_DATATYPE_Msk
#define HASH_CR_DATATYPE_0   (0x1UL << HASH_CR_DATATYPE_Pos)
#define HASH_CR_DATATYPE_1   (0x2UL << HASH_CR_DATATYPE_Pos)
#define HASH_CR_MODE_Pos   (6U)
#define HASH_CR_MODE_Msk   (0x1UL << HASH_CR_MODE_Pos)
#define HASH_CR_MODE   HASH_CR_MODE_Msk
#define HASH_CR_NBW_Pos   (8U)
#define HASH_CR_NBW_Msk   (0xFUL << HASH_CR_NBW_Pos)
#define HASH_CR_NBW   HASH_CR_NBW_Msk
#define HASH_CR_NBW_0   (0x1UL << HASH_CR_NBW_Pos)
#define HASH_CR_NBW_1   (0x2UL << HASH_CR_NBW_Pos)
#define HASH_CR_NBW_2   (0x4UL << HASH_CR_NBW_Pos)
#define HASH_CR_NBW_3   (0x8UL << HASH_CR_NBW_Pos)
#define HASH_CR_DINNE_Pos   (12U)
#define HASH_CR_DINNE_Msk   (0x1UL << HASH_CR_DINNE_Pos)
#define HASH_CR_DINNE   HASH_CR_DINNE_Msk
#define HASH_CR_MDMAT_Pos   (13U)
#define HASH_CR_MDMAT_Msk   (0x1UL << HASH_CR_MDMAT_Pos)
#define HASH_CR_MDMAT   HASH_CR_MDMAT_Msk
#define HASH_CR_LKEY_Pos   (16U)
#define HASH_CR_LKEY_Msk   (0x1UL << HASH_CR_LKEY_Pos)
#define HASH_CR_LKEY   HASH_CR_LKEY_Msk
#define HASH_CR_ALGO_Pos   (17U)
#define HASH_CR_ALGO_Msk   (0x3UL << HASH_CR_ALGO_Pos)
#define HASH_CR_ALGO   HASH_CR_ALGO_Msk
#define HASH_CR_ALGO_0   (0x1UL << HASH_CR_ALGO_Pos)
#define HASH_CR_ALGO_1   (0x2UL << HASH_CR_ALGO_Pos)
#define HASH_STR_NBLW_Pos   (0U)
#define HASH_STR_NBLW_Msk   (0x1FUL << HASH_STR_NBLW_Pos)
#define HASH_STR_NBLW   HASH_STR_NBLW_Msk
#define HASH_STR_NBLW_0   (0x01UL << HASH_STR_NBLW_Pos)
#define HASH_STR_NBLW_1   (0x02UL << HASH_STR_NBLW_Pos)
#define HASH_STR_NBLW_2   (0x04UL << HASH_STR_NBLW_Pos)
#define HASH_STR_NBLW_3   (0x08UL << HASH_STR_NBLW_Pos)
#define HASH_STR_NBLW_4   (0x10UL << HASH_STR_NBLW_Pos)
#define HASH_STR_DCAL_Pos   (8U)
#define HASH_STR_DCAL_Msk   (0x1UL << HASH_STR_DCAL_Pos)
#define HASH_STR_DCAL   HASH_STR_DCAL_Msk
#define HASH_IMR_DINIE_Pos   (0U)
#define HASH_IMR_DINIE_Msk   (0x1UL << HASH_IMR_DINIE_Pos)
#define HASH_IMR_DINIE   HASH_IMR_DINIE_Msk
#define HASH_IMR_DCIE_Pos   (1U)
#define HASH_IMR_DCIE_Msk   (0x1UL << HASH_IMR_DCIE_Pos)
#define HASH_IMR_DCIE   HASH_IMR_DCIE_Msk
#define HASH_SR_DINIS_Pos   (0U)
#define HASH_SR_DINIS_Msk   (0x1UL << HASH_SR_DINIS_Pos)
#define HASH_SR_DINIS   HASH_SR_DINIS_Msk
#define HASH_SR_DCIS_Pos   (1U)
#define HASH_SR_DCIS_Msk   (0x1UL << HASH_SR_DCIS_Pos)
#define HASH_SR_DCIS   HASH_SR_DCIS_Msk
#define HASH_SR_DMAS_Pos   (2U)
#define HASH_SR_DMAS_Msk   (0x1UL << HASH_SR_DMAS_Pos)
#define HASH_SR_DMAS   HASH_SR_DMAS_Msk
#define HASH_SR_BUSY_Pos   (3U)
#define HASH_SR_BUSY_Msk   (0x1UL << HASH_SR_BUSY_Pos)
#define HASH_SR_BUSY   HASH_SR_BUSY_Msk
#define HASH_SR_NBWE_Pos   (16U)
#define HASH_SR_NBWE_Msk   (0xFUL << HASH_SR_NBWE_Pos)
#define HASH_SR_NBWE   HASH_SR_NBWE_Msk
#define HASH_SR_NBWE_0   (0x01UL << HASH_SR_NBWE_Pos)
#define HASH_SR_NBWE_1   (0x02UL << HASH_SR_NBWE_Pos)
#define HASH_SR_NBWE_2   (0x04UL << HASH_SR_NBWE_Pos)
#define HASH_SR_NBWE_3   (0x08UL << HASH_SR_NBWE_Pos)
#define HASH_SR_DINNE_Pos   (15U)
#define HASH_SR_DINNE_Msk   (0x1UL << HASH_SR_DINNE_Pos)
#define HASH_SR_DINNE   HASH_SR_DINNE_Msk
#define HASH_SR_NBWP_Pos   (9U)
#define HASH_SR_NBWP_Msk   (0xFUL << HASH_SR_NBWP_Pos)
#define HASH_SR_NBWP   HASH_SR_NBWP_Msk
#define HASH_SR_NBWP_0   (0x01UL << HASH_SR_NBWP_Pos)
#define HASH_SR_NBWP_1   (0x02UL << HASH_SR_NBWP_Pos)
#define HASH_SR_NBWP_2   (0x04UL << HASH_SR_NBWP_Pos)
#define HASH_SR_NBWP_3   (0x08UL << HASH_SR_NBWP_Pos)
#define DBGMCU_IDCODE_DEV_ID_Pos   (0U)
#define DBGMCU_IDCODE_DEV_ID_Msk   (0xFFFUL << DBGMCU_IDCODE_DEV_ID_Pos)
#define DBGMCU_IDCODE_DEV_ID   DBGMCU_IDCODE_DEV_ID_Msk
#define DBGMCU_IDCODE_REV_ID_Pos   (16U)
#define DBGMCU_IDCODE_REV_ID_Msk   (0xFFFFUL << DBGMCU_IDCODE_REV_ID_Pos)
#define DBGMCU_IDCODE_REV_ID   DBGMCU_IDCODE_REV_ID_Msk
#define DBGMCU_CR_DBG_STOP_Pos   (1U)
#define DBGMCU_CR_DBG_STOP_Msk   (0x1UL << DBGMCU_CR_DBG_STOP_Pos)
#define DBGMCU_CR_DBG_STOP   DBGMCU_CR_DBG_STOP_Msk
#define DBGMCU_CR_DBG_STANDBY_Pos   (2U)
#define DBGMCU_CR_DBG_STANDBY_Msk   (0x1UL << DBGMCU_CR_DBG_STANDBY_Pos)
#define DBGMCU_CR_DBG_STANDBY   DBGMCU_CR_DBG_STANDBY_Msk
#define DBGMCU_CR_TRACE_IOEN_Pos   (4U)
#define DBGMCU_CR_TRACE_IOEN_Msk   (0x1UL << DBGMCU_CR_TRACE_IOEN_Pos)
#define DBGMCU_CR_TRACE_IOEN   DBGMCU_CR_TRACE_IOEN_Msk
#define DBGMCU_CR_TRACE_CLKEN_Pos   (5U)
#define DBGMCU_CR_TRACE_CLKEN_Msk   (0x1UL << DBGMCU_CR_TRACE_CLKEN_Pos)
#define DBGMCU_CR_TRACE_CLKEN   DBGMCU_CR_TRACE_CLKEN_Msk
#define DBGMCU_CR_TRACE_MODE_Pos   (6U)
#define DBGMCU_CR_TRACE_MODE_Msk   (0x3UL << DBGMCU_CR_TRACE_MODE_Pos)
#define DBGMCU_CR_TRACE_MODE   DBGMCU_CR_TRACE_MODE_Msk
#define DBGMCU_CR_TRACE_MODE_0   (0x1UL << DBGMCU_CR_TRACE_MODE_Pos)
#define DBGMCU_CR_TRACE_MODE_1   (0x2UL << DBGMCU_CR_TRACE_MODE_Pos)
#define DBGMCU_APB1FZR1_DBG_TIM2_STOP_Pos   (0U)
#define DBGMCU_APB1FZR1_DBG_TIM2_STOP_Msk   (0x1UL << DBGMCU_APB1FZR1_DBG_TIM2_STOP_Pos)
#define DBGMCU_APB1FZR1_DBG_TIM2_STOP   DBGMCU_APB1FZR1_DBG_TIM2_STOP_Msk
#define DBGMCU_APB1FZR1_DBG_TIM3_STOP_Pos   (1U)
#define DBGMCU_APB1FZR1_DBG_TIM3_STOP_Msk   (0x1UL << DBGMCU_APB1FZR1_DBG_TIM3_STOP_Pos)
#define DBGMCU_APB1FZR1_DBG_TIM3_STOP   DBGMCU_APB1FZR1_DBG_TIM3_STOP_Msk
#define DBGMCU_APB1FZR1_DBG_TIM4_STOP_Pos   (2U)
#define DBGMCU_APB1FZR1_DBG_TIM4_STOP_Msk   (0x1UL << DBGMCU_APB1FZR1_DBG_TIM4_STOP_Pos)
#define DBGMCU_APB1FZR1_DBG_TIM4_STOP   DBGMCU_APB1FZR1_DBG_TIM4_STOP_Msk
#define DBGMCU_APB1FZR1_DBG_TIM5_STOP_Pos   (3U)
#define DBGMCU_APB1FZR1_DBG_TIM5_STOP_Msk   (0x1UL << DBGMCU_APB1FZR1_DBG_TIM5_STOP_Pos)
#define DBGMCU_APB1FZR1_DBG_TIM5_STOP   DBGMCU_APB1FZR1_DBG_TIM5_STOP_Msk
#define DBGMCU_APB1FZR1_DBG_TIM6_STOP_Pos   (4U)
#define DBGMCU_APB1FZR1_DBG_TIM6_STOP_Msk   (0x1UL << DBGMCU_APB1FZR1_DBG_TIM6_STOP_Pos)
#define DBGMCU_APB1FZR1_DBG_TIM6_STOP   DBGMCU_APB1FZR1_DBG_TIM6_STOP_Msk
#define DBGMCU_APB1FZR1_DBG_TIM7_STOP_Pos   (5U)
#define DBGMCU_APB1FZR1_DBG_TIM7_STOP_Msk   (0x1UL << DBGMCU_APB1FZR1_DBG_TIM7_STOP_Pos)
#define DBGMCU_APB1FZR1_DBG_TIM7_STOP   DBGMCU_APB1FZR1_DBG_TIM7_STOP_Msk
#define DBGMCU_APB1FZR1_DBG_WWDG_STOP_Pos   (11U)
#define DBGMCU_APB1FZR1_DBG_WWDG_STOP_Msk   (0x1UL << DBGMCU_APB1FZR1_DBG_WWDG_STOP_Pos)
#define DBGMCU_APB1FZR1_DBG_WWDG_STOP   DBGMCU_APB1FZR1_DBG_WWDG_STOP_Msk
#define DBGMCU_APB1FZR1_DBG_IWDG_STOP_Pos   (12U)
#define DBGMCU_APB1FZR1_DBG_IWDG_STOP_Msk   (0x1UL << DBGMCU_APB1FZR1_DBG_IWDG_STOP_Pos)
#define DBGMCU_APB1FZR1_DBG_IWDG_STOP   DBGMCU_APB1FZR1_DBG_IWDG_STOP_Msk
#define DBGMCU_APB1FZR1_DBG_I2C1_STOP_Pos   (21U)
#define DBGMCU_APB1FZR1_DBG_I2C1_STOP_Msk   (0x1UL << DBGMCU_APB1FZR1_DBG_I2C1_STOP_Pos)
#define DBGMCU_APB1FZR1_DBG_I2C1_STOP   DBGMCU_APB1FZR1_DBG_I2C1_STOP_Msk
#define DBGMCU_APB1FZR1_DBG_I2C2_STOP_Pos   (22U)
#define DBGMCU_APB1FZR1_DBG_I2C2_STOP_Msk   (0x1UL << DBGMCU_APB1FZR1_DBG_I2C2_STOP_Pos)
#define DBGMCU_APB1FZR1_DBG_I2C2_STOP   DBGMCU_APB1FZR1_DBG_I2C2_STOP_Msk
#define DBGMCU_APB1FZR2_DBG_I2C4_STOP_Pos   (1U)
#define DBGMCU_APB1FZR2_DBG_I2C4_STOP_Msk   (0x1UL << DBGMCU_APB1FZR2_DBG_I2C4_STOP_Pos)
#define DBGMCU_APB1FZR2_DBG_I2C4_STOP   DBGMCU_APB1FZR2_DBG_I2C4_STOP_Msk
#define DBGMCU_APB1FZR2_DBG_LPTIM2_STOP_Pos   (5U)
#define DBGMCU_APB1FZR2_DBG_LPTIM2_STOP_Msk   (0x1UL << DBGMCU_APB1FZR2_DBG_LPTIM2_STOP_Pos)
#define DBGMCU_APB1FZR2_DBG_LPTIM2_STOP   DBGMCU_APB1FZR2_DBG_LPTIM2_STOP_Msk
#define DBGMCU_APB1FZR2_DBG_I2C5_STOP_Pos   (6U)
#define DBGMCU_APB1FZR2_DBG_I2C5_STOP_Msk   (0x1UL << DBGMCU_APB1FZR2_DBG_I2C5_STOP_Pos)
#define DBGMCU_APB1FZR2_DBG_I2C5_STOP   DBGMCU_APB1FZR2_DBG_I2C5_STOP_Msk
#define DBGMCU_APB1FZR2_DBG_I2C6_STOP_Pos   (7U)
#define DBGMCU_APB1FZR2_DBG_I2C6_STOP_Msk   (0x1UL << DBGMCU_APB1FZR2_DBG_I2C6_STOP_Pos)
#define DBGMCU_APB1FZR2_DBG_I2C6_STOP   DBGMCU_APB1FZR2_DBG_I2C6_STOP_Msk
#define DBGMCU_APB2FZR_DBG_TIM1_STOP_Pos   (11U)
#define DBGMCU_APB2FZR_DBG_TIM1_STOP_Msk   (0x1UL << DBGMCU_APB2FZR_DBG_TIM1_STOP_Pos)
#define DBGMCU_APB2FZR_DBG_TIM1_STOP   DBGMCU_APB2FZR_DBG_TIM1_STOP_Msk
#define DBGMCU_APB2FZR_DBG_TIM8_STOP_Pos   (13U)
#define DBGMCU_APB2FZR_DBG_TIM8_STOP_Msk   (0x1UL << DBGMCU_APB2FZR_DBG_TIM8_STOP_Pos)
#define DBGMCU_APB2FZR_DBG_TIM8_STOP   DBGMCU_APB2FZR_DBG_TIM8_STOP_Msk
#define DBGMCU_APB2FZR_DBG_TIM15_STOP_Pos   (16U)
#define DBGMCU_APB2FZR_DBG_TIM15_STOP_Msk   (0x1UL << DBGMCU_APB2FZR_DBG_TIM15_STOP_Pos)
#define DBGMCU_APB2FZR_DBG_TIM15_STOP   DBGMCU_APB2FZR_DBG_TIM15_STOP_Msk
#define DBGMCU_APB2FZR_DBG_TIM16_STOP_Pos   (17U)
#define DBGMCU_APB2FZR_DBG_TIM16_STOP_Msk   (0x1UL << DBGMCU_APB2FZR_DBG_TIM16_STOP_Pos)
#define DBGMCU_APB2FZR_DBG_TIM16_STOP   DBGMCU_APB2FZR_DBG_TIM16_STOP_Msk
#define DBGMCU_APB2FZR_DBG_TIM17_STOP_Pos   (18U)
#define DBGMCU_APB2FZR_DBG_TIM17_STOP_Msk   (0x1UL << DBGMCU_APB2FZR_DBG_TIM17_STOP_Pos)
#define DBGMCU_APB2FZR_DBG_TIM17_STOP   DBGMCU_APB2FZR_DBG_TIM17_STOP_Msk
#define DBGMCU_APB3FZR_DBG_I2C3_STOP_Pos   (10U)
#define DBGMCU_APB3FZR_DBG_I2C3_STOP_Msk   (0x1UL << DBGMCU_APB3FZR_DBG_I2C3_STOP_Pos)
#define DBGMCU_APB3FZR_DBG_I2C3_STOP   DBGMCU_APB3FZR_DBG_I2C3_STOP_Msk
#define DBGMCU_APB3FZR_DBG_LPTIM1_STOP_Pos   (17U)
#define DBGMCU_APB3FZR_DBG_LPTIM1_STOP_Msk   (0x1UL << DBGMCU_APB3FZR_DBG_LPTIM1_STOP_Pos)
#define DBGMCU_APB3FZR_DBG_LPTIM1_STOP   DBGMCU_APB3FZR_DBG_LPTIM1_STOP_Msk
#define DBGMCU_APB3FZR_DBG_LPTIM3_STOP_Pos   (18U)
#define DBGMCU_APB3FZR_DBG_LPTIM3_STOP_Msk   (0x1UL << DBGMCU_APB3FZR_DBG_LPTIM3_STOP_Pos)
#define DBGMCU_APB3FZR_DBG_LPTIM3_STOP   DBGMCU_APB3FZR_DBG_LPTIM3_STOP_Msk
#define DBGMCU_APB3FZR_DBG_LPTIM4_STOP_Pos   (19U)
#define DBGMCU_APB3FZR_DBG_LPTIM4_STOP_Msk   (0x1UL << DBGMCU_APB3FZR_DBG_LPTIM4_STOP_Pos)
#define DBGMCU_APB3FZR_DBG_LPTIM4_STOP   DBGMCU_APB3FZR_DBG_LPTIM4_STOP_Msk
#define DBGMCU_APB3FZR_DBG_RTC_STOP_Pos   (30U)
#define DBGMCU_APB3FZR_DBG_RTC_STOP_Msk   (0x1UL << DBGMCU_APB3FZR_DBG_RTC_STOP_Pos)
#define DBGMCU_APB3FZR_DBG_RTC_STOP   DBGMCU_APB3FZR_DBG_RTC_STOP_Msk
#define DBGMCU_AHB1FZR_DBG_GPDMA0_STOP_Pos   (0U)
#define DBGMCU_AHB1FZR_DBG_GPDMA0_STOP_Msk   (0x1UL << DBGMCU_AHB1FZR_DBG_GPDMA0_STOP_Pos)
#define DBGMCU_AHB1FZR_DBG_GPDMA0_STOP   DBGMCU_AHB1FZR_DBG_GPDMA0_STOP_Msk
#define DBGMCU_AHB1FZR_DBG_GPDMA1_STOP_Pos   (1U)
#define DBGMCU_AHB1FZR_DBG_GPDMA1_STOP_Msk   (0x1UL << DBGMCU_AHB1FZR_DBG_GPDMA1_STOP_Pos)
#define DBGMCU_AHB1FZR_DBG_GPDMA1_STOP   DBGMCU_AHB1FZR_DBG_GPDMA1_STOP_Msk
#define DBGMCU_AHB1FZR_DBG_GPDMA2_STOP_Pos   (2U)
#define DBGMCU_AHB1FZR_DBG_GPDMA2_STOP_Msk   (0x1UL << DBGMCU_AHB1FZR_DBG_GPDMA2_STOP_Pos)
#define DBGMCU_AHB1FZR_DBG_GPDMA2_STOP   DBGMCU_AHB1FZR_DBG_GPDMA2_STOP_Msk
#define DBGMCU_AHB1FZR_DBG_GPDMA3_STOP_Pos   (3U)
#define DBGMCU_AHB1FZR_DBG_GPDMA3_STOP_Msk   (0x1UL << DBGMCU_AHB1FZR_DBG_GPDMA3_STOP_Pos)
#define DBGMCU_AHB1FZR_DBG_GPDMA3_STOP   DBGMCU_AHB1FZR_DBG_GPDMA3_STOP_Msk
#define DBGMCU_AHB1FZR_DBG_GPDMA4_STOP_Pos   (4U)
#define DBGMCU_AHB1FZR_DBG_GPDMA4_STOP_Msk   (0x1UL << DBGMCU_AHB1FZR_DBG_GPDMA4_STOP_Pos)
#define DBGMCU_AHB1FZR_DBG_GPDMA4_STOP   DBGMCU_AHB1FZR_DBG_GPDMA4_STOP_Msk
#define DBGMCU_AHB1FZR_DBG_GPDMA5_STOP_Pos   (5U)
#define DBGMCU_AHB1FZR_DBG_GPDMA5_STOP_Msk   (0x1UL << DBGMCU_AHB1FZR_DBG_GPDMA5_STOP_Pos)
#define DBGMCU_AHB1FZR_DBG_GPDMA5_STOP   DBGMCU_AHB1FZR_DBG_GPDMA5_STOP_Msk
#define DBGMCU_AHB1FZR_DBG_GPDMA6_STOP_Pos   (6U)
#define DBGMCU_AHB1FZR_DBG_GPDMA6_STOP_Msk   (0x1UL << DBGMCU_AHB1FZR_DBG_GPDMA6_STOP_Pos)
#define DBGMCU_AHB1FZR_DBG_GPDMA6_STOP   DBGMCU_AHB1FZR_DBG_GPDMA6_STOP_Msk
#define DBGMCU_AHB1FZR_DBG_GPDMA7_STOP_Pos   (7U)
#define DBGMCU_AHB1FZR_DBG_GPDMA7_STOP_Msk   (0x1UL << DBGMCU_AHB1FZR_DBG_GPDMA7_STOP_Pos)
#define DBGMCU_AHB1FZR_DBG_GPDMA7_STOP   DBGMCU_AHB1FZR_DBG_GPDMA7_STOP_Msk
#define DBGMCU_AHB1FZR_DBG_GPDMA8_STOP_Pos   (8U)
#define DBGMCU_AHB1FZR_DBG_GPDMA8_STOP_Msk   (0x1UL << DBGMCU_AHB1FZR_DBG_GPDMA8_STOP_Pos)
#define DBGMCU_AHB1FZR_DBG_GPDMA8_STOP   DBGMCU_AHB1FZR_DBG_GPDMA8_STOP_Msk
#define DBGMCU_AHB1FZR_DBG_GPDMA9_STOP_Pos   (9U)
#define DBGMCU_AHB1FZR_DBG_GPDMA9_STOP_Msk   (0x1UL << DBGMCU_AHB1FZR_DBG_GPDMA9_STOP_Pos)
#define DBGMCU_AHB1FZR_DBG_GPDMA9_STOP   DBGMCU_AHB1FZR_DBG_GPDMA9_STOP_Msk
#define DBGMCU_AHB1FZR_DBG_GPDMA10_STOP_Pos   (10U)
#define DBGMCU_AHB1FZR_DBG_GPDMA10_STOP_Msk   (0x1UL << DBGMCU_AHB1FZR_DBG_GPDMA10_STOP_Pos)
#define DBGMCU_AHB1FZR_DBG_GPDMA10_STOP   DBGMCU_AHB1FZR_DBG_GPDMA10_STOP_Msk
#define DBGMCU_AHB1FZR_DBG_GPDMA11_STOP_Pos   (11U)
#define DBGMCU_AHB1FZR_DBG_GPDMA11_STOP_Msk   (0x1UL << DBGMCU_AHB1FZR_DBG_GPDMA11_STOP_Pos)
#define DBGMCU_AHB1FZR_DBG_GPDMA11_STOP   DBGMCU_AHB1FZR_DBG_GPDMA11_STOP_Msk
#define DBGMCU_AHB1FZR_DBG_GPDMA12_STOP_Pos   (12U)
#define DBGMCU_AHB1FZR_DBG_GPDMA12_STOP_Msk   (0x1UL << DBGMCU_AHB1FZR_DBG_GPDMA12_STOP_Pos)
#define DBGMCU_AHB1FZR_DBG_GPDMA12_STOP   DBGMCU_AHB1FZR_DBG_GPDMA12_STOP_Msk
#define DBGMCU_AHB1FZR_DBG_GPDMA13_STOP_Pos   (13U)
#define DBGMCU_AHB1FZR_DBG_GPDMA13_STOP_Msk   (0x1UL << DBGMCU_AHB1FZR_DBG_GPDMA13_STOP_Pos)
#define DBGMCU_AHB1FZR_DBG_GPDMA13_STOP   DBGMCU_AHB1FZR_DBG_GPDMA13_STOP_Msk
#define DBGMCU_AHB1FZR_DBG_GPDMA14_STOP_Pos   (14U)
#define DBGMCU_AHB1FZR_DBG_GPDMA14_STOP_Msk   (0x1UL << DBGMCU_AHB1FZR_DBG_GPDMA14_STOP_Pos)
#define DBGMCU_AHB1FZR_DBG_GPDMA14_STOP   DBGMCU_AHB1FZR_DBG_GPDMA14_STOP_Msk
#define DBGMCU_AHB1FZR_DBG_GPDMA15_STOP_Pos   (15U)
#define DBGMCU_AHB1FZR_DBG_GPDMA15_STOP_Msk   (0x1UL << DBGMCU_AHB1FZR_DBG_GPDMA15_STOP_Pos)
#define DBGMCU_AHB1FZR_DBG_GPDMA15_STOP   DBGMCU_AHB1FZR_DBG_GPDMA15_STOP_Msk
#define DBGMCU_AHB3FZR_DBG_LPDMA0_STOP_Pos   (0U)
#define DBGMCU_AHB3FZR_DBG_LPDMA0_STOP_Msk   (0x1UL << DBGMCU_AHB3FZR_DBG_LPDMA0_STOP_Pos)
#define DBGMCU_AHB3FZR_DBG_LPDMA0_STOP   DBGMCU_AHB3FZR_DBG_LPDMA0_STOP_Msk
#define DBGMCU_AHB3FZR_DBG_LPDMA1_STOP_Pos   (1U)
#define DBGMCU_AHB3FZR_DBG_LPDMA1_STOP_Msk   (0x1UL << DBGMCU_AHB3FZR_DBG_LPDMA1_STOP_Pos)
#define DBGMCU_AHB3FZR_DBG_LPDMA1_STOP   DBGMCU_AHB3FZR_DBG_LPDMA1_STOP_Msk
#define DBGMCU_AHB3FZR_DBG_LPDMA2_STOP_Pos   (2U)
#define DBGMCU_AHB3FZR_DBG_LPDMA2_STOP_Msk   (0x1UL << DBGMCU_AHB3FZR_DBG_LPDMA2_STOP_Pos)
#define DBGMCU_AHB3FZR_DBG_LPDMA2_STOP   DBGMCU_AHB3FZR_DBG_LPDMA2_STOP_Msk
#define DBGMCU_AHB3FZR_DBG_LPDMA3_STOP_Pos   (3U)
#define DBGMCU_AHB3FZR_DBG_LPDMA3_STOP_Msk   (0x1UL << DBGMCU_AHB3FZR_DBG_LPDMA3_STOP_Pos)
#define DBGMCU_AHB3FZR_DBG_LPDMA3_STOP   DBGMCU_AHB3FZR_DBG_LPDMA3_STOP_Msk
#define DCMI_CR_CAPTURE_Pos   (0U)
#define DCMI_CR_CAPTURE_Msk   (0x1UL << DCMI_CR_CAPTURE_Pos)
#define DCMI_CR_CAPTURE   DCMI_CR_CAPTURE_Msk
#define DCMI_CR_CM_Pos   (1U)
#define DCMI_CR_CM_Msk   (0x1UL << DCMI_CR_CM_Pos)
#define DCMI_CR_CM   DCMI_CR_CM_Msk
#define DCMI_CR_CROP_Pos   (2U)
#define DCMI_CR_CROP_Msk   (0x1UL << DCMI_CR_CROP_Pos)
#define DCMI_CR_CROP   DCMI_CR_CROP_Msk
#define DCMI_CR_JPEG_Pos   (3U)
#define DCMI_CR_JPEG_Msk   (0x1UL << DCMI_CR_JPEG_Pos)
#define DCMI_CR_JPEG   DCMI_CR_JPEG_Msk
#define DCMI_CR_ESS_Pos   (4U)
#define DCMI_CR_ESS_Msk   (0x1UL << DCMI_CR_ESS_Pos)
#define DCMI_CR_ESS   DCMI_CR_ESS_Msk
#define DCMI_CR_PCKPOL_Pos   (5U)
#define DCMI_CR_PCKPOL_Msk   (0x1UL << DCMI_CR_PCKPOL_Pos)
#define DCMI_CR_PCKPOL   DCMI_CR_PCKPOL_Msk
#define DCMI_CR_HSPOL_Pos   (6U)
#define DCMI_CR_HSPOL_Msk   (0x1UL << DCMI_CR_HSPOL_Pos)
#define DCMI_CR_HSPOL   DCMI_CR_HSPOL_Msk
#define DCMI_CR_VSPOL_Pos   (7U)
#define DCMI_CR_VSPOL_Msk   (0x1UL << DCMI_CR_VSPOL_Pos)
#define DCMI_CR_VSPOL   DCMI_CR_VSPOL_Msk
#define DCMI_CR_FCRC_Pos   (8U)
#define DCMI_CR_FCRC_Msk   (0x3UL << DCMI_CR_FCRC_Pos)
#define DCMI_CR_FCRC   DCMI_CR_FCRC_Msk
#define DCMI_CR_FCRC_0   (0x1UL << DCMI_CR_FCRC_Pos)
#define DCMI_CR_FCRC_1   (0x2UL << DCMI_CR_FCRC_Pos)
#define DCMI_CR_EDM_Pos   (10U)
#define DCMI_CR_EDM_Msk   (0x3UL << DCMI_CR_EDM_Pos)
#define DCMI_CR_EDM   DCMI_CR_EDM_Msk
#define DCMI_CR_EDM_0   (0x1UL << DCMI_CR_EDM_Pos)
#define DCMI_CR_EDM_1   (0x2UL << DCMI_CR_EDM_Pos)
#define DCMI_CR_ENABLE_Pos   (14U)
#define DCMI_CR_ENABLE_Msk   (0x1UL << DCMI_CR_ENABLE_Pos)
#define DCMI_CR_ENABLE   DCMI_CR_ENABLE_Msk
#define DCMI_CR_BSM_Pos   (16U)
#define DCMI_CR_BSM_Msk   (0x3UL << DCMI_CR_BSM_Pos)
#define DCMI_CR_BSM   DCMI_CR_BSM_Msk
#define DCMI_CR_BSM_0   (0x1UL << DCMI_CR_BSM_Pos)
#define DCMI_CR_BSM_1   (0x2UL << DCMI_CR_BSM_Pos)
#define DCMI_CR_OEBS_Pos   (18U)
#define DCMI_CR_OEBS_Msk   (0x1UL << DCMI_CR_OEBS_Pos)
#define DCMI_CR_OEBS   DCMI_CR_OEBS_Msk
#define DCMI_CR_LSM_Pos   (19U)
#define DCMI_CR_LSM_Msk   (0x1UL << DCMI_CR_LSM_Pos)
#define DCMI_CR_LSM   DCMI_CR_LSM_Msk
#define DCMI_CR_OELS_Pos   (20U)
#define DCMI_CR_OELS_Msk   (0x1UL << DCMI_CR_OELS_Pos)
#define DCMI_CR_OELS   DCMI_CR_OELS_Msk
#define DCMI_CR_PSDM_Pos   (31U)
#define DCMI_CR_PSDM_Msk   (0x0UL << DCMI_CR_PSDM_Pos)
#define DCMI_CR_PSDM   DCMI_CR_PSDM_Msk /*PSDM: Parallel Synchronous raw Data Mode (PSDM = 0)*/
#define DCMI_SR_HSYNC_Pos   (0U)
#define DCMI_SR_HSYNC_Msk   (0x1UL << DCMI_SR_HSYNC_Pos)
#define DCMI_SR_HSYNC   DCMI_SR_HSYNC_Msk
#define DCMI_SR_VSYNC_Pos   (1U)
#define DCMI_SR_VSYNC_Msk   (0x1UL << DCMI_SR_VSYNC_Pos)
#define DCMI_SR_VSYNC   DCMI_SR_VSYNC_Msk
#define DCMI_SR_FNE_Pos   (2U)
#define DCMI_SR_FNE_Msk   (0x1UL << DCMI_SR_FNE_Pos)
#define DCMI_SR_FNE   DCMI_SR_FNE_Msk
#define DCMI_RIS_FRAME_RIS_Pos   (0U)
#define DCMI_RIS_FRAME_RIS_Msk   (0x1UL << DCMI_RIS_FRAME_RIS_Pos)
#define DCMI_RIS_FRAME_RIS   DCMI_RIS_FRAME_RIS_Msk
#define DCMI_RIS_OVR_RIS_Pos   (1U)
#define DCMI_RIS_OVR_RIS_Msk   (0x1UL << DCMI_RIS_OVR_RIS_Pos)
#define DCMI_RIS_OVR_RIS   DCMI_RIS_OVR_RIS_Msk
#define DCMI_RIS_ERR_RIS_Pos   (2U)
#define DCMI_RIS_ERR_RIS_Msk   (0x1UL << DCMI_RIS_ERR_RIS_Pos)
#define DCMI_RIS_ERR_RIS   DCMI_RIS_ERR_RIS_Msk
#define DCMI_RIS_VSYNC_RIS_Pos   (3U)
#define DCMI_RIS_VSYNC_RIS_Msk   (0x1UL << DCMI_RIS_VSYNC_RIS_Pos)
#define DCMI_RIS_VSYNC_RIS   DCMI_RIS_VSYNC_RIS_Msk
#define DCMI_RIS_LINE_RIS_Pos   (4U)
#define DCMI_RIS_LINE_RIS_Msk   (0x1UL << DCMI_RIS_LINE_RIS_Pos)
#define DCMI_RIS_LINE_RIS   DCMI_RIS_LINE_RIS_Msk
#define DCMI_IER_FRAME_IE_Pos   (0U)
#define DCMI_IER_FRAME_IE_Msk   (0x1UL << DCMI_IER_FRAME_IE_Pos)
#define DCMI_IER_FRAME_IE   DCMI_IER_FRAME_IE_Msk
#define DCMI_IER_OVR_IE_Pos   (1U)
#define DCMI_IER_OVR_IE_Msk   (0x1UL << DCMI_IER_OVR_IE_Pos)
#define DCMI_IER_OVR_IE   DCMI_IER_OVR_IE_Msk
#define DCMI_IER_ERR_IE_Pos   (2U)
#define DCMI_IER_ERR_IE_Msk   (0x1UL << DCMI_IER_ERR_IE_Pos)
#define DCMI_IER_ERR_IE   DCMI_IER_ERR_IE_Msk
#define DCMI_IER_VSYNC_IE_Pos   (3U)
#define DCMI_IER_VSYNC_IE_Msk   (0x1UL << DCMI_IER_VSYNC_IE_Pos)
#define DCMI_IER_VSYNC_IE   DCMI_IER_VSYNC_IE_Msk
#define DCMI_IER_LINE_IE_Pos   (4U)
#define DCMI_IER_LINE_IE_Msk   (0x1UL << DCMI_IER_LINE_IE_Pos)
#define DCMI_IER_LINE_IE   DCMI_IER_LINE_IE_Msk
#define DCMI_MIS_FRAME_MIS_Pos   (0U)
#define DCMI_MIS_FRAME_MIS_Msk   (0x1UL << DCMI_MIS_FRAME_MIS_Pos)
#define DCMI_MIS_FRAME_MIS   DCMI_MIS_FRAME_MIS_Msk
#define DCMI_MIS_OVR_MIS_Pos   (1U)
#define DCMI_MIS_OVR_MIS_Msk   (0x1UL << DCMI_MIS_OVR_MIS_Pos)
#define DCMI_MIS_OVR_MIS   DCMI_MIS_OVR_MIS_Msk
#define DCMI_MIS_ERR_MIS_Pos   (2U)
#define DCMI_MIS_ERR_MIS_Msk   (0x1UL << DCMI_MIS_ERR_MIS_Pos)
#define DCMI_MIS_ERR_MIS   DCMI_MIS_ERR_MIS_Msk
#define DCMI_MIS_VSYNC_MIS_Pos   (3U)
#define DCMI_MIS_VSYNC_MIS_Msk   (0x1UL << DCMI_MIS_VSYNC_MIS_Pos)
#define DCMI_MIS_VSYNC_MIS   DCMI_MIS_VSYNC_MIS_Msk
#define DCMI_MIS_LINE_MIS_Pos   (4U)
#define DCMI_MIS_LINE_MIS_Msk   (0x1UL << DCMI_MIS_LINE_MIS_Pos)
#define DCMI_MIS_LINE_MIS   DCMI_MIS_LINE_MIS_Msk
#define DCMI_ICR_FRAME_ISC_Pos   (0U)
#define DCMI_ICR_FRAME_ISC_Msk   (0x1UL << DCMI_ICR_FRAME_ISC_Pos)
#define DCMI_ICR_FRAME_ISC   DCMI_ICR_FRAME_ISC_Msk
#define DCMI_ICR_OVR_ISC_Pos   (1U)
#define DCMI_ICR_OVR_ISC_Msk   (0x1UL << DCMI_ICR_OVR_ISC_Pos)
#define DCMI_ICR_OVR_ISC   DCMI_ICR_OVR_ISC_Msk
#define DCMI_ICR_ERR_ISC_Pos   (2U)
#define DCMI_ICR_ERR_ISC_Msk   (0x1UL << DCMI_ICR_ERR_ISC_Pos)
#define DCMI_ICR_ERR_ISC   DCMI_ICR_ERR_ISC_Msk
#define DCMI_ICR_VSYNC_ISC_Pos   (3U)
#define DCMI_ICR_VSYNC_ISC_Msk   (0x1UL << DCMI_ICR_VSYNC_ISC_Pos)
#define DCMI_ICR_VSYNC_ISC   DCMI_ICR_VSYNC_ISC_Msk
#define DCMI_ICR_LINE_ISC_Pos   (4U)
#define DCMI_ICR_LINE_ISC_Msk   (0x1UL << DCMI_ICR_LINE_ISC_Pos)
#define DCMI_ICR_LINE_ISC   DCMI_ICR_LINE_ISC_Msk
#define DCMI_ESCR_FSC_Pos   (0U)
#define DCMI_ESCR_FSC_Msk   (0xFFUL << DCMI_ESCR_FSC_Pos)
#define DCMI_ESCR_FSC   DCMI_ESCR_FSC_Msk
#define DCMI_ESCR_LSC_Pos   (8U)
#define DCMI_ESCR_LSC_Msk   (0xFFUL << DCMI_ESCR_LSC_Pos)
#define DCMI_ESCR_LSC   DCMI_ESCR_LSC_Msk
#define DCMI_ESCR_LEC_Pos   (16U)
#define DCMI_ESCR_LEC_Msk   (0xFFUL << DCMI_ESCR_LEC_Pos)
#define DCMI_ESCR_LEC   DCMI_ESCR_LEC_Msk
#define DCMI_ESCR_FEC_Pos   (24U)
#define DCMI_ESCR_FEC_Msk   (0xFFUL << DCMI_ESCR_FEC_Pos)
#define DCMI_ESCR_FEC   DCMI_ESCR_FEC_Msk
#define DCMI_ESUR_FSU_Pos   (0U)
#define DCMI_ESUR_FSU_Msk   (0xFFUL << DCMI_ESUR_FSU_Pos)
#define DCMI_ESUR_FSU   DCMI_ESUR_FSU_Msk
#define DCMI_ESUR_LSU_Pos   (8U)
#define DCMI_ESUR_LSU_Msk   (0xFFUL << DCMI_ESUR_LSU_Pos)
#define DCMI_ESUR_LSU   DCMI_ESUR_LSU_Msk
#define DCMI_ESUR_LEU_Pos   (16U)
#define DCMI_ESUR_LEU_Msk   (0xFFUL << DCMI_ESUR_LEU_Pos)
#define DCMI_ESUR_LEU   DCMI_ESUR_LEU_Msk
#define DCMI_ESUR_FEU_Pos   (24U)
#define DCMI_ESUR_FEU_Msk   (0xFFUL << DCMI_ESUR_FEU_Pos)
#define DCMI_ESUR_FEU   DCMI_ESUR_FEU_Msk
#define DCMI_CWSTRT_HOFFCNT_Pos   (0U)
#define DCMI_CWSTRT_HOFFCNT_Msk   (0x3FFFUL << DCMI_CWSTRT_HOFFCNT_Pos)
#define DCMI_CWSTRT_HOFFCNT   DCMI_CWSTRT_HOFFCNT_Msk
#define DCMI_CWSTRT_VST_Pos   (16U)
#define DCMI_CWSTRT_VST_Msk   (0x1FFFUL << DCMI_CWSTRT_VST_Pos)
#define DCMI_CWSTRT_VST   DCMI_CWSTRT_VST_Msk
#define DCMI_CWSIZE_CAPCNT_Pos   (0U)
#define DCMI_CWSIZE_CAPCNT_Msk   (0x3FFFUL << DCMI_CWSIZE_CAPCNT_Pos)
#define DCMI_CWSIZE_CAPCNT   DCMI_CWSIZE_CAPCNT_Msk
#define DCMI_CWSIZE_VLINE_Pos   (16U)
#define DCMI_CWSIZE_VLINE_Msk   (0x3FFFUL << DCMI_CWSIZE_VLINE_Pos)
#define DCMI_CWSIZE_VLINE   DCMI_CWSIZE_VLINE_Msk
#define DCMI_DR_BYTE0_Pos   (0U)
#define DCMI_DR_BYTE0_Msk   (0xFFUL << DCMI_DR_BYTE0_Pos)
#define DCMI_DR_BYTE0   DCMI_DR_BYTE0_Msk
#define DCMI_DR_BYTE1_Pos   (8U)
#define DCMI_DR_BYTE1_Msk   (0xFFUL << DCMI_DR_BYTE1_Pos)
#define DCMI_DR_BYTE1   DCMI_DR_BYTE1_Msk
#define DCMI_DR_BYTE2_Pos   (16U)
#define DCMI_DR_BYTE2_Msk   (0xFFUL << DCMI_DR_BYTE2_Pos)
#define DCMI_DR_BYTE2   DCMI_DR_BYTE2_Msk
#define DCMI_DR_BYTE3_Pos   (24U)
#define DCMI_DR_BYTE3_Msk   (0xFFUL << DCMI_DR_BYTE3_Pos)
#define DCMI_DR_BYTE3   DCMI_DR_BYTE3_Msk
#define TIM3_TRGO_TRIGGER_SUPPORT   /* TIM3 TRGO HW signal support */
#define TIM4_TRGO_TRIGGER_SUPPORT   /* TIM4 TRGO HW signal support */
#define TIM5_TRGO_TRIGGER_SUPPORT   /* TIM5 TRGO HW signal support */
#define DMA2D_TRIGGER_SUPPORT   /* DMA2D TRGO HW signal support */
#define DMA_SECCFGR_SEC0_Pos   (0U)
#define DMA_SECCFGR_SEC0_Msk   (0x1UL << DMA_SECCFGR_SEC0_Pos)
#define DMA_SECCFGR_SEC0   DMA_SECCFGR_SEC0_Msk
#define DMA_SECCFGR_SEC1_Pos   (1U)
#define DMA_SECCFGR_SEC1_Msk   (0x1UL << DMA_SECCFGR_SEC1_Pos)
#define DMA_SECCFGR_SEC1   DMA_SECCFGR_SEC1_Msk
#define DMA_SECCFGR_SEC2_Pos   (2U)
#define DMA_SECCFGR_SEC2_Msk   (0x1UL << DMA_SECCFGR_SEC2_Pos)
#define DMA_SECCFGR_SEC2   DMA_SECCFGR_SEC2_Msk
#define DMA_SECCFGR_SEC3_Pos   (3U)
#define DMA_SECCFGR_SEC3_Msk   (0x1UL << DMA_SECCFGR_SEC3_Pos)
#define DMA_SECCFGR_SEC3   DMA_SECCFGR_SEC3_Msk
#define DMA_SECCFGR_SEC4_Pos   (4U)
#define DMA_SECCFGR_SEC4_Msk   (0x1UL << DMA_SECCFGR_SEC4_Pos)
#define DMA_SECCFGR_SEC4   DMA_SECCFGR_SEC4_Msk
#define DMA_SECCFGR_SEC5_Pos   (5U)
#define DMA_SECCFGR_SEC5_Msk   (0x1UL << DMA_SECCFGR_SEC5_Pos)
#define DMA_SECCFGR_SEC5   DMA_SECCFGR_SEC5_Msk
#define DMA_SECCFGR_SEC6_Pos   (6U)
#define DMA_SECCFGR_SEC6_Msk   (0x1UL << DMA_SECCFGR_SEC6_Pos)
#define DMA_SECCFGR_SEC6   DMA_SECCFGR_SEC6_Msk
#define DMA_SECCFGR_SEC7_Pos   (7U)
#define DMA_SECCFGR_SEC7_Msk   (0x1UL << DMA_SECCFGR_SEC7_Pos)
#define DMA_SECCFGR_SEC7   DMA_SECCFGR_SEC7_Msk
#define DMA_SECCFGR_SEC8_Pos   (8U)
#define DMA_SECCFGR_SEC8_Msk   (0x1UL << DMA_SECCFGR_SEC8_Pos)
#define DMA_SECCFGR_SEC8   DMA_SECCFGR_SEC8_Msk
#define DMA_SECCFGR_SEC9_Pos   (9U)
#define DMA_SECCFGR_SEC9_Msk   (0x1UL << DMA_SECCFGR_SEC9_Pos)
#define DMA_SECCFGR_SEC9   DMA_SECCFGR_SEC9_Msk
#define DMA_SECCFGR_SEC10_Pos   (10U)
#define DMA_SECCFGR_SEC10_Msk   (0x1UL << DMA_SECCFGR_SEC10_Pos)
#define DMA_SECCFGR_SEC10   DMA_SECCFGR_SEC10_Msk
#define DMA_SECCFGR_SEC11_Pos   (11U)
#define DMA_SECCFGR_SEC11_Msk   (0x1UL << DMA_SECCFGR_SEC11_Pos)
#define DMA_SECCFGR_SEC11   DMA_SECCFGR_SEC11_Msk
#define DMA_SECCFGR_SEC12_Pos   (12U)
#define DMA_SECCFGR_SEC12_Msk   (0x1UL << DMA_SECCFGR_SEC12_Pos)
#define DMA_SECCFGR_SEC12   DMA_SECCFGR_SEC12_Msk
#define DMA_SECCFGR_SEC13_Pos   (13U)
#define DMA_SECCFGR_SEC13_Msk   (0x1UL << DMA_SECCFGR_SEC13_Pos)
#define DMA_SECCFGR_SEC13   DMA_SECCFGR_SEC13_Msk
#define DMA_SECCFGR_SEC14_Pos   (14U)
#define DMA_SECCFGR_SEC14_Msk   (0x1UL << DMA_SECCFGR_SEC14_Pos)
#define DMA_SECCFGR_SEC14   DMA_SECCFGR_SEC14_Msk
#define DMA_SECCFGR_SEC15_Pos   (15U)
#define DMA_SECCFGR_SEC15_Msk   (0x1UL << DMA_SECCFGR_SEC15_Pos)
#define DMA_SECCFGR_SEC15   DMA_SECCFGR_SEC15_Msk
#define DMA_PRIVCFGR_PRIV0_Pos   (0U)
#define DMA_PRIVCFGR_PRIV0_Msk   (0x1UL << DMA_PRIVCFGR_PRIV0_Pos)
#define DMA_PRIVCFGR_PRIV0   DMA_PRIVCFGR_PRIV0_Msk
#define DMA_PRIVCFGR_PRIV1_Pos   (1U)
#define DMA_PRIVCFGR_PRIV1_Msk   (0x1UL << DMA_PRIVCFGR_PRIV1_Pos)
#define DMA_PRIVCFGR_PRIV1   DMA_PRIVCFGR_PRIV1_Msk
#define DMA_PRIVCFGR_PRIV2_Pos   (2U)
#define DMA_PRIVCFGR_PRIV2_Msk   (0x1UL << DMA_PRIVCFGR_PRIV2_Pos)
#define DMA_PRIVCFGR_PRIV2   DMA_PRIVCFGR_PRIV2_Msk
#define DMA_PRIVCFGR_PRIV3_Pos   (3U)
#define DMA_PRIVCFGR_PRIV3_Msk   (0x1UL << DMA_PRIVCFGR_PRIV3_Pos)
#define DMA_PRIVCFGR_PRIV3   DMA_PRIVCFGR_PRIV3_Msk
#define DMA_PRIVCFGR_PRIV4_Pos   (4U)
#define DMA_PRIVCFGR_PRIV4_Msk   (0x1UL << DMA_PRIVCFGR_PRIV4_Pos)
#define DMA_PRIVCFGR_PRIV4   DMA_PRIVCFGR_PRIV4_Msk
#define DMA_PRIVCFGR_PRIV5_Pos   (5U)
#define DMA_PRIVCFGR_PRIV5_Msk   (0x1UL << DMA_PRIVCFGR_PRIV5_Pos)
#define DMA_PRIVCFGR_PRIV5   DMA_PRIVCFGR_PRIV5_Msk
#define DMA_PRIVCFGR_PRIV6_Pos   (6U)
#define DMA_PRIVCFGR_PRIV6_Msk   (0x1UL << DMA_PRIVCFGR_PRIV6_Pos)
#define DMA_PRIVCFGR_PRIV6   DMA_PRIVCFGR_PRIV6_Msk
#define DMA_PRIVCFGR_PRIV7_Pos   (7U)
#define DMA_PRIVCFGR_PRIV7_Msk   (0x1UL << DMA_PRIVCFGR_PRIV7_Pos)
#define DMA_PRIVCFGR_PRIV7   DMA_PRIVCFGR_PRIV7_Msk
#define DMA_PRIVCFGR_PRIV8_Pos   (8U)
#define DMA_PRIVCFGR_PRIV8_Msk   (0x1UL << DMA_PRIVCFGR_PRIV8_Pos)
#define DMA_PRIVCFGR_PRIV8   DMA_PRIVCFGR_PRIV8_Msk
#define DMA_PRIVCFGR_PRIV9_Pos   (9U)
#define DMA_PRIVCFGR_PRIV9_Msk   (0x1UL << DMA_PRIVCFGR_PRIV9_Pos)
#define DMA_PRIVCFGR_PRIV9   DMA_PRIVCFGR_PRIV9_Msk
#define DMA_PRIVCFGR_PRIV10_Pos   (10U)
#define DMA_PRIVCFGR_PRIV10_Msk   (0x1UL << DMA_PRIVCFGR_PRIV10_Pos)
#define DMA_PRIVCFGR_PRIV10   DMA_PRIVCFGR_PRIV10_Msk
#define DMA_PRIVCFGR_PRIV11_Pos   (11U)
#define DMA_PRIVCFGR_PRIV11_Msk   (0x1UL << DMA_PRIVCFGR_PRIV11_Pos)
#define DMA_PRIVCFGR_PRIV11   DMA_PRIVCFGR_PRIV11_Msk
#define DMA_PRIVCFGR_PRIV12_Pos   (12U)
#define DMA_PRIVCFGR_PRIV12_Msk   (0x1UL << DMA_PRIVCFGR_PRIV12_Pos)
#define DMA_PRIVCFGR_PRIV12   DMA_PRIVCFGR_PRIV12_Msk
#define DMA_PRIVCFGR_PRIV13_Pos   (13U)
#define DMA_PRIVCFGR_PRIV13_Msk   (0x1UL << DMA_PRIVCFGR_PRIV13_Pos)
#define DMA_PRIVCFGR_PRIV13   DMA_PRIVCFGR_PRIV13_Msk
#define DMA_PRIVCFGR_PRIV14_Pos   (14U)
#define DMA_PRIVCFGR_PRIV14_Msk   (0x1UL << DMA_PRIVCFGR_PRIV14_Pos)
#define DMA_PRIVCFGR_PRIV14   DMA_PRIVCFGR_PRIV14_Msk
#define DMA_PRIVCFGR_PRIV15_Pos   (15U)
#define DMA_PRIVCFGR_PRIV15_Msk   (0x1UL << DMA_PRIVCFGR_PRIV15_Pos)
#define DMA_PRIVCFGR_PRIV15   DMA_PRIVCFGR_PRIV15_Msk
#define DMA_RCFGLOCKR_LOCK0_Pos   (0U)
#define DMA_RCFGLOCKR_LOCK0_Msk   (0x1UL << DMA_RCFGLOCKR_LOCK0_Pos)
#define DMA_RCFGLOCKR_LOCK0   DMA_RCFGLOCKR_LOCK0_Msk
#define DMA_RCFGLOCKR_LOCK1_Pos   (1U)
#define DMA_RCFGLOCKR_LOCK1_Msk   (0x1UL << DMA_RCFGLOCKR_LOCK1_Pos)
#define DMA_RCFGLOCKR_LOCK1   DMA_RCFGLOCKR_LOCK1_Msk
#define DMA_RCFGLOCKR_LOCK2_Pos   (2U)
#define DMA_RCFGLOCKR_LOCK2_Msk   (0x1UL << DMA_RCFGLOCKR_LOCK2_Pos)
#define DMA_RCFGLOCKR_LOCK2   DMA_RCFGLOCKR_LOCK2_Msk
#define DMA_RCFGLOCKR_LOCK3_Pos   (3U)
#define DMA_RCFGLOCKR_LOCK3_Msk   (0x1UL << DMA_RCFGLOCKR_LOCK3_Pos)
#define DMA_RCFGLOCKR_LOCK3   DMA_RCFGLOCKR_LOCK3_Msk
#define DMA_RCFGLOCKR_LOCK4_Pos   (4U)
#define DMA_RCFGLOCKR_LOCK4_Msk   (0x1UL << DMA_RCFGLOCKR_LOCK4_Pos)
#define DMA_RCFGLOCKR_LOCK4   DMA_RCFGLOCKR_LOCK4_Msk
#define DMA_RCFGLOCKR_LOCK5_Pos   (5U)
#define DMA_RCFGLOCKR_LOCK5_Msk   (0x1UL << DMA_RCFGLOCKR_LOCK5_Pos)
#define DMA_RCFGLOCKR_LOCK5   DMA_RCFGLOCKR_LOCK5_Msk
#define DMA_RCFGLOCKR_LOCK6_Pos   (6U)
#define DMA_RCFGLOCKR_LOCK6_Msk   (0x1UL << DMA_RCFGLOCKR_LOCK6_Pos)
#define DMA_RCFGLOCKR_LOCK6   DMA_RCFGLOCKR_LOCK6_Msk
#define DMA_RCFGLOCKR_LOCK7_Pos   (7U)
#define DMA_RCFGLOCKR_LOCK7_Msk   (0x1UL << DMA_RCFGLOCKR_LOCK7_Pos)
#define DMA_RCFGLOCKR_LOCK7   DMA_RCFGLOCKR_LOCK7_Msk
#define DMA_RCFGLOCKR_LOCK8_Pos   (8U)
#define DMA_RCFGLOCKR_LOCK8_Msk   (0x1UL << DMA_RCFGLOCKR_LOCK8_Pos)
#define DMA_RCFGLOCKR_LOCK8   DMA_RCFGLOCKR_LOCK8_Msk
#define DMA_RCFGLOCKR_LOCK9_Pos   (9U)
#define DMA_RCFGLOCKR_LOCK9_Msk   (0x1UL << DMA_RCFGLOCKR_LOCK9_Pos)
#define DMA_RCFGLOCKR_LOCK9   DMA_RCFGLOCKR_LOCK9_Msk
#define DMA_RCFGLOCKR_LOCK10_Pos   (10U)
#define DMA_RCFGLOCKR_LOCK10_Msk   (0x1UL << DMA_RCFGLOCKR_LOCK10_Pos)
#define DMA_RCFGLOCKR_LOCK10   DMA_RCFGLOCKR_LOCK10_Msk
#define DMA_RCFGLOCKR_LOCK11_Pos   (11U)
#define DMA_RCFGLOCKR_LOCK11_Msk   (0x1UL << DMA_RCFGLOCKR_LOCK11_Pos)
#define DMA_RCFGLOCKR_LOCK11   DMA_RCFGLOCKR_LOCK11_Msk
#define DMA_RCFGLOCKR_LOCK12_Pos   (12U)
#define DMA_RCFGLOCKR_LOCK12_Msk   (0x1UL << DMA_RCFGLOCKR_LOCK12_Pos)
#define DMA_RCFGLOCKR_LOCK12   DMA_RCFGLOCKR_LOCK12_Msk
#define DMA_RCFGLOCKR_LOCK13_Pos   (13U)
#define DMA_RCFGLOCKR_LOCK13_Msk   (0x1UL << DMA_RCFGLOCKR_LOCK13_Pos)
#define DMA_RCFGLOCKR_LOCK13   DMA_RCFGLOCKR_LOCK13_Msk
#define DMA_RCFGLOCKR_LOCK14_Pos   (14U)
#define DMA_RCFGLOCKR_LOCK14_Msk   (0x1UL << DMA_RCFGLOCKR_LOCK14_Pos)
#define DMA_RCFGLOCKR_LOCK14   DMA_RCFGLOCKR_LOCK14_Msk
#define DMA_RCFGLOCKR_LOCK15_Pos   (15U)
#define DMA_RCFGLOCKR_LOCK15_Msk   (0x1UL << DMA_RCFGLOCKR_LOCK15_Pos)
#define DMA_RCFGLOCKR_LOCK15   DMA_RCFGLOCKR_LOCK15_Msk
#define DMA_MISR_MIS0_Pos   (0U)
#define DMA_MISR_MIS0_Msk   (0x1UL << DMA_MISR_MIS0_Pos)
#define DMA_MISR_MIS0   DMA_MISR_MIS0_Msk
#define DMA_MISR_MIS1_Pos   (1U)
#define DMA_MISR_MIS1_Msk   (0x1UL << DMA_MISR_MIS1_Pos)
#define DMA_MISR_MIS1   DMA_MISR_MIS1_Msk
#define DMA_MISR_MIS2_Pos   (2U)
#define DMA_MISR_MIS2_Msk   (0x1UL << DMA_MISR_MIS2_Pos)
#define DMA_MISR_MIS2   DMA_MISR_MIS2_Msk
#define DMA_MISR_MIS3_Pos   (3U)
#define DMA_MISR_MIS3_Msk   (0x1UL << DMA_MISR_MIS3_Pos)
#define DMA_MISR_MIS3   DMA_MISR_MIS3_Msk
#define DMA_MISR_MIS4_Pos   (4U)
#define DMA_MISR_MIS4_Msk   (0x1UL << DMA_MISR_MIS4_Pos)
#define DMA_MISR_MIS4   DMA_MISR_MIS4_Msk
#define DMA_MISR_MIS5_Pos   (5U)
#define DMA_MISR_MIS5_Msk   (0x1UL << DMA_MISR_MIS5_Pos)
#define DMA_MISR_MIS5   DMA_MISR_MIS5_Msk
#define DMA_MISR_MIS6_Pos   (6U)
#define DMA_MISR_MIS6_Msk   (0x1UL << DMA_MISR_MIS6_Pos)
#define DMA_MISR_MIS6   DMA_MISR_MIS6_Msk
#define DMA_MISR_MIS7_Pos   (7U)
#define DMA_MISR_MIS7_Msk   (0x1UL << DMA_MISR_MIS7_Pos)
#define DMA_MISR_MIS7   DMA_MISR_MIS7_Msk
#define DMA_MISR_MIS8_Pos   (8U)
#define DMA_MISR_MIS8_Msk   (0x1UL << DMA_MISR_MIS8_Pos)
#define DMA_MISR_MIS8   DMA_MISR_MIS8_Msk
#define DMA_MISR_MIS9_Pos   (9U)
#define DMA_MISR_MIS9_Msk   (0x1UL << DMA_MISR_MIS9_Pos)
#define DMA_MISR_MIS9   DMA_MISR_MIS9_Msk
#define DMA_MISR_MIS10_Pos   (10U)
#define DMA_MISR_MIS10_Msk   (0x1UL << DMA_MISR_MIS10_Pos)
#define DMA_MISR_MIS10   DMA_MISR_MIS10_Msk
#define DMA_MISR_MIS11_Pos   (11U)
#define DMA_MISR_MIS11_Msk   (0x1UL << DMA_MISR_MIS11_Pos)
#define DMA_MISR_MIS11   DMA_MISR_MIS11_Msk
#define DMA_MISR_MIS12_Pos   (12U)
#define DMA_MISR_MIS12_Msk   (0x1UL << DMA_MISR_MIS12_Pos)
#define DMA_MISR_MIS12   DMA_MISR_MIS12_Msk
#define DMA_MISR_MIS13_Pos   (13U)
#define DMA_MISR_MIS13_Msk   (0x1UL << DMA_MISR_MIS13_Pos)
#define DMA_MISR_MIS13   DMA_MISR_MIS13_Msk
#define DMA_MISR_MIS14_Pos   (14U)
#define DMA_MISR_MIS14_Msk   (0x1UL << DMA_MISR_MIS14_Pos)
#define DMA_MISR_MIS14   DMA_MISR_MIS14_Msk
#define DMA_MISR_MIS15_Pos   (15U)
#define DMA_MISR_MIS15_Msk   (0x1UL << DMA_MISR_MIS15_Pos)
#define DMA_MISR_MIS15   DMA_MISR_MIS14_Msk
#define DMA_SMISR_MIS0_Pos   (0U)
#define DMA_SMISR_MIS0_Msk   (0x1UL << DMA_SMISR_MIS0_Pos)
#define DMA_SMISR_MIS0   DMA_SMISR_MIS0_Msk
#define DMA_SMISR_MIS1_Pos   (1U)
#define DMA_SMISR_MIS1_Msk   (0x1UL << DMA_SMISR_MIS1_Pos)
#define DMA_SMISR_MIS1   DMA_SMISR_MIS1_Msk
#define DMA_SMISR_MIS2_Pos   (2U)
#define DMA_SMISR_MIS2_Msk   (0x1UL << DMA_SMISR_MIS2_Pos)
#define DMA_SMISR_MIS2   DMA_SMISR_MIS2_Msk
#define DMA_SMISR_MIS3_Pos   (3U)
#define DMA_SMISR_MIS3_Msk   (0x1UL << DMA_SMISR_MIS3_Pos)
#define DMA_SMISR_MIS3   DMA_SMISR_MIS3_Msk
#define DMA_SMISR_MIS4_Pos   (4U)
#define DMA_SMISR_MIS4_Msk   (0x1UL << DMA_SMISR_MIS4_Pos)
#define DMA_SMISR_MIS4   DMA_SMISR_MIS4_Msk
#define DMA_SMISR_MIS5_Pos   (5U)
#define DMA_SMISR_MIS5_Msk   (0x1UL << DMA_SMISR_MIS5_Pos)
#define DMA_SMISR_MIS5   DMA_SMISR_MIS5_Msk
#define DMA_SMISR_MIS6_Pos   (6U)
#define DMA_SMISR_MIS6_Msk   (0x1UL << DMA_SMISR_MIS6_Pos)
#define DMA_SMISR_MIS6   DMA_SMISR_MIS6_Msk
#define DMA_SMISR_MIS7_Pos   (7U)
#define DMA_SMISR_MIS7_Msk   (0x1UL << DMA_SMISR_MIS7_Pos)
#define DMA_SMISR_MIS7   DMA_SMISR_MIS7_Msk
#define DMA_SMISR_MIS8_Pos   (8U)
#define DMA_SMISR_MIS8_Msk   (0x1UL << DMA_SMISR_MIS8_Pos)
#define DMA_SMISR_MIS8   DMA_SMISR_MIS8_Msk
#define DMA_SMISR_MIS9_Pos   (9U)
#define DMA_SMISR_MIS9_Msk   (0x1UL << DMA_SMISR_MIS9_Pos)
#define DMA_SMISR_MIS9   DMA_SMISR_MIS9_Msk
#define DMA_SMISR_MIS10_Pos   (10U)
#define DMA_SMISR_MIS10_Msk   (0x1UL << DMA_SMISR_MIS10_Pos)
#define DMA_SMISR_MIS10   DMA_SMISR_MIS10_Msk
#define DMA_SMISR_MIS11_Pos   (11U)
#define DMA_SMISR_MIS11_Msk   (0x1UL << DMA_SMISR_MIS11_Pos)
#define DMA_SMISR_MIS11   DMA_SMISR_MIS11_Msk
#define DMA_SMISR_MIS12_Pos   (12U)
#define DMA_SMISR_MIS12_Msk   (0x1UL << DMA_SMISR_MIS12_Pos)
#define DMA_SMISR_MIS12   DMA_SMISR_MIS12_Msk
#define DMA_SMISR_MIS13_Pos   (13U)
#define DMA_SMISR_MIS13_Msk   (0x1UL << DMA_SMISR_MIS13_Pos)
#define DMA_SMISR_MIS13   DMA_SMISR_MIS13_Msk
#define DMA_SMISR_MIS14_Pos   (14U)
#define DMA_SMISR_MIS14_Msk   (0x1UL << DMA_SMISR_MIS14_Pos)
#define DMA_SMISR_MIS14   DMA_SMISR_MIS14_Msk
#define DMA_SMISR_MIS15_Pos   (15U)
#define DMA_SMISR_MIS15_Msk   (0x1UL << DMA_SMISR_MIS15_Pos)
#define DMA_SMISR_MIS15   DMA_SMISR_MIS14_Msk
#define DMA_CLBAR_LBA_Pos   (16U)
#define DMA_CLBAR_LBA_Msk   (0xFFFFUL << DMA_CLBAR_LBA_Pos)
#define DMA_CLBAR_LBA   DMA_CLBAR_LBA_Msk
#define DMA_CFCR_TCF_Pos   (8U)
#define DMA_CFCR_TCF_Msk   (0x1UL << DMA_CFCR_TCF_Pos)
#define DMA_CFCR_TCF   DMA_CFCR_TCF_Msk
#define DMA_CFCR_HTF_Pos   (9U)
#define DMA_CFCR_HTF_Msk   (0x1UL << DMA_CFCR_HTF_Pos)
#define DMA_CFCR_HTF   DMA_CFCR_HTF_Msk
#define DMA_CFCR_DTEF_Pos   (10U)
#define DMA_CFCR_DTEF_Msk   (0x1UL << DMA_CFCR_DTEF_Pos)
#define DMA_CFCR_DTEF   DMA_CFCR_DTEF_Msk
#define DMA_CFCR_ULEF_Pos   (11U)
#define DMA_CFCR_ULEF_Msk   (0x1UL << DMA_CFCR_ULEF_Pos)
#define DMA_CFCR_ULEF   DMA_CFCR_ULEF_Msk
#define DMA_CFCR_USEF_Pos   (12U)
#define DMA_CFCR_USEF_Msk   (0x1UL << DMA_CFCR_USEF_Pos)
#define DMA_CFCR_USEF   DMA_CFCR_USEF_Msk
#define DMA_CFCR_SUSPF_Pos   (13U)
#define DMA_CFCR_SUSPF_Msk   (0x1UL << DMA_CFCR_SUSPF_Pos)
#define DMA_CFCR_SUSPF   DMA_CFCR_SUSPF_Msk
#define DMA_CFCR_TOF_Pos   (14U)
#define DMA_CFCR_TOF_Msk   (0x1UL << DMA_CFCR_TOF_Pos)
#define DMA_CFCR_TOF   DMA_CFCR_TOF_Msk
#define DMA_CSR_IDLEF_Pos   (0U)
#define DMA_CSR_IDLEF_Msk   (0x1UL << DMA_CSR_IDLEF_Pos)
#define DMA_CSR_IDLEF   DMA_CSR_IDLEF_Msk
#define DMA_CSR_TCF_Pos   (8U)
#define DMA_CSR_TCF_Msk   (0x1UL << DMA_CSR_TCF_Pos)
#define DMA_CSR_TCF   DMA_CSR_TCF_Msk
#define DMA_CSR_HTF_Pos   (9U)
#define DMA_CSR_HTF_Msk   (0x1UL << DMA_CSR_HTF_Pos)
#define DMA_CSR_HTF   DMA_CSR_HTF_Msk
#define DMA_CSR_DTEF_Pos   (10U)
#define DMA_CSR_DTEF_Msk   (0x1UL << DMA_CSR_DTEF_Pos)
#define DMA_CSR_DTEF   DMA_CSR_DTEF_Msk
#define DMA_CSR_ULEF_Pos   (11U)
#define DMA_CSR_ULEF_Msk   (0x1UL << DMA_CSR_ULEF_Pos)
#define DMA_CSR_ULEF   DMA_CSR_ULEF_Msk
#define DMA_CSR_USEF_Pos   (12U)
#define DMA_CSR_USEF_Msk   (0x1UL << DMA_CSR_USEF_Pos)
#define DMA_CSR_USEF   DMA_CSR_USEF_Msk
#define DMA_CSR_SUSPF_Pos   (13U)
#define DMA_CSR_SUSPF_Msk   (0x1UL << DMA_CSR_SUSPF_Pos)
#define DMA_CSR_SUSPF   DMA_CSR_SUSPF_Msk
#define DMA_CSR_TOF_Pos   (14U)
#define DMA_CSR_TOF_Msk   (0x1UL << DMA_CSR_TOF_Pos)
#define DMA_CSR_TOF   DMA_CSR_TOF_Msk
#define DMA_CSR_FIFOL_Pos   (16U)
#define DMA_CSR_FIFOL_Msk   (0xFFUL << DMA_CSR_FIFOL_Pos)
#define DMA_CSR_FIFOL   DMA_CSR_FIFOL_Msk
#define DMA_CCR_EN_Pos   (0U)
#define DMA_CCR_EN_Msk   (0x1UL << DMA_CCR_EN_Pos)
#define DMA_CCR_EN   DMA_CCR_EN_Msk
#define DMA_CCR_RESET_Pos   (1U)
#define DMA_CCR_RESET_Msk   (0x1UL << DMA_CCR_RESET_Pos)
#define DMA_CCR_RESET   DMA_CCR_RESET_Msk
#define DMA_CCR_SUSP_Pos   (2U)
#define DMA_CCR_SUSP_Msk   (0x1UL << DMA_CCR_SUSP_Pos)
#define DMA_CCR_SUSP   DMA_CCR_SUSP_Msk
#define DMA_CCR_TCIE_Pos   (8U)
#define DMA_CCR_TCIE_Msk   (0x1UL << DMA_CCR_TCIE_Pos)
#define DMA_CCR_TCIE   DMA_CCR_TCIE_Msk
#define DMA_CCR_HTIE_Pos   (9U)
#define DMA_CCR_HTIE_Msk   (0x1UL << DMA_CCR_HTIE_Pos)
#define DMA_CCR_HTIE   DMA_CCR_HTIE_Msk
#define DMA_CCR_DTEIE_Pos   (10U)
#define DMA_CCR_DTEIE_Msk   (0x1UL << DMA_CCR_DTEIE_Pos)
#define DMA_CCR_DTEIE   DMA_CCR_DTEIE_Msk
#define DMA_CCR_ULEIE_Pos   (11U)
#define DMA_CCR_ULEIE_Msk   (0x1UL << DMA_CCR_ULEIE_Pos)
#define DMA_CCR_ULEIE   DMA_CCR_ULEIE_Msk
#define DMA_CCR_USEIE_Pos   (12U)
#define DMA_CCR_USEIE_Msk   (0x1UL << DMA_CCR_USEIE_Pos)
#define DMA_CCR_USEIE   DMA_CCR_USEIE_Msk
#define DMA_CCR_SUSPIE_Pos   (13U)
#define DMA_CCR_SUSPIE_Msk   (0x1UL << DMA_CCR_SUSPIE_Pos)
#define DMA_CCR_SUSPIE   DMA_CCR_SUSPIE_Msk
#define DMA_CCR_TOIE_Pos   (14U)
#define DMA_CCR_TOIE_Msk   (0x1UL << DMA_CCR_TOIE_Pos)
#define DMA_CCR_TOIE   DMA_CCR_TOIE_Msk
#define DMA_CCR_LSM_Pos   (16U)
#define DMA_CCR_LSM_Msk   (0x1UL << DMA_CCR_LSM_Pos)
#define DMA_CCR_LSM   DMA_CCR_LSM_Msk
#define DMA_CCR_LAP_Pos   (17U)
#define DMA_CCR_LAP_Msk   (0x1UL << DMA_CCR_LAP_Pos)
#define DMA_CCR_LAP   DMA_CCR_LAP_Msk
#define DMA_CCR_PRIO_Pos   (22U)
#define DMA_CCR_PRIO_Msk   (0x3UL << DMA_CCR_PRIO_Pos)
#define DMA_CCR_PRIO   DMA_CCR_PRIO_Msk
#define DMA_CCR_PRIO_0   (0x1UL << DMA_CCR_PRIO_Pos)
#define DMA_CCR_PRIO_1   (0x2UL << DMA_CCR_PRIO_Pos)
#define DMA_CTR1_SDW_LOG2_Pos   (0U)
#define DMA_CTR1_SDW_LOG2_Msk   (0x3UL << DMA_CTR1_SDW_LOG2_Pos)
#define DMA_CTR1_SDW_LOG2   DMA_CTR1_SDW_LOG2_Msk
#define DMA_CTR1_SDW_LOG2_0   (0x1UL << DMA_CTR1_SDW_LOG2_Pos)
#define DMA_CTR1_SDW_LOG2_1   (0x2UL << DMA_CTR1_SDW_LOG2_Pos)
#define DMA_CTR1_SINC_Pos   (3U)
#define DMA_CTR1_SINC_Msk   (0x1UL << DMA_CTR1_SINC_Pos)
#define DMA_CTR1_SINC   DMA_CTR1_SINC_Msk
#define DMA_CTR1_SBL_1_Pos   (4U)
#define DMA_CTR1_SBL_1_Msk   (0x3FUL << DMA_CTR1_SBL_1_Pos)
#define DMA_CTR1_SBL_1   DMA_CTR1_SBL_1_Msk
#define DMA_CTR1_PAM_Pos   (11U)
#define DMA_CTR1_PAM_Msk   (0x3UL << DMA_CTR1_PAM_Pos)
#define DMA_CTR1_PAM   DMA_CTR1_PAM_Msk
#define DMA_CTR1_PAM_0   (0x1UL << DMA_CTR1_PAM_Pos)
#define DMA_CTR1_PAM_1   (0x2UL << DMA_CTR1_PAM_Pos)
#define DMA_CTR1_SBX_Pos   (13U)
#define DMA_CTR1_SBX_Msk   (0x1UL << DMA_CTR1_SBX_Pos)
#define DMA_CTR1_SBX   DMA_CTR1_SBX_Msk
#define DMA_CTR1_SAP_Pos   (14U)
#define DMA_CTR1_SAP_Msk   (0x1UL << DMA_CTR1_SAP_Pos)
#define DMA_CTR1_SAP   DMA_CTR1_SAP_Msk
#define DMA_CTR1_SSEC_Pos   (15U)
#define DMA_CTR1_SSEC_Msk   (0x1UL << DMA_CTR1_SSEC_Pos)
#define DMA_CTR1_SSEC   DMA_CTR1_SSEC_Msk
#define DMA_CTR1_DDW_LOG2_Pos   (16U)
#define DMA_CTR1_DDW_LOG2_Msk   (0x3UL << DMA_CTR1_DDW_LOG2_Pos)
#define DMA_CTR1_DDW_LOG2   DMA_CTR1_DDW_LOG2_Msk
#define DMA_CTR1_DDW_LOG2_0   (0x1UL << DMA_CTR1_DDW_LOG2_Pos)
#define DMA_CTR1_DDW_LOG2_1   (0x2UL << DMA_CTR1_DDW_LOG2_Pos)
#define DMA_CTR1_DINC_Pos   (19U)
#define DMA_CTR1_DINC_Msk   (0x1UL << DMA_CTR1_DINC_Pos)
#define DMA_CTR1_DINC   DMA_CTR1_DINC_Msk
#define DMA_CTR1_DBL_1_Pos   (20U)
#define DMA_CTR1_DBL_1_Msk   (0x3FUL << DMA_CTR1_DBL_1_Pos)
#define DMA_CTR1_DBL_1   DMA_CTR1_DBL_1_Msk
#define DMA_CTR1_DBX_Pos   (26U)
#define DMA_CTR1_DBX_Msk   (0x1UL << DMA_CTR1_DBX_Pos)
#define DMA_CTR1_DBX   DMA_CTR1_DBX_Msk
#define DMA_CTR1_DHX_Pos   (27U)
#define DMA_CTR1_DHX_Msk   (0x1UL << DMA_CTR1_DHX_Pos)
#define DMA_CTR1_DHX   DMA_CTR1_DHX_Msk
#define DMA_CTR1_DAP_Pos   (30U)
#define DMA_CTR1_DAP_Msk   (0x1UL << DMA_CTR1_DAP_Pos)
#define DMA_CTR1_DAP   DMA_CTR1_DAP_Msk
#define DMA_CTR1_DSEC_Pos   (31U)
#define DMA_CTR1_DSEC_Msk   (0x1UL << DMA_CTR1_DSEC_Pos)
#define DMA_CTR1_DSEC   DMA_CTR1_DSEC_Msk
#define DMA_CTR2_REQSEL_Pos   (0U)
#define DMA_CTR2_REQSEL_Msk   (0x7FUL << DMA_CTR2_REQSEL_Pos)
#define DMA_CTR2_REQSEL   DMA_CTR2_REQSEL_Msk
#define DMA_CTR2_SWREQ_Pos   (9U)
#define DMA_CTR2_SWREQ_Msk   (0x1UL << DMA_CTR2_SWREQ_Pos)
#define DMA_CTR2_SWREQ   DMA_CTR2_SWREQ_Msk
#define DMA_CTR2_DREQ_Pos   (10U)
#define DMA_CTR2_DREQ_Msk   (0x1UL << DMA_CTR2_DREQ_Pos)
#define DMA_CTR2_DREQ   DMA_CTR2_DREQ_Msk
#define DMA_CTR2_BREQ_Pos   (11U)
#define DMA_CTR2_BREQ_Msk   (0x1UL << DMA_CTR2_BREQ_Pos)
#define DMA_CTR2_BREQ   DMA_CTR2_BREQ_Msk
#define DMA_CTR2_TRIGM_Pos   (14U)
#define DMA_CTR2_TRIGM_Msk   (0x3UL << DMA_CTR2_TRIGM_Pos)
#define DMA_CTR2_TRIGM   DMA_CTR2_TRIGM_Msk
#define DMA_CTR2_TRIGM_0   (0x1UL << DMA_CTR2_TRIGM_Pos)
#define DMA_CTR2_TRIGM_1   (0x2UL << DMA_CTR2_TRIGM_Pos)
#define DMA_CTR2_TRIGSEL_Pos   (16U)
#define DMA_CTR2_TRIGSEL_Msk   (0x7FUL << DMA_CTR2_TRIGSEL_Pos)
#define DMA_CTR2_TRIGSEL   DMA_CTR2_TRIGSEL_Msk
#define DMA_CTR2_TRIGPOL_Pos   (24U)
#define DMA_CTR2_TRIGPOL_Msk   (0x3UL << DMA_CTR2_TRIGPOL_Pos)
#define DMA_CTR2_TRIGPOL   DMA_CTR2_TRIGPOL_Msk
#define DMA_CTR2_TRIGPOL_0   (0x1UL << DMA_CTR2_TRIGPOL_Pos)
#define DMA_CTR2_TRIGPOL_1   (0x2UL << DMA_CTR2_TRIGPOL_Pos)
#define DMA_CTR2_TCEM_Pos   (30U)
#define DMA_CTR2_TCEM_Msk   (0x3UL << DMA_CTR2_TCEM_Pos)
#define DMA_CTR2_TCEM   DMA_CTR2_TCEM_Msk
#define DMA_CTR2_TCEM_0   (0x1UL << DMA_CTR2_TCEM_Pos)
#define DMA_CTR2_TCEM_1   (0x2UL << DMA_CTR2_TCEM_Pos)
#define DMA_CBR1_BNDT_Pos   (0U)
#define DMA_CBR1_BNDT_Msk   (0xFFFFUL << DMA_CBR1_BNDT_Pos)
#define DMA_CBR1_BNDT   DMA_CBR1_BNDT_Msk
#define DMA_CBR1_BRC_Pos   (16U)
#define DMA_CBR1_BRC_Msk   (0x7FFUL << DMA_CBR1_BRC_Pos)
#define DMA_CBR1_BRC   DMA_CBR1_BRC_Msk
#define DMA_CBR1_SDEC_Pos   (28U)
#define DMA_CBR1_SDEC_Msk   (0x1UL << DMA_CBR1_SDEC_Pos)
#define DMA_CBR1_SDEC   DMA_CBR1_SDEC_Msk
#define DMA_CBR1_DDEC_Pos   (29U)
#define DMA_CBR1_DDEC_Msk   (0x1UL << DMA_CBR1_DDEC_Pos)
#define DMA_CBR1_DDEC   DMA_CBR1_DDEC_Msk
#define DMA_CBR1_BRSDEC_Pos   (30U)
#define DMA_CBR1_BRSDEC_Msk   (0x1UL << DMA_CBR1_BRSDEC_Pos)
#define DMA_CBR1_BRSDEC   DMA_CBR1_BRSDEC_Msk
#define DMA_CBR1_BRDDEC_Pos   (31U)
#define DMA_CBR1_BRDDEC_Msk   (0x1UL << DMA_CBR1_BRDDEC_Pos)
#define DMA_CBR1_BRDDEC   DMA_CBR1_BRDDEC_Msk
#define DMA_CSAR_SA_Pos   (0U)
#define DMA_CSAR_SA_Msk   (0xFFFFFFFFUL << DMA_CSAR_SA_Pos)
#define DMA_CSAR_SA   DMA_CSAR_SA_Msk
#define DMA_CDAR_DA_Pos   (0U)
#define DMA_CDAR_DA_Msk   (0xFFFFFFFFUL << DMA_CDAR_DA_Pos)
#define DMA_CDAR_DA   DMA_CDAR_DA_Msk
#define DMA_CTR3_SAO_Pos   (0U)
#define DMA_CTR3_SAO_Msk   (0x1FFFUL << DMA_CTR3_SAO_Pos)
#define DMA_CTR3_SAO   DMA_CTR3_SAO_Msk
#define DMA_CTR3_DAO_Pos   (16U)
#define DMA_CTR3_DAO_Msk   (0x1FFFUL << DMA_CTR3_DAO_Pos)
#define DMA_CTR3_DAO   DMA_CTR3_DAO_Msk
#define DMA_CBR2_BRSAO_Pos   (0U)
#define DMA_CBR2_BRSAO_Msk   (0xFFFFUL << DMA_CBR2_BRSAO_Pos)
#define DMA_CBR2_BRSAO   DMA_CBR2_BRSAO_Msk
#define DMA_CBR2_BRDAO_Pos   (16U)
#define DMA_CBR2_BRDAO_Msk   (0xFFFFUL << DMA_CBR2_BRDAO_Pos)
#define DMA_CBR2_BRDAO   DMA_CBR2_BRDAO_Msk
#define DMA_CLLR_LA_Pos   (2U)
#define DMA_CLLR_LA_Msk   (0x3FFFUL << DMA_CLLR_LA_Pos)
#define DMA_CLLR_LA   DMA_CLLR_LA_Msk
#define DMA_CLLR_ULL_Pos   (16U)
#define DMA_CLLR_ULL_Msk   (0x1UL << DMA_CLLR_ULL_Pos)
#define DMA_CLLR_ULL   DMA_CLLR_ULL_Msk
#define DMA_CLLR_UB2_Pos   (25U)
#define DMA_CLLR_UB2_Msk   (0x1UL << DMA_CLLR_UB2_Pos)
#define DMA_CLLR_UB2   DMA_CLLR_UB2_Msk
#define DMA_CLLR_UT3_Pos   (26U)
#define DMA_CLLR_UT3_Msk   (0x1UL << DMA_CLLR_UT3_Pos)
#define DMA_CLLR_UT3   DMA_CLLR_UT3_Msk
#define DMA_CLLR_UDA_Pos   (27U)
#define DMA_CLLR_UDA_Msk   (0x1UL << DMA_CLLR_UDA_Pos)
#define DMA_CLLR_UDA   DMA_CLLR_UDA_Msk
#define DMA_CLLR_USA_Pos   (28U)
#define DMA_CLLR_USA_Msk   (0x1UL << DMA_CLLR_USA_Pos)
#define DMA_CLLR_USA   DMA_CLLR_USA_Msk
#define DMA_CLLR_UB1_Pos   (29U)
#define DMA_CLLR_UB1_Msk   (0x1UL << DMA_CLLR_UB1_Pos)
#define DMA_CLLR_UB1   DMA_CLLR_UB1_Msk
#define DMA_CLLR_UT2_Pos   (30U)
#define DMA_CLLR_UT2_Msk   (0x1UL << DMA_CLLR_UT2_Pos)
#define DMA_CLLR_UT2   DMA_CLLR_UT2_Msk
#define DMA_CLLR_UT1_Pos   (31U)
#define DMA_CLLR_UT1_Msk   (0x1UL << DMA_CLLR_UT1_Pos)
#define DMA_CLLR_UT1   DMA_CLLR_UT1_Msk
#define DMA2D_CR_START_Pos   (0U)
#define DMA2D_CR_START_Msk   (0x1UL << DMA2D_CR_START_Pos)
#define DMA2D_CR_START   DMA2D_CR_START_Msk
#define DMA2D_CR_SUSP_Pos   (1U)
#define DMA2D_CR_SUSP_Msk   (0x1UL << DMA2D_CR_SUSP_Pos)
#define DMA2D_CR_SUSP   DMA2D_CR_SUSP_Msk
#define DMA2D_CR_ABORT_Pos   (2U)
#define DMA2D_CR_ABORT_Msk   (0x1UL << DMA2D_CR_ABORT_Pos)
#define DMA2D_CR_ABORT   DMA2D_CR_ABORT_Msk
#define DMA2D_CR_LOM_Pos   (6U)
#define DMA2D_CR_LOM_Msk   (0x1UL << DMA2D_CR_LOM_Pos)
#define DMA2D_CR_LOM   DMA2D_CR_LOM_Msk
#define DMA2D_CR_TEIE_Pos   (8U)
#define DMA2D_CR_TEIE_Msk   (0x1UL << DMA2D_CR_TEIE_Pos)
#define DMA2D_CR_TEIE   DMA2D_CR_TEIE_Msk
#define DMA2D_CR_TCIE_Pos   (9U)
#define DMA2D_CR_TCIE_Msk   (0x1UL << DMA2D_CR_TCIE_Pos)
#define DMA2D_CR_TCIE   DMA2D_CR_TCIE_Msk
#define DMA2D_CR_TWIE_Pos   (10U)
#define DMA2D_CR_TWIE_Msk   (0x1UL << DMA2D_CR_TWIE_Pos)
#define DMA2D_CR_TWIE   DMA2D_CR_TWIE_Msk
#define DMA2D_CR_CAEIE_Pos   (11U)
#define DMA2D_CR_CAEIE_Msk   (0x1UL << DMA2D_CR_CAEIE_Pos)
#define DMA2D_CR_CAEIE   DMA2D_CR_CAEIE_Msk
#define DMA2D_CR_CTCIE_Pos   (12U)
#define DMA2D_CR_CTCIE_Msk   (0x1UL << DMA2D_CR_CTCIE_Pos)
#define DMA2D_CR_CTCIE   DMA2D_CR_CTCIE_Msk
#define DMA2D_CR_CEIE_Pos   (13U)
#define DMA2D_CR_CEIE_Msk   (0x1UL << DMA2D_CR_CEIE_Pos)
#define DMA2D_CR_CEIE   DMA2D_CR_CEIE_Msk
#define DMA2D_CR_MODE_Pos   (16U)
#define DMA2D_CR_MODE_Msk   (0x7UL << DMA2D_CR_MODE_Pos)
#define DMA2D_CR_MODE   DMA2D_CR_MODE_Msk
#define DMA2D_CR_MODE_0   (0x1UL << DMA2D_CR_MODE_Pos)
#define DMA2D_CR_MODE_1   (0x2UL << DMA2D_CR_MODE_Pos)
#define DMA2D_CR_MODE_2   (0x4UL << DMA2D_CR_MODE_Pos)
#define DMA2D_ISR_TEIF_Pos   (0U)
#define DMA2D_ISR_TEIF_Msk   (0x1UL << DMA2D_ISR_TEIF_Pos)
#define DMA2D_ISR_TEIF   DMA2D_ISR_TEIF_Msk
#define DMA2D_ISR_TCIF_Pos   (1U)
#define DMA2D_ISR_TCIF_Msk   (0x1UL << DMA2D_ISR_TCIF_Pos)
#define DMA2D_ISR_TCIF   DMA2D_ISR_TCIF_Msk
#define DMA2D_ISR_TWIF_Pos   (2U)
#define DMA2D_ISR_TWIF_Msk   (0x1UL << DMA2D_ISR_TWIF_Pos)
#define DMA2D_ISR_TWIF   DMA2D_ISR_TWIF_Msk
#define DMA2D_ISR_CAEIF_Pos   (3U)
#define DMA2D_ISR_CAEIF_Msk   (0x1UL << DMA2D_ISR_CAEIF_Pos)
#define DMA2D_ISR_CAEIF   DMA2D_ISR_CAEIF_Msk
#define DMA2D_ISR_CTCIF_Pos   (4U)
#define DMA2D_ISR_CTCIF_Msk   (0x1UL << DMA2D_ISR_CTCIF_Pos)
#define DMA2D_ISR_CTCIF   DMA2D_ISR_CTCIF_Msk
#define DMA2D_ISR_CEIF_Pos   (5U)
#define DMA2D_ISR_CEIF_Msk   (0x1UL << DMA2D_ISR_CEIF_Pos)
#define DMA2D_ISR_CEIF   DMA2D_ISR_CEIF_Msk
#define DMA2D_IFCR_CTEIF_Pos   (0U)
#define DMA2D_IFCR_CTEIF_Msk   (0x1UL << DMA2D_IFCR_CTEIF_Pos)
#define DMA2D_IFCR_CTEIF   DMA2D_IFCR_CTEIF_Msk
#define DMA2D_IFCR_CTCIF_Pos   (1U)
#define DMA2D_IFCR_CTCIF_Msk   (0x1UL << DMA2D_IFCR_CTCIF_Pos)
#define DMA2D_IFCR_CTCIF   DMA2D_IFCR_CTCIF_Msk
#define DMA2D_IFCR_CTWIF_Pos   (2U)
#define DMA2D_IFCR_CTWIF_Msk   (0x1UL << DMA2D_IFCR_CTWIF_Pos)
#define DMA2D_IFCR_CTWIF   DMA2D_IFCR_CTWIF_Msk
#define DMA2D_IFCR_CAECIF_Pos   (3U)
#define DMA2D_IFCR_CAECIF_Msk   (0x1UL << DMA2D_IFCR_CAECIF_Pos)
#define DMA2D_IFCR_CAECIF   DMA2D_IFCR_CAECIF_Msk
#define DMA2D_IFCR_CCTCIF_Pos   (4U)
#define DMA2D_IFCR_CCTCIF_Msk   (0x1UL << DMA2D_IFCR_CCTCIF_Pos)
#define DMA2D_IFCR_CCTCIF   DMA2D_IFCR_CCTCIF_Msk
#define DMA2D_IFCR_CCEIF_Pos   (5U)
#define DMA2D_IFCR_CCEIF_Msk   (0x1UL << DMA2D_IFCR_CCEIF_Pos)
#define DMA2D_IFCR_CCEIF   DMA2D_IFCR_CCEIF_Msk
#define DMA2D_FGMAR_MA_Pos   (0U)
#define DMA2D_FGMAR_MA_Msk   (0xFFFFFFFFUL << DMA2D_FGMAR_MA_Pos)
#define DMA2D_FGMAR_MA   DMA2D_FGMAR_MA_Msk
#define DMA2D_FGOR_LO_Pos   (0U)
#define DMA2D_FGOR_LO_Msk   (0xFFFFUL << DMA2D_FGOR_LO_Pos)
#define DMA2D_FGOR_LO   DMA2D_FGOR_LO_Msk
#define DMA2D_BGMAR_MA_Pos   (0U)
#define DMA2D_BGMAR_MA_Msk   (0xFFFFFFFFUL << DMA2D_BGMAR_MA_Pos)
#define DMA2D_BGMAR_MA   DMA2D_BGMAR_MA_Msk
#define DMA2D_BGOR_LO_Pos   (0U)
#define DMA2D_BGOR_LO_Msk   (0xFFFFUL << DMA2D_BGOR_LO_Pos)
#define DMA2D_BGOR_LO   DMA2D_BGOR_LO_Msk
#define DMA2D_FGPFCCR_CM_Pos   (0U)
#define DMA2D_FGPFCCR_CM_Msk   (0xFUL << DMA2D_FGPFCCR_CM_Pos)
#define DMA2D_FGPFCCR_CM   DMA2D_FGPFCCR_CM_Msk
#define DMA2D_FGPFCCR_CM_0   (0x1UL << DMA2D_FGPFCCR_CM_Pos)
#define DMA2D_FGPFCCR_CM_1   (0x2UL << DMA2D_FGPFCCR_CM_Pos)
#define DMA2D_FGPFCCR_CM_2   (0x4UL << DMA2D_FGPFCCR_CM_Pos)
#define DMA2D_FGPFCCR_CM_3   (0x8UL << DMA2D_FGPFCCR_CM_Pos)
#define DMA2D_FGPFCCR_CCM_Pos   (4U)
#define DMA2D_FGPFCCR_CCM_Msk   (0x1UL << DMA2D_FGPFCCR_CCM_Pos)
#define DMA2D_FGPFCCR_CCM   DMA2D_FGPFCCR_CCM_Msk
#define DMA2D_FGPFCCR_START_Pos   (5U)
#define DMA2D_FGPFCCR_START_Msk   (0x1UL << DMA2D_FGPFCCR_START_Pos)
#define DMA2D_FGPFCCR_START   DMA2D_FGPFCCR_START_Msk
#define DMA2D_FGPFCCR_CS_Pos   (8U)
#define DMA2D_FGPFCCR_CS_Msk   (0xFFUL << DMA2D_FGPFCCR_CS_Pos)
#define DMA2D_FGPFCCR_CS   DMA2D_FGPFCCR_CS_Msk
#define DMA2D_FGPFCCR_AM_Pos   (16U)
#define DMA2D_FGPFCCR_AM_Msk   (0x3UL << DMA2D_FGPFCCR_AM_Pos)
#define DMA2D_FGPFCCR_AM   DMA2D_FGPFCCR_AM_Msk
#define DMA2D_FGPFCCR_AM_0   (0x1UL << DMA2D_FGPFCCR_AM_Pos)
#define DMA2D_FGPFCCR_AM_1   (0x2UL << DMA2D_FGPFCCR_AM_Pos)
#define DMA2D_FGPFCCR_CSS_Pos   (18U)
#define DMA2D_FGPFCCR_CSS_Msk   (0x3UL << DMA2D_FGPFCCR_CSS_Pos)
#define DMA2D_FGPFCCR_CSS   DMA2D_FGPFCCR_CSS_Msk /* !< Chroma Sub-Sampling */
#define DMA2D_FGPFCCR_CSS_0   (0x1UL << DMA2D_FGPFCCR_CSS_Pos)
#define DMA2D_FGPFCCR_CSS_1   (0x2UL << DMA2D_FGPFCCR_CSS_Pos)
#define DMA2D_FGPFCCR_AI_Pos   (20U)
#define DMA2D_FGPFCCR_AI_Msk   (0x1UL << DMA2D_FGPFCCR_AI_Pos)
#define DMA2D_FGPFCCR_AI   DMA2D_FGPFCCR_AI_Msk
#define DMA2D_FGPFCCR_RBS_Pos   (21U)
#define DMA2D_FGPFCCR_RBS_Msk   (0x1UL << DMA2D_FGPFCCR_RBS_Pos)
#define DMA2D_FGPFCCR_RBS   DMA2D_FGPFCCR_RBS_Msk
#define DMA2D_FGPFCCR_ALPHA_Pos   (24U)
#define DMA2D_FGPFCCR_ALPHA_Msk   (0xFFUL << DMA2D_FGPFCCR_ALPHA_Pos)
#define DMA2D_FGPFCCR_ALPHA   DMA2D_FGPFCCR_ALPHA_Msk
#define DMA2D_FGCOLR_BLUE_Pos   (0U)
#define DMA2D_FGCOLR_BLUE_Msk   (0xFFUL << DMA2D_FGCOLR_BLUE_Pos)
#define DMA2D_FGCOLR_BLUE   DMA2D_FGCOLR_BLUE_Msk
#define DMA2D_FGCOLR_GREEN_Pos   (8U)
#define DMA2D_FGCOLR_GREEN_Msk   (0xFFUL << DMA2D_FGCOLR_GREEN_Pos)
#define DMA2D_FGCOLR_GREEN   DMA2D_FGCOLR_GREEN_Msk
#define DMA2D_FGCOLR_RED_Pos   (16U)
#define DMA2D_FGCOLR_RED_Msk   (0xFFUL << DMA2D_FGCOLR_RED_Pos)
#define DMA2D_FGCOLR_RED   DMA2D_FGCOLR_RED_Msk
#define DMA2D_BGPFCCR_CM_Pos   (0U)
#define DMA2D_BGPFCCR_CM_Msk   (0xFUL << DMA2D_BGPFCCR_CM_Pos)
#define DMA2D_BGPFCCR_CM   DMA2D_BGPFCCR_CM_Msk
#define DMA2D_BGPFCCR_CM_0   (0x1UL << DMA2D_BGPFCCR_CM_Pos)
#define DMA2D_BGPFCCR_CM_1   (0x2UL << DMA2D_BGPFCCR_CM_Pos)
#define DMA2D_BGPFCCR_CM_2   (0x4UL << DMA2D_BGPFCCR_CM_Pos)
#define DMA2D_BGPFCCR_CM_3   (0x8UL << DMA2D_BGPFCCR_CM_Pos)
#define DMA2D_BGPFCCR_CCM_Pos   (4U)
#define DMA2D_BGPFCCR_CCM_Msk   (0x1UL << DMA2D_BGPFCCR_CCM_Pos)
#define DMA2D_BGPFCCR_CCM   DMA2D_BGPFCCR_CCM_Msk
#define DMA2D_BGPFCCR_START_Pos   (5U)
#define DMA2D_BGPFCCR_START_Msk   (0x1UL << DMA2D_BGPFCCR_START_Pos)
#define DMA2D_BGPFCCR_START   DMA2D_BGPFCCR_START_Msk
#define DMA2D_BGPFCCR_CS_Pos   (8U)
#define DMA2D_BGPFCCR_CS_Msk   (0xFFUL << DMA2D_BGPFCCR_CS_Pos)
#define DMA2D_BGPFCCR_CS   DMA2D_BGPFCCR_CS_Msk
#define DMA2D_BGPFCCR_AM_Pos   (16U)
#define DMA2D_BGPFCCR_AM_Msk   (0x3UL << DMA2D_BGPFCCR_AM_Pos)
#define DMA2D_BGPFCCR_AM   DMA2D_BGPFCCR_AM_Msk
#define DMA2D_BGPFCCR_AM_0   (0x1UL << DMA2D_BGPFCCR_AM_Pos)
#define DMA2D_BGPFCCR_AM_1   (0x2UL << DMA2D_BGPFCCR_AM_Pos)
#define DMA2D_BGPFCCR_AI_Pos   (20U)
#define DMA2D_BGPFCCR_AI_Msk   (0x1UL << DMA2D_BGPFCCR_AI_Pos)
#define DMA2D_BGPFCCR_AI   DMA2D_BGPFCCR_AI_Msk
#define DMA2D_BGPFCCR_RBS_Pos   (21U)
#define DMA2D_BGPFCCR_RBS_Msk   (0x1UL << DMA2D_BGPFCCR_RBS_Pos)
#define DMA2D_BGPFCCR_RBS   DMA2D_BGPFCCR_RBS_Msk
#define DMA2D_BGPFCCR_ALPHA_Pos   (24U)
#define DMA2D_BGPFCCR_ALPHA_Msk   (0xFFUL << DMA2D_BGPFCCR_ALPHA_Pos)
#define DMA2D_BGPFCCR_ALPHA   DMA2D_BGPFCCR_ALPHA_Msk
#define DMA2D_BGCOLR_BLUE_Pos   (0U)
#define DMA2D_BGCOLR_BLUE_Msk   (0xFFUL << DMA2D_BGCOLR_BLUE_Pos)
#define DMA2D_BGCOLR_BLUE   DMA2D_BGCOLR_BLUE_Msk
#define DMA2D_BGCOLR_GREEN_Pos   (8U)
#define DMA2D_BGCOLR_GREEN_Msk   (0xFFUL << DMA2D_BGCOLR_GREEN_Pos)
#define DMA2D_BGCOLR_GREEN   DMA2D_BGCOLR_GREEN_Msk
#define DMA2D_BGCOLR_RED_Pos   (16U)
#define DMA2D_BGCOLR_RED_Msk   (0xFFUL << DMA2D_BGCOLR_RED_Pos)
#define DMA2D_BGCOLR_RED   DMA2D_BGCOLR_RED_Msk
#define DMA2D_FGCMAR_MA_Pos   (0U)
#define DMA2D_FGCMAR_MA_Msk   (0xFFFFFFFFUL << DMA2D_FGCMAR_MA_Pos)
#define DMA2D_FGCMAR_MA   DMA2D_FGCMAR_MA_Msk
#define DMA2D_BGCMAR_MA_Pos   (0U)
#define DMA2D_BGCMAR_MA_Msk   (0xFFFFFFFFUL << DMA2D_BGCMAR_MA_Pos)
#define DMA2D_BGCMAR_MA   DMA2D_BGCMAR_MA_Msk
#define DMA2D_OPFCCR_CM_Pos   (0U)
#define DMA2D_OPFCCR_CM_Msk   (0x7UL << DMA2D_OPFCCR_CM_Pos)
#define DMA2D_OPFCCR_CM   DMA2D_OPFCCR_CM_Msk
#define DMA2D_OPFCCR_CM_0   (0x1UL << DMA2D_OPFCCR_CM_Pos)
#define DMA2D_OPFCCR_CM_1   (0x2UL << DMA2D_OPFCCR_CM_Pos)
#define DMA2D_OPFCCR_CM_2   (0x4UL << DMA2D_OPFCCR_CM_Pos)
#define DMA2D_OPFCCR_SB_Pos   (8U)
#define DMA2D_OPFCCR_SB_Msk   (0x1UL << DMA2D_OPFCCR_SB_Pos)
#define DMA2D_OPFCCR_SB   DMA2D_OPFCCR_SB_Msk
#define DMA2D_OPFCCR_AI_Pos   (20U)
#define DMA2D_OPFCCR_AI_Msk   (0x1UL << DMA2D_OPFCCR_AI_Pos)
#define DMA2D_OPFCCR_AI   DMA2D_OPFCCR_AI_Msk
#define DMA2D_OPFCCR_RBS_Pos   (21U)
#define DMA2D_OPFCCR_RBS_Msk   (0x1UL << DMA2D_OPFCCR_RBS_Pos)
#define DMA2D_OPFCCR_RBS   DMA2D_OPFCCR_RBS_Msk
#define DMA2D_OCOLR_BLUE_1_Pos   (0U)
#define DMA2D_OCOLR_BLUE_1_Msk   (0xFFUL << DMA2D_OCOLR_BLUE_1_Pos) /*0x000000FFU*/
#define DMA2D_OCOLR_BLUE_1   DMA2D_OCOLR_BLUE_1_Msk
#define DMA2D_OCOLR_GREEN_1_Pos   (8U)
#define DMA2D_OCOLR_GREEN_1_Msk   (0xFFUL << DMA2D_OCOLR_GREEN_1_Pos) /*0x0000FF00U)*/
#define DMA2D_OCOLR_GREEN_1   DMA2D_OCOLR_GREEN_1_Msk
#define DMA2D_OCOLR_RED_1_Pos   (16U)
#define DMA2D_OCOLR_RED_1_Msk   (0xFFUL << DMA2D_OCOLR_RED_1_Pos) /*0x00FF0000U */
#define DMA2D_OCOLR_RED_1   DMA2D_OCOLR_RED_1_Msk
#define DMA2D_OCOLR_ALPHA_1_Pos   (24U)
#define DMA2D_OCOLR_ALPHA_1_Msk   (0xFFUL << DMA2D_OCOLR_ALPHA_1_Pos) /*0xFF000000U*/
#define DMA2D_OCOLR_ALPHA_1   DMA2D_OCOLR_ALPHA_1_Msk
#define DMA2D_OCOLR_BLUE_2_Pos   (0U)
#define DMA2D_OCOLR_BLUE_2_Msk   (0x1FUL << DMA2D_OCOLR_BLUE_2_Pos) /*0x0000001FU*/
#define DMA2D_OCOLR_BLUE_2   DMA2D_OCOLR_BLUE_2_Msk
#define DMA2D_OCOLR_GREEN_2_Pos   (5U)
#define DMA2D_OCOLR_GREEN_2_Msk   (0x7EUL << DMA2D_OCOLR_GREEN_2_Pos) /* 0x000007E0U */
#define DMA2D_OCOLR_GREEN_2   DMA2D_OCOLR_GREEN_2_Msk
#define DMA2D_OCOLR_RED_2_Pos   (11U)
#define DMA2D_OCOLR_RED_2_Msk   (0xF8UL << DMA2D_OCOLR_RED_2_Pos) /*0x0000F800U*/
#define DMA2D_OCOLR_RED_2   DMA2D_OCOLR_RED_2_Msk
#define DMA2D_OCOLR_BLUE_3_Pos   (0U)
#define DMA2D_OCOLR_BLUE_3_Msk   (0x1FUL << DMA2D_OCOLR_BLUE_3_Pos) /*0x0000001FU*/
#define DMA2D_OCOLR_BLUE_3   DMA2D_OCOLR_BLUE_3_Msk
#define DMA2D_OCOLR_GREEN_3_Pos   (5U)
#define DMA2D_OCOLR_GREEN_3_Msk   (0x3EUL << DMA2D_OCOLR_GREEN_3_Pos) /*0x000003E0U*/
#define DMA2D_OCOLR_GREEN_3   DMA2D_OCOLR_GREEN_3_Msk
#define DMA2D_OCOLR_RED_3_Pos   (10U)
#define DMA2D_OCOLR_RED_3_Msk   (0x7CUL << DMA2D_OCOLR_RED_3_Pos) /* 0x00007C00U*/
#define DMA2D_OCOLR_RED_3   DMA2D_OCOLR_RED_3_Msk
#define DMA2D_OCOLR_ALPHA_3_Pos   (15U)
#define DMA2D_OCOLR_ALPHA_3_Msk   (0x1UL << DMA2D_OCOLR_ALPHA_3_Pos) /*0x00008000U*/
#define DMA2D_OCOLR_ALPHA_3   DMA2D_OCOLR_ALPHA_3_Msk
#define DMA2D_OCOLR_BLUE_4_Pos   (0U)
#define DMA2D_OCOLR_BLUE_4_Msk   (0xFUL << DMA2D_OCOLR_BLUE_4_Pos) /*0x0000000FU*/
#define DMA2D_OCOLR_BLUE_4   DMA2D_OCOLR_BLUE_4_Msk
#define DMA2D_OCOLR_GREEN_4_Pos   (4U)
#define DMA2D_OCOLR_GREEN_4_Msk   (0xFUL << DMA2D_OCOLR_GREEN_4_Pos) /*0x000000F0U*/
#define DMA2D_OCOLR_GREEN_4   DMA2D_OCOLR_GREEN_4_Msk
#define DMA2D_OCOLR_RED_4_Pos   (8U)
#define DMA2D_OCOLR_RED_4_Msk   (0xFUL << DMA2D_OCOLR_RED_4_Pos) /*0x00000F00U*/
#define DMA2D_OCOLR_RED_4   DMA2D_OCOLR_RED_4_Msk
#define DMA2D_OCOLR_ALPHA_4_Pos   (12U)
#define DMA2D_OCOLR_ALPHA_4_Msk   (0xF << DMA2D_OCOLR_ALPHA_4_Pos) /*0x0000F000U*/
#define DMA2D_OCOLR_ALPHA_4   DMA2D_OCOLR_ALPHA_4_Msk
#define DMA2D_OMAR_MA_Pos   (0U)
#define DMA2D_OMAR_MA_Msk   (0xFFFFFFFFUL << DMA2D_OMAR_MA_Pos)
#define DMA2D_OMAR_MA   DMA2D_OMAR_MA_Msk
#define DMA2D_OOR_LO_Pos   (0U)
#define DMA2D_OOR_LO_Msk   (0xFFFFUL << DMA2D_OOR_LO_Pos)
#define DMA2D_OOR_LO   DMA2D_OOR_LO_Msk
#define DMA2D_NLR_NL_Pos   (0U)
#define DMA2D_NLR_NL_Msk   (0xFFFFUL << DMA2D_NLR_NL_Pos)
#define DMA2D_NLR_NL   DMA2D_NLR_NL_Msk
#define DMA2D_NLR_PL_Pos   (16U)
#define DMA2D_NLR_PL_Msk   (0x3FFFUL << DMA2D_NLR_PL_Pos)
#define DMA2D_NLR_PL   DMA2D_NLR_PL_Msk
#define DMA2D_LWR_LW_Pos   (0U)
#define DMA2D_LWR_LW_Msk   (0xFFFFUL << DMA2D_LWR_LW_Pos)
#define DMA2D_LWR_LW   DMA2D_LWR_LW_Msk
#define DMA2D_AMTCR_EN_Pos   (0U)
#define DMA2D_AMTCR_EN_Msk   (0x1UL << DMA2D_AMTCR_EN_Pos)
#define DMA2D_AMTCR_EN   DMA2D_AMTCR_EN_Msk
#define DMA2D_AMTCR_DT_Pos   (8U)
#define DMA2D_AMTCR_DT_Msk   (0xFFUL << DMA2D_AMTCR_DT_Pos)
#define DMA2D_AMTCR_DT   DMA2D_AMTCR_DT_Msk
#define DSI_VR_Pos   (0U)
#define DSI_VR_Msk   (0xFFFFFFFFUL << DSI_VR_Pos)
#define DSI_VR   DSI_VR_Msk
#define DSI_CR_EN_Pos   (0U)
#define DSI_CR_EN_Msk   (0x1UL << DSI_CR_EN_Pos)
#define DSI_CR_EN   DSI_CR_EN_Msk
#define DSI_CCR_TXECKDIV_Pos   (0U)
#define DSI_CCR_TXECKDIV_Msk   (0xFFUL << DSI_CCR_TXECKDIV_Pos)
#define DSI_CCR_TXECKDIV   DSI_CCR_TXECKDIV_Msk
#define DSI_CCR_TXECKDIV0_Pos   (0U)
#define DSI_CCR_TXECKDIV0_Msk   (0x1UL << DSI_CCR_TXECKDIV0_Pos)
#define DSI_CCR_TXECKDIV0   DSI_CCR_TXECKDIV0_Msk
#define DSI_CCR_TXECKDIV1_Pos   (1U)
#define DSI_CCR_TXECKDIV1_Msk   (0x1UL << DSI_CCR_TXECKDIV1_Pos)
#define DSI_CCR_TXECKDIV1   DSI_CCR_TXECKDIV1_Msk
#define DSI_CCR_TXECKDIV2_Pos   (2U)
#define DSI_CCR_TXECKDIV2_Msk   (0x1UL << DSI_CCR_TXECKDIV2_Pos)
#define DSI_CCR_TXECKDIV2   DSI_CCR_TXECKDIV2_Msk
#define DSI_CCR_TXECKDIV3_Pos   (3U)
#define DSI_CCR_TXECKDIV3_Msk   (0x1UL << DSI_CCR_TXECKDIV3_Pos)
#define DSI_CCR_TXECKDIV3   DSI_CCR_TXECKDIV3_Msk
#define DSI_CCR_TXECKDIV4_Pos   (4U)
#define DSI_CCR_TXECKDIV4_Msk   (0x1UL << DSI_CCR_TXECKDIV4_Pos)
#define DSI_CCR_TXECKDIV4   DSI_CCR_TXECKDIV4_Msk
#define DSI_CCR_TXECKDIV5_Pos   (5U)
#define DSI_CCR_TXECKDIV5_Msk   (0x1UL << DSI_CCR_TXECKDIV5_Pos)
#define DSI_CCR_TXECKDIV5   DSI_CCR_TXECKDIV5_Msk
#define DSI_CCR_TXECKDIV6_Pos   (6U)
#define DSI_CCR_TXECKDIV6_Msk   (0x1UL << DSI_CCR_TXECKDIV6_Pos)
#define DSI_CCR_TXECKDIV6   DSI_CCR_TXECKDIV6_Msk
#define DSI_CCR_TXECKDIV7_Pos   (7U)
#define DSI_CCR_TXECKDIV7_Msk   (0x1UL << DSI_CCR_TXECKDIV7_Pos)
#define DSI_CCR_TXECKDIV7   DSI_CCR_TXECKDIV7_Msk
#define DSI_CCR_TOCKDIV_Pos   (8U)
#define DSI_CCR_TOCKDIV_Msk   (0xFFUL << DSI_CCR_TOCKDIV_Pos)
#define DSI_CCR_TOCKDIV   DSI_CCR_TOCKDIV_Msk
#define DSI_CCR_TOCKDIV0_Pos   (8U)
#define DSI_CCR_TOCKDIV0_Msk   (0x1UL << DSI_CCR_TOCKDIV0_Pos)
#define DSI_CCR_TOCKDIV0   DSI_CCR_TOCKDIV0_Msk
#define DSI_CCR_TOCKDIV1_Pos   (9U)
#define DSI_CCR_TOCKDIV1_Msk   (0x1UL << DSI_CCR_TOCKDIV1_Pos)
#define DSI_CCR_TOCKDIV1   DSI_CCR_TOCKDIV1_Msk
#define DSI_CCR_TOCKDIV2_Pos   (10U)
#define DSI_CCR_TOCKDIV2_Msk   (0x1UL << DSI_CCR_TOCKDIV2_Pos)
#define DSI_CCR_TOCKDIV2   DSI_CCR_TOCKDIV2_Msk
#define DSI_CCR_TOCKDIV3_Pos   (11U)
#define DSI_CCR_TOCKDIV3_Msk   (0x1UL << DSI_CCR_TOCKDIV3_Pos)
#define DSI_CCR_TOCKDIV3   DSI_CCR_TOCKDIV3_Msk
#define DSI_CCR_TOCKDIV4_Pos   (12U)
#define DSI_CCR_TOCKDIV4_Msk   (0x1UL << DSI_CCR_TOCKDIV4_Pos)
#define DSI_CCR_TOCKDIV4   DSI_CCR_TOCKDIV4_Msk
#define DSI_CCR_TOCKDIV5_Pos   (13U)
#define DSI_CCR_TOCKDIV5_Msk   (0x1UL << DSI_CCR_TOCKDIV5_Pos)
#define DSI_CCR_TOCKDIV5   DSI_CCR_TOCKDIV5_Msk
#define DSI_CCR_TOCKDIV6_Pos   (14U)
#define DSI_CCR_TOCKDIV6_Msk   (0x1UL << DSI_CCR_TOCKDIV6_Pos)
#define DSI_CCR_TOCKDIV6   DSI_CCR_TOCKDIV6_Msk
#define DSI_CCR_TOCKDIV7_Pos   (15U)
#define DSI_CCR_TOCKDIV7_Msk   (0x1UL << DSI_CCR_TOCKDIV7_Pos)
#define DSI_CCR_TOCKDIV7   DSI_CCR_TOCKDIV7_Msk
#define DSI_LVCIDR_VCID_Pos   (0U)
#define DSI_LVCIDR_VCID_Msk   (0x3UL << DSI_LVCIDR_VCID_Pos)
#define DSI_LVCIDR_VCID   DSI_LVCIDR_VCID_Msk
#define DSI_LVCIDR_VCID0_Pos   (0U)
#define DSI_LVCIDR_VCID0_Msk   (0x1UL << DSI_LVCIDR_VCID0_Pos)
#define DSI_LVCIDR_VCID0   DSI_LVCIDR_VCID0_Msk
#define DSI_LVCIDR_VCID1_Pos   (1U)
#define DSI_LVCIDR_VCID1_Msk   (0x1UL << DSI_LVCIDR_VCID1_Pos)
#define DSI_LVCIDR_VCID1   DSI_LVCIDR_VCID1_Msk
#define DSI_LCOLCR_COLC_Pos   (0U)
#define DSI_LCOLCR_COLC_Msk   (0xFUL << DSI_LCOLCR_COLC_Pos)
#define DSI_LCOLCR_COLC   DSI_LCOLCR_COLC_Msk
#define DSI_LCOLCR_COLC0_Pos   (0U)
#define DSI_LCOLCR_COLC0_Msk   (0x1UL << DSI_LCOLCR_COLC0_Pos)
#define DSI_LCOLCR_COLC0   DSI_LCOLCR_COLC0_Msk
#define DSI_LCOLCR_COLC1_Pos   (1U)
#define DSI_LCOLCR_COLC1_Msk   (0x1UL << DSI_LCOLCR_COLC1_Pos)
#define DSI_LCOLCR_COLC1   DSI_LCOLCR_COLC1_Msk
#define DSI_LCOLCR_COLC2_Pos   (2U)
#define DSI_LCOLCR_COLC2_Msk   (0x1UL << DSI_LCOLCR_COLC2_Pos)
#define DSI_LCOLCR_COLC2   DSI_LCOLCR_COLC2_Msk
#define DSI_LCOLCR_COLC3_Pos   (3U)
#define DSI_LCOLCR_COLC3_Msk   (0x1UL << DSI_LCOLCR_COLC3_Pos)
#define DSI_LCOLCR_COLC3   DSI_LCOLCR_COLC3_Msk
#define DSI_LCOLCR_LPE_Pos   (8U)
#define DSI_LCOLCR_LPE_Msk   (0x1UL << DSI_LCOLCR_LPE_Pos)
#define DSI_LCOLCR_LPE   DSI_LCOLCR_LPE_Msk
#define DSI_LPCR_DEP_Pos   (0U)
#define DSI_LPCR_DEP_Msk   (0x1UL << DSI_LPCR_DEP_Pos)
#define DSI_LPCR_DEP   DSI_LPCR_DEP_Msk
#define DSI_LPCR_VSP_Pos   (1U)
#define DSI_LPCR_VSP_Msk   (0x1UL << DSI_LPCR_VSP_Pos)
#define DSI_LPCR_VSP   DSI_LPCR_VSP_Msk
#define DSI_LPCR_HSP_Pos   (2U)
#define DSI_LPCR_HSP_Msk   (0x1UL << DSI_LPCR_HSP_Pos)
#define DSI_LPCR_HSP   DSI_LPCR_HSP_Msk
#define DSI_LPMCR_VLPSIZE_Pos   (0U)
#define DSI_LPMCR_VLPSIZE_Msk   (0xFFUL << DSI_LPMCR_VLPSIZE_Pos)
#define DSI_LPMCR_VLPSIZE   DSI_LPMCR_VLPSIZE_Msk
#define DSI_LPMCR_VLPSIZE0_Pos   (0U)
#define DSI_LPMCR_VLPSIZE0_Msk   (0x1UL << DSI_LPMCR_VLPSIZE0_Pos)
#define DSI_LPMCR_VLPSIZE0   DSI_LPMCR_VLPSIZE0_Msk
#define DSI_LPMCR_VLPSIZE1_Pos   (1U)
#define DSI_LPMCR_VLPSIZE1_Msk   (0x1UL << DSI_LPMCR_VLPSIZE1_Pos)
#define DSI_LPMCR_VLPSIZE1   DSI_LPMCR_VLPSIZE1_Msk
#define DSI_LPMCR_VLPSIZE2_Pos   (2U)
#define DSI_LPMCR_VLPSIZE2_Msk   (0x1UL << DSI_LPMCR_VLPSIZE2_Pos)
#define DSI_LPMCR_VLPSIZE2   DSI_LPMCR_VLPSIZE2_Msk
#define DSI_LPMCR_VLPSIZE3_Pos   (3U)
#define DSI_LPMCR_VLPSIZE3_Msk   (0x1UL << DSI_LPMCR_VLPSIZE3_Pos)
#define DSI_LPMCR_VLPSIZE3   DSI_LPMCR_VLPSIZE3_Msk
#define DSI_LPMCR_VLPSIZE4_Pos   (4U)
#define DSI_LPMCR_VLPSIZE4_Msk   (0x1UL << DSI_LPMCR_VLPSIZE4_Pos)
#define DSI_LPMCR_VLPSIZE4   DSI_LPMCR_VLPSIZE4_Msk
#define DSI_LPMCR_VLPSIZE5_Pos   (5U)
#define DSI_LPMCR_VLPSIZE5_Msk   (0x1UL << DSI_LPMCR_VLPSIZE5_Pos)
#define DSI_LPMCR_VLPSIZE5   DSI_LPMCR_VLPSIZE5_Msk
#define DSI_LPMCR_VLPSIZE6_Pos   (6U)
#define DSI_LPMCR_VLPSIZE6_Msk   (0x1UL << DSI_LPMCR_VLPSIZE6_Pos)
#define DSI_LPMCR_VLPSIZE6   DSI_LPMCR_VLPSIZE6_Msk
#define DSI_LPMCR_VLPSIZE7_Pos   (7U)
#define DSI_LPMCR_VLPSIZE7_Msk   (0x1UL << DSI_LPMCR_VLPSIZE7_Pos)
#define DSI_LPMCR_VLPSIZE7   DSI_LPMCR_VLPSIZE7_Msk
#define DSI_LPMCR_LPSIZE_Pos   (16U)
#define DSI_LPMCR_LPSIZE_Msk   (0xFFUL << DSI_LPMCR_LPSIZE_Pos)
#define DSI_LPMCR_LPSIZE   DSI_LPMCR_LPSIZE_Msk
#define DSI_LPMCR_LPSIZE0_Pos   (16U)
#define DSI_LPMCR_LPSIZE0_Msk   (0x1UL << DSI_LPMCR_LPSIZE0_Pos)
#define DSI_LPMCR_LPSIZE0   DSI_LPMCR_LPSIZE0_Msk
#define DSI_LPMCR_LPSIZE1_Pos   (17U)
#define DSI_LPMCR_LPSIZE1_Msk   (0x1UL << DSI_LPMCR_LPSIZE1_Pos)
#define DSI_LPMCR_LPSIZE1   DSI_LPMCR_LPSIZE1_Msk
#define DSI_LPMCR_LPSIZE2_Pos   (18U)
#define DSI_LPMCR_LPSIZE2_Msk   (0x1UL << DSI_LPMCR_LPSIZE2_Pos)
#define DSI_LPMCR_LPSIZE2   DSI_LPMCR_LPSIZE2_Msk
#define DSI_LPMCR_LPSIZE3_Pos   (19U)
#define DSI_LPMCR_LPSIZE3_Msk   (0x1UL << DSI_LPMCR_LPSIZE3_Pos)
#define DSI_LPMCR_LPSIZE3   DSI_LPMCR_LPSIZE3_Msk
#define DSI_LPMCR_LPSIZE4_Pos   (20U)
#define DSI_LPMCR_LPSIZE4_Msk   (0x1UL << DSI_LPMCR_LPSIZE4_Pos)
#define DSI_LPMCR_LPSIZE4   DSI_LPMCR_LPSIZE4_Msk
#define DSI_LPMCR_LPSIZE5_Pos   (21U)
#define DSI_LPMCR_LPSIZE5_Msk   (0x1UL << DSI_LPMCR_LPSIZE5_Pos)
#define DSI_LPMCR_LPSIZE5   DSI_LPMCR_LPSIZE5_Msk
#define DSI_LPMCR_LPSIZE6_Pos   (22U)
#define DSI_LPMCR_LPSIZE6_Msk   (0x1UL << DSI_LPMCR_LPSIZE6_Pos)
#define DSI_LPMCR_LPSIZE6   DSI_LPMCR_LPSIZE6_Msk
#define DSI_LPMCR_LPSIZE7_Pos   (23U)
#define DSI_LPMCR_LPSIZE7_Msk   (0x1UL << DSI_LPMCR_LPSIZE7_Pos)
#define DSI_LPMCR_LPSIZE7   DSI_LPMCR_LPSIZE7_Msk
#define DSI_PCR_ETTXE_Pos   (0U)
#define DSI_PCR_ETTXE_Msk   (0x1UL << DSI_PCR_ETTXE_Pos)
#define DSI_PCR_ETTXE   DSI_PCR_ETTXE_Msk
#define DSI_PCR_ETRXE_Pos   (1U)
#define DSI_PCR_ETRXE_Msk   (0x1UL << DSI_PCR_ETRXE_Pos)
#define DSI_PCR_ETRXE   DSI_PCR_ETRXE_Msk
#define DSI_PCR_BTAE_Pos   (2U)
#define DSI_PCR_BTAE_Msk   (0x1UL << DSI_PCR_BTAE_Pos)
#define DSI_PCR_BTAE   DSI_PCR_BTAE_Msk
#define DSI_PCR_ECCRXE_Pos   (3U)
#define DSI_PCR_ECCRXE_Msk   (0x1UL << DSI_PCR_ECCRXE_Pos)
#define DSI_PCR_ECCRXE   DSI_PCR_ECCRXE_Msk
#define DSI_PCR_CRCRXE_Pos   (4U)
#define DSI_PCR_CRCRXE_Msk   (0x1UL << DSI_PCR_CRCRXE_Pos)
#define DSI_PCR_CRCRXE   DSI_PCR_CRCRXE_Msk
#define DSI_PCR_ETTXLPE_Pos   (5U)
#define DSI_PCR_ETTXLPE_Msk   (0x1UL << DSI_PCR_ETTXLPE_Pos)
#define DSI_PCR_ETTXLPE   DSI_PCR_ETTXLPE_Msk
#define DSI_GVCIDR_VCIDRX_Pos   (0U)
#define DSI_GVCIDR_VCIDRX_Msk   (0x3UL << DSI_GVCIDR_VCIDRX_Pos)
#define DSI_GVCIDR_VCIDRX   DSI_GVCIDR_VCIDRX_Msk
#define DSI_GVCIDR_VCIDRX0_Pos   (0U)
#define DSI_GVCIDR_VCIDRX0_Msk   (0x1UL << DSI_GVCIDR_VCIDRX0_Pos)
#define DSI_GVCIDR_VCIDRX0   DSI_GVCIDR_VCIDRX0_Msk
#define DSI_GVCIDR_VCIDRX1_Pos   (1U)
#define DSI_GVCIDR_VCIDRX1_Msk   (0x1UL << DSI_GVCIDR_VCIDRX1_Pos)
#define DSI_GVCIDR_VCIDRX1   DSI_GVCIDR_VCIDRX1_Msk
#define DSI_GVCIDR_VCIDTX_Pos   (16U)
#define DSI_GVCIDR_VCIDTX_Msk   (0x3UL << DSI_GVCIDR_VCIDTX_Pos)
#define DSI_GVCIDR_VCIDTX   DSI_GVCIDR_VCIDTX_Msk
#define DSI_GVCIDR_VCIDTX0_Pos   (16U)
#define DSI_GVCIDR_VCIDTX0_Msk   (0x1UL << DSI_GVCIDR_VCIDTX0_Pos)
#define DSI_GVCIDR_VCIDTX0   DSI_GVCIDR_VCIDTX0_Msk
#define DSI_GVCIDR_VCIDTX1_Pos   (17U)
#define DSI_GVCIDR_VCIDTX1_Msk   (0x1UL << DSI_GVCIDR_VCIDRT1_Pos)
#define DSI_GVCIDR_VCIDTX1   DSI_GVCIDR_VCIDRT1_Msk
#define DSI_MCR_CMDM_Pos   (0U)
#define DSI_MCR_CMDM_Msk   (0x1UL << DSI_MCR_CMDM_Pos)
#define DSI_MCR_CMDM   DSI_MCR_CMDM_Msk
#define DSI_VMCR_VMT_Pos   (0U)
#define DSI_VMCR_VMT_Msk   (0x3UL << DSI_VMCR_VMT_Pos)
#define DSI_VMCR_VMT   DSI_VMCR_VMT_Msk
#define DSI_VMCR_VMT0_Pos   (0U)
#define DSI_VMCR_VMT0_Msk   (0x1UL << DSI_VMCR_VMT0_Pos)
#define DSI_VMCR_VMT0   DSI_VMCR_VMT0_Msk
#define DSI_VMCR_VMT1_Pos   (1U)
#define DSI_VMCR_VMT1_Msk   (0x1UL << DSI_VMCR_VMT1_Pos)
#define DSI_VMCR_VMT1   DSI_VMCR_VMT1_Msk
#define DSI_VMCR_LPVSAE_Pos   (8U)
#define DSI_VMCR_LPVSAE_Msk   (0x1UL << DSI_VMCR_LPVSAE_Pos)
#define DSI_VMCR_LPVSAE   DSI_VMCR_LPVSAE_Msk
#define DSI_VMCR_LPVBPE_Pos   (9U)
#define DSI_VMCR_LPVBPE_Msk   (0x1UL << DSI_VMCR_LPVBPE_Pos)
#define DSI_VMCR_LPVBPE   DSI_VMCR_LPVBPE_Msk
#define DSI_VMCR_LPVFPE_Pos   (10U)
#define DSI_VMCR_LPVFPE_Msk   (0x1UL << DSI_VMCR_LPVFPE_Pos)
#define DSI_VMCR_LPVFPE   DSI_VMCR_LPVFPE_Msk
#define DSI_VMCR_LPVAE_Pos   (11U)
#define DSI_VMCR_LPVAE_Msk   (0x1UL << DSI_VMCR_LPVAE_Pos)
#define DSI_VMCR_LPVAE   DSI_VMCR_LPVAE_Msk
#define DSI_VMCR_LPHBPE_Pos   (12U)
#define DSI_VMCR_LPHBPE_Msk   (0x1UL << DSI_VMCR_LPHBPE_Pos)
#define DSI_VMCR_LPHBPE   DSI_VMCR_LPHBPE_Msk
#define DSI_VMCR_LPHFPE_Pos   (13U)
#define DSI_VMCR_LPHFPE_Msk   (0x1UL << DSI_VMCR_LPHFPE_Pos)
#define DSI_VMCR_LPHFPE   DSI_VMCR_LPHFPE_Msk
#define DSI_VMCR_FBTAAE_Pos   (14U)
#define DSI_VMCR_FBTAAE_Msk   (0x1UL << DSI_VMCR_FBTAAE_Pos)
#define DSI_VMCR_FBTAAE   DSI_VMCR_FBTAAE_Msk
#define DSI_VMCR_LPCE_Pos   (15U)
#define DSI_VMCR_LPCE_Msk   (0x1UL << DSI_VMCR_LPCE_Pos)
#define DSI_VMCR_LPCE   DSI_VMCR_LPCE_Msk
#define DSI_VMCR_PGE_Pos   (16U)
#define DSI_VMCR_PGE_Msk   (0x1UL << DSI_VMCR_PGE_Pos)
#define DSI_VMCR_PGE   DSI_VMCR_PGE_Msk
#define DSI_VMCR_PGM_Pos   (20U)
#define DSI_VMCR_PGM_Msk   (0x1UL << DSI_VMCR_PGM_Pos)
#define DSI_VMCR_PGM   DSI_VMCR_PGM_Msk
#define DSI_VMCR_PGO_Pos   (24U)
#define DSI_VMCR_PGO_Msk   (0x1UL << DSI_VMCR_PGO_Pos)
#define DSI_VMCR_PGO   DSI_VMCR_PGO_Msk
#define DSI_VPCR_VPSIZE_Pos   (0U)
#define DSI_VPCR_VPSIZE_Msk   (0x3FFFUL << DSI_VPCR_VPSIZE_Pos)
#define DSI_VPCR_VPSIZE   DSI_VPCR_VPSIZE_Msk
#define DSI_VPCR_VPSIZE0_Pos   (0U)
#define DSI_VPCR_VPSIZE0_Msk   (0x1UL << DSI_VPCR_VPSIZE0_Pos)
#define DSI_VPCR_VPSIZE0   DSI_VPCR_VPSIZE0_Msk
#define DSI_VPCR_VPSIZE1_Pos   (1U)
#define DSI_VPCR_VPSIZE1_Msk   (0x1UL << DSI_VPCR_VPSIZE1_Pos)
#define DSI_VPCR_VPSIZE1   DSI_VPCR_VPSIZE1_Msk
#define DSI_VPCR_VPSIZE2_Pos   (2U)
#define DSI_VPCR_VPSIZE2_Msk   (0x1UL << DSI_VPCR_VPSIZE2_Pos)
#define DSI_VPCR_VPSIZE2   DSI_VPCR_VPSIZE2_Msk
#define DSI_VPCR_VPSIZE3_Pos   (3U)
#define DSI_VPCR_VPSIZE3_Msk   (0x1UL << DSI_VPCR_VPSIZE3_Pos)
#define DSI_VPCR_VPSIZE3   DSI_VPCR_VPSIZE3_Msk
#define DSI_VPCR_VPSIZE4_Pos   (4U)
#define DSI_VPCR_VPSIZE4_Msk   (0x1UL << DSI_VPCR_VPSIZE4_Pos)
#define DSI_VPCR_VPSIZE4   DSI_VPCR_VPSIZE4_Msk
#define DSI_VPCR_VPSIZE5_Pos   (5U)
#define DSI_VPCR_VPSIZE5_Msk   (0x1UL << DSI_VPCR_VPSIZE5_Pos)
#define DSI_VPCR_VPSIZE5   DSI_VPCR_VPSIZE5_Msk
#define DSI_VPCR_VPSIZE6_Pos   (6U)
#define DSI_VPCR_VPSIZE6_Msk   (0x1UL << DSI_VPCR_VPSIZE6_Pos)
#define DSI_VPCR_VPSIZE6   DSI_VPCR_VPSIZE6_Msk
#define DSI_VPCR_VPSIZE7_Pos   (7U)
#define DSI_VPCR_VPSIZE7_Msk   (0x1UL << DSI_VPCR_VPSIZE7_Pos)
#define DSI_VPCR_VPSIZE7   DSI_VPCR_VPSIZE7_Msk
#define DSI_VPCR_VPSIZE8_Pos   (8U)
#define DSI_VPCR_VPSIZE8_Msk   (0x1UL << DSI_VPCR_VPSIZE8_Pos)
#define DSI_VPCR_VPSIZE8   DSI_VPCR_VPSIZE8_Msk
#define DSI_VPCR_VPSIZE9_Pos   (9U)
#define DSI_VPCR_VPSIZE9_Msk   (0x1UL << DSI_VPCR_VPSIZE9_Pos)
#define DSI_VPCR_VPSIZE9   DSI_VPCR_VPSIZE9_Msk
#define DSI_VPCR_VPSIZE10_Pos   (10U)
#define DSI_VPCR_VPSIZE10_Msk   (0x1UL << DSI_VPCR_VPSIZE10_Pos)
#define DSI_VPCR_VPSIZE10   DSI_VPCR_VPSIZE10_Msk
#define DSI_VPCR_VPSIZE11_Pos   (11U)
#define DSI_VPCR_VPSIZE11_Msk   (0x1UL << DSI_VPCR_VPSIZE11_Pos)
#define DSI_VPCR_VPSIZE11   DSI_VPCR_VPSIZE11_Msk
#define DSI_VPCR_VPSIZE12_Pos   (12U)
#define DSI_VPCR_VPSIZE12_Msk   (0x1UL << DSI_VPCR_VPSIZE12_Pos)
#define DSI_VPCR_VPSIZE12   DSI_VPCR_VPSIZE12_Msk
#define DSI_VPCR_VPSIZE13_Pos   (13U)
#define DSI_VPCR_VPSIZE13_Msk   (0x1UL << DSI_VPCR_VPSIZE13_Pos)
#define DSI_VPCR_VPSIZE13   DSI_VPCR_VPSIZE13_Msk
#define DSI_VCCR_NUMC_Pos   (0U)
#define DSI_VCCR_NUMC_Msk   (0x1FFFUL << DSI_VCCR_NUMC_Pos)
#define DSI_VCCR_NUMC   DSI_VCCR_NUMC_Msk
#define DSI_VCCR_NUMC0_Pos   (0U)
#define DSI_VCCR_NUMC0_Msk   (0x1UL << DSI_VCCR_NUMC0_Pos)
#define DSI_VCCR_NUMC0   DSI_VCCR_NUMC0_Msk
#define DSI_VCCR_NUMC1_Pos   (1U)
#define DSI_VCCR_NUMC1_Msk   (0x1UL << DSI_VCCR_NUMC1_Pos)
#define DSI_VCCR_NUMC1   DSI_VCCR_NUMC1_Msk
#define DSI_VCCR_NUMC2_Pos   (2U)
#define DSI_VCCR_NUMC2_Msk   (0x1UL << DSI_VCCR_NUMC2_Pos)
#define DSI_VCCR_NUMC2   DSI_VCCR_NUMC2_Msk
#define DSI_VCCR_NUMC3_Pos   (3U)
#define DSI_VCCR_NUMC3_Msk   (0x1UL << DSI_VCCR_NUMC3_Pos)
#define DSI_VCCR_NUMC3   DSI_VCCR_NUMC3_Msk
#define DSI_VCCR_NUMC4_Pos   (4U)
#define DSI_VCCR_NUMC4_Msk   (0x1UL << DSI_VCCR_NUMC4_Pos)
#define DSI_VCCR_NUMC4   DSI_VCCR_NUMC4_Msk
#define DSI_VCCR_NUMC5_Pos   (5U)
#define DSI_VCCR_NUMC5_Msk   (0x1UL << DSI_VCCR_NUMC5_Pos)
#define DSI_VCCR_NUMC5   DSI_VCCR_NUMC5_Msk
#define DSI_VCCR_NUMC6_Pos   (6U)
#define DSI_VCCR_NUMC6_Msk   (0x1UL << DSI_VCCR_NUMC6_Pos)
#define DSI_VCCR_NUMC6   DSI_VCCR_NUMC6_Msk
#define DSI_VCCR_NUMC7_Pos   (7U)
#define DSI_VCCR_NUMC7_Msk   (0x1UL << DSI_VCCR_NUMC7_Pos)
#define DSI_VCCR_NUMC7   DSI_VCCR_NUMC7_Msk
#define DSI_VCCR_NUMC8_Pos   (8U)
#define DSI_VCCR_NUMC8_Msk   (0x1UL << DSI_VCCR_NUMC8_Pos)
#define DSI_VCCR_NUMC8   DSI_VCCR_NUMC8_Msk
#define DSI_VCCR_NUMC9_Pos   (9U)
#define DSI_VCCR_NUMC9_Msk   (0x1UL << DSI_VCCR_NUMC9_Pos)
#define DSI_VCCR_NUMC9   DSI_VCCR_NUMC9_Msk
#define DSI_VCCR_NUMC10_Pos   (10U)
#define DSI_VCCR_NUMC10_Msk   (0x1UL << DSI_VCCR_NUMC10_Pos)
#define DSI_VCCR_NUMC10   DSI_VCCR_NUMC10_Msk
#define DSI_VCCR_NUMC11_Pos   (11U)
#define DSI_VCCR_NUMC11_Msk   (0x1UL << DSI_VCCR_NUMC11_Pos)
#define DSI_VCCR_NUMC11   DSI_VCCR_NUMC11_Msk
#define DSI_VCCR_NUMC12_Pos   (12U)
#define DSI_VCCR_NUMC12_Msk   (0x1UL << DSI_VCCR_NUMC12_Pos)
#define DSI_VCCR_NUMC12   DSI_VCCR_NUMC12_Msk
#define DSI_VNPCR_NPSIZE_Pos   (0U)
#define DSI_VNPCR_NPSIZE_Msk   (0x1FFFUL << DSI_VNPCR_NPSIZE_Pos)
#define DSI_VNPCR_NPSIZE   DSI_VNPCR_NPSIZE_Msk
#define DSI_VNPCR_NPSIZE0_Pos   (0U)
#define DSI_VNPCR_NPSIZE0_Msk   (0x1UL << DSI_VNPCR_NPSIZE0_Pos)
#define DSI_VNPCR_NPSIZE0   DSI_VNPCR_NPSIZE0_Msk
#define DSI_VNPCR_NPSIZE1_Pos   (1U)
#define DSI_VNPCR_NPSIZE1_Msk   (0x1UL << DSI_VNPCR_NPSIZE1_Pos)
#define DSI_VNPCR_NPSIZE1   DSI_VNPCR_NPSIZE1_Msk
#define DSI_VNPCR_NPSIZE2_Pos   (2U)
#define DSI_VNPCR_NPSIZE2_Msk   (0x1UL << DSI_VNPCR_NPSIZE2_Pos)
#define DSI_VNPCR_NPSIZE2   DSI_VNPCR_NPSIZE2_Msk
#define DSI_VNPCR_NPSIZE3_Pos   (3U)
#define DSI_VNPCR_NPSIZE3_Msk   (0x1UL << DSI_VNPCR_NPSIZE3_Pos)
#define DSI_VNPCR_NPSIZE3   DSI_VNPCR_NPSIZE3_Msk
#define DSI_VNPCR_NPSIZE4_Pos   (4U)
#define DSI_VNPCR_NPSIZE4_Msk   (0x1UL << DSI_VNPCR_NPSIZE4_Pos)
#define DSI_VNPCR_NPSIZE4   DSI_VNPCR_NPSIZE4_Msk
#define DSI_VNPCR_NPSIZE5_Pos   (5U)
#define DSI_VNPCR_NPSIZE5_Msk   (0x1UL << DSI_VNPCR_NPSIZE5_Pos)
#define DSI_VNPCR_NPSIZE5   DSI_VNPCR_NPSIZE5_Msk
#define DSI_VNPCR_NPSIZE6_Pos   (6U)
#define DSI_VNPCR_NPSIZE6_Msk   (0x1UL << DSI_VNPCR_NPSIZE6_Pos)
#define DSI_VNPCR_NPSIZE6   DSI_VNPCR_NPSIZE6_Msk
#define DSI_VNPCR_NPSIZE7_Pos   (7U)
#define DSI_VNPCR_NPSIZE7_Msk   (0x1UL << DSI_VNPCR_NPSIZE7_Pos)
#define DSI_VNPCR_NPSIZE7   DSI_VNPCR_NPSIZE7_Msk
#define DSI_VNPCR_NPSIZE8_Pos   (8U)
#define DSI_VNPCR_NPSIZE8_Msk   (0x1UL << DSI_VNPCR_NPSIZE8_Pos)
#define DSI_VNPCR_NPSIZE8   DSI_VNPCR_NPSIZE8_Msk
#define DSI_VNPCR_NPSIZE9_Pos   (9U)
#define DSI_VNPCR_NPSIZE9_Msk   (0x1UL << DSI_VNPCR_NPSIZE9_Pos)
#define DSI_VNPCR_NPSIZE9   DSI_VNPCR_NPSIZE9_Msk
#define DSI_VNPCR_NPSIZE10_Pos   (10U)
#define DSI_VNPCR_NPSIZE10_Msk   (0x1UL << DSI_VNPCR_NPSIZE10_Pos)
#define DSI_VNPCR_NPSIZE10   DSI_VNPCR_NPSIZE10_Msk
#define DSI_VNPCR_NPSIZE11_Pos   (11U)
#define DSI_VNPCR_NPSIZE11_Msk   (0x1UL << DSI_VNPCR_NPSIZE11_Pos)
#define DSI_VNPCR_NPSIZE11   DSI_VNPCR_NPSIZE11_Msk
#define DSI_VNPCR_NPSIZE12_Pos   (12U)
#define DSI_VNPCR_NPSIZE12_Msk   (0x1UL << DSI_VNPCR_NPSIZE12_Pos)
#define DSI_VNPCR_NPSIZE12   DSI_VNPCR_NPSIZE12_Msk
#define DSI_VHSACR_HSA_Pos   (0U)
#define DSI_VHSACR_HSA_Msk   (0xFFFUL << DSI_VHSACR_HSA_Pos)
#define DSI_VHSACR_HSA   DSI_VHSACR_HSA_Msk
#define DSI_VHSACR_HSA0_Pos   (0U)
#define DSI_VHSACR_HSA0_Msk   (0x1UL << DSI_VHSACR_HSA0_Pos)
#define DSI_VHSACR_HSA0   DSI_VHSACR_HSA0_Msk
#define DSI_VHSACR_HSA1_Pos   (1U)
#define DSI_VHSACR_HSA1_Msk   (0x1UL << DSI_VHSACR_HSA1_Pos)
#define DSI_VHSACR_HSA1   DSI_VHSACR_HSA1_Msk
#define DSI_VHSACR_HSA2_Pos   (2U)
#define DSI_VHSACR_HSA2_Msk   (0x1UL << DSI_VHSACR_HSA2_Pos)
#define DSI_VHSACR_HSA2   DSI_VHSACR_HSA2_Msk
#define DSI_VHSACR_HSA3_Pos   (3U)
#define DSI_VHSACR_HSA3_Msk   (0x1UL << DSI_VHSACR_HSA3_Pos)
#define DSI_VHSACR_HSA3   DSI_VHSACR_HSA3_Msk
#define DSI_VHSACR_HSA4_Pos   (4U)
#define DSI_VHSACR_HSA4_Msk   (0x1UL << DSI_VHSACR_HSA4_Pos)
#define DSI_VHSACR_HSA4   DSI_VHSACR_HSA4_Msk
#define DSI_VHSACR_HSA5_Pos   (5U)
#define DSI_VHSACR_HSA5_Msk   (0x1UL << DSI_VHSACR_HSA5_Pos)
#define DSI_VHSACR_HSA5   DSI_VHSACR_HSA5_Msk
#define DSI_VHSACR_HSA6_Pos   (6U)
#define DSI_VHSACR_HSA6_Msk   (0x1UL << DSI_VHSACR_HSA6_Pos)
#define DSI_VHSACR_HSA6   DSI_VHSACR_HSA6_Msk
#define DSI_VHSACR_HSA7_Pos   (7U)
#define DSI_VHSACR_HSA7_Msk   (0x1UL << DSI_VHSACR_HSA7_Pos)
#define DSI_VHSACR_HSA7   DSI_VHSACR_HSA7_Msk
#define DSI_VHSACR_HSA8_Pos   (8U)
#define DSI_VHSACR_HSA8_Msk   (0x1UL << DSI_VHSACR_HSA8_Pos)
#define DSI_VHSACR_HSA8   DSI_VHSACR_HSA8_Msk
#define DSI_VHSACR_HSA9_Pos   (9U)
#define DSI_VHSACR_HSA9_Msk   (0x1UL << DSI_VHSACR_HSA9_Pos)
#define DSI_VHSACR_HSA9   DSI_VHSACR_HSA9_Msk
#define DSI_VHSACR_HSA10_Pos   (10U)
#define DSI_VHSACR_HSA10_Msk   (0x1UL << DSI_VHSACR_HSA10_Pos)
#define DSI_VHSACR_HSA10   DSI_VHSACR_HSA10_Msk
#define DSI_VHSACR_HSA11_Pos   (11U)
#define DSI_VHSACR_HSA11_Msk   (0x1UL << DSI_VHSACR_HSA11_Pos)
#define DSI_VHSACR_HSA11   DSI_VHSACR_HSA11_Msk
#define DSI_VHBPCR_HBP_Pos   (0U)
#define DSI_VHBPCR_HBP_Msk   (0xFFFUL << DSI_VHBPCR_HBP_Pos)
#define DSI_VHBPCR_HBP   DSI_VHBPCR_HBP_Msk
#define DSI_VHBPCR_HBP0_Pos   (0U)
#define DSI_VHBPCR_HBP0_Msk   (0x1UL << DSI_VHBPCR_HBP0_Pos)
#define DSI_VHBPCR_HBP0   DSI_VHBPCR_HBP0_Msk
#define DSI_VHBPCR_HBP1_Pos   (1U)
#define DSI_VHBPCR_HBP1_Msk   (0x1UL << DSI_VHBPCR_HBP1_Pos)
#define DSI_VHBPCR_HBP1   DSI_VHBPCR_HBP1_Msk
#define DSI_VHBPCR_HBP2_Pos   (2U)
#define DSI_VHBPCR_HBP2_Msk   (0x1UL << DSI_VHBPCR_HBP2_Pos)
#define DSI_VHBPCR_HBP2   DSI_VHBPCR_HBP2_Msk
#define DSI_VHBPCR_HBP3_Pos   (3U)
#define DSI_VHBPCR_HBP3_Msk   (0x1UL << DSI_VHBPCR_HBP3_Pos)
#define DSI_VHBPCR_HBP3   DSI_VHBPCR_HBP3_Msk
#define DSI_VHBPCR_HBP4_Pos   (4U)
#define DSI_VHBPCR_HBP4_Msk   (0x1UL << DSI_VHBPCR_HBP4_Pos)
#define DSI_VHBPCR_HBP4   DSI_VHBPCR_HBP4_Msk
#define DSI_VHBPCR_HBP5_Pos   (5U)
#define DSI_VHBPCR_HBP5_Msk   (0x1UL << DSI_VHBPCR_HBP5_Pos)
#define DSI_VHBPCR_HBP5   DSI_VHBPCR_HBP5_Msk
#define DSI_VHBPCR_HBP6_Pos   (6U)
#define DSI_VHBPCR_HBP6_Msk   (0x1UL << DSI_VHBPCR_HBP6_Pos)
#define DSI_VHBPCR_HBP6   DSI_VHBPCR_HBP6_Msk
#define DSI_VHBPCR_HBP7_Pos   (7U)
#define DSI_VHBPCR_HBP7_Msk   (0x1UL << DSI_VHBPCR_HBP7_Pos)
#define DSI_VHBPCR_HBP7   DSI_VHBPCR_HBP7_Msk
#define DSI_VHBPCR_HBP8_Pos   (8U)
#define DSI_VHBPCR_HBP8_Msk   (0x1UL << DSI_VHBPCR_HBP8_Pos)
#define DSI_VHBPCR_HBP8   DSI_VHBPCR_HBP8_Msk
#define DSI_VHBPCR_HBP9_Pos   (9U)
#define DSI_VHBPCR_HBP9_Msk   (0x1UL << DSI_VHBPCR_HBP9_Pos)
#define DSI_VHBPCR_HBP9   DSI_VHBPCR_HBP9_Msk
#define DSI_VHBPCR_HBP10_Pos   (10U)
#define DSI_VHBPCR_HBP10_Msk   (0x1UL << DSI_VHBPCR_HBP10_Pos)
#define DSI_VHBPCR_HBP10   DSI_VHBPCR_HBP10_Msk
#define DSI_VHBPCR_HBP11_Pos   (11U)
#define DSI_VHBPCR_HBP11_Msk   (0x1UL << DSI_VHBPCR_HBP11_Pos)
#define DSI_VHBPCR_HBP11   DSI_VHBPCR_HBP11_Msk
#define DSI_VLCR_HLINE_Pos   (0U)
#define DSI_VLCR_HLINE_Msk   (0x7FFFUL << DSI_VLCR_HLINE_Pos)
#define DSI_VLCR_HLINE   DSI_VLCR_HLINE_Msk
#define DSI_VLCR_HLINE0_Pos   (0U)
#define DSI_VLCR_HLINE0_Msk   (0x1UL << DSI_VLCR_HLINE0_Pos)
#define DSI_VLCR_HLINE0   DSI_VLCR_HLINE0_Msk
#define DSI_VLCR_HLINE1_Pos   (1U)
#define DSI_VLCR_HLINE1_Msk   (0x1UL << DSI_VLCR_HLINE1_Pos)
#define DSI_VLCR_HLINE1   DSI_VLCR_HLINE1_Msk
#define DSI_VLCR_HLINE2_Pos   (2U)
#define DSI_VLCR_HLINE2_Msk   (0x1UL << DSI_VLCR_HLINE2_Pos)
#define DSI_VLCR_HLINE2   DSI_VLCR_HLINE2_Msk
#define DSI_VLCR_HLINE3_Pos   (3U)
#define DSI_VLCR_HLINE3_Msk   (0x1UL << DSI_VLCR_HLINE3_Pos)
#define DSI_VLCR_HLINE3   DSI_VLCR_HLINE3_Msk
#define DSI_VLCR_HLINE4_Pos   (4U)
#define DSI_VLCR_HLINE4_Msk   (0x1UL << DSI_VLCR_HLINE4_Pos)
#define DSI_VLCR_HLINE4   DSI_VLCR_HLINE4_Msk
#define DSI_VLCR_HLINE5_Pos   (5U)
#define DSI_VLCR_HLINE5_Msk   (0x1UL << DSI_VLCR_HLINE5_Pos)
#define DSI_VLCR_HLINE5   DSI_VLCR_HLINE5_Msk
#define DSI_VLCR_HLINE6_Pos   (6U)
#define DSI_VLCR_HLINE6_Msk   (0x1UL << DSI_VLCR_HLINE6_Pos)
#define DSI_VLCR_HLINE6   DSI_VLCR_HLINE6_Msk
#define DSI_VLCR_HLINE7_Pos   (7U)
#define DSI_VLCR_HLINE7_Msk   (0x1UL << DSI_VLCR_HLINE7_Pos)
#define DSI_VLCR_HLINE7   DSI_VLCR_HLINE7_Msk
#define DSI_VLCR_HLINE8_Pos   (8U)
#define DSI_VLCR_HLINE8_Msk   (0x1UL << DSI_VLCR_HLINE8_Pos)
#define DSI_VLCR_HLINE8   DSI_VLCR_HLINE8_Msk
#define DSI_VLCR_HLINE9_Pos   (9U)
#define DSI_VLCR_HLINE9_Msk   (0x1UL << DSI_VLCR_HLINE9_Pos)
#define DSI_VLCR_HLINE9   DSI_VLCR_HLINE9_Msk
#define DSI_VLCR_HLINE10_Pos   (10U)
#define DSI_VLCR_HLINE10_Msk   (0x1UL << DSI_VLCR_HLINE10_Pos)
#define DSI_VLCR_HLINE10   DSI_VLCR_HLINE10_Msk
#define DSI_VLCR_HLINE11_Pos   (11U)
#define DSI_VLCR_HLINE11_Msk   (0x1UL << DSI_VLCR_HLINE11_Pos)
#define DSI_VLCR_HLINE11   DSI_VLCR_HLINE11_Msk
#define DSI_VLCR_HLINE12_Pos   (12U)
#define DSI_VLCR_HLINE12_Msk   (0x1UL << DSI_VLCR_HLINE12_Pos)
#define DSI_VLCR_HLINE12   DSI_VLCR_HLINE12_Msk
#define DSI_VLCR_HLINE13_Pos   (13U)
#define DSI_VLCR_HLINE13_Msk   (0x1UL << DSI_VLCR_HLINE13_Pos)
#define DSI_VLCR_HLINE13   DSI_VLCR_HLINE13_Msk
#define DSI_VLCR_HLINE14_Pos   (14U)
#define DSI_VLCR_HLINE14_Msk   (0x1UL << DSI_VLCR_HLINE14_Pos)
#define DSI_VLCR_HLINE14   DSI_VLCR_HLINE14_Msk
#define DSI_VVSACR_VSA_Pos   (0U)
#define DSI_VVSACR_VSA_Msk   (0x3FFUL << DSI_VVSACR_VSA_Pos)
#define DSI_VVSACR_VSA   DSI_VVSACR_VSA_Msk
#define DSI_VVSACR_VSA0_Pos   (0U)
#define DSI_VVSACR_VSA0_Msk   (0x1UL << DSI_VVSACR_VSA0_Pos)
#define DSI_VVSACR_VSA0   DSI_VVSACR_VSA0_Msk
#define DSI_VVSACR_VSA1_Pos   (1U)
#define DSI_VVSACR_VSA1_Msk   (0x1UL << DSI_VVSACR_VSA1_Pos)
#define DSI_VVSACR_VSA1   DSI_VVSACR_VSA1_Msk
#define DSI_VVSACR_VSA2_Pos   (2U)
#define DSI_VVSACR_VSA2_Msk   (0x1UL << DSI_VVSACR_VSA2_Pos)
#define DSI_VVSACR_VSA2   DSI_VVSACR_VSA2_Msk
#define DSI_VVSACR_VSA3_Pos   (3U)
#define DSI_VVSACR_VSA3_Msk   (0x1UL << DSI_VVSACR_VSA3_Pos)
#define DSI_VVSACR_VSA3   DSI_VVSACR_VSA3_Msk
#define DSI_VVSACR_VSA4_Pos   (4U)
#define DSI_VVSACR_VSA4_Msk   (0x1UL << DSI_VVSACR_VSA4_Pos)
#define DSI_VVSACR_VSA4   DSI_VVSACR_VSA4_Msk
#define DSI_VVSACR_VSA5_Pos   (5U)
#define DSI_VVSACR_VSA5_Msk   (0x1UL << DSI_VVSACR_VSA5_Pos)
#define DSI_VVSACR_VSA5   DSI_VVSACR_VSA5_Msk
#define DSI_VVSACR_VSA6_Pos   (6U)
#define DSI_VVSACR_VSA6_Msk   (0x1UL << DSI_VVSACR_VSA6_Pos)
#define DSI_VVSACR_VSA6   DSI_VVSACR_VSA6_Msk
#define DSI_VVSACR_VSA7_Pos   (7U)
#define DSI_VVSACR_VSA7_Msk   (0x1UL << DSI_VVSACR_VSA7_Pos)
#define DSI_VVSACR_VSA7   DSI_VVSACR_VSA7_Msk
#define DSI_VVSACR_VSA8_Pos   (8U)
#define DSI_VVSACR_VSA8_Msk   (0x1UL << DSI_VVSACR_VSA8_Pos)
#define DSI_VVSACR_VSA8   DSI_VVSACR_VSA8_Msk
#define DSI_VVSACR_VSA9_Pos   (9U)
#define DSI_VVSACR_VSA9_Msk   (0x1UL << DSI_VVSACR_VSA9_Pos)
#define DSI_VVSACR_VSA9   DSI_VVSACR_VSA9_Msk
#define DSI_VVBPCR_VBP_Pos   (0U)
#define DSI_VVBPCR_VBP_Msk   (0x3FFUL << DSI_VVBPCR_VBP_Pos)
#define DSI_VVBPCR_VBP   DSI_VVBPCR_VBP_Msk
#define DSI_VVBPCR_VBP0_Pos   (0U)
#define DSI_VVBPCR_VBP0_Msk   (0x1UL << DSI_VVBPCR_VBP0_Pos)
#define DSI_VVBPCR_VBP0   DSI_VVBPCR_VBP0_Msk
#define DSI_VVBPCR_VBP1_Pos   (1U)
#define DSI_VVBPCR_VBP1_Msk   (0x1UL << DSI_VVBPCR_VBP1_Pos)
#define DSI_VVBPCR_VBP1   DSI_VVBPCR_VBP1_Msk
#define DSI_VVBPCR_VBP2_Pos   (2U)
#define DSI_VVBPCR_VBP2_Msk   (0x1UL << DSI_VVBPCR_VBP2_Pos)
#define DSI_VVBPCR_VBP2   DSI_VVBPCR_VBP2_Msk
#define DSI_VVBPCR_VBP3_Pos   (3U)
#define DSI_VVBPCR_VBP3_Msk   (0x1UL << DSI_VVBPCR_VBP3_Pos)
#define DSI_VVBPCR_VBP3   DSI_VVBPCR_VBP3_Msk
#define DSI_VVBPCR_VBP4_Pos   (4U)
#define DSI_VVBPCR_VBP4_Msk   (0x1UL << DSI_VVBPCR_VBP4_Pos)
#define DSI_VVBPCR_VBP4   DSI_VVBPCR_VBP4_Msk
#define DSI_VVBPCR_VBP5_Pos   (5U)
#define DSI_VVBPCR_VBP5_Msk   (0x1UL << DSI_VVBPCR_VBP5_Pos)
#define DSI_VVBPCR_VBP5   DSI_VVBPCR_VBP5_Msk
#define DSI_VVBPCR_VBP6_Pos   (6U)
#define DSI_VVBPCR_VBP6_Msk   (0x1UL << DSI_VVBPCR_VBP6_Pos)
#define DSI_VVBPCR_VBP6   DSI_VVBPCR_VBP6_Msk
#define DSI_VVBPCR_VBP7_Pos   (7U)
#define DSI_VVBPCR_VBP7_Msk   (0x1UL << DSI_VVBPCR_VBP7_Pos)
#define DSI_VVBPCR_VBP7   DSI_VVBPCR_VBP7_Msk
#define DSI_VVBPCR_VBP8_Pos   (8U)
#define DSI_VVBPCR_VBP8_Msk   (0x1UL << DSI_VVBPCR_VBP8_Pos)
#define DSI_VVBPCR_VBP8   DSI_VVBPCR_VBP8_Msk
#define DSI_VVBPCR_VBP9_Pos   (9U)
#define DSI_VVBPCR_VBP9_Msk   (0x1UL << DSI_VVBPCR_VBP9_Pos)
#define DSI_VVBPCR_VBP9   DSI_VVBPCR_VBP9_Msk
#define DSI_VVFPCR_VFP_Pos   (0U)
#define DSI_VVFPCR_VFP_Msk   (0x3FFUL << DSI_VVFPCR_VFP_Pos)
#define DSI_VVFPCR_VFP   DSI_VVFPCR_VFP_Msk
#define DSI_VVFPCR_VFP0_Pos   (0U)
#define DSI_VVFPCR_VFP0_Msk   (0x1UL << DSI_VVFPCR_VFP0_Pos)
#define DSI_VVFPCR_VFP0   DSI_VVFPCR_VFP0_Msk
#define DSI_VVFPCR_VFP1_Pos   (1U)
#define DSI_VVFPCR_VFP1_Msk   (0x1UL << DSI_VVFPCR_VFP1_Pos)
#define DSI_VVFPCR_VFP1   DSI_VVFPCR_VFP1_Msk
#define DSI_VVFPCR_VFP2_Pos   (2U)
#define DSI_VVFPCR_VFP2_Msk   (0x1UL << DSI_VVFPCR_VFP2_Pos)
#define DSI_VVFPCR_VFP2   DSI_VVFPCR_VFP2_Msk
#define DSI_VVFPCR_VFP3_Pos   (3U)
#define DSI_VVFPCR_VFP3_Msk   (0x1UL << DSI_VVFPCR_VFP3_Pos)
#define DSI_VVFPCR_VFP3   DSI_VVFPCR_VFP3_Msk
#define DSI_VVFPCR_VFP4_Pos   (4U)
#define DSI_VVFPCR_VFP4_Msk   (0x1UL << DSI_VVFPCR_VFP4_Pos)
#define DSI_VVFPCR_VFP4   DSI_VVFPCR_VFP4_Msk
#define DSI_VVFPCR_VFP5_Pos   (5U)
#define DSI_VVFPCR_VFP5_Msk   (0x1UL << DSI_VVFPCR_VFP5_Pos)
#define DSI_VVFPCR_VFP5   DSI_VVFPCR_VFP5_Msk
#define DSI_VVFPCR_VFP6_Pos   (6U)
#define DSI_VVFPCR_VFP6_Msk   (0x1UL << DSI_VVFPCR_VFP6_Pos)
#define DSI_VVFPCR_VFP6   DSI_VVFPCR_VFP6_Msk
#define DSI_VVFPCR_VFP7_Pos   (7U)
#define DSI_VVFPCR_VFP7_Msk   (0x1UL << DSI_VVFPCR_VFP7_Pos)
#define DSI_VVFPCR_VFP7   DSI_VVFPCR_VFP7_Msk
#define DSI_VVFPCR_VFP8_Pos   (8U)
#define DSI_VVFPCR_VFP8_Msk   (0x1UL << DSI_VVFPCR_VFP8_Pos)
#define DSI_VVFPCR_VFP8   DSI_VVFPCR_VFP8_Msk
#define DSI_VVFPCR_VFP9_Pos   (9U)
#define DSI_VVFPCR_VFP9_Msk   (0x1UL << DSI_VVFPCR_VFP9_Pos)
#define DSI_VVFPCR_VFP9   DSI_VVFPCR_VFP9_Msk
#define DSI_VVACR_VA_Pos   (0U)
#define DSI_VVACR_VA_Msk   (0x3FFFUL << DSI_VVACR_VA_Pos)
#define DSI_VVACR_VA   DSI_VVACR_VA_Msk
#define DSI_VVACR_VA0_Pos   (0U)
#define DSI_VVACR_VA0_Msk   (0x1UL << DSI_VVACR_VA0_Pos)
#define DSI_VVACR_VA0   DSI_VVACR_VA0_Msk
#define DSI_VVACR_VA1_Pos   (1U)
#define DSI_VVACR_VA1_Msk   (0x1UL << DSI_VVACR_VA1_Pos)
#define DSI_VVACR_VA1   DSI_VVACR_VA1_Msk
#define DSI_VVACR_VA2_Pos   (2U)
#define DSI_VVACR_VA2_Msk   (0x1UL << DSI_VVACR_VA2_Pos)
#define DSI_VVACR_VA2   DSI_VVACR_VA2_Msk
#define DSI_VVACR_VA3_Pos   (3U)
#define DSI_VVACR_VA3_Msk   (0x1UL << DSI_VVACR_VA3_Pos)
#define DSI_VVACR_VA3   DSI_VVACR_VA3_Msk
#define DSI_VVACR_VA4_Pos   (4U)
#define DSI_VVACR_VA4_Msk   (0x1UL << DSI_VVACR_VA4_Pos)
#define DSI_VVACR_VA4   DSI_VVACR_VA4_Msk
#define DSI_VVACR_VA5_Pos   (5U)
#define DSI_VVACR_VA5_Msk   (0x1UL << DSI_VVACR_VA5_Pos)
#define DSI_VVACR_VA5   DSI_VVACR_VA5_Msk
#define DSI_VVACR_VA6_Pos   (6U)
#define DSI_VVACR_VA6_Msk   (0x1UL << DSI_VVACR_VA6_Pos)
#define DSI_VVACR_VA6   DSI_VVACR_VA6_Msk
#define DSI_VVACR_VA7_Pos   (7U)
#define DSI_VVACR_VA7_Msk   (0x1UL << DSI_VVACR_VA7_Pos)
#define DSI_VVACR_VA7   DSI_VVACR_VA7_Msk
#define DSI_VVACR_VA8_Pos   (8U)
#define DSI_VVACR_VA8_Msk   (0x1UL << DSI_VVACR_VA8_Pos)
#define DSI_VVACR_VA8   DSI_VVACR_VA8_Msk
#define DSI_VVACR_VA9_Pos   (9U)
#define DSI_VVACR_VA9_Msk   (0x1UL << DSI_VVACR_VA9_Pos)
#define DSI_VVACR_VA9   DSI_VVACR_VA9_Msk
#define DSI_VVACR_VA10_Pos   (10U)
#define DSI_VVACR_VA10_Msk   (0x1UL << DSI_VVACR_VA10_Pos)
#define DSI_VVACR_VA10   DSI_VVACR_VA10_Msk
#define DSI_VVACR_VA11_Pos   (11U)
#define DSI_VVACR_VA11_Msk   (0x1UL << DSI_VVACR_VA11_Pos)
#define DSI_VVACR_VA11   DSI_VVACR_VA11_Msk
#define DSI_VVACR_VA12_Pos   (12U)
#define DSI_VVACR_VA12_Msk   (0x1UL << DSI_VVACR_VA12_Pos)
#define DSI_VVACR_VA12   DSI_VVACR_VA12_Msk
#define DSI_VVACR_VA13_Pos   (13U)
#define DSI_VVACR_VA13_Msk   (0x1UL << DSI_VVACR_VA13_Pos)
#define DSI_VVACR_VA13   DSI_VVACR_VA13_Msk
#define DSI_LCCR_CMDSIZE_Pos   (0U)
#define DSI_LCCR_CMDSIZE_Msk   (0xFFFFUL << DSI_LCCR_CMDSIZE_Pos)
#define DSI_LCCR_CMDSIZE   DSI_LCCR_CMDSIZE_Msk
#define DSI_LCCR_CMDSIZE0_Pos   (0U)
#define DSI_LCCR_CMDSIZE0_Msk   (0x1UL << DSI_LCCR_CMDSIZE0_Pos)
#define DSI_LCCR_CMDSIZE0   DSI_LCCR_CMDSIZE0_Msk
#define DSI_LCCR_CMDSIZE1_Pos   (1U)
#define DSI_LCCR_CMDSIZE1_Msk   (0x1UL << DSI_LCCR_CMDSIZE1_Pos)
#define DSI_LCCR_CMDSIZE1   DSI_LCCR_CMDSIZE1_Msk
#define DSI_LCCR_CMDSIZE2_Pos   (2U)
#define DSI_LCCR_CMDSIZE2_Msk   (0x1UL << DSI_LCCR_CMDSIZE2_Pos)
#define DSI_LCCR_CMDSIZE2   DSI_LCCR_CMDSIZE2_Msk
#define DSI_LCCR_CMDSIZE3_Pos   (3U)
#define DSI_LCCR_CMDSIZE3_Msk   (0x1UL << DSI_LCCR_CMDSIZE3_Pos)
#define DSI_LCCR_CMDSIZE3   DSI_LCCR_CMDSIZE3_Msk
#define DSI_LCCR_CMDSIZE4_Pos   (4U)
#define DSI_LCCR_CMDSIZE4_Msk   (0x1UL << DSI_LCCR_CMDSIZE4_Pos)
#define DSI_LCCR_CMDSIZE4   DSI_LCCR_CMDSIZE4_Msk
#define DSI_LCCR_CMDSIZE5_Pos   (5U)
#define DSI_LCCR_CMDSIZE5_Msk   (0x1UL << DSI_LCCR_CMDSIZE5_Pos)
#define DSI_LCCR_CMDSIZE5   DSI_LCCR_CMDSIZE5_Msk
#define DSI_LCCR_CMDSIZE6_Pos   (6U)
#define DSI_LCCR_CMDSIZE6_Msk   (0x1UL << DSI_LCCR_CMDSIZE6_Pos)
#define DSI_LCCR_CMDSIZE6   DSI_LCCR_CMDSIZE6_Msk
#define DSI_LCCR_CMDSIZE7_Pos   (7U)
#define DSI_LCCR_CMDSIZE7_Msk   (0x1UL << DSI_LCCR_CMDSIZE7_Pos)
#define DSI_LCCR_CMDSIZE7   DSI_LCCR_CMDSIZE7_Msk
#define DSI_LCCR_CMDSIZE8_Pos   (8U)
#define DSI_LCCR_CMDSIZE8_Msk   (0x1UL << DSI_LCCR_CMDSIZE8_Pos)
#define DSI_LCCR_CMDSIZE8   DSI_LCCR_CMDSIZE8_Msk
#define DSI_LCCR_CMDSIZE9_Pos   (9U)
#define DSI_LCCR_CMDSIZE9_Msk   (0x1UL << DSI_LCCR_CMDSIZE9_Pos)
#define DSI_LCCR_CMDSIZE9   DSI_LCCR_CMDSIZE9_Msk
#define DSI_LCCR_CMDSIZE10_Pos   (10U)
#define DSI_LCCR_CMDSIZE10_Msk   (0x1UL << DSI_LCCR_CMDSIZE10_Pos)
#define DSI_LCCR_CMDSIZE10   DSI_LCCR_CMDSIZE10_Msk
#define DSI_LCCR_CMDSIZE11_Pos   (11U)
#define DSI_LCCR_CMDSIZE11_Msk   (0x1UL << DSI_LCCR_CMDSIZE11_Pos)
#define DSI_LCCR_CMDSIZE11   DSI_LCCR_CMDSIZE11_Msk
#define DSI_LCCR_CMDSIZE12_Pos   (12U)
#define DSI_LCCR_CMDSIZE12_Msk   (0x1UL << DSI_LCCR_CMDSIZE12_Pos)
#define DSI_LCCR_CMDSIZE12   DSI_LCCR_CMDSIZE12_Msk
#define DSI_LCCR_CMDSIZE13_Pos   (13U)
#define DSI_LCCR_CMDSIZE13_Msk   (0x1UL << DSI_LCCR_CMDSIZE13_Pos)
#define DSI_LCCR_CMDSIZE13   DSI_LCCR_CMDSIZE13_Msk
#define DSI_LCCR_CMDSIZE14_Pos   (14U)
#define DSI_LCCR_CMDSIZE14_Msk   (0x1UL << DSI_LCCR_CMDSIZE14_Pos)
#define DSI_LCCR_CMDSIZE14   DSI_LCCR_CMDSIZE14_Msk
#define DSI_LCCR_CMDSIZE15_Pos   (15U)
#define DSI_LCCR_CMDSIZE15_Msk   (0x1UL << DSI_LCCR_CMDSIZE15_Pos)
#define DSI_LCCR_CMDSIZE15   DSI_LCCR_CMDSIZE15_Msk
#define DSI_CMCR_TEARE_Pos   (0U)
#define DSI_CMCR_TEARE_Msk   (0x1UL << DSI_CMCR_TEARE_Pos)
#define DSI_CMCR_TEARE   DSI_CMCR_TEARE_Msk
#define DSI_CMCR_ARE_Pos   (1U)
#define DSI_CMCR_ARE_Msk   (0x1UL << DSI_CMCR_ARE_Pos)
#define DSI_CMCR_ARE   DSI_CMCR_ARE_Msk
#define DSI_CMCR_GSW0TX_Pos   (8U)
#define DSI_CMCR_GSW0TX_Msk   (0x1UL << DSI_CMCR_GSW0TX_Pos)
#define DSI_CMCR_GSW0TX   DSI_CMCR_GSW0TX_Msk
#define DSI_CMCR_GSW1TX_Pos   (9U)
#define DSI_CMCR_GSW1TX_Msk   (0x1UL << DSI_CMCR_GSW1TX_Pos)
#define DSI_CMCR_GSW1TX   DSI_CMCR_GSW1TX_Msk
#define DSI_CMCR_GSW2TX_Pos   (10U)
#define DSI_CMCR_GSW2TX_Msk   (0x1UL << DSI_CMCR_GSW2TX_Pos)
#define DSI_CMCR_GSW2TX   DSI_CMCR_GSW2TX_Msk
#define DSI_CMCR_GSR0TX_Pos   (11U)
#define DSI_CMCR_GSR0TX_Msk   (0x1UL << DSI_CMCR_GSR0TX_Pos)
#define DSI_CMCR_GSR0TX   DSI_CMCR_GSR0TX_Msk
#define DSI_CMCR_GSR1TX_Pos   (12U)
#define DSI_CMCR_GSR1TX_Msk   (0x1UL << DSI_CMCR_GSR1TX_Pos)
#define DSI_CMCR_GSR1TX   DSI_CMCR_GSR1TX_Msk
#define DSI_CMCR_GSR2TX_Pos   (13U)
#define DSI_CMCR_GSR2TX_Msk   (0x1UL << DSI_CMCR_GSR2TX_Pos)
#define DSI_CMCR_GSR2TX   DSI_CMCR_GSR2TX_Msk
#define DSI_CMCR_GLWTX_Pos   (14U)
#define DSI_CMCR_GLWTX_Msk   (0x1UL << DSI_CMCR_GLWTX_Pos)
#define DSI_CMCR_GLWTX   DSI_CMCR_GLWTX_Msk
#define DSI_CMCR_DSW0TX_Pos   (16U)
#define DSI_CMCR_DSW0TX_Msk   (0x1UL << DSI_CMCR_DSW0TX_Pos)
#define DSI_CMCR_DSW0TX   DSI_CMCR_DSW0TX_Msk
#define DSI_CMCR_DSW1TX_Pos   (17U)
#define DSI_CMCR_DSW1TX_Msk   (0x1UL << DSI_CMCR_DSW1TX_Pos)
#define DSI_CMCR_DSW1TX   DSI_CMCR_DSW1TX_Msk
#define DSI_CMCR_DSR0TX_Pos   (18U)
#define DSI_CMCR_DSR0TX_Msk   (0x1UL << DSI_CMCR_DSR0TX_Pos)
#define DSI_CMCR_DSR0TX   DSI_CMCR_DSR0TX_Msk
#define DSI_CMCR_DLWTX_Pos   (19U)
#define DSI_CMCR_DLWTX_Msk   (0x1UL << DSI_CMCR_DLWTX_Pos)
#define DSI_CMCR_DLWTX   DSI_CMCR_DLWTX_Msk
#define DSI_CMCR_MRDPS_Pos   (24U)
#define DSI_CMCR_MRDPS_Msk   (0x1UL << DSI_CMCR_MRDPS_Pos)
#define DSI_CMCR_MRDPS   DSI_CMCR_MRDPS_Msk
#define DSI_GHCR_DT_Pos   (0U)
#define DSI_GHCR_DT_Msk   (0x3FUL << DSI_GHCR_DT_Pos)
#define DSI_GHCR_DT   DSI_GHCR_DT_Msk
#define DSI_GHCR_DT0_Pos   (0U)
#define DSI_GHCR_DT0_Msk   (0x1UL << DSI_GHCR_DT0_Pos)
#define DSI_GHCR_DT0   DSI_GHCR_DT0_Msk
#define DSI_GHCR_DT1_Pos   (1U)
#define DSI_GHCR_DT1_Msk   (0x1UL << DSI_GHCR_DT1_Pos)
#define DSI_GHCR_DT1   DSI_GHCR_DT1_Msk
#define DSI_GHCR_DT2_Pos   (2U)
#define DSI_GHCR_DT2_Msk   (0x1UL << DSI_GHCR_DT2_Pos)
#define DSI_GHCR_DT2   DSI_GHCR_DT2_Msk
#define DSI_GHCR_DT3_Pos   (3U)
#define DSI_GHCR_DT3_Msk   (0x1UL << DSI_GHCR_DT3_Pos)
#define DSI_GHCR_DT3   DSI_GHCR_DT3_Msk
#define DSI_GHCR_DT4_Pos   (4U)
#define DSI_GHCR_DT4_Msk   (0x1UL << DSI_GHCR_DT4_Pos)
#define DSI_GHCR_DT4   DSI_GHCR_DT4_Msk
#define DSI_GHCR_DT5_Pos   (5U)
#define DSI_GHCR_DT5_Msk   (0x1UL << DSI_GHCR_DT5_Pos)
#define DSI_GHCR_DT5   DSI_GHCR_DT5_Msk
#define DSI_GHCR_VCID_Pos   (6U)
#define DSI_GHCR_VCID_Msk   (0x3UL << DSI_GHCR_VCID_Pos)
#define DSI_GHCR_VCID   DSI_GHCR_VCID_Msk
#define DSI_GHCR_VCID0_Pos   (6U)
#define DSI_GHCR_VCID0_Msk   (0x1UL << DSI_GHCR_VCID0_Pos)
#define DSI_GHCR_VCID0   DSI_GHCR_VCID0_Msk
#define DSI_GHCR_VCID1_Pos   (7U)
#define DSI_GHCR_VCID1_Msk   (0x1UL << DSI_GHCR_VCID1_Pos)
#define DSI_GHCR_VCID1   DSI_GHCR_VCID1_Msk
#define DSI_GHCR_WCLSB_Pos   (8U)
#define DSI_GHCR_WCLSB_Msk   (0xFFUL << DSI_GHCR_WCLSB_Pos)
#define DSI_GHCR_WCLSB   DSI_GHCR_WCLSB_Msk
#define DSI_GHCR_WCLSB0_Pos   (8U)
#define DSI_GHCR_WCLSB0_Msk   (0x1UL << DSI_GHCR_WCLSB0_Pos)
#define DSI_GHCR_WCLSB0   DSI_GHCR_WCLSB0_Msk
#define DSI_GHCR_WCLSB1_Pos   (9U)
#define DSI_GHCR_WCLSB1_Msk   (0x1UL << DSI_GHCR_WCLSB1_Pos)
#define DSI_GHCR_WCLSB1   DSI_GHCR_WCLSB1_Msk
#define DSI_GHCR_WCLSB2_Pos   (10U)
#define DSI_GHCR_WCLSB2_Msk   (0x1UL << DSI_GHCR_WCLSB2_Pos)
#define DSI_GHCR_WCLSB2   DSI_GHCR_WCLSB2_Msk
#define DSI_GHCR_WCLSB3_Pos   (11U)
#define DSI_GHCR_WCLSB3_Msk   (0x1UL << DSI_GHCR_WCLSB3_Pos)
#define DSI_GHCR_WCLSB3   DSI_GHCR_WCLSB3_Msk
#define DSI_GHCR_WCLSB4_Pos   (12U)
#define DSI_GHCR_WCLSB4_Msk   (0x1UL << DSI_GHCR_WCLSB4_Pos)
#define DSI_GHCR_WCLSB4   DSI_GHCR_WCLSB4_Msk
#define DSI_GHCR_WCLSB5_Pos   (13U)
#define DSI_GHCR_WCLSB5_Msk   (0x1UL << DSI_GHCR_WCLSB5_Pos)
#define DSI_GHCR_WCLSB5   DSI_GHCR_WCLSB5_Msk
#define DSI_GHCR_WCLSB6_Pos   (14U)
#define DSI_GHCR_WCLSB6_Msk   (0x1UL << DSI_GHCR_WCLSB6_Pos)
#define DSI_GHCR_WCLSB6   DSI_GHCR_WCLSB6_Msk
#define DSI_GHCR_WCLSB7_Pos   (15U)
#define DSI_GHCR_WCLSB7_Msk   (0x1UL << DSI_GHCR_WCLSB7_Pos)
#define DSI_GHCR_WCLSB7   DSI_GHCR_WCLSB7_Msk
#define DSI_GHCR_WCMSB_Pos   (16U)
#define DSI_GHCR_WCMSB_Msk   (0xFFUL << DSI_GHCR_WCMSB_Pos)
#define DSI_GHCR_WCMSB   DSI_GHCR_WCMSB_Msk
#define DSI_GHCR_WCMSB0_Pos   (16U)
#define DSI_GHCR_WCMSB0_Msk   (0x1UL << DSI_GHCR_WCMSB0_Pos)
#define DSI_GHCR_WCMSB0   DSI_GHCR_WCMSB0_Msk
#define DSI_GHCR_WCMSB1_Pos   (17U)
#define DSI_GHCR_WCMSB1_Msk   (0x1UL << DSI_GHCR_WCMSB1_Pos)
#define DSI_GHCR_WCMSB1   DSI_GHCR_WCMSB1_Msk
#define DSI_GHCR_WCMSB2_Pos   (18U)
#define DSI_GHCR_WCMSB2_Msk   (0x1UL << DSI_GHCR_WCMSB2_Pos)
#define DSI_GHCR_WCMSB2   DSI_GHCR_WCMSB2_Msk
#define DSI_GHCR_WCMSB3_Pos   (19U)
#define DSI_GHCR_WCMSB3_Msk   (0x1UL << DSI_GHCR_WCMSB3_Pos)
#define DSI_GHCR_WCMSB3   DSI_GHCR_WCMSB3_Msk
#define DSI_GHCR_WCMSB4_Pos   (20U)
#define DSI_GHCR_WCMSB4_Msk   (0x1UL << DSI_GHCR_WCMSB4_Pos)
#define DSI_GHCR_WCMSB4   DSI_GHCR_WCMSB4_Msk
#define DSI_GHCR_WCMSB5_Pos   (21U)
#define DSI_GHCR_WCMSB5_Msk   (0x1UL << DSI_GHCR_WCMSB5_Pos)
#define DSI_GHCR_WCMSB5   DSI_GHCR_WCMSB5_Msk
#define DSI_GHCR_WCMSB6_Pos   (22U)
#define DSI_GHCR_WCMSB6_Msk   (0x1UL << DSI_GHCR_WCMSB6_Pos)
#define DSI_GHCR_WCMSB6   DSI_GHCR_WCMSB6_Msk
#define DSI_GHCR_WCMSB7_Pos   (23U)
#define DSI_GHCR_WCMSB7_Msk   (0x1UL << DSI_GHCR_WCMSB7_Pos)
#define DSI_GHCR_WCMSB7   DSI_GHCR_WCMSB7_Msk
#define DSI_GPDR_DATA1_Pos   (0U)
#define DSI_GPDR_DATA1_Msk   (0xFFUL << DSI_GPDR_DATA1_Pos)
#define DSI_GPDR_DATA1   DSI_GPDR_DATA1_Msk
#define DSI_GPDR_DATA1_0   (0x01UL << DSI_GPDR_DATA1_Pos)
#define DSI_GPDR_DATA1_1   (0x02UL << DSI_GPDR_DATA1_Pos)
#define DSI_GPDR_DATA1_2   (0x04UL << DSI_GPDR_DATA1_Pos)
#define DSI_GPDR_DATA1_3   (0x08UL << DSI_GPDR_DATA1_Pos)
#define DSI_GPDR_DATA1_4   (0x10UL << DSI_GPDR_DATA1_Pos)
#define DSI_GPDR_DATA1_5   (0x20UL << DSI_GPDR_DATA1_Pos)
#define DSI_GPDR_DATA1_6   (0x40UL << DSI_GPDR_DATA1_Pos)
#define DSI_GPDR_DATA1_7   (0x80UL << DSI_GPDR_DATA1_Pos)
#define DSI_GPDR_DATA2_Pos   (8U)
#define DSI_GPDR_DATA2_Msk   (0xFFUL << DSI_GPDR_DATA2_Pos)
#define DSI_GPDR_DATA2   DSI_GPDR_DATA2_Msk
#define DSI_GPDR_DATA2_0   (0x01UL << DSI_GPDR_DATA2_Pos)
#define DSI_GPDR_DATA2_1   (0x02UL << DSI_GPDR_DATA2_Pos)
#define DSI_GPDR_DATA2_2   (0x04UL << DSI_GPDR_DATA2_Pos)
#define DSI_GPDR_DATA2_3   (0x08UL << DSI_GPDR_DATA2_Pos)
#define DSI_GPDR_DATA2_4   (0x10UL << DSI_GPDR_DATA2_Pos)
#define DSI_GPDR_DATA2_5   (0x20UL << DSI_GPDR_DATA2_Pos)
#define DSI_GPDR_DATA2_6   (0x40UL << DSI_GPDR_DATA2_Pos)
#define DSI_GPDR_DATA2_7   (0x80UL << DSI_GPDR_DATA2_Pos)
#define DSI_GPDR_DATA3_Pos   (16U)
#define DSI_GPDR_DATA3_Msk   (0xFFUL << DSI_GPDR_DATA3_Pos)
#define DSI_GPDR_DATA3   DSI_GPDR_DATA3_Msk
#define DSI_GPDR_DATA3_0   (0x01UL << DSI_GPDR_DATA3_Pos)
#define DSI_GPDR_DATA3_1   (0x02UL << DSI_GPDR_DATA3_Pos)
#define DSI_GPDR_DATA3_2   (0x04UL << DSI_GPDR_DATA3_Pos)
#define DSI_GPDR_DATA3_3   (0x08UL << DSI_GPDR_DATA3_Pos)
#define DSI_GPDR_DATA3_4   (0x10UL << DSI_GPDR_DATA3_Pos)
#define DSI_GPDR_DATA3_5   (0x20UL << DSI_GPDR_DATA3_Pos)
#define DSI_GPDR_DATA3_6   (0x40UL << DSI_GPDR_DATA3_Pos)
#define DSI_GPDR_DATA3_7   (0x80UL << DSI_GPDR_DATA3_Pos)
#define DSI_GPDR_DATA4_Pos   (24U)
#define DSI_GPDR_DATA4_Msk   (0xFFUL << DSI_GPDR_DATA4_Pos)
#define DSI_GPDR_DATA4   DSI_GPDR_DATA4_Msk
#define DSI_GPDR_DATA4_0   (0x01UL << DSI_GPDR_DATA4_Pos)
#define DSI_GPDR_DATA4_1   (0x02UL << DSI_GPDR_DATA4_Pos)
#define DSI_GPDR_DATA4_2   (0x04UL << DSI_GPDR_DATA4_Pos)
#define DSI_GPDR_DATA4_3   (0x08UL << DSI_GPDR_DATA4_Pos)
#define DSI_GPDR_DATA4_4   (0x10UL << DSI_GPDR_DATA4_Pos)
#define DSI_GPDR_DATA4_5   (0x20UL << DSI_GPDR_DATA4_Pos)
#define DSI_GPDR_DATA4_6   (0x40UL << DSI_GPDR_DATA4_Pos)
#define DSI_GPDR_DATA4_7   (0x80UL << DSI_GPDR_DATA4_Pos)
#define DSI_GPSR_CMDFE_Pos   (0U)
#define DSI_GPSR_CMDFE_Msk   (0x1UL << DSI_GPSR_CMDFE_Pos)
#define DSI_GPSR_CMDFE   DSI_GPSR_CMDFE_Msk
#define DSI_GPSR_CMDFF_Pos   (1U)
#define DSI_GPSR_CMDFF_Msk   (0x1UL << DSI_GPSR_CMDFF_Pos)
#define DSI_GPSR_CMDFF   DSI_GPSR_CMDFF_Msk
#define DSI_GPSR_PWRFE_Pos   (2U)
#define DSI_GPSR_PWRFE_Msk   (0x1UL << DSI_GPSR_PWRFE_Pos)
#define DSI_GPSR_PWRFE   DSI_GPSR_PWRFE_Msk
#define DSI_GPSR_PWRFF_Pos   (3U)
#define DSI_GPSR_PWRFF_Msk   (0x1UL << DSI_GPSR_PWRFF_Pos)
#define DSI_GPSR_PWRFF   DSI_GPSR_PWRFF_Msk
#define DSI_GPSR_PRDFE_Pos   (4U)
#define DSI_GPSR_PRDFE_Msk   (0x1UL << DSI_GPSR_PRDFE_Pos)
#define DSI_GPSR_PRDFE   DSI_GPSR_PRDFE_Msk
#define DSI_GPSR_PRDFF_Pos   (5U)
#define DSI_GPSR_PRDFF_Msk   (0x1UL << DSI_GPSR_PRDFF_Pos)
#define DSI_GPSR_PRDFF   DSI_GPSR_PRDFF_Msk
#define DSI_GPSR_RCB_Pos   (6U)
#define DSI_GPSR_RCB_Msk   (0x1UL << DSI_GPSR_RCB_Pos)
#define DSI_GPSR_RCB   DSI_GPSR_RCB_Msk
#define DSI_GPSR_CMDBE_Pos   (16U)
#define DSI_GPSR_CMDBE_Msk   (0x1UL << DSI_GPSR_CMDBE_Pos)
#define DSI_GPSR_CMDBE   DSI_GPSR_CMDBE_Msk
#define DSI_GPSR_CMDBF_Pos   (17U)
#define DSI_GPSR_CMDBF_Msk   (0x1UL << DSI_GPSR_CMDBF_Pos)
#define DSI_GPSR_CMDBF   DSI_GPSR_CMDBF_Msk
#define DSI_GPSR_PBE_Pos   (18U)
#define DSI_GPSR_PBE_Msk   (0x1UL << DSI_GPSR_PBE_Pos)
#define DSI_GPSR_PBE   DSI_GPSR_PBE_Msk
#define DSI_GPSR_PBF_Pos   (19U)
#define DSI_GPSR_PBF_Msk   (0x1UL << DSI_GPSR_PBF_Pos)
#define DSI_GPSR_PBF   DSI_GPSR_PBF_Msk
#define DSI_TCCR0_LPRX_TOCNT_Pos   (0U)
#define DSI_TCCR0_LPRX_TOCNT_Msk   (0xFFFFUL << DSI_TCCR0_LPRX_TOCNT_Pos)
#define DSI_TCCR0_LPRX_TOCNT   DSI_TCCR0_LPRX_TOCNT_Msk
#define DSI_TCCR0_LPRX_TOCNT0_Pos   (0U)
#define DSI_TCCR0_LPRX_TOCNT0_Msk   (0x1UL << DSI_TCCR0_LPRX_TOCNT0_Pos)
#define DSI_TCCR0_LPRX_TOCNT0   DSI_TCCR0_LPRX_TOCNT0_Msk
#define DSI_TCCR0_LPRX_TOCNT1_Pos   (1U)
#define DSI_TCCR0_LPRX_TOCNT1_Msk   (0x1UL << DSI_TCCR0_LPRX_TOCNT1_Pos)
#define DSI_TCCR0_LPRX_TOCNT1   DSI_TCCR0_LPRX_TOCNT1_Msk
#define DSI_TCCR0_LPRX_TOCNT2_Pos   (2U)
#define DSI_TCCR0_LPRX_TOCNT2_Msk   (0x1UL << DSI_TCCR0_LPRX_TOCNT2_Pos)
#define DSI_TCCR0_LPRX_TOCNT2   DSI_TCCR0_LPRX_TOCNT2_Msk
#define DSI_TCCR0_LPRX_TOCNT3_Pos   (3U)
#define DSI_TCCR0_LPRX_TOCNT3_Msk   (0x1UL << DSI_TCCR0_LPRX_TOCNT3_Pos)
#define DSI_TCCR0_LPRX_TOCNT3   DSI_TCCR0_LPRX_TOCNT3_Msk
#define DSI_TCCR0_LPRX_TOCNT4_Pos   (4U)
#define DSI_TCCR0_LPRX_TOCNT4_Msk   (0x1UL << DSI_TCCR0_LPRX_TOCNT4_Pos)
#define DSI_TCCR0_LPRX_TOCNT4   DSI_TCCR0_LPRX_TOCNT4_Msk
#define DSI_TCCR0_LPRX_TOCNT5_Pos   (5U)
#define DSI_TCCR0_LPRX_TOCNT5_Msk   (0x1UL << DSI_TCCR0_LPRX_TOCNT5_Pos)
#define DSI_TCCR0_LPRX_TOCNT5   DSI_TCCR0_LPRX_TOCNT5_Msk
#define DSI_TCCR0_LPRX_TOCNT6_Pos   (6U)
#define DSI_TCCR0_LPRX_TOCNT6_Msk   (0x1UL << DSI_TCCR0_LPRX_TOCNT6_Pos)
#define DSI_TCCR0_LPRX_TOCNT6   DSI_TCCR0_LPRX_TOCNT6_Msk
#define DSI_TCCR0_LPRX_TOCNT7_Pos   (7U)
#define DSI_TCCR0_LPRX_TOCNT7_Msk   (0x1UL << DSI_TCCR0_LPRX_TOCNT7_Pos)
#define DSI_TCCR0_LPRX_TOCNT7   DSI_TCCR0_LPRX_TOCNT7_Msk
#define DSI_TCCR0_LPRX_TOCNT8_Pos   (8U)
#define DSI_TCCR0_LPRX_TOCNT8_Msk   (0x1UL << DSI_TCCR0_LPRX_TOCNT8_Pos)
#define DSI_TCCR0_LPRX_TOCNT8   DSI_TCCR0_LPRX_TOCNT8_Msk
#define DSI_TCCR0_LPRX_TOCNT9_Pos   (9U)
#define DSI_TCCR0_LPRX_TOCNT9_Msk   (0x1UL << DSI_TCCR0_LPRX_TOCNT9_Pos)
#define DSI_TCCR0_LPRX_TOCNT9   DSI_TCCR0_LPRX_TOCNT9_Msk
#define DSI_TCCR0_LPRX_TOCNT10_Pos   (10U)
#define DSI_TCCR0_LPRX_TOCNT10_Msk   (0x1UL << DSI_TCCR0_LPRX_TOCNT10_Pos)
#define DSI_TCCR0_LPRX_TOCNT10   DSI_TCCR0_LPRX_TOCNT10_Msk
#define DSI_TCCR0_LPRX_TOCNT11_Pos   (11U)
#define DSI_TCCR0_LPRX_TOCNT11_Msk   (0x1UL << DSI_TCCR0_LPRX_TOCNT11_Pos)
#define DSI_TCCR0_LPRX_TOCNT11   DSI_TCCR0_LPRX_TOCNT11_Msk
#define DSI_TCCR0_LPRX_TOCNT12_Pos   (12U)
#define DSI_TCCR0_LPRX_TOCNT12_Msk   (0x1UL << DSI_TCCR0_LPRX_TOCNT12_Pos)
#define DSI_TCCR0_LPRX_TOCNT12   DSI_TCCR0_LPRX_TOCNT12_Msk
#define DSI_TCCR0_LPRX_TOCNT13_Pos   (13U)
#define DSI_TCCR0_LPRX_TOCNT13_Msk   (0x1UL << DSI_TCCR0_LPRX_TOCNT13_Pos)
#define DSI_TCCR0_LPRX_TOCNT13   DSI_TCCR0_LPRX_TOCNT13_Msk
#define DSI_TCCR0_LPRX_TOCNT14_Pos   (14U)
#define DSI_TCCR0_LPRX_TOCNT14_Msk   (0x1UL << DSI_TCCR0_LPRX_TOCNT14_Pos)
#define DSI_TCCR0_LPRX_TOCNT14   DSI_TCCR0_LPRX_TOCNT14_Msk
#define DSI_TCCR0_LPRX_TOCNT15_Pos   (15U)
#define DSI_TCCR0_LPRX_TOCNT15_Msk   (0x1UL << DSI_TCCR0_LPRX_TOCNT15_Pos)
#define DSI_TCCR0_LPRX_TOCNT15   DSI_TCCR0_LPRX_TOCNT15_Msk
#define DSI_TCCR0_HSTX_TOCNT_Pos   (16U)
#define DSI_TCCR0_HSTX_TOCNT_Msk   (0xFFFFUL << DSI_TCCR0_HSTX_TOCNT_Pos)
#define DSI_TCCR0_HSTX_TOCNT   DSI_TCCR0_HSTX_TOCNT_Msk
#define DSI_TCCR0_HSTX_TOCNT0_Pos   (16U)
#define DSI_TCCR0_HSTX_TOCNT0_Msk   (0x1UL << DSI_TCCR0_HSTX_TOCNT0_Pos)
#define DSI_TCCR0_HSTX_TOCNT0   DSI_TCCR0_HSTX_TOCNT0_Msk
#define DSI_TCCR0_HSTX_TOCNT1_Pos   (17U)
#define DSI_TCCR0_HSTX_TOCNT1_Msk   (0x1UL << DSI_TCCR0_HSTX_TOCNT1_Pos)
#define DSI_TCCR0_HSTX_TOCNT1   DSI_TCCR0_HSTX_TOCNT1_Msk
#define DSI_TCCR0_HSTX_TOCNT2_Pos   (18U)
#define DSI_TCCR0_HSTX_TOCNT2_Msk   (0x1UL << DSI_TCCR0_HSTX_TOCNT2_Pos)
#define DSI_TCCR0_HSTX_TOCNT2   DSI_TCCR0_HSTX_TOCNT2_Msk
#define DSI_TCCR0_HSTX_TOCNT3_Pos   (19U)
#define DSI_TCCR0_HSTX_TOCNT3_Msk   (0x1UL << DSI_TCCR0_HSTX_TOCNT3_Pos)
#define DSI_TCCR0_HSTX_TOCNT3   DSI_TCCR0_HSTX_TOCNT3_Msk
#define DSI_TCCR0_HSTX_TOCNT4_Pos   (20U)
#define DSI_TCCR0_HSTX_TOCNT4_Msk   (0x1UL << DSI_TCCR0_HSTX_TOCNT4_Pos)
#define DSI_TCCR0_HSTX_TOCNT4   DSI_TCCR0_HSTX_TOCNT4_Msk
#define DSI_TCCR0_HSTX_TOCNT5_Pos   (21U)
#define DSI_TCCR0_HSTX_TOCNT5_Msk   (0x1UL << DSI_TCCR0_HSTX_TOCNT5_Pos)
#define DSI_TCCR0_HSTX_TOCNT5   DSI_TCCR0_HSTX_TOCNT5_Msk
#define DSI_TCCR0_HSTX_TOCNT6_Pos   (22U)
#define DSI_TCCR0_HSTX_TOCNT6_Msk   (0x1UL << DSI_TCCR0_HSTX_TOCNT6_Pos)
#define DSI_TCCR0_HSTX_TOCNT6   DSI_TCCR0_HSTX_TOCNT6_Msk
#define DSI_TCCR0_HSTX_TOCNT7_Pos   (23U)
#define DSI_TCCR0_HSTX_TOCNT7_Msk   (0x1UL << DSI_TCCR0_HSTX_TOCNT7_Pos)
#define DSI_TCCR0_HSTX_TOCNT7   DSI_TCCR0_HSTX_TOCNT7_Msk
#define DSI_TCCR0_HSTX_TOCNT8_Pos   (24U)
#define DSI_TCCR0_HSTX_TOCNT8_Msk   (0x1UL << DSI_TCCR0_HSTX_TOCNT8_Pos)
#define DSI_TCCR0_HSTX_TOCNT8   DSI_TCCR0_HSTX_TOCNT8_Msk
#define DSI_TCCR0_HSTX_TOCNT9_Pos   (25U)
#define DSI_TCCR0_HSTX_TOCNT9_Msk   (0x1UL << DSI_TCCR0_HSTX_TOCNT9_Pos)
#define DSI_TCCR0_HSTX_TOCNT9   DSI_TCCR0_HSTX_TOCNT9_Msk
#define DSI_TCCR0_HSTX_TOCNT10_Pos   (26U)
#define DSI_TCCR0_HSTX_TOCNT10_Msk   (0x1UL << DSI_TCCR0_HSTX_TOCNT10_Pos)
#define DSI_TCCR0_HSTX_TOCNT10   DSI_TCCR0_HSTX_TOCNT10_Msk
#define DSI_TCCR0_HSTX_TOCNT11_Pos   (27U)
#define DSI_TCCR0_HSTX_TOCNT11_Msk   (0x1UL << DSI_TCCR0_HSTX_TOCNT11_Pos)
#define DSI_TCCR0_HSTX_TOCNT11   DSI_TCCR0_HSTX_TOCNT11_Msk
#define DSI_TCCR0_HSTX_TOCNT12_Pos   (28U)
#define DSI_TCCR0_HSTX_TOCNT12_Msk   (0x1UL << DSI_TCCR0_HSTX_TOCNT12_Pos)
#define DSI_TCCR0_HSTX_TOCNT12   DSI_TCCR0_HSTX_TOCNT12_Msk
#define DSI_TCCR0_HSTX_TOCNT13_Pos   (29U)
#define DSI_TCCR0_HSTX_TOCNT13_Msk   (0x1UL << DSI_TCCR0_HSTX_TOCNT13_Pos)
#define DSI_TCCR0_HSTX_TOCNT13   DSI_TCCR0_HSTX_TOCNT13_Msk
#define DSI_TCCR0_HSTX_TOCNT14_Pos   (30U)
#define DSI_TCCR0_HSTX_TOCNT14_Msk   (0x1UL << DSI_TCCR0_HSTX_TOCNT14_Pos)
#define DSI_TCCR0_HSTX_TOCNT14   DSI_TCCR0_HSTX_TOCNT14_Msk
#define DSI_TCCR0_HSTX_TOCNT15_Pos   (31U)
#define DSI_TCCR0_HSTX_TOCNT15_Msk   (0x1UL << DSI_TCCR0_HSTX_TOCNT15_Pos)
#define DSI_TCCR0_HSTX_TOCNT15   DSI_TCCR0_HSTX_TOCNT15_Msk
#define DSI_TCCR1_HSRD_TOCNT_Pos   (0U)
#define DSI_TCCR1_HSRD_TOCNT_Msk   (0xFFFFUL << DSI_TCCR1_HSRD_TOCNT_Pos)
#define DSI_TCCR1_HSRD_TOCNT   DSI_TCCR1_HSRD_TOCNT_Msk
#define DSI_TCCR1_HSRD_TOCNT0_Pos   (0U)
#define DSI_TCCR1_HSRD_TOCNT0_Msk   (0x1UL << DSI_TCCR1_HSRD_TOCNT0_Pos)
#define DSI_TCCR1_HSRD_TOCNT0   DSI_TCCR1_HSRD_TOCNT0_Msk
#define DSI_TCCR1_HSRD_TOCNT1_Pos   (1U)
#define DSI_TCCR1_HSRD_TOCNT1_Msk   (0x1UL << DSI_TCCR1_HSRD_TOCNT1_Pos)
#define DSI_TCCR1_HSRD_TOCNT1   DSI_TCCR1_HSRD_TOCNT1_Msk
#define DSI_TCCR1_HSRD_TOCNT2_Pos   (2U)
#define DSI_TCCR1_HSRD_TOCNT2_Msk   (0x1UL << DSI_TCCR1_HSRD_TOCNT2_Pos)
#define DSI_TCCR1_HSRD_TOCNT2   DSI_TCCR1_HSRD_TOCNT2_Msk
#define DSI_TCCR1_HSRD_TOCNT3_Pos   (3U)
#define DSI_TCCR1_HSRD_TOCNT3_Msk   (0x1UL << DSI_TCCR1_HSRD_TOCNT3_Pos)
#define DSI_TCCR1_HSRD_TOCNT3   DSI_TCCR1_HSRD_TOCNT3_Msk
#define DSI_TCCR1_HSRD_TOCNT4_Pos   (4U)
#define DSI_TCCR1_HSRD_TOCNT4_Msk   (0x1UL << DSI_TCCR1_HSRD_TOCNT4_Pos)
#define DSI_TCCR1_HSRD_TOCNT4   DSI_TCCR1_HSRD_TOCNT4_Msk
#define DSI_TCCR1_HSRD_TOCNT5_Pos   (5U)
#define DSI_TCCR1_HSRD_TOCNT5_Msk   (0x1UL << DSI_TCCR1_HSRD_TOCNT5_Pos)
#define DSI_TCCR1_HSRD_TOCNT5   DSI_TCCR1_HSRD_TOCNT5_Msk
#define DSI_TCCR1_HSRD_TOCNT6_Pos   (6U)
#define DSI_TCCR1_HSRD_TOCNT6_Msk   (0x1UL << DSI_TCCR1_HSRD_TOCNT6_Pos)
#define DSI_TCCR1_HSRD_TOCNT6   DSI_TCCR1_HSRD_TOCNT6_Msk
#define DSI_TCCR1_HSRD_TOCNT7_Pos   (7U)
#define DSI_TCCR1_HSRD_TOCNT7_Msk   (0x1UL << DSI_TCCR1_HSRD_TOCNT7_Pos)
#define DSI_TCCR1_HSRD_TOCNT7   DSI_TCCR1_HSRD_TOCNT7_Msk
#define DSI_TCCR1_HSRD_TOCNT8_Pos   (8U)
#define DSI_TCCR1_HSRD_TOCNT8_Msk   (0x1UL << DSI_TCCR1_HSRD_TOCNT8_Pos)
#define DSI_TCCR1_HSRD_TOCNT8   DSI_TCCR1_HSRD_TOCNT8_Msk
#define DSI_TCCR1_HSRD_TOCNT9_Pos   (9U)
#define DSI_TCCR1_HSRD_TOCNT9_Msk   (0x1UL << DSI_TCCR1_HSRD_TOCNT9_Pos)
#define DSI_TCCR1_HSRD_TOCNT9   DSI_TCCR1_HSRD_TOCNT9_Msk
#define DSI_TCCR1_HSRD_TOCNT10_Pos   (10U)
#define DSI_TCCR1_HSRD_TOCNT10_Msk   (0x1UL << DSI_TCCR1_HSRD_TOCNT10_Pos)
#define DSI_TCCR1_HSRD_TOCNT10   DSI_TCCR1_HSRD_TOCNT10_Msk
#define DSI_TCCR1_HSRD_TOCNT11_Pos   (11U)
#define DSI_TCCR1_HSRD_TOCNT11_Msk   (0x1UL << DSI_TCCR1_HSRD_TOCNT11_Pos)
#define DSI_TCCR1_HSRD_TOCNT11   DSI_TCCR1_HSRD_TOCNT11_Msk
#define DSI_TCCR1_HSRD_TOCNT12_Pos   (12U)
#define DSI_TCCR1_HSRD_TOCNT12_Msk   (0x1UL << DSI_TCCR1_HSRD_TOCNT12_Pos)
#define DSI_TCCR1_HSRD_TOCNT12   DSI_TCCR1_HSRD_TOCNT12_Msk
#define DSI_TCCR1_HSRD_TOCNT13_Pos   (13U)
#define DSI_TCCR1_HSRD_TOCNT13_Msk   (0x1UL << DSI_TCCR1_HSRD_TOCNT13_Pos)
#define DSI_TCCR1_HSRD_TOCNT13   DSI_TCCR1_HSRD_TOCNT13_Msk
#define DSI_TCCR1_HSRD_TOCNT14_Pos   (14U)
#define DSI_TCCR1_HSRD_TOCNT14_Msk   (0x1UL << DSI_TCCR1_HSRD_TOCNT14_Pos)
#define DSI_TCCR1_HSRD_TOCNT14   DSI_TCCR1_HSRD_TOCNT14_Msk
#define DSI_TCCR1_HSRD_TOCNT15_Pos   (15U)
#define DSI_TCCR1_HSRD_TOCNT15_Msk   (0x1UL << DSI_TCCR1_HSRD_TOCNT15_Pos)
#define DSI_TCCR1_HSRD_TOCNT15   DSI_TCCR1_HSRD_TOCNT15_Msk
#define DSI_TCCR2_LPRD_TOCNT_Pos   (0U)
#define DSI_TCCR2_LPRD_TOCNT_Msk   (0xFFFFUL << DSI_TCCR2_LPRD_TOCNT_Pos)
#define DSI_TCCR2_LPRD_TOCNT   DSI_TCCR2_LPRD_TOCNT_Msk
#define DSI_TCCR2_LPRD_TOCNT0_Pos   (0U)
#define DSI_TCCR2_LPRD_TOCNT0_Msk   (0x1UL << DSI_TCCR2_LPRD_TOCNT0_Pos)
#define DSI_TCCR2_LPRD_TOCNT0   DSI_TCCR2_LPRD_TOCNT0_Msk
#define DSI_TCCR2_LPRD_TOCNT1_Pos   (1U)
#define DSI_TCCR2_LPRD_TOCNT1_Msk   (0x1UL << DSI_TCCR2_LPRD_TOCNT1_Pos)
#define DSI_TCCR2_LPRD_TOCNT1   DSI_TCCR2_LPRD_TOCNT1_Msk
#define DSI_TCCR2_LPRD_TOCNT2_Pos   (2U)
#define DSI_TCCR2_LPRD_TOCNT2_Msk   (0x1UL << DSI_TCCR2_LPRD_TOCNT2_Pos)
#define DSI_TCCR2_LPRD_TOCNT2   DSI_TCCR2_LPRD_TOCNT2_Msk
#define DSI_TCCR2_LPRD_TOCNT3_Pos   (3U)
#define DSI_TCCR2_LPRD_TOCNT3_Msk   (0x1UL << DSI_TCCR2_LPRD_TOCNT3_Pos)
#define DSI_TCCR2_LPRD_TOCNT3   DSI_TCCR2_LPRD_TOCNT3_Msk
#define DSI_TCCR2_LPRD_TOCNT4_Pos   (4U)
#define DSI_TCCR2_LPRD_TOCNT4_Msk   (0x1UL << DSI_TCCR2_LPRD_TOCNT4_Pos)
#define DSI_TCCR2_LPRD_TOCNT4   DSI_TCCR2_LPRD_TOCNT4_Msk
#define DSI_TCCR2_LPRD_TOCNT5_Pos   (5U)
#define DSI_TCCR2_LPRD_TOCNT5_Msk   (0x1UL << DSI_TCCR2_LPRD_TOCNT5_Pos)
#define DSI_TCCR2_LPRD_TOCNT5   DSI_TCCR2_LPRD_TOCNT5_Msk
#define DSI_TCCR2_LPRD_TOCNT6_Pos   (6U)
#define DSI_TCCR2_LPRD_TOCNT6_Msk   (0x1UL << DSI_TCCR2_LPRD_TOCNT6_Pos)
#define DSI_TCCR2_LPRD_TOCNT6   DSI_TCCR2_LPRD_TOCNT6_Msk
#define DSI_TCCR2_LPRD_TOCNT7_Pos   (7U)
#define DSI_TCCR2_LPRD_TOCNT7_Msk   (0x1UL << DSI_TCCR2_LPRD_TOCNT7_Pos)
#define DSI_TCCR2_LPRD_TOCNT7   DSI_TCCR2_LPRD_TOCNT7_Msk
#define DSI_TCCR2_LPRD_TOCNT8_Pos   (8U)
#define DSI_TCCR2_LPRD_TOCNT8_Msk   (0x1UL << DSI_TCCR2_LPRD_TOCNT8_Pos)
#define DSI_TCCR2_LPRD_TOCNT8   DSI_TCCR2_LPRD_TOCNT8_Msk
#define DSI_TCCR2_LPRD_TOCNT9_Pos   (9U)
#define DSI_TCCR2_LPRD_TOCNT9_Msk   (0x1UL << DSI_TCCR2_LPRD_TOCNT9_Pos)
#define DSI_TCCR2_LPRD_TOCNT9   DSI_TCCR2_LPRD_TOCNT9_Msk
#define DSI_TCCR2_LPRD_TOCNT10_Pos   (10U)
#define DSI_TCCR2_LPRD_TOCNT10_Msk   (0x1UL << DSI_TCCR2_LPRD_TOCNT10_Pos)
#define DSI_TCCR2_LPRD_TOCNT10   DSI_TCCR2_LPRD_TOCNT10_Msk
#define DSI_TCCR2_LPRD_TOCNT11_Pos   (11U)
#define DSI_TCCR2_LPRD_TOCNT11_Msk   (0x1UL << DSI_TCCR2_LPRD_TOCNT11_Pos)
#define DSI_TCCR2_LPRD_TOCNT11   DSI_TCCR2_LPRD_TOCNT11_Msk
#define DSI_TCCR2_LPRD_TOCNT12_Pos   (12U)
#define DSI_TCCR2_LPRD_TOCNT12_Msk   (0x1UL << DSI_TCCR2_LPRD_TOCNT12_Pos)
#define DSI_TCCR2_LPRD_TOCNT12   DSI_TCCR2_LPRD_TOCNT12_Msk
#define DSI_TCCR2_LPRD_TOCNT13_Pos   (13U)
#define DSI_TCCR2_LPRD_TOCNT13_Msk   (0x1UL << DSI_TCCR2_LPRD_TOCNT13_Pos)
#define DSI_TCCR2_LPRD_TOCNT13   DSI_TCCR2_LPRD_TOCNT13_Msk
#define DSI_TCCR2_LPRD_TOCNT14_Pos   (14U)
#define DSI_TCCR2_LPRD_TOCNT14_Msk   (0x1UL << DSI_TCCR2_LPRD_TOCNT14_Pos)
#define DSI_TCCR2_LPRD_TOCNT14   DSI_TCCR2_LPRD_TOCNT14_Msk
#define DSI_TCCR2_LPRD_TOCNT15_Pos   (15U)
#define DSI_TCCR2_LPRD_TOCNT15_Msk   (0x1UL << DSI_TCCR2_LPRD_TOCNT15_Pos)
#define DSI_TCCR2_LPRD_TOCNT15   DSI_TCCR2_LPRD_TOCNT15_Msk
#define DSI_TCCR3_HSWR_TOCNT_Pos   (0U)
#define DSI_TCCR3_HSWR_TOCNT_Msk   (0xFFFFUL << DSI_TCCR3_HSWR_TOCNT_Pos)
#define DSI_TCCR3_HSWR_TOCNT   DSI_TCCR3_HSWR_TOCNT_Msk
#define DSI_TCCR3_HSWR_TOCNT0_Pos   (0U)
#define DSI_TCCR3_HSWR_TOCNT0_Msk   (0x1UL << DSI_TCCR3_HSWR_TOCNT0_Pos)
#define DSI_TCCR3_HSWR_TOCNT0   DSI_TCCR3_HSWR_TOCNT0_Msk
#define DSI_TCCR3_HSWR_TOCNT1_Pos   (1U)
#define DSI_TCCR3_HSWR_TOCNT1_Msk   (0x1UL << DSI_TCCR3_HSWR_TOCNT1_Pos)
#define DSI_TCCR3_HSWR_TOCNT1   DSI_TCCR3_HSWR_TOCNT1_Msk
#define DSI_TCCR3_HSWR_TOCNT2_Pos   (2U)
#define DSI_TCCR3_HSWR_TOCNT2_Msk   (0x1UL << DSI_TCCR3_HSWR_TOCNT2_Pos)
#define DSI_TCCR3_HSWR_TOCNT2   DSI_TCCR3_HSWR_TOCNT2_Msk
#define DSI_TCCR3_HSWR_TOCNT3_Pos   (3U)
#define DSI_TCCR3_HSWR_TOCNT3_Msk   (0x1UL << DSI_TCCR3_HSWR_TOCNT3_Pos)
#define DSI_TCCR3_HSWR_TOCNT3   DSI_TCCR3_HSWR_TOCNT3_Msk
#define DSI_TCCR3_HSWR_TOCNT4_Pos   (4U)
#define DSI_TCCR3_HSWR_TOCNT4_Msk   (0x1UL << DSI_TCCR3_HSWR_TOCNT4_Pos)
#define DSI_TCCR3_HSWR_TOCNT4   DSI_TCCR3_HSWR_TOCNT4_Msk
#define DSI_TCCR3_HSWR_TOCNT5_Pos   (5U)
#define DSI_TCCR3_HSWR_TOCNT5_Msk   (0x1UL << DSI_TCCR3_HSWR_TOCNT5_Pos)
#define DSI_TCCR3_HSWR_TOCNT5   DSI_TCCR3_HSWR_TOCNT5_Msk
#define DSI_TCCR3_HSWR_TOCNT6_Pos   (6U)
#define DSI_TCCR3_HSWR_TOCNT6_Msk   (0x1UL << DSI_TCCR3_HSWR_TOCNT6_Pos)
#define DSI_TCCR3_HSWR_TOCNT6   DSI_TCCR3_HSWR_TOCNT6_Msk
#define DSI_TCCR3_HSWR_TOCNT7_Pos   (7U)
#define DSI_TCCR3_HSWR_TOCNT7_Msk   (0x1UL << DSI_TCCR3_HSWR_TOCNT7_Pos)
#define DSI_TCCR3_HSWR_TOCNT7   DSI_TCCR3_HSWR_TOCNT7_Msk
#define DSI_TCCR3_HSWR_TOCNT8_Pos   (8U)
#define DSI_TCCR3_HSWR_TOCNT8_Msk   (0x1UL << DSI_TCCR3_HSWR_TOCNT8_Pos)
#define DSI_TCCR3_HSWR_TOCNT8   DSI_TCCR3_HSWR_TOCNT8_Msk
#define DSI_TCCR3_HSWR_TOCNT9_Pos   (9U)
#define DSI_TCCR3_HSWR_TOCNT9_Msk   (0x1UL << DSI_TCCR3_HSWR_TOCNT9_Pos)
#define DSI_TCCR3_HSWR_TOCNT9   DSI_TCCR3_HSWR_TOCNT9_Msk
#define DSI_TCCR3_HSWR_TOCNT10_Pos   (10U)
#define DSI_TCCR3_HSWR_TOCNT10_Msk   (0x1UL << DSI_TCCR3_HSWR_TOCNT10_Pos)
#define DSI_TCCR3_HSWR_TOCNT10   DSI_TCCR3_HSWR_TOCNT10_Msk
#define DSI_TCCR3_HSWR_TOCNT11_Pos   (11U)
#define DSI_TCCR3_HSWR_TOCNT11_Msk   (0x1UL << DSI_TCCR3_HSWR_TOCNT11_Pos)
#define DSI_TCCR3_HSWR_TOCNT11   DSI_TCCR3_HSWR_TOCNT11_Msk
#define DSI_TCCR3_HSWR_TOCNT12_Pos   (12U)
#define DSI_TCCR3_HSWR_TOCNT12_Msk   (0x1UL << DSI_TCCR3_HSWR_TOCNT12_Pos)
#define DSI_TCCR3_HSWR_TOCNT12   DSI_TCCR3_HSWR_TOCNT12_Msk
#define DSI_TCCR3_HSWR_TOCNT13_Pos   (13U)
#define DSI_TCCR3_HSWR_TOCNT13_Msk   (0x1UL << DSI_TCCR3_HSWR_TOCNT13_Pos)
#define DSI_TCCR3_HSWR_TOCNT13   DSI_TCCR3_HSWR_TOCNT13_Msk
#define DSI_TCCR3_HSWR_TOCNT14_Pos   (14U)
#define DSI_TCCR3_HSWR_TOCNT14_Msk   (0x1UL << DSI_TCCR3_HSWR_TOCNT14_Pos)
#define DSI_TCCR3_HSWR_TOCNT14   DSI_TCCR3_HSWR_TOCNT14_Msk
#define DSI_TCCR3_HSWR_TOCNT15_Pos   (15U)
#define DSI_TCCR3_HSWR_TOCNT15_Msk   (0x1UL << DSI_TCCR3_HSWR_TOCNT15_Pos)
#define DSI_TCCR3_HSWR_TOCNT15   DSI_TCCR3_HSWR_TOCNT15_Msk
#define DSI_TCCR3_PM_Pos   (24U)
#define DSI_TCCR3_PM_Msk   (0x1UL << DSI_TCCR3_PM_Pos)
#define DSI_TCCR3_PM   DSI_TCCR3_PM_Msk
#define DSI_TCCR4_LPWR_TOCNT_Pos   (0U)
#define DSI_TCCR4_LPWR_TOCNT_Msk   (0xFFFFUL << DSI_TCCR4_LPWR_TOCNT_Pos)
#define DSI_TCCR4_LPWR_TOCNT   DSI_TCCR4_LPWR_TOCNT_Msk
#define DSI_TCCR4_LPWR_TOCNT0_Pos   (0U)
#define DSI_TCCR4_LPWR_TOCNT0_Msk   (0x1UL << DSI_TCCR4_LPWR_TOCNT0_Pos)
#define DSI_TCCR4_LPWR_TOCNT0   DSI_TCCR4_LPWR_TOCNT0_Msk
#define DSI_TCCR4_LPWR_TOCNT1_Pos   (1U)
#define DSI_TCCR4_LPWR_TOCNT1_Msk   (0x1UL << DSI_TCCR4_LPWR_TOCNT1_Pos)
#define DSI_TCCR4_LPWR_TOCNT1   DSI_TCCR4_LPWR_TOCNT1_Msk
#define DSI_TCCR4_LPWR_TOCNT2_Pos   (2U)
#define DSI_TCCR4_LPWR_TOCNT2_Msk   (0x1UL << DSI_TCCR4_LPWR_TOCNT2_Pos)
#define DSI_TCCR4_LPWR_TOCNT2   DSI_TCCR4_LPWR_TOCNT2_Msk
#define DSI_TCCR4_LPWR_TOCNT3_Pos   (3U)
#define DSI_TCCR4_LPWR_TOCNT3_Msk   (0x1UL << DSI_TCCR4_LPWR_TOCNT3_Pos)
#define DSI_TCCR4_LPWR_TOCNT3   DSI_TCCR4_LPWR_TOCNT3_Msk
#define DSI_TCCR4_LPWR_TOCNT4_Pos   (4U)
#define DSI_TCCR4_LPWR_TOCNT4_Msk   (0x1UL << DSI_TCCR4_LPWR_TOCNT4_Pos)
#define DSI_TCCR4_LPWR_TOCNT4   DSI_TCCR4_LPWR_TOCNT4_Msk
#define DSI_TCCR4_LPWR_TOCNT5_Pos   (5U)
#define DSI_TCCR4_LPWR_TOCNT5_Msk   (0x1UL << DSI_TCCR4_LPWR_TOCNT5_Pos)
#define DSI_TCCR4_LPWR_TOCNT5   DSI_TCCR4_LPWR_TOCNT5_Msk
#define DSI_TCCR4_LPWR_TOCNT6_Pos   (6U)
#define DSI_TCCR4_LPWR_TOCNT6_Msk   (0x1UL << DSI_TCCR4_LPWR_TOCNT6_Pos)
#define DSI_TCCR4_LPWR_TOCNT6   DSI_TCCR4_LPWR_TOCNT6_Msk
#define DSI_TCCR4_LPWR_TOCNT7_Pos   (7U)
#define DSI_TCCR4_LPWR_TOCNT7_Msk   (0x1UL << DSI_TCCR4_LPWR_TOCNT7_Pos)
#define DSI_TCCR4_LPWR_TOCNT7   DSI_TCCR4_LPWR_TOCNT7_Msk
#define DSI_TCCR4_LPWR_TOCNT8_Pos   (8U)
#define DSI_TCCR4_LPWR_TOCNT8_Msk   (0x1UL << DSI_TCCR4_LPWR_TOCNT8_Pos)
#define DSI_TCCR4_LPWR_TOCNT8   DSI_TCCR4_LPWR_TOCNT8_Msk
#define DSI_TCCR4_LPWR_TOCNT9_Pos   (9U)
#define DSI_TCCR4_LPWR_TOCNT9_Msk   (0x1UL << DSI_TCCR4_LPWR_TOCNT9_Pos)
#define DSI_TCCR4_LPWR_TOCNT9   DSI_TCCR4_LPWR_TOCNT9_Msk
#define DSI_TCCR4_LPWR_TOCNT10_Pos   (10U)
#define DSI_TCCR4_LPWR_TOCNT10_Msk   (0x1UL << DSI_TCCR4_LPWR_TOCNT10_Pos)
#define DSI_TCCR4_LPWR_TOCNT10   DSI_TCCR4_LPWR_TOCNT10_Msk
#define DSI_TCCR4_LPWR_TOCNT11_Pos   (11U)
#define DSI_TCCR4_LPWR_TOCNT11_Msk   (0x1UL << DSI_TCCR4_LPWR_TOCNT11_Pos)
#define DSI_TCCR4_LPWR_TOCNT11   DSI_TCCR4_LPWR_TOCNT11_Msk
#define DSI_TCCR4_LPWR_TOCNT12_Pos   (12U)
#define DSI_TCCR4_LPWR_TOCNT12_Msk   (0x1UL << DSI_TCCR4_LPWR_TOCNT12_Pos)
#define DSI_TCCR4_LPWR_TOCNT12   DSI_TCCR4_LPWR_TOCNT12_Msk
#define DSI_TCCR4_LPWR_TOCNT13_Pos   (13U)
#define DSI_TCCR4_LPWR_TOCNT13_Msk   (0x1UL << DSI_TCCR4_LPWR_TOCNT13_Pos)
#define DSI_TCCR4_LPWR_TOCNT13   DSI_TCCR4_LPWR_TOCNT13_Msk
#define DSI_TCCR4_LPWR_TOCNT14_Pos   (14U)
#define DSI_TCCR4_LPWR_TOCNT14_Msk   (0x1UL << DSI_TCCR4_LPWR_TOCNT14_Pos)
#define DSI_TCCR4_LPWR_TOCNT14   DSI_TCCR4_LPWR_TOCNT14_Msk
#define DSI_TCCR4_LPWR_TOCNT15_Pos   (15U)
#define DSI_TCCR4_LPWR_TOCNT15_Msk   (0x1UL << DSI_TCCR4_LPWR_TOCNT15_Pos)
#define DSI_TCCR4_LPWR_TOCNT15   DSI_TCCR4_LPWR_TOCNT15_Msk
#define DSI_TCCR5_BTA_TOCNT_Pos   (0U)
#define DSI_TCCR5_BTA_TOCNT_Msk   (0xFFFFUL << DSI_TCCR5_BTA_TOCNT_Pos)
#define DSI_TCCR5_BTA_TOCNT   DSI_TCCR5_BTA_TOCNT_Msk
#define DSI_TCCR5_BTA_TOCNT0_Pos   (0U)
#define DSI_TCCR5_BTA_TOCNT0_Msk   (0x1UL << DSI_TCCR5_BTA_TOCNT0_Pos)
#define DSI_TCCR5_BTA_TOCNT0   DSI_TCCR5_BTA_TOCNT0_Msk
#define DSI_TCCR5_BTA_TOCNT1_Pos   (1U)
#define DSI_TCCR5_BTA_TOCNT1_Msk   (0x1UL << DSI_TCCR5_BTA_TOCNT1_Pos)
#define DSI_TCCR5_BTA_TOCNT1   DSI_TCCR5_BTA_TOCNT1_Msk
#define DSI_TCCR5_BTA_TOCNT2_Pos   (2U)
#define DSI_TCCR5_BTA_TOCNT2_Msk   (0x1UL << DSI_TCCR5_BTA_TOCNT2_Pos)
#define DSI_TCCR5_BTA_TOCNT2   DSI_TCCR5_BTA_TOCNT2_Msk
#define DSI_TCCR5_BTA_TOCNT3_Pos   (3U)
#define DSI_TCCR5_BTA_TOCNT3_Msk   (0x1UL << DSI_TCCR5_BTA_TOCNT3_Pos)
#define DSI_TCCR5_BTA_TOCNT3   DSI_TCCR5_BTA_TOCNT3_Msk
#define DSI_TCCR5_BTA_TOCNT4_Pos   (4U)
#define DSI_TCCR5_BTA_TOCNT4_Msk   (0x1UL << DSI_TCCR5_BTA_TOCNT4_Pos)
#define DSI_TCCR5_BTA_TOCNT4   DSI_TCCR5_BTA_TOCNT4_Msk
#define DSI_TCCR5_BTA_TOCNT5_Pos   (5U)
#define DSI_TCCR5_BTA_TOCNT5_Msk   (0x1UL << DSI_TCCR5_BTA_TOCNT5_Pos)
#define DSI_TCCR5_BTA_TOCNT5   DSI_TCCR5_BTA_TOCNT5_Msk
#define DSI_TCCR5_BTA_TOCNT6_Pos   (6U)
#define DSI_TCCR5_BTA_TOCNT6_Msk   (0x1UL << DSI_TCCR5_BTA_TOCNT6_Pos)
#define DSI_TCCR5_BTA_TOCNT6   DSI_TCCR5_BTA_TOCNT6_Msk
#define DSI_TCCR5_BTA_TOCNT7_Pos   (7U)
#define DSI_TCCR5_BTA_TOCNT7_Msk   (0x1UL << DSI_TCCR5_BTA_TOCNT7_Pos)
#define DSI_TCCR5_BTA_TOCNT7   DSI_TCCR5_BTA_TOCNT7_Msk
#define DSI_TCCR5_BTA_TOCNT8_Pos   (8U)
#define DSI_TCCR5_BTA_TOCNT8_Msk   (0x1UL << DSI_TCCR5_BTA_TOCNT8_Pos)
#define DSI_TCCR5_BTA_TOCNT8   DSI_TCCR5_BTA_TOCNT8_Msk
#define DSI_TCCR5_BTA_TOCNT9_Pos   (9U)
#define DSI_TCCR5_BTA_TOCNT9_Msk   (0x1UL << DSI_TCCR5_BTA_TOCNT9_Pos)
#define DSI_TCCR5_BTA_TOCNT9   DSI_TCCR5_BTA_TOCNT9_Msk
#define DSI_TCCR5_BTA_TOCNT10_Pos   (10U)
#define DSI_TCCR5_BTA_TOCNT10_Msk   (0x1UL << DSI_TCCR5_BTA_TOCNT10_Pos)
#define DSI_TCCR5_BTA_TOCNT10   DSI_TCCR5_BTA_TOCNT10_Msk
#define DSI_TCCR5_BTA_TOCNT11_Pos   (11U)
#define DSI_TCCR5_BTA_TOCNT11_Msk   (0x1UL << DSI_TCCR5_BTA_TOCNT11_Pos)
#define DSI_TCCR5_BTA_TOCNT11   DSI_TCCR5_BTA_TOCNT11_Msk
#define DSI_TCCR5_BTA_TOCNT12_Pos   (12U)
#define DSI_TCCR5_BTA_TOCNT12_Msk   (0x1UL << DSI_TCCR5_BTA_TOCNT12_Pos)
#define DSI_TCCR5_BTA_TOCNT12   DSI_TCCR5_BTA_TOCNT12_Msk
#define DSI_TCCR5_BTA_TOCNT13_Pos   (13U)
#define DSI_TCCR5_BTA_TOCNT13_Msk   (0x1UL << DSI_TCCR5_BTA_TOCNT13_Pos)
#define DSI_TCCR5_BTA_TOCNT13   DSI_TCCR5_BTA_TOCNT13_Msk
#define DSI_TCCR5_BTA_TOCNT14_Pos   (14U)
#define DSI_TCCR5_BTA_TOCNT14_Msk   (0x1UL << DSI_TCCR5_BTA_TOCNT14_Pos)
#define DSI_TCCR5_BTA_TOCNT14   DSI_TCCR5_BTA_TOCNT14_Msk
#define DSI_TCCR5_BTA_TOCNT15_Pos   (15U)
#define DSI_TCCR5_BTA_TOCNT15_Msk   (0x1UL << DSI_TCCR5_BTA_TOCNT15_Pos)
#define DSI_TCCR5_BTA_TOCNT15   DSI_TCCR5_BTA_TOCNT15_Msk
#define DSI_CLCR_DPCC_Pos   (0U)
#define DSI_CLCR_DPCC_Msk   (0x1UL << DSI_CLCR_DPCC_Pos)
#define DSI_CLCR_DPCC   DSI_CLCR_DPCC_Msk
#define DSI_CLCR_ACR_Pos   (1U)
#define DSI_CLCR_ACR_Msk   (0x1UL << DSI_CLCR_ACR_Pos)
#define DSI_CLCR_ACR   DSI_CLCR_ACR_Msk
#define DSI_CLTCR_LP2HS_TIME_Pos   (0U)
#define DSI_CLTCR_LP2HS_TIME_Msk   (0x3FFUL << DSI_CLTCR_LP2HS_TIME_Pos)
#define DSI_CLTCR_LP2HS_TIME   DSI_CLTCR_LP2HS_TIME_Msk
#define DSI_CLTCR_LP2HS_TIME0_Pos   (0U)
#define DSI_CLTCR_LP2HS_TIME0_Msk   (0x1UL << DSI_CLTCR_LP2HS_TIME0_Pos)
#define DSI_CLTCR_LP2HS_TIME0   DSI_CLTCR_LP2HS_TIME0_Msk
#define DSI_CLTCR_LP2HS_TIME1_Pos   (1U)
#define DSI_CLTCR_LP2HS_TIME1_Msk   (0x1UL << DSI_CLTCR_LP2HS_TIME1_Pos)
#define DSI_CLTCR_LP2HS_TIME1   DSI_CLTCR_LP2HS_TIME1_Msk
#define DSI_CLTCR_LP2HS_TIME2_Pos   (2U)
#define DSI_CLTCR_LP2HS_TIME2_Msk   (0x1UL << DSI_CLTCR_LP2HS_TIME2_Pos)
#define DSI_CLTCR_LP2HS_TIME2   DSI_CLTCR_LP2HS_TIME2_Msk
#define DSI_CLTCR_LP2HS_TIME3_Pos   (3U)
#define DSI_CLTCR_LP2HS_TIME3_Msk   (0x1UL << DSI_CLTCR_LP2HS_TIME3_Pos)
#define DSI_CLTCR_LP2HS_TIME3   DSI_CLTCR_LP2HS_TIME3_Msk
#define DSI_CLTCR_LP2HS_TIME4_Pos   (4U)
#define DSI_CLTCR_LP2HS_TIME4_Msk   (0x1UL << DSI_CLTCR_LP2HS_TIME4_Pos)
#define DSI_CLTCR_LP2HS_TIME4   DSI_CLTCR_LP2HS_TIME4_Msk
#define DSI_CLTCR_LP2HS_TIME5_Pos   (5U)
#define DSI_CLTCR_LP2HS_TIME5_Msk   (0x1UL << DSI_CLTCR_LP2HS_TIME5_Pos)
#define DSI_CLTCR_LP2HS_TIME5   DSI_CLTCR_LP2HS_TIME5_Msk
#define DSI_CLTCR_LP2HS_TIME6_Pos   (6U)
#define DSI_CLTCR_LP2HS_TIME6_Msk   (0x1UL << DSI_CLTCR_LP2HS_TIME6_Pos)
#define DSI_CLTCR_LP2HS_TIME6   DSI_CLTCR_LP2HS_TIME6_Msk
#define DSI_CLTCR_LP2HS_TIME7_Pos   (7U)
#define DSI_CLTCR_LP2HS_TIME7_Msk   (0x1UL << DSI_CLTCR_LP2HS_TIME7_Pos)
#define DSI_CLTCR_LP2HS_TIME7   DSI_CLTCR_LP2HS_TIME7_Msk
#define DSI_CLTCR_LP2HS_TIME8_Pos   (8U)
#define DSI_CLTCR_LP2HS_TIME8_Msk   (0x1UL << DSI_CLTCR_LP2HS_TIME8_Pos)
#define DSI_CLTCR_LP2HS_TIME8   DSI_CLTCR_LP2HS_TIME8_Msk
#define DSI_CLTCR_LP2HS_TIME9_Pos   (9U)
#define DSI_CLTCR_LP2HS_TIME9_Msk   (0x1UL << DSI_CLTCR_LP2HS_TIME9_Pos)
#define DSI_CLTCR_LP2HS_TIME9   DSI_CLTCR_LP2HS_TIME9_Msk
#define DSI_CLTCR_HS2LP_TIME_Pos   (16U)
#define DSI_CLTCR_HS2LP_TIME_Msk   (0x3FFUL << DSI_CLTCR_HS2LP_TIME_Pos)
#define DSI_CLTCR_HS2LP_TIME   DSI_CLTCR_HS2LP_TIME_Msk
#define DSI_CLTCR_HS2LP_TIME0_Pos   (16U)
#define DSI_CLTCR_HS2LP_TIME0_Msk   (0x1UL << DSI_CLTCR_HS2LP_TIME0_Pos)
#define DSI_CLTCR_HS2LP_TIME0   DSI_CLTCR_HS2LP_TIME0_Msk
#define DSI_CLTCR_HS2LP_TIME1_Pos   (17U)
#define DSI_CLTCR_HS2LP_TIME1_Msk   (0x1UL << DSI_CLTCR_HS2LP_TIME1_Pos)
#define DSI_CLTCR_HS2LP_TIME1   DSI_CLTCR_HS2LP_TIME1_Msk
#define DSI_CLTCR_HS2LP_TIME2_Pos   (18U)
#define DSI_CLTCR_HS2LP_TIME2_Msk   (0x1UL << DSI_CLTCR_HS2LP_TIME2_Pos)
#define DSI_CLTCR_HS2LP_TIME2   DSI_CLTCR_HS2LP_TIME2_Msk
#define DSI_CLTCR_HS2LP_TIME3_Pos   (19U)
#define DSI_CLTCR_HS2LP_TIME3_Msk   (0x1UL << DSI_CLTCR_HS2LP_TIME3_Pos)
#define DSI_CLTCR_HS2LP_TIME3   DSI_CLTCR_HS2LP_TIME3_Msk
#define DSI_CLTCR_HS2LP_TIME4_Pos   (20U)
#define DSI_CLTCR_HS2LP_TIME4_Msk   (0x1UL << DSI_CLTCR_HS2LP_TIME4_Pos)
#define DSI_CLTCR_HS2LP_TIME4   DSI_CLTCR_HS2LP_TIME4_Msk
#define DSI_CLTCR_HS2LP_TIME5_Pos   (21U)
#define DSI_CLTCR_HS2LP_TIME5_Msk   (0x1UL << DSI_CLTCR_HS2LP_TIME5_Pos)
#define DSI_CLTCR_HS2LP_TIME5   DSI_CLTCR_HS2LP_TIME5_Msk
#define DSI_CLTCR_HS2LP_TIME6_Pos   (22U)
#define DSI_CLTCR_HS2LP_TIME6_Msk   (0x1UL << DSI_CLTCR_HS2LP_TIME6_Pos)
#define DSI_CLTCR_HS2LP_TIME6   DSI_CLTCR_HS2LP_TIME6_Msk
#define DSI_CLTCR_HS2LP_TIME7_Pos   (23U)
#define DSI_CLTCR_HS2LP_TIME7_Msk   (0x1UL << DSI_CLTCR_HS2LP_TIME7_Pos)
#define DSI_CLTCR_HS2LP_TIME7   DSI_CLTCR_HS2LP_TIME7_Msk
#define DSI_CLTCR_HS2LP_TIME8_Pos   (24U)
#define DSI_CLTCR_HS2LP_TIME8_Msk   (0x1UL << DSI_CLTCR_HS2LP_TIME8_Pos)
#define DSI_CLTCR_HS2LP_TIME8   DSI_CLTCR_HS2LP_TIME8_Msk
#define DSI_CLTCR_HS2LP_TIME9_Pos   (25U)
#define DSI_CLTCR_HS2LP_TIME9_Msk   (0x1UL << DSI_CLTCR_HS2LP_TIME9_Pos)
#define DSI_CLTCR_HS2LP_TIME9   DSI_CLTCR_HS2LP_TIME9_Msk
#define DSI_DLTCR_LP2HS_TIME_Pos   (0U)
#define DSI_DLTCR_LP2HS_TIME_Msk   (0x3FFUL << DSI_DLTCR_LP2HS_TIME_Pos)
#define DSI_DLTCR_LP2HS_TIME   DSI_DLTCR_LP2HS_TIME_Msk
#define DSI_DLTCR_LP2HS_TIME0_Pos   (0U)
#define DSI_DLTCR_LP2HS_TIME0_Msk   (0x1UL << DSI_DLTCR_LP2HS_TIME0_Pos)
#define DSI_DLTCR_LP2HS_TIME0   DSI_DLTCR_LP2HS_TIME0_Msk
#define DSI_DLTCR_LP2HS_TIME1_Pos   (1U)
#define DSI_DLTCR_LP2HS_TIME1_Msk   (0x1UL << DSI_DLTCR_LP2HS_TIME1_Pos)
#define DSI_DLTCR_LP2HS_TIME1   DSI_DLTCR_LP2HS_TIME1_Msk
#define DSI_DLTCR_LP2HS_TIME2_Pos   (2U)
#define DSI_DLTCR_LP2HS_TIME2_Msk   (0x1UL << DSI_DLTCR_LP2HS_TIME2_Pos)
#define DSI_DLTCR_LP2HS_TIME2   DSI_DLTCR_LP2HS_TIME2_Msk
#define DSI_DLTCR_LP2HS_TIME3_Pos   (3U)
#define DSI_DLTCR_LP2HS_TIME3_Msk   (0x1UL << DSI_DLTCR_LP2HS_TIME3_Pos)
#define DSI_DLTCR_LP2HS_TIME3   DSI_DLTCR_LP2HS_TIME3_Msk
#define DSI_DLTCR_LP2HS_TIME4_Pos   (4U)
#define DSI_DLTCR_LP2HS_TIME4_Msk   (0x1UL << DSI_DLTCR_LP2HS_TIME4_Pos)
#define DSI_DLTCR_LP2HS_TIME4   DSI_DLTCR_LP2HS_TIME4_Msk
#define DSI_DLTCR_LP2HS_TIME5_Pos   (5U)
#define DSI_DLTCR_LP2HS_TIME5_Msk   (0x1UL << DSI_DLTCR_LP2HS_TIME5_Pos)
#define DSI_DLTCR_LP2HS_TIME5   DSI_DLTCR_LP2HS_TIME5_Msk
#define DSI_DLTCR_LP2HS_TIME6_Pos   (6U)
#define DSI_DLTCR_LP2HS_TIME6_Msk   (0x1UL << DSI_DLTCR_LP2HS_TIME6_Pos)
#define DSI_DLTCR_LP2HS_TIME6   DSI_DLTCR_LP2HS_TIME6_Msk
#define DSI_DLTCR_LP2HS_TIME7_Pos   (7U)
#define DSI_DLTCR_LP2HS_TIME7_Msk   (0x1UL << DSI_DLTCR_LP2HS_TIME7_Pos)
#define DSI_DLTCR_LP2HS_TIME7   DSI_DLTCR_LP2HS_TIME7_Msk
#define DSI_DLTCR_LP2HS_TIME8_Pos   (8U)
#define DSI_DLTCR_LP2HS_TIME8_Msk   (0x1UL << DSI_DLTCR_LP2HS_TIME8_Pos)
#define DSI_DLTCR_LP2HS_TIME8   DSI_DLTCR_LP2HS_TIME8_Msk
#define DSI_DLTCR_LP2HS_TIME9_Pos   (9U)
#define DSI_DLTCR_LP2HS_TIME9_Msk   (0x1UL << DSI_DLTCR_LP2HS_TIME9_Pos)
#define DSI_DLTCR_LP2HS_TIME9   DSI_DLTCR_LP2HS_TIME9_Msk
#define DSI_DLTCR_HS2LP_TIME_Pos   (16U)
#define DSI_DLTCR_HS2LP_TIME_Msk   (0x3FFUL << DSI_DLTCR_HS2LP_TIME_Pos)
#define DSI_DLTCR_HS2LP_TIME   DSI_DLTCR_HS2LP_TIME_Msk
#define DSI_DLTCR_HS2LP_TIME0_Pos   (16U)
#define DSI_DLTCR_HS2LP_TIME0_Msk   (0x1UL << DSI_DLTCR_HS2LP_TIME0_Pos)
#define DSI_DLTCR_HS2LP_TIME0   DSI_DLTCR_HS2LP_TIME0_Msk
#define DSI_DLTCR_HS2LP_TIME1_Pos   (17U)
#define DSI_DLTCR_HS2LP_TIME1_Msk   (0x1UL << DSI_DLTCR_HS2LP_TIME1_Pos)
#define DSI_DLTCR_HS2LP_TIME1   DSI_DLTCR_HS2LP_TIME1_Msk
#define DSI_DLTCR_HS2LP_TIME2_Pos   (18U)
#define DSI_DLTCR_HS2LP_TIME2_Msk   (0x1UL << DSI_DLTCR_HS2LP_TIME2_Pos)
#define DSI_DLTCR_HS2LP_TIME2   DSI_DLTCR_HS2LP_TIME2_Msk
#define DSI_DLTCR_HS2LP_TIME3_Pos   (19U)
#define DSI_DLTCR_HS2LP_TIME3_Msk   (0x1UL << DSI_DLTCR_HS2LP_TIME3_Pos)
#define DSI_DLTCR_HS2LP_TIME3   DSI_DLTCR_HS2LP_TIME3_Msk
#define DSI_DLTCR_HS2LP_TIME4_Pos   (20U)
#define DSI_DLTCR_HS2LP_TIME4_Msk   (0x1UL << DSI_DLTCR_HS2LP_TIME4_Pos)
#define DSI_DLTCR_HS2LP_TIME4   DSI_DLTCR_HS2LP_TIME4_Msk
#define DSI_DLTCR_HS2LP_TIME5_Pos   (21U)
#define DSI_DLTCR_HS2LP_TIME5_Msk   (0x1UL << DSI_DLTCR_HS2LP_TIME5_Pos)
#define DSI_DLTCR_HS2LP_TIME5   DSI_DLTCR_HS2LP_TIME5_Msk
#define DSI_DLTCR_HS2LP_TIME6_Pos   (22U)
#define DSI_DLTCR_HS2LP_TIME6_Msk   (0x1UL << DSI_DLTCR_HS2LP_TIME6_Pos)
#define DSI_DLTCR_HS2LP_TIME6   DSI_DLTCR_HS2LP_TIME6_Msk
#define DSI_DLTCR_HS2LP_TIME7_Pos   (23U)
#define DSI_DLTCR_HS2LP_TIME7_Msk   (0x1UL << DSI_DLTCR_HS2LP_TIME7_Pos)
#define DSI_DLTCR_HS2LP_TIME7   DSI_DLTCR_HS2LP_TIME7_Msk
#define DSI_DLTCR_HS2LP_TIME8_Pos   (24U)
#define DSI_DLTCR_HS2LP_TIME8_Msk   (0x1UL << DSI_DLTCR_HS2LP_TIME8_Pos)
#define DSI_DLTCR_HS2LP_TIME8   DSI_DLTCR_HS2LP_TIME8_Msk
#define DSI_DLTCR_HS2LP_TIME9_Pos   (25U)
#define DSI_DLTCR_HS2LP_TIME9_Msk   (0x1UL << DSI_DLTCR_HS2LP_TIME9_Pos)
#define DSI_DLTCR_HS2LP_TIME9   DSI_DLTCR_HS2LP_TIME9_Msk
#define DSI_PCTLR_DEN_Pos   (1U)
#define DSI_PCTLR_DEN_Msk   (0x1UL << DSI_PCTLR_DEN_Pos)
#define DSI_PCTLR_DEN   DSI_PCTLR_DEN_Msk
#define DSI_PCTLR_CKE_Pos   (2U)
#define DSI_PCTLR_CKE_Msk   (0x1UL << DSI_PCTLR_CKE_Pos)
#define DSI_PCTLR_CKE   DSI_PCTLR_CKE_Msk
#define DSI_PCONFR_NL_Pos   (0U)
#define DSI_PCONFR_NL_Msk   (0x3UL << DSI_PCONFR_NL_Pos)
#define DSI_PCONFR_NL   DSI_PCONFR_NL_Msk
#define DSI_PCONFR_NL0_Pos   (0U)
#define DSI_PCONFR_NL0_Msk   (0x1UL << DSI_PCONFR_NL0_Pos)
#define DSI_PCONFR_NL0   DSI_PCONFR_NL0_Msk
#define DSI_PCONFR_NL1_Pos   (1U)
#define DSI_PCONFR_NL1_Msk   (0x1UL << DSI_PCONFR_NL1_Pos)
#define DSI_PCONFR_NL1   DSI_PCONFR_NL1_Msk
#define DSI_PCONFR_SW_TIME_Pos   (8U)
#define DSI_PCONFR_SW_TIME_Msk   (0xFFUL << DSI_PCONFR_SW_TIME_Pos)
#define DSI_PCONFR_SW_TIME   DSI_PCONFR_SW_TIME_Msk
#define DSI_PCONFR_SW_TIME0_Pos   (8U)
#define DSI_PCONFR_SW_TIME0_Msk   (0x1UL << DSI_PCONFR_SW_TIME0_Pos)
#define DSI_PCONFR_SW_TIME0   DSI_PCONFR_SW_TIME0_Msk
#define DSI_PCONFR_SW_TIME1_Pos   (9U)
#define DSI_PCONFR_SW_TIME1_Msk   (0x1UL << DSI_PCONFR_SW_TIME1_Pos)
#define DSI_PCONFR_SW_TIME1   DSI_PCONFR_SW_TIME1_Msk
#define DSI_PCONFR_SW_TIME2_Pos   (10U)
#define DSI_PCONFR_SW_TIME2_Msk   (0x1UL << DSI_PCONFR_SW_TIME2_Pos)
#define DSI_PCONFR_SW_TIME2   DSI_PCONFR_SW_TIME2_Msk
#define DSI_PCONFR_SW_TIME3_Pos   (11U)
#define DSI_PCONFR_SW_TIME3_Msk   (0x1UL << DSI_PCONFR_SW_TIME3_Pos)
#define DSI_PCONFR_SW_TIME3   DSI_PCONFR_SW_TIME3_Msk
#define DSI_PCONFR_SW_TIME4_Pos   (12U)
#define DSI_PCONFR_SW_TIME4_Msk   (0x1UL << DSI_PCONFR_SW_TIME4_Pos)
#define DSI_PCONFR_SW_TIME4   DSI_PCONFR_SW_TIME4_Msk
#define DSI_PCONFR_SW_TIME5_Pos   (13U)
#define DSI_PCONFR_SW_TIME5_Msk   (0x1UL << DSI_PCONFR_SW_TIME5_Pos)
#define DSI_PCONFR_SW_TIME5   DSI_PCONFR_SW_TIME5_Msk
#define DSI_PCONFR_SW_TIME6_Pos   (14U)
#define DSI_PCONFR_SW_TIME6_Msk   (0x1UL << DSI_PCONFR_SW_TIME6_Pos)
#define DSI_PCONFR_SW_TIME6   DSI_PCONFR_SW_TIME6_Msk
#define DSI_PCONFR_SW_TIME7_Pos   (15U)
#define DSI_PCONFR_SW_TIME7_Msk   (0x1UL << DSI_PCONFR_SW_TIME7_Pos)
#define DSI_PCONFR_SW_TIME7   DSI_PCONFR_SW_TIME7_Msk
#define DSI_PUCR_URCL_Pos   (0U)
#define DSI_PUCR_URCL_Msk   (0x1UL << DSI_PUCR_URCL_Pos)
#define DSI_PUCR_URCL   DSI_PUCR_URCL_Msk
#define DSI_PUCR_UECL_Pos   (1U)
#define DSI_PUCR_UECL_Msk   (0x1UL << DSI_PUCR_UECL_Pos)
#define DSI_PUCR_UECL   DSI_PUCR_UECL_Msk
#define DSI_PUCR_URDL_Pos   (2U)
#define DSI_PUCR_URDL_Msk   (0x1UL << DSI_PUCR_URDL_Pos)
#define DSI_PUCR_URDL   DSI_PUCR_URDL_Msk
#define DSI_PUCR_UEDL_Pos   (3U)
#define DSI_PUCR_UEDL_Msk   (0x1UL << DSI_PUCR_UEDL_Pos)
#define DSI_PUCR_UEDL   DSI_PUCR_UEDL_Msk
#define DSI_PTTCR_TX_TRIG_Pos   (0U)
#define DSI_PTTCR_TX_TRIG_Msk   (0xFUL << DSI_PTTCR_TX_TRIG_Pos)
#define DSI_PTTCR_TX_TRIG   DSI_PTTCR_TX_TRIG_Msk
#define DSI_PTTCR_TX_TRIG0_Pos   (0U)
#define DSI_PTTCR_TX_TRIG0_Msk   (0x1UL << DSI_PTTCR_TX_TRIG0_Pos)
#define DSI_PTTCR_TX_TRIG0   DSI_PTTCR_TX_TRIG0_Msk
#define DSI_PTTCR_TX_TRIG1_Pos   (1U)
#define DSI_PTTCR_TX_TRIG1_Msk   (0x1UL << DSI_PTTCR_TX_TRIG1_Pos)
#define DSI_PTTCR_TX_TRIG1   DSI_PTTCR_TX_TRIG1_Msk
#define DSI_PTTCR_TX_TRIG2_Pos   (2U)
#define DSI_PTTCR_TX_TRIG2_Msk   (0x1UL << DSI_PTTCR_TX_TRIG2_Pos)
#define DSI_PTTCR_TX_TRIG2   DSI_PTTCR_TX_TRIG2_Msk
#define DSI_PTTCR_TX_TRIG3_Pos   (3U)
#define DSI_PTTCR_TX_TRIG3_Msk   (0x1UL << DSI_PTTCR_TX_TRIG3_Pos)
#define DSI_PTTCR_TX_TRIG3   DSI_PTTCR_TX_TRIG3_Msk
#define DSI_PSR_PD_Pos   (1U)
#define DSI_PSR_PD_Msk   (0x1UL << DSI_PSR_PD_Pos)
#define DSI_PSR_PD   DSI_PSR_PD_Msk
#define DSI_PSR_PSSC_Pos   (2U)
#define DSI_PSR_PSSC_Msk   (0x1UL << DSI_PSR_PSSC_Pos)
#define DSI_PSR_PSSC   DSI_PSR_PSSC_Msk
#define DSI_PSR_UANC_Pos   (3U)
#define DSI_PSR_UANC_Msk   (0x1UL << DSI_PSR_UANC_Pos)
#define DSI_PSR_UANC   DSI_PSR_UANC_Msk
#define DSI_PSR_PSS0_Pos   (4U)
#define DSI_PSR_PSS0_Msk   (0x1UL << DSI_PSR_PSS0_Pos)
#define DSI_PSR_PSS0   DSI_PSR_PSS0_Msk
#define DSI_PSR_UAN0_Pos   (5U)
#define DSI_PSR_UAN0_Msk   (0x1UL << DSI_PSR_UAN0_Pos)
#define DSI_PSR_UAN0   DSI_PSR_UAN0_Msk
#define DSI_PSR_RUE0_Pos   (6U)
#define DSI_PSR_RUE0_Msk   (0x1UL << DSI_PSR_RUE0_Pos)
#define DSI_PSR_RUE0   DSI_PSR_RUE0_Msk
#define DSI_PSR_PSS1_Pos   (7U)
#define DSI_PSR_PSS1_Msk   (0x1UL << DSI_PSR_PSS1_Pos)
#define DSI_PSR_PSS1   DSI_PSR_PSS1_Msk
#define DSI_PSR_UAN1_Pos   (8U)
#define DSI_PSR_UAN1_Msk   (0x1UL << DSI_PSR_UAN1_Pos)
#define DSI_PSR_UAN1   DSI_PSR_UAN1_Msk
#define DSI_ISR0_AE0_Pos   (0U)
#define DSI_ISR0_AE0_Msk   (0x1UL << DSI_ISR0_AE0_Pos)
#define DSI_ISR0_AE0   DSI_ISR0_AE0_Msk
#define DSI_ISR0_AE1_Pos   (1U)
#define DSI_ISR0_AE1_Msk   (0x1UL << DSI_ISR0_AE1_Pos)
#define DSI_ISR0_AE1   DSI_ISR0_AE1_Msk
#define DSI_ISR0_AE2_Pos   (2U)
#define DSI_ISR0_AE2_Msk   (0x1UL << DSI_ISR0_AE2_Pos)
#define DSI_ISR0_AE2   DSI_ISR0_AE2_Msk
#define DSI_ISR0_AE3_Pos   (3U)
#define DSI_ISR0_AE3_Msk   (0x1UL << DSI_ISR0_AE3_Pos)
#define DSI_ISR0_AE3   DSI_ISR0_AE3_Msk
#define DSI_ISR0_AE4_Pos   (4U)
#define DSI_ISR0_AE4_Msk   (0x1UL << DSI_ISR0_AE4_Pos)
#define DSI_ISR0_AE4   DSI_ISR0_AE4_Msk
#define DSI_ISR0_AE5_Pos   (5U)
#define DSI_ISR0_AE5_Msk   (0x1UL << DSI_ISR0_AE5_Pos)
#define DSI_ISR0_AE5   DSI_ISR0_AE5_Msk
#define DSI_ISR0_AE6_Pos   (6U)
#define DSI_ISR0_AE6_Msk   (0x1UL << DSI_ISR0_AE6_Pos)
#define DSI_ISR0_AE6   DSI_ISR0_AE6_Msk
#define DSI_ISR0_AE7_Pos   (7U)
#define DSI_ISR0_AE7_Msk   (0x1UL << DSI_ISR0_AE7_Pos)
#define DSI_ISR0_AE7   DSI_ISR0_AE7_Msk
#define DSI_ISR0_AE8_Pos   (8U)
#define DSI_ISR0_AE8_Msk   (0x1UL << DSI_ISR0_AE8_Pos)
#define DSI_ISR0_AE8   DSI_ISR0_AE8_Msk
#define DSI_ISR0_AE9_Pos   (9U)
#define DSI_ISR0_AE9_Msk   (0x1UL << DSI_ISR0_AE9_Pos)
#define DSI_ISR0_AE9   DSI_ISR0_AE9_Msk
#define DSI_ISR0_AE10_Pos   (10U)
#define DSI_ISR0_AE10_Msk   (0x1UL << DSI_ISR0_AE10_Pos)
#define DSI_ISR0_AE10   DSI_ISR0_AE10_Msk
#define DSI_ISR0_AE11_Pos   (11U)
#define DSI_ISR0_AE11_Msk   (0x1UL << DSI_ISR0_AE11_Pos)
#define DSI_ISR0_AE11   DSI_ISR0_AE11_Msk
#define DSI_ISR0_AE12_Pos   (12U)
#define DSI_ISR0_AE12_Msk   (0x1UL << DSI_ISR0_AE12_Pos)
#define DSI_ISR0_AE12   DSI_ISR0_AE12_Msk
#define DSI_ISR0_AE13_Pos   (13U)
#define DSI_ISR0_AE13_Msk   (0x1UL << DSI_ISR0_AE13_Pos)
#define DSI_ISR0_AE13   DSI_ISR0_AE13_Msk
#define DSI_ISR0_AE14_Pos   (14U)
#define DSI_ISR0_AE14_Msk   (0x1UL << DSI_ISR0_AE14_Pos)
#define DSI_ISR0_AE14   DSI_ISR0_AE14_Msk
#define DSI_ISR0_AE15_Pos   (15U)
#define DSI_ISR0_AE15_Msk   (0x1UL << DSI_ISR0_AE15_Pos)
#define DSI_ISR0_AE15   DSI_ISR0_AE15_Msk
#define DSI_ISR0_PE0_Pos   (16U)
#define DSI_ISR0_PE0_Msk   (0x1UL << DSI_ISR0_PE0_Pos)
#define DSI_ISR0_PE0   DSI_ISR0_PE0_Msk
#define DSI_ISR0_PE1_Pos   (17U)
#define DSI_ISR0_PE1_Msk   (0x1UL << DSI_ISR0_PE1_Pos)
#define DSI_ISR0_PE1   DSI_ISR0_PE1_Msk
#define DSI_ISR0_PE2_Pos   (18U)
#define DSI_ISR0_PE2_Msk   (0x1UL << DSI_ISR0_PE2_Pos)
#define DSI_ISR0_PE2   DSI_ISR0_PE2_Msk
#define DSI_ISR0_PE3_Pos   (19U)
#define DSI_ISR0_PE3_Msk   (0x1UL << DSI_ISR0_PE3_Pos)
#define DSI_ISR0_PE3   DSI_ISR0_PE3_Msk
#define DSI_ISR0_PE4_Pos   (20U)
#define DSI_ISR0_PE4_Msk   (0x1UL << DSI_ISR0_PE4_Pos)
#define DSI_ISR0_PE4   DSI_ISR0_PE4_Msk
#define DSI_ISR1_TOHSTX_Pos   (0U)
#define DSI_ISR1_TOHSTX_Msk   (0x1UL << DSI_ISR1_TOHSTX_Pos)
#define DSI_ISR1_TOHSTX   DSI_ISR1_TOHSTX_Msk
#define DSI_ISR1_TOLPRX_Pos   (1U)
#define DSI_ISR1_TOLPRX_Msk   (0x1UL << DSI_ISR1_TOLPRX_Pos)
#define DSI_ISR1_TOLPRX   DSI_ISR1_TOLPRX_Msk
#define DSI_ISR1_ECCSE_Pos   (2U)
#define DSI_ISR1_ECCSE_Msk   (0x1UL << DSI_ISR1_ECCSE_Pos)
#define DSI_ISR1_ECCSE   DSI_ISR1_ECCSE_Msk
#define DSI_ISR1_ECCME_Pos   (3U)
#define DSI_ISR1_ECCME_Msk   (0x1UL << DSI_ISR1_ECCME_Pos)
#define DSI_ISR1_ECCME   DSI_ISR1_ECCME_Msk
#define DSI_ISR1_CRCE_Pos   (4U)
#define DSI_ISR1_CRCE_Msk   (0x1UL << DSI_ISR1_CRCE_Pos)
#define DSI_ISR1_CRCE   DSI_ISR1_CRCE_Msk
#define DSI_ISR1_PSE_Pos   (5U)
#define DSI_ISR1_PSE_Msk   (0x1UL << DSI_ISR1_PSE_Pos)
#define DSI_ISR1_PSE   DSI_ISR1_PSE_Msk
#define DSI_ISR1_EOTPE_Pos   (6U)
#define DSI_ISR1_EOTPE_Msk   (0x1UL << DSI_ISR1_EOTPE_Pos)
#define DSI_ISR1_EOTPE   DSI_ISR1_EOTPE_Msk
#define DSI_ISR1_LPWRE_Pos   (7U)
#define DSI_ISR1_LPWRE_Msk   (0x1UL << DSI_ISR1_LPWRE_Pos)
#define DSI_ISR1_LPWRE   DSI_ISR1_LPWRE_Msk
#define DSI_ISR1_GCWRE_Pos   (8U)
#define DSI_ISR1_GCWRE_Msk   (0x1UL << DSI_ISR1_GCWRE_Pos)
#define DSI_ISR1_GCWRE   DSI_ISR1_GCWRE_Msk
#define DSI_ISR1_GPWRE_Pos   (9U)
#define DSI_ISR1_GPWRE_Msk   (0x1UL << DSI_ISR1_GPWRE_Pos)
#define DSI_ISR1_GPWRE   DSI_ISR1_GPWRE_Msk
#define DSI_ISR1_GPTXE_Pos   (10U)
#define DSI_ISR1_GPTXE_Msk   (0x1UL << DSI_ISR1_GPTXE_Pos)
#define DSI_ISR1_GPTXE   DSI_ISR1_GPTXE_Msk
#define DSI_ISR1_GPRDE_Pos   (11U)
#define DSI_ISR1_GPRDE_Msk   (0x1UL << DSI_ISR1_GPRDE_Pos)
#define DSI_ISR1_GPRDE   DSI_ISR1_GPRDE_Msk
#define DSI_ISR1_GPRXE_Pos   (12U)
#define DSI_ISR1_GPRXE_Msk   (0x1UL << DSI_ISR1_GPRXE_Pos)
#define DSI_ISR1_GPRXE   DSI_ISR1_GPRXE_Msk
#define DSI_ISR1_PBUE_Pos   (19U)
#define DSI_ISR1_PBUE_Msk   (0x1UL << DSI_ISR1_PBUE_Pos)
#define DSI_ISR1_PBUE   DSI_ISR1_PBUE_Msk
#define DSI_IER0_AE0IE_Pos   (0U)
#define DSI_IER0_AE0IE_Msk   (0x1UL << DSI_IER0_AE0IE_Pos)
#define DSI_IER0_AE0IE   DSI_IER0_AE0IE_Msk
#define DSI_IER0_AE1IE_Pos   (1U)
#define DSI_IER0_AE1IE_Msk   (0x1UL << DSI_IER0_AE1IE_Pos)
#define DSI_IER0_AE1IE   DSI_IER0_AE1IE_Msk
#define DSI_IER0_AE2IE_Pos   (2U)
#define DSI_IER0_AE2IE_Msk   (0x1UL << DSI_IER0_AE2IE_Pos)
#define DSI_IER0_AE2IE   DSI_IER0_AE2IE_Msk
#define DSI_IER0_AE3IE_Pos   (3U)
#define DSI_IER0_AE3IE_Msk   (0x1UL << DSI_IER0_AE3IE_Pos)
#define DSI_IER0_AE3IE   DSI_IER0_AE3IE_Msk
#define DSI_IER0_AE4IE_Pos   (4U)
#define DSI_IER0_AE4IE_Msk   (0x1UL << DSI_IER0_AE4IE_Pos)
#define DSI_IER0_AE4IE   DSI_IER0_AE4IE_Msk
#define DSI_IER0_AE5IE_Pos   (5U)
#define DSI_IER0_AE5IE_Msk   (0x1UL << DSI_IER0_AE5IE_Pos)
#define DSI_IER0_AE5IE   DSI_IER0_AE5IE_Msk
#define DSI_IER0_AE6IE_Pos   (6U)
#define DSI_IER0_AE6IE_Msk   (0x1UL << DSI_IER0_AE6IE_Pos)
#define DSI_IER0_AE6IE   DSI_IER0_AE6IE_Msk
#define DSI_IER0_AE7IE_Pos   (7U)
#define DSI_IER0_AE7IE_Msk   (0x1UL << DSI_IER0_AE7IE_Pos)
#define DSI_IER0_AE7IE   DSI_IER0_AE7IE_Msk
#define DSI_IER0_AE8IE_Pos   (8U)
#define DSI_IER0_AE8IE_Msk   (0x1UL << DSI_IER0_AE8IE_Pos)
#define DSI_IER0_AE8IE   DSI_IER0_AE8IE_Msk
#define DSI_IER0_AE9IE_Pos   (9U)
#define DSI_IER0_AE9IE_Msk   (0x1UL << DSI_IER0_AE9IE_Pos)
#define DSI_IER0_AE9IE   DSI_IER0_AE9IE_Msk
#define DSI_IER0_AE10IE_Pos   (10U)
#define DSI_IER0_AE10IE_Msk   (0x1UL << DSI_IER0_AE10IE_Pos)
#define DSI_IER0_AE10IE   DSI_IER0_AE10IE_Msk
#define DSI_IER0_AE11IE_Pos   (11U)
#define DSI_IER0_AE11IE_Msk   (0x1UL << DSI_IER0_AE11IE_Pos)
#define DSI_IER0_AE11IE   DSI_IER0_AE11IE_Msk
#define DSI_IER0_AE12IE_Pos   (12U)
#define DSI_IER0_AE12IE_Msk   (0x1UL << DSI_IER0_AE12IE_Pos)
#define DSI_IER0_AE12IE   DSI_IER0_AE12IE_Msk
#define DSI_IER0_AE13IE_Pos   (13U)
#define DSI_IER0_AE13IE_Msk   (0x1UL << DSI_IER0_AE13IE_Pos)
#define DSI_IER0_AE13IE   DSI_IER0_AE13IE_Msk
#define DSI_IER0_AE14IE_Pos   (14U)
#define DSI_IER0_AE14IE_Msk   (0x1UL << DSI_IER0_AE14IE_Pos)
#define DSI_IER0_AE14IE   DSI_IER0_AE14IE_Msk
#define DSI_IER0_AE15IE_Pos   (15U)
#define DSI_IER0_AE15IE_Msk   (0x1UL << DSI_IER0_AE15IE_Pos)
#define DSI_IER0_AE15IE   DSI_IER0_AE15IE_Msk
#define DSI_IER0_PE0IE_Pos   (16U)
#define DSI_IER0_PE0IE_Msk   (0x1UL << DSI_IER0_PE0IE_Pos)
#define DSI_IER0_PE0IE   DSI_IER0_PE0IE_Msk
#define DSI_IER0_PE1IE_Pos   (17U)
#define DSI_IER0_PE1IE_Msk   (0x1UL << DSI_IER0_PE1IE_Pos)
#define DSI_IER0_PE1IE   DSI_IER0_PE1IE_Msk
#define DSI_IER0_PE2IE_Pos   (18U)
#define DSI_IER0_PE2IE_Msk   (0x1UL << DSI_IER0_PE2IE_Pos)
#define DSI_IER0_PE2IE   DSI_IER0_PE2IE_Msk
#define DSI_IER0_PE3IE_Pos   (19U)
#define DSI_IER0_PE3IE_Msk   (0x1UL << DSI_IER0_PE3IE_Pos)
#define DSI_IER0_PE3IE   DSI_IER0_PE3IE_Msk
#define DSI_IER0_PE4IE_Pos   (20U)
#define DSI_IER0_PE4IE_Msk   (0x1UL << DSI_IER0_PE4IE_Pos)
#define DSI_IER0_PE4IE   DSI_IER0_PE4IE_Msk
#define DSI_IER1_TOHSTXIE_Pos   (0U)
#define DSI_IER1_TOHSTXIE_Msk   (0x1UL << DSI_IER1_TOHSTXIE_Pos)
#define DSI_IER1_TOHSTXIE   DSI_IER1_TOHSTXIE_Msk
#define DSI_IER1_TOLPRXIE_Pos   (1U)
#define DSI_IER1_TOLPRXIE_Msk   (0x1UL << DSI_IER1_TOLPRXIE_Pos)
#define DSI_IER1_TOLPRXIE   DSI_IER1_TOLPRXIE_Msk
#define DSI_IER1_ECCSEIE_Pos   (2U)
#define DSI_IER1_ECCSEIE_Msk   (0x1UL << DSI_IER1_ECCSEIE_Pos)
#define DSI_IER1_ECCSEIE   DSI_IER1_ECCSEIE_Msk
#define DSI_IER1_ECCMEIE_Pos   (3U)
#define DSI_IER1_ECCMEIE_Msk   (0x1UL << DSI_IER1_ECCMEIE_Pos)
#define DSI_IER1_ECCMEIE   DSI_IER1_ECCMEIE_Msk
#define DSI_IER1_CRCEIE_Pos   (4U)
#define DSI_IER1_CRCEIE_Msk   (0x1UL << DSI_IER1_CRCEIE_Pos)
#define DSI_IER1_CRCEIE   DSI_IER1_CRCEIE_Msk
#define DSI_IER1_PSEIE_Pos   (5U)
#define DSI_IER1_PSEIE_Msk   (0x1UL << DSI_IER1_PSEIE_Pos)
#define DSI_IER1_PSEIE   DSI_IER1_PSEIE_Msk
#define DSI_IER1_EOTPEIE_Pos   (6U)
#define DSI_IER1_EOTPEIE_Msk   (0x1UL << DSI_IER1_EOTPEIE_Pos)
#define DSI_IER1_EOTPEIE   DSI_IER1_EOTPEIE_Msk
#define DSI_IER1_LPWREIE_Pos   (7U)
#define DSI_IER1_LPWREIE_Msk   (0x1UL << DSI_IER1_LPWREIE_Pos)
#define DSI_IER1_LPWREIE   DSI_IER1_LPWREIE_Msk
#define DSI_IER1_GCWREIE_Pos   (8U)
#define DSI_IER1_GCWREIE_Msk   (0x1UL << DSI_IER1_GCWREIE_Pos)
#define DSI_IER1_GCWREIE   DSI_IER1_GCWREIE_Msk
#define DSI_IER1_GPWREIE_Pos   (9U)
#define DSI_IER1_GPWREIE_Msk   (0x1UL << DSI_IER1_GPWREIE_Pos)
#define DSI_IER1_GPWREIE   DSI_IER1_GPWREIE_Msk
#define DSI_IER1_GPTXEIE_Pos   (10U)
#define DSI_IER1_GPTXEIE_Msk   (0x1UL << DSI_IER1_GPTXEIE_Pos)
#define DSI_IER1_GPTXEIE   DSI_IER1_GPTXEIE_Msk
#define DSI_IER1_GPRDEIE_Pos   (11U)
#define DSI_IER1_GPRDEIE_Msk   (0x1UL << DSI_IER1_GPRDEIE_Pos)
#define DSI_IER1_GPRDEIE   DSI_IER1_GPRDEIE_Msk
#define DSI_IER1_GPRXEIE_Pos   (12U)
#define DSI_IER1_GPRXEIE_Msk   (0x1UL << DSI_IER1_GPRXEIE_Pos)
#define DSI_IER1_GPRXEIE   DSI_IER1_GPRXEIE_Msk
#define DSI_IER1_PBUEIE_Pos   (19U)
#define DSI_IER1_PBUEIE_Msk   (0x1UL << DSI_IER1_PBUEIE_Pos)
#define DSI_IER1_PBUEIE   DSI_IER1_PBUEIE_Msk
#define DSI_FIR0_FAE0_Pos   (0U)
#define DSI_FIR0_FAE0_Msk   (0x1UL << DSI_FIR0_FAE0_Pos)
#define DSI_FIR0_FAE0   DSI_FIR0_FAE0_Msk
#define DSI_FIR0_FAE1_Pos   (1U)
#define DSI_FIR0_FAE1_Msk   (0x1UL << DSI_FIR0_FAE1_Pos)
#define DSI_FIR0_FAE1   DSI_FIR0_FAE1_Msk
#define DSI_FIR0_FAE2_Pos   (2U)
#define DSI_FIR0_FAE2_Msk   (0x1UL << DSI_FIR0_FAE2_Pos)
#define DSI_FIR0_FAE2   DSI_FIR0_FAE2_Msk
#define DSI_FIR0_FAE3_Pos   (3U)
#define DSI_FIR0_FAE3_Msk   (0x1UL << DSI_FIR0_FAE3_Pos)
#define DSI_FIR0_FAE3   DSI_FIR0_FAE3_Msk
#define DSI_FIR0_FAE4_Pos   (4U)
#define DSI_FIR0_FAE4_Msk   (0x1UL << DSI_FIR0_FAE4_Pos)
#define DSI_FIR0_FAE4   DSI_FIR0_FAE4_Msk
#define DSI_FIR0_FAE5_Pos   (5U)
#define DSI_FIR0_FAE5_Msk   (0x1UL << DSI_FIR0_FAE5_Pos)
#define DSI_FIR0_FAE5   DSI_FIR0_FAE5_Msk
#define DSI_FIR0_FAE6_Pos   (6U)
#define DSI_FIR0_FAE6_Msk   (0x1UL << DSI_FIR0_FAE6_Pos)
#define DSI_FIR0_FAE6   DSI_FIR0_FAE6_Msk
#define DSI_FIR0_FAE7_Pos   (7U)
#define DSI_FIR0_FAE7_Msk   (0x1UL << DSI_FIR0_FAE7_Pos)
#define DSI_FIR0_FAE7   DSI_FIR0_FAE7_Msk
#define DSI_FIR0_FAE8_Pos   (8U)
#define DSI_FIR0_FAE8_Msk   (0x1UL << DSI_FIR0_FAE8_Pos)
#define DSI_FIR0_FAE8   DSI_FIR0_FAE8_Msk
#define DSI_FIR0_FAE9_Pos   (9U)
#define DSI_FIR0_FAE9_Msk   (0x1UL << DSI_FIR0_FAE9_Pos)
#define DSI_FIR0_FAE9   DSI_FIR0_FAE9_Msk
#define DSI_FIR0_FAE10_Pos   (10U)
#define DSI_FIR0_FAE10_Msk   (0x1UL << DSI_FIR0_FAE10_Pos)
#define DSI_FIR0_FAE10   DSI_FIR0_FAE10_Msk
#define DSI_FIR0_FAE11_Pos   (11U)
#define DSI_FIR0_FAE11_Msk   (0x1UL << DSI_FIR0_FAE11_Pos)
#define DSI_FIR0_FAE11   DSI_FIR0_FAE11_Msk
#define DSI_FIR0_FAE12_Pos   (12U)
#define DSI_FIR0_FAE12_Msk   (0x1UL << DSI_FIR0_FAE12_Pos)
#define DSI_FIR0_FAE12   DSI_FIR0_FAE12_Msk
#define DSI_FIR0_FAE13_Pos   (13U)
#define DSI_FIR0_FAE13_Msk   (0x1UL << DSI_FIR0_FAE13_Pos)
#define DSI_FIR0_FAE13   DSI_FIR0_FAE13_Msk
#define DSI_FIR0_FAE14_Pos   (14U)
#define DSI_FIR0_FAE14_Msk   (0x1UL << DSI_FIR0_FAE14_Pos)
#define DSI_FIR0_FAE14   DSI_FIR0_FAE14_Msk
#define DSI_FIR0_FAE15_Pos   (15U)
#define DSI_FIR0_FAE15_Msk   (0x1UL << DSI_FIR0_FAE15_Pos)
#define DSI_FIR0_FAE15   DSI_FIR0_FAE15_Msk
#define DSI_FIR0_FPE0_Pos   (16U)
#define DSI_FIR0_FPE0_Msk   (0x1UL << DSI_FIR0_FPE0_Pos)
#define DSI_FIR0_FPE0   DSI_FIR0_FPE0_Msk
#define DSI_FIR0_FPE1_Pos   (17U)
#define DSI_FIR0_FPE1_Msk   (0x1UL << DSI_FIR0_FPE1_Pos)
#define DSI_FIR0_FPE1   DSI_FIR0_FPE1_Msk
#define DSI_FIR0_FPE2_Pos   (18U)
#define DSI_FIR0_FPE2_Msk   (0x1UL << DSI_FIR0_FPE2_Pos)
#define DSI_FIR0_FPE2   DSI_FIR0_FPE2_Msk
#define DSI_FIR0_FPE3_Pos   (19U)
#define DSI_FIR0_FPE3_Msk   (0x1UL << DSI_FIR0_FPE3_Pos)
#define DSI_FIR0_FPE3   DSI_FIR0_FPE3_Msk
#define DSI_FIR0_FPE4_Pos   (20U)
#define DSI_FIR0_FPE4_Msk   (0x1UL << DSI_FIR0_FPE4_Pos)
#define DSI_FIR0_FPE4   DSI_FIR0_FPE4_Msk
#define DSI_FIR1_FTOHSTX_Pos   (0U)
#define DSI_FIR1_FTOHSTX_Msk   (0x1UL << DSI_FIR1_FTOHSTX_Pos)
#define DSI_FIR1_FTOHSTX   DSI_FIR1_FTOHSTX_Msk
#define DSI_FIR1_FTOLPRX_Pos   (1U)
#define DSI_FIR1_FTOLPRX_Msk   (0x1UL << DSI_FIR1_FTOLPRX_Pos)
#define DSI_FIR1_FTOLPRX   DSI_FIR1_FTOLPRX_Msk
#define DSI_FIR1_FECCSE_Pos   (2U)
#define DSI_FIR1_FECCSE_Msk   (0x1UL << DSI_FIR1_FECCSE_Pos)
#define DSI_FIR1_FECCSE   DSI_FIR1_FECCSE_Msk
#define DSI_FIR1_FECCME_Pos   (3U)
#define DSI_FIR1_FECCME_Msk   (0x1UL << DSI_FIR1_FECCME_Pos)
#define DSI_FIR1_FECCME   DSI_FIR1_FECCME_Msk
#define DSI_FIR1_FCRCE_Pos   (4U)
#define DSI_FIR1_FCRCE_Msk   (0x1UL << DSI_FIR1_FCRCE_Pos)
#define DSI_FIR1_FCRCE   DSI_FIR1_FCRCE_Msk
#define DSI_FIR1_FPSE_Pos   (5U)
#define DSI_FIR1_FPSE_Msk   (0x1UL << DSI_FIR1_FPSE_Pos)
#define DSI_FIR1_FPSE   DSI_FIR1_FPSE_Msk
#define DSI_FIR1_FEOTPE_Pos   (6U)
#define DSI_FIR1_FEOTPE_Msk   (0x1UL << DSI_FIR1_FEOTPE_Pos)
#define DSI_FIR1_FEOTPE   DSI_FIR1_FEOTPE_Msk
#define DSI_FIR1_FLPWRE_Pos   (7U)
#define DSI_FIR1_FLPWRE_Msk   (0x1UL << DSI_FIR1_FLPWRE_Pos)
#define DSI_FIR1_FLPWRE   DSI_FIR1_FLPWRE_Msk
#define DSI_FIR1_FGCWRE_Pos   (8U)
#define DSI_FIR1_FGCWRE_Msk   (0x1UL << DSI_FIR1_FGCWRE_Pos)
#define DSI_FIR1_FGCWRE   DSI_FIR1_FGCWRE_Msk
#define DSI_FIR1_FGPWRE_Pos   (9U)
#define DSI_FIR1_FGPWRE_Msk   (0x1UL << DSI_FIR1_FGPWRE_Pos)
#define DSI_FIR1_FGPWRE   DSI_FIR1_FGPWRE_Msk
#define DSI_FIR1_FGPTXE_Pos   (10U)
#define DSI_FIR1_FGPTXE_Msk   (0x1UL << DSI_FIR1_FGPTXE_Pos)
#define DSI_FIR1_FGPTXE   DSI_FIR1_FGPTXE_Msk
#define DSI_FIR1_FGPRDE_Pos   (11U)
#define DSI_FIR1_FGPRDE_Msk   (0x1UL << DSI_FIR1_FGPRDE_Pos)
#define DSI_FIR1_FGPRDE   DSI_FIR1_FGPRDE_Msk
#define DSI_FIR1_FGPRXE_Pos   (12U)
#define DSI_FIR1_FGPRXE_Msk   (0x1UL << DSI_FIR1_FGPRXE_Pos)
#define DSI_FIR1_FGPRXE   DSI_FIR1_FGPRXE_Msk
#define DSI_FIR1_FPBUE_Pos   (19U)
#define DSI_FIR1_FPBUE_Msk   (0x1UL << DSI_FIR1_FPBUE_Pos)
#define DSI_FIR1_FPBUE   DSI_FIR1_FPBUE_Msk
#define DSI_DLTRCR_MRD_TIME_Pos   (0U)
#define DSI_DLTRCR_MRD_TIME_Msk   (0x7FFFUL << DSI_DLTRCR_MRD_TIME_Pos)
#define DSI_DLTRCR_MRD_TIME   DSI_DLTRCR_MRD_TIME_Msk
#define DSI_DLTRCR_MRD_TIME0_Pos   (0U)
#define DSI_DLTRCR_MRD_TIME0_Msk   (0x1UL << DSI_DLTRCR_MRD_TIME0_Pos)
#define DSI_DLTRCR_MRD_TIME0   DSI_DLTRCR_MRD_TIME0_Msk
#define DSI_DLTRCR_MRD_TIME1_Pos   (1U)
#define DSI_DLTRCR_MRD_TIME1_Msk   (0x1UL << DSI_DLTRCR_MRD_TIME1_Pos)
#define DSI_DLTRCR_MRD_TIME1   DSI_DLTRCR_MRD_TIME1_Msk
#define DSI_DLTRCR_MRD_TIME2_Pos   (2U)
#define DSI_DLTRCR_MRD_TIME2_Msk   (0x1UL << DSI_DLTRCR_MRD_TIME2_Pos)
#define DSI_DLTRCR_MRD_TIME2   DSI_DLTRCR_MRD_TIME2_Msk
#define DSI_DLTRCR_MRD_TIME3_Pos   (3U)
#define DSI_DLTRCR_MRD_TIME3_Msk   (0x1UL << DSI_DLTRCR_MRD_TIME3_Pos)
#define DSI_DLTRCR_MRD_TIME3   DSI_DLTRCR_MRD_TIME3_Msk
#define DSI_DLTRCR_MRD_TIME4_Pos   (4U)
#define DSI_DLTRCR_MRD_TIME4_Msk   (0x1UL << DSI_DLTRCR_MRD_TIME4_Pos)
#define DSI_DLTRCR_MRD_TIME4   DSI_DLTRCR_MRD_TIME4_Msk
#define DSI_DLTRCR_MRD_TIME5_Pos   (5U)
#define DSI_DLTRCR_MRD_TIME5_Msk   (0x1UL << DSI_DLTRCR_MRD_TIME5_Pos)
#define DSI_DLTRCR_MRD_TIME5   DSI_DLTRCR_MRD_TIME5_Msk
#define DSI_DLTRCR_MRD_TIME6_Pos   (6U)
#define DSI_DLTRCR_MRD_TIME6_Msk   (0x1UL << DSI_DLTRCR_MRD_TIME6_Pos)
#define DSI_DLTRCR_MRD_TIME6   DSI_DLTRCR_MRD_TIME6_Msk
#define DSI_DLTRCR_MRD_TIME7_Pos   (7U)
#define DSI_DLTRCR_MRD_TIME7_Msk   (0x1UL << DSI_DLTRCR_MRD_TIME7_Pos)
#define DSI_DLTRCR_MRD_TIME7   DSI_DLTRCR_MRD_TIME7_Msk
#define DSI_DLTRCR_MRD_TIME8_Pos   (8U)
#define DSI_DLTRCR_MRD_TIME8_Msk   (0x1UL << DSI_DLTRCR_MRD_TIME8_Pos)
#define DSI_DLTRCR_MRD_TIME8   DSI_DLTRCR_MRD_TIME8_Msk
#define DSI_DLTRCR_MRD_TIME9_Pos   (9U)
#define DSI_DLTRCR_MRD_TIME9_Msk   (0x1UL << DSI_DLTRCR_MRD_TIME9_Pos)
#define DSI_DLTRCR_MRD_TIME9   DSI_DLTRCR_MRD_TIME9_Msk
#define DSI_DLTRCR_MRD_TIME10_Pos   (10U)
#define DSI_DLTRCR_MRD_TIME10_Msk   (0x1UL << DSI_DLTRCR_MRD_TIME10_Pos)
#define DSI_DLTRCR_MRD_TIME10   DSI_DLTRCR_MRD_TIME10_Msk
#define DSI_DLTRCR_MRD_TIME11_Pos   (11U)
#define DSI_DLTRCR_MRD_TIME11_Msk   (0x1UL << DSI_DLTRCR_MRD_TIME11_Pos)
#define DSI_DLTRCR_MRD_TIME11   DSI_DLTRCR_MRD_TIME11_Msk
#define DSI_DLTRCR_MRD_TIME12_Pos   (12U)
#define DSI_DLTRCR_MRD_TIME12_Msk   (0x1UL << DSI_DLTRCR_MRD_TIME12_Pos)
#define DSI_DLTRCR_MRD_TIME12   DSI_DLTRCR_MRD_TIME12_Msk
#define DSI_DLTRCR_MRD_TIME13_Pos   (13U)
#define DSI_DLTRCR_MRD_TIME13_Msk   (0x1UL << DSI_DLTRCR_MRD_TIME13_Pos)
#define DSI_DLTRCR_MRD_TIME13   DSI_DLTRCR_MRD_TIME13_Msk
#define DSI_DLTRCR_MRD_TIME14_Pos   (14U)
#define DSI_DLTRCR_MRD_TIME14_Msk   (0x1UL << DSI_DLTRCR_MRD_TIME14_Pos)
#define DSI_DLTRCR_MRD_TIME14   DSI_DLTRCR_MRD_TIME14_Msk
#define DSI_VSCR_EN_Pos   (0U)
#define DSI_VSCR_EN_Msk   (0x1UL << DSI_VSCR_EN_Pos)
#define DSI_VSCR_EN   DSI_VSCR_EN_Msk
#define DSI_VSCR_UR_Pos   (8U)
#define DSI_VSCR_UR_Msk   (0x1UL << DSI_VSCR_UR_Pos)
#define DSI_VSCR_UR   DSI_VSCR_UR_Msk
#define DSI_LCVCIDR_VCID_Pos   (0U)
#define DSI_LCVCIDR_VCID_Msk   (0x3UL << DSI_LCVCIDR_VCID_Pos)
#define DSI_LCVCIDR_VCID   DSI_LCVCIDR_VCID_Msk
#define DSI_LCVCIDR_VCID0_Pos   (0U)
#define DSI_LCVCIDR_VCID0_Msk   (0x1UL << DSI_LCVCIDR_VCID0_Pos)
#define DSI_LCVCIDR_VCID0   DSI_LCVCIDR_VCID0_Msk
#define DSI_LCVCIDR_VCID1_Pos   (1U)
#define DSI_LCVCIDR_VCID1_Msk   (0x1UL << DSI_LCVCIDR_VCID1_Pos)
#define DSI_LCVCIDR_VCID1   DSI_LCVCIDR_VCID1_Msk
#define DSI_LCCCR_COLC_Pos   (0U)
#define DSI_LCCCR_COLC_Msk   (0xFUL << DSI_LCCCR_COLC_Pos)
#define DSI_LCCCR_COLC   DSI_LCCCR_COLC_Msk
#define DSI_LCCCR_COLC0_Pos   (0U)
#define DSI_LCCCR_COLC0_Msk   (0x1UL << DSI_LCCCR_COLC0_Pos)
#define DSI_LCCCR_COLC0   DSI_LCCCR_COLC0_Msk
#define DSI_LCCCR_COLC1_Pos   (1U)
#define DSI_LCCCR_COLC1_Msk   (0x1UL << DSI_LCCCR_COLC1_Pos)
#define DSI_LCCCR_COLC1   DSI_LCCCR_COLC1_Msk
#define DSI_LCCCR_COLC2_Pos   (2U)
#define DSI_LCCCR_COLC2_Msk   (0x1UL << DSI_LCCCR_COLC2_Pos)
#define DSI_LCCCR_COLC2   DSI_LCCCR_COLC2_Msk
#define DSI_LCCCR_COLC3_Pos   (3U)
#define DSI_LCCCR_COLC3_Msk   (0x1UL << DSI_LCCCR_COLC3_Pos)
#define DSI_LCCCR_COLC3   DSI_LCCCR_COLC3_Msk
#define DSI_LCCCR_LPE_Pos   (8U)
#define DSI_LCCCR_LPE_Msk   (0x1UL << DSI_LCCCR_LPE_Pos)
#define DSI_LCCCR_LPE   DSI_LCCCR_LPE_Msk
#define DSI_LPMCCR_VLPSIZE_Pos   (0U)
#define DSI_LPMCCR_VLPSIZE_Msk   (0xFFUL << DSI_LPMCCR_VLPSIZE_Pos)
#define DSI_LPMCCR_VLPSIZE   DSI_LPMCCR_VLPSIZE_Msk
#define DSI_LPMCCR_VLPSIZE0_Pos   (0U)
#define DSI_LPMCCR_VLPSIZE0_Msk   (0x1UL << DSI_LPMCCR_VLPSIZE0_Pos)
#define DSI_LPMCCR_VLPSIZE0   DSI_LPMCCR_VLPSIZE0_Msk
#define DSI_LPMCCR_VLPSIZE1_Pos   (1U)
#define DSI_LPMCCR_VLPSIZE1_Msk   (0x1UL << DSI_LPMCCR_VLPSIZE1_Pos)
#define DSI_LPMCCR_VLPSIZE1   DSI_LPMCCR_VLPSIZE1_Msk
#define DSI_LPMCCR_VLPSIZE2_Pos   (2U)
#define DSI_LPMCCR_VLPSIZE2_Msk   (0x1UL << DSI_LPMCCR_VLPSIZE2_Pos)
#define DSI_LPMCCR_VLPSIZE2   DSI_LPMCCR_VLPSIZE2_Msk
#define DSI_LPMCCR_VLPSIZE3_Pos   (3U)
#define DSI_LPMCCR_VLPSIZE3_Msk   (0x1UL << DSI_LPMCCR_VLPSIZE3_Pos)
#define DSI_LPMCCR_VLPSIZE3   DSI_LPMCCR_VLPSIZE3_Msk
#define DSI_LPMCCR_VLPSIZE4_Pos   (4U)
#define DSI_LPMCCR_VLPSIZE4_Msk   (0x1UL << DSI_LPMCCR_VLPSIZE4_Pos)
#define DSI_LPMCCR_VLPSIZE4   DSI_LPMCCR_VLPSIZE4_Msk
#define DSI_LPMCCR_VLPSIZE5_Pos   (5U)
#define DSI_LPMCCR_VLPSIZE5_Msk   (0x1UL << DSI_LPMCCR_VLPSIZE5_Pos)
#define DSI_LPMCCR_VLPSIZE5   DSI_LPMCCR_VLPSIZE5_Msk
#define DSI_LPMCCR_VLPSIZE6_Pos   (6U)
#define DSI_LPMCCR_VLPSIZE6_Msk   (0x1UL << DSI_LPMCCR_VLPSIZE6_Pos)
#define DSI_LPMCCR_VLPSIZE6   DSI_LPMCCR_VLPSIZE6_Msk
#define DSI_LPMCCR_VLPSIZE7_Pos   (7U)
#define DSI_LPMCCR_VLPSIZE7_Msk   (0x1UL << DSI_LPMCCR_VLPSIZE7_Pos)
#define DSI_LPMCCR_VLPSIZE7   DSI_LPMCCR_VLPSIZE7_Msk
#define DSI_LPMCCR_LPSIZE_Pos   (16U)
#define DSI_LPMCCR_LPSIZE_Msk   (0xFFUL << DSI_LPMCCR_LPSIZE_Pos)
#define DSI_LPMCCR_LPSIZE   DSI_LPMCCR_LPSIZE_Msk
#define DSI_LPMCCR_LPSIZE0_Pos   (16U)
#define DSI_LPMCCR_LPSIZE0_Msk   (0x1UL << DSI_LPMCCR_LPSIZE0_Pos)
#define DSI_LPMCCR_LPSIZE0   DSI_LPMCCR_LPSIZE0_Msk
#define DSI_LPMCCR_LPSIZE1_Pos   (17U)
#define DSI_LPMCCR_LPSIZE1_Msk   (0x1UL << DSI_LPMCCR_LPSIZE1_Pos)
#define DSI_LPMCCR_LPSIZE1   DSI_LPMCCR_LPSIZE1_Msk
#define DSI_LPMCCR_LPSIZE2_Pos   (18U)
#define DSI_LPMCCR_LPSIZE2_Msk   (0x1UL << DSI_LPMCCR_LPSIZE2_Pos)
#define DSI_LPMCCR_LPSIZE2   DSI_LPMCCR_LPSIZE2_Msk
#define DSI_LPMCCR_LPSIZE3_Pos   (19U)
#define DSI_LPMCCR_LPSIZE3_Msk   (0x1UL << DSI_LPMCCR_LPSIZE3_Pos)
#define DSI_LPMCCR_LPSIZE3   DSI_LPMCCR_LPSIZE3_Msk
#define DSI_LPMCCR_LPSIZE4_Pos   (20U)
#define DSI_LPMCCR_LPSIZE4_Msk   (0x1UL << DSI_LPMCCR_LPSIZE4_Pos)
#define DSI_LPMCCR_LPSIZE4   DSI_LPMCCR_LPSIZE4_Msk
#define DSI_LPMCCR_LPSIZE5_Pos   (21U)
#define DSI_LPMCCR_LPSIZE5_Msk   (0x1UL << DSI_LPMCCR_LPSIZE5_Pos)
#define DSI_LPMCCR_LPSIZE5   DSI_LPMCCR_LPSIZE5_Msk
#define DSI_LPMCCR_LPSIZE6_Pos   (22U)
#define DSI_LPMCCR_LPSIZE6_Msk   (0x1UL << DSI_LPMCCR_LPSIZE6_Pos)
#define DSI_LPMCCR_LPSIZE6   DSI_LPMCCR_LPSIZE6_Msk
#define DSI_LPMCCR_LPSIZE7_Pos   (23U)
#define DSI_LPMCCR_LPSIZE7_Msk   (0x1UL << DSI_LPMCCR_LPSIZE7_Pos)
#define DSI_LPMCCR_LPSIZE7   DSI_LPMCCR_LPSIZE7_Msk
#define DSI_VMCCR_VMT_Pos   (0U)
#define DSI_VMCCR_VMT_Msk   (0x3UL << DSI_VMCCR_VMT_Pos)
#define DSI_VMCCR_VMT   DSI_VMCCR_VMT_Msk
#define DSI_VMCCR_VMT0_Pos   (0U)
#define DSI_VMCCR_VMT0_Msk   (0x1UL << DSI_VMCCR_VMT0_Pos)
#define DSI_VMCCR_VMT0   DSI_VMCCR_VMT0_Msk
#define DSI_VMCCR_VMT1_Pos   (1U)
#define DSI_VMCCR_VMT1_Msk   (0x1UL << DSI_VMCCR_VMT1_Pos)
#define DSI_VMCCR_VMT1   DSI_VMCCR_VMT1_Msk
#define DSI_VMCCR_LPVSAE_Pos   (8U)
#define DSI_VMCCR_LPVSAE_Msk   (0x1UL << DSI_VMCCR_LPVSAE_Pos)
#define DSI_VMCCR_LPVSAE   DSI_VMCCR_LPVSAE_Msk
#define DSI_VMCCR_LPVBPE_Pos   (9U)
#define DSI_VMCCR_LPVBPE_Msk   (0x1UL << DSI_VMCCR_LPVBPE_Pos)
#define DSI_VMCCR_LPVBPE   DSI_VMCCR_LPVBPE_Msk
#define DSI_VMCCR_LPVFPE_Pos   (10U)
#define DSI_VMCCR_LPVFPE_Msk   (0x1UL << DSI_VMCCR_LPVFPE_Pos)
#define DSI_VMCCR_LPVFPE   DSI_VMCCR_LPVFPE_Msk
#define DSI_VMCCR_LPVAE_Pos   (11U)
#define DSI_VMCCR_LPVAE_Msk   (0x1UL << DSI_VMCCR_LPVAE_Pos)
#define DSI_VMCCR_LPVAE   DSI_VMCCR_LPVAE_Msk
#define DSI_VMCCR_LPHBPE_Pos   (12U)
#define DSI_VMCCR_LPHBPE_Msk   (0x1UL << DSI_VMCCR_LPHBPE_Pos)
#define DSI_VMCCR_LPHBPE   DSI_VMCCR_LPHBPE_Msk
#define DSI_VMCCR_LPHFE_Pos   (13U)
#define DSI_VMCCR_LPHFE_Msk   (0x1UL << DSI_VMCCR_LPHFE_Pos)
#define DSI_VMCCR_LPHFE   DSI_VMCCR_LPHFE_Msk
#define DSI_VMCCR_FBTAAE_Pos   (14U)
#define DSI_VMCCR_FBTAAE_Msk   (0x1UL << DSI_VMCCR_FBTAAE_Pos)
#define DSI_VMCCR_FBTAAE   DSI_VMCCR_FBTAAE_Msk
#define DSI_VMCCR_LPCE_Pos   (15U)
#define DSI_VMCCR_LPCE_Msk   (0x1UL << DSI_VMCCR_LPCE_Pos)
#define DSI_VMCCR_LPCE   DSI_VMCCR_LPCE_Msk
#define DSI_VPCCR_VPSIZE_Pos   (0U)
#define DSI_VPCCR_VPSIZE_Msk   (0x3FFFUL << DSI_VPCCR_VPSIZE_Pos)
#define DSI_VPCCR_VPSIZE   DSI_VPCCR_VPSIZE_Msk
#define DSI_VPCCR_VPSIZE0_Pos   (0U)
#define DSI_VPCCR_VPSIZE0_Msk   (0x1UL << DSI_VPCCR_VPSIZE0_Pos)
#define DSI_VPCCR_VPSIZE0   DSI_VPCCR_VPSIZE0_Msk
#define DSI_VPCCR_VPSIZE1_Pos   (1U)
#define DSI_VPCCR_VPSIZE1_Msk   (0x1UL << DSI_VPCCR_VPSIZE1_Pos)
#define DSI_VPCCR_VPSIZE1   DSI_VPCCR_VPSIZE1_Msk
#define DSI_VPCCR_VPSIZE2_Pos   (2U)
#define DSI_VPCCR_VPSIZE2_Msk   (0x1UL << DSI_VPCCR_VPSIZE2_Pos)
#define DSI_VPCCR_VPSIZE2   DSI_VPCCR_VPSIZE2_Msk
#define DSI_VPCCR_VPSIZE3_Pos   (3U)
#define DSI_VPCCR_VPSIZE3_Msk   (0x1UL << DSI_VPCCR_VPSIZE3_Pos)
#define DSI_VPCCR_VPSIZE3   DSI_VPCCR_VPSIZE3_Msk
#define DSI_VPCCR_VPSIZE4_Pos   (4U)
#define DSI_VPCCR_VPSIZE4_Msk   (0x1UL << DSI_VPCCR_VPSIZE4_Pos)
#define DSI_VPCCR_VPSIZE4   DSI_VPCCR_VPSIZE4_Msk
#define DSI_VPCCR_VPSIZE5_Pos   (5U)
#define DSI_VPCCR_VPSIZE5_Msk   (0x1UL << DSI_VPCCR_VPSIZE5_Pos)
#define DSI_VPCCR_VPSIZE5   DSI_VPCCR_VPSIZE5_Msk
#define DSI_VPCCR_VPSIZE6_Pos   (6U)
#define DSI_VPCCR_VPSIZE6_Msk   (0x1UL << DSI_VPCCR_VPSIZE6_Pos)
#define DSI_VPCCR_VPSIZE6   DSI_VPCCR_VPSIZE6_Msk
#define DSI_VPCCR_VPSIZE7_Pos   (7U)
#define DSI_VPCCR_VPSIZE7_Msk   (0x1UL << DSI_VPCCR_VPSIZE7_Pos)
#define DSI_VPCCR_VPSIZE7   DSI_VPCCR_VPSIZE7_Msk
#define DSI_VPCCR_VPSIZE8_Pos   (8U)
#define DSI_VPCCR_VPSIZE8_Msk   (0x1UL << DSI_VPCCR_VPSIZE8_Pos)
#define DSI_VPCCR_VPSIZE8   DSI_VPCCR_VPSIZE8_Msk
#define DSI_VPCCR_VPSIZE9_Pos   (9U)
#define DSI_VPCCR_VPSIZE9_Msk   (0x1UL << DSI_VPCCR_VPSIZE9_Pos)
#define DSI_VPCCR_VPSIZE9   DSI_VPCCR_VPSIZE9_Msk
#define DSI_VPCCR_VPSIZE10_Pos   (10U)
#define DSI_VPCCR_VPSIZE10_Msk   (0x1UL << DSI_VPCCR_VPSIZE10_Pos)
#define DSI_VPCCR_VPSIZE10   DSI_VPCCR_VPSIZE10_Msk
#define DSI_VPCCR_VPSIZE11_Pos   (11U)
#define DSI_VPCCR_VPSIZE11_Msk   (0x1UL << DSI_VPCCR_VPSIZE11_Pos)
#define DSI_VPCCR_VPSIZE11   DSI_VPCCR_VPSIZE11_Msk
#define DSI_VPCCR_VPSIZE12_Pos   (12U)
#define DSI_VPCCR_VPSIZE12_Msk   (0x1UL << DSI_VPCCR_VPSIZE12_Pos)
#define DSI_VPCCR_VPSIZE12   DSI_VPCCR_VPSIZE12_Msk
#define DSI_VPCCR_VPSIZE13_Pos   (13U)
#define DSI_VPCCR_VPSIZE13_Msk   (0x1UL << DSI_VPCCR_VPSIZE13_Pos)
#define DSI_VPCCR_VPSIZE13   DSI_VPCCR_VPSIZE13_Msk
#define DSI_VCCCR_NUMC_Pos   (0U)
#define DSI_VCCCR_NUMC_Msk   (0x1FFFUL << DSI_VCCCR_NUMC_Pos)
#define DSI_VCCCR_NUMC   DSI_VCCCR_NUMC_Msk
#define DSI_VCCCR_NUMC0_Pos   (0U)
#define DSI_VCCCR_NUMC0_Msk   (0x1UL << DSI_VCCCR_NUMC0_Pos)
#define DSI_VCCCR_NUMC0   DSI_VCCCR_NUMC0_Msk
#define DSI_VCCCR_NUMC1_Pos   (1U)
#define DSI_VCCCR_NUMC1_Msk   (0x1UL << DSI_VCCCR_NUMC1_Pos)
#define DSI_VCCCR_NUMC1   DSI_VCCCR_NUMC1_Msk
#define DSI_VCCCR_NUMC2_Pos   (2U)
#define DSI_VCCCR_NUMC2_Msk   (0x1UL << DSI_VCCCR_NUMC2_Pos)
#define DSI_VCCCR_NUMC2   DSI_VCCCR_NUMC2_Msk
#define DSI_VCCCR_NUMC3_Pos   (3U)
#define DSI_VCCCR_NUMC3_Msk   (0x1UL << DSI_VCCCR_NUMC3_Pos)
#define DSI_VCCCR_NUMC3   DSI_VCCCR_NUMC3_Msk
#define DSI_VCCCR_NUMC4_Pos   (4U)
#define DSI_VCCCR_NUMC4_Msk   (0x1UL << DSI_VCCCR_NUMC4_Pos)
#define DSI_VCCCR_NUMC4   DSI_VCCCR_NUMC4_Msk
#define DSI_VCCCR_NUMC5_Pos   (5U)
#define DSI_VCCCR_NUMC5_Msk   (0x1UL << DSI_VCCCR_NUMC5_Pos)
#define DSI_VCCCR_NUMC5   DSI_VCCCR_NUMC5_Msk
#define DSI_VCCCR_NUMC6_Pos   (6U)
#define DSI_VCCCR_NUMC6_Msk   (0x1UL << DSI_VCCCR_NUMC6_Pos)
#define DSI_VCCCR_NUMC6   DSI_VCCCR_NUMC6_Msk
#define DSI_VCCCR_NUMC7_Pos   (7U)
#define DSI_VCCCR_NUMC7_Msk   (0x1UL << DSI_VCCCR_NUMC7_Pos)
#define DSI_VCCCR_NUMC7   DSI_VCCCR_NUMC7_Msk
#define DSI_VCCCR_NUMC8_Pos   (8U)
#define DSI_VCCCR_NUMC8_Msk   (0x1UL << DSI_VCCCR_NUMC8_Pos)
#define DSI_VCCCR_NUMC8   DSI_VCCCR_NUMC8_Msk
#define DSI_VCCCR_NUMC9_Pos   (9U)
#define DSI_VCCCR_NUMC9_Msk   (0x1UL << DSI_VCCCR_NUMC9_Pos)
#define DSI_VCCCR_NUMC9   DSI_VCCCR_NUMC9_Msk
#define DSI_VCCCR_NUMC10_Pos   (10U)
#define DSI_VCCCR_NUMC10_Msk   (0x1UL << DSI_VCCCR_NUMC10_Pos)
#define DSI_VCCCR_NUMC10   DSI_VCCCR_NUMC10_Msk
#define DSI_VCCCR_NUMC11_Pos   (11U)
#define DSI_VCCCR_NUMC11_Msk   (0x1UL << DSI_VCCCR_NUMC11_Pos)
#define DSI_VCCCR_NUMC11   DSI_VCCCR_NUMC11_Msk
#define DSI_VCCCR_NUMC12_Pos   (12U)
#define DSI_VCCCR_NUMC12_Msk   (0x1UL << DSI_VCCCR_NUMC12_Pos)
#define DSI_VCCCR_NUMC12   DSI_VCCCR_NUMC12_Msk
#define DSI_VNPCCR_NPSIZE_Pos   (0U)
#define DSI_VNPCCR_NPSIZE_Msk   (0x1FFFUL << DSI_VNPCCR_NPSIZE_Pos)
#define DSI_VNPCCR_NPSIZE   DSI_VNPCCR_NPSIZE_Msk
#define DSI_VNPCCR_NPSIZE0_Pos   (0U)
#define DSI_VNPCCR_NPSIZE0_Msk   (0x1UL << DSI_VNPCCR_NPSIZE0_Pos)
#define DSI_VNPCCR_NPSIZE0   DSI_VNPCCR_NPSIZE0_Msk
#define DSI_VNPCCR_NPSIZE1_Pos   (1U)
#define DSI_VNPCCR_NPSIZE1_Msk   (0x1UL << DSI_VNPCCR_NPSIZE1_Pos)
#define DSI_VNPCCR_NPSIZE1   DSI_VNPCCR_NPSIZE1_Msk
#define DSI_VNPCCR_NPSIZE2_Pos   (2U)
#define DSI_VNPCCR_NPSIZE2_Msk   (0x1UL << DSI_VNPCCR_NPSIZE2_Pos)
#define DSI_VNPCCR_NPSIZE2   DSI_VNPCCR_NPSIZE2_Msk
#define DSI_VNPCCR_NPSIZE3_Pos   (3U)
#define DSI_VNPCCR_NPSIZE3_Msk   (0x1UL << DSI_VNPCCR_NPSIZE3_Pos)
#define DSI_VNPCCR_NPSIZE3   DSI_VNPCCR_NPSIZE3_Msk
#define DSI_VNPCCR_NPSIZE4_Pos   (4U)
#define DSI_VNPCCR_NPSIZE4_Msk   (0x1UL << DSI_VNPCCR_NPSIZE4_Pos)
#define DSI_VNPCCR_NPSIZE4   DSI_VNPCCR_NPSIZE4_Msk
#define DSI_VNPCCR_NPSIZE5_Pos   (5U)
#define DSI_VNPCCR_NPSIZE5_Msk   (0x1UL << DSI_VNPCCR_NPSIZE5_Pos)
#define DSI_VNPCCR_NPSIZE5   DSI_VNPCCR_NPSIZE5_Msk
#define DSI_VNPCCR_NPSIZE6_Pos   (6U)
#define DSI_VNPCCR_NPSIZE6_Msk   (0x1UL << DSI_VNPCCR_NPSIZE6_Pos)
#define DSI_VNPCCR_NPSIZE6   DSI_VNPCCR_NPSIZE6_Msk
#define DSI_VNPCCR_NPSIZE7_Pos   (7U)
#define DSI_VNPCCR_NPSIZE7_Msk   (0x1UL << DSI_VNPCCR_NPSIZE7_Pos)
#define DSI_VNPCCR_NPSIZE7   DSI_VNPCCR_NPSIZE7_Msk
#define DSI_VNPCCR_NPSIZE8_Pos   (8U)
#define DSI_VNPCCR_NPSIZE8_Msk   (0x1UL << DSI_VNPCCR_NPSIZE8_Pos)
#define DSI_VNPCCR_NPSIZE8   DSI_VNPCCR_NPSIZE8_Msk
#define DSI_VNPCCR_NPSIZE9_Pos   (9U)
#define DSI_VNPCCR_NPSIZE9_Msk   (0x1UL << DSI_VNPCCR_NPSIZE9_Pos)
#define DSI_VNPCCR_NPSIZE9   DSI_VNPCCR_NPSIZE9_Msk
#define DSI_VNPCCR_NPSIZE10_Pos   (10U)
#define DSI_VNPCCR_NPSIZE10_Msk   (0x1UL << DSI_VNPCCR_NPSIZE10_Pos)
#define DSI_VNPCCR_NPSIZE10   DSI_VNPCCR_NPSIZE10_Msk
#define DSI_VNPCCR_NPSIZE11_Pos   (11U)
#define DSI_VNPCCR_NPSIZE11_Msk   (0x1UL << DSI_VNPCCR_NPSIZE11_Pos)
#define DSI_VNPCCR_NPSIZE11   DSI_VNPCCR_NPSIZE11_Msk
#define DSI_VNPCCR_NPSIZE12_Pos   (12U)
#define DSI_VNPCCR_NPSIZE12_Msk   (0x1UL << DSI_VNPCCR_NPSIZE12_Pos)
#define DSI_VNPCCR_NPSIZE12   DSI_VNPCCR_NPSIZE12_Msk
#define DSI_VHSACCR_HSA_Pos   (0U)
#define DSI_VHSACCR_HSA_Msk   (0xFFFUL << DSI_VHSACCR_HSA_Pos)
#define DSI_VHSACCR_HSA   DSI_VHSACCR_HSA_Msk
#define DSI_VHSACCR_HSA0_Pos   (0U)
#define DSI_VHSACCR_HSA0_Msk   (0x1UL << DSI_VHSACCR_HSA0_Pos)
#define DSI_VHSACCR_HSA0   DSI_VHSACCR_HSA0_Msk
#define DSI_VHSACCR_HSA1_Pos   (1U)
#define DSI_VHSACCR_HSA1_Msk   (0x1UL << DSI_VHSACCR_HSA1_Pos)
#define DSI_VHSACCR_HSA1   DSI_VHSACCR_HSA1_Msk
#define DSI_VHSACCR_HSA2_Pos   (2U)
#define DSI_VHSACCR_HSA2_Msk   (0x1UL << DSI_VHSACCR_HSA2_Pos)
#define DSI_VHSACCR_HSA2   DSI_VHSACCR_HSA2_Msk
#define DSI_VHSACCR_HSA3_Pos   (3U)
#define DSI_VHSACCR_HSA3_Msk   (0x1UL << DSI_VHSACCR_HSA3_Pos)
#define DSI_VHSACCR_HSA3   DSI_VHSACCR_HSA3_Msk
#define DSI_VHSACCR_HSA4_Pos   (4U)
#define DSI_VHSACCR_HSA4_Msk   (0x1UL << DSI_VHSACCR_HSA4_Pos)
#define DSI_VHSACCR_HSA4   DSI_VHSACCR_HSA4_Msk
#define DSI_VHSACCR_HSA5_Pos   (5U)
#define DSI_VHSACCR_HSA5_Msk   (0x1UL << DSI_VHSACCR_HSA5_Pos)
#define DSI_VHSACCR_HSA5   DSI_VHSACCR_HSA5_Msk
#define DSI_VHSACCR_HSA6_Pos   (6U)
#define DSI_VHSACCR_HSA6_Msk   (0x1UL << DSI_VHSACCR_HSA6_Pos)
#define DSI_VHSACCR_HSA6   DSI_VHSACCR_HSA6_Msk
#define DSI_VHSACCR_HSA7_Pos   (7U)
#define DSI_VHSACCR_HSA7_Msk   (0x1UL << DSI_VHSACCR_HSA7_Pos)
#define DSI_VHSACCR_HSA7   DSI_VHSACCR_HSA7_Msk
#define DSI_VHSACCR_HSA8_Pos   (8U)
#define DSI_VHSACCR_HSA8_Msk   (0x1UL << DSI_VHSACCR_HSA8_Pos)
#define DSI_VHSACCR_HSA8   DSI_VHSACCR_HSA8_Msk
#define DSI_VHSACCR_HSA9_Pos   (9U)
#define DSI_VHSACCR_HSA9_Msk   (0x1UL << DSI_VHSACCR_HSA9_Pos)
#define DSI_VHSACCR_HSA9   DSI_VHSACCR_HSA9_Msk
#define DSI_VHSACCR_HSA10_Pos   (10U)
#define DSI_VHSACCR_HSA10_Msk   (0x1UL << DSI_VHSACCR_HSA10_Pos)
#define DSI_VHSACCR_HSA10   DSI_VHSACCR_HSA10_Msk
#define DSI_VHSACCR_HSA11_Pos   (11U)
#define DSI_VHSACCR_HSA11_Msk   (0x1UL << DSI_VHSACCR_HSA11_Pos)
#define DSI_VHSACCR_HSA11   DSI_VHSACCR_HSA11_Msk
#define DSI_VHBPCCR_HBP_Pos   (0U)
#define DSI_VHBPCCR_HBP_Msk   (0xFFFUL << DSI_VHBPCCR_HBP_Pos)
#define DSI_VHBPCCR_HBP   DSI_VHBPCCR_HBP_Msk
#define DSI_VHBPCCR_HBP0_Pos   (0U)
#define DSI_VHBPCCR_HBP0_Msk   (0x1UL << DSI_VHBPCCR_HBP0_Pos)
#define DSI_VHBPCCR_HBP0   DSI_VHBPCCR_HBP0_Msk
#define DSI_VHBPCCR_HBP1_Pos   (1U)
#define DSI_VHBPCCR_HBP1_Msk   (0x1UL << DSI_VHBPCCR_HBP1_Pos)
#define DSI_VHBPCCR_HBP1   DSI_VHBPCCR_HBP1_Msk
#define DSI_VHBPCCR_HBP2_Pos   (2U)
#define DSI_VHBPCCR_HBP2_Msk   (0x1UL << DSI_VHBPCCR_HBP2_Pos)
#define DSI_VHBPCCR_HBP2   DSI_VHBPCCR_HBP2_Msk
#define DSI_VHBPCCR_HBP3_Pos   (3U)
#define DSI_VHBPCCR_HBP3_Msk   (0x1UL << DSI_VHBPCCR_HBP3_Pos)
#define DSI_VHBPCCR_HBP3   DSI_VHBPCCR_HBP3_Msk
#define DSI_VHBPCCR_HBP4_Pos   (4U)
#define DSI_VHBPCCR_HBP4_Msk   (0x1UL << DSI_VHBPCCR_HBP4_Pos)
#define DSI_VHBPCCR_HBP4   DSI_VHBPCCR_HBP4_Msk
#define DSI_VHBPCCR_HBP5_Pos   (5U)
#define DSI_VHBPCCR_HBP5_Msk   (0x1UL << DSI_VHBPCCR_HBP5_Pos)
#define DSI_VHBPCCR_HBP5   DSI_VHBPCCR_HBP5_Msk
#define DSI_VHBPCCR_HBP6_Pos   (6U)
#define DSI_VHBPCCR_HBP6_Msk   (0x1UL << DSI_VHBPCCR_HBP6_Pos)
#define DSI_VHBPCCR_HBP6   DSI_VHBPCCR_HBP6_Msk
#define DSI_VHBPCCR_HBP7_Pos   (7U)
#define DSI_VHBPCCR_HBP7_Msk   (0x1UL << DSI_VHBPCCR_HBP7_Pos)
#define DSI_VHBPCCR_HBP7   DSI_VHBPCCR_HBP7_Msk
#define DSI_VHBPCCR_HBP8_Pos   (8U)
#define DSI_VHBPCCR_HBP8_Msk   (0x1UL << DSI_VHBPCCR_HBP8_Pos)
#define DSI_VHBPCCR_HBP8   DSI_VHBPCCR_HBP8_Msk
#define DSI_VHBPCCR_HBP9_Pos   (9U)
#define DSI_VHBPCCR_HBP9_Msk   (0x1UL << DSI_VHBPCCR_HBP9_Pos)
#define DSI_VHBPCCR_HBP9   DSI_VHBPCCR_HBP9_Msk
#define DSI_VHBPCCR_HBP10_Pos   (10U)
#define DSI_VHBPCCR_HBP10_Msk   (0x1UL << DSI_VHBPCCR_HBP10_Pos)
#define DSI_VHBPCCR_HBP10   DSI_VHBPCCR_HBP10_Msk
#define DSI_VHBPCCR_HBP11_Pos   (11U)
#define DSI_VHBPCCR_HBP11_Msk   (0x1UL << DSI_VHBPCCR_HBP11_Pos)
#define DSI_VHBPCCR_HBP11   DSI_VHBPCCR_HBP11_Msk
#define DSI_VLCCR_HLINE_Pos   (0U)
#define DSI_VLCCR_HLINE_Msk   (0x7FFFUL << DSI_VLCCR_HLINE_Pos)
#define DSI_VLCCR_HLINE   DSI_VLCCR_HLINE_Msk
#define DSI_VLCCR_HLINE0_Pos   (0U)
#define DSI_VLCCR_HLINE0_Msk   (0x1UL << DSI_VLCCR_HLINE0_Pos)
#define DSI_VLCCR_HLINE0   DSI_VLCCR_HLINE0_Msk
#define DSI_VLCCR_HLINE1_Pos   (1U)
#define DSI_VLCCR_HLINE1_Msk   (0x1UL << DSI_VLCCR_HLINE1_Pos)
#define DSI_VLCCR_HLINE1   DSI_VLCCR_HLINE1_Msk
#define DSI_VLCCR_HLINE2_Pos   (2U)
#define DSI_VLCCR_HLINE2_Msk   (0x1UL << DSI_VLCCR_HLINE2_Pos)
#define DSI_VLCCR_HLINE2   DSI_VLCCR_HLINE2_Msk
#define DSI_VLCCR_HLINE3_Pos   (3U)
#define DSI_VLCCR_HLINE3_Msk   (0x1UL << DSI_VLCCR_HLINE3_Pos)
#define DSI_VLCCR_HLINE3   DSI_VLCCR_HLINE3_Msk
#define DSI_VLCCR_HLINE4_Pos   (4U)
#define DSI_VLCCR_HLINE4_Msk   (0x1UL << DSI_VLCCR_HLINE4_Pos)
#define DSI_VLCCR_HLINE4   DSI_VLCCR_HLINE4_Msk
#define DSI_VLCCR_HLINE5_Pos   (5U)
#define DSI_VLCCR_HLINE5_Msk   (0x1UL << DSI_VLCCR_HLINE5_Pos)
#define DSI_VLCCR_HLINE5   DSI_VLCCR_HLINE5_Msk
#define DSI_VLCCR_HLINE6_Pos   (6U)
#define DSI_VLCCR_HLINE6_Msk   (0x1UL << DSI_VLCCR_HLINE6_Pos)
#define DSI_VLCCR_HLINE6   DSI_VLCCR_HLINE6_Msk
#define DSI_VLCCR_HLINE7_Pos   (7U)
#define DSI_VLCCR_HLINE7_Msk   (0x1UL << DSI_VLCCR_HLINE7_Pos)
#define DSI_VLCCR_HLINE7   DSI_VLCCR_HLINE7_Msk
#define DSI_VLCCR_HLINE8_Pos   (8U)
#define DSI_VLCCR_HLINE8_Msk   (0x1UL << DSI_VLCCR_HLINE8_Pos)
#define DSI_VLCCR_HLINE8   DSI_VLCCR_HLINE8_Msk
#define DSI_VLCCR_HLINE9_Pos   (9U)
#define DSI_VLCCR_HLINE9_Msk   (0x1UL << DSI_VLCCR_HLINE9_Pos)
#define DSI_VLCCR_HLINE9   DSI_VLCCR_HLINE9_Msk
#define DSI_VLCCR_HLINE10_Pos   (10U)
#define DSI_VLCCR_HLINE10_Msk   (0x1UL << DSI_VLCCR_HLINE10_Pos)
#define DSI_VLCCR_HLINE10   DSI_VLCCR_HLINE10_Msk
#define DSI_VLCCR_HLINE11_Pos   (11U)
#define DSI_VLCCR_HLINE11_Msk   (0x1UL << DSI_VLCCR_HLINE11_Pos)
#define DSI_VLCCR_HLINE11   DSI_VLCCR_HLINE11_Msk
#define DSI_VLCCR_HLINE12_Pos   (12U)
#define DSI_VLCCR_HLINE12_Msk   (0x1UL << DSI_VLCCR_HLINE12_Pos)
#define DSI_VLCCR_HLINE12   DSI_VLCCR_HLINE12_Msk
#define DSI_VLCCR_HLINE13_Pos   (13U)
#define DSI_VLCCR_HLINE13_Msk   (0x1UL << DSI_VLCCR_HLINE13_Pos)
#define DSI_VLCCR_HLINE13   DSI_VLCCR_HLINE13_Msk
#define DSI_VLCCR_HLINE14_Pos   (14U)
#define DSI_VLCCR_HLINE14_Msk   (0x1UL << DSI_VLCCR_HLINE14_Pos)
#define DSI_VLCCR_HLINE14   DSI_VLCCR_HLINE14_Msk
#define DSI_VVSACCR_VSA_Pos   (0U)
#define DSI_VVSACCR_VSA_Msk   (0x3FFUL << DSI_VVSACCR_VSA_Pos)
#define DSI_VVSACCR_VSA   DSI_VVSACCR_VSA_Msk
#define DSI_VVSACCR_VSA0_Pos   (0U)
#define DSI_VVSACCR_VSA0_Msk   (0x1UL << DSI_VVSACCR_VSA0_Pos)
#define DSI_VVSACCR_VSA0   DSI_VVSACCR_VSA0_Msk
#define DSI_VVSACCR_VSA1_Pos   (1U)
#define DSI_VVSACCR_VSA1_Msk   (0x1UL << DSI_VVSACCR_VSA1_Pos)
#define DSI_VVSACCR_VSA1   DSI_VVSACCR_VSA1_Msk
#define DSI_VVSACCR_VSA2_Pos   (2U)
#define DSI_VVSACCR_VSA2_Msk   (0x1UL << DSI_VVSACCR_VSA2_Pos)
#define DSI_VVSACCR_VSA2   DSI_VVSACCR_VSA2_Msk
#define DSI_VVSACCR_VSA3_Pos   (3U)
#define DSI_VVSACCR_VSA3_Msk   (0x1UL << DSI_VVSACCR_VSA3_Pos)
#define DSI_VVSACCR_VSA3   DSI_VVSACCR_VSA3_Msk
#define DSI_VVSACCR_VSA4_Pos   (4U)
#define DSI_VVSACCR_VSA4_Msk   (0x1UL << DSI_VVSACCR_VSA4_Pos)
#define DSI_VVSACCR_VSA4   DSI_VVSACCR_VSA4_Msk
#define DSI_VVSACCR_VSA5_Pos   (5U)
#define DSI_VVSACCR_VSA5_Msk   (0x1UL << DSI_VVSACCR_VSA5_Pos)
#define DSI_VVSACCR_VSA5   DSI_VVSACCR_VSA5_Msk
#define DSI_VVSACCR_VSA6_Pos   (6U)
#define DSI_VVSACCR_VSA6_Msk   (0x1UL << DSI_VVSACCR_VSA6_Pos)
#define DSI_VVSACCR_VSA6   DSI_VVSACCR_VSA6_Msk
#define DSI_VVSACCR_VSA7_Pos   (7U)
#define DSI_VVSACCR_VSA7_Msk   (0x1UL << DSI_VVSACCR_VSA7_Pos)
#define DSI_VVSACCR_VSA7   DSI_VVSACCR_VSA7_Msk
#define DSI_VVSACCR_VSA8_Pos   (8U)
#define DSI_VVSACCR_VSA8_Msk   (0x1UL << DSI_VVSACCR_VSA8_Pos)
#define DSI_VVSACCR_VSA8   DSI_VVSACCR_VSA8_Msk
#define DSI_VVSACCR_VSA9_Pos   (9U)
#define DSI_VVSACCR_VSA9_Msk   (0x1UL << DSI_VVSACCR_VSA9_Pos)
#define DSI_VVSACCR_VSA9   DSI_VVSACCR_VSA9_Msk
#define DSI_VVBPCCR_VBP_Pos   (0U)
#define DSI_VVBPCCR_VBP_Msk   (0x3FFUL << DSI_VVBPCCR_VBP_Pos)
#define DSI_VVBPCCR_VBP   DSI_VVBPCCR_VBP_Msk
#define DSI_VVBPCCR_VBP0_Pos   (0U)
#define DSI_VVBPCCR_VBP0_Msk   (0x1UL << DSI_VVBPCCR_VBP0_Pos)
#define DSI_VVBPCCR_VBP0   DSI_VVBPCCR_VBP0_Msk
#define DSI_VVBPCCR_VBP1_Pos   (1U)
#define DSI_VVBPCCR_VBP1_Msk   (0x1UL << DSI_VVBPCCR_VBP1_Pos)
#define DSI_VVBPCCR_VBP1   DSI_VVBPCCR_VBP1_Msk
#define DSI_VVBPCCR_VBP2_Pos   (2U)
#define DSI_VVBPCCR_VBP2_Msk   (0x1UL << DSI_VVBPCCR_VBP2_Pos)
#define DSI_VVBPCCR_VBP2   DSI_VVBPCCR_VBP2_Msk
#define DSI_VVBPCCR_VBP3_Pos   (3U)
#define DSI_VVBPCCR_VBP3_Msk   (0x1UL << DSI_VVBPCCR_VBP3_Pos)
#define DSI_VVBPCCR_VBP3   DSI_VVBPCCR_VBP3_Msk
#define DSI_VVBPCCR_VBP4_Pos   (4U)
#define DSI_VVBPCCR_VBP4_Msk   (0x1UL << DSI_VVBPCCR_VBP4_Pos)
#define DSI_VVBPCCR_VBP4   DSI_VVBPCCR_VBP4_Msk
#define DSI_VVBPCCR_VBP5_Pos   (5U)
#define DSI_VVBPCCR_VBP5_Msk   (0x1UL << DSI_VVBPCCR_VBP5_Pos)
#define DSI_VVBPCCR_VBP5   DSI_VVBPCCR_VBP5_Msk
#define DSI_VVBPCCR_VBP6_Pos   (6U)
#define DSI_VVBPCCR_VBP6_Msk   (0x1UL << DSI_VVBPCCR_VBP6_Pos)
#define DSI_VVBPCCR_VBP6   DSI_VVBPCCR_VBP6_Msk
#define DSI_VVBPCCR_VBP7_Pos   (7U)
#define DSI_VVBPCCR_VBP7_Msk   (0x1UL << DSI_VVBPCCR_VBP7_Pos)
#define DSI_VVBPCCR_VBP7   DSI_VVBPCCR_VBP7_Msk
#define DSI_VVBPCCR_VBP8_Pos   (8U)
#define DSI_VVBPCCR_VBP8_Msk   (0x1UL << DSI_VVBPCCR_VBP8_Pos)
#define DSI_VVBPCCR_VBP8   DSI_VVBPCCR_VBP8_Msk
#define DSI_VVBPCCR_VBP9_Pos   (9U)
#define DSI_VVBPCCR_VBP9_Msk   (0x1UL << DSI_VVBPCCR_VBP9_Pos)
#define DSI_VVBPCCR_VBP9   DSI_VVBPCCR_VBP9_Msk
#define DSI_VVFPCCR_VFP_Pos   (0U)
#define DSI_VVFPCCR_VFP_Msk   (0x3FFUL << DSI_VVFPCCR_VFP_Pos)
#define DSI_VVFPCCR_VFP   DSI_VVFPCCR_VFP_Msk
#define DSI_VVFPCCR_VFP0_Pos   (0U)
#define DSI_VVFPCCR_VFP0_Msk   (0x1UL << DSI_VVFPCCR_VFP0_Pos)
#define DSI_VVFPCCR_VFP0   DSI_VVFPCCR_VFP0_Msk
#define DSI_VVFPCCR_VFP1_Pos   (1U)
#define DSI_VVFPCCR_VFP1_Msk   (0x1UL << DSI_VVFPCCR_VFP1_Pos)
#define DSI_VVFPCCR_VFP1   DSI_VVFPCCR_VFP1_Msk
#define DSI_VVFPCCR_VFP2_Pos   (2U)
#define DSI_VVFPCCR_VFP2_Msk   (0x1UL << DSI_VVFPCCR_VFP2_Pos)
#define DSI_VVFPCCR_VFP2   DSI_VVFPCCR_VFP2_Msk
#define DSI_VVFPCCR_VFP3_Pos   (3U)
#define DSI_VVFPCCR_VFP3_Msk   (0x1UL << DSI_VVFPCCR_VFP3_Pos)
#define DSI_VVFPCCR_VFP3   DSI_VVFPCCR_VFP3_Msk
#define DSI_VVFPCCR_VFP4_Pos   (4U)
#define DSI_VVFPCCR_VFP4_Msk   (0x1UL << DSI_VVFPCCR_VFP4_Pos)
#define DSI_VVFPCCR_VFP4   DSI_VVFPCCR_VFP4_Msk
#define DSI_VVFPCCR_VFP5_Pos   (5U)
#define DSI_VVFPCCR_VFP5_Msk   (0x1UL << DSI_VVFPCCR_VFP5_Pos)
#define DSI_VVFPCCR_VFP5   DSI_VVFPCCR_VFP5_Msk
#define DSI_VVFPCCR_VFP6_Pos   (6U)
#define DSI_VVFPCCR_VFP6_Msk   (0x1UL << DSI_VVFPCCR_VFP6_Pos)
#define DSI_VVFPCCR_VFP6   DSI_VVFPCCR_VFP6_Msk
#define DSI_VVFPCCR_VFP7_Pos   (7U)
#define DSI_VVFPCCR_VFP7_Msk   (0x1UL << DSI_VVFPCCR_VFP7_Pos)
#define DSI_VVFPCCR_VFP7   DSI_VVFPCCR_VFP7_Msk
#define DSI_VVFPCCR_VFP8_Pos   (8U)
#define DSI_VVFPCCR_VFP8_Msk   (0x1UL << DSI_VVFPCCR_VFP8_Pos)
#define DSI_VVFPCCR_VFP8   DSI_VVFPCCR_VFP8_Msk
#define DSI_VVFPCCR_VFP9_Pos   (9U)
#define DSI_VVFPCCR_VFP9_Msk   (0x1UL << DSI_VVFPCCR_VFP9_Pos)
#define DSI_VVFPCCR_VFP9   DSI_VVFPCCR_VFP9_Msk
#define DSI_VVACCR_VA_Pos   (0U)
#define DSI_VVACCR_VA_Msk   (0x3FFFUL << DSI_VVACCR_VA_Pos)
#define DSI_VVACCR_VA   DSI_VVACCR_VA_Msk
#define DSI_VVACCR_VA0_Pos   (0U)
#define DSI_VVACCR_VA0_Msk   (0x1UL << DSI_VVACCR_VA0_Pos)
#define DSI_VVACCR_VA0   DSI_VVACCR_VA0_Msk
#define DSI_VVACCR_VA1_Pos   (1U)
#define DSI_VVACCR_VA1_Msk   (0x1UL << DSI_VVACCR_VA1_Pos)
#define DSI_VVACCR_VA1   DSI_VVACCR_VA1_Msk
#define DSI_VVACCR_VA2_Pos   (2U)
#define DSI_VVACCR_VA2_Msk   (0x1UL << DSI_VVACCR_VA2_Pos)
#define DSI_VVACCR_VA2   DSI_VVACCR_VA2_Msk
#define DSI_VVACCR_VA3_Pos   (3U)
#define DSI_VVACCR_VA3_Msk   (0x1UL << DSI_VVACCR_VA3_Pos)
#define DSI_VVACCR_VA3   DSI_VVACCR_VA3_Msk
#define DSI_VVACCR_VA4_Pos   (4U)
#define DSI_VVACCR_VA4_Msk   (0x1UL << DSI_VVACCR_VA4_Pos)
#define DSI_VVACCR_VA4   DSI_VVACCR_VA4_Msk
#define DSI_VVACCR_VA5_Pos   (5U)
#define DSI_VVACCR_VA5_Msk   (0x1UL << DSI_VVACCR_VA5_Pos)
#define DSI_VVACCR_VA5   DSI_VVACCR_VA5_Msk
#define DSI_VVACCR_VA6_Pos   (6U)
#define DSI_VVACCR_VA6_Msk   (0x1UL << DSI_VVACCR_VA6_Pos)
#define DSI_VVACCR_VA6   DSI_VVACCR_VA6_Msk
#define DSI_VVACCR_VA7_Pos   (7U)
#define DSI_VVACCR_VA7_Msk   (0x1UL << DSI_VVACCR_VA7_Pos)
#define DSI_VVACCR_VA7   DSI_VVACCR_VA7_Msk
#define DSI_VVACCR_VA8_Pos   (8U)
#define DSI_VVACCR_VA8_Msk   (0x1UL << DSI_VVACCR_VA8_Pos)
#define DSI_VVACCR_VA8   DSI_VVACCR_VA8_Msk
#define DSI_VVACCR_VA9_Pos   (9U)
#define DSI_VVACCR_VA9_Msk   (0x1UL << DSI_VVACCR_VA9_Pos)
#define DSI_VVACCR_VA9   DSI_VVACCR_VA9_Msk
#define DSI_VVACCR_VA10_Pos   (10U)
#define DSI_VVACCR_VA10_Msk   (0x1UL << DSI_VVACCR_VA10_Pos)
#define DSI_VVACCR_VA10   DSI_VVACCR_VA10_Msk
#define DSI_VVACCR_VA11_Pos   (11U)
#define DSI_VVACCR_VA11_Msk   (0x1UL << DSI_VVACCR_VA11_Pos)
#define DSI_VVACCR_VA11   DSI_VVACCR_VA11_Msk
#define DSI_VVACCR_VA12_Pos   (12U)
#define DSI_VVACCR_VA12_Msk   (0x1UL << DSI_VVACCR_VA12_Pos)
#define DSI_VVACCR_VA12   DSI_VVACCR_VA12_Msk
#define DSI_VVACCR_VA13_Pos   (13U)
#define DSI_VVACCR_VA13_Msk   (0x1UL << DSI_VVACCR_VA13_Pos)
#define DSI_VVACCR_VA13   DSI_VVACCR_VA13_Msk
#define DSI_FBSR_VCWFE_Pos   (0U)
#define DSI_FBSR_VCWFE_Msk   (0x1UL << DSI_FBSR_VCWFE_Pos)
#define DSI_FBSR_VCWFE   DSI_FBSR_VCWFE_Msk
#define DSI_FBSR_VCWFF_Pos   (1U)
#define DSI_FBSR_VCWFF_Msk   (0x1UL << DSI_FBSR_VCWFF_Pos)
#define DSI_FBSR_VCWFF   DSI_FBSR_VCWFF_Msk
#define DSI_FBSR_VPWFE_Pos   (2U)
#define DSI_FBSR_VPWFE_Msk   (0x1UL << DSI_FBSR_VPWFE_Pos)
#define DSI_FBSR_VPWFE   DSI_FBSR_VPWFE_Msk
#define DSI_FBSR_VPWFF_Pos   (3U)
#define DSI_FBSR_VPWFF_Msk   (0x1UL << DSI_FBSR_VPWFF_Pos)
#define DSI_FBSR_VPWFF   DSI_FBSR_VPWFF_Msk
#define DSI_FBSR_ACWFE_Pos   (4U)
#define DSI_FBSR_ACWFE_Msk   (0x1UL << DSI_FBSR_ACWFE_Pos)
#define DSI_FBSR_ACWFE   DSI_FBSR_ACWFE_Msk
#define DSI_FBSR_ACWFF_Pos   (5U)
#define DSI_FBSR_ACWFF_Msk   (0x1UL << DSI_FBSR_ACWFF_Pos)
#define DSI_FBSR_ACWFF   DSI_FBSR_ACWFF_Msk
#define DSI_FBSR_APWFE_Pos   (6U)
#define DSI_FBSR_APWFE_Msk   (0x1UL << DSI_FBSR_APWFE_Pos)
#define DSI_FBSR_APWFE   DSI_FBSR_APWFE_Msk
#define DSI_FBSR_APWFF_Pos   (7U)
#define DSI_FBSR_APWFF_Msk   (0x1UL << DSI_FBSR_APWFF_Pos)
#define DSI_FBSR_APWFF   DSI_FBSR_APWFF_Msk
#define DSI_FBSR_VPBE_Pos   (16U)
#define DSI_FBSR_VPBE_Msk   (0x1UL << DSI_FBSR_VPBE_Pos)
#define DSI_FBSR_VPBE   DSI_FBSR_VPBE_Msk
#define DSI_FBSR_VPBF_Pos   (17U)
#define DSI_FBSR_VPBF_Msk   (0x1UL << DSI_FBSR_VPBF_Pos)
#define DSI_FBSR_VPBF   DSI_FBSR_VPBF_Msk
#define DSI_FBSR_ACBE_Pos   (20U)
#define DSI_FBSR_ACBE_Msk   (0x1UL << DSI_FBSR_ACBE_Pos)
#define DSI_FBSR_ACBE   DSI_FBSR_ACBE_Msk
#define DSI_FBSR_ACBF_Pos   (21U)
#define DSI_FBSR_ACBF_Msk   (0x1UL << DSI_FBSR_ACBF_Pos)
#define DSI_FBSR_ACBF   DSI_FBSR_ACBF_Msk
#define DSI_FBSR_APBE_Pos   (22U)
#define DSI_FBSR_APBE_Msk   (0x1UL << DSI_FBSR_APBE_Pos)
#define DSI_FBSR_APBE   DSI_FBSR_APBE_Msk
#define DSI_FBSR_APBF_Pos   (23U)
#define DSI_FBSR_APBF_Msk   (0x1UL << DSI_FBSR_APBF_Pos)
#define DSI_FBSR_APBF   DSI_FBSR_APBF_Msk
#define DSI_WCFGR_DSIM_Pos   (0U)
#define DSI_WCFGR_DSIM_Msk   (0x1UL << DSI_WCFGR_DSIM_Pos)
#define DSI_WCFGR_DSIM   DSI_WCFGR_DSIM_Msk
#define DSI_WCFGR_COLMUX_Pos   (1U)
#define DSI_WCFGR_COLMUX_Msk   (0x7UL << DSI_WCFGR_COLMUX_Pos)
#define DSI_WCFGR_COLMUX   DSI_WCFGR_COLMUX_Msk
#define DSI_WCFGR_COLMUX0_Pos   (1U)
#define DSI_WCFGR_COLMUX0_Msk   (0x1UL << DSI_WCFGR_COLMUX0_Pos)
#define DSI_WCFGR_COLMUX0   DSI_WCFGR_COLMUX0_Msk
#define DSI_WCFGR_COLMUX1_Pos   (2U)
#define DSI_WCFGR_COLMUX1_Msk   (0x1UL << DSI_WCFGR_COLMUX1_Pos)
#define DSI_WCFGR_COLMUX1   DSI_WCFGR_COLMUX1_Msk
#define DSI_WCFGR_COLMUX2_Pos   (3U)
#define DSI_WCFGR_COLMUX2_Msk   (0x1UL << DSI_WCFGR_COLMUX2_Pos)
#define DSI_WCFGR_COLMUX2   DSI_WCFGR_COLMUX2_Msk
#define DSI_WCFGR_TESRC_Pos   (4U)
#define DSI_WCFGR_TESRC_Msk   (0x1UL << DSI_WCFGR_TESRC_Pos)
#define DSI_WCFGR_TESRC   DSI_WCFGR_TESRC_Msk
#define DSI_WCFGR_TEPOL_Pos   (5U)
#define DSI_WCFGR_TEPOL_Msk   (0x1UL << DSI_WCFGR_TEPOL_Pos)
#define DSI_WCFGR_TEPOL   DSI_WCFGR_TEPOL_Msk
#define DSI_WCFGR_AR_Pos   (6U)
#define DSI_WCFGR_AR_Msk   (0x1UL << DSI_WCFGR_AR_Pos)
#define DSI_WCFGR_AR   DSI_WCFGR_AR_Msk
#define DSI_WCFGR_VSPOL_Pos   (7U)
#define DSI_WCFGR_VSPOL_Msk   (0x1UL << DSI_WCFGR_VSPOL_Pos)
#define DSI_WCFGR_VSPOL   DSI_WCFGR_VSPOL_Msk
#define DSI_WCR_COLM_Pos   (0U)
#define DSI_WCR_COLM_Msk   (0x1UL << DSI_WCR_COLM_Pos)
#define DSI_WCR_COLM   DSI_WCR_COLM_Msk
#define DSI_WCR_SHTDN_Pos   (1U)
#define DSI_WCR_SHTDN_Msk   (0x1UL << DSI_WCR_SHTDN_Pos)
#define DSI_WCR_SHTDN   DSI_WCR_SHTDN_Msk
#define DSI_WCR_LTDCEN_Pos   (2U)
#define DSI_WCR_LTDCEN_Msk   (0x1UL << DSI_WCR_LTDCEN_Pos)
#define DSI_WCR_LTDCEN   DSI_WCR_LTDCEN_Msk
#define DSI_WCR_DSIEN_Pos   (3U)
#define DSI_WCR_DSIEN_Msk   (0x1UL << DSI_WCR_DSIEN_Pos)
#define DSI_WCR_DSIEN   DSI_WCR_DSIEN_Msk
#define DSI_WIER_TEIE_Pos   (0U)
#define DSI_WIER_TEIE_Msk   (0x1UL << DSI_WIER_TEIE_Pos)
#define DSI_WIER_TEIE   DSI_WIER_TEIE_Msk
#define DSI_WIER_ERIE_Pos   (1U)
#define DSI_WIER_ERIE_Msk   (0x1UL << DSI_WIER_ERIE_Pos)
#define DSI_WIER_ERIE   DSI_WIER_ERIE_Msk
#define DSI_WIER_PLLLIE_Pos   (9U)
#define DSI_WIER_PLLLIE_Msk   (0x1UL << DSI_WIER_PLLLIE_Pos)
#define DSI_WIER_PLLLIE   DSI_WIER_PLLLIE_Msk
#define DSI_WIER_PLLUIE_Pos   (10U)
#define DSI_WIER_PLLUIE_Msk   (0x1UL << DSI_WIER_PLLUIE_Pos)
#define DSI_WIER_PLLUIE   DSI_WIER_PLLUIE_Msk
#define DSI_WISR_TEIF_Pos   (0U)
#define DSI_WISR_TEIF_Msk   (0x1UL << DSI_WISR_TEIF_Pos)
#define DSI_WISR_TEIF   DSI_WISR_TEIF_Msk
#define DSI_WISR_ERIF_Pos   (1U)
#define DSI_WISR_ERIF_Msk   (0x1UL << DSI_WISR_ERIF_Pos)
#define DSI_WISR_ERIF   DSI_WISR_ERIF_Msk
#define DSI_WISR_BUSY_Pos   (2U)
#define DSI_WISR_BUSY_Msk   (0x1UL << DSI_WISR_BUSY_Pos)
#define DSI_WISR_BUSY   DSI_WISR_BUSY_Msk
#define DSI_WISR_PLLLS_Pos   (8U)
#define DSI_WISR_PLLLS_Msk   (0x1UL << DSI_WISR_PLLLS_Pos)
#define DSI_WISR_PLLLS   DSI_WISR_PLLLS_Msk
#define DSI_WISR_PLLLIF_Pos   (9U)
#define DSI_WISR_PLLLIF_Msk   (0x1UL << DSI_WISR_PLLLIF_Pos)
#define DSI_WISR_PLLLIF   DSI_WISR_PLLLIF_Msk
#define DSI_WISR_PLLUIF_Pos   (10U)
#define DSI_WISR_PLLUIF_Msk   (0x1UL << DSI_WISR_PLLUIF_Pos)
#define DSI_WISR_PLLUIF   DSI_WISR_PLLUIF_Msk
#define DSI_WIFCR_CTEIF_Pos   (0U)
#define DSI_WIFCR_CTEIF_Msk   (0x1UL << DSI_WIFCR_CTEIF_Pos)
#define DSI_WIFCR_CTEIF   DSI_WIFCR_CTEIF_Msk
#define DSI_WIFCR_CERIF_Pos   (1U)
#define DSI_WIFCR_CERIF_Msk   (0x1UL << DSI_WIFCR_CERIF_Pos)
#define DSI_WIFCR_CERIF   DSI_WIFCR_CERIF_Msk
#define DSI_WIFCR_CPLLLIF_Pos   (9U)
#define DSI_WIFCR_CPLLLIF_Msk   (0x1UL << DSI_WIFCR_CPLLLIF_Pos)
#define DSI_WIFCR_CPLLLIF   DSI_WIFCR_CPLLLIF_Msk
#define DSI_WIFCR_CPLLUIF_Pos   (10U)
#define DSI_WIFCR_CPLLUIF_Msk   (0x1UL << DSI_WIFCR_CPLLUIF_Pos)
#define DSI_WIFCR_CPLLUIF   DSI_WIFCR_CPLLUIF_Msk
#define DSI_WPCR0_SWCL_Pos   (6U)
#define DSI_WPCR0_SWCL_Msk   (0x1UL << DSI_WPCR0_SWCL_Pos)
#define DSI_WPCR0_SWCL   DSI_WPCR0_SWCL_Msk
#define DSI_WPCR0_SWDL0_Pos   (7U)
#define DSI_WPCR0_SWDL0_Msk   (0x1UL << DSI_WPCR0_SWDL0_Pos)
#define DSI_WPCR0_SWDL0   DSI_WPCR0_SWDL0_Msk
#define DSI_WPCR0_SWDL1_Pos   (8U)
#define DSI_WPCR0_SWDL1_Msk   (0x1UL << DSI_WPCR0_SWDL1_Pos)
#define DSI_WPCR0_SWDL1   DSI_WPCR0_SWDL1_Msk
#define DSI_WPCR0_FTXSMCL_Pos   (12U)
#define DSI_WPCR0_FTXSMCL_Msk   (0x1UL << DSI_WPCR0_FTXSMCL_Pos)
#define DSI_WPCR0_FTXSMCL   DSI_WPCR0_FTXSMCL_Msk
#define DSI_WPCR0_FTXSMDL_Pos   (13U)
#define DSI_WPCR0_FTXSMDL_Msk   (0x1UL << DSI_WPCR0_FTXSMDL_Pos)
#define DSI_WPCR0_FTXSMDL   DSI_WPCR0_FTXSMDL_Msk
#define DSI_WRPCR_PLLEN_Pos   (0U)
#define DSI_WRPCR_PLLEN_Msk   (0x1UL << DSI_WRPCR_PLLEN_Pos)
#define DSI_WRPCR_PLLEN   DSI_WRPCR_PLLEN_Msk
#define DSI_WRPCR_PLL_NDIV_Pos   (2U)
#define DSI_WRPCR_PLL_NDIV_Msk   (0x1FFUL << DSI_WRPCR_PLL_NDIV_Pos)
#define DSI_WRPCR_PLL_NDIV   DSI_WRPCR_PLL_NDIV_Msk
#define DSI_WRPCR_PLL_NDIV0_Pos   (2U)
#define DSI_WRPCR_PLL_NDIV0_Msk   (0x1UL << DSI_WRPCR_PLL_NDIV0_Pos)
#define DSI_WRPCR_PLL_NDIV0   DSI_WRPCR_PLL_NDIV0_Msk
#define DSI_WRPCR_PLL_NDIV1_Pos   (3U)
#define DSI_WRPCR_PLL_NDIV1_Msk   (0x1UL << DSI_WRPCR_PLL_NDIV1_Pos)
#define DSI_WRPCR_PLL_NDIV1   DSI_WRPCR_PLL_NDIV1_Msk
#define DSI_WRPCR_PLL_NDIV2_Pos   (4U)
#define DSI_WRPCR_PLL_NDIV2_Msk   (0x1UL << DSI_WRPCR_PLL_NDIV2_Pos)
#define DSI_WRPCR_PLL_NDIV2   DSI_WRPCR_PLL_NDIV2_Msk
#define DSI_WRPCR_PLL_NDIV3_Pos   (5U)
#define DSI_WRPCR_PLL_NDIV3_Msk   (0x1UL << DSI_WRPCR_PLL_NDIV3_Pos)
#define DSI_WRPCR_PLL_NDIV3   DSI_WRPCR_PLL_NDIV3_Msk
#define DSI_WRPCR_PLL_NDIV4_Pos   (6U)
#define DSI_WRPCR_PLL_NDIV4_Msk   (0x1UL << DSI_WRPCR_PLL_NDIV4_Pos)
#define DSI_WRPCR_PLL_NDIV4   DSI_WRPCR_PLL_NDIV4_Msk
#define DSI_WRPCR_PLL_NDIV5_Pos   (7U)
#define DSI_WRPCR_PLL_NDIV5_Msk   (0x1UL << DSI_WRPCR_PLL_NDIV5_Pos)
#define DSI_WRPCR_PLL_NDIV5   DSI_WRPCR_PLL_NDIV5_Msk
#define DSI_WRPCR_PLL_NDIV6_Pos   (8U)
#define DSI_WRPCR_PLL_NDIV6_Msk   (0x1UL << DSI_WRPCR_PLL_NDIV6_Pos)
#define DSI_WRPCR_PLL_NDIV6   DSI_WRPCR_PLL_NDIV6_Msk
#define DSI_WRPCR_PLL_NDIV7_Pos   (9U)
#define DSI_WRPCR_PLL_NDIV7_Msk   (0x1UL << DSI_WRPCR_PLL_NDIV7_Pos)
#define DSI_WRPCR_PLL_NDIV7   DSI_WRPCR_PLL_NDIV7_Msk
#define DSI_WRPCR_PLL_NDIV8_Pos   (10U)
#define DSI_WRPCR_PLL_NDIV8_Msk   (0x1UL << DSI_WRPCR_PLL_NDIV8_Pos)
#define DSI_WRPCR_PLL_NDIV8   DSI_WRPCR_PLL_NDIV8_Msk
#define DSI_WRPCR_PLL_IDF_Pos   (11U)
#define DSI_WRPCR_PLL_IDF_Msk   (0x1FFUL << DSI_WRPCR_PLL_IDF_Pos)
#define DSI_WRPCR_PLL_IDF   DSI_WRPCR_PLL_IDF_Msk
#define DSI_WRPCR_PLL_IDF0_Pos   (11U)
#define DSI_WRPCR_PLL_IDF0_Msk   (0x1UL << DSI_WRPCR_PLL_IDF0_Pos)
#define DSI_WRPCR_PLL_IDF0   DSI_WRPCR_PLL_IDF0_Msk
#define DSI_WRPCR_PLL_IDF1_Pos   (12U)
#define DSI_WRPCR_PLL_IDF1_Msk   (0x1UL << DSI_WRPCR_PLL_IDF1_Pos)
#define DSI_WRPCR_PLL_IDF1   DSI_WRPCR_PLL_IDF1_Msk
#define DSI_WRPCR_PLL_IDF2_Pos   (13U)
#define DSI_WRPCR_PLL_IDF2_Msk   (0x1UL << DSI_WRPCR_PLL_IDF2_Pos)
#define DSI_WRPCR_PLL_IDF2   DSI_WRPCR_PLL_IDF2_Msk
#define DSI_WRPCR_PLL_IDF3_Pos   (14U)
#define DSI_WRPCR_PLL_IDF3_Msk   (0x1UL << DSI_WRPCR_PLL_IDF3_Pos)
#define DSI_WRPCR_PLL_IDF3   DSI_WRPCR_PLL_IDF3_Msk
#define DSI_WRPCR_PLL_IDF4_Pos   (15U)
#define DSI_WRPCR_PLL_IDF4_Msk   (0x1UL << DSI_WRPCR_PLL_IDF4_Pos)
#define DSI_WRPCR_PLL_IDF4   DSI_WRPCR_PLL_IDF4_Msk
#define DSI_WRPCR_PLL_IDF5_Pos   (16U)
#define DSI_WRPCR_PLL_IDF5_Msk   (0x1UL << DSI_WRPCR_PLL_IDF5_Pos)
#define DSI_WRPCR_PLL_IDF5   DSI_WRPCR_PLL_IDF5_Msk
#define DSI_WRPCR_PLL_IDF6_Pos   (17U)
#define DSI_WRPCR_PLL_IDF6_Msk   (0x1UL << DSI_WRPCR_PLL_IDF6_Pos)
#define DSI_WRPCR_PLL_IDF6   DSI_WRPCR_PLL_IDF6_Msk
#define DSI_WRPCR_PLL_IDF7_Pos   (18U)
#define DSI_WRPCR_PLL_IDF7_Msk   (0x1UL << DSI_WRPCR_PLL_IDF7_Pos)
#define DSI_WRPCR_PLL_IDF7   DSI_WRPCR_PLL_IDF7_Msk
#define DSI_WRPCR_PLL_IDF8_Pos   (19U)
#define DSI_WRPCR_PLL_IDF8_Msk   (0x1UL << DSI_WRPCR_PLL_IDF8_Pos)
#define DSI_WRPCR_PLL_IDF8   DSI_WRPCR_PLL_IDF8_Msk
#define DSI_WRPCR_PLL_ODF_Pos   (20U)
#define DSI_WRPCR_PLL_ODF_Msk   (0x1FFUL << DSI_WRPCR_PLL_ODF_Pos)
#define DSI_WRPCR_PLL_ODF   DSI_WRPCR_PLL_ODF_Msk
#define DSI_WRPCR_PLL_ODF0_Pos   (20U)
#define DSI_WRPCR_PLL_ODF0_Msk   (0x1UL << DSI_WRPCR_PLL_ODF0_Pos)
#define DSI_WRPCR_PLL_ODF0   DSI_WRPCR_PLL_ODF0_Msk
#define DSI_WRPCR_PLL_ODF1_Pos   (21U)
#define DSI_WRPCR_PLL_ODF1_Msk   (0x1UL << DSI_WRPCR_PLL_ODF1_Pos)
#define DSI_WRPCR_PLL_ODF1   DSI_WRPCR_PLL_ODF1_Msk
#define DSI_WRPCR_PLL_ODF2_Pos   (22U)
#define DSI_WRPCR_PLL_ODF2_Msk   (0x1UL << DSI_WRPCR_PLL_ODF2_Pos)
#define DSI_WRPCR_PLL_ODF2   DSI_WRPCR_PLL_ODF2_Msk
#define DSI_WRPCR_PLL_ODF3_Pos   (23U)
#define DSI_WRPCR_PLL_ODF3_Msk   (0x1UL << DSI_WRPCR_PLL_ODF3_Pos)
#define DSI_WRPCR_PLL_ODF3   DSI_WRPCR_PLL_ODF3_Msk
#define DSI_WRPCR_PLL_ODF4_Pos   (24U)
#define DSI_WRPCR_PLL_ODF4_Msk   (0x1UL << DSI_WRPCR_PLL_ODF4_Pos)
#define DSI_WRPCR_PLL_ODF4   DSI_WRPCR_PLL_ODF4_Msk
#define DSI_WRPCR_PLL_ODF5_Pos   (25U)
#define DSI_WRPCR_PLL_ODF5_Msk   (0x1UL << DSI_WRPCR_PLL_ODF5_Pos)
#define DSI_WRPCR_PLL_ODF5   DSI_WRPCR_PLL_ODF5_Msk
#define DSI_WRPCR_PLL_ODF6_Pos   (26U)
#define DSI_WRPCR_PLL_ODF6_Msk   (0x1UL << DSI_WRPCR_PLL_ODF6_Pos)
#define DSI_WRPCR_PLL_ODF6   DSI_WRPCR_PLL_ODF6_Msk
#define DSI_WRPCR_PLL_ODF7_Pos   (27U)
#define DSI_WRPCR_PLL_ODF7_Msk   (0x1UL << DSI_WRPCR_PLL_ODF7_Pos)
#define DSI_WRPCR_PLL_ODF7   DSI_WRPCR_PLL_ODF7_Msk
#define DSI_WRPCR_PLL_ODF8_Pos   (28U)
#define DSI_WRPCR_PLL_ODF8_Msk   (0x1UL << DSI_WRPCR_PLL_ODF8_Pos)
#define DSI_WRPCR_PLL_ODF8   DSI_WRPCR_PLL_ODF8_Msk
#define DSI_WRPCR_BC_Pos   (29U)
#define DSI_WRPCR_BC_Msk   (0x1UL << DSI_WRPCR_BC_Pos)
#define DSI_WRPCR_BC   DSI_WRPCR_BC_Msk
#define DSI_WPTR_CP_Pos   (8U)
#define DSI_WPTR_CP_Msk   (0xFUL << DSI_WPTR_CP_Pos)
#define DSI_WPTR_CP   DSI_WPTR_CP_Msk
#define DSI_WPTR_CP0_Pos   (8U)
#define DSI_WPTR_CP0_Msk   (0x1UL << DSI_WPTR_CP0_Pos)
#define DSI_WPTR_CP0   DSI_WPTR_CP0_Msk
#define DSI_WPTR_CP1_Pos   (9U)
#define DSI_WPTR_CP1_Msk   (0x1UL << DSI_WPTR_CP1_Pos)
#define DSI_WPTR_CP1   DSI_WPTR_CP1_Msk
#define DSI_WPTR_CP2_Pos   (10U)
#define DSI_WPTR_CP2_Msk   (0x1UL << DSI_WPTR_CP2_Pos)
#define DSI_WPTR_CP2   DSI_WPTR_CP2_Msk
#define DSI_WPTR_CP3_Pos   (11U)
#define DSI_WPTR_CP3_Msk   (0x1UL << DSI_WPTR_CP3_Pos)
#define DSI_WPTR_CP3   DSI_WPTR_CP3_Msk
#define DSI_WPTR_LPF_Pos   (12U)
#define DSI_WPTR_LPF_Msk   (0xFUL << DSI_WPTR_LPF_Pos)
#define DSI_WPTR_LPF   DSI_WPTR_LPF_Msk
#define DSI_WPTR_LPF0_Pos   (12U)
#define DSI_WPTR_LPF0_Msk   (0x1UL << DSI_WPTR_LPF0_Pos)
#define DSI_WPTR_LPF0   DSI_WPTR_LPF0_Msk
#define DSI_WPTR_LPF1_Pos   (13U)
#define DSI_WPTR_LPF1_Msk   (0x1UL << DSI_WPTR_LPF1_Pos)
#define DSI_WPTR_LPF1   DSI_WPTR_LPF1_Msk
#define DSI_WPTR_LPF2_Pos   (14U)
#define DSI_WPTR_LPF2_Msk   (0x1UL << DSI_WPTR_LPF2_Pos)
#define DSI_WPTR_LPF2   DSI_WPTR_LPF2_Msk
#define DSI_WPTR_LPF3_Pos   (15U)
#define DSI_WPTR_LPF3_Msk   (0x1UL << DSI_WPTR_LPF3_Pos)
#define DSI_WPTR_LPF3   DSI_WPTR_LPF3_Msk
#define DSI_BCFGR_PWRUP_Pos   (6U)
#define DSI_BCFGR_PWRUP_Msk   (0x1UL << DSI_BCFGR_PWRUP_Pos)
#define DSI_BCFGR_PWRUP   DSI_BCFGR_PWRUP_Msk
#define DSI_DPCBCR_Pos   (3U)
#define DSI_DPCBCR_Msk   (0x1FUL << DSI_DPCBCR_Pos)
#define DSI_DPCBCR   DSI_DPCBCR_Msk
#define DSI_DPCBCR0_Pos   (3U)
#define DSI_DPCBCR0_Msk   (0x1UL << DSI_DPCBCR0_Pos)
#define DSI_DPCBCR0   DSI_DPCBCR0_Msk
#define DSI_DPCBCR1_Pos   (4U)
#define DSI_DPCBCR1_Msk   (0x1UL << DSI_DPCBCR1_Pos)
#define DSI_DPCBCR1   DSI_DPCBCR1_Msk
#define DSI_DPCBCR2_Pos   (5U)
#define DSI_DPCBCR2_Msk   (0x1UL << DSI_DPCBCR2_Pos)
#define DSI_DPCBCR2   DSI_DPCBCR2_Msk
#define DSI_DPCBCR3_Pos   (6U)
#define DSI_DPCBCR3_Msk   (0x1UL << DSI_DPCBCR3_Pos)
#define DSI_DPCBCR3   DSI_DPCBCR3_Msk
#define DSI_DPCBCR4_Pos   (7U)
#define DSI_DPCBCR4_Msk   (0x1UL << DSI_DPCBCR4_Pos)
#define DSI_DPCBCR4   DSI_DPCBCR4_Msk
#define DSI_DPCSRCR_Pos   (0U)
#define DSI_DPCSRCR_Msk   (0xFFUL << DSI_DPCSRCR_Pos)
#define DSI_DPCSRCR   DSI_DPCSRCR_Msk
#define DSI_DPCSRCR0_Pos   (0U)
#define DSI_DPCSRCR0_Msk   (0x1UL << DSI_DPCSRCR0_Pos)
#define DSI_DPCSRCR0   DSI_DPCSRCR0_Msk
#define DSI_DPCSRCR1_Pos   (1U)
#define DSI_DPCSRCR1_Msk   (0x1UL << DSI_DPCSRCR1_Pos)
#define DSI_DPCSRCR1   DSI_DPCSRCR1_Msk
#define DSI_DPCSRCR2_Pos   (2U)
#define DSI_DPCSRCR2_Msk   (0x1UL << DSI_DPCSRCR2_Pos)
#define DSI_DPCSRCR2   DSI_DPCSRCR2_Msk
#define DSI_DPCSRCR3_Pos   (3U)
#define DSI_DPCSRCR3_Msk   (0x1UL << DSI_DPCSRCR3_Pos)
#define DSI_DPCSRCR3   DSI_DPCSRCR3_Msk
#define DSI_DPCSRCR4_Pos   (4U)
#define DSI_DPCSRCR4_Msk   (0x1UL << DSI_DPCSRCR4_Pos)
#define DSI_DPCSRCR4   DSI_DPCSRCR4_Msk
#define DSI_DPCSRCR5_Pos   (5U)
#define DSI_DPCSRCR5_Msk   (0x1UL << DSI_DPCSRCR5_Pos)
#define DSI_DPCSRCR5   DSI_DPCSRCR5_Msk
#define DSI_DPCSRCR6_Pos   (6U)
#define DSI_DPCSRCR6_Msk   (0x1UL << DSI_DPCSRCR6_Pos)
#define DSI_DPCSRCR6   DSI_DPCSRCR6_Msk
#define DSI_DPCSRCR7_Pos   (7U)
#define DSI_DPCSRCR7_Msk   (0x1UL << DSI_DPCSRCR7_Pos)
#define DSI_DPCSRCR7   DSI_DPCSRCR7_Msk
#define DSI_DPDL0HSOCR_Pos   (4U)
#define DSI_DPDL0HSOCR_Msk   (0xFUL << DSI_DPDL0HSOCR_Pos)
#define DSI_DPDL0HSOCR   DSI_DPDL0HSOCR_Msk
#define DSI_DPDL0HSOCR_HSPRPO0_Pos   (4U)
#define DSI_DPDL0HSOCR_HSPRPO0_Msk   (0x1UL << DSI_DPDL0HSOCR_HSPRPO0_Pos)
#define DSI_DPDL0HSOCR_HSPRPO0   DSI_DPDL0HSOCR_HSPRPO0_Msk
#define DSI_DPDL0HSOCR_HSPRPO1_Pos   (5U)
#define DSI_DPDL0HSOCR_HSPRPO1_Msk   (0x1UL << DSI_DPDL0HSOCR_HSPRPO1_Pos)
#define DSI_DPDL0HSOCR_HSPRPO1   DSI_DPDL0HSOCR_HSPRPO1_Msk
#define DSI_DPDL0HSOCR_HSPRPO2_Pos   (6U)
#define DSI_DPDL0HSOCR_HSPRPO2_Msk   (0x1UL << DSI_DPDL0HSOCR_HSPRPO2_Pos)
#define DSI_DPDL0HSOCR_HSPRPO2   DSI_DPDL0HSOCR_HSPRPO2_Msk
#define DSI_DPDL0HSOCR_HSPRPO3_Pos   (7U)
#define DSI_DPDL0HSOCR_HSPRPO3_Msk   (0x1UL << DSI_DPDL0HSOCR_HSPRPO3_Pos)
#define DSI_DPDL0HSOCR_HSPRPO3   DSI_DPDL0HSOCR_HSPRPO3_Msk
#define DSI_DPDL0LPXOCR_Pos   (0U)
#define DSI_DPDL0LPXOCR_Msk   (0xFUL << DSI_DPDL0LPXOCR_Pos)
#define DSI_DPDL0LPXOCR   DSI_DPDL0LPXOCR_Msk
#define DSI_DPDL0LPXOCR_LPXO0_Pos   (0U)
#define DSI_DPDL0LPXOCR_LPXO0_Msk   (0x1UL << DSI_DPDL0LPXOCR_LPXO0_Pos)
#define DSI_DPDL0LPXOCR_LPXO0   DSI_DPDL0LPXOCR_LPXO0_Msk
#define DSI_DPDL0LPXOCR_LPXO1_Pos   (1U)
#define DSI_DPDL0LPXOCR_LPXO1_Msk   (0x1UL << DSI_DPDL0LPXOCR_LPXO1_Pos)
#define DSI_DPDL0LPXOCR_LPXO1   DSI_DPDL0LPXOCR_LPXO1_Msk
#define DSI_DPDL0LPXOCR_LPXO2_Pos   (2U)
#define DSI_DPDL0LPXOCR_LPXO2_Msk   (0x1UL << DSI_DPDL0LPXOCR_LPXO2_Pos)
#define DSI_DPDL0LPXOCR_LPXO2   DSI_DPDL0LPXOCR_LPXO2_Msk
#define DSI_DPDL0LPXOCR_LPXO3_Pos   (3U)
#define DSI_DPDL0LPXOCR_LPXO3_Msk   (0x1UL << DSI_DPDL0LPXOCR_LPXO3_Pos)
#define DSI_DPDL0LPXOCR_LPXO3   DSI_DPDL0LPXOCR_LPXO3_Msk
#define DSI_DPDL0BCR_Pos   (0U)
#define DSI_DPDL0BCR_Msk   (0x1FUL << DSI_DPDL0BCR_Pos)
#define DSI_DPDL0BCR   DSI_DPDL0BCR_Msk
#define DSI_DPDL0BCR0_Pos   (0U)
#define DSI_DPDL0BCR0_Msk   (0x1UL << DSI_DPDL0BCR0_Pos)
#define DSI_DPDL0BCR0   DSI_DPDL0BCR0_Msk
#define DSI_DPDL0BCR1_Pos   (1U)
#define DSI_DPDL0BCR1_Msk   (0x1UL << DSI_DPDL0BCR1_Pos)
#define DSI_DPDL0BCR1   DSI_DPDL0BCR1_Msk
#define DSI_DPDL0BCR2_Pos   (2U)
#define DSI_DPDL0BCR2_Msk   (0x1UL << DSI_DPDL0BCR2_Pos)
#define DSI_DPDL0BCR2   DSI_DPDL0BCR2_Msk
#define DSI_DPDL0BCR3_Pos   (3U)
#define DSI_DPDL0BCR3_Msk   (0x1UL << DSI_DPDL0BCR3_Pos)
#define DSI_DPDL0BCR3   DSI_DPDL0BCR3_Msk
#define DSI_DPDL0BCR4_Pos   (4U)
#define DSI_DPDL0BCR4_Msk   (0x1UL << DSI_DPDL0BCR4_Pos)
#define DSI_DPDL0BCR4   DSI_DPDL0BCR4_Msk
#define DSI_DPDL0SRCR_Pos   (0U)
#define DSI_DPDL0SRCR_Msk   (0xFFUL << DSI_DPDL0SRCR_Pos)
#define DSI_DPDL0SRCR   DSI_DPDL0SRCR_Msk
#define DSI_DPDL0SRCR0_Pos   (0U)
#define DSI_DPDL0SRCR0_Msk   (0x1UL << DSI_DPDL0SRCR0_Pos)
#define DSI_DPDL0SRCR0   DSI_DPDL0SRCR0_Msk
#define DSI_DPDL0SRCR1_Pos   (1U)
#define DSI_DPDL0SRCR1_Msk   (0x1UL << DSI_DPDL0SRCR1_Pos)
#define DSI_DPDL0SRCR1   DSI_DPDL0SRCR1_Msk
#define DSI_DPDL0SRCR2_Pos   (2U)
#define DSI_DPDL0SRCR2_Msk   (0x1UL << DSI_DPDL0SRCR2_Pos)
#define DSI_DPDL0SRCR2   DSI_DPDL0SRCR2_Msk
#define DSI_DPDL0SRCR3_Pos   (3U)
#define DSI_DPDL0SRCR3_Msk   (0x1UL << DSI_DPDL0SRCR3_Pos)
#define DSI_DPDL0SRCR3   DSI_DPDL0SRCR3_Msk
#define DSI_DPDL0SRCR4_Pos   (4U)
#define DSI_DPDL0SRCR4_Msk   (0x1UL << DSI_DPDL0SRCR4_Pos)
#define DSI_DPDL0SRCR4   DSI_DPDL0SRCR4_Msk
#define DSI_DPDL0SRCR5_Pos   (5U)
#define DSI_DPDL0SRCR5_Msk   (0x1UL << DSI_DPDL0SRCR5_Pos)
#define DSI_DPDL0SRCR5   DSI_DPDL0SRCR5_Msk
#define DSI_DPDL0SRCR6_Pos   (6U)
#define DSI_DPDL0SRCR6_Msk   (0x1UL << DSI_DPDL0SRCR6_Pos)
#define DSI_DPDL0SRCR6   DSI_DPDL0SRCR6_Msk
#define DSI_DPDL0SRCR7_Pos   (7U)
#define DSI_DPDL0SRCR7_Msk   (0x1UL << DSI_DPDL0SRCR7_Pos)
#define DSI_DPDL0SRCR7   DSI_DPDL0SRCR7_Msk
#define DSI_DPDL1HSOCR_Pos   (4U)
#define DSI_DPDL1HSOCR_Msk   (0xFUL << DSI_DPDL1HSOCR_Pos)
#define DSI_DPDL1HSOCR   DSI_DPDL1HSOCR_Msk
#define DSI_DPDL1HSOCR_HSPRPO00_Pos   (4U)
#define DSI_DPDL1HSOCR_HSPRPO00_Msk   (0x1UL << DSI_DPDL1HSOCR_HSPRPO00_Pos)
#define DSI_DPDL1HSOCR_HSPRPO00   DSI_DPDL1HSOCR_HSPRPO00_Msk
#define DSI_DPDL1HSOCR_HSPRPO01_Pos   (5U)
#define DSI_DPDL1HSOCR_HSPRPO01_Msk   (0x1UL << DSI_DPDL1HSOCR_HSPRPO01_Pos)
#define DSI_DPDL1HSOCR_HSPRPO01   DSI_DPDL1HSOCR_HSPRPO01_Msk
#define DSI_DPDL1HSOCR_HSPRPO02_Pos   (6U)
#define DSI_DPDL1HSOCR_HSPRPO02_Msk   (0x1UL << DSI_DPDL1HSOCR_HSPRPO02_Pos)
#define DSI_DPDL1HSOCR_HSPRPO02   DSI_DPDL1HSOCR_HSPRPO02_Msk
#define DSI_DPDL1HSOCR_HSPRPO03_Pos   (7U)
#define DSI_DPDL1HSOCR_HSPRPO03_Msk   (0x1UL << DSI_DPDL1HSOCR_HSPRPO03_Pos)
#define DSI_DPDL1HSOCR_HSPRPO03   DSI_DPDL1HSOCR_HSPRPO03_Msk
#define DSI_DPDL1LPXOCR_Pos   (0U)
#define DSI_DPDL1LPXOCR_Msk   (0xFUL << DSI_DPDL1LPXOCR_Pos)
#define DSI_DPDL1LPXOCR   DSI_DPDL1LPXOCR_Msk
#define DSI_DPDL1LPXOCR_LPXO0_Pos   (0U)
#define DSI_DPDL1LPXOCR_LPXO0_Msk   (0x1UL << DSI_DPDL1LPXOCR_LPXO0_Pos)
#define DSI_DPDL1LPXOCR_LPXO0   DSI_DPDL1LPXOCR_LPXO0_Msk
#define DSI_DPDL1LPXOCR_LPXO1_Pos   (1U)
#define DSI_DPDL1LPXOCR_LPXO1_Msk   (0x1UL << DSI_DPDL1LPXOCR_LPXO1_Pos)
#define DSI_DPDL1LPXOCR_LPXO1   DSI_DPDL1LPXOCR_LPXO1_Msk
#define DSI_DPDL1LPXOCR_LPXO2_Pos   (2U)
#define DSI_DPDL1LPXOCR_LPXO2_Msk   (0x1UL << DSI_DPDL1LPXOCR_LPXO2_Pos)
#define DSI_DPDL1LPXOCR_LPXO2   DSI_DPDL1LPXOCR_LPXO2_Msk
#define DSI_DPDL1LPXOCR_LPXO3_Pos   (3U)
#define DSI_DPDL1LPXOCR_LPXO3_Msk   (0x1UL << DSI_DPDL1LPXOCR_LPXO3_Pos)
#define DSI_DPDL1LPXOCR_LPXO3   DSI_DPDL1LPXOCR_LPXO3_Msk
#define DSI_DPDL1BCR_Pos   (0U)
#define DSI_DPDL1BCR_Msk   (0x1FUL << DSI_DPDL1BCR_Pos)
#define DSI_DPDL1BCR   DSI_DPDL1BCR_Msk
#define DSI_DPDL1BCR0_Pos   (0U)
#define DSI_DPDL1BCR0_Msk   (0x1UL << DSI_DPDL1BCR0_Pos)
#define DSI_DPDL1BCR0   DSI_DPDL1BCR0_Msk
#define DSI_DPDL1BCR1_Pos   (1U)
#define DSI_DPDL1BCR1_Msk   (0x1UL << DSI_DPDL1BCR1_Pos)
#define DSI_DPDL1BCR1   DSI_DPDL1BCR1_Msk
#define DSI_DPDL1BCR2_Pos   (2U)
#define DSI_DPDL1BCR2_Msk   (0x1UL << DSI_DPDL1BCR2_Pos)
#define DSI_DPDL1BCR2   DSI_DPDL1BCR2_Msk
#define DSI_DPDL1BCR3_Pos   (3U)
#define DSI_DPDL1BCR3_Msk   (0x1UL << DSI_DPDL1BCR3_Pos)
#define DSI_DPDL1BCR3   DSI_DPDL1BCR3_Msk
#define DSI_DPDL1BCR4_Pos   (4U)
#define DSI_DPDL1BCR4_Msk   (0x1UL << DSI_DPDL1BCR4_Pos)
#define DSI_DPDL1BCR4   DSI_DPDL1BCR4_Msk
#define DSI_DPDL1SRCR_Pos   (0U)
#define DSI_DPDL1SRCR_Msk   (0xFFUL << DSI_DPDL1SRCR_Pos)
#define DSI_DPDL1SRCR   DSI_DPDL1SRCR_Msk
#define DSI_DPDL1SRCR0_Pos   (0U)
#define DSI_DPDL1SRCR0_Msk   (0x1UL << DSI_DPDL1SRCR0_Pos)
#define DSI_DPDL1SRCR0   DSI_DPDL1SRCR0_Msk
#define DSI_DPDL1SRCR1_Pos   (1U)
#define DSI_DPDL1SRCR1_Msk   (0x1UL << DSI_DPDL1SRCR1_Pos)
#define DSI_DPDL1SRCR1   DSI_DPDL1SRCR1_Msk
#define DSI_DPDL1SRCR2_Pos   (2U)
#define DSI_DPDL1SRCR2_Msk   (0x1UL << DSI_DPDL1SRCR2_Pos)
#define DSI_DPDL1SRCR2   DSI_DPDL1SRCR2_Msk
#define DSI_DPDL1SRCR3_Pos   (3U)
#define DSI_DPDL1SRCR3_Msk   (0x1UL << DSI_DPDL1SRCR3_Pos)
#define DSI_DPDL1SRCR3   DSI_DPDL1SRCR3_Msk
#define DSI_DPDL1SRCR4_Pos   (4U)
#define DSI_DPDL1SRCR4_Msk   (0x1UL << DSI_DPDL1SRCR4_Pos)
#define DSI_DPDL1SRCR4   DSI_DPDL1SRCR4_Msk
#define DSI_DPDL1SRCR5_Pos   (5U)
#define DSI_DPDL1SRCR5_Msk   (0x1UL << DSI_DPDL1SRCR5_Pos)
#define DSI_DPDL1SRCR5   DSI_DPDL1SRCR5_Msk
#define DSI_DPDL1SRCR6_Pos   (6U)
#define DSI_DPDL1SRCR6_Msk   (0x1UL << DSI_DPDL1SRCR6_Pos)
#define DSI_DPDL1SRCR6   DSI_DPDL1SRCR6_Msk
#define DSI_DPDL1SRCR7_Pos   (7U)
#define DSI_DPDL1SRCR7_Msk   (0x1UL << DSI_DPDL1SRCR7_Pos)
#define DSI_DPDL1SRCR7   DSI_DPDL1SRCR7_Msk
#define EXTI_RTSR1_RT0_Pos   (0U)
#define EXTI_RTSR1_RT0_Msk   (0x1UL << EXTI_RTSR1_RT0_Pos)
#define EXTI_RTSR1_RT0   EXTI_RTSR1_RT0_Msk
#define EXTI_RTSR1_RT1_Pos   (1U)
#define EXTI_RTSR1_RT1_Msk   (0x1UL << EXTI_RTSR1_RT1_Pos)
#define EXTI_RTSR1_RT1   EXTI_RTSR1_RT1_Msk
#define EXTI_RTSR1_RT2_Pos   (2U)
#define EXTI_RTSR1_RT2_Msk   (0x1UL << EXTI_RTSR1_RT2_Pos)
#define EXTI_RTSR1_RT2   EXTI_RTSR1_RT2_Msk
#define EXTI_RTSR1_RT3_Pos   (3U)
#define EXTI_RTSR1_RT3_Msk   (0x1UL << EXTI_RTSR1_RT3_Pos)
#define EXTI_RTSR1_RT3   EXTI_RTSR1_RT3_Msk
#define EXTI_RTSR1_RT4_Pos   (4U)
#define EXTI_RTSR1_RT4_Msk   (0x1UL << EXTI_RTSR1_RT4_Pos)
#define EXTI_RTSR1_RT4   EXTI_RTSR1_RT4_Msk
#define EXTI_RTSR1_RT5_Pos   (5U)
#define EXTI_RTSR1_RT5_Msk   (0x1UL << EXTI_RTSR1_RT5_Pos)
#define EXTI_RTSR1_RT5   EXTI_RTSR1_RT5_Msk
#define EXTI_RTSR1_RT6_Pos   (6U)
#define EXTI_RTSR1_RT6_Msk   (0x1UL << EXTI_RTSR1_RT6_Pos)
#define EXTI_RTSR1_RT6   EXTI_RTSR1_RT6_Msk
#define EXTI_RTSR1_RT7_Pos   (7U)
#define EXTI_RTSR1_RT7_Msk   (0x1UL << EXTI_RTSR1_RT7_Pos)
#define EXTI_RTSR1_RT7   EXTI_RTSR1_RT7_Msk
#define EXTI_RTSR1_RT8_Pos   (8U)
#define EXTI_RTSR1_RT8_Msk   (0x1UL << EXTI_RTSR1_RT8_Pos)
#define EXTI_RTSR1_RT8   EXTI_RTSR1_RT8_Msk
#define EXTI_RTSR1_RT9_Pos   (9U)
#define EXTI_RTSR1_RT9_Msk   (0x1UL << EXTI_RTSR1_RT9_Pos)
#define EXTI_RTSR1_RT9   EXTI_RTSR1_RT9_Msk
#define EXTI_RTSR1_RT10_Pos   (10U)
#define EXTI_RTSR1_RT10_Msk   (0x1UL << EXTI_RTSR1_RT10_Pos)
#define EXTI_RTSR1_RT10   EXTI_RTSR1_RT10_Msk
#define EXTI_RTSR1_RT11_Pos   (11U)
#define EXTI_RTSR1_RT11_Msk   (0x1UL << EXTI_RTSR1_RT11_Pos)
#define EXTI_RTSR1_RT11   EXTI_RTSR1_RT11_Msk
#define EXTI_RTSR1_RT12_Pos   (12U)
#define EXTI_RTSR1_RT12_Msk   (0x1UL << EXTI_RTSR1_RT12_Pos)
#define EXTI_RTSR1_RT12   EXTI_RTSR1_RT12_Msk
#define EXTI_RTSR1_RT13_Pos   (13U)
#define EXTI_RTSR1_RT13_Msk   (0x1UL << EXTI_RTSR1_RT13_Pos)
#define EXTI_RTSR1_RT13   EXTI_RTSR1_RT13_Msk
#define EXTI_RTSR1_RT14_Pos   (14U)
#define EXTI_RTSR1_RT14_Msk   (0x1UL << EXTI_RTSR1_RT14_Pos)
#define EXTI_RTSR1_RT14   EXTI_RTSR1_RT14_Msk
#define EXTI_RTSR1_RT15_Pos   (15U)
#define EXTI_RTSR1_RT15_Msk   (0x1UL << EXTI_RTSR1_RT15_Pos)
#define EXTI_RTSR1_RT15   EXTI_RTSR1_RT15_Msk
#define EXTI_RTSR1_RT16_Pos   (16U)
#define EXTI_RTSR1_RT16_Msk   (0x1UL << EXTI_RTSR1_RT16_Pos)
#define EXTI_RTSR1_RT16   EXTI_RTSR1_RT16_Msk
#define EXTI_RTSR1_RT17_Pos   (17U)
#define EXTI_RTSR1_RT17_Msk   (0x1UL << EXTI_RTSR1_RT17_Pos)
#define EXTI_RTSR1_RT17   EXTI_RTSR1_RT17_Msk
#define EXTI_RTSR1_RT18_Pos   (18U)
#define EXTI_RTSR1_RT18_Msk   (0x1UL << EXTI_RTSR1_RT18_Pos)
#define EXTI_RTSR1_RT18   EXTI_RTSR1_RT18_Msk
#define EXTI_RTSR1_RT19_Pos   (19U)
#define EXTI_RTSR1_RT19_Msk   (0x1UL << EXTI_RTSR1_RT19_Pos)
#define EXTI_RTSR1_RT19   EXTI_RTSR1_RT19_Msk
#define EXTI_RTSR1_RT20_Pos   (20U)
#define EXTI_RTSR1_RT20_Msk   (0x1UL << EXTI_RTSR1_RT20_Pos)
#define EXTI_RTSR1_RT20   EXTI_RTSR1_RT20_Msk
#define EXTI_RTSR1_RT21_Pos   (21U)
#define EXTI_RTSR1_RT21_Msk   (0x1UL << EXTI_RTSR1_RT21_Pos)
#define EXTI_RTSR1_RT21   EXTI_RTSR1_RT21_Msk
#define EXTI_RTSR1_RT22_Pos   (22U)
#define EXTI_RTSR1_RT22_Msk   (0x1UL << EXTI_RTSR1_RT22_Pos)
#define EXTI_RTSR1_RT22   EXTI_RTSR1_RT22_Msk
#define EXTI_RTSR1_RT23_Pos   (23U)
#define EXTI_RTSR1_RT23_Msk   (0x1UL << EXTI_RTSR1_RT23_Pos)
#define EXTI_RTSR1_RT23   EXTI_RTSR1_RT23_Msk
#define EXTI_RTSR1_RT24_Pos   (24U)
#define EXTI_RTSR1_RT24_Msk   (0x1UL << EXTI_RTSR1_RT24_Pos)
#define EXTI_RTSR1_RT24   EXTI_RTSR1_RT24_Msk
#define EXTI_RTSR1_RT25_Pos   (25U)
#define EXTI_RTSR1_RT25_Msk   (0x1UL << EXTI_RTSR1_RT25_Pos)
#define EXTI_RTSR1_RT25   EXTI_RTSR1_RT25_Msk
#define EXTI_FTSR1_FT0_Pos   (0U)
#define EXTI_FTSR1_FT0_Msk   (0x1UL << EXTI_FTSR1_FT0_Pos)
#define EXTI_FTSR1_FT0   EXTI_FTSR1_FT0_Msk
#define EXTI_FTSR1_FT1_Pos   (1U)
#define EXTI_FTSR1_FT1_Msk   (0x1UL << EXTI_FTSR1_FT1_Pos)
#define EXTI_FTSR1_FT1   EXTI_FTSR1_FT1_Msk
#define EXTI_FTSR1_FT2_Pos   (2U)
#define EXTI_FTSR1_FT2_Msk   (0x1UL << EXTI_FTSR1_FT2_Pos)
#define EXTI_FTSR1_FT2   EXTI_FTSR1_FT2_Msk
#define EXTI_FTSR1_FT3_Pos   (3U)
#define EXTI_FTSR1_FT3_Msk   (0x1UL << EXTI_FTSR1_FT3_Pos)
#define EXTI_FTSR1_FT3   EXTI_FTSR1_FT3_Msk
#define EXTI_FTSR1_FT4_Pos   (4U)
#define EXTI_FTSR1_FT4_Msk   (0x1UL << EXTI_FTSR1_FT4_Pos)
#define EXTI_FTSR1_FT4   EXTI_FTSR1_FT4_Msk
#define EXTI_FTSR1_FT5_Pos   (5U)
#define EXTI_FTSR1_FT5_Msk   (0x1UL << EXTI_FTSR1_FT5_Pos)
#define EXTI_FTSR1_FT5   EXTI_FTSR1_FT5_Msk
#define EXTI_FTSR1_FT6_Pos   (6U)
#define EXTI_FTSR1_FT6_Msk   (0x1UL << EXTI_FTSR1_FT6_Pos)
#define EXTI_FTSR1_FT6   EXTI_FTSR1_FT6_Msk
#define EXTI_FTSR1_FT7_Pos   (7U)
#define EXTI_FTSR1_FT7_Msk   (0x1UL << EXTI_FTSR1_FT7_Pos)
#define EXTI_FTSR1_FT7   EXTI_FTSR1_FT7_Msk
#define EXTI_FTSR1_FT8_Pos   (8U)
#define EXTI_FTSR1_FT8_Msk   (0x1UL << EXTI_FTSR1_FT8_Pos)
#define EXTI_FTSR1_FT8   EXTI_FTSR1_FT8_Msk
#define EXTI_FTSR1_FT9_Pos   (9U)
#define EXTI_FTSR1_FT9_Msk   (0x1UL << EXTI_FTSR1_FT9_Pos)
#define EXTI_FTSR1_FT9   EXTI_FTSR1_FT9_Msk
#define EXTI_FTSR1_FT10_Pos   (10U)
#define EXTI_FTSR1_FT10_Msk   (0x1UL << EXTI_FTSR1_FT10_Pos)
#define EXTI_FTSR1_FT10   EXTI_FTSR1_FT10_Msk
#define EXTI_FTSR1_FT11_Pos   (11U)
#define EXTI_FTSR1_FT11_Msk   (0x1UL << EXTI_FTSR1_FT11_Pos)
#define EXTI_FTSR1_FT11   EXTI_FTSR1_FT11_Msk
#define EXTI_FTSR1_FT12_Pos   (12U)
#define EXTI_FTSR1_FT12_Msk   (0x1UL << EXTI_FTSR1_FT12_Pos)
#define EXTI_FTSR1_FT12   EXTI_FTSR1_FT12_Msk
#define EXTI_FTSR1_FT13_Pos   (13U)
#define EXTI_FTSR1_FT13_Msk   (0x1UL << EXTI_FTSR1_FT13_Pos)
#define EXTI_FTSR1_FT13   EXTI_FTSR1_FT13_Msk
#define EXTI_FTSR1_FT14_Pos   (14U)
#define EXTI_FTSR1_FT14_Msk   (0x1UL << EXTI_FTSR1_FT14_Pos)
#define EXTI_FTSR1_FT14   EXTI_FTSR1_FT14_Msk
#define EXTI_FTSR1_FT15_Pos   (15U)
#define EXTI_FTSR1_FT15_Msk   (0x1UL << EXTI_FTSR1_FT15_Pos)
#define EXTI_FTSR1_FT15   EXTI_FTSR1_FT15_Msk
#define EXTI_FTSR1_FT16_Pos   (16U)
#define EXTI_FTSR1_FT16_Msk   (0x1UL << EXTI_FTSR1_FT16_Pos)
#define EXTI_FTSR1_FT16   EXTI_FTSR1_FT16_Msk
#define EXTI_FTSR1_FT17_Pos   (17U)
#define EXTI_FTSR1_FT17_Msk   (0x1UL << EXTI_FTSR1_FT17_Pos)
#define EXTI_FTSR1_FT17   EXTI_FTSR1_FT17_Msk
#define EXTI_FTSR1_FT18_Pos   (18U)
#define EXTI_FTSR1_FT18_Msk   (0x1UL << EXTI_FTSR1_FT18_Pos)
#define EXTI_FTSR1_FT18   EXTI_FTSR1_FT18_Msk
#define EXTI_FTSR1_FT19_Pos   (19U)
#define EXTI_FTSR1_FT19_Msk   (0x1UL << EXTI_FTSR1_FT19_Pos)
#define EXTI_FTSR1_FT19   EXTI_FTSR1_FT19_Msk
#define EXTI_FTSR1_FT20_Pos   (20U)
#define EXTI_FTSR1_FT20_Msk   (0x1UL << EXTI_FTSR1_FT20_Pos)
#define EXTI_FTSR1_FT20   EXTI_FTSR1_FT20_Msk
#define EXTI_FTSR1_FT21_Pos   (21U)
#define EXTI_FTSR1_FT21_Msk   (0x1UL << EXTI_FTSR1_FT21_Pos)
#define EXTI_FTSR1_FT21   EXTI_FTSR1_FT21_Msk
#define EXTI_FTSR1_FT22_Pos   (22U)
#define EXTI_FTSR1_FT22_Msk   (0x1UL << EXTI_FTSR1_FT22_Pos)
#define EXTI_FTSR1_FT22   EXTI_FTSR1_FT22_Msk
#define EXTI_FTSR1_FT23_Pos   (23U)
#define EXTI_FTSR1_FT23_Msk   (0x1UL << EXTI_FTSR1_FT23_Pos)
#define EXTI_FTSR1_FT23   EXTI_FTSR1_FT23_Msk
#define EXTI_FTSR1_FT24_Pos   (24U)
#define EXTI_FTSR1_FT24_Msk   (0x1UL << EXTI_FTSR1_FT24_Pos)
#define EXTI_FTSR1_FT24   EXTI_FTSR1_FT24_Msk
#define EXTI_FTSR1_FT25_Pos   (25U)
#define EXTI_FTSR1_FT25_Msk   (0x1UL << EXTI_FTSR1_FT25_Pos)
#define EXTI_FTSR1_FT25   EXTI_FTSR1_FT25_Msk
#define EXTI_SWIER1_SWI0_Pos   (0U)
#define EXTI_SWIER1_SWI0_Msk   (0x1UL << EXTI_SWIER1_SWI0_Pos)
#define EXTI_SWIER1_SWI0   EXTI_SWIER1_SWI0_Msk
#define EXTI_SWIER1_SWI1_Pos   (1U)
#define EXTI_SWIER1_SWI1_Msk   (0x1UL << EXTI_SWIER1_SWI1_Pos)
#define EXTI_SWIER1_SWI1   EXTI_SWIER1_SWI1_Msk
#define EXTI_SWIER1_SWI2_Pos   (2U)
#define EXTI_SWIER1_SWI2_Msk   (0x1UL << EXTI_SWIER1_SWI2_Pos)
#define EXTI_SWIER1_SWI2   EXTI_SWIER1_SWI2_Msk
#define EXTI_SWIER1_SWI3_Pos   (3U)
#define EXTI_SWIER1_SWI3_Msk   (0x1UL << EXTI_SWIER1_SWI3_Pos)
#define EXTI_SWIER1_SWI3   EXTI_SWIER1_SWI3_Msk
#define EXTI_SWIER1_SWI4_Pos   (4U)
#define EXTI_SWIER1_SWI4_Msk   (0x1UL << EXTI_SWIER1_SWI4_Pos)
#define EXTI_SWIER1_SWI4   EXTI_SWIER1_SWI4_Msk
#define EXTI_SWIER1_SWI5_Pos   (5U)
#define EXTI_SWIER1_SWI5_Msk   (0x1UL << EXTI_SWIER1_SWI5_Pos)
#define EXTI_SWIER1_SWI5   EXTI_SWIER1_SWI5_Msk
#define EXTI_SWIER1_SWI6_Pos   (6U)
#define EXTI_SWIER1_SWI6_Msk   (0x1UL << EXTI_SWIER1_SWI6_Pos)
#define EXTI_SWIER1_SWI6   EXTI_SWIER1_SWI6_Msk
#define EXTI_SWIER1_SWI7_Pos   (7U)
#define EXTI_SWIER1_SWI7_Msk   (0x1UL << EXTI_SWIER1_SWI7_Pos)
#define EXTI_SWIER1_SWI7   EXTI_SWIER1_SWI7_Msk
#define EXTI_SWIER1_SWI8_Pos   (8U)
#define EXTI_SWIER1_SWI8_Msk   (0x1UL << EXTI_SWIER1_SWI8_Pos)
#define EXTI_SWIER1_SWI8   EXTI_SWIER1_SWI8_Msk
#define EXTI_SWIER1_SWI9_Pos   (9U)
#define EXTI_SWIER1_SWI9_Msk   (0x1UL << EXTI_SWIER1_SWI9_Pos)
#define EXTI_SWIER1_SWI9   EXTI_SWIER1_SWI9_Msk
#define EXTI_SWIER1_SWI10_Pos   (10U)
#define EXTI_SWIER1_SWI10_Msk   (0x1UL << EXTI_SWIER1_SWI10_Pos)
#define EXTI_SWIER1_SWI10   EXTI_SWIER1_SWI10_Msk
#define EXTI_SWIER1_SWI11_Pos   (11U)
#define EXTI_SWIER1_SWI11_Msk   (0x1UL << EXTI_SWIER1_SWI11_Pos)
#define EXTI_SWIER1_SWI11   EXTI_SWIER1_SWI11_Msk
#define EXTI_SWIER1_SWI12_Pos   (12U)
#define EXTI_SWIER1_SWI12_Msk   (0x1UL << EXTI_SWIER1_SWI12_Pos)
#define EXTI_SWIER1_SWI12   EXTI_SWIER1_SWI12_Msk
#define EXTI_SWIER1_SWI13_Pos   (13U)
#define EXTI_SWIER1_SWI13_Msk   (0x1UL << EXTI_SWIER1_SWI13_Pos)
#define EXTI_SWIER1_SWI13   EXTI_SWIER1_SWI13_Msk
#define EXTI_SWIER1_SWI14_Pos   (14U)
#define EXTI_SWIER1_SWI14_Msk   (0x1UL << EXTI_SWIER1_SWI14_Pos)
#define EXTI_SWIER1_SWI14   EXTI_SWIER1_SWI14_Msk
#define EXTI_SWIER1_SWI15_Pos   (15U)
#define EXTI_SWIER1_SWI15_Msk   (0x1UL << EXTI_SWIER1_SWI15_Pos)
#define EXTI_SWIER1_SWI15   EXTI_SWIER1_SWI15_Msk
#define EXTI_SWIER1_SWI16_Pos   (16U)
#define EXTI_SWIER1_SWI16_Msk   (0x1UL << EXTI_SWIER1_SWI16_Pos)
#define EXTI_SWIER1_SWI16   EXTI_SWIER1_SWI16_Msk
#define EXTI_SWIER1_SWI17_Pos   (17U)
#define EXTI_SWIER1_SWI17_Msk   (0x1UL << EXTI_SWIER1_SWI17_Pos)
#define EXTI_SWIER1_SWI17   EXTI_SWIER1_SWI17_Msk
#define EXTI_SWIER1_SWI18_Pos   (18U)
#define EXTI_SWIER1_SWI18_Msk   (0x1UL << EXTI_SWIER1_SWI18_Pos)
#define EXTI_SWIER1_SWI18   EXTI_SWIER1_SWI18_Msk
#define EXTI_SWIER1_SWI19_Pos   (19U)
#define EXTI_SWIER1_SWI19_Msk   (0x1UL << EXTI_SWIER1_SWI19_Pos)
#define EXTI_SWIER1_SWI19   EXTI_SWIER1_SWI19_Msk
#define EXTI_SWIER1_SWI20_Pos   (20U)
#define EXTI_SWIER1_SWI20_Msk   (0x1UL << EXTI_SWIER1_SWI20_Pos)
#define EXTI_SWIER1_SWI20   EXTI_SWIER1_SWI20_Msk
#define EXTI_SWIER1_SWI21_Pos   (21U)
#define EXTI_SWIER1_SWI21_Msk   (0x1UL << EXTI_SWIER1_SWI21_Pos)
#define EXTI_SWIER1_SWI21   EXTI_SWIER1_SWI21_Msk
#define EXTI_SWIER1_SWI22_Pos   (22U)
#define EXTI_SWIER1_SWI22_Msk   (0x1UL << EXTI_SWIER1_SWI22_Pos)
#define EXTI_SWIER1_SWI22   EXTI_SWIER1_SWI22_Msk
#define EXTI_SWIER1_SWI23_Pos   (23U)
#define EXTI_SWIER1_SWI23_Msk   (0x1UL << EXTI_SWIER1_SWI23_Pos)
#define EXTI_SWIER1_SWI23   EXTI_SWIER1_SWI23_Msk
#define EXTI_SWIER1_SWI24_Pos   (24U)
#define EXTI_SWIER1_SWI24_Msk   (0x1UL << EXTI_SWIER1_SWI24_Pos)
#define EXTI_SWIER1_SWI24   EXTI_SWIER1_SWI24_Msk
#define EXTI_SWIER1_SWI25_Pos   (25U)
#define EXTI_SWIER1_SWI25_Msk   (0x1UL << EXTI_SWIER1_SWI25_Pos)
#define EXTI_SWIER1_SWI25   EXTI_SWIER1_SWI25_Msk
#define EXTI_RPR1_RPIF0_Pos   (0U)
#define EXTI_RPR1_RPIF0_Msk   (0x1UL << EXTI_RPR1_RPIF0_Pos)
#define EXTI_RPR1_RPIF0   EXTI_RPR1_RPIF0_Msk
#define EXTI_RPR1_RPIF1_Pos   (1U)
#define EXTI_RPR1_RPIF1_Msk   (0x1UL << EXTI_RPR1_RPIF1_Pos)
#define EXTI_RPR1_RPIF1   EXTI_RPR1_RPIF1_Msk
#define EXTI_RPR1_RPIF2_Pos   (2U)
#define EXTI_RPR1_RPIF2_Msk   (0x1UL << EXTI_RPR1_RPIF2_Pos)
#define EXTI_RPR1_RPIF2   EXTI_RPR1_RPIF2_Msk
#define EXTI_RPR1_RPIF3_Pos   (3U)
#define EXTI_RPR1_RPIF3_Msk   (0x1UL << EXTI_RPR1_RPIF3_Pos)
#define EXTI_RPR1_RPIF3   EXTI_RPR1_RPIF3_Msk
#define EXTI_RPR1_RPIF4_Pos   (4U)
#define EXTI_RPR1_RPIF4_Msk   (0x1UL << EXTI_RPR1_RPIF4_Pos)
#define EXTI_RPR1_RPIF4   EXTI_RPR1_RPIF4_Msk
#define EXTI_RPR1_RPIF5_Pos   (5U)
#define EXTI_RPR1_RPIF5_Msk   (0x1UL << EXTI_RPR1_RPIF5_Pos)
#define EXTI_RPR1_RPIF5   EXTI_RPR1_RPIF5_Msk
#define EXTI_RPR1_RPIF6_Pos   (6U)
#define EXTI_RPR1_RPIF6_Msk   (0x1UL << EXTI_RPR1_RPIF6_Pos)
#define EXTI_RPR1_RPIF6   EXTI_RPR1_RPIF6_Msk
#define EXTI_RPR1_RPIF7_Pos   (7U)
#define EXTI_RPR1_RPIF7_Msk   (0x1UL << EXTI_RPR1_RPIF7_Pos)
#define EXTI_RPR1_RPIF7   EXTI_RPR1_RPIF7_Msk
#define EXTI_RPR1_RPIF8_Pos   (8U)
#define EXTI_RPR1_RPIF8_Msk   (0x1UL << EXTI_RPR1_RPIF8_Pos)
#define EXTI_RPR1_RPIF8   EXTI_RPR1_RPIF8_Msk
#define EXTI_RPR1_RPIF9_Pos   (9U)
#define EXTI_RPR1_RPIF9_Msk   (0x1UL << EXTI_RPR1_RPIF9_Pos)
#define EXTI_RPR1_RPIF9   EXTI_RPR1_RPIF9_Msk
#define EXTI_RPR1_RPIF10_Pos   (10U)
#define EXTI_RPR1_RPIF10_Msk   (0x1UL << EXTI_RPR1_RPIF10_Pos)
#define EXTI_RPR1_RPIF10   EXTI_RPR1_RPIF10_Msk
#define EXTI_RPR1_RPIF11_Pos   (11U)
#define EXTI_RPR1_RPIF11_Msk   (0x1UL << EXTI_RPR1_RPIF11_Pos)
#define EXTI_RPR1_RPIF11   EXTI_RPR1_RPIF11_Msk
#define EXTI_RPR1_RPIF12_Pos   (12U)
#define EXTI_RPR1_RPIF12_Msk   (0x1UL << EXTI_RPR1_RPIF12_Pos)
#define EXTI_RPR1_RPIF12   EXTI_RPR1_RPIF12_Msk
#define EXTI_RPR1_RPIF13_Pos   (13U)
#define EXTI_RPR1_RPIF13_Msk   (0x1UL << EXTI_RPR1_RPIF13_Pos)
#define EXTI_RPR1_RPIF13   EXTI_RPR1_RPIF13_Msk
#define EXTI_RPR1_RPIF14_Pos   (14U)
#define EXTI_RPR1_RPIF14_Msk   (0x1UL << EXTI_RPR1_RPIF14_Pos)
#define EXTI_RPR1_RPIF14   EXTI_RPR1_RPIF14_Msk
#define EXTI_RPR1_RPIF15_Pos   (15U)
#define EXTI_RPR1_RPIF15_Msk   (0x1UL << EXTI_RPR1_RPIF15_Pos)
#define EXTI_RPR1_RPIF15   EXTI_RPR1_RPIF15_Msk
#define EXTI_RPR1_RPIF16_Pos   (16U)
#define EXTI_RPR1_RPIF16_Msk   (0x1UL << EXTI_RPR1_RPIF16_Pos)
#define EXTI_RPR1_RPIF16   EXTI_RPR1_RPIF16_Msk
#define EXTI_RPR1_RPIF17_Pos   (17U)
#define EXTI_RPR1_RPIF17_Msk   (0x1UL << EXTI_RPR1_RPIF17_Pos)
#define EXTI_RPR1_RPIF17   EXTI_RPR1_RPIF17_Msk
#define EXTI_RPR1_RPIF18_Pos   (18U)
#define EXTI_RPR1_RPIF18_Msk   (0x1UL << EXTI_RPR1_RPIF18_Pos)
#define EXTI_RPR1_RPIF18   EXTI_RPR1_RPIF18_Msk
#define EXTI_RPR1_RPIF19_Pos   (19U)
#define EXTI_RPR1_RPIF19_Msk   (0x1UL << EXTI_RPR1_RPIF19_Pos)
#define EXTI_RPR1_RPIF19   EXTI_RPR1_RPIF19_Msk
#define EXTI_RPR1_RPIF20_Pos   (20U)
#define EXTI_RPR1_RPIF20_Msk   (0x1UL << EXTI_RPR1_RPIF20_Pos)
#define EXTI_RPR1_RPIF20   EXTI_RPR1_RPIF20_Msk
#define EXTI_RPR1_RPIF21_Pos   (21U)
#define EXTI_RPR1_RPIF21_Msk   (0x1UL << EXTI_RPR1_RPIF21_Pos)
#define EXTI_RPR1_RPIF21   EXTI_RPR1_RPIF21_Msk
#define EXTI_RPR1_RPIF22_Pos   (22U)
#define EXTI_RPR1_RPIF22_Msk   (0x1UL << EXTI_RPR1_RPIF22_Pos)
#define EXTI_RPR1_RPIF22   EXTI_RPR1_RPIF22_Msk
#define EXTI_RPR1_RPIF23_Pos   (23U)
#define EXTI_RPR1_RPIF23_Msk   (0x1UL << EXTI_RPR1_RPIF23_Pos)
#define EXTI_RPR1_RPIF23   EXTI_RPR1_RPIF23_Msk
#define EXTI_RPR1_RPIF24_Pos   (24U)
#define EXTI_RPR1_RPIF24_Msk   (0x1UL << EXTI_RPR1_RPIF24_Pos)
#define EXTI_RPR1_RPIF24   EXTI_RPR1_RPIF24_Msk
#define EXTI_RPR1_RPIF25_Pos   (25U)
#define EXTI_RPR1_RPIF25_Msk   (0x1UL << EXTI_RPR1_RPIF25_Pos)
#define EXTI_RPR1_RPIF25   EXTI_RPR1_RPIF25_Msk
#define EXTI_FPR1_FPIF0_Pos   (0U)
#define EXTI_FPR1_FPIF0_Msk   (0x1UL << EXTI_FPR1_FPIF0_Pos)
#define EXTI_FPR1_FPIF0   EXTI_FPR1_FPIF0_Msk
#define EXTI_FPR1_FPIF1_Pos   (1U)
#define EXTI_FPR1_FPIF1_Msk   (0x1UL << EXTI_FPR1_FPIF1_Pos)
#define EXTI_FPR1_FPIF1   EXTI_FPR1_FPIF1_Msk
#define EXTI_FPR1_FPIF2_Pos   (2U)
#define EXTI_FPR1_FPIF2_Msk   (0x1UL << EXTI_FPR1_FPIF2_Pos)
#define EXTI_FPR1_FPIF2   EXTI_FPR1_FPIF2_Msk
#define EXTI_FPR1_FPIF3_Pos   (3U)
#define EXTI_FPR1_FPIF3_Msk   (0x1UL << EXTI_FPR1_FPIF3_Pos)
#define EXTI_FPR1_FPIF3   EXTI_FPR1_FPIF3_Msk
#define EXTI_FPR1_FPIF4_Pos   (4U)
#define EXTI_FPR1_FPIF4_Msk   (0x1UL << EXTI_FPR1_FPIF4_Pos)
#define EXTI_FPR1_FPIF4   EXTI_FPR1_FPIF4_Msk
#define EXTI_FPR1_FPIF5_Pos   (5U)
#define EXTI_FPR1_FPIF5_Msk   (0x1UL << EXTI_FPR1_FPIF5_Pos)
#define EXTI_FPR1_FPIF5   EXTI_FPR1_FPIF5_Msk
#define EXTI_FPR1_FPIF6_Pos   (6U)
#define EXTI_FPR1_FPIF6_Msk   (0x1UL << EXTI_FPR1_FPIF6_Pos)
#define EXTI_FPR1_FPIF6   EXTI_FPR1_FPIF6_Msk
#define EXTI_FPR1_FPIF7_Pos   (7U)
#define EXTI_FPR1_FPIF7_Msk   (0x1UL << EXTI_FPR1_FPIF7_Pos)
#define EXTI_FPR1_FPIF7   EXTI_FPR1_FPIF7_Msk
#define EXTI_FPR1_FPIF8_Pos   (8U)
#define EXTI_FPR1_FPIF8_Msk   (0x1UL << EXTI_FPR1_FPIF8_Pos)
#define EXTI_FPR1_FPIF8   EXTI_FPR1_FPIF8_Msk
#define EXTI_FPR1_FPIF9_Pos   (9U)
#define EXTI_FPR1_FPIF9_Msk   (0x1UL << EXTI_FPR1_FPIF9_Pos)
#define EXTI_FPR1_FPIF9   EXTI_FPR1_FPIF9_Msk
#define EXTI_FPR1_FPIF10_Pos   (10U)
#define EXTI_FPR1_FPIF10_Msk   (0x1UL << EXTI_FPR1_FPIF10_Pos)
#define EXTI_FPR1_FPIF10   EXTI_FPR1_FPIF10_Msk
#define EXTI_FPR1_FPIF11_Pos   (11U)
#define EXTI_FPR1_FPIF11_Msk   (0x1UL << EXTI_FPR1_FPIF11_Pos)
#define EXTI_FPR1_FPIF11   EXTI_FPR1_FPIF11_Msk
#define EXTI_FPR1_FPIF12_Pos   (12U)
#define EXTI_FPR1_FPIF12_Msk   (0x1UL << EXTI_FPR1_FPIF12_Pos)
#define EXTI_FPR1_FPIF12   EXTI_FPR1_FPIF12_Msk
#define EXTI_FPR1_FPIF13_Pos   (13U)
#define EXTI_FPR1_FPIF13_Msk   (0x1UL << EXTI_FPR1_FPIF13_Pos)
#define EXTI_FPR1_FPIF13   EXTI_FPR1_FPIF13_Msk
#define EXTI_FPR1_FPIF14_Pos   (14U)
#define EXTI_FPR1_FPIF14_Msk   (0x1UL << EXTI_FPR1_FPIF14_Pos)
#define EXTI_FPR1_FPIF14   EXTI_FPR1_FPIF14_Msk
#define EXTI_FPR1_FPIF15_Pos   (15U)
#define EXTI_FPR1_FPIF15_Msk   (0x1UL << EXTI_FPR1_FPIF15_Pos)
#define EXTI_FPR1_FPIF15   EXTI_FPR1_FPIF15_Msk
#define EXTI_FPR1_FPIF16_Pos   (16U)
#define EXTI_FPR1_FPIF16_Msk   (0x1UL << EXTI_FPR1_FPIF16_Pos)
#define EXTI_FPR1_FPIF16   EXTI_FPR1_FPIF16_Msk
#define EXTI_FPR1_FPIF17_Pos   (17U)
#define EXTI_FPR1_FPIF17_Msk   (0x1UL << EXTI_FPR1_FPIF17_Pos)
#define EXTI_FPR1_FPIF17   EXTI_FPR1_FPIF17_Msk
#define EXTI_FPR1_FPIF18_Pos   (18U)
#define EXTI_FPR1_FPIF18_Msk   (0x1UL << EXTI_FPR1_FPIF18_Pos)
#define EXTI_FPR1_FPIF18   EXTI_FPR1_FPIF18_Msk
#define EXTI_FPR1_FPIF19_Pos   (19U)
#define EXTI_FPR1_FPIF19_Msk   (0x1UL << EXTI_FPR1_FPIF19_Pos)
#define EXTI_FPR1_FPIF19   EXTI_FPR1_FPIF19_Msk
#define EXTI_FPR1_FPIF20_Pos   (20U)
#define EXTI_FPR1_FPIF20_Msk   (0x1UL << EXTI_FPR1_FPIF20_Pos)
#define EXTI_FPR1_FPIF20   EXTI_FPR1_FPIF20_Msk
#define EXTI_FPR1_FPIF21_Pos   (21U)
#define EXTI_FPR1_FPIF21_Msk   (0x1UL << EXTI_FPR1_FPIF21_Pos)
#define EXTI_FPR1_FPIF21   EXTI_FPR1_FPIF21_Msk
#define EXTI_FPR1_FPIF22_Pos   (22U)
#define EXTI_FPR1_FPIF22_Msk   (0x1UL << EXTI_FPR1_FPIF22_Pos)
#define EXTI_FPR1_FPIF22   EXTI_FPR1_FPIF22_Msk
#define EXTI_FPR1_FPIF23_Pos   (23U)
#define EXTI_FPR1_FPIF23_Msk   (0x1UL << EXTI_FPR1_FPIF23_Pos)
#define EXTI_FPR1_FPIF23   EXTI_FPR1_FPIF23_Msk
#define EXTI_FPR1_FPIF24_Pos   (24U)
#define EXTI_FPR1_FPIF24_Msk   (0x1UL << EXTI_FPR1_FPIF24_Pos)
#define EXTI_FPR1_FPIF24   EXTI_FPR1_FPIF24_Msk
#define EXTI_FPR1_FPIF25_Pos   (25U)
#define EXTI_FPR1_FPIF25_Msk   (0x1UL << EXTI_FPR1_FPIF25_Pos)
#define EXTI_FPR1_FPIF25   EXTI_FPR1_FPIF25_Msk
#define EXTI_SECCFGR1_SEC0_Pos   (0U)
#define EXTI_SECCFGR1_SEC0_Msk   (0x1UL << EXTI_SECCFGR1_SEC0_Pos)
#define EXTI_SECCFGR1_SEC0   EXTI_SECCFGR1_SEC0_Msk
#define EXTI_SECCFGR1_SEC1_Pos   (1U)
#define EXTI_SECCFGR1_SEC1_Msk   (0x1UL << EXTI_SECCFGR1_SEC1_Pos)
#define EXTI_SECCFGR1_SEC1   EXTI_SECCFGR1_SEC1_Msk
#define EXTI_SECCFGR1_SEC2_Pos   (2U)
#define EXTI_SECCFGR1_SEC2_Msk   (0x1UL << EXTI_SECCFGR1_SEC2_Pos)
#define EXTI_SECCFGR1_SEC2   EXTI_SECCFGR1_SEC2_Msk
#define EXTI_SECCFGR1_SEC3_Pos   (3U)
#define EXTI_SECCFGR1_SEC3_Msk   (0x1UL << EXTI_SECCFGR1_SEC3_Pos)
#define EXTI_SECCFGR1_SEC3   EXTI_SECCFGR1_SEC3_Msk
#define EXTI_SECCFGR1_SEC4_Pos   (4U)
#define EXTI_SECCFGR1_SEC4_Msk   (0x1UL << EXTI_SECCFGR1_SEC4_Pos)
#define EXTI_SECCFGR1_SEC4   EXTI_SECCFGR1_SEC4_Msk
#define EXTI_SECCFGR1_SEC5_Pos   (5U)
#define EXTI_SECCFGR1_SEC5_Msk   (0x1UL << EXTI_SECCFGR1_SEC5_Pos)
#define EXTI_SECCFGR1_SEC5   EXTI_SECCFGR1_SEC5_Msk
#define EXTI_SECCFGR1_SEC6_Pos   (6U)
#define EXTI_SECCFGR1_SEC6_Msk   (0x1UL << EXTI_SECCFGR1_SEC6_Pos)
#define EXTI_SECCFGR1_SEC6   EXTI_SECCFGR1_SEC6_Msk
#define EXTI_SECCFGR1_SEC7_Pos   (7U)
#define EXTI_SECCFGR1_SEC7_Msk   (0x1UL << EXTI_SECCFGR1_SEC7_Pos)
#define EXTI_SECCFGR1_SEC7   EXTI_SECCFGR1_SEC7_Msk
#define EXTI_SECCFGR1_SEC8_Pos   (8U)
#define EXTI_SECCFGR1_SEC8_Msk   (0x1UL << EXTI_SECCFGR1_SEC8_Pos)
#define EXTI_SECCFGR1_SEC8   EXTI_SECCFGR1_SEC8_Msk
#define EXTI_SECCFGR1_SEC9_Pos   (9U)
#define EXTI_SECCFGR1_SEC9_Msk   (0x1UL << EXTI_SECCFGR1_SEC9_Pos)
#define EXTI_SECCFGR1_SEC9   EXTI_SECCFGR1_SEC9_Msk
#define EXTI_SECCFGR1_SEC10_Pos   (10U)
#define EXTI_SECCFGR1_SEC10_Msk   (0x1UL << EXTI_SECCFGR1_SEC10_Pos)
#define EXTI_SECCFGR1_SEC10   EXTI_SECCFGR1_SEC10_Msk
#define EXTI_SECCFGR1_SEC11_Pos   (11U)
#define EXTI_SECCFGR1_SEC11_Msk   (0x1UL << EXTI_SECCFGR1_SEC11_Pos)
#define EXTI_SECCFGR1_SEC11   EXTI_SECCFGR1_SEC11_Msk
#define EXTI_SECCFGR1_SEC12_Pos   (12U)
#define EXTI_SECCFGR1_SEC12_Msk   (0x1UL << EXTI_SECCFGR1_SEC12_Pos)
#define EXTI_SECCFGR1_SEC12   EXTI_SECCFGR1_SEC12_Msk
#define EXTI_SECCFGR1_SEC13_Pos   (13U)
#define EXTI_SECCFGR1_SEC13_Msk   (0x1UL << EXTI_SECCFGR1_SEC13_Pos)
#define EXTI_SECCFGR1_SEC13   EXTI_SECCFGR1_SEC13_Msk
#define EXTI_SECCFGR1_SEC14_Pos   (14U)
#define EXTI_SECCFGR1_SEC14_Msk   (0x1UL << EXTI_SECCFGR1_SEC14_Pos)
#define EXTI_SECCFGR1_SEC14   EXTI_SECCFGR1_SEC14_Msk
#define EXTI_SECCFGR1_SEC15_Pos   (15U)
#define EXTI_SECCFGR1_SEC15_Msk   (0x1UL << EXTI_SECCFGR1_SEC15_Pos)
#define EXTI_SECCFGR1_SEC15   EXTI_SECCFGR1_SEC15_Msk
#define EXTI_SECCFGR1_SEC16_Pos   (16U)
#define EXTI_SECCFGR1_SEC16_Msk   (0x1UL << EXTI_SECCFGR1_SEC16_Pos)
#define EXTI_SECCFGR1_SEC16   EXTI_SECCFGR1_SEC16_Msk
#define EXTI_SECCFGR1_SEC17_Pos   (17U)
#define EXTI_SECCFGR1_SEC17_Msk   (0x1UL << EXTI_SECCFGR1_SEC17_Pos)
#define EXTI_SECCFGR1_SEC17   EXTI_SECCFGR1_SEC17_Msk
#define EXTI_SECCFGR1_SEC18_Pos   (18U)
#define EXTI_SECCFGR1_SEC18_Msk   (0x1UL << EXTI_SECCFGR1_SEC18_Pos)
#define EXTI_SECCFGR1_SEC18   EXTI_SECCFGR1_SEC18_Msk
#define EXTI_SECCFGR1_SEC19_Pos   (19U)
#define EXTI_SECCFGR1_SEC19_Msk   (0x1UL << EXTI_SECCFGR1_SEC19_Pos)
#define EXTI_SECCFGR1_SEC19   EXTI_SECCFGR1_SEC19_Msk
#define EXTI_SECCFGR1_SEC20_Pos   (20U)
#define EXTI_SECCFGR1_SEC20_Msk   (0x1UL << EXTI_SECCFGR1_SEC20_Pos)
#define EXTI_SECCFGR1_SEC20   EXTI_SECCFGR1_SEC20_Msk
#define EXTI_SECCFGR1_SEC21_Pos   (21U)
#define EXTI_SECCFGR1_SEC21_Msk   (0x1UL << EXTI_SECCFGR1_SEC21_Pos)
#define EXTI_SECCFGR1_SEC21   EXTI_SECCFGR1_SEC21_Msk
#define EXTI_SECCFGR1_SEC22_Pos   (22U)
#define EXTI_SECCFGR1_SEC22_Msk   (0x1UL << EXTI_SECCFGR1_SEC22_Pos)
#define EXTI_SECCFGR1_SEC22   EXTI_SECCFGR1_SEC22_Msk
#define EXTI_SECCFGR1_SEC23_Pos   (23U)
#define EXTI_SECCFGR1_SEC23_Msk   (0x1UL << EXTI_SECCFGR1_SEC23_Pos)
#define EXTI_SECCFGR1_SEC23   EXTI_SECCFGR1_SEC23_Msk
#define EXTI_SECCFGR1_SEC24_Pos   (24U)
#define EXTI_SECCFGR1_SEC24_Msk   (0x1UL << EXTI_SECCFGR1_SEC24_Pos)
#define EXTI_SECCFGR1_SEC24   EXTI_SECCFGR1_SEC24_Msk
#define EXTI_SECCFGR1_SEC25_Pos   (25U)
#define EXTI_SECCFGR1_SEC25_Msk   (0x1UL << EXTI_SECCFGR1_SEC25_Pos)
#define EXTI_SECCFGR1_SEC25   EXTI_SECCFGR1_SEC25_Msk
#define EXTI_PRIVCFGR1_PRIV0_Pos   (0U)
#define EXTI_PRIVCFGR1_PRIV0_Msk   (0x1UL << EXTI_PRIVCFGR1_PRIV0_Pos)
#define EXTI_PRIVCFGR1_PRIV0   EXTI_PRIVCFGR1_PRIV0_Msk
#define EXTI_PRIVCFGR1_PRIV1_Pos   (1U)
#define EXTI_PRIVCFGR1_PRIV1_Msk   (0x1UL << EXTI_PRIVCFGR1_PRIV1_Pos)
#define EXTI_PRIVCFGR1_PRIV1   EXTI_PRIVCFGR1_PRIV1_Msk
#define EXTI_PRIVCFGR1_PRIV2_Pos   (2U)
#define EXTI_PRIVCFGR1_PRIV2_Msk   (0x1UL << EXTI_PRIVCFGR1_PRIV2_Pos)
#define EXTI_PRIVCFGR1_PRIV2   EXTI_PRIVCFGR1_PRIV2_Msk
#define EXTI_PRIVCFGR1_PRIV3_Pos   (3U)
#define EXTI_PRIVCFGR1_PRIV3_Msk   (0x1UL << EXTI_PRIVCFGR1_PRIV3_Pos)
#define EXTI_PRIVCFGR1_PRIV3   EXTI_PRIVCFGR1_PRIV3_Msk
#define EXTI_PRIVCFGR1_PRIV4_Pos   (4U)
#define EXTI_PRIVCFGR1_PRIV4_Msk   (0x1UL << EXTI_PRIVCFGR1_PRIV4_Pos)
#define EXTI_PRIVCFGR1_PRIV4   EXTI_PRIVCFGR1_PRIV4_Msk
#define EXTI_PRIVCFGR1_PRIV5_Pos   (5U)
#define EXTI_PRIVCFGR1_PRIV5_Msk   (0x1UL << EXTI_PRIVCFGR1_PRIV5_Pos)
#define EXTI_PRIVCFGR1_PRIV5   EXTI_PRIVCFGR1_PRIV5_Msk
#define EXTI_PRIVCFGR1_PRIV6_Pos   (6U)
#define EXTI_PRIVCFGR1_PRIV6_Msk   (0x1UL << EXTI_PRIVCFGR1_PRIV6_Pos)
#define EXTI_PRIVCFGR1_PRIV6   EXTI_PRIVCFGR1_PRIV6_Msk
#define EXTI_PRIVCFGR1_PRIV7_Pos   (7U)
#define EXTI_PRIVCFGR1_PRIV7_Msk   (0x1UL << EXTI_PRIVCFGR1_PRIV7_Pos)
#define EXTI_PRIVCFGR1_PRIV7   EXTI_PRIVCFGR1_PRIV7_Msk
#define EXTI_PRIVCFGR1_PRIV8_Pos   (8U)
#define EXTI_PRIVCFGR1_PRIV8_Msk   (0x1UL << EXTI_PRIVCFGR1_PRIV8_Pos)
#define EXTI_PRIVCFGR1_PRIV8   EXTI_PRIVCFGR1_PRIV8_Msk
#define EXTI_PRIVCFGR1_PRIV9_Pos   (9U)
#define EXTI_PRIVCFGR1_PRIV9_Msk   (0x1UL << EXTI_PRIVCFGR1_PRIV9_Pos)
#define EXTI_PRIVCFGR1_PRIV9   EXTI_PRIVCFGR1_PRIV9_Msk
#define EXTI_PRIVCFGR1_PRIV10_Pos   (10U)
#define EXTI_PRIVCFGR1_PRIV10_Msk   (0x1UL << EXTI_PRIVCFGR1_PRIV10_Pos)
#define EXTI_PRIVCFGR1_PRIV10   EXTI_PRIVCFGR1_PRIV10_Msk
#define EXTI_PRIVCFGR1_PRIV11_Pos   (11U)
#define EXTI_PRIVCFGR1_PRIV11_Msk   (0x1UL << EXTI_PRIVCFGR1_PRIV11_Pos)
#define EXTI_PRIVCFGR1_PRIV11   EXTI_PRIVCFGR1_PRIV11_Msk
#define EXTI_PRIVCFGR1_PRIV12_Pos   (12U)
#define EXTI_PRIVCFGR1_PRIV12_Msk   (0x1UL << EXTI_PRIVCFGR1_PRIV12_Pos)
#define EXTI_PRIVCFGR1_PRIV12   EXTI_PRIVCFGR1_PRIV12_Msk
#define EXTI_PRIVCFGR1_PRIV13_Pos   (13U)
#define EXTI_PRIVCFGR1_PRIV13_Msk   (0x1UL << EXTI_PRIVCFGR1_PRIV13_Pos)
#define EXTI_PRIVCFGR1_PRIV13   EXTI_PRIVCFGR1_PRIV13_Msk
#define EXTI_PRIVCFGR1_PRIV14_Pos   (14U)
#define EXTI_PRIVCFGR1_PRIV14_Msk   (0x1UL << EXTI_PRIVCFGR1_PRIV14_Pos)
#define EXTI_PRIVCFGR1_PRIV14   EXTI_PRIVCFGR1_PRIV14_Msk
#define EXTI_PRIVCFGR1_PRIV15_Pos   (15U)
#define EXTI_PRIVCFGR1_PRIV15_Msk   (0x1UL << EXTI_PRIVCFGR1_PRIV15_Pos)
#define EXTI_PRIVCFGR1_PRIV15   EXTI_PRIVCFGR1_PRIV15_Msk
#define EXTI_PRIVCFGR1_PRIV16_Pos   (16U)
#define EXTI_PRIVCFGR1_PRIV16_Msk   (0x1UL << EXTI_PRIVCFGR1_PRIV16_Pos)
#define EXTI_PRIVCFGR1_PRIV16   EXTI_PRIVCFGR1_PRIV16_Msk
#define EXTI_PRIVCFGR1_PRIV17_Pos   (17U)
#define EXTI_PRIVCFGR1_PRIV17_Msk   (0x1UL << EXTI_PRIVCFGR1_PRIV17_Pos)
#define EXTI_PRIVCFGR1_PRIV17   EXTI_PRIVCFGR1_PRIV17_Msk
#define EXTI_PRIVCFGR1_PRIV18_Pos   (18U)
#define EXTI_PRIVCFGR1_PRIV18_Msk   (0x1UL << EXTI_PRIVCFGR1_PRIV18_Pos)
#define EXTI_PRIVCFGR1_PRIV18   EXTI_PRIVCFGR1_PRIV18_Msk
#define EXTI_PRIVCFGR1_PRIV19_Pos   (19U)
#define EXTI_PRIVCFGR1_PRIV19_Msk   (0x1UL << EXTI_PRIVCFGR1_PRIV19_Pos)
#define EXTI_PRIVCFGR1_PRIV19   EXTI_PRIVCFGR1_PRIV19_Msk
#define EXTI_PRIVCFGR1_PRIV20_Pos   (20U)
#define EXTI_PRIVCFGR1_PRIV20_Msk   (0x1UL << EXTI_PRIVCFGR1_PRIV20_Pos)
#define EXTI_PRIVCFGR1_PRIV20   EXTI_PRIVCFGR1_PRIV20_Msk
#define EXTI_PRIVCFGR1_PRIV21_Pos   (21U)
#define EXTI_PRIVCFGR1_PRIV21_Msk   (0x1UL << EXTI_PRIVCFGR1_PRIV21_Pos)
#define EXTI_PRIVCFGR1_PRIV21   EXTI_PRIVCFGR1_PRIV21_Msk
#define EXTI_PRIVCFGR1_PRIV22_Pos   (22U)
#define EXTI_PRIVCFGR1_PRIV22_Msk   (0x1UL << EXTI_PRIVCFGR1_PRIV22_Pos)
#define EXTI_PRIVCFGR1_PRIV22   EXTI_PRIVCFGR1_PRIV22_Msk
#define EXTI_PRIVCFGR1_PRIV23_Pos   (23U)
#define EXTI_PRIVCFGR1_PRIV23_Msk   (0x1UL << EXTI_PRIVCFGR1_PRIV23_Pos)
#define EXTI_PRIVCFGR1_PRIV23   EXTI_PRIVCFGR1_PRIV23_Msk
#define EXTI_PRIVCFGR1_PRIV24_Pos   (24U)
#define EXTI_PRIVCFGR1_PRIV24_Msk   (0x1UL << EXTI_PRIVCFGR1_PRIV24_Pos)
#define EXTI_PRIVCFGR1_PRIV24   EXTI_PRIVCFGR1_PRIV24_Msk
#define EXTI_PRIVCFGR1_PRIV25_Pos   (25U)
#define EXTI_PRIVCFGR1_PRIV25_Msk   (0x1UL << EXTI_PRIVCFGR1_PRIV25_Pos)
#define EXTI_PRIVCFGR1_PRIV25   EXTI_PRIVCFGR1_PRIV25_Msk
#define EXTI_EXTICR1_EXTI0_Pos   (0U)
#define EXTI_EXTICR1_EXTI0_Msk   (0xFUL << EXTI_EXTICR1_EXTI0_Pos)
#define EXTI_EXTICR1_EXTI0   EXTI_EXTICR1_EXTI0_Msk
#define EXTI_EXTICR1_EXTI0_0   (0x1UL << EXTI_EXTICR1_EXTI0_Pos)
#define EXTI_EXTICR1_EXTI0_1   (0x2UL << EXTI_EXTICR1_EXTI0_Pos)
#define EXTI_EXTICR1_EXTI0_2   (0x4UL << EXTI_EXTICR1_EXTI0_Pos)
#define EXTI_EXTICR1_EXTI0_3   (0x8UL << EXTI_EXTICR1_EXTI0_Pos)
#define EXTI_EXTICR1_EXTI1_Pos   (8U)
#define EXTI_EXTICR1_EXTI1_Msk   (0xFUL << EXTI_EXTICR1_EXTI1_Pos)
#define EXTI_EXTICR1_EXTI1   EXTI_EXTICR1_EXTI1_Msk
#define EXTI_EXTICR1_EXTI1_0   (0x1UL << EXTI_EXTICR1_EXTI1_Pos)
#define EXTI_EXTICR1_EXTI1_1   (0x2UL << EXTI_EXTICR1_EXTI1_Pos)
#define EXTI_EXTICR1_EXTI1_2   (0x4UL << EXTI_EXTICR1_EXTI1_Pos)
#define EXTI_EXTICR1_EXTI1_3   (0x8UL << EXTI_EXTICR1_EXTI1_Pos)
#define EXTI_EXTICR1_EXTI2_Pos   (16U)
#define EXTI_EXTICR1_EXTI2_Msk   (0xFUL << EXTI_EXTICR1_EXTI2_Pos)
#define EXTI_EXTICR1_EXTI2   EXTI_EXTICR1_EXTI2_Msk
#define EXTI_EXTICR1_EXTI2_0   (0x1UL << EXTI_EXTICR1_EXTI2_Pos)
#define EXTI_EXTICR1_EXTI2_1   (0x2UL << EXTI_EXTICR1_EXTI2_Pos)
#define EXTI_EXTICR1_EXTI2_2   (0x4UL << EXTI_EXTICR1_EXTI2_Pos)
#define EXTI_EXTICR1_EXTI2_3   (0x8UL << EXTI_EXTICR1_EXTI2_Pos)
#define EXTI_EXTICR1_EXTI3_Pos   (24U)
#define EXTI_EXTICR1_EXTI3_Msk   (0xFUL << EXTI_EXTICR1_EXTI3_Pos)
#define EXTI_EXTICR1_EXTI3   EXTI_EXTICR1_EXTI3_Msk
#define EXTI_EXTICR1_EXTI3_0   (0x1UL << EXTI_EXTICR1_EXTI3_Pos)
#define EXTI_EXTICR1_EXTI3_1   (0x2UL << EXTI_EXTICR1_EXTI3_Pos)
#define EXTI_EXTICR1_EXTI3_2   (0x4UL << EXTI_EXTICR1_EXTI3_Pos)
#define EXTI_EXTICR1_EXTI3_3   (0x8UL << EXTI_EXTICR1_EXTI3_Pos)
#define EXTI_EXTICR2_EXTI4_Pos   (0U)
#define EXTI_EXTICR2_EXTI4_Msk   (0xFUL << EXTI_EXTICR2_EXTI4_Pos)
#define EXTI_EXTICR2_EXTI4   EXTI_EXTICR2_EXTI4_Msk
#define EXTI_EXTICR2_EXTI4_0   (0x1UL << EXTI_EXTICR2_EXTI4_Pos)
#define EXTI_EXTICR2_EXTI4_1   (0x2UL << EXTI_EXTICR2_EXTI4_Pos)
#define EXTI_EXTICR2_EXTI4_2   (0x4UL << EXTI_EXTICR2_EXTI4_Pos)
#define EXTI_EXTICR2_EXTI4_3   (0x8UL << EXTI_EXTICR2_EXTI4_Pos)
#define EXTI_EXTICR2_EXTI5_Pos   (8U)
#define EXTI_EXTICR2_EXTI5_Msk   (0xFUL << EXTI_EXTICR2_EXTI5_Pos)
#define EXTI_EXTICR2_EXTI5   EXTI_EXTICR2_EXTI5_Msk
#define EXTI_EXTICR2_EXTI5_0   (0x1UL << EXTI_EXTICR2_EXTI5_Pos)
#define EXTI_EXTICR2_EXTI5_1   (0x2UL << EXTI_EXTICR2_EXTI5_Pos)
#define EXTI_EXTICR2_EXTI5_2   (0x4UL << EXTI_EXTICR2_EXTI5_Pos)
#define EXTI_EXTICR2_EXTI5_3   (0x8UL << EXTI_EXTICR2_EXTI5_Pos)
#define EXTI_EXTICR2_EXTI6_Pos   (16U)
#define EXTI_EXTICR2_EXTI6_Msk   (0xFUL << EXTI_EXTICR2_EXTI6_Pos)
#define EXTI_EXTICR2_EXTI6   EXTI_EXTICR2_EXTI6_Msk
#define EXTI_EXTICR2_EXTI6_0   (0x1UL << EXTI_EXTICR2_EXTI6_Pos)
#define EXTI_EXTICR2_EXTI6_1   (0x2UL << EXTI_EXTICR2_EXTI6_Pos)
#define EXTI_EXTICR2_EXTI6_2   (0x4UL << EXTI_EXTICR2_EXTI6_Pos)
#define EXTI_EXTICR2_EXTI6_3   (0x8UL << EXTI_EXTICR2_EXTI6_Pos)
#define EXTI_EXTICR2_EXTI7_Pos   (24U)
#define EXTI_EXTICR2_EXTI7_Msk   (0xFUL << EXTI_EXTICR2_EXTI7_Pos)
#define EXTI_EXTICR2_EXTI7   EXTI_EXTICR2_EXTI7_Msk
#define EXTI_EXTICR2_EXTI7_0   (0x1UL << EXTI_EXTICR2_EXTI7_Pos)
#define EXTI_EXTICR2_EXTI7_1   (0x2UL << EXTI_EXTICR2_EXTI7_Pos)
#define EXTI_EXTICR2_EXTI7_2   (0x4UL << EXTI_EXTICR2_EXTI7_Pos)
#define EXTI_EXTICR2_EXTI7_3   (0x8UL << EXTI_EXTICR2_EXTI7_Pos)
#define EXTI_EXTICR3_EXTI8_Pos   (0U)
#define EXTI_EXTICR3_EXTI8_Msk   (0xFUL << EXTI_EXTICR3_EXTI8_Pos)
#define EXTI_EXTICR3_EXTI8   EXTI_EXTICR3_EXTI8_Msk
#define EXTI_EXTICR3_EXTI8_0   (0x1UL << EXTI_EXTICR3_EXTI8_Pos)
#define EXTI_EXTICR3_EXTI8_1   (0x2UL << EXTI_EXTICR3_EXTI8_Pos)
#define EXTI_EXTICR3_EXTI8_2   (0x4UL << EXTI_EXTICR3_EXTI8_Pos)
#define EXTI_EXTICR3_EXTI8_3   (0x8UL << EXTI_EXTICR3_EXTI8_Pos)
#define EXTI_EXTICR3_EXTI9_Pos   (8U)
#define EXTI_EXTICR3_EXTI9_Msk   (0xFUL << EXTI_EXTICR3_EXTI9_Pos)
#define EXTI_EXTICR3_EXTI9   EXTI_EXTICR3_EXTI9_Msk
#define EXTI_EXTICR3_EXTI9_0   (0x1UL << EXTI_EXTICR3_EXTI9_Pos)
#define EXTI_EXTICR3_EXTI9_1   (0x2UL << EXTI_EXTICR3_EXTI9_Pos)
#define EXTI_EXTICR3_EXTI9_2   (0x4UL << EXTI_EXTICR3_EXTI9_Pos)
#define EXTI_EXTICR3_EXTI9_3   (0x8UL << EXTI_EXTICR3_EXTI9_Pos)
#define EXTI_EXTICR3_EXTI10_Pos   (16U)
#define EXTI_EXTICR3_EXTI10_Msk   (0xFUL << EXTI_EXTICR3_EXTI10_Pos)
#define EXTI_EXTICR3_EXTI10   EXTI_EXTICR3_EXTI10_Msk
#define EXTI_EXTICR3_EXTI10_0   (0x1UL << EXTI_EXTICR3_EXTI10_Pos)
#define EXTI_EXTICR3_EXTI10_1   (0x2UL << EXTI_EXTICR3_EXTI10_Pos)
#define EXTI_EXTICR3_EXTI10_2   (0x4UL << EXTI_EXTICR3_EXTI10_Pos)
#define EXTI_EXTICR3_EXTI10_3   (0x8UL << EXTI_EXTICR3_EXTI10_Pos)
#define EXTI_EXTICR3_EXTI11_Pos   (24U)
#define EXTI_EXTICR3_EXTI11_Msk   (0xFUL << EXTI_EXTICR3_EXTI11_Pos)
#define EXTI_EXTICR3_EXTI11   EXTI_EXTICR3_EXTI11_Msk
#define EXTI_EXTICR3_EXTI11_0   (0x1UL << EXTI_EXTICR3_EXTI11_Pos)
#define EXTI_EXTICR3_EXTI11_1   (0x2UL << EXTI_EXTICR3_EXTI11_Pos)
#define EXTI_EXTICR3_EXTI11_2   (0x4UL << EXTI_EXTICR3_EXTI11_Pos)
#define EXTI_EXTICR3_EXTI11_3   (0x8UL << EXTI_EXTICR3_EXTI11_Pos)
#define EXTI_EXTICR4_EXTI12_Pos   (0U)
#define EXTI_EXTICR4_EXTI12_Msk   (0xFUL << EXTI_EXTICR4_EXTI12_Pos)
#define EXTI_EXTICR4_EXTI12   EXTI_EXTICR4_EXTI12_Msk
#define EXTI_EXTICR4_EXTI12_0   (0x1UL << EXTI_EXTICR4_EXTI12_Pos)
#define EXTI_EXTICR4_EXTI12_1   (0x2UL << EXTI_EXTICR4_EXTI12_Pos)
#define EXTI_EXTICR4_EXTI12_2   (0x4UL << EXTI_EXTICR4_EXTI12_Pos)
#define EXTI_EXTICR4_EXTI12_3   (0x8UL << EXTI_EXTICR4_EXTI12_Pos)
#define EXTI_EXTICR4_EXTI13_Pos   (8U)
#define EXTI_EXTICR4_EXTI13_Msk   (0xFUL << EXTI_EXTICR4_EXTI13_Pos)
#define EXTI_EXTICR4_EXTI13   EXTI_EXTICR4_EXTI13_Msk
#define EXTI_EXTICR4_EXTI13_0   (0x1UL << EXTI_EXTICR4_EXTI13_Pos)
#define EXTI_EXTICR4_EXTI13_1   (0x2UL << EXTI_EXTICR4_EXTI13_Pos)
#define EXTI_EXTICR4_EXTI13_2   (0x4UL << EXTI_EXTICR4_EXTI13_Pos)
#define EXTI_EXTICR4_EXTI13_3   (0x8UL << EXTI_EXTICR4_EXTI13_Pos)
#define EXTI_EXTICR4_EXTI14_Pos   (16U)
#define EXTI_EXTICR4_EXTI14_Msk   (0xFUL << EXTI_EXTICR4_EXTI14_Pos)
#define EXTI_EXTICR4_EXTI14   EXTI_EXTICR4_EXTI14_Msk
#define EXTI_EXTICR4_EXTI14_0   (0x1UL << EXTI_EXTICR4_EXTI14_Pos)
#define EXTI_EXTICR4_EXTI14_1   (0x2UL << EXTI_EXTICR4_EXTI14_Pos)
#define EXTI_EXTICR4_EXTI14_2   (0x4UL << EXTI_EXTICR4_EXTI14_Pos)
#define EXTI_EXTICR4_EXTI14_3   (0x8UL << EXTI_EXTICR4_EXTI14_Pos)
#define EXTI_EXTICR4_EXTI15_Pos   (24U)
#define EXTI_EXTICR4_EXTI15_Msk   (0xFUL << EXTI_EXTICR4_EXTI15_Pos)
#define EXTI_EXTICR4_EXTI15   EXTI_EXTICR4_EXTI15_Msk
#define EXTI_EXTICR4_EXTI15_0   (0x1UL << EXTI_EXTICR4_EXTI15_Pos)
#define EXTI_EXTICR4_EXTI15_1   (0x2UL << EXTI_EXTICR4_EXTI15_Pos)
#define EXTI_EXTICR4_EXTI15_2   (0x4UL << EXTI_EXTICR4_EXTI15_Pos)
#define EXTI_EXTICR4_EXTI15_3   (0x8UL << EXTI_EXTICR4_EXTI15_Pos)
#define EXTI_LOCKR_LOCK_Pos   (0U)
#define EXTI_LOCKR_LOCK_Msk   (0x1UL << EXTI_LOCKR_LOCK_Pos)
#define EXTI_LOCKR_LOCK   EXTI_LOCKR_LOCK_Msk
#define EXTI_IMR1_IM0_Pos   (0U)
#define EXTI_IMR1_IM0_Msk   (0x1UL << EXTI_IMR1_IM0_Pos)
#define EXTI_IMR1_IM0   EXTI_IMR1_IM0_Msk
#define EXTI_IMR1_IM1_Pos   (1U)
#define EXTI_IMR1_IM1_Msk   (0x1UL << EXTI_IMR1_IM1_Pos)
#define EXTI_IMR1_IM1   EXTI_IMR1_IM1_Msk
#define EXTI_IMR1_IM2_Pos   (2U)
#define EXTI_IMR1_IM2_Msk   (0x1UL << EXTI_IMR1_IM2_Pos)
#define EXTI_IMR1_IM2   EXTI_IMR1_IM2_Msk
#define EXTI_IMR1_IM3_Pos   (3U)
#define EXTI_IMR1_IM3_Msk   (0x1UL << EXTI_IMR1_IM3_Pos)
#define EXTI_IMR1_IM3   EXTI_IMR1_IM3_Msk
#define EXTI_IMR1_IM4_Pos   (4U)
#define EXTI_IMR1_IM4_Msk   (0x1UL << EXTI_IMR1_IM4_Pos)
#define EXTI_IMR1_IM4   EXTI_IMR1_IM4_Msk
#define EXTI_IMR1_IM5_Pos   (5U)
#define EXTI_IMR1_IM5_Msk   (0x1UL << EXTI_IMR1_IM5_Pos)
#define EXTI_IMR1_IM5   EXTI_IMR1_IM5_Msk
#define EXTI_IMR1_IM6_Pos   (6U)
#define EXTI_IMR1_IM6_Msk   (0x1UL << EXTI_IMR1_IM6_Pos)
#define EXTI_IMR1_IM6   EXTI_IMR1_IM6_Msk
#define EXTI_IMR1_IM7_Pos   (7U)
#define EXTI_IMR1_IM7_Msk   (0x1UL << EXTI_IMR1_IM7_Pos)
#define EXTI_IMR1_IM7   EXTI_IMR1_IM7_Msk
#define EXTI_IMR1_IM8_Pos   (8U)
#define EXTI_IMR1_IM8_Msk   (0x1UL << EXTI_IMR1_IM8_Pos)
#define EXTI_IMR1_IM8   EXTI_IMR1_IM8_Msk
#define EXTI_IMR1_IM9_Pos   (9U)
#define EXTI_IMR1_IM9_Msk   (0x1UL << EXTI_IMR1_IM9_Pos)
#define EXTI_IMR1_IM9   EXTI_IMR1_IM9_Msk
#define EXTI_IMR1_IM10_Pos   (10U)
#define EXTI_IMR1_IM10_Msk   (0x1UL << EXTI_IMR1_IM10_Pos)
#define EXTI_IMR1_IM10   EXTI_IMR1_IM10_Msk
#define EXTI_IMR1_IM11_Pos   (11U)
#define EXTI_IMR1_IM11_Msk   (0x1UL << EXTI_IMR1_IM11_Pos)
#define EXTI_IMR1_IM11   EXTI_IMR1_IM11_Msk
#define EXTI_IMR1_IM12_Pos   (12U)
#define EXTI_IMR1_IM12_Msk   (0x1UL << EXTI_IMR1_IM12_Pos)
#define EXTI_IMR1_IM12   EXTI_IMR1_IM12_Msk
#define EXTI_IMR1_IM13_Pos   (13U)
#define EXTI_IMR1_IM13_Msk   (0x1UL << EXTI_IMR1_IM13_Pos)
#define EXTI_IMR1_IM13   EXTI_IMR1_IM13_Msk
#define EXTI_IMR1_IM14_Pos   (14U)
#define EXTI_IMR1_IM14_Msk   (0x1UL << EXTI_IMR1_IM14_Pos)
#define EXTI_IMR1_IM14   EXTI_IMR1_IM14_Msk
#define EXTI_IMR1_IM15_Pos   (15U)
#define EXTI_IMR1_IM15_Msk   (0x1UL << EXTI_IMR1_IM15_Pos)
#define EXTI_IMR1_IM15   EXTI_IMR1_IM15_Msk
#define EXTI_IMR1_IM16_Pos   (16U)
#define EXTI_IMR1_IM16_Msk   (0x1UL << EXTI_IMR1_IM16_Pos)
#define EXTI_IMR1_IM16   EXTI_IMR1_IM16_Msk
#define EXTI_IMR1_IM17_Pos   (17U)
#define EXTI_IMR1_IM17_Msk   (0x1UL << EXTI_IMR1_IM17_Pos)
#define EXTI_IMR1_IM17   EXTI_IMR1_IM17_Msk
#define EXTI_IMR1_IM18_Pos   (18U)
#define EXTI_IMR1_IM18_Msk   (0x1UL << EXTI_IMR1_IM18_Pos)
#define EXTI_IMR1_IM18   EXTI_IMR1_IM18_Msk
#define EXTI_IMR1_IM19_Pos   (19U)
#define EXTI_IMR1_IM19_Msk   (0x1UL << EXTI_IMR1_IM19_Pos)
#define EXTI_IMR1_IM19   EXTI_IMR1_IM19_Msk
#define EXTI_IMR1_IM20_Pos   (20U)
#define EXTI_IMR1_IM20_Msk   (0x1UL << EXTI_IMR1_IM20_Pos)
#define EXTI_IMR1_IM20   EXTI_IMR1_IM20_Msk
#define EXTI_IMR1_IM21_Pos   (21U)
#define EXTI_IMR1_IM21_Msk   (0x1UL << EXTI_IMR1_IM21_Pos)
#define EXTI_IMR1_IM21   EXTI_IMR1_IM21_Msk
#define EXTI_IMR1_IM22_Pos   (22U)
#define EXTI_IMR1_IM22_Msk   (0x1UL << EXTI_IMR1_IM22_Pos)
#define EXTI_IMR1_IM22   EXTI_IMR1_IM22_Msk
#define EXTI_IMR1_IM23_Pos   (23U)
#define EXTI_IMR1_IM23_Msk   (0x1UL << EXTI_IMR1_IM23_Pos)
#define EXTI_IMR1_IM23   EXTI_IMR1_IM23_Msk
#define EXTI_IMR1_IM24_Pos   (24U)
#define EXTI_IMR1_IM24_Msk   (0x1UL << EXTI_IMR1_IM24_Pos)
#define EXTI_IMR1_IM24   EXTI_IMR1_IM24_Msk
#define EXTI_IMR1_IM25_Pos   (25U)
#define EXTI_IMR1_IM25_Msk   (0x1UL << EXTI_IMR1_IM25_Pos)
#define EXTI_IMR1_IM25   EXTI_IMR1_IM25_Msk
#define EXTI_EMR1_EM0_Pos   (0U)
#define EXTI_EMR1_EM0_Msk   (0x1UL << EXTI_EMR1_EM0_Pos)
#define EXTI_EMR1_EM0   EXTI_EMR1_EM0_Msk
#define EXTI_EMR1_EM1_Pos   (1U)
#define EXTI_EMR1_EM1_Msk   (0x1UL << EXTI_EMR1_EM1_Pos)
#define EXTI_EMR1_EM1   EXTI_EMR1_EM1_Msk
#define EXTI_EMR1_EM2_Pos   (2U)
#define EXTI_EMR1_EM2_Msk   (0x1UL << EXTI_EMR1_EM2_Pos)
#define EXTI_EMR1_EM2   EXTI_EMR1_EM2_Msk
#define EXTI_EMR1_EM3_Pos   (3U)
#define EXTI_EMR1_EM3_Msk   (0x1UL << EXTI_EMR1_EM3_Pos)
#define EXTI_EMR1_EM3   EXTI_EMR1_EM3_Msk
#define EXTI_EMR1_EM4_Pos   (4U)
#define EXTI_EMR1_EM4_Msk   (0x1UL << EXTI_EMR1_EM4_Pos)
#define EXTI_EMR1_EM4   EXTI_EMR1_EM4_Msk
#define EXTI_EMR1_EM5_Pos   (5U)
#define EXTI_EMR1_EM5_Msk   (0x1UL << EXTI_EMR1_EM5_Pos)
#define EXTI_EMR1_EM5   EXTI_EMR1_EM5_Msk
#define EXTI_EMR1_EM6_Pos   (6U)
#define EXTI_EMR1_EM6_Msk   (0x1UL << EXTI_EMR1_EM6_Pos)
#define EXTI_EMR1_EM6   EXTI_EMR1_EM6_Msk
#define EXTI_EMR1_EM7_Pos   (7U)
#define EXTI_EMR1_EM7_Msk   (0x1UL << EXTI_EMR1_EM7_Pos)
#define EXTI_EMR1_EM7   EXTI_EMR1_EM7_Msk
#define EXTI_EMR1_EM8_Pos   (8U)
#define EXTI_EMR1_EM8_Msk   (0x1UL << EXTI_EMR1_EM8_Pos)
#define EXTI_EMR1_EM8   EXTI_EMR1_EM8_Msk
#define EXTI_EMR1_EM9_Pos   (9U)
#define EXTI_EMR1_EM9_Msk   (0x1UL << EXTI_EMR1_EM9_Pos)
#define EXTI_EMR1_EM9   EXTI_EMR1_EM9_Msk
#define EXTI_EMR1_EM10_Pos   (10U)
#define EXTI_EMR1_EM10_Msk   (0x1UL << EXTI_EMR1_EM10_Pos)
#define EXTI_EMR1_EM10   EXTI_EMR1_EM10_Msk
#define EXTI_EMR1_EM11_Pos   (11U)
#define EXTI_EMR1_EM11_Msk   (0x1UL << EXTI_EMR1_EM11_Pos)
#define EXTI_EMR1_EM11   EXTI_EMR1_EM11_Msk
#define EXTI_EMR1_EM12_Pos   (12U)
#define EXTI_EMR1_EM12_Msk   (0x1UL << EXTI_EMR1_EM12_Pos)
#define EXTI_EMR1_EM12   EXTI_EMR1_EM12_Msk
#define EXTI_EMR1_EM13_Pos   (13U)
#define EXTI_EMR1_EM13_Msk   (0x1UL << EXTI_EMR1_EM13_Pos)
#define EXTI_EMR1_EM13   EXTI_EMR1_EM13_Msk
#define EXTI_EMR1_EM14_Pos   (14U)
#define EXTI_EMR1_EM14_Msk   (0x1UL << EXTI_EMR1_EM14_Pos)
#define EXTI_EMR1_EM14   EXTI_EMR1_EM14_Msk
#define EXTI_EMR1_EM15_Pos   (15U)
#define EXTI_EMR1_EM15_Msk   (0x1UL << EXTI_EMR1_EM15_Pos)
#define EXTI_EMR1_EM15   EXTI_EMR1_EM15_Msk
#define EXTI_EMR1_EM16_Pos   (16U)
#define EXTI_EMR1_EM16_Msk   (0x1UL << EXTI_EMR1_EM16_Pos)
#define EXTI_EMR1_EM16   EXTI_EMR1_EM16_Msk
#define EXTI_EMR1_EM17_Pos   (17U)
#define EXTI_EMR1_EM17_Msk   (0x1UL << EXTI_EMR1_EM17_Pos)
#define EXTI_EMR1_EM17   EXTI_EMR1_EM17_Msk
#define EXTI_EMR1_EM18_Pos   (18U)
#define EXTI_EMR1_EM18_Msk   (0x1UL << EXTI_EMR1_EM18_Pos)
#define EXTI_EMR1_EM18   EXTI_EMR1_EM18_Msk
#define EXTI_EMR1_EM19_Pos   (19U)
#define EXTI_EMR1_EM19_Msk   (0x1UL << EXTI_EMR1_EM19_Pos)
#define EXTI_EMR1_EM19   EXTI_EMR1_EM19_Msk
#define EXTI_EMR1_EM20_Pos   (20U)
#define EXTI_EMR1_EM20_Msk   (0x1UL << EXTI_EMR1_EM20_Pos)
#define EXTI_EMR1_EM20   EXTI_EMR1_EM20_Msk
#define EXTI_EMR1_EM21_Pos   (21U)
#define EXTI_EMR1_EM21_Msk   (0x1UL << EXTI_EMR1_EM21_Pos)
#define EXTI_EMR1_EM21   EXTI_EMR1_EM21_Msk
#define EXTI_EMR1_EM22_Pos   (22U)
#define EXTI_EMR1_EM22_Msk   (0x1UL << EXTI_EMR1_EM22_Pos)
#define EXTI_EMR1_EM22   EXTI_EMR1_EM22_Msk
#define EXTI_EMR1_EM23_Pos   (23U)
#define EXTI_EMR1_EM23_Msk   (0x1UL << EXTI_EMR1_EM23_Pos)
#define EXTI_EMR1_EM23   EXTI_EMR1_EM23_Msk
#define EXTI_EMR1_EM24_Pos   (24U)
#define EXTI_EMR1_EM24_Msk   (0x1UL << EXTI_EMR1_EM24_Pos)
#define EXTI_EMR1_EM24   EXTI_EMR1_EM24_Msk
#define EXTI_EMR1_EM25_Pos   (25U)
#define EXTI_EMR1_EM25_Msk   (0x1UL << EXTI_EMR1_EM25_Pos)
#define EXTI_EMR1_EM25   EXTI_EMR1_EM25_Msk
#define FDCAN_CREL_DAY_Pos   (0U)
#define FDCAN_CREL_DAY_Msk   (0xFFUL << FDCAN_CREL_DAY_Pos)
#define FDCAN_CREL_DAY   FDCAN_CREL_DAY_Msk
#define FDCAN_CREL_MON_Pos   (8U)
#define FDCAN_CREL_MON_Msk   (0xFFUL << FDCAN_CREL_MON_Pos)
#define FDCAN_CREL_MON   FDCAN_CREL_MON_Msk
#define FDCAN_CREL_YEAR_Pos   (16U)
#define FDCAN_CREL_YEAR_Msk   (0xFUL << FDCAN_CREL_YEAR_Pos)
#define FDCAN_CREL_YEAR   FDCAN_CREL_YEAR_Msk
#define FDCAN_CREL_SUBSTEP_Pos   (20U)
#define FDCAN_CREL_SUBSTEP_Msk   (0xFUL << FDCAN_CREL_SUBSTEP_Pos)
#define FDCAN_CREL_SUBSTEP   FDCAN_CREL_SUBSTEP_Msk
#define FDCAN_CREL_STEP_Pos   (24U)
#define FDCAN_CREL_STEP_Msk   (0xFUL << FDCAN_CREL_STEP_Pos)
#define FDCAN_CREL_STEP   FDCAN_CREL_STEP_Msk
#define FDCAN_CREL_REL_Pos   (28U)
#define FDCAN_CREL_REL_Msk   (0xFUL << FDCAN_CREL_REL_Pos)
#define FDCAN_CREL_REL   FDCAN_CREL_REL_Msk
#define FDCAN_ENDN_ETV_Pos   (0U)
#define FDCAN_ENDN_ETV_Msk   (0xFFFFFFFFUL << FDCAN_ENDN_ETV_Pos)
#define FDCAN_ENDN_ETV   FDCAN_ENDN_ETV_Msk
#define FDCAN_DBTP_DSJW_Pos   (0U)
#define FDCAN_DBTP_DSJW_Msk   (0xFUL << FDCAN_DBTP_DSJW_Pos)
#define FDCAN_DBTP_DSJW   FDCAN_DBTP_DSJW_Msk
#define FDCAN_DBTP_DTSEG2_Pos   (4U)
#define FDCAN_DBTP_DTSEG2_Msk   (0xFUL << FDCAN_DBTP_DTSEG2_Pos)
#define FDCAN_DBTP_DTSEG2   FDCAN_DBTP_DTSEG2_Msk
#define FDCAN_DBTP_DTSEG1_Pos   (8U)
#define FDCAN_DBTP_DTSEG1_Msk   (0x1FUL << FDCAN_DBTP_DTSEG1_Pos)
#define FDCAN_DBTP_DTSEG1   FDCAN_DBTP_DTSEG1_Msk
#define FDCAN_DBTP_DBRP_Pos   (16U)
#define FDCAN_DBTP_DBRP_Msk   (0x1FUL << FDCAN_DBTP_DBRP_Pos)
#define FDCAN_DBTP_DBRP   FDCAN_DBTP_DBRP_Msk
#define FDCAN_DBTP_TDC_Pos   (23U)
#define FDCAN_DBTP_TDC_Msk   (0x1UL << FDCAN_DBTP_TDC_Pos)
#define FDCAN_DBTP_TDC   FDCAN_DBTP_TDC_Msk
#define FDCAN_TEST_LBCK_Pos   (4U)
#define FDCAN_TEST_LBCK_Msk   (0x1UL << FDCAN_TEST_LBCK_Pos)
#define FDCAN_TEST_LBCK   FDCAN_TEST_LBCK_Msk
#define FDCAN_TEST_TX_Pos   (5U)
#define FDCAN_TEST_TX_Msk   (0x3UL << FDCAN_TEST_TX_Pos)
#define FDCAN_TEST_TX   FDCAN_TEST_TX_Msk
#define FDCAN_TEST_RX_Pos   (7U)
#define FDCAN_TEST_RX_Msk   (0x1UL << FDCAN_TEST_RX_Pos)
#define FDCAN_TEST_RX   FDCAN_TEST_RX_Msk
#define FDCAN_RWD_WDC_Pos   (0U)
#define FDCAN_RWD_WDC_Msk   (0xFFUL << FDCAN_RWD_WDC_Pos)
#define FDCAN_RWD_WDC   FDCAN_RWD_WDC_Msk
#define FDCAN_RWD_WDV_Pos   (8U)
#define FDCAN_RWD_WDV_Msk   (0xFFUL << FDCAN_RWD_WDV_Pos)
#define FDCAN_RWD_WDV   FDCAN_RWD_WDV_Msk
#define FDCAN_CCCR_INIT_Pos   (0U)
#define FDCAN_CCCR_INIT_Msk   (0x1UL << FDCAN_CCCR_INIT_Pos)
#define FDCAN_CCCR_INIT   FDCAN_CCCR_INIT_Msk
#define FDCAN_CCCR_CCE_Pos   (1U)
#define FDCAN_CCCR_CCE_Msk   (0x1UL << FDCAN_CCCR_CCE_Pos)
#define FDCAN_CCCR_CCE   FDCAN_CCCR_CCE_Msk
#define FDCAN_CCCR_ASM_Pos   (2U)
#define FDCAN_CCCR_ASM_Msk   (0x1UL << FDCAN_CCCR_ASM_Pos)
#define FDCAN_CCCR_ASM   FDCAN_CCCR_ASM_Msk
#define FDCAN_CCCR_CSA_Pos   (3U)
#define FDCAN_CCCR_CSA_Msk   (0x1UL << FDCAN_CCCR_CSA_Pos)
#define FDCAN_CCCR_CSA   FDCAN_CCCR_CSA_Msk
#define FDCAN_CCCR_CSR_Pos   (4U)
#define FDCAN_CCCR_CSR_Msk   (0x1UL << FDCAN_CCCR_CSR_Pos)
#define FDCAN_CCCR_CSR   FDCAN_CCCR_CSR_Msk
#define FDCAN_CCCR_MON_Pos   (5U)
#define FDCAN_CCCR_MON_Msk   (0x1UL << FDCAN_CCCR_MON_Pos)
#define FDCAN_CCCR_MON   FDCAN_CCCR_MON_Msk
#define FDCAN_CCCR_DAR_Pos   (6U)
#define FDCAN_CCCR_DAR_Msk   (0x1UL << FDCAN_CCCR_DAR_Pos)
#define FDCAN_CCCR_DAR   FDCAN_CCCR_DAR_Msk
#define FDCAN_CCCR_TEST_Pos   (7U)
#define FDCAN_CCCR_TEST_Msk   (0x1UL << FDCAN_CCCR_TEST_Pos)
#define FDCAN_CCCR_TEST   FDCAN_CCCR_TEST_Msk
#define FDCAN_CCCR_FDOE_Pos   (8U)
#define FDCAN_CCCR_FDOE_Msk   (0x1UL << FDCAN_CCCR_FDOE_Pos)
#define FDCAN_CCCR_FDOE   FDCAN_CCCR_FDOE_Msk
#define FDCAN_CCCR_BRSE_Pos   (9U)
#define FDCAN_CCCR_BRSE_Msk   (0x1UL << FDCAN_CCCR_BRSE_Pos)
#define FDCAN_CCCR_BRSE   FDCAN_CCCR_BRSE_Msk
#define FDCAN_CCCR_PXHD_Pos   (12U)
#define FDCAN_CCCR_PXHD_Msk   (0x1UL << FDCAN_CCCR_PXHD_Pos)
#define FDCAN_CCCR_PXHD   FDCAN_CCCR_PXHD_Msk
#define FDCAN_CCCR_EFBI_Pos   (13U)
#define FDCAN_CCCR_EFBI_Msk   (0x1UL << FDCAN_CCCR_EFBI_Pos)
#define FDCAN_CCCR_EFBI   FDCAN_CCCR_EFBI_Msk
#define FDCAN_CCCR_TXP_Pos   (14U)
#define FDCAN_CCCR_TXP_Msk   (0x1UL << FDCAN_CCCR_TXP_Pos)
#define FDCAN_CCCR_TXP   FDCAN_CCCR_TXP_Msk
#define FDCAN_CCCR_NISO_Pos   (15U)
#define FDCAN_CCCR_NISO_Msk   (0x1UL << FDCAN_CCCR_NISO_Pos)
#define FDCAN_CCCR_NISO   FDCAN_CCCR_NISO_Msk
#define FDCAN_NBTP_NTSEG2_Pos   (0U)
#define FDCAN_NBTP_NTSEG2_Msk   (0x7FUL << FDCAN_NBTP_NTSEG2_Pos)
#define FDCAN_NBTP_NTSEG2   FDCAN_NBTP_NTSEG2_Msk
#define FDCAN_NBTP_NTSEG1_Pos   (8U)
#define FDCAN_NBTP_NTSEG1_Msk   (0xFFUL << FDCAN_NBTP_NTSEG1_Pos)
#define FDCAN_NBTP_NTSEG1   FDCAN_NBTP_NTSEG1_Msk
#define FDCAN_NBTP_NBRP_Pos   (16U)
#define FDCAN_NBTP_NBRP_Msk   (0x1FFUL << FDCAN_NBTP_NBRP_Pos)
#define FDCAN_NBTP_NBRP   FDCAN_NBTP_NBRP_Msk
#define FDCAN_NBTP_NSJW_Pos   (25U)
#define FDCAN_NBTP_NSJW_Msk   (0x7FUL << FDCAN_NBTP_NSJW_Pos)
#define FDCAN_NBTP_NSJW   FDCAN_NBTP_NSJW_Msk
#define FDCAN_TSCC_TSS_Pos   (0U)
#define FDCAN_TSCC_TSS_Msk   (0x3UL << FDCAN_TSCC_TSS_Pos)
#define FDCAN_TSCC_TSS   FDCAN_TSCC_TSS_Msk
#define FDCAN_TSCC_TCP_Pos   (16U)
#define FDCAN_TSCC_TCP_Msk   (0xFUL << FDCAN_TSCC_TCP_Pos)
#define FDCAN_TSCC_TCP   FDCAN_TSCC_TCP_Msk
#define FDCAN_TSCV_TSC_Pos   (0U)
#define FDCAN_TSCV_TSC_Msk   (0xFFFFUL << FDCAN_TSCV_TSC_Pos)
#define FDCAN_TSCV_TSC   FDCAN_TSCV_TSC_Msk
#define FDCAN_TOCC_ETOC_Pos   (0U)
#define FDCAN_TOCC_ETOC_Msk   (0x1UL << FDCAN_TOCC_ETOC_Pos)
#define FDCAN_TOCC_ETOC   FDCAN_TOCC_ETOC_Msk
#define FDCAN_TOCC_TOS_Pos   (1U)
#define FDCAN_TOCC_TOS_Msk   (0x3UL << FDCAN_TOCC_TOS_Pos)
#define FDCAN_TOCC_TOS   FDCAN_TOCC_TOS_Msk
#define FDCAN_TOCC_TOP_Pos   (16U)
#define FDCAN_TOCC_TOP_Msk   (0xFFFFUL << FDCAN_TOCC_TOP_Pos)
#define FDCAN_TOCC_TOP   FDCAN_TOCC_TOP_Msk
#define FDCAN_TOCV_TOC_Pos   (0U)
#define FDCAN_TOCV_TOC_Msk   (0xFFFFUL << FDCAN_TOCV_TOC_Pos)
#define FDCAN_TOCV_TOC   FDCAN_TOCV_TOC_Msk
#define FDCAN_ECR_TEC_Pos   (0U)
#define FDCAN_ECR_TEC_Msk   (0xFFUL << FDCAN_ECR_TEC_Pos)
#define FDCAN_ECR_TEC   FDCAN_ECR_TEC_Msk
#define FDCAN_ECR_REC_Pos   (8U)
#define FDCAN_ECR_REC_Msk   (0x7FUL << FDCAN_ECR_REC_Pos)
#define FDCAN_ECR_REC   FDCAN_ECR_REC_Msk
#define FDCAN_ECR_RP_Pos   (15U)
#define FDCAN_ECR_RP_Msk   (0x1UL << FDCAN_ECR_RP_Pos)
#define FDCAN_ECR_RP   FDCAN_ECR_RP_Msk
#define FDCAN_ECR_CEL_Pos   (16U)
#define FDCAN_ECR_CEL_Msk   (0xFFUL << FDCAN_ECR_CEL_Pos)
#define FDCAN_ECR_CEL   FDCAN_ECR_CEL_Msk
#define FDCAN_PSR_LEC_Pos   (0U)
#define FDCAN_PSR_LEC_Msk   (0x7UL << FDCAN_PSR_LEC_Pos)
#define FDCAN_PSR_LEC   FDCAN_PSR_LEC_Msk
#define FDCAN_PSR_ACT_Pos   (3U)
#define FDCAN_PSR_ACT_Msk   (0x3UL << FDCAN_PSR_ACT_Pos)
#define FDCAN_PSR_ACT   FDCAN_PSR_ACT_Msk
#define FDCAN_PSR_EP_Pos   (5U)
#define FDCAN_PSR_EP_Msk   (0x1UL << FDCAN_PSR_EP_Pos)
#define FDCAN_PSR_EP   FDCAN_PSR_EP_Msk
#define FDCAN_PSR_EW_Pos   (6U)
#define FDCAN_PSR_EW_Msk   (0x1UL << FDCAN_PSR_EW_Pos)
#define FDCAN_PSR_EW   FDCAN_PSR_EW_Msk
#define FDCAN_PSR_BO_Pos   (7U)
#define FDCAN_PSR_BO_Msk   (0x1UL << FDCAN_PSR_BO_Pos)
#define FDCAN_PSR_BO   FDCAN_PSR_BO_Msk
#define FDCAN_PSR_DLEC_Pos   (8U)
#define FDCAN_PSR_DLEC_Msk   (0x7UL << FDCAN_PSR_DLEC_Pos)
#define FDCAN_PSR_DLEC   FDCAN_PSR_DLEC_Msk
#define FDCAN_PSR_RESI_Pos   (11U)
#define FDCAN_PSR_RESI_Msk   (0x1UL << FDCAN_PSR_RESI_Pos)
#define FDCAN_PSR_RESI   FDCAN_PSR_RESI_Msk
#define FDCAN_PSR_RBRS_Pos   (12U)
#define FDCAN_PSR_RBRS_Msk   (0x1UL << FDCAN_PSR_RBRS_Pos)
#define FDCAN_PSR_RBRS   FDCAN_PSR_RBRS_Msk
#define FDCAN_PSR_REDL_Pos   (13U)
#define FDCAN_PSR_REDL_Msk   (0x1UL << FDCAN_PSR_REDL_Pos)
#define FDCAN_PSR_REDL   FDCAN_PSR_REDL_Msk
#define FDCAN_PSR_PXE_Pos   (14U)
#define FDCAN_PSR_PXE_Msk   (0x1UL << FDCAN_PSR_PXE_Pos)
#define FDCAN_PSR_PXE   FDCAN_PSR_PXE_Msk
#define FDCAN_PSR_TDCV_Pos   (16U)
#define FDCAN_PSR_TDCV_Msk   (0x7FUL << FDCAN_PSR_TDCV_Pos)
#define FDCAN_PSR_TDCV   FDCAN_PSR_TDCV_Msk
#define FDCAN_TDCR_TDCF_Pos   (0U)
#define FDCAN_TDCR_TDCF_Msk   (0x7FUL << FDCAN_TDCR_TDCF_Pos)
#define FDCAN_TDCR_TDCF   FDCAN_TDCR_TDCF_Msk
#define FDCAN_TDCR_TDCO_Pos   (8U)
#define FDCAN_TDCR_TDCO_Msk   (0x7FUL << FDCAN_TDCR_TDCO_Pos)
#define FDCAN_TDCR_TDCO   FDCAN_TDCR_TDCO_Msk
#define FDCAN_IR_RF0N_Pos   (0U)
#define FDCAN_IR_RF0N_Msk   (0x1UL << FDCAN_IR_RF0N_Pos)
#define FDCAN_IR_RF0N   FDCAN_IR_RF0N_Msk
#define FDCAN_IR_RF0F_Pos   (1U)
#define FDCAN_IR_RF0F_Msk   (0x1UL << FDCAN_IR_RF0F_Pos)
#define FDCAN_IR_RF0F   FDCAN_IR_RF0F_Msk
#define FDCAN_IR_RF0L_Pos   (2U)
#define FDCAN_IR_RF0L_Msk   (0x1UL << FDCAN_IR_RF0L_Pos)
#define FDCAN_IR_RF0L   FDCAN_IR_RF0L_Msk
#define FDCAN_IR_RF1N_Pos   (3U)
#define FDCAN_IR_RF1N_Msk   (0x1UL << FDCAN_IR_RF1N_Pos)
#define FDCAN_IR_RF1N   FDCAN_IR_RF1N_Msk
#define FDCAN_IR_RF1F_Pos   (4U)
#define FDCAN_IR_RF1F_Msk   (0x1UL << FDCAN_IR_RF1F_Pos)
#define FDCAN_IR_RF1F   FDCAN_IR_RF1F_Msk
#define FDCAN_IR_RF1L_Pos   (5U)
#define FDCAN_IR_RF1L_Msk   (0x1UL << FDCAN_IR_RF1L_Pos)
#define FDCAN_IR_RF1L   FDCAN_IR_RF1L_Msk
#define FDCAN_IR_HPM_Pos   (6U)
#define FDCAN_IR_HPM_Msk   (0x1UL << FDCAN_IR_HPM_Pos)
#define FDCAN_IR_HPM   FDCAN_IR_HPM_Msk
#define FDCAN_IR_TC_Pos   (7U)
#define FDCAN_IR_TC_Msk   (0x1UL << FDCAN_IR_TC_Pos)
#define FDCAN_IR_TC   FDCAN_IR_TC_Msk
#define FDCAN_IR_TCF_Pos   (8U)
#define FDCAN_IR_TCF_Msk   (0x1UL << FDCAN_IR_TCF_Pos)
#define FDCAN_IR_TCF   FDCAN_IR_TCF_Msk
#define FDCAN_IR_TFE_Pos   (9U)
#define FDCAN_IR_TFE_Msk   (0x1UL << FDCAN_IR_TFE_Pos)
#define FDCAN_IR_TFE   FDCAN_IR_TFE_Msk
#define FDCAN_IR_TEFN_Pos   (10U)
#define FDCAN_IR_TEFN_Msk   (0x1UL << FDCAN_IR_TEFN_Pos)
#define FDCAN_IR_TEFN   FDCAN_IR_TEFN_Msk
#define FDCAN_IR_TEFF_Pos   (11U)
#define FDCAN_IR_TEFF_Msk   (0x1UL << FDCAN_IR_TEFF_Pos)
#define FDCAN_IR_TEFF   FDCAN_IR_TEFF_Msk
#define FDCAN_IR_TEFL_Pos   (12U)
#define FDCAN_IR_TEFL_Msk   (0x1UL << FDCAN_IR_TEFL_Pos)
#define FDCAN_IR_TEFL   FDCAN_IR_TEFL_Msk
#define FDCAN_IR_TSW_Pos   (13U)
#define FDCAN_IR_TSW_Msk   (0x1UL << FDCAN_IR_TSW_Pos)
#define FDCAN_IR_TSW   FDCAN_IR_TSW_Msk
#define FDCAN_IR_MRAF_Pos   (14U)
#define FDCAN_IR_MRAF_Msk   (0x1UL << FDCAN_IR_MRAF_Pos)
#define FDCAN_IR_MRAF   FDCAN_IR_MRAF_Msk
#define FDCAN_IR_TOO_Pos   (15U)
#define FDCAN_IR_TOO_Msk   (0x1UL << FDCAN_IR_TOO_Pos)
#define FDCAN_IR_TOO   FDCAN_IR_TOO_Msk
#define FDCAN_IR_ELO_Pos   (16U)
#define FDCAN_IR_ELO_Msk   (0x1UL << FDCAN_IR_ELO_Pos)
#define FDCAN_IR_ELO   FDCAN_IR_ELO_Msk
#define FDCAN_IR_EP_Pos   (17U)
#define FDCAN_IR_EP_Msk   (0x1UL << FDCAN_IR_EP_Pos)
#define FDCAN_IR_EP   FDCAN_IR_EP_Msk
#define FDCAN_IR_EW_Pos   (18U)
#define FDCAN_IR_EW_Msk   (0x1UL << FDCAN_IR_EW_Pos)
#define FDCAN_IR_EW   FDCAN_IR_EW_Msk
#define FDCAN_IR_BO_Pos   (19U)
#define FDCAN_IR_BO_Msk   (0x1UL << FDCAN_IR_BO_Pos)
#define FDCAN_IR_BO   FDCAN_IR_BO_Msk
#define FDCAN_IR_WDI_Pos   (20U)
#define FDCAN_IR_WDI_Msk   (0x1UL << FDCAN_IR_WDI_Pos)
#define FDCAN_IR_WDI   FDCAN_IR_WDI_Msk
#define FDCAN_IR_PEA_Pos   (21U)
#define FDCAN_IR_PEA_Msk   (0x1UL << FDCAN_IR_PEA_Pos)
#define FDCAN_IR_PEA   FDCAN_IR_PEA_Msk
#define FDCAN_IR_PED_Pos   (22U)
#define FDCAN_IR_PED_Msk   (0x1UL << FDCAN_IR_PED_Pos)
#define FDCAN_IR_PED   FDCAN_IR_PED_Msk
#define FDCAN_IR_ARA_Pos   (23U)
#define FDCAN_IR_ARA_Msk   (0x1UL << FDCAN_IR_ARA_Pos)
#define FDCAN_IR_ARA   FDCAN_IR_ARA_Msk
#define FDCAN_IE_RF0NE_Pos   (0U)
#define FDCAN_IE_RF0NE_Msk   (0x1UL << FDCAN_IE_RF0NE_Pos)
#define FDCAN_IE_RF0NE   FDCAN_IE_RF0NE_Msk
#define FDCAN_IE_RF0FE_Pos   (1U)
#define FDCAN_IE_RF0FE_Msk   (0x1UL << FDCAN_IE_RF0FE_Pos)
#define FDCAN_IE_RF0FE   FDCAN_IE_RF0FE_Msk
#define FDCAN_IE_RF0LE_Pos   (2U)
#define FDCAN_IE_RF0LE_Msk   (0x1UL << FDCAN_IE_RF0LE_Pos)
#define FDCAN_IE_RF0LE   FDCAN_IE_RF0LE_Msk
#define FDCAN_IE_RF1NE_Pos   (3U)
#define FDCAN_IE_RF1NE_Msk   (0x1UL << FDCAN_IE_RF1NE_Pos)
#define FDCAN_IE_RF1NE   FDCAN_IE_RF1NE_Msk
#define FDCAN_IE_RF1FE_Pos   (4U)
#define FDCAN_IE_RF1FE_Msk   (0x1UL << FDCAN_IE_RF1FE_Pos)
#define FDCAN_IE_RF1FE   FDCAN_IE_RF1FE_Msk
#define FDCAN_IE_RF1LE_Pos   (5U)
#define FDCAN_IE_RF1LE_Msk   (0x1UL << FDCAN_IE_RF1LE_Pos)
#define FDCAN_IE_RF1LE   FDCAN_IE_RF1LE_Msk
#define FDCAN_IE_HPME_Pos   (6U)
#define FDCAN_IE_HPME_Msk   (0x1UL << FDCAN_IE_HPME_Pos)
#define FDCAN_IE_HPME   FDCAN_IE_HPME_Msk
#define FDCAN_IE_TCE_Pos   (7U)
#define FDCAN_IE_TCE_Msk   (0x1UL << FDCAN_IE_TCE_Pos)
#define FDCAN_IE_TCE   FDCAN_IE_TCE_Msk
#define FDCAN_IE_TCFE_Pos   (8U)
#define FDCAN_IE_TCFE_Msk   (0x1UL << FDCAN_IE_TCFE_Pos)
#define FDCAN_IE_TCFE   FDCAN_IE_TCFE_Msk
#define FDCAN_IE_TFEE_Pos   (9U)
#define FDCAN_IE_TFEE_Msk   (0x1UL << FDCAN_IE_TFEE_Pos)
#define FDCAN_IE_TFEE   FDCAN_IE_TFEE_Msk
#define FDCAN_IE_TEFNE_Pos   (10U)
#define FDCAN_IE_TEFNE_Msk   (0x1UL << FDCAN_IE_TEFNE_Pos)
#define FDCAN_IE_TEFNE   FDCAN_IE_TEFNE_Msk
#define FDCAN_IE_TEFFE_Pos   (11U)
#define FDCAN_IE_TEFFE_Msk   (0x1UL << FDCAN_IE_TEFFE_Pos)
#define FDCAN_IE_TEFFE   FDCAN_IE_TEFFE_Msk
#define FDCAN_IE_TEFLE_Pos   (12U)
#define FDCAN_IE_TEFLE_Msk   (0x1UL << FDCAN_IE_TEFLE_Pos)
#define FDCAN_IE_TEFLE   FDCAN_IE_TEFLE_Msk
#define FDCAN_IE_TSWE_Pos   (13U)
#define FDCAN_IE_TSWE_Msk   (0x1UL << FDCAN_IE_TSWE_Pos)
#define FDCAN_IE_TSWE   FDCAN_IE_TSWE_Msk
#define FDCAN_IE_MRAFE_Pos   (14U)
#define FDCAN_IE_MRAFE_Msk   (0x1UL << FDCAN_IE_MRAFE_Pos)
#define FDCAN_IE_MRAFE   FDCAN_IE_MRAFE_Msk
#define FDCAN_IE_TOOE_Pos   (15U)
#define FDCAN_IE_TOOE_Msk   (0x1UL << FDCAN_IE_TOOE_Pos)
#define FDCAN_IE_TOOE   FDCAN_IE_TOOE_Msk
#define FDCAN_IE_ELOE_Pos   (16U)
#define FDCAN_IE_ELOE_Msk   (0x1UL << FDCAN_IE_ELOE_Pos)
#define FDCAN_IE_ELOE   FDCAN_IE_ELOE_Msk
#define FDCAN_IE_EPE_Pos   (17U)
#define FDCAN_IE_EPE_Msk   (0x1UL << FDCAN_IE_EPE_Pos)
#define FDCAN_IE_EPE   FDCAN_IE_EPE_Msk
#define FDCAN_IE_EWE_Pos   (18U)
#define FDCAN_IE_EWE_Msk   (0x1UL << FDCAN_IE_EWE_Pos)
#define FDCAN_IE_EWE   FDCAN_IE_EWE_Msk
#define FDCAN_IE_BOE_Pos   (19U)
#define FDCAN_IE_BOE_Msk   (0x1UL << FDCAN_IE_BOE_Pos)
#define FDCAN_IE_BOE   FDCAN_IE_BOE_Msk
#define FDCAN_IE_WDIE_Pos   (20U)
#define FDCAN_IE_WDIE_Msk   (0x1UL << FDCAN_IE_WDIE_Pos)
#define FDCAN_IE_WDIE   FDCAN_IE_WDIE_Msk
#define FDCAN_IE_PEAE_Pos   (21U)
#define FDCAN_IE_PEAE_Msk   (0x1UL << FDCAN_IE_PEAE_Pos)
#define FDCAN_IE_PEAE   FDCAN_IE_PEAE_Msk
#define FDCAN_IE_PEDE_Pos   (22U)
#define FDCAN_IE_PEDE_Msk   (0x1UL << FDCAN_IE_PEDE_Pos)
#define FDCAN_IE_PEDE   FDCAN_IE_PEDE_Msk
#define FDCAN_IE_ARAE_Pos   (23U)
#define FDCAN_IE_ARAE_Msk   (0x1UL << FDCAN_IE_ARAE_Pos)
#define FDCAN_IE_ARAE   FDCAN_IE_ARAE_Msk
#define FDCAN_ILS_RXFIFO0_Pos   (0U)
#define FDCAN_ILS_RXFIFO0_Msk   (0x1UL << FDCAN_ILS_RXFIFO0_Pos)
#define FDCAN_ILS_RXFIFO0   FDCAN_ILS_RXFIFO0_Msk
#define FDCAN_ILS_RXFIFO1_Pos   (1U)
#define FDCAN_ILS_RXFIFO1_Msk   (0x1UL << FDCAN_ILS_RXFIFO1_Pos)
#define FDCAN_ILS_RXFIFO1   FDCAN_ILS_RXFIFO1_Msk
#define FDCAN_ILS_SMSG_Pos   (2U)
#define FDCAN_ILS_SMSG_Msk   (0x1UL << FDCAN_ILS_SMSG_Pos)
#define FDCAN_ILS_SMSG   FDCAN_ILS_SMSG_Msk
#define FDCAN_ILS_TFERR_Pos   (3U)
#define FDCAN_ILS_TFERR_Msk   (0x1UL << FDCAN_ILS_TFERR_Pos)
#define FDCAN_ILS_TFERR   FDCAN_ILS_TFERR_Msk
#define FDCAN_ILS_MISC_Pos   (4U)
#define FDCAN_ILS_MISC_Msk   (0x1UL << FDCAN_ILS_MISC_Pos)
#define FDCAN_ILS_MISC   FDCAN_ILS_MISC_Msk
#define FDCAN_ILS_BERR_Pos   (5U)
#define FDCAN_ILS_BERR_Msk   (0x1UL << FDCAN_ILS_BERR_Pos)
#define FDCAN_ILS_BERR   FDCAN_ILS_BERR_Msk
#define FDCAN_ILS_PERR_Pos   (6U)
#define FDCAN_ILS_PERR_Msk   (0x1UL << FDCAN_ILS_PERR_Pos)
#define FDCAN_ILS_PERR   FDCAN_ILS_PERR_Msk
#define FDCAN_ILE_EINT0_Pos   (0U)
#define FDCAN_ILE_EINT0_Msk   (0x1UL << FDCAN_ILE_EINT0_Pos)
#define FDCAN_ILE_EINT0   FDCAN_ILE_EINT0_Msk
#define FDCAN_ILE_EINT1_Pos   (1U)
#define FDCAN_ILE_EINT1_Msk   (0x1UL << FDCAN_ILE_EINT1_Pos)
#define FDCAN_ILE_EINT1   FDCAN_ILE_EINT1_Msk
#define FDCAN_RXGFC_RRFE_Pos   (0U)
#define FDCAN_RXGFC_RRFE_Msk   (0x1UL << FDCAN_RXGFC_RRFE_Pos)
#define FDCAN_RXGFC_RRFE   FDCAN_RXGFC_RRFE_Msk
#define FDCAN_RXGFC_RRFS_Pos   (1U)
#define FDCAN_RXGFC_RRFS_Msk   (0x1UL << FDCAN_RXGFC_RRFS_Pos)
#define FDCAN_RXGFC_RRFS   FDCAN_RXGFC_RRFS_Msk
#define FDCAN_RXGFC_ANFE_Pos   (2U)
#define FDCAN_RXGFC_ANFE_Msk   (0x3UL << FDCAN_RXGFC_ANFE_Pos)
#define FDCAN_RXGFC_ANFE   FDCAN_RXGFC_ANFE_Msk
#define FDCAN_RXGFC_ANFS_Pos   (4U)
#define FDCAN_RXGFC_ANFS_Msk   (0x3UL << FDCAN_RXGFC_ANFS_Pos)
#define FDCAN_RXGFC_ANFS   FDCAN_RXGFC_ANFS_Msk
#define FDCAN_RXGFC_F1OM_Pos   (8U)
#define FDCAN_RXGFC_F1OM_Msk   (0x1UL << FDCAN_RXGFC_F1OM_Pos)
#define FDCAN_RXGFC_F1OM   FDCAN_RXGFC_F1OM_Msk
#define FDCAN_RXGFC_F0OM_Pos   (9U)
#define FDCAN_RXGFC_F0OM_Msk   (0x1UL << FDCAN_RXGFC_F0OM_Pos)
#define FDCAN_RXGFC_F0OM   FDCAN_RXGFC_F0OM_Msk
#define FDCAN_RXGFC_LSS_Pos   (16U)
#define FDCAN_RXGFC_LSS_Msk   (0x1FUL << FDCAN_RXGFC_LSS_Pos)
#define FDCAN_RXGFC_LSS   FDCAN_RXGFC_LSS_Msk
#define FDCAN_RXGFC_LSE_Pos   (24U)
#define FDCAN_RXGFC_LSE_Msk   (0xFUL << FDCAN_RXGFC_LSE_Pos)
#define FDCAN_RXGFC_LSE   FDCAN_RXGFC_LSE_Msk
#define FDCAN_XIDAM_EIDM_Pos   (0U)
#define FDCAN_XIDAM_EIDM_Msk   (0x1FFFFFFFUL << FDCAN_XIDAM_EIDM_Pos)
#define FDCAN_XIDAM_EIDM   FDCAN_XIDAM_EIDM_Msk
#define FDCAN_HPMS_BIDX_Pos   (0U)
#define FDCAN_HPMS_BIDX_Msk   (0x7UL << FDCAN_HPMS_BIDX_Pos)
#define FDCAN_HPMS_BIDX   FDCAN_HPMS_BIDX_Msk
#define FDCAN_HPMS_MSI_Pos   (6U)
#define FDCAN_HPMS_MSI_Msk   (0x3UL << FDCAN_HPMS_MSI_Pos)
#define FDCAN_HPMS_MSI   FDCAN_HPMS_MSI_Msk
#define FDCAN_HPMS_FIDX_Pos   (8U)
#define FDCAN_HPMS_FIDX_Msk   (0x1FUL << FDCAN_HPMS_FIDX_Pos)
#define FDCAN_HPMS_FIDX   FDCAN_HPMS_FIDX_Msk
#define FDCAN_HPMS_FLST_Pos   (15U)
#define FDCAN_HPMS_FLST_Msk   (0x1UL << FDCAN_HPMS_FLST_Pos)
#define FDCAN_HPMS_FLST   FDCAN_HPMS_FLST_Msk
#define FDCAN_RXF0S_F0FL_Pos   (0U)
#define FDCAN_RXF0S_F0FL_Msk   (0xFUL << FDCAN_RXF0S_F0FL_Pos)
#define FDCAN_RXF0S_F0FL   FDCAN_RXF0S_F0FL_Msk
#define FDCAN_RXF0S_F0GI_Pos   (8U)
#define FDCAN_RXF0S_F0GI_Msk   (0x3UL << FDCAN_RXF0S_F0GI_Pos)
#define FDCAN_RXF0S_F0GI   FDCAN_RXF0S_F0GI_Msk
#define FDCAN_RXF0S_F0PI_Pos   (16U)
#define FDCAN_RXF0S_F0PI_Msk   (0x3UL << FDCAN_RXF0S_F0PI_Pos)
#define FDCAN_RXF0S_F0PI   FDCAN_RXF0S_F0PI_Msk
#define FDCAN_RXF0S_F0F_Pos   (24U)
#define FDCAN_RXF0S_F0F_Msk   (0x1UL << FDCAN_RXF0S_F0F_Pos)
#define FDCAN_RXF0S_F0F   FDCAN_RXF0S_F0F_Msk
#define FDCAN_RXF0S_RF0L_Pos   (25U)
#define FDCAN_RXF0S_RF0L_Msk   (0x1UL << FDCAN_RXF0S_RF0L_Pos)
#define FDCAN_RXF0S_RF0L   FDCAN_RXF0S_RF0L_Msk
#define FDCAN_RXF0A_F0AI_Pos   (0U)
#define FDCAN_RXF0A_F0AI_Msk   (0x7UL << FDCAN_RXF0A_F0AI_Pos)
#define FDCAN_RXF0A_F0AI   FDCAN_RXF0A_F0AI_Msk
#define FDCAN_RXF1S_F1FL_Pos   (0U)
#define FDCAN_RXF1S_F1FL_Msk   (0xFUL << FDCAN_RXF1S_F1FL_Pos)
#define FDCAN_RXF1S_F1FL   FDCAN_RXF1S_F1FL_Msk
#define FDCAN_RXF1S_F1GI_Pos   (8U)
#define FDCAN_RXF1S_F1GI_Msk   (0x3UL << FDCAN_RXF1S_F1GI_Pos)
#define FDCAN_RXF1S_F1GI   FDCAN_RXF1S_F1GI_Msk
#define FDCAN_RXF1S_F1PI_Pos   (16U)
#define FDCAN_RXF1S_F1PI_Msk   (0x3UL << FDCAN_RXF1S_F1PI_Pos)
#define FDCAN_RXF1S_F1PI   FDCAN_RXF1S_F1PI_Msk
#define FDCAN_RXF1S_F1F_Pos   (24U)
#define FDCAN_RXF1S_F1F_Msk   (0x1UL << FDCAN_RXF1S_F1F_Pos)
#define FDCAN_RXF1S_F1F   FDCAN_RXF1S_F1F_Msk
#define FDCAN_RXF1S_RF1L_Pos   (25U)
#define FDCAN_RXF1S_RF1L_Msk   (0x1UL << FDCAN_RXF1S_RF1L_Pos)
#define FDCAN_RXF1S_RF1L   FDCAN_RXF1S_RF1L_Msk
#define FDCAN_RXF1A_F1AI_Pos   (0U)
#define FDCAN_RXF1A_F1AI_Msk   (0x7UL << FDCAN_RXF1A_F1AI_Pos)
#define FDCAN_RXF1A_F1AI   FDCAN_RXF1A_F1AI_Msk
#define FDCAN_TXBC_TFQM_Pos   (24U)
#define FDCAN_TXBC_TFQM_Msk   (0x1UL << FDCAN_TXBC_TFQM_Pos)
#define FDCAN_TXBC_TFQM   FDCAN_TXBC_TFQM_Msk
#define FDCAN_TXFQS_TFFL_Pos   (0U)
#define FDCAN_TXFQS_TFFL_Msk   (0x7UL << FDCAN_TXFQS_TFFL_Pos)
#define FDCAN_TXFQS_TFFL   FDCAN_TXFQS_TFFL_Msk
#define FDCAN_TXFQS_TFGI_Pos   (8U)
#define FDCAN_TXFQS_TFGI_Msk   (0x3UL << FDCAN_TXFQS_TFGI_Pos)
#define FDCAN_TXFQS_TFGI   FDCAN_TXFQS_TFGI_Msk
#define FDCAN_TXFQS_TFQPI_Pos   (16U)
#define FDCAN_TXFQS_TFQPI_Msk   (0x3UL << FDCAN_TXFQS_TFQPI_Pos)
#define FDCAN_TXFQS_TFQPI   FDCAN_TXFQS_TFQPI_Msk
#define FDCAN_TXFQS_TFQF_Pos   (21U)
#define FDCAN_TXFQS_TFQF_Msk   (0x1UL << FDCAN_TXFQS_TFQF_Pos)
#define FDCAN_TXFQS_TFQF   FDCAN_TXFQS_TFQF_Msk
#define FDCAN_TXBRP_TRP_Pos   (0U)
#define FDCAN_TXBRP_TRP_Msk   (0x7UL << FDCAN_TXBRP_TRP_Pos)
#define FDCAN_TXBRP_TRP   FDCAN_TXBRP_TRP_Msk
#define FDCAN_TXBAR_AR_Pos   (0U)
#define FDCAN_TXBAR_AR_Msk   (0x7UL << FDCAN_TXBAR_AR_Pos)
#define FDCAN_TXBAR_AR   FDCAN_TXBAR_AR_Msk
#define FDCAN_TXBCR_CR_Pos   (0U)
#define FDCAN_TXBCR_CR_Msk   (0x7UL << FDCAN_TXBCR_CR_Pos)
#define FDCAN_TXBCR_CR   FDCAN_TXBCR_CR_Msk
#define FDCAN_TXBTO_TO_Pos   (0U)
#define FDCAN_TXBTO_TO_Msk   (0x7UL << FDCAN_TXBTO_TO_Pos)
#define FDCAN_TXBTO_TO   FDCAN_TXBTO_TO_Msk
#define FDCAN_TXBCF_CF_Pos   (0U)
#define FDCAN_TXBCF_CF_Msk   (0x7UL << FDCAN_TXBCF_CF_Pos)
#define FDCAN_TXBCF_CF   FDCAN_TXBCF_CF_Msk
#define FDCAN_TXBTIE_TIE_Pos   (0U)
#define FDCAN_TXBTIE_TIE_Msk   (0x7UL << FDCAN_TXBTIE_TIE_Pos)
#define FDCAN_TXBTIE_TIE   FDCAN_TXBTIE_TIE_Msk
#define FDCAN_TXBCIE_CFIE_Pos   (0U)
#define FDCAN_TXBCIE_CFIE_Msk   (0x7UL << FDCAN_TXBCIE_CFIE_Pos)
#define FDCAN_TXBCIE_CFIE   FDCAN_TXBCIE_CFIE_Msk
#define FDCAN_TXEFS_EFFL_Pos   (0U)
#define FDCAN_TXEFS_EFFL_Msk   (0x7UL << FDCAN_TXEFS_EFFL_Pos)
#define FDCAN_TXEFS_EFFL   FDCAN_TXEFS_EFFL_Msk
#define FDCAN_TXEFS_EFGI_Pos   (8U)
#define FDCAN_TXEFS_EFGI_Msk   (0x3UL << FDCAN_TXEFS_EFGI_Pos)
#define FDCAN_TXEFS_EFGI   FDCAN_TXEFS_EFGI_Msk
#define FDCAN_TXEFS_EFPI_Pos   (16U)
#define FDCAN_TXEFS_EFPI_Msk   (0x3UL << FDCAN_TXEFS_EFPI_Pos)
#define FDCAN_TXEFS_EFPI   FDCAN_TXEFS_EFPI_Msk
#define FDCAN_TXEFS_EFF_Pos   (24U)
#define FDCAN_TXEFS_EFF_Msk   (0x1UL << FDCAN_TXEFS_EFF_Pos)
#define FDCAN_TXEFS_EFF   FDCAN_TXEFS_EFF_Msk
#define FDCAN_TXEFS_TEFL_Pos   (25U)
#define FDCAN_TXEFS_TEFL_Msk   (0x1UL << FDCAN_TXEFS_TEFL_Pos)
#define FDCAN_TXEFS_TEFL   FDCAN_TXEFS_TEFL_Msk
#define FDCAN_TXEFA_EFAI_Pos   (0U)
#define FDCAN_TXEFA_EFAI_Msk   (0x3UL << FDCAN_TXEFA_EFAI_Pos)
#define FDCAN_TXEFA_EFAI   FDCAN_TXEFA_EFAI_Msk
#define FDCAN_CKDIV_PDIV_Pos   (0U)
#define FDCAN_CKDIV_PDIV_Msk   (0xFUL << FDCAN_CKDIV_PDIV_Pos)
#define FDCAN_CKDIV_PDIV   FDCAN_CKDIV_PDIV_Msk
#define FLASH_LATENCY_DEFAULT   FLASH_ACR_LATENCY_0WS
#define FLASH_SIZE_DEFAULT   0x400000U
#define FLASH_BLOCKBASED_NB_REG   (8U)
#define FLASH_SIZE
#define FLASH_BANK_SIZE   (FLASH_SIZE >> 1U)
#define FLASH_PAGE_SIZE   0x2000U /* 8 KB */
#define FLASH_PAGE_NB   (FLASH_BANK_SIZE / FLASH_PAGE_SIZE)
#define FLASH_ACR_LATENCY_Pos   (0U)
#define FLASH_ACR_LATENCY_Msk   (0xFUL << FLASH_ACR_LATENCY_Pos)
#define FLASH_ACR_LATENCY   FLASH_ACR_LATENCY_Msk
#define FLASH_ACR_LATENCY_0WS   (0x00000000U)
#define FLASH_ACR_LATENCY_1WS   (0x00000001U)
#define FLASH_ACR_LATENCY_2WS   (0x00000002U)
#define FLASH_ACR_LATENCY_3WS   (0x00000003U)
#define FLASH_ACR_LATENCY_4WS   (0x00000004U)
#define FLASH_ACR_LATENCY_5WS   (0x00000005U)
#define FLASH_ACR_LATENCY_6WS   (0x00000006U)
#define FLASH_ACR_LATENCY_7WS   (0x00000007U)
#define FLASH_ACR_LATENCY_8WS   (0x00000008U)
#define FLASH_ACR_LATENCY_9WS   (0x00000009U)
#define FLASH_ACR_LATENCY_10WS   (0x0000000AU)
#define FLASH_ACR_LATENCY_11WS   (0x0000000BU)
#define FLASH_ACR_LATENCY_12WS   (0x0000000CU)
#define FLASH_ACR_LATENCY_13WS   (0x0000000DU)
#define FLASH_ACR_LATENCY_14WS   (0x0000000EU)
#define FLASH_ACR_LATENCY_15WS   (0x0000000FU)
#define FLASH_ACR_PRFTEN_Pos   (8U)
#define FLASH_ACR_PRFTEN_Msk   (0x1UL << FLASH_ACR_PRFTEN_Pos)
#define FLASH_ACR_PRFTEN   FLASH_ACR_PRFTEN_Msk
#define FLASH_ACR_LPM_Pos   (11U)
#define FLASH_ACR_LPM_Msk   (0x1UL << FLASH_ACR_LPM_Pos)
#define FLASH_ACR_LPM   FLASH_ACR_LPM_Msk
#define FLASH_ACR_PDREQ1_Pos   (12U)
#define FLASH_ACR_PDREQ1_Msk   (0x1UL << FLASH_ACR_PDREQ1_Pos)
#define FLASH_ACR_PDREQ1   FLASH_ACR_PDREQ1_Msk
#define FLASH_ACR_PDREQ2_Pos   (13U)
#define FLASH_ACR_PDREQ2_Msk   (0x1UL << FLASH_ACR_PDREQ2_Pos)
#define FLASH_ACR_PDREQ2   FLASH_ACR_PDREQ2_Msk
#define FLASH_ACR_SLEEP_PD_Pos   (14U)
#define FLASH_ACR_SLEEP_PD_Msk   (0x1UL << FLASH_ACR_SLEEP_PD_Pos)
#define FLASH_ACR_SLEEP_PD   FLASH_ACR_SLEEP_PD_Msk
#define FLASH_NSSR_EOP_Pos   (0U)
#define FLASH_NSSR_EOP_Msk   (0x1UL << FLASH_NSSR_EOP_Pos)
#define FLASH_NSSR_EOP   FLASH_NSSR_EOP_Msk
#define FLASH_NSSR_OPERR_Pos   (1U)
#define FLASH_NSSR_OPERR_Msk   (0x1UL << FLASH_NSSR_OPERR_Pos)
#define FLASH_NSSR_OPERR   FLASH_NSSR_OPERR_Msk
#define FLASH_NSSR_PROGERR_Pos   (3U)
#define FLASH_NSSR_PROGERR_Msk   (0x1UL << FLASH_NSSR_PROGERR_Pos)
#define FLASH_NSSR_PROGERR   FLASH_NSSR_PROGERR_Msk
#define FLASH_NSSR_WRPERR_Pos   (4U)
#define FLASH_NSSR_WRPERR_Msk   (0x1UL << FLASH_NSSR_WRPERR_Pos)
#define FLASH_NSSR_WRPERR   FLASH_NSSR_WRPERR_Msk
#define FLASH_NSSR_PGAERR_Pos   (5U)
#define FLASH_NSSR_PGAERR_Msk   (0x1UL << FLASH_NSSR_PGAERR_Pos)
#define FLASH_NSSR_PGAERR   FLASH_NSSR_PGAERR_Msk
#define FLASH_NSSR_SIZERR_Pos   (6U)
#define FLASH_NSSR_SIZERR_Msk   (0x1UL << FLASH_NSSR_SIZERR_Pos)
#define FLASH_NSSR_SIZERR   FLASH_NSSR_SIZERR_Msk
#define FLASH_NSSR_PGSERR_Pos   (7U)
#define FLASH_NSSR_PGSERR_Msk   (0x1UL << FLASH_NSSR_PGSERR_Pos)
#define FLASH_NSSR_PGSERR   FLASH_NSSR_PGSERR_Msk
#define FLASH_NSSR_OPTWERR_Pos   (13U)
#define FLASH_NSSR_OPTWERR_Msk   (0x1UL << FLASH_NSSR_OPTWERR_Pos)
#define FLASH_NSSR_OPTWERR   FLASH_NSSR_OPTWERR_Msk
#define FLASH_NSSR_BSY_Pos   (16U)
#define FLASH_NSSR_BSY_Msk   (0x1UL << FLASH_NSSR_BSY_Pos)
#define FLASH_NSSR_BSY   FLASH_NSSR_BSY_Msk
#define FLASH_NSSR_WDW_Pos   (17U)
#define FLASH_NSSR_WDW_Msk   (0x1UL << FLASH_NSSR_WDW_Pos)
#define FLASH_NSSR_WDW   FLASH_NSSR_WDW_Msk
#define FLASH_NSSR_OEM1LOCK_Pos   (18U)
#define FLASH_NSSR_OEM1LOCK_Msk   (0x1UL << FLASH_NSSR_OEM1LOCK_Pos)
#define FLASH_NSSR_OEM1LOCK   FLASH_NSSR_OEM1LOCK_Msk
#define FLASH_NSSR_OEM2LOCK_Pos   (19U)
#define FLASH_NSSR_OEM2LOCK_Msk   (0x1UL << FLASH_NSSR_OEM2LOCK_Pos)
#define FLASH_NSSR_OEM2LOCK   FLASH_NSSR_OEM2LOCK_Msk
#define FLASH_NSSR_PD1_Pos   (20U)
#define FLASH_NSSR_PD1_Msk   (0x1UL << FLASH_NSSR_PD1_Pos)
#define FLASH_NSSR_PD1   FLASH_NSSR_PD1_Msk
#define FLASH_NSSR_PD2_Pos   (21U)
#define FLASH_NSSR_PD2_Msk   (0x1UL << FLASH_NSSR_PD2_Pos)
#define FLASH_NSSR_PD2   FLASH_NSSR_PD2_Msk
#define FLASH_SECSR_EOP_Pos   (0U)
#define FLASH_SECSR_EOP_Msk   (0x1UL << FLASH_SECSR_EOP_Pos)
#define FLASH_SECSR_EOP   FLASH_SECSR_EOP_Msk
#define FLASH_SECSR_OPERR_Pos   (1U)
#define FLASH_SECSR_OPERR_Msk   (0x1UL << FLASH_SECSR_OPERR_Pos)
#define FLASH_SECSR_OPERR   FLASH_SECSR_OPERR_Msk
#define FLASH_SECSR_PROGERR_Pos   (3U)
#define FLASH_SECSR_PROGERR_Msk   (0x1UL << FLASH_SECSR_PROGERR_Pos)
#define FLASH_SECSR_PROGERR   FLASH_SECSR_PROGERR_Msk
#define FLASH_SECSR_WRPERR_Pos   (4U)
#define FLASH_SECSR_WRPERR_Msk   (0x1UL << FLASH_SECSR_WRPERR_Pos)
#define FLASH_SECSR_WRPERR   FLASH_SECSR_WRPERR_Msk
#define FLASH_SECSR_PGAERR_Pos   (5U)
#define FLASH_SECSR_PGAERR_Msk   (0x1UL << FLASH_SECSR_PGAERR_Pos)
#define FLASH_SECSR_PGAERR   FLASH_SECSR_PGAERR_Msk
#define FLASH_SECSR_SIZERR_Pos   (6U)
#define FLASH_SECSR_SIZERR_Msk   (0x1UL << FLASH_SECSR_SIZERR_Pos)
#define FLASH_SECSR_SIZERR   FLASH_SECSR_SIZERR_Msk
#define FLASH_SECSR_PGSERR_Pos   (7U)
#define FLASH_SECSR_PGSERR_Msk   (0x1UL << FLASH_SECSR_PGSERR_Pos)
#define FLASH_SECSR_PGSERR   FLASH_SECSR_PGSERR_Msk
#define FLASH_SECSR_BSY_Pos   (16U)
#define FLASH_SECSR_BSY_Msk   (0x1UL << FLASH_SECSR_BSY_Pos)
#define FLASH_SECSR_BSY   FLASH_SECSR_BSY_Msk
#define FLASH_SECSR_WDW_Pos   (17U)
#define FLASH_SECSR_WDW_Msk   (0x1UL << FLASH_SECSR_WDW_Pos)
#define FLASH_SECSR_WDW   FLASH_SECSR_WDW_Msk
#define FLASH_NSCR_PG_Pos   (0U)
#define FLASH_NSCR_PG_Msk   (0x1UL << FLASH_NSCR_PG_Pos)
#define FLASH_NSCR_PG   FLASH_NSCR_PG_Msk
#define FLASH_NSCR_PER_Pos   (1U)
#define FLASH_NSCR_PER_Msk   (0x1UL << FLASH_NSCR_PER_Pos)
#define FLASH_NSCR_PER   FLASH_NSCR_PER_Msk
#define FLASH_NSCR_MER1_Pos   (2U)
#define FLASH_NSCR_MER1_Msk   (0x1UL << FLASH_NSCR_MER1_Pos)
#define FLASH_NSCR_MER1   FLASH_NSCR_MER1_Msk
#define FLASH_NSCR_PNB_Pos   (3U)
#define FLASH_NSCR_PNB_Msk   (0xFFUL << FLASH_NSCR_PNB_Pos)
#define FLASH_NSCR_PNB   FLASH_NSCR_PNB_Msk
#define FLASH_NSCR_BKER_Pos   (11U)
#define FLASH_NSCR_BKER_Msk   (0x1UL << FLASH_NSCR_BKER_Pos)
#define FLASH_NSCR_BKER   FLASH_NSCR_BKER_Msk
#define FLASH_NSCR_BWR_Pos   (14U)
#define FLASH_NSCR_BWR_Msk   (0x1UL << FLASH_NSCR_BWR_Pos)
#define FLASH_NSCR_BWR   FLASH_NSCR_BWR_Msk
#define FLASH_NSCR_MER2_Pos   (15U)
#define FLASH_NSCR_MER2_Msk   (0x1UL << FLASH_NSCR_MER2_Pos)
#define FLASH_NSCR_MER2   FLASH_NSCR_MER2_Msk
#define FLASH_NSCR_STRT_Pos   (16U)
#define FLASH_NSCR_STRT_Msk   (0x1UL << FLASH_NSCR_STRT_Pos)
#define FLASH_NSCR_STRT   FLASH_NSCR_STRT_Msk
#define FLASH_NSCR_OPTSTRT_Pos   (17U)
#define FLASH_NSCR_OPTSTRT_Msk   (0x1UL << FLASH_NSCR_OPTSTRT_Pos)
#define FLASH_NSCR_OPTSTRT   FLASH_NSCR_OPTSTRT_Msk
#define FLASH_NSCR_EOPIE_Pos   (24U)
#define FLASH_NSCR_EOPIE_Msk   (0x1UL << FLASH_NSCR_EOPIE_Pos)
#define FLASH_NSCR_EOPIE   FLASH_NSCR_EOPIE_Msk
#define FLASH_NSCR_ERRIE_Pos   (25U)
#define FLASH_NSCR_ERRIE_Msk   (0x1UL << FLASH_NSCR_ERRIE_Pos)
#define FLASH_NSCR_ERRIE   FLASH_NSCR_ERRIE_Msk
#define FLASH_NSCR_OBL_LAUNCH_Pos   (27U)
#define FLASH_NSCR_OBL_LAUNCH_Msk   (0x1UL << FLASH_NSCR_OBL_LAUNCH_Pos)
#define FLASH_NSCR_OBL_LAUNCH   FLASH_NSCR_OBL_LAUNCH_Msk
#define FLASH_NSCR_OPTLOCK_Pos   (30U)
#define FLASH_NSCR_OPTLOCK_Msk   (0x1UL << FLASH_NSCR_OPTLOCK_Pos)
#define FLASH_NSCR_OPTLOCK   FLASH_NSCR_OPTLOCK_Msk
#define FLASH_NSCR_LOCK_Pos   (31U)
#define FLASH_NSCR_LOCK_Msk   (0x1UL << FLASH_NSCR_LOCK_Pos)
#define FLASH_NSCR_LOCK   FLASH_NSCR_LOCK_Msk
#define FLASH_SECCR_PG_Pos   (0U)
#define FLASH_SECCR_PG_Msk   (0x1UL << FLASH_SECCR_PG_Pos)
#define FLASH_SECCR_PG   FLASH_SECCR_PG_Msk
#define FLASH_SECCR_PER_Pos   (1U)
#define FLASH_SECCR_PER_Msk   (0x1UL << FLASH_SECCR_PER_Pos)
#define FLASH_SECCR_PER   FLASH_SECCR_PER_Msk
#define FLASH_SECCR_MER1_Pos   (2U)
#define FLASH_SECCR_MER1_Msk   (0x1UL << FLASH_SECCR_MER1_Pos)
#define FLASH_SECCR_MER1   FLASH_SECCR_MER1_Msk
#define FLASH_SECCR_PNB_Pos   (3U)
#define FLASH_SECCR_PNB_Msk   (0xFFUL << FLASH_SECCR_PNB_Pos)
#define FLASH_SECCR_PNB   FLASH_SECCR_PNB_Msk
#define FLASH_SECCR_BKER_Pos   (11U)
#define FLASH_SECCR_BKER_Msk   (0x1UL << FLASH_SECCR_BKER_Pos)
#define FLASH_SECCR_BKER   FLASH_SECCR_BKER_Msk
#define FLASH_SECCR_BWR_Pos   (14U)
#define FLASH_SECCR_BWR_Msk   (0x1UL << FLASH_SECCR_BWR_Pos)
#define FLASH_SECCR_BWR   FLASH_SECCR_BWR_Msk
#define FLASH_SECCR_MER2_Pos   (15U)
#define FLASH_SECCR_MER2_Msk   (0x1UL << FLASH_SECCR_MER2_Pos)
#define FLASH_SECCR_MER2   FLASH_SECCR_MER2_Msk
#define FLASH_SECCR_STRT_Pos   (16U)
#define FLASH_SECCR_STRT_Msk   (0x1UL << FLASH_SECCR_STRT_Pos)
#define FLASH_SECCR_STRT   FLASH_SECCR_STRT_Msk
#define FLASH_SECCR_EOPIE_Pos   (24U)
#define FLASH_SECCR_EOPIE_Msk   (0x1UL << FLASH_SECCR_EOPIE_Pos)
#define FLASH_SECCR_EOPIE   FLASH_SECCR_EOPIE_Msk
#define FLASH_SECCR_ERRIE_Pos   (25U)
#define FLASH_SECCR_ERRIE_Msk   (0x1UL << FLASH_SECCR_ERRIE_Pos)
#define FLASH_SECCR_ERRIE   FLASH_SECCR_ERRIE_Msk
#define FLASH_SECCR_INV_Pos   (29U)
#define FLASH_SECCR_INV_Msk   (0x1UL << FLASH_SECCR_INV_Pos)
#define FLASH_SECCR_INV   FLASH_SECCR_INV_Msk
#define FLASH_SECCR_LOCK_Pos   (31U)
#define FLASH_SECCR_LOCK_Msk   (0x1UL << FLASH_SECCR_LOCK_Pos)
#define FLASH_SECCR_LOCK   FLASH_SECCR_LOCK_Msk
#define FLASH_ECCR_ADDR_ECC_Pos   (0U)
#define FLASH_ECCR_ADDR_ECC_Msk   (0x1FFFFFUL << FLASH_ECCR_ADDR_ECC_Pos)
#define FLASH_ECCR_ADDR_ECC   FLASH_ECCR_ADDR_ECC_Msk
#define FLASH_ECCR_BK_ECC_Pos   (21U)
#define FLASH_ECCR_BK_ECC_Msk   (0x1UL << FLASH_ECCR_BK_ECC_Pos)
#define FLASH_ECCR_BK_ECC   FLASH_ECCR_BK_ECC_Msk
#define FLASH_ECCR_SYSF_ECC_Pos   (22U)
#define FLASH_ECCR_SYSF_ECC_Msk   (0x1UL << FLASH_ECCR_SYSF_ECC_Pos)
#define FLASH_ECCR_SYSF_ECC   FLASH_ECCR_SYSF_ECC_Msk
#define FLASH_ECCR_ECCIE_Pos   (24U)
#define FLASH_ECCR_ECCIE_Msk   (0x1UL << FLASH_ECCR_ECCIE_Pos)
#define FLASH_ECCR_ECCIE   FLASH_ECCR_ECCIE_Msk
#define FLASH_ECCR_ECCC_Pos   (30U)
#define FLASH_ECCR_ECCC_Msk   (0x1UL << FLASH_ECCR_ECCC_Pos)
#define FLASH_ECCR_ECCC   FLASH_ECCR_ECCC_Msk
#define FLASH_ECCR_ECCD_Pos   (31U)
#define FLASH_ECCR_ECCD_Msk   (0x1UL << FLASH_ECCR_ECCD_Pos)
#define FLASH_ECCR_ECCD   FLASH_ECCR_ECCD_Msk
#define FLASH_OPSR_ADDR_OP_Pos   (0U)
#define FLASH_OPSR_ADDR_OP_Msk   (0x1FFFFFUL << FLASH_OPSR_ADDR_OP_Pos)
#define FLASH_OPSR_ADDR_OP   FLASH_OPSR_ADDR_OP_Msk
#define FLASH_OPSR_BK_OP_Pos   (21U)
#define FLASH_OPSR_BK_OP_Msk   (0x1UL << FLASH_OPSR_BK_OP_Pos)
#define FLASH_OPSR_BK_OP   FLASH_OPSR_BK_OP_Msk
#define FLASH_OPSR_SYSF_OP_Pos   (22U)
#define FLASH_OPSR_SYSF_OP_Msk   (0x1UL << FLASH_OPSR_SYSF_OP_Pos)
#define FLASH_OPSR_SYSF_OP   FLASH_OPSR_SYSF_OP_Msk
#define FLASH_OPSR_CODE_OP_Pos   (29U)
#define FLASH_OPSR_CODE_OP_Msk   (0x7UL << FLASH_OPSR_CODE_OP_Pos)
#define FLASH_OPSR_CODE_OP   FLASH_OPSR_CODE_OP_Msk
#define FLASH_OPSR_CODE_OP_0   (0x1UL << FLASH_OPSR_CODE_OP_Pos)
#define FLASH_OPSR_CODE_OP_1   (0x2UL << FLASH_OPSR_CODE_OP_Pos)
#define FLASH_OPSR_CODE_OP_2   (0x4UL << FLASH_OPSR_CODE_OP_Pos)
#define FLASH_OPTR_RDP_Pos   (0U)
#define FLASH_OPTR_RDP_Msk   (0xFFUL << FLASH_OPTR_RDP_Pos)
#define FLASH_OPTR_RDP   FLASH_OPTR_RDP_Msk
#define FLASH_OPTR_BOR_LEV_Pos   (8U)
#define FLASH_OPTR_BOR_LEV_Msk   (0x7UL << FLASH_OPTR_BOR_LEV_Pos)
#define FLASH_OPTR_BOR_LEV   FLASH_OPTR_BOR_LEV_Msk
#define FLASH_OPTR_BOR_LEV_0   (0x1UL << FLASH_OPTR_BOR_LEV_Pos)
#define FLASH_OPTR_BOR_LEV_1   (0x2UL << FLASH_OPTR_BOR_LEV_Pos)
#define FLASH_OPTR_BOR_LEV_2   (0x4UL << FLASH_OPTR_BOR_LEV_Pos)
#define FLASH_OPTR_nRST_STOP_Pos   (12U)
#define FLASH_OPTR_nRST_STOP_Msk   (0x1UL << FLASH_OPTR_nRST_STOP_Pos)
#define FLASH_OPTR_nRST_STOP   FLASH_OPTR_nRST_STOP_Msk
#define FLASH_OPTR_nRST_STDBY_Pos   (13U)
#define FLASH_OPTR_nRST_STDBY_Msk   (0x1UL << FLASH_OPTR_nRST_STDBY_Pos)
#define FLASH_OPTR_nRST_STDBY   FLASH_OPTR_nRST_STDBY_Msk
#define FLASH_OPTR_nRST_SHDW_Pos   (14U)
#define FLASH_OPTR_nRST_SHDW_Msk   (0x1UL << FLASH_OPTR_nRST_SHDW_Pos)
#define FLASH_OPTR_nRST_SHDW   FLASH_OPTR_nRST_SHDW_Msk
#define FLASH_OPTR_SRAM_RST_Pos   (15U)
#define FLASH_OPTR_SRAM_RST_Msk   (0x1UL << FLASH_OPTR_SRAM_RST_Pos)
#define FLASH_OPTR_SRAM_RST   FLASH_OPTR_SRAM_RST_Msk
#define FLASH_OPTR_IWDG_SW_Pos   (16U)
#define FLASH_OPTR_IWDG_SW_Msk   (0x1UL << FLASH_OPTR_IWDG_SW_Pos)
#define FLASH_OPTR_IWDG_SW   FLASH_OPTR_IWDG_SW_Msk
#define FLASH_OPTR_IWDG_STOP_Pos   (17U)
#define FLASH_OPTR_IWDG_STOP_Msk   (0x1UL << FLASH_OPTR_IWDG_STOP_Pos)
#define FLASH_OPTR_IWDG_STOP   FLASH_OPTR_IWDG_STOP_Msk
#define FLASH_OPTR_IWDG_STDBY_Pos   (18U)
#define FLASH_OPTR_IWDG_STDBY_Msk   (0x1UL << FLASH_OPTR_IWDG_STDBY_Pos)
#define FLASH_OPTR_IWDG_STDBY   FLASH_OPTR_IWDG_STDBY_Msk
#define FLASH_OPTR_WWDG_SW_Pos   (19U)
#define FLASH_OPTR_WWDG_SW_Msk   (0x1UL << FLASH_OPTR_WWDG_SW_Pos)
#define FLASH_OPTR_WWDG_SW   FLASH_OPTR_WWDG_SW_Msk
#define FLASH_OPTR_SWAP_BANK_Pos   (20U)
#define FLASH_OPTR_SWAP_BANK_Msk   (0x1UL << FLASH_OPTR_SWAP_BANK_Pos)
#define FLASH_OPTR_SWAP_BANK   FLASH_OPTR_SWAP_BANK_Msk
#define FLASH_OPTR_DUALBANK_Pos   (21U)
#define FLASH_OPTR_DUALBANK_Msk   (0x1UL << FLASH_OPTR_DUALBANK_Pos)
#define FLASH_OPTR_DUALBANK   FLASH_OPTR_DUALBANK_Msk
#define FLASH_OPTR_BKPRAM_ECC_Pos   (22U)
#define FLASH_OPTR_BKPRAM_ECC_Msk   (0x1UL << FLASH_OPTR_BKPRAM_ECC_Pos)
#define FLASH_OPTR_BKPRAM_ECC   FLASH_OPTR_BKPRAM_ECC_Msk
#define FLASH_OPTR_SRAM3_ECC_Pos   (23U)
#define FLASH_OPTR_SRAM3_ECC_Msk   (0x1UL << FLASH_OPTR_SRAM3_ECC_Pos)
#define FLASH_OPTR_SRAM3_ECC   FLASH_OPTR_SRAM3_ECC_Msk
#define FLASH_OPTR_SRAM2_ECC_Pos   (24U)
#define FLASH_OPTR_SRAM2_ECC_Msk   (0x1UL << FLASH_OPTR_SRAM2_ECC_Pos)
#define FLASH_OPTR_SRAM2_ECC   FLASH_OPTR_SRAM2_ECC_Msk
#define FLASH_OPTR_SRAM2_RST_Pos   (25U)
#define FLASH_OPTR_SRAM2_RST_Msk   (0x1UL << FLASH_OPTR_SRAM2_RST_Pos)
#define FLASH_OPTR_SRAM2_RST   FLASH_OPTR_SRAM2_RST_Msk
#define FLASH_OPTR_nSWBOOT0_Pos   (26U)
#define FLASH_OPTR_nSWBOOT0_Msk   (0x1UL << FLASH_OPTR_nSWBOOT0_Pos)
#define FLASH_OPTR_nSWBOOT0   FLASH_OPTR_nSWBOOT0_Msk
#define FLASH_OPTR_nBOOT0_Pos   (27U)
#define FLASH_OPTR_nBOOT0_Msk   (0x1UL << FLASH_OPTR_nBOOT0_Pos)
#define FLASH_OPTR_nBOOT0   FLASH_OPTR_nBOOT0_Msk
#define FLASH_OPTR_PA15_PUPEN_Pos   (28U)
#define FLASH_OPTR_PA15_PUPEN_Msk   (0x1UL << FLASH_OPTR_PA15_PUPEN_Pos)
#define FLASH_OPTR_PA15_PUPEN   FLASH_OPTR_PA15_PUPEN_Msk
#define FLASH_OPTR_IO_VDD_HSLV_Pos   (29U)
#define FLASH_OPTR_IO_VDD_HSLV_Msk   (0x1UL << FLASH_OPTR_IO_VDD_HSLV_Pos)
#define FLASH_OPTR_IO_VDD_HSLV   FLASH_OPTR_IO_VDD_HSLV_Msk
#define FLASH_OPTR_IO_VDDIO2_HSLV_Pos   (30U)
#define FLASH_OPTR_IO_VDDIO2_HSLV_Msk   (0x1UL << FLASH_OPTR_IO_VDDIO2_HSLV_Pos)
#define FLASH_OPTR_IO_VDDIO2_HSLV   FLASH_OPTR_IO_VDDIO2_HSLV_Msk
#define FLASH_OPTR_TZEN_Pos   (31U)
#define FLASH_OPTR_TZEN_Msk   (0x1UL << FLASH_OPTR_TZEN_Pos)
#define FLASH_OPTR_TZEN   FLASH_OPTR_TZEN_Msk
#define FLASH_NSBOOTADD0R_NSBOOTADD0_Pos   (7U)
#define FLASH_NSBOOTADD0R_NSBOOTADD0_Msk   (0x1FFFFFFUL << FLASH_NSBOOTADD0R_NSBOOTADD0_Pos)
#define FLASH_NSBOOTADD0R_NSBOOTADD0   FLASH_NSBOOTADD0R_NSBOOTADD0_Msk
#define FLASH_NSBOOTADD1R_NSBOOTADD1_Pos   (7U)
#define FLASH_NSBOOTADD1R_NSBOOTADD1_Msk   (0x1FFFFFFUL << FLASH_NSBOOTADD1R_NSBOOTADD1_Pos)
#define FLASH_NSBOOTADD1R_NSBOOTADD1   FLASH_NSBOOTADD1R_NSBOOTADD1_Msk
#define FLASH_SECBOOTADD0R_BOOT_LOCK_Pos   (0U)
#define FLASH_SECBOOTADD0R_BOOT_LOCK_Msk   (0x1UL << FLASH_SECBOOTADD0R_BOOT_LOCK_Pos)
#define FLASH_SECBOOTADD0R_BOOT_LOCK   FLASH_SECBOOTADD0R_BOOT_LOCK_Msk
#define FLASH_SECBOOTADD0R_SECBOOTADD0_Pos   (7U)
#define FLASH_SECBOOTADD0R_SECBOOTADD0_Msk   (0x1FFFFFFUL << FLASH_SECBOOTADD0R_SECBOOTADD0_Pos)
#define FLASH_SECBOOTADD0R_SECBOOTADD0   FLASH_SECBOOTADD0R_SECBOOTADD0_Msk
#define FLASH_SECWM1R1_SECWM1_PSTRT_Pos   (0U)
#define FLASH_SECWM1R1_SECWM1_PSTRT_Msk   (0xFFUL << FLASH_SECWM1R1_SECWM1_PSTRT_Pos)
#define FLASH_SECWM1R1_SECWM1_PSTRT   FLASH_SECWM1R1_SECWM1_PSTRT_Msk
#define FLASH_SECWM1R1_SECWM1_PEND_Pos   (16U)
#define FLASH_SECWM1R1_SECWM1_PEND_Msk   (0xFFUL << FLASH_SECWM1R1_SECWM1_PEND_Pos)
#define FLASH_SECWM1R1_SECWM1_PEND   FLASH_SECWM1R1_SECWM1_PEND_Msk
#define FLASH_SECWM1R2_HDP1_PEND_Pos   (16U)
#define FLASH_SECWM1R2_HDP1_PEND_Msk   (0xFFUL << FLASH_SECWM1R2_HDP1_PEND_Pos)
#define FLASH_SECWM1R2_HDP1_PEND   FLASH_SECWM1R2_HDP1_PEND_Msk
#define FLASH_SECWM1R2_HDP1EN_Pos   (31U)
#define FLASH_SECWM1R2_HDP1EN_Msk   (0x1UL << FLASH_SECWM1R2_HDP1EN_Pos)
#define FLASH_SECWM1R2_HDP1EN   FLASH_SECWM1R2_HDP1EN_Msk
#define FLASH_WRP1AR_WRP1A_PSTRT_Pos   (0U)
#define FLASH_WRP1AR_WRP1A_PSTRT_Msk   (0xFFUL << FLASH_WRP1AR_WRP1A_PSTRT_Pos)
#define FLASH_WRP1AR_WRP1A_PSTRT   FLASH_WRP1AR_WRP1A_PSTRT_Msk
#define FLASH_WRP1AR_WRP1A_PEND_Pos   (16U)
#define FLASH_WRP1AR_WRP1A_PEND_Msk   (0xFFUL << FLASH_WRP1AR_WRP1A_PEND_Pos)
#define FLASH_WRP1AR_WRP1A_PEND   FLASH_WRP1AR_WRP1A_PEND_Msk
#define FLASH_WRP1AR_UNLOCK_Pos   (31U)
#define FLASH_WRP1AR_UNLOCK_Msk   (0x1UL << FLASH_WRP1AR_UNLOCK_Pos)
#define FLASH_WRP1AR_UNLOCK   FLASH_WRP1AR_UNLOCK_Msk
#define FLASH_WRP1BR_WRP1B_PSTRT_Pos   (0U)
#define FLASH_WRP1BR_WRP1B_PSTRT_Msk   (0xFFUL << FLASH_WRP1BR_WRP1B_PSTRT_Pos)
#define FLASH_WRP1BR_WRP1B_PSTRT   FLASH_WRP1BR_WRP1B_PSTRT_Msk
#define FLASH_WRP1BR_WRP1B_PEND_Pos   (16U)
#define FLASH_WRP1BR_WRP1B_PEND_Msk   (0xFFUL << FLASH_WRP1BR_WRP1B_PEND_Pos)
#define FLASH_WRP1BR_WRP1B_PEND   FLASH_WRP1BR_WRP1B_PEND_Msk
#define FLASH_WRP1BR_UNLOCK_Pos   (31U)
#define FLASH_WRP1BR_UNLOCK_Msk   (0x1UL << FLASH_WRP1BR_UNLOCK_Pos)
#define FLASH_WRP1BR_UNLOCK   FLASH_WRP1BR_UNLOCK_Msk
#define FLASH_SECWM2R1_SECWM2_PSTRT_Pos   (0U)
#define FLASH_SECWM2R1_SECWM2_PSTRT_Msk   (0xFFUL << FLASH_SECWM2R1_SECWM2_PSTRT_Pos)
#define FLASH_SECWM2R1_SECWM2_PSTRT   FLASH_SECWM2R1_SECWM2_PSTRT_Msk
#define FLASH_SECWM2R1_SECWM2_PEND_Pos   (16U)
#define FLASH_SECWM2R1_SECWM2_PEND_Msk   (0xFFUL << FLASH_SECWM2R1_SECWM2_PEND_Pos)
#define FLASH_SECWM2R1_SECWM2_PEND   FLASH_SECWM2R1_SECWM2_PEND_Msk
#define FLASH_SECWM2R2_HDP2_PEND_Pos   (16U)
#define FLASH_SECWM2R2_HDP2_PEND_Msk   (0xFFUL << FLASH_SECWM2R2_HDP2_PEND_Pos)
#define FLASH_SECWM2R2_HDP2_PEND   FLASH_SECWM2R2_HDP2_PEND_Msk
#define FLASH_SECWM2R2_HDP2EN_Pos   (31U)
#define FLASH_SECWM2R2_HDP2EN_Msk   (0x1UL << FLASH_SECWM2R2_HDP2EN_Pos)
#define FLASH_SECWM2R2_HDP2EN   FLASH_SECWM2R2_HDP2EN_Msk
#define FLASH_WRP2AR_WRP2A_PSTRT_Pos   (0U)
#define FLASH_WRP2AR_WRP2A_PSTRT_Msk   (0xFFUL << FLASH_WRP2AR_WRP2A_PSTRT_Pos)
#define FLASH_WRP2AR_WRP2A_PSTRT   FLASH_WRP2AR_WRP2A_PSTRT_Msk
#define FLASH_WRP2AR_WRP2A_PEND_Pos   (16U)
#define FLASH_WRP2AR_WRP2A_PEND_Msk   (0xFFUL << FLASH_WRP2AR_WRP2A_PEND_Pos)
#define FLASH_WRP2AR_WRP2A_PEND   FLASH_WRP2AR_WRP2A_PEND_Msk
#define FLASH_WRP2AR_UNLOCK_Pos   (31U)
#define FLASH_WRP2AR_UNLOCK_Msk   (0x1UL << FLASH_WRP2AR_UNLOCK_Pos)
#define FLASH_WRP2AR_UNLOCK   FLASH_WRP2AR_UNLOCK_Msk
#define FLASH_WRP2BR_WRP2B_PSTRT_Pos   (0U)
#define FLASH_WRP2BR_WRP2B_PSTRT_Msk   (0xFFUL << FLASH_WRP2BR_WRP2B_PSTRT_Pos)
#define FLASH_WRP2BR_WRP2B_PSTRT   FLASH_WRP2BR_WRP2B_PSTRT_Msk
#define FLASH_WRP2BR_WRP2B_PEND_Pos   (16U)
#define FLASH_WRP2BR_WRP2B_PEND_Msk   (0xFFUL << FLASH_WRP2BR_WRP2B_PEND_Pos)
#define FLASH_WRP2BR_WRP2B_PEND   FLASH_WRP2BR_WRP2B_PEND_Msk
#define FLASH_WRP2BR_UNLOCK_Pos   (31U)
#define FLASH_WRP2BR_UNLOCK_Msk   (0x1UL << FLASH_WRP2BR_UNLOCK_Pos)
#define FLASH_WRP2BR_UNLOCK   FLASH_WRP2BR_UNLOCK_Msk
#define FLASH_SECHDPCR_HDP1_ACCDIS_Pos   (0U)
#define FLASH_SECHDPCR_HDP1_ACCDIS_Msk   (0x1UL << FLASH_SECHDPCR_HDP1_ACCDIS_Pos)
#define FLASH_SECHDPCR_HDP1_ACCDIS   FLASH_SECHDPCR_HDP1_ACCDIS_Msk
#define FLASH_SECHDPCR_HDP2_ACCDIS_Pos   (1U)
#define FLASH_SECHDPCR_HDP2_ACCDIS_Msk   (0x1UL << FLASH_SECHDPCR_HDP2_ACCDIS_Pos)
#define FLASH_SECHDPCR_HDP2_ACCDIS   FLASH_SECHDPCR_HDP2_ACCDIS_Msk
#define FLASH_PRIVCFGR_SPRIV_Pos   (0U)
#define FLASH_PRIVCFGR_SPRIV_Msk   (0x1UL << FLASH_PRIVCFGR_SPRIV_Pos)
#define FLASH_PRIVCFGR_SPRIV   FLASH_PRIVCFGR_SPRIV_Msk
#define FLASH_PRIVCFGR_NSPRIV_Pos   (1U)
#define FLASH_PRIVCFGR_NSPRIV_Msk   (0x1UL << FLASH_PRIVCFGR_NSPRIV_Pos)
#define FLASH_PRIVCFGR_NSPRIV   FLASH_PRIVCFGR_NSPRIV_Msk
#define FMAC_X1BUFCFG_X1_BASE_Pos   (0U)
#define FMAC_X1BUFCFG_X1_BASE_Msk   (0xFFUL << FMAC_X1BUFCFG_X1_BASE_Pos)
#define FMAC_X1BUFCFG_X1_BASE   FMAC_X1BUFCFG_X1_BASE_Msk
#define FMAC_X1BUFCFG_X1_BUF_SIZE_Pos   (8U)
#define FMAC_X1BUFCFG_X1_BUF_SIZE_Msk   (0xFFUL << FMAC_X1BUFCFG_X1_BUF_SIZE_Pos)
#define FMAC_X1BUFCFG_X1_BUF_SIZE   FMAC_X1BUFCFG_X1_BUF_SIZE_Msk
#define FMAC_X1BUFCFG_FULL_WM_Pos   (24U)
#define FMAC_X1BUFCFG_FULL_WM_Msk   (0x3UL << FMAC_X1BUFCFG_FULL_WM_Pos)
#define FMAC_X1BUFCFG_FULL_WM   FMAC_X1BUFCFG_FULL_WM_Msk
#define FMAC_X2BUFCFG_X2_BASE_Pos   (0U)
#define FMAC_X2BUFCFG_X2_BASE_Msk   (0xFFUL << FMAC_X2BUFCFG_X2_BASE_Pos)
#define FMAC_X2BUFCFG_X2_BASE   FMAC_X2BUFCFG_X2_BASE_Msk
#define FMAC_X2BUFCFG_X2_BUF_SIZE_Pos   (8U)
#define FMAC_X2BUFCFG_X2_BUF_SIZE_Msk   (0xFFUL << FMAC_X2BUFCFG_X2_BUF_SIZE_Pos)
#define FMAC_X2BUFCFG_X2_BUF_SIZE   FMAC_X2BUFCFG_X2_BUF_SIZE_Msk
#define FMAC_YBUFCFG_Y_BASE_Pos   (0U)
#define FMAC_YBUFCFG_Y_BASE_Msk   (0xFFUL << FMAC_YBUFCFG_Y_BASE_Pos)
#define FMAC_YBUFCFG_Y_BASE   FMAC_YBUFCFG_Y_BASE_Msk
#define FMAC_YBUFCFG_Y_BUF_SIZE_Pos   (8U)
#define FMAC_YBUFCFG_Y_BUF_SIZE_Msk   (0xFFUL << FMAC_YBUFCFG_Y_BUF_SIZE_Pos)
#define FMAC_YBUFCFG_Y_BUF_SIZE   FMAC_YBUFCFG_Y_BUF_SIZE_Msk
#define FMAC_YBUFCFG_EMPTY_WM_Pos   (24U)
#define FMAC_YBUFCFG_EMPTY_WM_Msk   (0x3UL << FMAC_YBUFCFG_EMPTY_WM_Pos)
#define FMAC_YBUFCFG_EMPTY_WM   FMAC_YBUFCFG_EMPTY_WM_Msk
#define FMAC_PARAM_P_Pos   (0U)
#define FMAC_PARAM_P_Msk   (0xFFUL << FMAC_PARAM_P_Pos)
#define FMAC_PARAM_P   FMAC_PARAM_P_Msk
#define FMAC_PARAM_Q_Pos   (8U)
#define FMAC_PARAM_Q_Msk   (0xFFUL << FMAC_PARAM_Q_Pos)
#define FMAC_PARAM_Q   FMAC_PARAM_Q_Msk
#define FMAC_PARAM_R_Pos   (16U)
#define FMAC_PARAM_R_Msk   (0xFFUL << FMAC_PARAM_R_Pos)
#define FMAC_PARAM_R   FMAC_PARAM_R_Msk
#define FMAC_PARAM_FUNC_Pos   (24U)
#define FMAC_PARAM_FUNC_Msk   (0x7FUL << FMAC_PARAM_FUNC_Pos)
#define FMAC_PARAM_FUNC   FMAC_PARAM_FUNC_Msk
#define FMAC_PARAM_FUNC_0   (0x1UL << FMAC_PARAM_FUNC_Pos)
#define FMAC_PARAM_FUNC_1   (0x2UL << FMAC_PARAM_FUNC_Pos)
#define FMAC_PARAM_FUNC_2   (0x4UL << FMAC_PARAM_FUNC_Pos)
#define FMAC_PARAM_FUNC_3   (0x8UL << FMAC_PARAM_FUNC_Pos)
#define FMAC_PARAM_FUNC_4   (0x10UL << FMAC_PARAM_FUNC_Pos)
#define FMAC_PARAM_FUNC_5   (0x20UL << FMAC_PARAM_FUNC_Pos)
#define FMAC_PARAM_FUNC_6   (0x40UL << FMAC_PARAM_FUNC_Pos)
#define FMAC_PARAM_START_Pos   (31U)
#define FMAC_PARAM_START_Msk   (0x1UL << FMAC_PARAM_START_Pos)
#define FMAC_PARAM_START   FMAC_PARAM_START_Msk
#define FMAC_CR_RIEN_Pos   (0U)
#define FMAC_CR_RIEN_Msk   (0x1UL << FMAC_CR_RIEN_Pos)
#define FMAC_CR_RIEN   FMAC_CR_RIEN_Msk
#define FMAC_CR_WIEN_Pos   (1U)
#define FMAC_CR_WIEN_Msk   (0x1UL << FMAC_CR_WIEN_Pos)
#define FMAC_CR_WIEN   FMAC_CR_WIEN_Msk
#define FMAC_CR_OVFLIEN_Pos   (2U)
#define FMAC_CR_OVFLIEN_Msk   (0x1UL << FMAC_CR_OVFLIEN_Pos)
#define FMAC_CR_OVFLIEN   FMAC_CR_OVFLIEN_Msk
#define FMAC_CR_UNFLIEN_Pos   (3U)
#define FMAC_CR_UNFLIEN_Msk   (0x1UL << FMAC_CR_UNFLIEN_Pos)
#define FMAC_CR_UNFLIEN   FMAC_CR_UNFLIEN_Msk
#define FMAC_CR_SATIEN_Pos   (4U)
#define FMAC_CR_SATIEN_Msk   (0x1UL << FMAC_CR_SATIEN_Pos)
#define FMAC_CR_SATIEN   FMAC_CR_SATIEN_Msk
#define FMAC_CR_DMAREN_Pos   (8U)
#define FMAC_CR_DMAREN_Msk   (0x1UL << FMAC_CR_DMAREN_Pos)
#define FMAC_CR_DMAREN   FMAC_CR_DMAREN_Msk
#define FMAC_CR_DMAWEN_Pos   (9U)
#define FMAC_CR_DMAWEN_Msk   (0x1UL << FMAC_CR_DMAWEN_Pos)
#define FMAC_CR_DMAWEN   FMAC_CR_DMAWEN_Msk
#define FMAC_CR_CLIPEN_Pos   (15U)
#define FMAC_CR_CLIPEN_Msk   (0x1UL << FMAC_CR_CLIPEN_Pos)
#define FMAC_CR_CLIPEN   FMAC_CR_CLIPEN_Msk
#define FMAC_CR_RESET_Pos   (16U)
#define FMAC_CR_RESET_Msk   (0x1UL << FMAC_CR_RESET_Pos)
#define FMAC_CR_RESET   FMAC_CR_RESET_Msk
#define FMAC_SR_YEMPTY_Pos   (0U)
#define FMAC_SR_YEMPTY_Msk   (0x1UL << FMAC_SR_YEMPTY_Pos)
#define FMAC_SR_YEMPTY   FMAC_SR_YEMPTY_Msk
#define FMAC_SR_X1FULL_Pos   (1U)
#define FMAC_SR_X1FULL_Msk   (0x1UL << FMAC_SR_X1FULL_Pos)
#define FMAC_SR_X1FULL   FMAC_SR_X1FULL_Msk
#define FMAC_SR_OVFL_Pos   (8U)
#define FMAC_SR_OVFL_Msk   (0x1UL << FMAC_SR_OVFL_Pos)
#define FMAC_SR_OVFL   FMAC_SR_OVFL_Msk
#define FMAC_SR_UNFL_Pos   (9U)
#define FMAC_SR_UNFL_Msk   (0x1UL << FMAC_SR_UNFL_Pos)
#define FMAC_SR_UNFL   FMAC_SR_UNFL_Msk
#define FMAC_SR_SAT_Pos   (10U)
#define FMAC_SR_SAT_Msk   (0x1UL << FMAC_SR_SAT_Pos)
#define FMAC_SR_SAT   FMAC_SR_SAT_Msk
#define FMAC_WDATA_WDATA_Pos   (0U)
#define FMAC_WDATA_WDATA_Msk   (0xFFFFUL << FMAC_WDATA_WDATA_Pos)
#define FMAC_WDATA_WDATA   FMAC_WDATA_WDATA_Msk
#define FMAC_RDATA_RDATA_Pos   (0U)
#define FMAC_RDATA_RDATA_Msk   (0xFFFFUL << FMAC_RDATA_RDATA_Pos)
#define FMAC_RDATA_RDATA   FMAC_RDATA_RDATA_Msk
#define FMC_BCR1_CCLKEN_Pos   (20U)
#define FMC_BCR1_CCLKEN_Msk   (0x1UL << FMC_BCR1_CCLKEN_Pos)
#define FMC_BCR1_CCLKEN   FMC_BCR1_CCLKEN_Msk
#define FMC_BCR1_WFDIS_Pos   (21U)
#define FMC_BCR1_WFDIS_Msk   (0x1UL << FMC_BCR1_WFDIS_Pos)
#define FMC_BCR1_WFDIS   FMC_BCR1_WFDIS_Msk
#define FMC_BCR1_FMCEN_Pos   (31U)
#define FMC_BCR1_FMCEN_Msk   (0x1UL << FMC_BCR1_FMCEN_Pos)
#define FMC_BCR1_FMCEN   FMC_BCR1_FMCEN_Msk
#define FMC_BCRx_MBKEN_Pos   (0U)
#define FMC_BCRx_MBKEN_Msk   (0x1UL << FMC_BCRx_MBKEN_Pos)
#define FMC_BCRx_MBKEN   FMC_BCRx_MBKEN_Msk
#define FMC_BCRx_MUXEN_Pos   (1U)
#define FMC_BCRx_MUXEN_Msk   (0x1UL << FMC_BCRx_MUXEN_Pos)
#define FMC_BCRx_MUXEN   FMC_BCRx_MUXEN_Msk
#define FMC_BCRx_MTYP_Pos   (2U)
#define FMC_BCRx_MTYP_Msk   (0x3UL << FMC_BCRx_MTYP_Pos)
#define FMC_BCRx_MTYP   FMC_BCRx_MTYP_Msk
#define FMC_BCRx_MTYP_0   (0x1UL << FMC_BCRx_MTYP_Pos)
#define FMC_BCRx_MTYP_1   (0x2UL << FMC_BCRx_MTYP_Pos)
#define FMC_BCRx_MWID_Pos   (4U)
#define FMC_BCRx_MWID_Msk   (0x3UL << FMC_BCRx_MWID_Pos)
#define FMC_BCRx_MWID   FMC_BCRx_MWID_Msk
#define FMC_BCRx_MWID_0   (0x1UL << FMC_BCRx_MWID_Pos)
#define FMC_BCRx_MWID_1   (0x2UL << FMC_BCRx_MWID_Pos)
#define FMC_BCRx_FACCEN_Pos   (6U)
#define FMC_BCRx_FACCEN_Msk   (0x1UL << FMC_BCRx_FACCEN_Pos)
#define FMC_BCRx_FACCEN   FMC_BCRx_FACCEN_Msk
#define FMC_BCRx_BURSTEN_Pos   (8U)
#define FMC_BCRx_BURSTEN_Msk   (0x1UL << FMC_BCRx_BURSTEN_Pos)
#define FMC_BCRx_BURSTEN   FMC_BCRx_BURSTEN_Msk
#define FMC_BCRx_WAITPOL_Pos   (9U)
#define FMC_BCRx_WAITPOL_Msk   (0x1UL << FMC_BCRx_WAITPOL_Pos)
#define FMC_BCRx_WAITPOL   FMC_BCRx_WAITPOL_Msk
#define FMC_BCRx_WAITCFG_Pos   (11U)
#define FMC_BCRx_WAITCFG_Msk   (0x1UL << FMC_BCRx_WAITCFG_Pos)
#define FMC_BCRx_WAITCFG   FMC_BCRx_WAITCFG_Msk
#define FMC_BCRx_WREN_Pos   (12U)
#define FMC_BCRx_WREN_Msk   (0x1UL << FMC_BCRx_WREN_Pos)
#define FMC_BCRx_WREN   FMC_BCRx_WREN_Msk
#define FMC_BCRx_WAITEN_Pos   (13U)
#define FMC_BCRx_WAITEN_Msk   (0x1UL << FMC_BCRx_WAITEN_Pos)
#define FMC_BCRx_WAITEN   FMC_BCRx_WAITEN_Msk
#define FMC_BCRx_EXTMOD_Pos   (14U)
#define FMC_BCRx_EXTMOD_Msk   (0x1UL << FMC_BCRx_EXTMOD_Pos)
#define FMC_BCRx_EXTMOD   FMC_BCRx_EXTMOD_Msk
#define FMC_BCRx_ASYNCWAIT_Pos   (15U)
#define FMC_BCRx_ASYNCWAIT_Msk   (0x1UL << FMC_BCRx_ASYNCWAIT_Pos)
#define FMC_BCRx_ASYNCWAIT   FMC_BCRx_ASYNCWAIT_Msk
#define FMC_BCRx_CPSIZE_Pos   (16U)
#define FMC_BCRx_CPSIZE_Msk   (0x7UL << FMC_BCRx_CPSIZE_Pos)
#define FMC_BCRx_CPSIZE   FMC_BCRx_CPSIZE_Msk
#define FMC_BCRx_CPSIZE_0   (0x1UL << FMC_BCRx_CPSIZE_Pos)
#define FMC_BCRx_CPSIZE_1   (0x2UL << FMC_BCRx_CPSIZE_Pos)
#define FMC_BCRx_CPSIZE_2   (0x4UL << FMC_BCRx_CPSIZE_Pos)
#define FMC_BCRx_CBURSTRW_Pos   (19U)
#define FMC_BCRx_CBURSTRW_Msk   (0x1UL << FMC_BCRx_CBURSTRW_Pos)
#define FMC_BCRx_CBURSTRW   FMC_BCRx_CBURSTRW_Msk
#define FMC_BCRx_NBLSET_Pos   (22U)
#define FMC_BCRx_NBLSET_Msk   (0x3UL << FMC_BCRx_NBLSET_Pos)
#define FMC_BCRx_NBLSET   FMC_BCRx_NBLSET_Msk
#define FMC_BCRx_NBLSET_0   (0x1UL << FMC_BCRx_NBLSET_Pos)
#define FMC_BCRx_NBLSET_1   (0x2UL << FMC_BCRx_NBLSET_Pos)
#define FMC_BTRx_ADDSET_Pos   (0U)
#define FMC_BTRx_ADDSET_Msk   (0xFUL << FMC_BTRx_ADDSET_Pos)
#define FMC_BTRx_ADDSET   FMC_BTRx_ADDSET_Msk
#define FMC_BTRx_ADDSET_0   (0x1UL << FMC_BTRx_ADDSET_Pos)
#define FMC_BTRx_ADDSET_1   (0x2UL << FMC_BTRx_ADDSET_Pos)
#define FMC_BTRx_ADDSET_2   (0x4UL << FMC_BTRx_ADDSET_Pos)
#define FMC_BTRx_ADDSET_3   (0x8UL << FMC_BTRx_ADDSET_Pos)
#define FMC_BTRx_ADDHLD_Pos   (4U)
#define FMC_BTRx_ADDHLD_Msk   (0xFUL << FMC_BTRx_ADDHLD_Pos)
#define FMC_BTRx_ADDHLD   FMC_BTRx_ADDHLD_Msk
#define FMC_BTRx_ADDHLD_0   (0x1UL << FMC_BTRx_ADDHLD_Pos)
#define FMC_BTRx_ADDHLD_1   (0x2UL << FMC_BTRx_ADDHLD_Pos)
#define FMC_BTRx_ADDHLD_2   (0x4UL << FMC_BTRx_ADDHLD_Pos)
#define FMC_BTRx_ADDHLD_3   (0x8UL << FMC_BTRx_ADDHLD_Pos)
#define FMC_BTRx_DATAST_Pos   (8U)
#define FMC_BTRx_DATAST_Msk   (0xFFUL << FMC_BTRx_DATAST_Pos)
#define FMC_BTRx_DATAST   FMC_BTRx_DATAST_Msk
#define FMC_BTRx_DATAST_0   (0x01UL << FMC_BTRx_DATAST_Pos)
#define FMC_BTRx_DATAST_1   (0x02UL << FMC_BTRx_DATAST_Pos)
#define FMC_BTRx_DATAST_2   (0x04UL << FMC_BTRx_DATAST_Pos)
#define FMC_BTRx_DATAST_3   (0x08UL << FMC_BTRx_DATAST_Pos)
#define FMC_BTRx_DATAST_4   (0x10UL << FMC_BTRx_DATAST_Pos)
#define FMC_BTRx_DATAST_5   (0x20UL << FMC_BTRx_DATAST_Pos)
#define FMC_BTRx_DATAST_6   (0x40UL << FMC_BTRx_DATAST_Pos)
#define FMC_BTRx_DATAST_7   (0x80UL << FMC_BTRx_DATAST_Pos)
#define FMC_BTRx_BUSTURN_Pos   (16U)
#define FMC_BTRx_BUSTURN_Msk   (0xFUL << FMC_BTRx_BUSTURN_Pos)
#define FMC_BTRx_BUSTURN   FMC_BTRx_BUSTURN_Msk
#define FMC_BTRx_BUSTURN_0   (0x1UL << FMC_BTRx_BUSTURN_Pos)
#define FMC_BTRx_BUSTURN_1   (0x2UL << FMC_BTRx_BUSTURN_Pos)
#define FMC_BTRx_BUSTURN_2   (0x4UL << FMC_BTRx_BUSTURN_Pos)
#define FMC_BTRx_BUSTURN_3   (0x8UL << FMC_BTRx_BUSTURN_Pos)
#define FMC_BTRx_CLKDIV_Pos   (20U)
#define FMC_BTRx_CLKDIV_Msk   (0xFUL << FMC_BTRx_CLKDIV_Pos)
#define FMC_BTRx_CLKDIV   FMC_BTRx_CLKDIV_Msk
#define FMC_BTRx_CLKDIV_0   (0x1UL << FMC_BTRx_CLKDIV_Pos)
#define FMC_BTRx_CLKDIV_1   (0x2UL << FMC_BTRx_CLKDIV_Pos)
#define FMC_BTRx_CLKDIV_2   (0x4UL << FMC_BTRx_CLKDIV_Pos)
#define FMC_BTRx_CLKDIV_3   (0x8UL << FMC_BTRx_CLKDIV_Pos)
#define FMC_BTRx_DATLAT_Pos   (24U)
#define FMC_BTRx_DATLAT_Msk   (0xFUL << FMC_BTRx_DATLAT_Pos)
#define FMC_BTRx_DATLAT   FMC_BTRx_DATLAT_Msk
#define FMC_BTRx_DATLAT_0   (0x1UL << FMC_BTRx_DATLAT_Pos)
#define FMC_BTRx_DATLAT_1   (0x2UL << FMC_BTRx_DATLAT_Pos)
#define FMC_BTRx_DATLAT_2   (0x4UL << FMC_BTRx_DATLAT_Pos)
#define FMC_BTRx_DATLAT_3   (0x8UL << FMC_BTRx_DATLAT_Pos)
#define FMC_BTRx_ACCMOD_Pos   (28U)
#define FMC_BTRx_ACCMOD_Msk   (0x3UL << FMC_BTRx_ACCMOD_Pos)
#define FMC_BTRx_ACCMOD   FMC_BTRx_ACCMOD_Msk
#define FMC_BTRx_ACCMOD_0   (0x1UL << FMC_BTRx_ACCMOD_Pos)
#define FMC_BTRx_ACCMOD_1   (0x2UL << FMC_BTRx_ACCMOD_Pos)
#define FMC_BTRx_DATAHLD_Pos   (30U)
#define FMC_BTRx_DATAHLD_Msk   (0x3UL << FMC_BTRx_DATAHLD_Pos)
#define FMC_BTRx_DATAHLD   FMC_BTRx_DATAHLD_Msk
#define FMC_BTRx_DATAHLD_0   (0x1UL << FMC_BTRx_DATAHLD_Pos)
#define FMC_BTRx_DATAHLD_1   (0x2UL << FMC_BTRx_DATAHLD_Pos)
#define FMC_BWTRx_ADDSET_Pos   (0U)
#define FMC_BWTRx_ADDSET_Msk   (0xFUL << FMC_BWTRx_ADDSET_Pos)
#define FMC_BWTRx_ADDSET   FMC_BWTRx_ADDSET_Msk
#define FMC_BWTRx_ADDSET_0   (0x1UL << FMC_BWTRx_ADDSET_Pos)
#define FMC_BWTRx_ADDSET_1   (0x2UL << FMC_BWTRx_ADDSET_Pos)
#define FMC_BWTRx_ADDSET_2   (0x4UL << FMC_BWTRx_ADDSET_Pos)
#define FMC_BWTRx_ADDSET_3   (0x8UL << FMC_BWTRx_ADDSET_Pos)
#define FMC_BWTRx_ADDHLD_Pos   (4U)
#define FMC_BWTRx_ADDHLD_Msk   (0xFUL << FMC_BWTRx_ADDHLD_Pos)
#define FMC_BWTRx_ADDHLD   FMC_BWTRx_ADDHLD_Msk
#define FMC_BWTRx_ADDHLD_0   (0x1UL << FMC_BWTRx_ADDHLD_Pos)
#define FMC_BWTRx_ADDHLD_1   (0x2UL << FMC_BWTRx_ADDHLD_Pos)
#define FMC_BWTRx_ADDHLD_2   (0x4UL << FMC_BWTRx_ADDHLD_Pos)
#define FMC_BWTRx_ADDHLD_3   (0x8UL << FMC_BWTRx_ADDHLD_Pos)
#define FMC_BWTRx_DATAST_Pos   (8U)
#define FMC_BWTRx_DATAST_Msk   (0xFFUL << FMC_BWTRx_DATAST_Pos)
#define FMC_BWTRx_DATAST   FMC_BWTRx_DATAST_Msk
#define FMC_BWTRx_DATAST_0   (0x01UL << FMC_BWTRx_DATAST_Pos)
#define FMC_BWTRx_DATAST_1   (0x02UL << FMC_BWTRx_DATAST_Pos)
#define FMC_BWTRx_DATAST_2   (0x04UL << FMC_BWTRx_DATAST_Pos)
#define FMC_BWTRx_DATAST_3   (0x08UL << FMC_BWTRx_DATAST_Pos)
#define FMC_BWTRx_DATAST_4   (0x10UL << FMC_BWTRx_DATAST_Pos)
#define FMC_BWTRx_DATAST_5   (0x20UL << FMC_BWTRx_DATAST_Pos)
#define FMC_BWTRx_DATAST_6   (0x40UL << FMC_BWTRx_DATAST_Pos)
#define FMC_BWTRx_DATAST_7   (0x80UL << FMC_BWTRx_DATAST_Pos)
#define FMC_BWTRx_BUSTURN_Pos   (16U)
#define FMC_BWTRx_BUSTURN_Msk   (0xFUL << FMC_BWTRx_BUSTURN_Pos)
#define FMC_BWTRx_BUSTURN   FMC_BWTRx_BUSTURN_Msk
#define FMC_BWTRx_BUSTURN_0   (0x1UL << FMC_BWTRx_BUSTURN_Pos)
#define FMC_BWTRx_BUSTURN_1   (0x2UL << FMC_BWTRx_BUSTURN_Pos)
#define FMC_BWTRx_BUSTURN_2   (0x4UL << FMC_BWTRx_BUSTURN_Pos)
#define FMC_BWTRx_BUSTURN_3   (0x8UL << FMC_BWTRx_BUSTURN_Pos)
#define FMC_BWTRx_ACCMOD_Pos   (28U)
#define FMC_BWTRx_ACCMOD_Msk   (0x3UL << FMC_BWTRx_ACCMOD_Pos)
#define FMC_BWTRx_ACCMOD   FMC_BWTRx_ACCMOD_Msk
#define FMC_BWTRx_ACCMOD_0   (0x1UL << FMC_BWTRx_ACCMOD_Pos)
#define FMC_BWTRx_ACCMOD_1   (0x2UL << FMC_BWTRx_ACCMOD_Pos)
#define FMC_BWTRx_DATAHLD_Pos   (30U)
#define FMC_BWTRx_DATAHLD_Msk   (0x3UL << FMC_BWTRx_DATAHLD_Pos)
#define FMC_BWTRx_DATAHLD   FMC_BWTRx_DATAHLD_Msk
#define FMC_BWTRx_DATAHLD_0   (0x1UL << FMC_BWTRx_DATAHLD_Pos)
#define FMC_BWTRx_DATAHLD_1   (0x2UL << FMC_BWTRx_DATAHLD_Pos)
#define FMC_PCSCNTR_CSCOUNT_Pos   (0U)
#define FMC_PCSCNTR_CSCOUNT_Msk   (0xFFFFUL << FMC_PCSCNTR_CSCOUNT_Pos)
#define FMC_PCSCNTR_CSCOUNT   FMC_PCSCNTR_CSCOUNT_Msk
#define FMC_PCSCNTR_CNTB1EN_Pos   (16U)
#define FMC_PCSCNTR_CNTB1EN_Msk   (0x1UL << FMC_PCSCNTR_CNTB1EN_Pos)
#define FMC_PCSCNTR_CNTB1EN   FMC_PCSCNTR_CNTB1EN_Msk
#define FMC_PCSCNTR_CNTB2EN_Pos   (17U)
#define FMC_PCSCNTR_CNTB2EN_Msk   (0x1UL << FMC_PCSCNTR_CNTB2EN_Pos)
#define FMC_PCSCNTR_CNTB2EN   FMC_PCSCNTR_CNTB2EN_Msk
#define FMC_PCSCNTR_CNTB3EN_Pos   (18U)
#define FMC_PCSCNTR_CNTB3EN_Msk   (0x1UL << FMC_PCSCNTR_CNTB3EN_Pos)
#define FMC_PCSCNTR_CNTB3EN   FMC_PCSCNTR_CNTB3EN_Msk
#define FMC_PCSCNTR_CNTB4EN_Pos   (19U)
#define FMC_PCSCNTR_CNTB4EN_Msk   (0x1UL << FMC_PCSCNTR_CNTB4EN_Pos)
#define FMC_PCSCNTR_CNTB4EN   FMC_PCSCNTR_CNTB4EN_Msk
#define FMC_PCR_PWAITEN_Pos   (1U)
#define FMC_PCR_PWAITEN_Msk   (0x1UL << FMC_PCR_PWAITEN_Pos)
#define FMC_PCR_PWAITEN   FMC_PCR_PWAITEN_Msk
#define FMC_PCR_PBKEN_Pos   (2U)
#define FMC_PCR_PBKEN_Msk   (0x1UL << FMC_PCR_PBKEN_Pos)
#define FMC_PCR_PBKEN   FMC_PCR_PBKEN_Msk
#define FMC_PCR_PTYP_Pos   (3U)
#define FMC_PCR_PTYP_Msk   (0x1UL << FMC_PCR_PTYP_Pos)
#define FMC_PCR_PTYP   FMC_PCR_PTYP_Msk
#define FMC_PCR_PWID_Pos   (4U)
#define FMC_PCR_PWID_Msk   (0x3UL << FMC_PCR_PWID_Pos)
#define FMC_PCR_PWID   FMC_PCR_PWID_Msk
#define FMC_PCR_PWID_0   (0x1UL << FMC_PCR_PWID_Pos)
#define FMC_PCR_PWID_1   (0x2UL << FMC_PCR_PWID_Pos)
#define FMC_PCR_ECCEN_Pos   (6U)
#define FMC_PCR_ECCEN_Msk   (0x1UL << FMC_PCR_ECCEN_Pos)
#define FMC_PCR_ECCEN   FMC_PCR_ECCEN_Msk
#define FMC_PCR_TCLR_Pos   (9U)
#define FMC_PCR_TCLR_Msk   (0xFUL << FMC_PCR_TCLR_Pos)
#define FMC_PCR_TCLR   FMC_PCR_TCLR_Msk
#define FMC_PCR_TCLR_0   (0x1UL << FMC_PCR_TCLR_Pos)
#define FMC_PCR_TCLR_1   (0x2UL << FMC_PCR_TCLR_Pos)
#define FMC_PCR_TCLR_2   (0x4UL << FMC_PCR_TCLR_Pos)
#define FMC_PCR_TCLR_3   (0x8UL << FMC_PCR_TCLR_Pos)
#define FMC_PCR_TAR_Pos   (13U)
#define FMC_PCR_TAR_Msk   (0xFUL << FMC_PCR_TAR_Pos)
#define FMC_PCR_TAR   FMC_PCR_TAR_Msk
#define FMC_PCR_TAR_0   (0x1UL << FMC_PCR_TAR_Pos)
#define FMC_PCR_TAR_1   (0x2UL << FMC_PCR_TAR_Pos)
#define FMC_PCR_TAR_2   (0x4UL << FMC_PCR_TAR_Pos)
#define FMC_PCR_TAR_3   (0x8UL << FMC_PCR_TAR_Pos)
#define FMC_PCR_ECCPS_Pos   (17U)
#define FMC_PCR_ECCPS_Msk   (0x7UL << FMC_PCR_ECCPS_Pos)
#define FMC_PCR_ECCPS   FMC_PCR_ECCPS_Msk
#define FMC_PCR_ECCPS_0   (0x1UL << FMC_PCR_ECCPS_Pos)
#define FMC_PCR_ECCPS_1   (0x2UL << FMC_PCR_ECCPS_Pos)
#define FMC_PCR_ECCPS_2   (0x4UL << FMC_PCR_ECCPS_Pos)
#define FMC_SR_IRS_Pos   (0U)
#define FMC_SR_IRS_Msk   (0x1UL << FMC_SR_IRS_Pos)
#define FMC_SR_IRS   FMC_SR_IRS_Msk
#define FMC_SR_ILS_Pos   (1U)
#define FMC_SR_ILS_Msk   (0x1UL << FMC_SR_ILS_Pos)
#define FMC_SR_ILS   FMC_SR_ILS_Msk
#define FMC_SR_IFS_Pos   (2U)
#define FMC_SR_IFS_Msk   (0x1UL << FMC_SR_IFS_Pos)
#define FMC_SR_IFS   FMC_SR_IFS_Msk
#define FMC_SR_IREN_Pos   (3U)
#define FMC_SR_IREN_Msk   (0x1UL << FMC_SR_IREN_Pos)
#define FMC_SR_IREN   FMC_SR_IREN_Msk
#define FMC_SR_ILEN_Pos   (4U)
#define FMC_SR_ILEN_Msk   (0x1UL << FMC_SR_ILEN_Pos)
#define FMC_SR_ILEN   FMC_SR_ILEN_Msk
#define FMC_SR_IFEN_Pos   (5U)
#define FMC_SR_IFEN_Msk   (0x1UL << FMC_SR_IFEN_Pos)
#define FMC_SR_IFEN   FMC_SR_IFEN_Msk
#define FMC_SR_FEMPT_Pos   (6U)
#define FMC_SR_FEMPT_Msk   (0x1UL << FMC_SR_FEMPT_Pos)
#define FMC_SR_FEMPT   FMC_SR_FEMPT_Msk
#define FMC_PMEM_MEMSET_Pos   (0U)
#define FMC_PMEM_MEMSET_Msk   (0xFFUL << FMC_PMEM_MEMSET_Pos)
#define FMC_PMEM_MEMSET   FMC_PMEM_MEMSET_Msk
#define FMC_PMEM_MEMSET_0   (0x01UL << FMC_PMEM_MEMSET_Pos)
#define FMC_PMEM_MEMSET_1   (0x02UL << FMC_PMEM_MEMSET_Pos)
#define FMC_PMEM_MEMSET_2   (0x04UL << FMC_PMEM_MEMSET_Pos)
#define FMC_PMEM_MEMSET_3   (0x08UL << FMC_PMEM_MEMSET_Pos)
#define FMC_PMEM_MEMSET_4   (0x10UL << FMC_PMEM_MEMSET_Pos)
#define FMC_PMEM_MEMSET_5   (0x20UL << FMC_PMEM_MEMSET_Pos)
#define FMC_PMEM_MEMSET_6   (0x40UL << FMC_PMEM_MEMSET_Pos)
#define FMC_PMEM_MEMSET_7   (0x80UL << FMC_PMEM_MEMSET_Pos)
#define FMC_PMEM_MEMWAIT_Pos   (8U)
#define FMC_PMEM_MEMWAIT_Msk   (0xFFUL << FMC_PMEM_MEMWAIT_Pos)
#define FMC_PMEM_MEMWAIT   FMC_PMEM_MEMWAIT_Msk
#define FMC_PMEM_MEMWAIT_0   (0x01UL << FMC_PMEM_MEMWAIT_Pos)
#define FMC_PMEM_MEMWAIT_1   (0x02UL << FMC_PMEM_MEMWAIT_Pos)
#define FMC_PMEM_MEMWAIT_2   (0x04UL << FMC_PMEM_MEMWAIT_Pos)
#define FMC_PMEM_MEMWAIT_3   (0x08UL << FMC_PMEM_MEMWAIT_Pos)
#define FMC_PMEM_MEMWAIT_4   (0x10UL << FMC_PMEM_MEMWAIT_Pos)
#define FMC_PMEM_MEMWAIT_5   (0x20UL << FMC_PMEM_MEMWAIT_Pos)
#define FMC_PMEM_MEMWAIT_6   (0x40UL << FMC_PMEM_MEMWAIT_Pos)
#define FMC_PMEM_MEMWAIT_7   (0x80UL << FMC_PMEM_MEMWAIT_Pos)
#define FMC_PMEM_MEMHOLD_Pos   (16U)
#define FMC_PMEM_MEMHOLD_Msk   (0xFFUL << FMC_PMEM_MEMHOLD_Pos)
#define FMC_PMEM_MEMHOLD   FMC_PMEM_MEMHOLD_Msk
#define FMC_PMEM_MEMHOLD_0   (0x01UL << FMC_PMEM_MEMHOLD_Pos)
#define FMC_PMEM_MEMHOLD_1   (0x02UL << FMC_PMEM_MEMHOLD_Pos)
#define FMC_PMEM_MEMHOLD_2   (0x04UL << FMC_PMEM_MEMHOLD_Pos)
#define FMC_PMEM_MEMHOLD_3   (0x08UL << FMC_PMEM_MEMHOLD_Pos)
#define FMC_PMEM_MEMHOLD_4   (0x10UL << FMC_PMEM_MEMHOLD_Pos)
#define FMC_PMEM_MEMHOLD_5   (0x20UL << FMC_PMEM_MEMHOLD_Pos)
#define FMC_PMEM_MEMHOLD_6   (0x40UL << FMC_PMEM_MEMHOLD_Pos)
#define FMC_PMEM_MEMHOLD_7   (0x80UL << FMC_PMEM_MEMHOLD_Pos)
#define FMC_PMEM_MEMHIZ_Pos   (24U)
#define FMC_PMEM_MEMHIZ_Msk   (0xFFUL << FMC_PMEM_MEMHIZ_Pos)
#define FMC_PMEM_MEMHIZ   FMC_PMEM_MEMHIZ_Msk
#define FMC_PMEM_MEMHIZ_0   (0x01UL << FMC_PMEM_MEMHIZ_Pos)
#define FMC_PMEM_MEMHIZ_1   (0x02UL << FMC_PMEM_MEMHIZ_Pos)
#define FMC_PMEM_MEMHIZ_2   (0x04UL << FMC_PMEM_MEMHIZ_Pos)
#define FMC_PMEM_MEMHIZ_3   (0x08UL << FMC_PMEM_MEMHIZ_Pos)
#define FMC_PMEM_MEMHIZ_4   (0x10UL << FMC_PMEM_MEMHIZ_Pos)
#define FMC_PMEM_MEMHIZ_5   (0x20UL << FMC_PMEM_MEMHIZ_Pos)
#define FMC_PMEM_MEMHIZ_6   (0x40UL << FMC_PMEM_MEMHIZ_Pos)
#define FMC_PMEM_MEMHIZ_7   (0x80UL << FMC_PMEM_MEMHIZ_Pos)
#define FMC_PATT_ATTSET_Pos   (0U)
#define FMC_PATT_ATTSET_Msk   (0xFFUL << FMC_PATT_ATTSET_Pos)
#define FMC_PATT_ATTSET   FMC_PATT_ATTSET_Msk
#define FMC_PATT_ATTSET_0   (0x01UL << FMC_PATT_ATTSET_Pos)
#define FMC_PATT_ATTSET_1   (0x02UL << FMC_PATT_ATTSET_Pos)
#define FMC_PATT_ATTSET_2   (0x04UL << FMC_PATT_ATTSET_Pos)
#define FMC_PATT_ATTSET_3   (0x08UL << FMC_PATT_ATTSET_Pos)
#define FMC_PATT_ATTSET_4   (0x10UL << FMC_PATT_ATTSET_Pos)
#define FMC_PATT_ATTSET_5   (0x20UL << FMC_PATT_ATTSET_Pos)
#define FMC_PATT_ATTSET_6   (0x40UL << FMC_PATT_ATTSET_Pos)
#define FMC_PATT_ATTSET_7   (0x80UL << FMC_PATT_ATTSET_Pos)
#define FMC_PATT_ATTWAIT_Pos   (8U)
#define FMC_PATT_ATTWAIT_Msk   (0xFFUL << FMC_PATT_ATTWAIT_Pos)
#define FMC_PATT_ATTWAIT   FMC_PATT_ATTWAIT_Msk
#define FMC_PATT_ATTWAIT_0   (0x01UL << FMC_PATT_ATTWAIT_Pos)
#define FMC_PATT_ATTWAIT_1   (0x02UL << FMC_PATT_ATTWAIT_Pos)
#define FMC_PATT_ATTWAIT_2   (0x04UL << FMC_PATT_ATTWAIT_Pos)
#define FMC_PATT_ATTWAIT_3   (0x08UL << FMC_PATT_ATTWAIT_Pos)
#define FMC_PATT_ATTWAIT_4   (0x10UL << FMC_PATT_ATTWAIT_Pos)
#define FMC_PATT_ATTWAIT_5   (0x20UL << FMC_PATT_ATTWAIT_Pos)
#define FMC_PATT_ATTWAIT_6   (0x40UL << FMC_PATT_ATTWAIT_Pos)
#define FMC_PATT_ATTWAIT_7   (0x80UL << FMC_PATT_ATTWAIT_Pos)
#define FMC_PATT_ATTHOLD_Pos   (16U)
#define FMC_PATT_ATTHOLD_Msk   (0xFFUL << FMC_PATT_ATTHOLD_Pos)
#define FMC_PATT_ATTHOLD   FMC_PATT_ATTHOLD_Msk
#define FMC_PATT_ATTHOLD_0   (0x01UL << FMC_PATT_ATTHOLD_Pos)
#define FMC_PATT_ATTHOLD_1   (0x02UL << FMC_PATT_ATTHOLD_Pos)
#define FMC_PATT_ATTHOLD_2   (0x04UL << FMC_PATT_ATTHOLD_Pos)
#define FMC_PATT_ATTHOLD_3   (0x08UL << FMC_PATT_ATTHOLD_Pos)
#define FMC_PATT_ATTHOLD_4   (0x10UL << FMC_PATT_ATTHOLD_Pos)
#define FMC_PATT_ATTHOLD_5   (0x20UL << FMC_PATT_ATTHOLD_Pos)
#define FMC_PATT_ATTHOLD_6   (0x40UL << FMC_PATT_ATTHOLD_Pos)
#define FMC_PATT_ATTHOLD_7   (0x80UL << FMC_PATT_ATTHOLD_Pos)
#define FMC_PATT_ATTHIZ_Pos   (24U)
#define FMC_PATT_ATTHIZ_Msk   (0xFFUL << FMC_PATT_ATTHIZ_Pos)
#define FMC_PATT_ATTHIZ   FMC_PATT_ATTHIZ_Msk
#define FMC_PATT_ATTHIZ_0   (0x01UL << FMC_PATT_ATTHIZ_Pos)
#define FMC_PATT_ATTHIZ_1   (0x02UL << FMC_PATT_ATTHIZ_Pos)
#define FMC_PATT_ATTHIZ_2   (0x04UL << FMC_PATT_ATTHIZ_Pos)
#define FMC_PATT_ATTHIZ_3   (0x08UL << FMC_PATT_ATTHIZ_Pos)
#define FMC_PATT_ATTHIZ_4   (0x10UL << FMC_PATT_ATTHIZ_Pos)
#define FMC_PATT_ATTHIZ_5   (0x20UL << FMC_PATT_ATTHIZ_Pos)
#define FMC_PATT_ATTHIZ_6   (0x40UL << FMC_PATT_ATTHIZ_Pos)
#define FMC_PATT_ATTHIZ_7   (0x80UL << FMC_PATT_ATTHIZ_Pos)
#define FMC_ECCR3_ECC3_Pos   (0U)
#define FMC_ECCR3_ECC3_Msk   (0xFFFFFFFFUL << FMC_ECCR3_ECC3_Pos)
#define FMC_ECCR3_ECC3   FMC_ECCR3_ECC3_Msk
#define GFXMMU_CR_B0OIE_Pos   (0U)
#define GFXMMU_CR_B0OIE_Msk   (0x1UL << GFXMMU_CR_B0OIE_Pos)
#define GFXMMU_CR_B0OIE   GFXMMU_CR_B0OIE_Msk
#define GFXMMU_CR_B1OIE_Pos   (1U)
#define GFXMMU_CR_B1OIE_Msk   (0x1UL << GFXMMU_CR_B1OIE_Pos)
#define GFXMMU_CR_B1OIE   GFXMMU_CR_B1OIE_Msk
#define GFXMMU_CR_B2OIE_Pos   (2U)
#define GFXMMU_CR_B2OIE_Msk   (0x1UL << GFXMMU_CR_B2OIE_Pos)
#define GFXMMU_CR_B2OIE   GFXMMU_CR_B2OIE_Msk
#define GFXMMU_CR_B3OIE_Pos   (3U)
#define GFXMMU_CR_B3OIE_Msk   (0x1UL << GFXMMU_CR_B3OIE_Pos)
#define GFXMMU_CR_B3OIE   GFXMMU_CR_B3OIE_Msk
#define GFXMMU_CR_AMEIE_Pos   (4U)
#define GFXMMU_CR_AMEIE_Msk   (0x1UL << GFXMMU_CR_AMEIE_Pos)
#define GFXMMU_CR_AMEIE   GFXMMU_CR_AMEIE_Msk
#define GFXMMU_CR_192BM_Pos   (6U)
#define GFXMMU_CR_192BM_Msk   (0x1UL << GFXMMU_CR_192BM_Pos)
#define GFXMMU_CR_192BM   GFXMMU_CR_192BM_Msk
#define GFXMMU_CR_ACE_Pos   (20U)
#define GFXMMU_CR_ACE_Msk   (0x1UL << GFXMMU_CR_ACE_Pos)
#define GFXMMU_CR_ACE   GFXMMU_CR_ACE_Msk
#define GFXMMU_CR_ACLB_Pos   (21U)
#define GFXMMU_CR_ACLB_Msk   (0x3UL << GFXMMU_CR_ACLB_Pos)
#define GFXMMU_CR_ACLB   GFXMMU_CR_ACLB_Msk
#define GFXMMU_CR_ACLB_0   (0x1UL << GFXMMU_CR_ACLB_Pos)
#define GFXMMU_CR_ACLB_1   (0x2UL << GFXMMU_CR_ACLB_Pos)
#define GFXMMU_SR_B0OF_Pos   (0U)
#define GFXMMU_SR_B0OF_Msk   (0x1UL << GFXMMU_SR_B0OF_Pos)
#define GFXMMU_SR_B0OF   GFXMMU_SR_B0OF_Msk
#define GFXMMU_SR_B1OF_Pos   (1U)
#define GFXMMU_SR_B1OF_Msk   (0x1UL << GFXMMU_SR_B1OF_Pos)
#define GFXMMU_SR_B1OF   GFXMMU_SR_B1OF_Msk
#define GFXMMU_SR_B2OF_Pos   (2U)
#define GFXMMU_SR_B2OF_Msk   (0x1UL << GFXMMU_SR_B2OF_Pos)
#define GFXMMU_SR_B2OF   GFXMMU_SR_B2OF_Msk
#define GFXMMU_SR_B3OF_Pos   (3U)
#define GFXMMU_SR_B3OF_Msk   (0x1UL << GFXMMU_SR_B3OF_Pos)
#define GFXMMU_SR_B3OF   GFXMMU_SR_B3OF_Msk
#define GFXMMU_SR_AMEF_Pos   (4U)
#define GFXMMU_SR_AMEF_Msk   (0x1UL << GFXMMU_SR_AMEF_Pos)
#define GFXMMU_SR_AMEF   GFXMMU_SR_AMEF_Msk
#define GFXMMU_FCR_CB0OF_Pos   (0U)
#define GFXMMU_FCR_CB0OF_Msk   (0x1UL << GFXMMU_FCR_CB0OF_Pos)
#define GFXMMU_FCR_CB0OF   GFXMMU_FCR_CB0OF_Msk
#define GFXMMU_FCR_CB1OF_Pos   (1U)
#define GFXMMU_FCR_CB1OF_Msk   (0x1UL << GFXMMU_FCR_CB1OF_Pos)
#define GFXMMU_FCR_CB1OF   GFXMMU_FCR_CB1OF_Msk
#define GFXMMU_FCR_CB2OF_Pos   (2U)
#define GFXMMU_FCR_CB2OF_Msk   (0x1UL << GFXMMU_FCR_CB2OF_Pos)
#define GFXMMU_FCR_CB2OF   GFXMMU_FCR_CB2OF_Msk
#define GFXMMU_FCR_CB3OF_Pos   (3U)
#define GFXMMU_FCR_CB3OF_Msk   (0x1UL << GFXMMU_FCR_CB3OF_Pos)
#define GFXMMU_FCR_CB3OF   GFXMMU_FCR_CB3OF_Msk
#define GFXMMU_FCR_CAMEF_Pos   (4U)
#define GFXMMU_FCR_CAMEF_Msk   (0x1UL << GFXMMU_FCR_CAMEF_Pos)
#define GFXMMU_FCR_CAMEF   GFXMMU_FCR_CAMEF_Msk
#define GFXMMU_CCR_FF_Pos   (0U)
#define GFXMMU_CCR_FF_Msk   (0x1UL << GFXMMU_CCR_FF_Pos)
#define GFXMMU_CCR_FF   GFXMMU_CCR_FF_Msk
#define GFXMMU_CCR_FI_Pos   (1U)
#define GFXMMU_CCR_FI_Msk   (0x1UL << GFXMMU_CCR_FI_Pos)
#define GFXMMU_CCR_FI   GFXMMU_CCR_FI_Msk
#define GFXMMU_DVR_DV_Pos   (0U)
#define GFXMMU_DVR_DV_Msk   (0xFFFFFFFFUL << GFXMMU_DVR_DV_Pos)
#define GFXMMU_DVR_DV   GFXMMU_DVR_DV_Msk
#define GFXMMU_B0CR_PBO_Pos   (4U)
#define GFXMMU_B0CR_PBO_Msk   (0x7FFFFUL << GFXMMU_B0CR_PBO_Pos)
#define GFXMMU_B0CR_PBO   GFXMMU_B0CR_PBO_Msk
#define GFXMMU_B0CR_PBBA_Pos   (23U)
#define GFXMMU_B0CR_PBBA_Msk   (0x1FFUL << GFXMMU_B0CR_PBBA_Pos)
#define GFXMMU_B0CR_PBBA   GFXMMU_B0CR_PBBA_Msk
#define GFXMMU_B1CR_PBO_Pos   (4U)
#define GFXMMU_B1CR_PBO_Msk   (0x7FFFFUL << GFXMMU_B1CR_PBO_Pos)
#define GFXMMU_B1CR_PBO   GFXMMU_B1CR_PBO_Msk
#define GFXMMU_B1CR_PBBA_Pos   (23U)
#define GFXMMU_B1CR_PBBA_Msk   (0x1FFUL << GFXMMU_B1CR_PBBA_Pos)
#define GFXMMU_B1CR_PBBA   GFXMMU_B1CR_PBBA_Msk
#define GFXMMU_B2CR_PBO_Pos   (4U)
#define GFXMMU_B2CR_PBO_Msk   (0x7FFFFUL << GFXMMU_B2CR_PBO_Pos)
#define GFXMMU_B2CR_PBO   GFXMMU_B2CR_PBO_Msk
#define GFXMMU_B2CR_PBBA_Pos   (23U)
#define GFXMMU_B2CR_PBBA_Msk   (0x1FFUL << GFXMMU_B2CR_PBBA_Pos)
#define GFXMMU_B2CR_PBBA   GFXMMU_B2CR_PBBA_Msk
#define GFXMMU_B3CR_PBO_Pos   (4U)
#define GFXMMU_B3CR_PBO_Msk   (0x7FFFFUL << GFXMMU_B3CR_PBO_Pos)
#define GFXMMU_B3CR_PBO   GFXMMU_B3CR_PBO_Msk
#define GFXMMU_B3CR_PBBA_Pos   (23U)
#define GFXMMU_B3CR_PBBA_Msk   (0x1FFUL << GFXMMU_B3CR_PBBA_Pos)
#define GFXMMU_B3CR_PBBA   GFXMMU_B3CR_PBBA_Msk
#define GFXMMU_LUTxL_EN_Pos   (0U)
#define GFXMMU_LUTxL_EN_Msk   (0x1UL << GFXMMU_LUTxL_EN_Pos)
#define GFXMMU_LUTxL_EN   GFXMMU_LUTxL_EN_Msk
#define GFXMMU_LUTxL_FVB_Pos   (8U)
#define GFXMMU_LUTxL_FVB_Msk   (0xFFUL << GFXMMU_LUTxL_FVB_Pos)
#define GFXMMU_LUTxL_FVB   GFXMMU_LUTxL_FVB_Msk
#define GFXMMU_LUTxL_LVB_Pos   (16U)
#define GFXMMU_LUTxL_LVB_Msk   (0xFFUL << GFXMMU_LUTxL_LVB_Pos)
#define GFXMMU_LUTxL_LVB   GFXMMU_LUTxL_LVB_Msk
#define GFXMMU_LUTxH_LO_Pos   (4U)
#define GFXMMU_LUTxH_LO_Msk   (0x3FFFFUL << GFXMMU_LUTxH_LO_Pos)
#define GFXMMU_LUTxH_LO   GFXMMU_LUTxH_LO_Msk
#define GFXTIM_CR_TES_Pos   (0U)
#define GFXTIM_CR_TES_Msk   (0x3UL << GFXTIM_CR_TES_Pos)
#define GFXTIM_CR_TES   GFXTIM_CR_TES_Msk
#define GFXTIM_CR_TES_0   (0x1UL << GFXTIM_CR_TES_Pos)
#define GFXTIM_CR_TES_1   (0x2UL << GFXTIM_CR_TES_Pos)
#define GFXTIM_CR_TEPOL_Pos   (4U)
#define GFXTIM_CR_TEPOL_Msk   (0x1UL << GFXTIM_CR_TEPOL_Pos)
#define GFXTIM_CR_TEPOL   GFXTIM_CR_TEPOL_Msk
#define GFXTIM_CR_SYNCS_Pos   (8U)
#define GFXTIM_CR_SYNCS_Msk   (0x3UL << GFXTIM_CR_SYNCS_Pos)
#define GFXTIM_CR_SYNCS   GFXTIM_CR_SYNCS_Msk
#define GFXTIM_CR_SYNCS_0   (0x1UL << GFXTIM_CR_SYNCS_Pos)
#define GFXTIM_CR_SYNCS_1   (0x2UL << GFXTIM_CR_SYNCS_Pos)
#define GFXTIM_CR_FCCOE_Pos   (16U)
#define GFXTIM_CR_FCCOE_Msk   (0x1UL << GFXTIM_CR_FCCOE_Pos)
#define GFXTIM_CR_FCCOE   GFXTIM_CR_FCCOE_Msk
#define GFXTIM_CR_LCCOE_Pos   (17U)
#define GFXTIM_CR_LCCOE_Msk   (0x1UL << GFXTIM_CR_LCCOE_Pos)
#define GFXTIM_CR_LCCOE   GFXTIM_CR_LCCOE_Msk
#define GFXTIM_CGCR_LCS_Pos   (0U)
#define GFXTIM_CGCR_LCS_Msk   (0x7UL << GFXTIM_CGCR_LCS_Pos)
#define GFXTIM_CGCR_LCS   GFXTIM_CGCR_LCS_Msk
#define GFXTIM_CGCR_LCS_0   (0x1UL << GFXTIM_CGCR_LCS_Pos)
#define GFXTIM_CGCR_LCS_1   (0x2UL << GFXTIM_CGCR_LCS_Pos)
#define GFXTIM_CGCR_LCS_2   (0x4UL << GFXTIM_CGCR_LCS_Pos)
#define GFXTIM_CGCR_LCCCS_Pos   (4U)
#define GFXTIM_CGCR_LCCCS_Msk   (0x1UL << GFXTIM_CGCR_LCCCS_Pos)
#define GFXTIM_CGCR_LCCCS   GFXTIM_CGCR_LCCCS_Msk
#define GFXTIM_CGCR_LCCFR_Pos   (8U)
#define GFXTIM_CGCR_LCCFR_Msk   (0x1UL << GFXTIM_CGCR_LCCFR_Pos)
#define GFXTIM_CGCR_LCCFR   GFXTIM_CGCR_LCCFR_Msk
#define GFXTIM_CGCR_LCCHRS_Pos   (12U)
#define GFXTIM_CGCR_LCCHRS_Msk   (0x7UL << GFXTIM_CGCR_LCCHRS_Pos)
#define GFXTIM_CGCR_LCCHRS   GFXTIM_CGCR_LCCHRS_Msk
#define GFXTIM_CGCR_LCCHRS_0   (0x1UL << GFXTIM_CGCR_LCCHRS_Pos)
#define GFXTIM_CGCR_LCCHRS_1   (0x2UL << GFXTIM_CGCR_LCCHRS_Pos)
#define GFXTIM_CGCR_LCCHRS_2   (0x4UL << GFXTIM_CGCR_LCCHRS_Pos)
#define GFXTIM_CGCR_FCS_Pos   (16U)
#define GFXTIM_CGCR_FCS_Msk   (0x7UL << GFXTIM_CGCR_FCS_Pos)
#define GFXTIM_CGCR_FCS   GFXTIM_CGCR_FCS_Msk
#define GFXTIM_CGCR_FCS_0   (0x1UL << GFXTIM_CGCR_FCS_Pos)
#define GFXTIM_CGCR_FCS_1   (0x2UL << GFXTIM_CGCR_FCS_Pos)
#define GFXTIM_CGCR_FCS_2   (0x4UL << GFXTIM_CGCR_FCS_Pos)
#define GFXTIM_CGCR_FCCCS_Pos   (20U)
#define GFXTIM_CGCR_FCCCS_Msk   (0x7UL << GFXTIM_CGCR_FCCCS_Pos)
#define GFXTIM_CGCR_FCCCS   GFXTIM_CGCR_FCCCS_Msk
#define GFXTIM_CGCR_FCCCS_0   (0x1UL << GFXTIM_CGCR_FCCCS_Pos)
#define GFXTIM_CGCR_FCCCS_1   (0x2UL << GFXTIM_CGCR_FCCCS_Pos)
#define GFXTIM_CGCR_FCCCS_2   (0x4UL << GFXTIM_CGCR_FCCCS_Pos)
#define GFXTIM_CGCR_FCCFR_Pos   (24U)
#define GFXTIM_CGCR_FCCFR_Msk   (0x1UL << GFXTIM_CGCR_FCCFR_Pos)
#define GFXTIM_CGCR_FCCFR   GFXTIM_CGCR_FCCFR_Msk
#define GFXTIM_CGCR_FCCHRS_Pos   (28U)
#define GFXTIM_CGCR_FCCHRS_Msk   (0x7UL << GFXTIM_CGCR_FCCHRS_Pos)
#define GFXTIM_CGCR_FCCHRS   GFXTIM_CGCR_FCCHRS_Msk
#define GFXTIM_CGCR_FCCHRS_0   (0x1UL << GFXTIM_CGCR_FCCHRS_Pos)
#define GFXTIM_CGCR_FCCHRS_1   (0x2UL << GFXTIM_CGCR_FCCHRS_Pos)
#define GFXTIM_CGCR_FCCHRS_2   (0x4UL << GFXTIM_CGCR_FCCHRS_Pos)
#define GFXTIM_TCR_AFCEN_Pos   (0U)
#define GFXTIM_TCR_AFCEN_Msk   (0x1UL << GFXTIM_TCR_AFCEN_Pos)
#define GFXTIM_TCR_AFCEN   GFXTIM_TCR_AFCEN_Msk
#define GFXTIM_TCR_FAFCR_Pos   (1U)
#define GFXTIM_TCR_FAFCR_Msk   (0x1UL << GFXTIM_TCR_FAFCR_Pos)
#define GFXTIM_TCR_FAFCR   GFXTIM_TCR_FAFCR_Msk
#define GFXTIM_TCR_ALCEN_Pos   (4U)
#define GFXTIM_TCR_ALCEN_Msk   (0x1UL << GFXTIM_TCR_ALCEN_Pos)
#define GFXTIM_TCR_ALCEN   GFXTIM_TCR_ALCEN_Msk
#define GFXTIM_TCR_FALCR_Pos   (5U)
#define GFXTIM_TCR_FALCR_Msk   (0x1UL << GFXTIM_TCR_FALCR_Pos)
#define GFXTIM_TCR_FALCR   GFXTIM_TCR_FALCR_Msk
#define GFXTIM_TCR_RFC1EN_Pos   (16U)
#define GFXTIM_TCR_RFC1EN_Msk   (0x1UL << GFXTIM_TCR_RFC1EN_Pos)
#define GFXTIM_TCR_RFC1EN   GFXTIM_TCR_RFC1EN_Msk
#define GFXTIM_TCR_RFC1CM_Pos   (17U)
#define GFXTIM_TCR_RFC1CM_Msk   (0x1UL << GFXTIM_TCR_RFC1CM_Pos)
#define GFXTIM_TCR_RFC1CM   GFXTIM_TCR_RFC1CM_Msk
#define GFXTIM_TCR_FRFC1R_Pos   (18U)
#define GFXTIM_TCR_FRFC1R_Msk   (0x1UL << GFXTIM_TCR_FRFC1R_Pos)
#define GFXTIM_TCR_FRFC1R   GFXTIM_TCR_FRFC1R_Msk
#define GFXTIM_TCR_RFC2EN_Pos   (20U)
#define GFXTIM_TCR_RFC2EN_Msk   (0x1UL << GFXTIM_TCR_RFC2EN_Pos)
#define GFXTIM_TCR_RFC2EN   GFXTIM_TCR_RFC2EN_Msk
#define GFXTIM_TCR_RFC2CM_Pos   (21U)
#define GFXTIM_TCR_RFC2CM_Msk   (0x1UL << GFXTIM_TCR_RFC2CM_Pos)
#define GFXTIM_TCR_RFC2CM   GFXTIM_TCR_RFC2CM_Msk
#define GFXTIM_TCR_FRFC2R_Pos   (22U)
#define GFXTIM_TCR_FRFC2R_Msk   (0x1UL << GFXTIM_TCR_FRFC2R_Pos)
#define GFXTIM_TCR_FRFC2R   GFXTIM_TCR_FRFC2R_Msk
#define GFXTIM_TDR_AFCDIS_Pos   (0U)
#define GFXTIM_TDR_AFCDIS_Msk   (0x1UL << GFXTIM_TDR_AFCDIS_Pos)
#define GFXTIM_TDR_AFCDIS   GFXTIM_TDR_AFCDIS_Msk
#define GFXTIM_TDR_ALCDIS_Pos   (4U)
#define GFXTIM_TDR_ALCDIS_Msk   (0x1UL << GFXTIM_TDR_ALCDIS_Pos)
#define GFXTIM_TDR_ALCDIS   GFXTIM_TDR_ALCDIS_Msk
#define GFXTIM_TDR_RFC1DIS_Pos   (16U)
#define GFXTIM_TDR_RFC1DIS_Msk   (0x1UL << GFXTIM_TDR_RFC1DIS_Pos)
#define GFXTIM_TDR_RFC1DIS   GFXTIM_TDR_RFC1DIS_Msk
#define GFXTIM_TDR_RFC2DIS_Pos   (20U)
#define GFXTIM_TDR_RFC2DIS_Msk   (0x1UL << GFXTIM_TDR_RFC2DIS_Pos)
#define GFXTIM_TDR_RFC2DIS   GFXTIM_TDR_RFC2DIS_Msk
#define GFXTIM_EVCR_EV1EN_Pos   (0U)
#define GFXTIM_EVCR_EV1EN_Msk   (0x1UL << GFXTIM_EVCR_EV1EN_Pos)
#define GFXTIM_EVCR_EV1EN   GFXTIM_EVCR_EV1EN_Msk
#define GFXTIM_EVCR_EV2EN_Pos   (1U)
#define GFXTIM_EVCR_EV2EN_Msk   (0x1UL << GFXTIM_EVCR_EV2EN_Pos)
#define GFXTIM_EVCR_EV2EN   GFXTIM_EVCR_EV2EN_Msk
#define GFXTIM_EVCR_EV3EN_Pos   (2U)
#define GFXTIM_EVCR_EV3EN_Msk   (0x1UL << GFXTIM_EVCR_EV3EN_Pos)
#define GFXTIM_EVCR_EV3EN   GFXTIM_EVCR_EV3EN_Msk
#define GFXTIM_EVCR_EV4EN_Pos   (3U)
#define GFXTIM_EVCR_EV4EN_Msk   (0x1UL << GFXTIM_EVCR_EV4EN_Pos)
#define GFXTIM_EVCR_EV4EN   GFXTIM_EVCR_EV4EN_Msk
#define GFXTIM_EVSR_LES1_Pos   (0U)
#define GFXTIM_EVSR_LES1_Msk   (0x7UL << GFXTIM_EVSR_LES1_Pos)
#define GFXTIM_EVSR_LES1   GFXTIM_EVSR_LES1_Msk
#define GFXTIM_EVSR_LES1_0   (0x1UL << GFXTIM_EVSR_LES1_Pos)
#define GFXTIM_EVSR_LES1_1   (0x2UL << GFXTIM_EVSR_LES1_Pos)
#define GFXTIM_EVSR_LES1_2   (0x4UL << GFXTIM_EVSR_LES1_Pos)
#define GFXTIM_EVSR_FES1_Pos   (4U)
#define GFXTIM_EVSR_FES1_Msk   (0x7UL << GFXTIM_EVSR_FES1_Pos)
#define GFXTIM_EVSR_FES1   GFXTIM_EVSR_FES1_Msk
#define GFXTIM_EVSR_FES1_0   (0x1UL << GFXTIM_EVSR_FES1_Pos)
#define GFXTIM_EVSR_FES1_1   (0x2UL << GFXTIM_EVSR_FES1_Pos)
#define GFXTIM_EVSR_FES1_2   (0x4UL << GFXTIM_EVSR_FES1_Pos)
#define GFXTIM_EVSR_LES2_Pos   (8U)
#define GFXTIM_EVSR_LES2_Msk   (0x7UL << GFXTIM_EVSR_LES2_Pos)
#define GFXTIM_EVSR_LES2   GFXTIM_EVSR_LES2_Msk
#define GFXTIM_EVSR_LES2_0   (0x1UL << GFXTIM_EVSR_LES2_Pos)
#define GFXTIM_EVSR_LES2_1   (0x2UL << GFXTIM_EVSR_LES2_Pos)
#define GFXTIM_EVSR_LES2_2   (0x4UL << GFXTIM_EVSR_LES2_Pos)
#define GFXTIM_EVSR_FES2_Pos   (12U)
#define GFXTIM_EVSR_FES2_Msk   (0x7UL << GFXTIM_EVSR_FES2_Pos)
#define GFXTIM_EVSR_FES2   GFXTIM_EVSR_FES2_Msk
#define GFXTIM_EVSR_FES2_0   (0x1UL << GFXTIM_EVSR_FES2_Pos)
#define GFXTIM_EVSR_FES2_1   (0x2UL << GFXTIM_EVSR_FES2_Pos)
#define GFXTIM_EVSR_FES2_2   (0x4UL << GFXTIM_EVSR_FES2_Pos)
#define GFXTIM_EVSR_LES3_Pos   (16U)
#define GFXTIM_EVSR_LES3_Msk   (0x7UL << GFXTIM_EVSR_LES3_Pos)
#define GFXTIM_EVSR_LES3   GFXTIM_EVSR_LES3_Msk
#define GFXTIM_EVSR_LES3_0   (0x1UL << GFXTIM_EVSR_LES3_Pos)
#define GFXTIM_EVSR_LES3_1   (0x2UL << GFXTIM_EVSR_LES3_Pos)
#define GFXTIM_EVSR_LES3_2   (0x4UL << GFXTIM_EVSR_LES3_Pos)
#define GFXTIM_EVSR_FES3_Pos   (20U)
#define GFXTIM_EVSR_FES3_Msk   (0x7UL << GFXTIM_EVSR_FES3_Pos)
#define GFXTIM_EVSR_FES3   GFXTIM_EVSR_FES3_Msk
#define GFXTIM_EVSR_FES3_0   (0x1UL << GFXTIM_EVSR_FES3_Pos)
#define GFXTIM_EVSR_FES3_1   (0x2UL << GFXTIM_EVSR_FES3_Pos)
#define GFXTIM_EVSR_FES3_2   (0x4UL << GFXTIM_EVSR_FES3_Pos)
#define GFXTIM_EVSR_LES4_Pos   (24U)
#define GFXTIM_EVSR_LES4_Msk   (0x7UL << GFXTIM_EVSR_LES4_Pos)
#define GFXTIM_EVSR_LES4   GFXTIM_EVSR_LES4_Msk
#define GFXTIM_EVSR_LES4_0   (0x1UL << GFXTIM_EVSR_LES4_Pos)
#define GFXTIM_EVSR_LES4_1   (0x2UL << GFXTIM_EVSR_LES4_Pos)
#define GFXTIM_EVSR_LES4_2   (0x4UL << GFXTIM_EVSR_LES4_Pos)
#define GFXTIM_EVSR_FES4_Pos   (28U)
#define GFXTIM_EVSR_FES4_Msk   (0x7UL << GFXTIM_EVSR_FES4_Pos)
#define GFXTIM_EVSR_FES4   GFXTIM_EVSR_FES4_Msk
#define GFXTIM_EVSR_FES4_0   (0x1UL << GFXTIM_EVSR_FES4_Pos)
#define GFXTIM_EVSR_FES4_1   (0x2UL << GFXTIM_EVSR_FES4_Pos)
#define GFXTIM_EVSR_FES4_2   (0x4UL << GFXTIM_EVSR_FES4_Pos)
#define GFXTIM_WDGTCR_WDGEN_Pos   (0U)
#define GFXTIM_WDGTCR_WDGEN_Msk   (0x1UL << GFXTIM_WDGTCR_WDGEN_Pos)
#define GFXTIM_WDGTCR_WDGEN   GFXTIM_WDGTCR_WDGEN_Msk
#define GFXTIM_WDGTCR_WDGDIS_Pos   (1U)
#define GFXTIM_WDGTCR_WDGDIS_Msk   (0x1UL << GFXTIM_WDGTCR_WDGDIS_Pos)
#define GFXTIM_WDGTCR_WDGDIS   GFXTIM_WDGTCR_WDGDIS_Msk
#define GFXTIM_WDGTCR_WDGS_Pos   (2U)
#define GFXTIM_WDGTCR_WDGS_Msk   (0x1UL << GFXTIM_WDGTCR_WDGS_Pos)
#define GFXTIM_WDGTCR_WDGS   GFXTIM_WDGTCR_WDGS_Msk
#define GFXTIM_WDGTCR_WDGHRC_Pos   (4U)
#define GFXTIM_WDGTCR_WDGHRC_Msk   (0x3UL << GFXTIM_WDGTCR_WDGHRC_Pos)
#define GFXTIM_WDGTCR_WDGHRC   GFXTIM_WDGTCR_WDGHRC_Msk
#define GFXTIM_WDGTCR_WDGHRC_0   (0x1UL << GFXTIM_WDGTCR_WDGHRC_Pos)
#define GFXTIM_WDGTCR_WDGHRC_1   (0x2UL << GFXTIM_WDGTCR_WDGHRC_Pos)
#define GFXTIM_WDGTCR_WDGCS_Pos   (8U)
#define GFXTIM_WDGTCR_WDGCS_Msk   (0xFUL << GFXTIM_WDGTCR_WDGCS_Pos)
#define GFXTIM_WDGTCR_WDGCS   GFXTIM_WDGTCR_WDGCS_Msk
#define GFXTIM_WDGTCR_WDGCS_0   (0x1UL << GFXTIM_WDGTCR_WDGCS_Pos)
#define GFXTIM_WDGTCR_WDGCS_1   (0x2UL << GFXTIM_WDGTCR_WDGCS_Pos)
#define GFXTIM_WDGTCR_WDGCS_2   (0x4UL << GFXTIM_WDGTCR_WDGCS_Pos)
#define GFXTIM_WDGTCR_WDGCS_3   (0x8UL << GFXTIM_WDGTCR_WDGCS_Pos)
#define GFXTIM_WDGTCR_FWDGR_Pos   (16U)
#define GFXTIM_WDGTCR_FWDGR_Msk   (0x1UL << GFXTIM_WDGTCR_FWDGR_Pos)
#define GFXTIM_WDGTCR_FWDGR   GFXTIM_WDGTCR_FWDGR_Msk
#define GFXTIM_ISR_AFCOF_Pos   (0U)
#define GFXTIM_ISR_AFCOF_Msk   (0x1UL << GFXTIM_ISR_AFCOF_Pos)
#define GFXTIM_ISR_AFCOF   GFXTIM_ISR_AFCOF_Msk
#define GFXTIM_ISR_ALCOF_Pos   (1U)
#define GFXTIM_ISR_ALCOF_Msk   (0x1UL << GFXTIM_ISR_ALCOF_Pos)
#define GFXTIM_ISR_ALCOF   GFXTIM_ISR_ALCOF_Msk
#define GFXTIM_ISR_TEF_Pos   (2U)
#define GFXTIM_ISR_TEF_Msk   (0x1UL << GFXTIM_ISR_TEF_Pos)
#define GFXTIM_ISR_TEF   GFXTIM_ISR_TEF_Msk
#define GFXTIM_ISR_AFCC1F_Pos   (4U)
#define GFXTIM_ISR_AFCC1F_Msk   (0x1UL << GFXTIM_ISR_AFCC1F_Pos)
#define GFXTIM_ISR_AFCC1F   GFXTIM_ISR_AFCC1F_Msk
#define GFXTIM_ISR_ALCC1F_Pos   (8U)
#define GFXTIM_ISR_ALCC1F_Msk   (0x1UL << GFXTIM_ISR_ALCC1F_Pos)
#define GFXTIM_ISR_ALCC1F   GFXTIM_ISR_ALCC1F_Msk
#define GFXTIM_ISR_ALCC2F_Pos   (9U)
#define GFXTIM_ISR_ALCC2F_Msk   (0x1UL << GFXTIM_ISR_ALCC2F_Pos)
#define GFXTIM_ISR_ALCC2F   GFXTIM_ISR_ALCC2F_Msk
#define GFXTIM_ISR_RFC1RF_Pos   (12U)
#define GFXTIM_ISR_RFC1RF_Msk   (0x1UL << GFXTIM_ISR_RFC1RF_Pos)
#define GFXTIM_ISR_RFC1RF   GFXTIM_ISR_RFC1RF_Msk
#define GFXTIM_ISR_RFC2RF_Pos   (13U)
#define GFXTIM_ISR_RFC2RF_Msk   (0x1UL << GFXTIM_ISR_RFC2RF_Pos)
#define GFXTIM_ISR_RFC2RF   GFXTIM_ISR_RFC2RF_Msk
#define GFXTIM_ISR_EV1F_Pos   (16U)
#define GFXTIM_ISR_EV1F_Msk   (0x1UL << GFXTIM_ISR_EV1F_Pos)
#define GFXTIM_ISR_EV1F   GFXTIM_ISR_EV1F_Msk
#define GFXTIM_ISR_EV2F_Pos   (17U)
#define GFXTIM_ISR_EV2F_Msk   (0x1UL << GFXTIM_ISR_EV2F_Pos)
#define GFXTIM_ISR_EV2F   GFXTIM_ISR_EV2F_Msk
#define GFXTIM_ISR_EV3F_Pos   (18U)
#define GFXTIM_ISR_EV3F_Msk   (0x1UL << GFXTIM_ISR_EV3F_Pos)
#define GFXTIM_ISR_EV3F   GFXTIM_ISR_EV3F_Msk
#define GFXTIM_ISR_EV4F_Pos   (19U)
#define GFXTIM_ISR_EV4F_Msk   (0x1UL << GFXTIM_ISR_EV4F_Pos)
#define GFXTIM_ISR_EV4F   GFXTIM_ISR_EV4F_Msk
#define GFXTIM_ISR_WDGAF_Pos   (24U)
#define GFXTIM_ISR_WDGAF_Msk   (0x1UL << GFXTIM_ISR_WDGAF_Pos)
#define GFXTIM_ISR_WDGAF   GFXTIM_ISR_WDGAF_Msk
#define GFXTIM_ISR_WDGPF_Pos   (25U)
#define GFXTIM_ISR_WDGPF_Msk   (0x1UL << GFXTIM_ISR_WDGPF_Pos)
#define GFXTIM_ISR_WDGPF   GFXTIM_ISR_WDGPF_Msk
#define GFXTIM_ICR_CAFCOF_Pos   (0U)
#define GFXTIM_ICR_CAFCOF_Msk   (0x1UL << GFXTIM_ICR_CAFCOF_Pos)
#define GFXTIM_ICR_CAFCOF   GFXTIM_ICR_CAFCOF_Msk
#define GFXTIM_ICR_CALCOF_Pos   (1U)
#define GFXTIM_ICR_CALCOF_Msk   (0x1UL << GFXTIM_ICR_CALCOF_Pos)
#define GFXTIM_ICR_CALCOF   GFXTIM_ICR_CALCOF_Msk
#define GFXTIM_ICR_CTEF_Pos   (2U)
#define GFXTIM_ICR_CTEF_Msk   (0x1UL << GFXTIM_ICR_CTEF_Pos)
#define GFXTIM_ICR_CTEF   GFXTIM_ICR_CTEF_Msk
#define GFXTIM_ICR_CAFCC1F_Pos   (4U)
#define GFXTIM_ICR_CAFCC1F_Msk   (0x1UL << GFXTIM_ICR_CAFCC1F_Pos)
#define GFXTIM_ICR_CAFCC1F   GFXTIM_ICR_CAFCC1F_Msk
#define GFXTIM_ICR_CALCC1F_Pos   (8U)
#define GFXTIM_ICR_CALCC1F_Msk   (0x1UL << GFXTIM_ICR_CALCC1F_Pos)
#define GFXTIM_ICR_CALCC1F   GFXTIM_ICR_CALCC1F_Msk
#define GFXTIM_ICR_CALCC2F_Pos   (9U)
#define GFXTIM_ICR_CALCC2F_Msk   (0x1UL << GFXTIM_ICR_CALCC2F_Pos)
#define GFXTIM_ICR_CALCC2F   GFXTIM_ICR_CALCC2F_Msk
#define GFXTIM_ICR_CRFC1RF_Pos   (12U)
#define GFXTIM_ICR_CRFC1RF_Msk   (0x1UL << GFXTIM_ICR_CRFC1RF_Pos)
#define GFXTIM_ICR_CRFC1RF   GFXTIM_ICR_CRFC1RF_Msk
#define GFXTIM_ICR_CRFC2RF_Pos   (13U)
#define GFXTIM_ICR_CRFC2RF_Msk   (0x1UL << GFXTIM_ICR_CRFC2RF_Pos)
#define GFXTIM_ICR_CRFC2RF   GFXTIM_ICR_CRFC2RF_Msk
#define GFXTIM_ICR_CEV1F_Pos   (16U)
#define GFXTIM_ICR_CEV1F_Msk   (0x1UL << GFXTIM_ICR_CEV1F_Pos)
#define GFXTIM_ICR_CEV1F   GFXTIM_ICR_CEV1F_Msk
#define GFXTIM_ICR_CEV2F_Pos   (17U)
#define GFXTIM_ICR_CEV2F_Msk   (0x1UL << GFXTIM_ICR_CEV2F_Pos)
#define GFXTIM_ICR_CEV2F   GFXTIM_ICR_CEV2F_Msk
#define GFXTIM_ICR_CEV3F_Pos   (18U)
#define GFXTIM_ICR_CEV3F_Msk   (0x1UL << GFXTIM_ICR_CEV3F_Pos)
#define GFXTIM_ICR_CEV3F   GFXTIM_ICR_CEV3F_Msk
#define GFXTIM_ICR_CEV4F_Pos   (19U)
#define GFXTIM_ICR_CEV4F_Msk   (0x1UL << GFXTIM_ICR_CEV4F_Pos)
#define GFXTIM_ICR_CEV4F   GFXTIM_ICR_CEV4F_Msk
#define GFXTIM_ICR_CWDGAF_Pos   (24U)
#define GFXTIM_ICR_CWDGAF_Msk   (0x1UL << GFXTIM_ICR_CWDGAF_Pos)
#define GFXTIM_ICR_CWDGAF   GFXTIM_ICR_CWDGAF_Msk
#define GFXTIM_ICR_CWDGPF_Pos   (25U)
#define GFXTIM_ICR_CWDGPF_Msk   (0x1UL << GFXTIM_ICR_CWDGPF_Pos)
#define GFXTIM_ICR_CWDGPF   GFXTIM_ICR_CWDGPF_Msk
#define GFXTIM_IER_AFCOIE_Pos   (0U)
#define GFXTIM_IER_AFCOIE_Msk   (0x1UL << GFXTIM_IER_AFCOIE_Pos)
#define GFXTIM_IER_AFCOIE   GFXTIM_IER_AFCOIE_Msk
#define GFXTIM_IER_ALCOIE_Pos   (1U)
#define GFXTIM_IER_ALCOIE_Msk   (0x1UL << GFXTIM_IER_ALCOIE_Pos)
#define GFXTIM_IER_ALCOIE   GFXTIM_IER_ALCOIE_Msk
#define GFXTIM_IER_TEIE_Pos   (2U)
#define GFXTIM_IER_TEIE_Msk   (0x1UL << GFXTIM_IER_TEIE_Pos)
#define GFXTIM_IER_TEIE   GFXTIM_IER_TEIE_Msk
#define GFXTIM_IER_AFCC1IE_Pos   (4U)
#define GFXTIM_IER_AFCC1IE_Msk   (0x1UL << GFXTIM_IER_AFCC1IE_Pos)
#define GFXTIM_IER_AFCC1IE   GFXTIM_IER_AFCC1IE_Msk
#define GFXTIM_IER_ALCC1IE_Pos   (8U)
#define GFXTIM_IER_ALCC1IE_Msk   (0x1UL << GFXTIM_IER_ALCC1IE_Pos)
#define GFXTIM_IER_ALCC1IE   GFXTIM_IER_ALCC1IE_Msk
#define GFXTIM_IER_ALCC2IE_Pos   (9U)
#define GFXTIM_IER_ALCC2IE_Msk   (0x1UL << GFXTIM_IER_ALCC2IE_Pos)
#define GFXTIM_IER_ALCC2IE   GFXTIM_IER_ALCC2IE_Msk
#define GFXTIM_IER_RFC1RIE_Pos   (12U)
#define GFXTIM_IER_RFC1RIE_Msk   (0x1UL << GFXTIM_IER_RFC1RIE_Pos)
#define GFXTIM_IER_RFC1RIE   GFXTIM_IER_RFC1RIE_Msk
#define GFXTIM_IER_RFC2RIE_Pos   (13U)
#define GFXTIM_IER_RFC2RIE_Msk   (0x1UL << GFXTIM_IER_RFC2RIE_Pos)
#define GFXTIM_IER_RFC2RIE   GFXTIM_IER_RFC2RIE_Msk
#define GFXTIM_IER_EV1IE_Pos   (16U)
#define GFXTIM_IER_EV1IE_Msk   (0x1UL << GFXTIM_IER_EV1IE_Pos)
#define GFXTIM_IER_EV1IE   GFXTIM_IER_EV1IE_Msk
#define GFXTIM_IER_EV2IE_Pos   (17U)
#define GFXTIM_IER_EV2IE_Msk   (0x1UL << GFXTIM_IER_EV2IE_Pos)
#define GFXTIM_IER_EV2IE   GFXTIM_IER_EV2IE_Msk
#define GFXTIM_IER_EV3IE_Pos   (18U)
#define GFXTIM_IER_EV3IE_Msk   (0x1UL << GFXTIM_IER_EV3IE_Pos)
#define GFXTIM_IER_EV3IE   GFXTIM_IER_EV3IE_Msk
#define GFXTIM_IER_EV4IE_Pos   (19U)
#define GFXTIM_IER_EV4IE_Msk   (0x1UL << GFXTIM_IER_EV4IE_Pos)
#define GFXTIM_IER_EV4IE   GFXTIM_IER_EV4IE_Msk
#define GFXTIM_IER_WDGAIE_Pos   (24U)
#define GFXTIM_IER_WDGAIE_Msk   (0x1UL << GFXTIM_IER_WDGAIE_Pos)
#define GFXTIM_IER_WDGAIE   GFXTIM_IER_WDGAIE_Msk
#define GFXTIM_IER_WDGPIE_Pos   (25U)
#define GFXTIM_IER_WDGPIE_Msk   (0x1UL << GFXTIM_IER_WDGPIE_Pos)
#define GFXTIM_IER_WDGPIE   GFXTIM_IER_WDGPIE_Msk
#define GFXTIM_TSR_AFCS_Pos   (0U)
#define GFXTIM_TSR_AFCS_Msk   (0x1UL << GFXTIM_TSR_AFCS_Pos)
#define GFXTIM_TSR_AFCS   GFXTIM_TSR_AFCS_Msk
#define GFXTIM_TSR_ALCS_Pos   (4U)
#define GFXTIM_TSR_ALCS_Msk   (0x1UL << GFXTIM_TSR_ALCS_Pos)
#define GFXTIM_TSR_ALCS   GFXTIM_TSR_ALCS_Msk
#define GFXTIM_TSR_RFC1S_Pos   (16U)
#define GFXTIM_TSR_RFC1S_Msk   (0x1UL << GFXTIM_TSR_RFC1S_Pos)
#define GFXTIM_TSR_RFC1S   GFXTIM_TSR_RFC1S_Msk
#define GFXTIM_TSR_RFC2S_Pos   (20U)
#define GFXTIM_TSR_RFC2S_Msk   (0x1UL << GFXTIM_TSR_RFC2S_Pos)
#define GFXTIM_TSR_RFC2S   GFXTIM_TSR_RFC2S_Msk
#define GFXTIM_LCCRR_RELOAD_Pos   (0U)
#define GFXTIM_LCCRR_RELOAD_Msk   (0x3FFFFFUL << GFXTIM_LCCRR_RELOAD_Pos)
#define GFXTIM_LCCRR_RELOAD   GFXTIM_LCCRR_RELOAD_Msk
#define GFXTIM_FCCRR_RELOAD_Pos   (0U)
#define GFXTIM_FCCRR_RELOAD_Msk   (0xFFFUL << GFXTIM_FCCRR_RELOAD_Pos)
#define GFXTIM_FCCRR_RELOAD   GFXTIM_FCCRR_RELOAD_Msk
#define GFXTIM_ATR_LINE_Pos   (0U)
#define GFXTIM_ATR_LINE_Msk   (0xFFFUL << GFXTIM_ATR_LINE_Pos)
#define GFXTIM_ATR_LINE   GFXTIM_ATR_LINE_Msk
#define GFXTIM_ATR_FRAME_Pos   (12U)
#define GFXTIM_ATR_FRAME_Msk   (0xFFFFFUL << GFXTIM_ATR_FRAME_Pos)
#define GFXTIM_ATR_FRAME   GFXTIM_ATR_FRAME_Msk
#define GFXTIM_AFCR_FRAME_Pos   (0U)
#define GFXTIM_AFCR_FRAME_Msk   (0xFFFFFUL << GFXTIM_AFCR_FRAME_Pos)
#define GFXTIM_AFCR_FRAME   GFXTIM_AFCR_FRAME_Msk
#define GFXTIM_ALCR_LINE_Pos   (0U)
#define GFXTIM_ALCR_LINE_Msk   (0xFFFUL << GFXTIM_ALCR_LINE_Pos)
#define GFXTIM_ALCR_LINE   GFXTIM_ALCR_LINE_Msk
#define GFXTIM_AFCC1R_FRAME_Pos   (0U)
#define GFXTIM_AFCC1R_FRAME_Msk   (0xFFFFFUL << GFXTIM_AFCC1R_FRAME_Pos)
#define GFXTIM_AFCC1R_FRAME   GFXTIM_AFCC1R_FRAME_Msk
#define GFXTIM_ALCC1R_LINE_Pos   (0U)
#define GFXTIM_ALCC1R_LINE_Msk   (0xFFFUL << GFXTIM_ALCC1R_LINE_Pos)
#define GFXTIM_ALCC1R_LINE   GFXTIM_ALCC1R_LINE_Msk
#define GFXTIM_ALCC2R_LINE_Pos   (0U)
#define GFXTIM_ALCC2R_LINE_Msk   (0xFFFUL << GFXTIM_ALCC2R_LINE_Pos)
#define GFXTIM_ALCC2R_LINE   GFXTIM_ALCC2R_LINE_Msk
#define GFXTIM_RFC1R_FRAME_Pos   (0U)
#define GFXTIM_RFC1R_FRAME_Msk   (0xFFFUL << GFXTIM_RFC1R_FRAME_Pos)
#define GFXTIM_RFC1R_FRAME   GFXTIM_RFC1R_FRAME_Msk
#define GFXTIM_RFC1RR_FRAME_Pos   (0U)
#define GFXTIM_RFC1RR_FRAME_Msk   (0xFFFUL << GFXTIM_RFC1RR_FRAME_Pos)
#define GFXTIM_RFC1RR_FRAME   GFXTIM_RFC1RR_FRAME_Msk
#define GFXTIM_RFC2R_FRAME_Pos   (0U)
#define GFXTIM_RFC2R_FRAME_Msk   (0xFFFUL << GFXTIM_RFC2R_FRAME_Pos)
#define GFXTIM_RFC2R_FRAME   GFXTIM_RFC2R_FRAME_Msk
#define GFXTIM_RFC2RR_FRAME_Pos   (0U)
#define GFXTIM_RFC2RR_FRAME_Msk   (0xFFFUL << GFXTIM_RFC2RR_FRAME_Pos)
#define GFXTIM_RFC2RR_FRAME   GFXTIM_RFC2RR_FRAME_Msk
#define GFXTIM_WDGCR_VALUE_Pos   (0U)
#define GFXTIM_WDGCR_VALUE_Msk   (0xFFFFUL << GFXTIM_WDGCR_VALUE_Pos)
#define GFXTIM_WDGCR_VALUE   GFXTIM_WDGCR_VALUE_Msk
#define GFXTIM_WDGRR_RELOAD_Pos   (0U)
#define GFXTIM_WDGRR_RELOAD_Msk   (0xFFFFUL << GFXTIM_WDGRR_RELOAD_Pos)
#define GFXTIM_WDGRR_RELOAD   GFXTIM_WDGRR_RELOAD_Msk
#define GFXTIM_WDGPAR_PREALARM_Pos   (0U)
#define GFXTIM_WDGPAR_PREALARM_Msk   (0xFFFFUL << GFXTIM_WDGPAR_PREALARM_Pos)
#define GFXTIM_WDGPAR_PREALARM   GFXTIM_WDGPAR_PREALARM_Msk
#define GFXTIM_VERR_MINREV_Pos   (0U)
#define GFXTIM_VERR_MINREV_Msk   (0xFUL << GFXTIM_VERR_MINREV_Pos)
#define GFXTIM_VERR_MINREV   GFXTIM_VERR_MINREV_Msk
#define GFXTIM_VERR_MAJREV_Pos   (4U)
#define GFXTIM_VERR_MAJREV_Msk   (0xFUL << GFXTIM_VERR_MAJREV_Pos)
#define GFXTIM_VERR_MAJREV   GFXTIM_VERR_MAJREV_Msk
#define GFXTIM_IPIDR_ID_Pos   (0U)
#define GFXTIM_IPIDR_ID_Msk   (0xFFFFFFFFUL << GFXTIM_IPIDR_ID_Pos)
#define GFXTIM_IPIDR_ID   GFXTIM_IPIDR_ID_Msk
#define GFXTIM_SIDR_SID_Pos   (0U)
#define GFXTIM_SIDR_SID_Msk   (0xFFFFFFFFUL << GFXTIM_SIDR_SID_Pos)
#define GFXTIM_SIDR_SID   GFXTIM_SIDR_SID_Msk
#define GPIO_MODER_MODE0_Pos   (0U)
#define GPIO_MODER_MODE0_Msk   (0x3UL << GPIO_MODER_MODE0_Pos)
#define GPIO_MODER_MODE0   GPIO_MODER_MODE0_Msk
#define GPIO_MODER_MODE0_0   (0x1UL << GPIO_MODER_MODE0_Pos)
#define GPIO_MODER_MODE0_1   (0x2UL << GPIO_MODER_MODE0_Pos)
#define GPIO_MODER_MODE1_Pos   (2U)
#define GPIO_MODER_MODE1_Msk   (0x3UL << GPIO_MODER_MODE1_Pos)
#define GPIO_MODER_MODE1   GPIO_MODER_MODE1_Msk
#define GPIO_MODER_MODE1_0   (0x1UL << GPIO_MODER_MODE1_Pos)
#define GPIO_MODER_MODE1_1   (0x2UL << GPIO_MODER_MODE1_Pos)
#define GPIO_MODER_MODE2_Pos   (4U)
#define GPIO_MODER_MODE2_Msk   (0x3UL << GPIO_MODER_MODE2_Pos)
#define GPIO_MODER_MODE2   GPIO_MODER_MODE2_Msk
#define GPIO_MODER_MODE2_0   (0x1UL << GPIO_MODER_MODE2_Pos)
#define GPIO_MODER_MODE2_1   (0x2UL << GPIO_MODER_MODE2_Pos)
#define GPIO_MODER_MODE3_Pos   (6U)
#define GPIO_MODER_MODE3_Msk   (0x3UL << GPIO_MODER_MODE3_Pos)
#define GPIO_MODER_MODE3   GPIO_MODER_MODE3_Msk
#define GPIO_MODER_MODE3_0   (0x1UL << GPIO_MODER_MODE3_Pos)
#define GPIO_MODER_MODE3_1   (0x2UL << GPIO_MODER_MODE3_Pos)
#define GPIO_MODER_MODE4_Pos   (8U)
#define GPIO_MODER_MODE4_Msk   (0x3UL << GPIO_MODER_MODE4_Pos)
#define GPIO_MODER_MODE4   GPIO_MODER_MODE4_Msk
#define GPIO_MODER_MODE4_0   (0x1UL << GPIO_MODER_MODE4_Pos)
#define GPIO_MODER_MODE4_1   (0x2UL << GPIO_MODER_MODE4_Pos)
#define GPIO_MODER_MODE5_Pos   (10U)
#define GPIO_MODER_MODE5_Msk   (0x3UL << GPIO_MODER_MODE5_Pos)
#define GPIO_MODER_MODE5   GPIO_MODER_MODE5_Msk
#define GPIO_MODER_MODE5_0   (0x1UL << GPIO_MODER_MODE5_Pos)
#define GPIO_MODER_MODE5_1   (0x2UL << GPIO_MODER_MODE5_Pos)
#define GPIO_MODER_MODE6_Pos   (12U)
#define GPIO_MODER_MODE6_Msk   (0x3UL << GPIO_MODER_MODE6_Pos)
#define GPIO_MODER_MODE6   GPIO_MODER_MODE6_Msk
#define GPIO_MODER_MODE6_0   (0x1UL << GPIO_MODER_MODE6_Pos)
#define GPIO_MODER_MODE6_1   (0x2UL << GPIO_MODER_MODE6_Pos)
#define GPIO_MODER_MODE7_Pos   (14U)
#define GPIO_MODER_MODE7_Msk   (0x3UL << GPIO_MODER_MODE7_Pos)
#define GPIO_MODER_MODE7   GPIO_MODER_MODE7_Msk
#define GPIO_MODER_MODE7_0   (0x1UL << GPIO_MODER_MODE7_Pos)
#define GPIO_MODER_MODE7_1   (0x2UL << GPIO_MODER_MODE7_Pos)
#define GPIO_MODER_MODE8_Pos   (16U)
#define GPIO_MODER_MODE8_Msk   (0x3UL << GPIO_MODER_MODE8_Pos)
#define GPIO_MODER_MODE8   GPIO_MODER_MODE8_Msk
#define GPIO_MODER_MODE8_0   (0x1UL << GPIO_MODER_MODE8_Pos)
#define GPIO_MODER_MODE8_1   (0x2UL << GPIO_MODER_MODE8_Pos)
#define GPIO_MODER_MODE9_Pos   (18U)
#define GPIO_MODER_MODE9_Msk   (0x3UL << GPIO_MODER_MODE9_Pos)
#define GPIO_MODER_MODE9   GPIO_MODER_MODE9_Msk
#define GPIO_MODER_MODE9_0   (0x1UL << GPIO_MODER_MODE9_Pos)
#define GPIO_MODER_MODE9_1   (0x2UL << GPIO_MODER_MODE9_Pos)
#define GPIO_MODER_MODE10_Pos   (20U)
#define GPIO_MODER_MODE10_Msk   (0x3UL << GPIO_MODER_MODE10_Pos)
#define GPIO_MODER_MODE10   GPIO_MODER_MODE10_Msk
#define GPIO_MODER_MODE10_0   (0x1UL << GPIO_MODER_MODE10_Pos)
#define GPIO_MODER_MODE10_1   (0x2UL << GPIO_MODER_MODE10_Pos)
#define GPIO_MODER_MODE11_Pos   (22U)
#define GPIO_MODER_MODE11_Msk   (0x3UL << GPIO_MODER_MODE11_Pos)
#define GPIO_MODER_MODE11   GPIO_MODER_MODE11_Msk
#define GPIO_MODER_MODE11_0   (0x1UL << GPIO_MODER_MODE11_Pos)
#define GPIO_MODER_MODE11_1   (0x2UL << GPIO_MODER_MODE11_Pos)
#define GPIO_MODER_MODE12_Pos   (24U)
#define GPIO_MODER_MODE12_Msk   (0x3UL << GPIO_MODER_MODE12_Pos)
#define GPIO_MODER_MODE12   GPIO_MODER_MODE12_Msk
#define GPIO_MODER_MODE12_0   (0x1UL << GPIO_MODER_MODE12_Pos)
#define GPIO_MODER_MODE12_1   (0x2UL << GPIO_MODER_MODE12_Pos)
#define GPIO_MODER_MODE13_Pos   (26U)
#define GPIO_MODER_MODE13_Msk   (0x3UL << GPIO_MODER_MODE13_Pos)
#define GPIO_MODER_MODE13   GPIO_MODER_MODE13_Msk
#define GPIO_MODER_MODE13_0   (0x1UL << GPIO_MODER_MODE13_Pos)
#define GPIO_MODER_MODE13_1   (0x2UL << GPIO_MODER_MODE13_Pos)
#define GPIO_MODER_MODE14_Pos   (28U)
#define GPIO_MODER_MODE14_Msk   (0x3UL << GPIO_MODER_MODE14_Pos)
#define GPIO_MODER_MODE14   GPIO_MODER_MODE14_Msk
#define GPIO_MODER_MODE14_0   (0x1UL << GPIO_MODER_MODE14_Pos)
#define GPIO_MODER_MODE14_1   (0x2UL << GPIO_MODER_MODE14_Pos)
#define GPIO_MODER_MODE15_Pos   (30U)
#define GPIO_MODER_MODE15_Msk   (0x3UL << GPIO_MODER_MODE15_Pos)
#define GPIO_MODER_MODE15   GPIO_MODER_MODE15_Msk
#define GPIO_MODER_MODE15_0   (0x1UL << GPIO_MODER_MODE15_Pos)
#define GPIO_MODER_MODE15_1   (0x2UL << GPIO_MODER_MODE15_Pos)
#define GPIO_OTYPER_OT0_Pos   (0U)
#define GPIO_OTYPER_OT0_Msk   (0x1UL << GPIO_OTYPER_OT0_Pos)
#define GPIO_OTYPER_OT0   GPIO_OTYPER_OT0_Msk
#define GPIO_OTYPER_OT1_Pos   (1U)
#define GPIO_OTYPER_OT1_Msk   (0x1UL << GPIO_OTYPER_OT1_Pos)
#define GPIO_OTYPER_OT1   GPIO_OTYPER_OT1_Msk
#define GPIO_OTYPER_OT2_Pos   (2U)
#define GPIO_OTYPER_OT2_Msk   (0x1UL << GPIO_OTYPER_OT2_Pos)
#define GPIO_OTYPER_OT2   GPIO_OTYPER_OT2_Msk
#define GPIO_OTYPER_OT3_Pos   (3U)
#define GPIO_OTYPER_OT3_Msk   (0x1UL << GPIO_OTYPER_OT3_Pos)
#define GPIO_OTYPER_OT3   GPIO_OTYPER_OT3_Msk
#define GPIO_OTYPER_OT4_Pos   (4U)
#define GPIO_OTYPER_OT4_Msk   (0x1UL << GPIO_OTYPER_OT4_Pos)
#define GPIO_OTYPER_OT4   GPIO_OTYPER_OT4_Msk
#define GPIO_OTYPER_OT5_Pos   (5U)
#define GPIO_OTYPER_OT5_Msk   (0x1UL << GPIO_OTYPER_OT5_Pos)
#define GPIO_OTYPER_OT5   GPIO_OTYPER_OT5_Msk
#define GPIO_OTYPER_OT6_Pos   (6U)
#define GPIO_OTYPER_OT6_Msk   (0x1UL << GPIO_OTYPER_OT6_Pos)
#define GPIO_OTYPER_OT6   GPIO_OTYPER_OT6_Msk
#define GPIO_OTYPER_OT7_Pos   (7U)
#define GPIO_OTYPER_OT7_Msk   (0x1UL << GPIO_OTYPER_OT7_Pos)
#define GPIO_OTYPER_OT7   GPIO_OTYPER_OT7_Msk
#define GPIO_OTYPER_OT8_Pos   (8U)
#define GPIO_OTYPER_OT8_Msk   (0x1UL << GPIO_OTYPER_OT8_Pos)
#define GPIO_OTYPER_OT8   GPIO_OTYPER_OT8_Msk
#define GPIO_OTYPER_OT9_Pos   (9U)
#define GPIO_OTYPER_OT9_Msk   (0x1UL << GPIO_OTYPER_OT9_Pos)
#define GPIO_OTYPER_OT9   GPIO_OTYPER_OT9_Msk
#define GPIO_OTYPER_OT10_Pos   (10U)
#define GPIO_OTYPER_OT10_Msk   (0x1UL << GPIO_OTYPER_OT10_Pos)
#define GPIO_OTYPER_OT10   GPIO_OTYPER_OT10_Msk
#define GPIO_OTYPER_OT11_Pos   (11U)
#define GPIO_OTYPER_OT11_Msk   (0x1UL << GPIO_OTYPER_OT11_Pos)
#define GPIO_OTYPER_OT11   GPIO_OTYPER_OT11_Msk
#define GPIO_OTYPER_OT12_Pos   (12U)
#define GPIO_OTYPER_OT12_Msk   (0x1UL << GPIO_OTYPER_OT12_Pos)
#define GPIO_OTYPER_OT12   GPIO_OTYPER_OT12_Msk
#define GPIO_OTYPER_OT13_Pos   (13U)
#define GPIO_OTYPER_OT13_Msk   (0x1UL << GPIO_OTYPER_OT13_Pos)
#define GPIO_OTYPER_OT13   GPIO_OTYPER_OT13_Msk
#define GPIO_OTYPER_OT14_Pos   (14U)
#define GPIO_OTYPER_OT14_Msk   (0x1UL << GPIO_OTYPER_OT14_Pos)
#define GPIO_OTYPER_OT14   GPIO_OTYPER_OT14_Msk
#define GPIO_OTYPER_OT15_Pos   (15U)
#define GPIO_OTYPER_OT15_Msk   (0x1UL << GPIO_OTYPER_OT15_Pos)
#define GPIO_OTYPER_OT15   GPIO_OTYPER_OT15_Msk
#define GPIO_OSPEEDR_OSPEED0_Pos   (0U)
#define GPIO_OSPEEDR_OSPEED0_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED0_Pos)
#define GPIO_OSPEEDR_OSPEED0   GPIO_OSPEEDR_OSPEED0_Msk
#define GPIO_OSPEEDR_OSPEED0_0   (0x1UL << GPIO_OSPEEDR_OSPEED0_Pos)
#define GPIO_OSPEEDR_OSPEED0_1   (0x2UL << GPIO_OSPEEDR_OSPEED0_Pos)
#define GPIO_OSPEEDR_OSPEED1_Pos   (2U)
#define GPIO_OSPEEDR_OSPEED1_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED1_Pos)
#define GPIO_OSPEEDR_OSPEED1   GPIO_OSPEEDR_OSPEED1_Msk
#define GPIO_OSPEEDR_OSPEED1_0   (0x1UL << GPIO_OSPEEDR_OSPEED1_Pos)
#define GPIO_OSPEEDR_OSPEED1_1   (0x2UL << GPIO_OSPEEDR_OSPEED1_Pos)
#define GPIO_OSPEEDR_OSPEED2_Pos   (4U)
#define GPIO_OSPEEDR_OSPEED2_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED2_Pos)
#define GPIO_OSPEEDR_OSPEED2   GPIO_OSPEEDR_OSPEED2_Msk
#define GPIO_OSPEEDR_OSPEED2_0   (0x1UL << GPIO_OSPEEDR_OSPEED2_Pos)
#define GPIO_OSPEEDR_OSPEED2_1   (0x2UL << GPIO_OSPEEDR_OSPEED2_Pos)
#define GPIO_OSPEEDR_OSPEED3_Pos   (6U)
#define GPIO_OSPEEDR_OSPEED3_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED3_Pos)
#define GPIO_OSPEEDR_OSPEED3   GPIO_OSPEEDR_OSPEED3_Msk
#define GPIO_OSPEEDR_OSPEED3_0   (0x1UL << GPIO_OSPEEDR_OSPEED3_Pos)
#define GPIO_OSPEEDR_OSPEED3_1   (0x2UL << GPIO_OSPEEDR_OSPEED3_Pos)
#define GPIO_OSPEEDR_OSPEED4_Pos   (8U)
#define GPIO_OSPEEDR_OSPEED4_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED4_Pos)
#define GPIO_OSPEEDR_OSPEED4   GPIO_OSPEEDR_OSPEED4_Msk
#define GPIO_OSPEEDR_OSPEED4_0   (0x1UL << GPIO_OSPEEDR_OSPEED4_Pos)
#define GPIO_OSPEEDR_OSPEED4_1   (0x2UL << GPIO_OSPEEDR_OSPEED4_Pos)
#define GPIO_OSPEEDR_OSPEED5_Pos   (10U)
#define GPIO_OSPEEDR_OSPEED5_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED5_Pos)
#define GPIO_OSPEEDR_OSPEED5   GPIO_OSPEEDR_OSPEED5_Msk
#define GPIO_OSPEEDR_OSPEED5_0   (0x1UL << GPIO_OSPEEDR_OSPEED5_Pos)
#define GPIO_OSPEEDR_OSPEED5_1   (0x2UL << GPIO_OSPEEDR_OSPEED5_Pos)
#define GPIO_OSPEEDR_OSPEED6_Pos   (12U)
#define GPIO_OSPEEDR_OSPEED6_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED6_Pos)
#define GPIO_OSPEEDR_OSPEED6   GPIO_OSPEEDR_OSPEED6_Msk
#define GPIO_OSPEEDR_OSPEED6_0   (0x1UL << GPIO_OSPEEDR_OSPEED6_Pos)
#define GPIO_OSPEEDR_OSPEED6_1   (0x2UL << GPIO_OSPEEDR_OSPEED6_Pos)
#define GPIO_OSPEEDR_OSPEED7_Pos   (14U)
#define GPIO_OSPEEDR_OSPEED7_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED7_Pos)
#define GPIO_OSPEEDR_OSPEED7   GPIO_OSPEEDR_OSPEED7_Msk
#define GPIO_OSPEEDR_OSPEED7_0   (0x1UL << GPIO_OSPEEDR_OSPEED7_Pos)
#define GPIO_OSPEEDR_OSPEED7_1   (0x2UL << GPIO_OSPEEDR_OSPEED7_Pos)
#define GPIO_OSPEEDR_OSPEED8_Pos   (16U)
#define GPIO_OSPEEDR_OSPEED8_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED8_Pos)
#define GPIO_OSPEEDR_OSPEED8   GPIO_OSPEEDR_OSPEED8_Msk
#define GPIO_OSPEEDR_OSPEED8_0   (0x1UL << GPIO_OSPEEDR_OSPEED8_Pos)
#define GPIO_OSPEEDR_OSPEED8_1   (0x2UL << GPIO_OSPEEDR_OSPEED8_Pos)
#define GPIO_OSPEEDR_OSPEED9_Pos   (18U)
#define GPIO_OSPEEDR_OSPEED9_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED9_Pos)
#define GPIO_OSPEEDR_OSPEED9   GPIO_OSPEEDR_OSPEED9_Msk
#define GPIO_OSPEEDR_OSPEED9_0   (0x1UL << GPIO_OSPEEDR_OSPEED9_Pos)
#define GPIO_OSPEEDR_OSPEED9_1   (0x2UL << GPIO_OSPEEDR_OSPEED9_Pos)
#define GPIO_OSPEEDR_OSPEED10_Pos   (20U)
#define GPIO_OSPEEDR_OSPEED10_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED10_Pos)
#define GPIO_OSPEEDR_OSPEED10   GPIO_OSPEEDR_OSPEED10_Msk
#define GPIO_OSPEEDR_OSPEED10_0   (0x1UL << GPIO_OSPEEDR_OSPEED10_Pos)
#define GPIO_OSPEEDR_OSPEED10_1   (0x2UL << GPIO_OSPEEDR_OSPEED10_Pos)
#define GPIO_OSPEEDR_OSPEED11_Pos   (22U)
#define GPIO_OSPEEDR_OSPEED11_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED11_Pos)
#define GPIO_OSPEEDR_OSPEED11   GPIO_OSPEEDR_OSPEED11_Msk
#define GPIO_OSPEEDR_OSPEED11_0   (0x1UL << GPIO_OSPEEDR_OSPEED11_Pos)
#define GPIO_OSPEEDR_OSPEED11_1   (0x2UL << GPIO_OSPEEDR_OSPEED11_Pos)
#define GPIO_OSPEEDR_OSPEED12_Pos   (24U)
#define GPIO_OSPEEDR_OSPEED12_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED12_Pos)
#define GPIO_OSPEEDR_OSPEED12   GPIO_OSPEEDR_OSPEED12_Msk
#define GPIO_OSPEEDR_OSPEED12_0   (0x1UL << GPIO_OSPEEDR_OSPEED12_Pos)
#define GPIO_OSPEEDR_OSPEED12_1   (0x2UL << GPIO_OSPEEDR_OSPEED12_Pos)
#define GPIO_OSPEEDR_OSPEED13_Pos   (26U)
#define GPIO_OSPEEDR_OSPEED13_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED13_Pos)
#define GPIO_OSPEEDR_OSPEED13   GPIO_OSPEEDR_OSPEED13_Msk
#define GPIO_OSPEEDR_OSPEED13_0   (0x1UL << GPIO_OSPEEDR_OSPEED13_Pos)
#define GPIO_OSPEEDR_OSPEED13_1   (0x2UL << GPIO_OSPEEDR_OSPEED13_Pos)
#define GPIO_OSPEEDR_OSPEED14_Pos   (28U)
#define GPIO_OSPEEDR_OSPEED14_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED14_Pos)
#define GPIO_OSPEEDR_OSPEED14   GPIO_OSPEEDR_OSPEED14_Msk
#define GPIO_OSPEEDR_OSPEED14_0   (0x1UL << GPIO_OSPEEDR_OSPEED14_Pos)
#define GPIO_OSPEEDR_OSPEED14_1   (0x2UL << GPIO_OSPEEDR_OSPEED14_Pos)
#define GPIO_OSPEEDR_OSPEED15_Pos   (30U)
#define GPIO_OSPEEDR_OSPEED15_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED15_Pos)
#define GPIO_OSPEEDR_OSPEED15   GPIO_OSPEEDR_OSPEED15_Msk
#define GPIO_OSPEEDR_OSPEED15_0   (0x1UL << GPIO_OSPEEDR_OSPEED15_Pos)
#define GPIO_OSPEEDR_OSPEED15_1   (0x2UL << GPIO_OSPEEDR_OSPEED15_Pos)
#define GPIO_PUPDR_PUPD0_Pos   (0U)
#define GPIO_PUPDR_PUPD0_Msk   (0x3UL << GPIO_PUPDR_PUPD0_Pos)
#define GPIO_PUPDR_PUPD0   GPIO_PUPDR_PUPD0_Msk
#define GPIO_PUPDR_PUPD0_0   (0x1UL << GPIO_PUPDR_PUPD0_Pos)
#define GPIO_PUPDR_PUPD0_1   (0x2UL << GPIO_PUPDR_PUPD0_Pos)
#define GPIO_PUPDR_PUPD1_Pos   (2U)
#define GPIO_PUPDR_PUPD1_Msk   (0x3UL << GPIO_PUPDR_PUPD1_Pos)
#define GPIO_PUPDR_PUPD1   GPIO_PUPDR_PUPD1_Msk
#define GPIO_PUPDR_PUPD1_0   (0x1UL << GPIO_PUPDR_PUPD1_Pos)
#define GPIO_PUPDR_PUPD1_1   (0x2UL << GPIO_PUPDR_PUPD1_Pos)
#define GPIO_PUPDR_PUPD2_Pos   (4U)
#define GPIO_PUPDR_PUPD2_Msk   (0x3UL << GPIO_PUPDR_PUPD2_Pos)
#define GPIO_PUPDR_PUPD2   GPIO_PUPDR_PUPD2_Msk
#define GPIO_PUPDR_PUPD2_0   (0x1UL << GPIO_PUPDR_PUPD2_Pos)
#define GPIO_PUPDR_PUPD2_1   (0x2UL << GPIO_PUPDR_PUPD2_Pos)
#define GPIO_PUPDR_PUPD3_Pos   (6U)
#define GPIO_PUPDR_PUPD3_Msk   (0x3UL << GPIO_PUPDR_PUPD3_Pos)
#define GPIO_PUPDR_PUPD3   GPIO_PUPDR_PUPD3_Msk
#define GPIO_PUPDR_PUPD3_0   (0x1UL << GPIO_PUPDR_PUPD3_Pos)
#define GPIO_PUPDR_PUPD3_1   (0x2UL << GPIO_PUPDR_PUPD3_Pos)
#define GPIO_PUPDR_PUPD4_Pos   (8U)
#define GPIO_PUPDR_PUPD4_Msk   (0x3UL << GPIO_PUPDR_PUPD4_Pos)
#define GPIO_PUPDR_PUPD4   GPIO_PUPDR_PUPD4_Msk
#define GPIO_PUPDR_PUPD4_0   (0x1UL << GPIO_PUPDR_PUPD4_Pos)
#define GPIO_PUPDR_PUPD4_1   (0x2UL << GPIO_PUPDR_PUPD4_Pos)
#define GPIO_PUPDR_PUPD5_Pos   (10U)
#define GPIO_PUPDR_PUPD5_Msk   (0x3UL << GPIO_PUPDR_PUPD5_Pos)
#define GPIO_PUPDR_PUPD5   GPIO_PUPDR_PUPD5_Msk
#define GPIO_PUPDR_PUPD5_0   (0x1UL << GPIO_PUPDR_PUPD5_Pos)
#define GPIO_PUPDR_PUPD5_1   (0x2UL << GPIO_PUPDR_PUPD5_Pos)
#define GPIO_PUPDR_PUPD6_Pos   (12U)
#define GPIO_PUPDR_PUPD6_Msk   (0x3UL << GPIO_PUPDR_PUPD6_Pos)
#define GPIO_PUPDR_PUPD6   GPIO_PUPDR_PUPD6_Msk
#define GPIO_PUPDR_PUPD6_0   (0x1UL << GPIO_PUPDR_PUPD6_Pos)
#define GPIO_PUPDR_PUPD6_1   (0x2UL << GPIO_PUPDR_PUPD6_Pos)
#define GPIO_PUPDR_PUPD7_Pos   (14U)
#define GPIO_PUPDR_PUPD7_Msk   (0x3UL << GPIO_PUPDR_PUPD7_Pos)
#define GPIO_PUPDR_PUPD7   GPIO_PUPDR_PUPD7_Msk
#define GPIO_PUPDR_PUPD7_0   (0x1UL << GPIO_PUPDR_PUPD7_Pos)
#define GPIO_PUPDR_PUPD7_1   (0x2UL << GPIO_PUPDR_PUPD7_Pos)
#define GPIO_PUPDR_PUPD8_Pos   (16U)
#define GPIO_PUPDR_PUPD8_Msk   (0x3UL << GPIO_PUPDR_PUPD8_Pos)
#define GPIO_PUPDR_PUPD8   GPIO_PUPDR_PUPD8_Msk
#define GPIO_PUPDR_PUPD8_0   (0x1UL << GPIO_PUPDR_PUPD8_Pos)
#define GPIO_PUPDR_PUPD8_1   (0x2UL << GPIO_PUPDR_PUPD8_Pos)
#define GPIO_PUPDR_PUPD9_Pos   (18U)
#define GPIO_PUPDR_PUPD9_Msk   (0x3UL << GPIO_PUPDR_PUPD9_Pos)
#define GPIO_PUPDR_PUPD9   GPIO_PUPDR_PUPD9_Msk
#define GPIO_PUPDR_PUPD9_0   (0x1UL << GPIO_PUPDR_PUPD9_Pos)
#define GPIO_PUPDR_PUPD9_1   (0x2UL << GPIO_PUPDR_PUPD9_Pos)
#define GPIO_PUPDR_PUPD10_Pos   (20U)
#define GPIO_PUPDR_PUPD10_Msk   (0x3UL << GPIO_PUPDR_PUPD10_Pos)
#define GPIO_PUPDR_PUPD10   GPIO_PUPDR_PUPD10_Msk
#define GPIO_PUPDR_PUPD10_0   (0x1UL << GPIO_PUPDR_PUPD10_Pos)
#define GPIO_PUPDR_PUPD10_1   (0x2UL << GPIO_PUPDR_PUPD10_Pos)
#define GPIO_PUPDR_PUPD11_Pos   (22U)
#define GPIO_PUPDR_PUPD11_Msk   (0x3UL << GPIO_PUPDR_PUPD11_Pos)
#define GPIO_PUPDR_PUPD11   GPIO_PUPDR_PUPD11_Msk
#define GPIO_PUPDR_PUPD11_0   (0x1UL << GPIO_PUPDR_PUPD11_Pos)
#define GPIO_PUPDR_PUPD11_1   (0x2UL << GPIO_PUPDR_PUPD11_Pos)
#define GPIO_PUPDR_PUPD12_Pos   (24U)
#define GPIO_PUPDR_PUPD12_Msk   (0x3UL << GPIO_PUPDR_PUPD12_Pos)
#define GPIO_PUPDR_PUPD12   GPIO_PUPDR_PUPD12_Msk
#define GPIO_PUPDR_PUPD12_0   (0x1UL << GPIO_PUPDR_PUPD12_Pos)
#define GPIO_PUPDR_PUPD12_1   (0x2UL << GPIO_PUPDR_PUPD12_Pos)
#define GPIO_PUPDR_PUPD13_Pos   (26U)
#define GPIO_PUPDR_PUPD13_Msk   (0x3UL << GPIO_PUPDR_PUPD13_Pos)
#define GPIO_PUPDR_PUPD13   GPIO_PUPDR_PUPD13_Msk
#define GPIO_PUPDR_PUPD13_0   (0x1UL << GPIO_PUPDR_PUPD13_Pos)
#define GPIO_PUPDR_PUPD13_1   (0x2UL << GPIO_PUPDR_PUPD13_Pos)
#define GPIO_PUPDR_PUPD14_Pos   (28U)
#define GPIO_PUPDR_PUPD14_Msk   (0x3UL << GPIO_PUPDR_PUPD14_Pos)
#define GPIO_PUPDR_PUPD14   GPIO_PUPDR_PUPD14_Msk
#define GPIO_PUPDR_PUPD14_0   (0x1UL << GPIO_PUPDR_PUPD14_Pos)
#define GPIO_PUPDR_PUPD14_1   (0x2UL << GPIO_PUPDR_PUPD14_Pos)
#define GPIO_PUPDR_PUPD15_Pos   (30U)
#define GPIO_PUPDR_PUPD15_Msk   (0x3UL << GPIO_PUPDR_PUPD15_Pos)
#define GPIO_PUPDR_PUPD15   GPIO_PUPDR_PUPD15_Msk
#define GPIO_PUPDR_PUPD15_0   (0x1UL << GPIO_PUPDR_PUPD15_Pos)
#define GPIO_PUPDR_PUPD15_1   (0x2UL << GPIO_PUPDR_PUPD15_Pos)
#define GPIO_IDR_ID0_Pos   (0U)
#define GPIO_IDR_ID0_Msk   (0x1UL << GPIO_IDR_ID0_Pos)
#define GPIO_IDR_ID0   GPIO_IDR_ID0_Msk
#define GPIO_IDR_ID1_Pos   (1U)
#define GPIO_IDR_ID1_Msk   (0x1UL << GPIO_IDR_ID1_Pos)
#define GPIO_IDR_ID1   GPIO_IDR_ID1_Msk
#define GPIO_IDR_ID2_Pos   (2U)
#define GPIO_IDR_ID2_Msk   (0x1UL << GPIO_IDR_ID2_Pos)
#define GPIO_IDR_ID2   GPIO_IDR_ID2_Msk
#define GPIO_IDR_ID3_Pos   (3U)
#define GPIO_IDR_ID3_Msk   (0x1UL << GPIO_IDR_ID3_Pos)
#define GPIO_IDR_ID3   GPIO_IDR_ID3_Msk
#define GPIO_IDR_ID4_Pos   (4U)
#define GPIO_IDR_ID4_Msk   (0x1UL << GPIO_IDR_ID4_Pos)
#define GPIO_IDR_ID4   GPIO_IDR_ID4_Msk
#define GPIO_IDR_ID5_Pos   (5U)
#define GPIO_IDR_ID5_Msk   (0x1UL << GPIO_IDR_ID5_Pos)
#define GPIO_IDR_ID5   GPIO_IDR_ID5_Msk
#define GPIO_IDR_ID6_Pos   (6U)
#define GPIO_IDR_ID6_Msk   (0x1UL << GPIO_IDR_ID6_Pos)
#define GPIO_IDR_ID6   GPIO_IDR_ID6_Msk
#define GPIO_IDR_ID7_Pos   (7U)
#define GPIO_IDR_ID7_Msk   (0x1UL << GPIO_IDR_ID7_Pos)
#define GPIO_IDR_ID7   GPIO_IDR_ID7_Msk
#define GPIO_IDR_ID8_Pos   (8U)
#define GPIO_IDR_ID8_Msk   (0x1UL << GPIO_IDR_ID8_Pos)
#define GPIO_IDR_ID8   GPIO_IDR_ID8_Msk
#define GPIO_IDR_ID9_Pos   (9U)
#define GPIO_IDR_ID9_Msk   (0x1UL << GPIO_IDR_ID9_Pos)
#define GPIO_IDR_ID9   GPIO_IDR_ID9_Msk
#define GPIO_IDR_ID10_Pos   (10U)
#define GPIO_IDR_ID10_Msk   (0x1UL << GPIO_IDR_ID10_Pos)
#define GPIO_IDR_ID10   GPIO_IDR_ID10_Msk
#define GPIO_IDR_ID11_Pos   (11U)
#define GPIO_IDR_ID11_Msk   (0x1UL << GPIO_IDR_ID11_Pos)
#define GPIO_IDR_ID11   GPIO_IDR_ID11_Msk
#define GPIO_IDR_ID12_Pos   (12U)
#define GPIO_IDR_ID12_Msk   (0x1UL << GPIO_IDR_ID12_Pos)
#define GPIO_IDR_ID12   GPIO_IDR_ID12_Msk
#define GPIO_IDR_ID13_Pos   (13U)
#define GPIO_IDR_ID13_Msk   (0x1UL << GPIO_IDR_ID13_Pos)
#define GPIO_IDR_ID13   GPIO_IDR_ID13_Msk
#define GPIO_IDR_ID14_Pos   (14U)
#define GPIO_IDR_ID14_Msk   (0x1UL << GPIO_IDR_ID14_Pos)
#define GPIO_IDR_ID14   GPIO_IDR_ID14_Msk
#define GPIO_IDR_ID15_Pos   (15U)
#define GPIO_IDR_ID15_Msk   (0x1UL << GPIO_IDR_ID15_Pos)
#define GPIO_IDR_ID15   GPIO_IDR_ID15_Msk
#define GPIO_ODR_OD0_Pos   (0U)
#define GPIO_ODR_OD0_Msk   (0x1UL << GPIO_ODR_OD0_Pos)
#define GPIO_ODR_OD0   GPIO_ODR_OD0_Msk
#define GPIO_ODR_OD1_Pos   (1U)
#define GPIO_ODR_OD1_Msk   (0x1UL << GPIO_ODR_OD1_Pos)
#define GPIO_ODR_OD1   GPIO_ODR_OD1_Msk
#define GPIO_ODR_OD2_Pos   (2U)
#define GPIO_ODR_OD2_Msk   (0x1UL << GPIO_ODR_OD2_Pos)
#define GPIO_ODR_OD2   GPIO_ODR_OD2_Msk
#define GPIO_ODR_OD3_Pos   (3U)
#define GPIO_ODR_OD3_Msk   (0x1UL << GPIO_ODR_OD3_Pos)
#define GPIO_ODR_OD3   GPIO_ODR_OD3_Msk
#define GPIO_ODR_OD4_Pos   (4U)
#define GPIO_ODR_OD4_Msk   (0x1UL << GPIO_ODR_OD4_Pos)
#define GPIO_ODR_OD4   GPIO_ODR_OD4_Msk
#define GPIO_ODR_OD5_Pos   (5U)
#define GPIO_ODR_OD5_Msk   (0x1UL << GPIO_ODR_OD5_Pos)
#define GPIO_ODR_OD5   GPIO_ODR_OD5_Msk
#define GPIO_ODR_OD6_Pos   (6U)
#define GPIO_ODR_OD6_Msk   (0x1UL << GPIO_ODR_OD6_Pos)
#define GPIO_ODR_OD6   GPIO_ODR_OD6_Msk
#define GPIO_ODR_OD7_Pos   (7U)
#define GPIO_ODR_OD7_Msk   (0x1UL << GPIO_ODR_OD7_Pos)
#define GPIO_ODR_OD7   GPIO_ODR_OD7_Msk
#define GPIO_ODR_OD8_Pos   (8U)
#define GPIO_ODR_OD8_Msk   (0x1UL << GPIO_ODR_OD8_Pos)
#define GPIO_ODR_OD8   GPIO_ODR_OD8_Msk
#define GPIO_ODR_OD9_Pos   (9U)
#define GPIO_ODR_OD9_Msk   (0x1UL << GPIO_ODR_OD9_Pos)
#define GPIO_ODR_OD9   GPIO_ODR_OD9_Msk
#define GPIO_ODR_OD10_Pos   (10U)
#define GPIO_ODR_OD10_Msk   (0x1UL << GPIO_ODR_OD10_Pos)
#define GPIO_ODR_OD10   GPIO_ODR_OD10_Msk
#define GPIO_ODR_OD11_Pos   (11U)
#define GPIO_ODR_OD11_Msk   (0x1UL << GPIO_ODR_OD11_Pos)
#define GPIO_ODR_OD11   GPIO_ODR_OD11_Msk
#define GPIO_ODR_OD12_Pos   (12U)
#define GPIO_ODR_OD12_Msk   (0x1UL << GPIO_ODR_OD12_Pos)
#define GPIO_ODR_OD12   GPIO_ODR_OD12_Msk
#define GPIO_ODR_OD13_Pos   (13U)
#define GPIO_ODR_OD13_Msk   (0x1UL << GPIO_ODR_OD13_Pos)
#define GPIO_ODR_OD13   GPIO_ODR_OD13_Msk
#define GPIO_ODR_OD14_Pos   (14U)
#define GPIO_ODR_OD14_Msk   (0x1UL << GPIO_ODR_OD14_Pos)
#define GPIO_ODR_OD14   GPIO_ODR_OD14_Msk
#define GPIO_ODR_OD15_Pos   (15U)
#define GPIO_ODR_OD15_Msk   (0x1UL << GPIO_ODR_OD15_Pos)
#define GPIO_ODR_OD15   GPIO_ODR_OD15_Msk
#define GPIO_BSRR_BS0_Pos   (0U)
#define GPIO_BSRR_BS0_Msk   (0x1UL << GPIO_BSRR_BS0_Pos)
#define GPIO_BSRR_BS0   GPIO_BSRR_BS0_Msk
#define GPIO_BSRR_BS1_Pos   (1U)
#define GPIO_BSRR_BS1_Msk   (0x1UL << GPIO_BSRR_BS1_Pos)
#define GPIO_BSRR_BS1   GPIO_BSRR_BS1_Msk
#define GPIO_BSRR_BS2_Pos   (2U)
#define GPIO_BSRR_BS2_Msk   (0x1UL << GPIO_BSRR_BS2_Pos)
#define GPIO_BSRR_BS2   GPIO_BSRR_BS2_Msk
#define GPIO_BSRR_BS3_Pos   (3U)
#define GPIO_BSRR_BS3_Msk   (0x1UL << GPIO_BSRR_BS3_Pos)
#define GPIO_BSRR_BS3   GPIO_BSRR_BS3_Msk
#define GPIO_BSRR_BS4_Pos   (4U)
#define GPIO_BSRR_BS4_Msk   (0x1UL << GPIO_BSRR_BS4_Pos)
#define GPIO_BSRR_BS4   GPIO_BSRR_BS4_Msk
#define GPIO_BSRR_BS5_Pos   (5U)
#define GPIO_BSRR_BS5_Msk   (0x1UL << GPIO_BSRR_BS5_Pos)
#define GPIO_BSRR_BS5   GPIO_BSRR_BS5_Msk
#define GPIO_BSRR_BS6_Pos   (6U)
#define GPIO_BSRR_BS6_Msk   (0x1UL << GPIO_BSRR_BS6_Pos)
#define GPIO_BSRR_BS6   GPIO_BSRR_BS6_Msk
#define GPIO_BSRR_BS7_Pos   (7U)
#define GPIO_BSRR_BS7_Msk   (0x1UL << GPIO_BSRR_BS7_Pos)
#define GPIO_BSRR_BS7   GPIO_BSRR_BS7_Msk
#define GPIO_BSRR_BS8_Pos   (8U)
#define GPIO_BSRR_BS8_Msk   (0x1UL << GPIO_BSRR_BS8_Pos)
#define GPIO_BSRR_BS8   GPIO_BSRR_BS8_Msk
#define GPIO_BSRR_BS9_Pos   (9U)
#define GPIO_BSRR_BS9_Msk   (0x1UL << GPIO_BSRR_BS9_Pos)
#define GPIO_BSRR_BS9   GPIO_BSRR_BS9_Msk
#define GPIO_BSRR_BS10_Pos   (10U)
#define GPIO_BSRR_BS10_Msk   (0x1UL << GPIO_BSRR_BS10_Pos)
#define GPIO_BSRR_BS10   GPIO_BSRR_BS10_Msk
#define GPIO_BSRR_BS11_Pos   (11U)
#define GPIO_BSRR_BS11_Msk   (0x1UL << GPIO_BSRR_BS11_Pos)
#define GPIO_BSRR_BS11   GPIO_BSRR_BS11_Msk
#define GPIO_BSRR_BS12_Pos   (12U)
#define GPIO_BSRR_BS12_Msk   (0x1UL << GPIO_BSRR_BS12_Pos)
#define GPIO_BSRR_BS12   GPIO_BSRR_BS12_Msk
#define GPIO_BSRR_BS13_Pos   (13U)
#define GPIO_BSRR_BS13_Msk   (0x1UL << GPIO_BSRR_BS13_Pos)
#define GPIO_BSRR_BS13   GPIO_BSRR_BS13_Msk
#define GPIO_BSRR_BS14_Pos   (14U)
#define GPIO_BSRR_BS14_Msk   (0x1UL << GPIO_BSRR_BS14_Pos)
#define GPIO_BSRR_BS14   GPIO_BSRR_BS14_Msk
#define GPIO_BSRR_BS15_Pos   (15U)
#define GPIO_BSRR_BS15_Msk   (0x1UL << GPIO_BSRR_BS15_Pos)
#define GPIO_BSRR_BS15   GPIO_BSRR_BS15_Msk
#define GPIO_BSRR_BR0_Pos   (16U)
#define GPIO_BSRR_BR0_Msk   (0x1UL << GPIO_BSRR_BR0_Pos)
#define GPIO_BSRR_BR0   GPIO_BSRR_BR0_Msk
#define GPIO_BSRR_BR1_Pos   (17U)
#define GPIO_BSRR_BR1_Msk   (0x1UL << GPIO_BSRR_BR1_Pos)
#define GPIO_BSRR_BR1   GPIO_BSRR_BR1_Msk
#define GPIO_BSRR_BR2_Pos   (18U)
#define GPIO_BSRR_BR2_Msk   (0x1UL << GPIO_BSRR_BR2_Pos)
#define GPIO_BSRR_BR2   GPIO_BSRR_BR2_Msk
#define GPIO_BSRR_BR3_Pos   (19U)
#define GPIO_BSRR_BR3_Msk   (0x1UL << GPIO_BSRR_BR3_Pos)
#define GPIO_BSRR_BR3   GPIO_BSRR_BR3_Msk
#define GPIO_BSRR_BR4_Pos   (20U)
#define GPIO_BSRR_BR4_Msk   (0x1UL << GPIO_BSRR_BR4_Pos)
#define GPIO_BSRR_BR4   GPIO_BSRR_BR4_Msk
#define GPIO_BSRR_BR5_Pos   (21U)
#define GPIO_BSRR_BR5_Msk   (0x1UL << GPIO_BSRR_BR5_Pos)
#define GPIO_BSRR_BR5   GPIO_BSRR_BR5_Msk
#define GPIO_BSRR_BR6_Pos   (22U)
#define GPIO_BSRR_BR6_Msk   (0x1UL << GPIO_BSRR_BR6_Pos)
#define GPIO_BSRR_BR6   GPIO_BSRR_BR6_Msk
#define GPIO_BSRR_BR7_Pos   (23U)
#define GPIO_BSRR_BR7_Msk   (0x1UL << GPIO_BSRR_BR7_Pos)
#define GPIO_BSRR_BR7   GPIO_BSRR_BR7_Msk
#define GPIO_BSRR_BR8_Pos   (24U)
#define GPIO_BSRR_BR8_Msk   (0x1UL << GPIO_BSRR_BR8_Pos)
#define GPIO_BSRR_BR8   GPIO_BSRR_BR8_Msk
#define GPIO_BSRR_BR9_Pos   (25U)
#define GPIO_BSRR_BR9_Msk   (0x1UL << GPIO_BSRR_BR9_Pos)
#define GPIO_BSRR_BR9   GPIO_BSRR_BR9_Msk
#define GPIO_BSRR_BR10_Pos   (26U)
#define GPIO_BSRR_BR10_Msk   (0x1UL << GPIO_BSRR_BR10_Pos)
#define GPIO_BSRR_BR10   GPIO_BSRR_BR10_Msk
#define GPIO_BSRR_BR11_Pos   (27U)
#define GPIO_BSRR_BR11_Msk   (0x1UL << GPIO_BSRR_BR11_Pos)
#define GPIO_BSRR_BR11   GPIO_BSRR_BR11_Msk
#define GPIO_BSRR_BR12_Pos   (28U)
#define GPIO_BSRR_BR12_Msk   (0x1UL << GPIO_BSRR_BR12_Pos)
#define GPIO_BSRR_BR12   GPIO_BSRR_BR12_Msk
#define GPIO_BSRR_BR13_Pos   (29U)
#define GPIO_BSRR_BR13_Msk   (0x1UL << GPIO_BSRR_BR13_Pos)
#define GPIO_BSRR_BR13   GPIO_BSRR_BR13_Msk
#define GPIO_BSRR_BR14_Pos   (30U)
#define GPIO_BSRR_BR14_Msk   (0x1UL << GPIO_BSRR_BR14_Pos)
#define GPIO_BSRR_BR14   GPIO_BSRR_BR14_Msk
#define GPIO_BSRR_BR15_Pos   (31U)
#define GPIO_BSRR_BR15_Msk   (0x1UL << GPIO_BSRR_BR15_Pos)
#define GPIO_BSRR_BR15   GPIO_BSRR_BR15_Msk
#define GPIO_LCKR_LCK0_Pos   (0U)
#define GPIO_LCKR_LCK0_Msk   (0x1UL << GPIO_LCKR_LCK0_Pos)
#define GPIO_LCKR_LCK0   GPIO_LCKR_LCK0_Msk
#define GPIO_LCKR_LCK1_Pos   (1U)
#define GPIO_LCKR_LCK1_Msk   (0x1UL << GPIO_LCKR_LCK1_Pos)
#define GPIO_LCKR_LCK1   GPIO_LCKR_LCK1_Msk
#define GPIO_LCKR_LCK2_Pos   (2U)
#define GPIO_LCKR_LCK2_Msk   (0x1UL << GPIO_LCKR_LCK2_Pos)
#define GPIO_LCKR_LCK2   GPIO_LCKR_LCK2_Msk
#define GPIO_LCKR_LCK3_Pos   (3U)
#define GPIO_LCKR_LCK3_Msk   (0x1UL << GPIO_LCKR_LCK3_Pos)
#define GPIO_LCKR_LCK3   GPIO_LCKR_LCK3_Msk
#define GPIO_LCKR_LCK4_Pos   (4U)
#define GPIO_LCKR_LCK4_Msk   (0x1UL << GPIO_LCKR_LCK4_Pos)
#define GPIO_LCKR_LCK4   GPIO_LCKR_LCK4_Msk
#define GPIO_LCKR_LCK5_Pos   (5U)
#define GPIO_LCKR_LCK5_Msk   (0x1UL << GPIO_LCKR_LCK5_Pos)
#define GPIO_LCKR_LCK5   GPIO_LCKR_LCK5_Msk
#define GPIO_LCKR_LCK6_Pos   (6U)
#define GPIO_LCKR_LCK6_Msk   (0x1UL << GPIO_LCKR_LCK6_Pos)
#define GPIO_LCKR_LCK6   GPIO_LCKR_LCK6_Msk
#define GPIO_LCKR_LCK7_Pos   (7U)
#define GPIO_LCKR_LCK7_Msk   (0x1UL << GPIO_LCKR_LCK7_Pos)
#define GPIO_LCKR_LCK7   GPIO_LCKR_LCK7_Msk
#define GPIO_LCKR_LCK8_Pos   (8U)
#define GPIO_LCKR_LCK8_Msk   (0x1UL << GPIO_LCKR_LCK8_Pos)
#define GPIO_LCKR_LCK8   GPIO_LCKR_LCK8_Msk
#define GPIO_LCKR_LCK9_Pos   (9U)
#define GPIO_LCKR_LCK9_Msk   (0x1UL << GPIO_LCKR_LCK9_Pos)
#define GPIO_LCKR_LCK9   GPIO_LCKR_LCK9_Msk
#define GPIO_LCKR_LCK10_Pos   (10U)
#define GPIO_LCKR_LCK10_Msk   (0x1UL << GPIO_LCKR_LCK10_Pos)
#define GPIO_LCKR_LCK10   GPIO_LCKR_LCK10_Msk
#define GPIO_LCKR_LCK11_Pos   (11U)
#define GPIO_LCKR_LCK11_Msk   (0x1UL << GPIO_LCKR_LCK11_Pos)
#define GPIO_LCKR_LCK11   GPIO_LCKR_LCK11_Msk
#define GPIO_LCKR_LCK12_Pos   (12U)
#define GPIO_LCKR_LCK12_Msk   (0x1UL << GPIO_LCKR_LCK12_Pos)
#define GPIO_LCKR_LCK12   GPIO_LCKR_LCK12_Msk
#define GPIO_LCKR_LCK13_Pos   (13U)
#define GPIO_LCKR_LCK13_Msk   (0x1UL << GPIO_LCKR_LCK13_Pos)
#define GPIO_LCKR_LCK13   GPIO_LCKR_LCK13_Msk
#define GPIO_LCKR_LCK14_Pos   (14U)
#define GPIO_LCKR_LCK14_Msk   (0x1UL << GPIO_LCKR_LCK14_Pos)
#define GPIO_LCKR_LCK14   GPIO_LCKR_LCK14_Msk
#define GPIO_LCKR_LCK15_Pos   (15U)
#define GPIO_LCKR_LCK15_Msk   (0x1UL << GPIO_LCKR_LCK15_Pos)
#define GPIO_LCKR_LCK15   GPIO_LCKR_LCK15_Msk
#define GPIO_LCKR_LCKK_Pos   (16U)
#define GPIO_LCKR_LCKK_Msk   (0x1UL << GPIO_LCKR_LCKK_Pos)
#define GPIO_LCKR_LCKK   GPIO_LCKR_LCKK_Msk
#define GPIO_AFRL_AFSEL0_Pos   (0U)
#define GPIO_AFRL_AFSEL0_Msk   (0xFUL << GPIO_AFRL_AFSEL0_Pos)
#define GPIO_AFRL_AFSEL0   GPIO_AFRL_AFSEL0_Msk
#define GPIO_AFRL_AFSEL0_0   (0x1UL << GPIO_AFRL_AFSEL0_Pos)
#define GPIO_AFRL_AFSEL0_1   (0x2UL << GPIO_AFRL_AFSEL0_Pos)
#define GPIO_AFRL_AFSEL0_2   (0x4UL << GPIO_AFRL_AFSEL0_Pos)
#define GPIO_AFRL_AFSEL0_3   (0x8UL << GPIO_AFRL_AFSEL0_Pos)
#define GPIO_AFRL_AFSEL1_Pos   (4U)
#define GPIO_AFRL_AFSEL1_Msk   (0xFUL << GPIO_AFRL_AFSEL1_Pos)
#define GPIO_AFRL_AFSEL1   GPIO_AFRL_AFSEL1_Msk
#define GPIO_AFRL_AFSEL1_0   (0x1UL << GPIO_AFRL_AFSEL1_Pos)
#define GPIO_AFRL_AFSEL1_1   (0x2UL << GPIO_AFRL_AFSEL1_Pos)
#define GPIO_AFRL_AFSEL1_2   (0x4UL << GPIO_AFRL_AFSEL1_Pos)
#define GPIO_AFRL_AFSEL1_3   (0x8UL << GPIO_AFRL_AFSEL1_Pos)
#define GPIO_AFRL_AFSEL2_Pos   (8U)
#define GPIO_AFRL_AFSEL2_Msk   (0xFUL << GPIO_AFRL_AFSEL2_Pos)
#define GPIO_AFRL_AFSEL2   GPIO_AFRL_AFSEL2_Msk
#define GPIO_AFRL_AFSEL2_0   (0x1UL << GPIO_AFRL_AFSEL2_Pos)
#define GPIO_AFRL_AFSEL2_1   (0x2UL << GPIO_AFRL_AFSEL2_Pos)
#define GPIO_AFRL_AFSEL2_2   (0x4UL << GPIO_AFRL_AFSEL2_Pos)
#define GPIO_AFRL_AFSEL2_3   (0x8UL << GPIO_AFRL_AFSEL2_Pos)
#define GPIO_AFRL_AFSEL3_Pos   (12U)
#define GPIO_AFRL_AFSEL3_Msk   (0xFUL << GPIO_AFRL_AFSEL3_Pos)
#define GPIO_AFRL_AFSEL3   GPIO_AFRL_AFSEL3_Msk
#define GPIO_AFRL_AFSEL3_0   (0x1UL << GPIO_AFRL_AFSEL3_Pos)
#define GPIO_AFRL_AFSEL3_1   (0x2UL << GPIO_AFRL_AFSEL3_Pos)
#define GPIO_AFRL_AFSEL3_2   (0x4UL << GPIO_AFRL_AFSEL3_Pos)
#define GPIO_AFRL_AFSEL3_3   (0x8UL << GPIO_AFRL_AFSEL3_Pos)
#define GPIO_AFRL_AFSEL4_Pos   (16U)
#define GPIO_AFRL_AFSEL4_Msk   (0xFUL << GPIO_AFRL_AFSEL4_Pos)
#define GPIO_AFRL_AFSEL4   GPIO_AFRL_AFSEL4_Msk
#define GPIO_AFRL_AFSEL4_0   (0x1UL << GPIO_AFRL_AFSEL4_Pos)
#define GPIO_AFRL_AFSEL4_1   (0x2UL << GPIO_AFRL_AFSEL4_Pos)
#define GPIO_AFRL_AFSEL4_2   (0x4UL << GPIO_AFRL_AFSEL4_Pos)
#define GPIO_AFRL_AFSEL4_3   (0x8UL << GPIO_AFRL_AFSEL4_Pos)
#define GPIO_AFRL_AFSEL5_Pos   (20U)
#define GPIO_AFRL_AFSEL5_Msk   (0xFUL << GPIO_AFRL_AFSEL5_Pos)
#define GPIO_AFRL_AFSEL5   GPIO_AFRL_AFSEL5_Msk
#define GPIO_AFRL_AFSEL5_0   (0x1UL << GPIO_AFRL_AFSEL5_Pos)
#define GPIO_AFRL_AFSEL5_1   (0x2UL << GPIO_AFRL_AFSEL5_Pos)
#define GPIO_AFRL_AFSEL5_2   (0x4UL << GPIO_AFRL_AFSEL5_Pos)
#define GPIO_AFRL_AFSEL5_3   (0x8UL << GPIO_AFRL_AFSEL5_Pos)
#define GPIO_AFRL_AFSEL6_Pos   (24U)
#define GPIO_AFRL_AFSEL6_Msk   (0xFUL << GPIO_AFRL_AFSEL6_Pos)
#define GPIO_AFRL_AFSEL6   GPIO_AFRL_AFSEL6_Msk
#define GPIO_AFRL_AFSEL6_0   (0x1UL << GPIO_AFRL_AFSEL6_Pos)
#define GPIO_AFRL_AFSEL6_1   (0x2UL << GPIO_AFRL_AFSEL6_Pos)
#define GPIO_AFRL_AFSEL6_2   (0x4UL << GPIO_AFRL_AFSEL6_Pos)
#define GPIO_AFRL_AFSEL6_3   (0x8UL << GPIO_AFRL_AFSEL6_Pos)
#define GPIO_AFRL_AFSEL7_Pos   (28U)
#define GPIO_AFRL_AFSEL7_Msk   (0xFUL << GPIO_AFRL_AFSEL7_Pos)
#define GPIO_AFRL_AFSEL7   GPIO_AFRL_AFSEL7_Msk
#define GPIO_AFRL_AFSEL7_0   (0x1UL << GPIO_AFRL_AFSEL7_Pos)
#define GPIO_AFRL_AFSEL7_1   (0x2UL << GPIO_AFRL_AFSEL7_Pos)
#define GPIO_AFRL_AFSEL7_2   (0x4UL << GPIO_AFRL_AFSEL7_Pos)
#define GPIO_AFRL_AFSEL7_3   (0x8UL << GPIO_AFRL_AFSEL7_Pos)
#define GPIO_AFRH_AFSEL8_Pos   (0U)
#define GPIO_AFRH_AFSEL8_Msk   (0xFUL << GPIO_AFRH_AFSEL8_Pos)
#define GPIO_AFRH_AFSEL8   GPIO_AFRH_AFSEL8_Msk
#define GPIO_AFRH_AFSEL8_0   (0x1UL << GPIO_AFRH_AFSEL8_Pos)
#define GPIO_AFRH_AFSEL8_1   (0x2UL << GPIO_AFRH_AFSEL8_Pos)
#define GPIO_AFRH_AFSEL8_2   (0x4UL << GPIO_AFRH_AFSEL8_Pos)
#define GPIO_AFRH_AFSEL8_3   (0x8UL << GPIO_AFRH_AFSEL8_Pos)
#define GPIO_AFRH_AFSEL9_Pos   (4U)
#define GPIO_AFRH_AFSEL9_Msk   (0xFUL << GPIO_AFRH_AFSEL9_Pos)
#define GPIO_AFRH_AFSEL9   GPIO_AFRH_AFSEL9_Msk
#define GPIO_AFRH_AFSEL9_0   (0x1UL << GPIO_AFRH_AFSEL9_Pos)
#define GPIO_AFRH_AFSEL9_1   (0x2UL << GPIO_AFRH_AFSEL9_Pos)
#define GPIO_AFRH_AFSEL9_2   (0x4UL << GPIO_AFRH_AFSEL9_Pos)
#define GPIO_AFRH_AFSEL9_3   (0x8UL << GPIO_AFRH_AFSEL9_Pos)
#define GPIO_AFRH_AFSEL10_Pos   (8U)
#define GPIO_AFRH_AFSEL10_Msk   (0xFUL << GPIO_AFRH_AFSEL10_Pos)
#define GPIO_AFRH_AFSEL10   GPIO_AFRH_AFSEL10_Msk
#define GPIO_AFRH_AFSEL10_0   (0x1UL << GPIO_AFRH_AFSEL10_Pos)
#define GPIO_AFRH_AFSEL10_1   (0x2UL << GPIO_AFRH_AFSEL10_Pos)
#define GPIO_AFRH_AFSEL10_2   (0x4UL << GPIO_AFRH_AFSEL10_Pos)
#define GPIO_AFRH_AFSEL10_3   (0x8UL << GPIO_AFRH_AFSEL10_Pos)
#define GPIO_AFRH_AFSEL11_Pos   (12U)
#define GPIO_AFRH_AFSEL11_Msk   (0xFUL << GPIO_AFRH_AFSEL11_Pos)
#define GPIO_AFRH_AFSEL11   GPIO_AFRH_AFSEL11_Msk
#define GPIO_AFRH_AFSEL11_0   (0x1UL << GPIO_AFRH_AFSEL11_Pos)
#define GPIO_AFRH_AFSEL11_1   (0x2UL << GPIO_AFRH_AFSEL11_Pos)
#define GPIO_AFRH_AFSEL11_2   (0x4UL << GPIO_AFRH_AFSEL11_Pos)
#define GPIO_AFRH_AFSEL11_3   (0x8UL << GPIO_AFRH_AFSEL11_Pos)
#define GPIO_AFRH_AFSEL12_Pos   (16U)
#define GPIO_AFRH_AFSEL12_Msk   (0xFUL << GPIO_AFRH_AFSEL12_Pos)
#define GPIO_AFRH_AFSEL12   GPIO_AFRH_AFSEL12_Msk
#define GPIO_AFRH_AFSEL12_0   (0x1UL << GPIO_AFRH_AFSEL12_Pos)
#define GPIO_AFRH_AFSEL12_1   (0x2UL << GPIO_AFRH_AFSEL12_Pos)
#define GPIO_AFRH_AFSEL12_2   (0x4UL << GPIO_AFRH_AFSEL12_Pos)
#define GPIO_AFRH_AFSEL12_3   (0x8UL << GPIO_AFRH_AFSEL12_Pos)
#define GPIO_AFRH_AFSEL13_Pos   (20U)
#define GPIO_AFRH_AFSEL13_Msk   (0xFUL << GPIO_AFRH_AFSEL13_Pos)
#define GPIO_AFRH_AFSEL13   GPIO_AFRH_AFSEL13_Msk
#define GPIO_AFRH_AFSEL13_0   (0x1UL << GPIO_AFRH_AFSEL13_Pos)
#define GPIO_AFRH_AFSEL13_1   (0x2UL << GPIO_AFRH_AFSEL13_Pos)
#define GPIO_AFRH_AFSEL13_2   (0x4UL << GPIO_AFRH_AFSEL13_Pos)
#define GPIO_AFRH_AFSEL13_3   (0x8UL << GPIO_AFRH_AFSEL13_Pos)
#define GPIO_AFRH_AFSEL14_Pos   (24U)
#define GPIO_AFRH_AFSEL14_Msk   (0xFUL << GPIO_AFRH_AFSEL14_Pos)
#define GPIO_AFRH_AFSEL14   GPIO_AFRH_AFSEL14_Msk
#define GPIO_AFRH_AFSEL14_0   (0x1UL << GPIO_AFRH_AFSEL14_Pos)
#define GPIO_AFRH_AFSEL14_1   (0x2UL << GPIO_AFRH_AFSEL14_Pos)
#define GPIO_AFRH_AFSEL14_2   (0x4UL << GPIO_AFRH_AFSEL14_Pos)
#define GPIO_AFRH_AFSEL14_3   (0x8UL << GPIO_AFRH_AFSEL14_Pos)
#define GPIO_AFRH_AFSEL15_Pos   (28U)
#define GPIO_AFRH_AFSEL15_Msk   (0xFUL << GPIO_AFRH_AFSEL15_Pos)
#define GPIO_AFRH_AFSEL15   GPIO_AFRH_AFSEL15_Msk
#define GPIO_AFRH_AFSEL15_0   (0x1UL << GPIO_AFRH_AFSEL15_Pos)
#define GPIO_AFRH_AFSEL15_1   (0x2UL << GPIO_AFRH_AFSEL15_Pos)
#define GPIO_AFRH_AFSEL15_2   (0x4UL << GPIO_AFRH_AFSEL15_Pos)
#define GPIO_AFRH_AFSEL15_3   (0x8UL << GPIO_AFRH_AFSEL15_Pos)
#define GPIO_BRR_BR0_Pos   (0U)
#define GPIO_BRR_BR0_Msk   (0x1UL << GPIO_BRR_BR0_Pos)
#define GPIO_BRR_BR0   GPIO_BRR_BR0_Msk
#define GPIO_BRR_BR1_Pos   (1U)
#define GPIO_BRR_BR1_Msk   (0x1UL << GPIO_BRR_BR1_Pos)
#define GPIO_BRR_BR1   GPIO_BRR_BR1_Msk
#define GPIO_BRR_BR2_Pos   (2U)
#define GPIO_BRR_BR2_Msk   (0x1UL << GPIO_BRR_BR2_Pos)
#define GPIO_BRR_BR2   GPIO_BRR_BR2_Msk
#define GPIO_BRR_BR3_Pos   (3U)
#define GPIO_BRR_BR3_Msk   (0x1UL << GPIO_BRR_BR3_Pos)
#define GPIO_BRR_BR3   GPIO_BRR_BR3_Msk
#define GPIO_BRR_BR4_Pos   (4U)
#define GPIO_BRR_BR4_Msk   (0x1UL << GPIO_BRR_BR4_Pos)
#define GPIO_BRR_BR4   GPIO_BRR_BR4_Msk
#define GPIO_BRR_BR5_Pos   (5U)
#define GPIO_BRR_BR5_Msk   (0x1UL << GPIO_BRR_BR5_Pos)
#define GPIO_BRR_BR5   GPIO_BRR_BR5_Msk
#define GPIO_BRR_BR6_Pos   (6U)
#define GPIO_BRR_BR6_Msk   (0x1UL << GPIO_BRR_BR6_Pos)
#define GPIO_BRR_BR6   GPIO_BRR_BR6_Msk
#define GPIO_BRR_BR7_Pos   (7U)
#define GPIO_BRR_BR7_Msk   (0x1UL << GPIO_BRR_BR7_Pos)
#define GPIO_BRR_BR7   GPIO_BRR_BR7_Msk
#define GPIO_BRR_BR8_Pos   (8U)
#define GPIO_BRR_BR8_Msk   (0x1UL << GPIO_BRR_BR8_Pos)
#define GPIO_BRR_BR8   GPIO_BRR_BR8_Msk
#define GPIO_BRR_BR9_Pos   (9U)
#define GPIO_BRR_BR9_Msk   (0x1UL << GPIO_BRR_BR9_Pos)
#define GPIO_BRR_BR9   GPIO_BRR_BR9_Msk
#define GPIO_BRR_BR10_Pos   (10U)
#define GPIO_BRR_BR10_Msk   (0x1UL << GPIO_BRR_BR10_Pos)
#define GPIO_BRR_BR10   GPIO_BRR_BR10_Msk
#define GPIO_BRR_BR11_Pos   (11U)
#define GPIO_BRR_BR11_Msk   (0x1UL << GPIO_BRR_BR11_Pos)
#define GPIO_BRR_BR11   GPIO_BRR_BR11_Msk
#define GPIO_BRR_BR12_Pos   (12U)
#define GPIO_BRR_BR12_Msk   (0x1UL << GPIO_BRR_BR12_Pos)
#define GPIO_BRR_BR12   GPIO_BRR_BR12_Msk
#define GPIO_BRR_BR13_Pos   (13U)
#define GPIO_BRR_BR13_Msk   (0x1UL << GPIO_BRR_BR13_Pos)
#define GPIO_BRR_BR13   GPIO_BRR_BR13_Msk
#define GPIO_BRR_BR14_Pos   (14U)
#define GPIO_BRR_BR14_Msk   (0x1UL << GPIO_BRR_BR14_Pos)
#define GPIO_BRR_BR14   GPIO_BRR_BR14_Msk
#define GPIO_BRR_BR15_Pos   (15U)
#define GPIO_BRR_BR15_Msk   (0x1UL << GPIO_BRR_BR15_Pos)
#define GPIO_BRR_BR15   GPIO_BRR_BR15_Msk
#define GPIO_HSLVR_HSLV0_Pos   (0U)
#define GPIO_HSLVR_HSLV0_Msk   (0x1UL << GPIO_HSLVR_HSLV0_Pos)
#define GPIO_HSLVR_HSLV0   GPIO_HSLVR_HSLV0_Msk
#define GPIO_HSLVR_HSLV1_Pos   (1U)
#define GPIO_HSLVR_HSLV1_Msk   (0x1UL << GPIO_HSLVR_HSLV1_Pos)
#define GPIO_HSLVR_HSLV1   GPIO_HSLVR_HSLV1_Msk
#define GPIO_HSLVR_HSLV2_Pos   (2U)
#define GPIO_HSLVR_HSLV2_Msk   (0x1UL << GPIO_HSLVR_HSLV2_Pos)
#define GPIO_HSLVR_HSLV2   GPIO_HSLVR_HSLV2_Msk
#define GPIO_HSLVR_HSLV3_Pos   (3U)
#define GPIO_HSLVR_HSLV3_Msk   (0x1UL << GPIO_HSLVR_HSLV3_Pos)
#define GPIO_HSLVR_HSLV3   GPIO_HSLVR_HSLV3_Msk
#define GPIO_HSLVR_HSLV4_Pos   (4U)
#define GPIO_HSLVR_HSLV4_Msk   (0x1UL << GPIO_HSLVR_HSLV4_Pos)
#define GPIO_HSLVR_HSLV4   GPIO_HSLVR_HSLV4_Msk
#define GPIO_HSLVR_HSLV5_Pos   (5U)
#define GPIO_HSLVR_HSLV5_Msk   (0x1UL << GPIO_HSLVR_HSLV5_Pos)
#define GPIO_HSLVR_HSLV5   GPIO_HSLVR_HSLV5_Msk
#define GPIO_HSLVR_HSLV6_Pos   (6U)
#define GPIO_HSLVR_HSLV6_Msk   (0x1UL << GPIO_HSLVR_HSLV6_Pos)
#define GPIO_HSLVR_HSLV6   GPIO_HSLVR_HSLV6_Msk
#define GPIO_HSLVR_HSLV7_Pos   (7U)
#define GPIO_HSLVR_HSLV7_Msk   (0x1UL << GPIO_HSLVR_HSLV7_Pos)
#define GPIO_HSLVR_HSLV7   GPIO_HSLVR_HSLV7_Msk
#define GPIO_HSLVR_HSLV8_Pos   (8U)
#define GPIO_HSLVR_HSLV8_Msk   (0x1UL << GPIO_HSLVR_HSLV8_Pos)
#define GPIO_HSLVR_HSLV8   GPIO_HSLVR_HSLV8_Msk
#define GPIO_HSLVR_HSLV9_Pos   (9U)
#define GPIO_HSLVR_HSLV9_Msk   (0x1UL << GPIO_HSLVR_HSLV9_Pos)
#define GPIO_HSLVR_HSLV9   GPIO_HSLVR_HSLV9_Msk
#define GPIO_HSLVR_HSLV10_Pos   (10U)
#define GPIO_HSLVR_HSLV10_Msk   (0x1UL << GPIO_HSLVR_HSLV10_Pos)
#define GPIO_HSLVR_HSLV10   GPIO_HSLVR_HSLV10_Msk
#define GPIO_HSLVR_HSLV11_Pos   (11U)
#define GPIO_HSLVR_HSLV11_Msk   (x1UL << GPIO_HSLVR_HSLV11_Pos)
#define GPIO_HSLVR_HSLV11   GPIO_HSLVR_HSLV11_Msk
#define GPIO_HSLVR_HSLV12_Pos   (12U)
#define GPIO_HSLVR_HSLV12_Msk   (0x1UL << GPIO_HSLVR_HSLV12_Pos)
#define GPIO_HSLVR_HSLV12   GPIO_HSLVR_HSLV12_Msk
#define GPIO_HSLVR_HSLV13_Pos   (13U)
#define GPIO_HSLVR_HSLV13_Msk   (0x1UL << GPIO_HSLVR_HSLV13_Pos)
#define GPIO_HSLVR_HSLV13   GPIO_HSLVR_HSLV13_Msk
#define GPIO_HSLVR_HSLV14_Pos   (14U)
#define GPIO_HSLVR_HSLV14_Msk   (0x1UL << GPIO_HSLVR_HSLV14_Pos)
#define GPIO_HSLVR_HSLV14   GPIO_HSLVR_HSLV14_Msk
#define GPIO_HSLVR_HSLV15_Pos   (15U)
#define GPIO_HSLVR_HSLV15_Msk   (0x1UL << GPIO_HSLVR_HSLV15_Pos)
#define GPIO_HSLVR_HSLV15   GPIO_HSLVR_HSLV15_Msk
#define GPIO_SECCFGR_SEC0_Pos   (0U)
#define GPIO_SECCFGR_SEC0_Msk   (0x1UL << GPIO_SECCFGR_SEC0_Pos)
#define GPIO_SECCFGR_SEC0   GPIO_SECCFGR_SEC0_Msk
#define GPIO_SECCFGR_SEC1_Pos   (1U)
#define GPIO_SECCFGR_SEC1_Msk   (0x1UL << GPIO_SECCFGR_SEC1_Pos)
#define GPIO_SECCFGR_SEC1   GPIO_SECCFGR_SEC1_Msk
#define GPIO_SECCFGR_SEC2_Pos   (2U)
#define GPIO_SECCFGR_SEC2_Msk   (0x1UL << GPIO_SECCFGR_SEC2_Pos)
#define GPIO_SECCFGR_SEC2   GPIO_SECCFGR_SEC2_Msk
#define GPIO_SECCFGR_SEC3_Pos   (3U)
#define GPIO_SECCFGR_SEC3_Msk   (0x1UL << GPIO_SECCFGR_SEC3_Pos)
#define GPIO_SECCFGR_SEC3   GPIO_SECCFGR_SEC3_Msk
#define GPIO_SECCFGR_SEC4_Pos   (4U)
#define GPIO_SECCFGR_SEC4_Msk   (0x1UL << GPIO_SECCFGR_SEC4_Pos)
#define GPIO_SECCFGR_SEC4   GPIO_SECCFGR_SEC4_Msk
#define GPIO_SECCFGR_SEC5_Pos   (5U)
#define GPIO_SECCFGR_SEC5_Msk   (0x1UL << GPIO_SECCFGR_SEC5_Pos)
#define GPIO_SECCFGR_SEC5   GPIO_SECCFGR_SEC5_Msk
#define GPIO_SECCFGR_SEC6_Pos   (6U)
#define GPIO_SECCFGR_SEC6_Msk   (0x1UL << GPIO_SECCFGR_SEC6_Pos)
#define GPIO_SECCFGR_SEC6   GPIO_SECCFGR_SEC6_Msk
#define GPIO_SECCFGR_SEC7_Pos   (7U)
#define GPIO_SECCFGR_SEC7_Msk   (0x1UL << GPIO_SECCFGR_SEC7_Pos)
#define GPIO_SECCFGR_SEC7   GPIO_SECCFGR_SEC7_Msk
#define GPIO_SECCFGR_SEC8_Pos   (8U)
#define GPIO_SECCFGR_SEC8_Msk   (0x1UL << GPIO_SECCFGR_SEC8_Pos)
#define GPIO_SECCFGR_SEC8   GPIO_SECCFGR_SEC8_Msk
#define GPIO_SECCFGR_SEC9_Pos   (9U)
#define GPIO_SECCFGR_SEC9_Msk   (0x1UL << GPIO_SECCFGR_SEC9_Pos)
#define GPIO_SECCFGR_SEC9   GPIO_SECCFGR_SEC9_Msk
#define GPIO_SECCFGR_SEC10_Pos   (10U)
#define GPIO_SECCFGR_SEC10_Msk   (0x1UL << GPIO_SECCFGR_SEC10_Pos)
#define GPIO_SECCFGR_SEC10   GPIO_SECCFGR_SEC10_Msk
#define GPIO_SECCFGR_SEC11_Pos   (11U)
#define GPIO_SECCFGR_SEC11_Msk   (x1UL << GPIO_SECCFGR_SEC11_Pos)
#define GPIO_SECCFGR_SEC11   GPIO_SECCFGR_SEC11_Msk
#define GPIO_SECCFGR_SEC12_Pos   (12U)
#define GPIO_SECCFGR_SEC12_Msk   (0x1UL << GPIO_SECCFGR_SEC12_Pos)
#define GPIO_SECCFGR_SEC12   GPIO_SECCFGR_SEC12_Msk
#define GPIO_SECCFGR_SEC13_Pos   (13U)
#define GPIO_SECCFGR_SEC13_Msk   (0x1UL << GPIO_SECCFGR_SEC13_Pos)
#define GPIO_SECCFGR_SEC13   GPIO_SECCFGR_SEC13_Msk
#define GPIO_SECCFGR_SEC14_Pos   (14U)
#define GPIO_SECCFGR_SEC14_Msk   (0x1UL << GPIO_SECCFGR_SEC14_Pos)
#define GPIO_SECCFGR_SEC14   GPIO_SECCFGR_SEC14_Msk
#define GPIO_SECCFGR_SEC15_Pos   (15U)
#define GPIO_SECCFGR_SEC15_Msk   (0x1UL << GPIO_SECCFGR_SEC15_Pos)
#define GPIO_SECCFGR_SEC15   GPIO_SECCFGR_SEC15_Msk
#define JPEG_CONFR0_START_Pos   (0U)
#define JPEG_CONFR0_START_Msk   (0x1UL << JPEG_CONFR0_START_Pos)
#define JPEG_CONFR0_START   JPEG_CONFR0_START_Msk
#define JPEG_CONFR1_NF_Pos   (0U)
#define JPEG_CONFR1_NF_Msk   (0x3UL << JPEG_CONFR1_NF_Pos)
#define JPEG_CONFR1_NF   JPEG_CONFR1_NF_Msk
#define JPEG_CONFR1_NF_0   (0x1UL << JPEG_CONFR1_NF_Pos)
#define JPEG_CONFR1_NF_1   (0x2UL << JPEG_CONFR1_NF_Pos)
#define JPEG_CONFR1_DE_Pos   (3U)
#define JPEG_CONFR1_DE_Msk   (0x1UL << JPEG_CONFR1_DE_Pos)
#define JPEG_CONFR1_DE   JPEG_CONFR1_DE_Msk
#define JPEG_CONFR1_COLORSPACE_Pos   (4U)
#define JPEG_CONFR1_COLORSPACE_Msk   (0x3UL << JPEG_CONFR1_COLORSPACE_Pos)
#define JPEG_CONFR1_COLORSPACE   JPEG_CONFR1_COLORSPACE_Msk
#define JPEG_CONFR1_COLORSPACE_0   (0x1UL << JPEG_CONFR1_COLORSPACE_Pos)
#define JPEG_CONFR1_COLORSPACE_1   (0x2UL << JPEG_CONFR1_COLORSPACE_Pos)
#define JPEG_CONFR1_NS_Pos   (6U)
#define JPEG_CONFR1_NS_Msk   (0x3UL << JPEG_CONFR1_NS_Pos)
#define JPEG_CONFR1_NS   JPEG_CONFR1_NS_Msk
#define JPEG_CONFR1_NS_0   (0x1UL << JPEG_CONFR1_NS_Pos)
#define JPEG_CONFR1_NS_1   (0x2UL << JPEG_CONFR1_NS_Pos)
#define JPEG_CONFR1_HDR_Pos   (8U)
#define JPEG_CONFR1_HDR_Msk   (0x1UL << JPEG_CONFR1_HDR_Pos)
#define JPEG_CONFR1_HDR   JPEG_CONFR1_HDR_Msk
#define JPEG_CONFR1_YSIZE_Pos   (16U)
#define JPEG_CONFR1_YSIZE_Msk   (0xFFFFUL << JPEG_CONFR1_YSIZE_Pos)
#define JPEG_CONFR1_YSIZE   JPEG_CONFR1_YSIZE_Msk
#define JPEG_CONFR2_NMCU_Pos   (0U)
#define JPEG_CONFR2_NMCU_Msk   (0x3FFFFFFUL << JPEG_CONFR2_NMCU_Pos)
#define JPEG_CONFR2_NMCU   JPEG_CONFR2_NMCU_Msk
#define JPEG_CONFR3_XSIZE_Pos   (16U)
#define JPEG_CONFR3_XSIZE_Msk   (0xFFFFUL << JPEG_CONFR3_XSIZE_Pos)
#define JPEG_CONFR3_XSIZE   JPEG_CONFR3_XSIZE_Msk
#define JPEG_CONFR4_HD_Pos   (0U)
#define JPEG_CONFR4_HD_Msk   (0x1UL << JPEG_CONFR4_HD_Pos)
#define JPEG_CONFR4_HD   JPEG_CONFR4_HD_Msk
#define JPEG_CONFR4_HA_Pos   (1U)
#define JPEG_CONFR4_HA_Msk   (0x1UL << JPEG_CONFR4_HA_Pos)
#define JPEG_CONFR4_HA   JPEG_CONFR4_HA_Msk
#define JPEG_CONFR4_QT_Pos   (2U)
#define JPEG_CONFR4_QT_Msk   (0x3UL << JPEG_CONFR4_QT_Pos)
#define JPEG_CONFR4_QT   JPEG_CONFR4_QT_Msk
#define JPEG_CONFR4_QT_0   (0x1UL << JPEG_CONFR4_QT_Pos)
#define JPEG_CONFR4_QT_1   (0x2UL << JPEG_CONFR4_QT_Pos)
#define JPEG_CONFR4_NB_Pos   (4U)
#define JPEG_CONFR4_NB_Msk   (0xFUL << JPEG_CONFR4_NB_Pos)
#define JPEG_CONFR4_NB   JPEG_CONFR4_NB_Msk
#define JPEG_CONFR4_NB_0   (0x1UL << JPEG_CONFR4_NB_Pos)
#define JPEG_CONFR4_NB_1   (0x2UL << JPEG_CONFR4_NB_Pos)
#define JPEG_CONFR4_NB_2   (0x4UL << JPEG_CONFR4_NB_Pos)
#define JPEG_CONFR4_NB_3   (0x8UL << JPEG_CONFR4_NB_Pos)
#define JPEG_CONFR4_VSF_Pos   (8U)
#define JPEG_CONFR4_VSF_Msk   (0xFUL << JPEG_CONFR4_VSF_Pos)
#define JPEG_CONFR4_VSF   JPEG_CONFR4_VSF_Msk
#define JPEG_CONFR4_VSF_0   (0x1UL << JPEG_CONFR4_VSF_Pos)
#define JPEG_CONFR4_VSF_1   (0x2UL << JPEG_CONFR4_VSF_Pos)
#define JPEG_CONFR4_VSF_2   (0x4UL << JPEG_CONFR4_VSF_Pos)
#define JPEG_CONFR4_VSF_3   (0x8UL << JPEG_CONFR4_VSF_Pos)
#define JPEG_CONFR4_HSF_Pos   (12U)
#define JPEG_CONFR4_HSF_Msk   (0xFUL << JPEG_CONFR4_HSF_Pos)
#define JPEG_CONFR4_HSF   JPEG_CONFR4_HSF_Msk
#define JPEG_CONFR4_HSF_0   (0x1UL << JPEG_CONFR4_HSF_Pos)
#define JPEG_CONFR4_HSF_1   (0x2UL << JPEG_CONFR4_HSF_Pos)
#define JPEG_CONFR4_HSF_2   (0x4UL << JPEG_CONFR4_HSF_Pos)
#define JPEG_CONFR4_HSF_3   (0x8UL << JPEG_CONFR4_HSF_Pos)
#define JPEG_CONFR5_HD_Pos   (0U)
#define JPEG_CONFR5_HD_Msk   (0x1UL << JPEG_CONFR5_HD_Pos)
#define JPEG_CONFR5_HD   JPEG_CONFR5_HD_Msk
#define JPEG_CONFR5_HA_Pos   (1U)
#define JPEG_CONFR5_HA_Msk   (0x1UL << JPEG_CONFR5_HA_Pos)
#define JPEG_CONFR5_HA   JPEG_CONFR5_HA_Msk
#define JPEG_CONFR5_QT_Pos   (2U)
#define JPEG_CONFR5_QT_Msk   (0x3UL << JPEG_CONFR5_QT_Pos)
#define JPEG_CONFR5_QT   JPEG_CONFR5_QT_Msk
#define JPEG_CONFR5_QT_0   (0x1UL << JPEG_CONFR5_QT_Pos)
#define JPEG_CONFR5_QT_1   (0x2UL << JPEG_CONFR5_QT_Pos)
#define JPEG_CONFR5_NB_Pos   (4U)
#define JPEG_CONFR5_NB_Msk   (0xFUL << JPEG_CONFR5_NB_Pos)
#define JPEG_CONFR5_NB   JPEG_CONFR5_NB_Msk
#define JPEG_CONFR5_NB_0   (0x1UL << JPEG_CONFR5_NB_Pos)
#define JPEG_CONFR5_NB_1   (0x2UL << JPEG_CONFR5_NB_Pos)
#define JPEG_CONFR5_NB_2   (0x4UL << JPEG_CONFR5_NB_Pos)
#define JPEG_CONFR5_NB_3   (0x8UL << JPEG_CONFR5_NB_Pos)
#define JPEG_CONFR5_VSF_Pos   (8U)
#define JPEG_CONFR5_VSF_Msk   (0xFUL << JPEG_CONFR5_VSF_Pos)
#define JPEG_CONFR5_VSF   JPEG_CONFR5_VSF_Msk
#define JPEG_CONFR5_VSF_0   (0x1UL << JPEG_CONFR5_VSF_Pos)
#define JPEG_CONFR5_VSF_1   (0x2UL << JPEG_CONFR5_VSF_Pos)
#define JPEG_CONFR5_VSF_2   (0x4UL << JPEG_CONFR5_VSF_Pos)
#define JPEG_CONFR5_VSF_3   (0x8UL << JPEG_CONFR5_VSF_Pos)
#define JPEG_CONFR5_HSF_Pos   (12U)
#define JPEG_CONFR5_HSF_Msk   (0xFUL << JPEG_CONFR5_HSF_Pos)
#define JPEG_CONFR5_HSF   JPEG_CONFR5_HSF_Msk
#define JPEG_CONFR5_HSF_0   (0x1UL << JPEG_CONFR5_HSF_Pos)
#define JPEG_CONFR5_HSF_1   (0x2UL << JPEG_CONFR5_HSF_Pos)
#define JPEG_CONFR5_HSF_2   (0x4UL << JPEG_CONFR5_HSF_Pos)
#define JPEG_CONFR5_HSF_3   (0x8UL << JPEG_CONFR5_HSF_Pos)
#define JPEG_CONFR6_HD_Pos   (0U)
#define JPEG_CONFR6_HD_Msk   (0x1UL << JPEG_CONFR6_HD_Pos)
#define JPEG_CONFR6_HD   JPEG_CONFR6_HD_Msk
#define JPEG_CONFR6_HA_Pos   (1U)
#define JPEG_CONFR6_HA_Msk   (0x1UL << JPEG_CONFR6_HA_Pos)
#define JPEG_CONFR6_HA   JPEG_CONFR6_HA_Msk
#define JPEG_CONFR6_QT_Pos   (2U)
#define JPEG_CONFR6_QT_Msk   (0x3UL << JPEG_CONFR6_QT_Pos)
#define JPEG_CONFR6_QT   JPEG_CONFR6_QT_Msk
#define JPEG_CONFR6_QT_0   (0x1UL << JPEG_CONFR6_QT_Pos)
#define JPEG_CONFR6_QT_1   (0x2UL << JPEG_CONFR6_QT_Pos)
#define JPEG_CONFR6_NB_Pos   (4U)
#define JPEG_CONFR6_NB_Msk   (0xFUL << JPEG_CONFR6_NB_Pos)
#define JPEG_CONFR6_NB   JPEG_CONFR6_NB_Msk
#define JPEG_CONFR6_NB_0   (0x1UL << JPEG_CONFR6_NB_Pos)
#define JPEG_CONFR6_NB_1   (0x2UL << JPEG_CONFR6_NB_Pos)
#define JPEG_CONFR6_NB_2   (0x4UL << JPEG_CONFR6_NB_Pos)
#define JPEG_CONFR6_NB_3   (0x8UL << JPEG_CONFR6_NB_Pos)
#define JPEG_CONFR6_VSF_Pos   (8U)
#define JPEG_CONFR6_VSF_Msk   (0xFUL << JPEG_CONFR6_VSF_Pos)
#define JPEG_CONFR6_VSF   JPEG_CONFR6_VSF_Msk
#define JPEG_CONFR6_VSF_0   (0x1UL << JPEG_CONFR6_VSF_Pos)
#define JPEG_CONFR6_VSF_1   (0x2UL << JPEG_CONFR6_VSF_Pos)
#define JPEG_CONFR6_VSF_2   (0x4UL << JPEG_CONFR6_VSF_Pos)
#define JPEG_CONFR6_VSF_3   (0x8UL << JPEG_CONFR6_VSF_Pos)
#define JPEG_CONFR6_HSF_Pos   (12U)
#define JPEG_CONFR6_HSF_Msk   (0xFUL << JPEG_CONFR6_HSF_Pos)
#define JPEG_CONFR6_HSF   JPEG_CONFR6_HSF_Msk
#define JPEG_CONFR6_HSF_0   (0x1UL << JPEG_CONFR6_HSF_Pos)
#define JPEG_CONFR6_HSF_1   (0x2UL << JPEG_CONFR6_HSF_Pos)
#define JPEG_CONFR6_HSF_2   (0x4UL << JPEG_CONFR6_HSF_Pos)
#define JPEG_CONFR6_HSF_3   (0x8UL << JPEG_CONFR6_HSF_Pos)
#define JPEG_CONFR7_HD_Pos   (0U)
#define JPEG_CONFR7_HD_Msk   (0x1UL << JPEG_CONFR7_HD_Pos)
#define JPEG_CONFR7_HD   JPEG_CONFR7_HD_Msk
#define JPEG_CONFR7_HA_Pos   (1U)
#define JPEG_CONFR7_HA_Msk   (0x1UL << JPEG_CONFR7_HA_Pos)
#define JPEG_CONFR7_HA   JPEG_CONFR7_HA_Msk
#define JPEG_CONFR7_QT_Pos   (2U)
#define JPEG_CONFR7_QT_Msk   (0x3UL << JPEG_CONFR7_QT_Pos)
#define JPEG_CONFR7_QT   JPEG_CONFR7_QT_Msk
#define JPEG_CONFR7_QT_0   (0x1UL << JPEG_CONFR7_QT_Pos)
#define JPEG_CONFR7_QT_1   (0x2UL << JPEG_CONFR7_QT_Pos)
#define JPEG_CONFR7_NB_Pos   (4U)
#define JPEG_CONFR7_NB_Msk   (0xFUL << JPEG_CONFR7_NB_Pos)
#define JPEG_CONFR7_NB   JPEG_CONFR7_NB_Msk
#define JPEG_CONFR7_NB_0   (0x1UL << JPEG_CONFR7_NB_Pos)
#define JPEG_CONFR7_NB_1   (0x2UL << JPEG_CONFR7_NB_Pos)
#define JPEG_CONFR7_NB_2   (0x4UL << JPEG_CONFR7_NB_Pos)
#define JPEG_CONFR7_NB_3   (0x8UL << JPEG_CONFR7_NB_Pos)
#define JPEG_CONFR7_VSF_Pos   (8U)
#define JPEG_CONFR7_VSF_Msk   (0xFUL << JPEG_CONFR7_VSF_Pos)
#define JPEG_CONFR7_VSF   JPEG_CONFR7_VSF_Msk
#define JPEG_CONFR7_VSF_0   (0x1UL << JPEG_CONFR7_VSF_Pos)
#define JPEG_CONFR7_VSF_1   (0x2UL << JPEG_CONFR7_VSF_Pos)
#define JPEG_CONFR7_VSF_2   (0x4UL << JPEG_CONFR7_VSF_Pos)
#define JPEG_CONFR7_VSF_3   (0x8UL << JPEG_CONFR7_VSF_Pos)
#define JPEG_CONFR7_HSF_Pos   (12U)
#define JPEG_CONFR7_HSF_Msk   (0xFUL << JPEG_CONFR7_HSF_Pos)
#define JPEG_CONFR7_HSF   JPEG_CONFR7_HSF_Msk
#define JPEG_CONFR7_HSF_0   (0x1UL << JPEG_CONFR7_HSF_Pos)
#define JPEG_CONFR7_HSF_1   (0x2UL << JPEG_CONFR7_HSF_Pos)
#define JPEG_CONFR7_HSF_2   (0x4UL << JPEG_CONFR7_HSF_Pos)
#define JPEG_CONFR7_HSF_3   (0x8UL << JPEG_CONFR7_HSF_Pos)
#define JPEG_CR_JCEN_Pos   (0U)
#define JPEG_CR_JCEN_Msk   (0x1UL << JPEG_CR_JCEN_Pos)
#define JPEG_CR_JCEN   JPEG_CR_JCEN_Msk
#define JPEG_CR_IFTIE_Pos   (1U)
#define JPEG_CR_IFTIE_Msk   (0x1UL << JPEG_CR_IFTIE_Pos)
#define JPEG_CR_IFTIE   JPEG_CR_IFTIE_Msk
#define JPEG_CR_IFNFIE_Pos   (2U)
#define JPEG_CR_IFNFIE_Msk   (0x1UL << JPEG_CR_IFNFIE_Pos)
#define JPEG_CR_IFNFIE   JPEG_CR_IFNFIE_Msk
#define JPEG_CR_OFTIE_Pos   (3U)
#define JPEG_CR_OFTIE_Msk   (0x1UL << JPEG_CR_OFTIE_Pos)
#define JPEG_CR_OFTIE   JPEG_CR_OFTIE_Msk
#define JPEG_CR_OFNEIE_Pos   (4U)
#define JPEG_CR_OFNEIE_Msk   (0x1UL << JPEG_CR_OFNEIE_Pos)
#define JPEG_CR_OFNEIE   JPEG_CR_OFNEIE_Msk
#define JPEG_CR_EOCIE_Pos   (5U)
#define JPEG_CR_EOCIE_Msk   (0x1UL << JPEG_CR_EOCIE_Pos)
#define JPEG_CR_EOCIE   JPEG_CR_EOCIE_Msk
#define JPEG_CR_HPDIE_Pos   (6U)
#define JPEG_CR_HPDIE_Msk   (0x1UL << JPEG_CR_HPDIE_Pos)
#define JPEG_CR_HPDIE   JPEG_CR_HPDIE_Msk
#define JPEG_CR_IDMAEN_Pos   (11U)
#define JPEG_CR_IDMAEN_Msk   (0x1UL << JPEG_CR_IDMAEN_Pos)
#define JPEG_CR_IDMAEN   JPEG_CR_IDMAEN_Msk
#define JPEG_CR_ODMAEN_Pos   (12U)
#define JPEG_CR_ODMAEN_Msk   (0x1UL << JPEG_CR_ODMAEN_Pos)
#define JPEG_CR_ODMAEN   JPEG_CR_ODMAEN_Msk
#define JPEG_CR_IFF_Pos   (13U)
#define JPEG_CR_IFF_Msk   (0x1UL << JPEG_CR_IFF_Pos)
#define JPEG_CR_IFF   JPEG_CR_IFF_Msk
#define JPEG_CR_OFF_Pos   (14U)
#define JPEG_CR_OFF_Msk   (0x1UL << JPEG_CR_OFF_Pos)
#define JPEG_CR_OFF   JPEG_CR_OFF_Msk
#define JPEG_SR_IFTF_Pos   (1U)
#define JPEG_SR_IFTF_Msk   (0x1UL << JPEG_SR_IFTF_Pos)
#define JPEG_SR_IFTF   JPEG_SR_IFTF_Msk
#define JPEG_SR_IFNFF_Pos   (2U)
#define JPEG_SR_IFNFF_Msk   (0x1UL << JPEG_SR_IFNFF_Pos)
#define JPEG_SR_IFNFF   JPEG_SR_IFNFF_Msk
#define JPEG_SR_OFTF_Pos   (3U)
#define JPEG_SR_OFTF_Msk   (0x1UL << JPEG_SR_OFTF_Pos)
#define JPEG_SR_OFTF   JPEG_SR_OFTF_Msk
#define JPEG_SR_OFNEF_Pos   (4U)
#define JPEG_SR_OFNEF_Msk   (0x1UL << JPEG_SR_OFNEF_Pos)
#define JPEG_SR_OFNEF   JPEG_SR_OFNEF_Msk
#define JPEG_SR_EOCF_Pos   (5U)
#define JPEG_SR_EOCF_Msk   (0x1UL << JPEG_SR_EOCF_Pos)
#define JPEG_SR_EOCF   JPEG_SR_EOCF_Msk
#define JPEG_SR_HPDF_Pos   (6U)
#define JPEG_SR_HPDF_Msk   (0x1UL << JPEG_SR_HPDF_Pos)
#define JPEG_SR_HPDF   JPEG_SR_HPDF_Msk
#define JPEG_SR_COF_Pos   (7U)
#define JPEG_SR_COF_Msk   (0x1UL << JPEG_SR_COF_Pos)
#define JPEG_SR_COF   JPEG_SR_COF_Msk
#define JPEG_CFR_CEOCF_Pos   (4U)
#define JPEG_CFR_CEOCF_Msk   (0x1UL << JPEG_CFR_CEOCF_Pos)
#define JPEG_CFR_CEOCF   JPEG_CFR_CEOCF_Msk
#define JPEG_CFR_CHPDF_Pos   (5U)
#define JPEG_CFR_CHPDF_Msk   (0x1UL << JPEG_CFR_CHPDF_Pos)
#define JPEG_CFR_CHPDF   JPEG_CFR_CHPDF_Msk
#define JPEG_DIR_DATAIN_Pos   (0U)
#define JPEG_DIR_DATAIN_Msk   (0xFFFFFFFFUL << JPEG_DIR_DATAIN_Pos)
#define JPEG_DIR_DATAIN   JPEG_DIR_DATAIN_Msk
#define JPEG_DOR_DATAOUT_Pos   (0U)
#define JPEG_DOR_DATAOUT_Msk   (0xFFFFFFFFUL << JPEG_DOR_DATAOUT_Pos)
#define JPEG_DOR_DATAOUT   JPEG_DOR_DATAOUT_Msk
#define LPGPIO_MODER_MOD0_Pos   (0U)
#define LPGPIO_MODER_MOD0_Msk   (0x1UL << LPGPIO_MODER_MOD0_Pos)
#define LPGPIO_MODER_MOD0   LPGPIO_MODER_MOD0_Msk
#define LPGPIO_MODER_MOD1_Pos   (1U)
#define LPGPIO_MODER_MOD1_Msk   (0x1UL << LPGPIO_MODER_MOD1_Pos)
#define LPGPIO_MODER_MOD1   LPGPIO_MODER_MOD1_Msk
#define LPGPIO_MODER_MOD2_Pos   (2U)
#define LPGPIO_MODER_MOD2_Msk   (0x1UL << LPGPIO_MODER_MOD2_Pos)
#define LPGPIO_MODER_MOD2   LPGPIO_MODER_MOD2_Msk
#define LPGPIO_MODER_MOD3_Pos   (3U)
#define LPGPIO_MODER_MOD3_Msk   (0x1UL << LPGPIO_MODER_MOD3_Pos)
#define LPGPIO_MODER_MOD3   LPGPIO_MODER_MOD3_Msk
#define LPGPIO_MODER_MOD4_Pos   (4U)
#define LPGPIO_MODER_MOD4_Msk   (0x1UL << LPGPIO_MODER_MOD4_Pos)
#define LPGPIO_MODER_MOD4   LPGPIO_MODER_MOD4_Msk
#define LPGPIO_MODER_MOD5_Pos   (5U)
#define LPGPIO_MODER_MOD5_Msk   (0x1UL << LPGPIO_MODER_MOD5_Pos)
#define LPGPIO_MODER_MOD5   LPGPIO_MODER_MOD5_Msk
#define LPGPIO_MODER_MOD6_Pos   (6U)
#define LPGPIO_MODER_MOD6_Msk   (0x1UL << LPGPIO_MODER_MOD6_Pos)
#define LPGPIO_MODER_MOD6   LPGPIO_MODER_MOD6_Msk
#define LPGPIO_MODER_MOD7_Pos   (7U)
#define LPGPIO_MODER_MOD7_Msk   (0x1UL << LPGPIO_MODER_MOD7_Pos)
#define LPGPIO_MODER_MOD7   LPGPIO_MODER_MOD7_Msk
#define LPGPIO_MODER_MOD8_Pos   (8U)
#define LPGPIO_MODER_MOD8_Msk   (0x1UL << LPGPIO_MODER_MOD8_Pos)
#define LPGPIO_MODER_MOD8   LPGPIO_MODER_MOD8_Msk
#define LPGPIO_MODER_MOD9_Pos   (9U)
#define LPGPIO_MODER_MOD9_Msk   (0x1UL << LPGPIO_MODER_MOD9_Pos)
#define LPGPIO_MODER_MOD9   LPGPIO_MODER_MOD9_Msk
#define LPGPIO_MODER_MOD10_Pos   (10U)
#define LPGPIO_MODER_MOD10_Msk   (0x1UL << LPGPIO_MODER_MOD10_Pos)
#define LPGPIO_MODER_MOD10   LPGPIO_MODER_MOD10_Msk
#define LPGPIO_MODER_MOD11_Pos   (11U)
#define LPGPIO_MODER_MOD11_Msk   (0x1UL << LPGPIO_MODER_MOD11_Pos)
#define LPGPIO_MODER_MOD11   LPGPIO_MODER_MOD11_Msk
#define LPGPIO_MODER_MOD12_Pos   (12U)
#define LPGPIO_MODER_MOD12_Msk   (0x1UL << LPGPIO_MODER_MOD12_Pos)
#define LPGPIO_MODER_MOD12   LPGPIO_MODER_MOD12_Msk
#define LPGPIO_MODER_MOD13_Pos   (13U)
#define LPGPIO_MODER_MOD13_Msk   (0x1UL << LPGPIO_MODER_MOD13_Pos)
#define LPGPIO_MODER_MOD13   LPGPIO_MODER_MOD13_Msk
#define LPGPIO_MODER_MOD14_Pos   (14U)
#define LPGPIO_MODER_MOD14_Msk   (0x1UL << LPGPIO_MODER_MOD14_Pos)
#define LPGPIO_MODER_MOD14   LPGPIO_MODER_MOD14_Msk
#define LPGPIO_MODER_MOD15_Pos   (15U)
#define LPGPIO_MODER_MOD15_Msk   (0x1UL << LPGPIO_MODER_MOD15_Pos)
#define LPGPIO_MODER_MOD15   LPGPIO_MODER_MOD15_Msk
#define LPGPIO_IDR_ID0_Pos   (0U)
#define LPGPIO_IDR_ID0_Msk   (0x1UL << LPGPIO_IDR_ID0_Pos)
#define LPGPIO_IDR_ID0   LPGPIO_IDR_ID0_Msk
#define LPGPIO_IDR_ID1_Pos   (1U)
#define LPGPIO_IDR_ID1_Msk   (0x1UL << GPIO_IDR_ID1_Pos)
#define LPGPIO_IDR_ID1   LPGPIO_IDR_ID1_Msk
#define LPGPIO_IDR_ID2_Pos   (2U)
#define LPGPIO_IDR_ID2_Msk   (0x1UL << LPGPIO_IDR_ID2_Pos)
#define LPGPIO_IDR_ID2   LPGPIO_IDR_ID2_Msk
#define LPGPIO_IDR_ID3_Pos   (3U)
#define LPGPIO_IDR_ID3_Msk   (0x1UL << LPGPIO_IDR_ID3_Pos)
#define LPGPIO_IDR_ID3   LPGPIO_IDR_ID3_Msk
#define LPGPIO_IDR_ID4_Pos   (4U)
#define LPGPIO_IDR_ID4_Msk   (0x1UL << LPGPIO_IDR_ID4_Pos)
#define LPGPIO_IDR_ID4   LPGPIO_IDR_ID4_Msk
#define LPGPIO_IDR_ID5_Pos   (5U)
#define LPGPIO_IDR_ID5_Msk   (0x1UL << LPGPIO_IDR_ID5_Pos)
#define LPGPIO_IDR_ID5   LPGPIO_IDR_ID5_Msk
#define LPGPIO_IDR_ID6_Pos   (6U)
#define LPGPIO_IDR_ID6_Msk   (0x1UL << LPGPIO_IDR_ID6_Pos)
#define LPGPIO_IDR_ID6   LPGPIO_IDR_ID6_Msk
#define LPGPIO_IDR_ID7_Pos   (7U)
#define LPGPIO_IDR_ID7_Msk   (0x1UL << LPGPIO_IDR_ID7_Pos)
#define LPGPIO_IDR_ID7   LPGPIO_IDR_ID7_Msk
#define LPGPIO_IDR_ID8_Pos   (8U)
#define LPGPIO_IDR_ID8_Msk   (0x1UL << LPGPIO_IDR_ID8_Pos)
#define LPGPIO_IDR_ID8   LPGPIO_IDR_ID8_Msk
#define LPGPIO_IDR_ID9_Pos   (9U)
#define LPGPIO_IDR_ID9_Msk   (0x1UL << LPGPIO_IDR_ID9_Pos)
#define LPGPIO_IDR_ID9   LPGPIO_IDR_ID9_Msk
#define LPGPIO_IDR_ID10_Pos   (10U)
#define LPGPIO_IDR_ID10_Msk   (0x1UL << LPGPIO_IDR_ID10_Pos)
#define LPGPIO_IDR_ID10   LPGPIO_IDR_ID10_Msk
#define LPGPIO_IDR_ID11_Pos   (11U)
#define LPGPIO_IDR_ID11_Msk   (0x1UL << LPGPIO_IDR_ID11_Pos)
#define LPGPIO_IDR_ID11   LPGPIO_IDR_ID11_Msk
#define LPGPIO_IDR_ID12_Pos   (12U)
#define LPGPIO_IDR_ID12_Msk   (0x1UL << LPGPIO_IDR_ID12_Pos)
#define LPGPIO_IDR_ID12   LPGPIO_IDR_ID12_Msk
#define LPGPIO_IDR_ID13_Pos   (13U)
#define LPGPIO_IDR_ID13_Msk   (0x1UL << LPGPIO_IDR_ID13_Pos)
#define LPGPIO_IDR_ID13   LPGPIO_IDR_ID13_Msk
#define LPGPIO_IDR_ID14_Pos   (14U)
#define LPGPIO_IDR_ID14_Msk   (0x1UL << LPGPIO_IDR_ID14_Pos)
#define LPGPIO_IDR_ID14   LPGPIO_IDR_ID14_Msk
#define LPGPIO_IDR_ID15_Pos   (15U)
#define LPGPIO_IDR_ID15_Msk   (0x1UL << LPGPIO_IDR_ID15_Pos)
#define LPGPIO_IDR_ID15   LPGPIO_IDR_ID15_Msk
#define LPGPIO_ODR_OD0_Pos   (0U)
#define LPGPIO_ODR_OD0_Msk   (0x1UL << LPGPIO_ODR_OD0_Pos)
#define LPGPIO_ODR_OD0   LPGPIO_ODR_OD0_Msk
#define LPGPIO_ODR_OD1_Pos   (1U)
#define LPGPIO_ODR_OD1_Msk   (0x1UL << LPGPIO_ODR_OD1_Pos)
#define LPGPIO_ODR_OD1   LPGPIO_ODR_OD1_Msk
#define LPGPIO_ODR_OD2_Pos   (2U)
#define LPGPIO_ODR_OD2_Msk   (0x1UL << LPGPIO_ODR_OD2_Pos)
#define LPGPIO_ODR_OD2   LPGPIO_ODR_OD2_Msk
#define LPGPIO_ODR_OD3_Pos   (3U)
#define LPGPIO_ODR_OD3_Msk   (0x1UL << LPGPIO_ODR_OD3_Pos)
#define LPGPIO_ODR_OD3   LPGPIO_ODR_OD3_Msk
#define LPGPIO_ODR_OD4_Pos   (4U)
#define LPGPIO_ODR_OD4_Msk   (0x1UL << LPGPIO_ODR_OD4_Pos)
#define LPGPIO_ODR_OD4   LPGPIO_ODR_OD4_Msk
#define LPGPIO_ODR_OD5_Pos   (5U)
#define LPGPIO_ODR_OD5_Msk   (0x1UL << LPGPIO_ODR_OD5_Pos)
#define LPGPIO_ODR_OD5   LPGPIO_ODR_OD5_Msk
#define LPGPIO_ODR_OD6_Pos   (6U)
#define LPGPIO_ODR_OD6_Msk   (0x1UL << LPGPIO_ODR_OD6_Pos)
#define LPGPIO_ODR_OD6   LPGPIO_ODR_OD6_Msk
#define LPGPIO_ODR_OD7_Pos   (7U)
#define LPGPIO_ODR_OD7_Msk   (0x1UL << LPGPIO_ODR_OD7_Pos)
#define LPGPIO_ODR_OD7   LPGPIO_ODR_OD7_Msk
#define LPGPIO_ODR_OD8_Pos   (8U)
#define LPGPIO_ODR_OD8_Msk   (0x1UL << LPGPIO_ODR_OD8_Pos)
#define LPGPIO_ODR_OD8   LPGPIO_ODR_OD8_Msk
#define LPGPIO_ODR_OD9_Pos   (9U)
#define LPGPIO_ODR_OD9_Msk   (0x1UL << LPGPIO_ODR_OD9_Pos)
#define LPGPIO_ODR_OD9   LPGPIO_ODR_OD9_Msk
#define LPGPIO_ODR_OD10_Pos   (10U)
#define LPGPIO_ODR_OD10_Msk   (0x1UL << LPGPIO_ODR_OD10_Pos)
#define LPGPIO_ODR_OD10   LPGPIO_ODR_OD10_Msk
#define LPGPIO_ODR_OD11_Pos   (11U)
#define LPGPIO_ODR_OD11_Msk   (0x1UL << LPGPIO_ODR_OD11_Pos)
#define LPGPIO_ODR_OD11   LPGPIO_ODR_OD11_Msk
#define LPGPIO_ODR_OD12_Pos   (12U)
#define LPGPIO_ODR_OD12_Msk   (0x1UL << LPGPIO_ODR_OD12_Pos)
#define LPGPIO_ODR_OD12   LPGPIO_ODR_OD12_Msk
#define LPGPIO_ODR_OD13_Pos   (13U)
#define LPGPIO_ODR_OD13_Msk   (0x1UL << LPGPIO_ODR_OD13_Pos)
#define LPGPIO_ODR_OD13   LPGPIO_ODR_OD13_Msk
#define LPGPIO_ODR_OD14_Pos   (14U)
#define LPGPIO_ODR_OD14_Msk   (0x1UL << LPGPIO_ODR_OD14_Pos)
#define LPGPIO_ODR_OD14   LPGPIO_ODR_OD14_Msk
#define LPGPIO_ODR_OD15_Pos   (15U)
#define LPGPIO_ODR_OD15_Msk   (0x1UL << LPGPIO_ODR_OD15_Pos)
#define LPGPIO_ODR_OD15   LPGPIO_ODR_OD15_Msk
#define LPGPIO_BSRR_BS0_Pos   (0U)
#define LPGPIO_BSRR_BS0_Msk   (0x1UL << LPGPIO_BSRR_BS0_Pos)
#define LPGPIO_BSRR_BS0   LPGPIO_BSRR_BS0_Msk
#define LPGPIO_BSRR_BS1_Pos   (1U)
#define LPGPIO_BSRR_BS1_Msk   (0x1UL << LPGPIO_BSRR_BS1_Pos)
#define LPGPIO_BSRR_BS1   LPGPIO_BSRR_BS1_Msk
#define LPGPIO_BSRR_BS2_Pos   (2U)
#define LPGPIO_BSRR_BS2_Msk   (0x1UL << LPGPIO_BSRR_BS2_Pos)
#define LPGPIO_BSRR_BS2   LPGPIO_BSRR_BS2_Msk
#define LPGPIO_BSRR_BS3_Pos   (3U)
#define LPGPIO_BSRR_BS3_Msk   (0x1UL << LPGPIO_BSRR_BS3_Pos)
#define LPGPIO_BSRR_BS3   LPGPIO_BSRR_BS3_Msk
#define LPGPIO_BSRR_BS4_Pos   (4U)
#define LPGPIO_BSRR_BS4_Msk   (0x1UL << LPGPIO_BSRR_BS4_Pos)
#define LPGPIO_BSRR_BS4   LPGPIO_BSRR_BS4_Msk
#define LPGPIO_BSRR_BS5_Pos   (5U)
#define LPGPIO_BSRR_BS5_Msk   (0x1UL << LPGPIO_BSRR_BS5_Pos)
#define LPGPIO_BSRR_BS5   LPGPIO_BSRR_BS5_Msk
#define LPGPIO_BSRR_BS6_Pos   (6U)
#define LPGPIO_BSRR_BS6_Msk   (0x1UL << LPGPIO_BSRR_BS6_Pos)
#define LPGPIO_BSRR_BS6   LPGPIO_BSRR_BS6_Msk
#define LPGPIO_BSRR_BS7_Pos   (7U)
#define LPGPIO_BSRR_BS7_Msk   (0x1UL << LPGPIO_BSRR_BS7_Pos)
#define LPGPIO_BSRR_BS7   LPGPIO_BSRR_BS7_Msk
#define LPGPIO_BSRR_BS8_Pos   (8U)
#define LPGPIO_BSRR_BS8_Msk   (0x1UL << LPGPIO_BSRR_BS8_Pos)
#define LPGPIO_BSRR_BS8   LPGPIO_BSRR_BS8_Msk
#define LPGPIO_BSRR_BS9_Pos   (9U)
#define LPGPIO_BSRR_BS9_Msk   (0x1UL << LPGPIO_BSRR_BS9_Pos)
#define LPGPIO_BSRR_BS9   LPGPIO_BSRR_BS9_Msk
#define LPGPIO_BSRR_BS10_Pos   (10U)
#define LPGPIO_BSRR_BS10_Msk   (0x1UL << LPGPIO_BSRR_BS10_Pos)
#define LPGPIO_BSRR_BS10   LPGPIO_BSRR_BS10_Msk
#define LPGPIO_BSRR_BS11_Pos   (11U)
#define LPGPIO_BSRR_BS11_Msk   (0x1UL << LPGPIO_BSRR_BS11_Pos)
#define LPGPIO_BSRR_BS11   LPGPIO_BSRR_BS11_Msk
#define LPGPIO_BSRR_BS12_Pos   (12U)
#define LPGPIO_BSRR_BS12_Msk   (0x1UL << LPGPIO_BSRR_BS12_Pos)
#define LPGPIO_BSRR_BS12   LPGPIO_BSRR_BS12_Msk
#define LPGPIO_BSRR_BS13_Pos   (13U)
#define LPGPIO_BSRR_BS13_Msk   (0x1UL << LPGPIO_BSRR_BS13_Pos)
#define LPGPIO_BSRR_BS13   LPGPIO_BSRR_BS13_Msk
#define LPGPIO_BSRR_BS14_Pos   (14U)
#define LPGPIO_BSRR_BS14_Msk   (0x1UL << LPGPIO_BSRR_BS14_Pos)
#define LPGPIO_BSRR_BS14   LPGPIO_BSRR_BS14_Msk
#define LPGPIO_BSRR_BS15_Pos   (15U)
#define LPGPIO_BSRR_BS15_Msk   (0x1UL << LPGPIO_BSRR_BS15_Pos)
#define LPGPIO_BSRR_BS15   LPGPIO_BSRR_BS15_Msk
#define LPGPIO_BSRR_BR0_Pos   (16U)
#define LPGPIO_BSRR_BR0_Msk   (0x1UL << LPGPIO_BSRR_BR0_Pos)
#define LPGPIO_BSRR_BR0   LPGPIO_BSRR_BR0_Msk
#define LPGPIO_BSRR_BR1_Pos   (17U)
#define LPGPIO_BSRR_BR1_Msk   (0x1UL << LPGPIO_BSRR_BR1_Pos)
#define LPGPIO_BSRR_BR1   LPGPIO_BSRR_BR1_Msk
#define LPGPIO_BSRR_BR2_Pos   (18U)
#define LPGPIO_BSRR_BR2_Msk   (0x1UL << LPGPIO_BSRR_BR2_Pos)
#define LPGPIO_BSRR_BR2   LPGPIO_BSRR_BR2_Msk
#define LPGPIO_BSRR_BR3_Pos   (19U)
#define LPGPIO_BSRR_BR3_Msk   (0x1UL << LPGPIO_BSRR_BR3_Pos)
#define LPGPIO_BSRR_BR3   LPGPIO_BSRR_BR3_Msk
#define LPGPIO_BSRR_BR4_Pos   (20U)
#define LPGPIO_BSRR_BR4_Msk   (0x1UL << LPGPIO_BSRR_BR4_Pos)
#define LPGPIO_BSRR_BR4   LPGPIO_BSRR_BR4_Msk
#define LPGPIO_BSRR_BR5_Pos   (21U)
#define LPGPIO_BSRR_BR5_Msk   (0x1UL << LPGPIO_BSRR_BR5_Pos)
#define LPGPIO_BSRR_BR5   LPGPIO_BSRR_BR5_Msk
#define LPGPIO_BSRR_BR6_Pos   (22U)
#define LPGPIO_BSRR_BR6_Msk   (0x1UL << LPGPIO_BSRR_BR6_Pos)
#define LPGPIO_BSRR_BR6   LPGPIO_BSRR_BR6_Msk
#define LPGPIO_BSRR_BR7_Pos   (23U)
#define LPGPIO_BSRR_BR7_Msk   (0x1UL << LPGPIO_BSRR_BR7_Pos)
#define LPGPIO_BSRR_BR7   LPGPIO_BSRR_BR7_Msk
#define LPGPIO_BSRR_BR8_Pos   (24U)
#define LPGPIO_BSRR_BR8_Msk   (0x1UL << LPGPIO_BSRR_BR8_Pos)
#define LPGPIO_BSRR_BR8   LPGPIO_BSRR_BR8_Msk
#define LPGPIO_BSRR_BR9_Pos   (25U)
#define LPGPIO_BSRR_BR9_Msk   (0x1UL << LPGPIO_BSRR_BR9_Pos)
#define LPGPIO_BSRR_BR9   LPGPIO_BSRR_BR9_Msk
#define LPGPIO_BSRR_BR10_Pos   (26U)
#define LPGPIO_BSRR_BR10_Msk   (0x1UL << LPGPIO_BSRR_BR10_Pos)
#define LPGPIO_BSRR_BR10   LPGPIO_BSRR_BR10_Msk
#define LPGPIO_BSRR_BR11_Pos   (27U)
#define LPGPIO_BSRR_BR11_Msk   (0x1UL << LPGPIO_BSRR_BR11_Pos)
#define LPGPIO_BSRR_BR11   LPGPIO_BSRR_BR11_Msk
#define LPGPIO_BSRR_BR12_Pos   (28U)
#define LPGPIO_BSRR_BR12_Msk   (0x1UL << LPGPIO_BSRR_BR12_Pos)
#define LPGPIO_BSRR_BR12   LPGPIO_BSRR_BR12_Msk
#define LPGPIO_BSRR_BR13_Pos   (29U)
#define LPGPIO_BSRR_BR13_Msk   (0x1UL << LPGPIO_BSRR_BR13_Pos)
#define LPGPIO_BSRR_BR13   LPGPIO_BSRR_BR13_Msk
#define LPGPIO_BSRR_BR14_Pos   (30U)
#define LPGPIO_BSRR_BR14_Msk   (0x1UL << LPGPIO_BSRR_BR14_Pos)
#define LPGPIO_BSRR_BR14   LPGPIO_BSRR_BR14_Msk
#define LPGPIO_BSRR_BR15_Pos   (31U)
#define LPGPIO_BSRR_BR15_Msk   (0x1UL << LPGPIO_BSRR_BR15_Pos)
#define LPGPIO_BSRR_BR15   LPGPIO_BSRR_BR15_Msk
#define LPGPIO_BRR_BR0_Pos   (0U)
#define LPGPIO_BRR_BR0_Msk   (0x1UL << LPGPIO_BRR_BR0_Pos)
#define LPGPIO_BRR_BR0   LPGPIO_BRR_BR0_Msk
#define LPGPIO_BRR_BR1_Pos   (1U)
#define LPGPIO_BRR_BR1_Msk   (0x1UL << LPGPIO_BRR_BR1_Pos)
#define LPGPIO_BRR_BR1   LPGPIO_BRR_BR1_Msk
#define LPGPIO_BRR_BR2_Pos   (2U)
#define LPGPIO_BRR_BR2_Msk   (0x1UL << LPGPIO_BRR_BR2_Pos)
#define LPGPIO_BRR_BR2   LPGPIO_BRR_BR2_Msk
#define LPGPIO_BRR_BR3_Pos   (3U)
#define LPGPIO_BRR_BR3_Msk   (0x1UL << LPGPIO_BRR_BR3_Pos)
#define LPGPIO_BRR_BR3   LPGPIO_BRR_BR3_Msk
#define LPGPIO_BRR_BR4_Pos   (4U)
#define LPGPIO_BRR_BR4_Msk   (0x1UL << LPGPIO_BRR_BR4_Pos)
#define LPGPIO_BRR_BR4   LPGPIO_BRR_BR4_Msk
#define LPGPIO_BRR_BR5_Pos   (5U)
#define LPGPIO_BRR_BR5_Msk   (0x1UL << LPGPIO_BRR_BR5_Pos)
#define LPGPIO_BRR_BR5   LPGPIO_BRR_BR5_Msk
#define LPGPIO_BRR_BR6_Pos   (6U)
#define LPGPIO_BRR_BR6_Msk   (0x1UL << LPGPIO_BRR_BR6_Pos)
#define LPGPIO_BRR_BR6   LPGPIO_BRR_BR6_Msk
#define LPGPIO_BRR_BR7_Pos   (7U)
#define LPGPIO_BRR_BR7_Msk   (0x1UL << LPGPIO_BRR_BR7_Pos)
#define LPGPIO_BRR_BR7   LPGPIO_BRR_BR7_Msk
#define LPGPIO_BRR_BR8_Pos   (8U)
#define LPGPIO_BRR_BR8_Msk   (0x1UL << LPGPIO_BRR_BR8_Pos)
#define LPGPIO_BRR_BR8   LPGPIO_BRR_BR8_Msk
#define LPGPIO_BRR_BR9_Pos   (9U)
#define LPGPIO_BRR_BR9_Msk   (0x1UL << LPGPIO_BRR_BR9_Pos)
#define LPGPIO_BRR_BR9   LPGPIO_BRR_BR9_Msk
#define LPGPIO_BRR_BR10_Pos   (10U)
#define LPGPIO_BRR_BR10_Msk   (0x1UL << LPGPIO_BRR_BR10_Pos)
#define LPGPIO_BRR_BR10   LPGPIO_BRR_BR10_Msk
#define LPGPIO_BRR_BR11_Pos   (11U)
#define LPGPIO_BRR_BR11_Msk   (0x1UL << LPGPIO_BRR_BR11_Pos)
#define LPGPIO_BRR_BR11   LPGPIO_BRR_BR11_Msk
#define LPGPIO_BRR_BR12_Pos   (12U)
#define LPGPIO_BRR_BR12_Msk   (0x1UL << LPGPIO_BRR_BR12_Pos)
#define LPGPIO_BRR_BR12   LPGPIO_BRR_BR12_Msk
#define LPGPIO_BRR_BR13_Pos   (13U)
#define LPGPIO_BRR_BR13_Msk   (0x1UL << LPGPIO_BRR_BR13_Pos)
#define LPGPIO_BRR_BR13   LPGPIO_BRR_BR13_Msk
#define LPGPIO_BRR_BR14_Pos   (14U)
#define LPGPIO_BRR_BR14_Msk   (0x1UL << LPGPIO_BRR_BR14_Pos)
#define LPGPIO_BRR_BR14   LPGPIO_BRR_BR14_Msk
#define LPGPIO_BRR_BR15_Pos   (15U)
#define LPGPIO_BRR_BR15_Msk   (0x1UL << LPGPIO_BRR_BR15_Pos)
#define LPGPIO_BRR_BR15   LPGPIO_BRR_BR15_Msk
#define LTDC_SSCR_VSH_Pos   (0U)
#define LTDC_SSCR_VSH_Msk   (0x7FFUL << LTDC_SSCR_VSH_Pos)
#define LTDC_SSCR_VSH   LTDC_SSCR_VSH_Msk
#define LTDC_SSCR_HSW_Pos   (16U)
#define LTDC_SSCR_HSW_Msk   (0xFFFUL << LTDC_SSCR_HSW_Pos)
#define LTDC_SSCR_HSW   LTDC_SSCR_HSW_Msk
#define LTDC_BPCR_AVBP_Pos   (0U)
#define LTDC_BPCR_AVBP_Msk   (0x7FFUL << LTDC_BPCR_AVBP_Pos)
#define LTDC_BPCR_AVBP   LTDC_BPCR_AVBP_Msk
#define LTDC_BPCR_AHBP_Pos   (16U)
#define LTDC_BPCR_AHBP_Msk   (0xFFFUL << LTDC_BPCR_AHBP_Pos)
#define LTDC_BPCR_AHBP   LTDC_BPCR_AHBP_Msk
#define LTDC_AWCR_AAH_Pos   (0U)
#define LTDC_AWCR_AAH_Msk   (0x7FFUL << LTDC_AWCR_AAH_Pos)
#define LTDC_AWCR_AAH   LTDC_AWCR_AAH_Msk
#define LTDC_AWCR_AAW_Pos   (16U)
#define LTDC_AWCR_AAW_Msk   (0xFFFUL << LTDC_AWCR_AAW_Pos)
#define LTDC_AWCR_AAW   LTDC_AWCR_AAW_Msk
#define LTDC_TWCR_TOTALH_Pos   (0U)
#define LTDC_TWCR_TOTALH_Msk   (0x7FFUL << LTDC_TWCR_TOTALH_Pos)
#define LTDC_TWCR_TOTALH   LTDC_TWCR_TOTALH_Msk
#define LTDC_TWCR_TOTALW_Pos   (16U)
#define LTDC_TWCR_TOTALW_Msk   (0xFFFUL << LTDC_TWCR_TOTALW_Pos)
#define LTDC_TWCR_TOTALW   LTDC_TWCR_TOTALW_Msk
#define LTDC_GCR_LTDCEN_Pos   (0U)
#define LTDC_GCR_LTDCEN_Msk   (0x1UL << LTDC_GCR_LTDCEN_Pos)
#define LTDC_GCR_LTDCEN   LTDC_GCR_LTDCEN_Msk
#define LTDC_GCR_DBW_Pos   (4U)
#define LTDC_GCR_DBW_Msk   (0x7UL << LTDC_GCR_DBW_Pos)
#define LTDC_GCR_DBW   LTDC_GCR_DBW_Msk
#define LTDC_GCR_DGW_Pos   (8U)
#define LTDC_GCR_DGW_Msk   (0x7UL << LTDC_GCR_DGW_Pos)
#define LTDC_GCR_DGW   LTDC_GCR_DGW_Msk
#define LTDC_GCR_DRW_Pos   (12U)
#define LTDC_GCR_DRW_Msk   (0x7UL << LTDC_GCR_DRW_Pos)
#define LTDC_GCR_DRW   LTDC_GCR_DRW_Msk
#define LTDC_GCR_DEN_Pos   (16U)
#define LTDC_GCR_DEN_Msk   (0x1UL << LTDC_GCR_DEN_Pos)
#define LTDC_GCR_DEN   LTDC_GCR_DEN_Msk
#define LTDC_GCR_PCPOL_Pos   (28U)
#define LTDC_GCR_PCPOL_Msk   (0x1UL << LTDC_GCR_PCPOL_Pos)
#define LTDC_GCR_PCPOL   LTDC_GCR_PCPOL_Msk
#define LTDC_GCR_DEPOL_Pos   (29U)
#define LTDC_GCR_DEPOL_Msk   (0x1UL << LTDC_GCR_DEPOL_Pos)
#define LTDC_GCR_DEPOL   LTDC_GCR_DEPOL_Msk
#define LTDC_GCR_VSPOL_Pos   (30U)
#define LTDC_GCR_VSPOL_Msk   (0x1UL << LTDC_GCR_VSPOL_Pos)
#define LTDC_GCR_VSPOL   LTDC_GCR_VSPOL_Msk
#define LTDC_GCR_HSPOL_Pos   (31U)
#define LTDC_GCR_HSPOL_Msk   (0x1UL << LTDC_GCR_HSPOL_Pos)
#define LTDC_GCR_HSPOL   LTDC_GCR_HSPOL_Msk
#define LTDC_SRCR_IMR_Pos   (0U)
#define LTDC_SRCR_IMR_Msk   (0x1UL << LTDC_SRCR_IMR_Pos)
#define LTDC_SRCR_IMR   LTDC_SRCR_IMR_Msk
#define LTDC_SRCR_VBR_Pos   (1U)
#define LTDC_SRCR_VBR_Msk   (0x1UL << LTDC_SRCR_VBR_Pos)
#define LTDC_SRCR_VBR   LTDC_SRCR_VBR_Msk
#define LTDC_BCCR_BCBLUE_Pos   (0U)
#define LTDC_BCCR_BCBLUE_Msk   (0xFFUL << LTDC_BCCR_BCBLUE_Pos)
#define LTDC_BCCR_BCBLUE   LTDC_BCCR_BCBLUE_Msk
#define LTDC_BCCR_BCGREEN_Pos   (8U)
#define LTDC_BCCR_BCGREEN_Msk   (0xFFUL << LTDC_BCCR_BCGREEN_Pos)
#define LTDC_BCCR_BCGREEN   LTDC_BCCR_BCGREEN_Msk
#define LTDC_BCCR_BCRED_Pos   (16U)
#define LTDC_BCCR_BCRED_Msk   (0xFFUL << LTDC_BCCR_BCRED_Pos)
#define LTDC_BCCR_BCRED   LTDC_BCCR_BCRED_Msk
#define LTDC_IER_LIE_Pos   (0U)
#define LTDC_IER_LIE_Msk   (0x1UL << LTDC_IER_LIE_Pos)
#define LTDC_IER_LIE   LTDC_IER_LIE_Msk
#define LTDC_IER_FUIE_Pos   (1U)
#define LTDC_IER_FUIE_Msk   (0x1UL << LTDC_IER_FUIE_Pos)
#define LTDC_IER_FUIE   LTDC_IER_FUIE_Msk
#define LTDC_IER_TERRIE_Pos   (2U)
#define LTDC_IER_TERRIE_Msk   (0x1UL << LTDC_IER_TERRIE_Pos)
#define LTDC_IER_TERRIE   LTDC_IER_TERRIE_Msk
#define LTDC_IER_RRIE_Pos   (3U)
#define LTDC_IER_RRIE_Msk   (0x1UL << LTDC_IER_RRIE_Pos)
#define LTDC_IER_RRIE   LTDC_IER_RRIE_Msk
#define LTDC_ISR_LIF_Pos   (0U)
#define LTDC_ISR_LIF_Msk   (0x1UL << LTDC_ISR_LIF_Pos)
#define LTDC_ISR_LIF   LTDC_ISR_LIF_Msk
#define LTDC_ISR_FUIF_Pos   (1U)
#define LTDC_ISR_FUIF_Msk   (0x1UL << LTDC_ISR_FUIF_Pos)
#define LTDC_ISR_FUIF   LTDC_ISR_FUIF_Msk
#define LTDC_ISR_TERRIF_Pos   (2U)
#define LTDC_ISR_TERRIF_Msk   (0x1UL << LTDC_ISR_TERRIF_Pos)
#define LTDC_ISR_TERRIF   LTDC_ISR_TERRIF_Msk
#define LTDC_ISR_RRIF_Pos   (3U)
#define LTDC_ISR_RRIF_Msk   (0x1UL << LTDC_ISR_RRIF_Pos)
#define LTDC_ISR_RRIF   LTDC_ISR_RRIF_Msk
#define LTDC_ICR_CLIF_Pos   (0U)
#define LTDC_ICR_CLIF_Msk   (0x1UL << LTDC_ICR_CLIF_Pos)
#define LTDC_ICR_CLIF   LTDC_ICR_CLIF_Msk
#define LTDC_ICR_CFUIF_Pos   (1U)
#define LTDC_ICR_CFUIF_Msk   (0x1UL << LTDC_ICR_CFUIF_Pos)
#define LTDC_ICR_CFUIF   LTDC_ICR_CFUIF_Msk
#define LTDC_ICR_CTERRIF_Pos   (2U)
#define LTDC_ICR_CTERRIF_Msk   (0x1UL << LTDC_ICR_CTERRIF_Pos)
#define LTDC_ICR_CTERRIF   LTDC_ICR_CTERRIF_Msk
#define LTDC_ICR_CRRIF_Pos   (3U)
#define LTDC_ICR_CRRIF_Msk   (0x1UL << LTDC_ICR_CRRIF_Pos)
#define LTDC_ICR_CRRIF   LTDC_ICR_CRRIF_Msk
#define LTDC_LIPCR_LIPOS_Pos   (0U)
#define LTDC_LIPCR_LIPOS_Msk   (0x7FFUL << LTDC_LIPCR_LIPOS_Pos)
#define LTDC_LIPCR_LIPOS   LTDC_LIPCR_LIPOS_Msk
#define LTDC_CPSR_CYPOS_Pos   (0U)
#define LTDC_CPSR_CYPOS_Msk   (0xFFFFUL << LTDC_CPSR_CYPOS_Pos)
#define LTDC_CPSR_CYPOS   LTDC_CPSR_CYPOS_Msk
#define LTDC_CPSR_CXPOS_Pos   (16U)
#define LTDC_CPSR_CXPOS_Msk   (0xFFFFUL << LTDC_CPSR_CXPOS_Pos)
#define LTDC_CPSR_CXPOS   LTDC_CPSR_CXPOS_Msk
#define LTDC_CDSR_VDES_Pos   (0U)
#define LTDC_CDSR_VDES_Msk   (0x1UL << LTDC_CDSR_VDES_Pos)
#define LTDC_CDSR_VDES   LTDC_CDSR_VDES_Msk
#define LTDC_CDSR_HDES_Pos   (1U)
#define LTDC_CDSR_HDES_Msk   (0x1UL << LTDC_CDSR_HDES_Pos)
#define LTDC_CDSR_HDES   LTDC_CDSR_HDES_Msk
#define LTDC_CDSR_VSYNCS_Pos   (2U)
#define LTDC_CDSR_VSYNCS_Msk   (0x1UL << LTDC_CDSR_VSYNCS_Pos)
#define LTDC_CDSR_VSYNCS   LTDC_CDSR_VSYNCS_Msk
#define LTDC_CDSR_HSYNCS_Pos   (3U)
#define LTDC_CDSR_HSYNCS_Msk   (0x1UL << LTDC_CDSR_HSYNCS_Pos)
#define LTDC_CDSR_HSYNCS   LTDC_CDSR_HSYNCS_Msk
#define LTDC_LxCR_LEN_Pos   (0U)
#define LTDC_LxCR_LEN_Msk   (0x1UL << LTDC_LxCR_LEN_Pos)
#define LTDC_LxCR_LEN   LTDC_LxCR_LEN_Msk
#define LTDC_LxCR_COLKEN_Pos   (1U)
#define LTDC_LxCR_COLKEN_Msk   (0x1UL << LTDC_LxCR_COLKEN_Pos)
#define LTDC_LxCR_COLKEN   LTDC_LxCR_COLKEN_Msk
#define LTDC_LxCR_CLUTEN_Pos   (4U)
#define LTDC_LxCR_CLUTEN_Msk   (0x1UL << LTDC_LxCR_CLUTEN_Pos)
#define LTDC_LxCR_CLUTEN   LTDC_LxCR_CLUTEN_Msk
#define LTDC_LxWHPCR_WHSTPOS_Pos   (0U)
#define LTDC_LxWHPCR_WHSTPOS_Msk   (0xFFFUL << LTDC_LxWHPCR_WHSTPOS_Pos)
#define LTDC_LxWHPCR_WHSTPOS   LTDC_LxWHPCR_WHSTPOS_Msk
#define LTDC_LxWHPCR_WHSPPOS_Pos   (16U)
#define LTDC_LxWHPCR_WHSPPOS_Msk   (0xFFFUL << LTDC_LxWHPCR_WHSPPOS_Pos)
#define LTDC_LxWHPCR_WHSPPOS   LTDC_LxWHPCR_WHSPPOS_Msk
#define LTDC_LxWVPCR_WVSTPOS_Pos   (0U)
#define LTDC_LxWVPCR_WVSTPOS_Msk   (0xFFFUL << LTDC_LxWVPCR_WVSTPOS_Pos)
#define LTDC_LxWVPCR_WVSTPOS   LTDC_LxWVPCR_WVSTPOS_Msk
#define LTDC_LxWVPCR_WVSPPOS_Pos   (16U)
#define LTDC_LxWVPCR_WVSPPOS_Msk   (0xFFFUL << LTDC_LxWVPCR_WVSPPOS_Pos)
#define LTDC_LxWVPCR_WVSPPOS   LTDC_LxWVPCR_WVSPPOS_Msk
#define LTDC_LxCKCR_CKBLUE_Pos   (0U)
#define LTDC_LxCKCR_CKBLUE_Msk   (0xFFUL << LTDC_LxCKCR_CKBLUE_Pos)
#define LTDC_LxCKCR_CKBLUE   LTDC_LxCKCR_CKBLUE_Msk
#define LTDC_LxCKCR_CKGREEN_Pos   (8U)
#define LTDC_LxCKCR_CKGREEN_Msk   (0xFFUL << LTDC_LxCKCR_CKGREEN_Pos)
#define LTDC_LxCKCR_CKGREEN   LTDC_LxCKCR_CKGREEN_Msk
#define LTDC_LxCKCR_CKRED_Pos   (16U)
#define LTDC_LxCKCR_CKRED_Msk   (0xFFUL << LTDC_LxCKCR_CKRED_Pos)
#define LTDC_LxCKCR_CKRED   LTDC_LxCKCR_CKRED_Msk
#define LTDC_LxPFCR_PF_Pos   (0U)
#define LTDC_LxPFCR_PF_Msk   (0x7UL << LTDC_LxPFCR_PF_Pos)
#define LTDC_LxPFCR_PF   LTDC_LxPFCR_PF_Msk
#define LTDC_LxCACR_CONSTA_Pos   (0U)
#define LTDC_LxCACR_CONSTA_Msk   (0xFFUL << LTDC_LxCACR_CONSTA_Pos)
#define LTDC_LxCACR_CONSTA   LTDC_LxCACR_CONSTA_Msk
#define LTDC_LxDCCR_DCBLUE_Pos   (0U)
#define LTDC_LxDCCR_DCBLUE_Msk   (0xFFUL << LTDC_LxDCCR_DCBLUE_Pos)
#define LTDC_LxDCCR_DCBLUE   LTDC_LxDCCR_DCBLUE_Msk
#define LTDC_LxDCCR_DCGREEN_Pos   (8U)
#define LTDC_LxDCCR_DCGREEN_Msk   (0xFFUL << LTDC_LxDCCR_DCGREEN_Pos)
#define LTDC_LxDCCR_DCGREEN   LTDC_LxDCCR_DCGREEN_Msk
#define LTDC_LxDCCR_DCRED_Pos   (16U)
#define LTDC_LxDCCR_DCRED_Msk   (0xFFUL << LTDC_LxDCCR_DCRED_Pos)
#define LTDC_LxDCCR_DCRED   LTDC_LxDCCR_DCRED_Msk
#define LTDC_LxDCCR_DCALPHA_Pos   (24U)
#define LTDC_LxDCCR_DCALPHA_Msk   (0xFFUL << LTDC_LxDCCR_DCALPHA_Pos)
#define LTDC_LxDCCR_DCALPHA   LTDC_LxDCCR_DCALPHA_Msk
#define LTDC_LxBFCR_BF2_Pos   (0U)
#define LTDC_LxBFCR_BF2_Msk   (0x7UL << LTDC_LxBFCR_BF2_Pos)
#define LTDC_LxBFCR_BF2   LTDC_LxBFCR_BF2_Msk
#define LTDC_LxBFCR_BF1_Pos   (8U)
#define LTDC_LxBFCR_BF1_Msk   (0x7UL << LTDC_LxBFCR_BF1_Pos)
#define LTDC_LxBFCR_BF1   LTDC_LxBFCR_BF1_Msk
#define LTDC_LxCFBAR_CFBADD_Pos   (0U)
#define LTDC_LxCFBAR_CFBADD_Msk   (0xFFFFFFFFUL << LTDC_LxCFBAR_CFBADD_Pos)
#define LTDC_LxCFBAR_CFBADD   LTDC_LxCFBAR_CFBADD_Msk
#define LTDC_LxCFBLR_CFBLL_Pos   (0U)
#define LTDC_LxCFBLR_CFBLL_Msk   (0x1FFFUL << LTDC_LxCFBLR_CFBLL_Pos)
#define LTDC_LxCFBLR_CFBLL   LTDC_LxCFBLR_CFBLL_Msk
#define LTDC_LxCFBLR_CFBP_Pos   (16U)
#define LTDC_LxCFBLR_CFBP_Msk   (0x1FFFUL << LTDC_LxCFBLR_CFBP_Pos)
#define LTDC_LxCFBLR_CFBP   LTDC_LxCFBLR_CFBP_Msk
#define LTDC_LxCFBLNR_CFBLNBR_Pos   (0U)
#define LTDC_LxCFBLNR_CFBLNBR_Msk   (0x7FFUL << LTDC_LxCFBLNR_CFBLNBR_Pos)
#define LTDC_LxCFBLNR_CFBLNBR   LTDC_LxCFBLNR_CFBLNBR_Msk
#define LTDC_LxCLUTWR_BLUE_Pos   (0U)
#define LTDC_LxCLUTWR_BLUE_Msk   (0xFFUL << LTDC_LxCLUTWR_BLUE_Pos)
#define LTDC_LxCLUTWR_BLUE   LTDC_LxCLUTWR_BLUE_Msk
#define LTDC_LxCLUTWR_GREEN_Pos   (8U)
#define LTDC_LxCLUTWR_GREEN_Msk   (0xFFUL << LTDC_LxCLUTWR_GREEN_Pos)
#define LTDC_LxCLUTWR_GREEN   LTDC_LxCLUTWR_GREEN_Msk
#define LTDC_LxCLUTWR_RED_Pos   (16U)
#define LTDC_LxCLUTWR_RED_Msk   (0xFFUL << LTDC_LxCLUTWR_RED_Pos)
#define LTDC_LxCLUTWR_RED   LTDC_LxCLUTWR_RED_Msk
#define LTDC_LxCLUTWR_CLUTADD_Pos   (24U)
#define LTDC_LxCLUTWR_CLUTADD_Msk   (0xFFUL << LTDC_LxCLUTWR_CLUTADD_Pos)
#define LTDC_LxCLUTWR_CLUTADD   LTDC_LxCLUTWR_CLUTADD_Msk
#define ICACHE_CR_EN_Pos   (0U)
#define ICACHE_CR_EN_Msk   (0x1UL << ICACHE_CR_EN_Pos)
#define ICACHE_CR_EN   ICACHE_CR_EN_Msk
#define ICACHE_CR_CACHEINV_Pos   (1U)
#define ICACHE_CR_CACHEINV_Msk   (0x1UL << ICACHE_CR_CACHEINV_Pos)
#define ICACHE_CR_CACHEINV   ICACHE_CR_CACHEINV_Msk
#define ICACHE_CR_WAYSEL_Pos   (2U)
#define ICACHE_CR_WAYSEL_Msk   (0x1UL << ICACHE_CR_WAYSEL_Pos)
#define ICACHE_CR_WAYSEL   ICACHE_CR_WAYSEL_Msk
#define ICACHE_CR_HITMEN_Pos   (16U)
#define ICACHE_CR_HITMEN_Msk   (0x1UL << ICACHE_CR_HITMEN_Pos)
#define ICACHE_CR_HITMEN   ICACHE_CR_HITMEN_Msk
#define ICACHE_CR_MISSMEN_Pos   (17U)
#define ICACHE_CR_MISSMEN_Msk   (0x1UL << ICACHE_CR_MISSMEN_Pos)
#define ICACHE_CR_MISSMEN   ICACHE_CR_MISSMEN_Msk
#define ICACHE_CR_HITMRST_Pos   (18U)
#define ICACHE_CR_HITMRST_Msk   (0x1UL << ICACHE_CR_HITMRST_Pos)
#define ICACHE_CR_HITMRST   ICACHE_CR_HITMRST_Msk
#define ICACHE_CR_MISSMRST_Pos   (19U)
#define ICACHE_CR_MISSMRST_Msk   (0x1UL << ICACHE_CR_MISSMRST_Pos)
#define ICACHE_CR_MISSMRST   ICACHE_CR_MISSMRST_Msk
#define ICACHE_SR_BUSYF_Pos   (0U)
#define ICACHE_SR_BUSYF_Msk   (0x1UL << ICACHE_SR_BUSYF_Pos)
#define ICACHE_SR_BUSYF   ICACHE_SR_BUSYF_Msk
#define ICACHE_SR_BSYENDF_Pos   (1U)
#define ICACHE_SR_BSYENDF_Msk   (0x1UL << ICACHE_SR_BSYENDF_Pos)
#define ICACHE_SR_BSYENDF   ICACHE_SR_BSYENDF_Msk
#define ICACHE_SR_ERRF_Pos   (2U)
#define ICACHE_SR_ERRF_Msk   (0x1UL << ICACHE_SR_ERRF_Pos)
#define ICACHE_SR_ERRF   ICACHE_SR_ERRF_Msk
#define ICACHE_IER_BSYENDIE_Pos   (1U)
#define ICACHE_IER_BSYENDIE_Msk   (0x1UL << ICACHE_IER_BSYENDIE_Pos)
#define ICACHE_IER_BSYENDIE   ICACHE_IER_BSYENDIE_Msk
#define ICACHE_IER_ERRIE_Pos   (2U)
#define ICACHE_IER_ERRIE_Msk   (0x1UL << ICACHE_IER_ERRIE_Pos)
#define ICACHE_IER_ERRIE   ICACHE_IER_ERRIE_Msk
#define ICACHE_FCR_CBSYENDF_Pos   (1U)
#define ICACHE_FCR_CBSYENDF_Msk   (0x1UL << ICACHE_FCR_CBSYENDF_Pos)
#define ICACHE_FCR_CBSYENDF   ICACHE_FCR_CBSYENDF_Msk
#define ICACHE_FCR_CERRF_Pos   (2U)
#define ICACHE_FCR_CERRF_Msk   (0x1UL << ICACHE_FCR_CERRF_Pos)
#define ICACHE_FCR_CERRF   ICACHE_FCR_CERRF_Msk
#define ICACHE_HMONR_HITMON_Pos   (0U)
#define ICACHE_HMONR_HITMON_Msk   (0xFFFFFFFFUL << ICACHE_HMONR_HITMON_Pos)
#define ICACHE_HMONR_HITMON   ICACHE_HMONR_HITMON_Msk
#define ICACHE_MMONR_MISSMON_Pos   (0U)
#define ICACHE_MMONR_MISSMON_Msk   (0xFFFFUL << ICACHE_MMONR_MISSMON_Pos)
#define ICACHE_MMONR_MISSMON   ICACHE_MMONR_MISSMON_Msk
#define ICACHE_CRRx_BASEADDR_Pos   (0U)
#define ICACHE_CRRx_BASEADDR_Msk   (0xFFUL << ICACHE_CRRx_BASEADDR_Pos)
#define ICACHE_CRRx_BASEADDR   ICACHE_CRRx_BASEADDR_Msk
#define ICACHE_CRRx_RSIZE_Pos   (9U)
#define ICACHE_CRRx_RSIZE_Msk   (0x7UL << ICACHE_CRRx_RSIZE_Pos)
#define ICACHE_CRRx_RSIZE   ICACHE_CRRx_RSIZE_Msk
#define ICACHE_CRRx_RSIZE_0   (0x1UL << ICACHE_CRRx_RSIZE_Pos)
#define ICACHE_CRRx_RSIZE_1   (0x2UL << ICACHE_CRRx_RSIZE_Pos)
#define ICACHE_CRRx_RSIZE_2   (0x4UL << ICACHE_CRRx_RSIZE_Pos)
#define ICACHE_CRRx_REN_Pos   (15U)
#define ICACHE_CRRx_REN_Msk   (0x1UL << ICACHE_CRRx_REN_Pos)
#define ICACHE_CRRx_REN   ICACHE_CRRx_REN_Msk
#define ICACHE_CRRx_REMAPADDR_Pos   (16U)
#define ICACHE_CRRx_REMAPADDR_Msk   (0x7FFUL << ICACHE_CRRx_REMAPADDR_Pos)
#define ICACHE_CRRx_REMAPADDR   ICACHE_CRRx_REMAPADDR_Msk
#define ICACHE_CRRx_MSTSEL_Pos   (28U)
#define ICACHE_CRRx_MSTSEL_Msk   (0x1UL << ICACHE_CRRx_MSTSEL_Pos)
#define ICACHE_CRRx_MSTSEL   ICACHE_CRRx_MSTSEL_Msk
#define ICACHE_CRRx_HBURST_Pos   (31U)
#define ICACHE_CRRx_HBURST_Msk   (0x1UL << ICACHE_CRRx_HBURST_Pos)
#define ICACHE_CRRx_HBURST   ICACHE_CRRx_HBURST_Msk
#define DCACHE_CR_EN_Pos   (0U)
#define DCACHE_CR_EN_Msk   (0x1UL << DCACHE_CR_EN_Pos)
#define DCACHE_CR_EN   DCACHE_CR_EN_Msk
#define DCACHE_CR_CACHEINV_Pos   (1U)
#define DCACHE_CR_CACHEINV_Msk   (0x1UL << DCACHE_CR_CACHEINV_Pos)
#define DCACHE_CR_CACHEINV   DCACHE_CR_CACHEINV_Msk
#define DCACHE_CR_CACHECMD_Pos   (8U)
#define DCACHE_CR_CACHECMD_Msk   (0x7UL << DCACHE_CR_CACHECMD_Pos)
#define DCACHE_CR_CACHECMD   DCACHE_CR_CACHECMD_Msk
#define DCACHE_CR_CACHECMD_0   (0x1UL << DCACHE_CR_CACHECMD_Pos)
#define DCACHE_CR_CACHECMD_1   (0x2UL << DCACHE_CR_CACHECMD_Pos)
#define DCACHE_CR_CACHECMD_2   (0x4UL << DCACHE_CR_CACHECMD_Pos)
#define DCACHE_CR_STARTCMD_Pos   (11U)
#define DCACHE_CR_STARTCMD_Msk   (0x1UL << DCACHE_CR_STARTCMD_Pos)
#define DCACHE_CR_STARTCMD   DCACHE_CR_STARTCMD_Msk
#define DCACHE_CR_RHITMEN_Pos   (16U)
#define DCACHE_CR_RHITMEN_Msk   (0x1UL << DCACHE_CR_RHITMEN_Pos)
#define DCACHE_CR_RHITMEN   DCACHE_CR_RHITMEN_Msk
#define DCACHE_CR_RMISSMEN_Pos   (17U)
#define DCACHE_CR_RMISSMEN_Msk   (0x1UL << DCACHE_CR_RMISSMEN_Pos)
#define DCACHE_CR_RMISSMEN   DCACHE_CR_RMISSMEN_Msk
#define DCACHE_CR_RHITMRST_Pos   (18U)
#define DCACHE_CR_RHITMRST_Msk   (0x1UL << DCACHE_CR_RHITMRST_Pos)
#define DCACHE_CR_RHITMRST   DCACHE_CR_RHITMRST_Msk
#define DCACHE_CR_RMISSMRST_Pos   (19U)
#define DCACHE_CR_RMISSMRST_Msk   (0x1UL << DCACHE_CR_RMISSMRST_Pos)
#define DCACHE_CR_RMISSMRST   DCACHE_CR_RMISSMRST_Msk
#define DCACHE_CR_WHITMEN_Pos   (20U)
#define DCACHE_CR_WHITMEN_Msk   (0x1UL << DCACHE_CR_WHITMEN_Pos)
#define DCACHE_CR_WHITMEN   DCACHE_CR_WHITMEN_Msk
#define DCACHE_CR_WMISSMEN_Pos   (21U)
#define DCACHE_CR_WMISSMEN_Msk   (0x1UL << DCACHE_CR_WMISSMEN_Pos)
#define DCACHE_CR_WMISSMEN   DCACHE_CR_WMISSMEN_Msk
#define DCACHE_CR_WHITMRST_Pos   (22U)
#define DCACHE_CR_WHITMRST_Msk   (0x1UL << DCACHE_CR_WHITMRST_Pos)
#define DCACHE_CR_WHITMRST   DCACHE_CR_WHITMRST_Msk
#define DCACHE_CR_WMISSMRST_Pos   (23U)
#define DCACHE_CR_WMISSMRST_Msk   (0x1UL << DCACHE_CR_WMISSMRST_Pos)
#define DCACHE_CR_WMISSMRST   DCACHE_CR_WMISSMRST_Msk
#define DCACHE_CR_HBURST_Pos   (31U)
#define DCACHE_CR_HBURST_Msk   (0x1UL << DCACHE_CR_HBURST_Pos)
#define DCACHE_CR_HBURST   DCACHE_CR_HBURST_Msk
#define DCACHE_SR_BUSYF_Pos   (0U)
#define DCACHE_SR_BUSYF_Msk   (0x1UL << DCACHE_SR_BUSYF_Pos)
#define DCACHE_SR_BUSYF   DCACHE_SR_BUSYF_Msk
#define DCACHE_SR_BSYENDF_Pos   (1U)
#define DCACHE_SR_BSYENDF_Msk   (0x1UL << DCACHE_SR_BSYENDF_Pos)
#define DCACHE_SR_BSYENDF   DCACHE_SR_BSYENDF_Msk
#define DCACHE_SR_ERRF_Pos   (2U)
#define DCACHE_SR_ERRF_Msk   (0x1UL << DCACHE_SR_ERRF_Pos)
#define DCACHE_SR_ERRF   DCACHE_SR_ERRF_Msk
#define DCACHE_SR_BUSYCMDF_Pos   (3U)
#define DCACHE_SR_BUSYCMDF_Msk   (0x1UL << DCACHE_SR_BUSYCMDF_Pos)
#define DCACHE_SR_BUSYCMDF   DCACHE_SR_BUSYCMDF_Msk
#define DCACHE_SR_CMDENDF_Pos   (4U)
#define DCACHE_SR_CMDENDF_Msk   (0x1UL << DCACHE_SR_CMDENDF_Pos)
#define DCACHE_SR_CMDENDF   DCACHE_SR_CMDENDF_Msk
#define DCACHE_IER_BSYENDIE_Pos   (1U)
#define DCACHE_IER_BSYENDIE_Msk   (0x1UL << DCACHE_IER_BSYENDIE_Pos)
#define DCACHE_IER_BSYENDIE   DCACHE_IER_BSYENDIE_Msk
#define DCACHE_IER_ERRIE_Pos   (2U)
#define DCACHE_IER_ERRIE_Msk   (0x1UL << DCACHE_IER_ERRIE_Pos)
#define DCACHE_IER_ERRIE   DCACHE_IER_ERRIE_Msk
#define DCACHE_IER_CMDENDIE_Pos   (4U)
#define DCACHE_IER_CMDENDIE_Msk   (0x1UL << DCACHE_IER_CMDENDIE_Pos)
#define DCACHE_IER_CMDENDIE   DCACHE_IER_CMDENDIE_Msk
#define DCACHE_FCR_CBSYENDF_Pos   (1U)
#define DCACHE_FCR_CBSYENDF_Msk   (0x1UL << DCACHE_FCR_CBSYENDF_Pos)
#define DCACHE_FCR_CBSYENDF   DCACHE_FCR_CBSYENDF_Msk
#define DCACHE_FCR_CERRF_Pos   (2U)
#define DCACHE_FCR_CERRF_Msk   (0x1UL << DCACHE_FCR_CERRF_Pos)
#define DCACHE_FCR_CERRF   DCACHE_FCR_CERRF_Msk
#define DCACHE_FCR_CCMDENDF_Pos   (4U)
#define DCACHE_FCR_CCMDENDF_Msk   (0x1UL << DCACHE_FCR_CCMDENDF_Pos)
#define DCACHE_FCR_CCMDENDF   DCACHE_FCR_CCMDENDF_Msk
#define DCACHE_RHMONR_RHITMON_Pos   (0U)
#define DCACHE_RHMONR_RHITMON_Msk   (0xFFFFFFFFUL << DCACHE_RHMONR_RHITMON_Pos)
#define DCACHE_RHMONR_RHITMON   DCACHE_RHMONR_RHITMON_Msk
#define DCACHE_RMMONR_RMISSMON_Pos   (0U)
#define DCACHE_RMMONR_RMISSMON_Msk   (0xFFFFUL << DCACHE_RMMONR_RMISSMON_Pos)
#define DCACHE_RMMONR_RMISSMON   DCACHE_RMMONR_RMISSMON_Msk
#define DCACHE_WHMONR_WHITMON_Pos   (0U)
#define DCACHE_WHMONR_WHITMON_Msk   (0xFFFFFFFFUL << DCACHE_WHMONR_WHITMON_Pos)
#define DCACHE_WHMONR_WHITMON   DCACHE_WHMONR_WHITMON_Msk
#define DCACHE_WMMONR_WMISSMON_Pos   (0U)
#define DCACHE_WMMONR_WMISSMON_Msk   (0xFFFFUL << DCACHE_WMMONR_WMISSMON_Pos)
#define DCACHE_WMMONR_WMISSMON   DCACHE_WMMONR_WMISSMON_Msk
#define DCACHE_CMDRSADDRR_CMDSTARTADDR_Pos   (0U)
#define DCACHE_CMDRSADDRR_CMDSTARTADDR_Msk   (0xFFFFFFE0UL << DCACHE_CMDRSADDRR_CMDSTARTADDR_Pos)
#define DCACHE_CMDRSADDRR_CMDSTARTADDR   DCACHE_CMDRSADDRR_CMDSTARTADDR_Msk
#define DCACHE_CMDREADDRR_CMDENDADDR_Pos   (0U)
#define DCACHE_CMDREADDRR_CMDENDADDR_Msk   (0xFFFFFFE0UL << DCACHE_CMDREADDRR_CMDENDADDR_Pos)
#define DCACHE_CMDREADDRR_CMDENDADDR   DCACHE_CMDREADDRR_CMDENDADDR_Msk
#define COMP_WINDOW_MODE_SUPPORT
#define COMP_CSR_EN_Pos   (0U)
#define COMP_CSR_EN_Msk   (0x1UL << COMP_CSR_EN_Pos)
#define COMP_CSR_EN   COMP_CSR_EN_Msk
#define COMP_CSR_INMSEL_Pos   (4U)
#define COMP_CSR_INMSEL_Msk   (0xFUL << COMP_CSR_INMSEL_Pos)
#define COMP_CSR_INMSEL   COMP_CSR_INMSEL_Msk
#define COMP_CSR_INMSEL_0   (0x1UL << COMP_CSR_INMSEL_Pos)
#define COMP_CSR_INMSEL_1   (0x2UL << COMP_CSR_INMSEL_Pos)
#define COMP_CSR_INMSEL_2   (0x4UL << COMP_CSR_INMSEL_Pos)
#define COMP_CSR_INMSEL_3   (0x8UL << COMP_CSR_INMSEL_Pos)
#define COMP_CSR_INPSEL_Pos   (8U)
#define COMP_CSR_INPSEL_Msk   (0x3UL << COMP_CSR_INPSEL_Pos)
#define COMP_CSR_INPSEL   COMP_CSR_INPSEL_Msk
#define COMP_CSR_INPSEL_0   (0x1UL << COMP_CSR_INPSEL_Pos)
#define COMP_CSR_INPSEL_1   (0x2UL << COMP_CSR_INPSEL_Pos)
#define COMP_CSR_WINMODE_Pos   (11U)
#define COMP_CSR_WINMODE_Msk   (0x1UL << COMP_CSR_WINMODE_Pos)
#define COMP_CSR_WINMODE   COMP_CSR_WINMODE_Msk
#define COMP_CSR_WINOUT_Pos   (14U)
#define COMP_CSR_WINOUT_Msk   (0x1UL << COMP_CSR_WINOUT_Pos)
#define COMP_CSR_WINOUT   COMP_CSR_WINOUT_Msk
#define COMP_CSR_POLARITY_Pos   (15U)
#define COMP_CSR_POLARITY_Msk   (0x1UL << COMP_CSR_POLARITY_Pos)
#define COMP_CSR_POLARITY   COMP_CSR_POLARITY_Msk
#define COMP_CSR_HYST_Pos   (16U)
#define COMP_CSR_HYST_Msk   (0x3UL << COMP_CSR_HYST_Pos)
#define COMP_CSR_HYST   COMP_CSR_HYST_Msk
#define COMP_CSR_HYST_0   (0x1UL << COMP_CSR_HYST_Pos)
#define COMP_CSR_HYST_1   (0x2UL << COMP_CSR_HYST_Pos)
#define COMP_CSR_PWRMODE_Pos   (18U)
#define COMP_CSR_PWRMODE_Msk   (0x3UL << COMP_CSR_PWRMODE_Pos)
#define COMP_CSR_PWRMODE   COMP_CSR_PWRMODE_Msk
#define COMP_CSR_PWRMODE_0   (0x1UL << COMP_CSR_PWRMODE_Pos)
#define COMP_CSR_PWRMODE_1   (0x2UL << COMP_CSR_PWRMODE_Pos)
#define COMP_CSR_BLANKSEL_Pos   (20U)
#define COMP_CSR_BLANKSEL_Msk   (0x1FUL << COMP_CSR_BLANKSEL_Pos)
#define COMP_CSR_BLANKSEL   COMP_CSR_BLANKSEL_Msk
#define COMP_CSR_BLANKSEL_0   (0x01UL << COMP_CSR_BLANKSEL_Pos)
#define COMP_CSR_BLANKSEL_1   (0x02UL << COMP_CSR_BLANKSEL_Pos)
#define COMP_CSR_BLANKSEL_2   (0x04UL << COMP_CSR_BLANKSEL_Pos)
#define COMP_CSR_BLANKSEL_3   (0x08UL << COMP_CSR_BLANKSEL_Pos)
#define COMP_CSR_BLANKSEL_4   (0x10UL << COMP_CSR_BLANKSEL_Pos)
#define COMP_CSR_VALUE_Pos   (30U)
#define COMP_CSR_VALUE_Msk   (0x1UL << COMP_CSR_VALUE_Pos)
#define COMP_CSR_VALUE   COMP_CSR_VALUE_Msk
#define COMP_CSR_LOCK_Pos   (31U)
#define COMP_CSR_LOCK_Msk   (0x1UL << COMP_CSR_LOCK_Pos)
#define COMP_CSR_LOCK   COMP_CSR_LOCK_Msk
#define OPAMP_CSR_OPAEN_Pos   (0U)
#define OPAMP_CSR_OPAEN_Msk   (0x1UL << OPAMP_CSR_OPAEN_Pos)
#define OPAMP_CSR_OPAEN   OPAMP_CSR_OPAEN_Msk
#define OPAMP_CSR_OPALPM_Pos   (1U)
#define OPAMP_CSR_OPALPM_Msk   (0x1UL << OPAMP_CSR_OPALPM_Pos)
#define OPAMP_CSR_OPALPM   OPAMP_CSR_OPALPM_Msk
#define OPAMP_CSR_OPAMODE_Pos   (2U)
#define OPAMP_CSR_OPAMODE_Msk   (0x3UL << OPAMP_CSR_OPAMODE_Pos)
#define OPAMP_CSR_OPAMODE   OPAMP_CSR_OPAMODE_Msk
#define OPAMP_CSR_OPAMODE_0   (0x1UL << OPAMP_CSR_OPAMODE_Pos)
#define OPAMP_CSR_OPAMODE_1   (0x2UL << OPAMP_CSR_OPAMODE_Pos)
#define OPAMP_CSR_PGA_GAIN_Pos   (4U)
#define OPAMP_CSR_PGA_GAIN_Msk   (0x3UL << OPAMP_CSR_PGA_GAIN_Pos)
#define OPAMP_CSR_PGA_GAIN   OPAMP_CSR_PGA_GAIN_Msk
#define OPAMP_CSR_PGA_GAIN_0   (0x1UL << OPAMP_CSR_PGA_GAIN_Pos)
#define OPAMP_CSR_PGA_GAIN_1   (0x2UL << OPAMP_CSR_PGA_GAIN_Pos)
#define OPAMP_CSR_VM_SEL_Pos   (8U)
#define OPAMP_CSR_VM_SEL_Msk   (0x3UL << OPAMP_CSR_VM_SEL_Pos)
#define OPAMP_CSR_VM_SEL   OPAMP_CSR_VM_SEL_Msk
#define OPAMP_CSR_VM_SEL_0   (0x1UL << OPAMP_CSR_VM_SEL_Pos)
#define OPAMP_CSR_VM_SEL_1   (0x2UL << OPAMP_CSR_VM_SEL_Pos)
#define OPAMP_CSR_VP_SEL_Pos   (10U)
#define OPAMP_CSR_VP_SEL_Msk   (0x1UL << OPAMP_CSR_VP_SEL_Pos)
#define OPAMP_CSR_VP_SEL   OPAMP_CSR_VP_SEL_Msk
#define OPAMP_CSR_CALON_Pos   (12U)
#define OPAMP_CSR_CALON_Msk   (0x1UL << OPAMP_CSR_CALON_Pos)
#define OPAMP_CSR_CALON   OPAMP_CSR_CALON_Msk
#define OPAMP_CSR_CALSEL_Pos   (13U)
#define OPAMP_CSR_CALSEL_Msk   (0x1UL << OPAMP_CSR_CALSEL_Pos)
#define OPAMP_CSR_CALSEL   OPAMP_CSR_CALSEL_Msk
#define OPAMP_CSR_USERTRIM_Pos   (14U)
#define OPAMP_CSR_USERTRIM_Msk   (0x1UL << OPAMP_CSR_USERTRIM_Pos)
#define OPAMP_CSR_USERTRIM   OPAMP_CSR_USERTRIM_Msk
#define OPAMP_CSR_CALOUT_Pos   (15U)
#define OPAMP_CSR_CALOUT_Msk   (0x1UL << OPAMP_CSR_CALOUT_Pos)
#define OPAMP_CSR_CALOUT   OPAMP_CSR_CALOUT_Msk
#define OPAMP_CSR_HSM_Pos   (30U)
#define OPAMP_CSR_HSM_Msk   (0x1UL << OPAMP_CSR_HSM_Pos)
#define OPAMP_CSR_HSM   OPAMP_CSR_HSM_Msk
#define OPAMP_CSR_OPARANGE_Pos   (31U)
#define OPAMP_CSR_OPARANGE_Msk   (0x1UL << OPAMP_CSR_OPARANGE_Pos)
#define OPAMP_CSR_OPARANGE   OPAMP_CSR_OPARANGE_Msk
#define OPAMP_OTR_TRIMOFFSETN_Pos   (0U)
#define OPAMP_OTR_TRIMOFFSETN_Msk   (0x1FUL << OPAMP_OTR_TRIMOFFSETN_Pos)
#define OPAMP_OTR_TRIMOFFSETN   OPAMP_OTR_TRIMOFFSETN_Msk
#define OPAMP_OTR_TRIMOFFSETP_Pos   (8U)
#define OPAMP_OTR_TRIMOFFSETP_Msk   (0x1FUL << OPAMP_OTR_TRIMOFFSETP_Pos)
#define OPAMP_OTR_TRIMOFFSETP   OPAMP_OTR_TRIMOFFSETP_Msk
#define OPAMP_LPOTR_TRIMLPOFFSETN_Pos   (0U)
#define OPAMP_LPOTR_TRIMLPOFFSETN_Msk   (0x1FUL << OPAMP_LPOTR_TRIMLPOFFSETN_Pos)
#define OPAMP_LPOTR_TRIMLPOFFSETN   OPAMP_LPOTR_TRIMLPOFFSETN_Msk
#define OPAMP_LPOTR_TRIMLPOFFSETP_Pos   (8U)
#define OPAMP_LPOTR_TRIMLPOFFSETP_Msk   (0x1FUL << OPAMP_LPOTR_TRIMLPOFFSETP_Pos)
#define OPAMP_LPOTR_TRIMLPOFFSETP   OPAMP_LPOTR_TRIMLPOFFSETP_Msk
#define MDF_GCR_TRGO_Pos   (0U)
#define MDF_GCR_TRGO_Msk   (0x1UL << MDF_GCR_TRGO_Pos)
#define MDF_GCR_TRGO   MDF_GCR_TRGO_Msk
#define MDF_GCR_ILVNB_Pos   (4U)
#define MDF_GCR_ILVNB_Msk   (0xFUL << MDF_GCR_ILVNB_Pos)
#define MDF_GCR_ILVNB   MDF_GCR_ILVNB_Msk
#define MDF_CKGCR_CKDEN_Pos   (0U)
#define MDF_CKGCR_CKDEN_Msk   (0x1UL << MDF_CKGCR_CKDEN_Pos)
#define MDF_CKGCR_CKDEN   MDF_CKGCR_CKDEN_Msk
#define MDF_CKGCR_CCK0EN_Pos   (1U)
#define MDF_CKGCR_CCK0EN_Msk   (0x1UL << MDF_CKGCR_CCK0EN_Pos)
#define MDF_CKGCR_CCK0EN   MDF_CKGCR_CCK0EN_Msk
#define MDF_CKGCR_CCK1EN_Pos   (2U)
#define MDF_CKGCR_CCK1EN_Msk   (0x1UL << MDF_CKGCR_CCK1EN_Pos)
#define MDF_CKGCR_CCK1EN   MDF_CKGCR_CCK1EN_Msk
#define MDF_CKGCR_CKGMOD_Pos   (4U)
#define MDF_CKGCR_CKGMOD_Msk   (0x1UL << MDF_CKGCR_CKGMOD_Pos)
#define MDF_CKGCR_CKGMOD   MDF_CKGCR_CKGMOD_Msk
#define MDF_CKGCR_CCK0DIR_Pos   (5U)
#define MDF_CKGCR_CCK0DIR_Msk   (0x1UL << MDF_CKGCR_CCK0DIR_Pos)
#define MDF_CKGCR_CCK0DIR   MDF_CKGCR_CCK0DIR_Msk
#define MDF_CKGCR_CCK1DIR_Pos   (6U)
#define MDF_CKGCR_CCK1DIR_Msk   (0x1UL << MDF_CKGCR_CCK1DIR_Pos)
#define MDF_CKGCR_CCK1DIR   MDF_CKGCR_CCK1DIR_Msk
#define MDF_CKGCR_TRGSENS_Pos   (8U)
#define MDF_CKGCR_TRGSENS_Msk   (0x1UL << MDF_CKGCR_TRGSENS_Pos)
#define MDF_CKGCR_TRGSENS   MDF_CKGCR_TRGSENS_Msk
#define MDF_CKGCR_TRGSRC_Pos   (12U)
#define MDF_CKGCR_TRGSRC_Msk   (0xFUL << MDF_CKGCR_TRGSRC_Pos)
#define MDF_CKGCR_TRGSRC   MDF_CKGCR_TRGSRC_Msk
#define MDF_CKGCR_TRGSRC_0   (0x1UL << MDF_CKGCR_TRGSRC_Pos)
#define MDF_CKGCR_TRGSRC_1   (0x2UL << MDF_CKGCR_TRGSRC_Pos)
#define MDF_CKGCR_TRGSRC_2   (0x4UL << MDF_CKGCR_TRGSRC_Pos)
#define MDF_CKGCR_TRGSRC_3   (0x8UL << MDF_CKGCR_TRGSRC_Pos)
#define MDF_CKGCR_CCKDIV_Pos   (16U)
#define MDF_CKGCR_CCKDIV_Msk   (0xFUL << MDF_CKGCR_CCKDIV_Pos)
#define MDF_CKGCR_CCKDIV   MDF_CKGCR_CCKDIV_Msk
#define MDF_CKGCR_PROCDIV_Pos   (24U)
#define MDF_CKGCR_PROCDIV_Msk   (0x7FUL << MDF_CKGCR_PROCDIV_Pos)
#define MDF_CKGCR_PROCDIV   MDF_CKGCR_PROCDIV_Msk
#define MDF_CKGCR_CCKACTIVE_Pos   (31U)
#define MDF_CKGCR_CCKACTIVE_Msk   (0x1UL << MDF_CKGCR_CCKACTIVE_Pos)
#define MDF_CKGCR_CCKACTIVE   MDF_CKGCR_CCKACTIVE_Msk
#define MDF_OR_OPTION_Pos   (0U)
#define MDF_OR_OPTION_Msk   (0xFFFFFFFFUL << MDF_OR_OPTION_Pos)
#define MDF_OR_OPTION   MDF_OR_OPTION_Msk
#define MDF_SITFCR_SITFEN_Pos   (0U)
#define MDF_SITFCR_SITFEN_Msk   (0x1UL << MDF_SITFCR_SITFEN_Pos)
#define MDF_SITFCR_SITFEN   MDF_SITFCR_SITFEN_Msk
#define MDF_SITFCR_SCKSRC_Pos   (1U)
#define MDF_SITFCR_SCKSRC_Msk   (0x3UL << MDF_SITFCR_SCKSRC_Pos)
#define MDF_SITFCR_SCKSRC   MDF_SITFCR_SCKSRC_Msk
#define MDF_SITFCR_SCKSRC_0   (0x1UL << MDF_SITFCR_SCKSRC_Pos)
#define MDF_SITFCR_SCKSRC_1   (0x2UL << MDF_SITFCR_SCKSRC_Pos)
#define MDF_SITFCR_SITFMOD_Pos   (4U)
#define MDF_SITFCR_SITFMOD_Msk   (0x3UL << MDF_SITFCR_SITFMOD_Pos)
#define MDF_SITFCR_SITFMOD   MDF_SITFCR_SITFMOD_Msk
#define MDF_SITFCR_SITFMOD_0   (0x1UL << MDF_SITFCR_SITFMOD_Pos)
#define MDF_SITFCR_SITFMOD_1   (0x2UL << MDF_SITFCR_SITFMOD_Pos)
#define MDF_SITFCR_STH_Pos   (8U)
#define MDF_SITFCR_STH_Msk   (0x1FUL << MDF_SITFCR_STH_Pos)
#define MDF_SITFCR_STH   MDF_SITFCR_STH_Msk
#define MDF_SITFCR_SITFACTIVE_Pos   (31U)
#define MDF_SITFCR_SITFACTIVE_Msk   (0x1UL << MDF_SITFCR_SITFACTIVE_Pos)
#define MDF_SITFCR_SITFACTIVE   MDF_SITFCR_SITFACTIVE_Msk
#define MDF_BSMXCR_BSSEL_Pos   (0U)
#define MDF_BSMXCR_BSSEL_Msk   (0x1FUL << MDF_BSMXCR_BSSEL_Pos)
#define MDF_BSMXCR_BSSEL   MDF_BSMXCR_BSSEL_Msk
#define MDF_BSMXCR_BSSEL_0   (0x1UL << MDF_BSMXCR_BSSEL_Pos)
#define MDF_BSMXCR_BSSEL_1   (0x2UL << MDF_BSMXCR_BSSEL_Pos)
#define MDF_BSMXCR_BSSEL_2   (0x4UL << MDF_BSMXCR_BSSEL_Pos)
#define MDF_BSMXCR_BSSEL_3   (0x8UL << MDF_BSMXCR_BSSEL_Pos)
#define MDF_BSMXCR_BSSEL_4   (0x10UL << MDF_BSMXCR_BSSEL_Pos)
#define MDF_BSMXCR_BSMXACTIVATE_Pos   (31U)
#define MDF_BSMXCR_BSMXACTIVATE_Msk   (0x1UL << MDF_BSMXCR_BSMXACTIVATE_Pos)
#define MDF_BSMXCR_BSMXACTIVATE   MDF_BSMXCR_BSMXACTIVATE_Msk
#define MDF_DFLTCR_DFLTEN_Pos   (0U)
#define MDF_DFLTCR_DFLTEN_Msk   (0x1UL << MDF_DFLTCR_DFLTEN_Pos)
#define MDF_DFLTCR_DFLTEN   MDF_DFLTCR_DFLTEN_Msk
#define MDF_DFLTCR_DMAEN_Pos   (1U)
#define MDF_DFLTCR_DMAEN_Msk   (0x1UL << MDF_DFLTCR_DMAEN_Pos)
#define MDF_DFLTCR_DMAEN   MDF_DFLTCR_DMAEN_Msk
#define MDF_DFLTCR_FTH_Pos   (2U)
#define MDF_DFLTCR_FTH_Msk   (0x1UL << MDF_DFLTCR_FTH_Pos)
#define MDF_DFLTCR_FTH   MDF_DFLTCR_FTH_Msk
#define MDF_DFLTCR_ACQMOD_Pos   (4U)
#define MDF_DFLTCR_ACQMOD_Msk   (0x7UL << MDF_DFLTCR_ACQMOD_Pos)
#define MDF_DFLTCR_ACQMOD   MDF_DFLTCR_ACQMOD_Msk
#define MDF_DFLTCR_ACQMOD_0   (0x1UL << MDF_DFLTCR_ACQMOD_Pos)
#define MDF_DFLTCR_ACQMOD_1   (0x2UL << MDF_DFLTCR_ACQMOD_Pos)
#define MDF_DFLTCR_ACQMOD_2   (0x4UL << MDF_DFLTCR_ACQMOD_Pos)
#define MDF_DFLTCR_TRGSENS_Pos   (8U)
#define MDF_DFLTCR_TRGSENS_Msk   (0x1UL << MDF_DFLTCR_TRGSENS_Pos)
#define MDF_DFLTCR_TRGSENS   MDF_DFLTCR_TRGSENS_Msk
#define MDF_DFLTCR_TRGSRC_Pos   (12U)
#define MDF_DFLTCR_TRGSRC_Msk   (0xFUL << MDF_DFLTCR_TRGSRC_Pos)
#define MDF_DFLTCR_TRGSRC   MDF_DFLTCR_TRGSRC_Msk
#define MDF_DFLTCR_TRGSRC_0   (0x1UL << MDF_DFLTCR_TRGSRC_Pos)
#define MDF_DFLTCR_TRGSRC_1   (0x2UL << MDF_DFLTCR_TRGSRC_Pos)
#define MDF_DFLTCR_TRGSRC_2   (0x4UL << MDF_DFLTCR_TRGSRC_Pos)
#define MDF_DFLTCR_TRGSRC_3   (0x8UL << MDF_DFLTCR_TRGSRC_Pos)
#define MDF_DFLTCR_SNPSFMT_Pos   (16U)
#define MDF_DFLTCR_SNPSFMT_Msk   (0x1UL << MDF_DFLTCR_SNPSFMT_Pos)
#define MDF_DFLTCR_SNPSFMT   MDF_DFLTCR_SNPSFMT_Msk
#define MDF_DFLTCR_NBDIS_Pos   (20U)
#define MDF_DFLTCR_NBDIS_Msk   (0xFFUL << MDF_DFLTCR_NBDIS_Pos)
#define MDF_DFLTCR_NBDIS   MDF_DFLTCR_NBDIS_Msk
#define MDF_DFLTCR_DFLTRUN_Pos   (30U)
#define MDF_DFLTCR_DFLTRUN_Msk   (0x1UL << MDF_DFLTCR_DFLTRUN_Pos)
#define MDF_DFLTCR_DFLTRUN   MDF_DFLTCR_DFLTRUN_Msk
#define MDF_DFLTCR_DFLTACTIVE_Pos   (31U)
#define MDF_DFLTCR_DFLTACTIVE_Msk   (0x1UL << MDF_DFLTCR_DFLTACTIVE_Pos)
#define MDF_DFLTCR_DFLTACTIVE   MDF_DFLTCR_DFLTACTIVE_Msk
#define MDF_DFLTCICR_DATSRC_Pos   (0U)
#define MDF_DFLTCICR_DATSRC_Msk   (0x3UL << MDF_DFLTCICR_DATSRC_Pos)
#define MDF_DFLTCICR_DATSRC   MDF_DFLTCICR_DATSRC_Msk
#define MDF_DFLTCICR_DATSRC_0   (0x1UL << MDF_DFLTCICR_DATSRC_Pos)
#define MDF_DFLTCICR_DATSRC_1   (0x2UL << MDF_DFLTCICR_DATSRC_Pos)
#define MDF_DFLTCICR_CICMOD_Pos   (4U)
#define MDF_DFLTCICR_CICMOD_Msk   (0x7UL << MDF_DFLTCICR_CICMOD_Pos)
#define MDF_DFLTCICR_CICMOD   MDF_DFLTCICR_CICMOD_Msk
#define MDF_DFLTCICR_CICMOD_0   (0x1UL << MDF_DFLTCICR_CICMOD_Pos)
#define MDF_DFLTCICR_CICMOD_1   (0x2UL << MDF_DFLTCICR_CICMOD_Pos)
#define MDF_DFLTCICR_CICMOD_2   (0x4UL << MDF_DFLTCICR_CICMOD_Pos)
#define MDF_DFLTCICR_MCICD_Pos   (8U)
#define MDF_DFLTCICR_MCICD_Msk   (0x1FFUL << MDF_DFLTCICR_MCICD_Pos)
#define MDF_DFLTCICR_MCICD   MDF_DFLTCICR_MCICD_Msk
#define MDF_DFLTCICR_SCALE_Pos   (20U)
#define MDF_DFLTCICR_SCALE_Msk   (0x3FUL << MDF_DFLTCICR_SCALE_Pos)
#define MDF_DFLTCICR_SCALE   MDF_DFLTCICR_SCALE_Msk
#define MDF_DFLTRSFR_RSFLTBYP_Pos   (0U)
#define MDF_DFLTRSFR_RSFLTBYP_Msk   (0x1UL << MDF_DFLTRSFR_RSFLTBYP_Pos)
#define MDF_DFLTRSFR_RSFLTBYP   MDF_DFLTRSFR_RSFLTBYP_Msk
#define MDF_DFLTRSFR_RSFLTD_Pos   (4U)
#define MDF_DFLTRSFR_RSFLTD_Msk   (0x1UL << MDF_DFLTRSFR_RSFLTD_Pos)
#define MDF_DFLTRSFR_RSFLTD   MDF_DFLTRSFR_RSFLTD_Msk
#define MDF_DFLTRSFR_HPFBYP_Pos   (7U)
#define MDF_DFLTRSFR_HPFBYP_Msk   (0x1UL << MDF_DFLTRSFR_HPFBYP_Pos)
#define MDF_DFLTRSFR_HPFBYP   MDF_DFLTRSFR_HPFBYP_Msk
#define MDF_DFLTRSFR_HPFC_Pos   (8U)
#define MDF_DFLTRSFR_HPFC_Msk   (0x3UL << MDF_DFLTRSFR_HPFC_Pos)
#define MDF_DFLTRSFR_HPFC   MDF_DFLTRSFR_HPFC_Msk
#define MDF_DFLTRSFR_HPFC_0   (0x1UL << MDF_DFLTRSFR_HPFC_Pos)
#define MDF_DFLTRSFR_HPFC_1   (0x2UL << MDF_DFLTRSFR_HPFC_Pos)
#define MDF_DFLTINTR_INTDIV_Pos   (0U)
#define MDF_DFLTINTR_INTDIV_Msk   (0x3UL << MDF_DFLTINTR_INTDIV_Pos)
#define MDF_DFLTINTR_INTDIV   MDF_DFLTINTR_INTDIV_Msk
#define MDF_DFLTINTR_INTDIV_0   (0x1UL << MDF_DFLTINTR_INTDIV_Pos)
#define MDF_DFLTINTR_INTDIV_1   (0x2UL << MDF_DFLTINTR_INTDIV_Pos)
#define MDF_DFLTINTR_INTVAL_Pos   (4U)
#define MDF_DFLTINTR_INTVAL_Msk   (0x7FUL << MDF_DFLTINTR_INTVAL_Pos)
#define MDF_DFLTINTR_INTVAL   MDF_DFLTINTR_INTVAL_Msk
#define MDF_OLDCR_OLDEN_Pos   (0U)
#define MDF_OLDCR_OLDEN_Msk   (0x1UL << MDF_OLDCR_OLDEN_Pos)
#define MDF_OLDCR_OLDEN   MDF_OLDCR_OLDEN_Msk
#define MDF_OLDCR_THINB_Pos   (1U)
#define MDF_OLDCR_THINB_Msk   (0x1UL << MDF_OLDCR_THINB_Pos)
#define MDF_OLDCR_THINB   MDF_OLDCR_THINB_Msk
#define MDF_OLDCR_BKOLD_Pos   (4U)
#define MDF_OLDCR_BKOLD_Msk   (0xFUL << MDF_OLDCR_BKOLD_Pos)
#define MDF_OLDCR_BKOLD   MDF_OLDCR_BKOLD_Msk
#define MDF_OLDCR_BKOLD_0   (0x1UL << MDF_OLDCR_BKOLD_Pos)
#define MDF_OLDCR_BKOLD_1   (0x2UL << MDF_OLDCR_BKOLD_Pos)
#define MDF_OLDCR_BKOLD_2   (0x4UL << MDF_OLDCR_BKOLD_Pos)
#define MDF_OLDCR_BKOLD_3   (0x8UL << MDF_OLDCR_BKOLD_Pos)
#define MDF_OLDCR_ACICN_Pos   (12U)
#define MDF_OLDCR_ACICN_Msk   (0x3UL << MDF_OLDCR_ACICN_Pos)
#define MDF_OLDCR_ACICN   MDF_OLDCR_ACICN_Msk
#define MDF_OLDCR_ACICN_0   (0x1UL << MDF_OLDCR_ACICN_Pos)
#define MDF_OLDCR_ACICN_1   (0x2UL << MDF_OLDCR_ACICN_Pos)
#define MDF_OLDCR_ACICD_Pos   (17U)
#define MDF_OLDCR_ACICD_Msk   (0x1FUL << MDF_OLDCR_ACICD_Pos)
#define MDF_OLDCR_ACICD   MDF_OLDCR_ACICD_Msk
#define MDF_OLDCR_OLDACTIVE_Pos   (31U)
#define MDF_OLDCR_OLDACTIVE_Msk   (0x1UL << MDF_OLDCR_OLDACTIVE_Pos)
#define MDF_OLDCR_OLDACTIVE   MDF_OLDCR_OLDACTIVE_Msk
#define MDF_OLDTHLR_OLDTHL_Pos   (0U)
#define MDF_OLDTHLR_OLDTHL_Msk   (0x3FFFFFFUL << MDF_OLDTHLR_OLDTHL_Pos)
#define MDF_OLDTHLR_OLDTHL   MDF_OLDTHLR_OLDTHL_Msk
#define MDF_OLDTHHR_OLDTHH_Pos   (0U)
#define MDF_OLDTHHR_OLDTHH_Msk   (0x3FFFFFFUL << MDF_OLDTHHR_OLDTHH_Pos)
#define MDF_OLDTHHR_OLDTHH   MDF_OLDTHHR_OLDTHH_Msk
#define MDF_DLYCR_SKPDLY_Pos   (0U)
#define MDF_DLYCR_SKPDLY_Msk   (0x7FUL << MDF_DLYCR_SKPDLY_Pos)
#define MDF_DLYCR_SKPDLY   MDF_DLYCR_SKPDLY_Msk
#define MDF_DLYCR_SKPBF_Pos   (31U)
#define MDF_DLYCR_SKPBF_Msk   (0x1UL << MDF_DLYCR_SKPBF_Pos)
#define MDF_DLYCR_SKPBF   MDF_DLYCR_SKPBF_Msk
#define MDF_SCDCR_SCDEN_Pos   (0U)
#define MDF_SCDCR_SCDEN_Msk   (0x1UL << MDF_SCDCR_SCDEN_Pos)
#define MDF_SCDCR_SCDEN   MDF_SCDCR_SCDEN_Msk
#define MDF_SCDCR_BKSCD_Pos   (4U)
#define MDF_SCDCR_BKSCD_Msk   (0xFUL << MDF_SCDCR_BKSCD_Pos)
#define MDF_SCDCR_BKSCD   MDF_SCDCR_BKSCD_Msk
#define MDF_SCDCR_BKSCD_0   (0x1UL << MDF_SCDCR_BKSCD_Pos)
#define MDF_SCDCR_BKSCD_1   (0x2UL << MDF_SCDCR_BKSCD_Pos)
#define MDF_SCDCR_BKSCD_2   (0x4UL << MDF_SCDCR_BKSCD_Pos)
#define MDF_SCDCR_BKSCD_3   (0x8UL << MDF_SCDCR_BKSCD_Pos)
#define MDF_SCDCR_SCDT_Pos   (12U)
#define MDF_SCDCR_SCDT_Msk   (0xFFUL << MDF_SCDCR_SCDT_Pos)
#define MDF_SCDCR_SCDT   MDF_SCDCR_SCDT_Msk
#define MDF_SCDCR_SCDACTIVE_Pos   (31U)
#define MDF_SCDCR_SCDACTIVE_Msk   (0x1UL << MDF_SCDCR_SCDACTIVE_Pos)
#define MDF_SCDCR_SCDACTIVE   MDF_SCDCR_SCDACTIVE_Msk
#define MDF_DFLTIER_FTHIE_Pos   (0U)
#define MDF_DFLTIER_FTHIE_Msk   (0x1UL << MDF_DFLTIER_FTHIE_Pos)
#define MDF_DFLTIER_FTHIE   MDF_DFLTIER_FTHIE_Msk
#define MDF_DFLTIER_DOVRIE_Pos   (1U)
#define MDF_DFLTIER_DOVRIE_Msk   (0x1UL << MDF_DFLTIER_DOVRIE_Pos)
#define MDF_DFLTIER_DOVRIE   MDF_DFLTIER_DOVRIE_Msk
#define MDF_DFLTIER_SSDRIE_Pos   (2U)
#define MDF_DFLTIER_SSDRIE_Msk   (0x1UL << MDF_DFLTIER_SSDRIE_Pos)
#define MDF_DFLTIER_SSDRIE   MDF_DFLTIER_SSDRIE_Msk
#define MDF_DFLTIER_OLDIE_Pos   (4U)
#define MDF_DFLTIER_OLDIE_Msk   (0x1UL << MDF_DFLTIER_OLDIE_Pos)
#define MDF_DFLTIER_OLDIE   MDF_DFLTIER_OLDIE_Msk
#define MDF_DFLTIER_SSOVRIE_Pos   (7U)
#define MDF_DFLTIER_SSOVRIE_Msk   (0x1UL << MDF_DFLTIER_SSOVRIE_Pos)
#define MDF_DFLTIER_SSOVRIE   MDF_DFLTIER_SSOVRIE_Msk
#define MDF_DFLTIER_SCDIE_Pos   (8U)
#define MDF_DFLTIER_SCDIE_Msk   (0x1UL << MDF_DFLTIER_SCDIE_Pos)
#define MDF_DFLTIER_SCDIE   MDF_DFLTIER_SCDIE_Msk
#define MDF_DFLTIER_SATIE_Pos   (9U)
#define MDF_DFLTIER_SATIE_Msk   (0x1UL << MDF_DFLTIER_SATIE_Pos)
#define MDF_DFLTIER_SATIE   MDF_DFLTIER_SATIE_Msk
#define MDF_DFLTIER_CKABIE_Pos   (10U)
#define MDF_DFLTIER_CKABIE_Msk   (0x1UL << MDF_DFLTIER_CKABIE_Pos)
#define MDF_DFLTIER_CKABIE   MDF_DFLTIER_CKABIE_Msk
#define MDF_DFLTIER_RFOVRIE_Pos   (11U)
#define MDF_DFLTIER_RFOVRIE_Msk   (0x1UL << MDF_DFLTIER_RFOVRIE_Pos)
#define MDF_DFLTIER_RFOVRIE   MDF_DFLTIER_RFOVRIE_Msk
#define MDF_DFLTIER_SDDETIE_Pos   (12U)
#define MDF_DFLTIER_SDDETIE_Msk   (0x1UL << MDF_DFLTIER_SDDETIE_Pos)
#define MDF_DFLTIER_SDDETIE   MDF_DFLTIER_SDDETIE_Msk
#define MDF_DFLTIER_SDLVLIE_Pos   (13U)
#define MDF_DFLTIER_SDLVLIE_Msk   (0x1UL << MDF_DFLTIER_SDLVLIE_Pos)
#define MDF_DFLTIER_SDLVLIE   MDF_DFLTIER_SDLVLIE_Msk
#define MDF_DFLTISR_FTHF_Pos   (0U)
#define MDF_DFLTISR_FTHF_Msk   (0x1UL << MDF_DFLTISR_FTHF_Pos)
#define MDF_DFLTISR_FTHF   MDF_DFLTISR_FTHF_Msk
#define MDF_DFLTISR_DOVRF_Pos   (1U)
#define MDF_DFLTISR_DOVRF_Msk   (0x1UL << MDF_DFLTISR_DOVRF_Pos)
#define MDF_DFLTISR_DOVRF   MDF_DFLTISR_DOVRF_Msk
#define MDF_DFLTISR_SSDRF_Pos   (2U)
#define MDF_DFLTISR_SSDRF_Msk   (0x1UL << MDF_DFLTISR_SSDRF_Pos)
#define MDF_DFLTISR_SSDRF   MDF_DFLTISR_SSDRF_Msk
#define MDF_DFLTISR_RXNEF_Pos   (3U)
#define MDF_DFLTISR_RXNEF_Msk   (0x1UL << MDF_DFLTISR_RXNEF_Pos)
#define MDF_DFLTISR_RXNEF   MDF_DFLTISR_RXNEF_Msk
#define MDF_DFLTISR_OLDF_Pos   (4U)
#define MDF_DFLTISR_OLDF_Msk   (0x1UL << MDF_DFLTISR_OLDF_Pos)
#define MDF_DFLTISR_OLDF   MDF_DFLTISR_OLDF_Msk
#define MDF_DFLTISR_THLF_Pos   (5U)
#define MDF_DFLTISR_THLF_Msk   (0x1UL << MDF_DFLTISR_THLF_Pos)
#define MDF_DFLTISR_THLF   MDF_DFLTISR_THLF_Msk
#define MDF_DFLTISR_THHF_Pos   (6U)
#define MDF_DFLTISR_THHF_Msk   (0x1UL << MDF_DFLTISR_THHF_Pos)
#define MDF_DFLTISR_THHF   MDF_DFLTISR_THHF_Msk
#define MDF_DFLTISR_SSOVRF_Pos   (7U)
#define MDF_DFLTISR_SSOVRF_Msk   (0x1UL << MDF_DFLTISR_SSOVRF_Pos)
#define MDF_DFLTISR_SSOVRF   MDF_DFLTISR_SSOVRF_Msk
#define MDF_DFLTISR_SCDF_Pos   (8U)
#define MDF_DFLTISR_SCDF_Msk   (0x1UL << MDF_DFLTISR_SCDF_Pos)
#define MDF_DFLTISR_SCDF   MDF_DFLTISR_SCDF_Msk
#define MDF_DFLTISR_SATF_Pos   (9U)
#define MDF_DFLTISR_SATF_Msk   (0x1UL << MDF_DFLTISR_SATF_Pos)
#define MDF_DFLTISR_SATF   MDF_DFLTISR_SATF_Msk
#define MDF_DFLTISR_CKABF_Pos   (10U)
#define MDF_DFLTISR_CKABF_Msk   (0x1UL << MDF_DFLTISR_CKABF_Pos)
#define MDF_DFLTISR_CKABF   MDF_DFLTISR_CKABF_Msk
#define MDF_DFLTISR_RFOVRF_Pos   (11U)
#define MDF_DFLTISR_RFOVRF_Msk   (0x1UL << MDF_DFLTISR_RFOVRF_Pos)
#define MDF_DFLTISR_RFOVRF   MDF_DFLTISR_RFOVRF_Msk
#define MDF_DFLTISR_SDDETF_Pos   (12U)
#define MDF_DFLTISR_SDDETF_Msk   (0x1UL << MDF_DFLTISR_SDDETF_Pos)
#define MDF_DFLTISR_SDDETF   MDF_DFLTISR_SDDETF_Msk
#define MDF_DFLTISR_SDLVLF_Pos   (13U)
#define MDF_DFLTISR_SDLVLF_Msk   (0x1UL << MDF_DFLTISR_SDLVLF_Pos)
#define MDF_DFLTISR_SDLVLF   MDF_DFLTISR_SDLVLF_Msk
#define MDF_OECCR_OFFSET_Pos   (0U)
#define MDF_OECCR_OFFSET_Msk   (0x3FFFFFFUL << MDF_OECCR_OFFSET_Pos)
#define MDF_OECCR_OFFSET   MDF_OECCR_OFFSET_Msk
#define MDF_SADCR_SADEN_Pos   (0U)
#define MDF_SADCR_SADEN_Msk   (0x1UL << MDF_SADCR_SADEN_Pos)
#define MDF_SADCR_SADEN   MDF_SADCR_SADEN_Msk
#define MDF_SADCR_DATCAP_Pos   (1U)
#define MDF_SADCR_DATCAP_Msk   (0x3UL << MDF_SADCR_DATCAP_Pos)
#define MDF_SADCR_DATCAP   MDF_SADCR_DATCAP_Msk
#define MDF_SADCR_DATCAP_0   (0x1UL << MDF_SADCR_DATCAP_Pos)
#define MDF_SADCR_DATCAP_1   (0x2UL << MDF_SADCR_DATCAP_Pos)
#define MDF_SADCR_DETCFG_Pos   (3U)
#define MDF_SADCR_DETCFG_Msk   (0x1UL << MDF_SADCR_DETCFG_Pos)
#define MDF_SADCR_DETCFG   MDF_SADCR_DETCFG_Msk
#define MDF_SADCR_SADST_Pos   (4U)
#define MDF_SADCR_SADST_Msk   (0x3UL << MDF_SADCR_SADST_Pos)
#define MDF_SADCR_SADST   MDF_SADCR_SADST_Msk
#define MDF_SADCR_HYSTEN_Pos   (7U)
#define MDF_SADCR_HYSTEN_Msk   (0x1UL << MDF_SADCR_HYSTEN_Pos)
#define MDF_SADCR_HYSTEN   MDF_SADCR_HYSTEN_Msk
#define MDF_SADCR_FRSIZE_Pos   (8U)
#define MDF_SADCR_FRSIZE_Msk   (0x7UL << MDF_SADCR_FRSIZE_Pos)
#define MDF_SADCR_FRSIZE   MDF_SADCR_FRSIZE_Msk
#define MDF_SADCR_FRSIZE_0   (0x1UL << MDF_SADCR_FRSIZE_Pos)
#define MDF_SADCR_FRSIZE_1   (0x2UL << MDF_SADCR_FRSIZE_Pos)
#define MDF_SADCR_FRSIZE_2   (0x4UL << MDF_SADCR_FRSIZE_Pos)
#define MDF_SADCR_SADMOD_Pos   (12U)
#define MDF_SADCR_SADMOD_Msk   (0x3UL << MDF_SADCR_SADMOD_Pos)
#define MDF_SADCR_SADMOD   MDF_SADCR_SADMOD_Msk
#define MDF_SADCR_SADMOD_0   (0x1UL << MDF_SADCR_SADMOD_Pos)
#define MDF_SADCR_SADMOD_1   (0x2UL << MDF_SADCR_SADMOD_Pos)
#define MDF_SADCR_SADACTIVE_Pos   (31U)
#define MDF_SADCR_SADACTIVE_Msk   (0x1UL << MDF_SADCR_SADACTIVE_Pos)
#define MDF_SADCR_SADACTIVE   MDF_SADCR_SADACTIVE_Msk
#define MDF_SADCFGR_SNTHR_Pos   (0U)
#define MDF_SADCFGR_SNTHR_Msk   (0xFUL << MDF_SADCFGR_SNTHR_Pos)
#define MDF_SADCFGR_SNTHR   MDF_SADCFGR_SNTHR_Msk
#define MDF_SADCFGR_SNTHR_0   (0x1UL << MDF_SADCFGR_SNTHR_Pos)
#define MDF_SADCFGR_SNTHR_1   (0x2UL << MDF_SADCFGR_SNTHR_Pos)
#define MDF_SADCFGR_SNTHR_2   (0x4UL << MDF_SADCFGR_SNTHR_Pos)
#define MDF_SADCFGR_SNTHR_3   (0x8UL << MDF_SADCFGR_SNTHR_Pos)
#define MDF_SADCFGR_ANSLP_Pos   (4U)
#define MDF_SADCFGR_ANSLP_Msk   (0x7UL << MDF_SADCFGR_ANSLP_Pos)
#define MDF_SADCFGR_ANSLP   MDF_SADCFGR_ANSLP_Msk
#define MDF_SADCFGR_LFRNB_Pos   (8U)
#define MDF_SADCFGR_LFRNB_Msk   (0x7UL << MDF_SADCFGR_LFRNB_Pos)
#define MDF_SADCFGR_LFRNB   MDF_SADCFGR_LFRNB_Msk
#define MDF_SADCFGR_LFRNB_0   (0x1UL << MDF_SADCFGR_LFRNB_Pos)
#define MDF_SADCFGR_LFRNB_1   (0x2UL << MDF_SADCFGR_LFRNB_Pos)
#define MDF_SADCFGR_LFRNB_2   (0x4UL << MDF_SADCFGR_LFRNB_Pos)
#define MDF_SADCFGR_HGOVR_Pos   (12U)
#define MDF_SADCFGR_HGOVR_Msk   (0x7UL << MDF_SADCFGR_HGOVR_Pos)
#define MDF_SADCFGR_HGOVR   MDF_SADCFGR_HGOVR_Msk
#define MDF_SADCFGR_HGOVR_0   (0x1UL << MDF_SADCFGR_HGOVR_Pos)
#define MDF_SADCFGR_HGOVR_1   (0x2UL << MDF_SADCFGR_HGOVR_Pos)
#define MDF_SADCFGR_HGOVR_2   (0x4UL << MDF_SADCFGR_HGOVR_Pos)
#define MDF_SADCFGR_ANMIN_Pos   (16U)
#define MDF_SADCFGR_ANMIN_Msk   (0x1FFFUL << MDF_SADCFGR_ANMIN_Pos)
#define MDF_SADCFGR_ANMIN   MDF_SADCFGR_ANMIN_Msk
#define MDF_SADSDLVR_SDLVL_Pos   (0U)
#define MDF_SADSDLVR_SDLVL_Msk   (0x7FFFUL << MDF_SADSDLVR_SDLVL_Pos)
#define MDF_SADSDLVR_SDLVL   MDF_SADSDLVR_SDLVL_Msk
#define MDF_SADANLVR_ANLVL_Pos   (0U)
#define MDF_SADANLVR_ANLVL_Msk   (0x7FFFUL << MDF_SADANLVR_ANLVL_Pos)
#define MDF_SADANLVR_ANLVL   MDF_SADANLVR_ANLVL_Msk
#define MDF_SNPSDR_MCICDC_Pos   (0U)
#define MDF_SNPSDR_MCICDC_Msk   (0x1FFUL << MDF_SNPSDR_MCICDC_Pos)
#define MDF_SNPSDR_MCICDC   MDF_SNPSDR_MCICDC_Msk
#define MDF_SNPSDR_EXTSDR_Pos   (9U)
#define MDF_SNPSDR_EXTSDR_Msk   (0x7FUL << MDF_SNPSDR_EXTSDR_Pos)
#define MDF_SNPSDR_EXTSDR   MDF_SNPSDR_EXTSDR_Msk
#define MDF_SNPSDR_SDR_Pos   (16U)
#define MDF_SNPSDR_SDR_Msk   (0xFFFFUL << MDF_SNPSDR_SDR_Pos)
#define MDF_SNPSDR_SDR   MDF_SNPSDR_SDR_Msk
#define MDF_DFLTDR_DR_Pos   (8U)
#define MDF_DFLTDR_DR_Msk   (0xFFFFFFUL << MDF_DFLTDR_DR_Pos)
#define MDF_DFLTDR_DR   MDF_DFLTDR_DR_Msk
#define TIM_CR1_CEN_Pos   (0U)
#define TIM_CR1_CEN_Msk   (0x1UL << TIM_CR1_CEN_Pos)
#define TIM_CR1_CEN   TIM_CR1_CEN_Msk
#define TIM_CR1_UDIS_Pos   (1U)
#define TIM_CR1_UDIS_Msk   (0x1UL << TIM_CR1_UDIS_Pos)
#define TIM_CR1_UDIS   TIM_CR1_UDIS_Msk
#define TIM_CR1_URS_Pos   (2U)
#define TIM_CR1_URS_Msk   (0x1UL << TIM_CR1_URS_Pos)
#define TIM_CR1_URS   TIM_CR1_URS_Msk
#define TIM_CR1_OPM_Pos   (3U)
#define TIM_CR1_OPM_Msk   (0x1UL << TIM_CR1_OPM_Pos)
#define TIM_CR1_OPM   TIM_CR1_OPM_Msk
#define TIM_CR1_DIR_Pos   (4U)
#define TIM_CR1_DIR_Msk   (0x1UL << TIM_CR1_DIR_Pos)
#define TIM_CR1_DIR   TIM_CR1_DIR_Msk
#define TIM_CR1_CMS_Pos   (5U)
#define TIM_CR1_CMS_Msk   (0x3UL << TIM_CR1_CMS_Pos)
#define TIM_CR1_CMS   TIM_CR1_CMS_Msk
#define TIM_CR1_CMS_0   (0x1UL << TIM_CR1_CMS_Pos)
#define TIM_CR1_CMS_1   (0x2UL << TIM_CR1_CMS_Pos)
#define TIM_CR1_ARPE_Pos   (7U)
#define TIM_CR1_ARPE_Msk   (0x1UL << TIM_CR1_ARPE_Pos)
#define TIM_CR1_ARPE   TIM_CR1_ARPE_Msk
#define TIM_CR1_CKD_Pos   (8U)
#define TIM_CR1_CKD_Msk   (0x3UL << TIM_CR1_CKD_Pos)
#define TIM_CR1_CKD   TIM_CR1_CKD_Msk
#define TIM_CR1_CKD_0   (0x1UL << TIM_CR1_CKD_Pos)
#define TIM_CR1_CKD_1   (0x2UL << TIM_CR1_CKD_Pos)
#define TIM_CR1_UIFREMAP_Pos   (11U)
#define TIM_CR1_UIFREMAP_Msk   (0x1UL << TIM_CR1_UIFREMAP_Pos)
#define TIM_CR1_UIFREMAP   TIM_CR1_UIFREMAP_Msk
#define TIM_CR1_DITHEN_Pos   (12U)
#define TIM_CR1_DITHEN_Msk   (0x1UL << TIM_CR1_DITHEN_Pos)
#define TIM_CR1_DITHEN   TIM_CR1_DITHEN_Msk
#define TIM_CR2_CCPC_Pos   (0U)
#define TIM_CR2_CCPC_Msk   (0x1UL << TIM_CR2_CCPC_Pos)
#define TIM_CR2_CCPC   TIM_CR2_CCPC_Msk
#define TIM_CR2_CCUS_Pos   (2U)
#define TIM_CR2_CCUS_Msk   (0x1UL << TIM_CR2_CCUS_Pos)
#define TIM_CR2_CCUS   TIM_CR2_CCUS_Msk
#define TIM_CR2_CCDS_Pos   (3U)
#define TIM_CR2_CCDS_Msk   (0x1UL << TIM_CR2_CCDS_Pos)
#define TIM_CR2_CCDS   TIM_CR2_CCDS_Msk
#define TIM_CR2_MMS_Pos   (4U)
#define TIM_CR2_MMS_Msk   (0x200007UL << TIM_CR2_MMS_Pos)
#define TIM_CR2_MMS   TIM_CR2_MMS_Msk
#define TIM_CR2_MMS_0   (0x000001UL << TIM_CR2_MMS_Pos)
#define TIM_CR2_MMS_1   (0x000002UL << TIM_CR2_MMS_Pos)
#define TIM_CR2_MMS_2   (0x000004UL << TIM_CR2_MMS_Pos)
#define TIM_CR2_MMS_3   (0x200000UL << TIM_CR2_MMS_Pos)
#define TIM_CR2_TI1S_Pos   (7U)
#define TIM_CR2_TI1S_Msk   (0x1UL << TIM_CR2_TI1S_Pos)
#define TIM_CR2_TI1S   TIM_CR2_TI1S_Msk
#define TIM_CR2_OIS1_Pos   (8U)
#define TIM_CR2_OIS1_Msk   (0x1UL << TIM_CR2_OIS1_Pos)
#define TIM_CR2_OIS1   TIM_CR2_OIS1_Msk
#define TIM_CR2_OIS1N_Pos   (9U)
#define TIM_CR2_OIS1N_Msk   (0x1UL << TIM_CR2_OIS1N_Pos)
#define TIM_CR2_OIS1N   TIM_CR2_OIS1N_Msk
#define TIM_CR2_OIS2_Pos   (10U)
#define TIM_CR2_OIS2_Msk   (0x1UL << TIM_CR2_OIS2_Pos)
#define TIM_CR2_OIS2   TIM_CR2_OIS2_Msk
#define TIM_CR2_OIS2N_Pos   (11U)
#define TIM_CR2_OIS2N_Msk   (0x1UL << TIM_CR2_OIS2N_Pos)
#define TIM_CR2_OIS2N   TIM_CR2_OIS2N_Msk
#define TIM_CR2_OIS3_Pos   (12U)
#define TIM_CR2_OIS3_Msk   (0x1UL << TIM_CR2_OIS3_Pos)
#define TIM_CR2_OIS3   TIM_CR2_OIS3_Msk
#define TIM_CR2_OIS3N_Pos   (13U)
#define TIM_CR2_OIS3N_Msk   (0x1UL << TIM_CR2_OIS3N_Pos)
#define TIM_CR2_OIS3N   TIM_CR2_OIS3N_Msk
#define TIM_CR2_OIS4_Pos   (14U)
#define TIM_CR2_OIS4_Msk   (0x1UL << TIM_CR2_OIS4_Pos)
#define TIM_CR2_OIS4   TIM_CR2_OIS4_Msk
#define TIM_CR2_OIS4N_Pos   (15U)
#define TIM_CR2_OIS4N_Msk   (0x1UL << TIM_CR2_OIS4N_Pos)
#define TIM_CR2_OIS4N   TIM_CR2_OIS4N_Msk
#define TIM_CR2_OIS5_Pos   (16U)
#define TIM_CR2_OIS5_Msk   (0x1UL << TIM_CR2_OIS5_Pos)
#define TIM_CR2_OIS5   TIM_CR2_OIS5_Msk
#define TIM_CR2_OIS6_Pos   (18U)
#define TIM_CR2_OIS6_Msk   (0x1UL << TIM_CR2_OIS6_Pos)
#define TIM_CR2_OIS6   TIM_CR2_OIS6_Msk
#define TIM_CR2_MMS2_Pos   (20U)
#define TIM_CR2_MMS2_Msk   (0xFUL << TIM_CR2_MMS2_Pos)
#define TIM_CR2_MMS2   TIM_CR2_MMS2_Msk
#define TIM_CR2_MMS2_0   (0x1UL << TIM_CR2_MMS2_Pos)
#define TIM_CR2_MMS2_1   (0x2UL << TIM_CR2_MMS2_Pos)
#define TIM_CR2_MMS2_2   (0x4UL << TIM_CR2_MMS2_Pos)
#define TIM_CR2_MMS2_3   (0x8UL << TIM_CR2_MMS2_Pos)
#define TIM_SMCR_SMS_Pos   (0U)
#define TIM_SMCR_SMS_Msk   (0x10007UL << TIM_SMCR_SMS_Pos)
#define TIM_SMCR_SMS   TIM_SMCR_SMS_Msk
#define TIM_SMCR_SMS_0   (0x00001UL << TIM_SMCR_SMS_Pos)
#define TIM_SMCR_SMS_1   (0x00002UL << TIM_SMCR_SMS_Pos)
#define TIM_SMCR_SMS_2   (0x00004UL << TIM_SMCR_SMS_Pos)
#define TIM_SMCR_SMS_3   (0x10000UL << TIM_SMCR_SMS_Pos)
#define TIM_SMCR_OCCS_Pos   (3U)
#define TIM_SMCR_OCCS_Msk   (0x1UL << TIM_SMCR_OCCS_Pos)
#define TIM_SMCR_OCCS   TIM_SMCR_OCCS_Msk
#define TIM_SMCR_TS_Pos   (4U)
#define TIM_SMCR_TS_Msk   (0x30007UL << TIM_SMCR_TS_Pos)
#define TIM_SMCR_TS   TIM_SMCR_TS_Msk
#define TIM_SMCR_TS_0   (0x00001UL << TIM_SMCR_TS_Pos)
#define TIM_SMCR_TS_1   (0x00002UL << TIM_SMCR_TS_Pos)
#define TIM_SMCR_TS_2   (0x00004UL << TIM_SMCR_TS_Pos)
#define TIM_SMCR_TS_3   (0x10000UL << TIM_SMCR_TS_Pos)
#define TIM_SMCR_TS_4   (0x20000UL << TIM_SMCR_TS_Pos)
#define TIM_SMCR_MSM_Pos   (7U)
#define TIM_SMCR_MSM_Msk   (0x1UL << TIM_SMCR_MSM_Pos)
#define TIM_SMCR_MSM   TIM_SMCR_MSM_Msk
#define TIM_SMCR_ETF_Pos   (8U)
#define TIM_SMCR_ETF_Msk   (0xFUL << TIM_SMCR_ETF_Pos)
#define TIM_SMCR_ETF   TIM_SMCR_ETF_Msk
#define TIM_SMCR_ETF_0   (0x1UL << TIM_SMCR_ETF_Pos)
#define TIM_SMCR_ETF_1   (0x2UL << TIM_SMCR_ETF_Pos)
#define TIM_SMCR_ETF_2   (0x4UL << TIM_SMCR_ETF_Pos)
#define TIM_SMCR_ETF_3   (0x8UL << TIM_SMCR_ETF_Pos)
#define TIM_SMCR_ETPS_Pos   (12U)
#define TIM_SMCR_ETPS_Msk   (0x3UL << TIM_SMCR_ETPS_Pos)
#define TIM_SMCR_ETPS   TIM_SMCR_ETPS_Msk
#define TIM_SMCR_ETPS_0   (0x1UL << TIM_SMCR_ETPS_Pos)
#define TIM_SMCR_ETPS_1   (0x2UL << TIM_SMCR_ETPS_Pos)
#define TIM_SMCR_ECE_Pos   (14U)
#define TIM_SMCR_ECE_Msk   (0x1UL << TIM_SMCR_ECE_Pos)
#define TIM_SMCR_ECE   TIM_SMCR_ECE_Msk
#define TIM_SMCR_ETP_Pos   (15U)
#define TIM_SMCR_ETP_Msk   (0x1UL << TIM_SMCR_ETP_Pos)
#define TIM_SMCR_ETP   TIM_SMCR_ETP_Msk
#define TIM_SMCR_SMSPE_Pos   (24U)
#define TIM_SMCR_SMSPE_Msk   (0x1UL << TIM_SMCR_SMSPE_Pos)
#define TIM_SMCR_SMSPE   TIM_SMCR_SMSPE_Msk
#define TIM_SMCR_SMSPS_Pos   (25U)
#define TIM_SMCR_SMSPS_Msk   (0x1UL << TIM_SMCR_SMSPS_Pos)
#define TIM_SMCR_SMSPS   TIM_SMCR_SMSPS_Msk
#define TIM_DIER_UIE_Pos   (0U)
#define TIM_DIER_UIE_Msk   (0x1UL << TIM_DIER_UIE_Pos)
#define TIM_DIER_UIE   TIM_DIER_UIE_Msk
#define TIM_DIER_CC1IE_Pos   (1U)
#define TIM_DIER_CC1IE_Msk   (0x1UL << TIM_DIER_CC1IE_Pos)
#define TIM_DIER_CC1IE   TIM_DIER_CC1IE_Msk
#define TIM_DIER_CC2IE_Pos   (2U)
#define TIM_DIER_CC2IE_Msk   (0x1UL << TIM_DIER_CC2IE_Pos)
#define TIM_DIER_CC2IE   TIM_DIER_CC2IE_Msk
#define TIM_DIER_CC3IE_Pos   (3U)
#define TIM_DIER_CC3IE_Msk   (0x1UL << TIM_DIER_CC3IE_Pos)
#define TIM_DIER_CC3IE   TIM_DIER_CC3IE_Msk
#define TIM_DIER_CC4IE_Pos   (4U)
#define TIM_DIER_CC4IE_Msk   (0x1UL << TIM_DIER_CC4IE_Pos)
#define TIM_DIER_CC4IE   TIM_DIER_CC4IE_Msk
#define TIM_DIER_COMIE_Pos   (5U)
#define TIM_DIER_COMIE_Msk   (0x1UL << TIM_DIER_COMIE_Pos)
#define TIM_DIER_COMIE   TIM_DIER_COMIE_Msk
#define TIM_DIER_TIE_Pos   (6U)
#define TIM_DIER_TIE_Msk   (0x1UL << TIM_DIER_TIE_Pos)
#define TIM_DIER_TIE   TIM_DIER_TIE_Msk
#define TIM_DIER_BIE_Pos   (7U)
#define TIM_DIER_BIE_Msk   (0x1UL << TIM_DIER_BIE_Pos)
#define TIM_DIER_BIE   TIM_DIER_BIE_Msk
#define TIM_DIER_UDE_Pos   (8U)
#define TIM_DIER_UDE_Msk   (0x1UL << TIM_DIER_UDE_Pos)
#define TIM_DIER_UDE   TIM_DIER_UDE_Msk
#define TIM_DIER_CC1DE_Pos   (9U)
#define TIM_DIER_CC1DE_Msk   (0x1UL << TIM_DIER_CC1DE_Pos)
#define TIM_DIER_CC1DE   TIM_DIER_CC1DE_Msk
#define TIM_DIER_CC2DE_Pos   (10U)
#define TIM_DIER_CC2DE_Msk   (0x1UL << TIM_DIER_CC2DE_Pos)
#define TIM_DIER_CC2DE   TIM_DIER_CC2DE_Msk
#define TIM_DIER_CC3DE_Pos   (11U)
#define TIM_DIER_CC3DE_Msk   (0x1UL << TIM_DIER_CC3DE_Pos)
#define TIM_DIER_CC3DE   TIM_DIER_CC3DE_Msk
#define TIM_DIER_CC4DE_Pos   (12U)
#define TIM_DIER_CC4DE_Msk   (0x1UL << TIM_DIER_CC4DE_Pos)
#define TIM_DIER_CC4DE   TIM_DIER_CC4DE_Msk
#define TIM_DIER_COMDE_Pos   (13U)
#define TIM_DIER_COMDE_Msk   (0x1UL << TIM_DIER_COMDE_Pos)
#define TIM_DIER_COMDE   TIM_DIER_COMDE_Msk
#define TIM_DIER_TDE_Pos   (14U)
#define TIM_DIER_TDE_Msk   (0x1UL << TIM_DIER_TDE_Pos)
#define TIM_DIER_TDE   TIM_DIER_TDE_Msk
#define TIM_DIER_IDXIE_Pos   (20U)
#define TIM_DIER_IDXIE_Msk   (0x1UL << TIM_DIER_IDXIE_Pos)
#define TIM_DIER_IDXIE   TIM_DIER_IDXIE_Msk
#define TIM_DIER_DIRIE_Pos   (21U)
#define TIM_DIER_DIRIE_Msk   (0x1UL << TIM_DIER_DIRIE_Pos)
#define TIM_DIER_DIRIE   TIM_DIER_DIRIE_Msk
#define TIM_DIER_IERRIE_Pos   (22U)
#define TIM_DIER_IERRIE_Msk   (0x1UL << TIM_DIER_IERRIE_Pos)
#define TIM_DIER_IERRIE   TIM_DIER_IERRIE_Msk
#define TIM_DIER_TERRIE_Pos   (23U)
#define TIM_DIER_TERRIE_Msk   (0x1UL << TIM_DIER_TERRIE_Pos)
#define TIM_DIER_TERRIE   TIM_DIER_TERRIE_Msk
#define TIM_SR_UIF_Pos   (0U)
#define TIM_SR_UIF_Msk   (0x1UL << TIM_SR_UIF_Pos)
#define TIM_SR_UIF   TIM_SR_UIF_Msk
#define TIM_SR_CC1IF_Pos   (1U)
#define TIM_SR_CC1IF_Msk   (0x1UL << TIM_SR_CC1IF_Pos)
#define TIM_SR_CC1IF   TIM_SR_CC1IF_Msk
#define TIM_SR_CC2IF_Pos   (2U)
#define TIM_SR_CC2IF_Msk   (0x1UL << TIM_SR_CC2IF_Pos)
#define TIM_SR_CC2IF   TIM_SR_CC2IF_Msk
#define TIM_SR_CC3IF_Pos   (3U)
#define TIM_SR_CC3IF_Msk   (0x1UL << TIM_SR_CC3IF_Pos)
#define TIM_SR_CC3IF   TIM_SR_CC3IF_Msk
#define TIM_SR_CC4IF_Pos   (4U)
#define TIM_SR_CC4IF_Msk   (0x1UL << TIM_SR_CC4IF_Pos)
#define TIM_SR_CC4IF   TIM_SR_CC4IF_Msk
#define TIM_SR_COMIF_Pos   (5U)
#define TIM_SR_COMIF_Msk   (0x1UL << TIM_SR_COMIF_Pos)
#define TIM_SR_COMIF   TIM_SR_COMIF_Msk
#define TIM_SR_TIF_Pos   (6U)
#define TIM_SR_TIF_Msk   (0x1UL << TIM_SR_TIF_Pos)
#define TIM_SR_TIF   TIM_SR_TIF_Msk
#define TIM_SR_BIF_Pos   (7U)
#define TIM_SR_BIF_Msk   (0x1UL << TIM_SR_BIF_Pos)
#define TIM_SR_BIF   TIM_SR_BIF_Msk
#define TIM_SR_B2IF_Pos   (8U)
#define TIM_SR_B2IF_Msk   (0x1UL << TIM_SR_B2IF_Pos)
#define TIM_SR_B2IF   TIM_SR_B2IF_Msk
#define TIM_SR_CC1OF_Pos   (9U)
#define TIM_SR_CC1OF_Msk   (0x1UL << TIM_SR_CC1OF_Pos)
#define TIM_SR_CC1OF   TIM_SR_CC1OF_Msk
#define TIM_SR_CC2OF_Pos   (10U)
#define TIM_SR_CC2OF_Msk   (0x1UL << TIM_SR_CC2OF_Pos)
#define TIM_SR_CC2OF   TIM_SR_CC2OF_Msk
#define TIM_SR_CC3OF_Pos   (11U)
#define TIM_SR_CC3OF_Msk   (0x1UL << TIM_SR_CC3OF_Pos)
#define TIM_SR_CC3OF   TIM_SR_CC3OF_Msk
#define TIM_SR_CC4OF_Pos   (12U)
#define TIM_SR_CC4OF_Msk   (0x1UL << TIM_SR_CC4OF_Pos)
#define TIM_SR_CC4OF   TIM_SR_CC4OF_Msk
#define TIM_SR_SBIF_Pos   (13U)
#define TIM_SR_SBIF_Msk   (0x1UL << TIM_SR_SBIF_Pos)
#define TIM_SR_SBIF   TIM_SR_SBIF_Msk
#define TIM_SR_CC5IF_Pos   (16U)
#define TIM_SR_CC5IF_Msk   (0x1UL << TIM_SR_CC5IF_Pos)
#define TIM_SR_CC5IF   TIM_SR_CC5IF_Msk
#define TIM_SR_CC6IF_Pos   (17U)
#define TIM_SR_CC6IF_Msk   (0x1UL << TIM_SR_CC6IF_Pos)
#define TIM_SR_CC6IF   TIM_SR_CC6IF_Msk
#define TIM_SR_IDXF_Pos   (20U)
#define TIM_SR_IDXF_Msk   (0x1UL << TIM_SR_IDXF_Pos)
#define TIM_SR_IDXF   TIM_SR_IDXF_Msk
#define TIM_SR_DIRF_Pos   (21U)
#define TIM_SR_DIRF_Msk   (0x1UL << TIM_SR_DIRF_Pos)
#define TIM_SR_DIRF   TIM_SR_DIRF_Msk
#define TIM_SR_IERRF_Pos   (22U)
#define TIM_SR_IERRF_Msk   (0x1UL << TIM_SR_IERRF_Pos)
#define TIM_SR_IERRF   TIM_SR_IERRF_Msk
#define TIM_SR_TERRF_Pos   (23U)
#define TIM_SR_TERRF_Msk   (0x1UL << TIM_SR_TERRF_Pos)
#define TIM_SR_TERRF   TIM_SR_TERRF_Msk
#define TIM_EGR_UG_Pos   (0U)
#define TIM_EGR_UG_Msk   (0x1UL << TIM_EGR_UG_Pos)
#define TIM_EGR_UG   TIM_EGR_UG_Msk
#define TIM_EGR_CC1G_Pos   (1U)
#define TIM_EGR_CC1G_Msk   (0x1UL << TIM_EGR_CC1G_Pos)
#define TIM_EGR_CC1G   TIM_EGR_CC1G_Msk
#define TIM_EGR_CC2G_Pos   (2U)
#define TIM_EGR_CC2G_Msk   (0x1UL << TIM_EGR_CC2G_Pos)
#define TIM_EGR_CC2G   TIM_EGR_CC2G_Msk
#define TIM_EGR_CC3G_Pos   (3U)
#define TIM_EGR_CC3G_Msk   (0x1UL << TIM_EGR_CC3G_Pos)
#define TIM_EGR_CC3G   TIM_EGR_CC3G_Msk
#define TIM_EGR_CC4G_Pos   (4U)
#define TIM_EGR_CC4G_Msk   (0x1UL << TIM_EGR_CC4G_Pos)
#define TIM_EGR_CC4G   TIM_EGR_CC4G_Msk
#define TIM_EGR_COMG_Pos   (5U)
#define TIM_EGR_COMG_Msk   (0x1UL << TIM_EGR_COMG_Pos)
#define TIM_EGR_COMG   TIM_EGR_COMG_Msk
#define TIM_EGR_TG_Pos   (6U)
#define TIM_EGR_TG_Msk   (0x1UL << TIM_EGR_TG_Pos)
#define TIM_EGR_TG   TIM_EGR_TG_Msk
#define TIM_EGR_BG_Pos   (7U)
#define TIM_EGR_BG_Msk   (0x1UL << TIM_EGR_BG_Pos)
#define TIM_EGR_BG   TIM_EGR_BG_Msk
#define TIM_EGR_B2G_Pos   (8U)
#define TIM_EGR_B2G_Msk   (0x1UL << TIM_EGR_B2G_Pos)
#define TIM_EGR_B2G   TIM_EGR_B2G_Msk
#define TIM_CCMR1_CC1S_Pos   (0U)
#define TIM_CCMR1_CC1S_Msk   (0x3UL << TIM_CCMR1_CC1S_Pos)
#define TIM_CCMR1_CC1S   TIM_CCMR1_CC1S_Msk
#define TIM_CCMR1_CC1S_0   (0x1UL << TIM_CCMR1_CC1S_Pos)
#define TIM_CCMR1_CC1S_1   (0x2UL << TIM_CCMR1_CC1S_Pos)
#define TIM_CCMR1_OC1FE_Pos   (2U)
#define TIM_CCMR1_OC1FE_Msk   (0x1UL << TIM_CCMR1_OC1FE_Pos)
#define TIM_CCMR1_OC1FE   TIM_CCMR1_OC1FE_Msk
#define TIM_CCMR1_OC1PE_Pos   (3U)
#define TIM_CCMR1_OC1PE_Msk   (0x1UL << TIM_CCMR1_OC1PE_Pos)
#define TIM_CCMR1_OC1PE   TIM_CCMR1_OC1PE_Msk
#define TIM_CCMR1_OC1M_Pos   (4U)
#define TIM_CCMR1_OC1M_Msk   (0x1007UL << TIM_CCMR1_OC1M_Pos)
#define TIM_CCMR1_OC1M   TIM_CCMR1_OC1M_Msk
#define TIM_CCMR1_OC1M_0   (0x0001UL << TIM_CCMR1_OC1M_Pos)
#define TIM_CCMR1_OC1M_1   (0x0002UL << TIM_CCMR1_OC1M_Pos)
#define TIM_CCMR1_OC1M_2   (0x0004UL << TIM_CCMR1_OC1M_Pos)
#define TIM_CCMR1_OC1M_3   (0x1000UL << TIM_CCMR1_OC1M_Pos)
#define TIM_CCMR1_OC1CE_Pos   (7U)
#define TIM_CCMR1_OC1CE_Msk   (0x1UL << TIM_CCMR1_OC1CE_Pos)
#define TIM_CCMR1_OC1CE   TIM_CCMR1_OC1CE_Msk
#define TIM_CCMR1_CC2S_Pos   (8U)
#define TIM_CCMR1_CC2S_Msk   (0x3UL << TIM_CCMR1_CC2S_Pos)
#define TIM_CCMR1_CC2S   TIM_CCMR1_CC2S_Msk
#define TIM_CCMR1_CC2S_0   (0x1UL << TIM_CCMR1_CC2S_Pos)
#define TIM_CCMR1_CC2S_1   (0x2UL << TIM_CCMR1_CC2S_Pos)
#define TIM_CCMR1_OC2FE_Pos   (10U)
#define TIM_CCMR1_OC2FE_Msk   (0x1UL << TIM_CCMR1_OC2FE_Pos)
#define TIM_CCMR1_OC2FE   TIM_CCMR1_OC2FE_Msk
#define TIM_CCMR1_OC2PE_Pos   (11U)
#define TIM_CCMR1_OC2PE_Msk   (0x1UL << TIM_CCMR1_OC2PE_Pos)
#define TIM_CCMR1_OC2PE   TIM_CCMR1_OC2PE_Msk
#define TIM_CCMR1_OC2M_Pos   (12U)
#define TIM_CCMR1_OC2M_Msk   (0x1007UL << TIM_CCMR1_OC2M_Pos)
#define TIM_CCMR1_OC2M   TIM_CCMR1_OC2M_Msk
#define TIM_CCMR1_OC2M_0   (0x0001UL << TIM_CCMR1_OC2M_Pos)
#define TIM_CCMR1_OC2M_1   (0x0002UL << TIM_CCMR1_OC2M_Pos)
#define TIM_CCMR1_OC2M_2   (0x0004UL << TIM_CCMR1_OC2M_Pos)
#define TIM_CCMR1_OC2M_3   (0x1000UL << TIM_CCMR1_OC2M_Pos)
#define TIM_CCMR1_OC2CE_Pos   (15U)
#define TIM_CCMR1_OC2CE_Msk   (0x1UL << TIM_CCMR1_OC2CE_Pos)
#define TIM_CCMR1_OC2CE   TIM_CCMR1_OC2CE_Msk
#define TIM_CCMR1_IC1PSC_Pos   (2U)
#define TIM_CCMR1_IC1PSC_Msk   (0x3UL << TIM_CCMR1_IC1PSC_Pos)
#define TIM_CCMR1_IC1PSC   TIM_CCMR1_IC1PSC_Msk
#define TIM_CCMR1_IC1PSC_0   (0x1UL << TIM_CCMR1_IC1PSC_Pos)
#define TIM_CCMR1_IC1PSC_1   (0x2UL << TIM_CCMR1_IC1PSC_Pos)
#define TIM_CCMR1_IC1F_Pos   (4U)
#define TIM_CCMR1_IC1F_Msk   (0xFUL << TIM_CCMR1_IC1F_Pos)
#define TIM_CCMR1_IC1F   TIM_CCMR1_IC1F_Msk
#define TIM_CCMR1_IC1F_0   (0x1UL << TIM_CCMR1_IC1F_Pos)
#define TIM_CCMR1_IC1F_1   (0x2UL << TIM_CCMR1_IC1F_Pos)
#define TIM_CCMR1_IC1F_2   (0x4UL << TIM_CCMR1_IC1F_Pos)
#define TIM_CCMR1_IC1F_3   (0x8UL << TIM_CCMR1_IC1F_Pos)
#define TIM_CCMR1_IC2PSC_Pos   (10U)
#define TIM_CCMR1_IC2PSC_Msk   (0x3UL << TIM_CCMR1_IC2PSC_Pos)
#define TIM_CCMR1_IC2PSC   TIM_CCMR1_IC2PSC_Msk
#define TIM_CCMR1_IC2PSC_0   (0x1UL << TIM_CCMR1_IC2PSC_Pos)
#define TIM_CCMR1_IC2PSC_1   (0x2UL << TIM_CCMR1_IC2PSC_Pos)
#define TIM_CCMR1_IC2F_Pos   (12U)
#define TIM_CCMR1_IC2F_Msk   (0xFUL << TIM_CCMR1_IC2F_Pos)
#define TIM_CCMR1_IC2F   TIM_CCMR1_IC2F_Msk
#define TIM_CCMR1_IC2F_0   (0x1UL << TIM_CCMR1_IC2F_Pos)
#define TIM_CCMR1_IC2F_1   (0x2UL << TIM_CCMR1_IC2F_Pos)
#define TIM_CCMR1_IC2F_2   (0x4UL << TIM_CCMR1_IC2F_Pos)
#define TIM_CCMR1_IC2F_3   (0x8UL << TIM_CCMR1_IC2F_Pos)
#define TIM_CCMR2_CC3S_Pos   (0U)
#define TIM_CCMR2_CC3S_Msk   (0x3UL << TIM_CCMR2_CC3S_Pos)
#define TIM_CCMR2_CC3S   TIM_CCMR2_CC3S_Msk
#define TIM_CCMR2_CC3S_0   (0x1UL << TIM_CCMR2_CC3S_Pos)
#define TIM_CCMR2_CC3S_1   (0x2UL << TIM_CCMR2_CC3S_Pos)
#define TIM_CCMR2_OC3FE_Pos   (2U)
#define TIM_CCMR2_OC3FE_Msk   (0x1UL << TIM_CCMR2_OC3FE_Pos)
#define TIM_CCMR2_OC3FE   TIM_CCMR2_OC3FE_Msk
#define TIM_CCMR2_OC3PE_Pos   (3U)
#define TIM_CCMR2_OC3PE_Msk   (0x1UL << TIM_CCMR2_OC3PE_Pos)
#define TIM_CCMR2_OC3PE   TIM_CCMR2_OC3PE_Msk
#define TIM_CCMR2_OC3M_Pos   (4U)
#define TIM_CCMR2_OC3M_Msk   (0x1007UL << TIM_CCMR2_OC3M_Pos)
#define TIM_CCMR2_OC3M   TIM_CCMR2_OC3M_Msk
#define TIM_CCMR2_OC3M_0   (0x0001UL << TIM_CCMR2_OC3M_Pos)
#define TIM_CCMR2_OC3M_1   (0x0002UL << TIM_CCMR2_OC3M_Pos)
#define TIM_CCMR2_OC3M_2   (0x0004UL << TIM_CCMR2_OC3M_Pos)
#define TIM_CCMR2_OC3M_3   (0x1000UL << TIM_CCMR2_OC3M_Pos)
#define TIM_CCMR2_OC3CE_Pos   (7U)
#define TIM_CCMR2_OC3CE_Msk   (0x1UL << TIM_CCMR2_OC3CE_Pos)
#define TIM_CCMR2_OC3CE   TIM_CCMR2_OC3CE_Msk
#define TIM_CCMR2_CC4S_Pos   (8U)
#define TIM_CCMR2_CC4S_Msk   (0x3UL << TIM_CCMR2_CC4S_Pos)
#define TIM_CCMR2_CC4S   TIM_CCMR2_CC4S_Msk
#define TIM_CCMR2_CC4S_0   (0x1UL << TIM_CCMR2_CC4S_Pos)
#define TIM_CCMR2_CC4S_1   (0x2UL << TIM_CCMR2_CC4S_Pos)
#define TIM_CCMR2_OC4FE_Pos   (10U)
#define TIM_CCMR2_OC4FE_Msk   (0x1UL << TIM_CCMR2_OC4FE_Pos)
#define TIM_CCMR2_OC4FE   TIM_CCMR2_OC4FE_Msk
#define TIM_CCMR2_OC4PE_Pos   (11U)
#define TIM_CCMR2_OC4PE_Msk   (0x1UL << TIM_CCMR2_OC4PE_Pos)
#define TIM_CCMR2_OC4PE   TIM_CCMR2_OC4PE_Msk
#define TIM_CCMR2_OC4M_Pos   (12U)
#define TIM_CCMR2_OC4M_Msk   (0x1007UL << TIM_CCMR2_OC4M_Pos)
#define TIM_CCMR2_OC4M   TIM_CCMR2_OC4M_Msk
#define TIM_CCMR2_OC4M_0   (0x0001UL << TIM_CCMR2_OC4M_Pos)
#define TIM_CCMR2_OC4M_1   (0x0002UL << TIM_CCMR2_OC4M_Pos)
#define TIM_CCMR2_OC4M_2   (0x0004UL << TIM_CCMR2_OC4M_Pos)
#define TIM_CCMR2_OC4M_3   (0x1000UL << TIM_CCMR2_OC4M_Pos)
#define TIM_CCMR2_OC4CE_Pos   (15U)
#define TIM_CCMR2_OC4CE_Msk   (0x1UL << TIM_CCMR2_OC4CE_Pos)
#define TIM_CCMR2_OC4CE   TIM_CCMR2_OC4CE_Msk
#define TIM_CCMR2_IC3PSC_Pos   (2U)
#define TIM_CCMR2_IC3PSC_Msk   (0x3UL << TIM_CCMR2_IC3PSC_Pos)
#define TIM_CCMR2_IC3PSC   TIM_CCMR2_IC3PSC_Msk
#define TIM_CCMR2_IC3PSC_0   (0x1UL << TIM_CCMR2_IC3PSC_Pos)
#define TIM_CCMR2_IC3PSC_1   (0x2UL << TIM_CCMR2_IC3PSC_Pos)
#define TIM_CCMR2_IC3F_Pos   (4U)
#define TIM_CCMR2_IC3F_Msk   (0xFUL << TIM_CCMR2_IC3F_Pos)
#define TIM_CCMR2_IC3F   TIM_CCMR2_IC3F_Msk
#define TIM_CCMR2_IC3F_0   (0x1UL << TIM_CCMR2_IC3F_Pos)
#define TIM_CCMR2_IC3F_1   (0x2UL << TIM_CCMR2_IC3F_Pos)
#define TIM_CCMR2_IC3F_2   (0x4UL << TIM_CCMR2_IC3F_Pos)
#define TIM_CCMR2_IC3F_3   (0x8UL << TIM_CCMR2_IC3F_Pos)
#define TIM_CCMR2_IC4PSC_Pos   (10U)
#define TIM_CCMR2_IC4PSC_Msk   (0x3UL << TIM_CCMR2_IC4PSC_Pos)
#define TIM_CCMR2_IC4PSC   TIM_CCMR2_IC4PSC_Msk
#define TIM_CCMR2_IC4PSC_0   (0x1UL << TIM_CCMR2_IC4PSC_Pos)
#define TIM_CCMR2_IC4PSC_1   (0x2UL << TIM_CCMR2_IC4PSC_Pos)
#define TIM_CCMR2_IC4F_Pos   (12U)
#define TIM_CCMR2_IC4F_Msk   (0xFUL << TIM_CCMR2_IC4F_Pos)
#define TIM_CCMR2_IC4F   TIM_CCMR2_IC4F_Msk
#define TIM_CCMR2_IC4F_0   (0x1UL << TIM_CCMR2_IC4F_Pos)
#define TIM_CCMR2_IC4F_1   (0x2UL << TIM_CCMR2_IC4F_Pos)
#define TIM_CCMR2_IC4F_2   (0x4UL << TIM_CCMR2_IC4F_Pos)
#define TIM_CCMR2_IC4F_3   (0x8UL << TIM_CCMR2_IC4F_Pos)
#define TIM_CCMR3_OC5FE_Pos   (2U)
#define TIM_CCMR3_OC5FE_Msk   (0x1UL << TIM_CCMR3_OC5FE_Pos)
#define TIM_CCMR3_OC5FE   TIM_CCMR3_OC5FE_Msk
#define TIM_CCMR3_OC5PE_Pos   (3U)
#define TIM_CCMR3_OC5PE_Msk   (0x1UL << TIM_CCMR3_OC5PE_Pos)
#define TIM_CCMR3_OC5PE   TIM_CCMR3_OC5PE_Msk
#define TIM_CCMR3_OC5M_Pos   (4U)
#define TIM_CCMR3_OC5M_Msk   (0x1007UL << TIM_CCMR3_OC5M_Pos)
#define TIM_CCMR3_OC5M   TIM_CCMR3_OC5M_Msk
#define TIM_CCMR3_OC5M_0   (0x0001UL << TIM_CCMR3_OC5M_Pos)
#define TIM_CCMR3_OC5M_1   (0x0002UL << TIM_CCMR3_OC5M_Pos)
#define TIM_CCMR3_OC5M_2   (0x0004UL << TIM_CCMR3_OC5M_Pos)
#define TIM_CCMR3_OC5M_3   (0x1000UL << TIM_CCMR3_OC5M_Pos)
#define TIM_CCMR3_OC5CE_Pos   (7U)
#define TIM_CCMR3_OC5CE_Msk   (0x1UL << TIM_CCMR3_OC5CE_Pos)
#define TIM_CCMR3_OC5CE   TIM_CCMR3_OC5CE_Msk
#define TIM_CCMR3_OC6FE_Pos   (10U)
#define TIM_CCMR3_OC6FE_Msk   (0x1UL << TIM_CCMR3_OC6FE_Pos)
#define TIM_CCMR3_OC6FE   TIM_CCMR3_OC6FE_Msk
#define TIM_CCMR3_OC6PE_Pos   (11U)
#define TIM_CCMR3_OC6PE_Msk   (0x1UL << TIM_CCMR3_OC6PE_Pos)
#define TIM_CCMR3_OC6PE   TIM_CCMR3_OC6PE_Msk
#define TIM_CCMR3_OC6M_Pos   (12U)
#define TIM_CCMR3_OC6M_Msk   (0x1007UL << TIM_CCMR3_OC6M_Pos)
#define TIM_CCMR3_OC6M   TIM_CCMR3_OC6M_Msk
#define TIM_CCMR3_OC6M_0   (0x0001UL << TIM_CCMR3_OC6M_Pos)
#define TIM_CCMR3_OC6M_1   (0x0002UL << TIM_CCMR3_OC6M_Pos)
#define TIM_CCMR3_OC6M_2   (0x0004UL << TIM_CCMR3_OC6M_Pos)
#define TIM_CCMR3_OC6M_3   (0x1000UL << TIM_CCMR3_OC6M_Pos)
#define TIM_CCMR3_OC6CE_Pos   (15U)
#define TIM_CCMR3_OC6CE_Msk   (0x1UL << TIM_CCMR3_OC6CE_Pos)
#define TIM_CCMR3_OC6CE   TIM_CCMR3_OC6CE_Msk
#define TIM_CCER_CC1E_Pos   (0U)
#define TIM_CCER_CC1E_Msk   (0x1UL << TIM_CCER_CC1E_Pos)
#define TIM_CCER_CC1E   TIM_CCER_CC1E_Msk
#define TIM_CCER_CC1P_Pos   (1U)
#define TIM_CCER_CC1P_Msk   (0x1UL << TIM_CCER_CC1P_Pos)
#define TIM_CCER_CC1P   TIM_CCER_CC1P_Msk
#define TIM_CCER_CC1NE_Pos   (2U)
#define TIM_CCER_CC1NE_Msk   (0x1UL << TIM_CCER_CC1NE_Pos)
#define TIM_CCER_CC1NE   TIM_CCER_CC1NE_Msk
#define TIM_CCER_CC1NP_Pos   (3U)
#define TIM_CCER_CC1NP_Msk   (0x1UL << TIM_CCER_CC1NP_Pos)
#define TIM_CCER_CC1NP   TIM_CCER_CC1NP_Msk
#define TIM_CCER_CC2E_Pos   (4U)
#define TIM_CCER_CC2E_Msk   (0x1UL << TIM_CCER_CC2E_Pos)
#define TIM_CCER_CC2E   TIM_CCER_CC2E_Msk
#define TIM_CCER_CC2P_Pos   (5U)
#define TIM_CCER_CC2P_Msk   (0x1UL << TIM_CCER_CC2P_Pos)
#define TIM_CCER_CC2P   TIM_CCER_CC2P_Msk
#define TIM_CCER_CC2NE_Pos   (6U)
#define TIM_CCER_CC2NE_Msk   (0x1UL << TIM_CCER_CC2NE_Pos)
#define TIM_CCER_CC2NE   TIM_CCER_CC2NE_Msk
#define TIM_CCER_CC2NP_Pos   (7U)
#define TIM_CCER_CC2NP_Msk   (0x1UL << TIM_CCER_CC2NP_Pos)
#define TIM_CCER_CC2NP   TIM_CCER_CC2NP_Msk
#define TIM_CCER_CC3E_Pos   (8U)
#define TIM_CCER_CC3E_Msk   (0x1UL << TIM_CCER_CC3E_Pos)
#define TIM_CCER_CC3E   TIM_CCER_CC3E_Msk
#define TIM_CCER_CC3P_Pos   (9U)
#define TIM_CCER_CC3P_Msk   (0x1UL << TIM_CCER_CC3P_Pos)
#define TIM_CCER_CC3P   TIM_CCER_CC3P_Msk
#define TIM_CCER_CC3NE_Pos   (10U)
#define TIM_CCER_CC3NE_Msk   (0x1UL << TIM_CCER_CC3NE_Pos)
#define TIM_CCER_CC3NE   TIM_CCER_CC3NE_Msk
#define TIM_CCER_CC3NP_Pos   (11U)
#define TIM_CCER_CC3NP_Msk   (0x1UL << TIM_CCER_CC3NP_Pos)
#define TIM_CCER_CC3NP   TIM_CCER_CC3NP_Msk
#define TIM_CCER_CC4E_Pos   (12U)
#define TIM_CCER_CC4E_Msk   (0x1UL << TIM_CCER_CC4E_Pos)
#define TIM_CCER_CC4E   TIM_CCER_CC4E_Msk
#define TIM_CCER_CC4P_Pos   (13U)
#define TIM_CCER_CC4P_Msk   (0x1UL << TIM_CCER_CC4P_Pos)
#define TIM_CCER_CC4P   TIM_CCER_CC4P_Msk
#define TIM_CCER_CC4NE_Pos   (14U)
#define TIM_CCER_CC4NE_Msk   (0x1UL << TIM_CCER_CC4NE_Pos)
#define TIM_CCER_CC4NE   TIM_CCER_CC4NE_Msk
#define TIM_CCER_CC4NP_Pos   (15U)
#define TIM_CCER_CC4NP_Msk   (0x1UL << TIM_CCER_CC4NP_Pos)
#define TIM_CCER_CC4NP   TIM_CCER_CC4NP_Msk
#define TIM_CCER_CC5E_Pos   (16U)
#define TIM_CCER_CC5E_Msk   (0x1UL << TIM_CCER_CC5E_Pos)
#define TIM_CCER_CC5E   TIM_CCER_CC5E_Msk
#define TIM_CCER_CC5P_Pos   (17U)
#define TIM_CCER_CC5P_Msk   (0x1UL << TIM_CCER_CC5P_Pos)
#define TIM_CCER_CC5P   TIM_CCER_CC5P_Msk
#define TIM_CCER_CC6E_Pos   (20U)
#define TIM_CCER_CC6E_Msk   (0x1UL << TIM_CCER_CC6E_Pos)
#define TIM_CCER_CC6E   TIM_CCER_CC6E_Msk
#define TIM_CCER_CC6P_Pos   (21U)
#define TIM_CCER_CC6P_Msk   (0x1UL << TIM_CCER_CC6P_Pos)
#define TIM_CCER_CC6P   TIM_CCER_CC6P_Msk
#define TIM_CNT_CNT_Pos   (0U)
#define TIM_CNT_CNT_Msk   (0xFFFFFFFFUL << TIM_CNT_CNT_Pos)
#define TIM_CNT_CNT   TIM_CNT_CNT_Msk
#define TIM_CNT_UIFCPY_Pos   (31U)
#define TIM_CNT_UIFCPY_Msk   (0x1UL << TIM_CNT_UIFCPY_Pos)
#define TIM_CNT_UIFCPY   TIM_CNT_UIFCPY_Msk
#define TIM_PSC_PSC_Pos   (0U)
#define TIM_PSC_PSC_Msk   (0xFFFFUL << TIM_PSC_PSC_Pos)
#define TIM_PSC_PSC   TIM_PSC_PSC_Msk
#define TIM_ARR_ARR_Pos   (0U)
#define TIM_ARR_ARR_Msk   (0xFFFFFFFFUL << TIM_ARR_ARR_Pos)
#define TIM_ARR_ARR   TIM_ARR_ARR_Msk
#define TIM_RCR_REP_Pos   (0U)
#define TIM_RCR_REP_Msk   (0xFFFFUL << TIM_RCR_REP_Pos)
#define TIM_RCR_REP   TIM_RCR_REP_Msk
#define TIM_CCR1_CCR1_Pos   (0U)
#define TIM_CCR1_CCR1_Msk   (0xFFFFFFFFUL << TIM_CCR1_CCR1_Pos)
#define TIM_CCR1_CCR1   TIM_CCR1_CCR1_Msk
#define TIM_CCR2_CCR2_Pos   (0U)
#define TIM_CCR2_CCR2_Msk   (0xFFFFFFFFUL << TIM_CCR2_CCR2_Pos)
#define TIM_CCR2_CCR2   TIM_CCR2_CCR2_Msk
#define TIM_CCR3_CCR3_Pos   (0U)
#define TIM_CCR3_CCR3_Msk   (0xFFFFFFFFUL << TIM_CCR3_CCR3_Pos)
#define TIM_CCR3_CCR3   TIM_CCR3_CCR3_Msk
#define TIM_CCR4_CCR4_Pos   (0U)
#define TIM_CCR4_CCR4_Msk   (0xFFFFFFFFUL << TIM_CCR4_CCR4_Pos)
#define TIM_CCR4_CCR4   TIM_CCR4_CCR4_Msk
#define TIM_CCR5_CCR5_Pos   (0U)
#define TIM_CCR5_CCR5_Msk   (0xFFFFFUL << TIM_CCR5_CCR5_Pos)
#define TIM_CCR5_CCR5   TIM_CCR5_CCR5_Msk
#define TIM_CCR5_GC5C1_Pos   (29U)
#define TIM_CCR5_GC5C1_Msk   (0x1UL << TIM_CCR5_GC5C1_Pos)
#define TIM_CCR5_GC5C1   TIM_CCR5_GC5C1_Msk
#define TIM_CCR5_GC5C2_Pos   (30U)
#define TIM_CCR5_GC5C2_Msk   (0x1UL << TIM_CCR5_GC5C2_Pos)
#define TIM_CCR5_GC5C2   TIM_CCR5_GC5C2_Msk
#define TIM_CCR5_GC5C3_Pos   (31U)
#define TIM_CCR5_GC5C3_Msk   (0x1UL << TIM_CCR5_GC5C3_Pos)
#define TIM_CCR5_GC5C3   TIM_CCR5_GC5C3_Msk
#define TIM_CCR6_CCR6_Pos   (0U)
#define TIM_CCR6_CCR6_Msk   (0xFFFFFUL << TIM_CCR6_CCR6_Pos)
#define TIM_CCR6_CCR6   TIM_CCR6_CCR6_Msk
#define TIM_BDTR_DTG_Pos   (0U)
#define TIM_BDTR_DTG_Msk   (0xFFUL << TIM_BDTR_DTG_Pos)
#define TIM_BDTR_DTG   TIM_BDTR_DTG_Msk
#define TIM_BDTR_DTG_0   (0x01UL << TIM_BDTR_DTG_Pos)
#define TIM_BDTR_DTG_1   (0x02UL << TIM_BDTR_DTG_Pos)
#define TIM_BDTR_DTG_2   (0x04UL << TIM_BDTR_DTG_Pos)
#define TIM_BDTR_DTG_3   (0x08UL << TIM_BDTR_DTG_Pos)
#define TIM_BDTR_DTG_4   (0x10UL << TIM_BDTR_DTG_Pos)
#define TIM_BDTR_DTG_5   (0x20UL << TIM_BDTR_DTG_Pos)
#define TIM_BDTR_DTG_6   (0x40UL << TIM_BDTR_DTG_Pos)
#define TIM_BDTR_DTG_7   (0x80UL << TIM_BDTR_DTG_Pos)
#define TIM_BDTR_LOCK_Pos   (8U)
#define TIM_BDTR_LOCK_Msk   (0x3UL << TIM_BDTR_LOCK_Pos)
#define TIM_BDTR_LOCK   TIM_BDTR_LOCK_Msk
#define TIM_BDTR_LOCK_0   (0x1UL << TIM_BDTR_LOCK_Pos)
#define TIM_BDTR_LOCK_1   (0x2UL << TIM_BDTR_LOCK_Pos)
#define TIM_BDTR_OSSI_Pos   (10U)
#define TIM_BDTR_OSSI_Msk   (0x1UL << TIM_BDTR_OSSI_Pos)
#define TIM_BDTR_OSSI   TIM_BDTR_OSSI_Msk
#define TIM_BDTR_OSSR_Pos   (11U)
#define TIM_BDTR_OSSR_Msk   (0x1UL << TIM_BDTR_OSSR_Pos)
#define TIM_BDTR_OSSR   TIM_BDTR_OSSR_Msk
#define TIM_BDTR_BKE_Pos   (12U)
#define TIM_BDTR_BKE_Msk   (0x1UL << TIM_BDTR_BKE_Pos)
#define TIM_BDTR_BKE   TIM_BDTR_BKE_Msk
#define TIM_BDTR_BKP_Pos   (13U)
#define TIM_BDTR_BKP_Msk   (0x1UL << TIM_BDTR_BKP_Pos)
#define TIM_BDTR_BKP   TIM_BDTR_BKP_Msk
#define TIM_BDTR_AOE_Pos   (14U)
#define TIM_BDTR_AOE_Msk   (0x1UL << TIM_BDTR_AOE_Pos)
#define TIM_BDTR_AOE   TIM_BDTR_AOE_Msk
#define TIM_BDTR_MOE_Pos   (15U)
#define TIM_BDTR_MOE_Msk   (0x1UL << TIM_BDTR_MOE_Pos)
#define TIM_BDTR_MOE   TIM_BDTR_MOE_Msk
#define TIM_BDTR_BKF_Pos   (16U)
#define TIM_BDTR_BKF_Msk   (0xFUL << TIM_BDTR_BKF_Pos)
#define TIM_BDTR_BKF   TIM_BDTR_BKF_Msk
#define TIM_BDTR_BK2F_Pos   (20U)
#define TIM_BDTR_BK2F_Msk   (0xFUL << TIM_BDTR_BK2F_Pos)
#define TIM_BDTR_BK2F   TIM_BDTR_BK2F_Msk
#define TIM_BDTR_BK2E_Pos   (24U)
#define TIM_BDTR_BK2E_Msk   (0x1UL << TIM_BDTR_BK2E_Pos)
#define TIM_BDTR_BK2E   TIM_BDTR_BK2E_Msk
#define TIM_BDTR_BK2P_Pos   (25U)
#define TIM_BDTR_BK2P_Msk   (0x1UL << TIM_BDTR_BK2P_Pos)
#define TIM_BDTR_BK2P   TIM_BDTR_BK2P_Msk
#define TIM_BDTR_BKDSRM_Pos   (26U)
#define TIM_BDTR_BKDSRM_Msk   (0x1UL << TIM_BDTR_BKDSRM_Pos)
#define TIM_BDTR_BKDSRM   TIM_BDTR_BKDSRM_Msk
#define TIM_BDTR_BK2DSRM_Pos   (27U)
#define TIM_BDTR_BK2DSRM_Msk   (0x1UL << TIM_BDTR_BK2DSRM_Pos)
#define TIM_BDTR_BK2DSRM   TIM_BDTR_BK2DSRM_Msk
#define TIM_BDTR_BKBID_Pos   (28U)
#define TIM_BDTR_BKBID_Msk   (0x1UL << TIM_BDTR_BKBID_Pos)
#define TIM_BDTR_BKBID   TIM_BDTR_BKBID_Msk
#define TIM_BDTR_BK2BID_Pos   (29U)
#define TIM_BDTR_BK2BID_Msk   (0x1UL << TIM_BDTR_BK2BID_Pos)
#define TIM_BDTR_BK2BID   TIM_BDTR_BK2BID_Msk
#define TIM_DCR_DBA_Pos   (0U)
#define TIM_DCR_DBA_Msk   (0x1FUL << TIM_DCR_DBA_Pos)
#define TIM_DCR_DBA   TIM_DCR_DBA_Msk
#define TIM_DCR_DBA_0   (0x01UL << TIM_DCR_DBA_Pos)
#define TIM_DCR_DBA_1   (0x02UL << TIM_DCR_DBA_Pos)
#define TIM_DCR_DBA_2   (0x04UL << TIM_DCR_DBA_Pos)
#define TIM_DCR_DBA_3   (0x08UL << TIM_DCR_DBA_Pos)
#define TIM_DCR_DBA_4   (0x10UL << TIM_DCR_DBA_Pos)
#define TIM_DCR_DBL_Pos   (8U)
#define TIM_DCR_DBL_Msk   (0x1FUL << TIM_DCR_DBL_Pos)
#define TIM_DCR_DBL   TIM_DCR_DBL_Msk
#define TIM_DCR_DBL_0   (0x01UL << TIM_DCR_DBL_Pos)
#define TIM_DCR_DBL_1   (0x02UL << TIM_DCR_DBL_Pos)
#define TIM_DCR_DBL_2   (0x04UL << TIM_DCR_DBL_Pos)
#define TIM_DCR_DBL_3   (0x08UL << TIM_DCR_DBL_Pos)
#define TIM_DCR_DBL_4   (0x10UL << TIM_DCR_DBL_Pos)
#define TIM_DCR_DBSS_Pos   (16U)
#define TIM_DCR_DBSS_Msk   (0xFUL << TIM_DCR_DBSS_Pos)
#define TIM_DCR_DBSS   TIM_DCR_DBSS_Msk
#define TIM_DCR_DBSS_0   (0x01UL << TIM_DCR_DBSS_Pos)
#define TIM_DCR_DBSS_1   (0x02UL << TIM_DCR_DBSS_Pos)
#define TIM_DCR_DBSS_2   (0x04UL << TIM_DCR_DBSS_Pos)
#define TIM_DCR_DBSS_3   (0x08UL << TIM_DCR_DBSS_Pos)
#define TIM1_AF1_BKINE_Pos   (0U)
#define TIM1_AF1_BKINE_Msk   (0x1UL << TIM1_AF1_BKINE_Pos)
#define TIM1_AF1_BKINE   TIM1_AF1_BKINE_Msk
#define TIM1_AF1_BKCMP1E_Pos   (1U)
#define TIM1_AF1_BKCMP1E_Msk   (0x1UL << TIM1_AF1_BKCMP1E_Pos)
#define TIM1_AF1_BKCMP1E   TIM1_AF1_BKCMP1E_Msk
#define TIM1_AF1_BKCMP2E_Pos   (2U)
#define TIM1_AF1_BKCMP2E_Msk   (0x1UL << TIM1_AF1_BKCMP2E_Pos)
#define TIM1_AF1_BKCMP2E   TIM1_AF1_BKCMP2E_Msk
#define TIM1_AF1_BKDF1BK0E_Pos   (8U)
#define TIM1_AF1_BKDF1BK0E_Msk   (0x1UL << TIM1_AF1_BKDF1BK0E_Pos)
#define TIM1_AF1_BKDF1BK0E   TIM1_AF1_BKDF1BK0E_Msk
#define TIM1_AF1_BKINP_Pos   (9U)
#define TIM1_AF1_BKINP_Msk   (0x1UL << TIM1_AF1_BKINP_Pos)
#define TIM1_AF1_BKINP   TIM1_AF1_BKINP_Msk
#define TIM1_AF1_BKCMP1P_Pos   (10U)
#define TIM1_AF1_BKCMP1P_Msk   (0x1UL << TIM1_AF1_BKCMP1P_Pos)
#define TIM1_AF1_BKCMP1P   TIM1_AF1_BKCMP1P_Msk
#define TIM1_AF1_BKCMP2P_Pos   (11U)
#define TIM1_AF1_BKCMP2P_Msk   (0x1UL << TIM1_AF1_BKCMP2P_Pos)
#define TIM1_AF1_BKCMP2P   TIM1_AF1_BKCMP2P_Msk
#define TIM1_AF1_ETRSEL_Pos   (14U)
#define TIM1_AF1_ETRSEL_Msk   (0xFUL << TIM1_AF1_ETRSEL_Pos)
#define TIM1_AF1_ETRSEL   TIM1_AF1_ETRSEL_Msk
#define TIM1_AF1_ETRSEL_0   (0x1UL << TIM1_AF1_ETRSEL_Pos)
#define TIM1_AF1_ETRSEL_1   (0x2UL << TIM1_AF1_ETRSEL_Pos)
#define TIM1_AF1_ETRSEL_2   (0x4UL << TIM1_AF1_ETRSEL_Pos)
#define TIM1_AF1_ETRSEL_3   (0x8UL << TIM1_AF1_ETRSEL_Pos)
#define TIM1_AF2_BK2INE_Pos   (0U)
#define TIM1_AF2_BK2INE_Msk   (0x1UL << TIM1_AF2_BK2INE_Pos)
#define TIM1_AF2_BK2INE   TIM1_AF2_BK2INE_Msk
#define TIM1_AF2_BK2CMP1E_Pos   (1U)
#define TIM1_AF2_BK2CMP1E_Msk   (0x1UL << TIM1_AF2_BK2CMP1E_Pos)
#define TIM1_AF2_BK2CMP1E   TIM1_AF2_BK2CMP1E_Msk
#define TIM1_AF2_BK2CMP2E_Pos   (2U)
#define TIM1_AF2_BK2CMP2E_Msk   (0x1UL << TIM1_AF2_BK2CMP2E_Pos)
#define TIM1_AF2_BK2CMP2E   TIM1_AF2_BK2CMP2E_Msk
#define TIM1_AF2_BK2DF1BK1E_Pos   (8U)
#define TIM1_AF2_BK2DF1BK1E_Msk   (0x1UL << TIM1_AF2_BK2DF1BK1E_Pos)
#define TIM1_AF2_BK2DF1BK1E   TIM1_AF2_BK2DF1BK1E_Msk
#define TIM1_AF2_BK2INP_Pos   (9U)
#define TIM1_AF2_BK2INP_Msk   (0x1UL << TIM1_AF2_BK2INP_Pos)
#define TIM1_AF2_BK2INP   TIM1_AF2_BK2INP_Msk
#define TIM1_AF2_BK2CMP1P_Pos   (10U)
#define TIM1_AF2_BK2CMP1P_Msk   (0x1UL << TIM1_AF2_BK2CMP1P_Pos)
#define TIM1_AF2_BK2CMP1P   TIM1_AF2_BK2CMP1P_Msk
#define TIM1_AF2_BK2CMP2P_Pos   (11U)
#define TIM1_AF2_BK2CMP2P_Msk   (0x1UL << TIM1_AF2_BK2CMP2P_Pos)
#define TIM1_AF2_BK2CMP2P   TIM1_AF2_BK2CMP2P_Msk
#define TIM1_AF2_OCRSEL_Pos   (16U)
#define TIM1_AF2_OCRSEL_Msk   (0x1UL << TIM1_AF2_OCRSEL_Pos)
#define TIM1_AF2_OCRSEL   TIM1_AF2_OCRSEL_Msk
#define TIM1_AF2_OCRSEL_0   (0x1UL << TIM1_AF2_OCRSEL_Pos)
#define TIM_OR1_HSE32EN_Pos   (1U)
#define TIM_OR1_HSE32EN_Msk   (0x1UL << TIM_OR1_HSE32EN_Pos)
#define TIM_OR1_HSE32EN   TIM_OR1_HSE32EN_Msk
#define TIM_TISEL_TI1SEL_Pos   (0U)
#define TIM_TISEL_TI1SEL_Msk   (0xFUL << TIM_TISEL_TI1SEL_Pos)
#define TIM_TISEL_TI1SEL   TIM_TISEL_TI1SEL_Msk
#define TIM_TISEL_TI1SEL_0   (0x1UL << TIM_TISEL_TI1SEL_Pos)
#define TIM_TISEL_TI1SEL_1   (0x2UL << TIM_TISEL_TI1SEL_Pos)
#define TIM_TISEL_TI1SEL_2   (0x4UL << TIM_TISEL_TI1SEL_Pos)
#define TIM_TISEL_TI1SEL_3   (0x8UL << TIM_TISEL_TI1SEL_Pos)
#define TIM_TISEL_TI2SEL_Pos   (8U)
#define TIM_TISEL_TI2SEL_Msk   (0xFUL << TIM_TISEL_TI2SEL_Pos)
#define TIM_TISEL_TI2SEL   TIM_TISEL_TI2SEL_Msk
#define TIM_TISEL_TI2SEL_0   (0x1UL << TIM_TISEL_TI2SEL_Pos)
#define TIM_TISEL_TI2SEL_1   (0x2UL << TIM_TISEL_TI2SEL_Pos)
#define TIM_TISEL_TI2SEL_2   (0x4UL << TIM_TISEL_TI2SEL_Pos)
#define TIM_TISEL_TI2SEL_3   (0x8UL << TIM_TISEL_TI2SEL_Pos)
#define TIM_TISEL_TI3SEL_Pos   (16U)
#define TIM_TISEL_TI3SEL_Msk   (0xFUL << TIM_TISEL_TI3SEL_Pos)
#define TIM_TISEL_TI3SEL   TIM_TISEL_TI3SEL_Msk
#define TIM_TISEL_TI3SEL_0   (0x1UL << TIM_TISEL_TI3SEL_Pos)
#define TIM_TISEL_TI3SEL_1   (0x2UL << TIM_TISEL_TI3SEL_Pos)
#define TIM_TISEL_TI3SEL_2   (0x4UL << TIM_TISEL_TI3SEL_Pos)
#define TIM_TISEL_TI3SEL_3   (0x8UL << TIM_TISEL_TI3SEL_Pos)
#define TIM_TISEL_TI4SEL_Pos   (24U)
#define TIM_TISEL_TI4SEL_Msk   (0xFUL << TIM_TISEL_TI4SEL_Pos)
#define TIM_TISEL_TI4SEL   TIM_TISEL_TI4SEL_Msk
#define TIM_TISEL_TI4SEL_0   (0x1UL << TIM_TISEL_TI4SEL_Pos)
#define TIM_TISEL_TI4SEL_1   (0x2UL << TIM_TISEL_TI4SEL_Pos)
#define TIM_TISEL_TI4SEL_2   (0x4UL << TIM_TISEL_TI4SEL_Pos)
#define TIM_TISEL_TI4SEL_3   (0x8UL << TIM_TISEL_TI4SEL_Pos)
#define TIM_DTR2_DTGF_Pos   (0U)
#define TIM_DTR2_DTGF_Msk   (0xFFUL << TIM_DTR2_DTGF_Pos)
#define TIM_DTR2_DTGF   TIM_DTR2_DTGF_Msk
#define TIM_DTR2_DTGF_0   (0x01UL << TIM_DTR2_DTGF_Pos)
#define TIM_DTR2_DTGF_1   (0x02UL << TIM_DTR2_DTGF_Pos)
#define TIM_DTR2_DTGF_2   (0x04UL << TIM_DTR2_DTGF_Pos)
#define TIM_DTR2_DTGF_3   (0x08UL << TIM_DTR2_DTGF_Pos)
#define TIM_DTR2_DTGF_4   (0x10UL << TIM_DTR2_DTGF_Pos)
#define TIM_DTR2_DTGF_5   (0x20UL << TIM_DTR2_DTGF_Pos)
#define TIM_DTR2_DTGF_6   (0x40UL << TIM_DTR2_DTGF_Pos)
#define TIM_DTR2_DTGF_7   (0x80UL << TIM_DTR2_DTGF_Pos)
#define TIM_DTR2_DTAE_Pos   (16U)
#define TIM_DTR2_DTAE_Msk   (0x1UL << TIM_DTR2_DTAE_Pos)
#define TIM_DTR2_DTAE   TIM_DTR2_DTAE_Msk
#define TIM_DTR2_DTPE_Pos   (17U)
#define TIM_DTR2_DTPE_Msk   (0x1UL << TIM_DTR2_DTPE_Pos)
#define TIM_DTR2_DTPE   TIM_DTR2_DTPE_Msk
#define TIM_ECR_IE_Pos   (0U)
#define TIM_ECR_IE_Msk   (0x1UL << TIM_ECR_IE_Pos)
#define TIM_ECR_IE   TIM_ECR_IE_Msk
#define TIM_ECR_IDIR_Pos   (1U)
#define TIM_ECR_IDIR_Msk   (0x3UL << TIM_ECR_IDIR_Pos)
#define TIM_ECR_IDIR   TIM_ECR_IDIR_Msk
#define TIM_ECR_IDIR_0   (0x01UL << TIM_ECR_IDIR_Pos)
#define TIM_ECR_IDIR_1   (0x02UL << TIM_ECR_IDIR_Pos)
#define TIM_ECR_IBLK_Pos   (3U)
#define TIM_ECR_IBLK_Msk   (0x3UL << TIM_ECR_IBLK_Pos)
#define TIM_ECR_IBLK   TIM_ECR_IBLK_Msk
#define TIM_ECR_IBLK_0   (0x01UL << TIM_ECR_IBLK_Pos)
#define TIM_ECR_IBLK_1   (0x02UL << TIM_ECR_IBLK_Pos)
#define TIM_ECR_FIDX_Pos   (5U)
#define TIM_ECR_FIDX_Msk   (0x1UL << TIM_ECR_FIDX_Pos)
#define TIM_ECR_FIDX   TIM_ECR_FIDX_Msk
#define TIM_ECR_IPOS_Pos   (6U)
#define TIM_ECR_IPOS_Msk   (0x3UL << TIM_ECR_IPOS_Pos)
#define TIM_ECR_IPOS   TIM_ECR_IPOS_Msk
#define TIM_ECR_IPOS_0   (0x01UL << TIM_ECR_IPOS_Pos)
#define TIM_ECR_IPOS_1   (0x02UL << TIM_ECR_IPOS_Pos)
#define TIM_ECR_PW_Pos   (16U)
#define TIM_ECR_PW_Msk   (0xFFUL << TIM_ECR_PW_Pos)
#define TIM_ECR_PW   TIM_ECR_PW_Msk
#define TIM_ECR_PW_0   (0x01UL << TIM_ECR_PW_Pos)
#define TIM_ECR_PW_1   (0x02UL << TIM_ECR_PW_Pos)
#define TIM_ECR_PW_2   (0x04UL << TIM_ECR_PW_Pos)
#define TIM_ECR_PW_3   (0x08UL << TIM_ECR_PW_Pos)
#define TIM_ECR_PW_4   (0x10UL << TIM_ECR_PW_Pos)
#define TIM_ECR_PW_5   (0x20UL << TIM_ECR_PW_Pos)
#define TIM_ECR_PW_6   (0x40UL << TIM_ECR_PW_Pos)
#define TIM_ECR_PW_7   (0x80UL << TIM_ECR_PW_Pos)
#define TIM_ECR_PWPRSC_Pos   (24U)
#define TIM_ECR_PWPRSC_Msk   (0x7UL << TIM_ECR_PWPRSC_Pos)
#define TIM_ECR_PWPRSC   TIM_ECR_PWPRSC_Msk
#define TIM_ECR_PWPRSC_0   (0x01UL << TIM_ECR_PWPRSC_Pos)
#define TIM_ECR_PWPRSC_1   (0x02UL << TIM_ECR_PWPRSC_Pos)
#define TIM_ECR_PWPRSC_2   (0x04UL << TIM_ECR_PWPRSC_Pos)
#define TIM_DMAR_DMAB_Pos   (0U)
#define TIM_DMAR_DMAB_Msk   (0xFFFFFFFFUL << TIM_DMAR_DMAB_Pos)
#define TIM_DMAR_DMAB   TIM_DMAR_DMAB_Msk
#define LPTIM_ISR_CC1IF_Pos   (0U)
#define LPTIM_ISR_CC1IF_Msk   (0x1UL << LPTIM_ISR_CC1IF_Pos)
#define LPTIM_ISR_CC1IF   LPTIM_ISR_CC1IF_Msk
#define LPTIM_ISR_ARRM_Pos   (1U)
#define LPTIM_ISR_ARRM_Msk   (0x1UL << LPTIM_ISR_ARRM_Pos)
#define LPTIM_ISR_ARRM   LPTIM_ISR_ARRM_Msk
#define LPTIM_ISR_EXTTRIG_Pos   (2U)
#define LPTIM_ISR_EXTTRIG_Msk   (0x1UL << LPTIM_ISR_EXTTRIG_Pos)
#define LPTIM_ISR_EXTTRIG   LPTIM_ISR_EXTTRIG_Msk
#define LPTIM_ISR_CMP1OK_Pos   (3U)
#define LPTIM_ISR_CMP1OK_Msk   (0x1UL << LPTIM_ISR_CMP1OK_Pos)
#define LPTIM_ISR_CMP1OK   LPTIM_ISR_CMP1OK_Msk
#define LPTIM_ISR_ARROK_Pos   (4U)
#define LPTIM_ISR_ARROK_Msk   (0x1UL << LPTIM_ISR_ARROK_Pos)
#define LPTIM_ISR_ARROK   LPTIM_ISR_ARROK_Msk
#define LPTIM_ISR_UP_Pos   (5U)
#define LPTIM_ISR_UP_Msk   (0x1UL << LPTIM_ISR_UP_Pos)
#define LPTIM_ISR_UP   LPTIM_ISR_UP_Msk
#define LPTIM_ISR_DOWN_Pos   (6U)
#define LPTIM_ISR_DOWN_Msk   (0x1UL << LPTIM_ISR_DOWN_Pos)
#define LPTIM_ISR_DOWN   LPTIM_ISR_DOWN_Msk
#define LPTIM_ISR_UE_Pos   (7U)
#define LPTIM_ISR_UE_Msk   (0x1UL << LPTIM_ISR_UE_Pos)
#define LPTIM_ISR_UE   LPTIM_ISR_UE_Msk
#define LPTIM_ISR_REPOK_Pos   (8U)
#define LPTIM_ISR_REPOK_Msk   (0x1UL << LPTIM_ISR_REPOK_Pos)
#define LPTIM_ISR_REPOK   LPTIM_ISR_REPOK_Msk
#define LPTIM_ISR_CC2IF_Pos   (9U)
#define LPTIM_ISR_CC2IF_Msk   (0x1UL << LPTIM_ISR_CC2IF_Pos)
#define LPTIM_ISR_CC2IF   LPTIM_ISR_CC2IF_Msk
#define LPTIM_ISR_CC1OF_Pos   (12U)
#define LPTIM_ISR_CC1OF_Msk   (0x1UL << LPTIM_ISR_CC1OF_Pos)
#define LPTIM_ISR_CC1OF   LPTIM_ISR_CC1OF_Msk
#define LPTIM_ISR_CC2OF_Pos   (13U)
#define LPTIM_ISR_CC2OF_Msk   (0x1UL << LPTIM_ISR_CC2OF_Pos)
#define LPTIM_ISR_CC2OF   LPTIM_ISR_CC2OF_Msk
#define LPTIM_ISR_CMP2OK_Pos   (19U)
#define LPTIM_ISR_CMP2OK_Msk   (0x1UL << LPTIM_ISR_CMP2OK_Pos)
#define LPTIM_ISR_CMP2OK   LPTIM_ISR_CMP2OK_Msk
#define LPTIM_ISR_DIEROK_Pos   (24U)
#define LPTIM_ISR_DIEROK_Msk   (0x1UL << LPTIM_ISR_DIEROK_Pos)
#define LPTIM_ISR_DIEROK   LPTIM_ISR_DIEROK_Msk
#define LPTIM_ICR_CC1CF_Pos   (0U)
#define LPTIM_ICR_CC1CF_Msk   (0x1UL << LPTIM_ICR_CC1CF_Pos)
#define LPTIM_ICR_CC1CF   LPTIM_ICR_CC1CF_Msk
#define LPTIM_ICR_ARRMCF_Pos   (1U)
#define LPTIM_ICR_ARRMCF_Msk   (0x1UL << LPTIM_ICR_ARRMCF_Pos)
#define LPTIM_ICR_ARRMCF   LPTIM_ICR_ARRMCF_Msk
#define LPTIM_ICR_EXTTRIGCF_Pos   (2U)
#define LPTIM_ICR_EXTTRIGCF_Msk   (0x1UL << LPTIM_ICR_EXTTRIGCF_Pos)
#define LPTIM_ICR_EXTTRIGCF   LPTIM_ICR_EXTTRIGCF_Msk
#define LPTIM_ICR_CMP1OKCF_Pos   (3U)
#define LPTIM_ICR_CMP1OKCF_Msk   (0x1UL << LPTIM_ICR_CMP1OKCF_Pos)
#define LPTIM_ICR_CMP1OKCF   LPTIM_ICR_CMP1OKCF_Msk
#define LPTIM_ICR_ARROKCF_Pos   (4U)
#define LPTIM_ICR_ARROKCF_Msk   (0x1UL << LPTIM_ICR_ARROKCF_Pos)
#define LPTIM_ICR_ARROKCF   LPTIM_ICR_ARROKCF_Msk
#define LPTIM_ICR_UPCF_Pos   (5U)
#define LPTIM_ICR_UPCF_Msk   (0x1UL << LPTIM_ICR_UPCF_Pos)
#define LPTIM_ICR_UPCF   LPTIM_ICR_UPCF_Msk
#define LPTIM_ICR_DOWNCF_Pos   (6U)
#define LPTIM_ICR_DOWNCF_Msk   (0x1UL << LPTIM_ICR_DOWNCF_Pos)
#define LPTIM_ICR_DOWNCF   LPTIM_ICR_DOWNCF_Msk
#define LPTIM_ICR_UECF_Pos   (7U)
#define LPTIM_ICR_UECF_Msk   (0x1UL << LPTIM_ICR_UECF_Pos)
#define LPTIM_ICR_UECF   LPTIM_ICR_UECF_Msk
#define LPTIM_ICR_REPOKCF_Pos   (8U)
#define LPTIM_ICR_REPOKCF_Msk   (0x1UL << LPTIM_ICR_REPOKCF_Pos)
#define LPTIM_ICR_REPOKCF   LPTIM_ICR_REPOKCF_Msk
#define LPTIM_ICR_CC2CF_Pos   (9U)
#define LPTIM_ICR_CC2CF_Msk   (0x1UL << LPTIM_ICR_CC2CF_Pos)
#define LPTIM_ICR_CC2CF   LPTIM_ICR_CC2CF_Msk
#define LPTIM_ICR_CC1OCF_Pos   (12U)
#define LPTIM_ICR_CC1OCF_Msk   (0x1UL << LPTIM_ICR_CC1OCF_Pos)
#define LPTIM_ICR_CC1OCF   LPTIM_ICR_CC1OCF_Msk
#define LPTIM_ICR_CC2OCF_Pos   (13U)
#define LPTIM_ICR_CC2OCF_Msk   (0x1UL << LPTIM_ICR_CC2OCF_Pos)
#define LPTIM_ICR_CC2OCF   LPTIM_ICR_CC2OCF_Msk
#define LPTIM_ICR_CMP2OKCF_Pos   (19U)
#define LPTIM_ICR_CMP2OKCF_Msk   (0x1UL << LPTIM_ICR_CMP2OKCF_Pos)
#define LPTIM_ICR_CMP2OKCF   LPTIM_ICR_CMP2OKCF_Msk
#define LPTIM_ICR_DIEROKCF_Pos   (24U)
#define LPTIM_ICR_DIEROKCF_Msk   (0x1UL << LPTIM_ICR_DIEROKCF_Pos)
#define LPTIM_ICR_DIEROKCF   LPTIM_ICR_DIEROKCF_Msk
#define LPTIM_DIER_CC1IE_Pos   (0U)
#define LPTIM_DIER_CC1IE_Msk   (0x1UL << LPTIM_DIER_CC1IE_Pos)
#define LPTIM_DIER_CC1IE   LPTIM_DIER_CC1IE_Msk
#define LPTIM_DIER_ARRMIE_Pos   (1U)
#define LPTIM_DIER_ARRMIE_Msk   (0x1UL << LPTIM_DIER_ARRMIE_Pos)
#define LPTIM_DIER_ARRMIE   LPTIM_DIER_ARRMIE_Msk
#define LPTIM_DIER_EXTTRIGIE_Pos   (2U)
#define LPTIM_DIER_EXTTRIGIE_Msk   (0x1UL << LPTIM_DIER_EXTTRIGIE_Pos)
#define LPTIM_DIER_EXTTRIGIE   LPTIM_DIER_EXTTRIGIE_Msk
#define LPTIM_DIER_CMP1OKIE_Pos   (3U)
#define LPTIM_DIER_CMP1OKIE_Msk   (0x1UL << LPTIM_DIER_CMP1OKIE_Pos)
#define LPTIM_DIER_CMP1OKIE   LPTIM_DIER_CMP1OKIE_Msk
#define LPTIM_DIER_ARROKIE_Pos   (4U)
#define LPTIM_DIER_ARROKIE_Msk   (0x1UL << LPTIM_DIER_ARROKIE_Pos)
#define LPTIM_DIER_ARROKIE   LPTIM_DIER_ARROKIE_Msk
#define LPTIM_DIER_UPIE_Pos   (5U)
#define LPTIM_DIER_UPIE_Msk   (0x1UL << LPTIM_DIER_UPIE_Pos)
#define LPTIM_DIER_UPIE   LPTIM_DIER_UPIE_Msk
#define LPTIM_DIER_DOWNIE_Pos   (6U)
#define LPTIM_DIER_DOWNIE_Msk   (0x1UL << LPTIM_DIER_DOWNIE_Pos)
#define LPTIM_DIER_DOWNIE   LPTIM_DIER_DOWNIE_Msk
#define LPTIM_DIER_UEIE_Pos   (7U)
#define LPTIM_DIER_UEIE_Msk   (0x1UL << LPTIM_DIER_UEIE_Pos)
#define LPTIM_DIER_UEIE   LPTIM_DIER_UEIE_Msk
#define LPTIM_DIER_REPOKIE_Pos   (8U)
#define LPTIM_DIER_REPOKIE_Msk   (0x1UL << LPTIM_DIER_REPOKIE_Pos)
#define LPTIM_DIER_REPOKIE   LPTIM_DIER_REPOKIE_Msk
#define LPTIM_DIER_CC2IE_Pos   (9U)
#define LPTIM_DIER_CC2IE_Msk   (0x1UL << LPTIM_DIER_CC2IE_Pos)
#define LPTIM_DIER_CC2IE   LPTIM_DIER_CC2IE_Msk
#define LPTIM_DIER_CC1OIE_Pos   (12U)
#define LPTIM_DIER_CC1OIE_Msk   (0x1UL << LPTIM_DIER_CC1OIE_Pos)
#define LPTIM_DIER_CC1OIE   LPTIM_DIER_CC1OIE_Msk
#define LPTIM_DIER_CC2OIE_Pos   (13U)
#define LPTIM_DIER_CC2OIE_Msk   (0x1UL << LPTIM_DIER_CC2OIE_Pos)
#define LPTIM_DIER_CC2OIE   LPTIM_DIER_CC2OIE_Msk
#define LPTIM_DIER_CC1DE_Pos   (16U)
#define LPTIM_DIER_CC1DE_Msk   (0x1UL << LPTIM_DIER_CC1DE_Pos)
#define LPTIM_DIER_CC1DE   LPTIM_DIER_CC1DE_Msk
#define LPTIM_DIER_CMP2OKIE_Pos   (19U)
#define LPTIM_DIER_CMP2OKIE_Msk   (0x1UL << LPTIM_DIER_CMP2OKIE_Pos)
#define LPTIM_DIER_CMP2OKIE   LPTIM_DIER_CMP2OKIE_Msk
#define LPTIM_DIER_UEDE_Pos   (23U)
#define LPTIM_DIER_UEDE_Msk   (0x1UL << LPTIM_DIER_UEDE_Pos)
#define LPTIM_DIER_UEDE   LPTIM_DIER_UEDE_Msk
#define LPTIM_DIER_CC2DE_Pos   (25U)
#define LPTIM_DIER_CC2DE_Msk   (0x1UL << LPTIM_DIER_CC2DE_Pos)
#define LPTIM_DIER_CC2DE   LPTIM_DIER_CC2DE_Msk
#define LPTIM_CFGR_CKSEL_Pos   (0U)
#define LPTIM_CFGR_CKSEL_Msk   (0x1UL << LPTIM_CFGR_CKSEL_Pos)
#define LPTIM_CFGR_CKSEL   LPTIM_CFGR_CKSEL_Msk
#define LPTIM_CFGR_CKPOL_Pos   (1U)
#define LPTIM_CFGR_CKPOL_Msk   (0x3UL << LPTIM_CFGR_CKPOL_Pos)
#define LPTIM_CFGR_CKPOL   LPTIM_CFGR_CKPOL_Msk
#define LPTIM_CFGR_CKPOL_0   (0x1UL << LPTIM_CFGR_CKPOL_Pos)
#define LPTIM_CFGR_CKPOL_1   (0x2UL << LPTIM_CFGR_CKPOL_Pos)
#define LPTIM_CFGR_CKFLT_Pos   (3U)
#define LPTIM_CFGR_CKFLT_Msk   (0x3UL << LPTIM_CFGR_CKFLT_Pos)
#define LPTIM_CFGR_CKFLT   LPTIM_CFGR_CKFLT_Msk
#define LPTIM_CFGR_CKFLT_0   (0x1UL << LPTIM_CFGR_CKFLT_Pos)
#define LPTIM_CFGR_CKFLT_1   (0x2UL << LPTIM_CFGR_CKFLT_Pos)
#define LPTIM_CFGR_TRGFLT_Pos   (6U)
#define LPTIM_CFGR_TRGFLT_Msk   (0x3UL << LPTIM_CFGR_TRGFLT_Pos)
#define LPTIM_CFGR_TRGFLT   LPTIM_CFGR_TRGFLT_Msk
#define LPTIM_CFGR_TRGFLT_0   (0x1UL << LPTIM_CFGR_TRGFLT_Pos)
#define LPTIM_CFGR_TRGFLT_1   (0x2UL << LPTIM_CFGR_TRGFLT_Pos)
#define LPTIM_CFGR_PRESC_Pos   (9U)
#define LPTIM_CFGR_PRESC_Msk   (0x7UL << LPTIM_CFGR_PRESC_Pos)
#define LPTIM_CFGR_PRESC   LPTIM_CFGR_PRESC_Msk
#define LPTIM_CFGR_PRESC_0   (0x1UL << LPTIM_CFGR_PRESC_Pos)
#define LPTIM_CFGR_PRESC_1   (0x2UL << LPTIM_CFGR_PRESC_Pos)
#define LPTIM_CFGR_PRESC_2   (0x4UL << LPTIM_CFGR_PRESC_Pos)
#define LPTIM_CFGR_TRIGSEL_Pos   (13U)
#define LPTIM_CFGR_TRIGSEL_Msk   (0x7UL << LPTIM_CFGR_TRIGSEL_Pos)
#define LPTIM_CFGR_TRIGSEL   LPTIM_CFGR_TRIGSEL_Msk
#define LPTIM_CFGR_TRIGSEL_0   (0x1UL << LPTIM_CFGR_TRIGSEL_Pos)
#define LPTIM_CFGR_TRIGSEL_1   (0x2UL << LPTIM_CFGR_TRIGSEL_Pos)
#define LPTIM_CFGR_TRIGSEL_2   (0x4UL << LPTIM_CFGR_TRIGSEL_Pos)
#define LPTIM_CFGR_TRIGEN_Pos   (17U)
#define LPTIM_CFGR_TRIGEN_Msk   (0x3UL << LPTIM_CFGR_TRIGEN_Pos)
#define LPTIM_CFGR_TRIGEN   LPTIM_CFGR_TRIGEN_Msk
#define LPTIM_CFGR_TRIGEN_0   (0x1UL << LPTIM_CFGR_TRIGEN_Pos)
#define LPTIM_CFGR_TRIGEN_1   (0x2UL << LPTIM_CFGR_TRIGEN_Pos)
#define LPTIM_CFGR_TIMOUT_Pos   (19U)
#define LPTIM_CFGR_TIMOUT_Msk   (0x1UL << LPTIM_CFGR_TIMOUT_Pos)
#define LPTIM_CFGR_TIMOUT   LPTIM_CFGR_TIMOUT_Msk
#define LPTIM_CFGR_WAVE_Pos   (20U)
#define LPTIM_CFGR_WAVE_Msk   (0x1UL << LPTIM_CFGR_WAVE_Pos)
#define LPTIM_CFGR_WAVE   LPTIM_CFGR_WAVE_Msk
#define LPTIM_CFGR_WAVPOL_Pos   (21U)
#define LPTIM_CFGR_WAVPOL_Msk   (0x1UL << LPTIM_CFGR_WAVPOL_Pos)
#define LPTIM_CFGR_WAVPOL   LPTIM_CFGR_WAVPOL_Msk
#define LPTIM_CFGR_PRELOAD_Pos   (22U)
#define LPTIM_CFGR_PRELOAD_Msk   (0x1UL << LPTIM_CFGR_PRELOAD_Pos)
#define LPTIM_CFGR_PRELOAD   LPTIM_CFGR_PRELOAD_Msk
#define LPTIM_CFGR_COUNTMODE_Pos   (23U)
#define LPTIM_CFGR_COUNTMODE_Msk   (0x1UL << LPTIM_CFGR_COUNTMODE_Pos)
#define LPTIM_CFGR_COUNTMODE   LPTIM_CFGR_COUNTMODE_Msk
#define LPTIM_CFGR_ENC_Pos   (24U)
#define LPTIM_CFGR_ENC_Msk   (0x1UL << LPTIM_CFGR_ENC_Pos)
#define LPTIM_CFGR_ENC   LPTIM_CFGR_ENC_Msk
#define LPTIM_CR_ENABLE_Pos   (0U)
#define LPTIM_CR_ENABLE_Msk   (0x1UL << LPTIM_CR_ENABLE_Pos)
#define LPTIM_CR_ENABLE   LPTIM_CR_ENABLE_Msk
#define LPTIM_CR_SNGSTRT_Pos   (1U)
#define LPTIM_CR_SNGSTRT_Msk   (0x1UL << LPTIM_CR_SNGSTRT_Pos)
#define LPTIM_CR_SNGSTRT   LPTIM_CR_SNGSTRT_Msk
#define LPTIM_CR_CNTSTRT_Pos   (2U)
#define LPTIM_CR_CNTSTRT_Msk   (0x1UL << LPTIM_CR_CNTSTRT_Pos)
#define LPTIM_CR_CNTSTRT   LPTIM_CR_CNTSTRT_Msk
#define LPTIM_CR_COUNTRST_Pos   (3U)
#define LPTIM_CR_COUNTRST_Msk   (0x1UL << LPTIM_CR_COUNTRST_Pos)
#define LPTIM_CR_COUNTRST   LPTIM_CR_COUNTRST_Msk
#define LPTIM_CR_RSTARE_Pos   (4U)
#define LPTIM_CR_RSTARE_Msk   (0x1UL << LPTIM_CR_RSTARE_Pos)
#define LPTIM_CR_RSTARE   LPTIM_CR_RSTARE_Msk
#define LPTIM_CCR1_CCR1_Pos   (0U)
#define LPTIM_CCR1_CCR1_Msk   (0xFFFFUL << LPTIM_CCR1_CCR1_Pos)
#define LPTIM_CCR1_CCR1   LPTIM_CCR1_CCR1_Msk
#define LPTIM_ARR_ARR_Pos   (0U)
#define LPTIM_ARR_ARR_Msk   (0xFFFFUL << LPTIM_ARR_ARR_Pos)
#define LPTIM_ARR_ARR   LPTIM_ARR_ARR_Msk
#define LPTIM_CNT_CNT_Pos   (0U)
#define LPTIM_CNT_CNT_Msk   (0xFFFFUL << LPTIM_CNT_CNT_Pos)
#define LPTIM_CNT_CNT   LPTIM_CNT_CNT_Msk
#define LPTIM_CFGR2_IN1SEL_Pos   (0U)
#define LPTIM_CFGR2_IN1SEL_Msk   (0x3UL << LPTIM_CFGR2_IN1SEL_Pos)
#define LPTIM_CFGR2_IN1SEL   LPTIM_CFGR2_IN1SEL_Msk
#define LPTIM_CFGR2_IN1SEL_0   (0x1UL << LPTIM_CFGR2_IN1SEL_Pos)
#define LPTIM_CFGR2_IN1SEL_1   (0x2UL << LPTIM_CFGR2_IN1SEL_Pos)
#define LPTIM_CFGR2_IN2SEL_Pos   (4U)
#define LPTIM_CFGR2_IN2SEL_Msk   (0x3UL << LPTIM_CFGR2_IN2SEL_Pos)
#define LPTIM_CFGR2_IN2SEL   LPTIM_CFGR2_IN2SEL_Msk
#define LPTIM_CFGR2_IN2SEL_0   (0x1UL << LPTIM_CFGR2_IN2SEL_Pos)
#define LPTIM_CFGR2_IN2SEL_1   (0x2UL << LPTIM_CFGR2_IN2SEL_Pos)
#define LPTIM_CFGR2_IC1SEL_Pos   (16U)
#define LPTIM_CFGR2_IC1SEL_Msk   (0x3UL << LPTIM_CFGR2_IC1SEL_Pos)
#define LPTIM_CFGR2_IC1SEL   LPTIM_CFGR2_IC1SEL_Msk
#define LPTIM_CFGR2_IC1SEL_0   (0x1UL << LPTIM_CFGR2_IC1SEL_Pos)
#define LPTIM_CFGR2_IC1SEL_1   (0x2UL << LPTIM_CFGR2_IC1SEL_Pos)
#define LPTIM_CFGR2_IC2SEL_Pos   (20U)
#define LPTIM_CFGR2_IC2SEL_Msk   (0x3UL << LPTIM_CFGR2_IC2SEL_Pos)
#define LPTIM_CFGR2_IC2SEL   LPTIM_CFGR2_IC2SEL_Msk
#define LPTIM_CFGR2_IC2SEL_0   (0x1UL << LPTIM_CFGR2_IC2SEL_Pos)
#define LPTIM_CFGR2_IC2SEL_1   (0x2UL << LPTIM_CFGR2_IC2SEL_Pos)
#define LPTIM_RCR_REP_Pos   (0U)
#define LPTIM_RCR_REP_Msk   (0xFFUL << LPTIM_RCR_REP_Pos)
#define LPTIM_RCR_REP   LPTIM_RCR_REP_Msk
#define LPTIM_CCMR1_CC1SEL_Pos   (0U)
#define LPTIM_CCMR1_CC1SEL_Msk   (0x1UL << LPTIM_CCMR1_CC1SEL_Pos)
#define LPTIM_CCMR1_CC1SEL   LPTIM_CCMR1_CC1SEL_Msk
#define LPTIM_CCMR1_CC1E_Pos   (1U)
#define LPTIM_CCMR1_CC1E_Msk   (0x1UL << LPTIM_CCMR1_CC1E_Pos)
#define LPTIM_CCMR1_CC1E   LPTIM_CCMR1_CC1E_Msk
#define LPTIM_CCMR1_CC1P_Pos   (2U)
#define LPTIM_CCMR1_CC1P_Msk   (0x3UL << LPTIM_CCMR1_CC1P_Pos)
#define LPTIM_CCMR1_CC1P   LPTIM_CCMR1_CC1P_Msk
#define LPTIM_CCMR1_CC1P_0   (0x1UL << LPTIM_CCMR1_CC1P_Pos)
#define LPTIM_CCMR1_CC1P_1   (0x2UL << LPTIM_CCMR1_CC1P_Pos)
#define LPTIM_CCMR1_IC1PSC_Pos   (8U)
#define LPTIM_CCMR1_IC1PSC_Msk   (0x3UL << LPTIM_CCMR1_IC1PSC_Pos)
#define LPTIM_CCMR1_IC1PSC   LPTIM_CCMR1_IC1PSC_Msk
#define LPTIM_CCMR1_IC1PSC_0   (0x1UL << LPTIM_CCMR1_IC1PSC_Pos)
#define LPTIM_CCMR1_IC1PSC_1   (0x2UL << LPTIM_CCMR1_IC1PSC_Pos)
#define LPTIM_CCMR1_IC1F_Pos   (12U)
#define LPTIM_CCMR1_IC1F_Msk   (0x3UL << LPTIM_CCMR1_IC1F_Pos)
#define LPTIM_CCMR1_IC1F   LPTIM_CCMR1_IC1F_Msk
#define LPTIM_CCMR1_IC1F_0   (0x1UL << LPTIM_CCMR1_IC1F_Pos)
#define LPTIM_CCMR1_IC1F_1   (0x2UL << LPTIM_CCMR1_IC1F_Pos)
#define LPTIM_CCMR1_CC2SEL_Pos   (16U)
#define LPTIM_CCMR1_CC2SEL_Msk   (0x1UL << LPTIM_CCMR1_CC2SEL_Pos)
#define LPTIM_CCMR1_CC2SEL   LPTIM_CCMR1_CC2SEL_Msk
#define LPTIM_CCMR1_CC2E_Pos   (17U)
#define LPTIM_CCMR1_CC2E_Msk   (0x1UL << LPTIM_CCMR1_CC2E_Pos)
#define LPTIM_CCMR1_CC2E   LPTIM_CCMR1_CC2E_Msk
#define LPTIM_CCMR1_CC2P_Pos   (18U)
#define LPTIM_CCMR1_CC2P_Msk   (0x3UL << LPTIM_CCMR1_CC2P_Pos)
#define LPTIM_CCMR1_CC2P   LPTIM_CCMR1_CC2P_Msk
#define LPTIM_CCMR1_CC2P_0   (0x1UL << LPTIM_CCMR1_CC2P_Pos)
#define LPTIM_CCMR1_CC2P_1   (0x2UL << LPTIM_CCMR1_CC2P_Pos)
#define LPTIM_CCMR1_IC2PSC_Pos   (24U)
#define LPTIM_CCMR1_IC2PSC_Msk   (0x3UL << LPTIM_CCMR1_IC2PSC_Pos)
#define LPTIM_CCMR1_IC2PSC   LPTIM_CCMR1_IC2PSC_Msk
#define LPTIM_CCMR1_IC2PSC_0   (0x1UL << LPTIM_CCMR1_IC2PSC_Pos)
#define LPTIM_CCMR1_IC2PSC_1   (0x2UL << LPTIM_CCMR1_IC2PSC_Pos)
#define LPTIM_CCMR1_IC2F_Pos   (28U)
#define LPTIM_CCMR1_IC2F_Msk   (0x3UL << LPTIM_CCMR1_IC2F_Pos)
#define LPTIM_CCMR1_IC2F   LPTIM_CCMR1_IC2F_Msk
#define LPTIM_CCMR1_IC2F_0   (0x1UL << LPTIM_CCMR1_IC2F_Pos)
#define LPTIM_CCMR1_IC2F_1   (0x2UL << LPTIM_CCMR1_IC2F_Pos)
#define LPTIM_CCR2_CCR2_Pos   (0U)
#define LPTIM_CCR2_CCR2_Msk   (0xFFFFUL << LPTIM_CCR2_CCR2_Pos)
#define LPTIM_CCR2_CCR2   LPTIM_CCR2_CCR2_Msk
#define PSSI_CR_CKPOL_Pos   (5U)
#define PSSI_CR_CKPOL_Msk   (0x1UL << PSSI_CR_CKPOL_Pos)
#define PSSI_CR_CKPOL   PSSI_CR_CKPOL_Msk
#define PSSI_CR_DEPOL_Pos   (6U)
#define PSSI_CR_DEPOL_Msk   (0x1UL << PSSI_CR_DEPOL_Pos)
#define PSSI_CR_DEPOL   PSSI_CR_DEPOL_Msk
#define PSSI_CR_RDYPOL_Pos   (8U)
#define PSSI_CR_RDYPOL_Msk   (0x1UL << PSSI_CR_RDYPOL_Pos)
#define PSSI_CR_RDYPOL   PSSI_CR_RDYPOL_Msk
#define PSSI_CR_EDM_Pos   (10U)
#define PSSI_CR_EDM_Msk   (0x3UL << PSSI_CR_EDM_Pos)
#define PSSI_CR_EDM   PSSI_CR_EDM_Msk
#define PSSI_CR_ENABLE_Pos   (14U)
#define PSSI_CR_ENABLE_Msk   (0x1UL << PSSI_CR_ENABLE_Pos)
#define PSSI_CR_ENABLE   PSSI_CR_ENABLE_Msk
#define PSSI_CR_DERDYCFG_Pos   (18U)
#define PSSI_CR_DERDYCFG_Msk   (0x7UL << PSSI_CR_DERDYCFG_Pos)
#define PSSI_CR_DERDYCFG   PSSI_CR_DERDYCFG_Msk
#define PSSI_CR_DMAEN_Pos   (30U)
#define PSSI_CR_DMAEN_Msk   (0x1UL << PSSI_CR_DMAEN_Pos)
#define PSSI_CR_DMAEN   PSSI_CR_DMAEN_Msk
#define PSSI_CR_OUTEN_Pos   (31U)
#define PSSI_CR_OUTEN_Msk   (0x1UL << PSSI_CR_OUTEN_Pos)
#define PSSI_CR_OUTEN   PSSI_CR_OUTEN_Msk
#define PSSI_SR_RTT4B_Pos   (2U)
#define PSSI_SR_RTT4B_Msk   (0x1UL << PSSI_SR_RTT4B_Pos)
#define PSSI_SR_RTT4B   PSSI_SR_RTT4B_Msk
#define PSSI_SR_RTT1B_Pos   (3U)
#define PSSI_SR_RTT1B_Msk   (0x1UL << PSSI_SR_RTT1B_Pos)
#define PSSI_SR_RTT1B   PSSI_SR_RTT1B_Msk
#define PSSI_RIS_OVR_RIS_Pos   (1U)
#define PSSI_RIS_OVR_RIS_Msk   (0x1UL << PSSI_RIS_OVR_RIS_Pos)
#define PSSI_RIS_OVR_RIS   PSSI_RIS_OVR_RIS_Msk
#define PSSI_IER_OVR_IE_Pos   (1U)
#define PSSI_IER_OVR_IE_Msk   (0x1UL << PSSI_IER_OVR_IE_Pos)
#define PSSI_IER_OVR_IE   PSSI_IER_OVR_IE_Msk
#define PSSI_MIS_OVR_MIS_Pos   (1U)
#define PSSI_MIS_OVR_MIS_Msk   (0x1UL << PSSI_MIS_OVR_MIS_Pos)
#define PSSI_MIS_OVR_MIS   PSSI_MIS_OVR_MIS_Msk
#define PSSI_ICR_OVR_ISC_Pos   (1U)
#define PSSI_ICR_OVR_ISC_Msk   (0x1UL << PSSI_ICR_OVR_ISC_Pos)
#define PSSI_ICR_OVR_ISC   PSSI_ICR_OVR_ISC_Msk
#define PSSI_DR_DR_Pos   (0U)
#define PSSI_DR_DR_Msk   (0xFFFFFFFFUL << PSSI_DR_DR_Pos)
#define PSSI_DR_DR   PSSI_DR_DR_Msk
#define SDMMC_POWER_PWRCTRL_Pos   (0U)
#define SDMMC_POWER_PWRCTRL_Msk   (0x3UL << SDMMC_POWER_PWRCTRL_Pos)
#define SDMMC_POWER_PWRCTRL   SDMMC_POWER_PWRCTRL_Msk
#define SDMMC_POWER_PWRCTRL_0   (0x1UL << SDMMC_POWER_PWRCTRL_Pos)
#define SDMMC_POWER_PWRCTRL_1   (0x2UL << SDMMC_POWER_PWRCTRL_Pos)
#define SDMMC_POWER_VSWITCH_Pos   (2U)
#define SDMMC_POWER_VSWITCH_Msk   (0x1UL << SDMMC_POWER_VSWITCH_Pos)
#define SDMMC_POWER_VSWITCH   SDMMC_POWER_VSWITCH_Msk
#define SDMMC_POWER_VSWITCHEN_Pos   (3U)
#define SDMMC_POWER_VSWITCHEN_Msk   (0x1UL << SDMMC_POWER_VSWITCHEN_Pos)
#define SDMMC_POWER_VSWITCHEN   SDMMC_POWER_VSWITCHEN_Msk
#define SDMMC_POWER_DIRPOL_Pos   (4U)
#define SDMMC_POWER_DIRPOL_Msk   (0x1UL << SDMMC_POWER_DIRPOL_Pos)
#define SDMMC_POWER_DIRPOL   SDMMC_POWER_DIRPOL_Msk
#define SDMMC_CLKCR_CLKDIV_Pos   (0U)
#define SDMMC_CLKCR_CLKDIV_Msk   (0x3FFUL << SDMMC_CLKCR_CLKDIV_Pos)
#define SDMMC_CLKCR_CLKDIV   SDMMC_CLKCR_CLKDIV_Msk
#define SDMMC_CLKCR_PWRSAV_Pos   (12U)
#define SDMMC_CLKCR_PWRSAV_Msk   (0x1UL << SDMMC_CLKCR_PWRSAV_Pos)
#define SDMMC_CLKCR_PWRSAV   SDMMC_CLKCR_PWRSAV_Msk
#define SDMMC_CLKCR_WIDBUS_Pos   (14U)
#define SDMMC_CLKCR_WIDBUS_Msk   (0x3UL << SDMMC_CLKCR_WIDBUS_Pos)
#define SDMMC_CLKCR_WIDBUS   SDMMC_CLKCR_WIDBUS_Msk
#define SDMMC_CLKCR_WIDBUS_0   (0x1UL << SDMMC_CLKCR_WIDBUS_Pos)
#define SDMMC_CLKCR_WIDBUS_1   (0x2UL << SDMMC_CLKCR_WIDBUS_Pos)
#define SDMMC_CLKCR_NEGEDGE_Pos   (16U)
#define SDMMC_CLKCR_NEGEDGE_Msk   (0x1UL << SDMMC_CLKCR_NEGEDGE_Pos)
#define SDMMC_CLKCR_NEGEDGE   SDMMC_CLKCR_NEGEDGE_Msk
#define SDMMC_CLKCR_HWFC_EN_Pos   (17U)
#define SDMMC_CLKCR_HWFC_EN_Msk   (0x1UL << SDMMC_CLKCR_HWFC_EN_Pos)
#define SDMMC_CLKCR_HWFC_EN   SDMMC_CLKCR_HWFC_EN_Msk
#define SDMMC_CLKCR_DDR_Pos   (18U)
#define SDMMC_CLKCR_DDR_Msk   (0x1UL << SDMMC_CLKCR_DDR_Pos)
#define SDMMC_CLKCR_DDR   SDMMC_CLKCR_DDR_Msk
#define SDMMC_CLKCR_BUSSPEED_Pos   (19U)
#define SDMMC_CLKCR_BUSSPEED_Msk   (0x1UL << SDMMC_CLKCR_BUSSPEED_Pos)
#define SDMMC_CLKCR_BUSSPEED   SDMMC_CLKCR_BUSSPEED_Msk
#define SDMMC_CLKCR_SELCLKRX_Pos   (20U)
#define SDMMC_CLKCR_SELCLKRX_Msk   (0x3UL << SDMMC_CLKCR_SELCLKRX_Pos)
#define SDMMC_CLKCR_SELCLKRX   SDMMC_CLKCR_SELCLKRX_Msk
#define SDMMC_CLKCR_SELCLKRX_0   (0x1UL << SDMMC_CLKCR_SELCLKRX_Pos)
#define SDMMC_CLKCR_SELCLKRX_1   (0x2UL << SDMMC_CLKCR_SELCLKRX_Pos)
#define SDMMC_ARG_CMDARG_Pos   (0U)
#define SDMMC_ARG_CMDARG_Msk   (0xFFFFFFFFUL << SDMMC_ARG_CMDARG_Pos)
#define SDMMC_ARG_CMDARG   SDMMC_ARG_CMDARG_Msk
#define SDMMC_CMD_CMDINDEX_Pos   (0U)
#define SDMMC_CMD_CMDINDEX_Msk   (0x3FUL << SDMMC_CMD_CMDINDEX_Pos)
#define SDMMC_CMD_CMDINDEX   SDMMC_CMD_CMDINDEX_Msk
#define SDMMC_CMD_CMDTRANS_Pos   (6U)
#define SDMMC_CMD_CMDTRANS_Msk   (0x1UL << SDMMC_CMD_CMDTRANS_Pos)
#define SDMMC_CMD_CMDTRANS   SDMMC_CMD_CMDTRANS_Msk
#define SDMMC_CMD_CMDSTOP_Pos   (7U)
#define SDMMC_CMD_CMDSTOP_Msk   (0x1UL << SDMMC_CMD_CMDSTOP_Pos)
#define SDMMC_CMD_CMDSTOP   SDMMC_CMD_CMDSTOP_Msk
#define SDMMC_CMD_WAITRESP_Pos   (8U)
#define SDMMC_CMD_WAITRESP_Msk   (0x3UL << SDMMC_CMD_WAITRESP_Pos)
#define SDMMC_CMD_WAITRESP   SDMMC_CMD_WAITRESP_Msk
#define SDMMC_CMD_WAITRESP_0   (0x1UL << SDMMC_CMD_WAITRESP_Pos)
#define SDMMC_CMD_WAITRESP_1   (0x2UL << SDMMC_CMD_WAITRESP_Pos)
#define SDMMC_CMD_WAITINT_Pos   (10U)
#define SDMMC_CMD_WAITINT_Msk   (0x1UL << SDMMC_CMD_WAITINT_Pos)
#define SDMMC_CMD_WAITINT   SDMMC_CMD_WAITINT_Msk
#define SDMMC_CMD_WAITPEND_Pos   (11U)
#define SDMMC_CMD_WAITPEND_Msk   (0x1UL << SDMMC_CMD_WAITPEND_Pos)
#define SDMMC_CMD_WAITPEND   SDMMC_CMD_WAITPEND_Msk
#define SDMMC_CMD_CPSMEN_Pos   (12U)
#define SDMMC_CMD_CPSMEN_Msk   (0x1UL << SDMMC_CMD_CPSMEN_Pos)
#define SDMMC_CMD_CPSMEN   SDMMC_CMD_CPSMEN_Msk
#define SDMMC_CMD_DTHOLD_Pos   (13U)
#define SDMMC_CMD_DTHOLD_Msk   (0x1UL << SDMMC_CMD_DTHOLD_Pos)
#define SDMMC_CMD_DTHOLD   SDMMC_CMD_DTHOLD_Msk
#define SDMMC_CMD_BOOTMODE_Pos   (14U)
#define SDMMC_CMD_BOOTMODE_Msk   (0x1UL << SDMMC_CMD_BOOTMODE_Pos)
#define SDMMC_CMD_BOOTMODE   SDMMC_CMD_BOOTMODE_Msk
#define SDMMC_CMD_BOOTEN_Pos   (15U)
#define SDMMC_CMD_BOOTEN_Msk   (0x1UL << SDMMC_CMD_BOOTEN_Pos)
#define SDMMC_CMD_BOOTEN   SDMMC_CMD_BOOTEN_Msk
#define SDMMC_CMD_CMDSUSPEND_Pos   (16U)
#define SDMMC_CMD_CMDSUSPEND_Msk   (0x1UL << SDMMC_CMD_CMDSUSPEND_Pos)
#define SDMMC_CMD_CMDSUSPEND   SDMMC_CMD_CMDSUSPEND_Msk
#define SDMMC_RESPCMD_RESPCMD_Pos   (0U)
#define SDMMC_RESPCMD_RESPCMD_Msk   (0x3FUL << SDMMC_RESPCMD_RESPCMD_Pos)
#define SDMMC_RESPCMD_RESPCMD   SDMMC_RESPCMD_RESPCMD_Msk
#define SDMMC_RESP1_CARDSTATUS1_Pos   (0U)
#define SDMMC_RESP1_CARDSTATUS1_Msk   (0xFFFFFFFFUL << SDMMC_RESP1_CARDSTATUS1_Pos)
#define SDMMC_RESP1_CARDSTATUS1   SDMMC_RESP1_CARDSTATUS1_Msk
#define SDMMC_RESP2_CARDSTATUS2_Pos   (0U)
#define SDMMC_RESP2_CARDSTATUS2_Msk   (0xFFFFFFFFUL << SDMMC_RESP2_CARDSTATUS2_Pos)
#define SDMMC_RESP2_CARDSTATUS2   SDMMC_RESP2_CARDSTATUS2_Msk
#define SDMMC_RESP3_CARDSTATUS3_Pos   (0U)
#define SDMMC_RESP3_CARDSTATUS3_Msk   (0xFFFFFFFFUL << SDMMC_RESP3_CARDSTATUS3_Pos)
#define SDMMC_RESP3_CARDSTATUS3   SDMMC_RESP3_CARDSTATUS3_Msk
#define SDMMC_RESP4_CARDSTATUS4_Pos   (0U)
#define SDMMC_RESP4_CARDSTATUS4_Msk   (0xFFFFFFFFUL << SDMMC_RESP4_CARDSTATUS4_Pos)
#define SDMMC_RESP4_CARDSTATUS4   SDMMC_RESP4_CARDSTATUS4_Msk
#define SDMMC_DTIMER_DATATIME_Pos   (0U)
#define SDMMC_DTIMER_DATATIME_Msk   (0xFFFFFFFFUL << SDMMC_DTIMER_DATATIME_Pos)
#define SDMMC_DTIMER_DATATIME   SDMMC_DTIMER_DATATIME_Msk
#define SDMMC_DLEN_DATALENGTH_Pos   (0U)
#define SDMMC_DLEN_DATALENGTH_Msk   (0x1FFFFFFUL << SDMMC_DLEN_DATALENGTH_Pos)
#define SDMMC_DLEN_DATALENGTH   SDMMC_DLEN_DATALENGTH_Msk
#define SDMMC_DCTRL_DTEN_Pos   (0U)
#define SDMMC_DCTRL_DTEN_Msk   (0x1UL << SDMMC_DCTRL_DTEN_Pos)
#define SDMMC_DCTRL_DTEN   SDMMC_DCTRL_DTEN_Msk
#define SDMMC_DCTRL_DTDIR_Pos   (1U)
#define SDMMC_DCTRL_DTDIR_Msk   (0x1UL << SDMMC_DCTRL_DTDIR_Pos)
#define SDMMC_DCTRL_DTDIR   SDMMC_DCTRL_DTDIR_Msk
#define SDMMC_DCTRL_DTMODE_Pos   (2U)
#define SDMMC_DCTRL_DTMODE_Msk   (0x3UL << SDMMC_DCTRL_DTMODE_Pos)
#define SDMMC_DCTRL_DTMODE   SDMMC_DCTRL_DTMODE_Msk
#define SDMMC_DCTRL_DTMODE_0   (0x1UL << SDMMC_DCTRL_DTMODE_Pos)
#define SDMMC_DCTRL_DTMODE_1   (0x2UL << SDMMC_DCTRL_DTMODE_Pos)
#define SDMMC_DCTRL_DBLOCKSIZE_Pos   (4U)
#define SDMMC_DCTRL_DBLOCKSIZE_Msk   (0xFUL << SDMMC_DCTRL_DBLOCKSIZE_Pos)
#define SDMMC_DCTRL_DBLOCKSIZE   SDMMC_DCTRL_DBLOCKSIZE_Msk
#define SDMMC_DCTRL_DBLOCKSIZE_0   (0x1UL << SDMMC_DCTRL_DBLOCKSIZE_Pos)
#define SDMMC_DCTRL_DBLOCKSIZE_1   (0x2UL << SDMMC_DCTRL_DBLOCKSIZE_Pos)
#define SDMMC_DCTRL_DBLOCKSIZE_2   (0x4UL << SDMMC_DCTRL_DBLOCKSIZE_Pos)
#define SDMMC_DCTRL_DBLOCKSIZE_3   (0x8UL << SDMMC_DCTRL_DBLOCKSIZE_Pos)
#define SDMMC_DCTRL_RWSTART_Pos   (8U)
#define SDMMC_DCTRL_RWSTART_Msk   (0x1UL << SDMMC_DCTRL_RWSTART_Pos)
#define SDMMC_DCTRL_RWSTART   SDMMC_DCTRL_RWSTART_Msk
#define SDMMC_DCTRL_RWSTOP_Pos   (9U)
#define SDMMC_DCTRL_RWSTOP_Msk   (0x1UL << SDMMC_DCTRL_RWSTOP_Pos)
#define SDMMC_DCTRL_RWSTOP   SDMMC_DCTRL_RWSTOP_Msk
#define SDMMC_DCTRL_RWMOD_Pos   (10U)
#define SDMMC_DCTRL_RWMOD_Msk   (0x1UL << SDMMC_DCTRL_RWMOD_Pos)
#define SDMMC_DCTRL_RWMOD   SDMMC_DCTRL_RWMOD_Msk
#define SDMMC_DCTRL_SDIOEN_Pos   (11U)
#define SDMMC_DCTRL_SDIOEN_Msk   (0x1UL << SDMMC_DCTRL_SDIOEN_Pos)
#define SDMMC_DCTRL_SDIOEN   SDMMC_DCTRL_SDIOEN_Msk
#define SDMMC_DCTRL_BOOTACKEN_Pos   (12U)
#define SDMMC_DCTRL_BOOTACKEN_Msk   (0x1UL << SDMMC_DCTRL_BOOTACKEN_Pos)
#define SDMMC_DCTRL_BOOTACKEN   SDMMC_DCTRL_BOOTACKEN_Msk
#define SDMMC_DCTRL_FIFORST_Pos   (13U)
#define SDMMC_DCTRL_FIFORST_Msk   (0x1UL << SDMMC_DCTRL_FIFORST_Pos)
#define SDMMC_DCTRL_FIFORST   SDMMC_DCTRL_FIFORST_Msk
#define SDMMC_DCOUNT_DATACOUNT_Pos   (0U)
#define SDMMC_DCOUNT_DATACOUNT_Msk   (0x1FFFFFFUL << SDMMC_DCOUNT_DATACOUNT_Pos)
#define SDMMC_DCOUNT_DATACOUNT   SDMMC_DCOUNT_DATACOUNT_Msk
#define SDMMC_STA_CCRCFAIL_Pos   (0U)
#define SDMMC_STA_CCRCFAIL_Msk   (0x1UL << SDMMC_STA_CCRCFAIL_Pos)
#define SDMMC_STA_CCRCFAIL   SDMMC_STA_CCRCFAIL_Msk
#define SDMMC_STA_DCRCFAIL_Pos   (1U)
#define SDMMC_STA_DCRCFAIL_Msk   (0x1UL << SDMMC_STA_DCRCFAIL_Pos)
#define SDMMC_STA_DCRCFAIL   SDMMC_STA_DCRCFAIL_Msk
#define SDMMC_STA_CTIMEOUT_Pos   (2U)
#define SDMMC_STA_CTIMEOUT_Msk   (0x1UL << SDMMC_STA_CTIMEOUT_Pos)
#define SDMMC_STA_CTIMEOUT   SDMMC_STA_CTIMEOUT_Msk
#define SDMMC_STA_DTIMEOUT_Pos   (3U)
#define SDMMC_STA_DTIMEOUT_Msk   (0x1UL << SDMMC_STA_DTIMEOUT_Pos)
#define SDMMC_STA_DTIMEOUT   SDMMC_STA_DTIMEOUT_Msk
#define SDMMC_STA_TXUNDERR_Pos   (4U)
#define SDMMC_STA_TXUNDERR_Msk   (0x1UL << SDMMC_STA_TXUNDERR_Pos)
#define SDMMC_STA_TXUNDERR   SDMMC_STA_TXUNDERR_Msk
#define SDMMC_STA_RXOVERR_Pos   (5U)
#define SDMMC_STA_RXOVERR_Msk   (0x1UL << SDMMC_STA_RXOVERR_Pos)
#define SDMMC_STA_RXOVERR   SDMMC_STA_RXOVERR_Msk
#define SDMMC_STA_CMDREND_Pos   (6U)
#define SDMMC_STA_CMDREND_Msk   (0x1UL << SDMMC_STA_CMDREND_Pos)
#define SDMMC_STA_CMDREND   SDMMC_STA_CMDREND_Msk
#define SDMMC_STA_CMDSENT_Pos   (7U)
#define SDMMC_STA_CMDSENT_Msk   (0x1UL << SDMMC_STA_CMDSENT_Pos)
#define SDMMC_STA_CMDSENT   SDMMC_STA_CMDSENT_Msk
#define SDMMC_STA_DATAEND_Pos   (8U)
#define SDMMC_STA_DATAEND_Msk   (0x1UL << SDMMC_STA_DATAEND_Pos)
#define SDMMC_STA_DATAEND   SDMMC_STA_DATAEND_Msk
#define SDMMC_STA_DHOLD_Pos   (9U)
#define SDMMC_STA_DHOLD_Msk   (0x1UL << SDMMC_STA_DHOLD_Pos)
#define SDMMC_STA_DHOLD   SDMMC_STA_DHOLD_Msk
#define SDMMC_STA_DBCKEND_Pos   (10U)
#define SDMMC_STA_DBCKEND_Msk   (0x1UL << SDMMC_STA_DBCKEND_Pos)
#define SDMMC_STA_DBCKEND   SDMMC_STA_DBCKEND_Msk
#define SDMMC_STA_DABORT_Pos   (11U)
#define SDMMC_STA_DABORT_Msk   (0x1UL << SDMMC_STA_DABORT_Pos)
#define SDMMC_STA_DABORT   SDMMC_STA_DABORT_Msk
#define SDMMC_STA_DPSMACT_Pos   (12U)
#define SDMMC_STA_DPSMACT_Msk   (0x1UL << SDMMC_STA_DPSMACT_Pos)
#define SDMMC_STA_DPSMACT   SDMMC_STA_DPSMACT_Msk
#define SDMMC_STA_CPSMACT_Pos   (13U)
#define SDMMC_STA_CPSMACT_Msk   (0x1UL << SDMMC_STA_CPSMACT_Pos)
#define SDMMC_STA_CPSMACT   SDMMC_STA_CPSMACT_Msk
#define SDMMC_STA_TXFIFOHE_Pos   (14U)
#define SDMMC_STA_TXFIFOHE_Msk   (0x1UL << SDMMC_STA_TXFIFOHE_Pos)
#define SDMMC_STA_TXFIFOHE   SDMMC_STA_TXFIFOHE_Msk
#define SDMMC_STA_RXFIFOHF_Pos   (15U)
#define SDMMC_STA_RXFIFOHF_Msk   (0x1UL << SDMMC_STA_RXFIFOHF_Pos)
#define SDMMC_STA_RXFIFOHF   SDMMC_STA_RXFIFOHF_Msk
#define SDMMC_STA_TXFIFOF_Pos   (16U)
#define SDMMC_STA_TXFIFOF_Msk   (0x1UL << SDMMC_STA_TXFIFOF_Pos)
#define SDMMC_STA_TXFIFOF   SDMMC_STA_TXFIFOF_Msk
#define SDMMC_STA_RXFIFOF_Pos   (17U)
#define SDMMC_STA_RXFIFOF_Msk   (0x1UL << SDMMC_STA_RXFIFOF_Pos)
#define SDMMC_STA_RXFIFOF   SDMMC_STA_RXFIFOF_Msk
#define SDMMC_STA_TXFIFOE_Pos   (18U)
#define SDMMC_STA_TXFIFOE_Msk   (0x1UL << SDMMC_STA_TXFIFOE_Pos)
#define SDMMC_STA_TXFIFOE   SDMMC_STA_TXFIFOE_Msk
#define SDMMC_STA_RXFIFOE_Pos   (19U)
#define SDMMC_STA_RXFIFOE_Msk   (0x1UL << SDMMC_STA_RXFIFOE_Pos)
#define SDMMC_STA_RXFIFOE   SDMMC_STA_RXFIFOE_Msk
#define SDMMC_STA_BUSYD0_Pos   (20U)
#define SDMMC_STA_BUSYD0_Msk   (0x1UL << SDMMC_STA_BUSYD0_Pos)
#define SDMMC_STA_BUSYD0   SDMMC_STA_BUSYD0_Msk
#define SDMMC_STA_BUSYD0END_Pos   (21U)
#define SDMMC_STA_BUSYD0END_Msk   (0x1UL << SDMMC_STA_BUSYD0END_Pos)
#define SDMMC_STA_BUSYD0END   SDMMC_STA_BUSYD0END_Msk
#define SDMMC_STA_SDIOIT_Pos   (22U)
#define SDMMC_STA_SDIOIT_Msk   (0x1UL << SDMMC_STA_SDIOIT_Pos)
#define SDMMC_STA_SDIOIT   SDMMC_STA_SDIOIT_Msk
#define SDMMC_STA_ACKFAIL_Pos   (23U)
#define SDMMC_STA_ACKFAIL_Msk   (0x1UL << SDMMC_STA_ACKFAIL_Pos)
#define SDMMC_STA_ACKFAIL   SDMMC_STA_ACKFAIL_Msk
#define SDMMC_STA_ACKTIMEOUT_Pos   (24U)
#define SDMMC_STA_ACKTIMEOUT_Msk   (0x1UL << SDMMC_STA_ACKTIMEOUT_Pos)
#define SDMMC_STA_ACKTIMEOUT   SDMMC_STA_ACKTIMEOUT_Msk
#define SDMMC_STA_VSWEND_Pos   (25U)
#define SDMMC_STA_VSWEND_Msk   (0x1UL << SDMMC_STA_VSWEND_Pos)
#define SDMMC_STA_VSWEND   SDMMC_STA_VSWEND_Msk
#define SDMMC_STA_CKSTOP_Pos   (26U)
#define SDMMC_STA_CKSTOP_Msk   (0x1UL << SDMMC_STA_CKSTOP_Pos)
#define SDMMC_STA_CKSTOP   SDMMC_STA_CKSTOP_Msk
#define SDMMC_STA_IDMATE_Pos   (27U)
#define SDMMC_STA_IDMATE_Msk   (0x1UL << SDMMC_STA_IDMATE_Pos)
#define SDMMC_STA_IDMATE   SDMMC_STA_IDMATE_Msk
#define SDMMC_STA_IDMABTC_Pos   (28U)
#define SDMMC_STA_IDMABTC_Msk   (0x1UL << SDMMC_STA_IDMABTC_Pos)
#define SDMMC_STA_IDMABTC   SDMMC_STA_IDMABTC_Msk
#define SDMMC_ICR_CCRCFAILC_Pos   (0U)
#define SDMMC_ICR_CCRCFAILC_Msk   (0x1UL << SDMMC_ICR_CCRCFAILC_Pos)
#define SDMMC_ICR_CCRCFAILC   SDMMC_ICR_CCRCFAILC_Msk
#define SDMMC_ICR_DCRCFAILC_Pos   (1U)
#define SDMMC_ICR_DCRCFAILC_Msk   (0x1UL << SDMMC_ICR_DCRCFAILC_Pos)
#define SDMMC_ICR_DCRCFAILC   SDMMC_ICR_DCRCFAILC_Msk
#define SDMMC_ICR_CTIMEOUTC_Pos   (2U)
#define SDMMC_ICR_CTIMEOUTC_Msk   (0x1UL << SDMMC_ICR_CTIMEOUTC_Pos)
#define SDMMC_ICR_CTIMEOUTC   SDMMC_ICR_CTIMEOUTC_Msk
#define SDMMC_ICR_DTIMEOUTC_Pos   (3U)
#define SDMMC_ICR_DTIMEOUTC_Msk   (0x1UL << SDMMC_ICR_DTIMEOUTC_Pos)
#define SDMMC_ICR_DTIMEOUTC   SDMMC_ICR_DTIMEOUTC_Msk
#define SDMMC_ICR_TXUNDERRC_Pos   (4U)
#define SDMMC_ICR_TXUNDERRC_Msk   (0x1UL << SDMMC_ICR_TXUNDERRC_Pos)
#define SDMMC_ICR_TXUNDERRC   SDMMC_ICR_TXUNDERRC_Msk
#define SDMMC_ICR_RXOVERRC_Pos   (5U)
#define SDMMC_ICR_RXOVERRC_Msk   (0x1UL << SDMMC_ICR_RXOVERRC_Pos)
#define SDMMC_ICR_RXOVERRC   SDMMC_ICR_RXOVERRC_Msk
#define SDMMC_ICR_CMDRENDC_Pos   (6U)
#define SDMMC_ICR_CMDRENDC_Msk   (0x1UL << SDMMC_ICR_CMDRENDC_Pos)
#define SDMMC_ICR_CMDRENDC   SDMMC_ICR_CMDRENDC_Msk
#define SDMMC_ICR_CMDSENTC_Pos   (7U)
#define SDMMC_ICR_CMDSENTC_Msk   (0x1UL << SDMMC_ICR_CMDSENTC_Pos)
#define SDMMC_ICR_CMDSENTC   SDMMC_ICR_CMDSENTC_Msk
#define SDMMC_ICR_DATAENDC_Pos   (8U)
#define SDMMC_ICR_DATAENDC_Msk   (0x1UL << SDMMC_ICR_DATAENDC_Pos)
#define SDMMC_ICR_DATAENDC   SDMMC_ICR_DATAENDC_Msk
#define SDMMC_ICR_DHOLDC_Pos   (9U)
#define SDMMC_ICR_DHOLDC_Msk   (0x1UL << SDMMC_ICR_DHOLDC_Pos)
#define SDMMC_ICR_DHOLDC   SDMMC_ICR_DHOLDC_Msk
#define SDMMC_ICR_DBCKENDC_Pos   (10U)
#define SDMMC_ICR_DBCKENDC_Msk   (0x1UL << SDMMC_ICR_DBCKENDC_Pos)
#define SDMMC_ICR_DBCKENDC   SDMMC_ICR_DBCKENDC_Msk
#define SDMMC_ICR_DABORTC_Pos   (11U)
#define SDMMC_ICR_DABORTC_Msk   (0x1UL << SDMMC_ICR_DABORTC_Pos)
#define SDMMC_ICR_DABORTC   SDMMC_ICR_DABORTC_Msk
#define SDMMC_ICR_BUSYD0ENDC_Pos   (21U)
#define SDMMC_ICR_BUSYD0ENDC_Msk   (0x1UL << SDMMC_ICR_BUSYD0ENDC_Pos)
#define SDMMC_ICR_BUSYD0ENDC   SDMMC_ICR_BUSYD0ENDC_Msk
#define SDMMC_ICR_SDIOITC_Pos   (22U)
#define SDMMC_ICR_SDIOITC_Msk   (0x1UL << SDMMC_ICR_SDIOITC_Pos)
#define SDMMC_ICR_SDIOITC   SDMMC_ICR_SDIOITC_Msk
#define SDMMC_ICR_ACKFAILC_Pos   (23U)
#define SDMMC_ICR_ACKFAILC_Msk   (0x1UL << SDMMC_ICR_ACKFAILC_Pos)
#define SDMMC_ICR_ACKFAILC   SDMMC_ICR_ACKFAILC_Msk
#define SDMMC_ICR_ACKTIMEOUTC_Pos   (24U)
#define SDMMC_ICR_ACKTIMEOUTC_Msk   (0x1UL << SDMMC_ICR_ACKTIMEOUTC_Pos)
#define SDMMC_ICR_ACKTIMEOUTC   SDMMC_ICR_ACKTIMEOUTC_Msk
#define SDMMC_ICR_VSWENDC_Pos   (25U)
#define SDMMC_ICR_VSWENDC_Msk   (0x1UL << SDMMC_ICR_VSWENDC_Pos)
#define SDMMC_ICR_VSWENDC   SDMMC_ICR_VSWENDC_Msk
#define SDMMC_ICR_CKSTOPC_Pos   (26U)
#define SDMMC_ICR_CKSTOPC_Msk   (0x1UL << SDMMC_ICR_CKSTOPC_Pos)
#define SDMMC_ICR_CKSTOPC   SDMMC_ICR_CKSTOPC_Msk
#define SDMMC_ICR_IDMATEC_Pos   (27U)
#define SDMMC_ICR_IDMATEC_Msk   (0x1UL << SDMMC_ICR_IDMATEC_Pos)
#define SDMMC_ICR_IDMATEC   SDMMC_ICR_IDMATEC_Msk
#define SDMMC_ICR_IDMABTCC_Pos   (28U)
#define SDMMC_ICR_IDMABTCC_Msk   (0x1UL << SDMMC_ICR_IDMABTCC_Pos)
#define SDMMC_ICR_IDMABTCC   SDMMC_ICR_IDMABTCC_Msk
#define SDMMC_MASK_CCRCFAILIE_Pos   (0U)
#define SDMMC_MASK_CCRCFAILIE_Msk   (0x1UL << SDMMC_MASK_CCRCFAILIE_Pos)
#define SDMMC_MASK_CCRCFAILIE   SDMMC_MASK_CCRCFAILIE_Msk
#define SDMMC_MASK_DCRCFAILIE_Pos   (1U)
#define SDMMC_MASK_DCRCFAILIE_Msk   (0x1UL << SDMMC_MASK_DCRCFAILIE_Pos)
#define SDMMC_MASK_DCRCFAILIE   SDMMC_MASK_DCRCFAILIE_Msk
#define SDMMC_MASK_CTIMEOUTIE_Pos   (2U)
#define SDMMC_MASK_CTIMEOUTIE_Msk   (0x1UL << SDMMC_MASK_CTIMEOUTIE_Pos)
#define SDMMC_MASK_CTIMEOUTIE   SDMMC_MASK_CTIMEOUTIE_Msk
#define SDMMC_MASK_DTIMEOUTIE_Pos   (3U)
#define SDMMC_MASK_DTIMEOUTIE_Msk   (0x1UL << SDMMC_MASK_DTIMEOUTIE_Pos)
#define SDMMC_MASK_DTIMEOUTIE   SDMMC_MASK_DTIMEOUTIE_Msk
#define SDMMC_MASK_TXUNDERRIE_Pos   (4U)
#define SDMMC_MASK_TXUNDERRIE_Msk   (0x1UL << SDMMC_MASK_TXUNDERRIE_Pos)
#define SDMMC_MASK_TXUNDERRIE   SDMMC_MASK_TXUNDERRIE_Msk
#define SDMMC_MASK_RXOVERRIE_Pos   (5U)
#define SDMMC_MASK_RXOVERRIE_Msk   (0x1UL << SDMMC_MASK_RXOVERRIE_Pos)
#define SDMMC_MASK_RXOVERRIE   SDMMC_MASK_RXOVERRIE_Msk
#define SDMMC_MASK_CMDRENDIE_Pos   (6U)
#define SDMMC_MASK_CMDRENDIE_Msk   (0x1UL << SDMMC_MASK_CMDRENDIE_Pos)
#define SDMMC_MASK_CMDRENDIE   SDMMC_MASK_CMDRENDIE_Msk
#define SDMMC_MASK_CMDSENTIE_Pos   (7U)
#define SDMMC_MASK_CMDSENTIE_Msk   (0x1UL << SDMMC_MASK_CMDSENTIE_Pos)
#define SDMMC_MASK_CMDSENTIE   SDMMC_MASK_CMDSENTIE_Msk
#define SDMMC_MASK_DATAENDIE_Pos   (8U)
#define SDMMC_MASK_DATAENDIE_Msk   (0x1UL << SDMMC_MASK_DATAENDIE_Pos)
#define SDMMC_MASK_DATAENDIE   SDMMC_MASK_DATAENDIE_Msk
#define SDMMC_MASK_DHOLDIE_Pos   (9U)
#define SDMMC_MASK_DHOLDIE_Msk   (0x1UL << SDMMC_MASK_DHOLDIE_Pos)
#define SDMMC_MASK_DHOLDIE   SDMMC_MASK_DHOLDIE_Msk
#define SDMMC_MASK_DBCKENDIE_Pos   (10U)
#define SDMMC_MASK_DBCKENDIE_Msk   (0x1UL << SDMMC_MASK_DBCKENDIE_Pos)
#define SDMMC_MASK_DBCKENDIE   SDMMC_MASK_DBCKENDIE_Msk
#define SDMMC_MASK_DABORTIE_Pos   (11U)
#define SDMMC_MASK_DABORTIE_Msk   (0x1UL << SDMMC_MASK_DABORTIE_Pos)
#define SDMMC_MASK_DABORTIE   SDMMC_MASK_DABORTIE_Msk
#define SDMMC_MASK_TXFIFOHEIE_Pos   (14U)
#define SDMMC_MASK_TXFIFOHEIE_Msk   (0x1UL << SDMMC_MASK_TXFIFOHEIE_Pos)
#define SDMMC_MASK_TXFIFOHEIE   SDMMC_MASK_TXFIFOHEIE_Msk
#define SDMMC_MASK_RXFIFOHFIE_Pos   (15U)
#define SDMMC_MASK_RXFIFOHFIE_Msk   (0x1UL << SDMMC_MASK_RXFIFOHFIE_Pos)
#define SDMMC_MASK_RXFIFOHFIE   SDMMC_MASK_RXFIFOHFIE_Msk
#define SDMMC_MASK_RXFIFOFIE_Pos   (17U)
#define SDMMC_MASK_RXFIFOFIE_Msk   (0x1UL << SDMMC_MASK_RXFIFOFIE_Pos)
#define SDMMC_MASK_RXFIFOFIE   SDMMC_MASK_RXFIFOFIE_Msk
#define SDMMC_MASK_TXFIFOEIE_Pos   (18U)
#define SDMMC_MASK_TXFIFOEIE_Msk   (0x1UL << SDMMC_MASK_TXFIFOEIE_Pos)
#define SDMMC_MASK_TXFIFOEIE   SDMMC_MASK_TXFIFOEIE_Msk
#define SDMMC_MASK_BUSYD0ENDIE_Pos   (21U)
#define SDMMC_MASK_BUSYD0ENDIE_Msk   (0x1UL << SDMMC_MASK_BUSYD0ENDIE_Pos)
#define SDMMC_MASK_BUSYD0ENDIE   SDMMC_MASK_BUSYD0ENDIE_Msk
#define SDMMC_MASK_SDIOITIE_Pos   (22U)
#define SDMMC_MASK_SDIOITIE_Msk   (0x1UL << SDMMC_MASK_SDIOITIE_Pos)
#define SDMMC_MASK_SDIOITIE   SDMMC_MASK_SDIOITIE_Msk
#define SDMMC_MASK_ACKFAILIE_Pos   (23U)
#define SDMMC_MASK_ACKFAILIE_Msk   (0x1UL << SDMMC_MASK_ACKFAILIE_Pos)
#define SDMMC_MASK_ACKFAILIE   SDMMC_MASK_ACKFAILIE_Msk
#define SDMMC_MASK_ACKTIMEOUTIE_Pos   (24U)
#define SDMMC_MASK_ACKTIMEOUTIE_Msk   (0x1UL << SDMMC_MASK_ACKTIMEOUTIE_Pos)
#define SDMMC_MASK_ACKTIMEOUTIE   SDMMC_MASK_ACKTIMEOUTIE_Msk
#define SDMMC_MASK_VSWENDIE_Pos   (25U)
#define SDMMC_MASK_VSWENDIE_Msk   (0x1UL << SDMMC_MASK_VSWENDIE_Pos)
#define SDMMC_MASK_VSWENDIE   SDMMC_MASK_VSWENDIE_Msk
#define SDMMC_MASK_CKSTOPIE_Pos   (26U)
#define SDMMC_MASK_CKSTOPIE_Msk   (0x1UL << SDMMC_MASK_CKSTOPIE_Pos)
#define SDMMC_MASK_CKSTOPIE   SDMMC_MASK_CKSTOPIE_Msk
#define SDMMC_MASK_IDMABTCIE_Pos   (28U)
#define SDMMC_MASK_IDMABTCIE_Msk   (0x1UL << SDMMC_MASK_IDMABTCIE_Pos)
#define SDMMC_MASK_IDMABTCIE   SDMMC_MASK_IDMABTCIE_Msk
#define SDMMC_ACKTIME_ACKTIME_Pos   (0U)
#define SDMMC_ACKTIME_ACKTIME_Msk   (0x1FFFFFFUL << SDMMC_ACKTIME_ACKTIME_Pos)
#define SDMMC_ACKTIME_ACKTIME   SDMMC_ACKTIME_ACKTIME_Msk
#define SDMMC_FIFO_FIFODATA_Pos   (0U)
#define SDMMC_FIFO_FIFODATA_Msk   (0xFFFFFFFFUL << SDMMC_FIFO_FIFODATA_Pos)
#define SDMMC_FIFO_FIFODATA   SDMMC_FIFO_FIFODATA_Msk
#define SDMMC_IDMA_IDMAEN_Pos   (0U)
#define SDMMC_IDMA_IDMAEN_Msk   (0x1UL << SDMMC_IDMA_IDMAEN_Pos)
#define SDMMC_IDMA_IDMAEN   SDMMC_IDMA_IDMAEN_Msk
#define SDMMC_IDMA_IDMABMODE_Pos   (1U)
#define SDMMC_IDMA_IDMABMODE_Msk   (0x1UL << SDMMC_IDMA_IDMABMODE_Pos)
#define SDMMC_IDMA_IDMABMODE   SDMMC_IDMA_IDMABMODE_Msk
#define SDMMC_IDMABSIZE_IDMABNDT_Pos   (5U)
#define SDMMC_IDMABSIZE_IDMABNDT_Msk   (0xFFFUL << SDMMC_IDMABSIZE_IDMABNDT_Pos)
#define SDMMC_IDMABSIZE_IDMABNDT   SDMMC_IDMABSIZE_IDMABNDT_Msk
#define SDMMC_IDMABASER_IDMABASER   ((uint32_t)0xFFFFFFFF)
#define SDMMC_IDMALAR_IDMALA_Pos   (0U)
#define SDMMC_IDMALAR_IDMALA_Msk   (0x3FFFUL << SDMMC_IDMALAR_IDMALA_Pos)
#define SDMMC_IDMALAR_IDMALA   SDMMC_IDMALAR_IDMALA_Msk
#define SDMMC_IDMALAR_ABR_Pos   (29U)
#define SDMMC_IDMALAR_ABR_Msk   (0x1UL << SDMMC_IDMALAR_ABR_Pos)
#define SDMMC_IDMALAR_ABR   SDMMC_IDMALAR_ABR_Msk
#define SDMMC_IDMALAR_ULS_Pos   (30U)
#define SDMMC_IDMALAR_ULS_Msk   (0x1UL << SDMMC_IDMALAR_ULS_Pos)
#define SDMMC_IDMALAR_ULS   SDMMC_IDMALAR_ULS_Msk
#define SDMMC_IDMALAR_ULA_Pos   (31U)
#define SDMMC_IDMALAR_ULA_Msk   (0x1UL << SDMMC_IDMALAR_ULA_Pos)
#define SDMMC_IDMALAR_ULA   SDMMC_IDMALAR_ULA_Msk
#define SDMMC_IDMABAR_IDMABAR   ((uint32_t)0xFFFFFFFF)
#define XSPI_CR_EN_Pos   (0U)
#define XSPI_CR_EN_Msk   (0x1UL << XSPI_CR_EN_Pos)
#define XSPI_CR_EN   XSPI_CR_EN_Msk
#define XSPI_CR_ABORT_Pos   (1U)
#define XSPI_CR_ABORT_Msk   (0x1UL << XSPI_CR_ABORT_Pos)
#define XSPI_CR_ABORT   XSPI_CR_ABORT_Msk
#define XSPI_CR_DMAEN_Pos   (2U)
#define XSPI_CR_DMAEN_Msk   (0x1UL << XSPI_CR_DMAEN_Pos)
#define XSPI_CR_DMAEN   XSPI_CR_DMAEN_Msk
#define XSPI_CR_TCEN_Pos   (3U)
#define XSPI_CR_TCEN_Msk   (0x1UL << XSPI_CR_TCEN_Pos)
#define XSPI_CR_TCEN   XSPI_CR_TCEN_Msk
#define XSPI_CR_DMM_Pos   (6U)
#define XSPI_CR_DMM_Msk   (0x1UL << XSPI_CR_DMM_Pos)
#define XSPI_CR_DMM   XSPI_CR_DMM_Msk
#define XSPI_OCTOSPI_CR_MSEL_Pos   (7U)
#define XSPI_OCTOSPI_CR_MSEL_Msk   (0x1UL << XSPI_OCTOSPI_CR_MSEL_Pos)
#define XSPI_OCTOSPI_CR_MSEL   XSPI_OCTOSPI_CR_MSEL_Msk
#define XSPI_CR_FTHRES_Pos   (8U)
#define XSPI_CR_FTHRES_Msk   (0x3FUL << XSPI_CR_FTHRES_Pos)
#define XSPI_CR_FTHRES   XSPI_CR_FTHRES_Msk
#define XSPI_CR_TEIE_Pos   (16U)
#define XSPI_CR_TEIE_Msk   (0x1UL << XSPI_CR_TEIE_Pos)
#define XSPI_CR_TEIE   XSPI_CR_TEIE_Msk
#define XSPI_CR_TCIE_Pos   (17U)
#define XSPI_CR_TCIE_Msk   (0x1UL << XSPI_CR_TCIE_Pos)
#define XSPI_CR_TCIE   XSPI_CR_TCIE_Msk
#define XSPI_CR_FTIE_Pos   (18U)
#define XSPI_CR_FTIE_Msk   (0x1UL << XSPI_CR_FTIE_Pos)
#define XSPI_CR_FTIE   XSPI_CR_FTIE_Msk
#define XSPI_CR_SMIE_Pos   (19U)
#define XSPI_CR_SMIE_Msk   (0x1UL << XSPI_CR_SMIE_Pos)
#define XSPI_CR_SMIE   XSPI_CR_SMIE_Msk
#define XSPI_CR_TOIE_Pos   (20U)
#define XSPI_CR_TOIE_Msk   (0x1UL << XSPI_CR_TOIE_Pos)
#define XSPI_CR_TOIE   XSPI_CR_TOIE_Msk
#define XSPI_CR_APMS_Pos   (22U)
#define XSPI_CR_APMS_Msk   (0x1UL << XSPI_CR_APMS_Pos)
#define XSPI_CR_APMS   XSPI_CR_APMS_Msk
#define XSPI_CR_PMM_Pos   (23U)
#define XSPI_CR_PMM_Msk   (0x1UL << XSPI_CR_PMM_Pos)
#define XSPI_CR_PMM   XSPI_CR_PMM_Msk
#define XSPI_CR_FMODE_Pos   (28U)
#define XSPI_CR_FMODE_Msk   (0x3UL << XSPI_CR_FMODE_Pos)
#define XSPI_CR_FMODE   XSPI_CR_FMODE_Msk
#define XSPI_CR_FMODE_0   (0x1UL << XSPI_CR_FMODE_Pos)
#define XSPI_CR_FMODE_1   (0x2UL << XSPI_CR_FMODE_Pos)
#define XSPI_HSPI_CR_MSEL_Pos   (30U)
#define XSPI_HSPI_CR_MSEL_Msk   (0x3UL << XSPI_HSPI_CR_MSEL_Pos)
#define XSPI_HSPI_CR_MSEL   XSPI_HSPI_CR_MSEL_Msk
#define XSPI_HSPI_CR_MSEL_0   (0x1UL << XSPI_HSPI_CR_MSEL_Pos)
#define XSPI_HSPI_CR_MSEL_1   (0x2UL << XSPI_HSPI_CR_MSEL_Pos)
#define XSPI_DCR1_CKMODE_Pos   (0U)
#define XSPI_DCR1_CKMODE_Msk   (0x1UL << XSPI_DCR1_CKMODE_Pos)
#define XSPI_DCR1_CKMODE   XSPI_DCR1_CKMODE_Msk
#define XSPI_DCR1_FRCK_Pos   (1U)
#define XSPI_DCR1_FRCK_Msk   (0x1UL << XSPI_DCR1_FRCK_Pos)
#define XSPI_DCR1_FRCK   XSPI_DCR1_FRCK_Msk
#define XSPI_OCTOSPI_DCR1_DLYBYP_Pos   (3U)
#define XSPI_OCTOSPI_DCR1_DLYBYP_Msk   (0x1UL << XSPI_OCTOSPI_DCR1_DLYBYP_Pos)
#define XSPI_OCTOSPI_DCR1_DLYBYP   XSPI_OCTOSPI_DCR1_DLYBYP_Msk
#define XSPI_DCR1_CSHT_Pos   (8U)
#define XSPI_DCR1_CSHT_Msk   (0x3FUL << XSPI_DCR1_CSHT_Pos)
#define XSPI_DCR1_CSHT   XSPI_DCR1_CSHT_Msk
#define XSPI_DCR1_DEVSIZE_Pos   (16U)
#define XSPI_DCR1_DEVSIZE_Msk   (0x1FUL << XSPI_DCR1_DEVSIZE_Pos)
#define XSPI_DCR1_DEVSIZE   XSPI_DCR1_DEVSIZE_Msk
#define XSPI_DCR1_MTYP_Pos   (24U)
#define XSPI_DCR1_MTYP_Msk   (0x7UL << XSPI_DCR1_MTYP_Pos)
#define XSPI_DCR1_MTYP   XSPI_DCR1_MTYP_Msk
#define XSPI_DCR1_MTYP_0   (0x1UL << XSPI_DCR1_MTYP_Pos)
#define XSPI_DCR1_MTYP_1   (0x2UL << XSPI_DCR1_MTYP_Pos)
#define XSPI_DCR1_MTYP_2   (0x4UL << XSPI_DCR1_MTYP_Pos)
#define XSPI_DCR2_PRESCALER_Pos   (0U)
#define XSPI_DCR2_PRESCALER_Msk   (0xFFUL << XSPI_DCR2_PRESCALER_Pos)
#define XSPI_DCR2_PRESCALER   XSPI_DCR2_PRESCALER_Msk
#define XSPI_DCR2_WRAPSIZE_Pos   (16U)
#define XSPI_DCR2_WRAPSIZE_Msk   (0x7UL << XSPI_DCR2_WRAPSIZE_Pos)
#define XSPI_DCR2_WRAPSIZE   XSPI_DCR2_WRAPSIZE_Msk
#define XSPI_DCR2_WRAPSIZE_0   (0x1UL << XSPI_DCR2_WRAPSIZE_Pos)
#define XSPI_DCR2_WRAPSIZE_1   (0x2UL << XSPI_DCR2_WRAPSIZE_Pos)
#define XSPI_DCR2_WRAPSIZE_2   (0x4UL << XSPI_DCR2_WRAPSIZE_Pos)
#define XSPI_OCTOSPI_DCR3_MAXTRAN_Pos   (0U)
#define XSPI_OCTOSPI_DCR3_MAXTRAN_Msk   (0xFFUL << XSPI_OCTOSPI_DCR3_MAXTRAN_Pos)
#define XSPI_OCTOSPI_DCR3_MAXTRAN   XSPI_OCTOSPI_DCR3_MAXTRAN_Msk
#define XSPI_DCR3_CSBOUND_Pos   (16U)
#define XSPI_DCR3_CSBOUND_Msk   (0x1FUL << XSPI_DCR3_CSBOUND_Pos)
#define XSPI_DCR3_CSBOUND   XSPI_DCR3_CSBOUND_Msk
#define XSPI_DCR4_REFRESH_Pos   (0U)
#define XSPI_DCR4_REFRESH_Msk   (0xFFFFFFFFUL << XSPI_DCR4_REFRESH_Pos)
#define XSPI_DCR4_REFRESH   XSPI_DCR4_REFRESH_Msk
#define XSPI_SR_TEF_Pos   (0U)
#define XSPI_SR_TEF_Msk   (0x1UL << XSPI_SR_TEF_Pos)
#define XSPI_SR_TEF   XSPI_SR_TEF_Msk
#define XSPI_SR_TCF_Pos   (1U)
#define XSPI_SR_TCF_Msk   (0x1UL << XSPI_SR_TCF_Pos)
#define XSPI_SR_TCF   XSPI_SR_TCF_Msk
#define XSPI_SR_FTF_Pos   (2U)
#define XSPI_SR_FTF_Msk   (0x1UL << XSPI_SR_FTF_Pos)
#define XSPI_SR_FTF   XSPI_SR_FTF_Msk
#define XSPI_SR_SMF_Pos   (3U)
#define XSPI_SR_SMF_Msk   (0x1UL << XSPI_SR_SMF_Pos)
#define XSPI_SR_SMF   XSPI_SR_SMF_Msk
#define XSPI_SR_TOF_Pos   (4U)
#define XSPI_SR_TOF_Msk   (0x1UL << XSPI_SR_TOF_Pos)
#define XSPI_SR_TOF   XSPI_SR_TOF_Msk
#define XSPI_SR_BUSY_Pos   (5U)
#define XSPI_SR_BUSY_Msk   (0x1UL << XSPI_SR_BUSY_Pos)
#define XSPI_SR_BUSY   XSPI_SR_BUSY_Msk
#define XSPI_SR_FLEVEL_Pos   (8U)
#define XSPI_SR_FLEVEL_Msk   (0x7FUL << XSPI_SR_FLEVEL_Pos)
#define XSPI_SR_FLEVEL   XSPI_SR_FLEVEL_Msk
#define XSPI_FCR_CTEF_Pos   (0U)
#define XSPI_FCR_CTEF_Msk   (0x1UL << XSPI_FCR_CTEF_Pos)
#define XSPI_FCR_CTEF   XSPI_FCR_CTEF_Msk
#define XSPI_FCR_CTCF_Pos   (1U)
#define XSPI_FCR_CTCF_Msk   (0x1UL << XSPI_FCR_CTCF_Pos)
#define XSPI_FCR_CTCF   XSPI_FCR_CTCF_Msk
#define XSPI_FCR_CSMF_Pos   (3U)
#define XSPI_FCR_CSMF_Msk   (0x1UL << XSPI_FCR_CSMF_Pos)
#define XSPI_FCR_CSMF   XSPI_FCR_CSMF_Msk
#define XSPI_FCR_CTOF_Pos   (4U)
#define XSPI_FCR_CTOF_Msk   (0x1UL << XSPI_FCR_CTOF_Pos)
#define XSPI_FCR_CTOF   XSPI_FCR_CTOF_Msk
#define XSPI_DLR_DL_Pos   (0U)
#define XSPI_DLR_DL_Msk   (0xFFFFFFFFUL << XSPI_DLR_DL_Pos)
#define XSPI_DLR_DL   XSPI_DLR_DL_Msk
#define XSPI_AR_ADDRESS_Pos   (0U)
#define XSPI_AR_ADDRESS_Msk   (0xFFFFFFFFUL << XSPI_AR_ADDRESS_Pos)
#define XSPI_AR_ADDRESS   XSPI_AR_ADDRESS_Msk
#define XSPI_DR_DATA_Pos   (0U)
#define XSPI_DR_DATA_Msk   (0xFFFFFFFFUL << XSPI_DR_DATA_Pos)
#define XSPI_DR_DATA   XSPI_DR_DATA_Msk
#define XSPI_PSMKR_MASK_Pos   (0U)
#define XSPI_PSMKR_MASK_Msk   (0xFFFFFFFFUL << XSPI_PSMKR_MASK_Pos)
#define XSPI_PSMKR_MASK   XSPI_PSMKR_MASK_Msk
#define XSPI_PSMAR_MATCH_Pos   (0U)
#define XSPI_PSMAR_MATCH_Msk   (0xFFFFFFFFUL << XSPI_PSMAR_MATCH_Pos)
#define XSPI_PSMAR_MATCH   XSPI_PSMAR_MATCH_Msk
#define XSPI_PIR_INTERVAL_Pos   (0U)
#define XSPI_PIR_INTERVAL_Msk   (0xFFFFUL << XSPI_PIR_INTERVAL_Pos)
#define XSPI_PIR_INTERVAL   XSPI_PIR_INTERVAL_Msk
#define XSPI_CCR_IMODE_Pos   (0U)
#define XSPI_CCR_IMODE_Msk   (0x7UL << XSPI_CCR_IMODE_Pos)
#define XSPI_CCR_IMODE   XSPI_CCR_IMODE_Msk
#define XSPI_CCR_IMODE_0   (0x1UL << XSPI_CCR_IMODE_Pos)
#define XSPI_CCR_IMODE_1   (0x2UL << XSPI_CCR_IMODE_Pos)
#define XSPI_CCR_IMODE_2   (0x4UL << XSPI_CCR_IMODE_Pos)
#define XSPI_CCR_IDTR_Pos   (3U)
#define XSPI_CCR_IDTR_Msk   (0x1UL << XSPI_CCR_IDTR_Pos)
#define XSPI_CCR_IDTR   XSPI_CCR_IDTR_Msk
#define XSPI_CCR_ISIZE_Pos   (4U)
#define XSPI_CCR_ISIZE_Msk   (0x3UL << XSPI_CCR_ISIZE_Pos)
#define XSPI_CCR_ISIZE   XSPI_CCR_ISIZE_Msk
#define XSPI_CCR_ISIZE_0   (0x1UL << XSPI_CCR_ISIZE_Pos)
#define XSPI_CCR_ISIZE_1   (0x2UL << XSPI_CCR_ISIZE_Pos)
#define XSPI_CCR_ADMODE_Pos   (8U)
#define XSPI_CCR_ADMODE_Msk   (0x7UL << XSPI_CCR_ADMODE_Pos)
#define XSPI_CCR_ADMODE   XSPI_CCR_ADMODE_Msk
#define XSPI_CCR_ADMODE_0   (0x1UL << XSPI_CCR_ADMODE_Pos)
#define XSPI_CCR_ADMODE_1   (0x2UL << XSPI_CCR_ADMODE_Pos)
#define XSPI_CCR_ADMODE_2   (0x4UL << XSPI_CCR_ADMODE_Pos)
#define XSPI_CCR_ADDTR_Pos   (11U)
#define XSPI_CCR_ADDTR_Msk   (0x1UL << XSPI_CCR_ADDTR_Pos)
#define XSPI_CCR_ADDTR   XSPI_CCR_ADDTR_Msk
#define XSPI_CCR_ADSIZE_Pos   (12U)
#define XSPI_CCR_ADSIZE_Msk   (0x3UL << XSPI_CCR_ADSIZE_Pos)
#define XSPI_CCR_ADSIZE   XSPI_CCR_ADSIZE_Msk
#define XSPI_CCR_ADSIZE_0   (0x1UL << XSPI_CCR_ADSIZE_Pos)
#define XSPI_CCR_ADSIZE_1   (0x2UL << XSPI_CCR_ADSIZE_Pos)
#define XSPI_CCR_ABMODE_Pos   (16U)
#define XSPI_CCR_ABMODE_Msk   (0x7UL << XSPI_CCR_ABMODE_Pos)
#define XSPI_CCR_ABMODE   XSPI_CCR_ABMODE_Msk
#define XSPI_CCR_ABMODE_0   (0x1UL << XSPI_CCR_ABMODE_Pos)
#define XSPI_CCR_ABMODE_1   (0x2UL << XSPI_CCR_ABMODE_Pos)
#define XSPI_CCR_ABMODE_2   (0x4UL << XSPI_CCR_ABMODE_Pos)
#define XSPI_CCR_ABDTR_Pos   (19U)
#define XSPI_CCR_ABDTR_Msk   (0x1UL << XSPI_CCR_ABDTR_Pos)
#define XSPI_CCR_ABDTR   XSPI_CCR_ABDTR_Msk
#define XSPI_CCR_ABSIZE_Pos   (20U)
#define XSPI_CCR_ABSIZE_Msk   (0x3UL << XSPI_CCR_ABSIZE_Pos)
#define XSPI_CCR_ABSIZE   XSPI_CCR_ABSIZE_Msk
#define XSPI_CCR_ABSIZE_0   (0x1UL << XSPI_CCR_ABSIZE_Pos)
#define XSPI_CCR_ABSIZE_1   (0x2UL << XSPI_CCR_ABSIZE_Pos)
#define XSPI_CCR_DMODE_Pos   (24U)
#define XSPI_CCR_DMODE_Msk   (0x7UL << XSPI_CCR_DMODE_Pos)
#define XSPI_CCR_DMODE   XSPI_CCR_DMODE_Msk
#define XSPI_CCR_DMODE_0   (0x1UL << XSPI_CCR_DMODE_Pos)
#define XSPI_CCR_DMODE_1   (0x2UL << XSPI_CCR_DMODE_Pos)
#define XSPI_CCR_DMODE_2   (0x4UL << XSPI_CCR_DMODE_Pos)
#define XSPI_CCR_DDTR_Pos   (27U)
#define XSPI_CCR_DDTR_Msk   (0x1UL << XSPI_CCR_DDTR_Pos)
#define XSPI_CCR_DDTR   XSPI_CCR_DDTR_Msk
#define XSPI_CCR_DQSE_Pos   (29U)
#define XSPI_CCR_DQSE_Msk   (0x1UL << XSPI_CCR_DQSE_Pos)
#define XSPI_CCR_DQSE   XSPI_CCR_DQSE_Msk
#define XSPI_CCR_SIOO_Pos   (31U)
#define XSPI_CCR_SIOO_Msk   (0x1UL << XSPI_CCR_SIOO_Pos)
#define XSPI_CCR_SIOO   XSPI_CCR_SIOO_Msk
#define XSPI_TCR_DCYC_Pos   (0U)
#define XSPI_TCR_DCYC_Msk   (0x1FUL << XSPI_TCR_DCYC_Pos)
#define XSPI_TCR_DCYC   XSPI_TCR_DCYC_Msk
#define XSPI_TCR_DHQC_Pos   (28U)
#define XSPI_TCR_DHQC_Msk   (0x1UL << XSPI_TCR_DHQC_Pos)
#define XSPI_TCR_DHQC   XSPI_TCR_DHQC_Msk
#define XSPI_TCR_SSHIFT_Pos   (30U)
#define XSPI_TCR_SSHIFT_Msk   (0x1UL << XSPI_TCR_SSHIFT_Pos)
#define XSPI_TCR_SSHIFT   XSPI_TCR_SSHIFT_Msk
#define XSPI_IR_INSTRUCTION_Pos   (0U)
#define XSPI_IR_INSTRUCTION_Msk   (0xFFFFFFFFUL << XSPI_IR_INSTRUCTION_Pos)
#define XSPI_IR_INSTRUCTION   XSPI_IR_INSTRUCTION_Msk
#define XSPI_ABR_ALTERNATE_Pos   (0U)
#define XSPI_ABR_ALTERNATE_Msk   (0xFFFFFFFFUL << XSPI_ABR_ALTERNATE_Pos)
#define XSPI_ABR_ALTERNATE   XSPI_ABR_ALTERNATE_Msk
#define XSPI_LPTR_TIMEOUT_Pos   (0U)
#define XSPI_LPTR_TIMEOUT_Msk   (0xFFFFUL << XSPI_LPTR_TIMEOUT_Pos)
#define XSPI_LPTR_TIMEOUT   XSPI_LPTR_TIMEOUT_Msk
#define XSPI_WPCCR_IMODE_Pos   (0U)
#define XSPI_WPCCR_IMODE_Msk   (0x7UL << XSPI_WPCCR_IMODE_Pos)
#define XSPI_WPCCR_IMODE   XSPI_WPCCR_IMODE_Msk
#define XSPI_WPCCR_IMODE_0   (0x1UL << XSPI_WPCCR_IMODE_Pos)
#define XSPI_WPCCR_IMODE_1   (0x2UL << XSPI_WPCCR_IMODE_Pos)
#define XSPI_WPCCR_IMODE_2   (0x4UL << XSPI_WPCCR_IMODE_Pos)
#define XSPI_WPCCR_IDTR_Pos   (3U)
#define XSPI_WPCCR_IDTR_Msk   (0x1UL << XSPI_WPCCR_IDTR_Pos)
#define XSPI_WPCCR_IDTR   XSPI_WPCCR_IDTR_Msk
#define XSPI_WPCCR_ISIZE_Pos   (4U)
#define XSPI_WPCCR_ISIZE_Msk   (0x3UL << XSPI_WPCCR_ISIZE_Pos)
#define XSPI_WPCCR_ISIZE   XSPI_WPCCR_ISIZE_Msk
#define XSPI_WPCCR_ISIZE_0   (0x1UL << XSPI_WPCCR_ISIZE_Pos)
#define XSPI_WPCCR_ISIZE_1   (0x2UL << XSPI_WPCCR_ISIZE_Pos)
#define XSPI_WPCCR_ADMODE_Pos   (8U)
#define XSPI_WPCCR_ADMODE_Msk   (0x7UL << XSPI_WPCCR_ADMODE_Pos)
#define XSPI_WPCCR_ADMODE   XSPI_WPCCR_ADMODE_Msk
#define XSPI_WPCCR_ADMODE_0   (0x1UL << XSPI_WPCCR_ADMODE_Pos)
#define XSPI_WPCCR_ADMODE_1   (0x2UL << XSPI_WPCCR_ADMODE_Pos)
#define XSPI_WPCCR_ADMODE_2   (0x4UL << XSPI_WPCCR_ADMODE_Pos)
#define XSPI_WPCCR_ADDTR_Pos   (11U)
#define XSPI_WPCCR_ADDTR_Msk   (0x1UL << XSPI_WPCCR_ADDTR_Pos)
#define XSPI_WPCCR_ADDTR   XSPI_WPCCR_ADDTR_Msk
#define XSPI_WPCCR_ADSIZE_Pos   (12U)
#define XSPI_WPCCR_ADSIZE_Msk   (0x3UL << XSPI_WPCCR_ADSIZE_Pos)
#define XSPI_WPCCR_ADSIZE   XSPI_WPCCR_ADSIZE_Msk
#define XSPI_WPCCR_ADSIZE_0   (0x1UL << XSPI_WPCCR_ADSIZE_Pos)
#define XSPI_WPCCR_ADSIZE_1   (0x2UL << XSPI_WPCCR_ADSIZE_Pos)
#define XSPI_WPCCR_ABMODE_Pos   (16U)
#define XSPI_WPCCR_ABMODE_Msk   (0x7UL << XSPI_WPCCR_ABMODE_Pos)
#define XSPI_WPCCR_ABMODE   XSPI_WPCCR_ABMODE_Msk
#define XSPI_WPCCR_ABMODE_0   (0x1UL << XSPI_WPCCR_ABMODE_Pos)
#define XSPI_WPCCR_ABMODE_1   (0x2UL << XSPI_WPCCR_ABMODE_Pos)
#define XSPI_WPCCR_ABMODE_2   (0x4UL << XSPI_WPCCR_ABMODE_Pos)
#define XSPI_WPCCR_ABDTR_Pos   (19U)
#define XSPI_WPCCR_ABDTR_Msk   (0x1UL << XSPI_WPCCR_ABDTR_Pos)
#define XSPI_WPCCR_ABDTR   XSPI_WPCCR_ABDTR_Msk
#define XSPI_WPCCR_ABSIZE_Pos   (20U)
#define XSPI_WPCCR_ABSIZE_Msk   (0x3UL << XSPI_WPCCR_ABSIZE_Pos)
#define XSPI_WPCCR_ABSIZE   XSPI_WPCCR_ABSIZE_Msk
#define XSPI_WPCCR_ABSIZE_0   (0x1UL << XSPI_WPCCR_ABSIZE_Pos)
#define XSPI_WPCCR_ABSIZE_1   (0x2UL << XSPI_WPCCR_ABSIZE_Pos)
#define XSPI_WPCCR_DMODE_Pos   (24U)
#define XSPI_WPCCR_DMODE_Msk   (0x7UL << XSPI_WPCCR_DMODE_Pos)
#define XSPI_WPCCR_DMODE   XSPI_WPCCR_DMODE_Msk
#define XSPI_WPCCR_DMODE_0   (0x1UL << XSPI_WPCCR_DMODE_Pos)
#define XSPI_WPCCR_DMODE_1   (0x2UL << XSPI_WPCCR_DMODE_Pos)
#define XSPI_WPCCR_DMODE_2   (0x4UL << XSPI_WPCCR_DMODE_Pos)
#define XSPI_WPCCR_DDTR_Pos   (27U)
#define XSPI_WPCCR_DDTR_Msk   (0x1UL << XSPI_WPCCR_DDTR_Pos)
#define XSPI_WPCCR_DDTR   XSPI_WPCCR_DDTR_Msk
#define XSPI_WPCCR_DQSE_Pos   (29U)
#define XSPI_WPCCR_DQSE_Msk   (0x1UL << XSPI_WPCCR_DQSE_Pos)
#define XSPI_WPCCR_DQSE   XSPI_WPCCR_DQSE_Msk
#define XSPI_WPTCR_DCYC_Pos   (0U)
#define XSPI_WPTCR_DCYC_Msk   (0x1FUL << XSPI_WPTCR_DCYC_Pos)
#define XSPI_WPTCR_DCYC   XSPI_WPTCR_DCYC_Msk
#define XSPI_WPTCR_DHQC_Pos   (28U)
#define XSPI_WPTCR_DHQC_Msk   (0x1UL << XSPI_WPTCR_DHQC_Pos)
#define XSPI_WPTCR_DHQC   XSPI_WPTCR_DHQC_Msk
#define XSPI_WPTCR_SSHIFT_Pos   (30U)
#define XSPI_WPTCR_SSHIFT_Msk   (0x1UL << XSPI_WPTCR_SSHIFT_Pos)
#define XSPI_WPTCR_SSHIFT   XSPI_WPTCR_SSHIFT_Msk
#define XSPI_WPIR_INSTRUCTION_Pos   (0U)
#define XSPI_WPIR_INSTRUCTION_Msk   (0xFFFFFFFFUL << XSPI_WPIR_INSTRUCTION_Pos)
#define XSPI_WPIR_INSTRUCTION   XSPI_WPIR_INSTRUCTION_Msk
#define XSPI_WPABR_ALTERNATE_Pos   (0U)
#define XSPI_WPABR_ALTERNATE_Msk   (0xFFFFFFFFUL << XSPI_WPABR_ALTERNATE_Pos)
#define XSPI_WPABR_ALTERNATE   XSPI_WPABR_ALTERNATE_Msk
#define XSPI_WCCR_IMODE_Pos   (0U)
#define XSPI_WCCR_IMODE_Msk   (0x7UL << XSPI_WCCR_IMODE_Pos)
#define XSPI_WCCR_IMODE   XSPI_WCCR_IMODE_Msk
#define XSPI_WCCR_IMODE_0   (0x1UL << XSPI_WCCR_IMODE_Pos)
#define XSPI_WCCR_IMODE_1   (0x2UL << XSPI_WCCR_IMODE_Pos)
#define XSPI_WCCR_IMODE_2   (0x4UL << XSPI_WCCR_IMODE_Pos)
#define XSPI_WCCR_IDTR_Pos   (3U)
#define XSPI_WCCR_IDTR_Msk   (0x1UL << XSPI_WCCR_IDTR_Pos)
#define XSPI_WCCR_IDTR   XSPI_WCCR_IDTR_Msk
#define XSPI_WCCR_ISIZE_Pos   (4U)
#define XSPI_WCCR_ISIZE_Msk   (0x3UL << XSPI_WCCR_ISIZE_Pos)
#define XSPI_WCCR_ISIZE   XSPI_WCCR_ISIZE_Msk
#define XSPI_WCCR_ISIZE_0   (0x1UL << XSPI_WCCR_ISIZE_Pos)
#define XSPI_WCCR_ISIZE_1   (0x2UL << XSPI_WCCR_ISIZE_Pos)
#define XSPI_WCCR_ADMODE_Pos   (8U)
#define XSPI_WCCR_ADMODE_Msk   (0x7UL << XSPI_WCCR_ADMODE_Pos)
#define XSPI_WCCR_ADMODE   XSPI_WCCR_ADMODE_Msk
#define XSPI_WCCR_ADMODE_0   (0x1UL << XSPI_WCCR_ADMODE_Pos)
#define XSPI_WCCR_ADMODE_1   (0x2UL << XSPI_WCCR_ADMODE_Pos)
#define XSPI_WCCR_ADMODE_2   (0x4UL << XSPI_WCCR_ADMODE_Pos)
#define XSPI_WCCR_ADDTR_Pos   (11U)
#define XSPI_WCCR_ADDTR_Msk   (0x1UL << XSPI_WCCR_ADDTR_Pos)
#define XSPI_WCCR_ADDTR   XSPI_WCCR_ADDTR_Msk
#define XSPI_WCCR_ADSIZE_Pos   (12U)
#define XSPI_WCCR_ADSIZE_Msk   (0x3UL << XSPI_WCCR_ADSIZE_Pos)
#define XSPI_WCCR_ADSIZE   XSPI_WCCR_ADSIZE_Msk
#define XSPI_WCCR_ADSIZE_0   (0x1UL << XSPI_WCCR_ADSIZE_Pos)
#define XSPI_WCCR_ADSIZE_1   (0x2UL << XSPI_WCCR_ADSIZE_Pos)
#define XSPI_WCCR_ABMODE_Pos   (16U)
#define XSPI_WCCR_ABMODE_Msk   (0x7UL << XSPI_WCCR_ABMODE_Pos)
#define XSPI_WCCR_ABMODE   XSPI_WCCR_ABMODE_Msk
#define XSPI_WCCR_ABMODE_0   (0x1UL << XSPI_WCCR_ABMODE_Pos)
#define XSPI_WCCR_ABMODE_1   (0x2UL << XSPI_WCCR_ABMODE_Pos)
#define XSPI_WCCR_ABMODE_2   (0x4UL << XSPI_WCCR_ABMODE_Pos)
#define XSPI_WCCR_ABDTR_Pos   (19U)
#define XSPI_WCCR_ABDTR_Msk   (0x1UL << XSPI_WCCR_ABDTR_Pos)
#define XSPI_WCCR_ABDTR   XSPI_WCCR_ABDTR_Msk
#define XSPI_WCCR_ABSIZE_Pos   (20U)
#define XSPI_WCCR_ABSIZE_Msk   (0x3UL << XSPI_WCCR_ABSIZE_Pos)
#define XSPI_WCCR_ABSIZE   XSPI_WCCR_ABSIZE_Msk
#define XSPI_WCCR_ABSIZE_0   (0x1UL << XSPI_WCCR_ABSIZE_Pos)
#define XSPI_WCCR_ABSIZE_1   (0x2UL << XSPI_WCCR_ABSIZE_Pos)
#define XSPI_WCCR_DMODE_Pos   (24U)
#define XSPI_WCCR_DMODE_Msk   (0x7UL << XSPI_WCCR_DMODE_Pos)
#define XSPI_WCCR_DMODE   XSPI_WCCR_DMODE_Msk
#define XSPI_WCCR_DMODE_0   (0x1UL << XSPI_WCCR_DMODE_Pos)
#define XSPI_WCCR_DMODE_1   (0x2UL << XSPI_WCCR_DMODE_Pos)
#define XSPI_WCCR_DMODE_2   (0x4UL << XSPI_WCCR_DMODE_Pos)
#define XSPI_WCCR_DDTR_Pos   (27U)
#define XSPI_WCCR_DDTR_Msk   (0x1UL << XSPI_WCCR_DDTR_Pos)
#define XSPI_WCCR_DDTR   XSPI_WCCR_DDTR_Msk
#define XSPI_WCCR_DQSE_Pos   (29U)
#define XSPI_WCCR_DQSE_Msk   (0x1UL << XSPI_WCCR_DQSE_Pos)
#define XSPI_WCCR_DQSE   XSPI_WCCR_DQSE_Msk
#define XSPI_WTCR_DCYC_Pos   (0U)
#define XSPI_WTCR_DCYC_Msk   (0x1FUL << XSPI_WTCR_DCYC_Pos)
#define XSPI_WTCR_DCYC   XSPI_WTCR_DCYC_Msk
#define XSPI_WIR_INSTRUCTION_Pos   (0U)
#define XSPI_WIR_INSTRUCTION_Msk   (0xFFFFFFFFUL << XSPI_WIR_INSTRUCTION_Pos)
#define XSPI_WIR_INSTRUCTION   XSPI_WIR_INSTRUCTION_Msk
#define XSPI_WABR_ALTERNATE_Pos   (0U)
#define XSPI_WABR_ALTERNATE_Msk   (0xFFFFFFFFUL << XSPI_WABR_ALTERNATE_Pos)
#define XSPI_WABR_ALTERNATE   XSPI_WABR_ALTERNATE_Msk
#define XSPI_HLCR_LM_Pos   (0U)
#define XSPI_HLCR_LM_Msk   (0x1UL << XSPI_HLCR_LM_Pos)
#define XSPI_HLCR_LM   XSPI_HLCR_LM_Msk
#define XSPI_HLCR_WZL_Pos   (1U)
#define XSPI_HLCR_WZL_Msk   (0x1UL << XSPI_HLCR_WZL_Pos)
#define XSPI_HLCR_WZL   XSPI_HLCR_WZL_Msk
#define XSPI_HLCR_TACC_Pos   (8U)
#define XSPI_HLCR_TACC_Msk   (0xFFUL << XSPI_HLCR_TACC_Pos)
#define XSPI_HLCR_TACC   XSPI_HLCR_TACC_Msk
#define XSPI_HLCR_TRWR_Pos   (16U)
#define XSPI_HLCR_TRWR_Msk   (0xFFUL << XSPI_HLCR_TRWR_Pos)
#define XSPI_HLCR_TRWR   XSPI_HLCR_TRWR_Msk
#define XSPI_HSPI_CALFCR_FINE_Pos   (0U)
#define XSPI_HSPI_CALFCR_FINE_Msk   (0x7FUL << XSPI_HSPI_CALFCR_FINE_Pos)
#define XSPI_HSPI_CALFCR_FINE   XSPI_HSPI_CALFCR_FINE_Msk
#define XSPI_HSPI_CALFCR_COARSE_Pos   (16U)
#define XSPI_HSPI_CALFCR_COARSE_Msk   (0x1FUL << XSPI_HSPI_CALFCR_COARSE_Pos)
#define XSPI_HSPI_CALFCR_COARSE   XSPI_HSPI_CALFCR_COARSE_Msk
#define XSPI_HSPI_CALFCR_CALMAX_Pos   (31U)
#define XSPI_HSPI_CALFCR_CALMAX_Msk   (0x1UL << XSPI_HSPI_CALFCR_CALMAX_Pos)
#define XSPI_HSPI_CALFCR_CALMAX   XSPI_HSPI_CALFCR_CALMAX_Msk
#define XSPI_HSPI_CALMR_FINE_Pos   (0U)
#define XSPI_HSPI_CALMR_FINE_Msk   (0x7FUL << XSPI_HSPI_CALMR_FINE_Pos)
#define XSPI_HSPI_CALMR_FINE   XSPI_HSPI_CALMR_FINE_Msk
#define XSPI_HSPI_CALMR_COARSE_Pos   (16U)
#define XSPI_HSPI_CALMR_COARSE_Msk   (0x1FUL << XSPI_HSPI_CALMR_COARSE_Pos)
#define XSPI_HSPI_CALMR_COARSE   XSPI_HSPI_CALMR_COARSE_Msk
#define XSPI_HSPI_CALSOR_FINE_Pos   (0U)
#define XSPI_HSPI_CALSOR_FINE_Msk   (0x7FUL << XSPI_HSPI_CALSOR_FINE_Pos)
#define XSPI_HSPI_CALSOR_FINE   XSPI_HSPI_CALSOR_FINE_Msk
#define XSPI_HSPI_CALSOR_COARSE_Pos   (16U)
#define XSPI_HSPI_CALSOR_COARSE_Msk   (0x1FUL << XSPI_HSPI_CALSOR_COARSE_Pos)
#define XSPI_HSPI_CALSOR_COARSE   XSPI_HSPI_CALSOR_COARSE_Msk
#define XSPI_HSPI_CALSIR_FINE_Pos   (0U)
#define XSPI_HSPI_CALSIR_FINE_Msk   (0x7FUL << XSPI_HSPI_CALSIR_FINE_Pos)
#define XSPI_HSPI_CALSIR_FINE   XSPI_HSPI_CALSIR_FINE_Msk
#define XSPI_HSPI_CALSIR_COARSE_Pos   (16U)
#define XSPI_HSPI_CALSIR_COARSE_Msk   (0x1FUL << XSPI_HSPI_CALSIR_COARSE_Pos)
#define XSPI_HSPI_CALSIR_COARSE   XSPI_HSPI_CALSIR_COARSE_Msk
#define OCTOSPI_CR_EN_Pos   XSPI_CR_EN_Pos
#define OCTOSPI_CR_EN_Msk   XSPI_CR_EN_Msk
#define OCTOSPI_CR_EN   XSPI_CR_EN
#define OCTOSPI_CR_ABORT_Pos   XSPI_CR_ABORT_Pos
#define OCTOSPI_CR_ABORT_Msk   XSPI_CR_ABORT_Msk
#define OCTOSPI_CR_ABORT   XSPI_CR_ABORT
#define OCTOSPI_CR_DMAEN_Pos   XSPI_CR_DMAEN_Pos
#define OCTOSPI_CR_DMAEN_Msk   XSPI_CR_DMAEN_Msk
#define OCTOSPI_CR_DMAEN   XSPI_CR_DMAEN
#define OCTOSPI_CR_TCEN_Pos   XSPI_CR_TCEN_Pos
#define OCTOSPI_CR_TCEN_Msk   XSPI_CR_TCEN_Msk
#define OCTOSPI_CR_TCEN   XSPI_CR_TCEN
#define OCTOSPI_CR_DMM_Pos   XSPI_CR_DMM_Pos
#define OCTOSPI_CR_DMM_Msk   XSPI_CR_DMM_Msk
#define OCTOSPI_CR_DMM   XSPI_CR_DMM
#define OCTOSPI_CR_MSEL_Pos   XSPI_OCTOSPI_CR_MSEL_Pos
#define OCTOSPI_CR_MSEL_Msk   XSPI_OCTOSPI_CR_MSEL_Msk
#define OCTOSPI_CR_MSEL   XSPI_OCTOSPI_CR_MSEL
#define OCTOSPI_CR_FTHRES_Pos   XSPI_CR_FTHRES_Pos
#define OCTOSPI_CR_FTHRES_Msk   (0x1FUL << OCTOSPI_CR_FTHRES_Pos)
#define OCTOSPI_CR_FTHRES   XSPI_CR_FTHRES
#define OCTOSPI_CR_TEIE_Pos   XSPI_CR_TEIE_Pos
#define OCTOSPI_CR_TEIE_Msk   XSPI_CR_TEIE_Msk
#define OCTOSPI_CR_TEIE   XSPI_CR_TEIE
#define OCTOSPI_CR_TCIE_Pos   XSPI_CR_TCIE_Pos
#define OCTOSPI_CR_TCIE_Msk   XSPI_CR_TCIE_Msk
#define OCTOSPI_CR_TCIE   XSPI_CR_TCIE
#define OCTOSPI_CR_FTIE_Pos   XSPI_CR_FTIE_Pos
#define OCTOSPI_CR_FTIE_Msk   XSPI_CR_FTIE_Msk)
#define OCTOSPI_CR_FTIE   XSPI_CR_FTIE
#define OCTOSPI_CR_SMIE_Pos   XSPI_CR_SMIE_Pos
#define OCTOSPI_CR_SMIE_Msk   XSPI_CR_SMIE_Msk
#define OCTOSPI_CR_SMIE   XSPI_CR_SMIE
#define OCTOSPI_CR_TOIE_Pos   XSPI_CR_TOIE_Pos
#define OCTOSPI_CR_TOIE_Msk   XSPI_CR_TOIE_Msk
#define OCTOSPI_CR_TOIE   XSPI_CR_TOIE
#define OCTOSPI_CR_APMS_Pos   XSPI_CR_APMS_Pos
#define OCTOSPI_CR_APMS_Msk   XSPI_CR_APMS_Msk
#define OCTOSPI_CR_APMS   XSPI_CR_APMS
#define OCTOSPI_CR_PMM_Pos   XSPI_CR_PMM_Pos
#define OCTOSPI_CR_PMM_Msk   XSPI_CR_PMM_Msk
#define OCTOSPI_CR_PMM   XSPI_CR_PMM
#define OCTOSPI_CR_FMODE_Pos   XSPI_CR_FMODE_Pos
#define OCTOSPI_CR_FMODE_Msk   XSPI_CR_FMODE_Msk
#define OCTOSPI_CR_FMODE   XSPI_CR_FMODE
#define OCTOSPI_CR_FMODE_0   XSPI_CR_FMODE_0
#define OCTOSPI_CR_FMODE_1   XSPI_CR_FMODE_1
#define OCTOSPI_CR_DQM   XSPI_CR_DMM
#define OCTOSPI_CR_FSEL   XSPI_OCTOSPI_CR_MSEL
#define OCTOSPI_DCR1_CKMODE_Pos   XSPI_DCR1_CKMODE_Pos
#define OCTOSPI_DCR1_CKMODE_Msk   XSPI_DCR1_CKMODE_Msk
#define OCTOSPI_DCR1_CKMODE   XSPI_DCR1_CKMODE
#define OCTOSPI_DCR1_FRCK_Pos   XSPI_DCR1_FRCK_Pos
#define OCTOSPI_DCR1_FRCK_Msk   XSPI_DCR1_FRCK_Msk
#define OCTOSPI_DCR1_FRCK   XSPI_DCR1_FRCK
#define OCTOSPI_DCR1_DLYBYP_Pos   XSPI_OCTOSPI_DCR1_DLYBYP_Pos
#define OCTOSPI_DCR1_DLYBYP_Msk   XSPI_OCTOSPI_DCR1_DLYBYP_Msk
#define OCTOSPI_DCR1_DLYBYP   XSPI_OCTOSPI_DCR1_DLYBYP
#define OCTOSPI_DCR1_CSHT_Pos   XSPI_DCR1_CSHT_Pos
#define OCTOSPI_DCR1_CSHT_Msk   XSPI_DCR1_CSHT_Msk
#define OCTOSPI_DCR1_CSHT   XSPI_DCR1_CSHT
#define OCTOSPI_DCR1_DEVSIZE_Pos   XSPI_DCR1_DEVSIZE_Pos
#define OCTOSPI_DCR1_DEVSIZE_Msk   XSPI_DCR1_DEVSIZE_Msk
#define OCTOSPI_DCR1_DEVSIZE   XSPI_DCR1_DEVSIZE
#define OCTOSPI_DCR1_MTYP_Pos   XSPI_DCR1_MTYP_Pos
#define OCTOSPI_DCR1_MTYP_Msk   XSPI_DCR1_MTYP_Msk
#define OCTOSPI_DCR1_MTYP   XSPI_DCR1_MTYP
#define OCTOSPI_DCR1_MTYP_0   XSPI_DCR1_MTYP_0
#define OCTOSPI_DCR1_MTYP_1   XSPI_DCR1_MTYP_1
#define OCTOSPI_DCR1_MTYP_2   XSPI_DCR1_MTYP_2
#define OCTOSPI_DCR2_PRESCALER_Pos   XSPI_DCR2_PRESCALER_Pos
#define OCTOSPI_DCR2_PRESCALER_Msk   XSPI_DCR2_PRESCALER_Msk
#define OCTOSPI_DCR2_PRESCALER   XSPI_DCR2_PRESCALER
#define OCTOSPI_DCR2_WRAPSIZE_Pos   XSPI_DCR2_WRAPSIZE_Pos
#define OCTOSPI_DCR2_WRAPSIZE_Msk   XSPI_DCR2_WRAPSIZE_Msk
#define OCTOSPI_DCR2_WRAPSIZE   XSPI_DCR2_WRAPSIZE
#define OCTOSPI_DCR2_WRAPSIZE_0   XSPI_DCR2_WRAPSIZE_0
#define OCTOSPI_DCR2_WRAPSIZE_1   XSPI_DCR2_WRAPSIZE_1
#define OCTOSPI_DCR2_WRAPSIZE_2   XSPI_DCR2_WRAPSIZE_2
#define OCTOSPI_DCR3_MAXTRAN_Pos   XSPI_OCTOSPI_DCR3_MAXTRAN_Pos
#define OCTOSPI_DCR3_MAXTRAN_Msk   XSPI_OCTOSPI_DCR3_MAXTRAN_Msk
#define OCTOSPI_DCR3_MAXTRAN   XSPI_OCTOSPI_DCR3_MAXTRAN
#define OCTOSPI_DCR3_CSBOUND_Pos   XSPI_DCR3_CSBOUND_Pos
#define OCTOSPI_DCR3_CSBOUND_Msk   XSPI_DCR3_CSBOUND_Msk
#define OCTOSPI_DCR3_CSBOUND   XSPI_DCR3_CSBOUND
#define OCTOSPI_DCR4_REFRESH_Pos   XSPI_DCR4_REFRESH_Pos
#define OCTOSPI_DCR4_REFRESH_Msk   XSPI_DCR4_REFRESH_Msk
#define OCTOSPI_DCR4_REFRESH   XSPI_DCR4_REFRESH
#define OCTOSPI_SR_TEF_Pos   XSPI_SR_TEF_Pos
#define OCTOSPI_SR_TEF_Msk   XSPI_SR_TEF_Msk
#define OCTOSPI_SR_TEF   XSPI_SR_TEF
#define OCTOSPI_SR_TCF_Pos   XSPI_SR_TCF_Pos
#define OCTOSPI_SR_TCF_Msk   XSPI_SR_TCF_Msk
#define OCTOSPI_SR_TCF   XSPI_SR_TCF
#define OCTOSPI_SR_FTF_Pos   XSPI_SR_FTF_Pos
#define OCTOSPI_SR_FTF_Msk   XSPI_SR_FTF_Msk
#define OCTOSPI_SR_FTF   XSPI_SR_FTF
#define OCTOSPI_SR_SMF_Pos   XSPI_SR_SMF_Pos
#define OCTOSPI_SR_SMF_Msk   XSPI_SR_SMF_Msk
#define OCTOSPI_SR_SMF   XSPI_SR_SMF
#define OCTOSPI_SR_TOF_Pos   XSPI_SR_TOF_Pos
#define OCTOSPI_SR_TOF_Msk   XSPI_SR_TOF_Msk
#define OCTOSPI_SR_TOF   XSPI_SR_TOF
#define OCTOSPI_SR_BUSY_Pos   XSPI_SR_BUSY_Pos
#define OCTOSPI_SR_BUSY_Msk   XSPI_SR_BUSY_Msk
#define OCTOSPI_SR_BUSY   XSPI_SR_BUSY
#define OCTOSPI_SR_FLEVEL_Pos   XSPI_SR_FLEVEL_Pos
#define OCTOSPI_SR_FLEVEL_Msk   (0x3FUL << OCTOSPI_SR_FLEVEL_Pos)
#define OCTOSPI_SR_FLEVEL   XSPI_SR_FLEVEL
#define OCTOSPI_FCR_CTEF_Pos   XSPI_FCR_CTEF_Pos
#define OCTOSPI_FCR_CTEF_Msk   XSPI_FCR_CTEF_Msk
#define OCTOSPI_FCR_CTEF   XSPI_FCR_CTEF
#define OCTOSPI_FCR_CTCF_Pos   XSPI_FCR_CTCF_Pos
#define OCTOSPI_FCR_CTCF_Msk   XSPI_FCR_CTCF_Msk
#define OCTOSPI_FCR_CTCF   XSPI_FCR_CTCF
#define OCTOSPI_FCR_CSMF_Pos   XSPI_FCR_CSMF_Pos
#define OCTOSPI_FCR_CSMF_Msk   XSPI_FCR_CSMF_Msk
#define OCTOSPI_FCR_CSMF   XSPI_FCR_CSMF
#define OCTOSPI_FCR_CTOF_Pos   XSPI_FCR_CTOF_Pos
#define OCTOSPI_FCR_CTOF_Msk   XSPI_FCR_CTOF_Msk
#define OCTOSPI_FCR_CTOF   XSPI_FCR_CTOF
#define OCTOSPI_DLR_DL_Pos   XSPI_DLR_DL_Pos
#define OCTOSPI_DLR_DL_Msk   XSPI_DLR_DL_Msk
#define OCTOSPI_DLR_DL   XSPI_DLR_DL
#define OCTOSPI_AR_ADDRESS_Pos   XSPI_AR_ADDRESS_Pos
#define OCTOSPI_AR_ADDRESS_Msk   XSPI_AR_ADDRESS_Msk
#define OCTOSPI_AR_ADDRESS   XSPI_AR_ADDRESS
#define OCTOSPI_DR_DATA_Pos   XSPI_DR_DATA_Pos
#define OCTOSPI_DR_DATA_Msk   XSPI_DR_DATA_Msk
#define OCTOSPI_DR_DATA   XSPI_DR_DATA
#define OCTOSPI_PSMKR_MASK_Pos   XSPI_PSMKR_MASK_Pos
#define OCTOSPI_PSMKR_MASK_Msk   XSPI_PSMKR_MASK_Msk
#define OCTOSPI_PSMKR_MASK   XSPI_PSMKR_MASK
#define OCTOSPI_PSMAR_MATCH_Pos   XSPI_PSMAR_MATCH_Pos
#define OCTOSPI_PSMAR_MATCH_Msk   XSPI_PSMAR_MATCH_Msk
#define OCTOSPI_PSMAR_MATCH   XSPI_PSMAR_MATCH
#define OCTOSPI_PIR_INTERVAL_Pos   XSPI_PIR_INTERVAL_Pos
#define OCTOSPI_PIR_INTERVAL_Msk   XSPI_PIR_INTERVAL_Msk
#define OCTOSPI_PIR_INTERVAL   XSPI_PIR_INTERVAL
#define OCTOSPI_CCR_IMODE_Pos   XSPI_CCR_IMODE_Pos
#define OCTOSPI_CCR_IMODE_Msk   XSPI_CCR_IMODE_Msk
#define OCTOSPI_CCR_IMODE   XSPI_CCR_IMODE
#define OCTOSPI_CCR_IMODE_0   XSPI_CCR_IMODE_0
#define OCTOSPI_CCR_IMODE_1   XSPI_CCR_IMODE_1
#define OCTOSPI_CCR_IMODE_2   XSPI_CCR_IMODE_2
#define OCTOSPI_CCR_IDTR_Pos   XSPI_CCR_IDTR_Pos
#define OCTOSPI_CCR_IDTR_Msk   XSPI_CCR_IDTR_Msk
#define OCTOSPI_CCR_IDTR   XSPI_CCR_IDTR
#define OCTOSPI_CCR_ISIZE_Pos   XSPI_CCR_ISIZE_Pos
#define OCTOSPI_CCR_ISIZE_Msk   XSPI_CCR_ISIZE_Msk
#define OCTOSPI_CCR_ISIZE   XSPI_CCR_ISIZE
#define OCTOSPI_CCR_ISIZE_0   XSPI_CCR_ISIZE_0
#define OCTOSPI_CCR_ISIZE_1   XSPI_CCR_ISIZE_1
#define OCTOSPI_CCR_ADMODE_Pos   XSPI_CCR_ADMODE_Pos
#define OCTOSPI_CCR_ADMODE_Msk   XSPI_CCR_ADMODE_Msk
#define OCTOSPI_CCR_ADMODE   XSPI_CCR_ADMODE
#define OCTOSPI_CCR_ADMODE_0   XSPI_CCR_ADMODE_0
#define OCTOSPI_CCR_ADMODE_1   XSPI_CCR_ADMODE_1
#define OCTOSPI_CCR_ADMODE_2   XSPI_CCR_ADMODE_2
#define OCTOSPI_CCR_ADDTR_Pos   XSPI_CCR_ADDTR_Pos
#define OCTOSPI_CCR_ADDTR_Msk   XSPI_CCR_ADDTR_Msk
#define OCTOSPI_CCR_ADDTR   XSPI_CCR_ADDTR
#define OCTOSPI_CCR_ADSIZE_Pos   XSPI_CCR_ADSIZE_Pos
#define OCTOSPI_CCR_ADSIZE_Msk   XSPI_CCR_ADSIZE_Msk
#define OCTOSPI_CCR_ADSIZE   XSPI_CCR_ADSIZE
#define OCTOSPI_CCR_ADSIZE_0   XSPI_CCR_ADSIZE_0
#define OCTOSPI_CCR_ADSIZE_1   XSPI_CCR_ADSIZE_1
#define OCTOSPI_CCR_ABMODE_Pos   XSPI_CCR_ABMODE_Pos
#define OCTOSPI_CCR_ABMODE_Msk   XSPI_CCR_ABMODE_Msk
#define OCTOSPI_CCR_ABMODE   XSPI_CCR_ABMODE
#define OCTOSPI_CCR_ABMODE_0   XSPI_CCR_ABMODE_0
#define OCTOSPI_CCR_ABMODE_1   XSPI_CCR_ABMODE_1
#define OCTOSPI_CCR_ABMODE_2   XSPI_CCR_ABMODE_2
#define OCTOSPI_CCR_ABDTR_Pos   XSPI_CCR_ABDTR_Pos
#define OCTOSPI_CCR_ABDTR_Msk   XSPI_CCR_ABDTR_Msk
#define OCTOSPI_CCR_ABDTR   XSPI_CCR_ABDTR
#define OCTOSPI_CCR_ABSIZE_Pos   XSPI_CCR_ABSIZE_Pos
#define OCTOSPI_CCR_ABSIZE_Msk   XSPI_CCR_ABSIZE_Msk
#define OCTOSPI_CCR_ABSIZE   XSPI_CCR_ABSIZE
#define OCTOSPI_CCR_ABSIZE_0   XSPI_CCR_ABSIZE_0
#define OCTOSPI_CCR_ABSIZE_1   XSPI_CCR_ABSIZE_1
#define OCTOSPI_CCR_DMODE_Pos   XSPI_CCR_DMODE_Pos
#define OCTOSPI_CCR_DMODE_Msk   XSPI_CCR_DMODE_Msk
#define OCTOSPI_CCR_DMODE   XSPI_CCR_DMODE
#define OCTOSPI_CCR_DMODE_0   XSPI_CCR_DMODE_0
#define OCTOSPI_CCR_DMODE_1   XSPI_CCR_DMODE_1
#define OCTOSPI_CCR_DMODE_2   XSPI_CCR_DMODE_2
#define OCTOSPI_CCR_DDTR_Pos   XSPI_CCR_DDTR_Pos
#define OCTOSPI_CCR_DDTR_Msk   XSPI_CCR_DDTR_Msk
#define OCTOSPI_CCR_DDTR   XSPI_CCR_DDTR
#define OCTOSPI_CCR_DQSE_Pos   XSPI_CCR_DQSE_Pos
#define OCTOSPI_CCR_DQSE_Msk   XSPI_CCR_DQSE_Msk
#define OCTOSPI_CCR_DQSE   XSPI_CCR_DQSE
#define OCTOSPI_CCR_SIOO_Pos   XSPI_CCR_SIOO_Pos
#define OCTOSPI_CCR_SIOO_Msk   XSPI_CCR_SIOO_Msk
#define OCTOSPI_CCR_SIOO   XSPI_CCR_SIOO
#define OCTOSPI_TCR_DCYC_Pos   XSPI_TCR_DCYC_Pos
#define OCTOSPI_TCR_DCYC_Msk   XSPI_TCR_DCYC_Msk
#define OCTOSPI_TCR_DCYC   XSPI_TCR_DCYC
#define OCTOSPI_TCR_DHQC_Pos   XSPI_TCR_DHQC_Pos
#define OCTOSPI_TCR_DHQC_Msk   XSPI_TCR_DHQC_Msk
#define OCTOSPI_TCR_DHQC   XSPI_TCR_DHQC
#define OCTOSPI_TCR_SSHIFT_Pos   XSPI_TCR_SSHIFT_Pos
#define OCTOSPI_TCR_SSHIFT_Msk   XSPI_TCR_SSHIFT_Msk
#define OCTOSPI_TCR_SSHIFT   XSPI_TCR_SSHIFT
#define OCTOSPI_IR_INSTRUCTION_Pos   XSPI_IR_INSTRUCTION_Pos
#define OCTOSPI_IR_INSTRUCTION_Msk   XSPI_IR_INSTRUCTION_Msk
#define OCTOSPI_IR_INSTRUCTION   XSPI_IR_INSTRUCTION
#define OCTOSPI_ABR_ALTERNATE_Pos   XSPI_ABR_ALTERNATE_Pos
#define OCTOSPI_ABR_ALTERNATE_Msk   XSPI_ABR_ALTERNATE_Msk
#define OCTOSPI_ABR_ALTERNATE   XSPI_ABR_ALTERNATE
#define OCTOSPI_LPTR_TIMEOUT_Pos   XSPI_LPTR_TIMEOUT_Pos
#define OCTOSPI_LPTR_TIMEOUT_Msk   XSPI_LPTR_TIMEOUT_Msk
#define OCTOSPI_LPTR_TIMEOUT   XSPI_LPTR_TIMEOUT
#define OCTOSPI_WPCCR_IMODE_Pos   XSPI_WPCCR_IMODE_Pos
#define OCTOSPI_WPCCR_IMODE_Msk   XSPI_WPCCR_IMODE_Msk
#define OCTOSPI_WPCCR_IMODE   XSPI_WPCCR_IMODE
#define OCTOSPI_WPCCR_IMODE_0   XSPI_WPCCR_IMODE_0
#define OCTOSPI_WPCCR_IMODE_1   XSPI_WPCCR_IMODE_1
#define OCTOSPI_WPCCR_IMODE_2   XSPI_WPCCR_IMODE_2
#define OCTOSPI_WPCCR_IDTR_Pos   XSPI_WPCCR_IDTR_Pos
#define OCTOSPI_WPCCR_IDTR_Msk   XSPI_WPCCR_IDTR_Msk
#define OCTOSPI_WPCCR_IDTR   XSPI_WPCCR_IDTR
#define OCTOSPI_WPCCR_ISIZE_Pos   XSPI_WPCCR_ISIZE_Pos
#define OCTOSPI_WPCCR_ISIZE_Msk   XSPI_WPCCR_ISIZE_Msk
#define OCTOSPI_WPCCR_ISIZE   XSPI_WPCCR_ISIZE
#define OCTOSPI_WPCCR_ISIZE_0   XSPI_WPCCR_ISIZE_0
#define OCTOSPI_WPCCR_ISIZE_1   XSPI_WPCCR_ISIZE_1
#define OCTOSPI_WPCCR_ADMODE_Pos   XSPI_WPCCR_ADMODE_Pos
#define OCTOSPI_WPCCR_ADMODE_Msk   XSPI_WPCCR_ADMODE_Msk
#define OCTOSPI_WPCCR_ADMODE   XSPI_WPCCR_ADMODE
#define OCTOSPI_WPCCR_ADMODE_0   XSPI_WPCCR_ADMODE_0
#define OCTOSPI_WPCCR_ADMODE_1   XSPI_WPCCR_ADMODE_1
#define OCTOSPI_WPCCR_ADMODE_2   XSPI_WPCCR_ADMODE_2
#define OCTOSPI_WPCCR_ADDTR_Pos   XSPI_WPCCR_ADDTR_Pos
#define OCTOSPI_WPCCR_ADDTR_Msk   XSPI_WPCCR_ADDTR_Msk
#define OCTOSPI_WPCCR_ADDTR   XSPI_WPCCR_ADDTR
#define OCTOSPI_WPCCR_ADSIZE_Pos   XSPI_WPCCR_ADSIZE_Pos
#define OCTOSPI_WPCCR_ADSIZE_Msk   XSPI_WPCCR_ADSIZE_Msk
#define OCTOSPI_WPCCR_ADSIZE   XSPI_WPCCR_ADSIZE
#define OCTOSPI_WPCCR_ADSIZE_0   XSPI_WPCCR_ADSIZE_0
#define OCTOSPI_WPCCR_ADSIZE_1   XSPI_WPCCR_ADSIZE_1
#define OCTOSPI_WPCCR_ABMODE_Pos   XSPI_WPCCR_ABMODE_Pos
#define OCTOSPI_WPCCR_ABMODE_Msk   XSPI_WPCCR_ABMODE_Msk
#define OCTOSPI_WPCCR_ABMODE   XSPI_WPCCR_ABMODE
#define OCTOSPI_WPCCR_ABMODE_0   XSPI_WPCCR_ABMODE_0
#define OCTOSPI_WPCCR_ABMODE_1   XSPI_WPCCR_ABMODE_1
#define OCTOSPI_WPCCR_ABMODE_2   XSPI_WPCCR_ABMODE_2
#define OCTOSPI_WPCCR_ABDTR_Pos   XSPI_WPCCR_ABDTR_Pos
#define OCTOSPI_WPCCR_ABDTR_Msk   XSPI_WPCCR_ABDTR_Msk
#define OCTOSPI_WPCCR_ABDTR   XSPI_WPCCR_ABDTR
#define OCTOSPI_WPCCR_ABSIZE_Pos   XSPI_WPCCR_ABSIZE_Pos
#define OCTOSPI_WPCCR_ABSIZE_Msk   XSPI_WPCCR_ABSIZE_Msk
#define OCTOSPI_WPCCR_ABSIZE   XSPI_WPCCR_ABSIZE
#define OCTOSPI_WPCCR_ABSIZE_0   XSPI_WPCCR_ABSIZE_0
#define OCTOSPI_WPCCR_ABSIZE_1   XSPI_WPCCR_ABSIZE_1
#define OCTOSPI_WPCCR_DMODE_Pos   XSPI_WPCCR_DMODE_Pos
#define OCTOSPI_WPCCR_DMODE_Msk   XSPI_WPCCR_DMODE_Msk
#define OCTOSPI_WPCCR_DMODE   XSPI_WPCCR_DMODE
#define OCTOSPI_WPCCR_DMODE_0   XSPI_WPCCR_DMODE_0
#define OCTOSPI_WPCCR_DMODE_1   XSPI_WPCCR_DMODE_1
#define OCTOSPI_WPCCR_DMODE_2   XSPI_WPCCR_DMODE_2
#define OCTOSPI_WPCCR_DDTR_Pos   XSPI_WPCCR_DDTR_Pos
#define OCTOSPI_WPCCR_DDTR_Msk   XSPI_WPCCR_DDTR_Msk
#define OCTOSPI_WPCCR_DDTR   XSPI_WPCCR_DDTR
#define OCTOSPI_WPCCR_DQSE_Pos   XSPI_WPCCR_DQSE_Pos
#define OCTOSPI_WPCCR_DQSE_Msk   XSPI_WPCCR_DQSE_Msk
#define OCTOSPI_WPCCR_DQSE   XSPI_WPCCR_DQSE
#define OCTOSPI_WPTCR_DCYC_Pos   XSPI_WPTCR_DCYC_Pos
#define OCTOSPI_WPTCR_DCYC_Msk   XSPI_WPTCR_DCYC_Msk
#define OCTOSPI_WPTCR_DCYC   XSPI_WPTCR_DCYC
#define OCTOSPI_WPTCR_DHQC_Pos   XSPI_WPTCR_DHQC_Pos
#define OCTOSPI_WPTCR_DHQC_Msk   XSPI_WPTCR_DHQC_Msk
#define OCTOSPI_WPTCR_DHQC   XSPI_WPTCR_DHQC
#define OCTOSPI_WPTCR_SSHIFT_Pos   XSPI_WPTCR_SSHIFT_Pos
#define OCTOSPI_WPTCR_SSHIFT_Msk   XSPI_WPTCR_SSHIFT_Msk
#define OCTOSPI_WPTCR_SSHIFT   XSPI_WPTCR_SSHIFT
#define OCTOSPI_WPIR_INSTRUCTION_Pos   XSPI_WPIR_INSTRUCTION_Pos
#define OCTOSPI_WPIR_INSTRUCTION_Msk   XSPI_WPIR_INSTRUCTION_Msk
#define OCTOSPI_WPIR_INSTRUCTION   XSPI_WPIR_INSTRUCTION
#define OCTOSPI_WPABR_ALTERNATE_Pos   XSPI_WPABR_ALTERNATE_Pos
#define OCTOSPI_WPABR_ALTERNATE_Msk   XSPI_WPABR_ALTERNATE_Msk
#define OCTOSPI_WPABR_ALTERNATE   XSPI_WPABR_ALTERNATE
#define OCTOSPI_WCCR_IMODE_Pos   XSPI_WCCR_IMODE_Pos
#define OCTOSPI_WCCR_IMODE_Msk   XSPI_WCCR_IMODE_Msk
#define OCTOSPI_WCCR_IMODE   XSPI_WCCR_IMODE
#define OCTOSPI_WCCR_IMODE_0   XSPI_WCCR_IMODE_0
#define OCTOSPI_WCCR_IMODE_1   XSPI_WCCR_IMODE_1
#define OCTOSPI_WCCR_IMODE_2   XSPI_WCCR_IMODE_2
#define OCTOSPI_WCCR_IDTR_Pos   XSPI_WCCR_IDTR_Pos
#define OCTOSPI_WCCR_IDTR_Msk   XSPI_WCCR_IDTR_Msk
#define OCTOSPI_WCCR_IDTR   XSPI_WCCR_IDTR
#define OCTOSPI_WCCR_ISIZE_Pos   XSPI_WCCR_ISIZE_Pos
#define OCTOSPI_WCCR_ISIZE_Msk   XSPI_WCCR_ISIZE_Msk
#define OCTOSPI_WCCR_ISIZE   XSPI_WCCR_ISIZE
#define OCTOSPI_WCCR_ISIZE_0   XSPI_WCCR_ISIZE_0
#define OCTOSPI_WCCR_ISIZE_1   XSPI_WCCR_ISIZE_1
#define OCTOSPI_WCCR_ADMODE_Pos   XSPI_WCCR_ADMODE_Pos
#define OCTOSPI_WCCR_ADMODE_Msk   XSPI_WCCR_ADMODE_Msk
#define OCTOSPI_WCCR_ADMODE   XSPI_WCCR_ADMODE
#define OCTOSPI_WCCR_ADMODE_0   XSPI_WCCR_ADMODE_0
#define OCTOSPI_WCCR_ADMODE_1   XSPI_WCCR_ADMODE_1
#define OCTOSPI_WCCR_ADMODE_2   XSPI_WCCR_ADMODE_2
#define OCTOSPI_WCCR_ADDTR_Pos   XSPI_WCCR_ADDTR_Pos
#define OCTOSPI_WCCR_ADDTR_Msk   XSPI_WCCR_ADDTR_Msk
#define OCTOSPI_WCCR_ADDTR   XSPI_WCCR_ADDTR
#define OCTOSPI_WCCR_ADSIZE_Pos   XSPI_WCCR_ADSIZE_Pos
#define OCTOSPI_WCCR_ADSIZE_Msk   XSPI_WCCR_ADSIZE_Msk
#define OCTOSPI_WCCR_ADSIZE   XSPI_WCCR_ADSIZE
#define OCTOSPI_WCCR_ADSIZE_0   XSPI_WCCR_ADSIZE_0
#define OCTOSPI_WCCR_ADSIZE_1   XSPI_WCCR_ADSIZE_1
#define OCTOSPI_WCCR_ABMODE_Pos   XSPI_WCCR_ABMODE_Pos
#define OCTOSPI_WCCR_ABMODE_Msk   XSPI_WCCR_ABMODE_Msk
#define OCTOSPI_WCCR_ABMODE   XSPI_WCCR_ABMODE
#define OCTOSPI_WCCR_ABMODE_0   XSPI_WCCR_ABMODE_0
#define OCTOSPI_WCCR_ABMODE_1   XSPI_WCCR_ABMODE_1
#define OCTOSPI_WCCR_ABMODE_2   XSPI_WCCR_ABMODE_2
#define OCTOSPI_WCCR_ABDTR_Pos   XSPI_WCCR_ABDTR_Pos
#define OCTOSPI_WCCR_ABDTR_Msk   XSPI_WCCR_ABDTR_Msk
#define OCTOSPI_WCCR_ABDTR   XSPI_WCCR_ABDTR
#define OCTOSPI_WCCR_ABSIZE_Pos   XSPI_WCCR_ABSIZE_Pos
#define OCTOSPI_WCCR_ABSIZE_Msk   XSPI_WCCR_ABSIZE_Msk
#define OCTOSPI_WCCR_ABSIZE   XSPI_WCCR_ABSIZE
#define OCTOSPI_WCCR_ABSIZE_0   XSPI_WCCR_ABSIZE_0
#define OCTOSPI_WCCR_ABSIZE_1   XSPI_WCCR_ABSIZE_1
#define OCTOSPI_WCCR_DMODE_Pos   XSPI_WCCR_DMODE_Pos
#define OCTOSPI_WCCR_DMODE_Msk   XSPI_WCCR_DMODE_Msk
#define OCTOSPI_WCCR_DMODE   XSPI_WCCR_DMODE
#define OCTOSPI_WCCR_DMODE_0   XSPI_WCCR_DMODE_0
#define OCTOSPI_WCCR_DMODE_1   XSPI_WCCR_DMODE_1
#define OCTOSPI_WCCR_DMODE_2   XSPI_WCCR_DMODE_2
#define OCTOSPI_WCCR_DDTR_Pos   XSPI_WCCR_DDTR_Pos
#define OCTOSPI_WCCR_DDTR_Msk   XSPI_WCCR_DDTR_Msk
#define OCTOSPI_WCCR_DDTR   XSPI_WCCR_DDTR
#define OCTOSPI_WCCR_DQSE_Pos   XSPI_WCCR_DQSE_Pos
#define OCTOSPI_WCCR_DQSE_Msk   XSPI_WCCR_DQSE_Msk
#define OCTOSPI_WCCR_DQSE   XSPI_WCCR_DQSE
#define OCTOSPI_WTCR_DCYC_Pos   XSPI_WTCR_DCYC_Pos
#define OCTOSPI_WTCR_DCYC_Msk   XSPI_WTCR_DCYC_Msk
#define OCTOSPI_WTCR_DCYC   XSPI_WTCR_DCYC
#define OCTOSPI_WIR_INSTRUCTION_Pos   XSPI_WIR_INSTRUCTION_Pos
#define OCTOSPI_WIR_INSTRUCTION_Msk   XSPI_WIR_INSTRUCTION_Msk
#define OCTOSPI_WIR_INSTRUCTION   XSPI_WIR_INSTRUCTION
#define OCTOSPI_WABR_ALTERNATE_Pos   XSPI_WABR_ALTERNATE_Pos
#define OCTOSPI_WABR_ALTERNATE_Msk   XSPI_WABR_ALTERNATE_Msk
#define OCTOSPI_WABR_ALTERNATE   XSPI_WABR_ALTERNATE
#define OCTOSPI_HLCR_LM_Pos   XSPI_HLCR_LM_Pos
#define OCTOSPI_HLCR_LM_Msk   XSPI_HLCR_LM_Msk
#define OCTOSPI_HLCR_LM   XSPI_HLCR_LM
#define OCTOSPI_HLCR_WZL_Pos   XSPI_HLCR_WZL_Pos
#define OCTOSPI_HLCR_WZL_Msk   XSPI_HLCR_WZL_Msk
#define OCTOSPI_HLCR_WZL   XSPI_HLCR_WZL
#define OCTOSPI_HLCR_TACC_Pos   XSPI_HLCR_TACC_Pos
#define OCTOSPI_HLCR_TACC_Msk   XSPI_HLCR_TACC_Msk
#define OCTOSPI_HLCR_TACC   XSPI_HLCR_TACC
#define OCTOSPI_HLCR_TRWR_Pos   XSPI_HLCR_TRWR_Pos
#define OCTOSPI_HLCR_TRWR_Msk   XSPI_HLCR_TRWR_Msk
#define OCTOSPI_HLCR_TRWR   XSPI_HLCR_TRWR
#define HSPI_CR_EN_Pos   XSPI_CR_EN_Pos
#define HSPI_CR_EN_Msk   XSPI_CR_EN_Msk
#define HSPI_CR_EN   XSPI_CR_EN
#define HSPI_CR_ABORT_Pos   XSPI_CR_ABORT_Pos
#define HSPI_CR_ABORT_Msk   XSPI_CR_ABORT_Msk
#define HSPI_CR_ABORT   XSPI_CR_ABORT
#define HSPI_CR_DMAEN_Pos   XSPI_CR_DMAEN_Pos
#define HSPI_CR_DMAEN_Msk   XSPI_CR_DMAEN_Msk
#define HSPI_CR_DMAEN   XSPI_CR_DMAEN
#define HSPI_CR_TCEN_Pos   XSPI_CR_TCEN_Pos
#define HSPI_CR_TCEN_Msk   XSPI_CR_TCEN_Msk
#define HSPI_CR_TCEN   XSPI_CR_TCEN
#define HSPI_CR_DMM_Pos   XSPI_CR_DMM_Pos
#define HSPI_CR_DMM_Msk   XSPI_CR_DMM_Msk
#define HSPI_CR_DMM   XSPI_CR_DMM
#define HSPI_CR_FTHRES_Pos   XSPI_CR_FTHRES_Pos
#define HSPI_CR_FTHRES_Msk   XSPI_CR_FTHRES_Msk
#define HSPI_CR_FTHRES   XSPI_CR_FTHRES
#define HSPI_CR_TEIE_Pos   XSPI_CR_TEIE_Pos
#define HSPI_CR_TEIE_Msk   XSPI_CR_TEIE_Msk
#define HSPI_CR_TEIE   XSPI_CR_TEIE
#define HSPI_CR_TCIE_Pos   XSPI_CR_TCIE_Pos
#define HSPI_CR_TCIE_Msk   XSPI_CR_TCIE_Msk
#define HSPI_CR_TCIE   XSPI_CR_TCIE
#define HSPI_CR_FTIE_Pos   XSPI_CR_FTIE_Pos
#define HSPI_CR_FTIE_Msk   XSPI_CR_FTIE_Msk
#define HSPI_CR_FTIE   XSPI_CR_FTIE
#define HSPI_CR_SMIE_Pos   XSPI_CR_SMIE_Pos
#define HSPI_CR_SMIE_Msk   XSPI_CR_SMIE_Msk
#define HSPI_CR_SMIE   XSPI_CR_SMIE
#define HSPI_CR_TOIE_Pos   XSPI_CR_TOIE_Pos
#define HSPI_CR_TOIE_Msk   XSPI_CR_TOIE_Msk
#define HSPI_CR_TOIE   XSPI_CR_TOIE
#define HSPI_CR_APMS_Pos   XSPI_CR_APMS_Pos
#define HSPI_CR_APMS_Msk   XSPI_CR_APMS_Msk
#define HSPI_CR_APMS   XSPI_CR_APMS
#define HSPI_CR_PMM_Pos   XSPI_CR_PMM_Pos
#define HSPI_CR_PMM_Msk   XSPI_CR_PMM_Msk
#define HSPI_CR_PMM   XSPI_CR_PMM
#define HSPI_CR_FMODE_Pos   XSPI_CR_FMODE_Pos
#define HSPI_CR_FMODE_Msk   XSPI_CR_FMODE_Msk
#define HSPI_CR_FMODE   XSPI_CR_FMODE
#define HSPI_CR_FMODE_0   XSPI_CR_FMODE_0
#define HSPI_CR_FMODE_1   XSPI_CR_FMODE_1
#define HSPI_CR_MSEL_Pos   XSPI_HSPI_CR_MSEL_Pos
#define HSPI_CR_MSEL_Msk   XSPI_HSPI_CR_MSEL_Msk
#define HSPI_CR_MSEL   XSPI_HSPI_CR_MSEL
#define HSPI_CR_MSEL_0   XSPI_HSPI_CR_MSEL_0
#define HSPI_CR_MSEL_1   XSPI_HSPI_CR_MSEL_1
#define HSPI_DCR1_CKMODE_Pos   XSPI_DCR1_CKMODE_Pos
#define HSPI_DCR1_CKMODE_Msk   XSPI_DCR1_CKMODE_Msk
#define HSPI_DCR1_CKMODE   XSPI_DCR1_CKMODE
#define HSPI_DCR1_FRCK_Pos   XSPI_DCR1_FRCK_Pos
#define HSPI_DCR1_FRCK_Msk   XSPI_DCR1_FRCK_Msk
#define HSPI_DCR1_FRCK   XSPI_DCR1_FRCK
#define HSPI_DCR1_CSHT_Pos   XSPI_DCR1_CSHT_Pos
#define HSPI_DCR1_CSHT_Msk   XSPI_DCR1_CSHT_Msk
#define HSPI_DCR1_CSHT   XSPI_DCR1_CSHT
#define HSPI_DCR1_DEVSIZE_Pos   XSPI_DCR1_DEVSIZE_Pos
#define HSPI_DCR1_DEVSIZE_Msk   XSPI_DCR1_DEVSIZE_Msk
#define HSPI_DCR1_DEVSIZE   XSPI_DCR1_DEVSIZE
#define HSPI_DCR1_MTYP_Pos   XSPI_DCR1_MTYP_Pos
#define HSPI_DCR1_MTYP_Msk   XSPI_DCR1_MTYP_Msk
#define HSPI_DCR1_MTYP   XSPI_DCR1_MTYP
#define HSPI_DCR1_MTYP_0   XSPI_DCR1_MTYP_0
#define HSPI_DCR1_MTYP_1   XSPI_DCR1_MTYP_1
#define HSPI_DCR1_MTYP_2   XSPI_DCR1_MTYP_2
#define HSPI_DCR2_PRESCALER_Pos   XSPI_DCR2_PRESCALER_Pos
#define HSPI_DCR2_PRESCALER_Msk   XSPI_DCR2_PRESCALER_Msk
#define HSPI_DCR2_PRESCALER   XSPI_DCR2_PRESCALER
#define HSPI_DCR2_WRAPSIZE_Pos   XSPI_DCR2_WRAPSIZE_Pos
#define HSPI_DCR2_WRAPSIZE_Msk   XSPI_DCR2_WRAPSIZE_Msk
#define HSPI_DCR2_WRAPSIZE   XSPI_DCR2_WRAPSIZE
#define HSPI_DCR2_WRAPSIZE_0   XSPI_DCR2_WRAPSIZE_0
#define HSPI_DCR2_WRAPSIZE_1   XSPI_DCR2_WRAPSIZE_1
#define HSPI_DCR2_WRAPSIZE_2   XSPI_DCR2_WRAPSIZE_2
#define HSPI_DCR3_CSBOUND_Pos   XSPI_DCR3_CSBOUND_Pos
#define HSPI_DCR3_CSBOUND_Msk   XSPI_DCR3_CSBOUND_Msk
#define HSPI_DCR3_CSBOUND   XSPI_DCR3_CSBOUND
#define HSPI_DCR4_REFRESH_Pos   XSPI_DCR4_REFRESH_Pos
#define HSPI_DCR4_REFRESH_Msk   XSPI_DCR4_REFRESH_Msk
#define HSPI_DCR4_REFRESH   XSPI_DCR4_REFRESH
#define HSPI_SR_TEF_Pos   XSPI_SR_TEF_Pos
#define HSPI_SR_TEF_Msk   XSPI_SR_TEF_Msk
#define HSPI_SR_TEF   XSPI_SR_TEF
#define HSPI_SR_TCF_Pos   XSPI_SR_TCF_Pos
#define HSPI_SR_TCF_Msk   XSPI_SR_TCF_Msk
#define HSPI_SR_TCF   XSPI_SR_TCF
#define HSPI_SR_FTF_Pos   XSPI_SR_FTF_Pos
#define HSPI_SR_FTF_Msk   XSPI_SR_FTF_Msk
#define HSPI_SR_FTF   XSPI_SR_FTF
#define HSPI_SR_SMF_Pos   XSPI_SR_SMF_Pos
#define HSPI_SR_SMF_Msk   XSPI_SR_SMF_Msk
#define HSPI_SR_SMF   XSPI_SR_SMF
#define HSPI_SR_TOF_Pos   XSPI_SR_TOF_Pos
#define HSPI_SR_TOF_Msk   XSPI_SR_TOF_Msk
#define HSPI_SR_TOF   XSPI_SR_TOF
#define HSPI_SR_BUSY_Pos   XSPI_SR_BUSY_Pos
#define HSPI_SR_BUSY_Msk   XSPI_SR_BUSY_Msk
#define HSPI_SR_BUSY   XSPI_SR_BUSY
#define HSPI_SR_FLEVEL_Pos   XSPI_SR_FLEVEL_Pos
#define HSPI_SR_FLEVEL_Msk   XSPI_SR_FLEVEL_Msk
#define HSPI_SR_FLEVEL   XSPI_SR_FLEVEL
#define HSPI_FCR_CTEF_Pos   XSPI_FCR_CTEF_Pos
#define HSPI_FCR_CTEF_Msk   XSPI_FCR_CTEF_Msk
#define HSPI_FCR_CTEF   XSPI_FCR_CTEF
#define HSPI_FCR_CTCF_Pos   XSPI_FCR_CTCF_Pos
#define HSPI_FCR_CTCF_Msk   XSPI_FCR_CTCF_Msk
#define HSPI_FCR_CTCF   XSPI_FCR_CTCF
#define HSPI_FCR_CSMF_Pos   XSPI_FCR_CSMF_Pos
#define HSPI_FCR_CSMF_Msk   XSPI_FCR_CSMF_Msk
#define HSPI_FCR_CSMF   XSPI_FCR_CSMF
#define HSPI_FCR_CTOF_Pos   XSPI_FCR_CTOF_Pos
#define HSPI_FCR_CTOF_Msk   XSPI_FCR_CTOF_Msk
#define HSPI_FCR_CTOF   XSPI_FCR_CTOF
#define HSPI_DLR_DL_Pos   XSPI_DLR_DL_Pos
#define HSPI_DLR_DL_Msk   XSPI_DLR_DL_Msk
#define HSPI_DLR_DL   XSPI_DLR_DL
#define HSPI_AR_ADDRESS_Pos   XSPI_AR_ADDRESS_Pos
#define HSPI_AR_ADDRESS_Msk   XSPI_AR_ADDRESS_Msk
#define HSPI_AR_ADDRESS   XSPI_AR_ADDRESS
#define HSPI_DR_DATA_Pos   XSPI_DR_DATA_Pos
#define HSPI_DR_DATA_Msk   XSPI_DR_DATA_Msk
#define HSPI_DR_DATA   XSPI_DR_DATA
#define HSPI_PSMKR_MASK_Pos   XSPI_PSMKR_MASK_Pos
#define HSPI_PSMKR_MASK_Msk   XSPI_PSMKR_MASK_Msk
#define HSPI_PSMKR_MASK   XSPI_PSMKR_MASK
#define HSPI_PSMAR_MATCH_Pos   XSPI_PSMAR_MATCH_Pos
#define HSPI_PSMAR_MATCH_Msk   XSPI_PSMAR_MATCH_Msk
#define HSPI_PSMAR_MATCH   XSPI_PSMAR_MATCH
#define HSPI_PIR_INTERVAL_Pos   XSPI_PIR_INTERVAL_Pos
#define HSPI_PIR_INTERVAL_Msk   XSPI_PIR_INTERVAL_Msk
#define HSPI_PIR_INTERVAL   XSPI_PIR_INTERVAL
#define HSPI_CCR_IMODE_Pos   XSPI_CCR_IMODE_Pos
#define HSPI_CCR_IMODE_Msk   XSPI_CCR_IMODE_Msk
#define HSPI_CCR_IMODE   XSPI_CCR_IMODE
#define HSPI_CCR_IMODE_0   XSPI_CCR_IMODE_0
#define HSPI_CCR_IMODE_1   XSPI_CCR_IMODE_1
#define HSPI_CCR_IMODE_2   XSPI_CCR_IMODE_2
#define HSPI_CCR_IDTR_Pos   XSPI_CCR_IDTR_Pos
#define HSPI_CCR_IDTR_Msk   XSPI_CCR_IDTR_Msk
#define HSPI_CCR_IDTR   XSPI_CCR_IDTR
#define HSPI_CCR_ISIZE_Pos   XSPI_CCR_ISIZE_Pos
#define HSPI_CCR_ISIZE_Msk   XSPI_CCR_ISIZE_Msk
#define HSPI_CCR_ISIZE   XSPI_CCR_ISIZE
#define HSPI_CCR_ISIZE_0   XSPI_CCR_ISIZE_0
#define HSPI_CCR_ISIZE_1   XSPI_CCR_ISIZE_1
#define HSPI_CCR_ADMODE_Pos   XSPI_CCR_ADMODE_Pos
#define HSPI_CCR_ADMODE_Msk   XSPI_CCR_ADMODE_Msk
#define HSPI_CCR_ADMODE   XSPI_CCR_ADMODE
#define HSPI_CCR_ADMODE_0   XSPI_CCR_ADMODE_0
#define HSPI_CCR_ADMODE_1   XSPI_CCR_ADMODE_1
#define HSPI_CCR_ADMODE_2   XSPI_CCR_ADMODE_2
#define HSPI_CCR_ADDTR_Pos   XSPI_CCR_ADDTR_Pos
#define HSPI_CCR_ADDTR_Msk   XSPI_CCR_ADDTR_Msk
#define HSPI_CCR_ADDTR   XSPI_CCR_ADDTR
#define HSPI_CCR_ADSIZE_Pos   XSPI_CCR_ADSIZE_Pos
#define HSPI_CCR_ADSIZE_Msk   XSPI_CCR_ADSIZE_Msk
#define HSPI_CCR_ADSIZE   XSPI_CCR_ADSIZE
#define HSPI_CCR_ADSIZE_0   XSPI_CCR_ADSIZE_0
#define HSPI_CCR_ADSIZE_1   XSPI_CCR_ADSIZE_1
#define HSPI_CCR_ABMODE_Pos   XSPI_CCR_ABMODE_Pos
#define HSPI_CCR_ABMODE_Msk   XSPI_CCR_ABMODE_Msk
#define HSPI_CCR_ABMODE   XSPI_CCR_ABMODE
#define HSPI_CCR_ABMODE_0   XSPI_CCR_ABMODE_0
#define HSPI_CCR_ABMODE_1   XSPI_CCR_ABMODE_1
#define HSPI_CCR_ABMODE_2   XSPI_CCR_ABMODE_2
#define HSPI_CCR_ABDTR_Pos   XSPI_CCR_ABDTR_Pos
#define HSPI_CCR_ABDTR_Msk   XSPI_CCR_ABDTR_Msk
#define HSPI_CCR_ABDTR   XSPI_CCR_ABDTR
#define HSPI_CCR_ABSIZE_Pos   XSPI_CCR_ABSIZE_Pos
#define HSPI_CCR_ABSIZE_Msk   XSPI_CCR_ABSIZE_Msk
#define HSPI_CCR_ABSIZE   XSPI_CCR_ABSIZE
#define HSPI_CCR_ABSIZE_0   XSPI_CCR_ABSIZE_0
#define HSPI_CCR_ABSIZE_1   XSPI_CCR_ABSIZE_1
#define HSPI_CCR_DMODE_Pos   XSPI_CCR_DMODE_Pos
#define HSPI_CCR_DMODE_Msk   XSPI_CCR_DMODE_Msk
#define HSPI_CCR_DMODE   XSPI_CCR_DMODE
#define HSPI_CCR_DMODE_0   XSPI_CCR_DMODE_0
#define HSPI_CCR_DMODE_1   XSPI_CCR_DMODE_1
#define HSPI_CCR_DMODE_2   XSPI_CCR_DMODE_2
#define HSPI_CCR_DDTR_Pos   XSPI_CCR_DDTR_Pos
#define HSPI_CCR_DDTR_Msk   XSPI_CCR_DDTR_Msk
#define HSPI_CCR_DDTR   XSPI_CCR_DDTR
#define HSPI_CCR_DQSE_Pos   XSPI_CCR_DQSE_Pos
#define HSPI_CCR_DQSE_Msk   XSPI_CCR_DQSE_Msk
#define HSPI_CCR_DQSE   XSPI_CCR_DQSE
#define HSPI_CCR_SIOO_Pos   XSPI_CCR_SIOO_Pos
#define HSPI_CCR_SIOO_Msk   XSPI_CCR_SIOO_Msk
#define HSPI_CCR_SIOO   XSPI_CCR_SIOO
#define HSPI_TCR_DCYC_Pos   XSPI_TCR_DCYC_Pos
#define HSPI_TCR_DCYC_Msk   XSPI_TCR_DCYC_Msk
#define HSPI_TCR_DCYC   XSPI_TCR_DCYC
#define HSPI_TCR_DHQC_Pos   XSPI_TCR_DHQC_Pos
#define HSPI_TCR_DHQC_Msk   XSPI_TCR_DHQC_Msk
#define HSPI_TCR_DHQC   XSPI_TCR_DHQC
#define HSPI_TCR_SSHIFT_Pos   XSPI_TCR_SSHIFT_Pos
#define HSPI_TCR_SSHIFT_Msk   XSPI_TCR_SSHIFT_Msk
#define HSPI_TCR_SSHIFT   XSPI_TCR_SSHIFT
#define HSPI_IR_INSTRUCTION_Pos   XSPI_IR_INSTRUCTION_Pos
#define HSPI_IR_INSTRUCTION_Msk   XSPI_IR_INSTRUCTION_Msk
#define HSPI_IR_INSTRUCTION   XSPI_IR_INSTRUCTION
#define HSPI_ABR_ALTERNATE_Pos   XSPI_ABR_ALTERNATE_Pos
#define HSPI_ABR_ALTERNATE_Msk   XSPI_ABR_ALTERNATE_Msk
#define HSPI_ABR_ALTERNATE   XSPI_ABR_ALTERNATE
#define HSPI_LPTR_TIMEOUT_Pos   XSPI_LPTR_TIMEOUT_Pos
#define HSPI_LPTR_TIMEOUT_Msk   XSPI_LPTR_TIMEOUT_Msk
#define HSPI_LPTR_TIMEOUT   XSPI_LPTR_TIMEOUT
#define HSPI_WPCCR_IMODE_Pos   XSPI_WPCCR_IMODE_Pos
#define HSPI_WPCCR_IMODE_Msk   XSPI_WPCCR_IMODE_Msk
#define HSPI_WPCCR_IMODE   XSPI_WPCCR_IMODE
#define HSPI_WPCCR_IMODE_0   XSPI_WPCCR_IMODE_0
#define HSPI_WPCCR_IMODE_1   XSPI_WPCCR_IMODE_1
#define HSPI_WPCCR_IMODE_2   XSPI_WPCCR_IMODE_2
#define HSPI_WPCCR_IDTR_Pos   XSPI_WPCCR_IDTR_Pos
#define HSPI_WPCCR_IDTR_Msk   XSPI_WPCCR_IDTR_Msk
#define HSPI_WPCCR_IDTR   XSPI_WPCCR_IDTR
#define HSPI_WPCCR_ISIZE_Pos   XSPI_WPCCR_ISIZE_Pos
#define HSPI_WPCCR_ISIZE_Msk   XSPI_WPCCR_ISIZE_Msk
#define HSPI_WPCCR_ISIZE   XSPI_WPCCR_ISIZE
#define HSPI_WPCCR_ISIZE_0   XSPI_WPCCR_ISIZE_0
#define HSPI_WPCCR_ISIZE_1   XSPI_WPCCR_ISIZE_1
#define HSPI_WPCCR_ADMODE_Pos   XSPI_WPCCR_ADMODE_Pos
#define HSPI_WPCCR_ADMODE_Msk   XSPI_WPCCR_ADMODE_Msk
#define HSPI_WPCCR_ADMODE   XSPI_WPCCR_ADMODE
#define HSPI_WPCCR_ADMODE_0   XSPI_WPCCR_ADMODE_0
#define HSPI_WPCCR_ADMODE_1   XSPI_WPCCR_ADMODE_1
#define HSPI_WPCCR_ADMODE_2   XSPI_WPCCR_ADMODE_2
#define HSPI_WPCCR_ADDTR_Pos   XSPI_WPCCR_ADDTR_Pos
#define HSPI_WPCCR_ADDTR_Msk   XSPI_WPCCR_ADDTR_Msk
#define HSPI_WPCCR_ADDTR   XSPI_WPCCR_ADDTR
#define HSPI_WPCCR_ADSIZE_Pos   XSPI_WPCCR_ADSIZE_Pos
#define HSPI_WPCCR_ADSIZE_Msk   XSPI_WPCCR_ADSIZE_Msk
#define HSPI_WPCCR_ADSIZE   XSPI_WPCCR_ADSIZE
#define HSPI_WPCCR_ADSIZE_0   XSPI_WPCCR_ADSIZE_0
#define HSPI_WPCCR_ADSIZE_1   XSPI_WPCCR_ADSIZE_1
#define HSPI_WPCCR_ABMODE_Pos   XSPI_WPCCR_ABMODE_Pos
#define HSPI_WPCCR_ABMODE_Msk   XSPI_WPCCR_ABMODE_Msk
#define HSPI_WPCCR_ABMODE   XSPI_WPCCR_ABMODE
#define HSPI_WPCCR_ABMODE_0   XSPI_WPCCR_ABMODE_0
#define HSPI_WPCCR_ABMODE_1   XSPI_WPCCR_ABMODE_1
#define HSPI_WPCCR_ABMODE_2   XSPI_WPCCR_ABMODE_2
#define HSPI_WPCCR_ABDTR_Pos   XSPI_WPCCR_ABDTR_Pos
#define HSPI_WPCCR_ABDTR_Msk   XSPI_WPCCR_ABDTR_Msk
#define HSPI_WPCCR_ABDTR   XSPI_WPCCR_ABDTR
#define HSPI_WPCCR_ABSIZE_Pos   XSPI_WPCCR_ABSIZE_Pos
#define HSPI_WPCCR_ABSIZE_Msk   XSPI_WPCCR_ABSIZE_Msk
#define HSPI_WPCCR_ABSIZE   XSPI_WPCCR_ABSIZE
#define HSPI_WPCCR_ABSIZE_0   XSPI_WPCCR_ABSIZE_0
#define HSPI_WPCCR_ABSIZE_1   XSPI_WPCCR_ABSIZE_1
#define HSPI_WPCCR_DMODE_Pos   XSPI_WPCCR_DMODE_Pos
#define HSPI_WPCCR_DMODE_Msk   XSPI_WPCCR_DMODE_Msk
#define HSPI_WPCCR_DMODE   XSPI_WPCCR_DMODE
#define HSPI_WPCCR_DMODE_0   XSPI_WPCCR_DMODE_0
#define HSPI_WPCCR_DMODE_1   XSPI_WPCCR_DMODE_1
#define HSPI_WPCCR_DMODE_2   XSPI_WPCCR_DMODE_2
#define HSPI_WPCCR_DDTR_Pos   XSPI_WPCCR_DDTR_Pos
#define HSPI_WPCCR_DDTR_Msk   XSPI_WPCCR_DDTR_Msk
#define HSPI_WPCCR_DDTR   XSPI_WPCCR_DDTR
#define HSPI_WPCCR_DQSE_Pos   XSPI_WPCCR_DQSE_Pos
#define HSPI_WPCCR_DQSE_Msk   XSPI_WPCCR_DQSE_Msk
#define HSPI_WPCCR_DQSE   XSPI_WPCCR_DQSE
#define HSPI_WPTCR_DCYC_Pos   XSPI_WPTCR_DCYC_Pos
#define HSPI_WPTCR_DCYC_Msk   XSPI_WPTCR_DCYC_Msk
#define HSPI_WPTCR_DCYC   XSPI_WPTCR_DCYC
#define HSPI_WPTCR_DHQC_Pos   XSPI_WPTCR_DHQC_Pos
#define HSPI_WPTCR_DHQC_Msk   XSPI_WPTCR_DHQC_Msk
#define HSPI_WPTCR_DHQC   XSPI_WPTCR_DHQC
#define HSPI_WPTCR_SSHIFT_Pos   XSPI_WPTCR_SSHIFT_Pos
#define HSPI_WPTCR_SSHIFT_Msk   XSPI_WPTCR_SSHIFT_Msk
#define HSPI_WPTCR_SSHIFT   XSPI_WPTCR_SSHIFT
#define HSPI_WPIR_INSTRUCTION_Pos   XSPI_WPIR_INSTRUCTION_Pos
#define HSPI_WPIR_INSTRUCTION_Msk   XSPI_WPIR_INSTRUCTION_Msk
#define HSPI_WPIR_INSTRUCTION   XSPI_WPIR_INSTRUCTION
#define HSPI_WPABR_ALTERNATE_Pos   XSPI_WPABR_ALTERNATE_Pos
#define HSPI_WPABR_ALTERNATE_Msk   XSPI_WPABR_ALTERNATE_Msk
#define HSPI_WPABR_ALTERNATE   XSPI_WPABR_ALTERNATE
#define HSPI_WCCR_IMODE_Pos   XSPI_WCCR_IMODE_Pos
#define HSPI_WCCR_IMODE_Msk   XSPI_WCCR_IMODE_Msk
#define HSPI_WCCR_IMODE   XSPI_WCCR_IMODE
#define HSPI_WCCR_IMODE_0   XSPI_WCCR_IMODE_0
#define HSPI_WCCR_IMODE_1   XSPI_WCCR_IMODE_1
#define HSPI_WCCR_IMODE_2   XSPI_WCCR_IMODE_2
#define HSPI_WCCR_IDTR_Pos   XSPI_WCCR_IDTR_Pos
#define HSPI_WCCR_IDTR_Msk   XSPI_WCCR_IDTR_Msk
#define HSPI_WCCR_IDTR   XSPI_WCCR_IDTR
#define HSPI_WCCR_ISIZE_Pos   XSPI_WCCR_ISIZE_Pos
#define HSPI_WCCR_ISIZE_Msk   XSPI_WCCR_ISIZE_Msk
#define HSPI_WCCR_ISIZE   XSPI_WCCR_ISIZE
#define HSPI_WCCR_ISIZE_0   XSPI_WCCR_ISIZE_0
#define HSPI_WCCR_ISIZE_1   XSPI_WCCR_ISIZE_1
#define HSPI_WCCR_ADMODE_Pos   XSPI_WCCR_ADMODE_Pos
#define HSPI_WCCR_ADMODE_Msk   XSPI_WCCR_ADMODE_Msk
#define HSPI_WCCR_ADMODE   XSPI_WCCR_ADMODE
#define HSPI_WCCR_ADMODE_0   XSPI_WCCR_ADMODE_0
#define HSPI_WCCR_ADMODE_1   XSPI_WCCR_ADMODE_1
#define HSPI_WCCR_ADMODE_2   XSPI_WCCR_ADMODE_2
#define HSPI_WCCR_ADDTR_Pos   XSPI_WCCR_ADDTR_Pos
#define HSPI_WCCR_ADDTR_Msk   XSPI_WCCR_ADDTR_Msk
#define HSPI_WCCR_ADDTR   XSPI_WCCR_ADDTR
#define HSPI_WCCR_ADSIZE_Pos   XSPI_WCCR_ADSIZE_Pos
#define HSPI_WCCR_ADSIZE_Msk   XSPI_WCCR_ADSIZE_Msk
#define HSPI_WCCR_ADSIZE   XSPI_WCCR_ADSIZE
#define HSPI_WCCR_ADSIZE_0   XSPI_WCCR_ADSIZE_0
#define HSPI_WCCR_ADSIZE_1   XSPI_WCCR_ADSIZE_1
#define HSPI_WCCR_ABMODE_Pos   XSPI_WCCR_ABMODE_Pos
#define HSPI_WCCR_ABMODE_Msk   XSPI_WCCR_ABMODE_Msk
#define HSPI_WCCR_ABMODE   XSPI_WCCR_ABMODE
#define HSPI_WCCR_ABMODE_0   XSPI_WCCR_ABMODE_0
#define HSPI_WCCR_ABMODE_1   XSPI_WCCR_ABMODE_1
#define HSPI_WCCR_ABMODE_2   XSPI_WCCR_ABMODE_2
#define HSPI_WCCR_ABDTR_Pos   XSPI_WCCR_ABDTR_Pos
#define HSPI_WCCR_ABDTR_Msk   XSPI_WCCR_ABDTR_Msk
#define HSPI_WCCR_ABDTR   XSPI_WCCR_ABDTR
#define HSPI_WCCR_ABSIZE_Pos   XSPI_WCCR_ABSIZE_Pos
#define HSPI_WCCR_ABSIZE_Msk   XSPI_WCCR_ABSIZE_Msk
#define HSPI_WCCR_ABSIZE   XSPI_WCCR_ABSIZE
#define HSPI_WCCR_ABSIZE_0   XSPI_WCCR_ABSIZE_0
#define HSPI_WCCR_ABSIZE_1   XSPI_WCCR_ABSIZE_1
#define HSPI_WCCR_DMODE_Pos   XSPI_WCCR_DMODE_Pos
#define HSPI_WCCR_DMODE_Msk   XSPI_WCCR_DMODE_Msk
#define HSPI_WCCR_DMODE   XSPI_WCCR_DMODE
#define HSPI_WCCR_DMODE_0   XSPI_WCCR_DMODE_0
#define HSPI_WCCR_DMODE_1   XSPI_WCCR_DMODE_1
#define HSPI_WCCR_DMODE_2   XSPI_WCCR_DMODE_2
#define HSPI_WCCR_DDTR_Pos   XSPI_WCCR_DDTR_Pos
#define HSPI_WCCR_DDTR_Msk   XSPI_WCCR_DDTR_Msk
#define HSPI_WCCR_DDTR   XSPI_WCCR_DDTR
#define HSPI_WCCR_DQSE_Pos   XSPI_WCCR_DQSE_Pos
#define HSPI_WCCR_DQSE_Msk   XSPI_WCCR_DQSE_Msk
#define HSPI_WCCR_DQSE   XSPI_WCCR_DQSE
#define HSPI_WTCR_DCYC_Pos   XSPI_WTCR_DCYC_Pos
#define HSPI_WTCR_DCYC_Msk   XSPI_WTCR_DCYC_Msk
#define HSPI_WTCR_DCYC   XSPI_WTCR_DCYC
#define HSPI_WIR_INSTRUCTION_Pos   XSPI_WIR_INSTRUCTION_Pos
#define HSPI_WIR_INSTRUCTION_Msk   XSPI_WIR_INSTRUCTION_Msk
#define HSPI_WIR_INSTRUCTION   XSPI_WIR_INSTRUCTION
#define HSPI_WABR_ALTERNATE_Pos   XSPI_WABR_ALTERNATE_Pos
#define HSPI_WABR_ALTERNATE_Msk   XSPI_WABR_ALTERNATE_Msk
#define HSPI_WABR_ALTERNATE   XSPI_WABR_ALTERNATE
#define HSPI_HLCR_LM_Pos   XSPI_HLCR_LM_Pos
#define HSPI_HLCR_LM_Msk   XSPI_HLCR_LM_Msk
#define HSPI_HLCR_LM   XSPI_HLCR_LM
#define HSPI_HLCR_WZL_Pos   XSPI_HLCR_WZL_Pos
#define HSPI_HLCR_WZL_Msk   XSPI_HLCR_WZL_Msk
#define HSPI_HLCR_WZL   XSPI_HLCR_WZL
#define HSPI_HLCR_TACC_Pos   XSPI_HLCR_TACC_Pos
#define HSPI_HLCR_TACC_Msk   XSPI_HLCR_TACC_Msk
#define HSPI_HLCR_TACC   XSPI_HLCR_TACC
#define HSPI_HLCR_TRWR_Pos   XSPI_HLCR_TRWR_Pos
#define HSPI_HLCR_TRWR_Msk   XSPI_HLCR_TRWR_Msk
#define HSPI_HLCR_TRWR   XSPI_HLCR_TRWR
#define HSPI_CALFCR_FINE_Pos   XSPI_HSPI_CALFCR_FINE_Pos
#define HSPI_CALFCR_FINE_Msk   XSPI_HSPI_CALFCR_FINE_Msk
#define HSPI_CALFCR_FINE   XSPI_HSPI_CALFCR_FINE
#define HSPI_CALFCR_COARSE_Pos   XSPI_HSPI_CALFCR_COARSE_Pos
#define HSPI_CALFCR_COARSE_Msk   XSPI_HSPI_CALFCR_COARSE_Msk
#define HSPI_CALFCR_COARSE   XSPI_HSPI_CALFCR_COARSE
#define HSPI_CALFCR_CALMAX_Pos   XSPI_HSPI_CALFCR_CALMAX_Pos
#define HSPI_CALFCR_CALMAX_Msk   XSPI_HSPI_CALFCR_CALMAX_Msk
#define HSPI_CALFCR_CALMAX   XSPI_HSPI_CALFCR_CALMAX
#define HSPI_CALMR_FINE_Pos   XSPI_HSPI_CALMR_FINE_Pos
#define HSPI_CALMR_FINE_Msk   XSPI_HSPI_CALMR_FINE_Msk
#define HSPI_CALMR_FINE   XSPI_HSPI_CALMR_FINE
#define HSPI_CALMR_COARSE_Pos   XSPI_HSPI_CALMR_COARSE_Pos
#define HSPI_CALMR_COARSE_Msk   XSPI_HSPI_CALMR_COARSE_Msk
#define HSPI_CALMR_COARSE   XSPI_HSPI_CALMR_COARSE
#define HSPI_CALSOR_FINE_Pos   XSPI_HSPI_CALSOR_FINE_Pos
#define HSPI_CALSOR_FINE_Msk   XSPI_HSPI_CALSOR_FINE_Msk
#define HSPI_CALSOR_FINE   XSPI_HSPI_CALSOR_FINE
#define HSPI_CALSOR_COARSE_Pos   XSPI_HSPI_CALSOR_COARSE_Pos
#define HSPI_CALSOR_COARSE_Msk   XSPI_HSPI_CALSOR_COARSE_Msk
#define HSPI_CALSOR_COARSE   XSPI_HSPI_CALSOR_COARSE
#define HSPI_CALSIR_FINE_Pos   XSPI_HSPI_CALSIR_FINE_Pos
#define HSPI_CALSIR_FINE_Msk   XSPI_HSPI_CALSIR_FINE_Msk
#define HSPI_CALSIR_FINE   XSPI_HSPI_CALSIR_FINE
#define HSPI_CALSIR_COARSE_Pos   XSPI_HSPI_CALSIR_COARSE_Pos
#define HSPI_CALSIR_COARSE_Msk   XSPI_HSPI_CALSIR_COARSE_Msk
#define HSPI_CALSIR_COARSE   XSPI_HSPI_CALSIR_COARSE
#define XSPIM_CR_MUXEN_Pos   (0U)
#define XSPIM_CR_MUXEN_Msk   (0x1UL << XSPIM_CR_MUXEN_Pos)
#define XSPIM_CR_MUXEN   XSPIM_CR_MUXEN_Msk
#define XSPIM_CR_REQ2ACK_TIME_Pos   (16U)
#define XSPIM_CR_REQ2ACK_TIME_Msk   (0xFFUL << XSPIM_CR_REQ2ACK_TIME_Pos)
#define XSPIM_CR_REQ2ACK_TIME   XSPIM_CR_REQ2ACK_TIME_Msk
#define XSPIM_PCR_CLKEN_Pos   (0U)
#define XSPIM_PCR_CLKEN_Msk   (0x1UL << XSPIM_PCR_CLKEN_Pos)
#define XSPIM_PCR_CLKEN   XSPIM_PCR_CLKEN_Msk
#define XSPIM_PCR_CLKSRC_Pos   (1U)
#define XSPIM_PCR_CLKSRC_Msk   (0x1UL << XSPIM_PCR_CLKSRC_Pos)
#define XSPIM_PCR_CLKSRC   XSPIM_PCR_CLKSRC_Msk
#define XSPIM_PCR_DQSEN_Pos   (4U)
#define XSPIM_PCR_DQSEN_Msk   (0x1UL << XSPIM_PCR_DQSEN_Pos)
#define XSPIM_PCR_DQSEN   XSPIM_PCR_DQSEN_Msk
#define XSPIM_PCR_DQSSRC_Pos   (5U)
#define XSPIM_PCR_DQSSRC_Msk   (0x1UL << XSPIM_PCR_DQSSRC_Pos)
#define XSPIM_PCR_DQSSRC   XSPIM_PCR_DQSSRC_Msk
#define XSPIM_PCR_NCSEN_Pos   (8U)
#define XSPIM_PCR_NCSEN_Msk   (0x1UL << XSPIM_PCR_NCSEN_Pos)
#define XSPIM_PCR_NCSEN   XSPIM_PCR_NCSEN_Msk
#define XSPIM_PCR_NCSSRC_Pos   (9U)
#define XSPIM_PCR_NCSSRC_Msk   (0x1UL << XSPIM_PCR_NCSSRC_Pos)
#define XSPIM_PCR_NCSSRC   XSPIM_PCR_NCSSRC_Msk
#define XSPIM_PCR_IOLEN_Pos   (16U)
#define XSPIM_PCR_IOLEN_Msk   (0x1UL << XSPIM_PCR_IOLEN_Pos)
#define XSPIM_PCR_IOLEN   XSPIM_PCR_IOLEN_Msk
#define XSPIM_PCR_IOLSRC_Pos   (17U)
#define XSPIM_PCR_IOLSRC_Msk   (0x3UL << XSPIM_PCR_IOLSRC_Pos)
#define XSPIM_PCR_IOLSRC   XSPIM_PCR_IOLSRC_Msk
#define XSPIM_PCR_IOLSRC_0   (0x1UL << XSPIM_PCR_IOLSRC_Pos)
#define XSPIM_PCR_IOLSRC_1   (0x2UL << XSPIM_PCR_IOLSRC_Pos)
#define XSPIM_PCR_IOHEN_Pos   (24U)
#define XSPIM_PCR_IOHEN_Msk   (0x1UL << XSPIM_PCR_IOHEN_Pos)
#define XSPIM_PCR_IOHEN   XSPIM_PCR_IOHEN_Msk
#define XSPIM_PCR_IOHSRC_Pos   (25U)
#define XSPIM_PCR_IOHSRC_Msk   (0x3UL << XSPIM_PCR_IOHSRC_Pos)
#define XSPIM_PCR_IOHSRC   XSPIM_PCR_IOHSRC_Msk
#define XSPIM_PCR_IOHSRC_0   (0x1UL << XSPIM_PCR_IOHSRC_Pos)
#define XSPIM_PCR_IOHSRC_1   (0x2UL << XSPIM_PCR_IOHSRC_Pos)
#define OCTOSPIM_CR_MUXEN_Pos   XSPIM_CR_MUXEN_Pos
#define OCTOSPIM_CR_MUXEN_Msk   XSPIM_CR_MUXEN_Msk
#define OCTOSPIM_CR_MUXEN   XSPIM_CR_MUXEN
#define OCTOSPIM_CR_REQ2ACK_TIME_Pos   XSPIM_CR_REQ2ACK_TIME_Pos
#define OCTOSPIM_CR_REQ2ACK_TIME_Msk   XSPIM_CR_REQ2ACK_TIME_Msk
#define OCTOSPIM_CR_REQ2ACK_TIME   XSPIM_CR_REQ2ACK_TIME
#define OCTOSPIM_PCR_CLKEN_Pos   XSPIM_PCR_CLKEN_Pos
#define OCTOSPIM_PCR_CLKEN_Msk   XSPIM_PCR_CLKEN_Msk
#define OCTOSPIM_PCR_CLKEN   XSPIM_PCR_CLKEN
#define OCTOSPIM_PCR_CLKSRC_Pos   XSPIM_PCR_CLKSRC_Pos
#define OCTOSPIM_PCR_CLKSRC_Msk   XSPIM_PCR_CLKSRC_Msk
#define OCTOSPIM_PCR_CLKSRC   XSPIM_PCR_CLKSRC
#define OCTOSPIM_PCR_DQSEN_Pos   XSPIM_PCR_DQSEN_Pos
#define OCTOSPIM_PCR_DQSEN_Msk   XSPIM_PCR_DQSEN_Msk
#define OCTOSPIM_PCR_DQSEN   XSPIM_PCR_DQSEN
#define OCTOSPIM_PCR_DQSSRC_Pos   XSPIM_PCR_DQSSRC_Pos
#define OCTOSPIM_PCR_DQSSRC_Msk   XSPIM_PCR_DQSSRC_Msk
#define OCTOSPIM_PCR_DQSSRC   XSPIM_PCR_DQSSRC
#define OCTOSPIM_PCR_NCSEN_Pos   XSPIM_PCR_NCSEN_Pos
#define OCTOSPIM_PCR_NCSEN_Msk   XSPIM_PCR_NCSEN_Msk
#define OCTOSPIM_PCR_NCSEN   XSPIM_PCR_NCSEN
#define OCTOSPIM_PCR_NCSSRC_Pos   XSPIM_PCR_NCSSRC_Pos
#define OCTOSPIM_PCR_NCSSRC_Msk   XSPIM_PCR_NCSSRC_Msk
#define OCTOSPIM_PCR_NCSSRC   XSPIM_PCR_NCSSRC
#define OCTOSPIM_PCR_IOLEN_Pos   XSPIM_PCR_IOLEN_Pos
#define OCTOSPIM_PCR_IOLEN_Msk   XSPIM_PCR_IOLEN_Msk
#define OCTOSPIM_PCR_IOLEN   XSPIM_PCR_IOLEN
#define OCTOSPIM_PCR_IOLSRC_Pos   XSPIM_PCR_IOLSRC_Pos
#define OCTOSPIM_PCR_IOLSRC_Msk   XSPIM_PCR_IOLSRC_Msk
#define OCTOSPIM_PCR_IOLSRC   XSPIM_PCR_IOLSRC
#define OCTOSPIM_PCR_IOLSRC_0   XSPIM_PCR_IOLSRC_0
#define OCTOSPIM_PCR_IOLSRC_1   XSPIM_PCR_IOLSRC_1
#define OCTOSPIM_PCR_IOHEN_Pos   XSPIM_PCR_IOHEN_Pos
#define OCTOSPIM_PCR_IOHEN_Msk   XSPIM_PCR_IOHEN_Msk
#define OCTOSPIM_PCR_IOHEN   XSPIM_PCR_IOHEN
#define OCTOSPIM_PCR_IOHSRC_Pos   XSPIM_PCR_IOHSRC_Pos
#define OCTOSPIM_PCR_IOHSRC_Msk   XSPIM_PCR_IOHSRC_Msk
#define OCTOSPIM_PCR_IOHSRC   XSPIM_PCR_IOHSRC
#define OCTOSPIM_PCR_IOHSRC_0   XSPIM_PCR_IOHSRC_0
#define OCTOSPIM_PCR_IOHSRC_1   XSPIM_PCR_IOHSRC_1
#define DLYB_CR_DEN_Pos   (0U)
#define DLYB_CR_DEN_Msk   (0x1UL << DLYB_CR_DEN_Pos)
#define DLYB_CR_DEN   DLYB_CR_DEN_Msk
#define DLYB_CR_SEN_Pos   (1U)
#define DLYB_CR_SEN_Msk   (0x1UL << DLYB_CR_SEN_Pos)
#define DLYB_CR_SEN   DLYB_CR_SEN_Msk
#define DLYB_CFGR_SEL_Pos   (0U)
#define DLYB_CFGR_SEL_Msk   (0xFUL << DLYB_CFGR_SEL_Pos)
#define DLYB_CFGR_SEL   DLYB_CFGR_SEL_Msk
#define DLYB_CFGR_SEL_0   (0x1UL << DLYB_CFGR_SEL_Pos)
#define DLYB_CFGR_SEL_1   (0x2UL << DLYB_CFGR_SEL_Pos)
#define DLYB_CFGR_SEL_2   (0x3UL << DLYB_CFGR_SEL_Pos)
#define DLYB_CFGR_SEL_3   (0x8UL << DLYB_CFGR_SEL_Pos)
#define DLYB_CFGR_UNIT_Pos   (8U)
#define DLYB_CFGR_UNIT_Msk   (0x7FUL << DLYB_CFGR_UNIT_Pos)
#define DLYB_CFGR_UNIT   DLYB_CFGR_UNIT_Msk
#define DLYB_CFGR_UNIT_0   (0x01UL << DLYB_CFGR_UNIT_Pos)
#define DLYB_CFGR_UNIT_1   (0x02UL << DLYB_CFGR_UNIT_Pos)
#define DLYB_CFGR_UNIT_2   (0x04UL << DLYB_CFGR_UNIT_Pos)
#define DLYB_CFGR_UNIT_3   (0x08UL << DLYB_CFGR_UNIT_Pos)
#define DLYB_CFGR_UNIT_4   (0x10UL << DLYB_CFGR_UNIT_Pos)
#define DLYB_CFGR_UNIT_5   (0x20UL << DLYB_CFGR_UNIT_Pos)
#define DLYB_CFGR_UNIT_6   (0x40UL << DLYB_CFGR_UNIT_Pos)
#define DLYB_CFGR_LNG_Pos   (16U)
#define DLYB_CFGR_LNG_Msk   (0xFFFUL << DLYB_CFGR_LNG_Pos)
#define DLYB_CFGR_LNG   DLYB_CFGR_LNG_Msk
#define DLYB_CFGR_LNG_0   (0x001UL << DLYB_CFGR_LNG_Pos)
#define DLYB_CFGR_LNG_1   (0x002UL << DLYB_CFGR_LNG_Pos)
#define DLYB_CFGR_LNG_2   (0x004UL << DLYB_CFGR_LNG_Pos)
#define DLYB_CFGR_LNG_3   (0x008UL << DLYB_CFGR_LNG_Pos)
#define DLYB_CFGR_LNG_4   (0x010UL << DLYB_CFGR_LNG_Pos)
#define DLYB_CFGR_LNG_5   (0x020UL << DLYB_CFGR_LNG_Pos)
#define DLYB_CFGR_LNG_6   (0x040UL << DLYB_CFGR_LNG_Pos)
#define DLYB_CFGR_LNG_7   (0x080UL << DLYB_CFGR_LNG_Pos)
#define DLYB_CFGR_LNG_8   (0x100UL << DLYB_CFGR_LNG_Pos)
#define DLYB_CFGR_LNG_9   (0x200UL << DLYB_CFGR_LNG_Pos)
#define DLYB_CFGR_LNG_10   (0x400UL << DLYB_CFGR_LNG_Pos)
#define DLYB_CFGR_LNG_11   (0x800UL << DLYB_CFGR_LNG_Pos)
#define DLYB_CFGR_LNGF_Pos   (31U)
#define DLYB_CFGR_LNGF_Msk   (0x1UL << DLYB_CFGR_LNGF_Pos)
#define DLYB_CFGR_LNGF   DLYB_CFGR_LNGF_Msk
#define OTFDEC_CR_ENC_Pos   (0U)
#define OTFDEC_CR_ENC_Msk   (0x1UL << OTFDEC_CR_ENC_Pos)
#define OTFDEC_CR_ENC   OTFDEC_CR_ENC_Msk
#define OTFDEC_PRIVCFGR_PRIV_Pos   (0U)
#define OTFDEC_PRIVCFGR_PRIV_Msk   (0x1UL << OTFDEC_PRIVCFGR_PRIV_Pos)
#define OTFDEC_PRIVCFGR_PRIV   OTFDEC_PRIVCFGR_PRIV_Msk
#define OTFDEC_REG_CONFIGR_REG_EN_Pos   (0U)
#define OTFDEC_REG_CONFIGR_REG_EN_Msk   (0x1UL << OTFDEC_REG_CONFIGR_REG_EN_Pos)
#define OTFDEC_REG_CONFIGR_REG_EN   OTFDEC_REG_CONFIGR_REG_EN_Msk
#define OTFDEC_REG_CONFIGR_CONFIGLOCK_Pos   (1U)
#define OTFDEC_REG_CONFIGR_CONFIGLOCK_Msk   (0x1UL << OTFDEC_REG_CONFIGR_CONFIGLOCK_Pos)
#define OTFDEC_REG_CONFIGR_CONFIGLOCK   OTFDEC_REG_CONFIGR_CONFIGLOCK_Msk
#define OTFDEC_REG_CONFIGR_KEYLOCK_Pos   (2U)
#define OTFDEC_REG_CONFIGR_KEYLOCK_Msk   (0x1UL << OTFDEC_REG_CONFIGR_KEYLOCK_Pos)
#define OTFDEC_REG_CONFIGR_KEYLOCK   OTFDEC_REG_CONFIGR_KEYLOCK_Msk
#define OTFDEC_REG_CONFIGR_MODE_Pos   (4U)
#define OTFDEC_REG_CONFIGR_MODE_Msk   (0x3UL << OTFDEC_REG_CONFIGR_MODE_Pos)
#define OTFDEC_REG_CONFIGR_MODE   OTFDEC_REG_CONFIGR_MODE_Msk
#define OTFDEC_REG_CONFIGR_MODE_0   (0x1UL << OTFDEC_REG_CONFIGR_MODE_Pos)
#define OTFDEC_REG_CONFIGR_MODE_1   (0x2UL << OTFDEC_REG_CONFIGR_MODE_Pos)
#define OTFDEC_REG_CONFIGR_KEYCRC_Pos   (8U)
#define OTFDEC_REG_CONFIGR_KEYCRC_Msk   (0xFFUL << OTFDEC_REG_CONFIGR_KEYCRC_Pos)
#define OTFDEC_REG_CONFIGR_KEYCRC   OTFDEC_REG_CONFIGR_KEYCRC_Msk
#define OTFDEC_REG_CONFIGR_VERSION_Pos   (16U)
#define OTFDEC_REG_CONFIGR_VERSION_Msk   (0xFFFFUL << OTFDEC_REG_CONFIGR_VERSION_Pos)
#define OTFDEC_REG_CONFIGR_VERSION   OTFDEC_REG_CONFIGR_VERSION_Msk
#define OTFDEC_REG_START_ADDR_Pos   (0U)
#define OTFDEC_REG_START_ADDR_Msk   (0xFFFFFFFFUL << OTFDEC_REG_START_ADDR_Pos)
#define OTFDEC_REG_START_ADDR   OTFDEC_REG_START_ADDR_Msk
#define OTFDEC_REG_END_ADDR_Pos   (0U)
#define OTFDEC_REG_END_ADDR_Msk   (0xFFFFFFFFUL << OTFDEC_REG_END_ADDR_Pos)
#define OTFDEC_REG_END_ADDR   OTFDEC_REG_END_ADDR_Msk
#define OTFDEC_REG_NONCER0_Pos   (0U)
#define OTFDEC_REG_NONCER0_Msk   (0xFFFFFFFFUL << OTFDEC_REG_NONCER0_Pos)
#define OTFDEC_REG_NONCER0   OTFDEC_REG_NONCER0_Msk
#define OTFDEC_REG_NONCER1_Pos   (0U)
#define OTFDEC_REG_NONCER1_Msk   (0xFFFFFFFFUL << OTFDEC_REG_NONCER1_Pos)
#define OTFDEC_REG_NONCER1   OTFDEC_REG_NONCER1_Msk
#define OTFDEC_REG_KEYR0_Pos   (0U)
#define OTFDEC_REG_KEYR0_Msk   (0xFFFFFFFFUL << OTFDEC_REG_KEYR0_Pos)
#define OTFDEC_REG_KEYR0   OTFDEC_REG_KEYR0_Msk
#define OTFDEC_REG_KEYR1_Pos   (0U)
#define OTFDEC_REG_KEYR1_Msk   (0xFFFFFFFFUL << OTFDEC_REG_KEYR1_Pos)
#define OTFDEC_REG_KEYR1   OTFDEC_REG_KEYR1_Msk
#define OTFDEC_REG_KEYR2_Pos   (0U)
#define OTFDEC_REG_KEYR2_Msk   (0xFFFFFFFFUL << OTFDEC_REG_KEYR2_Pos)
#define OTFDEC_REG_KEYR2   OTFDEC_REG_KEYR2_Msk
#define OTFDEC_REG_KEYR3_Pos   (0U)
#define OTFDEC_REG_KEYR3_Msk   (0xFFFFFFFFUL << OTFDEC_REG_KEYR3_Pos)
#define OTFDEC_REG_KEYR3   OTFDEC_REG_KEYR3_Msk
#define OTFDEC_ISR_SEIF_Pos   (0U)
#define OTFDEC_ISR_SEIF_Msk   (0x1UL << OTFDEC_ISR_SEIF_Pos)
#define OTFDEC_ISR_SEIF   OTFDEC_ISR_SEIF_Msk
#define OTFDEC_ISR_XONEIF_Pos   (1U)
#define OTFDEC_ISR_XONEIF_Msk   (0x1UL << OTFDEC_ISR_XONEIF_Pos)
#define OTFDEC_ISR_XONEIF   OTFDEC_ISR_XONEIF_Msk
#define OTFDEC_ISR_KEIF_Pos   (2U)
#define OTFDEC_ISR_KEIF_Msk   (0x1UL << OTFDEC_ISR_KEIF_Pos)
#define OTFDEC_ISR_KEIF   OTFDEC_ISR_KEIF_Msk
#define OTFDEC_ICR_SEIF_Pos   (0U)
#define OTFDEC_ICR_SEIF_Msk   (0x1UL << OTFDEC_ICR_SEIF_Pos)
#define OTFDEC_ICR_SEIF   OTFDEC_ICR_SEIF_Msk
#define OTFDEC_ICR_XONEIF_Pos   (1U)
#define OTFDEC_ICR_XONEIF_Msk   (0x1UL << OTFDEC_ICR_XONEIF_Pos)
#define OTFDEC_ICR_XONEIF   OTFDEC_ICR_XONEIF_Msk
#define OTFDEC_ICR_KEIF_Pos   (2U)
#define OTFDEC_ICR_KEIF_Msk   (0x1UL << OTFDEC_ICR_KEIF_Pos)
#define OTFDEC_ICR_KEIF   OTFDEC_ICR_KEIF_Msk
#define OTFDEC_IER_SEIE_Pos   (0U)
#define OTFDEC_IER_SEIE_Msk   (0x1UL << OTFDEC_IER_SEIE_Pos)
#define OTFDEC_IER_SEIE   OTFDEC_IER_SEIE_Msk
#define OTFDEC_IER_XONEIE_Pos   (1U)
#define OTFDEC_IER_XONEIE_Msk   (0x1UL << OTFDEC_IER_XONEIE_Pos)
#define OTFDEC_IER_XONEIE   OTFDEC_IER_XONEIE_Msk
#define OTFDEC_IER_KEIE_Pos   (2U)
#define OTFDEC_IER_KEIE_Msk   (0x1UL << OTFDEC_IER_KEIE_Pos)
#define OTFDEC_IER_KEIE   OTFDEC_IER_KEIE_Msk
#define PWR_CR1_LPMS_Pos   (0U)
#define PWR_CR1_LPMS_Msk   (0x7UL << PWR_CR1_LPMS_Pos)
#define PWR_CR1_LPMS   PWR_CR1_LPMS_Msk
#define PWR_CR1_LPMS_0   (0x1UL << PWR_CR1_LPMS_Pos)
#define PWR_CR1_LPMS_1   (0x2UL << PWR_CR1_LPMS_Pos)
#define PWR_CR1_LPMS_2   (0x4UL << PWR_CR1_LPMS_Pos)
#define PWR_CR1_RRSB1_Pos   (5U)
#define PWR_CR1_RRSB1_Msk   (0x1UL << PWR_CR1_RRSB1_Pos)
#define PWR_CR1_RRSB1   PWR_CR1_RRSB1_Msk
#define PWR_CR1_RRSB2_Pos   (6U)
#define PWR_CR1_RRSB2_Msk   (0x1UL << PWR_CR1_RRSB2_Pos)
#define PWR_CR1_RRSB2   PWR_CR1_RRSB2_Msk
#define PWR_CR1_ULPMEN_Pos   (7U)
#define PWR_CR1_ULPMEN_Msk   (0x1UL << PWR_CR1_ULPMEN_Pos)
#define PWR_CR1_ULPMEN   PWR_CR1_ULPMEN_Msk
#define PWR_CR1_SRAM1PD_Pos   (8U)
#define PWR_CR1_SRAM1PD_Msk   (0x1UL << PWR_CR1_SRAM1PD_Pos)
#define PWR_CR1_SRAM1PD   PWR_CR1_SRAM1PD_Msk
#define PWR_CR1_SRAM2PD_Pos   (9U)
#define PWR_CR1_SRAM2PD_Msk   (0x1UL << PWR_CR1_SRAM2PD_Pos)
#define PWR_CR1_SRAM2PD   PWR_CR1_SRAM2PD_Msk
#define PWR_CR1_SRAM3PD_Pos   (10U)
#define PWR_CR1_SRAM3PD_Msk   (0x1UL << PWR_CR1_SRAM3PD_Pos)
#define PWR_CR1_SRAM3PD   PWR_CR1_SRAM3PD_Msk
#define PWR_CR1_SRAM4PD_Pos   (11U)
#define PWR_CR1_SRAM4PD_Msk   (0x1UL << PWR_CR1_SRAM4PD_Pos)
#define PWR_CR1_SRAM4PD   PWR_CR1_SRAM4PD_Msk
#define PWR_CR1_SRAM5PD_Pos   (12U)
#define PWR_CR1_SRAM5PD_Msk   (0x1UL << PWR_CR1_SRAM5PD_Pos)
#define PWR_CR1_SRAM5PD   PWR_CR1_SRAM5PD_Msk
#define PWR_CR1_SRAM6PD_Pos   (13U)
#define PWR_CR1_SRAM6PD_Msk   (0x1UL << PWR_CR1_SRAM6PD_Pos)
#define PWR_CR1_SRAM6PD   PWR_CR1_SRAM6PD_Msk
#define PWR_CR1_FORCE_USBPWR_Pos   (15U)
#define PWR_CR1_FORCE_USBPWR_Msk   (0x1UL << PWR_CR1_FORCE_USBPWR_Pos)
#define PWR_CR1_FORCE_USBPWR   PWR_CR1_FORCE_USBPWR_Msk
#define PWR_CR2_SRAM1PDS1_Pos   (0U)
#define PWR_CR2_SRAM1PDS1_Msk   (0x1UL << PWR_CR2_SRAM1PDS1_Pos)
#define PWR_CR2_SRAM1PDS1   PWR_CR2_SRAM1PDS1_Msk
#define PWR_CR2_SRAM1PDS2_Pos   (1U)
#define PWR_CR2_SRAM1PDS2_Msk   (0x1UL << PWR_CR2_SRAM1PDS2_Pos)
#define PWR_CR2_SRAM1PDS2   PWR_CR2_SRAM1PDS2_Msk
#define PWR_CR2_SRAM1PDS3_Pos   (2U)
#define PWR_CR2_SRAM1PDS3_Msk   (0x1UL << PWR_CR2_SRAM1PDS3_Pos)
#define PWR_CR2_SRAM1PDS3   PWR_CR2_SRAM1PDS3_Msk
#define PWR_CR2_SRAM2PDS1_Pos   (4U)
#define PWR_CR2_SRAM2PDS1_Msk   (0x1UL << PWR_CR2_SRAM2PDS1_Pos)
#define PWR_CR2_SRAM2PDS1   PWR_CR2_SRAM2PDS1_Msk
#define PWR_CR2_SRAM2PDS2_Pos   (5U)
#define PWR_CR2_SRAM2PDS2_Msk   (0x1UL << PWR_CR2_SRAM2PDS2_Pos)
#define PWR_CR2_SRAM2PDS2   PWR_CR2_SRAM2PDS2_Msk
#define PWR_CR2_SRAM4PDS_Pos   (6U)
#define PWR_CR2_SRAM4PDS_Msk   (0x1UL << PWR_CR2_SRAM4PDS_Pos)
#define PWR_CR2_SRAM4PDS   PWR_CR2_SRAM4PDS_Msk
#define PWR_CR2_DC2RAMPDS_Pos   (7U)
#define PWR_CR2_DC2RAMPDS_Msk   (0x1UL << PWR_CR2_DC2RAMPDS_Pos)
#define PWR_CR2_DC2RAMPDS   PWR_CR2_DC2RAMPDS_Msk
#define PWR_CR2_ICRAMPDS_Pos   (8U)
#define PWR_CR2_ICRAMPDS_Msk   (0x1UL << PWR_CR2_ICRAMPDS_Pos)
#define PWR_CR2_ICRAMPDS   PWR_CR2_ICRAMPDS_Msk
#define PWR_CR2_DC1RAMPDS_Pos   (9U)
#define PWR_CR2_DC1RAMPDS_Msk   (0x1UL << PWR_CR2_DC1RAMPDS_Pos)
#define PWR_CR2_DC1RAMPDS   PWR_CR2_DC1RAMPDS_Msk
#define PWR_CR2_DMA2DRAMPDS_Pos   (10U)
#define PWR_CR2_DMA2DRAMPDS_Msk   (0x1UL << PWR_CR2_DMA2DRAMPDS_Pos)
#define PWR_CR2_DMA2DRAMPDS   PWR_CR2_DMA2DRAMPDS_Msk
#define PWR_CR2_PRAMPDS_Pos   (11U)
#define PWR_CR2_PRAMPDS_Msk   (0x1UL << PWR_CR2_PRAMPDS_Pos)
#define PWR_CR2_PRAMPDS   PWR_CR2_PRAMPDS_Msk
#define PWR_CR2_PKARAMPDS_Pos   (12U)
#define PWR_CR2_PKARAMPDS_Msk   (0x1UL << PWR_CR2_PKARAMPDS_Pos)
#define PWR_CR2_PKARAMPDS   PWR_CR2_PKARAMPDS_Msk
#define PWR_CR2_SRAM4FWU_Pos   (13U)
#define PWR_CR2_SRAM4FWU_Msk   (0x1UL << PWR_CR2_SRAM4FWU_Pos)
#define PWR_CR2_SRAM4FWU   PWR_CR2_SRAM4FWU_Msk
#define PWR_CR2_FLASHFWU_Pos   (14U)
#define PWR_CR2_FLASHFWU_Msk   (0x1UL << PWR_CR2_FLASHFWU_Pos)
#define PWR_CR2_FLASHFWU   PWR_CR2_FLASHFWU_Msk
#define PWR_CR2_SRAM3PDS1_Pos   (16U)
#define PWR_CR2_SRAM3PDS1_Msk   (0x1UL << PWR_CR2_SRAM3PDS1_Pos)
#define PWR_CR2_SRAM3PDS1   PWR_CR2_SRAM3PDS1_Msk
#define PWR_CR2_SRAM3PDS2_Pos   (17U)
#define PWR_CR2_SRAM3PDS2_Msk   (0x1UL << PWR_CR2_SRAM3PDS2_Pos)
#define PWR_CR2_SRAM3PDS2   PWR_CR2_SRAM3PDS2_Msk
#define PWR_CR2_SRAM3PDS3_Pos   (18U)
#define PWR_CR2_SRAM3PDS3_Msk   (0x1UL << PWR_CR2_SRAM3PDS3_Pos)
#define PWR_CR2_SRAM3PDS3   PWR_CR2_SRAM3PDS3_Msk
#define PWR_CR2_SRAM3PDS4_Pos   (19U)
#define PWR_CR2_SRAM3PDS4_Msk   (0x1UL << PWR_CR2_SRAM3PDS4_Pos)
#define PWR_CR2_SRAM3PDS4   PWR_CR2_SRAM3PDS4_Msk
#define PWR_CR2_SRAM3PDS5_Pos   (20U)
#define PWR_CR2_SRAM3PDS5_Msk   (0x1UL << PWR_CR2_SRAM3PDS5_Pos)
#define PWR_CR2_SRAM3PDS5   PWR_CR2_SRAM3PDS5_Msk
#define PWR_CR2_SRAM3PDS6_Pos   (21U)
#define PWR_CR2_SRAM3PDS6_Msk   (0x1UL << PWR_CR2_SRAM3PDS6_Pos)
#define PWR_CR2_SRAM3PDS6   PWR_CR2_SRAM3PDS6_Msk
#define PWR_CR2_SRAM3PDS7_Pos   (22U)
#define PWR_CR2_SRAM3PDS7_Msk   (0x1UL << PWR_CR2_SRAM3PDS7_Pos)
#define PWR_CR2_SRAM3PDS7   PWR_CR2_SRAM3PDS7_Msk
#define PWR_CR2_SRAM3PDS8_Pos   (23U)
#define PWR_CR2_SRAM3PDS8_Msk   (0x1UL << PWR_CR2_SRAM3PDS8_Pos)
#define PWR_CR2_SRAM3PDS8   PWR_CR2_SRAM3PDS8_Msk
#define PWR_CR2_GPRAMPDS_Pos   (24U)
#define PWR_CR2_GPRAMPDS_Msk   (0x1UL << PWR_CR2_GPRAMPDS_Pos)
#define PWR_CR2_GPRAMPDS   PWR_CR2_GPRAMPDS_Msk
#define PWR_CR2_DSIRAMPDS_Pos   (25U)
#define PWR_CR2_DSIRAMPDS_Msk   (0x1UL << PWR_CR2_DSIRAMPDS_Pos)
#define PWR_CR2_DSIRAMPDS   PWR_CR2_DSIRAMPDS_Msk
#define PWR_CR2_JPEGRAMPDS_Pos   (26U)
#define PWR_CR2_JPEGRAMPDS_Msk   (0x1UL << PWR_CR2_JPEGRAMPDS_Pos)
#define PWR_CR2_JPEGRAMPDS   PWR_CR2_JPEGRAMPDS_Msk
#define PWR_CR2_SRDRUN_Pos   (31U)
#define PWR_CR2_SRDRUN_Msk   (0x1UL << PWR_CR2_SRDRUN_Pos)
#define PWR_CR2_SRDRUN   PWR_CR2_SRDRUN_Msk
#define PWR_CR3_REGSEL_Pos   (1U)
#define PWR_CR3_REGSEL_Msk   (0x1UL << PWR_CR3_REGSEL_Pos)
#define PWR_CR3_REGSEL   PWR_CR3_REGSEL_Msk
#define PWR_CR3_FSTEN_Pos   (2U)
#define PWR_CR3_FSTEN_Msk   (0x1UL << PWR_CR3_FSTEN_Pos)
#define PWR_CR3_FSTEN   PWR_CR3_FSTEN_Msk
#define PWR_VOSR_USBBOOSTRDY_Pos   (13U)
#define PWR_VOSR_USBBOOSTRDY_Msk   (0x1UL << PWR_VOSR_USBBOOSTRDY_Pos)
#define PWR_VOSR_USBBOOSTRDY   PWR_VOSR_USBBOOSTRDY_Msk
#define PWR_VOSR_BOOSTRDY_Pos   (14U)
#define PWR_VOSR_BOOSTRDY_Msk   (0x1UL << PWR_VOSR_BOOSTRDY_Pos)
#define PWR_VOSR_BOOSTRDY   PWR_VOSR_BOOSTRDY_Msk
#define PWR_VOSR_VOSRDY_Pos   (15U)
#define PWR_VOSR_VOSRDY_Msk   (0x1UL << PWR_VOSR_VOSRDY_Pos)
#define PWR_VOSR_VOSRDY   PWR_VOSR_VOSRDY_Msk
#define PWR_VOSR_VOS_Pos   (16U)
#define PWR_VOSR_VOS_Msk   (0x3UL << PWR_VOSR_VOS_Pos)
#define PWR_VOSR_VOS   PWR_VOSR_VOS_Msk
#define PWR_VOSR_VOS_0   (0x1UL << PWR_VOSR_VOS_Pos)
#define PWR_VOSR_VOS_1   (0x2UL << PWR_VOSR_VOS_Pos)
#define PWR_VOSR_BOOSTEN_Pos   (18U)
#define PWR_VOSR_BOOSTEN_Msk   (0x1UL << PWR_VOSR_BOOSTEN_Pos)
#define PWR_VOSR_BOOSTEN   PWR_VOSR_BOOSTEN_Msk
#define PWR_VOSR_USBPWREN_Pos   (19U)
#define PWR_VOSR_USBPWREN_Msk   (0x1UL << PWR_VOSR_USBPWREN_Pos)
#define PWR_VOSR_USBPWREN   PWR_VOSR_USBPWREN_Msk
#define PWR_VOSR_USBBOOSTEN_Pos   (20U)
#define PWR_VOSR_USBBOOSTEN_Msk   (0x1UL << PWR_VOSR_USBBOOSTEN_Pos)
#define PWR_VOSR_USBBOOSTEN   PWR_VOSR_USBBOOSTEN_Msk
#define PWR_VOSR_VDD11USBDIS_Pos   (21U)
#define PWR_VOSR_VDD11USBDIS_Msk   (0x1UL << PWR_VOSR_VDD11USBDIS_Pos)
#define PWR_VOSR_VDD11USBDIS   PWR_VOSR_VDD11USBDIS_Msk
#define PWR_SVMCR_PVDE_Pos   (4U)
#define PWR_SVMCR_PVDE_Msk   (0x1UL << PWR_SVMCR_PVDE_Pos)
#define PWR_SVMCR_PVDE   PWR_SVMCR_PVDE_Msk
#define PWR_SVMCR_PVDLS_Pos   (5U)
#define PWR_SVMCR_PVDLS_Msk   (0x7UL << PWR_SVMCR_PVDLS_Pos)
#define PWR_SVMCR_PVDLS   PWR_SVMCR_PVDLS_Msk
#define PWR_SVMCR_PVDLS_0   (0x1UL << PWR_SVMCR_PVDLS_Pos)
#define PWR_SVMCR_PVDLS_1   (0x2UL << PWR_SVMCR_PVDLS_Pos)
#define PWR_SVMCR_PVDLS_2   (0x4UL << PWR_SVMCR_PVDLS_Pos)
#define PWR_SVMCR_UVMEN_Pos   (24U)
#define PWR_SVMCR_UVMEN_Msk   (0x1UL << PWR_SVMCR_UVMEN_Pos)
#define PWR_SVMCR_UVMEN   PWR_SVMCR_UVMEN_Msk
#define PWR_SVMCR_IO2VMEN_Pos   (25U)
#define PWR_SVMCR_IO2VMEN_Msk   (0x1UL << PWR_SVMCR_IO2VMEN_Pos)
#define PWR_SVMCR_IO2VMEN   PWR_SVMCR_IO2VMEN_Msk
#define PWR_SVMCR_AVM1EN_Pos   (26U)
#define PWR_SVMCR_AVM1EN_Msk   (0x1UL << PWR_SVMCR_AVM1EN_Pos)
#define PWR_SVMCR_AVM1EN   PWR_SVMCR_AVM1EN_Msk
#define PWR_SVMCR_AVM2EN_Pos   (27U)
#define PWR_SVMCR_AVM2EN_Msk   (0x1UL << PWR_SVMCR_AVM2EN_Pos)
#define PWR_SVMCR_AVM2EN   PWR_SVMCR_AVM2EN_Msk
#define PWR_SVMCR_USV_Pos   (28U)
#define PWR_SVMCR_USV_Msk   (0x1UL << PWR_SVMCR_USV_Pos)
#define PWR_SVMCR_USV   PWR_SVMCR_USV_Msk
#define PWR_SVMCR_IO2SV_Pos   (29U)
#define PWR_SVMCR_IO2SV_Msk   (0x1UL << PWR_SVMCR_IO2SV_Pos)
#define PWR_SVMCR_IO2SV   PWR_SVMCR_IO2SV_Msk
#define PWR_SVMCR_ASV_Pos   (30U)
#define PWR_SVMCR_ASV_Msk   (0x1UL << PWR_SVMCR_ASV_Pos)
#define PWR_SVMCR_ASV   PWR_SVMCR_ASV_Msk
#define PWR_WUCR1_WUPEN1_Pos   (0U)
#define PWR_WUCR1_WUPEN1_Msk   (0x1UL << PWR_WUCR1_WUPEN1_Pos)
#define PWR_WUCR1_WUPEN1   PWR_WUCR1_WUPEN1_Msk
#define PWR_WUCR1_WUPEN2_Pos   (1U)
#define PWR_WUCR1_WUPEN2_Msk   (0x1UL << PWR_WUCR1_WUPEN2_Pos)
#define PWR_WUCR1_WUPEN2   PWR_WUCR1_WUPEN2_Msk
#define PWR_WUCR1_WUPEN3_Pos   (2U)
#define PWR_WUCR1_WUPEN3_Msk   (0x1UL << PWR_WUCR1_WUPEN3_Pos)
#define PWR_WUCR1_WUPEN3   PWR_WUCR1_WUPEN3_Msk
#define PWR_WUCR1_WUPEN4_Pos   (3U)
#define PWR_WUCR1_WUPEN4_Msk   (0x1UL << PWR_WUCR1_WUPEN4_Pos)
#define PWR_WUCR1_WUPEN4   PWR_WUCR1_WUPEN4_Msk
#define PWR_WUCR1_WUPEN5_Pos   (4U)
#define PWR_WUCR1_WUPEN5_Msk   (0x1UL << PWR_WUCR1_WUPEN5_Pos)
#define PWR_WUCR1_WUPEN5   PWR_WUCR1_WUPEN5_Msk
#define PWR_WUCR1_WUPEN6_Pos   (5U)
#define PWR_WUCR1_WUPEN6_Msk   (0x1UL << PWR_WUCR1_WUPEN6_Pos)
#define PWR_WUCR1_WUPEN6   PWR_WUCR1_WUPEN6_Msk
#define PWR_WUCR1_WUPEN7_Pos   (6U)
#define PWR_WUCR1_WUPEN7_Msk   (0x1UL << PWR_WUCR1_WUPEN7_Pos)
#define PWR_WUCR1_WUPEN7   PWR_WUCR1_WUPEN7_Msk
#define PWR_WUCR1_WUPEN8_Pos   (7U)
#define PWR_WUCR1_WUPEN8_Msk   (0x1UL << PWR_WUCR1_WUPEN8_Pos)
#define PWR_WUCR1_WUPEN8   PWR_WUCR1_WUPEN8_Msk
#define PWR_WUCR2_WUPP1_Pos   (0U)
#define PWR_WUCR2_WUPP1_Msk   (0x1UL << PWR_WUCR2_WUPP1_Pos)
#define PWR_WUCR2_WUPP1   PWR_WUCR2_WUPP1_Msk
#define PWR_WUCR2_WUPP2_Pos   (1U)
#define PWR_WUCR2_WUPP2_Msk   (0x1UL << PWR_WUCR2_WUPP2_Pos)
#define PWR_WUCR2_WUPP2   PWR_WUCR2_WUPP2_Msk
#define PWR_WUCR2_WUPP3_Pos   (2U)
#define PWR_WUCR2_WUPP3_Msk   (0x1UL << PWR_WUCR2_WUPP3_Pos)
#define PWR_WUCR2_WUPP3   PWR_WUCR2_WUPP3_Msk
#define PWR_WUCR2_WUPP4_Pos   (3U)
#define PWR_WUCR2_WUPP4_Msk   (0x1UL << PWR_WUCR2_WUPP4_Pos)
#define PWR_WUCR2_WUPP4   PWR_WUCR2_WUPP4_Msk
#define PWR_WUCR2_WUPP5_Pos   (4U)
#define PWR_WUCR2_WUPP5_Msk   (0x1UL << PWR_WUCR2_WUPP5_Pos)
#define PWR_WUCR2_WUPP5   PWR_WUCR2_WUPP5_Msk
#define PWR_WUCR2_WUPP6_Pos   (5U)
#define PWR_WUCR2_WUPP6_Msk   (0x1UL << PWR_WUCR2_WUPP6_Pos)
#define PWR_WUCR2_WUPP6   PWR_WUCR2_WUPP6_Msk
#define PWR_WUCR2_WUPP7_Pos   (6U)
#define PWR_WUCR2_WUPP7_Msk   (0x1UL << PWR_WUCR2_WUPP7_Pos)
#define PWR_WUCR2_WUPP7   PWR_WUCR2_WUPP7_Msk
#define PWR_WUCR2_WUPP8_Pos   (7U)
#define PWR_WUCR2_WUPP8_Msk   (0x1UL << PWR_WUCR2_WUPP8_Pos)
#define PWR_WUCR2_WUPP8   PWR_WUCR2_WUPP8_Msk
#define PWR_WUCR3_WUSEL1_Pos   (0U)
#define PWR_WUCR3_WUSEL1_Msk   (0x3UL << PWR_WUCR3_WUSEL1_Pos)
#define PWR_WUCR3_WUSEL1   PWR_WUCR3_WUSEL1_Msk
#define PWR_WUCR3_WUSEL1_0   (0x1UL << PWR_WUCR3_WUSEL1_Pos)
#define PWR_WUCR3_WUSEL1_1   (0x2UL << PWR_WUCR3_WUSEL1_Pos)
#define PWR_WUCR3_WUSEL2_Pos   (2U)
#define PWR_WUCR3_WUSEL2_Msk   (0x3UL << PWR_WUCR3_WUSEL2_Pos)
#define PWR_WUCR3_WUSEL2   PWR_WUCR3_WUSEL2_Msk
#define PWR_WUCR3_WUSEL2_0   (0x1UL << PWR_WUCR3_WUSEL2_Pos)
#define PWR_WUCR3_WUSEL2_1   (0x2UL << PWR_WUCR3_WUSEL2_Pos)
#define PWR_WUCR3_WUSEL3_Pos   (4U)
#define PWR_WUCR3_WUSEL3_Msk   (0x3UL << PWR_WUCR3_WUSEL3_Pos)
#define PWR_WUCR3_WUSEL3   PWR_WUCR3_WUSEL3_Msk
#define PWR_WUCR3_WUSEL3_0   (0x1UL << PWR_WUCR3_WUSEL3_Pos)
#define PWR_WUCR3_WUSEL3_1   (0x2UL << PWR_WUCR3_WUSEL3_Pos)
#define PWR_WUCR3_WUSEL4_Pos   (6U)
#define PWR_WUCR3_WUSEL4_Msk   (0x3UL << PWR_WUCR3_WUSEL4_Pos)
#define PWR_WUCR3_WUSEL4   PWR_WUCR3_WUSEL4_Msk
#define PWR_WUCR3_WUSEL4_0   (0x1UL << PWR_WUCR3_WUSEL4_Pos)
#define PWR_WUCR3_WUSEL4_1   (0x2UL << PWR_WUCR3_WUSEL4_Pos)
#define PWR_WUCR3_WUSEL5_Pos   (8U)
#define PWR_WUCR3_WUSEL5_Msk   (0x3UL << PWR_WUCR3_WUSEL5_Pos)
#define PWR_WUCR3_WUSEL5   PWR_WUCR3_WUSEL5_Msk
#define PWR_WUCR3_WUSEL5_0   (0x1UL << PWR_WUCR3_WUSEL5_Pos)
#define PWR_WUCR3_WUSEL5_1   (0x2UL << PWR_WUCR3_WUSEL5_Pos)
#define PWR_WUCR3_WUSEL6_Pos   (10U)
#define PWR_WUCR3_WUSEL6_Msk   (0x3UL << PWR_WUCR3_WUSEL6_Pos)
#define PWR_WUCR3_WUSEL6   PWR_WUCR3_WUSEL6_Msk
#define PWR_WUCR3_WUSEL6_0   (0x1UL << PWR_WUCR3_WUSEL6_Pos)
#define PWR_WUCR3_WUSEL6_1   (0x2UL << PWR_WUCR3_WUSEL6_Pos)
#define PWR_WUCR3_WUSEL7_Pos   (12U)
#define PWR_WUCR3_WUSEL7_Msk   (0x3UL << PWR_WUCR3_WUSEL7_Pos)
#define PWR_WUCR3_WUSEL7   PWR_WUCR3_WUSEL7_Msk
#define PWR_WUCR3_WUSEL7_0   (0x1UL << PWR_WUCR3_WUSEL7_Pos)
#define PWR_WUCR3_WUSEL7_1   (0x2UL << PWR_WUCR3_WUSEL7_Pos)
#define PWR_WUCR3_WUSEL8_Pos   (14U)
#define PWR_WUCR3_WUSEL8_Msk   (0x3UL << PWR_WUCR3_WUSEL8_Pos)
#define PWR_WUCR3_WUSEL8   PWR_WUCR3_WUSEL8_Msk
#define PWR_WUCR3_WUSEL8_0   (0x1UL << PWR_WUCR3_WUSEL8_Pos)
#define PWR_WUCR3_WUSEL8_1   (0x2UL << PWR_WUCR3_WUSEL8_Pos)
#define PWR_BDCR1_BREN_Pos   (0U)
#define PWR_BDCR1_BREN_Msk   (0x1UL << PWR_BDCR1_BREN_Pos)
#define PWR_BDCR1_BREN   PWR_BDCR1_BREN_Msk
#define PWR_BDCR1_MONEN_Pos   (4U)
#define PWR_BDCR1_MONEN_Msk   (0x1UL << PWR_BDCR1_MONEN_Pos)
#define PWR_BDCR1_MONEN   PWR_BDCR1_MONEN_Msk
#define PWR_BDCR2_VBE_Pos   (0U)
#define PWR_BDCR2_VBE_Msk   (0x1UL << PWR_BDCR2_VBE_Pos)
#define PWR_BDCR2_VBE   PWR_BDCR2_VBE_Msk
#define PWR_BDCR2_VBRS_Pos   (1U)
#define PWR_BDCR2_VBRS_Msk   (0x1UL << PWR_BDCR2_VBRS_Pos)
#define PWR_BDCR2_VBRS   PWR_BDCR2_VBRS_Msk
#define PWR_DBPR_DBP_Pos   (0U)
#define PWR_DBPR_DBP_Msk   (0x1UL << PWR_DBPR_DBP_Pos)
#define PWR_DBPR_DBP   PWR_DBPR_DBP_Msk
#define PWR_UCPDR_UCPD_DBDIS_Pos   (0U)
#define PWR_UCPDR_UCPD_DBDIS_Msk   (0x1UL << PWR_UCPDR_UCPD_DBDIS_Pos)
#define PWR_UCPDR_UCPD_DBDIS   PWR_UCPDR_UCPD_DBDIS_Msk
#define PWR_UCPDR_UCPD_STDBY_Pos   (1U)
#define PWR_UCPDR_UCPD_STDBY_Msk   (0x1UL << PWR_UCPDR_UCPD_STDBY_Pos)
#define PWR_UCPDR_UCPD_STDBY   PWR_UCPDR_UCPD_STDBY_Msk
#define PWR_SECCFGR_WUP1SEC_Pos   (0U)
#define PWR_SECCFGR_WUP1SEC_Msk   (0x1UL << PWR_SECCFGR_WUP1SEC_Pos)
#define PWR_SECCFGR_WUP1SEC   PWR_SECCFGR_WUP1SEC_Msk
#define PWR_SECCFGR_WUP2SEC_Pos   (1U)
#define PWR_SECCFGR_WUP2SEC_Msk   (0x1UL << PWR_SECCFGR_WUP2SEC_Pos)
#define PWR_SECCFGR_WUP2SEC   PWR_SECCFGR_WUP2SEC_Msk
#define PWR_SECCFGR_WUP3SEC_Pos   (2U)
#define PWR_SECCFGR_WUP3SEC_Msk   (0x1UL << PWR_SECCFGR_WUP3SEC_Pos)
#define PWR_SECCFGR_WUP3SEC   PWR_SECCFGR_WUP3SEC_Msk
#define PWR_SECCFGR_WUP4SEC_Pos   (3U)
#define PWR_SECCFGR_WUP4SEC_Msk   (0x1UL << PWR_SECCFGR_WUP4SEC_Pos)
#define PWR_SECCFGR_WUP4SEC   PWR_SECCFGR_WUP4SEC_Msk
#define PWR_SECCFGR_WUP5SEC_Pos   (4U)
#define PWR_SECCFGR_WUP5SEC_Msk   (0x1UL << PWR_SECCFGR_WUP5SEC_Pos)
#define PWR_SECCFGR_WUP5SEC   PWR_SECCFGR_WUP5SEC_Msk
#define PWR_SECCFGR_WUP6SEC_Pos   (5U)
#define PWR_SECCFGR_WUP6SEC_Msk   (0x1UL << PWR_SECCFGR_WUP6SEC_Pos)
#define PWR_SECCFGR_WUP6SEC   PWR_SECCFGR_WUP6SEC_Msk
#define PWR_SECCFGR_WUP7SEC_Pos   (6U)
#define PWR_SECCFGR_WUP7SEC_Msk   (0x1UL << PWR_SECCFGR_WUP7SEC_Pos)
#define PWR_SECCFGR_WUP7SEC   PWR_SECCFGR_WUP7SEC_Msk
#define PWR_SECCFGR_WUP8SEC_Pos   (7U)
#define PWR_SECCFGR_WUP8SEC_Msk   (0x1UL << PWR_SECCFGR_WUP8SEC_Pos)
#define PWR_SECCFGR_WUP8SEC   PWR_SECCFGR_WUP8SEC_Msk
#define PWR_SECCFGR_LPMSEC_Pos   (12U)
#define PWR_SECCFGR_LPMSEC_Msk   (0x1UL << PWR_SECCFGR_LPMSEC_Pos)
#define PWR_SECCFGR_LPMSEC   PWR_SECCFGR_LPMSEC_Msk
#define PWR_SECCFGR_VDMSEC_Pos   (13U)
#define PWR_SECCFGR_VDMSEC_Msk   (0x1UL << PWR_SECCFGR_VDMSEC_Pos)
#define PWR_SECCFGR_VDMSEC   PWR_SECCFGR_VDMSEC_Msk
#define PWR_SECCFGR_VBSEC_Pos   (14U)
#define PWR_SECCFGR_VBSEC_Msk   (0x1UL << PWR_SECCFGR_VBSEC_Pos)
#define PWR_SECCFGR_VBSEC   PWR_SECCFGR_VBSEC_Msk
#define PWR_SECCFGR_APCSEC_Pos   (15U)
#define PWR_SECCFGR_APCSEC_Msk   (0x1UL << PWR_SECCFGR_APCSEC_Pos)
#define PWR_SECCFGR_APCSEC   PWR_SECCFGR_APCSEC_Msk
#define PWR_PRIVCFGR_SPRIV_Pos   (0U)
#define PWR_PRIVCFGR_SPRIV_Msk   (0x1UL << PWR_PRIVCFGR_SPRIV_Pos)
#define PWR_PRIVCFGR_SPRIV   PWR_PRIVCFGR_SPRIV_Msk
#define PWR_PRIVCFGR_NSPRIV_Pos   (1U)
#define PWR_PRIVCFGR_NSPRIV_Msk   (0x1UL << PWR_PRIVCFGR_NSPRIV_Pos)
#define PWR_PRIVCFGR_NSPRIV   PWR_PRIVCFGR_NSPRIV_Msk
#define PWR_SR_CSSF_Pos   (0U)
#define PWR_SR_CSSF_Msk   (0x1UL << PWR_SR_CSSF_Pos)
#define PWR_SR_CSSF   PWR_SR_CSSF_Msk
#define PWR_SR_STOPF_Pos   (1U)
#define PWR_SR_STOPF_Msk   (0x1UL << PWR_SR_STOPF_Pos)
#define PWR_SR_STOPF   PWR_SR_STOPF_Msk
#define PWR_SR_SBF_Pos   (2U)
#define PWR_SR_SBF_Msk   (0x1UL << PWR_SR_SBF_Pos)
#define PWR_SR_SBF   PWR_SR_SBF_Msk
#define PWR_SVMSR_REGS_Pos   (1U)
#define PWR_SVMSR_REGS_Msk   (0x1UL << PWR_SVMSR_REGS_Pos)
#define PWR_SVMSR_REGS   PWR_SVMSR_REGS_Msk
#define PWR_SVMSR_PVDO_Pos   (4U)
#define PWR_SVMSR_PVDO_Msk   (0x1UL << PWR_SVMSR_PVDO_Pos)
#define PWR_SVMSR_PVDO   PWR_SVMSR_PVDO_Msk
#define PWR_SVMSR_ACTVOSRDY_Pos   (15U)
#define PWR_SVMSR_ACTVOSRDY_Msk   (0x1UL << PWR_SVMSR_ACTVOSRDY_Pos)
#define PWR_SVMSR_ACTVOSRDY   PWR_SVMSR_ACTVOSRDY_Msk
#define PWR_SVMSR_ACTVOS_Pos   (16U)
#define PWR_SVMSR_ACTVOS_Msk   (0x3UL << PWR_SVMSR_ACTVOS_Pos)
#define PWR_SVMSR_ACTVOS   PWR_SVMSR_ACTVOS_Msk
#define PWR_SVMSR_ACTVOS_0   (0x1UL << PWR_SVMSR_ACTVOS_Pos)
#define PWR_SVMSR_ACTVOS_1   (0x2UL << PWR_SVMSR_ACTVOS_Pos)
#define PWR_SVMSR_VDDUSBRDY_Pos   (24U)
#define PWR_SVMSR_VDDUSBRDY_Msk   (0x1UL << PWR_SVMSR_VDDUSBRDY_Pos)
#define PWR_SVMSR_VDDUSBRDY   PWR_SVMSR_VDDUSBRDY_Msk
#define PWR_SVMSR_VDDIO2RDY_Pos   (25U)
#define PWR_SVMSR_VDDIO2RDY_Msk   (0x1UL << PWR_SVMSR_VDDIO2RDY_Pos)
#define PWR_SVMSR_VDDIO2RDY   PWR_SVMSR_VDDIO2RDY_Msk
#define PWR_SVMSR_VDDA1RDY_Pos   (26U)
#define PWR_SVMSR_VDDA1RDY_Msk   (0x1UL << PWR_SVMSR_VDDA1RDY_Pos)
#define PWR_SVMSR_VDDA1RDY   PWR_SVMSR_VDDA1RDY_Msk
#define PWR_SVMSR_VDDA2RDY_Pos   (27U)
#define PWR_SVMSR_VDDA2RDY_Msk   (0x1UL << PWR_SVMSR_VDDA2RDY_Pos)
#define PWR_SVMSR_VDDA2RDY   PWR_SVMSR_VDDA2RDY_Msk
#define PWR_BDSR_VBATH_Pos   (1U)
#define PWR_BDSR_VBATH_Msk   (0x1UL << PWR_BDSR_VBATH_Pos)
#define PWR_BDSR_VBATH   PWR_BDSR_VBATH_Msk
#define PWR_BDSR_TEMPL_Pos   (2U)
#define PWR_BDSR_TEMPL_Msk   (0x1UL << PWR_BDSR_TEMPL_Pos)
#define PWR_BDSR_TEMPL   PWR_BDSR_TEMPL_Msk
#define PWR_BDSR_TEMPH_Pos   (3U)
#define PWR_BDSR_TEMPH_Msk   (0x1UL << PWR_BDSR_TEMPH_Pos)
#define PWR_BDSR_TEMPH   PWR_BDSR_TEMPH_Msk
#define PWR_WUSR_WUF1_Pos   (0U)
#define PWR_WUSR_WUF1_Msk   (0x1UL << PWR_WUSR_WUF1_Pos)
#define PWR_WUSR_WUF1   PWR_WUSR_WUF1_Msk
#define PWR_WUSR_WUF2_Pos   (1U)
#define PWR_WUSR_WUF2_Msk   (0x1UL << PWR_WUSR_WUF2_Pos)
#define PWR_WUSR_WUF2   PWR_WUSR_WUF2_Msk
#define PWR_WUSR_WUF3_Pos   (2U)
#define PWR_WUSR_WUF3_Msk   (0x1UL << PWR_WUSR_WUF3_Pos)
#define PWR_WUSR_WUF3   PWR_WUSR_WUF3_Msk
#define PWR_WUSR_WUF4_Pos   (3U)
#define PWR_WUSR_WUF4_Msk   (0x1UL << PWR_WUSR_WUF4_Pos)
#define PWR_WUSR_WUF4   PWR_WUSR_WUF4_Msk
#define PWR_WUSR_WUF5_Pos   (4U)
#define PWR_WUSR_WUF5_Msk   (0x1UL << PWR_WUSR_WUF5_Pos)
#define PWR_WUSR_WUF5   PWR_WUSR_WUF5_Msk
#define PWR_WUSR_WUF6_Pos   (5U)
#define PWR_WUSR_WUF6_Msk   (0x1UL << PWR_WUSR_WUF6_Pos)
#define PWR_WUSR_WUF6   PWR_WUSR_WUF6_Msk
#define PWR_WUSR_WUF7_Pos   (6U)
#define PWR_WUSR_WUF7_Msk   (0x1UL << PWR_WUSR_WUF7_Pos)
#define PWR_WUSR_WUF7   PWR_WUSR_WUF7_Msk
#define PWR_WUSR_WUF8_Pos   (7U)
#define PWR_WUSR_WUF8_Msk   (0x1UL << PWR_WUSR_WUF8_Pos)
#define PWR_WUSR_WUF8   PWR_WUSR_WUF8_Msk
#define PWR_WUSR_WUF_Pos   (0U)
#define PWR_WUSR_WUF_Msk   (0xFFUL << PWR_WUSR_WUF_Pos)
#define PWR_WUSR_WUF   PWR_WUSR_WUF_Msk
#define PWR_WUSCR_CWUF1_Pos   (0U)
#define PWR_WUSCR_CWUF1_Msk   (0x1UL << PWR_WUSCR_CWUF1_Pos)
#define PWR_WUSCR_CWUF1   PWR_WUSCR_CWUF1_Msk
#define PWR_WUSCR_CWUF2_Pos   (1U)
#define PWR_WUSCR_CWUF2_Msk   (0x1UL << PWR_WUSCR_CWUF2_Pos)
#define PWR_WUSCR_CWUF2   PWR_WUSCR_CWUF2_Msk
#define PWR_WUSCR_CWUF3_Pos   (2U)
#define PWR_WUSCR_CWUF3_Msk   (0x1UL << PWR_WUSCR_CWUF3_Pos)
#define PWR_WUSCR_CWUF3   PWR_WUSCR_CWUF3_Msk
#define PWR_WUSCR_CWUF4_Pos   (3U)
#define PWR_WUSCR_CWUF4_Msk   (0x1UL << PWR_WUSCR_CWUF4_Pos)
#define PWR_WUSCR_CWUF4   PWR_WUSCR_CWUF4_Msk
#define PWR_WUSCR_CWUF5_Pos   (4U)
#define PWR_WUSCR_CWUF5_Msk   (0x1UL << PWR_WUSCR_CWUF5_Pos)
#define PWR_WUSCR_CWUF5   PWR_WUSCR_CWUF5_Msk
#define PWR_WUSCR_CWUF6_Pos   (5U)
#define PWR_WUSCR_CWUF6_Msk   (0x1UL << PWR_WUSCR_CWUF6_Pos)
#define PWR_WUSCR_CWUF6   PWR_WUSCR_CWUF6_Msk
#define PWR_WUSCR_CWUF7_Pos   (6U)
#define PWR_WUSCR_CWUF7_Msk   (0x1UL << PWR_WUSCR_CWUF7_Pos)
#define PWR_WUSCR_CWUF7   PWR_WUSCR_CWUF7_Msk
#define PWR_WUSCR_CWUF8_Pos   (7U)
#define PWR_WUSCR_CWUF8_Msk   (0x1UL << PWR_WUSCR_CWUF8_Pos)
#define PWR_WUSCR_CWUF8   PWR_WUSCR_CWUF8_Msk
#define PWR_WUSCR_CWUF_Pos   (0U)
#define PWR_WUSCR_CWUF_Msk   (0xFFUL << PWR_WUSCR_CWUF_Pos)
#define PWR_WUSCR_CWUF   PWR_WUSCR_CWUF_Msk
#define PWR_APCR_APC_Pos   (0U)
#define PWR_APCR_APC_Msk   (0x1UL << PWR_APCR_APC_Pos)
#define PWR_APCR_APC   PWR_APCR_APC_Msk
#define PWR_PUCRA_PU0_Pos   (0U)
#define PWR_PUCRA_PU0_Msk   (0x1UL << PWR_PUCRA_PU0_Pos)
#define PWR_PUCRA_PU0   PWR_PUCRA_PU0_Msk
#define PWR_PUCRA_PU1_Pos   (1U)
#define PWR_PUCRA_PU1_Msk   (0x1UL << PWR_PUCRA_PU1_Pos)
#define PWR_PUCRA_PU1   PWR_PUCRA_PU1_Msk
#define PWR_PUCRA_PU2_Pos   (2U)
#define PWR_PUCRA_PU2_Msk   (0x1UL << PWR_PUCRA_PU2_Pos)
#define PWR_PUCRA_PU2   PWR_PUCRA_PU2_Msk
#define PWR_PUCRA_PU3_Pos   (3U)
#define PWR_PUCRA_PU3_Msk   (0x1UL << PWR_PUCRA_PU3_Pos)
#define PWR_PUCRA_PU3   PWR_PUCRA_PU3_Msk
#define PWR_PUCRA_PU4_Pos   (4U)
#define PWR_PUCRA_PU4_Msk   (0x1UL << PWR_PUCRA_PU4_Pos)
#define PWR_PUCRA_PU4   PWR_PUCRA_PU4_Msk
#define PWR_PUCRA_PU5_Pos   (5U)
#define PWR_PUCRA_PU5_Msk   (0x1UL << PWR_PUCRA_PU5_Pos)
#define PWR_PUCRA_PU5   PWR_PUCRA_PU5_Msk
#define PWR_PUCRA_PU6_Pos   (6U)
#define PWR_PUCRA_PU6_Msk   (0x1UL << PWR_PUCRA_PU6_Pos)
#define PWR_PUCRA_PU6   PWR_PUCRA_PU6_Msk
#define PWR_PUCRA_PU7_Pos   (7U)
#define PWR_PUCRA_PU7_Msk   (0x1UL << PWR_PUCRA_PU7_Pos)
#define PWR_PUCRA_PU7   PWR_PUCRA_PU7_Msk
#define PWR_PUCRA_PU8_Pos   (8U)
#define PWR_PUCRA_PU8_Msk   (0x1UL << PWR_PUCRA_PU8_Pos)
#define PWR_PUCRA_PU8   PWR_PUCRA_PU8_Msk
#define PWR_PUCRA_PU9_Pos   (9U)
#define PWR_PUCRA_PU9_Msk   (0x1UL << PWR_PUCRA_PU9_Pos)
#define PWR_PUCRA_PU9   PWR_PUCRA_PU9_Msk
#define PWR_PUCRA_PU10_Pos   (10U)
#define PWR_PUCRA_PU10_Msk   (0x1UL << PWR_PUCRA_PU10_Pos)
#define PWR_PUCRA_PU10   PWR_PUCRA_PU10_Msk
#define PWR_PUCRA_PU11_Pos   (11U)
#define PWR_PUCRA_PU11_Msk   (0x1UL << PWR_PUCRA_PU11_Pos)
#define PWR_PUCRA_PU11   PWR_PUCRA_PU11_Msk
#define PWR_PUCRA_PU12_Pos   (12U)
#define PWR_PUCRA_PU12_Msk   (0x1UL << PWR_PUCRA_PU12_Pos)
#define PWR_PUCRA_PU12   PWR_PUCRA_PU12_Msk
#define PWR_PUCRA_PU13_Pos   (13U)
#define PWR_PUCRA_PU13_Msk   (0x1UL << PWR_PUCRA_PU13_Pos)
#define PWR_PUCRA_PU13   PWR_PUCRA_PU13_Msk
#define PWR_PUCRA_PU15_Pos   (15U)
#define PWR_PUCRA_PU15_Msk   (0x1UL << PWR_PUCRA_PU15_Pos)
#define PWR_PUCRA_PU15   PWR_PUCRA_PU15_Msk
#define PWR_PDCRA_PD0_Pos   (0U)
#define PWR_PDCRA_PD0_Msk   (0x1UL << PWR_PDCRA_PD0_Pos)
#define PWR_PDCRA_PD0   PWR_PDCRA_PD0_Msk
#define PWR_PDCRA_PD1_Pos   (1U)
#define PWR_PDCRA_PD1_Msk   (0x1UL << PWR_PDCRA_PD1_Pos)
#define PWR_PDCRA_PD1   PWR_PDCRA_PD1_Msk
#define PWR_PDCRA_PD2_Pos   (2U)
#define PWR_PDCRA_PD2_Msk   (0x1UL << PWR_PDCRA_PD2_Pos)
#define PWR_PDCRA_PD2   PWR_PDCRA_PD2_Msk
#define PWR_PDCRA_PD3_Pos   (3U)
#define PWR_PDCRA_PD3_Msk   (0x1UL << PWR_PDCRA_PD3_Pos)
#define PWR_PDCRA_PD3   PWR_PDCRA_PD3_Msk
#define PWR_PDCRA_PD4_Pos   (4U)
#define PWR_PDCRA_PD4_Msk   (0x1UL << PWR_PDCRA_PD4_Pos)
#define PWR_PDCRA_PD4   PWR_PDCRA_PD4_Msk
#define PWR_PDCRA_PD5_Pos   (5U)
#define PWR_PDCRA_PD5_Msk   (0x1UL << PWR_PDCRA_PD5_Pos)
#define PWR_PDCRA_PD5   PWR_PDCRA_PD5_Msk
#define PWR_PDCRA_PD6_Pos   (6U)
#define PWR_PDCRA_PD6_Msk   (0x1UL << PWR_PDCRA_PD6_Pos)
#define PWR_PDCRA_PD6   PWR_PDCRA_PD6_Msk
#define PWR_PDCRA_PD7_Pos   (7U)
#define PWR_PDCRA_PD7_Msk   (0x1UL << PWR_PDCRA_PD7_Pos)
#define PWR_PDCRA_PD7   PWR_PDCRA_PD7_Msk
#define PWR_PDCRA_PD8_Pos   (8U)
#define PWR_PDCRA_PD8_Msk   (0x1UL << PWR_PDCRA_PD8_Pos)
#define PWR_PDCRA_PD8   PWR_PDCRA_PD8_Msk
#define PWR_PDCRA_PD9_Pos   (9U)
#define PWR_PDCRA_PD9_Msk   (0x1UL << PWR_PDCRA_PD9_Pos)
#define PWR_PDCRA_PD9   PWR_PDCRA_PD9_Msk
#define PWR_PDCRA_PD10_Pos   (10U)
#define PWR_PDCRA_PD10_Msk   (0x1UL << PWR_PDCRA_PD10_Pos)
#define PWR_PDCRA_PD10   PWR_PDCRA_PD10_Msk
#define PWR_PDCRA_PD11_Pos   (11U)
#define PWR_PDCRA_PD11_Msk   (0x1UL << PWR_PDCRA_PD11_Pos)
#define PWR_PDCRA_PD11   PWR_PDCRA_PD11_Msk
#define PWR_PDCRA_PD12_Pos   (12U)
#define PWR_PDCRA_PD12_Msk   (0x1UL << PWR_PDCRA_PD12_Pos)
#define PWR_PDCRA_PD12   PWR_PDCRA_PD12_Msk
#define PWR_PDCRA_PD14_Pos   (14U)
#define PWR_PDCRA_PD14_Msk   (0x1UL << PWR_PDCRA_PD14_Pos)
#define PWR_PDCRA_PD14   PWR_PDCRA_PD14_Msk
#define PWR_PUCRB_PU0_Pos   (0U)
#define PWR_PUCRB_PU0_Msk   (0x1UL << PWR_PUCRB_PU0_Pos)
#define PWR_PUCRB_PU0   PWR_PUCRB_PU0_Msk
#define PWR_PUCRB_PU1_Pos   (1U)
#define PWR_PUCRB_PU1_Msk   (0x1UL << PWR_PUCRB_PU1_Pos)
#define PWR_PUCRB_PU1   PWR_PUCRB_PU1_Msk
#define PWR_PUCRB_PU2_Pos   (2U)
#define PWR_PUCRB_PU2_Msk   (0x1UL << PWR_PUCRB_PU2_Pos)
#define PWR_PUCRB_PU2   PWR_PUCRB_PU2_Msk
#define PWR_PUCRB_PU3_Pos   (3U)
#define PWR_PUCRB_PU3_Msk   (0x1UL << PWR_PUCRB_PU3_Pos)
#define PWR_PUCRB_PU3   PWR_PUCRB_PU3_Msk
#define PWR_PUCRB_PU4_Pos   (4U)
#define PWR_PUCRB_PU4_Msk   (0x1UL << PWR_PUCRB_PU4_Pos)
#define PWR_PUCRB_PU4   PWR_PUCRB_PU4_Msk
#define PWR_PUCRB_PU5_Pos   (5U)
#define PWR_PUCRB_PU5_Msk   (0x1UL << PWR_PUCRB_PU5_Pos)
#define PWR_PUCRB_PU5   PWR_PUCRB_PU5_Msk
#define PWR_PUCRB_PU6_Pos   (6U)
#define PWR_PUCRB_PU6_Msk   (0x1UL << PWR_PUCRB_PU6_Pos)
#define PWR_PUCRB_PU6   PWR_PUCRB_PU6_Msk
#define PWR_PUCRB_PU7_Pos   (7U)
#define PWR_PUCRB_PU7_Msk   (0x1UL << PWR_PUCRB_PU7_Pos)
#define PWR_PUCRB_PU7   PWR_PUCRB_PU7_Msk
#define PWR_PUCRB_PU8_Pos   (8U)
#define PWR_PUCRB_PU8_Msk   (0x1UL << PWR_PUCRB_PU8_Pos)
#define PWR_PUCRB_PU8   PWR_PUCRB_PU8_Msk
#define PWR_PUCRB_PU9_Pos   (9U)
#define PWR_PUCRB_PU9_Msk   (0x1UL << PWR_PUCRB_PU9_Pos)
#define PWR_PUCRB_PU9   PWR_PUCRB_PU9_Msk
#define PWR_PUCRB_PU10_Pos   (10U)
#define PWR_PUCRB_PU10_Msk   (0x1UL << PWR_PUCRB_PU10_Pos)
#define PWR_PUCRB_PU10   PWR_PUCRB_PU10_Msk
#define PWR_PUCRB_PU11_Pos   (11U)
#define PWR_PUCRB_PU11_Msk   (0x1UL << PWR_PUCRB_PU11_Pos)
#define PWR_PUCRB_PU11   PWR_PUCRB_PU11_Msk
#define PWR_PUCRB_PU12_Pos   (12U)
#define PWR_PUCRB_PU12_Msk   (0x1UL << PWR_PUCRB_PU12_Pos)
#define PWR_PUCRB_PU12   PWR_PUCRB_PU12_Msk
#define PWR_PUCRB_PU13_Pos   (13U)
#define PWR_PUCRB_PU13_Msk   (0x1UL << PWR_PUCRB_PU13_Pos)
#define PWR_PUCRB_PU13   PWR_PUCRB_PU13_Msk
#define PWR_PUCRB_PU14_Pos   (14U)
#define PWR_PUCRB_PU14_Msk   (0x1UL << PWR_PUCRB_PU14_Pos)
#define PWR_PUCRB_PU14   PWR_PUCRB_PU14_Msk
#define PWR_PUCRB_PU15_Pos   (15U)
#define PWR_PUCRB_PU15_Msk   (0x1UL << PWR_PUCRB_PU15_Pos)
#define PWR_PUCRB_PU15   PWR_PUCRB_PU15_Msk
#define PWR_PDCRB_PD0_Pos   (0U)
#define PWR_PDCRB_PD0_Msk   (0x1UL << PWR_PDCRB_PD0_Pos)
#define PWR_PDCRB_PD0   PWR_PDCRB_PD0_Msk
#define PWR_PDCRB_PD1_Pos   (1U)
#define PWR_PDCRB_PD1_Msk   (0x1UL << PWR_PDCRB_PD1_Pos)
#define PWR_PDCRB_PD1   PWR_PDCRB_PD1_Msk
#define PWR_PDCRB_PD2_Pos   (2U)
#define PWR_PDCRB_PD2_Msk   (0x1UL << PWR_PDCRB_PD2_Pos)
#define PWR_PDCRB_PD2   PWR_PDCRB_PD2_Msk
#define PWR_PDCRB_PD3_Pos   (3U)
#define PWR_PDCRB_PD3_Msk   (0x1UL << PWR_PDCRB_PD3_Pos)
#define PWR_PDCRB_PD3   PWR_PDCRB_PD3_Msk
#define PWR_PDCRB_PD5_Pos   (5U)
#define PWR_PDCRB_PD5_Msk   (0x1UL << PWR_PDCRB_PD5_Pos)
#define PWR_PDCRB_PD5   PWR_PDCRB_PD5_Msk
#define PWR_PDCRB_PD6_Pos   (6U)
#define PWR_PDCRB_PD6_Msk   (0x1UL << PWR_PDCRB_PD6_Pos)
#define PWR_PDCRB_PD6   PWR_PDCRB_PD6_Msk
#define PWR_PDCRB_PD7_Pos   (7U)
#define PWR_PDCRB_PD7_Msk   (0x1UL << PWR_PDCRB_PD7_Pos)
#define PWR_PDCRB_PD7   PWR_PDCRB_PD7_Msk
#define PWR_PDCRB_PD8_Pos   (8U)
#define PWR_PDCRB_PD8_Msk   (0x1UL << PWR_PDCRB_PD8_Pos)
#define PWR_PDCRB_PD8   PWR_PDCRB_PD8_Msk
#define PWR_PDCRB_PD9_Pos   (9U)
#define PWR_PDCRB_PD9_Msk   (0x1UL << PWR_PDCRB_PD9_Pos)
#define PWR_PDCRB_PD9   PWR_PDCRB_PD9_Msk
#define PWR_PDCRB_PD10_Pos   (10U)
#define PWR_PDCRB_PD10_Msk   (0x1UL << PWR_PDCRB_PD10_Pos)
#define PWR_PDCRB_PD10   PWR_PDCRB_PD10_Msk
#define PWR_PDCRB_PD11_Pos   (11U)
#define PWR_PDCRB_PD11_Msk   (0x1UL << PWR_PDCRB_PD11_Pos)
#define PWR_PDCRB_PD11   PWR_PDCRB_PD11_Msk
#define PWR_PDCRB_PD12_Pos   (12U)
#define PWR_PDCRB_PD12_Msk   (0x1UL << PWR_PDCRB_PD12_Pos)
#define PWR_PDCRB_PD12   PWR_PDCRB_PD12_Msk
#define PWR_PDCRB_PD13_Pos   (13U)
#define PWR_PDCRB_PD13_Msk   (0x1UL << PWR_PDCRB_PD13_Pos)
#define PWR_PDCRB_PD13   PWR_PDCRB_PD13_Msk
#define PWR_PDCRB_PD14_Pos   (14U)
#define PWR_PDCRB_PD14_Msk   (0x1UL << PWR_PDCRB_PD14_Pos)
#define PWR_PDCRB_PD14   PWR_PDCRB_PD14_Msk
#define PWR_PDCRB_PD15_Pos   (15U)
#define PWR_PDCRB_PD15_Msk   (0x1UL << PWR_PDCRB_PD15_Pos)
#define PWR_PDCRB_PD15   PWR_PDCRB_PD15_Msk
#define PWR_PUCRC_PU0_Pos   (0U)
#define PWR_PUCRC_PU0_Msk   (0x1UL << PWR_PUCRC_PU0_Pos)
#define PWR_PUCRC_PU0   PWR_PUCRC_PU0_Msk
#define PWR_PUCRC_PU1_Pos   (1U)
#define PWR_PUCRC_PU1_Msk   (0x1UL << PWR_PUCRC_PU1_Pos)
#define PWR_PUCRC_PU1   PWR_PUCRC_PU1_Msk
#define PWR_PUCRC_PU2_Pos   (2U)
#define PWR_PUCRC_PU2_Msk   (0x1UL << PWR_PUCRC_PU2_Pos)
#define PWR_PUCRC_PU2   PWR_PUCRC_PU2_Msk
#define PWR_PUCRC_PU3_Pos   (3U)
#define PWR_PUCRC_PU3_Msk   (0x1UL << PWR_PUCRC_PU3_Pos)
#define PWR_PUCRC_PU3   PWR_PUCRC_PU3_Msk
#define PWR_PUCRC_PU4_Pos   (4U)
#define PWR_PUCRC_PU4_Msk   (0x1UL << PWR_PUCRC_PU4_Pos)
#define PWR_PUCRC_PU4   PWR_PUCRC_PU4_Msk
#define PWR_PUCRC_PU5_Pos   (5U)
#define PWR_PUCRC_PU5_Msk   (0x1UL << PWR_PUCRC_PU5_Pos)
#define PWR_PUCRC_PU5   PWR_PUCRC_PU5_Msk
#define PWR_PUCRC_PU6_Pos   (6U)
#define PWR_PUCRC_PU6_Msk   (0x1UL << PWR_PUCRC_PU6_Pos)
#define PWR_PUCRC_PU6   PWR_PUCRC_PU6_Msk
#define PWR_PUCRC_PU7_Pos   (7U)
#define PWR_PUCRC_PU7_Msk   (0x1UL << PWR_PUCRC_PU7_Pos)
#define PWR_PUCRC_PU7   PWR_PUCRC_PU7_Msk
#define PWR_PUCRC_PU8_Pos   (8U)
#define PWR_PUCRC_PU8_Msk   (0x1UL << PWR_PUCRC_PU8_Pos)
#define PWR_PUCRC_PU8   PWR_PUCRC_PU8_Msk
#define PWR_PUCRC_PU9_Pos   (9U)
#define PWR_PUCRC_PU9_Msk   (0x1UL << PWR_PUCRC_PU9_Pos)
#define PWR_PUCRC_PU9   PWR_PUCRC_PU9_Msk
#define PWR_PUCRC_PU10_Pos   (10U)
#define PWR_PUCRC_PU10_Msk   (0x1UL << PWR_PUCRC_PU10_Pos)
#define PWR_PUCRC_PU10   PWR_PUCRC_PU10_Msk
#define PWR_PUCRC_PU11_Pos   (11U)
#define PWR_PUCRC_PU11_Msk   (0x1UL << PWR_PUCRC_PU11_Pos)
#define PWR_PUCRC_PU11   PWR_PUCRC_PU11_Msk
#define PWR_PUCRC_PU12_Pos   (12U)
#define PWR_PUCRC_PU12_Msk   (0x1UL << PWR_PUCRC_PU12_Pos)
#define PWR_PUCRC_PU12   PWR_PUCRC_PU12_Msk
#define PWR_PUCRC_PU13_Pos   (13U)
#define PWR_PUCRC_PU13_Msk   (0x1UL << PWR_PUCRC_PU13_Pos)
#define PWR_PUCRC_PU13   PWR_PUCRC_PU13_Msk
#define PWR_PUCRC_PU14_Pos   (14U)
#define PWR_PUCRC_PU14_Msk   (0x1UL << PWR_PUCRC_PU14_Pos)
#define PWR_PUCRC_PU14   PWR_PUCRC_PU14_Msk
#define PWR_PUCRC_PU15_Pos   (15U)
#define PWR_PUCRC_PU15_Msk   (0x1UL << PWR_PUCRC_PU15_Pos)
#define PWR_PUCRC_PU15   PWR_PUCRC_PU15_Msk
#define PWR_PDCRC_PD0_Pos   (0U)
#define PWR_PDCRC_PD0_Msk   (0x1UL << PWR_PDCRC_PD0_Pos)
#define PWR_PDCRC_PD0   PWR_PDCRC_PD0_Msk
#define PWR_PDCRC_PD1_Pos   (1U)
#define PWR_PDCRC_PD1_Msk   (0x1UL << PWR_PDCRC_PD1_Pos)
#define PWR_PDCRC_PD1   PWR_PDCRC_PD1_Msk
#define PWR_PDCRC_PD2_Pos   (2U)
#define PWR_PDCRC_PD2_Msk   (0x1UL << PWR_PDCRC_PD2_Pos)
#define PWR_PDCRC_PD2   PWR_PDCRC_PD2_Msk
#define PWR_PDCRC_PD3_Pos   (3U)
#define PWR_PDCRC_PD3_Msk   (0x1UL << PWR_PDCRC_PD3_Pos)
#define PWR_PDCRC_PD3   PWR_PDCRC_PD3_Msk
#define PWR_PDCRC_PD4_Pos   (4U)
#define PWR_PDCRC_PD4_Msk   (0x1UL << PWR_PDCRC_PD4_Pos)
#define PWR_PDCRC_PD4   PWR_PDCRC_PD4_Msk
#define PWR_PDCRC_PD5_Pos   (5U)
#define PWR_PDCRC_PD5_Msk   (0x1UL << PWR_PDCRC_PD5_Pos)
#define PWR_PDCRC_PD5   PWR_PDCRC_PD5_Msk
#define PWR_PDCRC_PD6_Pos   (6U)
#define PWR_PDCRC_PD6_Msk   (0x1UL << PWR_PDCRC_PD6_Pos)
#define PWR_PDCRC_PD6   PWR_PDCRC_PD6_Msk
#define PWR_PDCRC_PD7_Pos   (7U)
#define PWR_PDCRC_PD7_Msk   (0x1UL << PWR_PDCRC_PD7_Pos)
#define PWR_PDCRC_PD7   PWR_PDCRC_PD7_Msk
#define PWR_PDCRC_PD8_Pos   (8U)
#define PWR_PDCRC_PD8_Msk   (0x1UL << PWR_PDCRC_PD8_Pos)
#define PWR_PDCRC_PD8   PWR_PDCRC_PD8_Msk
#define PWR_PDCRC_PD9_Pos   (9U)
#define PWR_PDCRC_PD9_Msk   (0x1UL << PWR_PDCRC_PD9_Pos)
#define PWR_PDCRC_PD9   PWR_PDCRC_PD9_Msk
#define PWR_PDCRC_PD10_Pos   (10U)
#define PWR_PDCRC_PD10_Msk   (0x1UL << PWR_PDCRC_PD10_Pos)
#define PWR_PDCRC_PD10   PWR_PDCRC_PD10_Msk
#define PWR_PDCRC_PD11_Pos   (11U)
#define PWR_PDCRC_PD11_Msk   (0x1UL << PWR_PDCRC_PD11_Pos)
#define PWR_PDCRC_PD11   PWR_PDCRC_PD11_Msk
#define PWR_PDCRC_PD12_Pos   (12U)
#define PWR_PDCRC_PD12_Msk   (0x1UL << PWR_PDCRC_PD12_Pos)
#define PWR_PDCRC_PD12   PWR_PDCRC_PD12_Msk
#define PWR_PDCRC_PD13_Pos   (13U)
#define PWR_PDCRC_PD13_Msk   (0x1UL << PWR_PDCRC_PD13_Pos)
#define PWR_PDCRC_PD13   PWR_PDCRC_PD13_Msk
#define PWR_PDCRC_PD14_Pos   (14U)
#define PWR_PDCRC_PD14_Msk   (0x1UL << PWR_PDCRC_PD14_Pos)
#define PWR_PDCRC_PD14   PWR_PDCRC_PD14_Msk
#define PWR_PDCRC_PD15_Pos   (15U)
#define PWR_PDCRC_PD15_Msk   (0x1UL << PWR_PDCRC_PD15_Pos)
#define PWR_PDCRC_PD15   PWR_PDCRC_PD15_Msk
#define PWR_PUCRD_PU0_Pos   (0U)
#define PWR_PUCRD_PU0_Msk   (0x1UL << PWR_PUCRD_PU0_Pos)
#define PWR_PUCRD_PU0   PWR_PUCRD_PU0_Msk
#define PWR_PUCRD_PU1_Pos   (1U)
#define PWR_PUCRD_PU1_Msk   (0x1UL << PWR_PUCRD_PU1_Pos)
#define PWR_PUCRD_PU1   PWR_PUCRD_PU1_Msk
#define PWR_PUCRD_PU2_Pos   (2U)
#define PWR_PUCRD_PU2_Msk   (0x1UL << PWR_PUCRD_PU2_Pos)
#define PWR_PUCRD_PU2   PWR_PUCRD_PU2_Msk
#define PWR_PUCRD_PU3_Pos   (3U)
#define PWR_PUCRD_PU3_Msk   (0x1UL << PWR_PUCRD_PU3_Pos)
#define PWR_PUCRD_PU3   PWR_PUCRD_PU3_Msk
#define PWR_PUCRD_PU4_Pos   (4U)
#define PWR_PUCRD_PU4_Msk   (0x1UL << PWR_PUCRD_PU4_Pos)
#define PWR_PUCRD_PU4   PWR_PUCRD_PU4_Msk
#define PWR_PUCRD_PU5_Pos   (5U)
#define PWR_PUCRD_PU5_Msk   (0x1UL << PWR_PUCRD_PU5_Pos)
#define PWR_PUCRD_PU5   PWR_PUCRD_PU5_Msk
#define PWR_PUCRD_PU6_Pos   (6U)
#define PWR_PUCRD_PU6_Msk   (0x1UL << PWR_PUCRD_PU6_Pos)
#define PWR_PUCRD_PU6   PWR_PUCRD_PU6_Msk
#define PWR_PUCRD_PU7_Pos   (7U)
#define PWR_PUCRD_PU7_Msk   (0x1UL << PWR_PUCRD_PU7_Pos)
#define PWR_PUCRD_PU7   PWR_PUCRD_PU7_Msk
#define PWR_PUCRD_PU8_Pos   (8U)
#define PWR_PUCRD_PU8_Msk   (0x1UL << PWR_PUCRD_PU8_Pos)
#define PWR_PUCRD_PU8   PWR_PUCRD_PU8_Msk
#define PWR_PUCRD_PU9_Pos   (9U)
#define PWR_PUCRD_PU9_Msk   (0x1UL << PWR_PUCRD_PU9_Pos)
#define PWR_PUCRD_PU9   PWR_PUCRD_PU9_Msk
#define PWR_PUCRD_PU10_Pos   (10U)
#define PWR_PUCRD_PU10_Msk   (0x1UL << PWR_PUCRD_PU10_Pos)
#define PWR_PUCRD_PU10   PWR_PUCRD_PU10_Msk
#define PWR_PUCRD_PU11_Pos   (11U)
#define PWR_PUCRD_PU11_Msk   (0x1UL << PWR_PUCRD_PU11_Pos)
#define PWR_PUCRD_PU11   PWR_PUCRD_PU11_Msk
#define PWR_PUCRD_PU12_Pos   (12U)
#define PWR_PUCRD_PU12_Msk   (0x1UL << PWR_PUCRD_PU12_Pos)
#define PWR_PUCRD_PU12   PWR_PUCRD_PU12_Msk
#define PWR_PUCRD_PU13_Pos   (13U)
#define PWR_PUCRD_PU13_Msk   (0x1UL << PWR_PUCRD_PU13_Pos)
#define PWR_PUCRD_PU13   PWR_PUCRD_PU13_Msk
#define PWR_PUCRD_PU14_Pos   (14U)
#define PWR_PUCRD_PU14_Msk   (0x1UL << PWR_PUCRD_PU14_Pos)
#define PWR_PUCRD_PU14   PWR_PUCRD_PU14_Msk
#define PWR_PUCRD_PU15_Pos   (15U)
#define PWR_PUCRD_PU15_Msk   (0x1UL << PWR_PUCRD_PU15_Pos)
#define PWR_PUCRD_PU15   PWR_PUCRD_PU15_Msk
#define PWR_PDCRD_PD0_Pos   (0U)
#define PWR_PDCRD_PD0_Msk   (0x1UL << PWR_PDCRD_PD0_Pos)
#define PWR_PDCRD_PD0   PWR_PDCRD_PD0_Msk
#define PWR_PDCRD_PD1_Pos   (1U)
#define PWR_PDCRD_PD1_Msk   (0x1UL << PWR_PDCRD_PD1_Pos)
#define PWR_PDCRD_PD1   PWR_PDCRD_PD1_Msk
#define PWR_PDCRD_PD2_Pos   (2U)
#define PWR_PDCRD_PD2_Msk   (0x1UL << PWR_PDCRD_PD2_Pos)
#define PWR_PDCRD_PD2   PWR_PDCRD_PD2_Msk
#define PWR_PDCRD_PD3_Pos   (3U)
#define PWR_PDCRD_PD3_Msk   (0x1UL << PWR_PDCRD_PD3_Pos)
#define PWR_PDCRD_PD3   PWR_PDCRD_PD3_Msk
#define PWR_PDCRD_PD4_Pos   (4U)
#define PWR_PDCRD_PD4_Msk   (0x1UL << PWR_PDCRD_PD4_Pos)
#define PWR_PDCRD_PD4   PWR_PDCRD_PD4_Msk
#define PWR_PDCRD_PD5_Pos   (5U)
#define PWR_PDCRD_PD5_Msk   (0x1UL << PWR_PDCRD_PD5_Pos)
#define PWR_PDCRD_PD5   PWR_PDCRD_PD5_Msk
#define PWR_PDCRD_PD6_Pos   (6U)
#define PWR_PDCRD_PD6_Msk   (0x1UL << PWR_PDCRD_PD6_Pos)
#define PWR_PDCRD_PD6   PWR_PDCRD_PD6_Msk
#define PWR_PDCRD_PD7_Pos   (7U)
#define PWR_PDCRD_PD7_Msk   (0x1UL << PWR_PDCRD_PD7_Pos)
#define PWR_PDCRD_PD7   PWR_PDCRD_PD7_Msk
#define PWR_PDCRD_PD8_Pos   (8U)
#define PWR_PDCRD_PD8_Msk   (0x1UL << PWR_PDCRD_PD8_Pos)
#define PWR_PDCRD_PD8   PWR_PDCRD_PD8_Msk
#define PWR_PDCRD_PD9_Pos   (9U)
#define PWR_PDCRD_PD9_Msk   (0x1UL << PWR_PDCRD_PD9_Pos)
#define PWR_PDCRD_PD9   PWR_PDCRD_PD9_Msk
#define PWR_PDCRD_PD10_Pos   (10U)
#define PWR_PDCRD_PD10_Msk   (0x1UL << PWR_PDCRD_PD10_Pos)
#define PWR_PDCRD_PD10   PWR_PDCRD_PD10_Msk
#define PWR_PDCRD_PD11_Pos   (11U)
#define PWR_PDCRD_PD11_Msk   (0x1UL << PWR_PDCRD_PD11_Pos)
#define PWR_PDCRD_PD11   PWR_PDCRD_PD11_Msk
#define PWR_PDCRD_PD12_Pos   (12U)
#define PWR_PDCRD_PD12_Msk   (0x1UL << PWR_PDCRD_PD12_Pos)
#define PWR_PDCRD_PD12   PWR_PDCRD_PD12_Msk
#define PWR_PDCRD_PD13_Pos   (13U)
#define PWR_PDCRD_PD13_Msk   (0x1UL << PWR_PDCRD_PD13_Pos)
#define PWR_PDCRD_PD13   PWR_PDCRD_PD13_Msk
#define PWR_PDCRD_PD14_Pos   (14U)
#define PWR_PDCRD_PD14_Msk   (0x1UL << PWR_PDCRD_PD14_Pos)
#define PWR_PDCRD_PD14   PWR_PDCRD_PD14_Msk
#define PWR_PDCRD_PD15_Pos   (15U)
#define PWR_PDCRD_PD15_Msk   (0x1UL << PWR_PDCRD_PD15_Pos)
#define PWR_PDCRD_PD15   PWR_PDCRD_PD15_Msk
#define PWR_PUCRE_PU0_Pos   (0U)
#define PWR_PUCRE_PU0_Msk   (0x1UL << PWR_PUCRE_PU0_Pos)
#define PWR_PUCRE_PU0   PWR_PUCRE_PU0_Msk
#define PWR_PUCRE_PU1_Pos   (1U)
#define PWR_PUCRE_PU1_Msk   (0x1UL << PWR_PUCRE_PU1_Pos)
#define PWR_PUCRE_PU1   PWR_PUCRE_PU1_Msk
#define PWR_PUCRE_PU2_Pos   (2U)
#define PWR_PUCRE_PU2_Msk   (0x1UL << PWR_PUCRE_PU2_Pos)
#define PWR_PUCRE_PU2   PWR_PUCRE_PU2_Msk
#define PWR_PUCRE_PU3_Pos   (3U)
#define PWR_PUCRE_PU3_Msk   (0x1UL << PWR_PUCRE_PU3_Pos)
#define PWR_PUCRE_PU3   PWR_PUCRE_PU3_Msk
#define PWR_PUCRE_PU4_Pos   (4U)
#define PWR_PUCRE_PU4_Msk   (0x1UL << PWR_PUCRE_PU4_Pos)
#define PWR_PUCRE_PU4   PWR_PUCRE_PU4_Msk
#define PWR_PUCRE_PU5_Pos   (5U)
#define PWR_PUCRE_PU5_Msk   (0x1UL << PWR_PUCRE_PU5_Pos)
#define PWR_PUCRE_PU5   PWR_PUCRE_PU5_Msk
#define PWR_PUCRE_PU6_Pos   (6U)
#define PWR_PUCRE_PU6_Msk   (0x1UL << PWR_PUCRE_PU6_Pos)
#define PWR_PUCRE_PU6   PWR_PUCRE_PU6_Msk
#define PWR_PUCRE_PU7_Pos   (7U)
#define PWR_PUCRE_PU7_Msk   (0x1UL << PWR_PUCRE_PU7_Pos)
#define PWR_PUCRE_PU7   PWR_PUCRE_PU7_Msk
#define PWR_PUCRE_PU8_Pos   (8U)
#define PWR_PUCRE_PU8_Msk   (0x1UL << PWR_PUCRE_PU8_Pos)
#define PWR_PUCRE_PU8   PWR_PUCRE_PU8_Msk
#define PWR_PUCRE_PU9_Pos   (9U)
#define PWR_PUCRE_PU9_Msk   (0x1UL << PWR_PUCRE_PU9_Pos)
#define PWR_PUCRE_PU9   PWR_PUCRE_PU9_Msk
#define PWR_PUCRE_PU10_Pos   (10U)
#define PWR_PUCRE_PU10_Msk   (0x1UL << PWR_PUCRE_PU10_Pos)
#define PWR_PUCRE_PU10   PWR_PUCRE_PU10_Msk
#define PWR_PUCRE_PU11_Pos   (11U)
#define PWR_PUCRE_PU11_Msk   (0x1UL << PWR_PUCRE_PU11_Pos)
#define PWR_PUCRE_PU11   PWR_PUCRE_PU11_Msk
#define PWR_PUCRE_PU12_Pos   (12U)
#define PWR_PUCRE_PU12_Msk   (0x1UL << PWR_PUCRE_PU12_Pos)
#define PWR_PUCRE_PU12   PWR_PUCRE_PU12_Msk
#define PWR_PUCRE_PU13_Pos   (13U)
#define PWR_PUCRE_PU13_Msk   (0x1UL << PWR_PUCRE_PU13_Pos)
#define PWR_PUCRE_PU13   PWR_PUCRE_PU13_Msk
#define PWR_PUCRE_PU14_Pos   (14U)
#define PWR_PUCRE_PU14_Msk   (0x1UL << PWR_PUCRE_PU14_Pos)
#define PWR_PUCRE_PU14   PWR_PUCRE_PU14_Msk
#define PWR_PUCRE_PU15_Pos   (15U)
#define PWR_PUCRE_PU15_Msk   (0x1UL << PWR_PUCRE_PU15_Pos)
#define PWR_PUCRE_PU15   PWR_PUCRE_PU15_Msk
#define PWR_PDCRE_PD0_Pos   (0U)
#define PWR_PDCRE_PD0_Msk   (0x1UL << PWR_PDCRE_PD0_Pos)
#define PWR_PDCRE_PD0   PWR_PDCRE_PD0_Msk
#define PWR_PDCRE_PD1_Pos   (1U)
#define PWR_PDCRE_PD1_Msk   (0x1UL << PWR_PDCRE_PD1_Pos)
#define PWR_PDCRE_PD1   PWR_PDCRE_PD1_Msk
#define PWR_PDCRE_PD2_Pos   (2U)
#define PWR_PDCRE_PD2_Msk   (0x1UL << PWR_PDCRE_PD2_Pos)
#define PWR_PDCRE_PD2   PWR_PDCRE_PD2_Msk
#define PWR_PDCRE_PD3_Pos   (3U)
#define PWR_PDCRE_PD3_Msk   (0x1UL << PWR_PDCRE_PD3_Pos)
#define PWR_PDCRE_PD3   PWR_PDCRE_PD3_Msk
#define PWR_PDCRE_PD4_Pos   (4U)
#define PWR_PDCRE_PD4_Msk   (0x1UL << PWR_PDCRE_PD4_Pos)
#define PWR_PDCRE_PD4   PWR_PDCRE_PD4_Msk
#define PWR_PDCRE_PD5_Pos   (5U)
#define PWR_PDCRE_PD5_Msk   (0x1UL << PWR_PDCRE_PD5_Pos)
#define PWR_PDCRE_PD5   PWR_PDCRE_PD5_Msk
#define PWR_PDCRE_PD6_Pos   (6U)
#define PWR_PDCRE_PD6_Msk   (0x1UL << PWR_PDCRE_PD6_Pos)
#define PWR_PDCRE_PD6   PWR_PDCRE_PD6_Msk
#define PWR_PDCRE_PD7_Pos   (7U)
#define PWR_PDCRE_PD7_Msk   (0x1UL << PWR_PDCRE_PD7_Pos)
#define PWR_PDCRE_PD7   PWR_PDCRE_PD7_Msk
#define PWR_PDCRE_PD8_Pos   (8U)
#define PWR_PDCRE_PD8_Msk   (0x1UL << PWR_PDCRE_PD8_Pos)
#define PWR_PDCRE_PD8   PWR_PDCRE_PD8_Msk
#define PWR_PDCRE_PD9_Pos   (9U)
#define PWR_PDCRE_PD9_Msk   (0x1UL << PWR_PDCRE_PD9_Pos)
#define PWR_PDCRE_PD9   PWR_PDCRE_PD9_Msk
#define PWR_PDCRE_PD10_Pos   (10U)
#define PWR_PDCRE_PD10_Msk   (0x1UL << PWR_PDCRE_PD10_Pos)
#define PWR_PDCRE_PD10   PWR_PDCRE_PD10_Msk
#define PWR_PDCRE_PD11_Pos   (11U)
#define PWR_PDCRE_PD11_Msk   (0x1UL << PWR_PDCRE_PD11_Pos)
#define PWR_PDCRE_PD11   PWR_PDCRE_PD11_Msk
#define PWR_PDCRE_PD12_Pos   (12U)
#define PWR_PDCRE_PD12_Msk   (0x1UL << PWR_PDCRE_PD12_Pos)
#define PWR_PDCRE_PD12   PWR_PDCRE_PD12_Msk
#define PWR_PDCRE_PD13_Pos   (13U)
#define PWR_PDCRE_PD13_Msk   (0x1UL << PWR_PDCRE_PD13_Pos)
#define PWR_PDCRE_PD13   PWR_PDCRE_PD13_Msk
#define PWR_PDCRE_PD14_Pos   (14U)
#define PWR_PDCRE_PD14_Msk   (0x1UL << PWR_PDCRE_PD14_Pos)
#define PWR_PDCRE_PD14   PWR_PDCRE_PD14_Msk
#define PWR_PDCRE_PD15_Pos   (15U)
#define PWR_PDCRE_PD15_Msk   (0x1UL << PWR_PDCRE_PD15_Pos)
#define PWR_PDCRE_PD15   PWR_PDCRE_PD15_Msk
#define PWR_PUCRF_PU0_Pos   (0U)
#define PWR_PUCRF_PU0_Msk   (0x1UL << PWR_PUCRF_PU0_Pos)
#define PWR_PUCRF_PU0   PWR_PUCRF_PU0_Msk
#define PWR_PUCRF_PU1_Pos   (1U)
#define PWR_PUCRF_PU1_Msk   (0x1UL << PWR_PUCRF_PU1_Pos)
#define PWR_PUCRF_PU1   PWR_PUCRF_PU1_Msk
#define PWR_PUCRF_PU2_Pos   (2U)
#define PWR_PUCRF_PU2_Msk   (0x1UL << PWR_PUCRF_PU2_Pos)
#define PWR_PUCRF_PU2   PWR_PUCRF_PU2_Msk
#define PWR_PUCRF_PU3_Pos   (3U)
#define PWR_PUCRF_PU3_Msk   (0x1UL << PWR_PUCRF_PU3_Pos)
#define PWR_PUCRF_PU3   PWR_PUCRF_PU3_Msk
#define PWR_PUCRF_PU4_Pos   (4U)
#define PWR_PUCRF_PU4_Msk   (0x1UL << PWR_PUCRF_PU4_Pos)
#define PWR_PUCRF_PU4   PWR_PUCRF_PU4_Msk
#define PWR_PUCRF_PU5_Pos   (5U)
#define PWR_PUCRF_PU5_Msk   (0x1UL << PWR_PUCRF_PU5_Pos)
#define PWR_PUCRF_PU5   PWR_PUCRF_PU5_Msk
#define PWR_PUCRF_PU6_Pos   (6U)
#define PWR_PUCRF_PU6_Msk   (0x1UL << PWR_PUCRF_PU6_Pos)
#define PWR_PUCRF_PU6   PWR_PUCRF_PU6_Msk
#define PWR_PUCRF_PU7_Pos   (7U)
#define PWR_PUCRF_PU7_Msk   (0x1UL << PWR_PUCRF_PU7_Pos)
#define PWR_PUCRF_PU7   PWR_PUCRF_PU7_Msk
#define PWR_PUCRF_PU8_Pos   (8U)
#define PWR_PUCRF_PU8_Msk   (0x1UL << PWR_PUCRF_PU8_Pos)
#define PWR_PUCRF_PU8   PWR_PUCRF_PU8_Msk
#define PWR_PUCRF_PU9_Pos   (9U)
#define PWR_PUCRF_PU9_Msk   (0x1UL << PWR_PUCRF_PU9_Pos)
#define PWR_PUCRF_PU9   PWR_PUCRF_PU9_Msk
#define PWR_PUCRF_PU10_Pos   (10U)
#define PWR_PUCRF_PU10_Msk   (0x1UL << PWR_PUCRF_PU10_Pos)
#define PWR_PUCRF_PU10   PWR_PUCRF_PU10_Msk
#define PWR_PUCRF_PU11_Pos   (11U)
#define PWR_PUCRF_PU11_Msk   (0x1UL << PWR_PUCRF_PU11_Pos)
#define PWR_PUCRF_PU11   PWR_PUCRF_PU11_Msk
#define PWR_PUCRF_PU12_Pos   (12U)
#define PWR_PUCRF_PU12_Msk   (0x1UL << PWR_PUCRF_PU12_Pos)
#define PWR_PUCRF_PU12   PWR_PUCRF_PU12_Msk
#define PWR_PUCRF_PU13_Pos   (13U)
#define PWR_PUCRF_PU13_Msk   (0x1UL << PWR_PUCRF_PU13_Pos)
#define PWR_PUCRF_PU13   PWR_PUCRF_PU13_Msk
#define PWR_PUCRF_PU14_Pos   (14U)
#define PWR_PUCRF_PU14_Msk   (0x1UL << PWR_PUCRF_PU14_Pos)
#define PWR_PUCRF_PU14   PWR_PUCRF_PU14_Msk
#define PWR_PUCRF_PU15_Pos   (15U)
#define PWR_PUCRF_PU15_Msk   (0x1UL << PWR_PUCRF_PU15_Pos)
#define PWR_PUCRF_PU15   PWR_PUCRF_PU15_Msk
#define PWR_PDCRF_PD0_Pos   (0U)
#define PWR_PDCRF_PD0_Msk   (0x1UL << PWR_PDCRF_PD0_Pos)
#define PWR_PDCRF_PD0   PWR_PDCRF_PD0_Msk
#define PWR_PDCRF_PD1_Pos   (1U)
#define PWR_PDCRF_PD1_Msk   (0x1UL << PWR_PDCRF_PD1_Pos)
#define PWR_PDCRF_PD1   PWR_PDCRF_PD1_Msk
#define PWR_PDCRF_PD2_Pos   (2U)
#define PWR_PDCRF_PD2_Msk   (0x1UL << PWR_PDCRF_PD2_Pos)
#define PWR_PDCRF_PD2   PWR_PDCRF_PD2_Msk
#define PWR_PDCRF_PD3_Pos   (3U)
#define PWR_PDCRF_PD3_Msk   (0x1UL << PWR_PDCRF_PD3_Pos)
#define PWR_PDCRF_PD3   PWR_PDCRF_PD3_Msk
#define PWR_PDCRF_PD4_Pos   (4U)
#define PWR_PDCRF_PD4_Msk   (0x1UL << PWR_PDCRF_PD4_Pos)
#define PWR_PDCRF_PD4   PWR_PDCRF_PD4_Msk
#define PWR_PDCRF_PD5_Pos   (5U)
#define PWR_PDCRF_PD5_Msk   (0x1UL << PWR_PDCRF_PD5_Pos)
#define PWR_PDCRF_PD5   PWR_PDCRF_PD5_Msk
#define PWR_PDCRF_PD6_Pos   (6U)
#define PWR_PDCRF_PD6_Msk   (0x1UL << PWR_PDCRF_PD6_Pos)
#define PWR_PDCRF_PD6   PWR_PDCRF_PD6_Msk
#define PWR_PDCRF_PD7_Pos   (7U)
#define PWR_PDCRF_PD7_Msk   (0x1UL << PWR_PDCRF_PD7_Pos)
#define PWR_PDCRF_PD7   PWR_PDCRF_PD7_Msk
#define PWR_PDCRF_PD8_Pos   (8U)
#define PWR_PDCRF_PD8_Msk   (0x1UL << PWR_PDCRF_PD8_Pos)
#define PWR_PDCRF_PD8   PWR_PDCRF_PD8_Msk
#define PWR_PDCRF_PD9_Pos   (9U)
#define PWR_PDCRF_PD9_Msk   (0x1UL << PWR_PDCRF_PD9_Pos)
#define PWR_PDCRF_PD9   PWR_PDCRF_PD9_Msk
#define PWR_PDCRF_PD10_Pos   (10U)
#define PWR_PDCRF_PD10_Msk   (0x1UL << PWR_PDCRF_PD10_Pos)
#define PWR_PDCRF_PD10   PWR_PDCRF_PD10_Msk
#define PWR_PDCRF_PD11_Pos   (11U)
#define PWR_PDCRF_PD11_Msk   (0x1UL << PWR_PDCRF_PD11_Pos)
#define PWR_PDCRF_PD11   PWR_PDCRF_PD11_Msk
#define PWR_PDCRF_PD12_Pos   (12U)
#define PWR_PDCRF_PD12_Msk   (0x1UL << PWR_PDCRF_PD12_Pos)
#define PWR_PDCRF_PD12   PWR_PDCRF_PD12_Msk
#define PWR_PDCRF_PD13_Pos   (13U)
#define PWR_PDCRF_PD13_Msk   (0x1UL << PWR_PDCRF_PD13_Pos)
#define PWR_PDCRF_PD13   PWR_PDCRF_PD13_Msk
#define PWR_PDCRF_PD14_Pos   (14U)
#define PWR_PDCRF_PD14_Msk   (0x1UL << PWR_PDCRF_PD14_Pos)
#define PWR_PDCRF_PD14   PWR_PDCRF_PD14_Msk
#define PWR_PDCRF_PD15_Pos   (15U)
#define PWR_PDCRF_PD15_Msk   (0x1UL << PWR_PDCRF_PD15_Pos)
#define PWR_PDCRF_PD15   PWR_PDCRF_PD15_Msk
#define PWR_PUCRG_PU0_Pos   (0U)
#define PWR_PUCRG_PU0_Msk   (0x1UL << PWR_PUCRG_PU0_Pos)
#define PWR_PUCRG_PU0   PWR_PUCRG_PU0_Msk
#define PWR_PUCRG_PU1_Pos   (1U)
#define PWR_PUCRG_PU1_Msk   (0x1UL << PWR_PUCRG_PU1_Pos)
#define PWR_PUCRG_PU1   PWR_PUCRG_PU1_Msk
#define PWR_PUCRG_PU2_Pos   (2U)
#define PWR_PUCRG_PU2_Msk   (0x1UL << PWR_PUCRG_PU2_Pos)
#define PWR_PUCRG_PU2   PWR_PUCRG_PU2_Msk
#define PWR_PUCRG_PU3_Pos   (3U)
#define PWR_PUCRG_PU3_Msk   (0x1UL << PWR_PUCRG_PU3_Pos)
#define PWR_PUCRG_PU3   PWR_PUCRG_PU3_Msk
#define PWR_PUCRG_PU4_Pos   (4U)
#define PWR_PUCRG_PU4_Msk   (0x1UL << PWR_PUCRG_PU4_Pos)
#define PWR_PUCRG_PU4   PWR_PUCRG_PU4_Msk
#define PWR_PUCRG_PU5_Pos   (5U)
#define PWR_PUCRG_PU5_Msk   (0x1UL << PWR_PUCRG_PU5_Pos)
#define PWR_PUCRG_PU5   PWR_PUCRG_PU5_Msk
#define PWR_PUCRG_PU6_Pos   (6U)
#define PWR_PUCRG_PU6_Msk   (0x1UL << PWR_PUCRG_PU6_Pos)
#define PWR_PUCRG_PU6   PWR_PUCRG_PU6_Msk
#define PWR_PUCRG_PU7_Pos   (7U)
#define PWR_PUCRG_PU7_Msk   (0x1UL << PWR_PUCRG_PU7_Pos)
#define PWR_PUCRG_PU7   PWR_PUCRG_PU7_Msk
#define PWR_PUCRG_PU8_Pos   (8U)
#define PWR_PUCRG_PU8_Msk   (0x1UL << PWR_PUCRG_PU8_Pos)
#define PWR_PUCRG_PU8   PWR_PUCRG_PU8_Msk
#define PWR_PUCRG_PU9_Pos   (9U)
#define PWR_PUCRG_PU9_Msk   (0x1UL << PWR_PUCRG_PU9_Pos)
#define PWR_PUCRG_PU9   PWR_PUCRG_PU9_Msk
#define PWR_PUCRG_PU10_Pos   (10U)
#define PWR_PUCRG_PU10_Msk   (0x1UL << PWR_PUCRG_PU10_Pos)
#define PWR_PUCRG_PU10   PWR_PUCRG_PU10_Msk
#define PWR_PUCRG_PU11_Pos   (11U)
#define PWR_PUCRG_PU11_Msk   (0x1UL << PWR_PUCRG_PU11_Pos)
#define PWR_PUCRG_PU11   PWR_PUCRG_PU11_Msk
#define PWR_PUCRG_PU12_Pos   (12U)
#define PWR_PUCRG_PU12_Msk   (0x1UL << PWR_PUCRG_PU12_Pos)
#define PWR_PUCRG_PU12   PWR_PUCRG_PU12_Msk
#define PWR_PUCRG_PU13_Pos   (13U)
#define PWR_PUCRG_PU13_Msk   (0x1UL << PWR_PUCRG_PU13_Pos)
#define PWR_PUCRG_PU13   PWR_PUCRG_PU13_Msk
#define PWR_PUCRG_PU14_Pos   (14U)
#define PWR_PUCRG_PU14_Msk   (0x1UL << PWR_PUCRG_PU14_Pos)
#define PWR_PUCRG_PU14   PWR_PUCRG_PU14_Msk
#define PWR_PUCRG_PU15_Pos   (15U)
#define PWR_PUCRG_PU15_Msk   (0x1UL << PWR_PUCRG_PU15_Pos)
#define PWR_PUCRG_PU15   PWR_PUCRG_PU15_Msk
#define PWR_PDCRG_PD0_Pos   (0U)
#define PWR_PDCRG_PD0_Msk   (0x1UL << PWR_PDCRG_PD0_Pos)
#define PWR_PDCRG_PD0   PWR_PDCRG_PD0_Msk
#define PWR_PDCRG_PD1_Pos   (1U)
#define PWR_PDCRG_PD1_Msk   (0x1UL << PWR_PDCRG_PD1_Pos)
#define PWR_PDCRG_PD1   PWR_PDCRG_PD1_Msk
#define PWR_PDCRG_PD2_Pos   (2U)
#define PWR_PDCRG_PD2_Msk   (0x1UL << PWR_PDCRG_PD2_Pos)
#define PWR_PDCRG_PD2   PWR_PDCRG_PD2_Msk
#define PWR_PDCRG_PD3_Pos   (3U)
#define PWR_PDCRG_PD3_Msk   (0x1UL << PWR_PDCRG_PD3_Pos)
#define PWR_PDCRG_PD3   PWR_PDCRG_PD3_Msk
#define PWR_PDCRG_PD4_Pos   (4U)
#define PWR_PDCRG_PD4_Msk   (0x1UL << PWR_PDCRG_PD4_Pos)
#define PWR_PDCRG_PD4   PWR_PDCRG_PD4_Msk
#define PWR_PDCRG_PD5_Pos   (5U)
#define PWR_PDCRG_PD5_Msk   (0x1UL << PWR_PDCRG_PD5_Pos)
#define PWR_PDCRG_PD5   PWR_PDCRG_PD5_Msk
#define PWR_PDCRG_PD6_Pos   (6U)
#define PWR_PDCRG_PD6_Msk   (0x1UL << PWR_PDCRG_PD6_Pos)
#define PWR_PDCRG_PD6   PWR_PDCRG_PD6_Msk
#define PWR_PDCRG_PD7_Pos   (7U)
#define PWR_PDCRG_PD7_Msk   (0x1UL << PWR_PDCRG_PD7_Pos)
#define PWR_PDCRG_PD7   PWR_PDCRG_PD7_Msk
#define PWR_PDCRG_PD8_Pos   (8U)
#define PWR_PDCRG_PD8_Msk   (0x1UL << PWR_PDCRG_PD8_Pos)
#define PWR_PDCRG_PD8   PWR_PDCRG_PD8_Msk
#define PWR_PDCRG_PD9_Pos   (9U)
#define PWR_PDCRG_PD9_Msk   (0x1UL << PWR_PDCRG_PD9_Pos)
#define PWR_PDCRG_PD9   PWR_PDCRG_PD9_Msk
#define PWR_PDCRG_PD10_Pos   (10U)
#define PWR_PDCRG_PD10_Msk   (0x1UL << PWR_PDCRG_PD10_Pos)
#define PWR_PDCRG_PD10   PWR_PDCRG_PD10_Msk
#define PWR_PDCRG_PD11_Pos   (11U)
#define PWR_PDCRG_PD11_Msk   (0x1UL << PWR_PDCRG_PD11_Pos)
#define PWR_PDCRG_PD11   PWR_PDCRG_PD11_Msk
#define PWR_PDCRG_PD12_Pos   (12U)
#define PWR_PDCRG_PD12_Msk   (0x1UL << PWR_PDCRG_PD12_Pos)
#define PWR_PDCRG_PD12   PWR_PDCRG_PD12_Msk
#define PWR_PDCRG_PD13_Pos   (13U)
#define PWR_PDCRG_PD13_Msk   (0x1UL << PWR_PDCRG_PD13_Pos)
#define PWR_PDCRG_PD13   PWR_PDCRG_PD13_Msk
#define PWR_PDCRG_PD14_Pos   (14U)
#define PWR_PDCRG_PD14_Msk   (0x1UL << PWR_PDCRG_PD14_Pos)
#define PWR_PDCRG_PD14   PWR_PDCRG_PD14_Msk
#define PWR_PDCRG_PD15_Pos   (15U)
#define PWR_PDCRG_PD15_Msk   (0x1UL << PWR_PDCRG_PD15_Pos)
#define PWR_PDCRG_PD15   PWR_PDCRG_PD15_Msk
#define PWR_PUCRH_PU0_Pos   (0U)
#define PWR_PUCRH_PU0_Msk   (0x1UL << PWR_PUCRH_PU0_Pos)
#define PWR_PUCRH_PU0   PWR_PUCRH_PU0_Msk
#define PWR_PUCRH_PU1_Pos   (1U)
#define PWR_PUCRH_PU1_Msk   (0x1UL << PWR_PUCRH_PU1_Pos)
#define PWR_PUCRH_PU1   PWR_PUCRH_PU1_Msk
#define PWR_PUCRH_PU2_Pos   (2U)
#define PWR_PUCRH_PU2_Msk   (0x1UL << PWR_PUCRH_PU2_Pos)
#define PWR_PUCRH_PU2   PWR_PUCRH_PU2_Msk
#define PWR_PUCRH_PU3_Pos   (3U)
#define PWR_PUCRH_PU3_Msk   (0x1UL << PWR_PUCRH_PU3_Pos)
#define PWR_PUCRH_PU3   PWR_PUCRH_PU3_Msk
#define PWR_PUCRH_PU4_Pos   (4U)
#define PWR_PUCRH_PU4_Msk   (0x1UL << PWR_PUCRH_PU4_Pos)
#define PWR_PUCRH_PU4   PWR_PUCRH_PU4_Msk
#define PWR_PUCRH_PU5_Pos   (5U)
#define PWR_PUCRH_PU5_Msk   (0x1UL << PWR_PUCRH_PU5_Pos)
#define PWR_PUCRH_PU5   PWR_PUCRH_PU5_Msk
#define PWR_PUCRH_PU6_Pos   (6U)
#define PWR_PUCRH_PU6_Msk   (0x1UL << PWR_PUCRH_PU6_Pos)
#define PWR_PUCRH_PU6   PWR_PUCRH_PU6_Msk
#define PWR_PUCRH_PU7_Pos   (7U)
#define PWR_PUCRH_PU7_Msk   (0x1UL << PWR_PUCRH_PU7_Pos)
#define PWR_PUCRH_PU7   PWR_PUCRH_PU7_Msk
#define PWR_PUCRH_PU8_Pos   (8U)
#define PWR_PUCRH_PU8_Msk   (0x1UL << PWR_PUCRH_PU8_Pos)
#define PWR_PUCRH_PU8   PWR_PUCRH_PU8_Msk
#define PWR_PUCRH_PU9_Pos   (9U)
#define PWR_PUCRH_PU9_Msk   (0x1UL << PWR_PUCRH_PU9_Pos)
#define PWR_PUCRH_PU9   PWR_PUCRH_PU9_Msk
#define PWR_PUCRH_PU10_Pos   (10U)
#define PWR_PUCRH_PU10_Msk   (0x1UL << PWR_PUCRH_PU10_Pos)
#define PWR_PUCRH_PU10   PWR_PUCRH_PU10_Msk
#define PWR_PUCRH_PU11_Pos   (11U)
#define PWR_PUCRH_PU11_Msk   (0x1UL << PWR_PUCRH_PU11_Pos)
#define PWR_PUCRH_PU11   PWR_PUCRH_PU11_Msk
#define PWR_PUCRH_PU12_Pos   (12U)
#define PWR_PUCRH_PU12_Msk   (0x1UL << PWR_PUCRH_PU12_Pos)
#define PWR_PUCRH_PU12   PWR_PUCRH_PU12_Msk
#define PWR_PUCRH_PU13_Pos   (13U)
#define PWR_PUCRH_PU13_Msk   (0x1UL << PWR_PUCRH_PU13_Pos)
#define PWR_PUCRH_PU13   PWR_PUCRH_PU13_Msk
#define PWR_PUCRH_PU14_Pos   (14U)
#define PWR_PUCRH_PU14_Msk   (0x1UL << PWR_PUCRH_PU14_Pos)
#define PWR_PUCRH_PU14   PWR_PUCRH_PU14_Msk
#define PWR_PUCRH_PU15_Pos   (15U)
#define PWR_PUCRH_PU15_Msk   (0x1UL << PWR_PUCRH_PU15_Pos)
#define PWR_PUCRH_PU15   PWR_PUCRH_PU15_Msk
#define PWR_PDCRH_PD0_Pos   (0U)
#define PWR_PDCRH_PD0_Msk   (0x1UL << PWR_PDCRH_PD0_Pos)
#define PWR_PDCRH_PD0   PWR_PDCRH_PD0_Msk
#define PWR_PDCRH_PD1_Pos   (1U)
#define PWR_PDCRH_PD1_Msk   (0x1UL << PWR_PDCRH_PD1_Pos)
#define PWR_PDCRH_PD1   PWR_PDCRH_PD1_Msk
#define PWR_PDCRH_PD2_Pos   (2U)
#define PWR_PDCRH_PD2_Msk   (0x1UL << PWR_PDCRH_PD2_Pos)
#define PWR_PDCRH_PD2   PWR_PDCRH_PD2_Msk
#define PWR_PDCRH_PD3_Pos   (3U)
#define PWR_PDCRH_PD3_Msk   (0x1UL << PWR_PDCRH_PD3_Pos)
#define PWR_PDCRH_PD3   PWR_PDCRH_PD3_Msk
#define PWR_PDCRH_PD4_Pos   (4U)
#define PWR_PDCRH_PD4_Msk   (0x1UL << PWR_PDCRH_PD4_Pos)
#define PWR_PDCRH_PD4   PWR_PDCRH_PD4_Msk
#define PWR_PDCRH_PD5_Pos   (5U)
#define PWR_PDCRH_PD5_Msk   (0x1UL << PWR_PDCRH_PD5_Pos)
#define PWR_PDCRH_PD5   PWR_PDCRH_PD5_Msk
#define PWR_PDCRH_PD6_Pos   (6U)
#define PWR_PDCRH_PD6_Msk   (0x1UL << PWR_PDCRH_PD6_Pos)
#define PWR_PDCRH_PD6   PWR_PDCRH_PD6_Msk
#define PWR_PDCRH_PD7_Pos   (7U)
#define PWR_PDCRH_PD7_Msk   (0x1UL << PWR_PDCRH_PD7_Pos)
#define PWR_PDCRH_PD7   PWR_PDCRH_PD7_Msk
#define PWR_PDCRH_PD8_Pos   (8U)
#define PWR_PDCRH_PD8_Msk   (0x1UL << PWR_PDCRH_PD8_Pos)
#define PWR_PDCRH_PD8   PWR_PDCRH_PD8_Msk
#define PWR_PDCRH_PD9_Pos   (9U)
#define PWR_PDCRH_PD9_Msk   (0x1UL << PWR_PDCRH_PD9_Pos)
#define PWR_PDCRH_PD9   PWR_PDCRH_PD9_Msk
#define PWR_PDCRH_PD10_Pos   (10U)
#define PWR_PDCRH_PD10_Msk   (0x1UL << PWR_PDCRH_PD10_Pos)
#define PWR_PDCRH_PD10   PWR_PDCRH_PD10_Msk
#define PWR_PDCRH_PD11_Pos   (11U)
#define PWR_PDCRH_PD11_Msk   (0x1UL << PWR_PDCRH_PD11_Pos)
#define PWR_PDCRH_PD11   PWR_PDCRH_PD11_Msk
#define PWR_PDCRH_PD12_Pos   (12U)
#define PWR_PDCRH_PD12_Msk   (0x1UL << PWR_PDCRH_PD12_Pos)
#define PWR_PDCRH_PD12   PWR_PDCRH_PD12_Msk
#define PWR_PDCRH_PD13_Pos   (13U)
#define PWR_PDCRH_PD13_Msk   (0x1UL << PWR_PDCRH_PD13_Pos)
#define PWR_PDCRH_PD13   PWR_PDCRH_PD13_Msk
#define PWR_PDCRH_PD14_Pos   (14U)
#define PWR_PDCRH_PD14_Msk   (0x1UL << PWR_PDCRH_PD14_Pos)
#define PWR_PDCRH_PD14   PWR_PDCRH_PD14_Msk
#define PWR_PDCRH_PD15_Pos   (15U)
#define PWR_PDCRH_PD15_Msk   (0x1UL << PWR_PDCRH_PD15_Pos)
#define PWR_PDCRH_PD15   PWR_PDCRH_PD15_Msk
#define PWR_PUCRI_PU0_Pos   (0U)
#define PWR_PUCRI_PU0_Msk   (0x1UL << PWR_PUCRI_PU0_Pos)
#define PWR_PUCRI_PU0   PWR_PUCRI_PU0_Msk
#define PWR_PUCRI_PU1_Pos   (1U)
#define PWR_PUCRI_PU1_Msk   (0x1UL << PWR_PUCRI_PU1_Pos)
#define PWR_PUCRI_PU1   PWR_PUCRI_PU1_Msk
#define PWR_PUCRI_PU2_Pos   (2U)
#define PWR_PUCRI_PU2_Msk   (0x1UL << PWR_PUCRI_PU2_Pos)
#define PWR_PUCRI_PU2   PWR_PUCRI_PU2_Msk
#define PWR_PUCRI_PU3_Pos   (3U)
#define PWR_PUCRI_PU3_Msk   (0x1UL << PWR_PUCRI_PU3_Pos)
#define PWR_PUCRI_PU3   PWR_PUCRI_PU3_Msk
#define PWR_PUCRI_PU4_Pos   (4U)
#define PWR_PUCRI_PU4_Msk   (0x1UL << PWR_PUCRI_PU4_Pos)
#define PWR_PUCRI_PU4   PWR_PUCRI_PU4_Msk
#define PWR_PUCRI_PU5_Pos   (5U)
#define PWR_PUCRI_PU5_Msk   (0x1UL << PWR_PUCRI_PU5_Pos)
#define PWR_PUCRI_PU5   PWR_PUCRI_PU5_Msk
#define PWR_PUCRI_PU6_Pos   (6U)
#define PWR_PUCRI_PU6_Msk   (0x1UL << PWR_PUCRI_PU6_Pos)
#define PWR_PUCRI_PU6   PWR_PUCRI_PU6_Msk
#define PWR_PUCRI_PU7_Pos   (7U)
#define PWR_PUCRI_PU7_Msk   (0x1UL << PWR_PUCRI_PU7_Pos)
#define PWR_PUCRI_PU7   PWR_PUCRI_PU7_Msk
#define PWR_PUCRI_PU8_Pos   (8U)
#define PWR_PUCRI_PU8_Msk   (0x1UL << PWR_PUCRI_PU8_Pos)
#define PWR_PUCRI_PU8   PWR_PUCRI_PU8_Msk
#define PWR_PUCRI_PU9_Pos   (9U)
#define PWR_PUCRI_PU9_Msk   (0x1UL << PWR_PUCRI_PU9_Pos)
#define PWR_PUCRI_PU9   PWR_PUCRI_PU9_Msk
#define PWR_PUCRI_PU10_Pos   (10U)
#define PWR_PUCRI_PU10_Msk   (0x1UL << PWR_PUCRI_PU10_Pos)
#define PWR_PUCRI_PU10   PWR_PUCRI_PU10_Msk
#define PWR_PUCRI_PU11_Pos   (11U)
#define PWR_PUCRI_PU11_Msk   (0x1UL << PWR_PUCRI_PU11_Pos)
#define PWR_PUCRI_PU11   PWR_PUCRI_PU11_Msk
#define PWR_PUCRI_PU12_Pos   (12U)
#define PWR_PUCRI_PU12_Msk   (0x1UL << PWR_PUCRI_PU12_Pos)
#define PWR_PUCRI_PU12   PWR_PUCRI_PU12_Msk
#define PWR_PUCRI_PU13_Pos   (13U)
#define PWR_PUCRI_PU13_Msk   (0x1UL << PWR_PUCRI_PU13_Pos)
#define PWR_PUCRI_PU13   PWR_PUCRI_PU13_Msk
#define PWR_PUCRI_PU14_Pos   (14U)
#define PWR_PUCRI_PU14_Msk   (0x1UL << PWR_PUCRI_PU14_Pos)
#define PWR_PUCRI_PU14   PWR_PUCRI_PU14_Msk
#define PWR_PUCRI_PU15_Pos   (15U)
#define PWR_PUCRI_PU15_Msk   (0x1UL << PWR_PUCRI_PU15_Pos)
#define PWR_PUCRI_PU15   PWR_PUCRI_PU15_Msk
#define PWR_PDCRI_PD0_Pos   (0U)
#define PWR_PDCRI_PD0_Msk   (0x1UL << PWR_PDCRI_PD0_Pos)
#define PWR_PDCRI_PD0   PWR_PDCRI_PD0_Msk
#define PWR_PDCRI_PD1_Pos   (1U)
#define PWR_PDCRI_PD1_Msk   (0x1UL << PWR_PDCRI_PD1_Pos)
#define PWR_PDCRI_PD1   PWR_PDCRI_PD1_Msk
#define PWR_PDCRI_PD2_Pos   (2U)
#define PWR_PDCRI_PD2_Msk   (0x1UL << PWR_PDCRI_PD2_Pos)
#define PWR_PDCRI_PD2   PWR_PDCRI_PD2_Msk
#define PWR_PDCRI_PD3_Pos   (3U)
#define PWR_PDCRI_PD3_Msk   (0x1UL << PWR_PDCRI_PD3_Pos)
#define PWR_PDCRI_PD3   PWR_PDCRI_PD3_Msk
#define PWR_PDCRI_PD4_Pos   (4U)
#define PWR_PDCRI_PD4_Msk   (0x1UL << PWR_PDCRI_PD4_Pos)
#define PWR_PDCRI_PD4   PWR_PDCRI_PD4_Msk
#define PWR_PDCRI_PD5_Pos   (5U)
#define PWR_PDCRI_PD5_Msk   (0x1UL << PWR_PDCRI_PD5_Pos)
#define PWR_PDCRI_PD5   PWR_PDCRI_PD5_Msk
#define PWR_PDCRI_PD6_Pos   (6U)
#define PWR_PDCRI_PD6_Msk   (0x1UL << PWR_PDCRI_PD6_Pos)
#define PWR_PDCRI_PD6   PWR_PDCRI_PD6_Msk
#define PWR_PDCRI_PD7_Pos   (7U)
#define PWR_PDCRI_PD7_Msk   (0x1UL << PWR_PDCRI_PD7_Pos)
#define PWR_PDCRI_PD7   PWR_PDCRI_PD7_Msk
#define PWR_PDCRI_PD8_Pos   (8U)
#define PWR_PDCRI_PD8_Msk   (0x1UL << PWR_PDCRI_PD8_Pos)
#define PWR_PDCRI_PD8   PWR_PDCRI_PD8_Msk
#define PWR_PDCRI_PD9_Pos   (9U)
#define PWR_PDCRI_PD9_Msk   (0x1UL << PWR_PDCRI_PD9_Pos)
#define PWR_PDCRI_PD9   PWR_PDCRI_PD9_Msk
#define PWR_PDCRI_PD10_Pos   (10U)
#define PWR_PDCRI_PD10_Msk   (0x1UL << PWR_PDCRI_PD10_Pos)
#define PWR_PDCRI_PD10   PWR_PDCRI_PD10_Msk
#define PWR_PDCRI_PD11_Pos   (11U)
#define PWR_PDCRI_PD11_Msk   (0x1UL << PWR_PDCRI_PD11_Pos)
#define PWR_PDCRI_PD11   PWR_PDCRI_PD11_Msk
#define PWR_PDCRI_PD12_Pos   (12U)
#define PWR_PDCRI_PD12_Msk   (0x1UL << PWR_PDCRI_PD12_Pos)
#define PWR_PDCRI_PD12   PWR_PDCRI_PD12_Msk
#define PWR_PDCRI_PD13_Pos   (13U)
#define PWR_PDCRI_PD13_Msk   (0x1UL << PWR_PDCRI_PD13_Pos)
#define PWR_PDCRI_PD13   PWR_PDCRI_PD13_Msk
#define PWR_PDCRI_PD14_Pos   (14U)
#define PWR_PDCRI_PD14_Msk   (0x1UL << PWR_PDCRI_PD14_Pos)
#define PWR_PDCRI_PD14   PWR_PDCRI_PD14_Msk
#define PWR_PDCRI_PD15_Pos   (15U)
#define PWR_PDCRI_PD15_Msk   (0x1UL << PWR_PDCRI_PD15_Pos)
#define PWR_PDCRI_PD15   PWR_PDCRI_PD15_Msk
#define PWR_PUCRJ_PU0_Pos   (0U)
#define PWR_PUCRJ_PU0_Msk   (0x1UL << PWR_PUCRJ_PU0_Pos)
#define PWR_PUCRJ_PU0   PWR_PUCRJ_PU0_Msk
#define PWR_PUCRJ_PU1_Pos   (1U)
#define PWR_PUCRJ_PU1_Msk   (0x1UL << PWR_PUCRJ_PU1_Pos)
#define PWR_PUCRJ_PU1   PWR_PUCRJ_PU1_Msk
#define PWR_PUCRJ_PU2_Pos   (2U)
#define PWR_PUCRJ_PU2_Msk   (0x1UL << PWR_PUCRJ_PU2_Pos)
#define PWR_PUCRJ_PU2   PWR_PUCRJ_PU2_Msk
#define PWR_PUCRJ_PU3_Pos   (3U)
#define PWR_PUCRJ_PU3_Msk   (0x1UL << PWR_PUCRJ_PU3_Pos)
#define PWR_PUCRJ_PU3   PWR_PUCRJ_PU3_Msk
#define PWR_PUCRJ_PU4_Pos   (4U)
#define PWR_PUCRJ_PU4_Msk   (0x1UL << PWR_PUCRJ_PU4_Pos)
#define PWR_PUCRJ_PU4   PWR_PUCRJ_PU4_Msk
#define PWR_PUCRJ_PU5_Pos   (5U)
#define PWR_PUCRJ_PU5_Msk   (0x1UL << PWR_PUCRJ_PU5_Pos)
#define PWR_PUCRJ_PU5   PWR_PUCRJ_PU5_Msk
#define PWR_PUCRJ_PU6_Pos   (6U)
#define PWR_PUCRJ_PU6_Msk   (0x1UL << PWR_PUCRJ_PU6_Pos)
#define PWR_PUCRJ_PU6   PWR_PUCRJ_PU6_Msk
#define PWR_PUCRJ_PU7_Pos   (7U)
#define PWR_PUCRJ_PU7_Msk   (0x1UL << PWR_PUCRJ_PU7_Pos)
#define PWR_PUCRJ_PU7   PWR_PUCRJ_PU7_Msk
#define PWR_PUCRJ_PU8_Pos   (8U)
#define PWR_PUCRJ_PU8_Msk   (0x1UL << PWR_PUCRJ_PU8_Pos)
#define PWR_PUCRJ_PU8   PWR_PUCRJ_PU8_Msk
#define PWR_PUCRJ_PU9_Pos   (9U)
#define PWR_PUCRJ_PU9_Msk   (0x1UL << PWR_PUCRJ_PU9_Pos)
#define PWR_PUCRJ_PU9   PWR_PUCRJ_PU9_Msk
#define PWR_PUCRJ_PU10_Pos   (10U)
#define PWR_PUCRJ_PU10_Msk   (0x1UL << PWR_PUCRJ_PU10_Pos)
#define PWR_PUCRJ_PU10   PWR_PUCRJ_PU10_Msk
#define PWR_PUCRJ_PU11_Pos   (11U)
#define PWR_PUCRJ_PU11_Msk   (0x1UL << PWR_PUCRJ_PU11_Pos)
#define PWR_PUCRJ_PU11   PWR_PUCRJ_PU11_Msk
#define PWR_PDCRJ_PD0_Pos   (0U)
#define PWR_PDCRJ_PD0_Msk   (0x1UL << PWR_PDCRJ_PD0_Pos)
#define PWR_PDCRJ_PD0   PWR_PDCRJ_PD0_Msk
#define PWR_PDCRJ_PD1_Pos   (1U)
#define PWR_PDCRJ_PD1_Msk   (0x1UL << PWR_PDCRJ_PD1_Pos)
#define PWR_PDCRJ_PD1   PWR_PDCRJ_PD1_Msk
#define PWR_PDCRJ_PD2_Pos   (2U)
#define PWR_PDCRJ_PD2_Msk   (0x1UL << PWR_PDCRJ_PD2_Pos)
#define PWR_PDCRJ_PD2   PWR_PDCRJ_PD2_Msk
#define PWR_PDCRJ_PD3_Pos   (3U)
#define PWR_PDCRJ_PD3_Msk   (0x1UL << PWR_PDCRJ_PD3_Pos)
#define PWR_PDCRJ_PD3   PWR_PDCRJ_PD3_Msk
#define PWR_PDCRJ_PD4_Pos   (4U)
#define PWR_PDCRJ_PD4_Msk   (0x1UL << PWR_PDCRJ_PD4_Pos)
#define PWR_PDCRJ_PD4   PWR_PDCRJ_PD4_Msk
#define PWR_PDCRJ_PD5_Pos   (5U)
#define PWR_PDCRJ_PD5_Msk   (0x1UL << PWR_PDCRJ_PD5_Pos)
#define PWR_PDCRJ_PD5   PWR_PDCRJ_PD5_Msk
#define PWR_PDCRJ_PD6_Pos   (6U)
#define PWR_PDCRJ_PD6_Msk   (0x1UL << PWR_PDCRJ_PD6_Pos)
#define PWR_PDCRJ_PD6   PWR_PDCRJ_PD6_Msk
#define PWR_PDCRJ_PD7_Pos   (7U)
#define PWR_PDCRJ_PD7_Msk   (0x1UL << PWR_PDCRJ_PD7_Pos)
#define PWR_PDCRJ_PD7   PWR_PDCRJ_PD7_Msk
#define PWR_PDCRJ_PD8_Pos   (8U)
#define PWR_PDCRJ_PD8_Msk   (0x1UL << PWR_PDCRJ_PD8_Pos)
#define PWR_PDCRJ_PD8   PWR_PDCRJ_PD8_Msk
#define PWR_PDCRJ_PD9_Pos   (9U)
#define PWR_PDCRJ_PD9_Msk   (0x1UL << PWR_PDCRJ_PD9_Pos)
#define PWR_PDCRJ_PD9   PWR_PDCRJ_PD9_Msk
#define PWR_PDCRJ_PD10_Pos   (10U)
#define PWR_PDCRJ_PD10_Msk   (0x1UL << PWR_PDCRJ_PD10_Pos)
#define PWR_PDCRJ_PD10   PWR_PDCRJ_PD10_Msk
#define PWR_PDCRJ_PD11_Pos   (11U)
#define PWR_PDCRJ_PD11_Msk   (0x1UL << PWR_PDCRJ_PD11_Pos)
#define PWR_PDCRJ_PD11   PWR_PDCRJ_PD11_Msk
#define PWR_CR4_SRAM1PDS4_Pos   (0U)
#define PWR_CR4_SRAM1PDS4_Msk   (0x1UL << PWR_CR4_SRAM1PDS4_Pos)
#define PWR_CR4_SRAM1PDS4   PWR_CR4_SRAM1PDS4_Msk
#define PWR_CR4_SRAM1PDS5_Pos   (1U)
#define PWR_CR4_SRAM1PDS5_Msk   (0x1UL << PWR_CR4_SRAM1PDS5_Pos)
#define PWR_CR4_SRAM1PDS5   PWR_CR4_SRAM1PDS5_Msk
#define PWR_CR4_SRAM1PDS6_Pos   (2U)
#define PWR_CR4_SRAM1PDS6_Msk   (0x1UL << PWR_CR4_SRAM1PDS6_Pos)
#define PWR_CR4_SRAM1PDS6   PWR_CR4_SRAM1PDS6_Msk
#define PWR_CR4_SRAM1PDS7_Pos   (3U)
#define PWR_CR4_SRAM1PDS7_Msk   (0x1UL << PWR_CR4_SRAM1PDS7_Pos)
#define PWR_CR4_SRAM1PDS7   PWR_CR4_SRAM1PDS7_Msk
#define PWR_CR4_SRAM1PDS8_Pos   (4U)
#define PWR_CR4_SRAM1PDS8_Msk   (0x1UL << PWR_CR4_SRAM1PDS8_Pos)
#define PWR_CR4_SRAM1PDS8   PWR_CR4_SRAM1PDS8_Msk
#define PWR_CR4_SRAM1PDS9_Pos   (5U)
#define PWR_CR4_SRAM1PDS9_Msk   (0x1UL << PWR_CR4_SRAM1PDS9_Pos)
#define PWR_CR4_SRAM1PDS9   PWR_CR4_SRAM1PDS9_Msk
#define PWR_CR4_SRAM1PDS10_Pos   (6U)
#define PWR_CR4_SRAM1PDS10_Msk   (0x1UL << PWR_CR4_SRAM1PDS10_Pos)
#define PWR_CR4_SRAM1PDS10   PWR_CR4_SRAM1PDS10_Msk
#define PWR_CR4_SRAM1PDS11_Pos   (7U)
#define PWR_CR4_SRAM1PDS11_Msk   (0x1UL << PWR_CR4_SRAM1PDS11_Pos)
#define PWR_CR4_SRAM1PDS11   PWR_CR4_SRAM1PDS11_Msk
#define PWR_CR4_SRAM1PDS12_Pos   (8U)
#define PWR_CR4_SRAM1PDS12_Msk   (0x1UL << PWR_CR4_SRAM1PDS12_Pos)
#define PWR_CR4_SRAM1PDS12   PWR_CR4_SRAM1PDS12_Msk
#define PWR_CR4_SRAM3PDS9_Pos   (10U)
#define PWR_CR4_SRAM3PDS9_Msk   (0x1UL << PWR_CR4_SRAM3PDS9_Pos)
#define PWR_CR4_SRAM3PDS9   PWR_CR4_SRAM3PDS9_Msk
#define PWR_CR4_SRAM3PDS10_Pos   (11U)
#define PWR_CR4_SRAM3PDS10_Msk   (0x1UL << PWR_CR4_SRAM3PDS10_Pos)
#define PWR_CR4_SRAM3PDS10   PWR_CR4_SRAM3PDS10_Msk
#define PWR_CR4_SRAM3PDS11_Pos   (12U)
#define PWR_CR4_SRAM3PDS11_Msk   (0x1UL << PWR_CR4_SRAM3PDS11_Pos)
#define PWR_CR4_SRAM3PDS11   PWR_CR4_SRAM3PDS11_Msk
#define PWR_CR4_SRAM3PDS12_Pos   (13U)
#define PWR_CR4_SRAM3PDS12_Msk   (0x1UL << PWR_CR4_SRAM3PDS12_Pos)
#define PWR_CR4_SRAM3PDS12   PWR_CR4_SRAM3PDS12_Msk
#define PWR_CR4_SRAM3PDS13_Pos   (14U)
#define PWR_CR4_SRAM3PDS13_Msk   (0x1UL << PWR_CR4_SRAM3PDS13_Pos)
#define PWR_CR4_SRAM3PDS13   PWR_CR4_SRAM3PDS13_Msk
#define PWR_CR4_SRAM5PDS1_Pos   (16U)
#define PWR_CR4_SRAM5PDS1_Msk   (0x1UL << PWR_CR4_SRAM5PDS1_Pos)
#define PWR_CR4_SRAM5PDS1   PWR_CR4_SRAM5PDS1_Msk
#define PWR_CR4_SRAM5PDS2_Pos   (17U)
#define PWR_CR4_SRAM5PDS2_Msk   (0x1UL << PWR_CR4_SRAM5PDS2_Pos)
#define PWR_CR4_SRAM5PDS2   PWR_CR4_SRAM5PDS2_Msk
#define PWR_CR4_SRAM5PDS3_Pos   (18U)
#define PWR_CR4_SRAM5PDS3_Msk   (0x1UL << PWR_CR4_SRAM5PDS3_Pos)
#define PWR_CR4_SRAM5PDS3   PWR_CR4_SRAM5PDS3_Msk
#define PWR_CR4_SRAM5PDS4_Pos   (19U)
#define PWR_CR4_SRAM5PDS4_Msk   (0x1UL << PWR_CR4_SRAM5PDS4_Pos)
#define PWR_CR4_SRAM5PDS4   PWR_CR4_SRAM5PDS4_Msk
#define PWR_CR4_SRAM5PDS5_Pos   (20U)
#define PWR_CR4_SRAM5PDS5_Msk   (0x1UL << PWR_CR4_SRAM5PDS5_Pos)
#define PWR_CR4_SRAM5PDS5   PWR_CR4_SRAM5PDS5_Msk
#define PWR_CR4_SRAM5PDS6_Pos   (21U)
#define PWR_CR4_SRAM5PDS6_Msk   (0x1UL << PWR_CR4_SRAM5PDS6_Pos)
#define PWR_CR4_SRAM5PDS6   PWR_CR4_SRAM5PDS6_Msk
#define PWR_CR4_SRAM5PDS7_Pos   (22U)
#define PWR_CR4_SRAM5PDS7_Msk   (0x1UL << PWR_CR4_SRAM5PDS7_Pos)
#define PWR_CR4_SRAM5PDS7   PWR_CR4_SRAM5PDS7_Msk
#define PWR_CR4_SRAM5PDS8_Pos   (23U)
#define PWR_CR4_SRAM5PDS8_Msk   (0x1UL << PWR_CR4_SRAM5PDS8_Pos)
#define PWR_CR4_SRAM5PDS8   PWR_CR4_SRAM5PDS8_Msk
#define PWR_CR4_SRAM5PDS9_Pos   (24U)
#define PWR_CR4_SRAM5PDS9_Msk   (0x1UL << PWR_CR4_SRAM5PDS9_Pos)
#define PWR_CR4_SRAM5PDS9   PWR_CR4_SRAM5PDS9_Msk
#define PWR_CR4_SRAM5PDS10_Pos   (25U)
#define PWR_CR4_SRAM5PDS10_Msk   (0x1UL << PWR_CR4_SRAM5PDS10_Pos)
#define PWR_CR4_SRAM5PDS10   PWR_CR4_SRAM5PDS10_Msk
#define PWR_CR4_SRAM5PDS11_Pos   (26U)
#define PWR_CR4_SRAM5PDS11_Msk   (0x1UL << PWR_CR4_SRAM5PDS11_Pos)
#define PWR_CR4_SRAM5PDS11   PWR_CR4_SRAM5PDS11_Msk
#define PWR_CR4_SRAM5PDS12_Pos   (27U)
#define PWR_CR4_SRAM5PDS12_Msk   (0x1UL << PWR_CR4_SRAM5PDS12_Pos)
#define PWR_CR4_SRAM5PDS12   PWR_CR4_SRAM5PDS12_Msk
#define PWR_CR4_SRAM5PDS13_Pos   (28U)
#define PWR_CR4_SRAM5PDS13_Msk   (0x1UL << PWR_CR4_SRAM5PDS13_Pos)
#define PWR_CR4_SRAM5PDS13   PWR_CR4_SRAM5PDS13_Msk
#define PWR_CR5_SRAM6PDS1_Pos   (0U)
#define PWR_CR5_SRAM6PDS1_Msk   (0x1UL << PWR_CR5_SRAM6PDS1_Pos)
#define PWR_CR5_SRAM6PDS1   PWR_CR5_SRAM6PDS1_Msk
#define PWR_CR5_SRAM6PDS2_Pos   (1U)
#define PWR_CR5_SRAM6PDS2_Msk   (0x1UL << PWR_CR5_SRAM6PDS2_Pos)
#define PWR_CR5_SRAM6PDS2   PWR_CR5_SRAM6PDS2_Msk
#define PWR_CR5_SRAM6PDS3_Pos   (2U)
#define PWR_CR5_SRAM6PDS3_Msk   (0x1UL << PWR_CR5_SRAM6PDS3_Pos)
#define PWR_CR5_SRAM6PDS3   PWR_CR5_SRAM6PDS3_Msk
#define PWR_CR5_SRAM6PDS4_Pos   (3U)
#define PWR_CR5_SRAM6PDS4_Msk   (0x1UL << PWR_CR5_SRAM6PDS4_Pos)
#define PWR_CR5_SRAM6PDS4   PWR_CR5_SRAM6PDS4_Msk
#define PWR_CR5_SRAM6PDS5_Pos   (4U)
#define PWR_CR5_SRAM6PDS5_Msk   (0x1UL << PWR_CR5_SRAM6PDS5_Pos)
#define PWR_CR5_SRAM6PDS5   PWR_CR5_SRAM6PDS5_Msk
#define PWR_CR5_SRAM6PDS6_Pos   (5U)
#define PWR_CR5_SRAM6PDS6_Msk   (0x1UL << PWR_CR5_SRAM6PDS6_Pos)
#define PWR_CR5_SRAM6PDS6   PWR_CR5_SRAM6PDS6_Msk
#define PWR_CR5_SRAM6PDS7_Pos   (6U)
#define PWR_CR5_SRAM6PDS7_Msk   (0x1UL << PWR_CR5_SRAM6PDS7_Pos)
#define PWR_CR5_SRAM6PDS7   PWR_CR5_SRAM6PDS7_Msk
#define PWR_CR5_SRAM6PDS8_Pos   (7U)
#define PWR_CR5_SRAM6PDS8_Msk   (0x1UL << PWR_CR5_SRAM6PDS8_Pos)
#define PWR_CR5_SRAM6PDS8   PWR_CR5_SRAM6PDS8_Msk
#define RAMCFG_CR_ECCE_Pos   (0U)
#define RAMCFG_CR_ECCE_Msk   (0x1UL << RAMCFG_CR_ECCE_Pos)
#define RAMCFG_CR_ECCE   RAMCFG_CR_ECCE_Msk
#define RAMCFG_CR_ALE_Pos   (4U)
#define RAMCFG_CR_ALE_Msk   (0x1UL << RAMCFG_CR_ALE_Pos)
#define RAMCFG_CR_ALE   RAMCFG_CR_ALE_Msk
#define RAMCFG_CR_SRAMER_Pos   (8U)
#define RAMCFG_CR_SRAMER_Msk   (0x1UL << RAMCFG_CR_SRAMER_Pos)
#define RAMCFG_CR_SRAMER   RAMCFG_CR_SRAMER_Msk
#define RAMCFG_CR_WSC_Pos   (16U)
#define RAMCFG_CR_WSC_Msk   (0x7UL << RAMCFG_CR_WSC_Pos)
#define RAMCFG_CR_WSC   RAMCFG_CR_WSC_Msk
#define RAMCFG_CR_WSC_0   (0x1UL << RAMCFG_CR_WSC_Pos)
#define RAMCFG_CR_WSC_1   (0x2UL << RAMCFG_CR_WSC_Pos)
#define RAMCFG_CR_WSC_2   (0x4UL << RAMCFG_CR_WSC_Pos)
#define RAMCFG_IER_SEIE_Pos   (0U)
#define RAMCFG_IER_SEIE_Msk   (0x1UL << RAMCFG_IER_SEIE_Pos)
#define RAMCFG_IER_SEIE   RAMCFG_IER_SEIE_Msk
#define RAMCFG_IER_DEIE_Pos   (1U)
#define RAMCFG_IER_DEIE_Msk   (0x1UL << RAMCFG_IER_DEIE_Pos)
#define RAMCFG_IER_DEIE   RAMCFG_IER_DEIE_Msk
#define RAMCFG_IER_ECCNMI_Pos   (3U)
#define RAMCFG_IER_ECCNMI_Msk   (0x1UL << RAMCFG_IER_ECCNMI_Pos)
#define RAMCFG_IER_ECCNMI   RAMCFG_IER_ECCNMI_Msk
#define RAMCFG_ISR_SEDC_Pos   (0U)
#define RAMCFG_ISR_SEDC_Msk   (0x1UL << RAMCFG_ISR_SEDC_Pos)
#define RAMCFG_ISR_SEDC   RAMCFG_ISR_SEDC_Msk
#define RAMCFG_ISR_DED_Pos   (1U)
#define RAMCFG_ISR_DED_Msk   (0x1UL << RAMCFG_ISR_DED_Pos)
#define RAMCFG_ISR_DED   RAMCFG_ISR_DED_Msk
#define RAMCFG_ISR_SRAMBUSY_Pos   (8U)
#define RAMCFG_ISR_SRAMBUSY_Msk   (0x1UL << RAMCFG_ISR_SRAMBUSY_Pos)
#define RAMCFG_ISR_SRAMBUSY   RAMCFG_ISR_SRAMBUSY_Msk
#define RAMCFG_SEAR_ESEA_Pos   (0U)
#define RAMCFG_SEAR_ESEA_Msk   (0xFFFFFFFFUL << RAMCFG_SEAR_ESEA_Pos)
#define RAMCFG_SEAR_ESEA   RAMCFG_SEAR_ESEA_Msk
#define RAMCFG_DEAR_EDEA_Pos   (0U)
#define RAMCFG_DEAR_EDEA_Msk   (0xFFFFFFFFUL << RAMCFG_DEAR_EDEA_Pos)
#define RAMCFG_DEAR_EDEA   RAMCFG_DEAR_EDEA_Msk
#define RAMCFG_ICR_CSEDC_Pos   (0U)
#define RAMCFG_ICR_CSEDC_Msk   (0x1UL << RAMCFG_ICR_CSEDC_Pos)
#define RAMCFG_ICR_CSEDC   RAMCFG_ICR_CSEDC_Msk
#define RAMCFG_ICR_CDED_Pos   (1U)
#define RAMCFG_ICR_CDED_Msk   (0x1UL << RAMCFG_ICR_CDED_Pos)
#define RAMCFG_ICR_CDED   RAMCFG_ICR_CDED_Msk
#define RAMCFG_WPR1_P0WP_Pos   (0U)
#define RAMCFG_WPR1_P0WP_Msk   (0x1UL << RAMCFG_WPR1_P0WP_Pos)
#define RAMCFG_WPR1_P0WP   RAMCFG_WPR1_P0WP_Msk
#define RAMCFG_WPR1_P1WP_Pos   (1U)
#define RAMCFG_WPR1_P1WP_Msk   (0x1UL << RAMCFG_WPR1_P1WP_Pos)
#define RAMCFG_WPR1_P1WP   RAMCFG_WPR1_P1WP_Msk
#define RAMCFG_WPR1_P2WP_Pos   (2U)
#define RAMCFG_WPR1_P2WP_Msk   (0x1UL << RAMCFG_WPR1_P2WP_Pos)
#define RAMCFG_WPR1_P2WP   RAMCFG_WPR1_P2WP_Msk
#define RAMCFG_WPR1_P3WP_Pos   (3U)
#define RAMCFG_WPR1_P3WP_Msk   (0x1UL << RAMCFG_WPR1_P3WP_Pos)
#define RAMCFG_WPR1_P3WP   RAMCFG_WPR1_P3WP_Msk
#define RAMCFG_WPR1_P4WP_Pos   (4U)
#define RAMCFG_WPR1_P4WP_Msk   (0x1UL << RAMCFG_WPR1_P4WP_Pos)
#define RAMCFG_WPR1_P4WP   RAMCFG_WPR1_P4WP_Msk
#define RAMCFG_WPR1_P5WP_Pos   (5U)
#define RAMCFG_WPR1_P5WP_Msk   (0x1UL << RAMCFG_WPR1_P5WP_Pos)
#define RAMCFG_WPR1_P5WP   RAMCFG_WPR1_P5WP_Msk
#define RAMCFG_WPR1_P6WP_Pos   (6U)
#define RAMCFG_WPR1_P6WP_Msk   (0x1UL << RAMCFG_WPR1_P6WP_Pos)
#define RAMCFG_WPR1_P6WP   RAMCFG_WPR1_P6WP_Msk
#define RAMCFG_WPR1_P7WP_Pos   (7U)
#define RAMCFG_WPR1_P7WP_Msk   (0x1UL << RAMCFG_WPR1_P7WP_Pos)
#define RAMCFG_WPR1_P7WP   RAMCFG_WPR1_P7WP_Msk
#define RAMCFG_WPR1_P8WP_Pos   (8U)
#define RAMCFG_WPR1_P8WP_Msk   (0x1UL << RAMCFG_WPR1_P8WP_Pos)
#define RAMCFG_WPR1_P8WP   RAMCFG_WPR1_P8WP_Msk
#define RAMCFG_WPR1_P9WP_Pos   (9U)
#define RAMCFG_WPR1_P9WP_Msk   (0x1UL << RAMCFG_WPR1_P9WP_Pos)
#define RAMCFG_WPR1_P9WP   RAMCFG_WPR1_P9WP_Msk
#define RAMCFG_WPR1_P10WP_Pos   (10U)
#define RAMCFG_WPR1_P10WP_Msk   (0x1UL << RAMCFG_WPR1_P10WP_Pos)
#define RAMCFG_WPR1_P10WP   RAMCFG_WPR1_P10WP_Msk
#define RAMCFG_WPR1_P11WP_Pos   (11U)
#define RAMCFG_WPR1_P11WP_Msk   (0x1UL << RAMCFG_WPR1_P11WP_Pos)
#define RAMCFG_WPR1_P11WP   RAMCFG_WPR1_P11WP_Msk
#define RAMCFG_WPR1_P12WP_Pos   (12U)
#define RAMCFG_WPR1_P12WP_Msk   (0x1UL << RAMCFG_WPR1_P12WP_Pos)
#define RAMCFG_WPR1_P12WP   RAMCFG_WPR1_P12WP_Msk
#define RAMCFG_WPR1_P13WP_Pos   (13U)
#define RAMCFG_WPR1_P13WP_Msk   (0x1UL << RAMCFG_WPR1_P13WP_Pos)
#define RAMCFG_WPR1_P13WP   RAMCFG_WPR1_P13WP_Msk
#define RAMCFG_WPR1_P14WP_Pos   (14U)
#define RAMCFG_WPR1_P14WP_Msk   (0x1UL << RAMCFG_WPR1_P14WP_Pos)
#define RAMCFG_WPR1_P14WP   RAMCFG_WPR1_P14WP_Msk
#define RAMCFG_WPR1_P15WP_Pos   (15U)
#define RAMCFG_WPR1_P15WP_Msk   (0x1UL << RAMCFG_WPR1_P15WP_Pos)
#define RAMCFG_WPR1_P15WP   RAMCFG_WPR1_P15WP_Msk
#define RAMCFG_WPR1_P16WP_Pos   (16U)
#define RAMCFG_WPR1_P16WP_Msk   (0x1UL << RAMCFG_WPR1_P16WP_Pos)
#define RAMCFG_WPR1_P16WP   RAMCFG_WPR1_P16WP_Msk
#define RAMCFG_WPR1_P17WP_Pos   (17U)
#define RAMCFG_WPR1_P17WP_Msk   (0x1UL << RAMCFG_WPR1_P17WP_Pos)
#define RAMCFG_WPR1_P17WP   RAMCFG_WPR1_P17WP_Msk
#define RAMCFG_WPR1_P18WP_Pos   (18U)
#define RAMCFG_WPR1_P18WP_Msk   (0x1UL << RAMCFG_WPR1_P18WP_Pos)
#define RAMCFG_WPR1_P18WP   RAMCFG_WPR1_P18WP_Msk
#define RAMCFG_WPR1_P19WP_Pos   (19U)
#define RAMCFG_WPR1_P19WP_Msk   (0x1UL << RAMCFG_WPR1_P19WP_Pos)
#define RAMCFG_WPR1_P19WP   RAMCFG_WPR1_P19WP_Msk
#define RAMCFG_WPR1_P20WP_Pos   (20U)
#define RAMCFG_WPR1_P20WP_Msk   (0x1UL << RAMCFG_WPR1_P20WP_Pos)
#define RAMCFG_WPR1_P20WP   RAMCFG_WPR1_P20WP_Msk
#define RAMCFG_WPR1_P21WP_Pos   (21U)
#define RAMCFG_WPR1_P21WP_Msk   (0x1UL << RAMCFG_WPR1_P21WP_Pos)
#define RAMCFG_WPR1_P21WP   RAMCFG_WPR1_P21WP_Msk
#define RAMCFG_WPR1_P22WP_Pos   (22U)
#define RAMCFG_WPR1_P22WP_Msk   (0x1UL << RAMCFG_WPR1_P22WP_Pos)
#define RAMCFG_WPR1_P22WP   RAMCFG_WPR1_P22WP_Msk
#define RAMCFG_WPR1_P23WP_Pos   (23U)
#define RAMCFG_WPR1_P23WP_Msk   (0x1UL << RAMCFG_WPR1_P23WP_Pos)
#define RAMCFG_WPR1_P23WP   RAMCFG_WPR1_P23WP_Msk
#define RAMCFG_WPR1_P24WP_Pos   (24U)
#define RAMCFG_WPR1_P24WP_Msk   (0x1UL << RAMCFG_WPR1_P24WP_Pos)
#define RAMCFG_WPR1_P24WP   RAMCFG_WPR1_P24WP_Msk
#define RAMCFG_WPR1_P25WP_Pos   (25U)
#define RAMCFG_WPR1_P25WP_Msk   (0x1UL << RAMCFG_WPR1_P25WP_Pos)
#define RAMCFG_WPR1_P25WP   RAMCFG_WPR1_P25WP_Msk
#define RAMCFG_WPR1_P26WP_Pos   (26U)
#define RAMCFG_WPR1_P26WP_Msk   (0x1UL << RAMCFG_WPR1_P26WP_Pos)
#define RAMCFG_WPR1_P26WP   RAMCFG_WPR1_P26WP_Msk
#define RAMCFG_WPR1_P27WP_Pos   (27U)
#define RAMCFG_WPR1_P27WP_Msk   (0x1UL << RAMCFG_WPR1_P27WP_Pos)
#define RAMCFG_WPR1_P27WP   RAMCFG_WPR1_P27WP_Msk
#define RAMCFG_WPR1_P28WP_Pos   (28U)
#define RAMCFG_WPR1_P28WP_Msk   (0x1UL << RAMCFG_WPR1_P28WP_Pos)
#define RAMCFG_WPR1_P28WP   RAMCFG_WPR1_P28WP_Msk
#define RAMCFG_WPR1_P29WP_Pos   (29U)
#define RAMCFG_WPR1_P29WP_Msk   (0x1UL << RAMCFG_WPR1_P29WP_Pos)
#define RAMCFG_WPR1_P29WP   RAMCFG_WPR1_P29WP_Msk
#define RAMCFG_WPR1_P30WP_Pos   (30U)
#define RAMCFG_WPR1_P30WP_Msk   (0x1UL << RAMCFG_WPR1_P30WP_Pos)
#define RAMCFG_WPR1_P30WP   RAMCFG_WPR1_P30WP_Msk
#define RAMCFG_WPR1_P31WP_Pos   (31U)
#define RAMCFG_WPR1_P31WP_Msk   (0x1UL << RAMCFG_WPR1_P31WP_Pos)
#define RAMCFG_WPR1_P31WP   RAMCFG_WPR1_P31WP_Msk
#define RAMCFG_WPR2_P32WP_Pos   (0U)
#define RAMCFG_WPR2_P32WP_Msk   (0x1UL << RAMCFG_WPR2_P32WP_Pos)
#define RAMCFG_WPR2_P32WP   RAMCFG_WPR2_P32WP_Msk
#define RAMCFG_WPR2_P33WP_Pos   (1U)
#define RAMCFG_WPR2_P33WP_Msk   (0x1UL << RAMCFG_WPR2_P33WP_Pos)
#define RAMCFG_WPR2_P33WP   RAMCFG_WPR2_P33WP_Msk
#define RAMCFG_WPR2_P34WP_Pos   (2U)
#define RAMCFG_WPR2_P34WP_Msk   (0x1UL << RAMCFG_WPR2_P34WP_Pos)
#define RAMCFG_WPR2_P34WP   RAMCFG_WPR2_P34WP_Msk
#define RAMCFG_WPR2_P35WP_Pos   (3U)
#define RAMCFG_WPR2_P35WP_Msk   (0x1UL << RAMCFG_WPR2_P35WP_Pos)
#define RAMCFG_WPR2_P35WP   RAMCFG_WPR2_P35WP_Msk
#define RAMCFG_WPR2_P36WP_Pos   (4U)
#define RAMCFG_WPR2_P36WP_Msk   (0x1UL << RAMCFG_WPR2_P36WP_Pos)
#define RAMCFG_WPR2_P36WP   RAMCFG_WPR2_P36WP_Msk
#define RAMCFG_WPR2_P37WP_Pos   (5U)
#define RAMCFG_WPR2_P37WP_Msk   (0x1UL << RAMCFG_WPR2_P37WP_Pos)
#define RAMCFG_WPR2_P37WP   RAMCFG_WPR2_P37WP_Msk
#define RAMCFG_WPR2_P38WP_Pos   (6U)
#define RAMCFG_WPR2_P38WP_Msk   (0x1UL << RAMCFG_WPR2_P38WP_Pos)
#define RAMCFG_WPR2_P38WP   RAMCFG_WPR2_P38WP_Msk
#define RAMCFG_WPR2_P39WP_Pos   (7U)
#define RAMCFG_WPR2_P39WP_Msk   (0x1UL << RAMCFG_WPR2_P39WP_Pos)
#define RAMCFG_WPR2_P39WP   RAMCFG_WPR2_P39WP_Msk
#define RAMCFG_WPR2_P40WP_Pos   (8U)
#define RAMCFG_WPR2_P40WP_Msk   (0x1UL << RAMCFG_WPR2_P40WP_Pos)
#define RAMCFG_WPR2_P40WP   RAMCFG_WPR2_P40WP_Msk
#define RAMCFG_WPR2_P41WP_Pos   (9U)
#define RAMCFG_WPR2_P41WP_Msk   (0x1UL << RAMCFG_WPR2_P41WP_Pos)
#define RAMCFG_WPR2_P41WP   RAMCFG_WPR2_P41WP_Msk
#define RAMCFG_WPR2_P42WP_Pos   (10U)
#define RAMCFG_WPR2_P42WP_Msk   (0x1UL << RAMCFG_WPR2_P42WP_Pos)
#define RAMCFG_WPR2_P42WP   RAMCFG_WPR2_P42WP_Msk
#define RAMCFG_WPR2_P43WP_Pos   (11U)
#define RAMCFG_WPR2_P43WP_Msk   (0x1UL << RAMCFG_WPR2_P43WP_Pos)
#define RAMCFG_WPR2_P43WP   RAMCFG_WPR2_P43WP_Msk
#define RAMCFG_WPR2_P44WP_Pos   (12U)
#define RAMCFG_WPR2_P44WP_Msk   (0x1UL << RAMCFG_WPR2_P44WP_Pos)
#define RAMCFG_WPR2_P44WP   RAMCFG_WPR2_P44WP_Msk
#define RAMCFG_WPR2_P45WP_Pos   (13U)
#define RAMCFG_WPR2_P45WP_Msk   (0x1UL << RAMCFG_WPR2_P45WP_Pos)
#define RAMCFG_WPR2_P45WP   RAMCFG_WPR2_P45WP_Msk
#define RAMCFG_WPR2_P46WP_Pos   (14U)
#define RAMCFG_WPR2_P46WP_Msk   (0x1UL << RAMCFG_WPR2_P46WP_Pos)
#define RAMCFG_WPR2_P46WP   RAMCFG_WPR2_P46WP_Msk
#define RAMCFG_WPR2_P47WP_Pos   (15U)
#define RAMCFG_WPR2_P47WP_Msk   (0x1UL << RAMCFG_WPR2_P47WP_Pos)
#define RAMCFG_WPR2_P47WP   RAMCFG_WPR2_P47WP_Msk
#define RAMCFG_WPR2_P48WP_Pos   (16U)
#define RAMCFG_WPR2_P48WP_Msk   (0x1UL << RAMCFG_WPR2_P48WP_Pos)
#define RAMCFG_WPR2_P48WP   RAMCFG_WPR2_P48WP_Msk
#define RAMCFG_WPR2_P49WP_Pos   (17U)
#define RAMCFG_WPR2_P49WP_Msk   (0x1UL << RAMCFG_WPR2_P49WP_Pos)
#define RAMCFG_WPR2_P49WP   RAMCFG_WPR2_P49WP_Msk
#define RAMCFG_WPR2_P50WP_Pos   (18U)
#define RAMCFG_WPR2_P50WP_Msk   (0x1UL << RAMCFG_WPR2_P50WP_Pos)
#define RAMCFG_WPR2_P50WP   RAMCFG_WPR2_P50WP_Msk
#define RAMCFG_WPR2_P51WP_Pos   (19U)
#define RAMCFG_WPR2_P51WP_Msk   (0x1UL << RAMCFG_WPR2_P51WP_Pos)
#define RAMCFG_WPR2_P51WP   RAMCFG_WPR2_P51WP_Msk
#define RAMCFG_WPR2_P52WP_Pos   (20U)
#define RAMCFG_WPR2_P52WP_Msk   (0x1UL << RAMCFG_WPR2_P52WP_Pos)
#define RAMCFG_WPR2_P52WP   RAMCFG_WPR2_P52WP_Msk
#define RAMCFG_WPR2_P53WP_Pos   (21U)
#define RAMCFG_WPR2_P53WP_Msk   (0x1UL << RAMCFG_WPR2_P53WP_Pos)
#define RAMCFG_WPR2_P53WP   RAMCFG_WPR2_P53WP_Msk
#define RAMCFG_WPR2_P54WP_Pos   (22U)
#define RAMCFG_WPR2_P54WP_Msk   (0x1UL << RAMCFG_WPR2_P54WP_Pos)
#define RAMCFG_WPR2_P54WP   RAMCFG_WPR2_P54WP_Msk
#define RAMCFG_WPR2_P55WP_Pos   (23U)
#define RAMCFG_WPR2_P55WP_Msk   (0x1UL << RAMCFG_WPR2_P55WP_Pos)
#define RAMCFG_WPR2_P55WP   RAMCFG_WPR2_P55WP_Msk
#define RAMCFG_WPR2_P56WP_Pos   (24U)
#define RAMCFG_WPR2_P56WP_Msk   (0x1UL << RAMCFG_WPR2_P56WP_Pos)
#define RAMCFG_WPR2_P56WP   RAMCFG_WPR2_P56WP_Msk
#define RAMCFG_WPR2_P57WP_Pos   (25U)
#define RAMCFG_WPR2_P57WP_Msk   (0x1UL << RAMCFG_WPR2_P57WP_Pos)
#define RAMCFG_WPR2_P57WP   RAMCFG_WPR2_P57WP_Msk
#define RAMCFG_WPR2_P58WP_Pos   (26U)
#define RAMCFG_WPR2_P58WP_Msk   (0x1UL << RAMCFG_WPR2_P58WP_Pos)
#define RAMCFG_WPR2_P58WP   RAMCFG_WPR2_P58WP_Msk
#define RAMCFG_WPR2_P59WP_Pos   (27U)
#define RAMCFG_WPR2_P59WP_Msk   (0x1UL << RAMCFG_WPR2_P59WP_Pos)
#define RAMCFG_WPR2_P59WP   RAMCFG_WPR2_P59WP_Msk
#define RAMCFG_WPR2_P60WP_Pos   (28U)
#define RAMCFG_WPR2_P60WP_Msk   (0x1UL << RAMCFG_WPR2_P60WP_Pos)
#define RAMCFG_WPR2_P60WP   RAMCFG_WPR2_P60WP_Msk
#define RAMCFG_WPR2_P61WP_Pos   (29U)
#define RAMCFG_WPR2_P61WP_Msk   (0x1UL << RAMCFG_WPR2_P61WP_Pos)
#define RAMCFG_WPR2_P61WP   RAMCFG_WPR2_P61WP_Msk
#define RAMCFG_WPR2_P62WP_Pos   (30U)
#define RAMCFG_WPR2_P62WP_Msk   (0x1UL << RAMCFG_WPR2_P62WP_Pos)
#define RAMCFG_WPR2_P62WP   RAMCFG_WPR2_P62WP_Msk
#define RAMCFG_WPR2_P63WP_Pos   (31U)
#define RAMCFG_WPR2_P63WP_Msk   (0x1UL << RAMCFG_WPR2_P63WP_Pos)
#define RAMCFG_WPR2_P63WP   RAMCFG_WPR2_P63WP_Msk
#define RAMCFG_ECCKEYR_ECCKEY_Pos   (0U)
#define RAMCFG_ECCKEYR_ECCKEY_Msk   (0xFFUL << RAMCFG_ECCKEYR_ECCKEY_Pos)
#define RAMCFG_ECCKEYR_ECCKEY   RAMCFG_ECCKEYR_ECCKEY_Msk
#define RAMCFG_ERKEYR_ERASEKEY_Pos   (0U)
#define RAMCFG_ERKEYR_ERASEKEY_Msk   (0xFFUL << RAMCFG_ERKEYR_ERASEKEY_Pos)
#define RAMCFG_ERKEYR_ERASEKEY   RAMCFG_ERKEYR_ERASEKEY_Msk
#define RCC_CR_MSISON_Pos   (0U)
#define RCC_CR_MSISON_Msk   (0x1UL << RCC_CR_MSISON_Pos)
#define RCC_CR_MSISON   RCC_CR_MSISON_Msk
#define RCC_CR_MSIKERON_Pos   (1U)
#define RCC_CR_MSIKERON_Msk   (0x1UL << RCC_CR_MSIKERON_Pos)
#define RCC_CR_MSIKERON   RCC_CR_MSIKERON_Msk
#define RCC_CR_MSISRDY_Pos   (2U)
#define RCC_CR_MSISRDY_Msk   (0x1UL << RCC_CR_MSISRDY_Pos)
#define RCC_CR_MSISRDY   RCC_CR_MSISRDY_Msk
#define RCC_CR_MSIPLLEN_Pos   (3U)
#define RCC_CR_MSIPLLEN_Msk   (0x1UL << RCC_CR_MSIPLLEN_Pos)
#define RCC_CR_MSIPLLEN   RCC_CR_MSIPLLEN_Msk
#define RCC_CR_MSIKON_Pos   (4U)
#define RCC_CR_MSIKON_Msk   (0x1UL << RCC_CR_MSIKON_Pos)
#define RCC_CR_MSIKON   RCC_CR_MSIKON_Msk
#define RCC_CR_MSIKRDY_Pos   (5U)
#define RCC_CR_MSIKRDY_Msk   (0x1UL << RCC_CR_MSIKRDY_Pos)
#define RCC_CR_MSIKRDY   RCC_CR_MSIKRDY_Msk
#define RCC_CR_MSIPLLSEL_Pos   (6U)
#define RCC_CR_MSIPLLSEL_Msk   (0x1UL << RCC_CR_MSIPLLSEL_Pos)
#define RCC_CR_MSIPLLSEL   RCC_CR_MSIPLLSEL_Msk
#define RCC_CR_MSIPLLFAST_Pos   (7U)
#define RCC_CR_MSIPLLFAST_Msk   (0x1UL << RCC_CR_MSIPLLFAST_Pos)
#define RCC_CR_MSIPLLFAST   RCC_CR_MSIPLLFAST_Msk
#define RCC_CR_HSION_Pos   (8U)
#define RCC_CR_HSION_Msk   (0x1UL << RCC_CR_HSION_Pos)
#define RCC_CR_HSION   RCC_CR_HSION_Msk
#define RCC_CR_HSIKERON_Pos   (9U)
#define RCC_CR_HSIKERON_Msk   (0x1UL << RCC_CR_HSIKERON_Pos)
#define RCC_CR_HSIKERON   RCC_CR_HSIKERON_Msk
#define RCC_CR_HSIRDY_Pos   (10U)
#define RCC_CR_HSIRDY_Msk   (0x1UL << RCC_CR_HSIRDY_Pos)
#define RCC_CR_HSIRDY   RCC_CR_HSIRDY_Msk
#define RCC_CR_HSI48ON_Pos   (12U)
#define RCC_CR_HSI48ON_Msk   (0x1UL << RCC_CR_HSI48ON_Pos)
#define RCC_CR_HSI48ON   RCC_CR_HSI48ON_Msk
#define RCC_CR_HSI48RDY_Pos   (13U)
#define RCC_CR_HSI48RDY_Msk   (0x1UL << RCC_CR_HSI48RDY_Pos)
#define RCC_CR_HSI48RDY   RCC_CR_HSI48RDY_Msk
#define RCC_CR_SHSION_Pos   (14U)
#define RCC_CR_SHSION_Msk   (0x1UL << RCC_CR_SHSION_Pos)
#define RCC_CR_SHSION   RCC_CR_SHSION_Msk
#define RCC_CR_SHSIRDY_Pos   (15U)
#define RCC_CR_SHSIRDY_Msk   (0x1UL << RCC_CR_SHSIRDY_Pos)
#define RCC_CR_SHSIRDY   RCC_CR_SHSIRDY_Msk
#define RCC_CR_HSEON_Pos   (16U)
#define RCC_CR_HSEON_Msk   (0x1UL << RCC_CR_HSEON_Pos)
#define RCC_CR_HSEON   RCC_CR_HSEON_Msk
#define RCC_CR_HSERDY_Pos   (17U)
#define RCC_CR_HSERDY_Msk   (0x1UL << RCC_CR_HSERDY_Pos)
#define RCC_CR_HSERDY   RCC_CR_HSERDY_Msk
#define RCC_CR_HSEBYP_Pos   (18U)
#define RCC_CR_HSEBYP_Msk   (0x1UL << RCC_CR_HSEBYP_Pos)
#define RCC_CR_HSEBYP   RCC_CR_HSEBYP_Msk
#define RCC_CR_CSSON_Pos   (19U)
#define RCC_CR_CSSON_Msk   (0x1UL << RCC_CR_CSSON_Pos)
#define RCC_CR_CSSON   RCC_CR_CSSON_Msk
#define RCC_CR_HSEEXT_Pos   (20U)
#define RCC_CR_HSEEXT_Msk   (0x1UL << RCC_CR_HSEEXT_Pos)
#define RCC_CR_HSEEXT   RCC_CR_HSEEXT_Msk
#define RCC_CR_PLL1ON_Pos   (24U)
#define RCC_CR_PLL1ON_Msk   (0x1UL << RCC_CR_PLL1ON_Pos)
#define RCC_CR_PLL1ON   RCC_CR_PLL1ON_Msk
#define RCC_CR_PLL1RDY_Pos   (25U)
#define RCC_CR_PLL1RDY_Msk   (0x1UL << RCC_CR_PLL1RDY_Pos)
#define RCC_CR_PLL1RDY   RCC_CR_PLL1RDY_Msk
#define RCC_CR_PLL2ON_Pos   (26U)
#define RCC_CR_PLL2ON_Msk   (0x1UL << RCC_CR_PLL2ON_Pos)
#define RCC_CR_PLL2ON   RCC_CR_PLL2ON_Msk
#define RCC_CR_PLL2RDY_Pos   (27U)
#define RCC_CR_PLL2RDY_Msk   (0x1UL << RCC_CR_PLL2RDY_Pos)
#define RCC_CR_PLL2RDY   RCC_CR_PLL2RDY_Msk
#define RCC_CR_PLL3ON_Pos   (28U)
#define RCC_CR_PLL3ON_Msk   (0x1UL << RCC_CR_PLL3ON_Pos)
#define RCC_CR_PLL3ON   RCC_CR_PLL3ON_Msk
#define RCC_CR_PLL3RDY_Pos   (29U)
#define RCC_CR_PLL3RDY_Msk   (0x1UL << RCC_CR_PLL3RDY_Pos)
#define RCC_CR_PLL3RDY   RCC_CR_PLL3RDY_Msk
#define RCC_ICSCR1_MSICAL3_Pos   (0U)
#define RCC_ICSCR1_MSICAL3_Msk   (0x1FUL << RCC_ICSCR1_MSICAL3_Pos)
#define RCC_ICSCR1_MSICAL3   RCC_ICSCR1_MSICAL3_Msk
#define RCC_ICSCR1_MSICAL3_0   (0x01UL << RCC_ICSCR1_MSICAL3_Pos)
#define RCC_ICSCR1_MSICAL3_1   (0x02UL << RCC_ICSCR1_MSICAL3_Pos)
#define RCC_ICSCR1_MSICAL3_2   (0x04UL << RCC_ICSCR1_MSICAL3_Pos)
#define RCC_ICSCR1_MSICAL3_3   (0x08UL << RCC_ICSCR1_MSICAL3_Pos)
#define RCC_ICSCR1_MSICAL3_4   (0x10UL << RCC_ICSCR1_MSICAL3_Pos)
#define RCC_ICSCR1_MSICAL2_Pos   (5U)
#define RCC_ICSCR1_MSICAL2_Msk   (0x1FUL << RCC_ICSCR1_MSICAL2_Pos)
#define RCC_ICSCR1_MSICAL2   RCC_ICSCR1_MSICAL2_Msk
#define RCC_ICSCR1_MSICAL2_0   (0x01UL << RCC_ICSCR1_MSICAL2_Pos)
#define RCC_ICSCR1_MSICAL2_1   (0x02UL << RCC_ICSCR1_MSICAL2_Pos)
#define RCC_ICSCR1_MSICAL2_2   (0x04UL << RCC_ICSCR1_MSICAL2_Pos)
#define RCC_ICSCR1_MSICAL2_3   (0x08UL << RCC_ICSCR1_MSICAL2_Pos)
#define RCC_ICSCR1_MSICAL2_4   (0x10UL << RCC_ICSCR1_MSICAL2_Pos)
#define RCC_ICSCR1_MSICAL1_Pos   (10U)
#define RCC_ICSCR1_MSICAL1_Msk   (0x1FUL << RCC_ICSCR1_MSICAL1_Pos)
#define RCC_ICSCR1_MSICAL1   RCC_ICSCR1_MSICAL1_Msk
#define RCC_ICSCR1_MSICAL1_0   (0x01UL << RCC_ICSCR1_MSICAL1_Pos)
#define RCC_ICSCR1_MSICAL1_1   (0x02UL << RCC_ICSCR1_MSICAL1_Pos)
#define RCC_ICSCR1_MSICAL1_2   (0x04UL << RCC_ICSCR1_MSICAL1_Pos)
#define RCC_ICSCR1_MSICAL1_3   (0x08UL << RCC_ICSCR1_MSICAL1_Pos)
#define RCC_ICSCR1_MSICAL1_4   (0x10UL << RCC_ICSCR1_MSICAL1_Pos)
#define RCC_ICSCR1_MSICAL0_Pos   (15U)
#define RCC_ICSCR1_MSICAL0_Msk   (0x1FUL << RCC_ICSCR1_MSICAL0_Pos)
#define RCC_ICSCR1_MSICAL0   RCC_ICSCR1_MSICAL0_Msk
#define RCC_ICSCR1_MSICAL0_0   (0x01UL << RCC_ICSCR1_MSICAL0_Pos)
#define RCC_ICSCR1_MSICAL0_1   (0x02UL << RCC_ICSCR1_MSICAL0_Pos)
#define RCC_ICSCR1_MSICAL0_2   (0x04UL << RCC_ICSCR1_MSICAL0_Pos)
#define RCC_ICSCR1_MSICAL0_3   (0x08UL << RCC_ICSCR1_MSICAL0_Pos)
#define RCC_ICSCR1_MSICAL0_4   (0x10UL << RCC_ICSCR1_MSICAL0_Pos)
#define RCC_ICSCR1_MSIBIAS_Pos   (22U)
#define RCC_ICSCR1_MSIBIAS_Msk   (0x1UL << RCC_ICSCR1_MSIBIAS_Pos)
#define RCC_ICSCR1_MSIBIAS   RCC_ICSCR1_MSIBIAS_Msk
#define RCC_ICSCR1_MSIRGSEL_Pos   (23U)
#define RCC_ICSCR1_MSIRGSEL_Msk   (0x1UL << RCC_ICSCR1_MSIRGSEL_Pos)
#define RCC_ICSCR1_MSIRGSEL   RCC_ICSCR1_MSIRGSEL_Msk
#define RCC_ICSCR1_MSIKRANGE_Pos   (24U)
#define RCC_ICSCR1_MSIKRANGE_Msk   (0xFUL << RCC_ICSCR1_MSIKRANGE_Pos)
#define RCC_ICSCR1_MSIKRANGE   RCC_ICSCR1_MSIKRANGE_Msk
#define RCC_ICSCR1_MSIKRANGE_0   (0x1UL << RCC_ICSCR1_MSIKRANGE_Pos)
#define RCC_ICSCR1_MSIKRANGE_1   (0x2UL << RCC_ICSCR1_MSIKRANGE_Pos)
#define RCC_ICSCR1_MSIKRANGE_2   (0x4UL << RCC_ICSCR1_MSIKRANGE_Pos)
#define RCC_ICSCR1_MSIKRANGE_3   (0x8UL << RCC_ICSCR1_MSIKRANGE_Pos)
#define RCC_ICSCR1_MSISRANGE_Pos   (28U)
#define RCC_ICSCR1_MSISRANGE_Msk   (0xFUL << RCC_ICSCR1_MSISRANGE_Pos)
#define RCC_ICSCR1_MSISRANGE   RCC_ICSCR1_MSISRANGE_Msk
#define RCC_ICSCR1_MSISRANGE_0   (0x1UL << RCC_ICSCR1_MSISRANGE_Pos)
#define RCC_ICSCR1_MSISRANGE_1   (0x2UL << RCC_ICSCR1_MSISRANGE_Pos)
#define RCC_ICSCR1_MSISRANGE_2   (0x4UL << RCC_ICSCR1_MSISRANGE_Pos)
#define RCC_ICSCR1_MSISRANGE_3   (0x8UL << RCC_ICSCR1_MSISRANGE_Pos)
#define RCC_ICSCR2_MSITRIM3_Pos   (0U)
#define RCC_ICSCR2_MSITRIM3_Msk   (0x1FUL << RCC_ICSCR2_MSITRIM3_Pos)
#define RCC_ICSCR2_MSITRIM3   RCC_ICSCR2_MSITRIM3_Msk
#define RCC_ICSCR2_MSITRIM3_0   (0x01UL << RCC_ICSCR2_MSITRIM3_Pos)
#define RCC_ICSCR2_MSITRIM3_1   (0x02UL << RCC_ICSCR2_MSITRIM3_Pos)
#define RCC_ICSCR2_MSITRIM3_2   (0x04UL << RCC_ICSCR2_MSITRIM3_Pos)
#define RCC_ICSCR2_MSITRIM3_3   (0x08UL << RCC_ICSCR2_MSITRIM3_Pos)
#define RCC_ICSCR2_MSITRIM3_4   (0x10UL << RCC_ICSCR2_MSITRIM3_Pos)
#define RCC_ICSCR2_MSITRIM2_Pos   (5U)
#define RCC_ICSCR2_MSITRIM2_Msk   (0x1FUL << RCC_ICSCR2_MSITRIM2_Pos)
#define RCC_ICSCR2_MSITRIM2   RCC_ICSCR2_MSITRIM2_Msk
#define RCC_ICSCR2_MSITRIM2_0   (0x01UL << RCC_ICSCR2_MSITRIM2_Pos)
#define RCC_ICSCR2_MSITRIM2_1   (0x02UL << RCC_ICSCR2_MSITRIM2_Pos)
#define RCC_ICSCR2_MSITRIM2_2   (0x04UL << RCC_ICSCR2_MSITRIM2_Pos)
#define RCC_ICSCR2_MSITRIM2_3   (0x08UL << RCC_ICSCR2_MSITRIM2_Pos)
#define RCC_ICSCR2_MSITRIM2_4   (0x10UL << RCC_ICSCR2_MSITRIM2_Pos)
#define RCC_ICSCR2_MSITRIM1_Pos   (10U)
#define RCC_ICSCR2_MSITRIM1_Msk   (0x1FUL << RCC_ICSCR2_MSITRIM1_Pos)
#define RCC_ICSCR2_MSITRIM1   RCC_ICSCR2_MSITRIM1_Msk
#define RCC_ICSCR2_MSITRIM1_0   (0x01UL << RCC_ICSCR2_MSITRIM1_Pos)
#define RCC_ICSCR2_MSITRIM1_1   (0x02UL << RCC_ICSCR2_MSITRIM1_Pos)
#define RCC_ICSCR2_MSITRIM1_2   (0x04UL << RCC_ICSCR2_MSITRIM1_Pos)
#define RCC_ICSCR2_MSITRIM1_3   (0x08UL << RCC_ICSCR2_MSITRIM1_Pos)
#define RCC_ICSCR2_MSITRIM1_4   (0x10UL << RCC_ICSCR2_MSITRIM1_Pos)
#define RCC_ICSCR2_MSITRIM0_Pos   (15U)
#define RCC_ICSCR2_MSITRIM0_Msk   (0x1FUL << RCC_ICSCR2_MSITRIM0_Pos)
#define RCC_ICSCR2_MSITRIM0   RCC_ICSCR2_MSITRIM0_Msk
#define RCC_ICSCR2_MSITRIM0_0   (0x01UL << RCC_ICSCR2_MSITRIM0_Pos)
#define RCC_ICSCR2_MSITRIM0_1   (0x02UL << RCC_ICSCR2_MSITRIM0_Pos)
#define RCC_ICSCR2_MSITRIM0_2   (0x04UL << RCC_ICSCR2_MSITRIM0_Pos)
#define RCC_ICSCR2_MSITRIM0_3   (0x08UL << RCC_ICSCR2_MSITRIM0_Pos)
#define RCC_ICSCR2_MSITRIM0_4   (0x10UL << RCC_ICSCR2_MSITRIM0_Pos)
#define RCC_ICSCR3_HSICAL_Pos   (0U)
#define RCC_ICSCR3_HSICAL_Msk   (0xFFFUL << RCC_ICSCR3_HSICAL_Pos)
#define RCC_ICSCR3_HSICAL   RCC_ICSCR3_HSICAL_Msk
#define RCC_ICSCR3_HSICAL_0   (0x001UL << RCC_ICSCR3_HSICAL_Pos)
#define RCC_ICSCR3_HSICAL_1   (0x002UL << RCC_ICSCR3_HSICAL_Pos)
#define RCC_ICSCR3_HSICAL_2   (0x004UL << RCC_ICSCR3_HSICAL_Pos)
#define RCC_ICSCR3_HSICAL_3   (0x008UL << RCC_ICSCR3_HSICAL_Pos)
#define RCC_ICSCR3_HSICAL_4   (0x010UL << RCC_ICSCR3_HSICAL_Pos)
#define RCC_ICSCR3_HSICAL_5   (0x020UL << RCC_ICSCR3_HSICAL_Pos)
#define RCC_ICSCR3_HSICAL_6   (0x040UL << RCC_ICSCR3_HSICAL_Pos)
#define RCC_ICSCR3_HSICAL_7   (0x080UL << RCC_ICSCR3_HSICAL_Pos)
#define RCC_ICSCR3_HSICAL_8   (0x100UL << RCC_ICSCR3_HSICAL_Pos)
#define RCC_ICSCR3_HSICAL_9   (0x200UL << RCC_ICSCR3_HSICAL_Pos)
#define RCC_ICSCR3_HSICAL_10   (0x400UL << RCC_ICSCR3_HSICAL_Pos)
#define RCC_ICSCR3_HSICAL_11   (0x800UL << RCC_ICSCR3_HSICAL_Pos)
#define RCC_ICSCR3_HSITRIM_Pos   (16U)
#define RCC_ICSCR3_HSITRIM_Msk   (0x1FUL << RCC_ICSCR3_HSITRIM_Pos)
#define RCC_ICSCR3_HSITRIM   RCC_ICSCR3_HSITRIM_Msk
#define RCC_ICSCR3_HSITRIM_0   (0x01UL << RCC_ICSCR3_HSITRIM_Pos)
#define RCC_ICSCR3_HSITRIM_1   (0x02UL << RCC_ICSCR3_HSITRIM_Pos)
#define RCC_ICSCR3_HSITRIM_2   (0x04UL << RCC_ICSCR3_HSITRIM_Pos)
#define RCC_ICSCR3_HSITRIM_3   (0x08UL << RCC_ICSCR3_HSITRIM_Pos)
#define RCC_ICSCR3_HSITRIM_4   (0x10UL << RCC_ICSCR3_HSITRIM_Pos)
#define RCC_CRRCR_HSI48CAL_Pos   (0U)
#define RCC_CRRCR_HSI48CAL_Msk   (0x1FFUL << RCC_CRRCR_HSI48CAL_Pos)
#define RCC_CRRCR_HSI48CAL   RCC_CRRCR_HSI48CAL_Msk
#define RCC_CRRCR_HSI48CAL_0   (0x001UL << RCC_CRRCR_HSI48CAL_Pos)
#define RCC_CRRCR_HSI48CAL_1   (0x002UL << RCC_CRRCR_HSI48CAL_Pos)
#define RCC_CRRCR_HSI48CAL_2   (0x004UL << RCC_CRRCR_HSI48CAL_Pos)
#define RCC_CRRCR_HSI48CAL_3   (0x008UL << RCC_CRRCR_HSI48CAL_Pos)
#define RCC_CRRCR_HSI48CAL_4   (0x010UL << RCC_CRRCR_HSI48CAL_Pos)
#define RCC_CRRCR_HSI48CAL_5   (0x020UL << RCC_CRRCR_HSI48CAL_Pos)
#define RCC_CRRCR_HSI48CAL_6   (0x040UL << RCC_CRRCR_HSI48CAL_Pos)
#define RCC_CRRCR_HSI48CAL_7   (0x080UL << RCC_CRRCR_HSI48CAL_Pos)
#define RCC_CRRCR_HSI48CAL_8   (0x100UL << RCC_CRRCR_HSI48CAL_Pos)
#define RCC_CFGR1_SW_Pos   (0U)
#define RCC_CFGR1_SW_Msk   (0x3UL << RCC_CFGR1_SW_Pos)
#define RCC_CFGR1_SW   RCC_CFGR1_SW_Msk
#define RCC_CFGR1_SW_0   (0x1UL << RCC_CFGR1_SW_Pos)
#define RCC_CFGR1_SW_1   (0x2UL << RCC_CFGR1_SW_Pos)
#define RCC_CFGR1_SWS_Pos   (2U)
#define RCC_CFGR1_SWS_Msk   (0x3UL << RCC_CFGR1_SWS_Pos)
#define RCC_CFGR1_SWS   RCC_CFGR1_SWS_Msk
#define RCC_CFGR1_SWS_0   (0x1UL << RCC_CFGR1_SWS_Pos)
#define RCC_CFGR1_SWS_1   (0x2UL << RCC_CFGR1_SWS_Pos)
#define RCC_CFGR1_STOPWUCK_Pos   (4U)
#define RCC_CFGR1_STOPWUCK_Msk   (0x1UL << RCC_CFGR1_STOPWUCK_Pos)
#define RCC_CFGR1_STOPWUCK   RCC_CFGR1_STOPWUCK_Msk
#define RCC_CFGR1_STOPKERWUCK_Pos   (5U)
#define RCC_CFGR1_STOPKERWUCK_Msk   (0x1UL << RCC_CFGR1_STOPKERWUCK_Pos)
#define RCC_CFGR1_STOPKERWUCK   RCC_CFGR1_STOPKERWUCK_Msk
#define RCC_CFGR1_MCOSEL_Pos   (24U)
#define RCC_CFGR1_MCOSEL_Msk   (0xFUL << RCC_CFGR1_MCOSEL_Pos)
#define RCC_CFGR1_MCOSEL   RCC_CFGR1_MCOSEL_Msk
#define RCC_CFGR1_MCOSEL_0   (0x1UL << RCC_CFGR1_MCOSEL_Pos)
#define RCC_CFGR1_MCOSEL_1   (0x2UL << RCC_CFGR1_MCOSEL_Pos)
#define RCC_CFGR1_MCOSEL_2   (0x4UL << RCC_CFGR1_MCOSEL_Pos)
#define RCC_CFGR1_MCOSEL_3   (0x8UL << RCC_CFGR1_MCOSEL_Pos)
#define RCC_CFGR1_MCOPRE_Pos   (28U)
#define RCC_CFGR1_MCOPRE_Msk   (0x7UL << RCC_CFGR1_MCOPRE_Pos)
#define RCC_CFGR1_MCOPRE   RCC_CFGR1_MCOPRE_Msk
#define RCC_CFGR1_MCOPRE_0   (0x1UL << RCC_CFGR1_MCOPRE_Pos)
#define RCC_CFGR1_MCOPRE_1   (0x2UL << RCC_CFGR1_MCOPRE_Pos)
#define RCC_CFGR1_MCOPRE_2   (0x4UL << RCC_CFGR1_MCOPRE_Pos)
#define RCC_CFGR2_HPRE_Pos   (0U)
#define RCC_CFGR2_HPRE_Msk   (0xFUL << RCC_CFGR2_HPRE_Pos)
#define RCC_CFGR2_HPRE   RCC_CFGR2_HPRE_Msk
#define RCC_CFGR2_HPRE_0   (0x1UL << RCC_CFGR2_HPRE_Pos)
#define RCC_CFGR2_HPRE_1   (0x2UL << RCC_CFGR2_HPRE_Pos)
#define RCC_CFGR2_HPRE_2   (0x4UL << RCC_CFGR2_HPRE_Pos)
#define RCC_CFGR2_HPRE_3   (0x8UL << RCC_CFGR2_HPRE_Pos)
#define RCC_CFGR2_PPRE1_Pos   (4U)
#define RCC_CFGR2_PPRE1_Msk   (0x7UL << RCC_CFGR2_PPRE1_Pos)
#define RCC_CFGR2_PPRE1   RCC_CFGR2_PPRE1_Msk
#define RCC_CFGR2_PPRE1_0   (0x1UL << RCC_CFGR2_PPRE1_Pos)
#define RCC_CFGR2_PPRE1_1   (0x2UL << RCC_CFGR2_PPRE1_Pos)
#define RCC_CFGR2_PPRE1_2   (0x4UL << RCC_CFGR2_PPRE1_Pos)
#define RCC_CFGR2_PPRE2_Pos   (8U)
#define RCC_CFGR2_PPRE2_Msk   (0x7UL << RCC_CFGR2_PPRE2_Pos)
#define RCC_CFGR2_PPRE2   RCC_CFGR2_PPRE2_Msk
#define RCC_CFGR2_PPRE2_0   (0x1UL << RCC_CFGR2_PPRE2_Pos)
#define RCC_CFGR2_PPRE2_1   (0x2UL << RCC_CFGR2_PPRE2_Pos)
#define RCC_CFGR2_PPRE2_2   (0x4UL << RCC_CFGR2_PPRE2_Pos)
#define RCC_CFGR2_PPRE_DPHY_Pos   (12U)
#define RCC_CFGR2_PPRE_DPHY_Msk   (0x7UL << RCC_CFGR2_PPRE_DPHY_Pos)
#define RCC_CFGR2_PPRE_DPHY   RCC_CFGR2_PPRE_DPHY_Msk
#define RCC_CFGR2_PPRE_DPHY_0   (0x1UL << RCC_CFGR2_PPRE_DPHY_Pos)
#define RCC_CFGR2_PPRE_DPHY_1   (0x2UL << RCC_CFGR2_PPRE_DPHY_Pos)
#define RCC_CFGR2_PPRE_DPHY_2   (0x4UL << RCC_CFGR2_PPRE_DPHY_Pos)
#define RCC_CFGR2_AHB1DIS_Pos   (16U)
#define RCC_CFGR2_AHB1DIS_Msk   (0x1UL << RCC_CFGR2_AHB1DIS_Pos)
#define RCC_CFGR2_AHB1DIS   RCC_CFGR2_AHB1DIS_Msk
#define RCC_CFGR2_AHB2DIS1_Pos   (17U)
#define RCC_CFGR2_AHB2DIS1_Msk   (0x1UL << RCC_CFGR2_AHB2DIS1_Pos)
#define RCC_CFGR2_AHB2DIS1   RCC_CFGR2_AHB2DIS1_Msk
#define RCC_CFGR2_AHB2DIS2_Pos   (18U)
#define RCC_CFGR2_AHB2DIS2_Msk   (0x1UL << RCC_CFGR2_AHB2DIS2_Pos)
#define RCC_CFGR2_AHB2DIS2   RCC_CFGR2_AHB2DIS2_Msk
#define RCC_CFGR2_APB1DIS_Pos   (19U)
#define RCC_CFGR2_APB1DIS_Msk   (0x1UL << RCC_CFGR2_APB1DIS_Pos)
#define RCC_CFGR2_APB1DIS   RCC_CFGR2_APB1DIS_Msk
#define RCC_CFGR2_APB2DIS_Pos   (20U)
#define RCC_CFGR2_APB2DIS_Msk   (0x1UL << RCC_CFGR2_APB2DIS_Pos)
#define RCC_CFGR2_APB2DIS   RCC_CFGR2_APB2DIS_Msk
#define RCC_CFGR3_PPRE3_Pos   (4U)
#define RCC_CFGR3_PPRE3_Msk   (0x7UL << RCC_CFGR3_PPRE3_Pos)
#define RCC_CFGR3_PPRE3   RCC_CFGR3_PPRE3_Msk
#define RCC_CFGR3_PPRE3_0   (0x1UL << RCC_CFGR3_PPRE3_Pos)
#define RCC_CFGR3_PPRE3_1   (0x2UL << RCC_CFGR3_PPRE3_Pos)
#define RCC_CFGR3_PPRE3_2   (0x4UL << RCC_CFGR3_PPRE3_Pos)
#define RCC_CFGR3_AHB3DIS_Pos   (16U)
#define RCC_CFGR3_AHB3DIS_Msk   (0x1UL << RCC_CFGR3_AHB3DIS_Pos)
#define RCC_CFGR3_AHB3DIS   RCC_CFGR3_AHB3DIS_Msk
#define RCC_CFGR3_APB3DIS_Pos   (17U)
#define RCC_CFGR3_APB3DIS_Msk   (0x1UL << RCC_CFGR3_APB3DIS_Pos)
#define RCC_CFGR3_APB3DIS   RCC_CFGR3_APB3DIS_Msk
#define RCC_PLL1CFGR_PLL1SRC_Pos   (0U)
#define RCC_PLL1CFGR_PLL1SRC_Msk   (0x3UL << RCC_PLL1CFGR_PLL1SRC_Pos)
#define RCC_PLL1CFGR_PLL1SRC   RCC_PLL1CFGR_PLL1SRC_Msk
#define RCC_PLL1CFGR_PLL1SRC_0   (0x1UL << RCC_PLL1CFGR_PLL1SRC_Pos)
#define RCC_PLL1CFGR_PLL1SRC_1   (0x2UL << RCC_PLL1CFGR_PLL1SRC_Pos)
#define RCC_PLL1CFGR_PLL1RGE_Pos   (2U)
#define RCC_PLL1CFGR_PLL1RGE_Msk   (0x3UL << RCC_PLL1CFGR_PLL1RGE_Pos)
#define RCC_PLL1CFGR_PLL1RGE   RCC_PLL1CFGR_PLL1RGE_Msk
#define RCC_PLL1CFGR_PLL1RGE_0   (0x1UL << RCC_PLL1CFGR_PLL1RGE_Pos)
#define RCC_PLL1CFGR_PLL1RGE_1   (0x2UL << RCC_PLL1CFGR_PLL1RGE_Pos)
#define RCC_PLL1CFGR_PLL1FRACEN_Pos   (4U)
#define RCC_PLL1CFGR_PLL1FRACEN_Msk   (0x1UL << RCC_PLL1CFGR_PLL1FRACEN_Pos)
#define RCC_PLL1CFGR_PLL1FRACEN   RCC_PLL1CFGR_PLL1FRACEN_Msk
#define RCC_PLL1CFGR_PLL1M_Pos   (8U)
#define RCC_PLL1CFGR_PLL1M_Msk   (0xFUL << RCC_PLL1CFGR_PLL1M_Pos)
#define RCC_PLL1CFGR_PLL1M   RCC_PLL1CFGR_PLL1M_Msk
#define RCC_PLL1CFGR_PLL1M_0   (0x01UL << RCC_PLL1CFGR_PLL1M_Pos)
#define RCC_PLL1CFGR_PLL1M_1   (0x02UL << RCC_PLL1CFGR_PLL1M_Pos)
#define RCC_PLL1CFGR_PLL1M_2   (0x04UL << RCC_PLL1CFGR_PLL1M_Pos)
#define RCC_PLL1CFGR_PLL1M_3   (0x08UL << RCC_PLL1CFGR_PLL1M_Pos)
#define RCC_PLL1CFGR_PLL1MBOOST_Pos   (12U)
#define RCC_PLL1CFGR_PLL1MBOOST_Msk   (0xFUL << RCC_PLL1CFGR_PLL1MBOOST_Pos)
#define RCC_PLL1CFGR_PLL1MBOOST   RCC_PLL1CFGR_PLL1MBOOST_Msk
#define RCC_PLL1CFGR_PLL1MBOOST_0   (0x01UL << RCC_PLL1CFGR_PLL1MBOOST_Pos)
#define RCC_PLL1CFGR_PLL1MBOOST_1   (0x02UL << RCC_PLL1CFGR_PLL1MBOOST_Pos)
#define RCC_PLL1CFGR_PLL1MBOOST_2   (0x04UL << RCC_PLL1CFGR_PLL1MBOOST_Pos)
#define RCC_PLL1CFGR_PLL1MBOOST_3   (0x08UL << RCC_PLL1CFGR_PLL1MBOOST_Pos)
#define RCC_PLL1CFGR_PLL1PEN_Pos   (16U)
#define RCC_PLL1CFGR_PLL1PEN_Msk   (0x1UL << RCC_PLL1CFGR_PLL1PEN_Pos)
#define RCC_PLL1CFGR_PLL1PEN   RCC_PLL1CFGR_PLL1PEN_Msk
#define RCC_PLL1CFGR_PLL1QEN_Pos   (17U)
#define RCC_PLL1CFGR_PLL1QEN_Msk   (0x1UL << RCC_PLL1CFGR_PLL1QEN_Pos)
#define RCC_PLL1CFGR_PLL1QEN   RCC_PLL1CFGR_PLL1QEN_Msk
#define RCC_PLL1CFGR_PLL1REN_Pos   (18U)
#define RCC_PLL1CFGR_PLL1REN_Msk   (0x1UL << RCC_PLL1CFGR_PLL1REN_Pos)
#define RCC_PLL1CFGR_PLL1REN   RCC_PLL1CFGR_PLL1REN_Msk
#define RCC_PLL2CFGR_PLL2SRC_Pos   (0U)
#define RCC_PLL2CFGR_PLL2SRC_Msk   (0x3UL << RCC_PLL2CFGR_PLL2SRC_Pos)
#define RCC_PLL2CFGR_PLL2SRC   RCC_PLL2CFGR_PLL2SRC_Msk
#define RCC_PLL2CFGR_PLL2SRC_0   (0x1UL << RCC_PLL2CFGR_PLL2SRC_Pos)
#define RCC_PLL2CFGR_PLL2SRC_1   (0x2UL << RCC_PLL2CFGR_PLL2SRC_Pos)
#define RCC_PLL2CFGR_PLL2RGE_Pos   (2U)
#define RCC_PLL2CFGR_PLL2RGE_Msk   (0x3UL << RCC_PLL2CFGR_PLL2RGE_Pos)
#define RCC_PLL2CFGR_PLL2RGE   RCC_PLL2CFGR_PLL2RGE_Msk
#define RCC_PLL2CFGR_PLL2RGE_0   (0x1UL << RCC_PLL2CFGR_PLL2RGE_Pos)
#define RCC_PLL2CFGR_PLL2RGE_1   (0x2UL << RCC_PLL2CFGR_PLL2RGE_Pos)
#define RCC_PLL2CFGR_PLL2FRACEN_Pos   (4U)
#define RCC_PLL2CFGR_PLL2FRACEN_Msk   (0x1UL << RCC_PLL2CFGR_PLL2FRACEN_Pos)
#define RCC_PLL2CFGR_PLL2FRACEN   RCC_PLL2CFGR_PLL2FRACEN_Msk
#define RCC_PLL2CFGR_PLL2M_Pos   (8U)
#define RCC_PLL2CFGR_PLL2M_Msk   (0xFUL << RCC_PLL2CFGR_PLL2M_Pos)
#define RCC_PLL2CFGR_PLL2M   RCC_PLL2CFGR_PLL2M_Msk
#define RCC_PLL2CFGR_PLL2M_0   (0x01UL << RCC_PLL2CFGR_PLL2M_Pos)
#define RCC_PLL2CFGR_PLL2M_1   (0x02UL << RCC_PLL2CFGR_PLL2M_Pos)
#define RCC_PLL2CFGR_PLL2M_2   (0x04UL << RCC_PLL2CFGR_PLL2M_Pos)
#define RCC_PLL2CFGR_PLL2M_3   (0x08UL << RCC_PLL2CFGR_PLL2M_Pos)
#define RCC_PLL2CFGR_PLL2PEN_Pos   (16U)
#define RCC_PLL2CFGR_PLL2PEN_Msk   (0x1UL << RCC_PLL2CFGR_PLL2PEN_Pos)
#define RCC_PLL2CFGR_PLL2PEN   RCC_PLL2CFGR_PLL2PEN_Msk
#define RCC_PLL2CFGR_PLL2QEN_Pos   (17U)
#define RCC_PLL2CFGR_PLL2QEN_Msk   (0x1UL << RCC_PLL2CFGR_PLL2QEN_Pos)
#define RCC_PLL2CFGR_PLL2QEN   RCC_PLL2CFGR_PLL2QEN_Msk
#define RCC_PLL2CFGR_PLL2REN_Pos   (18U)
#define RCC_PLL2CFGR_PLL2REN_Msk   (0x1UL << RCC_PLL2CFGR_PLL2REN_Pos)
#define RCC_PLL2CFGR_PLL2REN   RCC_PLL2CFGR_PLL2REN_Msk
#define RCC_PLL3CFGR_PLL3SRC_Pos   (0U)
#define RCC_PLL3CFGR_PLL3SRC_Msk   (0x3UL << RCC_PLL3CFGR_PLL3SRC_Pos)
#define RCC_PLL3CFGR_PLL3SRC   RCC_PLL3CFGR_PLL3SRC_Msk
#define RCC_PLL3CFGR_PLL3SRC_0   (0x1UL << RCC_PLL3CFGR_PLL3SRC_Pos)
#define RCC_PLL3CFGR_PLL3SRC_1   (0x2UL << RCC_PLL3CFGR_PLL3SRC_Pos)
#define RCC_PLL3CFGR_PLL3RGE_Pos   (2U)
#define RCC_PLL3CFGR_PLL3RGE_Msk   (0x3UL << RCC_PLL3CFGR_PLL3RGE_Pos)
#define RCC_PLL3CFGR_PLL3RGE   RCC_PLL3CFGR_PLL3RGE_Msk
#define RCC_PLL3CFGR_PLL3RGE_0   (0x1UL << RCC_PLL3CFGR_PLL3RGE_Pos)
#define RCC_PLL3CFGR_PLL3RGE_1   (0x2UL << RCC_PLL3CFGR_PLL3RGE_Pos)
#define RCC_PLL3CFGR_PLL3FRACEN_Pos   (4U)
#define RCC_PLL3CFGR_PLL3FRACEN_Msk   (0x1UL << RCC_PLL3CFGR_PLL3FRACEN_Pos)
#define RCC_PLL3CFGR_PLL3FRACEN   RCC_PLL3CFGR_PLL3FRACEN_Msk
#define RCC_PLL3CFGR_PLL3M_Pos   (8U)
#define RCC_PLL3CFGR_PLL3M_Msk   (0xFUL << RCC_PLL3CFGR_PLL3M_Pos)
#define RCC_PLL3CFGR_PLL3M   RCC_PLL3CFGR_PLL3M_Msk
#define RCC_PLL3CFGR_PLL3M_0   (0x01UL << RCC_PLL3CFGR_PLL3M_Pos)
#define RCC_PLL3CFGR_PLL3M_1   (0x02UL << RCC_PLL3CFGR_PLL3M_Pos)
#define RCC_PLL3CFGR_PLL3M_2   (0x04UL << RCC_PLL3CFGR_PLL3M_Pos)
#define RCC_PLL3CFGR_PLL3M_3   (0x08UL << RCC_PLL3CFGR_PLL3M_Pos)
#define RCC_PLL3CFGR_PLL3PEN_Pos   (16U)
#define RCC_PLL3CFGR_PLL3PEN_Msk   (0x1UL << RCC_PLL3CFGR_PLL3PEN_Pos)
#define RCC_PLL3CFGR_PLL3PEN   RCC_PLL3CFGR_PLL3PEN_Msk
#define RCC_PLL3CFGR_PLL3QEN_Pos   (17U)
#define RCC_PLL3CFGR_PLL3QEN_Msk   (0x1UL << RCC_PLL3CFGR_PLL3QEN_Pos)
#define RCC_PLL3CFGR_PLL3QEN   RCC_PLL3CFGR_PLL3QEN_Msk
#define RCC_PLL3CFGR_PLL3REN_Pos   (18U)
#define RCC_PLL3CFGR_PLL3REN_Msk   (0x1UL << RCC_PLL3CFGR_PLL3REN_Pos)
#define RCC_PLL3CFGR_PLL3REN   RCC_PLL3CFGR_PLL3REN_Msk
#define RCC_PLL1DIVR_PLL1N_Pos   (0U)
#define RCC_PLL1DIVR_PLL1N_Msk   (0x1FFUL << RCC_PLL1DIVR_PLL1N_Pos)
#define RCC_PLL1DIVR_PLL1N   RCC_PLL1DIVR_PLL1N_Msk
#define RCC_PLL1DIVR_PLL1N_0   (0x001UL << RCC_PLL1DIVR_PLL1N_Pos)
#define RCC_PLL1DIVR_PLL1N_1   (0x002UL << RCC_PLL1DIVR_PLL1N_Pos)
#define RCC_PLL1DIVR_PLL1N_2   (0x004UL << RCC_PLL1DIVR_PLL1N_Pos)
#define RCC_PLL1DIVR_PLL1N_3   (0x008UL << RCC_PLL1DIVR_PLL1N_Pos)
#define RCC_PLL1DIVR_PLL1N_4   (0x010UL << RCC_PLL1DIVR_PLL1N_Pos)
#define RCC_PLL1DIVR_PLL1N_5   (0x020UL << RCC_PLL1DIVR_PLL1N_Pos)
#define RCC_PLL1DIVR_PLL1N_6   (0x040UL << RCC_PLL1DIVR_PLL1N_Pos)
#define RCC_PLL1DIVR_PLL1N_7   (0x080UL << RCC_PLL1DIVR_PLL1N_Pos)
#define RCC_PLL1DIVR_PLL1N_8   (0x100UL << RCC_PLL1DIVR_PLL1N_Pos)
#define RCC_PLL1DIVR_PLL1P_Pos   (9U)
#define RCC_PLL1DIVR_PLL1P_Msk   (0x7FUL << RCC_PLL1DIVR_PLL1P_Pos)
#define RCC_PLL1DIVR_PLL1P   RCC_PLL1DIVR_PLL1P_Msk
#define RCC_PLL1DIVR_PLL1P_0   (0x001UL << RCC_PLL1DIVR_PLL1P_Pos)
#define RCC_PLL1DIVR_PLL1P_1   (0x002UL << RCC_PLL1DIVR_PLL1P_Pos)
#define RCC_PLL1DIVR_PLL1P_2   (0x004UL << RCC_PLL1DIVR_PLL1P_Pos)
#define RCC_PLL1DIVR_PLL1P_3   (0x008UL << RCC_PLL1DIVR_PLL1P_Pos)
#define RCC_PLL1DIVR_PLL1P_4   (0x010UL << RCC_PLL1DIVR_PLL1P_Pos)
#define RCC_PLL1DIVR_PLL1P_5   (0x020UL << RCC_PLL1DIVR_PLL1P_Pos)
#define RCC_PLL1DIVR_PLL1P_6   (0x040UL << RCC_PLL1DIVR_PLL1P_Pos)
#define RCC_PLL1DIVR_PLL1Q_Pos   (16U)
#define RCC_PLL1DIVR_PLL1Q_Msk   (0x7FUL << RCC_PLL1DIVR_PLL1Q_Pos)
#define RCC_PLL1DIVR_PLL1Q   RCC_PLL1DIVR_PLL1Q_Msk
#define RCC_PLL1DIVR_PLL1Q_0   (0x001UL << RCC_PLL1DIVR_PLL1Q_Pos)
#define RCC_PLL1DIVR_PLL1Q_1   (0x002UL << RCC_PLL1DIVR_PLL1Q_Pos)
#define RCC_PLL1DIVR_PLL1Q_2   (0x004UL << RCC_PLL1DIVR_PLL1Q_Pos)
#define RCC_PLL1DIVR_PLL1Q_3   (0x008UL << RCC_PLL1DIVR_PLL1Q_Pos)
#define RCC_PLL1DIVR_PLL1Q_4   (0x010UL << RCC_PLL1DIVR_PLL1Q_Pos)
#define RCC_PLL1DIVR_PLL1Q_5   (0x020UL << RCC_PLL1DIVR_PLL1Q_Pos)
#define RCC_PLL1DIVR_PLL1Q_6   (0x040UL << RCC_PLL1DIVR_PLL1Q_Pos)
#define RCC_PLL1DIVR_PLL1R_Pos   (24U)
#define RCC_PLL1DIVR_PLL1R_Msk   (0x7FUL << RCC_PLL1DIVR_PLL1R_Pos)
#define RCC_PLL1DIVR_PLL1R   RCC_PLL1DIVR_PLL1R_Msk
#define RCC_PLL1DIVR_PLL1R_0   (0x001UL << RCC_PLL1DIVR_PLL1R_Pos)
#define RCC_PLL1DIVR_PLL1R_1   (0x002UL << RCC_PLL1DIVR_PLL1R_Pos)
#define RCC_PLL1DIVR_PLL1R_2   (0x004UL << RCC_PLL1DIVR_PLL1R_Pos)
#define RCC_PLL1DIVR_PLL1R_3   (0x008UL << RCC_PLL1DIVR_PLL1R_Pos)
#define RCC_PLL1DIVR_PLL1R_4   (0x010UL << RCC_PLL1DIVR_PLL1R_Pos)
#define RCC_PLL1DIVR_PLL1R_5   (0x020UL << RCC_PLL1DIVR_PLL1R_Pos)
#define RCC_PLL1DIVR_PLL1R_6   (0x040UL << RCC_PLL1DIVR_PLL1R_Pos)
#define RCC_PLL1FRACR_PLL1FRACN_Pos   (3U)
#define RCC_PLL1FRACR_PLL1FRACN_Msk   (0x1FFFUL << RCC_PLL1FRACR_PLL1FRACN_Pos)
#define RCC_PLL1FRACR_PLL1FRACN   RCC_PLL1FRACR_PLL1FRACN_Msk
#define RCC_PLL1FRACR_PLL1FRACN_0   (0x0001UL << RCC_PLL1FRACR_PLL1FRACN_Pos)
#define RCC_PLL1FRACR_PLL1FRACN_1   (0x0002UL << RCC_PLL1FRACR_PLL1FRACN_Pos)
#define RCC_PLL1FRACR_PLL1FRACN_2   (0x0004UL << RCC_PLL1FRACR_PLL1FRACN_Pos)
#define RCC_PLL1FRACR_PLL1FRACN_3   (0x0008UL << RCC_PLL1FRACR_PLL1FRACN_Pos)
#define RCC_PLL1FRACR_PLL1FRACN_4   (0x0010UL << RCC_PLL1FRACR_PLL1FRACN_Pos)
#define RCC_PLL1FRACR_PLL1FRACN_5   (0x0020UL << RCC_PLL1FRACR_PLL1FRACN_Pos)
#define RCC_PLL1FRACR_PLL1FRACN_6   (0x0040UL << RCC_PLL1FRACR_PLL1FRACN_Pos)
#define RCC_PLL1FRACR_PLL1FRACN_7   (0x0080UL << RCC_PLL1FRACR_PLL1FRACN_Pos)
#define RCC_PLL1FRACR_PLL1FRACN_8   (0x0100UL << RCC_PLL1FRACR_PLL1FRACN_Pos)
#define RCC_PLL1FRACR_PLL1FRACN_9   (0x0200UL << RCC_PLL1FRACR_PLL1FRACN_Pos)
#define RCC_PLL1FRACR_PLL1FRACN_10   (0x0400UL << RCC_PLL1FRACR_PLL1FRACN_Pos)
#define RCC_PLL1FRACR_PLL1FRACN_11   (0x0800UL << RCC_PLL1FRACR_PLL1FRACN_Pos)
#define RCC_PLL1FRACR_PLL1FRACN_12   (0x1000UL << RCC_PLL1FRACR_PLL1FRACN_Pos)
#define RCC_PLL2DIVR_PLL2N_Pos   (0U)
#define RCC_PLL2DIVR_PLL2N_Msk   (0x1FFUL << RCC_PLL2DIVR_PLL2N_Pos)
#define RCC_PLL2DIVR_PLL2N   RCC_PLL2DIVR_PLL2N_Msk
#define RCC_PLL2DIVR_PLL2N_0   (0x001UL << RCC_PLL2DIVR_PLL2N_Pos)
#define RCC_PLL2DIVR_PLL2N_1   (0x002UL << RCC_PLL2DIVR_PLL2N_Pos)
#define RCC_PLL2DIVR_PLL2N_2   (0x004UL << RCC_PLL2DIVR_PLL2N_Pos)
#define RCC_PLL2DIVR_PLL2N_3   (0x008UL << RCC_PLL2DIVR_PLL2N_Pos)
#define RCC_PLL2DIVR_PLL2N_4   (0x010UL << RCC_PLL2DIVR_PLL2N_Pos)
#define RCC_PLL2DIVR_PLL2N_5   (0x020UL << RCC_PLL2DIVR_PLL2N_Pos)
#define RCC_PLL2DIVR_PLL2N_6   (0x040UL << RCC_PLL2DIVR_PLL2N_Pos)
#define RCC_PLL2DIVR_PLL2N_7   (0x080UL << RCC_PLL2DIVR_PLL2N_Pos)
#define RCC_PLL2DIVR_PLL2N_8   (0x100UL << RCC_PLL2DIVR_PLL2N_Pos)
#define RCC_PLL2DIVR_PLL2P_Pos   (9U)
#define RCC_PLL2DIVR_PLL2P_Msk   (0x7FUL << RCC_PLL2DIVR_PLL2P_Pos)
#define RCC_PLL2DIVR_PLL2P   RCC_PLL2DIVR_PLL2P_Msk
#define RCC_PLL2DIVR_PLL2P_0   (0x001UL << RCC_PLL2DIVR_PLL2P_Pos)
#define RCC_PLL2DIVR_PLL2P_1   (0x002UL << RCC_PLL2DIVR_PLL2P_Pos)
#define RCC_PLL2DIVR_PLL2P_2   (0x004UL << RCC_PLL2DIVR_PLL2P_Pos)
#define RCC_PLL2DIVR_PLL2P_3   (0x008UL << RCC_PLL2DIVR_PLL2P_Pos)
#define RCC_PLL2DIVR_PLL2P_4   (0x010UL << RCC_PLL2DIVR_PLL2P_Pos)
#define RCC_PLL2DIVR_PLL2P_5   (0x020UL << RCC_PLL2DIVR_PLL2P_Pos)
#define RCC_PLL2DIVR_PLL2P_6   (0x040UL << RCC_PLL2DIVR_PLL2P_Pos)
#define RCC_PLL2DIVR_PLL2Q_Pos   (16U)
#define RCC_PLL2DIVR_PLL2Q_Msk   (0x7FUL << RCC_PLL2DIVR_PLL2Q_Pos)
#define RCC_PLL2DIVR_PLL2Q   RCC_PLL2DIVR_PLL2Q_Msk
#define RCC_PLL2DIVR_PLL2Q_0   (0x001UL << RCC_PLL2DIVR_PLL2Q_Pos)
#define RCC_PLL2DIVR_PLL2Q_1   (0x002UL << RCC_PLL2DIVR_PLL2Q_Pos)
#define RCC_PLL2DIVR_PLL2Q_2   (0x004UL << RCC_PLL2DIVR_PLL2Q_Pos)
#define RCC_PLL2DIVR_PLL2Q_3   (0x008UL << RCC_PLL2DIVR_PLL2Q_Pos)
#define RCC_PLL2DIVR_PLL2Q_4   (0x010UL << RCC_PLL2DIVR_PLL2Q_Pos)
#define RCC_PLL2DIVR_PLL2Q_5   (0x020UL << RCC_PLL2DIVR_PLL2Q_Pos)
#define RCC_PLL2DIVR_PLL2Q_6   (0x040UL << RCC_PLL2DIVR_PLL2Q_Pos)
#define RCC_PLL2DIVR_PLL2R_Pos   (24U)
#define RCC_PLL2DIVR_PLL2R_Msk   (0x7FUL << RCC_PLL2DIVR_PLL2R_Pos)
#define RCC_PLL2DIVR_PLL2R   RCC_PLL2DIVR_PLL2R_Msk
#define RCC_PLL2DIVR_PLL2R_0   (0x001UL << RCC_PLL2DIVR_PLL2R_Pos)
#define RCC_PLL2DIVR_PLL2R_1   (0x002UL << RCC_PLL2DIVR_PLL2R_Pos)
#define RCC_PLL2DIVR_PLL2R_2   (0x004UL << RCC_PLL2DIVR_PLL2R_Pos)
#define RCC_PLL2DIVR_PLL2R_3   (0x008UL << RCC_PLL2DIVR_PLL2R_Pos)
#define RCC_PLL2DIVR_PLL2R_4   (0x010UL << RCC_PLL2DIVR_PLL2R_Pos)
#define RCC_PLL2DIVR_PLL2R_5   (0x020UL << RCC_PLL2DIVR_PLL2R_Pos)
#define RCC_PLL2DIVR_PLL2R_6   (0x040UL << RCC_PLL2DIVR_PLL2R_Pos)
#define RCC_PLL2FRACR_PLL2FRACN_Pos   (3U)
#define RCC_PLL2FRACR_PLL2FRACN_Msk   (0x1FFFUL << RCC_PLL2FRACR_PLL2FRACN_Pos)
#define RCC_PLL2FRACR_PLL2FRACN   RCC_PLL2FRACR_PLL2FRACN_Msk
#define RCC_PLL2FRACR_PLL2FRACN_0   (0x0001UL << RCC_PLL2FRACR_PLL2FRACN_Pos)
#define RCC_PLL2FRACR_PLL2FRACN_1   (0x0002UL << RCC_PLL2FRACR_PLL2FRACN_Pos)
#define RCC_PLL2FRACR_PLL2FRACN_2   (0x0004UL << RCC_PLL2FRACR_PLL2FRACN_Pos)
#define RCC_PLL2FRACR_PLL2FRACN_3   (0x0008UL << RCC_PLL2FRACR_PLL2FRACN_Pos)
#define RCC_PLL2FRACR_PLL2FRACN_4   (0x0010UL << RCC_PLL2FRACR_PLL2FRACN_Pos)
#define RCC_PLL2FRACR_PLL2FRACN_5   (0x0020UL << RCC_PLL2FRACR_PLL2FRACN_Pos)
#define RCC_PLL2FRACR_PLL2FRACN_6   (0x0040UL << RCC_PLL2FRACR_PLL2FRACN_Pos)
#define RCC_PLL2FRACR_PLL2FRACN_7   (0x0080UL << RCC_PLL2FRACR_PLL2FRACN_Pos)
#define RCC_PLL2FRACR_PLL2FRACN_8   (0x0100UL << RCC_PLL2FRACR_PLL2FRACN_Pos)
#define RCC_PLL2FRACR_PLL2FRACN_9   (0x0200UL << RCC_PLL2FRACR_PLL2FRACN_Pos)
#define RCC_PLL2FRACR_PLL2FRACN_10   (0x0400UL << RCC_PLL2FRACR_PLL2FRACN_Pos)
#define RCC_PLL2FRACR_PLL2FRACN_11   (0x0800UL << RCC_PLL2FRACR_PLL2FRACN_Pos)
#define RCC_PLL2FRACR_PLL2FRACN_12   (0x1000UL << RCC_PLL2FRACR_PLL2FRACN_Pos)
#define RCC_PLL3DIVR_PLL3N_Pos   (0U)
#define RCC_PLL3DIVR_PLL3N_Msk   (0x1FFUL << RCC_PLL3DIVR_PLL3N_Pos)
#define RCC_PLL3DIVR_PLL3N   RCC_PLL3DIVR_PLL3N_Msk
#define RCC_PLL3DIVR_PLL3N_0   (0x001UL << RCC_PLL3DIVR_PLL3N_Pos)
#define RCC_PLL3DIVR_PLL3N_1   (0x002UL << RCC_PLL3DIVR_PLL3N_Pos)
#define RCC_PLL3DIVR_PLL3N_2   (0x004UL << RCC_PLL3DIVR_PLL3N_Pos)
#define RCC_PLL3DIVR_PLL3N_3   (0x008UL << RCC_PLL3DIVR_PLL3N_Pos)
#define RCC_PLL3DIVR_PLL3N_4   (0x010UL << RCC_PLL3DIVR_PLL3N_Pos)
#define RCC_PLL3DIVR_PLL3N_5   (0x020UL << RCC_PLL3DIVR_PLL3N_Pos)
#define RCC_PLL3DIVR_PLL3N_6   (0x040UL << RCC_PLL3DIVR_PLL3N_Pos)
#define RCC_PLL3DIVR_PLL3N_7   (0x080UL << RCC_PLL3DIVR_PLL3N_Pos)
#define RCC_PLL3DIVR_PLL3N_8   (0x100UL << RCC_PLL3DIVR_PLL3N_Pos)
#define RCC_PLL3DIVR_PLL3P_Pos   (9U)
#define RCC_PLL3DIVR_PLL3P_Msk   (0x7FUL << RCC_PLL3DIVR_PLL3P_Pos)
#define RCC_PLL3DIVR_PLL3P   RCC_PLL3DIVR_PLL3P_Msk
#define RCC_PLL3DIVR_PLL3P_0   (0x001UL << RCC_PLL3DIVR_PLL3P_Pos)
#define RCC_PLL3DIVR_PLL3P_1   (0x002UL << RCC_PLL3DIVR_PLL3P_Pos)
#define RCC_PLL3DIVR_PLL3P_2   (0x004UL << RCC_PLL3DIVR_PLL3P_Pos)
#define RCC_PLL3DIVR_PLL3P_3   (0x008UL << RCC_PLL3DIVR_PLL3P_Pos)
#define RCC_PLL3DIVR_PLL3P_4   (0x010UL << RCC_PLL3DIVR_PLL3P_Pos)
#define RCC_PLL3DIVR_PLL3P_5   (0x020UL << RCC_PLL3DIVR_PLL3P_Pos)
#define RCC_PLL3DIVR_PLL3P_6   (0x040UL << RCC_PLL3DIVR_PLL3P_Pos)
#define RCC_PLL3DIVR_PLL3Q_Pos   (16U)
#define RCC_PLL3DIVR_PLL3Q_Msk   (0x7FUL << RCC_PLL3DIVR_PLL3Q_Pos)
#define RCC_PLL3DIVR_PLL3Q   RCC_PLL3DIVR_PLL3Q_Msk
#define RCC_PLL3DIVR_PLL3Q_0   (0x001UL << RCC_PLL3DIVR_PLL3Q_Pos)
#define RCC_PLL3DIVR_PLL3Q_1   (0x002UL << RCC_PLL3DIVR_PLL3Q_Pos)
#define RCC_PLL3DIVR_PLL3Q_2   (0x004UL << RCC_PLL3DIVR_PLL3Q_Pos)
#define RCC_PLL3DIVR_PLL3Q_3   (0x008UL << RCC_PLL3DIVR_PLL3Q_Pos)
#define RCC_PLL3DIVR_PLL3Q_4   (0x010UL << RCC_PLL3DIVR_PLL3Q_Pos)
#define RCC_PLL3DIVR_PLL3Q_5   (0x020UL << RCC_PLL3DIVR_PLL3Q_Pos)
#define RCC_PLL3DIVR_PLL3Q_6   (0x040UL << RCC_PLL3DIVR_PLL3Q_Pos)
#define RCC_PLL3DIVR_PLL3R_Pos   (24U)
#define RCC_PLL3DIVR_PLL3R_Msk   (0x7FUL << RCC_PLL3DIVR_PLL3R_Pos)
#define RCC_PLL3DIVR_PLL3R   RCC_PLL3DIVR_PLL3R_Msk
#define RCC_PLL3DIVR_PLL3R_0   (0x001UL << RCC_PLL3DIVR_PLL3R_Pos)
#define RCC_PLL3DIVR_PLL3R_1   (0x002UL << RCC_PLL3DIVR_PLL3R_Pos)
#define RCC_PLL3DIVR_PLL3R_2   (0x004UL << RCC_PLL3DIVR_PLL3R_Pos)
#define RCC_PLL3DIVR_PLL3R_3   (0x008UL << RCC_PLL3DIVR_PLL3R_Pos)
#define RCC_PLL3DIVR_PLL3R_4   (0x010UL << RCC_PLL3DIVR_PLL3R_Pos)
#define RCC_PLL3DIVR_PLL3R_5   (0x020UL << RCC_PLL3DIVR_PLL3R_Pos)
#define RCC_PLL3DIVR_PLL3R_6   (0x040UL << RCC_PLL3DIVR_PLL3R_Pos)
#define RCC_PLL3FRACR_PLL3FRACN_Pos   (3U)
#define RCC_PLL3FRACR_PLL3FRACN_Msk   (0x1FFFUL << RCC_PLL3FRACR_PLL3FRACN_Pos)
#define RCC_PLL3FRACR_PLL3FRACN   RCC_PLL3FRACR_PLL3FRACN_Msk
#define RCC_PLL3FRACR_PLL3FRACN_0   (0x0001UL << RCC_PLL3FRACR_PLL3FRACN_Pos)
#define RCC_PLL3FRACR_PLL3FRACN_1   (0x0002UL << RCC_PLL3FRACR_PLL3FRACN_Pos)
#define RCC_PLL3FRACR_PLL3FRACN_2   (0x0004UL << RCC_PLL3FRACR_PLL3FRACN_Pos)
#define RCC_PLL3FRACR_PLL3FRACN_3   (0x0008UL << RCC_PLL3FRACR_PLL3FRACN_Pos)
#define RCC_PLL3FRACR_PLL3FRACN_4   (0x0010UL << RCC_PLL3FRACR_PLL3FRACN_Pos)
#define RCC_PLL3FRACR_PLL3FRACN_5   (0x0020UL << RCC_PLL3FRACR_PLL3FRACN_Pos)
#define RCC_PLL3FRACR_PLL3FRACN_6   (0x0040UL << RCC_PLL3FRACR_PLL3FRACN_Pos)
#define RCC_PLL3FRACR_PLL3FRACN_7   (0x0080UL << RCC_PLL3FRACR_PLL3FRACN_Pos)
#define RCC_PLL3FRACR_PLL3FRACN_8   (0x0100UL << RCC_PLL3FRACR_PLL3FRACN_Pos)
#define RCC_PLL3FRACR_PLL3FRACN_9   (0x0200UL << RCC_PLL3FRACR_PLL3FRACN_Pos)
#define RCC_PLL3FRACR_PLL3FRACN_10   (0x0400UL << RCC_PLL3FRACR_PLL3FRACN_Pos)
#define RCC_PLL3FRACR_PLL3FRACN_11   (0x0800UL << RCC_PLL3FRACR_PLL3FRACN_Pos)
#define RCC_PLL3FRACR_PLL3FRACN_12   (0x1000UL << RCC_PLL3FRACR_PLL3FRACN_Pos)
#define RCC_CIER_LSIRDYIE_Pos   (0U)
#define RCC_CIER_LSIRDYIE_Msk   (0x1UL << RCC_CIER_LSIRDYIE_Pos)
#define RCC_CIER_LSIRDYIE   RCC_CIER_LSIRDYIE_Msk
#define RCC_CIER_LSERDYIE_Pos   (1U)
#define RCC_CIER_LSERDYIE_Msk   (0x1UL << RCC_CIER_LSERDYIE_Pos)
#define RCC_CIER_LSERDYIE   RCC_CIER_LSERDYIE_Msk
#define RCC_CIER_MSISRDYIE_Pos   (2U)
#define RCC_CIER_MSISRDYIE_Msk   (0x1UL << RCC_CIER_MSISRDYIE_Pos)
#define RCC_CIER_MSISRDYIE   RCC_CIER_MSISRDYIE_Msk
#define RCC_CIER_HSIRDYIE_Pos   (3U)
#define RCC_CIER_HSIRDYIE_Msk   (0x1UL << RCC_CIER_HSIRDYIE_Pos)
#define RCC_CIER_HSIRDYIE   RCC_CIER_HSIRDYIE_Msk
#define RCC_CIER_HSERDYIE_Pos   (4U)
#define RCC_CIER_HSERDYIE_Msk   (0x1UL << RCC_CIER_HSERDYIE_Pos)
#define RCC_CIER_HSERDYIE   RCC_CIER_HSERDYIE_Msk
#define RCC_CIER_HSI48RDYIE_Pos   (5U)
#define RCC_CIER_HSI48RDYIE_Msk   (0x1UL << RCC_CIER_HSI48RDYIE_Pos)
#define RCC_CIER_HSI48RDYIE   RCC_CIER_HSI48RDYIE_Msk
#define RCC_CIER_PLL1RDYIE_Pos   (6U)
#define RCC_CIER_PLL1RDYIE_Msk   (0x1UL << RCC_CIER_PLL1RDYIE_Pos)
#define RCC_CIER_PLL1RDYIE   RCC_CIER_PLL1RDYIE_Msk
#define RCC_CIER_PLL2RDYIE_Pos   (7U)
#define RCC_CIER_PLL2RDYIE_Msk   (0x1UL << RCC_CIER_PLL2RDYIE_Pos)
#define RCC_CIER_PLL2RDYIE   RCC_CIER_PLL2RDYIE_Msk
#define RCC_CIER_PLL3RDYIE_Pos   (8U)
#define RCC_CIER_PLL3RDYIE_Msk   (0x1UL << RCC_CIER_PLL3RDYIE_Pos)
#define RCC_CIER_PLL3RDYIE   RCC_CIER_PLL3RDYIE_Msk
#define RCC_CIER_MSIKRDYIE_Pos   (11U)
#define RCC_CIER_MSIKRDYIE_Msk   (0x1UL << RCC_CIER_MSIKRDYIE_Pos)
#define RCC_CIER_MSIKRDYIE   RCC_CIER_MSIKRDYIE_Msk
#define RCC_CIER_SHSIRDYIE_Pos   (12U)
#define RCC_CIER_SHSIRDYIE_Msk   (0x1UL << RCC_CIER_SHSIRDYIE_Pos)
#define RCC_CIER_SHSIRDYIE   RCC_CIER_SHSIRDYIE_Msk
#define RCC_CIFR_LSIRDYF_Pos   (0U)
#define RCC_CIFR_LSIRDYF_Msk   (0x1UL << RCC_CIFR_LSIRDYF_Pos)
#define RCC_CIFR_LSIRDYF   RCC_CIFR_LSIRDYF_Msk
#define RCC_CIFR_LSERDYF_Pos   (1U)
#define RCC_CIFR_LSERDYF_Msk   (0x1UL << RCC_CIFR_LSERDYF_Pos)
#define RCC_CIFR_LSERDYF   RCC_CIFR_LSERDYF_Msk
#define RCC_CIFR_MSISRDYF_Pos   (2U)
#define RCC_CIFR_MSISRDYF_Msk   (0x1UL << RCC_CIFR_MSISRDYF_Pos)
#define RCC_CIFR_MSISRDYF   RCC_CIFR_MSISRDYF_Msk
#define RCC_CIFR_HSIRDYF_Pos   (3U)
#define RCC_CIFR_HSIRDYF_Msk   (0x1UL << RCC_CIFR_HSIRDYF_Pos)
#define RCC_CIFR_HSIRDYF   RCC_CIFR_HSIRDYF_Msk
#define RCC_CIFR_HSERDYF_Pos   (4U)
#define RCC_CIFR_HSERDYF_Msk   (0x1UL << RCC_CIFR_HSERDYF_Pos)
#define RCC_CIFR_HSERDYF   RCC_CIFR_HSERDYF_Msk
#define RCC_CIFR_HSI48RDYF_Pos   (5U)
#define RCC_CIFR_HSI48RDYF_Msk   (0x1UL << RCC_CIFR_HSI48RDYF_Pos)
#define RCC_CIFR_HSI48RDYF   RCC_CIFR_HSI48RDYF_Msk
#define RCC_CIFR_PLL1RDYF_Pos   (6U)
#define RCC_CIFR_PLL1RDYF_Msk   (0x1UL << RCC_CIFR_PLL1RDYF_Pos)
#define RCC_CIFR_PLL1RDYF   RCC_CIFR_PLL1RDYF_Msk
#define RCC_CIFR_PLL2RDYF_Pos   (7U)
#define RCC_CIFR_PLL2RDYF_Msk   (0x1UL << RCC_CIFR_PLL2RDYF_Pos)
#define RCC_CIFR_PLL2RDYF   RCC_CIFR_PLL2RDYF_Msk
#define RCC_CIFR_PLL3RDYF_Pos   (8U)
#define RCC_CIFR_PLL3RDYF_Msk   (0x1UL << RCC_CIFR_PLL3RDYF_Pos)
#define RCC_CIFR_PLL3RDYF   RCC_CIFR_PLL3RDYF_Msk
#define RCC_CIFR_CSSF_Pos   (10U)
#define RCC_CIFR_CSSF_Msk   (0x1UL << RCC_CIFR_CSSF_Pos)
#define RCC_CIFR_CSSF   RCC_CIFR_CSSF_Msk
#define RCC_CIFR_MSIKRDYF_Pos   (11U)
#define RCC_CIFR_MSIKRDYF_Msk   (0x1UL << RCC_CIFR_MSIKRDYF_Pos)
#define RCC_CIFR_MSIKRDYF   RCC_CIFR_MSIKRDYF_Msk
#define RCC_CIFR_SHSIRDYF_Pos   (12U)
#define RCC_CIFR_SHSIRDYF_Msk   (0x1UL << RCC_CIFR_SHSIRDYF_Pos)
#define RCC_CIFR_SHSIRDYF   RCC_CIFR_SHSIRDYF_Msk
#define RCC_CICR_LSIRDYC_Pos   (0U)
#define RCC_CICR_LSIRDYC_Msk   (0x1UL << RCC_CICR_LSIRDYC_Pos)
#define RCC_CICR_LSIRDYC   RCC_CICR_LSIRDYC_Msk
#define RCC_CICR_LSERDYC_Pos   (1U)
#define RCC_CICR_LSERDYC_Msk   (0x1UL << RCC_CICR_LSERDYC_Pos)
#define RCC_CICR_LSERDYC   RCC_CICR_LSERDYC_Msk
#define RCC_CICR_MSISRDYC_Pos   (2U)
#define RCC_CICR_MSISRDYC_Msk   (0x1UL << RCC_CICR_MSISRDYC_Pos)
#define RCC_CICR_MSISRDYC   RCC_CICR_MSISRDYC_Msk
#define RCC_CICR_HSIRDYC_Pos   (3U)
#define RCC_CICR_HSIRDYC_Msk   (0x1UL << RCC_CICR_HSIRDYC_Pos)
#define RCC_CICR_HSIRDYC   RCC_CICR_HSIRDYC_Msk
#define RCC_CICR_HSERDYC_Pos   (4U)
#define RCC_CICR_HSERDYC_Msk   (0x1UL << RCC_CICR_HSERDYC_Pos)
#define RCC_CICR_HSERDYC   RCC_CICR_HSERDYC_Msk
#define RCC_CICR_HSI48RDYC_Pos   (5U)
#define RCC_CICR_HSI48RDYC_Msk   (0x1UL << RCC_CICR_HSI48RDYC_Pos)
#define RCC_CICR_HSI48RDYC   RCC_CICR_HSI48RDYC_Msk
#define RCC_CICR_PLL1RDYC_Pos   (6U)
#define RCC_CICR_PLL1RDYC_Msk   (0x1UL << RCC_CICR_PLL1RDYC_Pos)
#define RCC_CICR_PLL1RDYC   RCC_CICR_PLL1RDYC_Msk
#define RCC_CICR_PLL2RDYC_Pos   (7U)
#define RCC_CICR_PLL2RDYC_Msk   (0x1UL << RCC_CICR_PLL2RDYC_Pos)
#define RCC_CICR_PLL2RDYC   RCC_CICR_PLL2RDYC_Msk
#define RCC_CICR_PLL3RDYC_Pos   (8U)
#define RCC_CICR_PLL3RDYC_Msk   (0x1UL << RCC_CICR_PLL3RDYC_Pos)
#define RCC_CICR_PLL3RDYC   RCC_CICR_PLL3RDYC_Msk
#define RCC_CICR_CSSC_Pos   (10U)
#define RCC_CICR_CSSC_Msk   (0x1UL << RCC_CICR_CSSC_Pos)
#define RCC_CICR_CSSC   RCC_CICR_CSSC_Msk
#define RCC_CICR_MSIKRDYC_Pos   (11U)
#define RCC_CICR_MSIKRDYC_Msk   (0x1UL << RCC_CICR_MSIKRDYC_Pos)
#define RCC_CICR_MSIKRDYC   RCC_CICR_MSIKRDYC_Msk
#define RCC_CICR_SHSIRDYC_Pos   (12U)
#define RCC_CICR_SHSIRDYC_Msk   (0x1UL << RCC_CICR_SHSIRDYC_Pos)
#define RCC_CICR_SHSIRDYC   RCC_CICR_SHSIRDYC_Msk
#define RCC_AHB1RSTR_GPDMA1RST_Pos   (0U)
#define RCC_AHB1RSTR_GPDMA1RST_Msk   (0x1UL << RCC_AHB1RSTR_GPDMA1RST_Pos)
#define RCC_AHB1RSTR_GPDMA1RST   RCC_AHB1RSTR_GPDMA1RST_Msk
#define RCC_AHB1RSTR_CORDICRST_Pos   (1U)
#define RCC_AHB1RSTR_CORDICRST_Msk   (0x1UL << RCC_AHB1RSTR_CORDICRST_Pos)
#define RCC_AHB1RSTR_CORDICRST   RCC_AHB1RSTR_CORDICRST_Msk
#define RCC_AHB1RSTR_FMACRST_Pos   (2U)
#define RCC_AHB1RSTR_FMACRST_Msk   (0x1UL << RCC_AHB1RSTR_FMACRST_Pos)
#define RCC_AHB1RSTR_FMACRST   RCC_AHB1RSTR_FMACRST_Msk
#define RCC_AHB1RSTR_MDF1RST_Pos   (3U)
#define RCC_AHB1RSTR_MDF1RST_Msk   (0x1UL << RCC_AHB1RSTR_MDF1RST_Pos)
#define RCC_AHB1RSTR_MDF1RST   RCC_AHB1RSTR_MDF1RST_Msk
#define RCC_AHB1RSTR_CRCRST_Pos   (12U)
#define RCC_AHB1RSTR_CRCRST_Msk   (0x1UL << RCC_AHB1RSTR_CRCRST_Pos)
#define RCC_AHB1RSTR_CRCRST   RCC_AHB1RSTR_CRCRST_Msk
#define RCC_AHB1RSTR_JPEGRST_Pos   (15U)
#define RCC_AHB1RSTR_JPEGRST_Msk   (0x1UL << RCC_AHB1RSTR_JPEGRST_Pos)
#define RCC_AHB1RSTR_JPEGRST   RCC_AHB1RSTR_JPEGRST_Msk
#define RCC_AHB1RSTR_TSCRST_Pos   (16U)
#define RCC_AHB1RSTR_TSCRST_Msk   (0x1UL << RCC_AHB1RSTR_TSCRST_Pos)
#define RCC_AHB1RSTR_TSCRST   RCC_AHB1RSTR_TSCRST_Msk
#define RCC_AHB1RSTR_RAMCFGRST_Pos   (17U)
#define RCC_AHB1RSTR_RAMCFGRST_Msk   (0x1UL << RCC_AHB1RSTR_RAMCFGRST_Pos)
#define RCC_AHB1RSTR_RAMCFGRST   RCC_AHB1RSTR_RAMCFGRST_Msk
#define RCC_AHB1RSTR_DMA2DRST_Pos   (18U)
#define RCC_AHB1RSTR_DMA2DRST_Msk   (0x1UL << RCC_AHB1RSTR_DMA2DRST_Pos)
#define RCC_AHB1RSTR_DMA2DRST   RCC_AHB1RSTR_DMA2DRST_Msk
#define RCC_AHB1RSTR_GFXMMURST_Pos   (19U)
#define RCC_AHB1RSTR_GFXMMURST_Msk   (0x1UL << RCC_AHB1RSTR_GFXMMURST_Pos)
#define RCC_AHB1RSTR_GFXMMURST   RCC_AHB1RSTR_GFXMMURST_Msk
#define RCC_AHB1RSTR_GPU2DRST_Pos   (20U)
#define RCC_AHB1RSTR_GPU2DRST_Msk   (0x1UL << RCC_AHB1RSTR_GPU2DRST_Pos)
#define RCC_AHB1RSTR_GPU2DRST   RCC_AHB1RSTR_GPU2DRST_Msk
#define RCC_AHB2RSTR1_GPIOARST_Pos   (0U)
#define RCC_AHB2RSTR1_GPIOARST_Msk   (0x1UL << RCC_AHB2RSTR1_GPIOARST_Pos)
#define RCC_AHB2RSTR1_GPIOARST   RCC_AHB2RSTR1_GPIOARST_Msk
#define RCC_AHB2RSTR1_GPIOBRST_Pos   (1U)
#define RCC_AHB2RSTR1_GPIOBRST_Msk   (0x1UL << RCC_AHB2RSTR1_GPIOBRST_Pos)
#define RCC_AHB2RSTR1_GPIOBRST   RCC_AHB2RSTR1_GPIOBRST_Msk
#define RCC_AHB2RSTR1_GPIOCRST_Pos   (2U)
#define RCC_AHB2RSTR1_GPIOCRST_Msk   (0x1UL << RCC_AHB2RSTR1_GPIOCRST_Pos)
#define RCC_AHB2RSTR1_GPIOCRST   RCC_AHB2RSTR1_GPIOCRST_Msk
#define RCC_AHB2RSTR1_GPIODRST_Pos   (3U)
#define RCC_AHB2RSTR1_GPIODRST_Msk   (0x1UL << RCC_AHB2RSTR1_GPIODRST_Pos)
#define RCC_AHB2RSTR1_GPIODRST   RCC_AHB2RSTR1_GPIODRST_Msk
#define RCC_AHB2RSTR1_GPIOERST_Pos   (4U)
#define RCC_AHB2RSTR1_GPIOERST_Msk   (0x1UL << RCC_AHB2RSTR1_GPIOERST_Pos)
#define RCC_AHB2RSTR1_GPIOERST   RCC_AHB2RSTR1_GPIOERST_Msk
#define RCC_AHB2RSTR1_GPIOFRST_Pos   (5U)
#define RCC_AHB2RSTR1_GPIOFRST_Msk   (0x1UL << RCC_AHB2RSTR1_GPIOFRST_Pos)
#define RCC_AHB2RSTR1_GPIOFRST   RCC_AHB2RSTR1_GPIOFRST_Msk
#define RCC_AHB2RSTR1_GPIOGRST_Pos   (6U)
#define RCC_AHB2RSTR1_GPIOGRST_Msk   (0x1UL << RCC_AHB2RSTR1_GPIOGRST_Pos)
#define RCC_AHB2RSTR1_GPIOGRST   RCC_AHB2RSTR1_GPIOGRST_Msk
#define RCC_AHB2RSTR1_GPIOHRST_Pos   (7U)
#define RCC_AHB2RSTR1_GPIOHRST_Msk   (0x1UL << RCC_AHB2RSTR1_GPIOHRST_Pos)
#define RCC_AHB2RSTR1_GPIOHRST   RCC_AHB2RSTR1_GPIOHRST_Msk
#define RCC_AHB2RSTR1_GPIOIRST_Pos   (8U)
#define RCC_AHB2RSTR1_GPIOIRST_Msk   (0x1UL << RCC_AHB2RSTR1_GPIOIRST_Pos)
#define RCC_AHB2RSTR1_GPIOIRST   RCC_AHB2RSTR1_GPIOIRST_Msk
#define RCC_AHB2RSTR1_GPIOJRST_Pos   (9U)
#define RCC_AHB2RSTR1_GPIOJRST_Msk   (0x1UL << RCC_AHB2RSTR1_GPIOJRST_Pos)
#define RCC_AHB2RSTR1_GPIOJRST   RCC_AHB2RSTR1_GPIOJRST_Msk
#define RCC_AHB2RSTR1_ADC12RST_Pos   (10U)
#define RCC_AHB2RSTR1_ADC12RST_Msk   (0x1UL << RCC_AHB2RSTR1_ADC12RST_Pos)
#define RCC_AHB2RSTR1_ADC12RST   RCC_AHB2RSTR1_ADC12RST_Msk
#define RCC_AHB2RSTR1_DCMI_PSSIRST_Pos   (12U)
#define RCC_AHB2RSTR1_DCMI_PSSIRST_Msk   (0x1UL << RCC_AHB2RSTR1_DCMI_PSSIRST_Pos)
#define RCC_AHB2RSTR1_DCMI_PSSIRST   RCC_AHB2RSTR1_DCMI_PSSIRST_Msk
#define RCC_AHB2RSTR1_OTGRST_Pos   (14U)
#define RCC_AHB2RSTR1_OTGRST_Msk   (0x1UL << RCC_AHB2RSTR1_OTGRST_Pos)
#define RCC_AHB2RSTR1_OTGRST   RCC_AHB2RSTR1_OTGRST_Msk
#define RCC_AHB2RSTR1_AESRST_Pos   (16U)
#define RCC_AHB2RSTR1_AESRST_Msk   (0x1UL << RCC_AHB2RSTR1_AESRST_Pos)
#define RCC_AHB2RSTR1_AESRST   RCC_AHB2RSTR1_AESRST_Msk
#define RCC_AHB2RSTR1_HASHRST_Pos   (17U)
#define RCC_AHB2RSTR1_HASHRST_Msk   (0x1UL << RCC_AHB2RSTR1_HASHRST_Pos)
#define RCC_AHB2RSTR1_HASHRST   RCC_AHB2RSTR1_HASHRST_Msk
#define RCC_AHB2RSTR1_RNGRST_Pos   (18U)
#define RCC_AHB2RSTR1_RNGRST_Msk   (0x1UL << RCC_AHB2RSTR1_RNGRST_Pos)
#define RCC_AHB2RSTR1_RNGRST   RCC_AHB2RSTR1_RNGRST_Msk
#define RCC_AHB2RSTR1_PKARST_Pos   (19U)
#define RCC_AHB2RSTR1_PKARST_Msk   (0x1UL << RCC_AHB2RSTR1_PKARST_Pos)
#define RCC_AHB2RSTR1_PKARST   RCC_AHB2RSTR1_PKARST_Msk
#define RCC_AHB2RSTR1_SAESRST_Pos   (20U)
#define RCC_AHB2RSTR1_SAESRST_Msk   (0x1UL << RCC_AHB2RSTR1_SAESRST_Pos)
#define RCC_AHB2RSTR1_SAESRST   RCC_AHB2RSTR1_SAESRST_Msk
#define RCC_AHB2RSTR1_OCTOSPIMRST_Pos   (21U)
#define RCC_AHB2RSTR1_OCTOSPIMRST_Msk   (0x1UL << RCC_AHB2RSTR1_OCTOSPIMRST_Pos)
#define RCC_AHB2RSTR1_OCTOSPIMRST   RCC_AHB2RSTR1_OCTOSPIMRST_Msk
#define RCC_AHB2RSTR1_OTFDEC1RST_Pos   (23U)
#define RCC_AHB2RSTR1_OTFDEC1RST_Msk   (0x1UL << RCC_AHB2RSTR1_OTFDEC1RST_Pos)
#define RCC_AHB2RSTR1_OTFDEC1RST   RCC_AHB2RSTR1_OTFDEC1RST_Msk
#define RCC_AHB2RSTR1_OTFDEC2RST_Pos   (24U)
#define RCC_AHB2RSTR1_OTFDEC2RST_Msk   (0x1UL << RCC_AHB2RSTR1_OTFDEC2RST_Pos)
#define RCC_AHB2RSTR1_OTFDEC2RST   RCC_AHB2RSTR1_OTFDEC2RST_Msk
#define RCC_AHB2RSTR1_SDMMC1RST_Pos   (27U)
#define RCC_AHB2RSTR1_SDMMC1RST_Msk   (0x1UL << RCC_AHB2RSTR1_SDMMC1RST_Pos)
#define RCC_AHB2RSTR1_SDMMC1RST   RCC_AHB2RSTR1_SDMMC1RST_Msk
#define RCC_AHB2RSTR1_SDMMC2RST_Pos   (28U)
#define RCC_AHB2RSTR1_SDMMC2RST_Msk   (0x1UL << RCC_AHB2RSTR1_SDMMC2RST_Pos)
#define RCC_AHB2RSTR1_SDMMC2RST   RCC_AHB2RSTR1_SDMMC2RST_Msk
#define RCC_AHB2RSTR2_FSMCRST_Pos   (0U)
#define RCC_AHB2RSTR2_FSMCRST_Msk   (0x1UL << RCC_AHB2RSTR2_FSMCRST_Pos)
#define RCC_AHB2RSTR2_FSMCRST   RCC_AHB2RSTR2_FSMCRST_Msk
#define RCC_AHB2RSTR2_OCTOSPI1RST_Pos   (4U)
#define RCC_AHB2RSTR2_OCTOSPI1RST_Msk   (0x1UL << RCC_AHB2RSTR2_OCTOSPI1RST_Pos)
#define RCC_AHB2RSTR2_OCTOSPI1RST   RCC_AHB2RSTR2_OCTOSPI1RST_Msk
#define RCC_AHB2RSTR2_OCTOSPI2RST_Pos   (8U)
#define RCC_AHB2RSTR2_OCTOSPI2RST_Msk   (0x1UL << RCC_AHB2RSTR2_OCTOSPI2RST_Pos)
#define RCC_AHB2RSTR2_OCTOSPI2RST   RCC_AHB2RSTR2_OCTOSPI2RST_Msk
#define RCC_AHB2RSTR2_HSPI1RST_Pos   (12U)
#define RCC_AHB2RSTR2_HSPI1RST_Msk   (0x1UL << RCC_AHB2RSTR2_HSPI1RST_Pos)
#define RCC_AHB2RSTR2_HSPI1RST   RCC_AHB2RSTR2_HSPI1RST_Msk
#define RCC_AHB3RSTR_LPGPIO1RST_Pos   (0U)
#define RCC_AHB3RSTR_LPGPIO1RST_Msk   (0x1UL << RCC_AHB3RSTR_LPGPIO1RST_Pos)
#define RCC_AHB3RSTR_LPGPIO1RST   RCC_AHB3RSTR_LPGPIO1RST_Msk
#define RCC_AHB3RSTR_ADC4RST_Pos   (5U)
#define RCC_AHB3RSTR_ADC4RST_Msk   (0x1UL << RCC_AHB3RSTR_ADC4RST_Pos)
#define RCC_AHB3RSTR_ADC4RST   RCC_AHB3RSTR_ADC4RST_Msk
#define RCC_AHB3RSTR_DAC1RST_Pos   (6U)
#define RCC_AHB3RSTR_DAC1RST_Msk   (0x1UL << RCC_AHB3RSTR_DAC1RST_Pos)
#define RCC_AHB3RSTR_DAC1RST   RCC_AHB3RSTR_DAC1RST_Msk
#define RCC_AHB3RSTR_LPDMA1RST_Pos   (9U)
#define RCC_AHB3RSTR_LPDMA1RST_Msk   (0x1UL << RCC_AHB3RSTR_LPDMA1RST_Pos)
#define RCC_AHB3RSTR_LPDMA1RST   RCC_AHB3RSTR_LPDMA1RST_Msk
#define RCC_AHB3RSTR_ADF1RST_Pos   (10U)
#define RCC_AHB3RSTR_ADF1RST_Msk   (0x1UL << RCC_AHB3RSTR_ADF1RST_Pos)
#define RCC_AHB3RSTR_ADF1RST   RCC_AHB3RSTR_ADF1RST_Msk
#define RCC_APB1RSTR1_TIM2RST_Pos   (0U)
#define RCC_APB1RSTR1_TIM2RST_Msk   (0x1UL << RCC_APB1RSTR1_TIM2RST_Pos)
#define RCC_APB1RSTR1_TIM2RST   RCC_APB1RSTR1_TIM2RST_Msk
#define RCC_APB1RSTR1_TIM3RST_Pos   (1U)
#define RCC_APB1RSTR1_TIM3RST_Msk   (0x1UL << RCC_APB1RSTR1_TIM3RST_Pos)
#define RCC_APB1RSTR1_TIM3RST   RCC_APB1RSTR1_TIM3RST_Msk
#define RCC_APB1RSTR1_TIM4RST_Pos   (2U)
#define RCC_APB1RSTR1_TIM4RST_Msk   (0x1UL << RCC_APB1RSTR1_TIM4RST_Pos)
#define RCC_APB1RSTR1_TIM4RST   RCC_APB1RSTR1_TIM4RST_Msk
#define RCC_APB1RSTR1_TIM5RST_Pos   (3U)
#define RCC_APB1RSTR1_TIM5RST_Msk   (0x1UL << RCC_APB1RSTR1_TIM5RST_Pos)
#define RCC_APB1RSTR1_TIM5RST   RCC_APB1RSTR1_TIM5RST_Msk
#define RCC_APB1RSTR1_TIM6RST_Pos   (4U)
#define RCC_APB1RSTR1_TIM6RST_Msk   (0x1UL << RCC_APB1RSTR1_TIM6RST_Pos)
#define RCC_APB1RSTR1_TIM6RST   RCC_APB1RSTR1_TIM6RST_Msk
#define RCC_APB1RSTR1_TIM7RST_Pos   (5U)
#define RCC_APB1RSTR1_TIM7RST_Msk   (0x1UL << RCC_APB1RSTR1_TIM7RST_Pos)
#define RCC_APB1RSTR1_TIM7RST   RCC_APB1RSTR1_TIM7RST_Msk
#define RCC_APB1RSTR1_SPI2RST_Pos   (14U)
#define RCC_APB1RSTR1_SPI2RST_Msk   (0x1UL << RCC_APB1RSTR1_SPI2RST_Pos)
#define RCC_APB1RSTR1_SPI2RST   RCC_APB1RSTR1_SPI2RST_Msk
#define RCC_APB1RSTR1_USART2RST_Pos   (17U)
#define RCC_APB1RSTR1_USART2RST_Msk   (0x1UL << RCC_APB1RSTR1_USART2RST_Pos)
#define RCC_APB1RSTR1_USART2RST   RCC_APB1RSTR1_USART2RST_Msk
#define RCC_APB1RSTR1_USART3RST_Pos   (18U)
#define RCC_APB1RSTR1_USART3RST_Msk   (0x1UL << RCC_APB1RSTR1_USART3RST_Pos)
#define RCC_APB1RSTR1_USART3RST   RCC_APB1RSTR1_USART3RST_Msk
#define RCC_APB1RSTR1_UART4RST_Pos   (19U)
#define RCC_APB1RSTR1_UART4RST_Msk   (0x1UL << RCC_APB1RSTR1_UART4RST_Pos)
#define RCC_APB1RSTR1_UART4RST   RCC_APB1RSTR1_UART4RST_Msk
#define RCC_APB1RSTR1_UART5RST_Pos   (20U)
#define RCC_APB1RSTR1_UART5RST_Msk   (0x1UL << RCC_APB1RSTR1_UART5RST_Pos)
#define RCC_APB1RSTR1_UART5RST   RCC_APB1RSTR1_UART5RST_Msk
#define RCC_APB1RSTR1_I2C1RST_Pos   (21U)
#define RCC_APB1RSTR1_I2C1RST_Msk   (0x1UL << RCC_APB1RSTR1_I2C1RST_Pos)
#define RCC_APB1RSTR1_I2C1RST   RCC_APB1RSTR1_I2C1RST_Msk
#define RCC_APB1RSTR1_I2C2RST_Pos   (22U)
#define RCC_APB1RSTR1_I2C2RST_Msk   (0x1UL << RCC_APB1RSTR1_I2C2RST_Pos)
#define RCC_APB1RSTR1_I2C2RST   RCC_APB1RSTR1_I2C2RST_Msk
#define RCC_APB1RSTR1_CRSRST_Pos   (24U)
#define RCC_APB1RSTR1_CRSRST_Msk   (0x1UL << RCC_APB1RSTR1_CRSRST_Pos)
#define RCC_APB1RSTR1_CRSRST   RCC_APB1RSTR1_CRSRST_Msk
#define RCC_APB1RSTR1_USART6RST_Pos   (25U)
#define RCC_APB1RSTR1_USART6RST_Msk   (0x1UL << RCC_APB1RSTR1_USART6RST_Pos)
#define RCC_APB1RSTR1_USART6RST   RCC_APB1RSTR1_USART6RST_Msk
#define RCC_APB1RSTR2_I2C4RST_Pos   (1U)
#define RCC_APB1RSTR2_I2C4RST_Msk   (0x1UL << RCC_APB1RSTR2_I2C4RST_Pos)
#define RCC_APB1RSTR2_I2C4RST   RCC_APB1RSTR2_I2C4RST_Msk
#define RCC_APB1RSTR2_LPTIM2RST_Pos   (5U)
#define RCC_APB1RSTR2_LPTIM2RST_Msk   (0x1UL << RCC_APB1RSTR2_LPTIM2RST_Pos)
#define RCC_APB1RSTR2_LPTIM2RST   RCC_APB1RSTR2_LPTIM2RST_Msk
#define RCC_APB1RSTR2_I2C5RST_Pos   (6U)
#define RCC_APB1RSTR2_I2C5RST_Msk   (0x1UL << RCC_APB1RSTR2_I2C5RST_Pos)
#define RCC_APB1RSTR2_I2C5RST   RCC_APB1RSTR2_I2C5RST_Msk
#define RCC_APB1RSTR2_I2C6RST_Pos   (7U)
#define RCC_APB1RSTR2_I2C6RST_Msk   (0x1UL << RCC_APB1RSTR2_I2C6RST_Pos)
#define RCC_APB1RSTR2_I2C6RST   RCC_APB1RSTR2_I2C6RST_Msk
#define RCC_APB1RSTR2_FDCAN1RST_Pos   (9U)
#define RCC_APB1RSTR2_FDCAN1RST_Msk   (0x1UL << RCC_APB1RSTR2_FDCAN1RST_Pos)
#define RCC_APB1RSTR2_FDCAN1RST   RCC_APB1RSTR2_FDCAN1RST_Msk
#define RCC_APB1RSTR2_UCPD1RST_Pos   (23U)
#define RCC_APB1RSTR2_UCPD1RST_Msk   (0x1UL << RCC_APB1RSTR2_UCPD1RST_Pos)
#define RCC_APB1RSTR2_UCPD1RST   RCC_APB1RSTR2_UCPD1RST_Msk
#define RCC_APB2RSTR_TIM1RST_Pos   (11U)
#define RCC_APB2RSTR_TIM1RST_Msk   (0x1UL << RCC_APB2RSTR_TIM1RST_Pos)
#define RCC_APB2RSTR_TIM1RST   RCC_APB2RSTR_TIM1RST_Msk
#define RCC_APB2RSTR_SPI1RST_Pos   (12U)
#define RCC_APB2RSTR_SPI1RST_Msk   (0x1UL << RCC_APB2RSTR_SPI1RST_Pos)
#define RCC_APB2RSTR_SPI1RST   RCC_APB2RSTR_SPI1RST_Msk
#define RCC_APB2RSTR_TIM8RST_Pos   (13U)
#define RCC_APB2RSTR_TIM8RST_Msk   (0x1UL << RCC_APB2RSTR_TIM8RST_Pos)
#define RCC_APB2RSTR_TIM8RST   RCC_APB2RSTR_TIM8RST_Msk
#define RCC_APB2RSTR_USART1RST_Pos   (14U)
#define RCC_APB2RSTR_USART1RST_Msk   (0x1UL << RCC_APB2RSTR_USART1RST_Pos)
#define RCC_APB2RSTR_USART1RST   RCC_APB2RSTR_USART1RST_Msk
#define RCC_APB2RSTR_TIM15RST_Pos   (16U)
#define RCC_APB2RSTR_TIM15RST_Msk   (0x1UL << RCC_APB2RSTR_TIM15RST_Pos)
#define RCC_APB2RSTR_TIM15RST   RCC_APB2RSTR_TIM15RST_Msk
#define RCC_APB2RSTR_TIM16RST_Pos   (17U)
#define RCC_APB2RSTR_TIM16RST_Msk   (0x1UL << RCC_APB2RSTR_TIM16RST_Pos)
#define RCC_APB2RSTR_TIM16RST   RCC_APB2RSTR_TIM16RST_Msk
#define RCC_APB2RSTR_TIM17RST_Pos   (18U)
#define RCC_APB2RSTR_TIM17RST_Msk   (0x1UL << RCC_APB2RSTR_TIM17RST_Pos)
#define RCC_APB2RSTR_TIM17RST   RCC_APB2RSTR_TIM17RST_Msk
#define RCC_APB2RSTR_SAI1RST_Pos   (21U)
#define RCC_APB2RSTR_SAI1RST_Msk   (0x1UL << RCC_APB2RSTR_SAI1RST_Pos)
#define RCC_APB2RSTR_SAI1RST   RCC_APB2RSTR_SAI1RST_Msk
#define RCC_APB2RSTR_SAI2RST_Pos   (22U)
#define RCC_APB2RSTR_SAI2RST_Msk   (0x1UL << RCC_APB2RSTR_SAI2RST_Pos)
#define RCC_APB2RSTR_SAI2RST   RCC_APB2RSTR_SAI2RST_Msk
#define RCC_APB2RSTR_GFXTIMRST_Pos   (25U)
#define RCC_APB2RSTR_GFXTIMRST_Msk   (0x1UL << RCC_APB2RSTR_GFXTIMRST_Pos)
#define RCC_APB2RSTR_GFXTIMRST   RCC_APB2RSTR_GFXTIMRST_Msk
#define RCC_APB2RSTR_LTDCRST_Pos   (26U)
#define RCC_APB2RSTR_LTDCRST_Msk   (0x1UL << RCC_APB2RSTR_LTDCRST_Pos)
#define RCC_APB2RSTR_LTDCRST   RCC_APB2RSTR_LTDCRST_Msk
#define RCC_APB2RSTR_DSIHOSTRST_Pos   (27U)
#define RCC_APB2RSTR_DSIHOSTRST_Msk   (0x1UL << RCC_APB2RSTR_DSIHOSTRST_Pos)
#define RCC_APB2RSTR_DSIHOSTRST   RCC_APB2RSTR_DSIHOSTRST_Msk
#define RCC_APB3RSTR_SYSCFGRST_Pos   (1U)
#define RCC_APB3RSTR_SYSCFGRST_Msk   (0x1UL << RCC_APB3RSTR_SYSCFGRST_Pos)
#define RCC_APB3RSTR_SYSCFGRST   RCC_APB3RSTR_SYSCFGRST_Msk
#define RCC_APB3RSTR_SPI3RST_Pos   (5U)
#define RCC_APB3RSTR_SPI3RST_Msk   (0x1UL << RCC_APB3RSTR_SPI3RST_Pos)
#define RCC_APB3RSTR_SPI3RST   RCC_APB3RSTR_SPI3RST_Msk
#define RCC_APB3RSTR_LPUART1RST_Pos   (6U)
#define RCC_APB3RSTR_LPUART1RST_Msk   (0x1UL << RCC_APB3RSTR_LPUART1RST_Pos)
#define RCC_APB3RSTR_LPUART1RST   RCC_APB3RSTR_LPUART1RST_Msk
#define RCC_APB3RSTR_I2C3RST_Pos   (7U)
#define RCC_APB3RSTR_I2C3RST_Msk   (0x1UL << RCC_APB3RSTR_I2C3RST_Pos)
#define RCC_APB3RSTR_I2C3RST   RCC_APB3RSTR_I2C3RST_Msk
#define RCC_APB3RSTR_LPTIM1RST_Pos   (11U)
#define RCC_APB3RSTR_LPTIM1RST_Msk   (0x1UL << RCC_APB3RSTR_LPTIM1RST_Pos)
#define RCC_APB3RSTR_LPTIM1RST   RCC_APB3RSTR_LPTIM1RST_Msk
#define RCC_APB3RSTR_LPTIM3RST_Pos   (12U)
#define RCC_APB3RSTR_LPTIM3RST_Msk   (0x1UL << RCC_APB3RSTR_LPTIM3RST_Pos)
#define RCC_APB3RSTR_LPTIM3RST   RCC_APB3RSTR_LPTIM3RST_Msk
#define RCC_APB3RSTR_LPTIM4RST_Pos   (13U)
#define RCC_APB3RSTR_LPTIM4RST_Msk   (0x1UL << RCC_APB3RSTR_LPTIM4RST_Pos)
#define RCC_APB3RSTR_LPTIM4RST   RCC_APB3RSTR_LPTIM4RST_Msk
#define RCC_APB3RSTR_OPAMPRST_Pos   (14U)
#define RCC_APB3RSTR_OPAMPRST_Msk   (0x1UL << RCC_APB3RSTR_OPAMPRST_Pos)
#define RCC_APB3RSTR_OPAMPRST   RCC_APB3RSTR_OPAMPRST_Msk
#define RCC_APB3RSTR_COMPRST_Pos   (15U)
#define RCC_APB3RSTR_COMPRST_Msk   (0x1UL << RCC_APB3RSTR_COMPRST_Pos)
#define RCC_APB3RSTR_COMPRST   RCC_APB3RSTR_COMPRST_Msk
#define RCC_APB3RSTR_VREFRST_Pos   (20U)
#define RCC_APB3RSTR_VREFRST_Msk   (0x1UL << RCC_APB3RSTR_VREFRST_Pos)
#define RCC_APB3RSTR_VREFRST   RCC_APB3RSTR_VREFRST_Msk
#define RCC_AHB1ENR_GPDMA1EN_Pos   (0U)
#define RCC_AHB1ENR_GPDMA1EN_Msk   (0x1UL << RCC_AHB1ENR_GPDMA1EN_Pos)
#define RCC_AHB1ENR_GPDMA1EN   RCC_AHB1ENR_GPDMA1EN_Msk
#define RCC_AHB1ENR_CORDICEN_Pos   (1U)
#define RCC_AHB1ENR_CORDICEN_Msk   (0x1UL << RCC_AHB1ENR_CORDICEN_Pos)
#define RCC_AHB1ENR_CORDICEN   RCC_AHB1ENR_CORDICEN_Msk
#define RCC_AHB1ENR_FMACEN_Pos   (2U)
#define RCC_AHB1ENR_FMACEN_Msk   (0x1UL << RCC_AHB1ENR_FMACEN_Pos)
#define RCC_AHB1ENR_FMACEN   RCC_AHB1ENR_FMACEN_Msk
#define RCC_AHB1ENR_MDF1EN_Pos   (3U)
#define RCC_AHB1ENR_MDF1EN_Msk   (0x1UL << RCC_AHB1ENR_MDF1EN_Pos)
#define RCC_AHB1ENR_MDF1EN   RCC_AHB1ENR_MDF1EN_Msk
#define RCC_AHB1ENR_FLASHEN_Pos   (8U)
#define RCC_AHB1ENR_FLASHEN_Msk   (0x1UL << RCC_AHB1ENR_FLASHEN_Pos)
#define RCC_AHB1ENR_FLASHEN   RCC_AHB1ENR_FLASHEN_Msk
#define RCC_AHB1ENR_CRCEN_Pos   (12U)
#define RCC_AHB1ENR_CRCEN_Msk   (0x1UL << RCC_AHB1ENR_CRCEN_Pos)
#define RCC_AHB1ENR_CRCEN   RCC_AHB1ENR_CRCEN_Msk
#define RCC_AHB1ENR_JPEGEN_Pos   (15U)
#define RCC_AHB1ENR_JPEGEN_Msk   (0x1UL << RCC_AHB1ENR_JPEGEN_Pos)
#define RCC_AHB1ENR_JPEGEN   RCC_AHB1ENR_JPEGEN_Msk
#define RCC_AHB1ENR_TSCEN_Pos   (16U)
#define RCC_AHB1ENR_TSCEN_Msk   (0x1UL << RCC_AHB1ENR_TSCEN_Pos)
#define RCC_AHB1ENR_TSCEN   RCC_AHB1ENR_TSCEN_Msk
#define RCC_AHB1ENR_RAMCFGEN_Pos   (17U)
#define RCC_AHB1ENR_RAMCFGEN_Msk   (0x1UL << RCC_AHB1ENR_RAMCFGEN_Pos)
#define RCC_AHB1ENR_RAMCFGEN   RCC_AHB1ENR_RAMCFGEN_Msk
#define RCC_AHB1ENR_DMA2DEN_Pos   (18U)
#define RCC_AHB1ENR_DMA2DEN_Msk   (0x1UL << RCC_AHB1ENR_DMA2DEN_Pos)
#define RCC_AHB1ENR_DMA2DEN   RCC_AHB1ENR_DMA2DEN_Msk
#define RCC_AHB1ENR_GFXMMUEN_Pos   (19U)
#define RCC_AHB1ENR_GFXMMUEN_Msk   (0x1UL << RCC_AHB1ENR_GFXMMUEN_Pos)
#define RCC_AHB1ENR_GFXMMUEN   RCC_AHB1ENR_GFXMMUEN_Msk
#define RCC_AHB1ENR_GPU2DEN_Pos   (20U)
#define RCC_AHB1ENR_GPU2DEN_Msk   (0x1UL << RCC_AHB1ENR_GPU2DEN_Pos)
#define RCC_AHB1ENR_GPU2DEN   RCC_AHB1ENR_GPU2DEN_Msk
#define RCC_AHB1ENR_DCACHE2EN_Pos   (21U)
#define RCC_AHB1ENR_DCACHE2EN_Msk   (0x1UL << RCC_AHB1ENR_DCACHE2EN_Pos)
#define RCC_AHB1ENR_DCACHE2EN   RCC_AHB1ENR_DCACHE2EN_Msk
#define RCC_AHB1ENR_GTZC1EN_Pos   (24U)
#define RCC_AHB1ENR_GTZC1EN_Msk   (0x1UL << RCC_AHB1ENR_GTZC1EN_Pos)
#define RCC_AHB1ENR_GTZC1EN   RCC_AHB1ENR_GTZC1EN_Msk
#define RCC_AHB1ENR_BKPSRAMEN_Pos   (28U)
#define RCC_AHB1ENR_BKPSRAMEN_Msk   (0x1UL << RCC_AHB1ENR_BKPSRAMEN_Pos)
#define RCC_AHB1ENR_BKPSRAMEN   RCC_AHB1ENR_BKPSRAMEN_Msk
#define RCC_AHB1ENR_DCACHE1EN_Pos   (30U)
#define RCC_AHB1ENR_DCACHE1EN_Msk   (0x1UL << RCC_AHB1ENR_DCACHE1EN_Pos)
#define RCC_AHB1ENR_DCACHE1EN   RCC_AHB1ENR_DCACHE1EN_Msk
#define RCC_AHB1ENR_SRAM1EN_Pos   (31U)
#define RCC_AHB1ENR_SRAM1EN_Msk   (0x1UL << RCC_AHB1ENR_SRAM1EN_Pos)
#define RCC_AHB1ENR_SRAM1EN   RCC_AHB1ENR_SRAM1EN_Msk
#define RCC_AHB2ENR1_GPIOAEN_Pos   (0U)
#define RCC_AHB2ENR1_GPIOAEN_Msk   (0x1UL << RCC_AHB2ENR1_GPIOAEN_Pos)
#define RCC_AHB2ENR1_GPIOAEN   RCC_AHB2ENR1_GPIOAEN_Msk
#define RCC_AHB2ENR1_GPIOBEN_Pos   (1U)
#define RCC_AHB2ENR1_GPIOBEN_Msk   (0x1UL << RCC_AHB2ENR1_GPIOBEN_Pos)
#define RCC_AHB2ENR1_GPIOBEN   RCC_AHB2ENR1_GPIOBEN_Msk
#define RCC_AHB2ENR1_GPIOCEN_Pos   (2U)
#define RCC_AHB2ENR1_GPIOCEN_Msk   (0x1UL << RCC_AHB2ENR1_GPIOCEN_Pos)
#define RCC_AHB2ENR1_GPIOCEN   RCC_AHB2ENR1_GPIOCEN_Msk
#define RCC_AHB2ENR1_GPIODEN_Pos   (3U)
#define RCC_AHB2ENR1_GPIODEN_Msk   (0x1UL << RCC_AHB2ENR1_GPIODEN_Pos)
#define RCC_AHB2ENR1_GPIODEN   RCC_AHB2ENR1_GPIODEN_Msk
#define RCC_AHB2ENR1_GPIOEEN_Pos   (4U)
#define RCC_AHB2ENR1_GPIOEEN_Msk   (0x1UL << RCC_AHB2ENR1_GPIOEEN_Pos)
#define RCC_AHB2ENR1_GPIOEEN   RCC_AHB2ENR1_GPIOEEN_Msk
#define RCC_AHB2ENR1_GPIOFEN_Pos   (5U)
#define RCC_AHB2ENR1_GPIOFEN_Msk   (0x1UL << RCC_AHB2ENR1_GPIOFEN_Pos)
#define RCC_AHB2ENR1_GPIOFEN   RCC_AHB2ENR1_GPIOFEN_Msk
#define RCC_AHB2ENR1_GPIOGEN_Pos   (6U)
#define RCC_AHB2ENR1_GPIOGEN_Msk   (0x1UL << RCC_AHB2ENR1_GPIOGEN_Pos)
#define RCC_AHB2ENR1_GPIOGEN   RCC_AHB2ENR1_GPIOGEN_Msk
#define RCC_AHB2ENR1_GPIOHEN_Pos   (7U)
#define RCC_AHB2ENR1_GPIOHEN_Msk   (0x1UL << RCC_AHB2ENR1_GPIOHEN_Pos)
#define RCC_AHB2ENR1_GPIOHEN   RCC_AHB2ENR1_GPIOHEN_Msk
#define RCC_AHB2ENR1_GPIOIEN_Pos   (8U)
#define RCC_AHB2ENR1_GPIOIEN_Msk   (0x1UL << RCC_AHB2ENR1_GPIOIEN_Pos)
#define RCC_AHB2ENR1_GPIOIEN   RCC_AHB2ENR1_GPIOIEN_Msk
#define RCC_AHB2ENR1_GPIOJEN_Pos   (9U)
#define RCC_AHB2ENR1_GPIOJEN_Msk   (0x1UL << RCC_AHB2ENR1_GPIOJEN_Pos)
#define RCC_AHB2ENR1_GPIOJEN   RCC_AHB2ENR1_GPIOJEN_Msk
#define RCC_AHB2ENR1_ADC12EN_Pos   (10U)
#define RCC_AHB2ENR1_ADC12EN_Msk   (0x1UL << RCC_AHB2ENR1_ADC12EN_Pos)
#define RCC_AHB2ENR1_ADC12EN   RCC_AHB2ENR1_ADC12EN_Msk
#define RCC_AHB2ENR1_DCMI_PSSIEN_Pos   (12U)
#define RCC_AHB2ENR1_DCMI_PSSIEN_Msk   (0x1UL << RCC_AHB2ENR1_DCMI_PSSIEN_Pos)
#define RCC_AHB2ENR1_DCMI_PSSIEN   RCC_AHB2ENR1_DCMI_PSSIEN_Msk
#define RCC_AHB2ENR1_OTGEN_Pos   (14U)
#define RCC_AHB2ENR1_OTGEN_Msk   (0x1UL << RCC_AHB2ENR1_OTGEN_Pos)
#define RCC_AHB2ENR1_OTGEN   RCC_AHB2ENR1_OTGEN_Msk
#define RCC_AHB2ENR1_USBPHYCEN_Pos   (15U)
#define RCC_AHB2ENR1_USBPHYCEN_Msk   (0x1UL << RCC_AHB2ENR1_USBPHYCEN_Pos)
#define RCC_AHB2ENR1_USBPHYCEN   RCC_AHB2ENR1_USBPHYCEN_Msk
#define RCC_AHB2ENR1_AESEN_Pos   (16U)
#define RCC_AHB2ENR1_AESEN_Msk   (0x1UL << RCC_AHB2ENR1_AESEN_Pos)
#define RCC_AHB2ENR1_AESEN   RCC_AHB2ENR1_AESEN_Msk
#define RCC_AHB2ENR1_HASHEN_Pos   (17U)
#define RCC_AHB2ENR1_HASHEN_Msk   (0x1UL << RCC_AHB2ENR1_HASHEN_Pos)
#define RCC_AHB2ENR1_HASHEN   RCC_AHB2ENR1_HASHEN_Msk
#define RCC_AHB2ENR1_RNGEN_Pos   (18U)
#define RCC_AHB2ENR1_RNGEN_Msk   (0x1UL << RCC_AHB2ENR1_RNGEN_Pos)
#define RCC_AHB2ENR1_RNGEN   RCC_AHB2ENR1_RNGEN_Msk
#define RCC_AHB2ENR1_PKAEN_Pos   (19U)
#define RCC_AHB2ENR1_PKAEN_Msk   (0x1UL << RCC_AHB2ENR1_PKAEN_Pos)
#define RCC_AHB2ENR1_PKAEN   RCC_AHB2ENR1_PKAEN_Msk
#define RCC_AHB2ENR1_SAESEN_Pos   (20U)
#define RCC_AHB2ENR1_SAESEN_Msk   (0x1UL << RCC_AHB2ENR1_SAESEN_Pos)
#define RCC_AHB2ENR1_SAESEN   RCC_AHB2ENR1_SAESEN_Msk
#define RCC_AHB2ENR1_OCTOSPIMEN_Pos   (21U)
#define RCC_AHB2ENR1_OCTOSPIMEN_Msk   (0x1UL << RCC_AHB2ENR1_OCTOSPIMEN_Pos)
#define RCC_AHB2ENR1_OCTOSPIMEN   RCC_AHB2ENR1_OCTOSPIMEN_Msk
#define RCC_AHB2ENR1_OTFDEC1EN_Pos   (23U)
#define RCC_AHB2ENR1_OTFDEC1EN_Msk   (0x1UL << RCC_AHB2ENR1_OTFDEC1EN_Pos)
#define RCC_AHB2ENR1_OTFDEC1EN   RCC_AHB2ENR1_OTFDEC1EN_Msk
#define RCC_AHB2ENR1_OTFDEC2EN_Pos   (24U)
#define RCC_AHB2ENR1_OTFDEC2EN_Msk   (0x1UL << RCC_AHB2ENR1_OTFDEC2EN_Pos)
#define RCC_AHB2ENR1_OTFDEC2EN   RCC_AHB2ENR1_OTFDEC2EN_Msk
#define RCC_AHB2ENR1_SDMMC1EN_Pos   (27U)
#define RCC_AHB2ENR1_SDMMC1EN_Msk   (0x1UL << RCC_AHB2ENR1_SDMMC1EN_Pos)
#define RCC_AHB2ENR1_SDMMC1EN   RCC_AHB2ENR1_SDMMC1EN_Msk
#define RCC_AHB2ENR1_SDMMC2EN_Pos   (28U)
#define RCC_AHB2ENR1_SDMMC2EN_Msk   (0x1UL << RCC_AHB2ENR1_SDMMC2EN_Pos)
#define RCC_AHB2ENR1_SDMMC2EN   RCC_AHB2ENR1_SDMMC2EN_Msk
#define RCC_AHB2ENR1_SRAM2EN_Pos   (30U)
#define RCC_AHB2ENR1_SRAM2EN_Msk   (0x1UL << RCC_AHB2ENR1_SRAM2EN_Pos)
#define RCC_AHB2ENR1_SRAM2EN   RCC_AHB2ENR1_SRAM2EN_Msk
#define RCC_AHB2ENR1_SRAM3EN_Pos   (31U)
#define RCC_AHB2ENR1_SRAM3EN_Msk   (0x1UL << RCC_AHB2ENR1_SRAM3EN_Pos)
#define RCC_AHB2ENR1_SRAM3EN   RCC_AHB2ENR1_SRAM3EN_Msk
#define RCC_AHB2ENR2_FSMCEN_Pos   (0U)
#define RCC_AHB2ENR2_FSMCEN_Msk   (0x1UL << RCC_AHB2ENR2_FSMCEN_Pos)
#define RCC_AHB2ENR2_FSMCEN   RCC_AHB2ENR2_FSMCEN_Msk
#define RCC_AHB2ENR2_OCTOSPI1EN_Pos   (4U)
#define RCC_AHB2ENR2_OCTOSPI1EN_Msk   (0x1UL << RCC_AHB2ENR2_OCTOSPI1EN_Pos)
#define RCC_AHB2ENR2_OCTOSPI1EN   RCC_AHB2ENR2_OCTOSPI1EN_Msk
#define RCC_AHB2ENR2_OCTOSPI2EN_Pos   (8U)
#define RCC_AHB2ENR2_OCTOSPI2EN_Msk   (0x1UL << RCC_AHB2ENR2_OCTOSPI2EN_Pos)
#define RCC_AHB2ENR2_OCTOSPI2EN   RCC_AHB2ENR2_OCTOSPI2EN_Msk
#define RCC_AHB2ENR2_HSPI1EN_Pos   (12U)
#define RCC_AHB2ENR2_HSPI1EN_Msk   (0x1UL << RCC_AHB2ENR2_HSPI1EN_Pos)
#define RCC_AHB2ENR2_HSPI1EN   RCC_AHB2ENR2_HSPI1EN_Msk
#define RCC_AHB2ENR2_SRAM6EN_Pos   (30U)
#define RCC_AHB2ENR2_SRAM6EN_Msk   (0x1UL << RCC_AHB2ENR2_SRAM6EN_Pos)
#define RCC_AHB2ENR2_SRAM6EN   RCC_AHB2ENR2_SRAM6EN_Msk
#define RCC_AHB2ENR2_SRAM5EN_Pos   (31U)
#define RCC_AHB2ENR2_SRAM5EN_Msk   (0x1UL << RCC_AHB2ENR2_SRAM5EN_Pos)
#define RCC_AHB2ENR2_SRAM5EN   RCC_AHB2ENR2_SRAM5EN_Msk
#define RCC_AHB3ENR_LPGPIO1EN_Pos   (0U)
#define RCC_AHB3ENR_LPGPIO1EN_Msk   (0x1UL << RCC_AHB3ENR_LPGPIO1EN_Pos)
#define RCC_AHB3ENR_LPGPIO1EN   RCC_AHB3ENR_LPGPIO1EN_Msk
#define RCC_AHB3ENR_PWREN_Pos   (2U)
#define RCC_AHB3ENR_PWREN_Msk   (0x1UL << RCC_AHB3ENR_PWREN_Pos)
#define RCC_AHB3ENR_PWREN   RCC_AHB3ENR_PWREN_Msk
#define RCC_AHB3ENR_ADC4EN_Pos   (5U)
#define RCC_AHB3ENR_ADC4EN_Msk   (0x1UL << RCC_AHB3ENR_ADC4EN_Pos)
#define RCC_AHB3ENR_ADC4EN   RCC_AHB3ENR_ADC4EN_Msk
#define RCC_AHB3ENR_DAC1EN_Pos   (6U)
#define RCC_AHB3ENR_DAC1EN_Msk   (0x1UL << RCC_AHB3ENR_DAC1EN_Pos)
#define RCC_AHB3ENR_DAC1EN   RCC_AHB3ENR_DAC1EN_Msk
#define RCC_AHB3ENR_LPDMA1EN_Pos   (9U)
#define RCC_AHB3ENR_LPDMA1EN_Msk   (0x1UL << RCC_AHB3ENR_LPDMA1EN_Pos)
#define RCC_AHB3ENR_LPDMA1EN   RCC_AHB3ENR_LPDMA1EN_Msk
#define RCC_AHB3ENR_ADF1EN_Pos   (10U)
#define RCC_AHB3ENR_ADF1EN_Msk   (0x1UL << RCC_AHB3ENR_ADF1EN_Pos)
#define RCC_AHB3ENR_ADF1EN   RCC_AHB3ENR_ADF1EN_Msk
#define RCC_AHB3ENR_GTZC2EN_Pos   (12U)
#define RCC_AHB3ENR_GTZC2EN_Msk   (0x1UL << RCC_AHB3ENR_GTZC2EN_Pos)
#define RCC_AHB3ENR_GTZC2EN   RCC_AHB3ENR_GTZC2EN_Msk
#define RCC_AHB3ENR_SRAM4EN_Pos   (31U)
#define RCC_AHB3ENR_SRAM4EN_Msk   (0x1UL << RCC_AHB3ENR_SRAM4EN_Pos)
#define RCC_AHB3ENR_SRAM4EN   RCC_AHB3ENR_SRAM4EN_Msk
#define RCC_APB1ENR1_TIM2EN_Pos   (0U)
#define RCC_APB1ENR1_TIM2EN_Msk   (0x1UL << RCC_APB1ENR1_TIM2EN_Pos)
#define RCC_APB1ENR1_TIM2EN   RCC_APB1ENR1_TIM2EN_Msk
#define RCC_APB1ENR1_TIM3EN_Pos   (1U)
#define RCC_APB1ENR1_TIM3EN_Msk   (0x1UL << RCC_APB1ENR1_TIM3EN_Pos)
#define RCC_APB1ENR1_TIM3EN   RCC_APB1ENR1_TIM3EN_Msk
#define RCC_APB1ENR1_TIM4EN_Pos   (2U)
#define RCC_APB1ENR1_TIM4EN_Msk   (0x1UL << RCC_APB1ENR1_TIM4EN_Pos)
#define RCC_APB1ENR1_TIM4EN   RCC_APB1ENR1_TIM4EN_Msk
#define RCC_APB1ENR1_TIM5EN_Pos   (3U)
#define RCC_APB1ENR1_TIM5EN_Msk   (0x1UL << RCC_APB1ENR1_TIM5EN_Pos)
#define RCC_APB1ENR1_TIM5EN   RCC_APB1ENR1_TIM5EN_Msk
#define RCC_APB1ENR1_TIM6EN_Pos   (4U)
#define RCC_APB1ENR1_TIM6EN_Msk   (0x1UL << RCC_APB1ENR1_TIM6EN_Pos)
#define RCC_APB1ENR1_TIM6EN   RCC_APB1ENR1_TIM6EN_Msk
#define RCC_APB1ENR1_TIM7EN_Pos   (5U)
#define RCC_APB1ENR1_TIM7EN_Msk   (0x1UL << RCC_APB1ENR1_TIM7EN_Pos)
#define RCC_APB1ENR1_TIM7EN   RCC_APB1ENR1_TIM7EN_Msk
#define RCC_APB1ENR1_WWDGEN_Pos   (11U)
#define RCC_APB1ENR1_WWDGEN_Msk   (0x1UL << RCC_APB1ENR1_WWDGEN_Pos)
#define RCC_APB1ENR1_WWDGEN   RCC_APB1ENR1_WWDGEN_Msk
#define RCC_APB1ENR1_SPI2EN_Pos   (14U)
#define RCC_APB1ENR1_SPI2EN_Msk   (0x1UL << RCC_APB1ENR1_SPI2EN_Pos)
#define RCC_APB1ENR1_SPI2EN   RCC_APB1ENR1_SPI2EN_Msk
#define RCC_APB1ENR1_USART2EN_Pos   (17U)
#define RCC_APB1ENR1_USART2EN_Msk   (0x1UL << RCC_APB1ENR1_USART2EN_Pos)
#define RCC_APB1ENR1_USART2EN   RCC_APB1ENR1_USART2EN_Msk
#define RCC_APB1ENR1_USART3EN_Pos   (18U)
#define RCC_APB1ENR1_USART3EN_Msk   (0x1UL << RCC_APB1ENR1_USART3EN_Pos)
#define RCC_APB1ENR1_USART3EN   RCC_APB1ENR1_USART3EN_Msk
#define RCC_APB1ENR1_UART4EN_Pos   (19U)
#define RCC_APB1ENR1_UART4EN_Msk   (0x1UL << RCC_APB1ENR1_UART4EN_Pos)
#define RCC_APB1ENR1_UART4EN   RCC_APB1ENR1_UART4EN_Msk
#define RCC_APB1ENR1_UART5EN_Pos   (20U)
#define RCC_APB1ENR1_UART5EN_Msk   (0x1UL << RCC_APB1ENR1_UART5EN_Pos)
#define RCC_APB1ENR1_UART5EN   RCC_APB1ENR1_UART5EN_Msk
#define RCC_APB1ENR1_I2C1EN_Pos   (21U)
#define RCC_APB1ENR1_I2C1EN_Msk   (0x1UL << RCC_APB1ENR1_I2C1EN_Pos)
#define RCC_APB1ENR1_I2C1EN   RCC_APB1ENR1_I2C1EN_Msk
#define RCC_APB1ENR1_I2C2EN_Pos   (22U)
#define RCC_APB1ENR1_I2C2EN_Msk   (0x1UL << RCC_APB1ENR1_I2C2EN_Pos)
#define RCC_APB1ENR1_I2C2EN   RCC_APB1ENR1_I2C2EN_Msk
#define RCC_APB1ENR1_CRSEN_Pos   (24U)
#define RCC_APB1ENR1_CRSEN_Msk   (0x1UL << RCC_APB1ENR1_CRSEN_Pos)
#define RCC_APB1ENR1_CRSEN   RCC_APB1ENR1_CRSEN_Msk
#define RCC_APB1ENR1_USART6EN_Pos   (25U)
#define RCC_APB1ENR1_USART6EN_Msk   (0x1UL << RCC_APB1ENR1_USART6EN_Pos)
#define RCC_APB1ENR1_USART6EN   RCC_APB1ENR1_USART6EN_Msk
#define RCC_APB1ENR2_I2C4EN_Pos   (1U)
#define RCC_APB1ENR2_I2C4EN_Msk   (0x1UL << RCC_APB1ENR2_I2C4EN_Pos)
#define RCC_APB1ENR2_I2C4EN   RCC_APB1ENR2_I2C4EN_Msk
#define RCC_APB1ENR2_LPTIM2EN_Pos   (5U)
#define RCC_APB1ENR2_LPTIM2EN_Msk   (0x1UL << RCC_APB1ENR2_LPTIM2EN_Pos)
#define RCC_APB1ENR2_LPTIM2EN   RCC_APB1ENR2_LPTIM2EN_Msk
#define RCC_APB1ENR2_I2C5EN_Pos   (6U)
#define RCC_APB1ENR2_I2C5EN_Msk   (0x1UL << RCC_APB1ENR2_I2C5EN_Pos)
#define RCC_APB1ENR2_I2C5EN   RCC_APB1ENR2_I2C5EN_Msk
#define RCC_APB1ENR2_I2C6EN_Pos   (7U)
#define RCC_APB1ENR2_I2C6EN_Msk   (0x1UL << RCC_APB1ENR2_I2C6EN_Pos)
#define RCC_APB1ENR2_I2C6EN   RCC_APB1ENR2_I2C6EN_Msk
#define RCC_APB1ENR2_FDCAN1EN_Pos   (9U)
#define RCC_APB1ENR2_FDCAN1EN_Msk   (0x1UL << RCC_APB1ENR2_FDCAN1EN_Pos)
#define RCC_APB1ENR2_FDCAN1EN   RCC_APB1ENR2_FDCAN1EN_Msk
#define RCC_APB1ENR2_UCPD1EN_Pos   (23U)
#define RCC_APB1ENR2_UCPD1EN_Msk   (0x1UL << RCC_APB1ENR2_UCPD1EN_Pos)
#define RCC_APB1ENR2_UCPD1EN   RCC_APB1ENR2_UCPD1EN_Msk
#define RCC_APB2ENR_TIM1EN_Pos   (11U)
#define RCC_APB2ENR_TIM1EN_Msk   (0x1UL << RCC_APB2ENR_TIM1EN_Pos)
#define RCC_APB2ENR_TIM1EN   RCC_APB2ENR_TIM1EN_Msk
#define RCC_APB2ENR_SPI1EN_Pos   (12U)
#define RCC_APB2ENR_SPI1EN_Msk   (0x1UL << RCC_APB2ENR_SPI1EN_Pos)
#define RCC_APB2ENR_SPI1EN   RCC_APB2ENR_SPI1EN_Msk
#define RCC_APB2ENR_TIM8EN_Pos   (13U)
#define RCC_APB2ENR_TIM8EN_Msk   (0x1UL << RCC_APB2ENR_TIM8EN_Pos)
#define RCC_APB2ENR_TIM8EN   RCC_APB2ENR_TIM8EN_Msk
#define RCC_APB2ENR_USART1EN_Pos   (14U)
#define RCC_APB2ENR_USART1EN_Msk   (0x1UL << RCC_APB2ENR_USART1EN_Pos)
#define RCC_APB2ENR_USART1EN   RCC_APB2ENR_USART1EN_Msk
#define RCC_APB2ENR_TIM15EN_Pos   (16U)
#define RCC_APB2ENR_TIM15EN_Msk   (0x1UL << RCC_APB2ENR_TIM15EN_Pos)
#define RCC_APB2ENR_TIM15EN   RCC_APB2ENR_TIM15EN_Msk
#define RCC_APB2ENR_TIM16EN_Pos   (17U)
#define RCC_APB2ENR_TIM16EN_Msk   (0x1UL << RCC_APB2ENR_TIM16EN_Pos)
#define RCC_APB2ENR_TIM16EN   RCC_APB2ENR_TIM16EN_Msk
#define RCC_APB2ENR_TIM17EN_Pos   (18U)
#define RCC_APB2ENR_TIM17EN_Msk   (0x1UL << RCC_APB2ENR_TIM17EN_Pos)
#define RCC_APB2ENR_TIM17EN   RCC_APB2ENR_TIM17EN_Msk
#define RCC_APB2ENR_SAI1EN_Pos   (21U)
#define RCC_APB2ENR_SAI1EN_Msk   (0x1UL << RCC_APB2ENR_SAI1EN_Pos)
#define RCC_APB2ENR_SAI1EN   RCC_APB2ENR_SAI1EN_Msk
#define RCC_APB2ENR_SAI2EN_Pos   (22U)
#define RCC_APB2ENR_SAI2EN_Msk   (0x1UL << RCC_APB2ENR_SAI2EN_Pos)
#define RCC_APB2ENR_SAI2EN   RCC_APB2ENR_SAI2EN_Msk
#define RCC_APB2ENR_GFXTIMEN_Pos   (25U)
#define RCC_APB2ENR_GFXTIMEN_Msk   (0x1UL << RCC_APB2ENR_GFXTIMEN_Pos)
#define RCC_APB2ENR_GFXTIMEN   RCC_APB2ENR_GFXTIMEN_Msk
#define RCC_APB2ENR_LTDCEN_Pos   (26U)
#define RCC_APB2ENR_LTDCEN_Msk   (0x1UL << RCC_APB2ENR_LTDCEN_Pos)
#define RCC_APB2ENR_LTDCEN   RCC_APB2ENR_LTDCEN_Msk
#define RCC_APB2ENR_DSIHOSTEN_Pos   (27U)
#define RCC_APB2ENR_DSIHOSTEN_Msk   (0x1UL << RCC_APB2ENR_DSIHOSTEN_Pos)
#define RCC_APB2ENR_DSIHOSTEN   RCC_APB2ENR_DSIHOSTEN_Msk
#define RCC_APB3ENR_SYSCFGEN_Pos   (1U)
#define RCC_APB3ENR_SYSCFGEN_Msk   (0x1UL << RCC_APB3ENR_SYSCFGEN_Pos)
#define RCC_APB3ENR_SYSCFGEN   RCC_APB3ENR_SYSCFGEN_Msk
#define RCC_APB3ENR_SPI3EN_Pos   (5U)
#define RCC_APB3ENR_SPI3EN_Msk   (0x1UL << RCC_APB3ENR_SPI3EN_Pos)
#define RCC_APB3ENR_SPI3EN   RCC_APB3ENR_SPI3EN_Msk
#define RCC_APB3ENR_LPUART1EN_Pos   (6U)
#define RCC_APB3ENR_LPUART1EN_Msk   (0x1UL << RCC_APB3ENR_LPUART1EN_Pos)
#define RCC_APB3ENR_LPUART1EN   RCC_APB3ENR_LPUART1EN_Msk
#define RCC_APB3ENR_I2C3EN_Pos   (7U)
#define RCC_APB3ENR_I2C3EN_Msk   (0x1UL << RCC_APB3ENR_I2C3EN_Pos)
#define RCC_APB3ENR_I2C3EN   RCC_APB3ENR_I2C3EN_Msk
#define RCC_APB3ENR_LPTIM1EN_Pos   (11U)
#define RCC_APB3ENR_LPTIM1EN_Msk   (0x1UL << RCC_APB3ENR_LPTIM1EN_Pos)
#define RCC_APB3ENR_LPTIM1EN   RCC_APB3ENR_LPTIM1EN_Msk
#define RCC_APB3ENR_LPTIM3EN_Pos   (12U)
#define RCC_APB3ENR_LPTIM3EN_Msk   (0x1UL << RCC_APB3ENR_LPTIM3EN_Pos)
#define RCC_APB3ENR_LPTIM3EN   RCC_APB3ENR_LPTIM3EN_Msk
#define RCC_APB3ENR_LPTIM4EN_Pos   (13U)
#define RCC_APB3ENR_LPTIM4EN_Msk   (0x1UL << RCC_APB3ENR_LPTIM4EN_Pos)
#define RCC_APB3ENR_LPTIM4EN   RCC_APB3ENR_LPTIM4EN_Msk
#define RCC_APB3ENR_OPAMPEN_Pos   (14U)
#define RCC_APB3ENR_OPAMPEN_Msk   (0x1UL << RCC_APB3ENR_OPAMPEN_Pos)
#define RCC_APB3ENR_OPAMPEN   RCC_APB3ENR_OPAMPEN_Msk
#define RCC_APB3ENR_COMPEN_Pos   (15U)
#define RCC_APB3ENR_COMPEN_Msk   (0x1UL << RCC_APB3ENR_COMPEN_Pos)
#define RCC_APB3ENR_COMPEN   RCC_APB3ENR_COMPEN_Msk
#define RCC_APB3ENR_VREFEN_Pos   (20U)
#define RCC_APB3ENR_VREFEN_Msk   (0x1UL << RCC_APB3ENR_VREFEN_Pos)
#define RCC_APB3ENR_VREFEN   RCC_APB3ENR_VREFEN_Msk
#define RCC_APB3ENR_RTCAPBEN_Pos   (21U)
#define RCC_APB3ENR_RTCAPBEN_Msk   (0x1UL << RCC_APB3ENR_RTCAPBEN_Pos)
#define RCC_APB3ENR_RTCAPBEN   RCC_APB3ENR_RTCAPBEN_Msk
#define RCC_AHB1SMENR_GPDMA1SMEN_Pos   (0U)
#define RCC_AHB1SMENR_GPDMA1SMEN_Msk   (0x1UL << RCC_AHB1SMENR_GPDMA1SMEN_Pos)
#define RCC_AHB1SMENR_GPDMA1SMEN   RCC_AHB1SMENR_GPDMA1SMEN_Msk
#define RCC_AHB1SMENR_CORDICSMEN_Pos   (1U)
#define RCC_AHB1SMENR_CORDICSMEN_Msk   (0x1UL << RCC_AHB1SMENR_CORDICSMEN_Pos)
#define RCC_AHB1SMENR_CORDICSMEN   RCC_AHB1SMENR_CORDICSMEN_Msk
#define RCC_AHB1SMENR_FMACSMEN_Pos   (2U)
#define RCC_AHB1SMENR_FMACSMEN_Msk   (0x1UL << RCC_AHB1SMENR_FMACSMEN_Pos)
#define RCC_AHB1SMENR_FMACSMEN   RCC_AHB1SMENR_FMACSMEN_Msk
#define RCC_AHB1SMENR_MDF1SMEN_Pos   (3U)
#define RCC_AHB1SMENR_MDF1SMEN_Msk   (0x1UL << RCC_AHB1SMENR_MDF1SMEN_Pos)
#define RCC_AHB1SMENR_MDF1SMEN   RCC_AHB1SMENR_MDF1SMEN_Msk
#define RCC_AHB1SMENR_FLASHSMEN_Pos   (8U)
#define RCC_AHB1SMENR_FLASHSMEN_Msk   (0x1UL << RCC_AHB1SMENR_FLASHSMEN_Pos)
#define RCC_AHB1SMENR_FLASHSMEN   RCC_AHB1SMENR_FLASHSMEN_Msk
#define RCC_AHB1SMENR_CRCSMEN_Pos   (12U)
#define RCC_AHB1SMENR_CRCSMEN_Msk   (0x1UL << RCC_AHB1SMENR_CRCSMEN_Pos)
#define RCC_AHB1SMENR_CRCSMEN   RCC_AHB1SMENR_CRCSMEN_Msk
#define RCC_AHB1SMENR_JPEGSMEN_Pos   (15U)
#define RCC_AHB1SMENR_JPEGSMEN_Msk   (0x1UL << RCC_AHB1SMENR_JPEGSMEN_Pos)
#define RCC_AHB1SMENR_JPEGSMEN   RCC_AHB1SMENR_JPEGSMEN_Msk
#define RCC_AHB1SMENR_TSCSMEN_Pos   (16U)
#define RCC_AHB1SMENR_TSCSMEN_Msk   (0x1UL << RCC_AHB1SMENR_TSCSMEN_Pos)
#define RCC_AHB1SMENR_TSCSMEN   RCC_AHB1SMENR_TSCSMEN_Msk
#define RCC_AHB1SMENR_RAMCFGSMEN_Pos   (17U)
#define RCC_AHB1SMENR_RAMCFGSMEN_Msk   (0x1UL << RCC_AHB1SMENR_RAMCFGSMEN_Pos)
#define RCC_AHB1SMENR_RAMCFGSMEN   RCC_AHB1SMENR_RAMCFGSMEN_Msk
#define RCC_AHB1SMENR_DMA2DSMEN_Pos   (18U)
#define RCC_AHB1SMENR_DMA2DSMEN_Msk   (0x1UL << RCC_AHB1SMENR_DMA2DSMEN_Pos)
#define RCC_AHB1SMENR_DMA2DSMEN   RCC_AHB1SMENR_DMA2DSMEN_Msk
#define RCC_AHB1SMENR_GFXMMUSMEN_Pos   (19U)
#define RCC_AHB1SMENR_GFXMMUSMEN_Msk   (0x1UL << RCC_AHB1SMENR_GFXMMUSMEN_Pos)
#define RCC_AHB1SMENR_GFXMMUSMEN   RCC_AHB1SMENR_GFXMMUSMEN_Msk
#define RCC_AHB1SMENR_GPU2DSMEN_Pos   (20U)
#define RCC_AHB1SMENR_GPU2DSMEN_Msk   (0x1UL << RCC_AHB1SMENR_GPU2DSMEN_Pos)
#define RCC_AHB1SMENR_GPU2DSMEN   RCC_AHB1SMENR_GPU2DSMEN_Msk
#define RCC_AHB1SMENR_DCACHE2SMEN_Pos   (21U)
#define RCC_AHB1SMENR_DCACHE2SMEN_Msk   (0x1UL << RCC_AHB1SMENR_DCACHE2SMEN_Pos)
#define RCC_AHB1SMENR_DCACHE2SMEN   RCC_AHB1SMENR_DCACHE2SMEN_Msk
#define RCC_AHB1SMENR_GTZC1SMEN_Pos   (24U)
#define RCC_AHB1SMENR_GTZC1SMEN_Msk   (0x1UL << RCC_AHB1SMENR_GTZC1SMEN_Pos)
#define RCC_AHB1SMENR_GTZC1SMEN   RCC_AHB1SMENR_GTZC1SMEN_Msk
#define RCC_AHB1SMENR_BKPSRAMSMEN_Pos   (28U)
#define RCC_AHB1SMENR_BKPSRAMSMEN_Msk   (0x1UL << RCC_AHB1SMENR_BKPSRAMSMEN_Pos)
#define RCC_AHB1SMENR_BKPSRAMSMEN   RCC_AHB1SMENR_BKPSRAMSMEN_Msk
#define RCC_AHB1SMENR_ICACHESMEN_Pos   (29U)
#define RCC_AHB1SMENR_ICACHESMEN_Msk   (0x1UL << RCC_AHB1SMENR_ICACHESMEN_Pos)
#define RCC_AHB1SMENR_ICACHESMEN   RCC_AHB1SMENR_ICACHESMEN_Msk
#define RCC_AHB1SMENR_DCACHE1SMEN_Pos   (30U)
#define RCC_AHB1SMENR_DCACHE1SMEN_Msk   (0x1UL << RCC_AHB1SMENR_DCACHE1SMEN_Pos)
#define RCC_AHB1SMENR_DCACHE1SMEN   RCC_AHB1SMENR_DCACHE1SMEN_Msk
#define RCC_AHB1SMENR_SRAM1SMEN_Pos   (31U)
#define RCC_AHB1SMENR_SRAM1SMEN_Msk   (0x1UL << RCC_AHB1SMENR_SRAM1SMEN_Pos)
#define RCC_AHB1SMENR_SRAM1SMEN   RCC_AHB1SMENR_SRAM1SMEN_Msk
#define RCC_AHB2SMENR1_GPIOASMEN_Pos   (0U)
#define RCC_AHB2SMENR1_GPIOASMEN_Msk   (0x1UL << RCC_AHB2SMENR1_GPIOASMEN_Pos)
#define RCC_AHB2SMENR1_GPIOASMEN   RCC_AHB2SMENR1_GPIOASMEN_Msk
#define RCC_AHB2SMENR1_GPIOBSMEN_Pos   (1U)
#define RCC_AHB2SMENR1_GPIOBSMEN_Msk   (0x1UL << RCC_AHB2SMENR1_GPIOBSMEN_Pos)
#define RCC_AHB2SMENR1_GPIOBSMEN   RCC_AHB2SMENR1_GPIOBSMEN_Msk
#define RCC_AHB2SMENR1_GPIOCSMEN_Pos   (2U)
#define RCC_AHB2SMENR1_GPIOCSMEN_Msk   (0x1UL << RCC_AHB2SMENR1_GPIOCSMEN_Pos)
#define RCC_AHB2SMENR1_GPIOCSMEN   RCC_AHB2SMENR1_GPIOCSMEN_Msk
#define RCC_AHB2SMENR1_GPIODSMEN_Pos   (3U)
#define RCC_AHB2SMENR1_GPIODSMEN_Msk   (0x1UL << RCC_AHB2SMENR1_GPIODSMEN_Pos)
#define RCC_AHB2SMENR1_GPIODSMEN   RCC_AHB2SMENR1_GPIODSMEN_Msk
#define RCC_AHB2SMENR1_GPIOESMEN_Pos   (4U)
#define RCC_AHB2SMENR1_GPIOESMEN_Msk   (0x1UL << RCC_AHB2SMENR1_GPIOESMEN_Pos)
#define RCC_AHB2SMENR1_GPIOESMEN   RCC_AHB2SMENR1_GPIOESMEN_Msk
#define RCC_AHB2SMENR1_GPIOFSMEN_Pos   (5U)
#define RCC_AHB2SMENR1_GPIOFSMEN_Msk   (0x1UL << RCC_AHB2SMENR1_GPIOFSMEN_Pos)
#define RCC_AHB2SMENR1_GPIOFSMEN   RCC_AHB2SMENR1_GPIOFSMEN_Msk
#define RCC_AHB2SMENR1_GPIOGSMEN_Pos   (6U)
#define RCC_AHB2SMENR1_GPIOGSMEN_Msk   (0x1UL << RCC_AHB2SMENR1_GPIOGSMEN_Pos)
#define RCC_AHB2SMENR1_GPIOGSMEN   RCC_AHB2SMENR1_GPIOGSMEN_Msk
#define RCC_AHB2SMENR1_GPIOHSMEN_Pos   (7U)
#define RCC_AHB2SMENR1_GPIOHSMEN_Msk   (0x1UL << RCC_AHB2SMENR1_GPIOHSMEN_Pos)
#define RCC_AHB2SMENR1_GPIOHSMEN   RCC_AHB2SMENR1_GPIOHSMEN_Msk
#define RCC_AHB2SMENR1_GPIOISMEN_Pos   (8U)
#define RCC_AHB2SMENR1_GPIOISMEN_Msk   (0x1UL << RCC_AHB2SMENR1_GPIOISMEN_Pos)
#define RCC_AHB2SMENR1_GPIOISMEN   RCC_AHB2SMENR1_GPIOISMEN_Msk
#define RCC_AHB2SMENR1_GPIOJSMEN_Pos   (9U)
#define RCC_AHB2SMENR1_GPIOJSMEN_Msk   (0x1UL << RCC_AHB2SMENR1_GPIOJSMEN_Pos)
#define RCC_AHB2SMENR1_GPIOJSMEN   RCC_AHB2SMENR1_GPIOJSMEN_Msk
#define RCC_AHB2SMENR1_ADC12SMEN_Pos   (10U)
#define RCC_AHB2SMENR1_ADC12SMEN_Msk   (0x1UL << RCC_AHB2SMENR1_ADC12SMEN_Pos)
#define RCC_AHB2SMENR1_ADC12SMEN   RCC_AHB2SMENR1_ADC12SMEN_Msk
#define RCC_AHB2SMENR1_DCMI_PSSISMEN_Pos   (12U)
#define RCC_AHB2SMENR1_DCMI_PSSISMEN_Msk   (0x1UL << RCC_AHB2SMENR1_DCMI_PSSISMEN_Pos)
#define RCC_AHB2SMENR1_DCMI_PSSISMEN   RCC_AHB2SMENR1_DCMI_PSSISMEN_Msk
#define RCC_AHB2SMENR1_OTGSMEN_Pos   (14U)
#define RCC_AHB2SMENR1_OTGSMEN_Msk   (0x1UL << RCC_AHB2SMENR1_OTGSMEN_Pos)
#define RCC_AHB2SMENR1_OTGSMEN   RCC_AHB2SMENR1_OTGSMEN_Msk
#define RCC_AHB2SMENR1_USBPHYCSMEN_Pos   (15U)
#define RCC_AHB2SMENR1_USBPHYCSMEN_Msk   (0x1UL << RCC_AHB2SMENR1_USBPHYCSMEN_Pos)
#define RCC_AHB2SMENR1_USBPHYCSMEN   RCC_AHB2SMENR1_USBPHYCSMEN_Msk
#define RCC_AHB2SMENR1_AESSMEN_Pos   (16U)
#define RCC_AHB2SMENR1_AESSMEN_Msk   (0x1UL << RCC_AHB2SMENR1_AESSMEN_Pos)
#define RCC_AHB2SMENR1_AESSMEN   RCC_AHB2SMENR1_AESSMEN_Msk
#define RCC_AHB2SMENR1_HASHSMEN_Pos   (17U)
#define RCC_AHB2SMENR1_HASHSMEN_Msk   (0x1UL << RCC_AHB2SMENR1_HASHSMEN_Pos)
#define RCC_AHB2SMENR1_HASHSMEN   RCC_AHB2SMENR1_HASHSMEN_Msk
#define RCC_AHB2SMENR1_RNGSMEN_Pos   (18U)
#define RCC_AHB2SMENR1_RNGSMEN_Msk   (0x1UL << RCC_AHB2SMENR1_RNGSMEN_Pos)
#define RCC_AHB2SMENR1_RNGSMEN   RCC_AHB2SMENR1_RNGSMEN_Msk
#define RCC_AHB2SMENR1_PKASMEN_Pos   (19U)
#define RCC_AHB2SMENR1_PKASMEN_Msk   (0x1UL << RCC_AHB2SMENR1_PKASMEN_Pos)
#define RCC_AHB2SMENR1_PKASMEN   RCC_AHB2SMENR1_PKASMEN_Msk
#define RCC_AHB2SMENR1_SAESSMEN_Pos   (20U)
#define RCC_AHB2SMENR1_SAESSMEN_Msk   (0x1UL << RCC_AHB2SMENR1_SAESSMEN_Pos)
#define RCC_AHB2SMENR1_SAESSMEN   RCC_AHB2SMENR1_SAESSMEN_Msk
#define RCC_AHB2SMENR1_OCTOSPIMSMEN_Pos   (21U)
#define RCC_AHB2SMENR1_OCTOSPIMSMEN_Msk   (0x1UL << RCC_AHB2SMENR1_OCTOSPIMSMEN_Pos)
#define RCC_AHB2SMENR1_OCTOSPIMSMEN   RCC_AHB2SMENR1_OCTOSPIMSMEN_Msk
#define RCC_AHB2SMENR1_OTFDEC1SMEN_Pos   (23U)
#define RCC_AHB2SMENR1_OTFDEC1SMEN_Msk   (0x1UL << RCC_AHB2SMENR1_OTFDEC1SMEN_Pos)
#define RCC_AHB2SMENR1_OTFDEC1SMEN   RCC_AHB2SMENR1_OTFDEC1SMEN_Msk
#define RCC_AHB2SMENR1_OTFDEC2SMEN_Pos   (24U)
#define RCC_AHB2SMENR1_OTFDEC2SMEN_Msk   (0x1UL << RCC_AHB2SMENR1_OTFDEC2SMEN_Pos)
#define RCC_AHB2SMENR1_OTFDEC2SMEN   RCC_AHB2SMENR1_OTFDEC2SMEN_Msk
#define RCC_AHB2SMENR1_SDMMC1SMEN_Pos   (27U)
#define RCC_AHB2SMENR1_SDMMC1SMEN_Msk   (0x1UL << RCC_AHB2SMENR1_SDMMC1SMEN_Pos)
#define RCC_AHB2SMENR1_SDMMC1SMEN   RCC_AHB2SMENR1_SDMMC1SMEN_Msk
#define RCC_AHB2SMENR1_SDMMC2SMEN_Pos   (28U)
#define RCC_AHB2SMENR1_SDMMC2SMEN_Msk   (0x1UL << RCC_AHB2SMENR1_SDMMC2SMEN_Pos)
#define RCC_AHB2SMENR1_SDMMC2SMEN   RCC_AHB2SMENR1_SDMMC2SMEN_Msk
#define RCC_AHB2SMENR1_SRAM2SMEN_Pos   (30U)
#define RCC_AHB2SMENR1_SRAM2SMEN_Msk   (0x1UL << RCC_AHB2SMENR1_SRAM2SMEN_Pos)
#define RCC_AHB2SMENR1_SRAM2SMEN   RCC_AHB2SMENR1_SRAM2SMEN_Msk
#define RCC_AHB2SMENR1_SRAM3SMEN_Pos   (31U)
#define RCC_AHB2SMENR1_SRAM3SMEN_Msk   (0x1UL << RCC_AHB2SMENR1_SRAM3SMEN_Pos)
#define RCC_AHB2SMENR1_SRAM3SMEN   RCC_AHB2SMENR1_SRAM3SMEN_Msk
#define RCC_AHB2SMENR2_FSMCSMEN_Pos   (0U)
#define RCC_AHB2SMENR2_FSMCSMEN_Msk   (0x1UL << RCC_AHB2SMENR2_FSMCSMEN_Pos)
#define RCC_AHB2SMENR2_FSMCSMEN   RCC_AHB2SMENR2_FSMCSMEN_Msk
#define RCC_AHB2SMENR2_OCTOSPI1SMEN_Pos   (4U)
#define RCC_AHB2SMENR2_OCTOSPI1SMEN_Msk   (0x1UL << RCC_AHB2SMENR2_OCTOSPI1SMEN_Pos)
#define RCC_AHB2SMENR2_OCTOSPI1SMEN   RCC_AHB2SMENR2_OCTOSPI1SMEN_Msk
#define RCC_AHB2SMENR2_OCTOSPI2SMEN_Pos   (8U)
#define RCC_AHB2SMENR2_OCTOSPI2SMEN_Msk   (0x1UL << RCC_AHB2SMENR2_OCTOSPI2SMEN_Pos)
#define RCC_AHB2SMENR2_OCTOSPI2SMEN   RCC_AHB2SMENR2_OCTOSPI2SMEN_Msk
#define RCC_AHB2SMENR2_HSPI1SMEN_Pos   (12U)
#define RCC_AHB2SMENR2_HSPI1SMEN_Msk   (0x1UL << RCC_AHB2SMENR2_HSPI1SMEN_Pos)
#define RCC_AHB2SMENR2_HSPI1SMEN   RCC_AHB2SMENR2_HSPI1SMEN_Msk
#define RCC_AHB2SMENR2_SRAM6SMEN_Pos   (30U)
#define RCC_AHB2SMENR2_SRAM6SMEN_Msk   (0x1UL << RCC_AHB2SMENR2_SRAM6SMEN_Pos)
#define RCC_AHB2SMENR2_SRAM6SMEN   RCC_AHB2SMENR2_SRAM6SMEN_Msk
#define RCC_AHB2SMENR2_SRAM5SMEN_Pos   (31U)
#define RCC_AHB2SMENR2_SRAM5SMEN_Msk   (0x1UL << RCC_AHB2SMENR2_SRAM5SMEN_Pos)
#define RCC_AHB2SMENR2_SRAM5SMEN   RCC_AHB2SMENR2_SRAM5SMEN_Msk
#define RCC_AHB3SMENR_LPGPIO1SMEN_Pos   (0U)
#define RCC_AHB3SMENR_LPGPIO1SMEN_Msk   (0x1UL << RCC_AHB3SMENR_LPGPIO1SMEN_Pos)
#define RCC_AHB3SMENR_LPGPIO1SMEN   RCC_AHB3SMENR_LPGPIO1SMEN_Msk
#define RCC_AHB3SMENR_PWRSMEN_Pos   (2U)
#define RCC_AHB3SMENR_PWRSMEN_Msk   (0x1UL << RCC_AHB3SMENR_PWRSMEN_Pos)
#define RCC_AHB3SMENR_PWRSMEN   RCC_AHB3SMENR_PWRSMEN_Msk
#define RCC_AHB3SMENR_ADC4SMEN_Pos   (5U)
#define RCC_AHB3SMENR_ADC4SMEN_Msk   (0x1UL << RCC_AHB3SMENR_ADC4SMEN_Pos)
#define RCC_AHB3SMENR_ADC4SMEN   RCC_AHB3SMENR_ADC4SMEN_Msk
#define RCC_AHB3SMENR_DAC1SMEN_Pos   (6U)
#define RCC_AHB3SMENR_DAC1SMEN_Msk   (0x1UL << RCC_AHB3SMENR_DAC1SMEN_Pos)
#define RCC_AHB3SMENR_DAC1SMEN   RCC_AHB3SMENR_DAC1SMEN_Msk
#define RCC_AHB3SMENR_LPDMA1SMEN_Pos   (9U)
#define RCC_AHB3SMENR_LPDMA1SMEN_Msk   (0x1UL << RCC_AHB3SMENR_LPDMA1SMEN_Pos)
#define RCC_AHB3SMENR_LPDMA1SMEN   RCC_AHB3SMENR_LPDMA1SMEN_Msk
#define RCC_AHB3SMENR_ADF1SMEN_Pos   (10U)
#define RCC_AHB3SMENR_ADF1SMEN_Msk   (0x1UL << RCC_AHB3SMENR_ADF1SMEN_Pos)
#define RCC_AHB3SMENR_ADF1SMEN   RCC_AHB3SMENR_ADF1SMEN_Msk
#define RCC_AHB3SMENR_GTZC2SMEN_Pos   (12U)
#define RCC_AHB3SMENR_GTZC2SMEN_Msk   (0x1UL << RCC_AHB3SMENR_GTZC2SMEN_Pos)
#define RCC_AHB3SMENR_GTZC2SMEN   RCC_AHB3SMENR_GTZC2SMEN_Msk
#define RCC_AHB3SMENR_SRAM4SMEN_Pos   (31U)
#define RCC_AHB3SMENR_SRAM4SMEN_Msk   (0x1UL << RCC_AHB3SMENR_SRAM4SMEN_Pos)
#define RCC_AHB3SMENR_SRAM4SMEN   RCC_AHB3SMENR_SRAM4SMEN_Msk
#define RCC_APB1SMENR1_TIM2SMEN_Pos   (0U)
#define RCC_APB1SMENR1_TIM2SMEN_Msk   (0x1UL << RCC_APB1SMENR1_TIM2SMEN_Pos)
#define RCC_APB1SMENR1_TIM2SMEN   RCC_APB1SMENR1_TIM2SMEN_Msk
#define RCC_APB1SMENR1_TIM3SMEN_Pos   (1U)
#define RCC_APB1SMENR1_TIM3SMEN_Msk   (0x1UL << RCC_APB1SMENR1_TIM3SMEN_Pos)
#define RCC_APB1SMENR1_TIM3SMEN   RCC_APB1SMENR1_TIM3SMEN_Msk
#define RCC_APB1SMENR1_TIM4SMEN_Pos   (2U)
#define RCC_APB1SMENR1_TIM4SMEN_Msk   (0x1UL << RCC_APB1SMENR1_TIM4SMEN_Pos)
#define RCC_APB1SMENR1_TIM4SMEN   RCC_APB1SMENR1_TIM4SMEN_Msk
#define RCC_APB1SMENR1_TIM5SMEN_Pos   (3U)
#define RCC_APB1SMENR1_TIM5SMEN_Msk   (0x1UL << RCC_APB1SMENR1_TIM5SMEN_Pos)
#define RCC_APB1SMENR1_TIM5SMEN   RCC_APB1SMENR1_TIM5SMEN_Msk
#define RCC_APB1SMENR1_TIM6SMEN_Pos   (4U)
#define RCC_APB1SMENR1_TIM6SMEN_Msk   (0x1UL << RCC_APB1SMENR1_TIM6SMEN_Pos)
#define RCC_APB1SMENR1_TIM6SMEN   RCC_APB1SMENR1_TIM6SMEN_Msk
#define RCC_APB1SMENR1_TIM7SMEN_Pos   (5U)
#define RCC_APB1SMENR1_TIM7SMEN_Msk   (0x1UL << RCC_APB1SMENR1_TIM7SMEN_Pos)
#define RCC_APB1SMENR1_TIM7SMEN   RCC_APB1SMENR1_TIM7SMEN_Msk
#define RCC_APB1SMENR1_WWDGSMEN_Pos   (11U)
#define RCC_APB1SMENR1_WWDGSMEN_Msk   (0x1UL << RCC_APB1SMENR1_WWDGSMEN_Pos)
#define RCC_APB1SMENR1_WWDGSMEN   RCC_APB1SMENR1_WWDGSMEN_Msk
#define RCC_APB1SMENR1_SPI2SMEN_Pos   (14U)
#define RCC_APB1SMENR1_SPI2SMEN_Msk   (0x1UL << RCC_APB1SMENR1_SPI2SMEN_Pos)
#define RCC_APB1SMENR1_SPI2SMEN   RCC_APB1SMENR1_SPI2SMEN_Msk
#define RCC_APB1SMENR1_USART2SMEN_Pos   (17U)
#define RCC_APB1SMENR1_USART2SMEN_Msk   (0x1UL << RCC_APB1SMENR1_USART2SMEN_Pos)
#define RCC_APB1SMENR1_USART2SMEN   RCC_APB1SMENR1_USART2SMEN_Msk
#define RCC_APB1SMENR1_USART3SMEN_Pos   (18U)
#define RCC_APB1SMENR1_USART3SMEN_Msk   (0x1UL << RCC_APB1SMENR1_USART3SMEN_Pos)
#define RCC_APB1SMENR1_USART3SMEN   RCC_APB1SMENR1_USART3SMEN_Msk
#define RCC_APB1SMENR1_UART4SMEN_Pos   (19U)
#define RCC_APB1SMENR1_UART4SMEN_Msk   (0x1UL << RCC_APB1SMENR1_UART4SMEN_Pos)
#define RCC_APB1SMENR1_UART4SMEN   RCC_APB1SMENR1_UART4SMEN_Msk
#define RCC_APB1SMENR1_UART5SMEN_Pos   (20U)
#define RCC_APB1SMENR1_UART5SMEN_Msk   (0x1UL << RCC_APB1SMENR1_UART5SMEN_Pos)
#define RCC_APB1SMENR1_UART5SMEN   RCC_APB1SMENR1_UART5SMEN_Msk
#define RCC_APB1SMENR1_I2C1SMEN_Pos   (21U)
#define RCC_APB1SMENR1_I2C1SMEN_Msk   (0x1UL << RCC_APB1SMENR1_I2C1SMEN_Pos)
#define RCC_APB1SMENR1_I2C1SMEN   RCC_APB1SMENR1_I2C1SMEN_Msk
#define RCC_APB1SMENR1_I2C2SMEN_Pos   (22U)
#define RCC_APB1SMENR1_I2C2SMEN_Msk   (0x1UL << RCC_APB1SMENR1_I2C2SMEN_Pos)
#define RCC_APB1SMENR1_I2C2SMEN   RCC_APB1SMENR1_I2C2SMEN_Msk
#define RCC_APB1SMENR1_CRSSMEN_Pos   (24U)
#define RCC_APB1SMENR1_CRSSMEN_Msk   (0x1UL << RCC_APB1SMENR1_CRSSMEN_Pos)
#define RCC_APB1SMENR1_CRSSMEN   RCC_APB1SMENR1_CRSSMEN_Msk
#define RCC_APB1SMENR1_USART6SMEN_Pos   (25U)
#define RCC_APB1SMENR1_USART6SMEN_Msk   (0x1UL << RCC_APB1SMENR1_USART6SMEN_Pos)
#define RCC_APB1SMENR1_USART6SMEN   RCC_APB1SMENR1_USART6SMEN_Msk
#define RCC_APB1SMENR2_I2C4SMEN_Pos   (1U)
#define RCC_APB1SMENR2_I2C4SMEN_Msk   (0x1UL << RCC_APB1SMENR2_I2C4SMEN_Pos)
#define RCC_APB1SMENR2_I2C4SMEN   RCC_APB1SMENR2_I2C4SMEN_Msk
#define RCC_APB1SMENR2_LPTIM2SMEN_Pos   (5U)
#define RCC_APB1SMENR2_LPTIM2SMEN_Msk   (0x1UL << RCC_APB1SMENR2_LPTIM2SMEN_Pos)
#define RCC_APB1SMENR2_LPTIM2SMEN   RCC_APB1SMENR2_LPTIM2SMEN_Msk
#define RCC_APB1SMENR2_I2C5SMEN_Pos   (6U)
#define RCC_APB1SMENR2_I2C5SMEN_Msk   (0x1UL << RCC_APB1SMENR2_I2C5SMEN_Pos)
#define RCC_APB1SMENR2_I2C5SMEN   RCC_APB1SMENR2_I2C5SMEN_Msk
#define RCC_APB1SMENR2_I2C6SMEN_Pos   (7U)
#define RCC_APB1SMENR2_I2C6SMEN_Msk   (0x1UL << RCC_APB1SMENR2_I2C6SMEN_Pos)
#define RCC_APB1SMENR2_I2C6SMEN   RCC_APB1SMENR2_I2C6SMEN_Msk
#define RCC_APB1SMENR2_FDCAN1SMEN_Pos   (9U)
#define RCC_APB1SMENR2_FDCAN1SMEN_Msk   (0x1UL << RCC_APB1SMENR2_FDCAN1SMEN_Pos)
#define RCC_APB1SMENR2_FDCAN1SMEN   RCC_APB1SMENR2_FDCAN1SMEN_Msk
#define RCC_APB1SMENR2_UCPD1SMEN_Pos   (23U)
#define RCC_APB1SMENR2_UCPD1SMEN_Msk   (0x1UL << RCC_APB1SMENR2_UCPD1SMEN_Pos)
#define RCC_APB1SMENR2_UCPD1SMEN   RCC_APB1SMENR2_UCPD1SMEN_Msk
#define RCC_APB2SMENR_TIM1SMEN_Pos   (11U)
#define RCC_APB2SMENR_TIM1SMEN_Msk   (0x1UL << RCC_APB2SMENR_TIM1SMEN_Pos)
#define RCC_APB2SMENR_TIM1SMEN   RCC_APB2SMENR_TIM1SMEN_Msk
#define RCC_APB2SMENR_SPI1SMEN_Pos   (12U)
#define RCC_APB2SMENR_SPI1SMEN_Msk   (0x1UL << RCC_APB2SMENR_SPI1SMEN_Pos)
#define RCC_APB2SMENR_SPI1SMEN   RCC_APB2SMENR_SPI1SMEN_Msk
#define RCC_APB2SMENR_TIM8SMEN_Pos   (13U)
#define RCC_APB2SMENR_TIM8SMEN_Msk   (0x1UL << RCC_APB2SMENR_TIM8SMEN_Pos)
#define RCC_APB2SMENR_TIM8SMEN   RCC_APB2SMENR_TIM8SMEN_Msk
#define RCC_APB2SMENR_USART1SMEN_Pos   (14U)
#define RCC_APB2SMENR_USART1SMEN_Msk   (0x1UL << RCC_APB2SMENR_USART1SMEN_Pos)
#define RCC_APB2SMENR_USART1SMEN   RCC_APB2SMENR_USART1SMEN_Msk
#define RCC_APB2SMENR_TIM15SMEN_Pos   (16U)
#define RCC_APB2SMENR_TIM15SMEN_Msk   (0x1UL << RCC_APB2SMENR_TIM15SMEN_Pos)
#define RCC_APB2SMENR_TIM15SMEN   RCC_APB2SMENR_TIM15SMEN_Msk
#define RCC_APB2SMENR_TIM16SMEN_Pos   (17U)
#define RCC_APB2SMENR_TIM16SMEN_Msk   (0x1UL << RCC_APB2SMENR_TIM16SMEN_Pos)
#define RCC_APB2SMENR_TIM16SMEN   RCC_APB2SMENR_TIM16SMEN_Msk
#define RCC_APB2SMENR_TIM17SMEN_Pos   (18U)
#define RCC_APB2SMENR_TIM17SMEN_Msk   (0x1UL << RCC_APB2SMENR_TIM17SMEN_Pos)
#define RCC_APB2SMENR_TIM17SMEN   RCC_APB2SMENR_TIM17SMEN_Msk
#define RCC_APB2SMENR_SAI1SMEN_Pos   (21U)
#define RCC_APB2SMENR_SAI1SMEN_Msk   (0x1UL << RCC_APB2SMENR_SAI1SMEN_Pos)
#define RCC_APB2SMENR_SAI1SMEN   RCC_APB2SMENR_SAI1SMEN_Msk
#define RCC_APB2SMENR_SAI2SMEN_Pos   (22U)
#define RCC_APB2SMENR_SAI2SMEN_Msk   (0x1UL << RCC_APB2SMENR_SAI2SMEN_Pos)
#define RCC_APB2SMENR_SAI2SMEN   RCC_APB2SMENR_SAI2SMEN_Msk
#define RCC_APB2SMENR_GFXTIMSMEN_Pos   (25U)
#define RCC_APB2SMENR_GFXTIMSMEN_Msk   (0x1UL << RCC_APB2SMENR_GFXTIMSMEN_Pos)
#define RCC_APB2SMENR_GFXTIMSMEN   RCC_APB2SMENR_GFXTIMSMEN_Msk
#define RCC_APB2SMENR_LTDCSMEN_Pos   (26U)
#define RCC_APB2SMENR_LTDCSMEN_Msk   (0x1UL << RCC_APB2SMENR_LTDCSMEN_Pos)
#define RCC_APB2SMENR_LTDCSMEN   RCC_APB2SMENR_LTDCSMEN_Msk
#define RCC_APB2SMENR_DSIHOSTSMEN_Pos   (27U)
#define RCC_APB2SMENR_DSIHOSTSMEN_Msk   (0x1UL << RCC_APB2SMENR_DSIHOSTSMEN_Pos)
#define RCC_APB2SMENR_DSIHOSTSMEN   RCC_APB2SMENR_DSIHOSTSMEN_Msk
#define RCC_APB3SMENR_SYSCFGSMEN_Pos   (1U)
#define RCC_APB3SMENR_SYSCFGSMEN_Msk   (0x1UL << RCC_APB3SMENR_SYSCFGSMEN_Pos)
#define RCC_APB3SMENR_SYSCFGSMEN   RCC_APB3SMENR_SYSCFGSMEN_Msk
#define RCC_APB3SMENR_SPI3SMEN_Pos   (5U)
#define RCC_APB3SMENR_SPI3SMEN_Msk   (0x1UL << RCC_APB3SMENR_SPI3SMEN_Pos)
#define RCC_APB3SMENR_SPI3SMEN   RCC_APB3SMENR_SPI3SMEN_Msk
#define RCC_APB3SMENR_LPUART1SMEN_Pos   (6U)
#define RCC_APB3SMENR_LPUART1SMEN_Msk   (0x1UL << RCC_APB3SMENR_LPUART1SMEN_Pos)
#define RCC_APB3SMENR_LPUART1SMEN   RCC_APB3SMENR_LPUART1SMEN_Msk
#define RCC_APB3SMENR_I2C3SMEN_Pos   (7U)
#define RCC_APB3SMENR_I2C3SMEN_Msk   (0x1UL << RCC_APB3SMENR_I2C3SMEN_Pos)
#define RCC_APB3SMENR_I2C3SMEN   RCC_APB3SMENR_I2C3SMEN_Msk
#define RCC_APB3SMENR_LPTIM1SMEN_Pos   (11U)
#define RCC_APB3SMENR_LPTIM1SMEN_Msk   (0x1UL << RCC_APB3SMENR_LPTIM1SMEN_Pos)
#define RCC_APB3SMENR_LPTIM1SMEN   RCC_APB3SMENR_LPTIM1SMEN_Msk
#define RCC_APB3SMENR_LPTIM3SMEN_Pos   (12U)
#define RCC_APB3SMENR_LPTIM3SMEN_Msk   (0x1UL << RCC_APB3SMENR_LPTIM3SMEN_Pos)
#define RCC_APB3SMENR_LPTIM3SMEN   RCC_APB3SMENR_LPTIM3SMEN_Msk
#define RCC_APB3SMENR_LPTIM4SMEN_Pos   (13U)
#define RCC_APB3SMENR_LPTIM4SMEN_Msk   (0x1UL << RCC_APB3SMENR_LPTIM4SMEN_Pos)
#define RCC_APB3SMENR_LPTIM4SMEN   RCC_APB3SMENR_LPTIM4SMEN_Msk
#define RCC_APB3SMENR_OPAMPSMEN_Pos   (14U)
#define RCC_APB3SMENR_OPAMPSMEN_Msk   (0x1UL << RCC_APB3SMENR_OPAMPSMEN_Pos)
#define RCC_APB3SMENR_OPAMPSMEN   RCC_APB3SMENR_OPAMPSMEN_Msk
#define RCC_APB3SMENR_COMPSMEN_Pos   (15U)
#define RCC_APB3SMENR_COMPSMEN_Msk   (0x1UL << RCC_APB3SMENR_COMPSMEN_Pos)
#define RCC_APB3SMENR_COMPSMEN   RCC_APB3SMENR_COMPSMEN_Msk
#define RCC_APB3SMENR_VREFSMEN_Pos   (20U)
#define RCC_APB3SMENR_VREFSMEN_Msk   (0x1UL << RCC_APB3SMENR_VREFSMEN_Pos)
#define RCC_APB3SMENR_VREFSMEN   RCC_APB3SMENR_VREFSMEN_Msk
#define RCC_APB3SMENR_RTCAPBSMEN_Pos   (21U)
#define RCC_APB3SMENR_RTCAPBSMEN_Msk   (0x1UL << RCC_APB3SMENR_RTCAPBSMEN_Pos)
#define RCC_APB3SMENR_RTCAPBSMEN   RCC_APB3SMENR_RTCAPBSMEN_Msk
#define RCC_SRDAMR_SPI3AMEN_Pos   (5U)
#define RCC_SRDAMR_SPI3AMEN_Msk   (0x1UL << RCC_SRDAMR_SPI3AMEN_Pos)
#define RCC_SRDAMR_SPI3AMEN   RCC_SRDAMR_SPI3AMEN_Msk
#define RCC_SRDAMR_LPUART1AMEN_Pos   (6U)
#define RCC_SRDAMR_LPUART1AMEN_Msk   (0x1UL << RCC_SRDAMR_LPUART1AMEN_Pos)
#define RCC_SRDAMR_LPUART1AMEN   RCC_SRDAMR_LPUART1AMEN_Msk
#define RCC_SRDAMR_I2C3AMEN_Pos   (7U)
#define RCC_SRDAMR_I2C3AMEN_Msk   (0x1UL << RCC_SRDAMR_I2C3AMEN_Pos)
#define RCC_SRDAMR_I2C3AMEN   RCC_SRDAMR_I2C3AMEN_Msk
#define RCC_SRDAMR_LPTIM1AMEN_Pos   (11U)
#define RCC_SRDAMR_LPTIM1AMEN_Msk   (0x1UL << RCC_SRDAMR_LPTIM1AMEN_Pos)
#define RCC_SRDAMR_LPTIM1AMEN   RCC_SRDAMR_LPTIM1AMEN_Msk
#define RCC_SRDAMR_LPTIM3AMEN_Pos   (12U)
#define RCC_SRDAMR_LPTIM3AMEN_Msk   (0x1UL << RCC_SRDAMR_LPTIM3AMEN_Pos)
#define RCC_SRDAMR_LPTIM3AMEN   RCC_SRDAMR_LPTIM3AMEN_Msk
#define RCC_SRDAMR_LPTIM4AMEN_Pos   (13U)
#define RCC_SRDAMR_LPTIM4AMEN_Msk   (0x1UL << RCC_SRDAMR_LPTIM4AMEN_Pos)
#define RCC_SRDAMR_LPTIM4AMEN   RCC_SRDAMR_LPTIM4AMEN_Msk
#define RCC_SRDAMR_OPAMPAMEN_Pos   (14U)
#define RCC_SRDAMR_OPAMPAMEN_Msk   (0x1UL << RCC_SRDAMR_OPAMPAMEN_Pos)
#define RCC_SRDAMR_OPAMPAMEN   RCC_SRDAMR_OPAMPAMEN_Msk
#define RCC_SRDAMR_COMPAMEN_Pos   (15U)
#define RCC_SRDAMR_COMPAMEN_Msk   (0x1UL << RCC_SRDAMR_COMPAMEN_Pos)
#define RCC_SRDAMR_COMPAMEN   RCC_SRDAMR_COMPAMEN_Msk
#define RCC_SRDAMR_VREFAMEN_Pos   (20U)
#define RCC_SRDAMR_VREFAMEN_Msk   (0x1UL << RCC_SRDAMR_VREFAMEN_Pos)
#define RCC_SRDAMR_VREFAMEN   RCC_SRDAMR_VREFAMEN_Msk
#define RCC_SRDAMR_RTCAPBAMEN_Pos   (21U)
#define RCC_SRDAMR_RTCAPBAMEN_Msk   (0x1UL << RCC_SRDAMR_RTCAPBAMEN_Pos)
#define RCC_SRDAMR_RTCAPBAMEN   RCC_SRDAMR_RTCAPBAMEN_Msk
#define RCC_SRDAMR_ADC4AMEN_Pos   (25U)
#define RCC_SRDAMR_ADC4AMEN_Msk   (0x1UL << RCC_SRDAMR_ADC4AMEN_Pos)
#define RCC_SRDAMR_ADC4AMEN   RCC_SRDAMR_ADC4AMEN_Msk
#define RCC_SRDAMR_LPGPIO1AMEN_Pos   (26U)
#define RCC_SRDAMR_LPGPIO1AMEN_Msk   (0x1UL << RCC_SRDAMR_LPGPIO1AMEN_Pos)
#define RCC_SRDAMR_LPGPIO1AMEN   RCC_SRDAMR_LPGPIO1AMEN_Msk
#define RCC_SRDAMR_DAC1AMEN_Pos   (27U)
#define RCC_SRDAMR_DAC1AMEN_Msk   (0x1UL << RCC_SRDAMR_DAC1AMEN_Pos)
#define RCC_SRDAMR_DAC1AMEN   RCC_SRDAMR_DAC1AMEN_Msk
#define RCC_SRDAMR_LPDMA1AMEN_Pos   (28U)
#define RCC_SRDAMR_LPDMA1AMEN_Msk   (0x1UL << RCC_SRDAMR_LPDMA1AMEN_Pos)
#define RCC_SRDAMR_LPDMA1AMEN   RCC_SRDAMR_LPDMA1AMEN_Msk
#define RCC_SRDAMR_ADF1AMEN_Pos   (29U)
#define RCC_SRDAMR_ADF1AMEN_Msk   (0x1UL << RCC_SRDAMR_ADF1AMEN_Pos)
#define RCC_SRDAMR_ADF1AMEN   RCC_SRDAMR_ADF1AMEN_Msk
#define RCC_SRDAMR_SRAM4AMEN_Pos   (31U)
#define RCC_SRDAMR_SRAM4AMEN_Msk   (0x1UL << RCC_SRDAMR_SRAM4AMEN_Pos)
#define RCC_SRDAMR_SRAM4AMEN   RCC_SRDAMR_SRAM4AMEN_Msk
#define RCC_CCIPR1_USART1SEL_Pos   (0U)
#define RCC_CCIPR1_USART1SEL_Msk   (0x3UL << RCC_CCIPR1_USART1SEL_Pos)
#define RCC_CCIPR1_USART1SEL   RCC_CCIPR1_USART1SEL_Msk
#define RCC_CCIPR1_USART1SEL_0   (0x1UL << RCC_CCIPR1_USART1SEL_Pos)
#define RCC_CCIPR1_USART1SEL_1   (0x2UL << RCC_CCIPR1_USART1SEL_Pos)
#define RCC_CCIPR1_USART2SEL_Pos   (2U)
#define RCC_CCIPR1_USART2SEL_Msk   (0x3UL << RCC_CCIPR1_USART2SEL_Pos)
#define RCC_CCIPR1_USART2SEL   RCC_CCIPR1_USART2SEL_Msk
#define RCC_CCIPR1_USART2SEL_0   (0x1UL << RCC_CCIPR1_USART2SEL_Pos)
#define RCC_CCIPR1_USART2SEL_1   (0x2UL << RCC_CCIPR1_USART2SEL_Pos)
#define RCC_CCIPR1_USART3SEL_Pos   (4U)
#define RCC_CCIPR1_USART3SEL_Msk   (0x3UL << RCC_CCIPR1_USART3SEL_Pos)
#define RCC_CCIPR1_USART3SEL   RCC_CCIPR1_USART3SEL_Msk
#define RCC_CCIPR1_USART3SEL_0   (0x1UL << RCC_CCIPR1_USART3SEL_Pos)
#define RCC_CCIPR1_USART3SEL_1   (0x2UL << RCC_CCIPR1_USART3SEL_Pos)
#define RCC_CCIPR1_UART4SEL_Pos   (6U)
#define RCC_CCIPR1_UART4SEL_Msk   (0x3UL << RCC_CCIPR1_UART4SEL_Pos)
#define RCC_CCIPR1_UART4SEL   RCC_CCIPR1_UART4SEL_Msk
#define RCC_CCIPR1_UART4SEL_0   (0x1UL << RCC_CCIPR1_UART4SEL_Pos)
#define RCC_CCIPR1_UART4SEL_1   (0x2UL << RCC_CCIPR1_UART4SEL_Pos)
#define RCC_CCIPR1_UART5SEL_Pos   (8U)
#define RCC_CCIPR1_UART5SEL_Msk   (0x3UL << RCC_CCIPR1_UART5SEL_Pos)
#define RCC_CCIPR1_UART5SEL   RCC_CCIPR1_UART5SEL_Msk
#define RCC_CCIPR1_UART5SEL_0   (0x1UL << RCC_CCIPR1_UART5SEL_Pos)
#define RCC_CCIPR1_UART5SEL_1   (0x2UL << RCC_CCIPR1_UART5SEL_Pos)
#define RCC_CCIPR1_I2C1SEL_Pos   (10U)
#define RCC_CCIPR1_I2C1SEL_Msk   (0x3UL << RCC_CCIPR1_I2C1SEL_Pos)
#define RCC_CCIPR1_I2C1SEL   RCC_CCIPR1_I2C1SEL_Msk
#define RCC_CCIPR1_I2C1SEL_0   (0x1UL << RCC_CCIPR1_I2C1SEL_Pos)
#define RCC_CCIPR1_I2C1SEL_1   (0x2UL << RCC_CCIPR1_I2C1SEL_Pos)
#define RCC_CCIPR1_I2C2SEL_Pos   (12U)
#define RCC_CCIPR1_I2C2SEL_Msk   (0x3UL << RCC_CCIPR1_I2C2SEL_Pos)
#define RCC_CCIPR1_I2C2SEL   RCC_CCIPR1_I2C2SEL_Msk
#define RCC_CCIPR1_I2C2SEL_0   (0x1UL << RCC_CCIPR1_I2C2SEL_Pos)
#define RCC_CCIPR1_I2C2SEL_1   (0x2UL << RCC_CCIPR1_I2C2SEL_Pos)
#define RCC_CCIPR1_I2C4SEL_Pos   (14U)
#define RCC_CCIPR1_I2C4SEL_Msk   (0x3UL << RCC_CCIPR1_I2C4SEL_Pos)
#define RCC_CCIPR1_I2C4SEL   RCC_CCIPR1_I2C4SEL_Msk
#define RCC_CCIPR1_I2C4SEL_0   (0x1UL << RCC_CCIPR1_I2C4SEL_Pos)
#define RCC_CCIPR1_I2C4SEL_1   (0x2UL << RCC_CCIPR1_I2C4SEL_Pos)
#define RCC_CCIPR1_SPI2SEL_Pos   (16U)
#define RCC_CCIPR1_SPI2SEL_Msk   (0x3UL << RCC_CCIPR1_SPI2SEL_Pos)
#define RCC_CCIPR1_SPI2SEL   RCC_CCIPR1_SPI2SEL_Msk
#define RCC_CCIPR1_SPI2SEL_0   (0x1UL << RCC_CCIPR1_SPI2SEL_Pos)
#define RCC_CCIPR1_SPI2SEL_1   (0x2UL << RCC_CCIPR1_SPI2SEL_Pos)
#define RCC_CCIPR1_LPTIM2SEL_Pos   (18U)
#define RCC_CCIPR1_LPTIM2SEL_Msk   (0x3UL << RCC_CCIPR1_LPTIM2SEL_Pos)
#define RCC_CCIPR1_LPTIM2SEL   RCC_CCIPR1_LPTIM2SEL_Msk
#define RCC_CCIPR1_LPTIM2SEL_0   (0x1UL << RCC_CCIPR1_LPTIM2SEL_Pos)
#define RCC_CCIPR1_LPTIM2SEL_1   (0x2UL << RCC_CCIPR1_LPTIM2SEL_Pos)
#define RCC_CCIPR1_SPI1SEL_Pos   (20U)
#define RCC_CCIPR1_SPI1SEL_Msk   (0x3UL << RCC_CCIPR1_SPI1SEL_Pos)
#define RCC_CCIPR1_SPI1SEL   RCC_CCIPR1_SPI1SEL_Msk
#define RCC_CCIPR1_SPI1SEL_0   (0x1UL << RCC_CCIPR1_SPI1SEL_Pos)
#define RCC_CCIPR1_SPI1SEL_1   (0x2UL << RCC_CCIPR1_SPI1SEL_Pos)
#define RCC_CCIPR1_SYSTICKSEL_Pos   (22U)
#define RCC_CCIPR1_SYSTICKSEL_Msk   (0x3UL << RCC_CCIPR1_SYSTICKSEL_Pos)
#define RCC_CCIPR1_SYSTICKSEL   RCC_CCIPR1_SYSTICKSEL_Msk
#define RCC_CCIPR1_SYSTICKSEL_0   (0x1UL << RCC_CCIPR1_SYSTICKSEL_Pos)
#define RCC_CCIPR1_SYSTICKSEL_1   (0x2UL << RCC_CCIPR1_SYSTICKSEL_Pos)
#define RCC_CCIPR1_FDCANSEL_Pos   (24U)
#define RCC_CCIPR1_FDCANSEL_Msk   (0x3UL << RCC_CCIPR1_FDCANSEL_Pos)
#define RCC_CCIPR1_FDCANSEL   RCC_CCIPR1_FDCANSEL_Msk
#define RCC_CCIPR1_FDCANSEL_0   (0x1UL << RCC_CCIPR1_FDCANSEL_Pos)
#define RCC_CCIPR1_FDCANSEL_1   (0x2UL << RCC_CCIPR1_FDCANSEL_Pos)
#define RCC_CCIPR1_ICLKSEL_Pos   (26U)
#define RCC_CCIPR1_ICLKSEL_Msk   (0x3UL << RCC_CCIPR1_ICLKSEL_Pos)
#define RCC_CCIPR1_ICLKSEL   RCC_CCIPR1_ICLKSEL_Msk
#define RCC_CCIPR1_ICLKSEL_0   (0x1UL << RCC_CCIPR1_ICLKSEL_Pos)
#define RCC_CCIPR1_ICLKSEL_1   (0x2UL << RCC_CCIPR1_ICLKSEL_Pos)
#define RCC_CCIPR1_TIMICSEL_Pos   (29U)
#define RCC_CCIPR1_TIMICSEL_Msk   (0x7UL << RCC_CCIPR1_TIMICSEL_Pos)
#define RCC_CCIPR1_TIMICSEL   RCC_CCIPR1_TIMICSEL_Msk
#define RCC_CCIPR1_TIMICSEL_0   (0x1UL << RCC_CCIPR1_TIMICSEL_Pos)
#define RCC_CCIPR1_TIMICSEL_1   (0x2UL << RCC_CCIPR1_TIMICSEL_Pos)
#define RCC_CCIPR1_TIMICSEL_2   (0x4UL << RCC_CCIPR1_TIMICSEL_Pos)
#define RCC_CCIPR2_MDF1SEL_Pos   (0U)
#define RCC_CCIPR2_MDF1SEL_Msk   (0x7UL << RCC_CCIPR2_MDF1SEL_Pos)
#define RCC_CCIPR2_MDF1SEL   RCC_CCIPR2_MDF1SEL_Msk
#define RCC_CCIPR2_MDF1SEL_0   (0x1UL << RCC_CCIPR2_MDF1SEL_Pos)
#define RCC_CCIPR2_MDF1SEL_1   (0x2UL << RCC_CCIPR2_MDF1SEL_Pos)
#define RCC_CCIPR2_MDF1SEL_2   (0x4UL << RCC_CCIPR2_MDF1SEL_Pos)
#define RCC_CCIPR2_SAI1SEL_Pos   (5U)
#define RCC_CCIPR2_SAI1SEL_Msk   (0x7UL << RCC_CCIPR2_SAI1SEL_Pos)
#define RCC_CCIPR2_SAI1SEL   RCC_CCIPR2_SAI1SEL_Msk
#define RCC_CCIPR2_SAI1SEL_0   (0x1UL << RCC_CCIPR2_SAI1SEL_Pos)
#define RCC_CCIPR2_SAI1SEL_1   (0x2UL << RCC_CCIPR2_SAI1SEL_Pos)
#define RCC_CCIPR2_SAI1SEL_2   (0x4UL << RCC_CCIPR2_SAI1SEL_Pos)
#define RCC_CCIPR2_SAI2SEL_Pos   (8U)
#define RCC_CCIPR2_SAI2SEL_Msk   (0x7UL << RCC_CCIPR2_SAI2SEL_Pos)
#define RCC_CCIPR2_SAI2SEL   RCC_CCIPR2_SAI2SEL_Msk
#define RCC_CCIPR2_SAI2SEL_0   (0x1UL << RCC_CCIPR2_SAI2SEL_Pos)
#define RCC_CCIPR2_SAI2SEL_1   (0x2UL << RCC_CCIPR2_SAI2SEL_Pos)
#define RCC_CCIPR2_SAI2SEL_2   (0x4UL << RCC_CCIPR2_SAI2SEL_Pos)
#define RCC_CCIPR2_SAESSEL_Pos   (11U)
#define RCC_CCIPR2_SAESSEL_Msk   (0x1UL << RCC_CCIPR2_SAESSEL_Pos)
#define RCC_CCIPR2_SAESSEL   RCC_CCIPR2_SAESSEL_Msk
#define RCC_CCIPR2_RNGSEL_Pos   (12U)
#define RCC_CCIPR2_RNGSEL_Msk   (0x3UL << RCC_CCIPR2_RNGSEL_Pos)
#define RCC_CCIPR2_RNGSEL   RCC_CCIPR2_RNGSEL_Msk
#define RCC_CCIPR2_RNGSEL_0   (0x1UL << RCC_CCIPR2_RNGSEL_Pos)
#define RCC_CCIPR2_RNGSEL_1   (0x2UL << RCC_CCIPR2_RNGSEL_Pos)
#define RCC_CCIPR2_SDMMCSEL_Pos   (14U)
#define RCC_CCIPR2_SDMMCSEL_Msk   (0x1UL << RCC_CCIPR2_SDMMCSEL_Pos)
#define RCC_CCIPR2_SDMMCSEL   RCC_CCIPR2_SDMMCSEL_Msk
#define RCC_CCIPR2_DSIHOSTSEL_Pos   (15U)
#define RCC_CCIPR2_DSIHOSTSEL_Msk   (0x1UL << RCC_CCIPR2_DSIHOSTSEL_Pos)
#define RCC_CCIPR2_DSIHOSTSEL   RCC_CCIPR2_DSIHOSTSEL_Msk
#define RCC_CCIPR2_USART6SEL_Pos   (16U)
#define RCC_CCIPR2_USART6SEL_Msk   (0x3UL << RCC_CCIPR2_USART6SEL_Pos)
#define RCC_CCIPR2_USART6SEL   RCC_CCIPR2_USART6SEL_Msk
#define RCC_CCIPR2_USART6SEL_0   (0x1UL << RCC_CCIPR2_USART6SEL_Pos)
#define RCC_CCIPR2_USART6SEL_1   (0x2UL << RCC_CCIPR2_USART6SEL_Pos)
#define RCC_CCIPR2_LTDCSEL_Pos   (18U)
#define RCC_CCIPR2_LTDCSEL_Msk   (0x1UL << RCC_CCIPR2_LTDCSEL_Pos)
#define RCC_CCIPR2_LTDCSEL   RCC_CCIPR2_LTDCSEL_Msk
#define RCC_CCIPR2_OCTOSPISEL_Pos   (20U)
#define RCC_CCIPR2_OCTOSPISEL_Msk   (0x3UL << RCC_CCIPR2_OCTOSPISEL_Pos)
#define RCC_CCIPR2_OCTOSPISEL   RCC_CCIPR2_OCTOSPISEL_Msk
#define RCC_CCIPR2_OCTOSPISEL_0   (0x1UL << RCC_CCIPR2_OCTOSPISEL_Pos)
#define RCC_CCIPR2_OCTOSPISEL_1   (0x2UL << RCC_CCIPR2_OCTOSPISEL_Pos)
#define RCC_CCIPR2_HSPISEL_Pos   (22U)
#define RCC_CCIPR2_HSPISEL_Msk   (0x3UL << RCC_CCIPR2_HSPISEL_Pos)
#define RCC_CCIPR2_HSPISEL   RCC_CCIPR2_HSPISEL_Msk
#define RCC_CCIPR2_HSPISEL_0   (0x1UL << RCC_CCIPR2_HSPISEL_Pos)
#define RCC_CCIPR2_HSPISEL_1   (0x2UL << RCC_CCIPR2_HSPISEL_Pos)
#define RCC_CCIPR2_I2C5SEL_Pos   (24U)
#define RCC_CCIPR2_I2C5SEL_Msk   (0x3UL << RCC_CCIPR2_I2C5SEL_Pos)
#define RCC_CCIPR2_I2C5SEL   RCC_CCIPR2_I2C5SEL_Msk
#define RCC_CCIPR2_I2C5SEL_0   (0x1UL << RCC_CCIPR2_I2C5SEL_Pos)
#define RCC_CCIPR2_I2C5SEL_1   (0x2UL << RCC_CCIPR2_I2C5SEL_Pos)
#define RCC_CCIPR2_I2C6SEL_Pos   (26U)
#define RCC_CCIPR2_I2C6SEL_Msk   (0x3UL << RCC_CCIPR2_I2C6SEL_Pos)
#define RCC_CCIPR2_I2C6SEL   RCC_CCIPR2_I2C6SEL_Msk
#define RCC_CCIPR2_I2C6SEL_0   (0x1UL << RCC_CCIPR2_I2C6SEL_Pos)
#define RCC_CCIPR2_I2C6SEL_1   (0x2UL << RCC_CCIPR2_I2C6SEL_Pos)
#define RCC_CCIPR2_USBPHYCSEL_Pos   (30U)
#define RCC_CCIPR2_USBPHYCSEL_Msk   (0x3UL << RCC_CCIPR2_USBPHYCSEL_Pos)
#define RCC_CCIPR2_USBPHYCSEL   RCC_CCIPR2_USBPHYCSEL_Msk
#define RCC_CCIPR2_USBPHYCSEL_0   (0x1UL << RCC_CCIPR2_USBPHYCSEL_Pos)
#define RCC_CCIPR2_USBPHYCSEL_1   (0x2UL << RCC_CCIPR2_USBPHYCSEL_Pos)
#define RCC_CCIPR3_LPUART1SEL_Pos   (0U)
#define RCC_CCIPR3_LPUART1SEL_Msk   (0x7UL << RCC_CCIPR3_LPUART1SEL_Pos)
#define RCC_CCIPR3_LPUART1SEL   RCC_CCIPR3_LPUART1SEL_Msk
#define RCC_CCIPR3_LPUART1SEL_0   (0x1UL << RCC_CCIPR3_LPUART1SEL_Pos)
#define RCC_CCIPR3_LPUART1SEL_1   (0x2UL << RCC_CCIPR3_LPUART1SEL_Pos)
#define RCC_CCIPR3_LPUART1SEL_2   (0x4UL << RCC_CCIPR3_LPUART1SEL_Pos)
#define RCC_CCIPR3_SPI3SEL_Pos   (3U)
#define RCC_CCIPR3_SPI3SEL_Msk   (0x3UL << RCC_CCIPR3_SPI3SEL_Pos)
#define RCC_CCIPR3_SPI3SEL   RCC_CCIPR3_SPI3SEL_Msk
#define RCC_CCIPR3_SPI3SEL_0   (0x1UL << RCC_CCIPR3_SPI3SEL_Pos)
#define RCC_CCIPR3_SPI3SEL_1   (0x2UL << RCC_CCIPR3_SPI3SEL_Pos)
#define RCC_CCIPR3_I2C3SEL_Pos   (6U)
#define RCC_CCIPR3_I2C3SEL_Msk   (0x3UL << RCC_CCIPR3_I2C3SEL_Pos)
#define RCC_CCIPR3_I2C3SEL   RCC_CCIPR3_I2C3SEL_Msk
#define RCC_CCIPR3_I2C3SEL_0   (0x1UL << RCC_CCIPR3_I2C3SEL_Pos)
#define RCC_CCIPR3_I2C3SEL_1   (0x2UL << RCC_CCIPR3_I2C3SEL_Pos)
#define RCC_CCIPR3_LPTIM34SEL_Pos   (8U)
#define RCC_CCIPR3_LPTIM34SEL_Msk   (0x3UL << RCC_CCIPR3_LPTIM34SEL_Pos)
#define RCC_CCIPR3_LPTIM34SEL   RCC_CCIPR3_LPTIM34SEL_Msk
#define RCC_CCIPR3_LPTIM34SEL_0   (0x1UL << RCC_CCIPR3_LPTIM34SEL_Pos)
#define RCC_CCIPR3_LPTIM34SEL_1   (0x2UL << RCC_CCIPR3_LPTIM34SEL_Pos)
#define RCC_CCIPR3_LPTIM1SEL_Pos   (10U)
#define RCC_CCIPR3_LPTIM1SEL_Msk   (0x3UL << RCC_CCIPR3_LPTIM1SEL_Pos)
#define RCC_CCIPR3_LPTIM1SEL   RCC_CCIPR3_LPTIM1SEL_Msk
#define RCC_CCIPR3_LPTIM1SEL_0   (0x1UL << RCC_CCIPR3_LPTIM1SEL_Pos)
#define RCC_CCIPR3_LPTIM1SEL_1   (0x2UL << RCC_CCIPR3_LPTIM1SEL_Pos)
#define RCC_CCIPR3_ADCDACSEL_Pos   (12U)
#define RCC_CCIPR3_ADCDACSEL_Msk   (0x7UL << RCC_CCIPR3_ADCDACSEL_Pos)
#define RCC_CCIPR3_ADCDACSEL   RCC_CCIPR3_ADCDACSEL_Msk
#define RCC_CCIPR3_ADCDACSEL_0   (0x1UL << RCC_CCIPR3_ADCDACSEL_Pos)
#define RCC_CCIPR3_ADCDACSEL_1   (0x2UL << RCC_CCIPR3_ADCDACSEL_Pos)
#define RCC_CCIPR3_ADCDACSEL_2   (0x4UL << RCC_CCIPR3_ADCDACSEL_Pos)
#define RCC_CCIPR3_DAC1SEL_Pos   (15U)
#define RCC_CCIPR3_DAC1SEL_Msk   (0x1UL << RCC_CCIPR3_DAC1SEL_Pos)
#define RCC_CCIPR3_DAC1SEL   RCC_CCIPR3_DAC1SEL_Msk
#define RCC_CCIPR3_ADF1SEL_Pos   (16U)
#define RCC_CCIPR3_ADF1SEL_Msk   (0x7UL << RCC_CCIPR3_ADF1SEL_Pos)
#define RCC_CCIPR3_ADF1SEL   RCC_CCIPR3_ADF1SEL_Msk
#define RCC_CCIPR3_ADF1SEL_0   (0x1UL << RCC_CCIPR3_ADF1SEL_Pos)
#define RCC_CCIPR3_ADF1SEL_1   (0x2UL << RCC_CCIPR3_ADF1SEL_Pos)
#define RCC_CCIPR3_ADF1SEL_2   (0x4UL << RCC_CCIPR3_ADF1SEL_Pos)
#define RCC_BDCR_LSEON_Pos   (0U)
#define RCC_BDCR_LSEON_Msk   (0x1UL << RCC_BDCR_LSEON_Pos)
#define RCC_BDCR_LSEON   RCC_BDCR_LSEON_Msk
#define RCC_BDCR_LSERDY_Pos   (1U)
#define RCC_BDCR_LSERDY_Msk   (0x1UL << RCC_BDCR_LSERDY_Pos)
#define RCC_BDCR_LSERDY   RCC_BDCR_LSERDY_Msk
#define RCC_BDCR_LSEBYP_Pos   (2U)
#define RCC_BDCR_LSEBYP_Msk   (0x1UL << RCC_BDCR_LSEBYP_Pos)
#define RCC_BDCR_LSEBYP   RCC_BDCR_LSEBYP_Msk
#define RCC_BDCR_LSEDRV_Pos   (3U)
#define RCC_BDCR_LSEDRV_Msk   (0x3UL << RCC_BDCR_LSEDRV_Pos)
#define RCC_BDCR_LSEDRV   RCC_BDCR_LSEDRV_Msk
#define RCC_BDCR_LSEDRV_0   (0x1UL << RCC_BDCR_LSEDRV_Pos)
#define RCC_BDCR_LSEDRV_1   (0x2UL << RCC_BDCR_LSEDRV_Pos)
#define RCC_BDCR_LSECSSON_Pos   (5U)
#define RCC_BDCR_LSECSSON_Msk   (0x1UL << RCC_BDCR_LSECSSON_Pos)
#define RCC_BDCR_LSECSSON   RCC_BDCR_LSECSSON_Msk
#define RCC_BDCR_LSECSSD_Pos   (6U)
#define RCC_BDCR_LSECSSD_Msk   (0x1UL << RCC_BDCR_LSECSSD_Pos)
#define RCC_BDCR_LSECSSD   RCC_BDCR_LSECSSD_Msk
#define RCC_BDCR_LSESYSEN_Pos   (7U)
#define RCC_BDCR_LSESYSEN_Msk   (0x1UL << RCC_BDCR_LSESYSEN_Pos)
#define RCC_BDCR_LSESYSEN   RCC_BDCR_LSESYSEN_Msk
#define RCC_BDCR_RTCSEL_Pos   (8U)
#define RCC_BDCR_RTCSEL_Msk   (0x3UL << RCC_BDCR_RTCSEL_Pos)
#define RCC_BDCR_RTCSEL   RCC_BDCR_RTCSEL_Msk
#define RCC_BDCR_RTCSEL_0   (0x1UL << RCC_BDCR_RTCSEL_Pos)
#define RCC_BDCR_RTCSEL_1   (0x2UL << RCC_BDCR_RTCSEL_Pos)
#define RCC_BDCR_LSESYSRDY_Pos   (11U)
#define RCC_BDCR_LSESYSRDY_Msk   (0x1UL << RCC_BDCR_LSESYSRDY_Pos)
#define RCC_BDCR_LSESYSRDY   RCC_BDCR_LSESYSRDY_Msk
#define RCC_BDCR_LSEGFON_Pos   (12U)
#define RCC_BDCR_LSEGFON_Msk   (0x1UL << RCC_BDCR_LSEGFON_Pos)
#define RCC_BDCR_LSEGFON   RCC_BDCR_LSEGFON_Msk
#define RCC_BDCR_RTCEN_Pos   (15U)
#define RCC_BDCR_RTCEN_Msk   (0x1UL << RCC_BDCR_RTCEN_Pos)
#define RCC_BDCR_RTCEN   RCC_BDCR_RTCEN_Msk
#define RCC_BDCR_BDRST_Pos   (16U)
#define RCC_BDCR_BDRST_Msk   (0x1UL << RCC_BDCR_BDRST_Pos)
#define RCC_BDCR_BDRST   RCC_BDCR_BDRST_Msk
#define RCC_BDCR_LSCOEN_Pos   (24U)
#define RCC_BDCR_LSCOEN_Msk   (0x1UL << RCC_BDCR_LSCOEN_Pos)
#define RCC_BDCR_LSCOEN   RCC_BDCR_LSCOEN_Msk
#define RCC_BDCR_LSCOSEL_Pos   (25U)
#define RCC_BDCR_LSCOSEL_Msk   (0x1UL << RCC_BDCR_LSCOSEL_Pos)
#define RCC_BDCR_LSCOSEL   RCC_BDCR_LSCOSEL_Msk
#define RCC_BDCR_LSION_Pos   (26U)
#define RCC_BDCR_LSION_Msk   (0x1UL << RCC_BDCR_LSION_Pos)
#define RCC_BDCR_LSION   RCC_BDCR_LSION_Msk
#define RCC_BDCR_LSIRDY_Pos   (27U)
#define RCC_BDCR_LSIRDY_Msk   (0x1UL << RCC_BDCR_LSIRDY_Pos)
#define RCC_BDCR_LSIRDY   RCC_BDCR_LSIRDY_Msk
#define RCC_BDCR_LSIPREDIV_Pos   (28U)
#define RCC_BDCR_LSIPREDIV_Msk   (0x1UL << RCC_BDCR_LSIPREDIV_Pos)
#define RCC_BDCR_LSIPREDIV   RCC_BDCR_LSIPREDIV_Msk
#define RCC_CSR_MSIKSRANGE_Pos   (8U)
#define RCC_CSR_MSIKSRANGE_Msk   (0xFUL << RCC_CSR_MSIKSRANGE_Pos)
#define RCC_CSR_MSIKSRANGE   RCC_CSR_MSIKSRANGE_Msk
#define RCC_CSR_MSIKSRANGE_0   (0x1UL << RCC_CSR_MSIKSRANGE_Pos)
#define RCC_CSR_MSIKSRANGE_1   (0x2UL << RCC_CSR_MSIKSRANGE_Pos)
#define RCC_CSR_MSIKSRANGE_2   (0x4UL << RCC_CSR_MSIKSRANGE_Pos)
#define RCC_CSR_MSIKSRANGE_3   (0x8UL << RCC_CSR_MSIKSRANGE_Pos)
#define RCC_CSR_MSISSRANGE_Pos   (12U)
#define RCC_CSR_MSISSRANGE_Msk   (0xFUL << RCC_CSR_MSISSRANGE_Pos)
#define RCC_CSR_MSISSRANGE   RCC_CSR_MSISSRANGE_Msk
#define RCC_CSR_MSISSRANGE_0   (0x1UL << RCC_CSR_MSISSRANGE_Pos)
#define RCC_CSR_MSISSRANGE_1   (0x2UL << RCC_CSR_MSISSRANGE_Pos)
#define RCC_CSR_MSISSRANGE_2   (0x4UL << RCC_CSR_MSISSRANGE_Pos)
#define RCC_CSR_MSISSRANGE_3   (0x8UL << RCC_CSR_MSISSRANGE_Pos)
#define RCC_CSR_RMVF_Pos   (23U)
#define RCC_CSR_RMVF_Msk   (0x1UL << RCC_CSR_RMVF_Pos)
#define RCC_CSR_RMVF   RCC_CSR_RMVF_Msk
#define RCC_CSR_OBLRSTF_Pos   (25U)
#define RCC_CSR_OBLRSTF_Msk   (0x1UL << RCC_CSR_OBLRSTF_Pos)
#define RCC_CSR_OBLRSTF   RCC_CSR_OBLRSTF_Msk
#define RCC_CSR_PINRSTF_Pos   (26U)
#define RCC_CSR_PINRSTF_Msk   (0x1UL << RCC_CSR_PINRSTF_Pos)
#define RCC_CSR_PINRSTF   RCC_CSR_PINRSTF_Msk
#define RCC_CSR_BORRSTF_Pos   (27U)
#define RCC_CSR_BORRSTF_Msk   (0x1UL << RCC_CSR_BORRSTF_Pos)
#define RCC_CSR_BORRSTF   RCC_CSR_BORRSTF_Msk
#define RCC_CSR_SFTRSTF_Pos   (28U)
#define RCC_CSR_SFTRSTF_Msk   (0x1UL << RCC_CSR_SFTRSTF_Pos)
#define RCC_CSR_SFTRSTF   RCC_CSR_SFTRSTF_Msk
#define RCC_CSR_IWDGRSTF_Pos   (29U)
#define RCC_CSR_IWDGRSTF_Msk   (0x1UL << RCC_CSR_IWDGRSTF_Pos)
#define RCC_CSR_IWDGRSTF   RCC_CSR_IWDGRSTF_Msk
#define RCC_CSR_WWDGRSTF_Pos   (30U)
#define RCC_CSR_WWDGRSTF_Msk   (0x1UL << RCC_CSR_WWDGRSTF_Pos)
#define RCC_CSR_WWDGRSTF   RCC_CSR_WWDGRSTF_Msk
#define RCC_CSR_LPWRRSTF_Pos   (31U)
#define RCC_CSR_LPWRRSTF_Msk   (0x1UL << RCC_CSR_LPWRRSTF_Pos)
#define RCC_CSR_LPWRRSTF   RCC_CSR_LPWRRSTF_Msk
#define RCC_SECCFGR_HSISEC_Pos   (0U)
#define RCC_SECCFGR_HSISEC_Msk   (0x1UL << RCC_SECCFGR_HSISEC_Pos)
#define RCC_SECCFGR_HSISEC   RCC_SECCFGR_HSISEC_Msk
#define RCC_SECCFGR_HSESEC_Pos   (1U)
#define RCC_SECCFGR_HSESEC_Msk   (0x1UL << RCC_SECCFGR_HSESEC_Pos)
#define RCC_SECCFGR_HSESEC   RCC_SECCFGR_HSESEC_Msk
#define RCC_SECCFGR_MSISEC_Pos   (2U)
#define RCC_SECCFGR_MSISEC_Msk   (0x1UL << RCC_SECCFGR_MSISEC_Pos)
#define RCC_SECCFGR_MSISEC   RCC_SECCFGR_MSISEC_Msk
#define RCC_SECCFGR_LSISEC_Pos   (3U)
#define RCC_SECCFGR_LSISEC_Msk   (0x1UL << RCC_SECCFGR_LSISEC_Pos)
#define RCC_SECCFGR_LSISEC   RCC_SECCFGR_LSISEC_Msk
#define RCC_SECCFGR_LSESEC_Pos   (4U)
#define RCC_SECCFGR_LSESEC_Msk   (0x1UL << RCC_SECCFGR_LSESEC_Pos)
#define RCC_SECCFGR_LSESEC   RCC_SECCFGR_LSESEC_Msk
#define RCC_SECCFGR_SYSCLKSEC_Pos   (5U)
#define RCC_SECCFGR_SYSCLKSEC_Msk   (0x1UL << RCC_SECCFGR_SYSCLKSEC_Pos)
#define RCC_SECCFGR_SYSCLKSEC   RCC_SECCFGR_SYSCLKSEC_Msk
#define RCC_SECCFGR_PRESCSEC_Pos   (6U)
#define RCC_SECCFGR_PRESCSEC_Msk   (0x1UL << RCC_SECCFGR_PRESCSEC_Pos)
#define RCC_SECCFGR_PRESCSEC   RCC_SECCFGR_PRESCSEC_Msk
#define RCC_SECCFGR_PLL1SEC_Pos   (7U)
#define RCC_SECCFGR_PLL1SEC_Msk   (0x1UL << RCC_SECCFGR_PLL1SEC_Pos)
#define RCC_SECCFGR_PLL1SEC   RCC_SECCFGR_PLL1SEC_Msk
#define RCC_SECCFGR_PLL2SEC_Pos   (8U)
#define RCC_SECCFGR_PLL2SEC_Msk   (0x1UL << RCC_SECCFGR_PLL2SEC_Pos)
#define RCC_SECCFGR_PLL2SEC   RCC_SECCFGR_PLL2SEC_Msk
#define RCC_SECCFGR_PLL3SEC_Pos   (9U)
#define RCC_SECCFGR_PLL3SEC_Msk   (0x1UL << RCC_SECCFGR_PLL3SEC_Pos)
#define RCC_SECCFGR_PLL3SEC   RCC_SECCFGR_PLL3SEC_Msk
#define RCC_SECCFGR_ICLKSEC_Pos   (10U)
#define RCC_SECCFGR_ICLKSEC_Msk   (0x1UL << RCC_SECCFGR_ICLKSEC_Pos)
#define RCC_SECCFGR_ICLKSEC   RCC_SECCFGR_ICLKSEC_Msk
#define RCC_SECCFGR_HSI48SEC_Pos   (11U)
#define RCC_SECCFGR_HSI48SEC_Msk   (0x1UL << RCC_SECCFGR_HSI48SEC_Pos)
#define RCC_SECCFGR_HSI48SEC   RCC_SECCFGR_HSI48SEC_Msk
#define RCC_SECCFGR_RMVFSEC_Pos   (12U)
#define RCC_SECCFGR_RMVFSEC_Msk   (0x1UL << RCC_SECCFGR_RMVFSEC_Pos)
#define RCC_SECCFGR_RMVFSEC   RCC_SECCFGR_RMVFSEC_Msk
#define RCC_PRIVCFGR_SPRIV_Pos   (0U)
#define RCC_PRIVCFGR_SPRIV_Msk   (0x1UL << RCC_PRIVCFGR_SPRIV_Pos)
#define RCC_PRIVCFGR_SPRIV   RCC_PRIVCFGR_SPRIV_Msk
#define RCC_PRIVCFGR_NSPRIV_Pos   (1U)
#define RCC_PRIVCFGR_NSPRIV_Msk   (0x1UL << RCC_PRIVCFGR_NSPRIV_Pos)
#define RCC_PRIVCFGR_NSPRIV   RCC_PRIVCFGR_NSPRIV_Msk
#define RTC_TR_SU_Pos   (0U)
#define RTC_TR_SU_Msk   (0xFUL << RTC_TR_SU_Pos)
#define RTC_TR_SU   RTC_TR_SU_Msk
#define RTC_TR_SU_0   (0x1UL << RTC_TR_SU_Pos)
#define RTC_TR_SU_1   (0x2UL << RTC_TR_SU_Pos)
#define RTC_TR_SU_2   (0x4UL << RTC_TR_SU_Pos)
#define RTC_TR_SU_3   (0x8UL << RTC_TR_SU_Pos)
#define RTC_TR_ST_Pos   (4U)
#define RTC_TR_ST_Msk   (0x7UL << RTC_TR_ST_Pos)
#define RTC_TR_ST   RTC_TR_ST_Msk
#define RTC_TR_ST_0   (0x1UL << RTC_TR_ST_Pos)
#define RTC_TR_ST_1   (0x2UL << RTC_TR_ST_Pos)
#define RTC_TR_ST_2   (0x4UL << RTC_TR_ST_Pos)
#define RTC_TR_MNU_Pos   (8U)
#define RTC_TR_MNU_Msk   (0xFUL << RTC_TR_MNU_Pos)
#define RTC_TR_MNU   RTC_TR_MNU_Msk
#define RTC_TR_MNU_0   (0x1UL << RTC_TR_MNU_Pos)
#define RTC_TR_MNU_1   (0x2UL << RTC_TR_MNU_Pos)
#define RTC_TR_MNU_2   (0x4UL << RTC_TR_MNU_Pos)
#define RTC_TR_MNU_3   (0x8UL << RTC_TR_MNU_Pos)
#define RTC_TR_MNT_Pos   (12U)
#define RTC_TR_MNT_Msk   (0x7UL << RTC_TR_MNT_Pos)
#define RTC_TR_MNT   RTC_TR_MNT_Msk
#define RTC_TR_MNT_0   (0x1UL << RTC_TR_MNT_Pos)
#define RTC_TR_MNT_1   (0x2UL << RTC_TR_MNT_Pos)
#define RTC_TR_MNT_2   (0x4UL << RTC_TR_MNT_Pos)
#define RTC_TR_HU_Pos   (16U)
#define RTC_TR_HU_Msk   (0xFUL << RTC_TR_HU_Pos)
#define RTC_TR_HU   RTC_TR_HU_Msk
#define RTC_TR_HU_0   (0x1UL << RTC_TR_HU_Pos)
#define RTC_TR_HU_1   (0x2UL << RTC_TR_HU_Pos)
#define RTC_TR_HU_2   (0x4UL << RTC_TR_HU_Pos)
#define RTC_TR_HU_3   (0x8UL << RTC_TR_HU_Pos)
#define RTC_TR_HT_Pos   (20U)
#define RTC_TR_HT_Msk   (0x3UL << RTC_TR_HT_Pos)
#define RTC_TR_HT   RTC_TR_HT_Msk
#define RTC_TR_HT_0   (0x1UL << RTC_TR_HT_Pos)
#define RTC_TR_HT_1   (0x2UL << RTC_TR_HT_Pos)
#define RTC_TR_PM_Pos   (22U)
#define RTC_TR_PM_Msk   (0x1UL << RTC_TR_PM_Pos)
#define RTC_TR_PM   RTC_TR_PM_Msk
#define RTC_DR_DU_Pos   (0U)
#define RTC_DR_DU_Msk   (0xFUL << RTC_DR_DU_Pos)
#define RTC_DR_DU   RTC_DR_DU_Msk
#define RTC_DR_DU_0   (0x1UL << RTC_DR_DU_Pos)
#define RTC_DR_DU_1   (0x2UL << RTC_DR_DU_Pos)
#define RTC_DR_DU_2   (0x4UL << RTC_DR_DU_Pos)
#define RTC_DR_DU_3   (0x8UL << RTC_DR_DU_Pos)
#define RTC_DR_DT_Pos   (4U)
#define RTC_DR_DT_Msk   (0x3UL << RTC_DR_DT_Pos)
#define RTC_DR_DT   RTC_DR_DT_Msk
#define RTC_DR_DT_0   (0x1UL << RTC_DR_DT_Pos)
#define RTC_DR_DT_1   (0x2UL << RTC_DR_DT_Pos)
#define RTC_DR_MU_Pos   (8U)
#define RTC_DR_MU_Msk   (0xFUL << RTC_DR_MU_Pos)
#define RTC_DR_MU   RTC_DR_MU_Msk
#define RTC_DR_MU_0   (0x1UL << RTC_DR_MU_Pos)
#define RTC_DR_MU_1   (0x2UL << RTC_DR_MU_Pos)
#define RTC_DR_MU_2   (0x4UL << RTC_DR_MU_Pos)
#define RTC_DR_MU_3   (0x8UL << RTC_DR_MU_Pos)
#define RTC_DR_MT_Pos   (12U)
#define RTC_DR_MT_Msk   (0x1UL << RTC_DR_MT_Pos)
#define RTC_DR_MT   RTC_DR_MT_Msk
#define RTC_DR_WDU_Pos   (13U)
#define RTC_DR_WDU_Msk   (0x7UL << RTC_DR_WDU_Pos)
#define RTC_DR_WDU   RTC_DR_WDU_Msk
#define RTC_DR_WDU_0   (0x1UL << RTC_DR_WDU_Pos)
#define RTC_DR_WDU_1   (0x2UL << RTC_DR_WDU_Pos)
#define RTC_DR_WDU_2   (0x4UL << RTC_DR_WDU_Pos)
#define RTC_DR_YU_Pos   (16U)
#define RTC_DR_YU_Msk   (0xFUL << RTC_DR_YU_Pos)
#define RTC_DR_YU   RTC_DR_YU_Msk
#define RTC_DR_YU_0   (0x1UL << RTC_DR_YU_Pos)
#define RTC_DR_YU_1   (0x2UL << RTC_DR_YU_Pos)
#define RTC_DR_YU_2   (0x4UL << RTC_DR_YU_Pos)
#define RTC_DR_YU_3   (0x8UL << RTC_DR_YU_Pos)
#define RTC_DR_YT_Pos   (20U)
#define RTC_DR_YT_Msk   (0xFUL << RTC_DR_YT_Pos)
#define RTC_DR_YT   RTC_DR_YT_Msk
#define RTC_DR_YT_0   (0x1UL << RTC_DR_YT_Pos)
#define RTC_DR_YT_1   (0x2UL << RTC_DR_YT_Pos)
#define RTC_DR_YT_2   (0x4UL << RTC_DR_YT_Pos)
#define RTC_DR_YT_3   (0x8UL << RTC_DR_YT_Pos)
#define RTC_SSR_SS_Pos   (0U)
#define RTC_SSR_SS_Msk   (0xFFFFFFFFUL << RTC_SSR_SS_Pos)
#define RTC_SSR_SS   RTC_SSR_SS_Msk
#define RTC_ICSR_WUTWF_Pos   (2U)
#define RTC_ICSR_WUTWF_Msk   (0x1UL << RTC_ICSR_WUTWF_Pos)
#define RTC_ICSR_WUTWF   RTC_ICSR_WUTWF_Msk
#define RTC_ICSR_SHPF_Pos   (3U)
#define RTC_ICSR_SHPF_Msk   (0x1UL << RTC_ICSR_SHPF_Pos)
#define RTC_ICSR_SHPF   RTC_ICSR_SHPF_Msk
#define RTC_ICSR_INITS_Pos   (4U)
#define RTC_ICSR_INITS_Msk   (0x1UL << RTC_ICSR_INITS_Pos)
#define RTC_ICSR_INITS   RTC_ICSR_INITS_Msk
#define RTC_ICSR_RSF_Pos   (5U)
#define RTC_ICSR_RSF_Msk   (0x1UL << RTC_ICSR_RSF_Pos)
#define RTC_ICSR_RSF   RTC_ICSR_RSF_Msk
#define RTC_ICSR_INITF_Pos   (6U)
#define RTC_ICSR_INITF_Msk   (0x1UL << RTC_ICSR_INITF_Pos)
#define RTC_ICSR_INITF   RTC_ICSR_INITF_Msk
#define RTC_ICSR_INIT_Pos   (7U)
#define RTC_ICSR_INIT_Msk   (0x1UL << RTC_ICSR_INIT_Pos)
#define RTC_ICSR_INIT   RTC_ICSR_INIT_Msk
#define RTC_ICSR_BIN_Pos   (8U)
#define RTC_ICSR_BIN_Msk   (0x3UL << RTC_ICSR_BIN_Pos)
#define RTC_ICSR_BIN   RTC_ICSR_BIN_Msk
#define RTC_ICSR_BIN_0   (0x1UL << RTC_ICSR_BIN_Pos)
#define RTC_ICSR_BIN_1   (0x2UL << RTC_ICSR_BIN_Pos)
#define RTC_ICSR_BCDU_Pos   (10U)
#define RTC_ICSR_BCDU_Msk   (0x7UL << RTC_ICSR_BCDU_Pos)
#define RTC_ICSR_BCDU   RTC_ICSR_BCDU_Msk
#define RTC_ICSR_BCDU_0   (0x1UL << RTC_ICSR_BCDU_Pos)
#define RTC_ICSR_BCDU_1   (0x2UL << RTC_ICSR_BCDU_Pos)
#define RTC_ICSR_BCDU_2   (0x4UL << RTC_ICSR_BCDU_Pos)
#define RTC_ICSR_RECALPF_Pos   (16U)
#define RTC_ICSR_RECALPF_Msk   (0x1UL << RTC_ICSR_RECALPF_Pos)
#define RTC_ICSR_RECALPF   RTC_ICSR_RECALPF_Msk
#define RTC_PRER_PREDIV_S_Pos   (0U)
#define RTC_PRER_PREDIV_S_Msk   (0x7FFFUL << RTC_PRER_PREDIV_S_Pos)
#define RTC_PRER_PREDIV_S   RTC_PRER_PREDIV_S_Msk
#define RTC_PRER_PREDIV_A_Pos   (16U)
#define RTC_PRER_PREDIV_A_Msk   (0x7FUL << RTC_PRER_PREDIV_A_Pos)
#define RTC_PRER_PREDIV_A   RTC_PRER_PREDIV_A_Msk
#define RTC_WUTR_WUT_Pos   (0U)
#define RTC_WUTR_WUT_Msk   (0xFFFFUL << RTC_WUTR_WUT_Pos)
#define RTC_WUTR_WUT   RTC_WUTR_WUT_Msk
#define RTC_WUTR_WUTOCLR_Pos   (16U)
#define RTC_WUTR_WUTOCLR_Msk   (0xFFFFUL << RTC_WUTR_WUTOCLR_Pos)
#define RTC_WUTR_WUTOCLR   RTC_WUTR_WUTOCLR_Msk
#define RTC_CR_WUCKSEL_Pos   (0U)
#define RTC_CR_WUCKSEL_Msk   (0x7UL << RTC_CR_WUCKSEL_Pos)
#define RTC_CR_WUCKSEL   RTC_CR_WUCKSEL_Msk
#define RTC_CR_WUCKSEL_0   (0x1UL << RTC_CR_WUCKSEL_Pos)
#define RTC_CR_WUCKSEL_1   (0x2UL << RTC_CR_WUCKSEL_Pos)
#define RTC_CR_WUCKSEL_2   (0x4UL << RTC_CR_WUCKSEL_Pos)
#define RTC_CR_TSEDGE_Pos   (3U)
#define RTC_CR_TSEDGE_Msk   (0x1UL << RTC_CR_TSEDGE_Pos)
#define RTC_CR_TSEDGE   RTC_CR_TSEDGE_Msk
#define RTC_CR_REFCKON_Pos   (4U)
#define RTC_CR_REFCKON_Msk   (0x1UL << RTC_CR_REFCKON_Pos)
#define RTC_CR_REFCKON   RTC_CR_REFCKON_Msk
#define RTC_CR_BYPSHAD_Pos   (5U)
#define RTC_CR_BYPSHAD_Msk   (0x1UL << RTC_CR_BYPSHAD_Pos)
#define RTC_CR_BYPSHAD   RTC_CR_BYPSHAD_Msk
#define RTC_CR_FMT_Pos   (6U)
#define RTC_CR_FMT_Msk   (0x1UL << RTC_CR_FMT_Pos)
#define RTC_CR_FMT   RTC_CR_FMT_Msk
#define RTC_CR_SSRUIE_Pos   (7U)
#define RTC_CR_SSRUIE_Msk   (0x1UL << RTC_CR_SSRUIE_Pos)
#define RTC_CR_SSRUIE   RTC_CR_SSRUIE_Msk
#define RTC_CR_ALRAE_Pos   (8U)
#define RTC_CR_ALRAE_Msk   (0x1UL << RTC_CR_ALRAE_Pos)
#define RTC_CR_ALRAE   RTC_CR_ALRAE_Msk
#define RTC_CR_ALRBE_Pos   (9U)
#define RTC_CR_ALRBE_Msk   (0x1UL << RTC_CR_ALRBE_Pos)
#define RTC_CR_ALRBE   RTC_CR_ALRBE_Msk
#define RTC_CR_WUTE_Pos   (10U)
#define RTC_CR_WUTE_Msk   (0x1UL << RTC_CR_WUTE_Pos)
#define RTC_CR_WUTE   RTC_CR_WUTE_Msk
#define RTC_CR_TSE_Pos   (11U)
#define RTC_CR_TSE_Msk   (0x1UL << RTC_CR_TSE_Pos)
#define RTC_CR_TSE   RTC_CR_TSE_Msk
#define RTC_CR_ALRAIE_Pos   (12U)
#define RTC_CR_ALRAIE_Msk   (0x1UL << RTC_CR_ALRAIE_Pos)
#define RTC_CR_ALRAIE   RTC_CR_ALRAIE_Msk
#define RTC_CR_ALRBIE_Pos   (13U)
#define RTC_CR_ALRBIE_Msk   (0x1UL << RTC_CR_ALRBIE_Pos)
#define RTC_CR_ALRBIE   RTC_CR_ALRBIE_Msk
#define RTC_CR_WUTIE_Pos   (14U)
#define RTC_CR_WUTIE_Msk   (0x1UL << RTC_CR_WUTIE_Pos)
#define RTC_CR_WUTIE   RTC_CR_WUTIE_Msk
#define RTC_CR_TSIE_Pos   (15U)
#define RTC_CR_TSIE_Msk   (0x1UL << RTC_CR_TSIE_Pos)
#define RTC_CR_TSIE   RTC_CR_TSIE_Msk
#define RTC_CR_ADD1H_Pos   (16U)
#define RTC_CR_ADD1H_Msk   (0x1UL << RTC_CR_ADD1H_Pos)
#define RTC_CR_ADD1H   RTC_CR_ADD1H_Msk
#define RTC_CR_SUB1H_Pos   (17U)
#define RTC_CR_SUB1H_Msk   (0x1UL << RTC_CR_SUB1H_Pos)
#define RTC_CR_SUB1H   RTC_CR_SUB1H_Msk
#define RTC_CR_BKP_Pos   (18U)
#define RTC_CR_BKP_Msk   (0x1UL << RTC_CR_BKP_Pos)
#define RTC_CR_BKP   RTC_CR_BKP_Msk
#define RTC_CR_COSEL_Pos   (19U)
#define RTC_CR_COSEL_Msk   (0x1UL << RTC_CR_COSEL_Pos)
#define RTC_CR_COSEL   RTC_CR_COSEL_Msk
#define RTC_CR_POL_Pos   (20U)
#define RTC_CR_POL_Msk   (0x1UL << RTC_CR_POL_Pos)
#define RTC_CR_POL   RTC_CR_POL_Msk
#define RTC_CR_OSEL_Pos   (21U)
#define RTC_CR_OSEL_Msk   (0x3UL << RTC_CR_OSEL_Pos)
#define RTC_CR_OSEL   RTC_CR_OSEL_Msk
#define RTC_CR_OSEL_0   (0x1UL << RTC_CR_OSEL_Pos)
#define RTC_CR_OSEL_1   (0x2UL << RTC_CR_OSEL_Pos)
#define RTC_CR_COE_Pos   (23U)
#define RTC_CR_COE_Msk   (0x1UL << RTC_CR_COE_Pos)
#define RTC_CR_COE   RTC_CR_COE_Msk
#define RTC_CR_ITSE_Pos   (24U)
#define RTC_CR_ITSE_Msk   (0x1UL << RTC_CR_ITSE_Pos)
#define RTC_CR_ITSE   RTC_CR_ITSE_Msk
#define RTC_CR_TAMPTS_Pos   (25U)
#define RTC_CR_TAMPTS_Msk   (0x1UL << RTC_CR_TAMPTS_Pos)
#define RTC_CR_TAMPTS   RTC_CR_TAMPTS_Msk
#define RTC_CR_TAMPOE_Pos   (26U)
#define RTC_CR_TAMPOE_Msk   (0x1UL << RTC_CR_TAMPOE_Pos)
#define RTC_CR_TAMPOE   RTC_CR_TAMPOE_Msk
#define RTC_CR_ALRAFCLR_Pos   (27U)
#define RTC_CR_ALRAFCLR_Msk   (0x1UL << RTC_CR_ALRAFCLR_Pos)
#define RTC_CR_ALRAFCLR   RTC_CR_ALRAFCLR_Msk
#define RTC_CR_ALRBFCLR_Pos   (28U)
#define RTC_CR_ALRBFCLR_Msk   (0x1UL << RTC_CR_ALRBFCLR_Pos)
#define RTC_CR_ALRBFCLR   RTC_CR_ALRBFCLR_Msk
#define RTC_CR_TAMPALRM_PU_Pos   (29U)
#define RTC_CR_TAMPALRM_PU_Msk   (0x1UL << RTC_CR_TAMPALRM_PU_Pos)
#define RTC_CR_TAMPALRM_PU   RTC_CR_TAMPALRM_PU_Msk
#define RTC_CR_TAMPALRM_TYPE_Pos   (30U)
#define RTC_CR_TAMPALRM_TYPE_Msk   (0x1UL << RTC_CR_TAMPALRM_TYPE_Pos)
#define RTC_CR_TAMPALRM_TYPE   RTC_CR_TAMPALRM_TYPE_Msk
#define RTC_CR_OUT2EN_Pos   (31U)
#define RTC_CR_OUT2EN_Msk   (0x1UL << RTC_CR_OUT2EN_Pos)
#define RTC_CR_OUT2EN   RTC_CR_OUT2EN_Msk
#define RTC_PRIVCFGR_ALRAPRIV_Pos   (0U)
#define RTC_PRIVCFGR_ALRAPRIV_Msk   (0x1UL << RTC_PRIVCFGR_ALRAPRIV_Pos)
#define RTC_PRIVCFGR_ALRAPRIV   RTC_PRIVCFGR_ALRAPRIV_Msk
#define RTC_PRIVCFGR_ALRBPRIV_Pos   (1U)
#define RTC_PRIVCFGR_ALRBPRIV_Msk   (0x1UL << RTC_PRIVCFGR_ALRBPRIV_Pos)
#define RTC_PRIVCFGR_ALRBPRIV   RTC_PRIVCFGR_ALRBPRIV_Msk
#define RTC_PRIVCFGR_WUTPRIV_Pos   (2U)
#define RTC_PRIVCFGR_WUTPRIV_Msk   (0x1UL << RTC_PRIVCFGR_WUTPRIV_Pos)
#define RTC_PRIVCFGR_WUTPRIV   RTC_PRIVCFGR_WUTPRIV_Msk
#define RTC_PRIVCFGR_TSPRIV_Pos   (3U)
#define RTC_PRIVCFGR_TSPRIV_Msk   (0x1UL << RTC_PRIVCFGR_TSPRIV_Pos)
#define RTC_PRIVCFGR_TSPRIV   RTC_PRIVCFGR_TSPRIV_Msk
#define RTC_PRIVCFGR_CALPRIV_Pos   (13U)
#define RTC_PRIVCFGR_CALPRIV_Msk   (0x1UL << RTC_PRIVCFGR_CALPRIV_Pos)
#define RTC_PRIVCFGR_CALPRIV   RTC_PRIVCFGR_CALPRIV_Msk
#define RTC_PRIVCFGR_INITPRIV_Pos   (14U)
#define RTC_PRIVCFGR_INITPRIV_Msk   (0x1UL << RTC_PRIVCFGR_INITPRIV_Pos)
#define RTC_PRIVCFGR_INITPRIV   RTC_PRIVCFGR_INITPRIV_Msk
#define RTC_PRIVCFGR_PRIV_Pos   (15U)
#define RTC_PRIVCFGR_PRIV_Msk   (0x1UL << RTC_PRIVCFGR_PRIV_Pos)
#define RTC_PRIVCFGR_PRIV   RTC_PRIVCFGR_PRIV_Msk
#define RTC_SECCFGR_ALRASEC_Pos   (0U)
#define RTC_SECCFGR_ALRASEC_Msk   (0x1UL << RTC_SECCFGR_ALRASEC_Pos)
#define RTC_SECCFGR_ALRASEC   RTC_SECCFGR_ALRASEC_Msk
#define RTC_SECCFGR_ALRBSEC_Pos   (1U)
#define RTC_SECCFGR_ALRBSEC_Msk   (0x1UL << RTC_SECCFGR_ALRBSEC_Pos)
#define RTC_SECCFGR_ALRBSEC   RTC_SECCFGR_ALRBSEC_Msk
#define RTC_SECCFGR_WUTSEC_Pos   (2U)
#define RTC_SECCFGR_WUTSEC_Msk   (0x1UL << RTC_SECCFGR_WUTSEC_Pos)
#define RTC_SECCFGR_WUTSEC   RTC_SECCFGR_WUTSEC_Msk
#define RTC_SECCFGR_TSSEC_Pos   (3U)
#define RTC_SECCFGR_TSSEC_Msk   (0x1UL << RTC_SECCFGR_TSSEC_Pos)
#define RTC_SECCFGR_TSSEC   RTC_SECCFGR_TSSEC_Msk
#define RTC_SECCFGR_CALSEC_Pos   (13U)
#define RTC_SECCFGR_CALSEC_Msk   (0x1UL << RTC_SECCFGR_CALSEC_Pos)
#define RTC_SECCFGR_CALSEC   RTC_SECCFGR_CALSEC_Msk
#define RTC_SECCFGR_INITSEC_Pos   (14U)
#define RTC_SECCFGR_INITSEC_Msk   (0x1UL << RTC_SECCFGR_INITSEC_Pos)
#define RTC_SECCFGR_INITSEC   RTC_SECCFGR_INITSEC_Msk
#define RTC_SECCFGR_SEC_Pos   (15U)
#define RTC_SECCFGR_SEC_Msk   (0x1UL << RTC_SECCFGR_SEC_Pos)
#define RTC_SECCFGR_SEC   RTC_SECCFGR_SEC_Msk
#define RTC_WPR_KEY_Pos   (0U)
#define RTC_WPR_KEY_Msk   (0xFFUL << RTC_WPR_KEY_Pos)
#define RTC_WPR_KEY   RTC_WPR_KEY_Msk
#define RTC_CALR_CALM_Pos   (0U)
#define RTC_CALR_CALM_Msk   (0x1FFUL << RTC_CALR_CALM_Pos)
#define RTC_CALR_CALM   RTC_CALR_CALM_Msk
#define RTC_CALR_CALM_0   (0x001UL << RTC_CALR_CALM_Pos)
#define RTC_CALR_CALM_1   (0x002UL << RTC_CALR_CALM_Pos)
#define RTC_CALR_CALM_2   (0x004UL << RTC_CALR_CALM_Pos)
#define RTC_CALR_CALM_3   (0x008UL << RTC_CALR_CALM_Pos)
#define RTC_CALR_CALM_4   (0x010UL << RTC_CALR_CALM_Pos)
#define RTC_CALR_CALM_5   (0x020UL << RTC_CALR_CALM_Pos)
#define RTC_CALR_CALM_6   (0x040UL << RTC_CALR_CALM_Pos)
#define RTC_CALR_CALM_7   (0x080UL << RTC_CALR_CALM_Pos)
#define RTC_CALR_CALM_8   (0x100UL << RTC_CALR_CALM_Pos)
#define RTC_CALR_LPCAL_Pos   (12U)
#define RTC_CALR_LPCAL_Msk   (0x1UL << RTC_CALR_LPCAL_Pos)
#define RTC_CALR_CALW16   RTC_CALR_CALW16_Msk
#define RTC_CALR_CALW16_Pos   (13U)
#define RTC_CALR_CALW16_Msk   (0x1UL << RTC_CALR_CALW16_Pos)
#define RTC_CALR_LPCAL   RTC_CALR_LPCAL_Msk
#define RTC_CALR_CALW8_Pos   (14U)
#define RTC_CALR_CALW8_Msk   (0x1UL << RTC_CALR_CALW8_Pos)
#define RTC_CALR_CALW8   RTC_CALR_CALW8_Msk
#define RTC_CALR_CALP_Pos   (15U)
#define RTC_CALR_CALP_Msk   (0x1UL << RTC_CALR_CALP_Pos)
#define RTC_CALR_CALP   RTC_CALR_CALP_Msk
#define RTC_SHIFTR_SUBFS_Pos   (0U)
#define RTC_SHIFTR_SUBFS_Msk   (0x7FFFUL << RTC_SHIFTR_SUBFS_Pos)
#define RTC_SHIFTR_SUBFS   RTC_SHIFTR_SUBFS_Msk
#define RTC_SHIFTR_ADD1S_Pos   (31U)
#define RTC_SHIFTR_ADD1S_Msk   (0x1UL << RTC_SHIFTR_ADD1S_Pos)
#define RTC_SHIFTR_ADD1S   RTC_SHIFTR_ADD1S_Msk
#define RTC_TSTR_SU_Pos   (0U)
#define RTC_TSTR_SU_Msk   (0xFUL << RTC_TSTR_SU_Pos)
#define RTC_TSTR_SU   RTC_TSTR_SU_Msk
#define RTC_TSTR_SU_0   (0x1UL << RTC_TSTR_SU_Pos)
#define RTC_TSTR_SU_1   (0x2UL << RTC_TSTR_SU_Pos)
#define RTC_TSTR_SU_2   (0x4UL << RTC_TSTR_SU_Pos)
#define RTC_TSTR_SU_3   (0x8UL << RTC_TSTR_SU_Pos)
#define RTC_TSTR_ST_Pos   (4U)
#define RTC_TSTR_ST_Msk   (0x7UL << RTC_TSTR_ST_Pos)
#define RTC_TSTR_ST   RTC_TSTR_ST_Msk
#define RTC_TSTR_ST_0   (0x1UL << RTC_TSTR_ST_Pos)
#define RTC_TSTR_ST_1   (0x2UL << RTC_TSTR_ST_Pos)
#define RTC_TSTR_ST_2   (0x4UL << RTC_TSTR_ST_Pos)
#define RTC_TSTR_MNU_Pos   (8U)
#define RTC_TSTR_MNU_Msk   (0xFUL << RTC_TSTR_MNU_Pos)
#define RTC_TSTR_MNU   RTC_TSTR_MNU_Msk
#define RTC_TSTR_MNU_0   (0x1UL << RTC_TSTR_MNU_Pos)
#define RTC_TSTR_MNU_1   (0x2UL << RTC_TSTR_MNU_Pos)
#define RTC_TSTR_MNU_2   (0x4UL << RTC_TSTR_MNU_Pos)
#define RTC_TSTR_MNU_3   (0x8UL << RTC_TSTR_MNU_Pos)
#define RTC_TSTR_MNT_Pos   (12U)
#define RTC_TSTR_MNT_Msk   (0x7UL << RTC_TSTR_MNT_Pos)
#define RTC_TSTR_MNT   RTC_TSTR_MNT_Msk
#define RTC_TSTR_MNT_0   (0x1UL << RTC_TSTR_MNT_Pos)
#define RTC_TSTR_MNT_1   (0x2UL << RTC_TSTR_MNT_Pos)
#define RTC_TSTR_MNT_2   (0x4UL << RTC_TSTR_MNT_Pos)
#define RTC_TSTR_HU_Pos   (16U)
#define RTC_TSTR_HU_Msk   (0xFUL << RTC_TSTR_HU_Pos)
#define RTC_TSTR_HU   RTC_TSTR_HU_Msk
#define RTC_TSTR_HU_0   (0x1UL << RTC_TSTR_HU_Pos)
#define RTC_TSTR_HU_1   (0x2UL << RTC_TSTR_HU_Pos)
#define RTC_TSTR_HU_2   (0x4UL << RTC_TSTR_HU_Pos)
#define RTC_TSTR_HU_3   (0x8UL << RTC_TSTR_HU_Pos)
#define RTC_TSTR_HT_Pos   (20U)
#define RTC_TSTR_HT_Msk   (0x3UL << RTC_TSTR_HT_Pos)
#define RTC_TSTR_HT   RTC_TSTR_HT_Msk
#define RTC_TSTR_HT_0   (0x1UL << RTC_TSTR_HT_Pos)
#define RTC_TSTR_HT_1   (0x2UL << RTC_TSTR_HT_Pos)
#define RTC_TSTR_PM_Pos   (22U)
#define RTC_TSTR_PM_Msk   (0x1UL << RTC_TSTR_PM_Pos)
#define RTC_TSTR_PM   RTC_TSTR_PM_Msk
#define RTC_TSDR_DU_Pos   (0U)
#define RTC_TSDR_DU_Msk   (0xFUL << RTC_TSDR_DU_Pos)
#define RTC_TSDR_DU   RTC_TSDR_DU_Msk
#define RTC_TSDR_DU_0   (0x1UL << RTC_TSDR_DU_Pos)
#define RTC_TSDR_DU_1   (0x2UL << RTC_TSDR_DU_Pos)
#define RTC_TSDR_DU_2   (0x4UL << RTC_TSDR_DU_Pos)
#define RTC_TSDR_DU_3   (0x8UL << RTC_TSDR_DU_Pos)
#define RTC_TSDR_DT_Pos   (4U)
#define RTC_TSDR_DT_Msk   (0x3UL << RTC_TSDR_DT_Pos)
#define RTC_TSDR_DT   RTC_TSDR_DT_Msk
#define RTC_TSDR_DT_0   (0x1UL << RTC_TSDR_DT_Pos)
#define RTC_TSDR_DT_1   (0x2UL << RTC_TSDR_DT_Pos)
#define RTC_TSDR_MU_Pos   (8U)
#define RTC_TSDR_MU_Msk   (0xFUL << RTC_TSDR_MU_Pos)
#define RTC_TSDR_MU   RTC_TSDR_MU_Msk
#define RTC_TSDR_MU_0   (0x1UL << RTC_TSDR_MU_Pos)
#define RTC_TSDR_MU_1   (0x2UL << RTC_TSDR_MU_Pos)
#define RTC_TSDR_MU_2   (0x4UL << RTC_TSDR_MU_Pos)
#define RTC_TSDR_MU_3   (0x8UL << RTC_TSDR_MU_Pos)
#define RTC_TSDR_MT_Pos   (12U)
#define RTC_TSDR_MT_Msk   (0x1UL << RTC_TSDR_MT_Pos)
#define RTC_TSDR_MT   RTC_TSDR_MT_Msk
#define RTC_TSDR_WDU_Pos   (13U)
#define RTC_TSDR_WDU_Msk   (0x7UL << RTC_TSDR_WDU_Pos)
#define RTC_TSDR_WDU   RTC_TSDR_WDU_Msk
#define RTC_TSDR_WDU_0   (0x1UL << RTC_TSDR_WDU_Pos)
#define RTC_TSDR_WDU_1   (0x2UL << RTC_TSDR_WDU_Pos)
#define RTC_TSDR_WDU_2   (0x4UL << RTC_TSDR_WDU_Pos)
#define RTC_TSSSR_SS_Pos   (0U)
#define RTC_TSSSR_SS_Msk   (0xFFFFFFFFUL << RTC_TSSSR_SS_Pos)
#define RTC_TSSSR_SS   RTC_TSSSR_SS_Msk
#define RTC_ALRMAR_SU_Pos   (0U)
#define RTC_ALRMAR_SU_Msk   (0xFUL << RTC_ALRMAR_SU_Pos)
#define RTC_ALRMAR_SU   RTC_ALRMAR_SU_Msk
#define RTC_ALRMAR_SU_0   (0x1UL << RTC_ALRMAR_SU_Pos)
#define RTC_ALRMAR_SU_1   (0x2UL << RTC_ALRMAR_SU_Pos)
#define RTC_ALRMAR_SU_2   (0x4UL << RTC_ALRMAR_SU_Pos)
#define RTC_ALRMAR_SU_3   (0x8UL << RTC_ALRMAR_SU_Pos)
#define RTC_ALRMAR_ST_Pos   (4U)
#define RTC_ALRMAR_ST_Msk   (0x7UL << RTC_ALRMAR_ST_Pos)
#define RTC_ALRMAR_ST   RTC_ALRMAR_ST_Msk
#define RTC_ALRMAR_ST_0   (0x1UL << RTC_ALRMAR_ST_Pos)
#define RTC_ALRMAR_ST_1   (0x2UL << RTC_ALRMAR_ST_Pos)
#define RTC_ALRMAR_ST_2   (0x4UL << RTC_ALRMAR_ST_Pos)
#define RTC_ALRMAR_MSK1_Pos   (7U)
#define RTC_ALRMAR_MSK1_Msk   (0x1UL << RTC_ALRMAR_MSK1_Pos)
#define RTC_ALRMAR_MSK1   RTC_ALRMAR_MSK1_Msk
#define RTC_ALRMAR_MNU_Pos   (8U)
#define RTC_ALRMAR_MNU_Msk   (0xFUL << RTC_ALRMAR_MNU_Pos)
#define RTC_ALRMAR_MNU   RTC_ALRMAR_MNU_Msk
#define RTC_ALRMAR_MNU_0   (0x1UL << RTC_ALRMAR_MNU_Pos)
#define RTC_ALRMAR_MNU_1   (0x2UL << RTC_ALRMAR_MNU_Pos)
#define RTC_ALRMAR_MNU_2   (0x4UL << RTC_ALRMAR_MNU_Pos)
#define RTC_ALRMAR_MNU_3   (0x8UL << RTC_ALRMAR_MNU_Pos)
#define RTC_ALRMAR_MNT_Pos   (12U)
#define RTC_ALRMAR_MNT_Msk   (0x7UL << RTC_ALRMAR_MNT_Pos)
#define RTC_ALRMAR_MNT   RTC_ALRMAR_MNT_Msk
#define RTC_ALRMAR_MNT_0   (0x1UL << RTC_ALRMAR_MNT_Pos)
#define RTC_ALRMAR_MNT_1   (0x2UL << RTC_ALRMAR_MNT_Pos)
#define RTC_ALRMAR_MNT_2   (0x4UL << RTC_ALRMAR_MNT_Pos)
#define RTC_ALRMAR_MSK2_Pos   (15U)
#define RTC_ALRMAR_MSK2_Msk   (0x1UL << RTC_ALRMAR_MSK2_Pos)
#define RTC_ALRMAR_MSK2   RTC_ALRMAR_MSK2_Msk
#define RTC_ALRMAR_HU_Pos   (16U)
#define RTC_ALRMAR_HU_Msk   (0xFUL << RTC_ALRMAR_HU_Pos)
#define RTC_ALRMAR_HU   RTC_ALRMAR_HU_Msk
#define RTC_ALRMAR_HU_0   (0x1UL << RTC_ALRMAR_HU_Pos)
#define RTC_ALRMAR_HU_1   (0x2UL << RTC_ALRMAR_HU_Pos)
#define RTC_ALRMAR_HU_2   (0x4UL << RTC_ALRMAR_HU_Pos)
#define RTC_ALRMAR_HU_3   (0x8UL << RTC_ALRMAR_HU_Pos)
#define RTC_ALRMAR_HT_Pos   (20U)
#define RTC_ALRMAR_HT_Msk   (0x3UL << RTC_ALRMAR_HT_Pos)
#define RTC_ALRMAR_HT   RTC_ALRMAR_HT_Msk
#define RTC_ALRMAR_HT_0   (0x1UL << RTC_ALRMAR_HT_Pos)
#define RTC_ALRMAR_HT_1   (0x2UL << RTC_ALRMAR_HT_Pos)
#define RTC_ALRMAR_PM_Pos   (22U)
#define RTC_ALRMAR_PM_Msk   (0x1UL << RTC_ALRMAR_PM_Pos)
#define RTC_ALRMAR_PM   RTC_ALRMAR_PM_Msk
#define RTC_ALRMAR_MSK3_Pos   (23U)
#define RTC_ALRMAR_MSK3_Msk   (0x1UL << RTC_ALRMAR_MSK3_Pos)
#define RTC_ALRMAR_MSK3   RTC_ALRMAR_MSK3_Msk
#define RTC_ALRMAR_DU_Pos   (24U)
#define RTC_ALRMAR_DU_Msk   (0xFUL << RTC_ALRMAR_DU_Pos)
#define RTC_ALRMAR_DU   RTC_ALRMAR_DU_Msk
#define RTC_ALRMAR_DU_0   (0x1UL << RTC_ALRMAR_DU_Pos)
#define RTC_ALRMAR_DU_1   (0x2UL << RTC_ALRMAR_DU_Pos)
#define RTC_ALRMAR_DU_2   (0x4UL << RTC_ALRMAR_DU_Pos)
#define RTC_ALRMAR_DU_3   (0x8UL << RTC_ALRMAR_DU_Pos)
#define RTC_ALRMAR_DT_Pos   (28U)
#define RTC_ALRMAR_DT_Msk   (0x3UL << RTC_ALRMAR_DT_Pos)
#define RTC_ALRMAR_DT   RTC_ALRMAR_DT_Msk
#define RTC_ALRMAR_DT_0   (0x1UL << RTC_ALRMAR_DT_Pos)
#define RTC_ALRMAR_DT_1   (0x2UL << RTC_ALRMAR_DT_Pos)
#define RTC_ALRMAR_WDSEL_Pos   (30U)
#define RTC_ALRMAR_WDSEL_Msk   (0x1UL << RTC_ALRMAR_WDSEL_Pos)
#define RTC_ALRMAR_WDSEL   RTC_ALRMAR_WDSEL_Msk
#define RTC_ALRMAR_MSK4_Pos   (31U)
#define RTC_ALRMAR_MSK4_Msk   (0x1UL << RTC_ALRMAR_MSK4_Pos)
#define RTC_ALRMAR_MSK4   RTC_ALRMAR_MSK4_Msk
#define RTC_ALRMASSR_SS_Pos   (0U)
#define RTC_ALRMASSR_SS_Msk   (0x7FFFUL << RTC_ALRMASSR_SS_Pos)
#define RTC_ALRMASSR_SS   RTC_ALRMASSR_SS_Msk
#define RTC_ALRMASSR_MASKSS_Pos   (24U)
#define RTC_ALRMASSR_MASKSS_Msk   (0xFUL << RTC_ALRMASSR_MASKSS_Pos)
#define RTC_ALRMASSR_MASKSS   RTC_ALRMASSR_MASKSS_Msk
#define RTC_ALRMASSR_MASKSS_0   (0x1UL << RTC_ALRMASSR_MASKSS_Pos)
#define RTC_ALRMASSR_MASKSS_1   (0x2UL << RTC_ALRMASSR_MASKSS_Pos)
#define RTC_ALRMASSR_MASKSS_2   (0x4UL << RTC_ALRMASSR_MASKSS_Pos)
#define RTC_ALRMASSR_MASKSS_3   (0x8UL << RTC_ALRMASSR_MASKSS_Pos)
#define RTC_ALRMASSR_SSCLR_Pos   (31U)
#define RTC_ALRMASSR_SSCLR_Msk   (0x1UL << RTC_ALRMASSR_SSCLR_Pos)
#define RTC_ALRMASSR_SSCLR   RTC_ALRMASSR_SSCLR_Msk
#define RTC_ALRMBR_SU_Pos   (0U)
#define RTC_ALRMBR_SU_Msk   (0xFUL << RTC_ALRMBR_SU_Pos)
#define RTC_ALRMBR_SU   RTC_ALRMBR_SU_Msk
#define RTC_ALRMBR_SU_0   (0x1UL << RTC_ALRMBR_SU_Pos)
#define RTC_ALRMBR_SU_1   (0x2UL << RTC_ALRMBR_SU_Pos)
#define RTC_ALRMBR_SU_2   (0x4UL << RTC_ALRMBR_SU_Pos)
#define RTC_ALRMBR_SU_3   (0x8UL << RTC_ALRMBR_SU_Pos)
#define RTC_ALRMBR_ST_Pos   (4U)
#define RTC_ALRMBR_ST_Msk   (0x7UL << RTC_ALRMBR_ST_Pos)
#define RTC_ALRMBR_ST   RTC_ALRMBR_ST_Msk
#define RTC_ALRMBR_ST_0   (0x1UL << RTC_ALRMBR_ST_Pos)
#define RTC_ALRMBR_ST_1   (0x2UL << RTC_ALRMBR_ST_Pos)
#define RTC_ALRMBR_ST_2   (0x4UL << RTC_ALRMBR_ST_Pos)
#define RTC_ALRMBR_MSK1_Pos   (7U)
#define RTC_ALRMBR_MSK1_Msk   (0x1UL << RTC_ALRMBR_MSK1_Pos)
#define RTC_ALRMBR_MSK1   RTC_ALRMBR_MSK1_Msk
#define RTC_ALRMBR_MNU_Pos   (8U)
#define RTC_ALRMBR_MNU_Msk   (0xFUL << RTC_ALRMBR_MNU_Pos)
#define RTC_ALRMBR_MNU   RTC_ALRMBR_MNU_Msk
#define RTC_ALRMBR_MNU_0   (0x1UL << RTC_ALRMBR_MNU_Pos)
#define RTC_ALRMBR_MNU_1   (0x2UL << RTC_ALRMBR_MNU_Pos)
#define RTC_ALRMBR_MNU_2   (0x4UL << RTC_ALRMBR_MNU_Pos)
#define RTC_ALRMBR_MNU_3   (0x8UL << RTC_ALRMBR_MNU_Pos)
#define RTC_ALRMBR_MNT_Pos   (12U)
#define RTC_ALRMBR_MNT_Msk   (0x7UL << RTC_ALRMBR_MNT_Pos)
#define RTC_ALRMBR_MNT   RTC_ALRMBR_MNT_Msk
#define RTC_ALRMBR_MNT_0   (0x1UL << RTC_ALRMBR_MNT_Pos)
#define RTC_ALRMBR_MNT_1   (0x2UL << RTC_ALRMBR_MNT_Pos)
#define RTC_ALRMBR_MNT_2   (0x4UL << RTC_ALRMBR_MNT_Pos)
#define RTC_ALRMBR_MSK2_Pos   (15U)
#define RTC_ALRMBR_MSK2_Msk   (0x1UL << RTC_ALRMBR_MSK2_Pos)
#define RTC_ALRMBR_MSK2   RTC_ALRMBR_MSK2_Msk
#define RTC_ALRMBR_HU_Pos   (16U)
#define RTC_ALRMBR_HU_Msk   (0xFUL << RTC_ALRMBR_HU_Pos)
#define RTC_ALRMBR_HU   RTC_ALRMBR_HU_Msk
#define RTC_ALRMBR_HU_0   (0x1UL << RTC_ALRMBR_HU_Pos)
#define RTC_ALRMBR_HU_1   (0x2UL << RTC_ALRMBR_HU_Pos)
#define RTC_ALRMBR_HU_2   (0x4UL << RTC_ALRMBR_HU_Pos)
#define RTC_ALRMBR_HU_3   (0x8UL << RTC_ALRMBR_HU_Pos)
#define RTC_ALRMBR_HT_Pos   (20U)
#define RTC_ALRMBR_HT_Msk   (0x3UL << RTC_ALRMBR_HT_Pos)
#define RTC_ALRMBR_HT   RTC_ALRMBR_HT_Msk
#define RTC_ALRMBR_HT_0   (0x1UL << RTC_ALRMBR_HT_Pos)
#define RTC_ALRMBR_HT_1   (0x2UL << RTC_ALRMBR_HT_Pos)
#define RTC_ALRMBR_PM_Pos   (22U)
#define RTC_ALRMBR_PM_Msk   (0x1UL << RTC_ALRMBR_PM_Pos)
#define RTC_ALRMBR_PM   RTC_ALRMBR_PM_Msk
#define RTC_ALRMBR_MSK3_Pos   (23U)
#define RTC_ALRMBR_MSK3_Msk   (0x1UL << RTC_ALRMBR_MSK3_Pos)
#define RTC_ALRMBR_MSK3   RTC_ALRMBR_MSK3_Msk
#define RTC_ALRMBR_DU_Pos   (24U)
#define RTC_ALRMBR_DU_Msk   (0xFUL << RTC_ALRMBR_DU_Pos)
#define RTC_ALRMBR_DU   RTC_ALRMBR_DU_Msk
#define RTC_ALRMBR_DU_0   (0x1UL << RTC_ALRMBR_DU_Pos)
#define RTC_ALRMBR_DU_1   (0x2UL << RTC_ALRMBR_DU_Pos)
#define RTC_ALRMBR_DU_2   (0x4UL << RTC_ALRMBR_DU_Pos)
#define RTC_ALRMBR_DU_3   (0x8UL << RTC_ALRMBR_DU_Pos)
#define RTC_ALRMBR_DT_Pos   (28U)
#define RTC_ALRMBR_DT_Msk   (0x3UL << RTC_ALRMBR_DT_Pos)
#define RTC_ALRMBR_DT   RTC_ALRMBR_DT_Msk
#define RTC_ALRMBR_DT_0   (0x1UL << RTC_ALRMBR_DT_Pos)
#define RTC_ALRMBR_DT_1   (0x2UL << RTC_ALRMBR_DT_Pos)
#define RTC_ALRMBR_WDSEL_Pos   (30U)
#define RTC_ALRMBR_WDSEL_Msk   (0x1UL << RTC_ALRMBR_WDSEL_Pos)
#define RTC_ALRMBR_WDSEL   RTC_ALRMBR_WDSEL_Msk
#define RTC_ALRMBR_MSK4_Pos   (31U)
#define RTC_ALRMBR_MSK4_Msk   (0x1UL << RTC_ALRMBR_MSK4_Pos)
#define RTC_ALRMBR_MSK4   RTC_ALRMBR_MSK4_Msk
#define RTC_ALRMBSSR_SS_Pos   (0U)
#define RTC_ALRMBSSR_SS_Msk   (0x7FFFUL << RTC_ALRMBSSR_SS_Pos)
#define RTC_ALRMBSSR_SS   RTC_ALRMBSSR_SS_Msk
#define RTC_ALRMBSSR_MASKSS_Pos   (24U)
#define RTC_ALRMBSSR_MASKSS_Msk   (0xFUL << RTC_ALRMBSSR_MASKSS_Pos)
#define RTC_ALRMBSSR_MASKSS   RTC_ALRMBSSR_MASKSS_Msk
#define RTC_ALRMBSSR_MASKSS_0   (0x1UL << RTC_ALRMBSSR_MASKSS_Pos)
#define RTC_ALRMBSSR_MASKSS_1   (0x2UL << RTC_ALRMBSSR_MASKSS_Pos)
#define RTC_ALRMBSSR_MASKSS_2   (0x4UL << RTC_ALRMBSSR_MASKSS_Pos)
#define RTC_ALRMBSSR_MASKSS_3   (0x8UL << RTC_ALRMBSSR_MASKSS_Pos)
#define RTC_ALRMBSSR_SSCLR_Pos   (31U)
#define RTC_ALRMBSSR_SSCLR_Msk   (0x1UL << RTC_ALRMBSSR_SSCLR_Pos)
#define RTC_ALRMBSSR_SSCLR   RTC_ALRMBSSR_SSCLR_Msk
#define RTC_SR_ALRAF_Pos   (0U)
#define RTC_SR_ALRAF_Msk   (0x1UL << RTC_SR_ALRAF_Pos)
#define RTC_SR_ALRAF   RTC_SR_ALRAF_Msk
#define RTC_SR_ALRBF_Pos   (1U)
#define RTC_SR_ALRBF_Msk   (0x1UL << RTC_SR_ALRBF_Pos)
#define RTC_SR_ALRBF   RTC_SR_ALRBF_Msk
#define RTC_SR_WUTF_Pos   (2U)
#define RTC_SR_WUTF_Msk   (0x1UL << RTC_SR_WUTF_Pos)
#define RTC_SR_WUTF   RTC_SR_WUTF_Msk
#define RTC_SR_TSF_Pos   (3U)
#define RTC_SR_TSF_Msk   (0x1UL << RTC_SR_TSF_Pos)
#define RTC_SR_TSF   RTC_SR_TSF_Msk
#define RTC_SR_TSOVF_Pos   (4U)
#define RTC_SR_TSOVF_Msk   (0x1UL << RTC_SR_TSOVF_Pos)
#define RTC_SR_TSOVF   RTC_SR_TSOVF_Msk
#define RTC_SR_ITSF_Pos   (5U)
#define RTC_SR_ITSF_Msk   (0x1UL << RTC_SR_ITSF_Pos)
#define RTC_SR_ITSF   RTC_SR_ITSF_Msk
#define RTC_SR_SSRUF_Pos   (6U)
#define RTC_SR_SSRUF_Msk   (0x1UL << RTC_SR_SSRUF_Pos)
#define RTC_SR_SSRUF   RTC_SR_SSRUF_Msk
#define RTC_MISR_ALRAMF_Pos   (0U)
#define RTC_MISR_ALRAMF_Msk   (0x1UL << RTC_MISR_ALRAMF_Pos)
#define RTC_MISR_ALRAMF   RTC_MISR_ALRAMF_Msk
#define RTC_MISR_ALRBMF_Pos   (1U)
#define RTC_MISR_ALRBMF_Msk   (0x1UL << RTC_MISR_ALRBMF_Pos)
#define RTC_MISR_ALRBMF   RTC_MISR_ALRBMF_Msk
#define RTC_MISR_WUTMF_Pos   (2U)
#define RTC_MISR_WUTMF_Msk   (0x1UL << RTC_MISR_WUTMF_Pos)
#define RTC_MISR_WUTMF   RTC_MISR_WUTMF_Msk
#define RTC_MISR_TSMF_Pos   (3U)
#define RTC_MISR_TSMF_Msk   (0x1UL << RTC_MISR_TSMF_Pos)
#define RTC_MISR_TSMF   RTC_MISR_TSMF_Msk
#define RTC_MISR_TSOVMF_Pos   (4U)
#define RTC_MISR_TSOVMF_Msk   (0x1UL << RTC_MISR_TSOVMF_Pos)
#define RTC_MISR_TSOVMF   RTC_MISR_TSOVMF_Msk
#define RTC_MISR_ITSMF_Pos   (5U)
#define RTC_MISR_ITSMF_Msk   (0x1UL << RTC_MISR_ITSMF_Pos)
#define RTC_MISR_ITSMF   RTC_MISR_ITSMF_Msk
#define RTC_MISR_SSRUMF_Pos   (6U)
#define RTC_MISR_SSRUMF_Msk   (0x1UL << RTC_MISR_SSRUMF_Pos)
#define RTC_MISR_SSRUMF   RTC_MISR_SSRUMF_Msk
#define RTC_SMISR_ALRAMF_Pos   (0U)
#define RTC_SMISR_ALRAMF_Msk   (0x1UL << RTC_SMISR_ALRAMF_Pos)
#define RTC_SMISR_ALRAMF   RTC_SMISR_ALRAMF_Msk
#define RTC_SMISR_ALRBMF_Pos   (1U)
#define RTC_SMISR_ALRBMF_Msk   (0x1UL << RTC_SMISR_ALRBMF_Pos)
#define RTC_SMISR_ALRBMF   RTC_SMISR_ALRBMF_Msk
#define RTC_SMISR_WUTMF_Pos   (2U)
#define RTC_SMISR_WUTMF_Msk   (0x1UL << RTC_SMISR_WUTMF_Pos)
#define RTC_SMISR_WUTMF   RTC_SMISR_WUTMF_Msk
#define RTC_SMISR_TSMF_Pos   (3U)
#define RTC_SMISR_TSMF_Msk   (0x1UL << RTC_SMISR_TSMF_Pos)
#define RTC_SMISR_TSMF   RTC_SMISR_TSMF_Msk
#define RTC_SMISR_TSOVMF_Pos   (4U)
#define RTC_SMISR_TSOVMF_Msk   (0x1UL << RTC_SMISR_TSOVMF_Pos)
#define RTC_SMISR_TSOVMF   RTC_SMISR_TSOVMF_Msk
#define RTC_SMISR_ITSMF_Pos   (5U)
#define RTC_SMISR_ITSMF_Msk   (0x1UL << RTC_SMISR_ITSMF_Pos)
#define RTC_SMISR_ITSMF   RTC_SMISR_ITSMF_Msk
#define RTC_SMISR_SSRUMF_Pos   (6U)
#define RTC_SMISR_SSRUMF_Msk   (0x1UL << RTC_SMISR_SSRUMF_Pos)
#define RTC_SMISR_SSRUMF   RTC_SMISR_SSRUMF_Msk
#define RTC_SCR_CALRAF_Pos   (0U)
#define RTC_SCR_CALRAF_Msk   (0x1UL << RTC_SCR_CALRAF_Pos)
#define RTC_SCR_CALRAF   RTC_SCR_CALRAF_Msk
#define RTC_SCR_CALRBF_Pos   (1U)
#define RTC_SCR_CALRBF_Msk   (0x1UL << RTC_SCR_CALRBF_Pos)
#define RTC_SCR_CALRBF   RTC_SCR_CALRBF_Msk
#define RTC_SCR_CWUTF_Pos   (2U)
#define RTC_SCR_CWUTF_Msk   (0x1UL << RTC_SCR_CWUTF_Pos)
#define RTC_SCR_CWUTF   RTC_SCR_CWUTF_Msk
#define RTC_SCR_CTSF_Pos   (3U)
#define RTC_SCR_CTSF_Msk   (0x1UL << RTC_SCR_CTSF_Pos)
#define RTC_SCR_CTSF   RTC_SCR_CTSF_Msk
#define RTC_SCR_CTSOVF_Pos   (4U)
#define RTC_SCR_CTSOVF_Msk   (0x1UL << RTC_SCR_CTSOVF_Pos)
#define RTC_SCR_CTSOVF   RTC_SCR_CTSOVF_Msk
#define RTC_SCR_CITSF_Pos   (5U)
#define RTC_SCR_CITSF_Msk   (0x1UL << RTC_SCR_CITSF_Pos)
#define RTC_SCR_CITSF   RTC_SCR_CITSF_Msk
#define RTC_SCR_CSSRUF_Pos   (6U)
#define RTC_SCR_CSSRUF_Msk   (0x1UL << RTC_SCR_CSSRUF_Pos)
#define RTC_SCR_CSSRUF   RTC_SCR_CSSRUF_Msk
#define RTC_ALRABINR_SS_Pos   (0U)
#define RTC_ALRABINR_SS_Msk   (0xFFFFFFFFUL << RTC_ALRABINR_SS_Pos)
#define RTC_ALRABINR_SS   RTC_ALRABINR_SS_Msk
#define RTC_ALRBBINR_SS_Pos   (0U)
#define RTC_ALRBBINR_SS_Msk   (0xFFFFFFFFUL << RTC_ALRBBINR_SS_Pos)
#define RTC_ALRBBINR_SS   RTC_ALRBBINR_SS_Msk
#define TAMP_CR1_TAMP1E_Pos   (0U)
#define TAMP_CR1_TAMP1E_Msk   (0x1UL << TAMP_CR1_TAMP1E_Pos)
#define TAMP_CR1_TAMP1E   TAMP_CR1_TAMP1E_Msk
#define TAMP_CR1_TAMP2E_Pos   (1U)
#define TAMP_CR1_TAMP2E_Msk   (0x1UL << TAMP_CR1_TAMP2E_Pos)
#define TAMP_CR1_TAMP2E   TAMP_CR1_TAMP2E_Msk
#define TAMP_CR1_TAMP3E_Pos   (2U)
#define TAMP_CR1_TAMP3E_Msk   (0x1UL << TAMP_CR1_TAMP3E_Pos)
#define TAMP_CR1_TAMP3E   TAMP_CR1_TAMP3E_Msk
#define TAMP_CR1_TAMP4E_Pos   (3U)
#define TAMP_CR1_TAMP4E_Msk   (0x1UL << TAMP_CR1_TAMP4E_Pos)
#define TAMP_CR1_TAMP4E   TAMP_CR1_TAMP4E_Msk
#define TAMP_CR1_TAMP5E_Pos   (4U)
#define TAMP_CR1_TAMP5E_Msk   (0x1UL << TAMP_CR1_TAMP5E_Pos)
#define TAMP_CR1_TAMP5E   TAMP_CR1_TAMP5E_Msk
#define TAMP_CR1_TAMP6E_Pos   (5U)
#define TAMP_CR1_TAMP6E_Msk   (0x1UL << TAMP_CR1_TAMP6E_Pos)
#define TAMP_CR1_TAMP6E   TAMP_CR1_TAMP6E_Msk
#define TAMP_CR1_TAMP7E_Pos   (6U)
#define TAMP_CR1_TAMP7E_Msk   (0x1UL << TAMP_CR1_TAMP7E_Pos)
#define TAMP_CR1_TAMP7E   TAMP_CR1_TAMP7E_Msk
#define TAMP_CR1_TAMP8E_Pos   (7U)
#define TAMP_CR1_TAMP8E_Msk   (0x1UL << TAMP_CR1_TAMP8E_Pos)
#define TAMP_CR1_TAMP8E   TAMP_CR1_TAMP8E_Msk
#define TAMP_CR1_ITAMP1E_Pos   (16U)
#define TAMP_CR1_ITAMP1E_Msk   (0x1UL << TAMP_CR1_ITAMP1E_Pos)
#define TAMP_CR1_ITAMP1E   TAMP_CR1_ITAMP1E_Msk
#define TAMP_CR1_ITAMP2E_Pos   (17U)
#define TAMP_CR1_ITAMP2E_Msk   (0x1UL << TAMP_CR1_ITAMP2E_Pos)
#define TAMP_CR1_ITAMP2E   TAMP_CR1_ITAMP2E_Msk
#define TAMP_CR1_ITAMP3E_Pos   (18U)
#define TAMP_CR1_ITAMP3E_Msk   (0x1UL << TAMP_CR1_ITAMP3E_Pos)
#define TAMP_CR1_ITAMP3E   TAMP_CR1_ITAMP3E_Msk
#define TAMP_CR1_ITAMP5E_Pos   (20U)
#define TAMP_CR1_ITAMP5E_Msk   (0x1UL << TAMP_CR1_ITAMP5E_Pos)
#define TAMP_CR1_ITAMP5E   TAMP_CR1_ITAMP5E_Msk
#define TAMP_CR1_ITAMP6E_Pos   (21U)
#define TAMP_CR1_ITAMP6E_Msk   (0x1UL << TAMP_CR1_ITAMP6E_Pos)
#define TAMP_CR1_ITAMP6E   TAMP_CR1_ITAMP6E_Msk
#define TAMP_CR1_ITAMP7E_Pos   (22U)
#define TAMP_CR1_ITAMP7E_Msk   (0x1UL << TAMP_CR1_ITAMP7E_Pos)
#define TAMP_CR1_ITAMP7E   TAMP_CR1_ITAMP7E_Msk
#define TAMP_CR1_ITAMP8E_Pos   (23U)
#define TAMP_CR1_ITAMP8E_Msk   (0x1UL << TAMP_CR1_ITAMP8E_Pos)
#define TAMP_CR1_ITAMP8E   TAMP_CR1_ITAMP8E_Msk
#define TAMP_CR1_ITAMP9E_Pos   (24U)
#define TAMP_CR1_ITAMP9E_Msk   (0x1UL << TAMP_CR1_ITAMP9E_Pos)
#define TAMP_CR1_ITAMP9E   TAMP_CR1_ITAMP9E_Msk
#define TAMP_CR1_ITAMP11E_Pos   (26U)
#define TAMP_CR1_ITAMP11E_Msk   (0x1UL << TAMP_CR1_ITAMP11E_Pos)
#define TAMP_CR1_ITAMP11E   TAMP_CR1_ITAMP11E_Msk
#define TAMP_CR1_ITAMP12E_Pos   (27U)
#define TAMP_CR1_ITAMP12E_Msk   (0x1UL << TAMP_CR1_ITAMP12E_Pos)
#define TAMP_CR1_ITAMP12E   TAMP_CR1_ITAMP12E_Msk
#define TAMP_CR1_ITAMP13E_Pos   (28U)
#define TAMP_CR1_ITAMP13E_Msk   (0x1UL << TAMP_CR1_ITAMP13E_Pos)
#define TAMP_CR1_ITAMP13E   TAMP_CR1_ITAMP13E_Msk
#define TAMP_CR2_TAMP1NOERASE_Pos   (0U)
#define TAMP_CR2_TAMP1NOERASE_Msk   (0x1UL << TAMP_CR2_TAMP1NOERASE_Pos)
#define TAMP_CR2_TAMP1NOERASE   TAMP_CR2_TAMP1NOERASE_Msk
#define TAMP_CR2_TAMP2NOERASE_Pos   (1U)
#define TAMP_CR2_TAMP2NOERASE_Msk   (0x1UL << TAMP_CR2_TAMP2NOERASE_Pos)
#define TAMP_CR2_TAMP2NOERASE   TAMP_CR2_TAMP2NOERASE_Msk
#define TAMP_CR2_TAMP3NOERASE_Pos   (2U)
#define TAMP_CR2_TAMP3NOERASE_Msk   (0x1UL << TAMP_CR2_TAMP3NOERASE_Pos)
#define TAMP_CR2_TAMP3NOERASE   TAMP_CR2_TAMP3NOERASE_Msk
#define TAMP_CR2_TAMP4NOERASE_Pos   (3U)
#define TAMP_CR2_TAMP4NOERASE_Msk   (0x1UL << TAMP_CR2_TAMP4NOERASE_Pos)
#define TAMP_CR2_TAMP4NOERASE   TAMP_CR2_TAMP4NOERASE_Msk
#define TAMP_CR2_TAMP5NOERASE_Pos   (4U)
#define TAMP_CR2_TAMP5NOERASE_Msk   (0x1UL << TAMP_CR2_TAMP5NOERASE_Pos)
#define TAMP_CR2_TAMP5NOERASE   TAMP_CR2_TAMP5NOERASE_Msk
#define TAMP_CR2_TAMP6NOERASE_Pos   (5U)
#define TAMP_CR2_TAMP6NOERASE_Msk   (0x1UL << TAMP_CR2_TAMP6NOERASE_Pos)
#define TAMP_CR2_TAMP6NOERASE   TAMP_CR2_TAMP6NOERASE_Msk
#define TAMP_CR2_TAMP7NOERASE_Pos   (6U)
#define TAMP_CR2_TAMP7NOERASE_Msk   (0x1UL << TAMP_CR2_TAMP7NOERASE_Pos)
#define TAMP_CR2_TAMP7NOERASE   TAMP_CR2_TAMP7NOERASE_Msk
#define TAMP_CR2_TAMP8NOERASE_Pos   (7U)
#define TAMP_CR2_TAMP8NOERASE_Msk   (0x1UL << TAMP_CR2_TAMP8NOERASE_Pos)
#define TAMP_CR2_TAMP8NOERASE   TAMP_CR2_TAMP8NOERASE_Msk
#define TAMP_CR2_TAMP1MSK_Pos   (16U)
#define TAMP_CR2_TAMP1MSK_Msk   (0x1UL << TAMP_CR2_TAMP1MSK_Pos)
#define TAMP_CR2_TAMP1MSK   TAMP_CR2_TAMP1MSK_Msk
#define TAMP_CR2_TAMP2MSK_Pos   (17U)
#define TAMP_CR2_TAMP2MSK_Msk   (0x1UL << TAMP_CR2_TAMP2MSK_Pos)
#define TAMP_CR2_TAMP2MSK   TAMP_CR2_TAMP2MSK_Msk
#define TAMP_CR2_TAMP3MSK_Pos   (18U)
#define TAMP_CR2_TAMP3MSK_Msk   (0x1UL << TAMP_CR2_TAMP3MSK_Pos)
#define TAMP_CR2_TAMP3MSK   TAMP_CR2_TAMP3MSK_Msk
#define TAMP_CR2_BKBLOCK_Pos   (22U)
#define TAMP_CR2_BKBLOCK_Msk   (0x1UL << TAMP_CR2_BKBLOCK_Pos)
#define TAMP_CR2_BKBLOCK   TAMP_CR2_BKBLOCK_Msk
#define TAMP_CR2_BKERASE_Pos   (23U)
#define TAMP_CR2_BKERASE_Msk   (0x1UL << TAMP_CR2_BKERASE_Pos)
#define TAMP_CR2_BKERASE   TAMP_CR2_BKERASE_Msk
#define TAMP_CR2_TAMP1TRG_Pos   (24U)
#define TAMP_CR2_TAMP1TRG_Msk   (0x1UL << TAMP_CR2_TAMP1TRG_Pos)
#define TAMP_CR2_TAMP1TRG   TAMP_CR2_TAMP1TRG_Msk
#define TAMP_CR2_TAMP2TRG_Pos   (25U)
#define TAMP_CR2_TAMP2TRG_Msk   (0x1UL << TAMP_CR2_TAMP2TRG_Pos)
#define TAMP_CR2_TAMP2TRG   TAMP_CR2_TAMP2TRG_Msk
#define TAMP_CR2_TAMP3TRG_Pos   (26U)
#define TAMP_CR2_TAMP3TRG_Msk   (0x1UL << TAMP_CR2_TAMP3TRG_Pos)
#define TAMP_CR2_TAMP3TRG   TAMP_CR2_TAMP3TRG_Msk
#define TAMP_CR2_TAMP4TRG_Pos   (27U)
#define TAMP_CR2_TAMP4TRG_Msk   (0x1UL << TAMP_CR2_TAMP4TRG_Pos)
#define TAMP_CR2_TAMP4TRG   TAMP_CR2_TAMP4TRG_Msk
#define TAMP_CR2_TAMP5TRG_Pos   (28U)
#define TAMP_CR2_TAMP5TRG_Msk   (0x1UL << TAMP_CR2_TAMP5TRG_Pos)
#define TAMP_CR2_TAMP5TRG   TAMP_CR2_TAMP5TRG_Msk
#define TAMP_CR2_TAMP6TRG_Pos   (29U)
#define TAMP_CR2_TAMP6TRG_Msk   (0x1UL << TAMP_CR2_TAMP6TRG_Pos)
#define TAMP_CR2_TAMP6TRG   TAMP_CR2_TAMP6TRG_Msk
#define TAMP_CR2_TAMP7TRG_Pos   (30U)
#define TAMP_CR2_TAMP7TRG_Msk   (0x1UL << TAMP_CR2_TAMP7TRG_Pos)
#define TAMP_CR2_TAMP7TRG   TAMP_CR2_TAMP7TRG_Msk
#define TAMP_CR2_TAMP8TRG_Pos   (31U)
#define TAMP_CR2_TAMP8TRG_Msk   (0x1UL << TAMP_CR2_TAMP8TRG_Pos)
#define TAMP_CR2_TAMP8TRG   TAMP_CR2_TAMP8TRG_Msk
#define TAMP_CR3_ITAMP1NOER_Pos   (0U)
#define TAMP_CR3_ITAMP1NOER_Msk   (0x1UL << TAMP_CR3_ITAMP1NOER_Pos)
#define TAMP_CR3_ITAMP1NOER   TAMP_CR3_ITAMP1NOER_Msk
#define TAMP_CR3_ITAMP2NOER_Pos   (1U)
#define TAMP_CR3_ITAMP2NOER_Msk   (0x1UL << TAMP_CR3_ITAMP2NOER_Pos)
#define TAMP_CR3_ITAMP2NOER   TAMP_CR3_ITAMP2NOER_Msk
#define TAMP_CR3_ITAMP3NOER_Pos   (2U)
#define TAMP_CR3_ITAMP3NOER_Msk   (0x1UL << TAMP_CR3_ITAMP3NOER_Pos)
#define TAMP_CR3_ITAMP3NOER   TAMP_CR3_ITAMP3NOER_Msk
#define TAMP_CR3_ITAMP5NOER_Pos   (4U)
#define TAMP_CR3_ITAMP5NOER_Msk   (0x1UL << TAMP_CR3_ITAMP5NOER_Pos)
#define TAMP_CR3_ITAMP5NOER   TAMP_CR3_ITAMP5NOER_Msk
#define TAMP_CR3_ITAMP6NOER_Pos   (5U)
#define TAMP_CR3_ITAMP6NOER_Msk   (0x1UL << TAMP_CR3_ITAMP6NOER_Pos)
#define TAMP_CR3_ITAMP6NOER   TAMP_CR3_ITAMP6NOER_Msk
#define TAMP_CR3_ITAMP7NOER_Pos   (6U)
#define TAMP_CR3_ITAMP7NOER_Msk   (0x1UL << TAMP_CR3_ITAMP7NOER)
#define TAMP_CR3_ITAMP7NOER   TAMP_CR3_ITAMP7NOER_Msk
#define TAMP_CR3_ITAMP8NOER_Pos   (7U)
#define TAMP_CR3_ITAMP8NOER_Msk   (0x1UL << TAMP_CR3_ITAMP8NOER_Pos)
#define TAMP_CR3_ITAMP8NOER   TAMP_CR3_ITAMP8NOER_Msk
#define TAMP_CR3_ITAMP9NOER_Pos   (8U)
#define TAMP_CR3_ITAMP9NOER_Msk   (0x1UL << TAMP_CR3_ITAMP9NOER_Pos)
#define TAMP_CR3_ITAMP9NOER   TAMP_CR3_ITAMP9NOER_Msk
#define TAMP_CR3_ITAMP11NOER_Pos   (10U)
#define TAMP_CR3_ITAMP11NOER_Msk   (0x1UL << TAMP_CR3_ITAMP11NOER_Pos)
#define TAMP_CR3_ITAMP11NOER   TAMP_CR3_ITAMP11NOER_Msk
#define TAMP_CR3_ITAMP12NOER_Pos   (11U)
#define TAMP_CR3_ITAMP12NOER_Msk   (0x1UL << TAMP_CR3_ITAMP12NOER_Pos)
#define TAMP_CR3_ITAMP12NOER   TAMP_CR3_ITAMP12NOER_Msk
#define TAMP_CR3_ITAMP13NOER_Pos   (12U)
#define TAMP_CR3_ITAMP13NOER_Msk   (0x1UL << TAMP_CR3_ITAMP13NOER_Pos)
#define TAMP_CR3_ITAMP13NOER   TAMP_CR3_ITAMP13NOER_Msk
#define TAMP_FLTCR_TAMPFREQ_Pos   (0U)
#define TAMP_FLTCR_TAMPFREQ_Msk   (0x7UL << TAMP_FLTCR_TAMPFREQ_Pos)
#define TAMP_FLTCR_TAMPFREQ   TAMP_FLTCR_TAMPFREQ_Msk
#define TAMP_FLTCR_TAMPFREQ_0   (0x1UL << TAMP_FLTCR_TAMPFREQ_Pos)
#define TAMP_FLTCR_TAMPFREQ_1   (0x2UL << TAMP_FLTCR_TAMPFREQ_Pos)
#define TAMP_FLTCR_TAMPFREQ_2   (0x4UL << TAMP_FLTCR_TAMPFREQ_Pos)
#define TAMP_FLTCR_TAMPFLT_Pos   (3U)
#define TAMP_FLTCR_TAMPFLT_Msk   (0x3UL << TAMP_FLTCR_TAMPFLT_Pos)
#define TAMP_FLTCR_TAMPFLT   TAMP_FLTCR_TAMPFLT_Msk
#define TAMP_FLTCR_TAMPFLT_0   (0x1UL << TAMP_FLTCR_TAMPFLT_Pos)
#define TAMP_FLTCR_TAMPFLT_1   (0x2UL << TAMP_FLTCR_TAMPFLT_Pos)
#define TAMP_FLTCR_TAMPPRCH_Pos   (5U)
#define TAMP_FLTCR_TAMPPRCH_Msk   (0x3UL << TAMP_FLTCR_TAMPPRCH_Pos)
#define TAMP_FLTCR_TAMPPRCH   TAMP_FLTCR_TAMPPRCH_Msk
#define TAMP_FLTCR_TAMPPRCH_0   (0x1UL << TAMP_FLTCR_TAMPPRCH_Pos)
#define TAMP_FLTCR_TAMPPRCH_1   (0x2UL << TAMP_FLTCR_TAMPPRCH_Pos)
#define TAMP_FLTCR_TAMPPUDIS_Pos   (7U)
#define TAMP_FLTCR_TAMPPUDIS_Msk   (0x1UL << TAMP_FLTCR_TAMPPUDIS_Pos)
#define TAMP_FLTCR_TAMPPUDIS   TAMP_FLTCR_TAMPPUDIS_Msk
#define TAMP_ATCR1_TAMP1AM_Pos   (0U)
#define TAMP_ATCR1_TAMP1AM_Msk   (0x1UL << TAMP_ATCR1_TAMP1AM_Pos)
#define TAMP_ATCR1_TAMP1AM   TAMP_ATCR1_TAMP1AM_Msk
#define TAMP_ATCR1_TAMP2AM_Pos   (1U)
#define TAMP_ATCR1_TAMP2AM_Msk   (0x1UL << TAMP_ATCR1_TAMP2AM_Pos)
#define TAMP_ATCR1_TAMP2AM   TAMP_ATCR1_TAMP2AM_Msk
#define TAMP_ATCR1_TAMP3AM_Pos   (2U)
#define TAMP_ATCR1_TAMP3AM_Msk   (0x1UL << TAMP_ATCR1_TAMP3AM_Pos)
#define TAMP_ATCR1_TAMP3AM   TAMP_ATCR1_TAMP3AM_Msk
#define TAMP_ATCR1_TAMP4AM_Pos   (3U)
#define TAMP_ATCR1_TAMP4AM_Msk   (0x1UL << TAMP_ATCR1_TAMP4AM_Pos)
#define TAMP_ATCR1_TAMP4AM   TAMP_ATCR1_TAMP4AM_Msk
#define TAMP_ATCR1_TAMP5AM_Pos   (4U)
#define TAMP_ATCR1_TAMP5AM_Msk   (0x1UL << TAMP_ATCR1_TAMP5AM_Pos)
#define TAMP_ATCR1_TAMP5AM   TAMP_ATCR1_TAMP5AM_Msk
#define TAMP_ATCR1_TAMP6AM_Pos   (5U)
#define TAMP_ATCR1_TAMP6AM_Msk   (0x1UL << TAMP_ATCR1_TAMP6AM_Pos)
#define TAMP_ATCR1_TAMP6AM   TAMP_ATCR1_TAMP6AM_Msk
#define TAMP_ATCR1_TAMP7AM_Pos   (6U)
#define TAMP_ATCR1_TAMP7AM_Msk   (0x1UL << TAMP_ATCR1_TAMP7AM_Pos)
#define TAMP_ATCR1_TAMP7AM   TAMP_ATCR1_TAMP7AM_Msk
#define TAMP_ATCR1_TAMP8AM_Pos   (7U)
#define TAMP_ATCR1_TAMP8AM_Msk   (0x1UL << TAMP_ATCR1_TAMP8AM_Pos)
#define TAMP_ATCR1_TAMP8AM   TAMP_ATCR1_TAMP8AM_Msk
#define TAMP_ATCR1_ATOSEL1_Pos   (8U)
#define TAMP_ATCR1_ATOSEL1_Msk   (0x3UL << TAMP_ATCR1_ATOSEL1_Pos)
#define TAMP_ATCR1_ATOSEL1   TAMP_ATCR1_ATOSEL1_Msk
#define TAMP_ATCR1_ATOSEL1_0   (0x1UL << TAMP_ATCR1_ATOSEL1_Pos)
#define TAMP_ATCR1_ATOSEL1_1   (0x2UL << TAMP_ATCR1_ATOSEL1_Pos)
#define TAMP_ATCR1_ATOSEL2_Pos   (10U)
#define TAMP_ATCR1_ATOSEL2_Msk   (0x3UL << TAMP_ATCR1_ATOSEL2_Pos)
#define TAMP_ATCR1_ATOSEL2   TAMP_ATCR1_ATOSEL2_Msk
#define TAMP_ATCR1_ATOSEL2_0   (0x1UL << TAMP_ATCR1_ATOSEL2_Pos)
#define TAMP_ATCR1_ATOSEL2_1   (0x2UL << TAMP_ATCR1_ATOSEL2_Pos)
#define TAMP_ATCR1_ATOSEL3_Pos   (12U)
#define TAMP_ATCR1_ATOSEL3_Msk   (0x3UL << TAMP_ATCR1_ATOSEL3_Pos)
#define TAMP_ATCR1_ATOSEL3   TAMP_ATCR1_ATOSEL3_Msk
#define TAMP_ATCR1_ATOSEL3_0   (0x1UL << TAMP_ATCR1_ATOSEL3_Pos)
#define TAMP_ATCR1_ATOSEL3_1   (0x2UL << TAMP_ATCR1_ATOSEL3_Pos)
#define TAMP_ATCR1_ATOSEL4_Pos   (14U)
#define TAMP_ATCR1_ATOSEL4_Msk   (0x3UL << TAMP_ATCR1_ATOSEL4_Pos)
#define TAMP_ATCR1_ATOSEL4   TAMP_ATCR1_ATOSEL4_Msk
#define TAMP_ATCR1_ATOSEL4_0   (0x1UL << TAMP_ATCR1_ATOSEL4_Pos)
#define TAMP_ATCR1_ATOSEL4_1   (0x2UL << TAMP_ATCR1_ATOSEL4_Pos)
#define TAMP_ATCR1_ATCKSEL_Pos   (16U)
#define TAMP_ATCR1_ATCKSEL_Msk   (0xFUL << TAMP_ATCR1_ATCKSEL_Pos)
#define TAMP_ATCR1_ATCKSEL   TAMP_ATCR1_ATCKSEL_Msk
#define TAMP_ATCR1_ATCKSEL_0   (0x1UL << TAMP_ATCR1_ATCKSEL_Pos)
#define TAMP_ATCR1_ATCKSEL_1   (0x2UL << TAMP_ATCR1_ATCKSEL_Pos)
#define TAMP_ATCR1_ATCKSEL_2   (0x4UL << TAMP_ATCR1_ATCKSEL_Pos)
#define TAMP_ATCR1_ATCKSEL_3   (0x8UL << TAMP_ATCR1_ATCKSEL_Pos)
#define TAMP_ATCR1_ATPER_Pos   (24U)
#define TAMP_ATCR1_ATPER_Msk   (0x7UL << TAMP_ATCR1_ATPER_Pos)
#define TAMP_ATCR1_ATPER   TAMP_ATCR1_ATPER_Msk
#define TAMP_ATCR1_ATPER_0   (0x1UL << TAMP_ATCR1_ATPER_Pos)
#define TAMP_ATCR1_ATPER_1   (0x2UL << TAMP_ATCR1_ATPER_Pos)
#define TAMP_ATCR1_ATPER_2   (0x4UL << TAMP_ATCR1_ATPER_Pos)
#define TAMP_ATCR1_ATOSHARE_Pos   (30U)
#define TAMP_ATCR1_ATOSHARE_Msk   (0x1UL << TAMP_ATCR1_ATOSHARE_Pos)
#define TAMP_ATCR1_ATOSHARE   TAMP_ATCR1_ATOSHARE_Msk
#define TAMP_ATCR1_FLTEN_Pos   (31U)
#define TAMP_ATCR1_FLTEN_Msk   (0x1UL << TAMP_ATCR1_FLTEN_Pos)
#define TAMP_ATCR1_FLTEN   TAMP_ATCR1_FLTEN_Msk
#define TAMP_ATSEEDR_SEED_Pos   (0U)
#define TAMP_ATSEEDR_SEED_Msk   (0xFFFFFFFFUL << TAMP_ATSEEDR_SEED_Pos)
#define TAMP_ATSEEDR_SEED   TAMP_ATSEEDR_SEED_Msk
#define TAMP_ATOR_PRNG_Pos   (0U)
#define TAMP_ATOR_PRNG_Msk   (0xFF << TAMP_ATOR_PRNG_Pos)
#define TAMP_ATOR_PRNG   TAMP_ATOR_PRNG_Msk
#define TAMP_ATOR_PRNG_0   (0x1UL << TAMP_ATOR_PRNG_Pos)
#define TAMP_ATOR_PRNG_1   (0x2UL << TAMP_ATOR_PRNG_Pos)
#define TAMP_ATOR_PRNG_2   (0x4UL << TAMP_ATOR_PRNG_Pos)
#define TAMP_ATOR_PRNG_3   (0x8UL << TAMP_ATOR_PRNG_Pos)
#define TAMP_ATOR_PRNG_4   (0x10UL << TAMP_ATOR_PRNG_Pos)
#define TAMP_ATOR_PRNG_5   (0x20UL << TAMP_ATOR_PRNG_Pos)
#define TAMP_ATOR_PRNG_6   (0x40UL << TAMP_ATOR_PRNG_Pos)
#define TAMP_ATOR_PRNG_7   (0x80UL << TAMP_ATOR_PRNG_Pos)
#define TAMP_ATOR_SEEDF_Pos   (14U)
#define TAMP_ATOR_SEEDF_Msk   (1UL << TAMP_ATOR_SEEDF_Pos)
#define TAMP_ATOR_SEEDF   TAMP_ATOR_SEEDF_Msk
#define TAMP_ATOR_INITS_Pos   (15U)
#define TAMP_ATOR_INITS_Msk   (1UL << TAMP_ATOR_INITS_Pos)
#define TAMP_ATOR_INITS   TAMP_ATOR_INITS_Msk
#define TAMP_ATCR2_ATOSEL1_Pos   (8U)
#define TAMP_ATCR2_ATOSEL1_Msk   (0x7UL << TAMP_ATCR2_ATOSEL1_Pos)
#define TAMP_ATCR2_ATOSEL1   TAMP_ATCR2_ATOSEL1_Msk
#define TAMP_ATCR2_ATOSEL1_0   (0x1UL << TAMP_ATCR2_ATOSEL1_Pos)
#define TAMP_ATCR2_ATOSEL1_1   (0x2UL << TAMP_ATCR2_ATOSEL1_Pos)
#define TAMP_ATCR2_ATOSEL1_2   (0x4UL << TAMP_ATCR2_ATOSEL1_Pos)
#define TAMP_ATCR2_ATOSEL2_Pos   (11U)
#define TAMP_ATCR2_ATOSEL2_Msk   (0x7UL << TAMP_ATCR2_ATOSEL2_Pos)
#define TAMP_ATCR2_ATOSEL2   TAMP_ATCR2_ATOSEL2_Msk
#define TAMP_ATCR2_ATOSEL2_0   (0x1UL << TAMP_ATCR2_ATOSEL2_Pos)
#define TAMP_ATCR2_ATOSEL2_1   (0x2UL << TAMP_ATCR2_ATOSEL2_Pos)
#define TAMP_ATCR2_ATOSEL2_2   (0x4UL << TAMP_ATCR2_ATOSEL2_Pos)
#define TAMP_ATCR2_ATOSEL3_Pos   (14U)
#define TAMP_ATCR2_ATOSEL3_Msk   (0x7UL << TAMP_ATCR2_ATOSEL3_Pos)
#define TAMP_ATCR2_ATOSEL3   TAMP_ATCR2_ATOSEL3_Msk
#define TAMP_ATCR2_ATOSEL3_0   (0x1UL << TAMP_ATCR2_ATOSEL3_Pos)
#define TAMP_ATCR2_ATOSEL3_1   (0x2UL << TAMP_ATCR2_ATOSEL3_Pos)
#define TAMP_ATCR2_ATOSEL3_2   (0x4UL << TAMP_ATCR2_ATOSEL3_Pos)
#define TAMP_ATCR2_ATOSEL4_Pos   (17U)
#define TAMP_ATCR2_ATOSEL4_Msk   (0x7UL << TAMP_ATCR2_ATOSEL4_Pos)
#define TAMP_ATCR2_ATOSEL4   TAMP_ATCR2_ATOSEL4_Msk
#define TAMP_ATCR2_ATOSEL4_0   (0x1UL << TAMP_ATCR2_ATOSEL4_Pos)
#define TAMP_ATCR2_ATOSEL4_1   (0x2UL << TAMP_ATCR2_ATOSEL4_Pos)
#define TAMP_ATCR2_ATOSEL4_2   (0x4UL << TAMP_ATCR2_ATOSEL4_Pos)
#define TAMP_ATCR2_ATOSEL5_Pos   (20U)
#define TAMP_ATCR2_ATOSEL5_Msk   (0x7UL << TAMP_ATCR2_ATOSEL5_Pos)
#define TAMP_ATCR2_ATOSEL5   TAMP_ATCR2_ATOSEL5_Msk
#define TAMP_ATCR2_ATOSEL5_0   (0x1UL << TAMP_ATCR2_ATOSEL5_Pos)
#define TAMP_ATCR2_ATOSEL5_1   (0x2UL << TAMP_ATCR2_ATOSEL5_Pos)
#define TAMP_ATCR2_ATOSEL5_2   (0x4UL << TAMP_ATCR2_ATOSEL5_Pos)
#define TAMP_ATCR2_ATOSEL6_Pos   (23U)
#define TAMP_ATCR2_ATOSEL6_Msk   (0x7UL << TAMP_ATCR2_ATOSEL6_Pos)
#define TAMP_ATCR2_ATOSEL6   TAMP_ATCR2_ATOSEL6_Msk
#define TAMP_ATCR2_ATOSEL6_0   (0x1UL << TAMP_ATCR2_ATOSEL6_Pos)
#define TAMP_ATCR2_ATOSEL6_1   (0x2UL << TAMP_ATCR2_ATOSEL6_Pos)
#define TAMP_ATCR2_ATOSEL6_2   (0x4UL << TAMP_ATCR2_ATOSEL6_Pos)
#define TAMP_ATCR2_ATOSEL7_Pos   (26U)
#define TAMP_ATCR2_ATOSEL7_Msk   (0x7UL << TAMP_ATCR2_ATOSEL7_Pos)
#define TAMP_ATCR2_ATOSEL7   TAMP_ATCR2_ATOSEL7_Msk
#define TAMP_ATCR2_ATOSEL7_0   (0x1UL << TAMP_ATCR2_ATOSEL7_Pos)
#define TAMP_ATCR2_ATOSEL7_1   (0x2UL << TAMP_ATCR2_ATOSEL7_Pos)
#define TAMP_ATCR2_ATOSEL7_2   (0x4UL << TAMP_ATCR2_ATOSEL7_Pos)
#define TAMP_ATCR2_ATOSEL8_Pos   (29U)
#define TAMP_ATCR2_ATOSEL8_Msk   (0x7UL << TAMP_ATCR2_ATOSEL8_Pos)
#define TAMP_ATCR2_ATOSEL8   TAMP_ATCR2_ATOSEL8_Msk
#define TAMP_ATCR2_ATOSEL8_0   (0x1UL << TAMP_ATCR2_ATOSEL8_Pos)
#define TAMP_ATCR2_ATOSEL8_1   (0x2UL << TAMP_ATCR2_ATOSEL8_Pos)
#define TAMP_ATCR2_ATOSEL8_2   (0x4UL << TAMP_ATCR2_ATOSEL8_Pos)
#define TAMP_SECCFGR_BKPRWSEC_Pos   (0U)
#define TAMP_SECCFGR_BKPRWSEC_Msk   (0xFFUL << TAMP_SECCFGR_BKPRWSEC_Pos)
#define TAMP_SECCFGR_BKPRWSEC   TAMP_SECCFGR_BKPRWSEC_Msk
#define TAMP_SECCFGR_BKPRWSEC_0   (0x1UL << TAMP_SECCFGR_BKPRWSEC_Pos)
#define TAMP_SECCFGR_BKPRWSEC_1   (0x2UL << TAMP_SECCFGR_BKPRWSEC_Pos)
#define TAMP_SECCFGR_BKPRWSEC_2   (0x4UL << TAMP_SECCFGR_BKPRWSEC_Pos)
#define TAMP_SECCFGR_BKPRWSEC_3   (0x8UL << TAMP_SECCFGR_BKPRWSEC_Pos)
#define TAMP_SECCFGR_BKPRWSEC_4   (0x10UL << TAMP_SECCFGR_BKPRWSEC_Pos)
#define TAMP_SECCFGR_BKPRWSEC_5   (0x20UL << TAMP_SECCFGR_BKPRWSEC_Pos)
#define TAMP_SECCFGR_BKPRWSEC_6   (0x40UL << TAMP_SECCFGR_BKPRWSEC_Pos)
#define TAMP_SECCFGR_BKPRWSEC_7   (0x80UL << TAMP_SECCFGR_BKPRWSEC_Pos)
#define TAMP_SECCFGR_CNT1SEC_Pos   (15U)
#define TAMP_SECCFGR_CNT1SEC_Msk   (0x1UL << TAMP_SECCFGR_CNT1SEC_Pos)
#define TAMP_SECCFGR_CNT1SEC   TAMP_SECCFGR_CNT1SEC_Msk
#define TAMP_SECCFGR_BKPWSEC_Pos   (16U)
#define TAMP_SECCFGR_BKPWSEC_Msk   (0xFFUL << TAMP_SECCFGR_BKPWSEC_Pos)
#define TAMP_SECCFGR_BKPWSEC   TAMP_SECCFGR_BKPWSEC_Msk
#define TAMP_SECCFGR_BKPWSEC_0   (0x1UL << TAMP_SECCFGR_BKPWSEC_Pos)
#define TAMP_SECCFGR_BKPWSEC_1   (0x2UL << TAMP_SECCFGR_BKPWSEC_Pos)
#define TAMP_SECCFGR_BKPWSEC_2   (0x4UL << TAMP_SECCFGR_BKPWSEC_Pos)
#define TAMP_SECCFGR_BKPWSEC_3   (0x8UL << TAMP_SECCFGR_BKPWSEC_Pos)
#define TAMP_SECCFGR_BKPWSEC_4   (0x10UL << TAMP_SECCFGR_BKPWSEC_Pos)
#define TAMP_SECCFGR_BKPWSEC_5   (0x20UL << TAMP_SECCFGR_BKPWSEC_Pos)
#define TAMP_SECCFGR_BKPWSEC_6   (0x40UL << TAMP_SECCFGR_BKPWSEC_Pos)
#define TAMP_SECCFGR_BKPWSEC_7   (0x80UL << TAMP_SECCFGR_BKPWSEC_Pos)
#define TAMP_SECCFGR_BHKLOCK_Pos   (30U)
#define TAMP_SECCFGR_BHKLOCK_Msk   (0x1UL << TAMP_SECCFGR_BHKLOCK_Pos)
#define TAMP_SECCFGR_BHKLOCK   TAMP_SECCFGR_BHKLOCK_Msk
#define TAMP_SECCFGR_TAMPSEC_Pos   (31U)
#define TAMP_SECCFGR_TAMPSEC_Msk   (0x1UL << TAMP_SECCFGR_TAMPSEC_Pos)
#define TAMP_SECCFGR_TAMPSEC   TAMP_SECCFGR_TAMPSEC_Msk
#define TAMP_PRIVCFGR_CNT1PRIV_Pos   (15U)
#define TAMP_PRIVCFGR_CNT1PRIV_Msk   (0x1UL << TAMP_PRIVCFGR_CNT1PRIV_Pos)
#define TAMP_PRIVCFGR_CNT1PRIV   TAMP_PRIVCFGR_CNT1PRIV_Msk
#define TAMP_PRIVCFGR_BKPRWPRIV_Pos   (29U)
#define TAMP_PRIVCFGR_BKPRWPRIV_Msk   (0x1UL << TAMP_PRIVCFGR_BKPRWPRIV_Pos)
#define TAMP_PRIVCFGR_BKPRWPRIV   TAMP_PRIVCFGR_BKPRWPRIV_Msk
#define TAMP_PRIVCFGR_BKPWPRIV_Pos   (30U)
#define TAMP_PRIVCFGR_BKPWPRIV_Msk   (0x1UL << TAMP_PRIVCFGR_BKPWPRIV_Pos)
#define TAMP_PRIVCFGR_BKPWPRIV   TAMP_PRIVCFGR_BKPWPRIV_Msk
#define TAMP_PRIVCFGR_TAMPPRIV_Pos   (31U)
#define TAMP_PRIVCFGR_TAMPPRIV_Msk   (0x1UL << TAMP_PRIVCFGR_TAMPPRIV_Pos)
#define TAMP_PRIVCFGR_TAMPPRIV   TAMP_PRIVCFGR_TAMPPRIV_Msk
#define TAMP_IER_TAMP1IE_Pos   (0U)
#define TAMP_IER_TAMP1IE_Msk   (0x1UL << TAMP_IER_TAMP1IE_Pos)
#define TAMP_IER_TAMP1IE   TAMP_IER_TAMP1IE_Msk
#define TAMP_IER_TAMP2IE_Pos   (1U)
#define TAMP_IER_TAMP2IE_Msk   (0x1UL << TAMP_IER_TAMP2IE_Pos)
#define TAMP_IER_TAMP2IE   TAMP_IER_TAMP2IE_Msk
#define TAMP_IER_TAMP3IE_Pos   (2U)
#define TAMP_IER_TAMP3IE_Msk   (0x1UL << TAMP_IER_TAMP3IE_Pos)
#define TAMP_IER_TAMP3IE   TAMP_IER_TAMP3IE_Msk
#define TAMP_IER_TAMP4IE_Pos   (3U)
#define TAMP_IER_TAMP4IE_Msk   (0x1UL << TAMP_IER_TAMP4IE_Pos)
#define TAMP_IER_TAMP4IE   TAMP_IER_TAMP4IE_Msk
#define TAMP_IER_TAMP5IE_Pos   (4U)
#define TAMP_IER_TAMP5IE_Msk   (0x1UL << TAMP_IER_TAMP5IE_Pos)
#define TAMP_IER_TAMP5IE   TAMP_IER_TAMP5IE_Msk
#define TAMP_IER_TAMP6IE_Pos   (5U)
#define TAMP_IER_TAMP6IE_Msk   (0x1UL << TAMP_IER_TAMP6IE_Pos)
#define TAMP_IER_TAMP6IE   TAMP_IER_TAMP6IE_Msk
#define TAMP_IER_TAMP7IE_Pos   (6U)
#define TAMP_IER_TAMP7IE_Msk   (0x1UL << TAMP_IER_TAMP7IE_Pos)
#define TAMP_IER_TAMP7IE   TAMP_IER_TAMP7IE_Msk
#define TAMP_IER_TAMP8IE_Pos   (7U)
#define TAMP_IER_TAMP8IE_Msk   (0x1UL << TAMP_IER_TAMP8IE_Pos)
#define TAMP_IER_TAMP8IE   TAMP_IER_TAMP8IE_Msk
#define TAMP_IER_ITAMP1IE_Pos   (16U)
#define TAMP_IER_ITAMP1IE_Msk   (0x1UL << TAMP_IER_ITAMP1IE_Pos)
#define TAMP_IER_ITAMP1IE   TAMP_IER_ITAMP1IE_Msk
#define TAMP_IER_ITAMP2IE_Pos   (17U)
#define TAMP_IER_ITAMP2IE_Msk   (0x1UL << TAMP_IER_ITAMP2IE_Pos)
#define TAMP_IER_ITAMP2IE   TAMP_IER_ITAMP2IE_Msk
#define TAMP_IER_ITAMP3IE_Pos   (18U)
#define TAMP_IER_ITAMP3IE_Msk   (0x1UL << TAMP_IER_ITAMP3IE_Pos)
#define TAMP_IER_ITAMP3IE   TAMP_IER_ITAMP3IE_Msk
#define TAMP_IER_ITAMP5IE_Pos   (20U)
#define TAMP_IER_ITAMP5IE_Msk   (0x1UL << TAMP_IER_ITAMP5IE_Pos)
#define TAMP_IER_ITAMP5IE   TAMP_IER_ITAMP5IE_Msk
#define TAMP_IER_ITAMP6IE_Pos   (21U)
#define TAMP_IER_ITAMP6IE_Msk   (0x1UL << TAMP_IER_ITAMP6IE_Pos)
#define TAMP_IER_ITAMP6IE   TAMP_IER_ITAMP6IE_Msk
#define TAMP_IER_ITAMP7IE_Pos   (22U)
#define TAMP_IER_ITAMP7IE_Msk   (0x1UL << TAMP_IER_ITAMP7IE_Pos)
#define TAMP_IER_ITAMP7IE   TAMP_IER_ITAMP7IE_Msk
#define TAMP_IER_ITAMP8IE_Pos   (23U)
#define TAMP_IER_ITAMP8IE_Msk   (0x1UL << TAMP_IER_ITAMP8IE_Pos)
#define TAMP_IER_ITAMP8IE   TAMP_IER_ITAMP8IE_Msk
#define TAMP_IER_ITAMP9IE_Pos   (24U)
#define TAMP_IER_ITAMP9IE_Msk   (0x1UL << TAMP_IER_ITAMP9IE_Pos)
#define TAMP_IER_ITAMP9IE   TAMP_IER_ITAMP9IE_Msk
#define TAMP_IER_ITAMP11IE_Pos   (26U)
#define TAMP_IER_ITAMP11IE_Msk   (0x1UL << TAMP_IER_ITAMP11IE_Pos)
#define TAMP_IER_ITAMP11IE   TAMP_IER_ITAMP11IE_Msk
#define TAMP_IER_ITAMP12IE_Pos   (27U)
#define TAMP_IER_ITAMP12IE_Msk   (0x1UL << TAMP_IER_ITAMP12IE_Pos)
#define TAMP_IER_ITAMP12IE   TAMP_IER_ITAMP12IE_Msk
#define TAMP_IER_ITAMP13IE_Pos   (28U)
#define TAMP_IER_ITAMP13IE_Msk   (0x1UL << TAMP_IER_ITAMP13IE_Pos)
#define TAMP_IER_ITAMP13IE   TAMP_IER_ITAMP13IE_Msk
#define TAMP_SR_TAMP1F_Pos   (0U)
#define TAMP_SR_TAMP1F_Msk   (0x1UL << TAMP_SR_TAMP1F_Pos)
#define TAMP_SR_TAMP1F   TAMP_SR_TAMP1F_Msk
#define TAMP_SR_TAMP2F_Pos   (1U)
#define TAMP_SR_TAMP2F_Msk   (0x1UL << TAMP_SR_TAMP2F_Pos)
#define TAMP_SR_TAMP2F   TAMP_SR_TAMP2F_Msk
#define TAMP_SR_TAMP3F_Pos   (2U)
#define TAMP_SR_TAMP3F_Msk   (0x1UL << TAMP_SR_TAMP3F_Pos)
#define TAMP_SR_TAMP3F   TAMP_SR_TAMP3F_Msk
#define TAMP_SR_TAMP4F_Pos   (3U)
#define TAMP_SR_TAMP4F_Msk   (0x1UL << TAMP_SR_TAMP4F_Pos)
#define TAMP_SR_TAMP4F   TAMP_SR_TAMP4F_Msk
#define TAMP_SR_TAMP5F_Pos   (4U)
#define TAMP_SR_TAMP5F_Msk   (0x1UL << TAMP_SR_TAMP5F_Pos)
#define TAMP_SR_TAMP5F   TAMP_SR_TAMP5F_Msk
#define TAMP_SR_TAMP6F_Pos   (5U)
#define TAMP_SR_TAMP6F_Msk   (0x1UL << TAMP_SR_TAMP6F_Pos)
#define TAMP_SR_TAMP6F   TAMP_SR_TAMP6F_Msk
#define TAMP_SR_TAMP7F_Pos   (6U)
#define TAMP_SR_TAMP7F_Msk   (0x1UL << TAMP_SR_TAMP7F_Pos)
#define TAMP_SR_TAMP7F   TAMP_SR_TAMP7F_Msk
#define TAMP_SR_TAMP8F_Pos   (7U)
#define TAMP_SR_TAMP8F_Msk   (0x1UL << TAMP_SR_TAMP8F_Pos)
#define TAMP_SR_TAMP8F   TAMP_SR_TAMP8F_Msk
#define TAMP_SR_ITAMP1F_Pos   (16U)
#define TAMP_SR_ITAMP1F_Msk   (0x1UL << TAMP_SR_ITAMP1F_Pos)
#define TAMP_SR_ITAMP1F   TAMP_SR_ITAMP1F_Msk
#define TAMP_SR_ITAMP2F_Pos   (17U)
#define TAMP_SR_ITAMP2F_Msk   (0x1UL << TAMP_SR_ITAMP2F_Pos)
#define TAMP_SR_ITAMP2F   TAMP_SR_ITAMP2F_Msk
#define TAMP_SR_ITAMP3F_Pos   (18U)
#define TAMP_SR_ITAMP3F_Msk   (0x1UL << TAMP_SR_ITAMP3F_Pos)
#define TAMP_SR_ITAMP3F   TAMP_SR_ITAMP3F_Msk
#define TAMP_SR_ITAMP5F_Pos   (20U)
#define TAMP_SR_ITAMP5F_Msk   (0x1UL << TAMP_SR_ITAMP5F_Pos)
#define TAMP_SR_ITAMP5F   TAMP_SR_ITAMP5F_Msk
#define TAMP_SR_ITAMP6F_Pos   (21U)
#define TAMP_SR_ITAMP6F_Msk   (0x1UL << TAMP_SR_ITAMP6F_Pos)
#define TAMP_SR_ITAMP6F   TAMP_SR_ITAMP6F_Msk
#define TAMP_SR_ITAMP7F_Pos   (22U)
#define TAMP_SR_ITAMP7F_Msk   (0x1UL << TAMP_SR_ITAMP7F_Pos)
#define TAMP_SR_ITAMP7F   TAMP_SR_ITAMP7F_Msk
#define TAMP_SR_ITAMP8F_Pos   (23U)
#define TAMP_SR_ITAMP8F_Msk   (0x1UL << TAMP_SR_ITAMP8F_Pos)
#define TAMP_SR_ITAMP8F   TAMP_SR_ITAMP8F_Msk
#define TAMP_SR_ITAMP9F_Pos   (24U)
#define TAMP_SR_ITAMP9F_Msk   (0x1UL << TAMP_SR_ITAMP9F_Pos)
#define TAMP_SR_ITAMP9F   TAMP_SR_ITAMP9F_Msk
#define TAMP_SR_ITAMP11F_Pos   (26U)
#define TAMP_SR_ITAMP11F_Msk   (0x1UL << TAMP_SR_ITAMP11F_Pos)
#define TAMP_SR_ITAMP11F   TAMP_SR_ITAMP11F_Msk
#define TAMP_SR_ITAMP12F_Pos   (27U)
#define TAMP_SR_ITAMP12F_Msk   (0x1UL << TAMP_SR_ITAMP12F_Pos)
#define TAMP_SR_ITAMP12F   TAMP_SR_ITAMP12F_Msk
#define TAMP_SR_ITAMP13F_Pos   (28U)
#define TAMP_SR_ITAMP13F_Msk   (0x1UL << TAMP_SR_ITAMP13F_Pos)
#define TAMP_SR_ITAMP13F   TAMP_SR_ITAMP13F_Msk
#define TAMP_MISR_TAMP1MF_Pos   (0U)
#define TAMP_MISR_TAMP1MF_Msk   (0x1UL << TAMP_MISR_TAMP1MF_Pos)
#define TAMP_MISR_TAMP1MF   TAMP_MISR_TAMP1MF_Msk
#define TAMP_MISR_TAMP2MF_Pos   (1U)
#define TAMP_MISR_TAMP2MF_Msk   (0x1UL << TAMP_MISR_TAMP2MF_Pos)
#define TAMP_MISR_TAMP2MF   TAMP_MISR_TAMP2MF_Msk
#define TAMP_MISR_TAMP3MF_Pos   (2U)
#define TAMP_MISR_TAMP3MF_Msk   (0x1UL << TAMP_MISR_TAMP3MF_Pos)
#define TAMP_MISR_TAMP3MF   TAMP_MISR_TAMP3MF_Msk
#define TAMP_MISR_TAMP4MF_Pos   (3U)
#define TAMP_MISR_TAMP4MF_Msk   (0x1UL << TAMP_MISR_TAMP4MF_Pos)
#define TAMP_MISR_TAMP4MF   TAMP_MISR_TAMP4MF_Msk
#define TAMP_MISR_TAMP5MF_Pos   (4U)
#define TAMP_MISR_TAMP5MF_Msk   (0x1UL << TAMP_MISR_TAMP5MF_Pos)
#define TAMP_MISR_TAMP5MF   TAMP_MISR_TAMP5MF_Msk
#define TAMP_MISR_TAMP6MF_Pos   (5U)
#define TAMP_MISR_TAMP6MF_Msk   (0x1UL << TAMP_MISR_TAMP6MF_Pos)
#define TAMP_MISR_TAMP6MF   TAMP_MISR_TAMP6MF_Msk
#define TAMP_MISR_TAMP7MF_Pos   (6U)
#define TAMP_MISR_TAMP7MF_Msk   (0x1UL << TAMP_MISR_TAMP7MF_Pos)
#define TAMP_MISR_TAMP7MF   TAMP_MISR_TAMP7MF_Msk
#define TAMP_MISR_TAMP8MF_Pos   (7U)
#define TAMP_MISR_TAMP8MF_Msk   (0x1UL << TAMP_MISR_TAMP8MF_Pos)
#define TAMP_MISR_TAMP8MF   TAMP_MISR_TAMP8MF_Msk
#define TAMP_MISR_ITAMP1MF_Pos   (16U)
#define TAMP_MISR_ITAMP1MF_Msk   (0x1UL << TAMP_MISR_ITAMP1MF_Pos)
#define TAMP_MISR_ITAMP1MF   TAMP_MISR_ITAMP1MF_Msk
#define TAMP_MISR_ITAMP2MF_Pos   (17U)
#define TAMP_MISR_ITAMP2MF_Msk   (0x1UL << TAMP_MISR_ITAMP2MF_Pos)
#define TAMP_MISR_ITAMP2MF   TAMP_MISR_ITAMP2MF_Msk
#define TAMP_MISR_ITAMP3MF_Pos   (18U)
#define TAMP_MISR_ITAMP3MF_Msk   (0x1UL << TAMP_MISR_ITAMP3MF_Pos)
#define TAMP_MISR_ITAMP3MF   TAMP_MISR_ITAMP3MF_Msk
#define TAMP_MISR_ITAMP5MF_Pos   (20U)
#define TAMP_MISR_ITAMP5MF_Msk   (0x1UL << TAMP_MISR_ITAMP5MF_Pos)
#define TAMP_MISR_ITAMP5MF   TAMP_MISR_ITAMP5MF_Msk
#define TAMP_MISR_ITAMP6MF_Pos   (21U)
#define TAMP_MISR_ITAMP6MF_Msk   (0x1UL << TAMP_MISR_ITAMP6MF_Pos)
#define TAMP_MISR_ITAMP6MF   TAMP_MISR_ITAMP6MF_Msk
#define TAMP_MISR_ITAMP7MF_Pos   (22U)
#define TAMP_MISR_ITAMP7MF_Msk   (0x1UL << TAMP_MISR_ITAMP7MF_Pos)
#define TAMP_MISR_ITAMP7MF   TAMP_MISR_ITAMP7MF_Msk
#define TAMP_MISR_ITAMP8MF_Pos   (23U)
#define TAMP_MISR_ITAMP8MF_Msk   (0x1UL << TAMP_MISR_ITAMP8MF_Pos)
#define TAMP_MISR_ITAMP8MF   TAMP_MISR_ITAMP8MF_Msk
#define TAMP_MISR_ITAMP9MF_Pos   (24U)
#define TAMP_MISR_ITAMP9MF_Msk   (0x1UL << TAMP_MISR_ITAMP9MF_Pos)
#define TAMP_MISR_ITAMP9MF   TAMP_MISR_ITAMP9MF_Msk
#define TAMP_MISR_ITAMP11MF_Pos   (26U)
#define TAMP_MISR_ITAMP11MF_Msk   (0x1UL << TAMP_MISR_ITAMP11MF_Pos)
#define TAMP_MISR_ITAMP11MF   TAMP_MISR_ITAMP11MF_Msk
#define TAMP_MISR_ITAMP12MF_Pos   (27U)
#define TAMP_MISR_ITAMP12MF_Msk   (0x1UL << TAMP_MISR_ITAMP12MF_Pos)
#define TAMP_MISR_ITAMP12MF   TAMP_MISR_ITAMP12MF_Msk
#define TAMP_MISR_ITAMP13MF_Pos   (28U)
#define TAMP_MISR_ITAMP13MF_Msk   (0x1UL << TAMP_MISR_ITAMP13MF_Pos)
#define TAMP_MISR_ITAMP13MF   TAMP_MISR_ITAMP13MF_Msk
#define TAMP_SMISR_TAMP1MF_Pos   (0U)
#define TAMP_SMISR_TAMP1MF_Msk   (0x1UL << TAMP_SMISR_TAMP1MF_Pos)
#define TAMP_SMISR_TAMP1MF   TAMP_SMISR_TAMP1MF_Msk
#define TAMP_SMISR_TAMP2MF_Pos   (1U)
#define TAMP_SMISR_TAMP2MF_Msk   (0x1UL << TAMP_SMISR_TAMP2MF_Pos)
#define TAMP_SMISR_TAMP2MF   TAMP_SMISR_TAMP2MF_Msk
#define TAMP_SMISR_TAMP3MF_Pos   (2U)
#define TAMP_SMISR_TAMP3MF_Msk   (0x1UL << TAMP_SMISR_TAMP3MF_Pos)
#define TAMP_SMISR_TAMP3MF   TAMP_SMISR_TAMP3MF_Msk
#define TAMP_SMISR_TAMP4MF_Pos   (3U)
#define TAMP_SMISR_TAMP4MF_Msk   (0x1UL << TAMP_SMISR_TAMP4MF_Pos)
#define TAMP_SMISR_TAMP4MF   TAMP_SMISR_TAMP4MF_Msk
#define TAMP_SMISR_TAMP5MF_Pos   (4U)
#define TAMP_SMISR_TAMP5MF_Msk   (0x1UL << TAMP_SMISR_TAMP5MF_Pos)
#define TAMP_SMISR_TAMP5MF   TAMP_SMISR_TAMP5MF_Msk
#define TAMP_SMISR_TAMP6MF_Pos   (5U)
#define TAMP_SMISR_TAMP6MF_Msk   (0x1UL << TAMP_SMISR_TAMP6MF_Pos)
#define TAMP_SMISR_TAMP6MF   TAMP_SMISR_TAMP6MF_Msk
#define TAMP_SMISR_TAMP7MF_Pos   (6U)
#define TAMP_SMISR_TAMP7MF_Msk   (0x1UL << TAMP_SMISR_TAMP7MF_Pos)
#define TAMP_SMISR_TAMP7MF   TAMP_SMISR_TAMP7MF_Msk
#define TAMP_SMISR_TAMP8MF_Pos   (7U)
#define TAMP_SMISR_TAMP8MF_Msk   (0x1UL << TAMP_SMISR_TAMP8MF_Pos)
#define TAMP_SMISR_TAMP8MF   TAMP_SMISR_TAMP8MF_Msk
#define TAMP_SMISR_ITAMP1MF_Pos   (16U)
#define TAMP_SMISR_ITAMP1MF_Msk   (0x1UL << TAMP_SMISR_ITAMP1MF_Pos)
#define TAMP_SMISR_ITAMP1MF   TAMP_SMISR_ITAMP1MF_Msk
#define TAMP_SMISR_ITAMP2MF_Pos   (17U)
#define TAMP_SMISR_ITAMP2MF_Msk   (0x1UL << TAMP_SMISR_ITAMP2MF_Pos)
#define TAMP_SMISR_ITAMP2MF   TAMP_SMISR_ITAMP2MF_Msk
#define TAMP_SMISR_ITAMP3MF_Pos   (18U)
#define TAMP_SMISR_ITAMP3MF_Msk   (0x1UL << TAMP_SMISR_ITAMP3MF_Pos)
#define TAMP_SMISR_ITAMP3MF   TAMP_SMISR_ITAMP3MF_Msk
#define TAMP_SMISR_ITAMP5MF_Pos   (20U)
#define TAMP_SMISR_ITAMP5MF_Msk   (0x1UL << TAMP_SMISR_ITAMP5MF_Pos)
#define TAMP_SMISR_ITAMP5MF   TAMP_SMISR_ITAMP5MF_Msk
#define TAMP_SMISR_ITAMP6MF_Pos   (21U)
#define TAMP_SMISR_ITAMP6MF_Msk   (0x1UL << TAMP_SMISR_ITAMP6MF_Pos)
#define TAMP_SMISR_ITAMP6MF   TAMP_SMISR_ITAMP6MF_Msk
#define TAMP_SMISR_ITAMP7MF_Pos   (22U)
#define TAMP_SMISR_ITAMP7MF_Msk   (0x1UL << TAMP_SMISR_ITAMP7MF_Pos)
#define TAMP_SMISR_ITAMP7MF   TAMP_SMISR_ITAMP7MF_Msk
#define TAMP_SMISR_ITAMP8MF_Pos   (23U)
#define TAMP_SMISR_ITAMP8MF_Msk   (0x1UL << TAMP_SMISR_ITAMP8MF_Pos)
#define TAMP_SMISR_ITAMP8MF   TAMP_SMISR_ITAMP8MF_Msk
#define TAMP_SMISR_ITAMP9MF_Pos   (24U)
#define TAMP_SMISR_ITAMP9MF_Msk   (0x1UL << TAMP_SMISR_ITAMP9MF_Pos)
#define TAMP_SMISR_ITAMP9MF   TAMP_SMISR_ITAMP9MF_Msk
#define TAMP_SMISR_ITAMP11MF_Pos   (26U)
#define TAMP_SMISR_ITAMP11MF_Msk   (0x1UL << TAMP_SMISR_ITAMP11MF_Pos)
#define TAMP_SMISR_ITAMP11MF   TAMP_SMISR_ITAMP11MF_Msk
#define TAMP_SMISR_ITAMP12MF_Pos   (27U)
#define TAMP_SMISR_ITAMP12MF_Msk   (0x1UL << TAMP_SMISR_ITAMP12MF_Pos)
#define TAMP_SMISR_ITAMP12MF   TAMP_SMISR_ITAMP12MF_Msk
#define TAMP_SMISR_ITAMP13MF_Pos   (28U)
#define TAMP_SMISR_ITAMP13MF_Msk   (0x1UL << TAMP_SMISR_ITAMP13MF_Pos)
#define TAMP_SMISR_ITAMP13MF   TAMP_SMISR_ITAMP13MF_Msk
#define TAMP_SCR_CTAMP1F_Pos   (0U)
#define TAMP_SCR_CTAMP1F_Msk   (0x1UL << TAMP_SCR_CTAMP1F_Pos)
#define TAMP_SCR_CTAMP1F   TAMP_SCR_CTAMP1F_Msk
#define TAMP_SCR_CTAMP2F_Pos   (1U)
#define TAMP_SCR_CTAMP2F_Msk   (0x1UL << TAMP_SCR_CTAMP2F_Pos)
#define TAMP_SCR_CTAMP2F   TAMP_SCR_CTAMP2F_Msk
#define TAMP_SCR_CTAMP3F_Pos   (2U)
#define TAMP_SCR_CTAMP3F_Msk   (0x1UL << TAMP_SCR_CTAMP3F_Pos)
#define TAMP_SCR_CTAMP3F   TAMP_SCR_CTAMP3F_Msk
#define TAMP_SCR_CTAMP4F_Pos   (3U)
#define TAMP_SCR_CTAMP4F_Msk   (0x1UL << TAMP_SCR_CTAMP4F_Pos)
#define TAMP_SCR_CTAMP4F   TAMP_SCR_CTAMP4F_Msk
#define TAMP_SCR_CTAMP5F_Pos   (4U)
#define TAMP_SCR_CTAMP5F_Msk   (0x1UL << TAMP_SCR_CTAMP5F_Pos)
#define TAMP_SCR_CTAMP5F   TAMP_SCR_CTAMP5F_Msk
#define TAMP_SCR_CTAMP6F_Pos   (5U)
#define TAMP_SCR_CTAMP6F_Msk   (0x1UL << TAMP_SCR_CTAMP6F_Pos)
#define TAMP_SCR_CTAMP6F   TAMP_SCR_CTAMP6F_Msk
#define TAMP_SCR_CTAMP7F_Pos   (6U)
#define TAMP_SCR_CTAMP7F_Msk   (0x1UL << TAMP_SCR_CTAMP7F_Pos)
#define TAMP_SCR_CTAMP7F   TAMP_SCR_CTAMP7F_Msk
#define TAMP_SCR_CTAMP8F_Pos   (7U)
#define TAMP_SCR_CTAMP8F_Msk   (0x1UL << TAMP_SCR_CTAMP8F_Pos)
#define TAMP_SCR_CTAMP8F   TAMP_SCR_CTAMP8F_Msk
#define TAMP_SCR_CITAMP1F_Pos   (16U)
#define TAMP_SCR_CITAMP1F_Msk   (0x1UL << TAMP_SCR_CITAMP1F_Pos)
#define TAMP_SCR_CITAMP1F   TAMP_SCR_CITAMP1F_Msk
#define TAMP_SCR_CITAMP2F_Pos   (17U)
#define TAMP_SCR_CITAMP2F_Msk   (0x1UL << TAMP_SCR_CITAMP2F_Pos)
#define TAMP_SCR_CITAMP2F   TAMP_SCR_CITAMP2F_Msk
#define TAMP_SCR_CITAMP3F_Pos   (18U)
#define TAMP_SCR_CITAMP3F_Msk   (0x1UL << TAMP_SCR_CITAMP3F_Pos)
#define TAMP_SCR_CITAMP3F   TAMP_SCR_CITAMP3F_Msk
#define TAMP_SCR_CITAMP5F_Pos   (20U)
#define TAMP_SCR_CITAMP5F_Msk   (0x1UL << TAMP_SCR_CITAMP5F_Pos)
#define TAMP_SCR_CITAMP5F   TAMP_SCR_CITAMP5F_Msk
#define TAMP_SCR_CITAMP6F_Pos   (21U)
#define TAMP_SCR_CITAMP6F_Msk   (0x1UL << TAMP_SCR_CITAMP6F_Pos)
#define TAMP_SCR_CITAMP6F   TAMP_SCR_CITAMP6F_Msk
#define TAMP_SCR_CITAMP7F_Pos   (22U)
#define TAMP_SCR_CITAMP7F_Msk   (0x1UL << TAMP_SCR_CITAMP7F_Pos)
#define TAMP_SCR_CITAMP7F   TAMP_SCR_CITAMP7F_Msk
#define TAMP_SCR_CITAMP8F_Pos   (23U)
#define TAMP_SCR_CITAMP8F_Msk   (0x1UL << TAMP_SCR_CITAMP8F_Pos)
#define TAMP_SCR_CITAMP8F   TAMP_SCR_CITAMP8F_Msk
#define TAMP_SCR_CITAMP9F_Pos   (24U)
#define TAMP_SCR_CITAMP9F_Msk   (0x1UL << TAMP_SCR_CITAMP9F_Pos)
#define TAMP_SCR_CITAMP9F   TAMP_SCR_CITAMP9F_Msk
#define TAMP_SCR_CITAMP11F_Pos   (26U)
#define TAMP_SCR_CITAMP11F_Msk   (0x1UL << TAMP_SCR_CITAMP11F_Pos)
#define TAMP_SCR_CITAMP11F   TAMP_SCR_CITAMP11F_Msk
#define TAMP_SCR_CITAMP12F_Pos   (27U)
#define TAMP_SCR_CITAMP12F_Msk   (0x1UL << TAMP_SCR_CITAMP12F_Pos)
#define TAMP_SCR_CITAMP12F   TAMP_SCR_CITAMP12F_Msk
#define TAMP_SCR_CITAMP13F_Pos   (28U)
#define TAMP_SCR_CITAMP13F_Msk   (0x1UL << TAMP_SCR_CITAMP13F_Pos)
#define TAMP_SCR_CITAMP13F   TAMP_SCR_CITAMP13F_Msk
#define TAMP_COUNTR_Pos   (16U)
#define TAMP_COUNTR_Msk   (0xFFFFUL << TAMP_COUNTR_Pos)
#define TAMP_COUNTR   TAMP_COUNTR_Msk
#define TAMP_ERCFGR0_Pos   (0U)
#define TAMP_ERCFGR0_Msk   (0x1UL << TAMP_ERCFGR0_Pos)
#define TAMP_ERCFGR0   TAMP_ERCFGR0_Msk
#define TAMP_BKP0R_Pos   (0U)
#define TAMP_BKP0R_Msk   (0xFFFFFFFFUL << TAMP_BKP0R_Pos)
#define TAMP_BKP0R   TAMP_BKP0R_Msk
#define TAMP_BKP1R_Pos   (0U)
#define TAMP_BKP1R_Msk   (0xFFFFFFFFUL << TAMP_BKP1R_Pos)
#define TAMP_BKP1R   TAMP_BKP1R_Msk
#define TAMP_BKP2R_Pos   (0U)
#define TAMP_BKP2R_Msk   (0xFFFFFFFFUL << TAMP_BKP2R_Pos)
#define TAMP_BKP2R   TAMP_BKP2R_Msk
#define TAMP_BKP3R_Pos   (0U)
#define TAMP_BKP3R_Msk   (0xFFFFFFFFUL << TAMP_BKP3R_Pos)
#define TAMP_BKP3R   TAMP_BKP3R_Msk
#define TAMP_BKP4R_Pos   (0U)
#define TAMP_BKP4R_Msk   (0xFFFFFFFFUL << TAMP_BKP4R_Pos)
#define TAMP_BKP4R   TAMP_BKP4R_Msk
#define TAMP_BKP5R_Pos   (0U)
#define TAMP_BKP5R_Msk   (0xFFFFFFFFUL << TAMP_BKP5R_Pos)
#define TAMP_BKP5R   TAMP_BKP5R_Msk
#define TAMP_BKP6R_Pos   (0U)
#define TAMP_BKP6R_Msk   (0xFFFFFFFFUL << TAMP_BKP6R_Pos)
#define TAMP_BKP6R   TAMP_BKP6R_Msk
#define TAMP_BKP7R_Pos   (0U)
#define TAMP_BKP7R_Msk   (0xFFFFFFFFUL << TAMP_BKP7R_Pos)
#define TAMP_BKP7R   TAMP_BKP7R_Msk
#define TAMP_BKP8R_Pos   (0U)
#define TAMP_BKP8R_Msk   (0xFFFFFFFFUL << TAMP_BKP8R_Pos)
#define TAMP_BKP8R   TAMP_BKP8R_Msk
#define TAMP_BKP9R_Pos   (0U)
#define TAMP_BKP9R_Msk   (0xFFFFFFFFUL << TAMP_BKP9R_Pos)
#define TAMP_BKP9R   TAMP_BKP9R_Msk
#define TAMP_BKP10R_Pos   (0U)
#define TAMP_BKP10R_Msk   (0xFFFFFFFFUL << TAMP_BKP10R_Pos)
#define TAMP_BKP10R   TAMP_BKP10R_Msk
#define TAMP_BKP11R_Pos   (0U)
#define TAMP_BKP11R_Msk   (0xFFFFFFFFUL << TAMP_BKP11R_Pos)
#define TAMP_BKP11R   TAMP_BKP11R_Msk
#define TAMP_BKP12R_Pos   (0U)
#define TAMP_BKP12R_Msk   (0xFFFFFFFFUL << TAMP_BKP12R_Pos)
#define TAMP_BKP12R   TAMP_BKP12R_Msk
#define TAMP_BKP13R_Pos   (0U)
#define TAMP_BKP13R_Msk   (0xFFFFFFFFUL << TAMP_BKP13R_Pos)
#define TAMP_BKP13R   TAMP_BKP13R_Msk
#define TAMP_BKP14R_Pos   (0U)
#define TAMP_BKP14R_Msk   (0xFFFFFFFFUL << TAMP_BKP14R_Pos)
#define TAMP_BKP14R   TAMP_BKP14R_Msk
#define TAMP_BKP15R_Pos   (0U)
#define TAMP_BKP15R_Msk   (0xFFFFFFFFUL << TAMP_BKP15R_Pos)
#define TAMP_BKP15R   TAMP_BKP15R_Msk
#define TAMP_BKP16R_Pos   (0U)
#define TAMP_BKP16R_Msk   (0xFFFFFFFFUL << TAMP_BKP16R_Pos)
#define TAMP_BKP16R   TAMP_BKP16R_Msk
#define TAMP_BKP17R_Pos   (0U)
#define TAMP_BKP17R_Msk   (0xFFFFFFFFUL << TAMP_BKP17R_Pos)
#define TAMP_BKP17R   TAMP_BKP17R_Msk
#define TAMP_BKP18R_Pos   (0U)
#define TAMP_BKP18R_Msk   (0xFFFFFFFFUL << TAMP_BKP18R_Pos)
#define TAMP_BKP18R   TAMP_BKP18R_Msk
#define TAMP_BKP19R_Pos   (0U)
#define TAMP_BKP19R_Msk   (0xFFFFFFFFUL << TAMP_BKP19R_Pos)
#define TAMP_BKP19R   TAMP_BKP19R_Msk
#define TAMP_BKP20R_Pos   (0U)
#define TAMP_BKP20R_Msk   (0xFFFFFFFFUL << TAMP_BKP20R_Pos)
#define TAMP_BKP20R   TAMP_BKP20R_Msk
#define TAMP_BKP21R_Pos   (0U)
#define TAMP_BKP21R_Msk   (0xFFFFFFFFUL << TAMP_BKP21R_Pos)
#define TAMP_BKP21R   TAMP_BKP21R_Msk
#define TAMP_BKP22R_Pos   (0U)
#define TAMP_BKP22R_Msk   (0xFFFFFFFFUL << TAMP_BKP22R_Pos)
#define TAMP_BKP22R   TAMP_BKP22R_Msk
#define TAMP_BKP23R_Pos   (0U)
#define TAMP_BKP23R_Msk   (0xFFFFFFFFUL << TAMP_BKP23R_Pos)
#define TAMP_BKP23R   TAMP_BKP23R_Msk
#define TAMP_BKP24R_Pos   (0U)
#define TAMP_BKP24R_Msk   (0xFFFFFFFFUL << TAMP_BKP24R_Pos)
#define TAMP_BKP24R   TAMP_BKP24R_Msk
#define TAMP_BKP25R_Pos   (0U)
#define TAMP_BKP25R_Msk   (0xFFFFFFFFUL << TAMP_BKP25R_Pos)
#define TAMP_BKP25R   TAMP_BKP25R_Msk
#define TAMP_BKP26R_Pos   (0U)
#define TAMP_BKP26R_Msk   (0xFFFFFFFFUL << TAMP_BKP26R_Pos)
#define TAMP_BKP26R   TAMP_BKP26R_Msk
#define TAMP_BKP27R_Pos   (0U)
#define TAMP_BKP27R_Msk   (0xFFFFFFFFUL << TAMP_BKP27R_Pos)
#define TAMP_BKP27R   TAMP_BKP27R_Msk
#define TAMP_BKP28R_Pos   (0U)
#define TAMP_BKP28R_Msk   (0xFFFFFFFFUL << TAMP_BKP28R_Pos)
#define TAMP_BKP28R   TAMP_BKP28R_Msk
#define TAMP_BKP29R_Pos   (0U)
#define TAMP_BKP29R_Msk   (0xFFFFFFFFUL << TAMP_BKP29R_Pos)
#define TAMP_BKP29R   TAMP_BKP29R_Msk
#define TAMP_BKP30R_Pos   (0U)
#define TAMP_BKP30R_Msk   (0xFFFFFFFFUL << TAMP_BKP30R_Pos)
#define TAMP_BKP30R   TAMP_BKP30R_Msk
#define TAMP_BKP31R_Pos   (0U)
#define TAMP_BKP31R_Msk   (0xFFFFFFFFUL << TAMP_BKP31R_Pos)
#define TAMP_BKP31R   TAMP_BKP31R_Msk
#define TSC_CR_TSCE_Pos   (0U)
#define TSC_CR_TSCE_Msk   (0x1UL << TSC_CR_TSCE_Pos)
#define TSC_CR_TSCE   TSC_CR_TSCE_Msk
#define TSC_CR_START_Pos   (1U)
#define TSC_CR_START_Msk   (0x1UL << TSC_CR_START_Pos)
#define TSC_CR_START   TSC_CR_START_Msk
#define TSC_CR_AM_Pos   (2U)
#define TSC_CR_AM_Msk   (0x1UL << TSC_CR_AM_Pos)
#define TSC_CR_AM   TSC_CR_AM_Msk
#define TSC_CR_SYNCPOL_Pos   (3U)
#define TSC_CR_SYNCPOL_Msk   (0x1UL << TSC_CR_SYNCPOL_Pos)
#define TSC_CR_SYNCPOL   TSC_CR_SYNCPOL_Msk
#define TSC_CR_IODEF_Pos   (4U)
#define TSC_CR_IODEF_Msk   (0x1UL << TSC_CR_IODEF_Pos)
#define TSC_CR_IODEF   TSC_CR_IODEF_Msk
#define TSC_CR_MCV_Pos   (5U)
#define TSC_CR_MCV_Msk   (0x7UL << TSC_CR_MCV_Pos)
#define TSC_CR_MCV   TSC_CR_MCV_Msk
#define TSC_CR_MCV_0   (0x1UL << TSC_CR_MCV_Pos)
#define TSC_CR_MCV_1   (0x2UL << TSC_CR_MCV_Pos)
#define TSC_CR_MCV_2   (0x4UL << TSC_CR_MCV_Pos)
#define TSC_CR_PGPSC_Pos   (12U)
#define TSC_CR_PGPSC_Msk   (0x7UL << TSC_CR_PGPSC_Pos)
#define TSC_CR_PGPSC   TSC_CR_PGPSC_Msk
#define TSC_CR_PGPSC_0   (0x1UL << TSC_CR_PGPSC_Pos)
#define TSC_CR_PGPSC_1   (0x2UL << TSC_CR_PGPSC_Pos)
#define TSC_CR_PGPSC_2   (0x4UL << TSC_CR_PGPSC_Pos)
#define TSC_CR_SSPSC_Pos   (15U)
#define TSC_CR_SSPSC_Msk   (0x1UL << TSC_CR_SSPSC_Pos)
#define TSC_CR_SSPSC   TSC_CR_SSPSC_Msk
#define TSC_CR_SSE_Pos   (16U)
#define TSC_CR_SSE_Msk   (0x1UL << TSC_CR_SSE_Pos)
#define TSC_CR_SSE   TSC_CR_SSE_Msk
#define TSC_CR_SSD_Pos   (17U)
#define TSC_CR_SSD_Msk   (0x7FUL << TSC_CR_SSD_Pos)
#define TSC_CR_SSD   TSC_CR_SSD_Msk
#define TSC_CR_SSD_0   (0x01UL << TSC_CR_SSD_Pos)
#define TSC_CR_SSD_1   (0x02UL << TSC_CR_SSD_Pos)
#define TSC_CR_SSD_2   (0x04UL << TSC_CR_SSD_Pos)
#define TSC_CR_SSD_3   (0x08UL << TSC_CR_SSD_Pos)
#define TSC_CR_SSD_4   (0x10UL << TSC_CR_SSD_Pos)
#define TSC_CR_SSD_5   (0x20UL << TSC_CR_SSD_Pos)
#define TSC_CR_SSD_6   (0x40UL << TSC_CR_SSD_Pos)
#define TSC_CR_CTPL_Pos   (24U)
#define TSC_CR_CTPL_Msk   (0xFUL << TSC_CR_CTPL_Pos)
#define TSC_CR_CTPL   TSC_CR_CTPL_Msk
#define TSC_CR_CTPL_0   (0x1UL << TSC_CR_CTPL_Pos)
#define TSC_CR_CTPL_1   (0x2UL << TSC_CR_CTPL_Pos)
#define TSC_CR_CTPL_2   (0x4UL << TSC_CR_CTPL_Pos)
#define TSC_CR_CTPL_3   (0x8UL << TSC_CR_CTPL_Pos)
#define TSC_CR_CTPH_Pos   (28U)
#define TSC_CR_CTPH_Msk   (0xFUL << TSC_CR_CTPH_Pos)
#define TSC_CR_CTPH   TSC_CR_CTPH_Msk
#define TSC_CR_CTPH_0   (0x1UL << TSC_CR_CTPH_Pos)
#define TSC_CR_CTPH_1   (0x2UL << TSC_CR_CTPH_Pos)
#define TSC_CR_CTPH_2   (0x4UL << TSC_CR_CTPH_Pos)
#define TSC_CR_CTPH_3   (0x8UL << TSC_CR_CTPH_Pos)
#define TSC_IER_EOAIE_Pos   (0U)
#define TSC_IER_EOAIE_Msk   (0x1UL << TSC_IER_EOAIE_Pos)
#define TSC_IER_EOAIE   TSC_IER_EOAIE_Msk
#define TSC_IER_MCEIE_Pos   (1U)
#define TSC_IER_MCEIE_Msk   (0x1UL << TSC_IER_MCEIE_Pos)
#define TSC_IER_MCEIE   TSC_IER_MCEIE_Msk
#define TSC_ICR_EOAIC_Pos   (0U)
#define TSC_ICR_EOAIC_Msk   (0x1UL << TSC_ICR_EOAIC_Pos)
#define TSC_ICR_EOAIC   TSC_ICR_EOAIC_Msk
#define TSC_ICR_MCEIC_Pos   (1U)
#define TSC_ICR_MCEIC_Msk   (0x1UL << TSC_ICR_MCEIC_Pos)
#define TSC_ICR_MCEIC   TSC_ICR_MCEIC_Msk
#define TSC_ISR_EOAF_Pos   (0U)
#define TSC_ISR_EOAF_Msk   (0x1UL << TSC_ISR_EOAF_Pos)
#define TSC_ISR_EOAF   TSC_ISR_EOAF_Msk
#define TSC_ISR_MCEF_Pos   (1U)
#define TSC_ISR_MCEF_Msk   (0x1UL << TSC_ISR_MCEF_Pos)
#define TSC_ISR_MCEF   TSC_ISR_MCEF_Msk
#define TSC_IOHCR_G1_IO1_Pos   (0U)
#define TSC_IOHCR_G1_IO1_Msk   (0x1UL << TSC_IOHCR_G1_IO1_Pos)
#define TSC_IOHCR_G1_IO1   TSC_IOHCR_G1_IO1_Msk
#define TSC_IOHCR_G1_IO2_Pos   (1U)
#define TSC_IOHCR_G1_IO2_Msk   (0x1UL << TSC_IOHCR_G1_IO2_Pos)
#define TSC_IOHCR_G1_IO2   TSC_IOHCR_G1_IO2_Msk
#define TSC_IOHCR_G1_IO3_Pos   (2U)
#define TSC_IOHCR_G1_IO3_Msk   (0x1UL << TSC_IOHCR_G1_IO3_Pos)
#define TSC_IOHCR_G1_IO3   TSC_IOHCR_G1_IO3_Msk
#define TSC_IOHCR_G1_IO4_Pos   (3U)
#define TSC_IOHCR_G1_IO4_Msk   (0x1UL << TSC_IOHCR_G1_IO4_Pos)
#define TSC_IOHCR_G1_IO4   TSC_IOHCR_G1_IO4_Msk
#define TSC_IOHCR_G2_IO1_Pos   (4U)
#define TSC_IOHCR_G2_IO1_Msk   (0x1UL << TSC_IOHCR_G2_IO1_Pos)
#define TSC_IOHCR_G2_IO1   TSC_IOHCR_G2_IO1_Msk
#define TSC_IOHCR_G2_IO2_Pos   (5U)
#define TSC_IOHCR_G2_IO2_Msk   (0x1UL << TSC_IOHCR_G2_IO2_Pos)
#define TSC_IOHCR_G2_IO2   TSC_IOHCR_G2_IO2_Msk
#define TSC_IOHCR_G2_IO3_Pos   (6U)
#define TSC_IOHCR_G2_IO3_Msk   (0x1UL << TSC_IOHCR_G2_IO3_Pos)
#define TSC_IOHCR_G2_IO3   TSC_IOHCR_G2_IO3_Msk
#define TSC_IOHCR_G2_IO4_Pos   (7U)
#define TSC_IOHCR_G2_IO4_Msk   (0x1UL << TSC_IOHCR_G2_IO4_Pos)
#define TSC_IOHCR_G2_IO4   TSC_IOHCR_G2_IO4_Msk
#define TSC_IOHCR_G3_IO1_Pos   (8U)
#define TSC_IOHCR_G3_IO1_Msk   (0x1UL << TSC_IOHCR_G3_IO1_Pos)
#define TSC_IOHCR_G3_IO1   TSC_IOHCR_G3_IO1_Msk
#define TSC_IOHCR_G3_IO2_Pos   (9U)
#define TSC_IOHCR_G3_IO2_Msk   (0x1UL << TSC_IOHCR_G3_IO2_Pos)
#define TSC_IOHCR_G3_IO2   TSC_IOHCR_G3_IO2_Msk
#define TSC_IOHCR_G3_IO3_Pos   (10U)
#define TSC_IOHCR_G3_IO3_Msk   (0x1UL << TSC_IOHCR_G3_IO3_Pos)
#define TSC_IOHCR_G3_IO3   TSC_IOHCR_G3_IO3_Msk
#define TSC_IOHCR_G3_IO4_Pos   (11U)
#define TSC_IOHCR_G3_IO4_Msk   (0x1UL << TSC_IOHCR_G3_IO4_Pos)
#define TSC_IOHCR_G3_IO4   TSC_IOHCR_G3_IO4_Msk
#define TSC_IOHCR_G4_IO1_Pos   (12U)
#define TSC_IOHCR_G4_IO1_Msk   (0x1UL << TSC_IOHCR_G4_IO1_Pos)
#define TSC_IOHCR_G4_IO1   TSC_IOHCR_G4_IO1_Msk
#define TSC_IOHCR_G4_IO2_Pos   (13U)
#define TSC_IOHCR_G4_IO2_Msk   (0x1UL << TSC_IOHCR_G4_IO2_Pos)
#define TSC_IOHCR_G4_IO2   TSC_IOHCR_G4_IO2_Msk
#define TSC_IOHCR_G4_IO3_Pos   (14U)
#define TSC_IOHCR_G4_IO3_Msk   (0x1UL << TSC_IOHCR_G4_IO3_Pos)
#define TSC_IOHCR_G4_IO3   TSC_IOHCR_G4_IO3_Msk
#define TSC_IOHCR_G4_IO4_Pos   (15U)
#define TSC_IOHCR_G4_IO4_Msk   (0x1UL << TSC_IOHCR_G4_IO4_Pos)
#define TSC_IOHCR_G4_IO4   TSC_IOHCR_G4_IO4_Msk
#define TSC_IOHCR_G5_IO1_Pos   (16U)
#define TSC_IOHCR_G5_IO1_Msk   (0x1UL << TSC_IOHCR_G5_IO1_Pos)
#define TSC_IOHCR_G5_IO1   TSC_IOHCR_G5_IO1_Msk
#define TSC_IOHCR_G5_IO2_Pos   (17U)
#define TSC_IOHCR_G5_IO2_Msk   (0x1UL << TSC_IOHCR_G5_IO2_Pos)
#define TSC_IOHCR_G5_IO2   TSC_IOHCR_G5_IO2_Msk
#define TSC_IOHCR_G5_IO3_Pos   (18U)
#define TSC_IOHCR_G5_IO3_Msk   (0x1UL << TSC_IOHCR_G5_IO3_Pos)
#define TSC_IOHCR_G5_IO3   TSC_IOHCR_G5_IO3_Msk
#define TSC_IOHCR_G5_IO4_Pos   (19U)
#define TSC_IOHCR_G5_IO4_Msk   (0x1UL << TSC_IOHCR_G5_IO4_Pos)
#define TSC_IOHCR_G5_IO4   TSC_IOHCR_G5_IO4_Msk
#define TSC_IOHCR_G6_IO1_Pos   (20U)
#define TSC_IOHCR_G6_IO1_Msk   (0x1UL << TSC_IOHCR_G6_IO1_Pos)
#define TSC_IOHCR_G6_IO1   TSC_IOHCR_G6_IO1_Msk
#define TSC_IOHCR_G6_IO2_Pos   (21U)
#define TSC_IOHCR_G6_IO2_Msk   (0x1UL << TSC_IOHCR_G6_IO2_Pos)
#define TSC_IOHCR_G6_IO2   TSC_IOHCR_G6_IO2_Msk
#define TSC_IOHCR_G6_IO3_Pos   (22U)
#define TSC_IOHCR_G6_IO3_Msk   (0x1UL << TSC_IOHCR_G6_IO3_Pos)
#define TSC_IOHCR_G6_IO3   TSC_IOHCR_G6_IO3_Msk
#define TSC_IOHCR_G6_IO4_Pos   (23U)
#define TSC_IOHCR_G6_IO4_Msk   (0x1UL << TSC_IOHCR_G6_IO4_Pos)
#define TSC_IOHCR_G6_IO4   TSC_IOHCR_G6_IO4_Msk
#define TSC_IOHCR_G7_IO1_Pos   (24U)
#define TSC_IOHCR_G7_IO1_Msk   (0x1UL << TSC_IOHCR_G7_IO1_Pos)
#define TSC_IOHCR_G7_IO1   TSC_IOHCR_G7_IO1_Msk
#define TSC_IOHCR_G7_IO2_Pos   (25U)
#define TSC_IOHCR_G7_IO2_Msk   (0x1UL << TSC_IOHCR_G7_IO2_Pos)
#define TSC_IOHCR_G7_IO2   TSC_IOHCR_G7_IO2_Msk
#define TSC_IOHCR_G7_IO3_Pos   (26U)
#define TSC_IOHCR_G7_IO3_Msk   (0x1UL << TSC_IOHCR_G7_IO3_Pos)
#define TSC_IOHCR_G7_IO3   TSC_IOHCR_G7_IO3_Msk
#define TSC_IOHCR_G7_IO4_Pos   (27U)
#define TSC_IOHCR_G7_IO4_Msk   (0x1UL << TSC_IOHCR_G7_IO4_Pos)
#define TSC_IOHCR_G7_IO4   TSC_IOHCR_G7_IO4_Msk
#define TSC_IOHCR_G8_IO1_Pos   (28U)
#define TSC_IOHCR_G8_IO1_Msk   (0x1UL << TSC_IOHCR_G8_IO1_Pos)
#define TSC_IOHCR_G8_IO1   TSC_IOHCR_G8_IO1_Msk
#define TSC_IOHCR_G8_IO2_Pos   (29U)
#define TSC_IOHCR_G8_IO2_Msk   (0x1UL << TSC_IOHCR_G8_IO2_Pos)
#define TSC_IOHCR_G8_IO2   TSC_IOHCR_G8_IO2_Msk
#define TSC_IOHCR_G8_IO3_Pos   (30U)
#define TSC_IOHCR_G8_IO3_Msk   (0x1UL << TSC_IOHCR_G8_IO3_Pos)
#define TSC_IOHCR_G8_IO3   TSC_IOHCR_G8_IO3_Msk
#define TSC_IOHCR_G8_IO4_Pos   (31U)
#define TSC_IOHCR_G8_IO4_Msk   (0x1UL << TSC_IOHCR_G8_IO4_Pos)
#define TSC_IOHCR_G8_IO4   TSC_IOHCR_G8_IO4_Msk
#define TSC_IOASCR_G1_IO1_Pos   (0U)
#define TSC_IOASCR_G1_IO1_Msk   (0x1UL << TSC_IOASCR_G1_IO1_Pos)
#define TSC_IOASCR_G1_IO1   TSC_IOASCR_G1_IO1_Msk
#define TSC_IOASCR_G1_IO2_Pos   (1U)
#define TSC_IOASCR_G1_IO2_Msk   (0x1UL << TSC_IOASCR_G1_IO2_Pos)
#define TSC_IOASCR_G1_IO2   TSC_IOASCR_G1_IO2_Msk
#define TSC_IOASCR_G1_IO3_Pos   (2U)
#define TSC_IOASCR_G1_IO3_Msk   (0x1UL << TSC_IOASCR_G1_IO3_Pos)
#define TSC_IOASCR_G1_IO3   TSC_IOASCR_G1_IO3_Msk
#define TSC_IOASCR_G1_IO4_Pos   (3U)
#define TSC_IOASCR_G1_IO4_Msk   (0x1UL << TSC_IOASCR_G1_IO4_Pos)
#define TSC_IOASCR_G1_IO4   TSC_IOASCR_G1_IO4_Msk
#define TSC_IOASCR_G2_IO1_Pos   (4U)
#define TSC_IOASCR_G2_IO1_Msk   (0x1UL << TSC_IOASCR_G2_IO1_Pos)
#define TSC_IOASCR_G2_IO1   TSC_IOASCR_G2_IO1_Msk
#define TSC_IOASCR_G2_IO2_Pos   (5U)
#define TSC_IOASCR_G2_IO2_Msk   (0x1UL << TSC_IOASCR_G2_IO2_Pos)
#define TSC_IOASCR_G2_IO2   TSC_IOASCR_G2_IO2_Msk
#define TSC_IOASCR_G2_IO3_Pos   (6U)
#define TSC_IOASCR_G2_IO3_Msk   (0x1UL << TSC_IOASCR_G2_IO3_Pos)
#define TSC_IOASCR_G2_IO3   TSC_IOASCR_G2_IO3_Msk
#define TSC_IOASCR_G2_IO4_Pos   (7U)
#define TSC_IOASCR_G2_IO4_Msk   (0x1UL << TSC_IOASCR_G2_IO4_Pos)
#define TSC_IOASCR_G2_IO4   TSC_IOASCR_G2_IO4_Msk
#define TSC_IOASCR_G3_IO1_Pos   (8U)
#define TSC_IOASCR_G3_IO1_Msk   (0x1UL << TSC_IOASCR_G3_IO1_Pos)
#define TSC_IOASCR_G3_IO1   TSC_IOASCR_G3_IO1_Msk
#define TSC_IOASCR_G3_IO2_Pos   (9U)
#define TSC_IOASCR_G3_IO2_Msk   (0x1UL << TSC_IOASCR_G3_IO2_Pos)
#define TSC_IOASCR_G3_IO2   TSC_IOASCR_G3_IO2_Msk
#define TSC_IOASCR_G3_IO3_Pos   (10U)
#define TSC_IOASCR_G3_IO3_Msk   (0x1UL << TSC_IOASCR_G3_IO3_Pos)
#define TSC_IOASCR_G3_IO3   TSC_IOASCR_G3_IO3_Msk
#define TSC_IOASCR_G3_IO4_Pos   (11U)
#define TSC_IOASCR_G3_IO4_Msk   (0x1UL << TSC_IOASCR_G3_IO4_Pos)
#define TSC_IOASCR_G3_IO4   TSC_IOASCR_G3_IO4_Msk
#define TSC_IOASCR_G4_IO1_Pos   (12U)
#define TSC_IOASCR_G4_IO1_Msk   (0x1UL << TSC_IOASCR_G4_IO1_Pos)
#define TSC_IOASCR_G4_IO1   TSC_IOASCR_G4_IO1_Msk
#define TSC_IOASCR_G4_IO2_Pos   (13U)
#define TSC_IOASCR_G4_IO2_Msk   (0x1UL << TSC_IOASCR_G4_IO2_Pos)
#define TSC_IOASCR_G4_IO2   TSC_IOASCR_G4_IO2_Msk
#define TSC_IOASCR_G4_IO3_Pos   (14U)
#define TSC_IOASCR_G4_IO3_Msk   (0x1UL << TSC_IOASCR_G4_IO3_Pos)
#define TSC_IOASCR_G4_IO3   TSC_IOASCR_G4_IO3_Msk
#define TSC_IOASCR_G4_IO4_Pos   (15U)
#define TSC_IOASCR_G4_IO4_Msk   (0x1UL << TSC_IOASCR_G4_IO4_Pos)
#define TSC_IOASCR_G4_IO4   TSC_IOASCR_G4_IO4_Msk
#define TSC_IOASCR_G5_IO1_Pos   (16U)
#define TSC_IOASCR_G5_IO1_Msk   (0x1UL << TSC_IOASCR_G5_IO1_Pos)
#define TSC_IOASCR_G5_IO1   TSC_IOASCR_G5_IO1_Msk
#define TSC_IOASCR_G5_IO2_Pos   (17U)
#define TSC_IOASCR_G5_IO2_Msk   (0x1UL << TSC_IOASCR_G5_IO2_Pos)
#define TSC_IOASCR_G5_IO2   TSC_IOASCR_G5_IO2_Msk
#define TSC_IOASCR_G5_IO3_Pos   (18U)
#define TSC_IOASCR_G5_IO3_Msk   (0x1UL << TSC_IOASCR_G5_IO3_Pos)
#define TSC_IOASCR_G5_IO3   TSC_IOASCR_G5_IO3_Msk
#define TSC_IOASCR_G5_IO4_Pos   (19U)
#define TSC_IOASCR_G5_IO4_Msk   (0x1UL << TSC_IOASCR_G5_IO4_Pos)
#define TSC_IOASCR_G5_IO4   TSC_IOASCR_G5_IO4_Msk
#define TSC_IOASCR_G6_IO1_Pos   (20U)
#define TSC_IOASCR_G6_IO1_Msk   (0x1UL << TSC_IOASCR_G6_IO1_Pos)
#define TSC_IOASCR_G6_IO1   TSC_IOASCR_G6_IO1_Msk
#define TSC_IOASCR_G6_IO2_Pos   (21U)
#define TSC_IOASCR_G6_IO2_Msk   (0x1UL << TSC_IOASCR_G6_IO2_Pos)
#define TSC_IOASCR_G6_IO2   TSC_IOASCR_G6_IO2_Msk
#define TSC_IOASCR_G6_IO3_Pos   (22U)
#define TSC_IOASCR_G6_IO3_Msk   (0x1UL << TSC_IOASCR_G6_IO3_Pos)
#define TSC_IOASCR_G6_IO3   TSC_IOASCR_G6_IO3_Msk
#define TSC_IOASCR_G6_IO4_Pos   (23U)
#define TSC_IOASCR_G6_IO4_Msk   (0x1UL << TSC_IOASCR_G6_IO4_Pos)
#define TSC_IOASCR_G6_IO4   TSC_IOASCR_G6_IO4_Msk
#define TSC_IOASCR_G7_IO1_Pos   (24U)
#define TSC_IOASCR_G7_IO1_Msk   (0x1UL << TSC_IOASCR_G7_IO1_Pos)
#define TSC_IOASCR_G7_IO1   TSC_IOASCR_G7_IO1_Msk
#define TSC_IOASCR_G7_IO2_Pos   (25U)
#define TSC_IOASCR_G7_IO2_Msk   (0x1UL << TSC_IOASCR_G7_IO2_Pos)
#define TSC_IOASCR_G7_IO2   TSC_IOASCR_G7_IO2_Msk
#define TSC_IOASCR_G7_IO3_Pos   (26U)
#define TSC_IOASCR_G7_IO3_Msk   (0x1UL << TSC_IOASCR_G7_IO3_Pos)
#define TSC_IOASCR_G7_IO3   TSC_IOASCR_G7_IO3_Msk
#define TSC_IOASCR_G7_IO4_Pos   (27U)
#define TSC_IOASCR_G7_IO4_Msk   (0x1UL << TSC_IOASCR_G7_IO4_Pos)
#define TSC_IOASCR_G7_IO4   TSC_IOASCR_G7_IO4_Msk
#define TSC_IOASCR_G8_IO1_Pos   (28U)
#define TSC_IOASCR_G8_IO1_Msk   (0x1UL << TSC_IOASCR_G8_IO1_Pos)
#define TSC_IOASCR_G8_IO1   TSC_IOASCR_G8_IO1_Msk
#define TSC_IOASCR_G8_IO2_Pos   (29U)
#define TSC_IOASCR_G8_IO2_Msk   (0x1UL << TSC_IOASCR_G8_IO2_Pos)
#define TSC_IOASCR_G8_IO2   TSC_IOASCR_G8_IO2_Msk
#define TSC_IOASCR_G8_IO3_Pos   (30U)
#define TSC_IOASCR_G8_IO3_Msk   (0x1UL << TSC_IOASCR_G8_IO3_Pos)
#define TSC_IOASCR_G8_IO3   TSC_IOASCR_G8_IO3_Msk
#define TSC_IOASCR_G8_IO4_Pos   (31U)
#define TSC_IOASCR_G8_IO4_Msk   (0x1UL << TSC_IOASCR_G8_IO4_Pos)
#define TSC_IOASCR_G8_IO4   TSC_IOASCR_G8_IO4_Msk
#define TSC_IOSCR_G1_IO1_Pos   (0U)
#define TSC_IOSCR_G1_IO1_Msk   (0x1UL << TSC_IOSCR_G1_IO1_Pos)
#define TSC_IOSCR_G1_IO1   TSC_IOSCR_G1_IO1_Msk
#define TSC_IOSCR_G1_IO2_Pos   (1U)
#define TSC_IOSCR_G1_IO2_Msk   (0x1UL << TSC_IOSCR_G1_IO2_Pos)
#define TSC_IOSCR_G1_IO2   TSC_IOSCR_G1_IO2_Msk
#define TSC_IOSCR_G1_IO3_Pos   (2U)
#define TSC_IOSCR_G1_IO3_Msk   (0x1UL << TSC_IOSCR_G1_IO3_Pos)
#define TSC_IOSCR_G1_IO3   TSC_IOSCR_G1_IO3_Msk
#define TSC_IOSCR_G1_IO4_Pos   (3U)
#define TSC_IOSCR_G1_IO4_Msk   (0x1UL << TSC_IOSCR_G1_IO4_Pos)
#define TSC_IOSCR_G1_IO4   TSC_IOSCR_G1_IO4_Msk
#define TSC_IOSCR_G2_IO1_Pos   (4U)
#define TSC_IOSCR_G2_IO1_Msk   (0x1UL << TSC_IOSCR_G2_IO1_Pos)
#define TSC_IOSCR_G2_IO1   TSC_IOSCR_G2_IO1_Msk
#define TSC_IOSCR_G2_IO2_Pos   (5U)
#define TSC_IOSCR_G2_IO2_Msk   (0x1UL << TSC_IOSCR_G2_IO2_Pos)
#define TSC_IOSCR_G2_IO2   TSC_IOSCR_G2_IO2_Msk
#define TSC_IOSCR_G2_IO3_Pos   (6U)
#define TSC_IOSCR_G2_IO3_Msk   (0x1UL << TSC_IOSCR_G2_IO3_Pos)
#define TSC_IOSCR_G2_IO3   TSC_IOSCR_G2_IO3_Msk
#define TSC_IOSCR_G2_IO4_Pos   (7U)
#define TSC_IOSCR_G2_IO4_Msk   (0x1UL << TSC_IOSCR_G2_IO4_Pos)
#define TSC_IOSCR_G2_IO4   TSC_IOSCR_G2_IO4_Msk
#define TSC_IOSCR_G3_IO1_Pos   (8U)
#define TSC_IOSCR_G3_IO1_Msk   (0x1UL << TSC_IOSCR_G3_IO1_Pos)
#define TSC_IOSCR_G3_IO1   TSC_IOSCR_G3_IO1_Msk
#define TSC_IOSCR_G3_IO2_Pos   (9U)
#define TSC_IOSCR_G3_IO2_Msk   (0x1UL << TSC_IOSCR_G3_IO2_Pos)
#define TSC_IOSCR_G3_IO2   TSC_IOSCR_G3_IO2_Msk
#define TSC_IOSCR_G3_IO3_Pos   (10U)
#define TSC_IOSCR_G3_IO3_Msk   (0x1UL << TSC_IOSCR_G3_IO3_Pos)
#define TSC_IOSCR_G3_IO3   TSC_IOSCR_G3_IO3_Msk
#define TSC_IOSCR_G3_IO4_Pos   (11U)
#define TSC_IOSCR_G3_IO4_Msk   (0x1UL << TSC_IOSCR_G3_IO4_Pos)
#define TSC_IOSCR_G3_IO4   TSC_IOSCR_G3_IO4_Msk
#define TSC_IOSCR_G4_IO1_Pos   (12U)
#define TSC_IOSCR_G4_IO1_Msk   (0x1UL << TSC_IOSCR_G4_IO1_Pos)
#define TSC_IOSCR_G4_IO1   TSC_IOSCR_G4_IO1_Msk
#define TSC_IOSCR_G4_IO2_Pos   (13U)
#define TSC_IOSCR_G4_IO2_Msk   (0x1UL << TSC_IOSCR_G4_IO2_Pos)
#define TSC_IOSCR_G4_IO2   TSC_IOSCR_G4_IO2_Msk
#define TSC_IOSCR_G4_IO3_Pos   (14U)
#define TSC_IOSCR_G4_IO3_Msk   (0x1UL << TSC_IOSCR_G4_IO3_Pos)
#define TSC_IOSCR_G4_IO3   TSC_IOSCR_G4_IO3_Msk
#define TSC_IOSCR_G4_IO4_Pos   (15U)
#define TSC_IOSCR_G4_IO4_Msk   (0x1UL << TSC_IOSCR_G4_IO4_Pos)
#define TSC_IOSCR_G4_IO4   TSC_IOSCR_G4_IO4_Msk
#define TSC_IOSCR_G5_IO1_Pos   (16U)
#define TSC_IOSCR_G5_IO1_Msk   (0x1UL << TSC_IOSCR_G5_IO1_Pos)
#define TSC_IOSCR_G5_IO1   TSC_IOSCR_G5_IO1_Msk
#define TSC_IOSCR_G5_IO2_Pos   (17U)
#define TSC_IOSCR_G5_IO2_Msk   (0x1UL << TSC_IOSCR_G5_IO2_Pos)
#define TSC_IOSCR_G5_IO2   TSC_IOSCR_G5_IO2_Msk
#define TSC_IOSCR_G5_IO3_Pos   (18U)
#define TSC_IOSCR_G5_IO3_Msk   (0x1UL << TSC_IOSCR_G5_IO3_Pos)
#define TSC_IOSCR_G5_IO3   TSC_IOSCR_G5_IO3_Msk
#define TSC_IOSCR_G5_IO4_Pos   (19U)
#define TSC_IOSCR_G5_IO4_Msk   (0x1UL << TSC_IOSCR_G5_IO4_Pos)
#define TSC_IOSCR_G5_IO4   TSC_IOSCR_G5_IO4_Msk
#define TSC_IOSCR_G6_IO1_Pos   (20U)
#define TSC_IOSCR_G6_IO1_Msk   (0x1UL << TSC_IOSCR_G6_IO1_Pos)
#define TSC_IOSCR_G6_IO1   TSC_IOSCR_G6_IO1_Msk
#define TSC_IOSCR_G6_IO2_Pos   (21U)
#define TSC_IOSCR_G6_IO2_Msk   (0x1UL << TSC_IOSCR_G6_IO2_Pos)
#define TSC_IOSCR_G6_IO2   TSC_IOSCR_G6_IO2_Msk
#define TSC_IOSCR_G6_IO3_Pos   (22U)
#define TSC_IOSCR_G6_IO3_Msk   (0x1UL << TSC_IOSCR_G6_IO3_Pos)
#define TSC_IOSCR_G6_IO3   TSC_IOSCR_G6_IO3_Msk
#define TSC_IOSCR_G6_IO4_Pos   (23U)
#define TSC_IOSCR_G6_IO4_Msk   (0x1UL << TSC_IOSCR_G6_IO4_Pos)
#define TSC_IOSCR_G6_IO4   TSC_IOSCR_G6_IO4_Msk
#define TSC_IOSCR_G7_IO1_Pos   (24U)
#define TSC_IOSCR_G7_IO1_Msk   (0x1UL << TSC_IOSCR_G7_IO1_Pos)
#define TSC_IOSCR_G7_IO1   TSC_IOSCR_G7_IO1_Msk
#define TSC_IOSCR_G7_IO2_Pos   (25U)
#define TSC_IOSCR_G7_IO2_Msk   (0x1UL << TSC_IOSCR_G7_IO2_Pos)
#define TSC_IOSCR_G7_IO2   TSC_IOSCR_G7_IO2_Msk
#define TSC_IOSCR_G7_IO3_Pos   (26U)
#define TSC_IOSCR_G7_IO3_Msk   (0x1UL << TSC_IOSCR_G7_IO3_Pos)
#define TSC_IOSCR_G7_IO3   TSC_IOSCR_G7_IO3_Msk
#define TSC_IOSCR_G7_IO4_Pos   (27U)
#define TSC_IOSCR_G7_IO4_Msk   (0x1UL << TSC_IOSCR_G7_IO4_Pos)
#define TSC_IOSCR_G7_IO4   TSC_IOSCR_G7_IO4_Msk
#define TSC_IOSCR_G8_IO1_Pos   (28U)
#define TSC_IOSCR_G8_IO1_Msk   (0x1UL << TSC_IOSCR_G8_IO1_Pos)
#define TSC_IOSCR_G8_IO1   TSC_IOSCR_G8_IO1_Msk
#define TSC_IOSCR_G8_IO2_Pos   (29U)
#define TSC_IOSCR_G8_IO2_Msk   (0x1UL << TSC_IOSCR_G8_IO2_Pos)
#define TSC_IOSCR_G8_IO2   TSC_IOSCR_G8_IO2_Msk
#define TSC_IOSCR_G8_IO3_Pos   (30U)
#define TSC_IOSCR_G8_IO3_Msk   (0x1UL << TSC_IOSCR_G8_IO3_Pos)
#define TSC_IOSCR_G8_IO3   TSC_IOSCR_G8_IO3_Msk
#define TSC_IOSCR_G8_IO4_Pos   (31U)
#define TSC_IOSCR_G8_IO4_Msk   (0x1UL << TSC_IOSCR_G8_IO4_Pos)
#define TSC_IOSCR_G8_IO4   TSC_IOSCR_G8_IO4_Msk
#define TSC_IOCCR_G1_IO1_Pos   (0U)
#define TSC_IOCCR_G1_IO1_Msk   (0x1UL << TSC_IOCCR_G1_IO1_Pos)
#define TSC_IOCCR_G1_IO1   TSC_IOCCR_G1_IO1_Msk
#define TSC_IOCCR_G1_IO2_Pos   (1U)
#define TSC_IOCCR_G1_IO2_Msk   (0x1UL << TSC_IOCCR_G1_IO2_Pos)
#define TSC_IOCCR_G1_IO2   TSC_IOCCR_G1_IO2_Msk
#define TSC_IOCCR_G1_IO3_Pos   (2U)
#define TSC_IOCCR_G1_IO3_Msk   (0x1UL << TSC_IOCCR_G1_IO3_Pos)
#define TSC_IOCCR_G1_IO3   TSC_IOCCR_G1_IO3_Msk
#define TSC_IOCCR_G1_IO4_Pos   (3U)
#define TSC_IOCCR_G1_IO4_Msk   (0x1UL << TSC_IOCCR_G1_IO4_Pos)
#define TSC_IOCCR_G1_IO4   TSC_IOCCR_G1_IO4_Msk
#define TSC_IOCCR_G2_IO1_Pos   (4U)
#define TSC_IOCCR_G2_IO1_Msk   (0x1UL << TSC_IOCCR_G2_IO1_Pos)
#define TSC_IOCCR_G2_IO1   TSC_IOCCR_G2_IO1_Msk
#define TSC_IOCCR_G2_IO2_Pos   (5U)
#define TSC_IOCCR_G2_IO2_Msk   (0x1UL << TSC_IOCCR_G2_IO2_Pos)
#define TSC_IOCCR_G2_IO2   TSC_IOCCR_G2_IO2_Msk
#define TSC_IOCCR_G2_IO3_Pos   (6U)
#define TSC_IOCCR_G2_IO3_Msk   (0x1UL << TSC_IOCCR_G2_IO3_Pos)
#define TSC_IOCCR_G2_IO3   TSC_IOCCR_G2_IO3_Msk
#define TSC_IOCCR_G2_IO4_Pos   (7U)
#define TSC_IOCCR_G2_IO4_Msk   (0x1UL << TSC_IOCCR_G2_IO4_Pos)
#define TSC_IOCCR_G2_IO4   TSC_IOCCR_G2_IO4_Msk
#define TSC_IOCCR_G3_IO1_Pos   (8U)
#define TSC_IOCCR_G3_IO1_Msk   (0x1UL << TSC_IOCCR_G3_IO1_Pos)
#define TSC_IOCCR_G3_IO1   TSC_IOCCR_G3_IO1_Msk
#define TSC_IOCCR_G3_IO2_Pos   (9U)
#define TSC_IOCCR_G3_IO2_Msk   (0x1UL << TSC_IOCCR_G3_IO2_Pos)
#define TSC_IOCCR_G3_IO2   TSC_IOCCR_G3_IO2_Msk
#define TSC_IOCCR_G3_IO3_Pos   (10U)
#define TSC_IOCCR_G3_IO3_Msk   (0x1UL << TSC_IOCCR_G3_IO3_Pos)
#define TSC_IOCCR_G3_IO3   TSC_IOCCR_G3_IO3_Msk
#define TSC_IOCCR_G3_IO4_Pos   (11U)
#define TSC_IOCCR_G3_IO4_Msk   (0x1UL << TSC_IOCCR_G3_IO4_Pos)
#define TSC_IOCCR_G3_IO4   TSC_IOCCR_G3_IO4_Msk
#define TSC_IOCCR_G4_IO1_Pos   (12U)
#define TSC_IOCCR_G4_IO1_Msk   (0x1UL << TSC_IOCCR_G4_IO1_Pos)
#define TSC_IOCCR_G4_IO1   TSC_IOCCR_G4_IO1_Msk
#define TSC_IOCCR_G4_IO2_Pos   (13U)
#define TSC_IOCCR_G4_IO2_Msk   (0x1UL << TSC_IOCCR_G4_IO2_Pos)
#define TSC_IOCCR_G4_IO2   TSC_IOCCR_G4_IO2_Msk
#define TSC_IOCCR_G4_IO3_Pos   (14U)
#define TSC_IOCCR_G4_IO3_Msk   (0x1UL << TSC_IOCCR_G4_IO3_Pos)
#define TSC_IOCCR_G4_IO3   TSC_IOCCR_G4_IO3_Msk
#define TSC_IOCCR_G4_IO4_Pos   (15U)
#define TSC_IOCCR_G4_IO4_Msk   (0x1UL << TSC_IOCCR_G4_IO4_Pos)
#define TSC_IOCCR_G4_IO4   TSC_IOCCR_G4_IO4_Msk
#define TSC_IOCCR_G5_IO1_Pos   (16U)
#define TSC_IOCCR_G5_IO1_Msk   (0x1UL << TSC_IOCCR_G5_IO1_Pos)
#define TSC_IOCCR_G5_IO1   TSC_IOCCR_G5_IO1_Msk
#define TSC_IOCCR_G5_IO2_Pos   (17U)
#define TSC_IOCCR_G5_IO2_Msk   (0x1UL << TSC_IOCCR_G5_IO2_Pos)
#define TSC_IOCCR_G5_IO2   TSC_IOCCR_G5_IO2_Msk
#define TSC_IOCCR_G5_IO3_Pos   (18U)
#define TSC_IOCCR_G5_IO3_Msk   (0x1UL << TSC_IOCCR_G5_IO3_Pos)
#define TSC_IOCCR_G5_IO3   TSC_IOCCR_G5_IO3_Msk
#define TSC_IOCCR_G5_IO4_Pos   (19U)
#define TSC_IOCCR_G5_IO4_Msk   (0x1UL << TSC_IOCCR_G5_IO4_Pos)
#define TSC_IOCCR_G5_IO4   TSC_IOCCR_G5_IO4_Msk
#define TSC_IOCCR_G6_IO1_Pos   (20U)
#define TSC_IOCCR_G6_IO1_Msk   (0x1UL << TSC_IOCCR_G6_IO1_Pos)
#define TSC_IOCCR_G6_IO1   TSC_IOCCR_G6_IO1_Msk
#define TSC_IOCCR_G6_IO2_Pos   (21U)
#define TSC_IOCCR_G6_IO2_Msk   (0x1UL << TSC_IOCCR_G6_IO2_Pos)
#define TSC_IOCCR_G6_IO2   TSC_IOCCR_G6_IO2_Msk
#define TSC_IOCCR_G6_IO3_Pos   (22U)
#define TSC_IOCCR_G6_IO3_Msk   (0x1UL << TSC_IOCCR_G6_IO3_Pos)
#define TSC_IOCCR_G6_IO3   TSC_IOCCR_G6_IO3_Msk
#define TSC_IOCCR_G6_IO4_Pos   (23U)
#define TSC_IOCCR_G6_IO4_Msk   (0x1UL << TSC_IOCCR_G6_IO4_Pos)
#define TSC_IOCCR_G6_IO4   TSC_IOCCR_G6_IO4_Msk
#define TSC_IOCCR_G7_IO1_Pos   (24U)
#define TSC_IOCCR_G7_IO1_Msk   (0x1UL << TSC_IOCCR_G7_IO1_Pos)
#define TSC_IOCCR_G7_IO1   TSC_IOCCR_G7_IO1_Msk
#define TSC_IOCCR_G7_IO2_Pos   (25U)
#define TSC_IOCCR_G7_IO2_Msk   (0x1UL << TSC_IOCCR_G7_IO2_Pos)
#define TSC_IOCCR_G7_IO2   TSC_IOCCR_G7_IO2_Msk
#define TSC_IOCCR_G7_IO3_Pos   (26U)
#define TSC_IOCCR_G7_IO3_Msk   (0x1UL << TSC_IOCCR_G7_IO3_Pos)
#define TSC_IOCCR_G7_IO3   TSC_IOCCR_G7_IO3_Msk
#define TSC_IOCCR_G7_IO4_Pos   (27U)
#define TSC_IOCCR_G7_IO4_Msk   (0x1UL << TSC_IOCCR_G7_IO4_Pos)
#define TSC_IOCCR_G7_IO4   TSC_IOCCR_G7_IO4_Msk
#define TSC_IOCCR_G8_IO1_Pos   (28U)
#define TSC_IOCCR_G8_IO1_Msk   (0x1UL << TSC_IOCCR_G8_IO1_Pos)
#define TSC_IOCCR_G8_IO1   TSC_IOCCR_G8_IO1_Msk
#define TSC_IOCCR_G8_IO2_Pos   (29U)
#define TSC_IOCCR_G8_IO2_Msk   (0x1UL << TSC_IOCCR_G8_IO2_Pos)
#define TSC_IOCCR_G8_IO2   TSC_IOCCR_G8_IO2_Msk
#define TSC_IOCCR_G8_IO3_Pos   (30U)
#define TSC_IOCCR_G8_IO3_Msk   (0x1UL << TSC_IOCCR_G8_IO3_Pos)
#define TSC_IOCCR_G8_IO3   TSC_IOCCR_G8_IO3_Msk
#define TSC_IOCCR_G8_IO4_Pos   (31U)
#define TSC_IOCCR_G8_IO4_Msk   (0x1UL << TSC_IOCCR_G8_IO4_Pos)
#define TSC_IOCCR_G8_IO4   TSC_IOCCR_G8_IO4_Msk
#define TSC_IOGCSR_G1E_Pos   (0U)
#define TSC_IOGCSR_G1E_Msk   (0x1UL << TSC_IOGCSR_G1E_Pos)
#define TSC_IOGCSR_G1E   TSC_IOGCSR_G1E_Msk
#define TSC_IOGCSR_G2E_Pos   (1U)
#define TSC_IOGCSR_G2E_Msk   (0x1UL << TSC_IOGCSR_G2E_Pos)
#define TSC_IOGCSR_G2E   TSC_IOGCSR_G2E_Msk
#define TSC_IOGCSR_G3E_Pos   (2U)
#define TSC_IOGCSR_G3E_Msk   (0x1UL << TSC_IOGCSR_G3E_Pos)
#define TSC_IOGCSR_G3E   TSC_IOGCSR_G3E_Msk
#define TSC_IOGCSR_G4E_Pos   (3U)
#define TSC_IOGCSR_G4E_Msk   (0x1UL << TSC_IOGCSR_G4E_Pos)
#define TSC_IOGCSR_G4E   TSC_IOGCSR_G4E_Msk
#define TSC_IOGCSR_G5E_Pos   (4U)
#define TSC_IOGCSR_G5E_Msk   (0x1UL << TSC_IOGCSR_G5E_Pos)
#define TSC_IOGCSR_G5E   TSC_IOGCSR_G5E_Msk
#define TSC_IOGCSR_G6E_Pos   (5U)
#define TSC_IOGCSR_G6E_Msk   (0x1UL << TSC_IOGCSR_G6E_Pos)
#define TSC_IOGCSR_G6E   TSC_IOGCSR_G6E_Msk
#define TSC_IOGCSR_G7E_Pos   (6U)
#define TSC_IOGCSR_G7E_Msk   (0x1UL << TSC_IOGCSR_G7E_Pos)
#define TSC_IOGCSR_G7E   TSC_IOGCSR_G7E_Msk
#define TSC_IOGCSR_G8E_Pos   (7U)
#define TSC_IOGCSR_G8E_Msk   (0x1UL << TSC_IOGCSR_G8E_Pos)
#define TSC_IOGCSR_G8E   TSC_IOGCSR_G8E_Msk
#define TSC_IOGCSR_G1S_Pos   (16U)
#define TSC_IOGCSR_G1S_Msk   (0x1UL << TSC_IOGCSR_G1S_Pos)
#define TSC_IOGCSR_G1S   TSC_IOGCSR_G1S_Msk
#define TSC_IOGCSR_G2S_Pos   (17U)
#define TSC_IOGCSR_G2S_Msk   (0x1UL << TSC_IOGCSR_G2S_Pos)
#define TSC_IOGCSR_G2S   TSC_IOGCSR_G2S_Msk
#define TSC_IOGCSR_G3S_Pos   (18U)
#define TSC_IOGCSR_G3S_Msk   (0x1UL << TSC_IOGCSR_G3S_Pos)
#define TSC_IOGCSR_G3S   TSC_IOGCSR_G3S_Msk
#define TSC_IOGCSR_G4S_Pos   (19U)
#define TSC_IOGCSR_G4S_Msk   (0x1UL << TSC_IOGCSR_G4S_Pos)
#define TSC_IOGCSR_G4S   TSC_IOGCSR_G4S_Msk
#define TSC_IOGCSR_G5S_Pos   (20U)
#define TSC_IOGCSR_G5S_Msk   (0x1UL << TSC_IOGCSR_G5S_Pos)
#define TSC_IOGCSR_G5S   TSC_IOGCSR_G5S_Msk
#define TSC_IOGCSR_G6S_Pos   (21U)
#define TSC_IOGCSR_G6S_Msk   (0x1UL << TSC_IOGCSR_G6S_Pos)
#define TSC_IOGCSR_G6S   TSC_IOGCSR_G6S_Msk
#define TSC_IOGCSR_G7S_Pos   (22U)
#define TSC_IOGCSR_G7S_Msk   (0x1UL << TSC_IOGCSR_G7S_Pos)
#define TSC_IOGCSR_G7S   TSC_IOGCSR_G7S_Msk
#define TSC_IOGCSR_G8S_Pos   (23U)
#define TSC_IOGCSR_G8S_Msk   (0x1UL << TSC_IOGCSR_G8S_Pos)
#define TSC_IOGCSR_G8S   TSC_IOGCSR_G8S_Msk
#define TSC_IOGXCR_CNT_Pos   (0U)
#define TSC_IOGXCR_CNT_Msk   (0x3FFFUL << TSC_IOGXCR_CNT_Pos)
#define TSC_IOGXCR_CNT   TSC_IOGXCR_CNT_Msk
#define SAI_GCR_SYNCIN_Pos   (0U)
#define SAI_GCR_SYNCIN_Msk   (0x3UL << SAI_GCR_SYNCIN_Pos)
#define SAI_GCR_SYNCIN   SAI_GCR_SYNCIN_Msk
#define SAI_GCR_SYNCIN_0   (0x1UL << SAI_GCR_SYNCIN_Pos)
#define SAI_GCR_SYNCIN_1   (0x2UL << SAI_GCR_SYNCIN_Pos)
#define SAI_GCR_SYNCOUT_Pos   (4U)
#define SAI_GCR_SYNCOUT_Msk   (0x3UL << SAI_GCR_SYNCOUT_Pos)
#define SAI_GCR_SYNCOUT   SAI_GCR_SYNCOUT_Msk
#define SAI_GCR_SYNCOUT_0   (0x1UL << SAI_GCR_SYNCOUT_Pos)
#define SAI_GCR_SYNCOUT_1   (0x2UL << SAI_GCR_SYNCOUT_Pos)
#define SAI_xCR1_MODE_Pos   (0U)
#define SAI_xCR1_MODE_Msk   (0x3UL << SAI_xCR1_MODE_Pos)
#define SAI_xCR1_MODE   SAI_xCR1_MODE_Msk
#define SAI_xCR1_MODE_0   (0x1UL << SAI_xCR1_MODE_Pos)
#define SAI_xCR1_MODE_1   (0x2UL << SAI_xCR1_MODE_Pos)
#define SAI_xCR1_PRTCFG_Pos   (2U)
#define SAI_xCR1_PRTCFG_Msk   (0x3UL << SAI_xCR1_PRTCFG_Pos)
#define SAI_xCR1_PRTCFG   SAI_xCR1_PRTCFG_Msk
#define SAI_xCR1_PRTCFG_0   (0x1UL << SAI_xCR1_PRTCFG_Pos)
#define SAI_xCR1_PRTCFG_1   (0x2UL << SAI_xCR1_PRTCFG_Pos)
#define SAI_xCR1_DS_Pos   (5U)
#define SAI_xCR1_DS_Msk   (0x7UL << SAI_xCR1_DS_Pos)
#define SAI_xCR1_DS   SAI_xCR1_DS_Msk
#define SAI_xCR1_DS_0   (0x1UL << SAI_xCR1_DS_Pos)
#define SAI_xCR1_DS_1   (0x2UL << SAI_xCR1_DS_Pos)
#define SAI_xCR1_DS_2   (0x4UL << SAI_xCR1_DS_Pos)
#define SAI_xCR1_LSBFIRST_Pos   (8U)
#define SAI_xCR1_LSBFIRST_Msk   (0x1UL << SAI_xCR1_LSBFIRST_Pos)
#define SAI_xCR1_LSBFIRST   SAI_xCR1_LSBFIRST_Msk
#define SAI_xCR1_CKSTR_Pos   (9U)
#define SAI_xCR1_CKSTR_Msk   (0x1UL << SAI_xCR1_CKSTR_Pos)
#define SAI_xCR1_CKSTR   SAI_xCR1_CKSTR_Msk
#define SAI_xCR1_SYNCEN_Pos   (10U)
#define SAI_xCR1_SYNCEN_Msk   (0x3UL << SAI_xCR1_SYNCEN_Pos)
#define SAI_xCR1_SYNCEN   SAI_xCR1_SYNCEN_Msk
#define SAI_xCR1_SYNCEN_0   (0x1UL << SAI_xCR1_SYNCEN_Pos)
#define SAI_xCR1_SYNCEN_1   (0x2UL << SAI_xCR1_SYNCEN_Pos)
#define SAI_xCR1_MONO_Pos   (12U)
#define SAI_xCR1_MONO_Msk   (0x1UL << SAI_xCR1_MONO_Pos)
#define SAI_xCR1_MONO   SAI_xCR1_MONO_Msk
#define SAI_xCR1_OUTDRIV_Pos   (13U)
#define SAI_xCR1_OUTDRIV_Msk   (0x1UL << SAI_xCR1_OUTDRIV_Pos)
#define SAI_xCR1_OUTDRIV   SAI_xCR1_OUTDRIV_Msk
#define SAI_xCR1_SAIEN_Pos   (16U)
#define SAI_xCR1_SAIEN_Msk   (0x1UL << SAI_xCR1_SAIEN_Pos)
#define SAI_xCR1_SAIEN   SAI_xCR1_SAIEN_Msk
#define SAI_xCR1_DMAEN_Pos   (17U)
#define SAI_xCR1_DMAEN_Msk   (0x1UL << SAI_xCR1_DMAEN_Pos)
#define SAI_xCR1_DMAEN   SAI_xCR1_DMAEN_Msk
#define SAI_xCR1_NODIV_Pos   (19U)
#define SAI_xCR1_NODIV_Msk   (0x1UL << SAI_xCR1_NODIV_Pos)
#define SAI_xCR1_NODIV   SAI_xCR1_NODIV_Msk
#define SAI_xCR1_MCKDIV_Pos   (20U)
#define SAI_xCR1_MCKDIV_Msk   (0x3FUL << SAI_xCR1_MCKDIV_Pos)
#define SAI_xCR1_MCKDIV   SAI_xCR1_MCKDIV_Msk
#define SAI_xCR1_MCKDIV_0   (0x00100000UL)
#define SAI_xCR1_MCKDIV_1   (0x00200000UL)
#define SAI_xCR1_MCKDIV_2   (0x00400000UL)
#define SAI_xCR1_MCKDIV_3   (0x00800000UL)
#define SAI_xCR1_MCKDIV_4   (0x01000000UL)
#define SAI_xCR1_MCKDIV_5   (0x02000000UL)
#define SAI_xCR1_OSR_Pos   (26U)
#define SAI_xCR1_OSR_Msk   (0x1UL << SAI_xCR1_OSR_Pos)
#define SAI_xCR1_OSR   SAI_xCR1_OSR_Msk
#define SAI_xCR1_MCKEN_Pos   (27U)
#define SAI_xCR1_MCKEN_Msk   (0x1UL << SAI_xCR1_MCKEN_Pos)
#define SAI_xCR1_MCKEN   SAI_xCR1_MCKEN_Msk
#define SAI_xCR2_FTH_Pos   (0U)
#define SAI_xCR2_FTH_Msk   (0x7UL << SAI_xCR2_FTH_Pos)
#define SAI_xCR2_FTH   SAI_xCR2_FTH_Msk
#define SAI_xCR2_FTH_0   (0x1UL << SAI_xCR2_FTH_Pos)
#define SAI_xCR2_FTH_1   (0x2UL << SAI_xCR2_FTH_Pos)
#define SAI_xCR2_FTH_2   (0x4UL << SAI_xCR2_FTH_Pos)
#define SAI_xCR2_FFLUSH_Pos   (3U)
#define SAI_xCR2_FFLUSH_Msk   (0x1UL << SAI_xCR2_FFLUSH_Pos)
#define SAI_xCR2_FFLUSH   SAI_xCR2_FFLUSH_Msk
#define SAI_xCR2_TRIS_Pos   (4U)
#define SAI_xCR2_TRIS_Msk   (0x1UL << SAI_xCR2_TRIS_Pos)
#define SAI_xCR2_TRIS   SAI_xCR2_TRIS_Msk
#define SAI_xCR2_MUTE_Pos   (5U)
#define SAI_xCR2_MUTE_Msk   (0x1UL << SAI_xCR2_MUTE_Pos)
#define SAI_xCR2_MUTE   SAI_xCR2_MUTE_Msk
#define SAI_xCR2_MUTEVAL_Pos   (6U)
#define SAI_xCR2_MUTEVAL_Msk   (0x1UL << SAI_xCR2_MUTEVAL_Pos)
#define SAI_xCR2_MUTEVAL   SAI_xCR2_MUTEVAL_Msk
#define SAI_xCR2_MUTECNT_Pos   (7U)
#define SAI_xCR2_MUTECNT_Msk   (0x3FUL << SAI_xCR2_MUTECNT_Pos)
#define SAI_xCR2_MUTECNT   SAI_xCR2_MUTECNT_Msk
#define SAI_xCR2_MUTECNT_0   (0x01UL << SAI_xCR2_MUTECNT_Pos)
#define SAI_xCR2_MUTECNT_1   (0x02UL << SAI_xCR2_MUTECNT_Pos)
#define SAI_xCR2_MUTECNT_2   (0x04UL << SAI_xCR2_MUTECNT_Pos)
#define SAI_xCR2_MUTECNT_3   (0x08UL << SAI_xCR2_MUTECNT_Pos)
#define SAI_xCR2_MUTECNT_4   (0x10UL << SAI_xCR2_MUTECNT_Pos)
#define SAI_xCR2_MUTECNT_5   (0x20UL << SAI_xCR2_MUTECNT_Pos)
#define SAI_xCR2_CPL_Pos   (13U)
#define SAI_xCR2_CPL_Msk   (0x1UL << SAI_xCR2_CPL_Pos)
#define SAI_xCR2_CPL   SAI_xCR2_CPL_Msk
#define SAI_xCR2_COMP_Pos   (14U)
#define SAI_xCR2_COMP_Msk   (0x3UL << SAI_xCR2_COMP_Pos)
#define SAI_xCR2_COMP   SAI_xCR2_COMP_Msk
#define SAI_xCR2_COMP_0   (0x1UL << SAI_xCR2_COMP_Pos)
#define SAI_xCR2_COMP_1   (0x2UL << SAI_xCR2_COMP_Pos)
#define SAI_xFRCR_FRL_Pos   (0U)
#define SAI_xFRCR_FRL_Msk   (0xFFUL << SAI_xFRCR_FRL_Pos)
#define SAI_xFRCR_FRL   SAI_xFRCR_FRL_Msk
#define SAI_xFRCR_FRL_0   (0x01UL << SAI_xFRCR_FRL_Pos)
#define SAI_xFRCR_FRL_1   (0x02UL << SAI_xFRCR_FRL_Pos)
#define SAI_xFRCR_FRL_2   (0x04UL << SAI_xFRCR_FRL_Pos)
#define SAI_xFRCR_FRL_3   (0x08UL << SAI_xFRCR_FRL_Pos)
#define SAI_xFRCR_FRL_4   (0x10UL << SAI_xFRCR_FRL_Pos)
#define SAI_xFRCR_FRL_5   (0x20UL << SAI_xFRCR_FRL_Pos)
#define SAI_xFRCR_FRL_6   (0x40UL << SAI_xFRCR_FRL_Pos)
#define SAI_xFRCR_FRL_7   (0x80UL << SAI_xFRCR_FRL_Pos)
#define SAI_xFRCR_FSALL_Pos   (8U)
#define SAI_xFRCR_FSALL_Msk   (0x7FUL << SAI_xFRCR_FSALL_Pos)
#define SAI_xFRCR_FSALL   SAI_xFRCR_FSALL_Msk
#define SAI_xFRCR_FSALL_0   (0x01UL << SAI_xFRCR_FSALL_Pos)
#define SAI_xFRCR_FSALL_1   (0x02UL << SAI_xFRCR_FSALL_Pos)
#define SAI_xFRCR_FSALL_2   (0x04UL << SAI_xFRCR_FSALL_Pos)
#define SAI_xFRCR_FSALL_3   (0x08UL << SAI_xFRCR_FSALL_Pos)
#define SAI_xFRCR_FSALL_4   (0x10UL << SAI_xFRCR_FSALL_Pos)
#define SAI_xFRCR_FSALL_5   (0x20UL << SAI_xFRCR_FSALL_Pos)
#define SAI_xFRCR_FSALL_6   (0x40UL << SAI_xFRCR_FSALL_Pos)
#define SAI_xFRCR_FSDEF_Pos   (16U)
#define SAI_xFRCR_FSDEF_Msk   (0x1UL << SAI_xFRCR_FSDEF_Pos)
#define SAI_xFRCR_FSDEF   SAI_xFRCR_FSDEF_Msk
#define SAI_xFRCR_FSPOL_Pos   (17U)
#define SAI_xFRCR_FSPOL_Msk   (0x1UL << SAI_xFRCR_FSPOL_Pos)
#define SAI_xFRCR_FSPOL   SAI_xFRCR_FSPOL_Msk
#define SAI_xFRCR_FSOFF_Pos   (18U)
#define SAI_xFRCR_FSOFF_Msk   (0x1UL << SAI_xFRCR_FSOFF_Pos)
#define SAI_xFRCR_FSOFF   SAI_xFRCR_FSOFF_Msk
#define SAI_xSLOTR_FBOFF_Pos   (0U)
#define SAI_xSLOTR_FBOFF_Msk   (0x1FUL << SAI_xSLOTR_FBOFF_Pos)
#define SAI_xSLOTR_FBOFF   SAI_xSLOTR_FBOFF_Msk
#define SAI_xSLOTR_FBOFF_0   (0x01UL << SAI_xSLOTR_FBOFF_Pos)
#define SAI_xSLOTR_FBOFF_1   (0x02UL << SAI_xSLOTR_FBOFF_Pos)
#define SAI_xSLOTR_FBOFF_2   (0x04UL << SAI_xSLOTR_FBOFF_Pos)
#define SAI_xSLOTR_FBOFF_3   (0x08UL << SAI_xSLOTR_FBOFF_Pos)
#define SAI_xSLOTR_FBOFF_4   (0x10UL << SAI_xSLOTR_FBOFF_Pos)
#define SAI_xSLOTR_SLOTSZ_Pos   (6U)
#define SAI_xSLOTR_SLOTSZ_Msk   (0x3UL << SAI_xSLOTR_SLOTSZ_Pos)
#define SAI_xSLOTR_SLOTSZ   SAI_xSLOTR_SLOTSZ_Msk
#define SAI_xSLOTR_SLOTSZ_0   (0x1UL << SAI_xSLOTR_SLOTSZ_Pos)
#define SAI_xSLOTR_SLOTSZ_1   (0x2UL << SAI_xSLOTR_SLOTSZ_Pos)
#define SAI_xSLOTR_NBSLOT_Pos   (8U)
#define SAI_xSLOTR_NBSLOT_Msk   (0xFUL << SAI_xSLOTR_NBSLOT_Pos)
#define SAI_xSLOTR_NBSLOT   SAI_xSLOTR_NBSLOT_Msk
#define SAI_xSLOTR_NBSLOT_0   (0x1UL << SAI_xSLOTR_NBSLOT_Pos)
#define SAI_xSLOTR_NBSLOT_1   (0x2UL << SAI_xSLOTR_NBSLOT_Pos)
#define SAI_xSLOTR_NBSLOT_2   (0x4UL << SAI_xSLOTR_NBSLOT_Pos)
#define SAI_xSLOTR_NBSLOT_3   (0x8UL << SAI_xSLOTR_NBSLOT_Pos)
#define SAI_xSLOTR_SLOTEN_Pos   (16U)
#define SAI_xSLOTR_SLOTEN_Msk   (0xFFFFUL << SAI_xSLOTR_SLOTEN_Pos)
#define SAI_xSLOTR_SLOTEN   SAI_xSLOTR_SLOTEN_Msk
#define SAI_xIMR_OVRUDRIE_Pos   (0U)
#define SAI_xIMR_OVRUDRIE_Msk   (0x1UL << SAI_xIMR_OVRUDRIE_Pos)
#define SAI_xIMR_OVRUDRIE   SAI_xIMR_OVRUDRIE_Msk
#define SAI_xIMR_MUTEDETIE_Pos   (1U)
#define SAI_xIMR_MUTEDETIE_Msk   (0x1UL << SAI_xIMR_MUTEDETIE_Pos)
#define SAI_xIMR_MUTEDETIE   SAI_xIMR_MUTEDETIE_Msk
#define SAI_xIMR_WCKCFGIE_Pos   (2U)
#define SAI_xIMR_WCKCFGIE_Msk   (0x1UL << SAI_xIMR_WCKCFGIE_Pos)
#define SAI_xIMR_WCKCFGIE   SAI_xIMR_WCKCFGIE_Msk
#define SAI_xIMR_FREQIE_Pos   (3U)
#define SAI_xIMR_FREQIE_Msk   (0x1UL << SAI_xIMR_FREQIE_Pos)
#define SAI_xIMR_FREQIE   SAI_xIMR_FREQIE_Msk
#define SAI_xIMR_CNRDYIE_Pos   (4U)
#define SAI_xIMR_CNRDYIE_Msk   (0x1UL << SAI_xIMR_CNRDYIE_Pos)
#define SAI_xIMR_CNRDYIE   SAI_xIMR_CNRDYIE_Msk
#define SAI_xIMR_AFSDETIE_Pos   (5U)
#define SAI_xIMR_AFSDETIE_Msk   (0x1UL << SAI_xIMR_AFSDETIE_Pos)
#define SAI_xIMR_AFSDETIE   SAI_xIMR_AFSDETIE_Msk
#define SAI_xIMR_LFSDETIE_Pos   (6U)
#define SAI_xIMR_LFSDETIE_Msk   (0x1UL << SAI_xIMR_LFSDETIE_Pos)
#define SAI_xIMR_LFSDETIE   SAI_xIMR_LFSDETIE_Msk
#define SAI_xSR_OVRUDR_Pos   (0U)
#define SAI_xSR_OVRUDR_Msk   (0x1UL << SAI_xSR_OVRUDR_Pos)
#define SAI_xSR_OVRUDR   SAI_xSR_OVRUDR_Msk
#define SAI_xSR_MUTEDET_Pos   (1U)
#define SAI_xSR_MUTEDET_Msk   (0x1UL << SAI_xSR_MUTEDET_Pos)
#define SAI_xSR_MUTEDET   SAI_xSR_MUTEDET_Msk
#define SAI_xSR_WCKCFG_Pos   (2U)
#define SAI_xSR_WCKCFG_Msk   (0x1UL << SAI_xSR_WCKCFG_Pos)
#define SAI_xSR_WCKCFG   SAI_xSR_WCKCFG_Msk
#define SAI_xSR_FREQ_Pos   (3U)
#define SAI_xSR_FREQ_Msk   (0x1UL << SAI_xSR_FREQ_Pos)
#define SAI_xSR_FREQ   SAI_xSR_FREQ_Msk
#define SAI_xSR_CNRDY_Pos   (4U)
#define SAI_xSR_CNRDY_Msk   (0x1UL << SAI_xSR_CNRDY_Pos)
#define SAI_xSR_CNRDY   SAI_xSR_CNRDY_Msk
#define SAI_xSR_AFSDET_Pos   (5U)
#define SAI_xSR_AFSDET_Msk   (0x1UL << SAI_xSR_AFSDET_Pos)
#define SAI_xSR_AFSDET   SAI_xSR_AFSDET_Msk
#define SAI_xSR_LFSDET_Pos   (6U)
#define SAI_xSR_LFSDET_Msk   (0x1UL << SAI_xSR_LFSDET_Pos)
#define SAI_xSR_LFSDET   SAI_xSR_LFSDET_Msk
#define SAI_xSR_FLVL_Pos   (16U)
#define SAI_xSR_FLVL_Msk   (0x7UL << SAI_xSR_FLVL_Pos)
#define SAI_xSR_FLVL   SAI_xSR_FLVL_Msk
#define SAI_xSR_FLVL_0   (0x1UL << SAI_xSR_FLVL_Pos)
#define SAI_xSR_FLVL_1   (0x2UL << SAI_xSR_FLVL_Pos)
#define SAI_xSR_FLVL_2   (0x4UL << SAI_xSR_FLVL_Pos)
#define SAI_xCLRFR_COVRUDR_Pos   (0U)
#define SAI_xCLRFR_COVRUDR_Msk   (0x1UL << SAI_xCLRFR_COVRUDR_Pos)
#define SAI_xCLRFR_COVRUDR   SAI_xCLRFR_COVRUDR_Msk
#define SAI_xCLRFR_CMUTEDET_Pos   (1U)
#define SAI_xCLRFR_CMUTEDET_Msk   (0x1UL << SAI_xCLRFR_CMUTEDET_Pos)
#define SAI_xCLRFR_CMUTEDET   SAI_xCLRFR_CMUTEDET_Msk
#define SAI_xCLRFR_CWCKCFG_Pos   (2U)
#define SAI_xCLRFR_CWCKCFG_Msk   (0x1UL << SAI_xCLRFR_CWCKCFG_Pos)
#define SAI_xCLRFR_CWCKCFG   SAI_xCLRFR_CWCKCFG_Msk
#define SAI_xCLRFR_CFREQ_Pos   (3U)
#define SAI_xCLRFR_CFREQ_Msk   (0x1UL << SAI_xCLRFR_CFREQ_Pos)
#define SAI_xCLRFR_CFREQ   SAI_xCLRFR_CFREQ_Msk
#define SAI_xCLRFR_CCNRDY_Pos   (4U)
#define SAI_xCLRFR_CCNRDY_Msk   (0x1UL << SAI_xCLRFR_CCNRDY_Pos)
#define SAI_xCLRFR_CCNRDY   SAI_xCLRFR_CCNRDY_Msk
#define SAI_xCLRFR_CAFSDET_Pos   (5U)
#define SAI_xCLRFR_CAFSDET_Msk   (0x1UL << SAI_xCLRFR_CAFSDET_Pos)
#define SAI_xCLRFR_CAFSDET   SAI_xCLRFR_CAFSDET_Msk
#define SAI_xCLRFR_CLFSDET_Pos   (6U)
#define SAI_xCLRFR_CLFSDET_Msk   (0x1UL << SAI_xCLRFR_CLFSDET_Pos)
#define SAI_xCLRFR_CLFSDET   SAI_xCLRFR_CLFSDET_Msk
#define SAI_xDR_DATA_Pos   (0U)
#define SAI_xDR_DATA_Msk   (0xFFFFFFFFUL << SAI_xDR_DATA_Pos)
#define SAI_xDR_DATA   SAI_xDR_DATA_Msk
#define SAI_PDMCR_PDMEN_Pos   (0U)
#define SAI_PDMCR_PDMEN_Msk   (0x1UL << SAI_PDMCR_PDMEN_Pos)
#define SAI_PDMCR_PDMEN   SAI_PDMCR_PDMEN_Msk
#define SAI_PDMCR_MICNBR_Pos   (4U)
#define SAI_PDMCR_MICNBR_Msk   (0x3UL << SAI_PDMCR_MICNBR_Pos)
#define SAI_PDMCR_MICNBR   SAI_PDMCR_MICNBR_Msk
#define SAI_PDMCR_MICNBR_0   (0x1UL << SAI_PDMCR_MICNBR_Pos)
#define SAI_PDMCR_MICNBR_1   (0x2UL << SAI_PDMCR_MICNBR_Pos)
#define SAI_PDMCR_CKEN1_Pos   (8U)
#define SAI_PDMCR_CKEN1_Msk   (0x1UL << SAI_PDMCR_CKEN1_Pos)
#define SAI_PDMCR_CKEN1   SAI_PDMCR_CKEN1_Msk
#define SAI_PDMCR_CKEN2_Pos   (9U)
#define SAI_PDMCR_CKEN2_Msk   (0x1UL << SAI_PDMCR_CKEN2_Pos)
#define SAI_PDMCR_CKEN2   SAI_PDMCR_CKEN2_Msk
#define SAI_PDMCR_CKEN3_Pos   (10U)
#define SAI_PDMCR_CKEN3_Msk   (0x1UL << SAI_PDMCR_CKEN3_Pos)
#define SAI_PDMCR_CKEN3   SAI_PDMCR_CKEN3_Msk
#define SAI_PDMCR_CKEN4_Pos   (11U)
#define SAI_PDMCR_CKEN4_Msk   (0x1UL << SAI_PDMCR_CKEN4_Pos)
#define SAI_PDMCR_CKEN4   SAI_PDMCR_CKEN4_Msk
#define SAI_PDMDLY_DLYM1L_Pos   (0U)
#define SAI_PDMDLY_DLYM1L_Msk   (0x7UL << SAI_PDMDLY_DLYM1L_Pos)
#define SAI_PDMDLY_DLYM1L   SAI_PDMDLY_DLYM1L_Msk
#define SAI_PDMDLY_DLYM1L_0   (0x1UL << SAI_PDMDLY_DLYM1L_Pos)
#define SAI_PDMDLY_DLYM1L_1   (0x2UL << SAI_PDMDLY_DLYM1L_Pos)
#define SAI_PDMDLY_DLYM1L_2   (0x4UL << SAI_PDMDLY_DLYM1L_Pos)
#define SAI_PDMDLY_DLYM1R_Pos   (4U)
#define SAI_PDMDLY_DLYM1R_Msk   (0x7UL << SAI_PDMDLY_DLYM1R_Pos)
#define SAI_PDMDLY_DLYM1R   SAI_PDMDLY_DLYM1R_Msk
#define SAI_PDMDLY_DLYM1R_0   (0x1UL << SAI_PDMDLY_DLYM1R_Pos)
#define SAI_PDMDLY_DLYM1R_1   (0x2UL << SAI_PDMDLY_DLYM1R_Pos)
#define SAI_PDMDLY_DLYM1R_2   (0x4UL << SAI_PDMDLY_DLYM1R_Pos)
#define SAI_PDMDLY_DLYM2L_Pos   (8U)
#define SAI_PDMDLY_DLYM2L_Msk   (0x7UL << SAI_PDMDLY_DLYM2L_Pos)
#define SAI_PDMDLY_DLYM2L   SAI_PDMDLY_DLYM2L_Msk
#define SAI_PDMDLY_DLYM2L_0   (0x1UL << SAI_PDMDLY_DLYM2L_Pos)
#define SAI_PDMDLY_DLYM2L_1   (0x2UL << SAI_PDMDLY_DLYM2L_Pos)
#define SAI_PDMDLY_DLYM2L_2   (0x4UL << SAI_PDMDLY_DLYM2L_Pos)
#define SAI_PDMDLY_DLYM2R_Pos   (12U)
#define SAI_PDMDLY_DLYM2R_Msk   (0x7UL << SAI_PDMDLY_DLYM2R_Pos)
#define SAI_PDMDLY_DLYM2R   SAI_PDMDLY_DLYM2R_Msk
#define SAI_PDMDLY_DLYM2R_0   (0x1UL << SAI_PDMDLY_DLYM2R_Pos)
#define SAI_PDMDLY_DLYM2R_1   (0x2UL << SAI_PDMDLY_DLYM2R_Pos)
#define SAI_PDMDLY_DLYM2R_2   (0x4UL << SAI_PDMDLY_DLYM2R_Pos)
#define SAI_PDMDLY_DLYM3L_Pos   (16U)
#define SAI_PDMDLY_DLYM3L_Msk   (0x7UL << SAI_PDMDLY_DLYM3L_Pos)
#define SAI_PDMDLY_DLYM3L   SAI_PDMDLY_DLYM3L_Msk
#define SAI_PDMDLY_DLYM3L_0   (0x1UL << SAI_PDMDLY_DLYM3L_Pos)
#define SAI_PDMDLY_DLYM3L_1   (0x2UL << SAI_PDMDLY_DLYM3L_Pos)
#define SAI_PDMDLY_DLYM3L_2   (0x4UL << SAI_PDMDLY_DLYM3L_Pos)
#define SAI_PDMDLY_DLYM3R_Pos   (20U)
#define SAI_PDMDLY_DLYM3R_Msk   (0x7UL << SAI_PDMDLY_DLYM3R_Pos)
#define SAI_PDMDLY_DLYM3R   SAI_PDMDLY_DLYM3R_Msk
#define SAI_PDMDLY_DLYM3R_0   (0x1UL << SAI_PDMDLY_DLYM3R_Pos)
#define SAI_PDMDLY_DLYM3R_1   (0x2UL << SAI_PDMDLY_DLYM3R_Pos)
#define SAI_PDMDLY_DLYM3R_2   (0x4UL << SAI_PDMDLY_DLYM3R_Pos)
#define SAI_PDMDLY_DLYM4L_Pos   (24U)
#define SAI_PDMDLY_DLYM4L_Msk   (0x7UL << SAI_PDMDLY_DLYM4L_Pos)
#define SAI_PDMDLY_DLYM4L   SAI_PDMDLY_DLYM4L_Msk
#define SAI_PDMDLY_DLYM4L_0   (0x1UL << SAI_PDMDLY_DLYM4L_Pos)
#define SAI_PDMDLY_DLYM4L_1   (0x2UL << SAI_PDMDLY_DLYM4L_Pos)
#define SAI_PDMDLY_DLYM4L_2   (0x4UL << SAI_PDMDLY_DLYM4L_Pos)
#define SAI_PDMDLY_DLYM4R_Pos   (28U)
#define SAI_PDMDLY_DLYM4R_Msk   (0x7UL << SAI_PDMDLY_DLYM4R_Pos)
#define SAI_PDMDLY_DLYM4R   SAI_PDMDLY_DLYM4R_Msk
#define SAI_PDMDLY_DLYM4R_0   (0x1UL << SAI_PDMDLY_DLYM4R_Pos)
#define SAI_PDMDLY_DLYM4R_1   (0x2UL << SAI_PDMDLY_DLYM4R_Pos)
#define SAI_PDMDLY_DLYM4R_2   (0x4UL << SAI_PDMDLY_DLYM4R_Pos)
#define SYSCFG_SECCFGR_SYSCFGSEC_Pos   (0U)
#define SYSCFG_SECCFGR_SYSCFGSEC_Msk   (0x1UL << SYSCFG_SECCFGR_SYSCFGSEC_Pos)
#define SYSCFG_SECCFGR_SYSCFGSEC   SYSCFG_SECCFGR_SYSCFGSEC_Msk
#define SYSCFG_SECCFGR_CLASSBSEC_Pos   (1U)
#define SYSCFG_SECCFGR_CLASSBSEC_Msk   (0x1UL << SYSCFG_SECCFGR_CLASSBSEC_Pos)
#define SYSCFG_SECCFGR_CLASSBSEC   SYSCFG_SECCFGR_CLASSBSEC_Msk
#define SYSCFG_SECCFGR_FPUSEC_Pos   (3U)
#define SYSCFG_SECCFGR_FPUSEC_Msk   (0x1UL << SYSCFG_SECCFGR_FPUSEC_Pos)
#define SYSCFG_SECCFGR_FPUSEC   SYSCFG_SECCFGR_FPUSEC_Msk
#define SYSCFG_CFGR1_BOOSTEN_Pos   (8U)
#define SYSCFG_CFGR1_BOOSTEN_Msk   (0x1UL << SYSCFG_CFGR1_BOOSTEN_Pos)
#define SYSCFG_CFGR1_BOOSTEN   SYSCFG_CFGR1_BOOSTEN_Msk
#define SYSCFG_CFGR1_ANASWVDD_Pos   (9U)
#define SYSCFG_CFGR1_ANASWVDD_Msk   (0x1UL << SYSCFG_CFGR1_ANASWVDD_Pos)
#define SYSCFG_CFGR1_ANASWVDD   SYSCFG_CFGR1_ANASWVDD_Msk
#define SYSCFG_CFGR1_PB6_FMP_Pos   (16U)
#define SYSCFG_CFGR1_PB6_FMP_Msk   (0x1UL << SYSCFG_CFGR1_PB6_FMP_Pos)
#define SYSCFG_CFGR1_PB6_FMP   SYSCFG_CFGR1_PB6_FMP_Msk
#define SYSCFG_CFGR1_PB7_FMP_Pos   (17U)
#define SYSCFG_CFGR1_PB7_FMP_Msk   (0x1UL << SYSCFG_CFGR1_PB7_FMP_Pos)
#define SYSCFG_CFGR1_PB7_FMP   SYSCFG_CFGR1_PB7_FMP_Msk
#define SYSCFG_CFGR1_PB8_FMP_Pos   (18U)
#define SYSCFG_CFGR1_PB8_FMP_Msk   (0x1UL << SYSCFG_CFGR1_PB8_FMP_Pos)
#define SYSCFG_CFGR1_PB8_FMP   SYSCFG_CFGR1_PB8_FMP_Msk
#define SYSCFG_CFGR1_PB9_FMP_Pos   (19U)
#define SYSCFG_CFGR1_PB9_FMP_Msk   (0x1UL << SYSCFG_CFGR1_PB9_FMP_Pos)
#define SYSCFG_CFGR1_PB9_FMP   SYSCFG_CFGR1_PB9_FMP_Msk
#define SYSCFG_CFGR1_ENDCAP_Pos   (24U)
#define SYSCFG_CFGR1_ENDCAP_Msk   (0x3UL << SYSCFG_CFGR1_ENDCAP_Pos)
#define SYSCFG_CFGR1_ENDCAP   SYSCFG_CFGR1_ENDCAP_Msk
#define SYSCFG_CFGR1_ENDCAP_0   (0x1UL << SYSCFG_CFGR1_ENDCAP_Pos)
#define SYSCFG_CFGR1_ENDCAP_1   (0x2UL << SYSCFG_CFGR1_ENDCAP_Pos)
#define SYSCFG_CFGR1_SRAMCACHED_Pos   (28U)
#define SYSCFG_CFGR1_SRAMCACHED_Msk   (0x1UL << SYSCFG_CFGR1_SRAMCACHED_Pos)
#define SYSCFG_CFGR1_SRAMCACHED   SYSCFG_CFGR1_SRAMCACHED_Msk
#define SYSCFG_FPUIMR_FPU_IE_Pos   (0U)
#define SYSCFG_FPUIMR_FPU_IE_Msk   (0x3FUL << SYSCFG_FPUIMR_FPU_IE_Pos)
#define SYSCFG_FPUIMR_FPU_IE   SYSCFG_FPUIMR_FPU_IE_Msk
#define SYSCFG_FPUIMR_FPU_IE_0   (0x1UL << SYSCFG_FPUIMR_FPU_IE_Pos)
#define SYSCFG_FPUIMR_FPU_IE_1   (0x2UL << SYSCFG_FPUIMR_FPU_IE_Pos)
#define SYSCFG_FPUIMR_FPU_IE_2   (0x4UL << SYSCFG_FPUIMR_FPU_IE_Pos)
#define SYSCFG_FPUIMR_FPU_IE_3   (0x8UL << SYSCFG_FPUIMR_FPU_IE_Pos)
#define SYSCFG_FPUIMR_FPU_IE_4   (0x10UL << SYSCFG_FPUIMR_FPU_IE_Pos)
#define SYSCFG_FPUIMR_FPU_IE_5   (0x20UL << SYSCFG_FPUIMR_FPU_IE_Pos)
#define SYSCFG_CNSLCKR_LOCKNSVTOR_Pos   (0U)
#define SYSCFG_CNSLCKR_LOCKNSVTOR_Msk   (0x1UL << SYSCFG_CNSLCKR_LOCKNSVTOR_Pos)
#define SYSCFG_CNSLCKR_LOCKNSVTOR   SYSCFG_CNSLCKR_LOCKNSVTOR_Msk
#define SYSCFG_CNSLCKR_LOCKNSMPU_Pos   (1U)
#define SYSCFG_CNSLCKR_LOCKNSMPU_Msk   (0x1UL << SYSCFG_CNSLCKR_LOCKNSMPU_Pos)
#define SYSCFG_CNSLCKR_LOCKNSMPU   SYSCFG_CNSLCKR_LOCKNSMPU_Msk
#define SYSCFG_CSLCKR_LOCKSVTAIRCR_Pos   (0U)
#define SYSCFG_CSLCKR_LOCKSVTAIRCR_Msk   (0x1UL << SYSCFG_CSLCKR_LOCKSVTAIRCR_Pos)
#define SYSCFG_CSLCKR_LOCKSVTAIRCR   SYSCFG_CSLCKR_LOCKSVTAIRCR_Msk
#define SYSCFG_CSLCKR_LOCKSMPU_Pos   (1U)
#define SYSCFG_CSLCKR_LOCKSMPU_Msk   (0x1UL << SYSCFG_CSLCKR_LOCKSMPU_Pos)
#define SYSCFG_CSLCKR_LOCKSMPU   SYSCFG_CSLCKR_LOCKSMPU_Msk
#define SYSCFG_CSLCKR_LOCKSAU_Pos   (2U)
#define SYSCFG_CSLCKR_LOCKSAU_Msk   (0x1UL << SYSCFG_CSLCKR_LOCKSAU_Pos)
#define SYSCFG_CSLCKR_LOCKSAU   SYSCFG_CSLCKR_LOCKSAU_Msk
#define SYSCFG_CFGR2_CLL_Pos   (0U)
#define SYSCFG_CFGR2_CLL_Msk   (0x1UL << SYSCFG_CFGR2_CLL_Pos)
#define SYSCFG_CFGR2_CLL   SYSCFG_CFGR2_CLL_Msk
#define SYSCFG_CFGR2_SPL_Pos   (1U)
#define SYSCFG_CFGR2_SPL_Msk   (0x1UL << SYSCFG_CFGR2_SPL_Pos)
#define SYSCFG_CFGR2_SPL   SYSCFG_CFGR2_SPL_Msk
#define SYSCFG_CFGR2_PVDL_Pos   (2U)
#define SYSCFG_CFGR2_PVDL_Msk   (0x1UL << SYSCFG_CFGR2_PVDL_Pos)
#define SYSCFG_CFGR2_PVDL   SYSCFG_CFGR2_PVDL_Msk
#define SYSCFG_CFGR2_ECCL_Pos   (3U)
#define SYSCFG_CFGR2_ECCL_Msk   (0x1UL << SYSCFG_CFGR2_ECCL_Pos)
#define SYSCFG_CFGR2_ECCL   SYSCFG_CFGR2_ECCL_Msk
#define SYSCFG_MESR_MCLR_Pos   (0U)
#define SYSCFG_MESR_MCLR_Msk   (0x1UL << SYSCFG_MESR_MCLR_Pos)
#define SYSCFG_MESR_MCLR   SYSCFG_MESR_MCLR_Msk
#define SYSCFG_MESR_IPMEE_Pos   (16U)
#define SYSCFG_MESR_IPMEE_Msk   (0x1UL << SYSCFG_MESR_IPMEE_Pos)
#define SYSCFG_MESR_IPMEE   SYSCFG_MESR_IPMEE_Msk
#define SYSCFG_CCCSR_EN1_Pos   (0U)
#define SYSCFG_CCCSR_EN1_Msk   (0x1UL << SYSCFG_CCCSR_EN1_Pos)
#define SYSCFG_CCCSR_EN1   SYSCFG_CCCSR_EN1_Msk
#define SYSCFG_CCCSR_CS1_Pos   (1U)
#define SYSCFG_CCCSR_CS1_Msk   (0x1UL << SYSCFG_CCCSR_CS1_Pos)
#define SYSCFG_CCCSR_CS1   SYSCFG_CCCSR_CS1_Msk
#define SYSCFG_CCCSR_EN2_Pos   (2U)
#define SYSCFG_CCCSR_EN2_Msk   (0x1UL << SYSCFG_CCCSR_EN2_Pos)
#define SYSCFG_CCCSR_EN2   SYSCFG_CCCSR_EN2_Msk
#define SYSCFG_CCCSR_CS2_Pos   (3U)
#define SYSCFG_CCCSR_CS2_Msk   (0x1UL << SYSCFG_CCCSR_CS2_Pos)
#define SYSCFG_CCCSR_CS2   SYSCFG_CCCSR_CS2_Msk
#define SYSCFG_CCCSR_EN3_Pos   (4U)
#define SYSCFG_CCCSR_EN3_Msk   (0x1UL << SYSCFG_CCCSR_EN3_Pos)
#define SYSCFG_CCCSR_EN3   SYSCFG_CCCSR_EN3_Msk
#define SYSCFG_CCCSR_CS3_Pos   (5U)
#define SYSCFG_CCCSR_CS3_Msk   (0x1UL << SYSCFG_CCCSR_CS3_Pos)
#define SYSCFG_CCCSR_CS3   SYSCFG_CCCSR_CS3_Msk
#define SYSCFG_CCCSR_RDY1_Pos   (8U)
#define SYSCFG_CCCSR_RDY1_Msk   (0x1UL << SYSCFG_CCCSR_RDY1_Pos)
#define SYSCFG_CCCSR_RDY1   SYSCFG_CCCSR_RDY1_Msk
#define SYSCFG_CCCSR_RDY2_Pos   (9U)
#define SYSCFG_CCCSR_RDY2_Msk   (0x1UL << SYSCFG_CCCSR_RDY2_Pos)
#define SYSCFG_CCCSR_RDY2   SYSCFG_CCCSR_RDY2_Msk
#define SYSCFG_CCCSR_RDY3_Pos   (10U)
#define SYSCFG_CCCSR_RDY3_Msk   (0x1UL << SYSCFG_CCCSR_RDY3_Pos)
#define SYSCFG_CCCSR_RDY3   SYSCFG_CCCSR_RDY3_Msk
#define SYSCFG_CCVR_NCV1_Pos   (0U)
#define SYSCFG_CCVR_NCV1_Msk   (0xFUL << SYSCFG_CCVR_NCV1_Pos)
#define SYSCFG_CCVR_NCV1   SYSCFG_CCVR_NCV1_Msk
#define SYSCFG_CCVR_PCV1_Pos   (4U)
#define SYSCFG_CCVR_PCV1_Msk   (0xFUL << SYSCFG_CCVR_PCV1_Pos)
#define SYSCFG_CCVR_PCV1   SYSCFG_CCVR_PCV1_Msk
#define SYSCFG_CCVR_NCV2_Pos   (8U)
#define SYSCFG_CCVR_NCV2_Msk   (0xFUL << SYSCFG_CCVR_NCV2_Pos)
#define SYSCFG_CCVR_NCV2   SYSCFG_CCVR_NCV2_Msk
#define SYSCFG_CCVR_PCV2_Pos   (12U)
#define SYSCFG_CCVR_PCV2_Msk   (0xFUL << SYSCFG_CCVR_PCV2_Pos)
#define SYSCFG_CCVR_PCV2   SYSCFG_CCVR_PCV2_Msk
#define SYSCFG_CCVR_NCV3_Pos   (16U)
#define SYSCFG_CCVR_NCV3_Msk   (0xFUL << SYSCFG_CCVR_NCV3_Pos)
#define SYSCFG_CCVR_NCV3   SYSCFG_CCVR_NCV3_Msk
#define SYSCFG_CCVR_PCV3_Pos   (20U)
#define SYSCFG_CCVR_PCV3_Msk   (0xFUL << SYSCFG_CCVR_PCV3_Pos)
#define SYSCFG_CCVR_PCV3   SYSCFG_CCVR_PCV3_Msk
#define SYSCFG_CCCR_NCC1_Pos   (0U)
#define SYSCFG_CCCR_NCC1_Msk   (0xFUL << SYSCFG_CCCR_NCC1_Pos)
#define SYSCFG_CCCR_NCC1   SYSCFG_CCCR_NCC1_Msk
#define SYSCFG_CCCR_PCC1_Pos   (4U)
#define SYSCFG_CCCR_PCC1_Msk   (0xFUL << SYSCFG_CCCR_PCC1_Pos)
#define SYSCFG_CCCR_PCC1   SYSCFG_CCCR_PCC1_Msk
#define SYSCFG_CCCR_NCC2_Pos   (8U)
#define SYSCFG_CCCR_NCC2_Msk   (0xFUL << SYSCFG_CCCR_NCC2_Pos)
#define SYSCFG_CCCR_NCC2   SYSCFG_CCCR_NCC2_Msk
#define SYSCFG_CCCR_PCC2_Pos   (12U)
#define SYSCFG_CCCR_PCC2_Msk   (0xFUL << SYSCFG_CCCR_PCC2_Pos)
#define SYSCFG_CCCR_PCC2   SYSCFG_CCCR_PCC2_Msk
#define SYSCFG_CCCR_NCC3_Pos   (16U)
#define SYSCFG_CCCR_NCC3_Msk   (0xFUL << SYSCFG_CCCR_NCC3_Pos)
#define SYSCFG_CCCR_NCC3   SYSCFG_CCCR_NCC3_Msk
#define SYSCFG_CCCR_PCC3_Pos   (20U)
#define SYSCFG_CCCR_PCC3_Msk   (0xFUL << SYSCFG_CCCR_PCC3_Pos)
#define SYSCFG_CCCR_PCC3   SYSCFG_CCCR_PCC3_Msk
#define SYSCFG_RSSCMDR_RSSCMD_Pos   (0U)
#define SYSCFG_RSSCMDR_RSSCMD_Msk   (0xFFFFUL << SYSCFG_RSSCMDR_RSSCMD_Pos)
#define SYSCFG_RSSCMDR_RSSCMD   SYSCFG_RSSCMDR_RSSCMD_Msk
#define SYSCFG_OTGHSPHYCR_EN_Pos   (0U)
#define SYSCFG_OTGHSPHYCR_EN_Msk   (0x1UL << SYSCFG_OTGHSPHYCR_EN_Pos)
#define SYSCFG_OTGHSPHYCR_EN   SYSCFG_OTGHSPHYCR_EN_Msk
#define SYSCFG_OTGHSPHYCR_PDCTRL_Pos   (1U)
#define SYSCFG_OTGHSPHYCR_PDCTRL_Msk   (0x1UL << SYSCFG_OTGHSPHYCR_PDCTRL_Pos)
#define SYSCFG_OTGHSPHYCR_PDCTRL   SYSCFG_OTGHSPHYCR_PDCTRL_Msk
#define SYSCFG_OTGHSPHYCR_CLKSEL_Pos   (2U)
#define SYSCFG_OTGHSPHYCR_CLKSEL_Msk   (0xFUL << SYSCFG_OTGHSPHYCR_CLKSEL_Pos)
#define SYSCFG_OTGHSPHYCR_CLKSEL   SYSCFG_OTGHSPHYCR_CLKSEL_Msk
#define SYSCFG_OTGHSPHYCR_CLKSEL_0   (0x1UL << SYSCFG_OTGHSPHYCR_CLKSEL_Pos)
#define SYSCFG_OTGHSPHYCR_CLKSEL_1   (0x2UL << SYSCFG_OTGHSPHYCR_CLKSEL_Pos)
#define SYSCFG_OTGHSPHYCR_CLKSEL_2   (0x4UL << SYSCFG_OTGHSPHYCR_CLKSEL_Pos)
#define SYSCFG_OTGHSPHYCR_CLKSEL_3   (0x8UL << SYSCFG_OTGHSPHYCR_CLKSEL_Pos)
#define SYSCFG_OTGHSPHYTUNER2_COMPDISTUNE_Pos   (0U)
#define SYSCFG_OTGHSPHYTUNER2_COMPDISTUNE_Msk   (0x7UL << SYSCFG_OTGHSPHYTUNER2_COMPDISTUNE_Pos)
#define SYSCFG_OTGHSPHYTUNER2_COMPDISTUNE   SYSCFG_OTGHSPHYTUNER2_COMPDISTUNE_Msk
#define SYSCFG_OTGHSPHYTUNER2_COMPDISTUNE_0   (0x1UL << SYSCFG_OTGHSPHYTUNER2_COMPDISTUNE_Pos)
#define SYSCFG_OTGHSPHYTUNER2_COMPDISTUNE_1   (0x2UL << SYSCFG_OTGHSPHYTUNER2_COMPDISTUNE_Pos)
#define SYSCFG_OTGHSPHYTUNER2_COMPDISTUNE_2   (0x4UL << SYSCFG_OTGHSPHYTUNER2_COMPDISTUNE_Pos)
#define SYSCFG_OTGHSPHYTUNER2_SQRXTUNE_Pos   (4U)
#define SYSCFG_OTGHSPHYTUNER2_SQRXTUNE_Msk   (0x7UL << SYSCFG_OTGHSPHYTUNER2_SQRXTUNE_Pos)
#define SYSCFG_OTGHSPHYTUNER2_SQRXTUNE   SYSCFG_OTGHSPHYTUNER2_SQRXTUNE_Msk
#define SYSCFG_OTGHSPHYTUNER2_SQRXTUNE_0   (0x1UL << SYSCFG_OTGHSPHYTUNER2_SQRXTUNE_Pos)
#define SYSCFG_OTGHSPHYTUNER2_SQRXTUNE_1   (0x2UL << SYSCFG_OTGHSPHYTUNER2_SQRXTUNE_Pos)
#define SYSCFG_OTGHSPHYTUNER2_SQRXTUNE_2   (0x4UL << SYSCFG_OTGHSPHYTUNER2_SQRXTUNE_Pos)
#define SYSCFG_OTGHSPHYTUNER2_TXPREEMPAMPTUNE_Pos   (13U)
#define SYSCFG_OTGHSPHYTUNER2_TXPREEMPAMPTUNE_Msk   (0x3UL << SYSCFG_OTGHSPHYTUNER2_TXPREEMPAMPTUNE_Pos)
#define SYSCFG_OTGHSPHYTUNER2_TXPREEMPAMPTUNE   SYSCFG_OTGHSPHYTUNER2_TXPREEMPAMPTUNE_Msk
#define SYSCFG_OTGHSPHYTUNER2_TXPREEMPAMPTUNE_0   (0x1UL << SYSCFG_OTGHSPHYTUNER2_TXPREEMPAMPTUNE_Pos)
#define SYSCFG_OTGHSPHYTUNER2_TXPREEMPAMPTUNE_1   (0x2UL << SYSCFG_OTGHSPHYTUNER2_TXPREEMPAMPTUNE_Pos)
#define GTZC_TZSC_CR_LCK_Pos   (0U)
#define GTZC_TZSC_CR_LCK_Msk   (0x01UL << GTZC_TZSC_CR_LCK_Pos)
#define GTZC_TZSC_MPCWM_CFGR_SREN_Pos   (0U)
#define GTZC_TZSC_MPCWM_CFGR_SREN_Msk   (0x1UL << GTZC_TZSC_MPCWM_CFGR_SREN_Pos)
#define GTZC_TZSC_MPCWM_CFGR_SREN   GTZC_TZSC_MPCWM_CFGR_SREN_Msk
#define GTZC_TZSC_MPCWM_CFGR_SRLOCK_Pos   (1U)
#define GTZC_TZSC_MPCWM_CFGR_SRLOCK_Msk   (0x1UL << GTZC_TZSC_MPCWM_CFGR_SRLOCK_Pos)
#define GTZC_TZSC_MPCWM_CFGR_SRLOCK   GTZC_TZSC_MPCWM_CFGR_SRLOCK_Msk
#define GTZC_TZSC_MPCWM_CFGR_SEC_Pos   (8U)
#define GTZC_TZSC_MPCWM_CFGR_SEC_Msk   (0x1UL << GTZC_TZSC_MPCWM_CFGR_SEC_Pos)
#define GTZC_TZSC_MPCWM_CFGR_SEC   GTZC_TZSC_MPCWM_CFGR_SEC_Msk
#define GTZC_TZSC_MPCWM_CFGR_PRIV_Pos   (9U)
#define GTZC_TZSC_MPCWM_CFGR_PRIV_Msk   (0x1UL << GTZC_TZSC_MPCWM_CFGR_PRIV_Pos)
#define GTZC_TZSC_MPCWM_CFGR_PRIV   GTZC_TZSC_MPCWM_CFGR_PRIV_Msk
#define GTZC_TZSC_MPCWMR_SUBZ_START_Pos   (0U)
#define GTZC_TZSC_MPCWMR_SUBZ_START_Msk   (0x7FFUL << GTZC_TZSC_MPCWMR_SUBZ_START_Pos)
#define GTZC_TZSC_MPCWMR_SUBZ_START   GTZC_TZSC_MPCWMR_SUBZ_START_Msk
#define GTZC_TZSC_MPCWMR_SUBZ_LENGTH_Pos   (16U)
#define GTZC_TZSC_MPCWMR_SUBZ_LENGTH_Msk   (0xFFFUL << GTZC_TZSC_MPCWMR_SUBZ_LENGTH_Pos)
#define GTZC_TZSC_MPCWMR_SUBZ_LENGTH   GTZC_TZSC_MPCWMR_SUBZ_LENGTH_Msk
#define GTZC_CFGR1_TIM2_Pos   (0U)
#define GTZC_CFGR1_TIM2_Msk   (0x01UL << GTZC_CFGR1_TIM2_Pos)
#define GTZC_CFGR1_TIM3_Pos   (1U)
#define GTZC_CFGR1_TIM3_Msk   (0x01UL << GTZC_CFGR1_TIM3_Pos)
#define GTZC_CFGR1_TIM4_Pos   (2U)
#define GTZC_CFGR1_TIM4_Msk   (0x01UL << GTZC_CFGR1_TIM4_Pos)
#define GTZC_CFGR1_TIM5_Pos   (3U)
#define GTZC_CFGR1_TIM5_Msk   (0x01UL << GTZC_CFGR1_TIM5_Pos)
#define GTZC_CFGR1_TIM6_Pos   (4U)
#define GTZC_CFGR1_TIM6_Msk   (0x01UL << GTZC_CFGR1_TIM6_Pos)
#define GTZC_CFGR1_TIM7_Pos   (5U)
#define GTZC_CFGR1_TIM7_Msk   (0x01UL << GTZC_CFGR1_TIM7_Pos)
#define GTZC_CFGR1_WWDG_Pos   (6U)
#define GTZC_CFGR1_WWDG_Msk   (0x01UL << GTZC_CFGR1_WWDG_Pos)
#define GTZC_CFGR1_IWDG_Pos   (7U)
#define GTZC_CFGR1_IWDG_Msk   (0x01UL << GTZC_CFGR1_IWDG_Pos)
#define GTZC_CFGR1_SPI2_Pos   (8U)
#define GTZC_CFGR1_SPI2_Msk   (0x01UL << GTZC_CFGR1_SPI2_Pos)
#define GTZC_CFGR1_USART2_Pos   (9U)
#define GTZC_CFGR1_USART2_Msk   (0x01UL << GTZC_CFGR1_USART2_Pos)
#define GTZC_CFGR1_USART3_Pos   (10U)
#define GTZC_CFGR1_USART3_Msk   (0x01UL << GTZC_CFGR1_USART3_Pos)
#define GTZC_CFGR1_UART4_Pos   (11U)
#define GTZC_CFGR1_UART4_Msk   (0x01UL << GTZC_CFGR1_UART4_Pos)
#define GTZC_CFGR1_UART5_Pos   (12U)
#define GTZC_CFGR1_UART5_Msk   (0x01UL << GTZC_CFGR1_UART5_Pos)
#define GTZC_CFGR1_I2C1_Pos   (13U)
#define GTZC_CFGR1_I2C1_Msk   (0x01UL << GTZC_CFGR1_I2C1_Pos)
#define GTZC_CFGR1_I2C2_Pos   (14U)
#define GTZC_CFGR1_I2C2_Msk   (0x01UL << GTZC_CFGR1_I2C2_Pos)
#define GTZC_CFGR1_CRS_Pos   (15U)
#define GTZC_CFGR1_CRS_Msk   (0x01UL << GTZC_CFGR1_CRS_Pos)
#define GTZC_CFGR1_I2C4_Pos   (16U)
#define GTZC_CFGR1_I2C4_Msk   (0x01UL << GTZC_CFGR1_I2C4_Pos)
#define GTZC_CFGR1_LPTIM2_Pos   (17U)
#define GTZC_CFGR1_LPTIM2_Msk   (0x01UL << GTZC_CFGR1_LPTIM2_Pos)
#define GTZC_CFGR1_FDCAN1_Pos   (18U)
#define GTZC_CFGR1_FDCAN1_Msk   (0x01UL << GTZC_CFGR1_FDCAN1_Pos)
#define GTZC_CFGR1_UCPD1_Pos   (19U)
#define GTZC_CFGR1_UCPD1_Msk   (0x01UL << GTZC_CFGR1_UCPD1_Pos)
#define GTZC_CFGR1_USART6_Pos   (21U)
#define GTZC_CFGR1_USART6_Msk   (0x01UL << GTZC_CFGR1_USART6_Pos)
#define GTZC_CFGR1_I2C5_Pos   (22U)
#define GTZC_CFGR1_I2C5_Msk   (0x01UL << GTZC_CFGR1_I2C5_Pos)
#define GTZC_CFGR1_I2C6_Pos   (23U)
#define GTZC_CFGR1_I2C6_Msk   (0x01UL << GTZC_CFGR1_I2C6_Pos)
#define GTZC_CFGR2_TIM1_Pos   (0U)
#define GTZC_CFGR2_TIM1_Msk   (0x01UL << GTZC_CFGR2_TIM1_Pos)
#define GTZC_CFGR2_SPI1_Pos   (1U)
#define GTZC_CFGR2_SPI1_Msk   (0x01UL << GTZC_CFGR2_SPI1_Pos)
#define GTZC_CFGR2_TIM8_Pos   (2U)
#define GTZC_CFGR2_TIM8_Msk   (0x01UL << GTZC_CFGR2_TIM8_Pos)
#define GTZC_CFGR2_USART1_Pos   (3U)
#define GTZC_CFGR2_USART1_Msk   (0x01UL << GTZC_CFGR2_USART1_Pos)
#define GTZC_CFGR2_TIM15_Pos   (4U)
#define GTZC_CFGR2_TIM15_Msk   (0x01UL << GTZC_CFGR2_TIM15_Pos)
#define GTZC_CFGR2_TIM16_Pos   (5U)
#define GTZC_CFGR2_TIM16_Msk   (0x01UL << GTZC_CFGR2_TIM16_Pos)
#define GTZC_CFGR2_TIM17_Pos   (6U)
#define GTZC_CFGR2_TIM17_Msk   (0x01UL << GTZC_CFGR2_TIM17_Pos)
#define GTZC_CFGR2_SAI1_Pos   (7U)
#define GTZC_CFGR2_SAI1_Msk   (0x01UL << GTZC_CFGR2_SAI1_Pos)
#define GTZC_CFGR2_SAI2_Pos   (8U)
#define GTZC_CFGR2_SAI2_Msk   (0x01UL << GTZC_CFGR2_SAI2_Pos)
#define GTZC_CFGR2_LTDCUSB_Pos   (9U)
#define GTZC_CFGR2_LTDCUSB_Msk   (0x01UL << GTZC_CFGR2_LTDCUSB_Pos)
#define GTZC_CFGR2_DSI_Pos   (10U)
#define GTZC_CFGR2_DSI_Msk   (0x01UL << GTZC_CFGR2_DSI_Pos)
#define GTZC_CFGR2_GFXTIM_Pos   (11U)
#define GTZC_CFGR2_GFXTIM_Msk   (0x01UL << GTZC_CFGR2_GFXTIM_Pos)
#define GTZC_CFGR3_MDF1_Pos   (0U)
#define GTZC_CFGR3_MDF1_Msk   (0x01UL << GTZC_CFGR3_MDF1_Pos)
#define GTZC_CFGR3_CORDIC_Pos   (1U)
#define GTZC_CFGR3_CORDIC_Msk   (0x01UL << GTZC_CFGR3_CORDIC_Pos)
#define GTZC_CFGR3_FMAC_Pos   (2U)
#define GTZC_CFGR3_FMAC_Msk   (0x01UL << GTZC_CFGR3_FMAC_Pos)
#define GTZC_CFGR3_CRC_Pos   (3U)
#define GTZC_CFGR3_CRC_Msk   (0x01UL << GTZC_CFGR3_CRC_Pos)
#define GTZC_CFGR3_TSC_Pos   (4U)
#define GTZC_CFGR3_TSC_Msk   (0x01UL << GTZC_CFGR3_TSC_Pos)
#define GTZC_CFGR3_DMA2D_Pos   (5U)
#define GTZC_CFGR3_DMA2D_Msk   (0x01UL << GTZC_CFGR3_DMA2D_Pos)
#define GTZC_CFGR3_ICACHE_REG_Pos   (6U)
#define GTZC_CFGR3_ICACHE_REG_Msk   (0x01UL << GTZC_CFGR3_ICACHE_REG_Pos)
#define GTZC_CFGR3_DCACHE1_REG_Pos   (7U)
#define GTZC_CFGR3_DCACHE1_REG_Msk   (0x01UL << GTZC_CFGR3_DCACHE1_REG_Pos)
#define GTZC_CFGR3_ADC12_Pos   (8U)
#define GTZC_CFGR3_ADC12_Msk   (0x01UL << GTZC_CFGR3_ADC12_Pos)
#define GTZC_CFGR3_DCMI_Pos   (9U)
#define GTZC_CFGR3_DCMI_Msk   (0x01UL << GTZC_CFGR3_DCMI_Pos)
#define GTZC_CFGR3_OTG_Pos   (10U)
#define GTZC_CFGR3_OTG_Msk   (0x01UL << GTZC_CFGR3_OTG_Pos)
#define GTZC_CFGR3_AES_Pos   (11U)
#define GTZC_CFGR3_AES_Msk   (0x01UL << GTZC_CFGR3_AES_Pos)
#define GTZC_CFGR3_HASH_Pos   (12U)
#define GTZC_CFGR3_HASH_Msk   (0x01UL << GTZC_CFGR3_HASH_Pos)
#define GTZC_CFGR3_RNG_Pos   (13U)
#define GTZC_CFGR3_RNG_Msk   (0x01UL << GTZC_CFGR3_RNG_Pos)
#define GTZC_CFGR3_PKA_Pos   (14U)
#define GTZC_CFGR3_PKA_Msk   (0x01UL << GTZC_CFGR3_PKA_Pos)
#define GTZC_CFGR3_SAES_Pos   (15U)
#define GTZC_CFGR3_SAES_Msk   (0x01UL << GTZC_CFGR3_SAES_Pos)
#define GTZC_CFGR3_OCTOSPIM_Pos   (16U)
#define GTZC_CFGR3_OCTOSPIM_Msk   (0x01UL << GTZC_CFGR3_OCTOSPIM_Pos)
#define GTZC_CFGR3_SDMMC1_Pos   (17U)
#define GTZC_CFGR3_SDMMC1_Msk   (0x01UL << GTZC_CFGR3_SDMMC1_Pos)
#define GTZC_CFGR3_SDMMC2_Pos   (18U)
#define GTZC_CFGR3_SDMMC2_Msk   (0x01UL << GTZC_CFGR3_SDMMC2_Pos)
#define GTZC_CFGR3_FSMC_REG_Pos   (19U)
#define GTZC_CFGR3_FSMC_REG_Msk   (0x01UL << GTZC_CFGR3_FSMC_REG_Pos)
#define GTZC_CFGR3_OCTOSPI1_REG_Pos   (20U)
#define GTZC_CFGR3_OCTOSPI1_REG_Msk   (0x01UL << GTZC_CFGR3_OCTOSPI1_REG_Pos)
#define GTZC_CFGR3_OCTOSPI2_REG_Pos   (21U)
#define GTZC_CFGR3_OCTOSPI2_REG_Msk   (0x01UL << GTZC_CFGR3_OCTOSPI2_REG_Pos)
#define GTZC_CFGR3_RAMCFG_Pos   (22U)
#define GTZC_CFGR3_RAMCFG_Msk   (0x01UL << GTZC_CFGR3_RAMCFG_Pos)
#define GTZC_CFGR3_GPU2D_Pos   (23U)
#define GTZC_CFGR3_GPU2D_Msk   (0x01UL << GTZC_CFGR3_GPU2D_Pos)
#define GTZC_CFGR3_GFXMMU_Pos   (24U)
#define GTZC_CFGR3_GFXMMU_Msk   (0x01UL << GTZC_CFGR3_GFXMMU_Pos)
#define GTZC_CFGR3_GFXMMU_REG_Pos   (25U)
#define GTZC_CFGR3_GFXMMU_REG_Msk   (0x01UL << GTZC_CFGR3_GFXMMU_REG_Pos)
#define GTZC_CFGR3_HSPI1_REG_Pos   (26U)
#define GTZC_CFGR3_HSPI1_REG_Msk   (0x01UL << GTZC_CFGR3_HSPI1_REG_Pos)
#define GTZC_CFGR3_DCACHE2_REG_Pos   (27U)
#define GTZC_CFGR3_DCACHE2_REG_Msk   (0x01UL << GTZC_CFGR3_DCACHE2_REG_Pos)
#define GTZC_CFGR3_JPEG_Pos   (28U)
#define GTZC_CFGR3_JPEG_Msk   (0x01UL << GTZC_CFGR3_JPEG_Pos)
#define GTZC_CFGR4_GPDMA1_Pos   (0U)
#define GTZC_CFGR4_GPDMA1_Msk   (0x01UL << GTZC_CFGR4_GPDMA1_Pos)
#define GTZC_CFGR4_FLASH_REG_Pos   (1U)
#define GTZC_CFGR4_FLASH_REG_Msk   (0x01UL << GTZC_CFGR4_FLASH_REG_Pos)
#define GTZC_CFGR4_FLASH_Pos   (2U)
#define GTZC_CFGR4_FLASH_Msk   (0x01UL << GTZC_CFGR4_FLASH_Pos)
#define GTZC_CFGR4_OTFDEC1_Pos   (3U)
#define GTZC_CFGR4_OTFDEC1_Msk   (0x01UL << GTZC_CFGR4_OTFDEC1_Pos)
#define GTZC_CFGR4_OTFDEC2_Pos   (4U)
#define GTZC_CFGR4_OTFDEC2_Msk   (0x01UL << GTZC_CFGR4_OTFDEC2_Pos)
#define GTZC_CFGR4_TZSC1_Pos   (14U)
#define GTZC_CFGR4_TZSC1_Msk   (0x01UL << GTZC_CFGR4_TZSC1_Pos)
#define GTZC_CFGR4_TZIC1_Pos   (15U)
#define GTZC_CFGR4_TZIC1_Msk   (0x01UL << GTZC_CFGR4_TZIC1_Pos)
#define GTZC_CFGR4_OCTOSPI1_MEM_Pos   (16U)
#define GTZC_CFGR4_OCTOSPI1_MEM_Msk   (0x01UL << GTZC_CFGR4_OCTOSPI1_MEM_Pos)
#define GTZC_CFGR4_FSMC_MEM_Pos   (17U)
#define GTZC_CFGR4_FSMC_MEM_Msk   (0x01UL << GTZC_CFGR4_FSMC_MEM_Pos)
#define GTZC_CFGR4_BKPSRAM_Pos   (18U)
#define GTZC_CFGR4_BKPSRAM_Msk   (0x01UL << GTZC_CFGR4_BKPSRAM_Pos)
#define GTZC_CFGR4_OCTOSPI2_MEM_Pos   (19U)
#define GTZC_CFGR4_OCTOSPI2_MEM_Msk   (0x01UL << GTZC_CFGR4_OCTOSPI2_MEM_Pos)
#define GTZC_CFGR4_HSPI1_MEM_Pos   (20U)
#define GTZC_CFGR4_HSPI1_MEM_Msk   (0x01UL << GTZC_CFGR4_HSPI1_MEM_Pos)
#define GTZC_CFGR4_SRAM6_Pos   (22U)
#define GTZC_CFGR4_SRAM6_Msk   (0x01UL << GTZC_CFGR4_SRAM6_Pos)
#define GTZC_CFGR4_MPCBB6_REG_Pos   (23U)
#define GTZC_CFGR4_MPCBB6_REG_Msk   (0x01UL << GTZC_CFGR4_MPCBB6_REG_Pos)
#define GTZC_CFGR4_SRAM1_Pos   (24U)
#define GTZC_CFGR4_SRAM1_Msk   (0x01UL << GTZC_CFGR4_SRAM1_Pos)
#define GTZC_CFGR4_MPCBB1_REG_Pos   (25U)
#define GTZC_CFGR4_MPCBB1_REG_Msk   (0x01UL << GTZC_CFGR4_MPCBB1_REG_Pos)
#define GTZC_CFGR4_SRAM2_Pos   (26U)
#define GTZC_CFGR4_SRAM2_Msk   (0x01UL << GTZC_CFGR4_SRAM2_Pos)
#define GTZC_CFGR4_MPCBB2_REG_Pos   (27U)
#define GTZC_CFGR4_MPCBB2_REG_Msk   (0x01UL << GTZC_CFGR4_MPCBB2_REG_Pos)
#define GTZC_CFGR4_SRAM3_Pos   (28U)
#define GTZC_CFGR4_SRAM3_Msk   (0x01UL << GTZC_CFGR4_SRAM3_Pos)
#define GTZC_CFGR4_MPCBB3_REG_Pos   (29U)
#define GTZC_CFGR4_MPCBB3_REG_Msk   (0x01UL << GTZC_CFGR4_MPCBB3_REG_Pos)
#define GTZC_CFGR4_SRAM5_Pos   (30U)
#define GTZC_CFGR4_SRAM5_Msk   (0x01UL << GTZC_CFGR4_SRAM5_Pos)
#define GTZC_CFGR4_MPCBB5_REG_Pos   (31U)
#define GTZC_CFGR4_MPCBB5_REG_Msk   (0x01UL << GTZC_CFGR4_MPCBB5_REG_Pos)
#define GTZC_CFGR1_SPI3_Pos   (0U)
#define GTZC_CFGR1_SPI3_Msk   (0x01UL << GTZC_CFGR1_SPI3_Pos)
#define GTZC_CFGR1_LPUART1_Pos   (1U)
#define GTZC_CFGR1_LPUART1_Msk   (0x01UL << GTZC_CFGR1_LPUART1_Pos)
#define GTZC_CFGR1_I2C3_Pos   (2U)
#define GTZC_CFGR1_I2C3_Msk   (0x01UL << GTZC_CFGR1_I2C3_Pos)
#define GTZC_CFGR1_LPTIM1_Pos   (3U)
#define GTZC_CFGR1_LPTIM1_Msk   (0x01UL << GTZC_CFGR1_LPTIM1_Pos)
#define GTZC_CFGR1_LPTIM3_Pos   (4U)
#define GTZC_CFGR1_LPTIM3_Msk   (0x01UL << GTZC_CFGR1_LPTIM3_Pos)
#define GTZC_CFGR1_LPTIM4_Pos   (5U)
#define GTZC_CFGR1_LPTIM4_Msk   (0x01UL << GTZC_CFGR1_LPTIM4_Pos)
#define GTZC_CFGR1_OPAMP_Pos   (6U)
#define GTZC_CFGR1_OPAMP_Msk   (0x01UL << GTZC_CFGR1_OPAMP_Pos)
#define GTZC_CFGR1_COMP_Pos   (7U)
#define GTZC_CFGR1_COMP_Msk   (0x01UL << GTZC_CFGR1_COMP_Pos)
#define GTZC_CFGR1_ADC4_Pos   (8U)
#define GTZC_CFGR1_ADC4_Msk   (0x01UL << GTZC_CFGR1_ADC4_Pos)
#define GTZC_CFGR1_VREFBUF_Pos   (9U)
#define GTZC_CFGR1_VREFBUF_Msk   (0x01UL << GTZC_CFGR1_VREFBUF_Pos)
#define GTZC_CFGR1_DAC1_Pos   (11U)
#define GTZC_CFGR1_DAC1_Msk   (0x01UL << GTZC_CFGR1_DAC1_Pos)
#define GTZC_CFGR1_ADF1_Pos   (12U)
#define GTZC_CFGR1_ADF1_Msk   (0x01UL << GTZC_CFGR1_ADF1_Pos)
#define GTZC_CFGR2_SYSCFG_Pos   (0U)
#define GTZC_CFGR2_SYSCFG_Msk   (0x01UL << GTZC_CFGR2_SYSCFG_Pos)
#define GTZC_CFGR2_RTC_Pos   (1U)
#define GTZC_CFGR2_RTC_Msk   (0x01UL << GTZC_CFGR2_RTC_Pos)
#define GTZC_CFGR2_TAMP_Pos   (2U)
#define GTZC_CFGR2_TAMP_Msk   (0x01UL << GTZC_CFGR2_TAMP_Pos)
#define GTZC_CFGR2_PWR_Pos   (3U)
#define GTZC_CFGR2_PWR_Msk   (0x01UL << GTZC_CFGR2_PWR_Pos)
#define GTZC_CFGR2_RCC_Pos   (4U)
#define GTZC_CFGR2_RCC_Msk   (0x01UL << GTZC_CFGR2_RCC_Pos)
#define GTZC_CFGR2_LPDMA1_Pos   (5U)
#define GTZC_CFGR2_LPDMA1_Msk   (0x01UL << GTZC_CFGR2_LPDMA1_Pos)
#define GTZC_CFGR2_EXTI_Pos   (6U)
#define GTZC_CFGR2_EXTI_Msk   (0x01UL << GTZC_CFGR2_EXTI_Pos)
#define GTZC_CFGR2_TZSC2_Pos   (14U)
#define GTZC_CFGR2_TZSC2_Msk   (0x01UL << GTZC_CFGR2_TZSC2_Pos)
#define GTZC_CFGR2_TZIC2_Pos   (15U)
#define GTZC_CFGR2_TZIC2_Msk   (0x01UL << GTZC_CFGR2_TZIC2_Pos)
#define GTZC_CFGR2_SRAM4_Pos   (24U)
#define GTZC_CFGR2_SRAM4_Msk   (0x01UL << GTZC_CFGR2_SRAM4_Pos)
#define GTZC_CFGR2_MPCBB4_REG_Pos   (25U)
#define GTZC_CFGR2_MPCBB4_REG_Msk   (0x01UL << GTZC_CFGR2_MPCBB4_REG_Pos)
#define GTZC_TZSC1_SECCFGR1_TIM2_Pos   GTZC_CFGR1_TIM2_Pos
#define GTZC_TZSC1_SECCFGR1_TIM2_Msk   GTZC_CFGR1_TIM2_Msk
#define GTZC_TZSC1_SECCFGR1_TIM3_Pos   GTZC_CFGR1_TIM3_Pos
#define GTZC_TZSC1_SECCFGR1_TIM3_Msk   GTZC_CFGR1_TIM3_Msk
#define GTZC_TZSC1_SECCFGR1_TIM4_Pos   GTZC_CFGR1_TIM4_Pos
#define GTZC_TZSC1_SECCFGR1_TIM4_Msk   GTZC_CFGR1_TIM4_Msk
#define GTZC_TZSC1_SECCFGR1_TIM5_Pos   GTZC_CFGR1_TIM5_Pos
#define GTZC_TZSC1_SECCFGR1_TIM5_Msk   GTZC_CFGR1_TIM5_Msk
#define GTZC_TZSC1_SECCFGR1_TIM6_Pos   GTZC_CFGR1_TIM6_Pos
#define GTZC_TZSC1_SECCFGR1_TIM6_Msk   GTZC_CFGR1_TIM6_Msk
#define GTZC_TZSC1_SECCFGR1_TIM7_Pos   GTZC_CFGR1_TIM7_Pos
#define GTZC_TZSC1_SECCFGR1_TIM7_Msk   GTZC_CFGR1_TIM7_Msk
#define GTZC_TZSC1_SECCFGR1_WWDG_Pos   GTZC_CFGR1_WWDG_Pos
#define GTZC_TZSC1_SECCFGR1_WWDG_Msk   GTZC_CFGR1_WWDG_Msk
#define GTZC_TZSC1_SECCFGR1_IWDG_Pos   GTZC_CFGR1_IWDG_Pos
#define GTZC_TZSC1_SECCFGR1_IWDG_Msk   GTZC_CFGR1_IWDG_Msk
#define GTZC_TZSC1_SECCFGR1_SPI2_Pos   GTZC_CFGR1_SPI2_Pos
#define GTZC_TZSC1_SECCFGR1_SPI2_Msk   GTZC_CFGR1_SPI2_Msk
#define GTZC_TZSC1_SECCFGR1_USART2_Pos   GTZC_CFGR1_USART2_Pos
#define GTZC_TZSC1_SECCFGR1_USART2_Msk   GTZC_CFGR1_USART2_Msk
#define GTZC_TZSC1_SECCFGR1_USART3_Pos   GTZC_CFGR1_USART3_Pos
#define GTZC_TZSC1_SECCFGR1_USART3_Msk   GTZC_CFGR1_USART3_Msk
#define GTZC_TZSC1_SECCFGR1_UART4_Pos   GTZC_CFGR1_UART4_Pos
#define GTZC_TZSC1_SECCFGR1_UART4_Msk   GTZC_CFGR1_UART4_Msk
#define GTZC_TZSC1_SECCFGR1_UART5_Pos   GTZC_CFGR1_UART5_Pos
#define GTZC_TZSC1_SECCFGR1_UART5_Msk   GTZC_CFGR1_UART5_Msk
#define GTZC_TZSC1_SECCFGR1_I2C1_Pos   GTZC_CFGR1_I2C1_Pos
#define GTZC_TZSC1_SECCFGR1_I2C1_Msk   GTZC_CFGR1_I2C1_Msk
#define GTZC_TZSC1_SECCFGR1_I2C2_Pos   GTZC_CFGR1_I2C2_Pos
#define GTZC_TZSC1_SECCFGR1_I2C2_Msk   GTZC_CFGR1_I2C2_Msk
#define GTZC_TZSC1_SECCFGR1_CRS_Pos   GTZC_CFGR1_CRS_Pos
#define GTZC_TZSC1_SECCFGR1_CRS_Msk   GTZC_CFGR1_CRS_Msk
#define GTZC_TZSC1_SECCFGR1_I2C4_Pos   GTZC_CFGR1_I2C4_Pos
#define GTZC_TZSC1_SECCFGR1_I2C4_Msk   GTZC_CFGR1_I2C4_Msk
#define GTZC_TZSC1_SECCFGR1_LPTIM2_Pos   GTZC_CFGR1_LPTIM2_Pos
#define GTZC_TZSC1_SECCFGR1_LPTIM2_Msk   GTZC_CFGR1_LPTIM2_Msk
#define GTZC_TZSC1_SECCFGR1_FDCAN1_Pos   GTZC_CFGR1_FDCAN1_Pos
#define GTZC_TZSC1_SECCFGR1_FDCAN1_Msk   GTZC_CFGR1_FDCAN1_Msk
#define GTZC_TZSC1_SECCFGR1_UCPD1_Pos   GTZC_CFGR1_UCPD1_Pos
#define GTZC_TZSC1_SECCFGR1_UCPD1_Msk   GTZC_CFGR1_UCPD1_Msk
#define GTZC_TZSC1_SECCFGR1_USART6_Pos   GTZC_CFGR1_USART6_Pos
#define GTZC_TZSC1_SECCFGR1_USART6_Msk   GTZC_CFGR1_USART6_Msk
#define GTZC_TZSC1_SECCFGR1_I2C5_Pos   GTZC_CFGR1_I2C5_Pos
#define GTZC_TZSC1_SECCFGR1_I2C5_Msk   GTZC_CFGR1_I2C5_Msk
#define GTZC_TZSC1_SECCFGR1_I2C6_Pos   GTZC_CFGR1_I2C6_Pos
#define GTZC_TZSC1_SECCFGR1_I2C6_Msk   GTZC_CFGR1_I2C6_Msk
#define GTZC_TZSC1_SECCFGR2_TIM1_Pos   GTZC_CFGR2_TIM1_Pos
#define GTZC_TZSC1_SECCFGR2_TIM1_Msk   GTZC_CFGR2_TIM1_Msk
#define GTZC_TZSC1_SECCFGR2_SPI1_Pos   GTZC_CFGR2_SPI1_Pos
#define GTZC_TZSC1_SECCFGR2_SPI1_Msk   GTZC_CFGR2_SPI1_Msk
#define GTZC_TZSC1_SECCFGR2_TIM8_Pos   GTZC_CFGR2_TIM8_Pos
#define GTZC_TZSC1_SECCFGR2_TIM8_Msk   GTZC_CFGR2_TIM8_Msk
#define GTZC_TZSC1_SECCFGR2_USART1_Pos   GTZC_CFGR2_USART1_Pos
#define GTZC_TZSC1_SECCFGR2_USART1_Msk   GTZC_CFGR2_USART1_Msk
#define GTZC_TZSC1_SECCFGR2_TIM15_Pos   GTZC_CFGR2_TIM15_Pos
#define GTZC_TZSC1_SECCFGR2_TIM15_Msk   GTZC_CFGR2_TIM15_Msk
#define GTZC_TZSC1_SECCFGR2_TIM16_Pos   GTZC_CFGR2_TIM16_Pos
#define GTZC_TZSC1_SECCFGR2_TIM16_Msk   GTZC_CFGR2_TIM16_Msk
#define GTZC_TZSC1_SECCFGR2_TIM17_Pos   GTZC_CFGR2_TIM17_Pos
#define GTZC_TZSC1_SECCFGR2_TIM17_Msk   GTZC_CFGR2_TIM17_Msk
#define GTZC_TZSC1_SECCFGR2_SAI1_Pos   GTZC_CFGR2_SAI1_Pos
#define GTZC_TZSC1_SECCFGR2_SAI1_Msk   GTZC_CFGR2_SAI1_Msk
#define GTZC_TZSC1_SECCFGR2_SAI2_Pos   GTZC_CFGR2_SAI2_Pos
#define GTZC_TZSC1_SECCFGR2_SAI2_Msk   GTZC_CFGR2_SAI2_Msk
#define GTZC_TZSC1_SECCFGR2_LTDCUSB_Pos   GTZC_CFGR2_LTDCUSB_Pos
#define GTZC_TZSC1_SECCFGR2_LTDCUSB_Msk   GTZC_CFGR2_LTDCUSB_Msk
#define GTZC_TZSC1_SECCFGR2_DSI_Pos   GTZC_CFGR2_DSI_Pos
#define GTZC_TZSC1_SECCFGR2_DSI_Msk   GTZC_CFGR2_DSI_Msk
#define GTZC_TZSC1_SECCFGR2_GFXTIM_Pos   GTZC_CFGR2_GFXTIM_Pos
#define GTZC_TZSC1_SECCFGR2_GFXTIM_Msk   GTZC_CFGR2_GFXTIM_Msk
#define GTZC_TZSC1_SECCFGR3_MDF1_Pos   GTZC_CFGR3_MDF1_Pos
#define GTZC_TZSC1_SECCFGR3_MDF1_Msk   GTZC_CFGR3_MDF1_Msk
#define GTZC_TZSC1_SECCFGR3_CORDIC_Pos   GTZC_CFGR3_CORDIC_Pos
#define GTZC_TZSC1_SECCFGR3_CORDIC_Msk   GTZC_CFGR3_CORDIC_Msk
#define GTZC_TZSC1_SECCFGR3_FMAC_Pos   GTZC_CFGR3_FMAC_Pos
#define GTZC_TZSC1_SECCFGR3_FMAC_Msk   GTZC_CFGR3_FMAC_Msk
#define GTZC_TZSC1_SECCFGR3_CRC_Pos   GTZC_CFGR3_CRC_Pos
#define GTZC_TZSC1_SECCFGR3_CRC_Msk   GTZC_CFGR3_CRC_Msk
#define GTZC_TZSC1_SECCFGR3_TSC_Pos   GTZC_CFGR3_TSC_Pos
#define GTZC_TZSC1_SECCFGR3_TSC_Msk   GTZC_CFGR3_TSC_Msk
#define GTZC_TZSC1_SECCFGR3_DMA2D_Pos   GTZC_CFGR3_DMA2D_Pos
#define GTZC_TZSC1_SECCFGR3_DMA2D_Msk   GTZC_CFGR3_DMA2D_Msk
#define GTZC_TZSC1_SECCFGR3_ICACHE_REG_Pos   GTZC_CFGR3_ICACHE_REG_Pos
#define GTZC_TZSC1_SECCFGR3_ICACHE_REG_Msk   GTZC_CFGR3_ICACHE_REG_Msk
#define GTZC_TZSC1_SECCFGR3_DCACHE1_REG_Pos   GTZC_CFGR3_DCACHE1_REG_Pos
#define GTZC_TZSC1_SECCFGR3_DCACHE1_REG_Msk   GTZC_CFGR3_DCACHE1_REG_Msk
#define GTZC_TZSC1_SECCFGR3_ADC12_Pos   GTZC_CFGR3_ADC12_Pos
#define GTZC_TZSC1_SECCFGR3_ADC12_Msk   GTZC_CFGR3_ADC12_Msk
#define GTZC_TZSC1_SECCFGR3_DCMI_Pos   GTZC_CFGR3_DCMI_Pos
#define GTZC_TZSC1_SECCFGR3_DCMI_Msk   GTZC_CFGR3_DCMI_Msk
#define GTZC_TZSC1_SECCFGR3_OTG_Pos   GTZC_CFGR3_OTG_Pos
#define GTZC_TZSC1_SECCFGR3_OTG_Msk   GTZC_CFGR3_OTG_Msk
#define GTZC_TZSC1_SECCFGR3_AES_Pos   GTZC_CFGR3_AES_Pos
#define GTZC_TZSC1_SECCFGR3_AES_Msk   GTZC_CFGR3_AES_Msk
#define GTZC_TZSC1_SECCFGR3_HASH_Pos   GTZC_CFGR3_HASH_Pos
#define GTZC_TZSC1_SECCFGR3_HASH_Msk   GTZC_CFGR3_HASH_Msk
#define GTZC_TZSC1_SECCFGR3_RNG_Pos   GTZC_CFGR3_RNG_Pos
#define GTZC_TZSC1_SECCFGR3_RNG_Msk   GTZC_CFGR3_RNG_Msk
#define GTZC_TZSC1_SECCFGR3_PKA_Pos   GTZC_CFGR3_PKA_Pos
#define GTZC_TZSC1_SECCFGR3_PKA_Msk   GTZC_CFGR3_PKA_Msk
#define GTZC_TZSC1_SECCFGR3_SAES_Pos   GTZC_CFGR3_SAES_Pos
#define GTZC_TZSC1_SECCFGR3_SAES_Msk   GTZC_CFGR3_SAES_Msk
#define GTZC_TZSC1_SECCFGR3_OCTOSPIM_Pos   GTZC_CFGR3_OCTOSPIM_Pos
#define GTZC_TZSC1_SECCFGR3_OCTOSPIM_Msk   GTZC_CFGR3_OCTOSPIM_Msk
#define GTZC_TZSC1_SECCFGR3_SDMMC1_Pos   GTZC_CFGR3_SDMMC1_Pos
#define GTZC_TZSC1_SECCFGR3_SDMMC1_Msk   GTZC_CFGR3_SDMMC1_Msk
#define GTZC_TZSC1_SECCFGR3_SDMMC2_Pos   GTZC_CFGR3_SDMMC2_Pos
#define GTZC_TZSC1_SECCFGR3_SDMMC2_Msk   GTZC_CFGR3_SDMMC2_Msk
#define GTZC_TZSC1_SECCFGR3_FSMC_REG_Pos   GTZC_CFGR3_FSMC_REG_Pos
#define GTZC_TZSC1_SECCFGR3_FSMC_REG_Msk   GTZC_CFGR3_FSMC_REG_Msk
#define GTZC_TZSC1_SECCFGR3_OCTOSPI1_REG_Pos   GTZC_CFGR3_OCTOSPI1_REG_Pos
#define GTZC_TZSC1_SECCFGR3_OCTOSPI1_REG_Msk   GTZC_CFGR3_OCTOSPI1_REG_Msk
#define GTZC_TZSC1_SECCFGR3_OCTOSPI2_REG_Pos   GTZC_CFGR3_OCTOSPI2_REG_Pos
#define GTZC_TZSC1_SECCFGR3_OCTOSPI2_REG_Msk   GTZC_CFGR3_OCTOSPI2_REG_Msk
#define GTZC_TZSC1_SECCFGR3_RAMCFG_Pos   GTZC_CFGR3_RAMCFG_Pos
#define GTZC_TZSC1_SECCFGR3_RAMCFG_Msk   GTZC_CFGR3_RAMCFG_Msk
#define GTZC_TZSC1_SECCFGR3_GPU2D_Pos   GTZC_CFGR3_GPU2D_Pos
#define GTZC_TZSC1_SECCFGR3_GPU2D_Msk   GTZC_CFGR3_GPU2D_Msk
#define GTZC_TZSC1_SECCFGR3_GFXMMU_Pos   GTZC_CFGR3_GFXMMU_Pos
#define GTZC_TZSC1_SECCFGR3_GFXMMU_Msk   GTZC_CFGR3_GFXMMU_Msk
#define GTZC_TZSC1_SECCFGR3_GFXMMU_REG_Pos   GTZC_CFGR3_GFXMMU_REG_Pos
#define GTZC_TZSC1_SECCFGR3_GFXMMU_REG_Msk   GTZC_CFGR3_GFXMMU_REG_Msk
#define GTZC_TZSC1_SECCFGR3_HSPI1_REG_Pos   GTZC_CFGR3_HSPI1_REG_Pos
#define GTZC_TZSC1_SECCFGR3_HSPI1_REG_Msk   GTZC_CFGR3_HSPI1_REG_Msk
#define GTZC_TZSC1_SECCFGR3_DCACHE2_REG_Pos   GTZC_CFGR3_DCACHE2_REG_Pos
#define GTZC_TZSC1_SECCFGR3_DCACHE2_REG_Msk   GTZC_CFGR3_DCACHE2_REG_Msk
#define GTZC_TZSC1_SECCFGR3_JPEG_Pos   GTZC_CFGR3_JPEG_REG_Pos
#define GTZC_TZSC1_SECCFGR3_JPEG_Msk   GTZC_CFGR3_JPEG_REG_Msk
#define GTZC_TZSC2_SECCFGR1_SPI3_Pos   GTZC_CFGR1_SPI3_Pos
#define GTZC_TZSC2_SECCFGR1_SPI3_Msk   GTZC_CFGR1_SPI3_Msk
#define GTZC_TZSC2_SECCFGR1_LPUART1_Pos   GTZC_CFGR1_LPUART1_Pos
#define GTZC_TZSC2_SECCFGR1_LPUART1_Msk   GTZC_CFGR1_LPUART1_Msk
#define GTZC_TZSC2_SECCFGR1_I2C3_Pos   GTZC_CFGR1_I2C3_Pos
#define GTZC_TZSC2_SECCFGR1_I2C3_Msk   GTZC_CFGR1_I2C3_Msk
#define GTZC_TZSC2_SECCFGR1_LPTIM1_Pos   GTZC_CFGR1_LPTIM1_Pos
#define GTZC_TZSC2_SECCFGR1_LPTIM1_Msk   GTZC_CFGR1_LPTIM1_Msk
#define GTZC_TZSC2_SECCFGR1_LPTIM3_Pos   GTZC_CFGR1_LPTIM3_Pos
#define GTZC_TZSC2_SECCFGR1_LPTIM3_Msk   GTZC_CFGR1_LPTIM3_Msk
#define GTZC_TZSC2_SECCFGR1_LPTIM4_Pos   GTZC_CFGR1_LPTIM4_Pos
#define GTZC_TZSC2_SECCFGR1_LPTIM4_Msk   GTZC_CFGR1_LPTIM4_Msk
#define GTZC_TZSC2_SECCFGR1_OPAMP_Pos   GTZC_CFGR1_OPAMP_Pos
#define GTZC_TZSC2_SECCFGR1_OPAMP_Msk   GTZC_CFGR1_OPAMP_Msk
#define GTZC_TZSC2_SECCFGR1_COMP_Pos   GTZC_CFGR1_COMP_Pos
#define GTZC_TZSC2_SECCFGR1_COMP_Msk   GTZC_CFGR1_COMP_Msk
#define GTZC_TZSC2_SECCFGR1_ADC4_Pos   GTZC_CFGR1_ADC4_Pos
#define GTZC_TZSC2_SECCFGR1_ADC4_Msk   GTZC_CFGR1_ADC4_Msk
#define GTZC_TZSC2_SECCFGR1_VREFBUF_Pos   GTZC_CFGR1_VREFBUF_Pos
#define GTZC_TZSC2_SECCFGR1_VREFBUF_Msk   GTZC_CFGR1_VREFBUF_Msk
#define GTZC_TZSC2_SECCFGR1_DAC1_Pos   GTZC_CFGR1_DAC1_Pos
#define GTZC_TZSC2_SECCFGR1_DAC1_Msk   GTZC_CFGR1_DAC1_Msk
#define GTZC_TZSC2_SECCFGR1_ADF1_Pos   GTZC_CFGR1_ADF1_Pos
#define GTZC_TZSC2_SECCFGR1_ADF1_Msk   GTZC_CFGR1_ADF1_Msk
#define GTZC_TZSC1_PRIVCFGR1_TIM2_Pos   GTZC_CFGR1_TIM2_Pos
#define GTZC_TZSC1_PRIVCFGR1_TIM2_Msk   GTZC_CFGR1_TIM2_Msk
#define GTZC_TZSC1_PRIVCFGR1_TIM3_Pos   GTZC_CFGR1_TIM3_Pos
#define GTZC_TZSC1_PRIVCFGR1_TIM3_Msk   GTZC_CFGR1_TIM3_Msk
#define GTZC_TZSC1_PRIVCFGR1_TIM4_Pos   GTZC_CFGR1_TIM4_Pos
#define GTZC_TZSC1_PRIVCFGR1_TIM4_Msk   GTZC_CFGR1_TIM4_Msk
#define GTZC_TZSC1_PRIVCFGR1_TIM5_Pos   GTZC_CFGR1_TIM5_Pos
#define GTZC_TZSC1_PRIVCFGR1_TIM5_Msk   GTZC_CFGR1_TIM5_Msk
#define GTZC_TZSC1_PRIVCFGR1_TIM6_Pos   GTZC_CFGR1_TIM6_Pos
#define GTZC_TZSC1_PRIVCFGR1_TIM6_Msk   GTZC_CFGR1_TIM6_Msk
#define GTZC_TZSC1_PRIVCFGR1_TIM7_Pos   GTZC_CFGR1_TIM7_Pos
#define GTZC_TZSC1_PRIVCFGR1_TIM7_Msk   GTZC_CFGR1_TIM7_Msk
#define GTZC_TZSC1_PRIVCFGR1_WWDG_Pos   GTZC_CFGR1_WWDG_Pos
#define GTZC_TZSC1_PRIVCFGR1_WWDG_Msk   GTZC_CFGR1_WWDG_Msk
#define GTZC_TZSC1_PRIVCFGR1_IWDG_Pos   GTZC_CFGR1_IWDG_Pos
#define GTZC_TZSC1_PRIVCFGR1_IWDG_Msk   GTZC_CFGR1_IWDG_Msk
#define GTZC_TZSC1_PRIVCFGR1_SPI2_Pos   GTZC_CFGR1_SPI2_Pos
#define GTZC_TZSC1_PRIVCFGR1_SPI2_Msk   GTZC_CFGR1_SPI2_Msk
#define GTZC_TZSC1_PRIVCFGR1_USART2_Pos   GTZC_CFGR1_USART2_Pos
#define GTZC_TZSC1_PRIVCFGR1_USART2_Msk   GTZC_CFGR1_USART2_Msk
#define GTZC_TZSC1_PRIVCFGR1_USART3_Pos   GTZC_CFGR1_USART3_Pos
#define GTZC_TZSC1_PRIVCFGR1_USART3_Msk   GTZC_CFGR1_USART3_Msk
#define GTZC_TZSC1_PRIVCFGR1_UART4_Pos   GTZC_CFGR1_UART4_Pos
#define GTZC_TZSC1_PRIVCFGR1_UART4_Msk   GTZC_CFGR1_UART4_Msk
#define GTZC_TZSC1_PRIVCFGR1_UART5_Pos   GTZC_CFGR1_UART5_Pos
#define GTZC_TZSC1_PRIVCFGR1_UART5_Msk   GTZC_CFGR1_UART5_Msk
#define GTZC_TZSC1_PRIVCFGR1_I2C1_Pos   GTZC_CFGR1_I2C1_Pos
#define GTZC_TZSC1_PRIVCFGR1_I2C1_Msk   GTZC_CFGR1_I2C1_Msk
#define GTZC_TZSC1_PRIVCFGR1_I2C2_Pos   GTZC_CFGR1_I2C2_Pos
#define GTZC_TZSC1_PRIVCFGR1_I2C2_Msk   GTZC_CFGR1_I2C2_Msk
#define GTZC_TZSC1_PRIVCFGR1_CRS_Pos   GTZC_CFGR1_CRS_Pos
#define GTZC_TZSC1_PRIVCFGR1_CRS_Msk   GTZC_CFGR1_CRS_Msk
#define GTZC_TZSC1_PRIVCFGR1_I2C4_Pos   GTZC_CFGR1_I2C4_Pos
#define GTZC_TZSC1_PRIVCFGR1_I2C4_Msk   GTZC_CFGR1_I2C4_Msk
#define GTZC_TZSC1_PRIVCFGR1_LPTIM2_Pos   GTZC_CFGR1_LPTIM2_Pos
#define GTZC_TZSC1_PRIVCFGR1_LPTIM2_Msk   GTZC_CFGR1_LPTIM2_Msk
#define GTZC_TZSC1_PRIVCFGR1_FDCAN1_Pos   GTZC_CFGR1_FDCAN1_Pos
#define GTZC_TZSC1_PRIVCFGR1_FDCAN1_Msk   GTZC_CFGR1_FDCAN1_Msk
#define GTZC_TZSC1_PRIVCFGR1_UCPD1_Pos   GTZC_CFGR1_UCPD1_Pos
#define GTZC_TZSC1_PRIVCFGR1_UCPD1_Msk   GTZC_CFGR1_UCPD1_Msk
#define GTZC_TZSC1_PRIVCFGR1_USART6_Pos   GTZC_CFGR1_USART6_Pos
#define GTZC_TZSC1_PRIVCFGR1_USART6_Msk   GTZC_CFGR1_USART6_Msk
#define GTZC_TZSC1_PRIVCFGR1_I2C5_Pos   GTZC_CFGR1_I2C5_Pos
#define GTZC_TZSC1_PRIVCFGR1_I2C5_Msk   GTZC_CFGR1_I2C5_Msk
#define GTZC_TZSC1_PRIVCFGR1_I2C6_Pos   GTZC_CFGR1_I2C6_Pos
#define GTZC_TZSC1_PRIVCFGR1_I2C6_Msk   GTZC_CFGR1_I2C6_Msk
#define GTZC_TZSC1_PRIVCFGR2_TIM1_Pos   GTZC_CFGR2_TIM1_Pos
#define GTZC_TZSC1_PRIVCFGR2_TIM1_Msk   GTZC_CFGR2_TIM1_Msk
#define GTZC_TZSC1_PRIVCFGR2_SPI1_Pos   GTZC_CFGR2_SPI1_Pos
#define GTZC_TZSC1_PRIVCFGR2_SPI1_Msk   GTZC_CFGR2_SPI1_Msk
#define GTZC_TZSC1_PRIVCFGR2_TIM8_Pos   GTZC_CFGR2_TIM8_Pos
#define GTZC_TZSC1_PRIVCFGR2_TIM8_Msk   GTZC_CFGR2_TIM8_Msk
#define GTZC_TZSC1_PRIVCFGR2_USART1_Pos   GTZC_CFGR2_USART1_Pos
#define GTZC_TZSC1_PRIVCFGR2_USART1_Msk   GTZC_CFGR2_USART1_Msk
#define GTZC_TZSC1_PRIVCFGR2_TIM15_Pos   GTZC_CFGR2_TIM15_Pos
#define GTZC_TZSC1_PRIVCFGR2_TIM15_Msk   GTZC_CFGR2_TIM15_Msk
#define GTZC_TZSC1_PRIVCFGR2_TIM16_Pos   GTZC_CFGR2_TIM16_Pos
#define GTZC_TZSC1_PRIVCFGR2_TIM16_Msk   GTZC_CFGR2_TIM16_Msk
#define GTZC_TZSC1_PRIVCFGR2_TIM17_Pos   GTZC_CFGR2_TIM17_Pos
#define GTZC_TZSC1_PRIVCFGR2_TIM17_Msk   GTZC_CFGR2_TIM17_Msk
#define GTZC_TZSC1_PRIVCFGR2_SAI1_Pos   GTZC_CFGR2_SAI1_Pos
#define GTZC_TZSC1_PRIVCFGR2_SAI1_Msk   GTZC_CFGR2_SAI1_Msk
#define GTZC_TZSC1_PRIVCFGR2_SAI2_Pos   GTZC_CFGR2_SAI2_Pos
#define GTZC_TZSC1_PRIVCFGR2_SAI2_Msk   GTZC_CFGR2_SAI2_Msk
#define GTZC_TZSC1_PRIVCFGR2_LTDCUSB_Pos   GTZC_CFGR2_LTDCUSB_Pos
#define GTZC_TZSC1_PRIVCFGR2_LTDCUSB_Msk   GTZC_CFGR2_LTDCUSB_Msk
#define GTZC_TZSC1_PRIVCFGR2_DSI_Pos   GTZC_CFGR2_DSI_Pos
#define GTZC_TZSC1_PRIVCFGR2_DSI_Msk   GTZC_CFGR2_DSI_Msk
#define GTZC_TZSC1_PRIVCFGR2_GFXTIM_Pos   GTZC_CFGR2_GFXTIM_Pos
#define GTZC_TZSC1_PRIVCFGR2_GFXTIM_Msk   GTZC_CFGR2_GFXTIM_Msk
#define GTZC_TZSC1_PRIVCFGR3_MDF1_Pos   GTZC_CFGR3_MDF1_Pos
#define GTZC_TZSC1_PRIVCFGR3_MDF1_Msk   GTZC_CFGR3_MDF1_Msk
#define GTZC_TZSC1_PRIVCFGR3_CORDIC_Pos   GTZC_CFGR3_CORDIC_Pos
#define GTZC_TZSC1_PRIVCFGR3_CORDIC_Msk   GTZC_CFGR3_CORDIC_Msk
#define GTZC_TZSC1_PRIVCFGR3_FMAC_Pos   GTZC_CFGR3_FMAC_Pos
#define GTZC_TZSC1_PRIVCFGR3_FMAC_Msk   GTZC_CFGR3_FMAC_Msk
#define GTZC_TZSC1_PRIVCFGR3_CRC_Pos   GTZC_CFGR3_CRC_Pos
#define GTZC_TZSC1_PRIVCFGR3_CRC_Msk   GTZC_CFGR3_CRC_Msk
#define GTZC_TZSC1_PRIVCFGR3_TSC_Pos   GTZC_CFGR3_TSC_Pos
#define GTZC_TZSC1_PRIVCFGR3_TSC_Msk   GTZC_CFGR3_TSC_Msk
#define GTZC_TZSC1_PRIVCFGR3_DMA2D_Pos   GTZC_CFGR3_DMA2D_Pos
#define GTZC_TZSC1_PRIVCFGR3_DMA2D_Msk   GTZC_CFGR3_DMA2D_Msk
#define GTZC_TZSC1_PRIVCFGR3_ICACHE_REG_Pos   GTZC_CFGR3_ICACHE_REG_Pos
#define GTZC_TZSC1_PRIVCFGR3_ICACHE_REG_Msk   GTZC_CFGR3_ICACHE_REG_Msk
#define GTZC_TZSC1_PRIVCFGR3_DCACHE1_REG_Pos   GTZC_CFGR3_DCACHE1_REG_Pos
#define GTZC_TZSC1_PRIVCFGR3_DCACHE1_REG_Msk   GTZC_CFGR3_DCACHE1_REG_Msk
#define GTZC_TZSC1_PRIVCFGR3_ADC12_Pos   GTZC_CFGR3_ADC12_Pos
#define GTZC_TZSC1_PRIVCFGR3_ADC12_Msk   GTZC_CFGR3_ADC12_Msk
#define GTZC_TZSC1_PRIVCFGR3_DCMI_Pos   GTZC_CFGR3_DCMI_Pos
#define GTZC_TZSC1_PRIVCFGR3_DCMI_Msk   GTZC_CFGR3_DCMI_Msk
#define GTZC_TZSC1_PRIVCFGR3_OTG_Pos   GTZC_CFGR3_OTG_Pos
#define GTZC_TZSC1_PRIVCFGR3_OTG_Msk   GTZC_CFGR3_OTG_Msk
#define GTZC_TZSC1_PRIVCFGR3_AES_Pos   GTZC_CFGR3_AES_Pos
#define GTZC_TZSC1_PRIVCFGR3_AES_Msk   GTZC_CFGR3_AES_Msk
#define GTZC_TZSC1_PRIVCFGR3_HASH_Pos   GTZC_CFGR3_HASH_Pos
#define GTZC_TZSC1_PRIVCFGR3_HASH_Msk   GTZC_CFGR3_HASH_Msk
#define GTZC_TZSC1_PRIVCFGR3_RNG_Pos   GTZC_CFGR3_RNG_Pos
#define GTZC_TZSC1_PRIVCFGR3_RNG_Msk   GTZC_CFGR3_RNG_Msk
#define GTZC_TZSC1_PRIVCFGR3_PKA_Pos   GTZC_CFGR3_PKA_Pos
#define GTZC_TZSC1_PRIVCFGR3_PKA_Msk   GTZC_CFGR3_PKA_Msk
#define GTZC_TZSC1_PRIVCFGR3_SAES_Pos   GTZC_CFGR3_SAES_Pos
#define GTZC_TZSC1_PRIVCFGR3_SAES_Msk   GTZC_CFGR3_SAES_Msk
#define GTZC_TZSC1_PRIVCFGR3_OCTOSPIM_Pos   GTZC_CFGR3_OCTOSPIM_Pos
#define GTZC_TZSC1_PRIVCFGR3_OCTOSPIM_Msk   GTZC_CFGR3_OCTOSPIM_Msk
#define GTZC_TZSC1_PRIVCFGR3_SDMMC1_Pos   GTZC_CFGR3_SDMMC1_Pos
#define GTZC_TZSC1_PRIVCFGR3_SDMMC1_Msk   GTZC_CFGR3_SDMMC1_Msk
#define GTZC_TZSC1_PRIVCFGR3_SDMMC2_Pos   GTZC_CFGR3_SDMMC2_Pos
#define GTZC_TZSC1_PRIVCFGR3_SDMMC2_Msk   GTZC_CFGR3_SDMMC2_Msk
#define GTZC_TZSC1_PRIVCFGR3_FSMC_REG_Pos   GTZC_CFGR3_FSMC_REG_Pos
#define GTZC_TZSC1_PRIVCFGR3_FSMC_REG_Msk   GTZC_CFGR3_FSMC_REG_Msk
#define GTZC_TZSC1_PRIVCFGR3_OCTOSPI1_REG_Pos   GTZC_CFGR3_OCTOSPI1_REG_Pos
#define GTZC_TZSC1_PRIVCFGR3_OCTOSPI1_REG_Msk   GTZC_CFGR3_OCTOSPI1_REG_Msk
#define GTZC_TZSC1_PRIVCFGR3_OCTOSPI2_REG_Pos   GTZC_CFGR3_OCTOSPI2_REG_Pos
#define GTZC_TZSC1_PRIVCFGR3_OCTOSPI2_REG_Msk   GTZC_CFGR3_OCTOSPI2_REG_Msk
#define GTZC_TZSC1_PRIVCFGR3_RAMCFG_Pos   GTZC_CFGR3_RAMCFG_Pos
#define GTZC_TZSC1_PRIVCFGR3_RAMCFG_Msk   GTZC_CFGR3_RAMCFG_Msk
#define GTZC_TZSC1_PRIVCFGR3_GPU2D_Pos   GTZC_CFGR3_GPU2D_Pos
#define GTZC_TZSC1_PRIVCFGR3_GPU2D_Msk   GTZC_CFGR3_GPU2D_Msk
#define GTZC_TZSC1_PRIVCFGR3_GFXMMU_Pos   GTZC_CFGR3_GFXMMU_Pos
#define GTZC_TZSC1_PRIVCFGR3_GFXMMU_Msk   GTZC_CFGR3_GFXMMU_Msk
#define GTZC_TZSC1_PRIVCFGR3_GFXMMU_REG_Pos   GTZC_CFGR3_GFXMMU_REG_Pos
#define GTZC_TZSC1_PRIVCFGR3_GFXMMU_REG_Msk   GTZC_CFGR3_GFXMMU_REG_Msk
#define GTZC_TZSC1_PRIVCFGR3_HSPI1_REG_Pos   GTZC_CFGR3_HSPI1_REG_Pos
#define GTZC_TZSC1_PRIVCFGR3_HSPI1_REG_Msk   GTZC_CFGR3_HSPI1_REG_Msk
#define GTZC_TZSC1_PRIVCFGR3_DCACHE2_REG_Pos   GTZC_CFGR3_DCACHE2_REG_Pos
#define GTZC_TZSC1_PRIVCFGR3_DCACHE2_REG_Msk   GTZC_CFGR3_DCACHE2_REG_Msk
#define GTZC_TZSC1_PRIVCFGR3_JPEG_Pos   GTZC_CFGR3_JPEG_REG_Pos
#define GTZC_TZSC1_PRIVCFGR3_JPEG_Msk   GTZC_CFGR3_JPEG_REG_Msk
#define GTZC_TZSC2_PRIVCFGR1_SPI3_Pos   GTZC_CFGR1_SPI3_Pos
#define GTZC_TZSC2_PRIVCFGR1_SPI3_Msk   GTZC_CFGR1_SPI3_Msk
#define GTZC_TZSC2_PRIVCFGR1_LPUART1_Pos   GTZC_CFGR1_LPUART1_Pos
#define GTZC_TZSC2_PRIVCFGR1_LPUART1_Msk   GTZC_CFGR1_LPUART1_Msk
#define GTZC_TZSC2_PRIVCFGR1_I2C3_Pos   GTZC_CFGR1_I2C3_Pos
#define GTZC_TZSC2_PRIVCFGR1_I2C3_Msk   GTZC_CFGR1_I2C3_Msk
#define GTZC_TZSC2_PRIVCFGR1_LPTIM1_Pos   GTZC_CFGR1_LPTIM1_Pos
#define GTZC_TZSC2_PRIVCFGR1_LPTIM1_Msk   GTZC_CFGR1_LPTIM1_Msk
#define GTZC_TZSC2_PRIVCFGR1_LPTIM3_Pos   GTZC_CFGR1_LPTIM3_Pos
#define GTZC_TZSC2_PRIVCFGR1_LPTIM3_Msk   GTZC_CFGR1_LPTIM3_Msk
#define GTZC_TZSC2_PRIVCFGR1_LPTIM4_Pos   GTZC_CFGR1_LPTIM4_Pos
#define GTZC_TZSC2_PRIVCFGR1_LPTIM4_Msk   GTZC_CFGR1_LPTIM4_Msk
#define GTZC_TZSC2_PRIVCFGR1_OPAMP_Pos   GTZC_CFGR1_OPAMP_Pos
#define GTZC_TZSC2_PRIVCFGR1_OPAMP_Msk   GTZC_CFGR1_OPAMP_Msk
#define GTZC_TZSC2_PRIVCFGR1_COMP_Pos   GTZC_CFGR1_COMP_Pos
#define GTZC_TZSC2_PRIVCFGR1_COMP_Msk   GTZC_CFGR1_COMP_Msk
#define GTZC_TZSC2_PRIVCFGR1_ADC4_Pos   GTZC_CFGR1_ADC4_Pos
#define GTZC_TZSC2_PRIVCFGR1_ADC4_Msk   GTZC_CFGR1_ADC4_Msk
#define GTZC_TZSC2_PRIVCFGR1_VREFBUF_Pos   GTZC_CFGR1_VREFBUF_Pos
#define GTZC_TZSC2_PRIVCFGR1_VREFBUF_Msk   GTZC_CFGR1_VREFBUF_Msk
#define GTZC_TZSC2_PRIVCFGR1_DAC1_Pos   GTZC_CFGR1_DAC1_Pos
#define GTZC_TZSC2_PRIVCFGR1_DAC1_Msk   GTZC_CFGR1_DAC1_Msk
#define GTZC_TZSC2_PRIVCFGR1_ADF1_Pos   GTZC_CFGR1_ADF1_Pos
#define GTZC_TZSC2_PRIVCFGR1_ADF1_Msk   GTZC_CFGR1_ADF1_Msk
#define GTZC_TZIC1_IER1_TIM2_Pos   GTZC_CFGR1_TIM2_Pos
#define GTZC_TZIC1_IER1_TIM2_Msk   GTZC_CFGR1_TIM2_Msk
#define GTZC_TZIC1_IER1_TIM3_Pos   GTZC_CFGR1_TIM3_Pos
#define GTZC_TZIC1_IER1_TIM3_Msk   GTZC_CFGR1_TIM3_Msk
#define GTZC_TZIC1_IER1_TIM4_Pos   GTZC_CFGR1_TIM4_Pos
#define GTZC_TZIC1_IER1_TIM4_Msk   GTZC_CFGR1_TIM4_Msk
#define GTZC_TZIC1_IER1_TIM5_Pos   GTZC_CFGR1_TIM5_Pos
#define GTZC_TZIC1_IER1_TIM5_Msk   GTZC_CFGR1_TIM5_Msk
#define GTZC_TZIC1_IER1_TIM6_Pos   GTZC_CFGR1_TIM6_Pos
#define GTZC_TZIC1_IER1_TIM6_Msk   GTZC_CFGR1_TIM6_Msk
#define GTZC_TZIC1_IER1_TIM7_Pos   GTZC_CFGR1_TIM7_Pos
#define GTZC_TZIC1_IER1_TIM7_Msk   GTZC_CFGR1_TIM7_Msk
#define GTZC_TZIC1_IER1_WWDG_Pos   GTZC_CFGR1_WWDG_Pos
#define GTZC_TZIC1_IER1_WWDG_Msk   GTZC_CFGR1_WWDG_Msk
#define GTZC_TZIC1_IER1_IWDG_Pos   GTZC_CFGR1_IWDG_Pos
#define GTZC_TZIC1_IER1_IWDG_Msk   GTZC_CFGR1_IWDG_Msk
#define GTZC_TZIC1_IER1_SPI2_Pos   GTZC_CFGR1_SPI2_Pos
#define GTZC_TZIC1_IER1_SPI2_Msk   GTZC_CFGR1_SPI2_Msk
#define GTZC_TZIC1_IER1_USART2_Pos   GTZC_CFGR1_USART2_Pos
#define GTZC_TZIC1_IER1_USART2_Msk   GTZC_CFGR1_USART2_Msk
#define GTZC_TZIC1_IER1_USART3_Pos   GTZC_CFGR1_USART3_Pos
#define GTZC_TZIC1_IER1_USART3_Msk   GTZC_CFGR1_USART3_Msk
#define GTZC_TZIC1_IER1_UART4_Pos   GTZC_CFGR1_UART4_Pos
#define GTZC_TZIC1_IER1_UART4_Msk   GTZC_CFGR1_UART4_Msk
#define GTZC_TZIC1_IER1_UART5_Pos   GTZC_CFGR1_UART5_Pos
#define GTZC_TZIC1_IER1_UART5_Msk   GTZC_CFGR1_UART5_Msk
#define GTZC_TZIC1_IER1_I2C1_Pos   GTZC_CFGR1_I2C1_Pos
#define GTZC_TZIC1_IER1_I2C1_Msk   GTZC_CFGR1_I2C1_Msk
#define GTZC_TZIC1_IER1_I2C2_Pos   GTZC_CFGR1_I2C2_Pos
#define GTZC_TZIC1_IER1_I2C2_Msk   GTZC_CFGR1_I2C2_Msk
#define GTZC_TZIC1_IER1_CRS_Pos   GTZC_CFGR1_CRS_Pos
#define GTZC_TZIC1_IER1_CRS_Msk   GTZC_CFGR1_CRS_Msk
#define GTZC_TZIC1_IER1_I2C4_Pos   GTZC_CFGR1_I2C4_Pos
#define GTZC_TZIC1_IER1_I2C4_Msk   GTZC_CFGR1_I2C4_Msk
#define GTZC_TZIC1_IER1_LPTIM2_Pos   GTZC_CFGR1_LPTIM2_Pos
#define GTZC_TZIC1_IER1_LPTIM2_Msk   GTZC_CFGR1_LPTIM2_Msk
#define GTZC_TZIC1_IER1_FDCAN1_Pos   GTZC_CFGR1_FDCAN1_Pos
#define GTZC_TZIC1_IER1_FDCAN1_Msk   GTZC_CFGR1_FDCAN1_Msk
#define GTZC_TZIC1_IER1_UCPD1_Pos   GTZC_CFGR1_UCPD1_Pos
#define GTZC_TZIC1_IER1_UCPD1_Msk   GTZC_CFGR1_UCPD1_Msk
#define GTZC_TZIC1_IER1_USART6_Pos   GTZC_CFGR1_USART6_Pos
#define GTZC_TZIC1_IER1_USART6_Msk   GTZC_CFGR1_USART6_Msk
#define GTZC_TZIC1_IER1_I2C5_Pos   GTZC_CFGR1_I2C5_Pos
#define GTZC_TZIC1_IER1_I2C5_Msk   GTZC_CFGR1_I2C5_Msk
#define GTZC_TZIC1_IER1_I2C6_Pos   GTZC_CFGR1_I2C6_Pos
#define GTZC_TZIC1_IER1_I2C6_Msk   GTZC_CFGR1_I2C6_Msk
#define GTZC_TZIC1_IER2_TIM1_Pos   GTZC_CFGR2_TIM1_Pos
#define GTZC_TZIC1_IER2_TIM1_Msk   GTZC_CFGR2_TIM1_Msk
#define GTZC_TZIC1_IER2_SPI1_Pos   GTZC_CFGR2_SPI1_Pos
#define GTZC_TZIC1_IER2_SPI1_Msk   GTZC_CFGR2_SPI1_Msk
#define GTZC_TZIC1_IER2_TIM8_Pos   GTZC_CFGR2_TIM8_Pos
#define GTZC_TZIC1_IER2_TIM8_Msk   GTZC_CFGR2_TIM8_Msk
#define GTZC_TZIC1_IER2_USART1_Pos   GTZC_CFGR2_USART1_Pos
#define GTZC_TZIC1_IER2_USART1_Msk   GTZC_CFGR2_USART1_Msk
#define GTZC_TZIC1_IER2_TIM15_Pos   GTZC_CFGR2_TIM15_Pos
#define GTZC_TZIC1_IER2_TIM15_Msk   GTZC_CFGR2_TIM15_Msk
#define GTZC_TZIC1_IER2_TIM16_Pos   GTZC_CFGR2_TIM16_Pos
#define GTZC_TZIC1_IER2_TIM16_Msk   GTZC_CFGR2_TIM16_Msk
#define GTZC_TZIC1_IER2_TIM17_Pos   GTZC_CFGR2_TIM17_Pos
#define GTZC_TZIC1_IER2_TIM17_Msk   GTZC_CFGR2_TIM17_Msk
#define GTZC_TZIC1_IER2_SAI1_Pos   GTZC_CFGR2_SAI1_Pos
#define GTZC_TZIC1_IER2_SAI1_Msk   GTZC_CFGR2_SAI1_Msk
#define GTZC_TZIC1_IER2_SAI2_Pos   GTZC_CFGR2_SAI2_Pos
#define GTZC_TZIC1_IER2_SAI2_Msk   GTZC_CFGR2_SAI2_Msk
#define GTZC_TZIC1_IER2_LTDCUSB_Pos   GTZC_CFGR2_LTDCUSB_Pos
#define GTZC_TZIC1_IER2_LTDCUSB_Msk   GTZC_CFGR2_LTDCUSB_Msk
#define GTZC_TZIC1_IER2_DSI_Pos   GTZC_CFGR2_DSI_Pos
#define GTZC_TZIC1_IER2_DSI_Msk   GTZC_CFGR2_DSI_Msk
#define GTZC_TZIC1_IER2_GFXTIM_Pos   GTZC_CFGR2_GFXTIM_Pos
#define GTZC_TZIC1_IER2_GFXTIM_Msk   GTZC_CFGR2_GFXTIM_Msk
#define GTZC_TZIC1_IER3_MDF1_Pos   GTZC_CFGR3_MDF1_Pos
#define GTZC_TZIC1_IER3_MDF1_Msk   GTZC_CFGR3_MDF1_Msk
#define GTZC_TZIC1_IER3_CORDIC_Pos   GTZC_CFGR3_CORDIC_Pos
#define GTZC_TZIC1_IER3_CORDIC_Msk   GTZC_CFGR3_CORDIC_Msk
#define GTZC_TZIC1_IER3_FMAC_Pos   GTZC_CFGR3_FMAC_Pos
#define GTZC_TZIC1_IER3_FMAC_Msk   GTZC_CFGR3_FMAC_Msk
#define GTZC_TZIC1_IER3_CRC_Pos   GTZC_CFGR3_CRC_Pos
#define GTZC_TZIC1_IER3_CRC_Msk   GTZC_CFGR3_CRC_Msk
#define GTZC_TZIC1_IER3_TSC_Pos   GTZC_CFGR3_TSC_Pos
#define GTZC_TZIC1_IER3_TSC_Msk   GTZC_CFGR3_TSC_Msk
#define GTZC_TZIC1_IER3_DMA2D_Pos   GTZC_CFGR3_DMA2D_Pos
#define GTZC_TZIC1_IER3_DMA2D_Msk   GTZC_CFGR3_DMA2D_Msk
#define GTZC_TZIC1_IER3_ICACHE_REG_Pos   GTZC_CFGR3_ICACHE_REG_Pos
#define GTZC_TZIC1_IER3_ICACHE_REG_Msk   GTZC_CFGR3_ICACHE_REG_Msk
#define GTZC_TZIC1_IER3_DCACHE1_REG_Pos   GTZC_CFGR3_DCACHE1_REG_Pos
#define GTZC_TZIC1_IER3_DCACHE1_REG_Msk   GTZC_CFGR3_DCACHE1_REG_Msk
#define GTZC_TZIC1_IER3_ADC12_Pos   GTZC_CFGR3_ADC12_Pos
#define GTZC_TZIC1_IER3_ADC12_Msk   GTZC_CFGR3_ADC12_Msk
#define GTZC_TZIC1_IER3_DCMI_Pos   GTZC_CFGR3_DCMI_Pos
#define GTZC_TZIC1_IER3_DCMI_Msk   GTZC_CFGR3_DCMI_Msk
#define GTZC_TZIC1_IER3_OTG_Pos   GTZC_CFGR3_OTG_Pos
#define GTZC_TZIC1_IER3_OTG_Msk   GTZC_CFGR3_OTG_Msk
#define GTZC_TZIC1_IER3_AES_Pos   GTZC_CFGR3_AES_Pos
#define GTZC_TZIC1_IER3_AES_Msk   GTZC_CFGR3_AES_Msk
#define GTZC_TZIC1_IER3_HASH_Pos   GTZC_CFGR3_HASH_Pos
#define GTZC_TZIC1_IER3_HASH_Msk   GTZC_CFGR3_HASH_Msk
#define GTZC_TZIC1_IER3_RNG_Pos   GTZC_CFGR3_RNG_Pos
#define GTZC_TZIC1_IER3_RNG_Msk   GTZC_CFGR3_RNG_Msk
#define GTZC_TZIC1_IER3_PKA_Pos   GTZC_CFGR3_PKA_Pos
#define GTZC_TZIC1_IER3_PKA_Msk   GTZC_CFGR3_PKA_Msk
#define GTZC_TZIC1_IER3_SAES_Pos   GTZC_CFGR3_SAES_Pos
#define GTZC_TZIC1_IER3_SAES_Msk   GTZC_CFGR3_SAES_Msk
#define GTZC_TZIC1_IER3_OCTOSPIM_Pos   GTZC_CFGR3_OCTOSPIM_Pos
#define GTZC_TZIC1_IER3_OCTOSPIM_Msk   GTZC_CFGR3_OCTOSPIM_Msk
#define GTZC_TZIC1_IER3_SDMMC1_Pos   GTZC_CFGR3_SDMMC1_Pos
#define GTZC_TZIC1_IER3_SDMMC1_Msk   GTZC_CFGR3_SDMMC1_Msk
#define GTZC_TZIC1_IER3_SDMMC2_Pos   GTZC_CFGR3_SDMMC2_Pos
#define GTZC_TZIC1_IER3_SDMMC2_Msk   GTZC_CFGR3_SDMMC2_Msk
#define GTZC_TZIC1_IER3_FSMC_REG_Pos   GTZC_CFGR3_FSMC_REG_Pos
#define GTZC_TZIC1_IER3_FSMC_REG_Msk   GTZC_CFGR3_FSMC_REG_Msk
#define GTZC_TZIC1_IER3_OCTOSPI1_REG_Pos   GTZC_CFGR3_OCTOSPI1_REG_Pos
#define GTZC_TZIC1_IER3_OCTOSPI1_REG_Msk   GTZC_CFGR3_OCTOSPI1_REG_Msk
#define GTZC_TZIC1_IER3_OCTOSPI2_REG_Pos   GTZC_CFGR3_OCTOSPI2_REG_Pos
#define GTZC_TZIC1_IER3_OCTOSPI2_REG_Msk   GTZC_CFGR3_OCTOSPI2_REG_Msk
#define GTZC_TZIC1_IER3_RAMCFG_Pos   GTZC_CFGR3_RAMCFG_Pos
#define GTZC_TZIC1_IER3_RAMCFG_Msk   GTZC_CFGR3_RAMCFG_Msk
#define GTZC_TZIC1_IER3_GPU2D_Pos   GTZC_CFGR3_GPU2D_Pos
#define GTZC_TZIC1_IER3_GPU2D_Msk   GTZC_CFGR3_GPU2D_Msk
#define GTZC_TZIC1_IER3_GFXMMU_Pos   GTZC_CFGR3_GFXMMU_Pos
#define GTZC_TZIC1_IER3_GFXMMU_Msk   GTZC_CFGR3_GFXMMU_Msk
#define GTZC_TZIC1_IER3_GFXMMU_REG_Pos   GTZC_CFGR3_GFXMMU_REG_Pos
#define GTZC_TZIC1_IER3_GFXMMU_REG_Msk   GTZC_CFGR3_GFXMMU_REG_Msk
#define GTZC_TZIC1_IER3_HSPI1_REG_Pos   GTZC_CFGR3_HSPI1_REG_Pos
#define GTZC_TZIC1_IER3_HSPI1_REG_Msk   GTZC_CFGR3_HSPI1_REG_Msk
#define GTZC_TZIC1_IER3_DCACHE2_REG_Pos   GTZC_CFGR3_DCACHE2_REG_Pos
#define GTZC_TZIC1_IER3_DCACHE2_REG_Msk   GTZC_CFGR3_DCACHE2_REG_Msk
#define GTZC_TZIC1_IER3_JPEG_Pos   GTZC_CFGR3_JPEG_REG_Pos
#define GTZC_TZIC1_IER3_JPEG_Msk   GTZC_CFGR3_JPEG_REG_Msk
#define GTZC_TZIC1_IER4_GPDMA1_Pos   GTZC_CFGR4_GPDMA1_Pos
#define GTZC_TZIC1_IER4_GPDMA1_Msk   GTZC_CFGR4_GPDMA1_Msk
#define GTZC_TZIC1_IER4_FLASH_REG_Pos   GTZC_CFGR4_FLASH_REG_Pos
#define GTZC_TZIC1_IER4_FLASH_REG_Msk   GTZC_CFGR4_FLASH_REG_Msk
#define GTZC_TZIC1_IER4_FLASH_Pos   GTZC_CFGR4_FLASH_Pos
#define GTZC_TZIC1_IER4_FLASH_Msk   GTZC_CFGR4_FLASH_Msk
#define GTZC_TZIC1_IER4_OTFDEC1_Pos   GTZC_CFGR4_OTFDEC1_Pos
#define GTZC_TZIC1_IER4_OTFDEC1_Msk   GTZC_CFGR4_OTFDEC1_Msk
#define GTZC_TZIC1_IER4_OTFDEC2_Pos   GTZC_CFGR4_OTFDEC2_Pos
#define GTZC_TZIC1_IER4_OTFDEC2_Msk   GTZC_CFGR4_OTFDEC2_Msk
#define GTZC_TZIC1_IER4_TZSC1_Pos   GTZC_CFGR4_TZSC1_Pos
#define GTZC_TZIC1_IER4_TZSC1_Msk   GTZC_CFGR4_TZSC1_Msk
#define GTZC_TZIC1_IER4_TZIC1_Pos   GTZC_CFGR4_TZIC1_Pos
#define GTZC_TZIC1_IER4_TZIC1_Msk   GTZC_CFGR4_TZIC1_Msk
#define GTZC_TZIC1_IER4_OCTOSPI1_MEM_Pos   GTZC_CFGR4_OCTOSPI1_MEM_Pos
#define GTZC_TZIC1_IER4_OCTOSPI1_MEM_Msk   GTZC_CFGR4_OCTOSPI1_MEM_Msk
#define GTZC_TZIC1_IER4_FSMC_MEM_Pos   GTZC_CFGR4_FSMC_MEM_Pos
#define GTZC_TZIC1_IER4_FSMC_MEM_Msk   GTZC_CFGR4_FSMC_MEM_Msk
#define GTZC_TZIC1_IER4_BKPSRAM_Pos   GTZC_CFGR4_BKPSRAM_Pos
#define GTZC_TZIC1_IER4_BKPSRAM_Msk   GTZC_CFGR4_BKPSRAM_Msk
#define GTZC_TZIC1_IER4_OCTOSPI2_MEM_Pos   GTZC_CFGR4_OCTOSPI2_MEM_Pos
#define GTZC_TZIC1_IER4_OCTOSPI2_MEM_Msk   GTZC_CFGR4_OCTOSPI2_MEM_Msk
#define GTZC_TZIC1_IER4_HSPI1_MEM_Pos   GTZC_CFGR4_HSPI1_MEM_Pos
#define GTZC_TZIC1_IER4_HSPI1_MEM_Msk   GTZC_CFGR4_HSPI1_MEM_Msk
#define GTZC_TZIC1_IER4_SRAM6_Pos   GTZC_CFGR4_SRAM6_Pos
#define GTZC_TZIC1_IER4_SRAM6_Msk   GTZC_CFGR4_SRAM6_Msk
#define GTZC_TZIC1_IER4_MPCBB6_REG_Pos   GTZC_CFGR4_MPCBB6_REG_Pos
#define GTZC_TZIC1_IER4_MPCBB6_REG_Msk   GTZC_CFGR4_MPCBB6_REG_Msk
#define GTZC_TZIC1_IER4_SRAM1_Pos   GTZC_CFGR4_SRAM1_Pos
#define GTZC_TZIC1_IER4_SRAM1_Msk   GTZC_CFGR4_SRAM1_Msk
#define GTZC_TZIC1_IER4_MPCBB1_REG_Pos   GTZC_CFGR4_MPCBB1_REG_Pos
#define GTZC_TZIC1_IER4_MPCBB1_REG_Msk   GTZC_CFGR4_MPCBB1_REG_Msk
#define GTZC_TZIC1_IER4_SRAM2_Pos   GTZC_CFGR4_SRAM2_Pos
#define GTZC_TZIC1_IER4_SRAM2_Msk   GTZC_CFGR4_SRAM2_Msk
#define GTZC_TZIC1_IER4_MPCBB2_REG_Pos   GTZC_CFGR4_MPCBB2_REG_Pos
#define GTZC_TZIC1_IER4_MPCBB2_REG_Msk   GTZC_CFGR4_MPCBB2_REG_Msk
#define GTZC_TZIC1_IER4_SRAM3_Pos   GTZC_CFGR4_SRAM3_Pos
#define GTZC_TZIC1_IER4_SRAM3_Msk   GTZC_CFGR4_SRAM3_Msk
#define GTZC_TZIC1_IER4_MPCBB3_REG_Pos   GTZC_CFGR4_MPCBB3_REG_Pos
#define GTZC_TZIC1_IER4_MPCBB3_REG_Msk   GTZC_CFGR4_MPCBB3_REG_Msk
#define GTZC_TZIC1_IER4_SRAM5_Pos   GTZC_CFGR4_SRAM5_Pos
#define GTZC_TZIC1_IER4_SRAM5_Msk   GTZC_CFGR4_SRAM5_Msk
#define GTZC_TZIC1_IER4_MPCBB5_REG_Pos   GTZC_CFGR4_MPCBB5_REG_Pos
#define GTZC_TZIC1_IER4_MPCBB5_REG_Msk   GTZC_CFGR4_MPCBB5_REG_Msk
#define GTZC_TZIC2_IER1_SPI3_Pos   GTZC_CFGR1_SPI3_Pos
#define GTZC_TZIC2_IER1_SPI3_Msk   GTZC_CFGR1_SPI3_Msk
#define GTZC_TZIC2_IER1_LPUART1_Pos   GTZC_CFGR1_LPUART1_Pos
#define GTZC_TZIC2_IER1_LPUART1_Msk   GTZC_CFGR1_LPUART1_Msk
#define GTZC_TZIC2_IER1_I2C3_Pos   GTZC_CFGR1_I2C3_Pos
#define GTZC_TZIC2_IER1_I2C3_Msk   GTZC_CFGR1_I2C3_Msk
#define GTZC_TZIC2_IER1_LPTIM1_Pos   GTZC_CFGR1_LPTIM1_Pos
#define GTZC_TZIC2_IER1_LPTIM1_Msk   GTZC_CFGR1_LPTIM1_Msk
#define GTZC_TZIC2_IER1_LPTIM3_Pos   GTZC_CFGR1_LPTIM3_Pos
#define GTZC_TZIC2_IER1_LPTIM3_Msk   GTZC_CFGR1_LPTIM3_Msk
#define GTZC_TZIC2_IER1_LPTIM4_Pos   GTZC_CFGR1_LPTIM4_Pos
#define GTZC_TZIC2_IER1_LPTIM4_Msk   GTZC_CFGR1_LPTIM4_Msk
#define GTZC_TZIC2_IER1_OPAMP_Pos   GTZC_CFGR1_OPAMP_Pos
#define GTZC_TZIC2_IER1_OPAMP_Msk   GTZC_CFGR1_OPAMP_Msk
#define GTZC_TZIC2_IER1_COMP_Pos   GTZC_CFGR1_COMP_Pos
#define GTZC_TZIC2_IER1_COMP_Msk   GTZC_CFGR1_COMP_Msk
#define GTZC_TZIC2_IER1_ADC4_Pos   GTZC_CFGR1_ADC4_Pos
#define GTZC_TZIC2_IER1_ADC4_Msk   GTZC_CFGR1_ADC4_Msk
#define GTZC_TZIC2_IER1_VREFBUF_Pos   GTZC_CFGR1_VREFBUF_Pos
#define GTZC_TZIC2_IER1_VREFBUF_Msk   GTZC_CFGR1_VREFBUF_Msk
#define GTZC_TZIC2_IER1_DAC1_Pos   GTZC_CFGR1_DAC1_Pos
#define GTZC_TZIC2_IER1_DAC1_Msk   GTZC_CFGR1_DAC1_Msk
#define GTZC_TZIC2_IER1_ADF1_Pos   GTZC_CFGR1_ADF1_Pos
#define GTZC_TZIC2_IER1_ADF1_Msk   GTZC_CFGR1_ADF1_Msk
#define GTZC_TZIC2_IER2_SYSCFG_Pos   GTZC_CFGR2_SYSCFG_Pos
#define GTZC_TZIC2_IER2_SYSCFG_Msk   GTZC_CFGR2_SYSCFG_Msk
#define GTZC_TZIC2_IER2_RTC_Pos   GTZC_CFGR2_RTC_Pos
#define GTZC_TZIC2_IER2_RTC_Msk   GTZC_CFGR2_RTC_Msk
#define GTZC_TZIC2_IER2_TAMP_Pos   GTZC_CFGR2_TAMP_Pos
#define GTZC_TZIC2_IER2_TAMP_Msk   GTZC_CFGR2_TAMP_Msk
#define GTZC_TZIC2_IER2_PWR_Pos   GTZC_CFGR2_PWR_Pos
#define GTZC_TZIC2_IER2_PWR_Msk   GTZC_CFGR2_PWR_Msk
#define GTZC_TZIC2_IER2_RCC_Pos   GTZC_CFGR2_RCC_Pos
#define GTZC_TZIC2_IER2_RCC_Msk   GTZC_CFGR2_RCC_Msk
#define GTZC_TZIC2_IER2_LPDMA1_Pos   GTZC_CFGR2_LPDMA1_Pos
#define GTZC_TZIC2_IER2_LPDMA1_Msk   GTZC_CFGR2_LPDMA1_Msk
#define GTZC_TZIC2_IER2_EXTI_Pos   GTZC_CFGR2_EXTI_Pos
#define GTZC_TZIC2_IER2_EXTI_Msk   GTZC_CFGR2_EXTI_Msk
#define GTZC_TZIC2_IER2_TZSC2_Pos   GTZC_CFGR2_TZSC2_Pos
#define GTZC_TZIC2_IER2_TZSC2_Msk   GTZC_CFGR2_TZSC2_Msk
#define GTZC_TZIC2_IER2_TZIC2_Pos   GTZC_CFGR2_TZIC2_Pos
#define GTZC_TZIC2_IER2_TZIC2_Msk   GTZC_CFGR2_TZIC2_Msk
#define GTZC_TZIC2_IER2_SRAM4_Pos   GTZC_CFGR2_SRAM4_Pos
#define GTZC_TZIC2_IER2_SRAM4_Msk   GTZC_CFGR2_SRAM4_Msk
#define GTZC_TZIC2_IER2_MPCBB4_REG_Pos   GTZC_CFGR2_MPCBB4_REG_Pos
#define GTZC_TZIC2_IER2_MPCBB4_REG_Msk   GTZC_CFGR2_MPCBB4_REG_Msk
#define GTZC_TZIC1_SR1_TIM2_Pos   GTZC_CFGR1_TIM2_Pos
#define GTZC_TZIC1_SR1_TIM2_Msk   GTZC_CFGR1_TIM2_Msk
#define GTZC_TZIC1_SR1_TIM3_Pos   GTZC_CFGR1_TIM3_Pos
#define GTZC_TZIC1_SR1_TIM3_Msk   GTZC_CFGR1_TIM3_Msk
#define GTZC_TZIC1_SR1_TIM4_Pos   GTZC_CFGR1_TIM4_Pos
#define GTZC_TZIC1_SR1_TIM4_Msk   GTZC_CFGR1_TIM4_Msk
#define GTZC_TZIC1_SR1_TIM5_Pos   GTZC_CFGR1_TIM5_Pos
#define GTZC_TZIC1_SR1_TIM5_Msk   GTZC_CFGR1_TIM5_Msk
#define GTZC_TZIC1_SR1_TIM6_Pos   GTZC_CFGR1_TIM6_Pos
#define GTZC_TZIC1_SR1_TIM6_Msk   GTZC_CFGR1_TIM6_Msk
#define GTZC_TZIC1_SR1_TIM7_Pos   GTZC_CFGR1_TIM7_Pos
#define GTZC_TZIC1_SR1_TIM7_Msk   GTZC_CFGR1_TIM7_Msk
#define GTZC_TZIC1_SR1_WWDG_Pos   GTZC_CFGR1_WWDG_Pos
#define GTZC_TZIC1_SR1_WWDG_Msk   GTZC_CFGR1_WWDG_Msk
#define GTZC_TZIC1_SR1_IWDG_Pos   GTZC_CFGR1_IWDG_Pos
#define GTZC_TZIC1_SR1_IWDG_Msk   GTZC_CFGR1_IWDG_Msk
#define GTZC_TZIC1_SR1_SPI2_Pos   GTZC_CFGR1_SPI2_Pos
#define GTZC_TZIC1_SR1_SPI2_Msk   GTZC_CFGR1_SPI2_Msk
#define GTZC_TZIC1_SR1_USART2_Pos   GTZC_CFGR1_USART2_Pos
#define GTZC_TZIC1_SR1_USART2_Msk   GTZC_CFGR1_USART2_Msk
#define GTZC_TZIC1_SR1_USART3_Pos   GTZC_CFGR1_USART3_Pos
#define GTZC_TZIC1_SR1_USART3_Msk   GTZC_CFGR1_USART3_Msk
#define GTZC_TZIC1_SR1_UART4_Pos   GTZC_CFGR1_UART4_Pos
#define GTZC_TZIC1_SR1_UART4_Msk   GTZC_CFGR1_UART4_Msk
#define GTZC_TZIC1_SR1_UART5_Pos   GTZC_CFGR1_UART5_Pos
#define GTZC_TZIC1_SR1_UART5_Msk   GTZC_CFGR1_UART5_Msk
#define GTZC_TZIC1_SR1_I2C1_Pos   GTZC_CFGR1_I2C1_Pos
#define GTZC_TZIC1_SR1_I2C1_Msk   GTZC_CFGR1_I2C1_Msk
#define GTZC_TZIC1_SR1_I2C2_Pos   GTZC_CFGR1_I2C2_Pos
#define GTZC_TZIC1_SR1_I2C2_Msk   GTZC_CFGR1_I2C2_Msk
#define GTZC_TZIC1_SR1_CRS_Pos   GTZC_CFGR1_CRS_Pos
#define GTZC_TZIC1_SR1_CRS_Msk   GTZC_CFGR1_CRS_Msk
#define GTZC_TZIC1_SR1_I2C4_Pos   GTZC_CFGR1_I2C4_Pos
#define GTZC_TZIC1_SR1_I2C4_Msk   GTZC_CFGR1_I2C4_Msk
#define GTZC_TZIC1_SR1_LPTIM2_Pos   GTZC_CFGR1_LPTIM2_Pos
#define GTZC_TZIC1_SR1_LPTIM2_Msk   GTZC_CFGR1_LPTIM2_Msk
#define GTZC_TZIC1_SR1_FDCAN1_Pos   GTZC_CFGR1_FDCAN1_Pos
#define GTZC_TZIC1_SR1_FDCAN1_Msk   GTZC_CFGR1_FDCAN1_Msk
#define GTZC_TZIC1_SR1_UCPD1_Pos   GTZC_CFGR1_UCPD1_Pos
#define GTZC_TZIC1_SR1_UCPD1_Msk   GTZC_CFGR1_UCPD1_Msk
#define GTZC_TZIC1_SR1_USART6_Pos   GTZC_CFGR1_USART6_Pos
#define GTZC_TZIC1_SR1_USART6_Msk   GTZC_CFGR1_USART6_Msk
#define GTZC_TZIC1_SR1_I2C5_Pos   GTZC_CFGR1_I2C5_Pos
#define GTZC_TZIC1_SR1_I2C5_Msk   GTZC_CFGR1_I2C5_Msk
#define GTZC_TZIC1_SR1_I2C6_Pos   GTZC_CFGR1_I2C6_Pos
#define GTZC_TZIC1_SR1_I2C6_Msk   GTZC_CFGR1_I2C6_Msk
#define GTZC_TZIC1_SR2_TIM1_Pos   GTZC_CFGR2_TIM1_Pos
#define GTZC_TZIC1_SR2_TIM1_Msk   GTZC_CFGR2_TIM1_Msk
#define GTZC_TZIC1_SR2_SPI1_Pos   GTZC_CFGR2_SPI1_Pos
#define GTZC_TZIC1_SR2_SPI1_Msk   GTZC_CFGR2_SPI1_Msk
#define GTZC_TZIC1_SR2_TIM8_Pos   GTZC_CFGR2_TIM8_Pos
#define GTZC_TZIC1_SR2_TIM8_Msk   GTZC_CFGR2_TIM8_Msk
#define GTZC_TZIC1_SR2_USART1_Pos   GTZC_CFGR2_USART1_Pos
#define GTZC_TZIC1_SR2_USART1_Msk   GTZC_CFGR2_USART1_Msk
#define GTZC_TZIC1_SR2_TIM15_Pos   GTZC_CFGR2_TIM15_Pos
#define GTZC_TZIC1_SR2_TIM15_Msk   GTZC_CFGR2_TIM15_Msk
#define GTZC_TZIC1_SR2_TIM16_Pos   GTZC_CFGR2_TIM16_Pos
#define GTZC_TZIC1_SR2_TIM16_Msk   GTZC_CFGR2_TIM16_Msk
#define GTZC_TZIC1_SR2_TIM17_Pos   GTZC_CFGR2_TIM17_Pos
#define GTZC_TZIC1_SR2_TIM17_Msk   GTZC_CFGR2_TIM17_Msk
#define GTZC_TZIC1_SR2_SAI1_Pos   GTZC_CFGR2_SAI1_Pos
#define GTZC_TZIC1_SR2_SAI1_Msk   GTZC_CFGR2_SAI1_Msk
#define GTZC_TZIC1_SR2_SAI2_Pos   GTZC_CFGR2_SAI2_Pos
#define GTZC_TZIC1_SR2_SAI2_Msk   GTZC_CFGR2_SAI2_Msk
#define GTZC_TZIC1_SR2_LTDCUSB_Pos   GTZC_CFGR2_LTDCUSB_Pos
#define GTZC_TZIC1_SR2_LTDCUSB_Msk   GTZC_CFGR2_LTDCUSB_Msk
#define GTZC_TZIC1_SR2_DSI_Pos   GTZC_CFGR2_DSI_Pos
#define GTZC_TZIC1_SR2_DSI_Msk   GTZC_CFGR2_DSI_Msk
#define GTZC_TZIC1_SR2_GFXTIM_Pos   GTZC_CFGR2_GFXTIM_Pos
#define GTZC_TZIC1_SR2_GFXTIM_Msk   GTZC_CFGR2_GFXTIM_Msk
#define GTZC_TZIC1_SR3_MDF1_Pos   GTZC_CFGR3_MDF1_Pos
#define GTZC_TZIC1_SR3_MDF1_Msk   GTZC_CFGR3_MDF1_Msk
#define GTZC_TZIC1_SR3_CORDIC_Pos   GTZC_CFGR3_CORDIC_Pos
#define GTZC_TZIC1_SR3_CORDIC_Msk   GTZC_CFGR3_CORDIC_Msk
#define GTZC_TZIC1_SR3_FMAC_Pos   GTZC_CFGR3_FMAC_Pos
#define GTZC_TZIC1_SR3_FMAC_Msk   GTZC_CFGR3_FMAC_Msk
#define GTZC_TZIC1_SR3_CRC_Pos   GTZC_CFGR3_CRC_Pos
#define GTZC_TZIC1_SR3_CRC_Msk   GTZC_CFGR3_CRC_Msk
#define GTZC_TZIC1_SR3_TSC_Pos   GTZC_CFGR3_TSC_Pos
#define GTZC_TZIC1_SR3_TSC_Msk   GTZC_CFGR3_TSC_Msk
#define GTZC_TZIC1_SR3_DMA2D_Pos   GTZC_CFGR3_DMA2D_Pos
#define GTZC_TZIC1_SR3_DMA2D_Msk   GTZC_CFGR3_DMA2D_Msk
#define GTZC_TZIC1_SR3_ICACHE_REG_Pos   GTZC_CFGR3_ICACHE_REG_Pos
#define GTZC_TZIC1_SR3_ICACHE_REG_Msk   GTZC_CFGR3_ICACHE_REG_Msk
#define GTZC_TZIC1_SR3_DCACHE1_REG_Pos   GTZC_CFGR3_DCACHE1_REG_Pos
#define GTZC_TZIC1_SR3_DCACHE1_REG_Msk   GTZC_CFGR3_DCACHE1_REG_Msk
#define GTZC_TZIC1_SR3_ADC12_Pos   GTZC_CFGR3_ADC12_Pos
#define GTZC_TZIC1_SR3_ADC12_Msk   GTZC_CFGR3_ADC12_Msk
#define GTZC_TZIC1_SR3_DCMI_Pos   GTZC_CFGR3_DCMI_Pos
#define GTZC_TZIC1_SR3_DCMI_Msk   GTZC_CFGR3_DCMI_Msk
#define GTZC_TZIC1_SR3_OTG_Pos   GTZC_CFGR3_OTG_Pos
#define GTZC_TZIC1_SR3_OTG_Msk   GTZC_CFGR3_OTG_Msk
#define GTZC_TZIC1_SR3_AES_Pos   GTZC_CFGR3_AES_Pos
#define GTZC_TZIC1_SR3_AES_Msk   GTZC_CFGR3_AES_Msk
#define GTZC_TZIC1_SR3_HASH_Pos   GTZC_CFGR3_HASH_Pos
#define GTZC_TZIC1_SR3_HASH_Msk   GTZC_CFGR3_HASH_Msk
#define GTZC_TZIC1_SR3_RNG_Pos   GTZC_CFGR3_RNG_Pos
#define GTZC_TZIC1_SR3_RNG_Msk   GTZC_CFGR3_RNG_Msk
#define GTZC_TZIC1_SR3_PKA_Pos   GTZC_CFGR3_PKA_Pos
#define GTZC_TZIC1_SR3_PKA_Msk   GTZC_CFGR3_PKA_Msk
#define GTZC_TZIC1_SR3_SAES_Pos   GTZC_CFGR3_SAES_Pos
#define GTZC_TZIC1_SR3_SAES_Msk   GTZC_CFGR3_SAES_Msk
#define GTZC_TZIC1_SR3_OCTOSPIM_Pos   GTZC_CFGR3_OCTOSPIM_Pos
#define GTZC_TZIC1_SR3_OCTOSPIM_Msk   GTZC_CFGR3_OCTOSPIM_Msk
#define GTZC_TZIC1_SR3_SDMMC1_Pos   GTZC_CFGR3_SDMMC1_Pos
#define GTZC_TZIC1_SR3_SDMMC1_Msk   GTZC_CFGR3_SDMMC1_Msk
#define GTZC_TZIC1_SR3_SDMMC2_Pos   GTZC_CFGR3_SDMMC2_Pos
#define GTZC_TZIC1_SR3_SDMMC2_Msk   GTZC_CFGR3_SDMMC2_Msk
#define GTZC_TZIC1_SR3_FSMC_REG_Pos   GTZC_CFGR3_FSMC_REG_Pos
#define GTZC_TZIC1_SR3_FSMC_REG_Msk   GTZC_CFGR3_FSMC_REG_Msk
#define GTZC_TZIC1_SR3_OCTOSPI1_REG_Pos   GTZC_CFGR3_OCTOSPI1_REG_Pos
#define GTZC_TZIC1_SR3_OCTOSPI1_REG_Msk   GTZC_CFGR3_OCTOSPI1_REG_Msk
#define GTZC_TZIC1_SR3_OCTOSPI2_REG_Pos   GTZC_CFGR3_OCTOSPI2_REG_Pos
#define GTZC_TZIC1_SR3_OCTOSPI2_REG_Msk   GTZC_CFGR3_OCTOSPI2_REG_Msk
#define GTZC_TZIC1_SR3_RAMCFG_Pos   GTZC_CFGR3_RAMCFG_Pos
#define GTZC_TZIC1_SR3_RAMCFG_Msk   GTZC_CFGR3_RAMCFG_Msk
#define GTZC_TZIC1_SR3_GPU2D_Pos   GTZC_CFGR3_GPU2D_Pos
#define GTZC_TZIC1_SR3_GPU2D_Msk   GTZC_CFGR3_GPU2D_Msk
#define GTZC_TZIC1_SR3_GFXMMU_Pos   GTZC_CFGR3_GFXMMU_Pos
#define GTZC_TZIC1_SR3_GFXMMU_Msk   GTZC_CFGR3_GFXMMU_Msk
#define GTZC_TZIC1_SR3_GFXMMU_REG_Pos   GTZC_CFGR3_GFXMMU_REG_Pos
#define GTZC_TZIC1_SR3_GFXMMU_REG_Msk   GTZC_CFGR3_GFXMMU_REG_Msk
#define GTZC_TZIC1_SR3_HSPI1_REG_Pos   GTZC_CFGR3_HSPI1_REG_Pos
#define GTZC_TZIC1_SR3_HSPI1_REG_Msk   GTZC_CFGR3_HSPI1_REG_Msk
#define GTZC_TZIC1_SR3_DCACHE2_REG_Pos   GTZC_CFGR3_DCACHE2_REG_Pos
#define GTZC_TZIC1_SR3_DCACHE2_REG_Msk   GTZC_CFGR3_DCACHE2_REG_Msk
#define GTZC_TZIC1_SR3_JPEG_Pos   GTZC_CFGR3_JPEG_REG_Pos
#define GTZC_TZIC1_SR3_JPEG_Msk   GTZC_CFGR3_JPEG_REG_Msk
#define GTZC_TZIC1_SR4_GPDMA1_Pos   GTZC_CFGR4_GPDMA1_Pos
#define GTZC_TZIC1_SR4_GPDMA1_Msk   GTZC_CFGR4_GPDMA1_Msk
#define GTZC_TZIC1_SR4_FLASH_REG_Pos   GTZC_CFGR4_FLASH_REG_Pos
#define GTZC_TZIC1_SR4_FLASH_REG_Msk   GTZC_CFGR4_FLASH_REG_Msk
#define GTZC_TZIC1_SR4_FLASH_Pos   GTZC_CFGR4_FLASH_Pos
#define GTZC_TZIC1_SR4_FLASH_Msk   GTZC_CFGR4_FLASH_Msk
#define GTZC_TZIC1_SR4_OTFDEC1_Pos   GTZC_CFGR4_OTFDEC1_Pos
#define GTZC_TZIC1_SR4_OTFDEC1_Msk   GTZC_CFGR4_OTFDEC1_Msk
#define GTZC_TZIC1_SR4_OTFDEC2_Pos   GTZC_CFGR4_OTFDEC2_Pos
#define GTZC_TZIC1_SR4_OTFDEC2_Msk   GTZC_CFGR4_OTFDEC2_Msk
#define GTZC_TZIC1_SR4_TZSC1_Pos   GTZC_CFGR4_TZSC1_Pos
#define GTZC_TZIC1_SR4_TZSC1_Msk   GTZC_CFGR4_TZSC1_Msk
#define GTZC_TZIC1_SR4_TZIC1_Pos   GTZC_CFGR4_TZIC1_Pos
#define GTZC_TZIC1_SR4_TZIC1_Msk   GTZC_CFGR4_TZIC1_Msk
#define GTZC_TZIC1_SR4_OCTOSPI1_MEM_Pos   GTZC_CFGR4_OCTOSPI1_MEM_Pos
#define GTZC_TZIC1_SR4_OCTOSPI1_MEM_Msk   GTZC_CFGR4_OCTOSPI1_MEM_Msk
#define GTZC_TZIC1_SR4_FSMC_MEM_Pos   GTZC_CFGR4_FSMC_MEM_Pos
#define GTZC_TZIC1_SR4_FSMC_MEM_Msk   GTZC_CFGR4_FSMC_MEM_Msk
#define GTZC_TZIC1_SR4_BKPSRAM_Pos   GTZC_CFGR4_BKPSRAM_Pos
#define GTZC_TZIC1_SR4_BKPSRAM_Msk   GTZC_CFGR4_BKPSRAM_Msk
#define GTZC_TZIC1_SR4_OCTOSPI2_MEM_Pos   GTZC_CFGR4_OCTOSPI2_MEM_Pos
#define GTZC_TZIC1_SR4_OCTOSPI2_MEM_Msk   GTZC_CFGR4_OCTOSPI2_MEM_Msk
#define GTZC_TZIC1_SR4_HSPI1_MEM_Pos   GTZC_CFGR4_HSPI1_MEM_Pos
#define GTZC_TZIC1_SR4_HSPI1_MEM_Msk   GTZC_CFGR4_HSPI1_MEM_Msk
#define GTZC_TZIC1_SR4_SRAM6_Pos   GTZC_CFGR4_SRAM6_Pos
#define GTZC_TZIC1_SR4_SRAM6_Msk   GTZC_CFGR4_SRAM6_Msk
#define GTZC_TZIC1_SR4_MPCBB6_REG_Pos   GTZC_CFGR4_MPCBB6_REG_Pos
#define GTZC_TZIC1_SR4_MPCBB6_REG_Msk   GTZC_CFGR4_MPCBB6_REG_Msk
#define GTZC_TZIC1_SR4_SRAM1_Pos   GTZC_CFGR4_SRAM1_Pos
#define GTZC_TZIC1_SR4_SRAM1_Msk   GTZC_CFGR4_SRAM1_Msk
#define GTZC_TZIC1_SR4_MPCBB1_REG_Pos   GTZC_CFGR4_MPCBB1_REG_Pos
#define GTZC_TZIC1_SR4_MPCBB1_REG_Msk   GTZC_CFGR4_MPCBB1_REG_Msk
#define GTZC_TZIC1_SR4_SRAM2_Pos   GTZC_CFGR4_SRAM2_Pos
#define GTZC_TZIC1_SR4_SRAM2_Msk   GTZC_CFGR4_SRAM2_Msk
#define GTZC_TZIC1_SR4_MPCBB2_REG_Pos   GTZC_CFGR4_MPCBB2_REG_Pos
#define GTZC_TZIC1_SR4_MPCBB2_REG_Msk   GTZC_CFGR4_MPCBB2_REG_Msk
#define GTZC_TZIC1_SR4_SRAM3_Pos   GTZC_CFGR4_SRAM3_Pos
#define GTZC_TZIC1_SR4_SRAM3_Msk   GTZC_CFGR4_SRAM3_Msk
#define GTZC_TZIC1_SR4_MPCBB3_REG_Pos   GTZC_CFGR4_MPCBB3_REG_Pos
#define GTZC_TZIC1_SR4_MPCBB3_REG_Msk   GTZC_CFGR4_MPCBB3_REG_Msk
#define GTZC_TZIC1_SR4_SRAM5_Pos   GTZC_CFGR4_SRAM5_Pos
#define GTZC_TZIC1_SR4_SRAM5_Msk   GTZC_CFGR4_SRAM5_Msk
#define GTZC_TZIC1_SR4_MPCBB5_REG_Pos   GTZC_CFGR4_MPCBB5_REG_Pos
#define GTZC_TZIC1_SR4_MPCBB5_REG_Msk   GTZC_CFGR4_MPCBB5_REG_Msk
#define GTZC_TZIC2_SR1_SPI3_Pos   GTZC_CFGR1_SPI3_Pos
#define GTZC_TZIC2_SR1_SPI3_Msk   GTZC_CFGR1_SPI3_Msk
#define GTZC_TZIC2_SR1_LPUART1_Pos   GTZC_CFGR1_LPUART1_Pos
#define GTZC_TZIC2_SR1_LPUART1_Msk   GTZC_CFGR1_LPUART1_Msk
#define GTZC_TZIC2_SR1_I2C3_Pos   GTZC_CFGR1_I2C3_Pos
#define GTZC_TZIC2_SR1_I2C3_Msk   GTZC_CFGR1_I2C3_Msk
#define GTZC_TZIC2_SR1_LPTIM1_Pos   GTZC_CFGR1_LPTIM1_Pos
#define GTZC_TZIC2_SR1_LPTIM1_Msk   GTZC_CFGR1_LPTIM1_Msk
#define GTZC_TZIC2_SR1_LPTIM3_Pos   GTZC_CFGR1_LPTIM3_Pos
#define GTZC_TZIC2_SR1_LPTIM3_Msk   GTZC_CFGR1_LPTIM3_Msk
#define GTZC_TZIC2_SR1_LPTIM4_Pos   GTZC_CFGR1_LPTIM4_Pos
#define GTZC_TZIC2_SR1_LPTIM4_Msk   GTZC_CFGR1_LPTIM4_Msk
#define GTZC_TZIC2_SR1_OPAMP_Pos   GTZC_CFGR1_OPAMP_Pos
#define GTZC_TZIC2_SR1_OPAMP_Msk   GTZC_CFGR1_OPAMP_Msk
#define GTZC_TZIC2_SR1_COMP_Pos   GTZC_CFGR1_COMP_Pos
#define GTZC_TZIC2_SR1_COMP_Msk   GTZC_CFGR1_COMP_Msk
#define GTZC_TZIC2_SR1_ADC4_Pos   GTZC_CFGR1_ADC4_Pos
#define GTZC_TZIC2_SR1_ADC4_Msk   GTZC_CFGR1_ADC4_Msk
#define GTZC_TZIC2_SR1_VREFBUF_Pos   GTZC_CFGR1_VREFBUF_Pos
#define GTZC_TZIC2_SR1_VREFBUF_Msk   GTZC_CFGR1_VREFBUF_Msk
#define GTZC_TZIC2_SR1_DAC1_Pos   GTZC_CFGR1_DAC1_Pos
#define GTZC_TZIC2_SR1_DAC1_Msk   GTZC_CFGR1_DAC1_Msk
#define GTZC_TZIC2_SR1_ADF1_Pos   GTZC_CFGR1_ADF1_Pos
#define GTZC_TZIC2_SR1_ADF1_Msk   GTZC_CFGR1_ADF1_Msk
#define GTZC_TZIC2_SR2_SYSCFG_Pos   GTZC_CFGR2_SYSCFG_Pos
#define GTZC_TZIC2_SR2_SYSCFG_Msk   GTZC_CFGR2_SYSCFG_Msk
#define GTZC_TZIC2_SR2_RTC_Pos   GTZC_CFGR2_RTC_Pos
#define GTZC_TZIC2_SR2_RTC_Msk   GTZC_CFGR2_RTC_Msk
#define GTZC_TZIC2_SR2_TAMP_Pos   GTZC_CFGR2_TAMP_Pos
#define GTZC_TZIC2_SR2_TAMP_Msk   GTZC_CFGR2_TAMP_Msk
#define GTZC_TZIC2_SR2_PWR_Pos   GTZC_CFGR2_PWR_Pos
#define GTZC_TZIC2_SR2_PWR_Msk   GTZC_CFGR2_PWR_Msk
#define GTZC_TZIC2_SR2_RCC_Pos   GTZC_CFGR2_RCC_Pos
#define GTZC_TZIC2_SR2_RCC_Msk   GTZC_CFGR2_RCC_Msk
#define GTZC_TZIC2_SR2_LPDMA1_Pos   GTZC_CFGR2_LPDMA1_Pos
#define GTZC_TZIC2_SR2_LPDMA1_Msk   GTZC_CFGR2_LPDMA1_Msk
#define GTZC_TZIC2_SR2_EXTI_Pos   GTZC_CFGR2_EXTI_Pos
#define GTZC_TZIC2_SR2_EXTI_Msk   GTZC_CFGR2_EXTI_Msk
#define GTZC_TZIC2_SR2_TZSC2_Pos   GTZC_CFGR2_TZSC2_Pos
#define GTZC_TZIC2_SR2_TZSC2_Msk   GTZC_CFGR2_TZSC2_Msk
#define GTZC_TZIC2_SR2_TZIC2_Pos   GTZC_CFGR2_TZIC2_Pos
#define GTZC_TZIC2_SR2_TZIC2_Msk   GTZC_CFGR2_TZIC2_Msk
#define GTZC_TZIC2_SR2_SRAM4_Pos   GTZC_CFGR2_SRAM4_Pos
#define GTZC_TZIC2_SR2_SRAM4_Msk   GTZC_CFGR2_SRAM4_Msk
#define GTZC_TZIC2_SR2_MPCBB4_REG_Pos   GTZC_CFGR2_MPCBB4_REG_Pos
#define GTZC_TZIC2_SR2_MPCBB4_REG_Msk   GTZC_CFGR2_MPCBB4_REG_Msk
#define GTZC_TZIC1_FCR1_TIM2_Pos   GTZC_CFGR1_TIM2_Pos
#define GTZC_TZIC1_FCR1_TIM2_Msk   GTZC_CFGR1_TIM2_Msk
#define GTZC_TZIC1_FCR1_TIM3_Pos   GTZC_CFGR1_TIM3_Pos
#define GTZC_TZIC1_FCR1_TIM3_Msk   GTZC_CFGR1_TIM3_Msk
#define GTZC_TZIC1_FCR1_TIM4_Pos   GTZC_CFGR1_TIM4_Pos
#define GTZC_TZIC1_FCR1_TIM4_Msk   GTZC_CFGR1_TIM4_Msk
#define GTZC_TZIC1_FCR1_TIM5_Pos   GTZC_CFGR1_TIM5_Pos
#define GTZC_TZIC1_FCR1_TIM5_Msk   GTZC_CFGR1_TIM5_Msk
#define GTZC_TZIC1_FCR1_TIM6_Pos   GTZC_CFGR1_TIM6_Pos
#define GTZC_TZIC1_FCR1_TIM6_Msk   GTZC_CFGR1_TIM6_Msk
#define GTZC_TZIC1_FCR1_TIM7_Pos   GTZC_CFGR1_TIM7_Pos
#define GTZC_TZIC1_FCR1_TIM7_Msk   GTZC_CFGR1_TIM7_Msk
#define GTZC_TZIC1_FCR1_WWDG_Pos   GTZC_CFGR1_WWDG_Pos
#define GTZC_TZIC1_FCR1_WWDG_Msk   GTZC_CFGR1_WWDG_Msk
#define GTZC_TZIC1_FCR1_IWDG_Pos   GTZC_CFGR1_IWDG_Pos
#define GTZC_TZIC1_FCR1_IWDG_Msk   GTZC_CFGR1_IWDG_Msk
#define GTZC_TZIC1_FCR1_SPI2_Pos   GTZC_CFGR1_SPI2_Pos
#define GTZC_TZIC1_FCR1_SPI2_Msk   GTZC_CFGR1_SPI2_Msk
#define GTZC_TZIC1_FCR1_USART2_Pos   GTZC_CFGR1_USART2_Pos
#define GTZC_TZIC1_FCR1_USART2_Msk   GTZC_CFGR1_USART2_Msk
#define GTZC_TZIC1_FCR1_USART3_Pos   GTZC_CFGR1_USART3_Pos
#define GTZC_TZIC1_FCR1_USART3_Msk   GTZC_CFGR1_USART3_Msk
#define GTZC_TZIC1_FCR1_UART4_Pos   GTZC_CFGR1_UART4_Pos
#define GTZC_TZIC1_FCR1_UART4_Msk   GTZC_CFGR1_UART4_Msk
#define GTZC_TZIC1_FCR1_UART5_Pos   GTZC_CFGR1_UART5_Pos
#define GTZC_TZIC1_FCR1_UART5_Msk   GTZC_CFGR1_UART5_Msk
#define GTZC_TZIC1_FCR1_I2C1_Pos   GTZC_CFGR1_I2C1_Pos
#define GTZC_TZIC1_FCR1_I2C1_Msk   GTZC_CFGR1_I2C1_Msk
#define GTZC_TZIC1_FCR1_I2C2_Pos   GTZC_CFGR1_I2C2_Pos
#define GTZC_TZIC1_FCR1_I2C2_Msk   GTZC_CFGR1_I2C2_Msk
#define GTZC_TZIC1_FCR1_CRS_Pos   GTZC_CFGR1_CRS_Pos
#define GTZC_TZIC1_FCR1_CRS_Msk   GTZC_CFGR1_CRS_Msk
#define GTZC_TZIC1_FCR1_I2C4_Pos   GTZC_CFGR1_I2C4_Pos
#define GTZC_TZIC1_FCR1_I2C4_Msk   GTZC_CFGR1_I2C4_Msk
#define GTZC_TZIC1_FCR1_LPTIM2_Pos   GTZC_CFGR1_LPTIM2_Pos
#define GTZC_TZIC1_FCR1_LPTIM2_Msk   GTZC_CFGR1_LPTIM2_Msk
#define GTZC_TZIC1_FCR1_FDCAN1_Pos   GTZC_CFGR1_FDCAN1_Pos
#define GTZC_TZIC1_FCR1_FDCAN1_Msk   GTZC_CFGR1_FDCAN1_Msk
#define GTZC_TZIC1_FCR1_UCPD1_Pos   GTZC_CFGR1_UCPD1_Pos
#define GTZC_TZIC1_FCR1_UCPD1_Msk   GTZC_CFGR1_UCPD1_Msk
#define GTZC_TZIC1_FCR1_USART6_Pos   GTZC_CFGR1_USART6_Pos
#define GTZC_TZIC1_FCR1_USART6_Msk   GTZC_CFGR1_USART6_Msk
#define GTZC_TZIC1_FCR1_I2C5_Pos   GTZC_CFGR1_I2C5_Pos
#define GTZC_TZIC1_FCR1_I2C5_Msk   GTZC_CFGR1_I2C5_Msk
#define GTZC_TZIC1_FCR1_I2C6_Pos   GTZC_CFGR1_I2C6_Pos
#define GTZC_TZIC1_FCR1_I2C6_Msk   GTZC_CFGR1_I2C6_Msk
#define GTZC_TZIC1_FCR2_TIM1_Pos   GTZC_CFGR2_TIM1_Pos
#define GTZC_TZIC1_FCR2_TIM1_Msk   GTZC_CFGR2_TIM1_Msk
#define GTZC_TZIC1_FCR2_SPI1_Pos   GTZC_CFGR2_SPI1_Pos
#define GTZC_TZIC1_FCR2_SPI1_Msk   GTZC_CFGR2_SPI1_Msk
#define GTZC_TZIC1_FCR2_TIM8_Pos   GTZC_CFGR2_TIM8_Pos
#define GTZC_TZIC1_FCR2_TIM8_Msk   GTZC_CFGR2_TIM8_Msk
#define GTZC_TZIC1_FCR2_USART1_Pos   GTZC_CFGR2_USART1_Pos
#define GTZC_TZIC1_FCR2_USART1_Msk   GTZC_CFGR2_USART1_Msk
#define GTZC_TZIC1_FCR2_TIM15_Pos   GTZC_CFGR2_TIM15_Pos
#define GTZC_TZIC1_FCR2_TIM15_Msk   GTZC_CFGR2_TIM15_Msk
#define GTZC_TZIC1_FCR2_TIM16_Pos   GTZC_CFGR2_TIM16_Pos
#define GTZC_TZIC1_FCR2_TIM16_Msk   GTZC_CFGR2_TIM16_Msk
#define GTZC_TZIC1_FCR2_TIM17_Pos   GTZC_CFGR2_TIM17_Pos
#define GTZC_TZIC1_FCR2_TIM17_Msk   GTZC_CFGR2_TIM17_Msk
#define GTZC_TZIC1_FCR2_SAI1_Pos   GTZC_CFGR2_SAI1_Pos
#define GTZC_TZIC1_FCR2_SAI1_Msk   GTZC_CFGR2_SAI1_Msk
#define GTZC_TZIC1_FCR2_SAI2_Pos   GTZC_CFGR2_SAI2_Pos
#define GTZC_TZIC1_FCR2_SAI2_Msk   GTZC_CFGR2_SAI2_Msk
#define GTZC_TZIC1_FCR2_LTDCUSB_Pos   GTZC_CFGR2_LTDCUSB_Pos
#define GTZC_TZIC1_FCR2_LTDCUSB_Msk   GTZC_CFGR2_LTDCUSB_Msk
#define GTZC_TZIC1_FCR2_DSI_Pos   GTZC_CFGR2_DSI_Pos
#define GTZC_TZIC1_FCR2_DSI_Msk   GTZC_CFGR2_DSI_Msk
#define GTZC_TZIC1_FCR2_GFXTIM_Pos   GTZC_CFGR2_GFXTIM_Pos
#define GTZC_TZIC1_FCR2_GFXTIM_Msk   GTZC_CFGR2_GFXTIM_Msk
#define GTZC_TZIC1_FCR3_MDF1_Pos   GTZC_CFGR3_MDF1_Pos
#define GTZC_TZIC1_FCR3_MDF1_Msk   GTZC_CFGR3_MDF1_Msk
#define GTZC_TZIC1_FCR3_CORDIC_Pos   GTZC_CFGR3_CORDIC_Pos
#define GTZC_TZIC1_FCR3_CORDIC_Msk   GTZC_CFGR3_CORDIC_Msk
#define GTZC_TZIC1_FCR3_FMAC_Pos   GTZC_CFGR3_FMAC_Pos
#define GTZC_TZIC1_FCR3_FMAC_Msk   GTZC_CFGR3_FMAC_Msk
#define GTZC_TZIC1_FCR3_CRC_Pos   GTZC_CFGR3_CRC_Pos
#define GTZC_TZIC1_FCR3_CRC_Msk   GTZC_CFGR3_CRC_Msk
#define GTZC_TZIC1_FCR3_TSC_Pos   GTZC_CFGR3_TSC_Pos
#define GTZC_TZIC1_FCR3_TSC_Msk   GTZC_CFGR3_TSC_Msk
#define GTZC_TZIC1_FCR3_DMA2D_Pos   GTZC_CFGR3_DMA2D_Pos
#define GTZC_TZIC1_FCR3_DMA2D_Msk   GTZC_CFGR3_DMA2D_Msk
#define GTZC_TZIC1_FCR3_ICACHE_REG_Pos   GTZC_CFGR3_ICACHE_REG_Pos
#define GTZC_TZIC1_FCR3_ICACHE_REG_Msk   GTZC_CFGR3_ICACHE_REG_Msk
#define GTZC_TZIC1_FCR3_DCACHE1_REG_Pos   GTZC_CFGR3_DCACHE1_REG_Pos
#define GTZC_TZIC1_FCR3_DCACHE1_REG_Msk   GTZC_CFGR3_DCACHE1_REG_Msk
#define GTZC_TZIC1_FCR3_ADC12_Pos   GTZC_CFGR3_ADC12_Pos
#define GTZC_TZIC1_FCR3_ADC12_Msk   GTZC_CFGR3_ADC12_Msk
#define GTZC_TZIC1_FCR3_DCMI_Pos   GTZC_CFGR3_DCMI_Pos
#define GTZC_TZIC1_FCR3_DCMI_Msk   GTZC_CFGR3_DCMI_Msk
#define GTZC_TZIC1_FCR3_OTG_Pos   GTZC_CFGR3_OTG_Pos
#define GTZC_TZIC1_FCR3_OTG_Msk   GTZC_CFGR3_OTG_Msk
#define GTZC_TZIC1_FCR3_AES_Pos   GTZC_CFGR3_AES_Pos
#define GTZC_TZIC1_FCR3_AES_Msk   GTZC_CFGR3_AES_Msk
#define GTZC_TZIC1_FCR3_HASH_Pos   GTZC_CFGR3_HASH_Pos
#define GTZC_TZIC1_FCR3_HASH_Msk   GTZC_CFGR3_HASH_Msk
#define GTZC_TZIC1_FCR3_RNG_Pos   GTZC_CFGR3_RNG_Pos
#define GTZC_TZIC1_FCR3_RNG_Msk   GTZC_CFGR3_RNG_Msk
#define GTZC_TZIC1_FCR3_PKA_Pos   GTZC_CFGR3_PKA_Pos
#define GTZC_TZIC1_FCR3_PKA_Msk   GTZC_CFGR3_PKA_Msk
#define GTZC_TZIC1_FCR3_SAES_Pos   GTZC_CFGR3_SAES_Pos
#define GTZC_TZIC1_FCR3_SAES_Msk   GTZC_CFGR3_SAES_Msk
#define GTZC_TZIC1_FCR3_OCTOSPIM_Pos   GTZC_CFGR3_OCTOSPIM_Pos
#define GTZC_TZIC1_FCR3_OCTOSPIM_Msk   GTZC_CFGR3_OCTOSPIM_Msk
#define GTZC_TZIC1_FCR3_SDMMC1_Pos   GTZC_CFGR3_SDMMC1_Pos
#define GTZC_TZIC1_FCR3_SDMMC1_Msk   GTZC_CFGR3_SDMMC1_Msk
#define GTZC_TZIC1_FCR3_SDMMC2_Pos   GTZC_CFGR3_SDMMC2_Pos
#define GTZC_TZIC1_FCR3_SDMMC2_Msk   GTZC_CFGR3_SDMMC2_Msk
#define GTZC_TZIC1_FCR3_FSMC_REG_Pos   GTZC_CFGR3_FSMC_REG_Pos
#define GTZC_TZIC1_FCR3_FSMC_REG_Msk   GTZC_CFGR3_FSMC_REG_Msk
#define GTZC_TZIC1_FCR3_OCTOSPI1_REG_Pos   GTZC_CFGR3_OCTOSPI1_REG_Pos
#define GTZC_TZIC1_FCR3_OCTOSPI1_REG_Msk   GTZC_CFGR3_OCTOSPI1_REG_Msk
#define GTZC_TZIC1_FCR3_OCTOSPI2_REG_Pos   GTZC_CFGR3_OCTOSPI2_REG_Pos
#define GTZC_TZIC1_FCR3_OCTOSPI2_REG_Msk   GTZC_CFGR3_OCTOSPI2_REG_Msk
#define GTZC_TZIC1_FCR3_RAMCFG_Pos   GTZC_CFGR3_RAMCFG_Pos
#define GTZC_TZIC1_FCR3_RAMCFG_Msk   GTZC_CFGR3_RAMCFG_Msk
#define GTZC_TZIC1_FCR3_GPU2D_Pos   GTZC_CFGR3_GPU2D_Pos
#define GTZC_TZIC1_FCR3_GPU2D_Msk   GTZC_CFGR3_GPU2D_Msk
#define GTZC_TZIC1_FCR3_GFXMMU_Pos   GTZC_CFGR3_GFXMMU_Pos
#define GTZC_TZIC1_FCR3_GFXMMU_Msk   GTZC_CFGR3_GFXMMU_Msk
#define GTZC_TZIC1_FCR3_GFXMMU_REG_Pos   GTZC_CFGR3_GFXMMU_REG_Pos
#define GTZC_TZIC1_FCR3_GFXMMU_REG_Msk   GTZC_CFGR3_GFXMMU_REG_Msk
#define GTZC_TZIC1_FCR3_HSPI1_REG_Pos   GTZC_CFGR3_HSPI1_REG_Pos
#define GTZC_TZIC1_FCR3_HSPI1_REG_Msk   GTZC_CFGR3_HSPI1_REG_Msk
#define GTZC_TZIC1_FCR3_DCACHE2_REG_Pos   GTZC_CFGR3_DCACHE2_REG_Pos
#define GTZC_TZIC1_FCR3_DCACHE2_REG_Msk   GTZC_CFGR3_DCACHE2_REG_Msk
#define GTZC_TZIC1_FCR3_JPEG_Pos   GTZC_CFGR3_JPEG_REG_Pos
#define GTZC_TZIC1_FCR3_JPEG_Msk   GTZC_CFGR3_JPEG_REG_Msk
#define GTZC_TZIC1_FCR4_GPDMA1_Pos   GTZC_CFGR4_GPDMA1_Pos
#define GTZC_TZIC1_FCR4_GPDMA1_Msk   GTZC_CFGR4_GPDMA1_Msk
#define GTZC_TZIC1_FCR4_FLASH_REG_Pos   GTZC_CFGR4_FLASH_REG_Pos
#define GTZC_TZIC1_FCR4_FLASH_REG_Msk   GTZC_CFGR4_FLASH_REG_Msk
#define GTZC_TZIC1_FCR4_FLASH_Pos   GTZC_CFGR4_FLASH_Pos
#define GTZC_TZIC1_FCR4_FLASH_Msk   GTZC_CFGR4_FLASH_Msk
#define GTZC_TZIC1_FCR4_OTFDEC1_Pos   GTZC_CFGR4_OTFDEC1_Pos
#define GTZC_TZIC1_FCR4_OTFDEC1_Msk   GTZC_CFGR4_OTFDEC1_Msk
#define GTZC_TZIC1_FCR4_OTFDEC2_Pos   GTZC_CFGR4_OTFDEC2_Pos
#define GTZC_TZIC1_FCR4_OTFDEC2_Msk   GTZC_CFGR4_OTFDEC2_Msk
#define GTZC_TZIC1_FCR4_TZSC1_Pos   GTZC_CFGR4_TZSC1_Pos
#define GTZC_TZIC1_FCR4_TZSC1_Msk   GTZC_CFGR4_TZSC1_Msk
#define GTZC_TZIC1_FCR4_TZIC1_Pos   GTZC_CFGR4_TZIC1_Pos
#define GTZC_TZIC1_FCR4_TZIC1_Msk   GTZC_CFGR4_TZIC1_Msk
#define GTZC_TZIC1_FCR4_OCTOSPI1_MEM_Pos   GTZC_CFGR4_OCTOSPI1_MEM_Pos
#define GTZC_TZIC1_FCR4_OCTOSPI1_MEM_Msk   GTZC_CFGR4_OCTOSPI1_MEM_Msk
#define GTZC_TZIC1_FCR4_FSMC_MEM_Pos   GTZC_CFGR4_FSMC_MEM_Pos
#define GTZC_TZIC1_FCR4_FSMC_MEM_Msk   GTZC_CFGR4_FSMC_MEM_Msk
#define GTZC_TZIC1_FCR4_BKPSRAM_Pos   GTZC_CFGR4_BKPSRAM_Pos
#define GTZC_TZIC1_FCR4_BKPSRAM_Msk   GTZC_CFGR4_BKPSRAM_Msk
#define GTZC_TZIC1_FCR4_OCTOSPI2_MEM_Pos   GTZC_CFGR4_OCTOSPI2_MEM_Pos
#define GTZC_TZIC1_FCR4_OCTOSPI2_MEM_Msk   GTZC_CFGR4_OCTOSPI2_MEM_Msk
#define GTZC_TZIC1_FCR4_HSPI1_MEM_Pos   GTZC_CFGR4_HSPI1_MEM_Pos
#define GTZC_TZIC1_FCR4_HSPI1_MEM_Msk   GTZC_CFGR4_HSPI1_MEM_Msk
#define GTZC_TZIC1_FCR4_SRAM6_Pos   GTZC_CFGR4_SRAM6_Pos
#define GTZC_TZIC1_FCR4_SRAM6_Msk   GTZC_CFGR4_SRAM6_Msk
#define GTZC_TZIC1_FCR4_MPCBB6_REG_Pos   GTZC_CFGR4_MPCBB6_REG_Pos
#define GTZC_TZIC1_FCR4_MPCBB6_REG_Msk   GTZC_CFGR4_MPCBB6_REG_Msk
#define GTZC_TZIC1_FCR4_SRAM1_Pos   GTZC_CFGR4_SRAM1_Pos
#define GTZC_TZIC1_FCR4_SRAM1_Msk   GTZC_CFGR4_SRAM1_Msk
#define GTZC_TZIC1_FCR4_MPCBB1_REG_Pos   GTZC_CFGR4_MPCBB1_REG_Pos
#define GTZC_TZIC1_FCR4_MPCBB1_REG_Msk   GTZC_CFGR4_MPCBB1_REG_Msk
#define GTZC_TZIC1_FCR4_SRAM2_Pos   GTZC_CFGR4_SRAM2_Pos
#define GTZC_TZIC1_FCR4_SRAM2_Msk   GTZC_CFGR4_SRAM2_Msk
#define GTZC_TZIC1_FCR4_MPCBB2_REG_Pos   GTZC_CFGR4_MPCBB2_REG_Pos
#define GTZC_TZIC1_FCR4_MPCBB2_REG_Msk   GTZC_CFGR4_MPCBB2_REG_Msk
#define GTZC_TZIC1_FCR4_SRAM3_Pos   GTZC_CFGR4_SRAM3_Pos
#define GTZC_TZIC1_FCR4_SRAM3_Msk   GTZC_CFGR4_SRAM3_Msk
#define GTZC_TZIC1_FCR4_MPCBB3_REG_Pos   GTZC_CFGR4_MPCBB3_REG_Pos
#define GTZC_TZIC1_FCR4_MPCBB3_REG_Msk   GTZC_CFGR4_MPCBB3_REG_Msk
#define GTZC_TZIC1_FCR4_SRAM5_Pos   GTZC_CFGR4_SRAM5_Pos
#define GTZC_TZIC1_FCR4_SRAM5_Msk   GTZC_CFGR4_SRAM5_Msk
#define GTZC_TZIC1_FCR4_MPCBB5_REG_Pos   GTZC_CFGR4_MPCBB5_REG_Pos
#define GTZC_TZIC1_FCR4_MPCBB5_REG_Msk   GTZC_CFGR4_MPCBB5_REG_Msk
#define GTZC_TZIC2_FCR1_SPI3_Pos   GTZC_CFGR1_SPI3_Pos
#define GTZC_TZIC2_FCR1_SPI3_Msk   GTZC_CFGR1_SPI3_Msk
#define GTZC_TZIC2_FCR1_LPUART1_Pos   GTZC_CFGR1_LPUART1_Pos
#define GTZC_TZIC2_FCR1_LPUART1_Msk   GTZC_CFGR1_LPUART1_Msk
#define GTZC_TZIC2_FCR1_I2C3_Pos   GTZC_CFGR1_I2C3_Pos
#define GTZC_TZIC2_FCR1_I2C3_Msk   GTZC_CFGR1_I2C3_Msk
#define GTZC_TZIC2_FCR1_LPTIM1_Pos   GTZC_CFGR1_LPTIM1_Pos
#define GTZC_TZIC2_FCR1_LPTIM1_Msk   GTZC_CFGR1_LPTIM1_Msk
#define GTZC_TZIC2_FCR1_LPTIM3_Pos   GTZC_CFGR1_LPTIM3_Pos
#define GTZC_TZIC2_FCR1_LPTIM3_Msk   GTZC_CFGR1_LPTIM3_Msk
#define GTZC_TZIC2_FCR1_LPTIM4_Pos   GTZC_CFGR1_LPTIM4_Pos
#define GTZC_TZIC2_FCR1_LPTIM4_Msk   GTZC_CFGR1_LPTIM4_Msk
#define GTZC_TZIC2_FCR1_OPAMP_Pos   GTZC_CFGR1_OPAMP_Pos
#define GTZC_TZIC2_FCR1_OPAMP_Msk   GTZC_CFGR1_OPAMP_Msk
#define GTZC_TZIC2_FCR1_COMP_Pos   GTZC_CFGR1_COMP_Pos
#define GTZC_TZIC2_FCR1_COMP_Msk   GTZC_CFGR1_COMP_Msk
#define GTZC_TZIC2_FCR1_ADC4_Pos   GTZC_CFGR1_ADC4_Pos
#define GTZC_TZIC2_FCR1_ADC4_Msk   GTZC_CFGR1_ADC4_Msk
#define GTZC_TZIC2_FCR1_VREFBUF_Pos   GTZC_CFGR1_VREFBUF_Pos
#define GTZC_TZIC2_FCR1_VREFBUF_Msk   GTZC_CFGR1_VREFBUF_Msk
#define GTZC_TZIC2_FCR1_DAC1_Pos   GTZC_CFGR1_DAC1_Pos
#define GTZC_TZIC2_FCR1_DAC1_Msk   GTZC_CFGR1_DAC1_Msk
#define GTZC_TZIC2_FCR1_ADF1_Pos   GTZC_CFGR1_ADF1_Pos
#define GTZC_TZIC2_FCR1_ADF1_Msk   GTZC_CFGR1_ADF1_Msk
#define GTZC_TZIC2_FCR2_SYSCFG_Pos   GTZC_CFGR2_SYSCFG_Pos
#define GTZC_TZIC2_FCR2_SYSCFG_Msk   GTZC_CFGR2_SYSCFG_Msk
#define GTZC_TZIC2_FCR2_RTC_Pos   GTZC_CFGR2_RTC_Pos
#define GTZC_TZIC2_FCR2_RTC_Msk   GTZC_CFGR2_RTC_Msk
#define GTZC_TZIC2_FCR2_TAMP_Pos   GTZC_CFGR2_TAMP_Pos
#define GTZC_TZIC2_FCR2_TAMP_Msk   GTZC_CFGR2_TAMP_Msk
#define GTZC_TZIC2_FCR2_PWR_Pos   GTZC_CFGR2_PWR_Pos
#define GTZC_TZIC2_FCR2_PWR_Msk   GTZC_CFGR2_PWR_Msk
#define GTZC_TZIC2_FCR2_RCC_Pos   GTZC_CFGR2_RCC_Pos
#define GTZC_TZIC2_FCR2_RCC_Msk   GTZC_CFGR2_RCC_Msk
#define GTZC_TZIC2_FCR2_LPDMA1_Pos   GTZC_CFGR2_LPDMA1_Pos
#define GTZC_TZIC2_FCR2_LPDMA1_Msk   GTZC_CFGR2_LPDMA1_Msk
#define GTZC_TZIC2_FCR2_EXTI_Pos   GTZC_CFGR2_EXTI_Pos
#define GTZC_TZIC2_FCR2_EXTI_Msk   GTZC_CFGR2_EXTI_Msk
#define GTZC_TZIC2_FCR2_TZSC2_Pos   GTZC_CFGR2_TZSC2_Pos
#define GTZC_TZIC2_FCR2_TZSC2_Msk   GTZC_CFGR2_TZSC2_Msk
#define GTZC_TZIC2_FCR2_TZIC2_Pos   GTZC_CFGR2_TZIC2_Pos
#define GTZC_TZIC2_FCR2_TZIC2_Msk   GTZC_CFGR2_TZIC2_Msk
#define GTZC_TZIC2_FCR2_SRAM4_Pos   GTZC_CFGR2_SRAM4_Pos
#define GTZC_TZIC2_FCR2_SRAM4_Msk   GTZC_CFGR2_SRAM4_Msk
#define GTZC_TZIC2_FCR2_MPCBB4_REG_Pos   GTZC_CFGR2_MPCBB4_REG_Pos
#define GTZC_TZIC2_FCR2_MPCBB4_REG_Msk   GTZC_CFGR2_MPCBB4_REG_Msk
#define GTZC_MPCBB_CR_GLOCK_Pos   (0U)
#define GTZC_MPCBB_CR_GLOCK_Msk   (0x01UL << GTZC_MPCBB_CR_GLOCK_Pos)
#define GTZC_MPCBB_CR_INVSECSTATE_Pos   (30U)
#define GTZC_MPCBB_CR_INVSECSTATE_Msk   (0x01UL << GTZC_MPCBB_CR_INVSECSTATE_Pos)
#define GTZC_MPCBB_CR_SRWILADIS_Pos   (31U)
#define GTZC_MPCBB_CR_SRWILADIS_Msk   (0x01UL << GTZC_MPCBB_CR_SRWILADIS_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK0_Pos   (0U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK0_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK0_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK1_Pos   (1U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK1_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK1_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK2_Pos   (2U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK2_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK2_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK3_Pos   (3U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK3_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK3_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK4_Pos   (4U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK4_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK4_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK5_Pos   (5U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK5_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK5_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK6_Pos   (6U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK6_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK6_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK7_Pos   (7U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK7_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK7_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK8_Pos   (8U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK8_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK8_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK9_Pos   (9U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK9_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK9_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK10_Pos   (10U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK10_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK10_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK11_Pos   (11U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK11_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK11_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK12_Pos   (12U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK12_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK12_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK13_Pos   (13U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK13_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK13_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK14_Pos   (14U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK14_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK14_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK15_Pos   (15U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK15_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK15_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK16_Pos   (16U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK16_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK16_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK17_Pos   (17U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK17_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK17_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK18_Pos   (18U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK18_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK18_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK19_Pos   (19U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK19_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK19_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK20_Pos   (20U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK20_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK20_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK21_Pos   (21U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK21_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK21_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK22_Pos   (22U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK22_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK22_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK23_Pos   (23U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK23_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK23_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK24_Pos   (24U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK24_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK24_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK25_Pos   (25U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK25_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK25_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK26_Pos   (26U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK26_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK26_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK27_Pos   (27U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK27_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK27_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK28_Pos   (28U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK28_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK28_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK29_Pos   (29U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK29_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK29_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK30_Pos   (30U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK30_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK30_Pos)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK31_Pos   (31U)
#define GTZC_MPCBB_CFGLOCKR1_SPLCK31_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR1_SPLCK31_Pos)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK32_Pos   (0U)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK32_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR2_SPLCK32_Pos)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK33_Pos   (1U)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK33_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR2_SPLCK33_Pos)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK34_Pos   (2U)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK34_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR2_SPLCK34_Pos)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK35_Pos   (3U)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK35_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR2_SPLCK35_Pos)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK36_Pos   (4U)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK36_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR2_SPLCK36_Pos)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK37_Pos   (5U)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK37_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR2_SPLCK37_Pos)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK38_Pos   (6U)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK38_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR2_SPLCK38_Pos)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK39_Pos   (7U)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK39_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR2_SPLCK39_Pos)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK40_Pos   (8U)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK40_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR2_SPLCK40_Pos)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK41_Pos   (9U)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK41_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR2_SPLCK41_Pos)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK42_Pos   (10U)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK42_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR2_SPLCK42_Pos)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK43_Pos   (11U)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK43_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR2_SPLCK43_Pos)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK44_Pos   (12U)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK44_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR2_SPLCK44_Pos)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK45_Pos   (13U)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK45_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR2_SPLCK45_Pos)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK46_Pos   (14U)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK46_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR2_SPLCK46_Pos)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK47_Pos   (15U)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK47_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR2_SPLCK47_Pos)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK48_Pos   (16U)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK48_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR2_SPLCK48_Pos)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK49_Pos   (17U)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK49_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR2_SPLCK49_Pos)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK50_Pos   (18U)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK50_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR2_SPLCK50_Pos)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK51_Pos   (19U)
#define GTZC_MPCBB_CFGLOCKR2_SPLCK51_Msk   (0x01UL << GTZC_MPCBB_CFGLOCKR2_SPLCK51_Pos)
#define UCPD_CFG1_HBITCLKDIV_Pos   (0U)
#define UCPD_CFG1_HBITCLKDIV_Msk   (0x3FUL << UCPD_CFG1_HBITCLKDIV_Pos)
#define UCPD_CFG1_HBITCLKDIV   UCPD_CFG1_HBITCLKDIV_Msk
#define UCPD_CFG1_HBITCLKDIV_0   (0x01UL << UCPD_CFG1_HBITCLKDIV_Pos)
#define UCPD_CFG1_HBITCLKDIV_1   (0x02UL << UCPD_CFG1_HBITCLKDIV_Pos)
#define UCPD_CFG1_HBITCLKDIV_2   (0x04UL << UCPD_CFG1_HBITCLKDIV_Pos)
#define UCPD_CFG1_HBITCLKDIV_3   (0x08UL << UCPD_CFG1_HBITCLKDIV_Pos)
#define UCPD_CFG1_HBITCLKDIV_4   (0x10UL << UCPD_CFG1_HBITCLKDIV_Pos)
#define UCPD_CFG1_HBITCLKDIV_5   (0x20UL << UCPD_CFG1_HBITCLKDIV_Pos)
#define UCPD_CFG1_IFRGAP_Pos   (6U)
#define UCPD_CFG1_IFRGAP_Msk   (0x1FUL << UCPD_CFG1_IFRGAP_Pos)
#define UCPD_CFG1_IFRGAP   UCPD_CFG1_IFRGAP_Msk
#define UCPD_CFG1_IFRGAP_0   (0x01UL << UCPD_CFG1_IFRGAP_Pos)
#define UCPD_CFG1_IFRGAP_1   (0x02UL << UCPD_CFG1_IFRGAP_Pos)
#define UCPD_CFG1_IFRGAP_2   (0x04UL << UCPD_CFG1_IFRGAP_Pos)
#define UCPD_CFG1_IFRGAP_3   (0x08UL << UCPD_CFG1_IFRGAP_Pos)
#define UCPD_CFG1_IFRGAP_4   (0x10UL << UCPD_CFG1_IFRGAP_Pos)
#define UCPD_CFG1_TRANSWIN_Pos   (11U)
#define UCPD_CFG1_TRANSWIN_Msk   (0x1FUL << UCPD_CFG1_TRANSWIN_Pos)
#define UCPD_CFG1_TRANSWIN   UCPD_CFG1_TRANSWIN_Msk
#define UCPD_CFG1_TRANSWIN_0   (0x01UL << UCPD_CFG1_TRANSWIN_Pos)
#define UCPD_CFG1_TRANSWIN_1   (0x02UL << UCPD_CFG1_TRANSWIN_Pos)
#define UCPD_CFG1_TRANSWIN_2   (0x04UL << UCPD_CFG1_TRANSWIN_Pos)
#define UCPD_CFG1_TRANSWIN_3   (0x08UL << UCPD_CFG1_TRANSWIN_Pos)
#define UCPD_CFG1_TRANSWIN_4   (0x10UL << UCPD_CFG1_TRANSWIN_Pos)
#define UCPD_CFG1_PSC_UCPDCLK_Pos   (17U)
#define UCPD_CFG1_PSC_UCPDCLK_Msk   (0x7UL << UCPD_CFG1_PSC_UCPDCLK_Pos)
#define UCPD_CFG1_PSC_UCPDCLK   UCPD_CFG1_PSC_UCPDCLK_Msk
#define UCPD_CFG1_PSC_UCPDCLK_0   (0x1UL << UCPD_CFG1_PSC_UCPDCLK_Pos)
#define UCPD_CFG1_PSC_UCPDCLK_1   (0x2UL << UCPD_CFG1_PSC_UCPDCLK_Pos)
#define UCPD_CFG1_PSC_UCPDCLK_2   (0x4UL << UCPD_CFG1_PSC_UCPDCLK_Pos)
#define UCPD_CFG1_RXORDSETEN_Pos   (20U)
#define UCPD_CFG1_RXORDSETEN_Msk   (0x1FFUL << UCPD_CFG1_RXORDSETEN_Pos)
#define UCPD_CFG1_RXORDSETEN   UCPD_CFG1_RXORDSETEN_Msk
#define UCPD_CFG1_RXORDSETEN_0   (0x001UL << UCPD_CFG1_RXORDSETEN_Pos)
#define UCPD_CFG1_RXORDSETEN_1   (0x002UL << UCPD_CFG1_RXORDSETEN_Pos)
#define UCPD_CFG1_RXORDSETEN_2   (0x004UL << UCPD_CFG1_RXORDSETEN_Pos)
#define UCPD_CFG1_RXORDSETEN_3   (0x008UL << UCPD_CFG1_RXORDSETEN_Pos)
#define UCPD_CFG1_RXORDSETEN_4   (0x010UL << UCPD_CFG1_RXORDSETEN_Pos)
#define UCPD_CFG1_RXORDSETEN_5   (0x020UL << UCPD_CFG1_RXORDSETEN_Pos)
#define UCPD_CFG1_RXORDSETEN_6   (0x040UL << UCPD_CFG1_RXORDSETEN_Pos)
#define UCPD_CFG1_RXORDSETEN_7   (0x080UL << UCPD_CFG1_RXORDSETEN_Pos)
#define UCPD_CFG1_RXORDSETEN_8   (0x100UL << UCPD_CFG1_RXORDSETEN_Pos)
#define UCPD_CFG1_TXDMAEN_Pos   (29U)
#define UCPD_CFG1_TXDMAEN_Msk   (0x1UL << UCPD_CFG1_TXDMAEN_Pos)
#define UCPD_CFG1_TXDMAEN   UCPD_CFG1_TXDMAEN_Msk
#define UCPD_CFG1_RXDMAEN_Pos   (30U)
#define UCPD_CFG1_RXDMAEN_Msk   (0x1UL << UCPD_CFG1_RXDMAEN_Pos)
#define UCPD_CFG1_RXDMAEN   UCPD_CFG1_RXDMAEN_Msk
#define UCPD_CFG1_UCPDEN_Pos   (31U)
#define UCPD_CFG1_UCPDEN_Msk   (0x1UL << UCPD_CFG1_UCPDEN_Pos)
#define UCPD_CFG1_UCPDEN   UCPD_CFG1_UCPDEN_Msk
#define UCPD_CFG2_RXFILTDIS_Pos   (0U)
#define UCPD_CFG2_RXFILTDIS_Msk   (0x1UL << UCPD_CFG2_RXFILTDIS_Pos)
#define UCPD_CFG2_RXFILTDIS   UCPD_CFG2_RXFILTDIS_Msk
#define UCPD_CFG2_RXFILT2N3_Pos   (1U)
#define UCPD_CFG2_RXFILT2N3_Msk   (0x1UL << UCPD_CFG2_RXFILT2N3_Pos)
#define UCPD_CFG2_RXFILT2N3   UCPD_CFG2_RXFILT2N3_Msk
#define UCPD_CFG2_FORCECLK_Pos   (2U)
#define UCPD_CFG2_FORCECLK_Msk   (0x1UL << UCPD_CFG2_FORCECLK_Pos)
#define UCPD_CFG2_FORCECLK   UCPD_CFG2_FORCECLK_Msk
#define UCPD_CFG2_WUPEN_Pos   (3U)
#define UCPD_CFG2_WUPEN_Msk   (0x1UL << UCPD_CFG2_WUPEN_Pos)
#define UCPD_CFG2_WUPEN   UCPD_CFG2_WUPEN_Msk
#define UCPD_CFG2_RXAFILTEN_Pos   (8U)
#define UCPD_CFG2_RXAFILTEN_Msk   (0x1UL << UCPD_CFG2_RXAFILTEN_Pos)
#define UCPD_CFG2_RXAFILTEN   UCPD_CFG2_RXAFILTEN_Msk
#define UCPD_CFG3_TRIM_CC1_RD_Pos   (0U)
#define UCPD_CFG3_TRIM_CC1_RD_Msk   (0xFUL << UCPD_CFG3_TRIM_CC1_RD_Pos)
#define UCPD_CFG3_TRIM_CC1_RD   UCPD_CFG3_TRIM_CC1_RD_Msk
#define UCPD_CFG3_TRIM_CC1_RP_Pos   (9U)
#define UCPD_CFG3_TRIM_CC1_RP_Msk   (0xFUL << UCPD_CFG3_TRIM_CC1_RP_Pos)
#define UCPD_CFG3_TRIM_CC1_RP   UCPD_CFG3_TRIM_CC1_RP_Msk
#define UCPD_CFG3_TRIM_CC2_RD_Pos   (16U)
#define UCPD_CFG3_TRIM_CC2_RD_Msk   (0xFUL << UCPD_CFG3_TRIM_CC2_RD_Pos)
#define UCPD_CFG3_TRIM_CC2_RD   UCPD_CFG3_TRIM_CC2_RD_Msk
#define UCPD_CFG3_TRIM_CC2_RP_Pos   (25U)
#define UCPD_CFG3_TRIM_CC2_RP_Msk   (0xFUL << UCPD_CFG3_TRIM_CC2_RP_Pos)
#define UCPD_CFG3_TRIM_CC2_RP   UCPD_CFG3_TRIM_CC2_RP_Msk
#define UCPD_CR_TXMODE_Pos   (0U)
#define UCPD_CR_TXMODE_Msk   (0x3UL << UCPD_CR_TXMODE_Pos)
#define UCPD_CR_TXMODE   UCPD_CR_TXMODE_Msk
#define UCPD_CR_TXMODE_0   (0x1UL << UCPD_CR_TXMODE_Pos)
#define UCPD_CR_TXMODE_1   (0x2UL << UCPD_CR_TXMODE_Pos)
#define UCPD_CR_TXSEND_Pos   (2U)
#define UCPD_CR_TXSEND_Msk   (0x1UL << UCPD_CR_TXSEND_Pos)
#define UCPD_CR_TXSEND   UCPD_CR_TXSEND_Msk
#define UCPD_CR_TXHRST_Pos   (3U)
#define UCPD_CR_TXHRST_Msk   (0x1UL << UCPD_CR_TXHRST_Pos)
#define UCPD_CR_TXHRST   UCPD_CR_TXHRST_Msk
#define UCPD_CR_RXMODE_Pos   (4U)
#define UCPD_CR_RXMODE_Msk   (0x1UL << UCPD_CR_RXMODE_Pos)
#define UCPD_CR_RXMODE   UCPD_CR_RXMODE_Msk
#define UCPD_CR_PHYRXEN_Pos   (5U)
#define UCPD_CR_PHYRXEN_Msk   (0x1UL << UCPD_CR_PHYRXEN_Pos)
#define UCPD_CR_PHYRXEN   UCPD_CR_PHYRXEN_Msk
#define UCPD_CR_PHYCCSEL_Pos   (6U)
#define UCPD_CR_PHYCCSEL_Msk   (0x1UL << UCPD_CR_PHYCCSEL_Pos)
#define UCPD_CR_PHYCCSEL   UCPD_CR_PHYCCSEL_Msk
#define UCPD_CR_ANASUBMODE_Pos   (7U)
#define UCPD_CR_ANASUBMODE_Msk   (0x3UL << UCPD_CR_ANASUBMODE_Pos)
#define UCPD_CR_ANASUBMODE   UCPD_CR_ANASUBMODE_Msk
#define UCPD_CR_ANASUBMODE_0   (0x1UL << UCPD_CR_ANASUBMODE_Pos)
#define UCPD_CR_ANASUBMODE_1   (0x2UL << UCPD_CR_ANASUBMODE_Pos)
#define UCPD_CR_ANAMODE_Pos   (9U)
#define UCPD_CR_ANAMODE_Msk   (0x1UL << UCPD_CR_ANAMODE_Pos)
#define UCPD_CR_ANAMODE   UCPD_CR_ANAMODE_Msk
#define UCPD_CR_CCENABLE_Pos   (10U)
#define UCPD_CR_CCENABLE_Msk   (0x3UL << UCPD_CR_CCENABLE_Pos)
#define UCPD_CR_CCENABLE   UCPD_CR_CCENABLE_Msk
#define UCPD_CR_CCENABLE_0   (0x1UL << UCPD_CR_CCENABLE_Pos)
#define UCPD_CR_CCENABLE_1   (0x2UL << UCPD_CR_CCENABLE_Pos)
#define UCPD_CR_FRSRXEN_Pos   (16U)
#define UCPD_CR_FRSRXEN_Msk   (0x1UL << UCPD_CR_FRSRXEN_Pos)
#define UCPD_CR_FRSRXEN   UCPD_CR_FRSRXEN_Msk
#define UCPD_CR_FRSTX_Pos   (17U)
#define UCPD_CR_FRSTX_Msk   (0x1UL << UCPD_CR_FRSTX_Pos)
#define UCPD_CR_FRSTX   UCPD_CR_FRSTX_Msk
#define UCPD_CR_RDCH_Pos   (18U)
#define UCPD_CR_RDCH_Msk   (0x1UL << UCPD_CR_RDCH_Pos)
#define UCPD_CR_RDCH   UCPD_CR_RDCH_Msk
#define UCPD_CR_CC1TCDIS_Pos   (20U)
#define UCPD_CR_CC1TCDIS_Msk   (0x1UL << UCPD_CR_CC1TCDIS_Pos)
#define UCPD_CR_CC1TCDIS   UCPD_CR_CC1TCDIS_Msk
#define UCPD_CR_CC2TCDIS_Pos   (21U)
#define UCPD_CR_CC2TCDIS_Msk   (0x1UL << UCPD_CR_CC2TCDIS_Pos)
#define UCPD_CR_CC2TCDIS   UCPD_CR_CC2TCDIS_Msk
#define UCPD_IMR_TXISIE_Pos   (0U)
#define UCPD_IMR_TXISIE_Msk   (0x1UL << UCPD_IMR_TXISIE_Pos)
#define UCPD_IMR_TXISIE   UCPD_IMR_TXISIE_Msk
#define UCPD_IMR_TXMSGDISCIE_Pos   (1U)
#define UCPD_IMR_TXMSGDISCIE_Msk   (0x1UL << UCPD_IMR_TXMSGDISCIE_Pos)
#define UCPD_IMR_TXMSGDISCIE   UCPD_IMR_TXMSGDISCIE_Msk
#define UCPD_IMR_TXMSGSENTIE_Pos   (2U)
#define UCPD_IMR_TXMSGSENTIE_Msk   (0x1UL << UCPD_IMR_TXMSGSENTIE_Pos)
#define UCPD_IMR_TXMSGSENTIE   UCPD_IMR_TXMSGSENTIE_Msk
#define UCPD_IMR_TXMSGABTIE_Pos   (3U)
#define UCPD_IMR_TXMSGABTIE_Msk   (0x1UL << UCPD_IMR_TXMSGABTIE_Pos)
#define UCPD_IMR_TXMSGABTIE   UCPD_IMR_TXMSGABTIE_Msk
#define UCPD_IMR_HRSTDISCIE_Pos   (4U)
#define UCPD_IMR_HRSTDISCIE_Msk   (0x1UL << UCPD_IMR_HRSTDISCIE_Pos)
#define UCPD_IMR_HRSTDISCIE   UCPD_IMR_HRSTDISCIE_Msk
#define UCPD_IMR_HRSTSENTIE_Pos   (5U)
#define UCPD_IMR_HRSTSENTIE_Msk   (0x1UL << UCPD_IMR_HRSTSENTIE_Pos)
#define UCPD_IMR_HRSTSENTIE   UCPD_IMR_HRSTSENTIE_Msk
#define UCPD_IMR_TXUNDIE_Pos   (6U)
#define UCPD_IMR_TXUNDIE_Msk   (0x1UL << UCPD_IMR_TXUNDIE_Pos)
#define UCPD_IMR_TXUNDIE   UCPD_IMR_TXUNDIE_Msk
#define UCPD_IMR_RXNEIE_Pos   (8U)
#define UCPD_IMR_RXNEIE_Msk   (0x1UL << UCPD_IMR_RXNEIE_Pos)
#define UCPD_IMR_RXNEIE   UCPD_IMR_RXNEIE_Msk
#define UCPD_IMR_RXORDDETIE_Pos   (9U)
#define UCPD_IMR_RXORDDETIE_Msk   (0x1UL << UCPD_IMR_RXORDDETIE_Pos)
#define UCPD_IMR_RXORDDETIE   UCPD_IMR_RXORDDETIE_Msk
#define UCPD_IMR_RXHRSTDETIE_Pos   (10U)
#define UCPD_IMR_RXHRSTDETIE_Msk   (0x1UL << UCPD_IMR_RXHRSTDETIE_Pos)
#define UCPD_IMR_RXHRSTDETIE   UCPD_IMR_RXHRSTDETIE_Msk
#define UCPD_IMR_RXOVRIE_Pos   (11U)
#define UCPD_IMR_RXOVRIE_Msk   (0x1UL << UCPD_IMR_RXOVRIE_Pos)
#define UCPD_IMR_RXOVRIE   UCPD_IMR_RXOVRIE_Msk
#define UCPD_IMR_RXMSGENDIE_Pos   (12U)
#define UCPD_IMR_RXMSGENDIE_Msk   (0x1UL << UCPD_IMR_RXMSGENDIE_Pos)
#define UCPD_IMR_RXMSGENDIE   UCPD_IMR_RXMSGENDIE_Msk
#define UCPD_IMR_TYPECEVT1IE_Pos   (14U)
#define UCPD_IMR_TYPECEVT1IE_Msk   (0x1UL << UCPD_IMR_TYPECEVT1IE_Pos)
#define UCPD_IMR_TYPECEVT1IE   UCPD_IMR_TYPECEVT1IE_Msk
#define UCPD_IMR_TYPECEVT2IE_Pos   (15U)
#define UCPD_IMR_TYPECEVT2IE_Msk   (0x1UL << UCPD_IMR_TYPECEVT2IE_Pos)
#define UCPD_IMR_TYPECEVT2IE   UCPD_IMR_TYPECEVT2IE_Msk
#define UCPD_IMR_FRSEVTIE_Pos   (20U)
#define UCPD_IMR_FRSEVTIE_Msk   (0x1UL << UCPD_IMR_FRSEVTIE_Pos)
#define UCPD_IMR_FRSEVTIE   UCPD_IMR_FRSEVTIE_Msk
#define UCPD_SR_TXIS_Pos   (0U)
#define UCPD_SR_TXIS_Msk   (0x1UL << UCPD_SR_TXIS_Pos)
#define UCPD_SR_TXIS   UCPD_SR_TXIS_Msk
#define UCPD_SR_TXMSGDISC_Pos   (1U)
#define UCPD_SR_TXMSGDISC_Msk   (0x1UL << UCPD_SR_TXMSGDISC_Pos)
#define UCPD_SR_TXMSGDISC   UCPD_SR_TXMSGDISC_Msk
#define UCPD_SR_TXMSGSENT_Pos   (2U)
#define UCPD_SR_TXMSGSENT_Msk   (0x1UL << UCPD_SR_TXMSGSENT_Pos)
#define UCPD_SR_TXMSGSENT   UCPD_SR_TXMSGSENT_Msk
#define UCPD_SR_TXMSGABT_Pos   (3U)
#define UCPD_SR_TXMSGABT_Msk   (0x1UL << UCPD_SR_TXMSGABT_Pos)
#define UCPD_SR_TXMSGABT   UCPD_SR_TXMSGABT_Msk
#define UCPD_SR_HRSTDISC_Pos   (4U)
#define UCPD_SR_HRSTDISC_Msk   (0x1UL << UCPD_SR_HRSTDISC_Pos)
#define UCPD_SR_HRSTDISC   UCPD_SR_HRSTDISC_Msk
#define UCPD_SR_HRSTSENT_Pos   (5U)
#define UCPD_SR_HRSTSENT_Msk   (0x1UL << UCPD_SR_HRSTSENT_Pos)
#define UCPD_SR_HRSTSENT   UCPD_SR_HRSTSENT_Msk
#define UCPD_SR_TXUND_Pos   (6U)
#define UCPD_SR_TXUND_Msk   (0x1UL << UCPD_SR_TXUND_Pos)
#define UCPD_SR_TXUND   UCPD_SR_TXUND_Msk
#define UCPD_SR_RXNE_Pos   (8U)
#define UCPD_SR_RXNE_Msk   (0x1UL << UCPD_SR_RXNE_Pos)
#define UCPD_SR_RXNE   UCPD_SR_RXNE_Msk
#define UCPD_SR_RXORDDET_Pos   (9U)
#define UCPD_SR_RXORDDET_Msk   (0x1UL << UCPD_SR_RXORDDET_Pos)
#define UCPD_SR_RXORDDET   UCPD_SR_RXORDDET_Msk
#define UCPD_SR_RXHRSTDET_Pos   (10U)
#define UCPD_SR_RXHRSTDET_Msk   (0x1UL << UCPD_SR_RXHRSTDET_Pos)
#define UCPD_SR_RXHRSTDET   UCPD_SR_RXHRSTDET_Msk
#define UCPD_SR_RXOVR_Pos   (11U)
#define UCPD_SR_RXOVR_Msk   (0x1UL << UCPD_SR_RXOVR_Pos)
#define UCPD_SR_RXOVR   UCPD_SR_RXOVR_Msk
#define UCPD_SR_RXMSGEND_Pos   (12U)
#define UCPD_SR_RXMSGEND_Msk   (0x1UL << UCPD_SR_RXMSGEND_Pos)
#define UCPD_SR_RXMSGEND   UCPD_SR_RXMSGEND_Msk
#define UCPD_SR_RXERR_Pos   (13U)
#define UCPD_SR_RXERR_Msk   (0x1UL << UCPD_SR_RXERR_Pos)
#define UCPD_SR_RXERR   UCPD_SR_RXERR_Msk
#define UCPD_SR_TYPECEVT1_Pos   (14U)
#define UCPD_SR_TYPECEVT1_Msk   (0x1UL << UCPD_SR_TYPECEVT1_Pos)
#define UCPD_SR_TYPECEVT1   UCPD_SR_TYPECEVT1_Msk
#define UCPD_SR_TYPECEVT2_Pos   (15U)
#define UCPD_SR_TYPECEVT2_Msk   (0x1UL << UCPD_SR_TYPECEVT2_Pos)
#define UCPD_SR_TYPECEVT2   UCPD_SR_TYPECEVT2_Msk
#define UCPD_SR_TYPEC_VSTATE_CC1_Pos   (16U)
#define UCPD_SR_TYPEC_VSTATE_CC1_Msk   (0x3UL << UCPD_SR_TYPEC_VSTATE_CC1_Pos)
#define UCPD_SR_TYPEC_VSTATE_CC1   UCPD_SR_TYPEC_VSTATE_CC1_Msk
#define UCPD_SR_TYPEC_VSTATE_CC1_0   (0x1UL << UCPD_SR_TYPEC_VSTATE_CC1_Pos)
#define UCPD_SR_TYPEC_VSTATE_CC1_1   (0x2UL << UCPD_SR_TYPEC_VSTATE_CC1_Pos)
#define UCPD_SR_TYPEC_VSTATE_CC2_Pos   (18U)
#define UCPD_SR_TYPEC_VSTATE_CC2_Msk   (0x3UL << UCPD_SR_TYPEC_VSTATE_CC2_Pos)
#define UCPD_SR_TYPEC_VSTATE_CC2   UCPD_SR_TYPEC_VSTATE_CC2_Msk
#define UCPD_SR_TYPEC_VSTATE_CC2_0   (0x1UL << UCPD_SR_TYPEC_VSTATE_CC2_Pos)
#define UCPD_SR_TYPEC_VSTATE_CC2_1   (0x2UL << UCPD_SR_TYPEC_VSTATE_CC2_Pos)
#define UCPD_SR_FRSEVT_Pos   (20U)
#define UCPD_SR_FRSEVT_Msk   (0x1UL << UCPD_SR_FRSEVT_Pos)
#define UCPD_SR_FRSEVT   UCPD_SR_FRSEVT_Msk
#define UCPD_ICR_TXMSGDISCCF_Pos   (1U)
#define UCPD_ICR_TXMSGDISCCF_Msk   (0x1UL << UCPD_ICR_TXMSGDISCCF_Pos)
#define UCPD_ICR_TXMSGDISCCF   UCPD_ICR_TXMSGDISCCF_Msk
#define UCPD_ICR_TXMSGSENTCF_Pos   (2U)
#define UCPD_ICR_TXMSGSENTCF_Msk   (0x1UL << UCPD_ICR_TXMSGSENTCF_Pos)
#define UCPD_ICR_TXMSGSENTCF   UCPD_ICR_TXMSGSENTCF_Msk
#define UCPD_ICR_TXMSGABTCF_Pos   (3U)
#define UCPD_ICR_TXMSGABTCF_Msk   (0x1UL << UCPD_ICR_TXMSGABTCF_Pos)
#define UCPD_ICR_TXMSGABTCF   UCPD_ICR_TXMSGABTCF_Msk
#define UCPD_ICR_HRSTDISCCF_Pos   (4U)
#define UCPD_ICR_HRSTDISCCF_Msk   (0x1UL << UCPD_ICR_HRSTDISCCF_Pos)
#define UCPD_ICR_HRSTDISCCF   UCPD_ICR_HRSTDISCCF_Msk
#define UCPD_ICR_HRSTSENTCF_Pos   (5U)
#define UCPD_ICR_HRSTSENTCF_Msk   (0x1UL << UCPD_ICR_HRSTSENTCF_Pos)
#define UCPD_ICR_HRSTSENTCF   UCPD_ICR_HRSTSENTCF_Msk
#define UCPD_ICR_TXUNDCF_Pos   (6U)
#define UCPD_ICR_TXUNDCF_Msk   (0x1UL << UCPD_ICR_TXUNDCF_Pos)
#define UCPD_ICR_TXUNDCF   UCPD_ICR_TXUNDCF_Msk
#define UCPD_ICR_RXORDDETCF_Pos   (9U)
#define UCPD_ICR_RXORDDETCF_Msk   (0x1UL << UCPD_ICR_RXORDDETCF_Pos)
#define UCPD_ICR_RXORDDETCF   UCPD_ICR_RXORDDETCF_Msk
#define UCPD_ICR_RXHRSTDETCF_Pos   (10U)
#define UCPD_ICR_RXHRSTDETCF_Msk   (0x1UL << UCPD_ICR_RXHRSTDETCF_Pos)
#define UCPD_ICR_RXHRSTDETCF   UCPD_ICR_RXHRSTDETCF_Msk
#define UCPD_ICR_RXOVRCF_Pos   (11U)
#define UCPD_ICR_RXOVRCF_Msk   (0x1UL << UCPD_ICR_RXOVRCF_Pos)
#define UCPD_ICR_RXOVRCF   UCPD_ICR_RXOVRCF_Msk
#define UCPD_ICR_RXMSGENDCF_Pos   (12U)
#define UCPD_ICR_RXMSGENDCF_Msk   (0x1UL << UCPD_ICR_RXMSGENDCF_Pos)
#define UCPD_ICR_RXMSGENDCF   UCPD_ICR_RXMSGENDCF_Msk
#define UCPD_ICR_TYPECEVT1CF_Pos   (14U)
#define UCPD_ICR_TYPECEVT1CF_Msk   (0x1UL << UCPD_ICR_TYPECEVT1CF_Pos)
#define UCPD_ICR_TYPECEVT1CF   UCPD_ICR_TYPECEVT1CF_Msk
#define UCPD_ICR_TYPECEVT2CF_Pos   (15U)
#define UCPD_ICR_TYPECEVT2CF_Msk   (0x1UL << UCPD_ICR_TYPECEVT2CF_Pos)
#define UCPD_ICR_TYPECEVT2CF   UCPD_ICR_TYPECEVT2CF_Msk
#define UCPD_ICR_FRSEVTCF_Pos   (20U)
#define UCPD_ICR_FRSEVTCF_Msk   (0x1UL << UCPD_ICR_FRSEVTCF_Pos)
#define UCPD_ICR_FRSEVTCF   UCPD_ICR_FRSEVTCF_Msk
#define UCPD_TX_ORDSET_TXORDSET_Pos   (0U)
#define UCPD_TX_ORDSET_TXORDSET_Msk   (0xFFFFFUL << UCPD_TX_ORDSET_TXORDSET_Pos)
#define UCPD_TX_ORDSET_TXORDSET   UCPD_TX_ORDSET_TXORDSET_Msk
#define UCPD_TX_PAYSZ_TXPAYSZ_Pos   (0U)
#define UCPD_TX_PAYSZ_TXPAYSZ_Msk   (0x3FFUL << UCPD_TX_PAYSZ_TXPAYSZ_Pos)
#define UCPD_TX_PAYSZ_TXPAYSZ   UCPD_TX_PAYSZ_TXPAYSZ_Msk
#define UCPD_TXDR_TXDATA_Pos   (0U)
#define UCPD_TXDR_TXDATA_Msk   (0xFFUL << UCPD_TXDR_TXDATA_Pos)
#define UCPD_TXDR_TXDATA   UCPD_TXDR_TXDATA_Msk
#define UCPD_RX_ORDSET_RXORDSET_Pos   (0U)
#define UCPD_RX_ORDSET_RXORDSET_Msk   (0x7UL << UCPD_RX_ORDSET_RXORDSET_Pos)
#define UCPD_RX_ORDSET_RXORDSET   UCPD_RX_ORDSET_RXORDSET_Msk
#define UCPD_RX_ORDSET_RXORDSET_0   (0x1UL << UCPD_RX_ORDSET_RXORDSET_Pos)
#define UCPD_RX_ORDSET_RXORDSET_1   (0x2UL << UCPD_RX_ORDSET_RXORDSET_Pos)
#define UCPD_RX_ORDSET_RXORDSET_2   (0x4UL << UCPD_RX_ORDSET_RXORDSET_Pos)
#define UCPD_RX_ORDSET_RXSOP3OF4_Pos   (3U)
#define UCPD_RX_ORDSET_RXSOP3OF4_Msk   (0x1UL << UCPD_RX_ORDSET_RXSOP3OF4_Pos)
#define UCPD_RX_ORDSET_RXSOP3OF4   UCPD_RX_ORDSET_RXSOP3OF4_Msk
#define UCPD_RX_ORDSET_RXSOPKINVALID_Pos   (4U)
#define UCPD_RX_ORDSET_RXSOPKINVALID_Msk   (0x7UL << UCPD_RX_ORDSET_RXSOPKINVALID_Pos)
#define UCPD_RX_ORDSET_RXSOPKINVALID   UCPD_RX_ORDSET_RXSOPKINVALID_Msk
#define UCPD_RX_PAYSZ_RXPAYSZ_Pos   (0U)
#define UCPD_RX_PAYSZ_RXPAYSZ_Msk   (0x3FFUL << UCPD_RX_PAYSZ_RXPAYSZ_Pos)
#define UCPD_RX_PAYSZ_RXPAYSZ   UCPD_RX_PAYSZ_RXPAYSZ_Msk
#define UCPD_RXDR_RXDATA_Pos   (0U)
#define UCPD_RXDR_RXDATA_Msk   (0xFFUL << UCPD_RXDR_RXDATA_Pos)
#define UCPD_RXDR_RXDATA   UCPD_RXDR_RXDATA_Msk
#define UCPD_RX_ORDEXT1_RXSOPX1_Pos   (0U)
#define UCPD_RX_ORDEXT1_RXSOPX1_Msk   (0xFFFFFUL << UCPD_RX_ORDEXT1_RXSOPX1_Pos)
#define UCPD_RX_ORDEXT1_RXSOPX1   UCPD_RX_ORDEXT1_RXSOPX1_Msk
#define UCPD_RX_ORDEXT2_RXSOPX2_Pos   (0U)
#define UCPD_RX_ORDEXT2_RXSOPX2_Msk   (0xFFFFFUL << UCPD_RX_ORDEXT2_RXSOPX2_Pos)
#define UCPD_RX_ORDEXT2_RXSOPX2   UCPD_RX_ORDEXT2_RXSOPX2_Msk
#define USB_OTG_GOTGCTL_SRQSCS_Pos   (0U)
#define USB_OTG_GOTGCTL_SRQSCS_Msk   (0x1U << USB_OTG_GOTGCTL_SRQSCS_Pos)
#define USB_OTG_GOTGCTL_SRQSCS   USB_OTG_GOTGCTL_SRQSCS_Msk
#define USB_OTG_GOTGCTL_SRQ_Pos   (1U)
#define USB_OTG_GOTGCTL_SRQ_Msk   (0x1U << USB_OTG_GOTGCTL_SRQ_Pos)
#define USB_OTG_GOTGCTL_SRQ   USB_OTG_GOTGCTL_SRQ_Msk
#define USB_OTG_GOTGCTL_VBVALOEN_Pos   (2U)
#define USB_OTG_GOTGCTL_VBVALOEN_Msk   (0x1U << USB_OTG_GOTGCTL_VBVALOEN_Pos)
#define USB_OTG_GOTGCTL_VBVALOEN   USB_OTG_GOTGCTL_VBVALOEN_Msk
#define USB_OTG_GOTGCTL_VBVALOVAL_Pos   (3U)
#define USB_OTG_GOTGCTL_VBVALOVAL_Msk   (0x1U << USB_OTG_GOTGCTL_VBVALOVAL_Pos)
#define USB_OTG_GOTGCTL_VBVALOVAL   USB_OTG_GOTGCTL_VBVALOVAL_Msk
#define USB_OTG_GOTGCTL_AVALOEN_Pos   (4U)
#define USB_OTG_GOTGCTL_AVALOEN_Msk   (0x1U << USB_OTG_GOTGCTL_AVALOEN_Pos)
#define USB_OTG_GOTGCTL_AVALOEN   USB_OTG_GOTGCTL_AVALOEN_Msk
#define USB_OTG_GOTGCTL_AVALOVAL_Pos   (5U)
#define USB_OTG_GOTGCTL_AVALOVAL_Msk   (0x1U << USB_OTG_GOTGCTL_AVALOVAL_Pos)
#define USB_OTG_GOTGCTL_AVALOVAL   USB_OTG_GOTGCTL_AVALOVAL_Msk
#define USB_OTG_GOTGCTL_BVALOEN_Pos   (6U)
#define USB_OTG_GOTGCTL_BVALOEN_Msk   (0x1U << USB_OTG_GOTGCTL_BVALOEN_Pos)
#define USB_OTG_GOTGCTL_BVALOEN   USB_OTG_GOTGCTL_BVALOEN_Msk
#define USB_OTG_GOTGCTL_BVALOVAL_Pos   (7U)
#define USB_OTG_GOTGCTL_BVALOVAL_Msk   (0x1U << USB_OTG_GOTGCTL_BVALOVAL_Pos)
#define USB_OTG_GOTGCTL_BVALOVAL   USB_OTG_GOTGCTL_BVALOVAL_Msk
#define USB_OTG_GOTGCTL_BSESVLD_Pos   (19U)
#define USB_OTG_GOTGCTL_BSESVLD_Msk   (0x1U << USB_OTG_GOTGCTL_BSESVLD_Pos)
#define USB_OTG_GOTGCTL_BSESVLD   USB_OTG_GOTGCTL_BSESVLD_Msk
#define USB_OTG_HCFG_FSLSPCS_Pos   (0U)
#define USB_OTG_HCFG_FSLSPCS_Msk   (0x3U << USB_OTG_HCFG_FSLSPCS_Pos)
#define USB_OTG_HCFG_FSLSPCS   USB_OTG_HCFG_FSLSPCS_Msk
#define USB_OTG_HCFG_FSLSPCS_0   (0x1U << USB_OTG_HCFG_FSLSPCS_Pos)
#define USB_OTG_HCFG_FSLSPCS_1   (0x2U << USB_OTG_HCFG_FSLSPCS_Pos)
#define USB_OTG_HCFG_FSLSS_Pos   (2U)
#define USB_OTG_HCFG_FSLSS_Msk   (0x1U << USB_OTG_HCFG_FSLSS_Pos)
#define USB_OTG_HCFG_FSLSS   USB_OTG_HCFG_FSLSS_Msk
#define USB_OTG_DCFG_DSPD_Pos   (0U)
#define USB_OTG_DCFG_DSPD_Msk   (0x3U << USB_OTG_DCFG_DSPD_Pos)
#define USB_OTG_DCFG_DSPD   USB_OTG_DCFG_DSPD_Msk
#define USB_OTG_DCFG_DSPD_0   (0x1U << USB_OTG_DCFG_DSPD_Pos)
#define USB_OTG_DCFG_DSPD_1   (0x2U << USB_OTG_DCFG_DSPD_Pos)
#define USB_OTG_DCFG_NZLSOHSK_Pos   (2U)
#define USB_OTG_DCFG_NZLSOHSK_Msk   (0x1U << USB_OTG_DCFG_NZLSOHSK_Pos)
#define USB_OTG_DCFG_NZLSOHSK   USB_OTG_DCFG_NZLSOHSK_Msk
#define USB_OTG_DCFG_DAD_Pos   (4U)
#define USB_OTG_DCFG_DAD_Msk   (0x7FU << USB_OTG_DCFG_DAD_Pos)
#define USB_OTG_DCFG_DAD   USB_OTG_DCFG_DAD_Msk
#define USB_OTG_DCFG_DAD_0   (0x01U << USB_OTG_DCFG_DAD_Pos)
#define USB_OTG_DCFG_DAD_1   (0x02U << USB_OTG_DCFG_DAD_Pos)
#define USB_OTG_DCFG_DAD_2   (0x04U << USB_OTG_DCFG_DAD_Pos)
#define USB_OTG_DCFG_DAD_3   (0x08U << USB_OTG_DCFG_DAD_Pos)
#define USB_OTG_DCFG_DAD_4   (0x10U << USB_OTG_DCFG_DAD_Pos)
#define USB_OTG_DCFG_DAD_5   (0x20U << USB_OTG_DCFG_DAD_Pos)
#define USB_OTG_DCFG_DAD_6   (0x40U << USB_OTG_DCFG_DAD_Pos)
#define USB_OTG_DCFG_PFIVL_Pos   (11U)
#define USB_OTG_DCFG_PFIVL_Msk   (0x3U << USB_OTG_DCFG_PFIVL_Pos)
#define USB_OTG_DCFG_PFIVL   USB_OTG_DCFG_PFIVL_Msk
#define USB_OTG_DCFG_PFIVL_0   (0x1U << USB_OTG_DCFG_PFIVL_Pos)
#define USB_OTG_DCFG_PFIVL_1   (0x2U << USB_OTG_DCFG_PFIVL_Pos)
#define USB_OTG_DCFG_PERSCHIVL_Pos   (24U)
#define USB_OTG_DCFG_PERSCHIVL_Msk   (0x3U << USB_OTG_DCFG_PERSCHIVL_Pos)
#define USB_OTG_DCFG_PERSCHIVL   USB_OTG_DCFG_PERSCHIVL_Msk
#define USB_OTG_DCFG_PERSCHIVL_0   (0x1U << USB_OTG_DCFG_PERSCHIVL_Pos)
#define USB_OTG_DCFG_PERSCHIVL_1   (0x2U << USB_OTG_DCFG_PERSCHIVL_Pos)
#define USB_OTG_PCGCR_STPPCLK_Pos   (0U)
#define USB_OTG_PCGCR_STPPCLK_Msk   (0x1U << USB_OTG_PCGCR_STPPCLK_Pos)
#define USB_OTG_PCGCR_STPPCLK   USB_OTG_PCGCR_STPPCLK_Msk
#define USB_OTG_PCGCR_GATEHCLK_Pos   (1U)
#define USB_OTG_PCGCR_GATEHCLK_Msk   (0x1U << USB_OTG_PCGCR_GATEHCLK_Pos)
#define USB_OTG_PCGCR_GATEHCLK   USB_OTG_PCGCR_GATEHCLK_Msk
#define USB_OTG_PCGCR_PHYSUSP_Pos   (4U)
#define USB_OTG_PCGCR_PHYSUSP_Msk   (0x1U << USB_OTG_PCGCR_PHYSUSP_Pos)
#define USB_OTG_PCGCR_PHYSUSP   USB_OTG_PCGCR_PHYSUSP_Msk
#define USB_OTG_GOTGINT_SEDET_Pos   (2U)
#define USB_OTG_GOTGINT_SEDET_Msk   (0x1U << USB_OTG_GOTGINT_SEDET_Pos)
#define USB_OTG_GOTGINT_SEDET   USB_OTG_GOTGINT_SEDET_Msk
#define USB_OTG_GOTGINT_SRSSCHG_Pos   (8U)
#define USB_OTG_GOTGINT_SRSSCHG_Msk   (0x1U << USB_OTG_GOTGINT_SRSSCHG_Pos)
#define USB_OTG_GOTGINT_SRSSCHG   USB_OTG_GOTGINT_SRSSCHG_Msk
#define USB_OTG_GOTGINT_HNSSCHG_Pos   (9U)
#define USB_OTG_GOTGINT_HNSSCHG_Msk   (0x1U << USB_OTG_GOTGINT_HNSSCHG_Pos)
#define USB_OTG_GOTGINT_HNSSCHG   USB_OTG_GOTGINT_HNSSCHG_Msk
#define USB_OTG_GOTGINT_HNGDET_Pos   (17U)
#define USB_OTG_GOTGINT_HNGDET_Msk   (0x1U << USB_OTG_GOTGINT_HNGDET_Pos)
#define USB_OTG_GOTGINT_HNGDET   USB_OTG_GOTGINT_HNGDET_Msk
#define USB_OTG_GOTGINT_ADTOCHG_Pos   (18U)
#define USB_OTG_GOTGINT_ADTOCHG_Msk   (0x1U << USB_OTG_GOTGINT_ADTOCHG_Pos)
#define USB_OTG_GOTGINT_ADTOCHG   USB_OTG_GOTGINT_ADTOCHG_Msk
#define USB_OTG_GOTGINT_DBCDNE_Pos   (19U)
#define USB_OTG_GOTGINT_DBCDNE_Msk   (0x1U << USB_OTG_GOTGINT_DBCDNE_Pos)
#define USB_OTG_GOTGINT_DBCDNE   USB_OTG_GOTGINT_DBCDNE_Msk
#define USB_OTG_DCTL_RWUSIG_Pos   (0U)
#define USB_OTG_DCTL_RWUSIG_Msk   (0x1U << USB_OTG_DCTL_RWUSIG_Pos)
#define USB_OTG_DCTL_RWUSIG   USB_OTG_DCTL_RWUSIG_Msk
#define USB_OTG_DCTL_SDIS_Pos   (1U)
#define USB_OTG_DCTL_SDIS_Msk   (0x1U << USB_OTG_DCTL_SDIS_Pos)
#define USB_OTG_DCTL_SDIS   USB_OTG_DCTL_SDIS_Msk
#define USB_OTG_DCTL_GINSTS_Pos   (2U)
#define USB_OTG_DCTL_GINSTS_Msk   (0x1U << USB_OTG_DCTL_GINSTS_Pos)
#define USB_OTG_DCTL_GINSTS   USB_OTG_DCTL_GINSTS_Msk
#define USB_OTG_DCTL_GONSTS_Pos   (3U)
#define USB_OTG_DCTL_GONSTS_Msk   (0x1U << USB_OTG_DCTL_GONSTS_Pos)
#define USB_OTG_DCTL_GONSTS   USB_OTG_DCTL_GONSTS_Msk
#define USB_OTG_DCTL_TCTL_Pos   (4U)
#define USB_OTG_DCTL_TCTL_Msk   (0x7U << USB_OTG_DCTL_TCTL_Pos)
#define USB_OTG_DCTL_TCTL   USB_OTG_DCTL_TCTL_Msk
#define USB_OTG_DCTL_TCTL_0   (0x1U << USB_OTG_DCTL_TCTL_Pos)
#define USB_OTG_DCTL_TCTL_1   (0x2U << USB_OTG_DCTL_TCTL_Pos)
#define USB_OTG_DCTL_TCTL_2   (0x4U << USB_OTG_DCTL_TCTL_Pos)
#define USB_OTG_DCTL_SGINAK_Pos   (7U)
#define USB_OTG_DCTL_SGINAK_Msk   (0x1U << USB_OTG_DCTL_SGINAK_Pos)
#define USB_OTG_DCTL_SGINAK   USB_OTG_DCTL_SGINAK_Msk
#define USB_OTG_DCTL_CGINAK_Pos   (8U)
#define USB_OTG_DCTL_CGINAK_Msk   (0x1U << USB_OTG_DCTL_CGINAK_Pos)
#define USB_OTG_DCTL_CGINAK   USB_OTG_DCTL_CGINAK_Msk
#define USB_OTG_DCTL_SGONAK_Pos   (9U)
#define USB_OTG_DCTL_SGONAK_Msk   (0x1U << USB_OTG_DCTL_SGONAK_Pos)
#define USB_OTG_DCTL_SGONAK   USB_OTG_DCTL_SGONAK_Msk
#define USB_OTG_DCTL_CGONAK_Pos   (10U)
#define USB_OTG_DCTL_CGONAK_Msk   (0x1U << USB_OTG_DCTL_CGONAK_Pos)
#define USB_OTG_DCTL_CGONAK   USB_OTG_DCTL_CGONAK_Msk
#define USB_OTG_DCTL_POPRGDNE_Pos   (11U)
#define USB_OTG_DCTL_POPRGDNE_Msk   (0x1U << USB_OTG_DCTL_POPRGDNE_Pos)
#define USB_OTG_DCTL_POPRGDNE   USB_OTG_DCTL_POPRGDNE_Msk
#define USB_OTG_HFIR_FRIVL_Pos   (0U)
#define USB_OTG_HFIR_FRIVL_Msk   (0xFFFFU << USB_OTG_HFIR_FRIVL_Pos)
#define USB_OTG_HFIR_FRIVL   USB_OTG_HFIR_FRIVL_Msk
#define USB_OTG_HFNUM_FRNUM_Pos   (0U)
#define USB_OTG_HFNUM_FRNUM_Msk   (0xFFFFU << USB_OTG_HFNUM_FRNUM_Pos)
#define USB_OTG_HFNUM_FRNUM   USB_OTG_HFNUM_FRNUM_Msk
#define USB_OTG_HFNUM_FTREM_Pos   (16U)
#define USB_OTG_HFNUM_FTREM_Msk   (0xFFFFU << USB_OTG_HFNUM_FTREM_Pos)
#define USB_OTG_HFNUM_FTREM   USB_OTG_HFNUM_FTREM_Msk
#define USB_OTG_DSTS_SUSPSTS_Pos   (0U)
#define USB_OTG_DSTS_SUSPSTS_Msk   (0x1U << USB_OTG_DSTS_SUSPSTS_Pos)
#define USB_OTG_DSTS_SUSPSTS   USB_OTG_DSTS_SUSPSTS_Msk
#define USB_OTG_DSTS_ENUMSPD_Pos   (1U)
#define USB_OTG_DSTS_ENUMSPD_Msk   (0x3U << USB_OTG_DSTS_ENUMSPD_Pos)
#define USB_OTG_DSTS_ENUMSPD   USB_OTG_DSTS_ENUMSPD_Msk
#define USB_OTG_DSTS_ENUMSPD_0   (0x1U << USB_OTG_DSTS_ENUMSPD_Pos)
#define USB_OTG_DSTS_ENUMSPD_1   (0x2U << USB_OTG_DSTS_ENUMSPD_Pos)
#define USB_OTG_DSTS_EERR_Pos   (3U)
#define USB_OTG_DSTS_EERR_Msk   (0x1U << USB_OTG_DSTS_EERR_Pos)
#define USB_OTG_DSTS_EERR   USB_OTG_DSTS_EERR_Msk
#define USB_OTG_DSTS_FNSOF_Pos   (8U)
#define USB_OTG_DSTS_FNSOF_Msk   (0x3FFFU << USB_OTG_DSTS_FNSOF_Pos)
#define USB_OTG_DSTS_FNSOF   USB_OTG_DSTS_FNSOF_Msk
#define USB_OTG_GAHBCFG_GINT_Pos   (0U)
#define USB_OTG_GAHBCFG_GINT_Msk   (0x1U << USB_OTG_GAHBCFG_GINT_Pos)
#define USB_OTG_GAHBCFG_GINT   USB_OTG_GAHBCFG_GINT_Msk
#define USB_OTG_GAHBCFG_HBSTLEN_Pos   (1U)
#define USB_OTG_GAHBCFG_HBSTLEN_Msk   (0xFU << USB_OTG_GAHBCFG_HBSTLEN_Pos)
#define USB_OTG_GAHBCFG_HBSTLEN   USB_OTG_GAHBCFG_HBSTLEN_Msk
#define USB_OTG_GAHBCFG_HBSTLEN_0   (0x1U << USB_OTG_GAHBCFG_HBSTLEN_Pos)
#define USB_OTG_GAHBCFG_HBSTLEN_1   (0x2U << USB_OTG_GAHBCFG_HBSTLEN_Pos)
#define USB_OTG_GAHBCFG_HBSTLEN_2   (0x4U << USB_OTG_GAHBCFG_HBSTLEN_Pos)
#define USB_OTG_GAHBCFG_HBSTLEN_3   (0x8U << USB_OTG_GAHBCFG_HBSTLEN_Pos)
#define USB_OTG_GAHBCFG_DMAEN_Pos   (5U)
#define USB_OTG_GAHBCFG_DMAEN_Msk   (0x1U << USB_OTG_GAHBCFG_DMAEN_Pos)
#define USB_OTG_GAHBCFG_DMAEN   USB_OTG_GAHBCFG_DMAEN_Msk
#define USB_OTG_GAHBCFG_TXFELVL_Pos   (7U)
#define USB_OTG_GAHBCFG_TXFELVL_Msk   (0x1U << USB_OTG_GAHBCFG_TXFELVL_Pos)
#define USB_OTG_GAHBCFG_TXFELVL   USB_OTG_GAHBCFG_TXFELVL_Msk
#define USB_OTG_GAHBCFG_PTXFELVL_Pos   (8U)
#define USB_OTG_GAHBCFG_PTXFELVL_Msk   (0x1U << USB_OTG_GAHBCFG_PTXFELVL_Pos)
#define USB_OTG_GAHBCFG_PTXFELVL   USB_OTG_GAHBCFG_PTXFELVL_Msk
#define USB_OTG_GUSBCFG_TOCAL_Pos   (0U)
#define USB_OTG_GUSBCFG_TOCAL_Msk   (0x7U << USB_OTG_GUSBCFG_TOCAL_Pos)
#define USB_OTG_GUSBCFG_TOCAL   USB_OTG_GUSBCFG_TOCAL_Msk
#define USB_OTG_GUSBCFG_TOCAL_0   (0x1U << USB_OTG_GUSBCFG_TOCAL_Pos)
#define USB_OTG_GUSBCFG_TOCAL_1   (0x2U << USB_OTG_GUSBCFG_TOCAL_Pos)
#define USB_OTG_GUSBCFG_TOCAL_2   (0x4U << USB_OTG_GUSBCFG_TOCAL_Pos)
#define USB_OTG_GUSBCFG_PHYSEL_Pos   (6U)
#define USB_OTG_GUSBCFG_PHYSEL_Msk   (0x1U << USB_OTG_GUSBCFG_PHYSEL_Pos)
#define USB_OTG_GUSBCFG_PHYSEL   USB_OTG_GUSBCFG_PHYSEL_Msk
#define USB_OTG_GUSBCFG_SRPCAP_Pos   (8U)
#define USB_OTG_GUSBCFG_SRPCAP_Msk   (0x1U << USB_OTG_GUSBCFG_SRPCAP_Pos)
#define USB_OTG_GUSBCFG_SRPCAP   USB_OTG_GUSBCFG_SRPCAP_Msk
#define USB_OTG_GUSBCFG_HNPCAP_Pos   (9U)
#define USB_OTG_GUSBCFG_HNPCAP_Msk   (0x1U << USB_OTG_GUSBCFG_HNPCAP_Pos)
#define USB_OTG_GUSBCFG_HNPCAP   USB_OTG_GUSBCFG_HNPCAP_Msk
#define USB_OTG_GUSBCFG_TRDT_Pos   (10U)
#define USB_OTG_GUSBCFG_TRDT_Msk   (0xFU << USB_OTG_GUSBCFG_TRDT_Pos)
#define USB_OTG_GUSBCFG_TRDT   USB_OTG_GUSBCFG_TRDT_Msk
#define USB_OTG_GUSBCFG_TRDT_0   (0x1U << USB_OTG_GUSBCFG_TRDT_Pos)
#define USB_OTG_GUSBCFG_TRDT_1   (0x2U << USB_OTG_GUSBCFG_TRDT_Pos)
#define USB_OTG_GUSBCFG_TRDT_2   (0x4U << USB_OTG_GUSBCFG_TRDT_Pos)
#define USB_OTG_GUSBCFG_TRDT_3   (0x8U << USB_OTG_GUSBCFG_TRDT_Pos)
#define USB_OTG_GUSBCFG_PHYLPCS_Pos   (15U)
#define USB_OTG_GUSBCFG_PHYLPCS_Msk   (0x1U << USB_OTG_GUSBCFG_PHYLPCS_Pos)
#define USB_OTG_GUSBCFG_PHYLPCS   USB_OTG_GUSBCFG_PHYLPCS_Msk
#define USB_OTG_GUSBCFG_ULPIFSLS_Pos   (17U)
#define USB_OTG_GUSBCFG_ULPIFSLS_Msk   (0x1U << USB_OTG_GUSBCFG_ULPIFSLS_Pos)
#define USB_OTG_GUSBCFG_ULPIFSLS   USB_OTG_GUSBCFG_ULPIFSLS_Msk
#define USB_OTG_GUSBCFG_ULPIAR_Pos   (18U)
#define USB_OTG_GUSBCFG_ULPIAR_Msk   (0x1U << USB_OTG_GUSBCFG_ULPIAR_Pos)
#define USB_OTG_GUSBCFG_ULPIAR   USB_OTG_GUSBCFG_ULPIAR_Msk
#define USB_OTG_GUSBCFG_ULPICSM_Pos   (19U)
#define USB_OTG_GUSBCFG_ULPICSM_Msk   (0x1U << USB_OTG_GUSBCFG_ULPICSM_Pos)
#define USB_OTG_GUSBCFG_ULPICSM   USB_OTG_GUSBCFG_ULPICSM_Msk
#define USB_OTG_GUSBCFG_ULPIEVBUSD_Pos   (20U)
#define USB_OTG_GUSBCFG_ULPIEVBUSD_Msk   (0x1U << USB_OTG_GUSBCFG_ULPIEVBUSD_Pos)
#define USB_OTG_GUSBCFG_ULPIEVBUSD   USB_OTG_GUSBCFG_ULPIEVBUSD_Msk
#define USB_OTG_GUSBCFG_ULPIEVBUSI_Pos   (21U)
#define USB_OTG_GUSBCFG_ULPIEVBUSI_Msk   (0x1U << USB_OTG_GUSBCFG_ULPIEVBUSI_Pos)
#define USB_OTG_GUSBCFG_ULPIEVBUSI   USB_OTG_GUSBCFG_ULPIEVBUSI_Msk
#define USB_OTG_GUSBCFG_TSDPS_Pos   (22U)
#define USB_OTG_GUSBCFG_TSDPS_Msk   (0x1U << USB_OTG_GUSBCFG_TSDPS_Pos)
#define USB_OTG_GUSBCFG_TSDPS   USB_OTG_GUSBCFG_TSDPS_Msk
#define USB_OTG_GUSBCFG_PCCI_Pos   (23U)
#define USB_OTG_GUSBCFG_PCCI_Msk   (0x1U << USB_OTG_GUSBCFG_PCCI_Pos)
#define USB_OTG_GUSBCFG_PCCI   USB_OTG_GUSBCFG_PCCI_Msk
#define USB_OTG_GUSBCFG_PTCI_Pos   (24U)
#define USB_OTG_GUSBCFG_PTCI_Msk   (0x1U << USB_OTG_GUSBCFG_PTCI_Pos)
#define USB_OTG_GUSBCFG_PTCI   USB_OTG_GUSBCFG_PTCI_Msk
#define USB_OTG_GUSBCFG_ULPIIPD_Pos   (25U)
#define USB_OTG_GUSBCFG_ULPIIPD_Msk   (0x1U << USB_OTG_GUSBCFG_ULPIIPD_Pos)
#define USB_OTG_GUSBCFG_ULPIIPD   USB_OTG_GUSBCFG_ULPIIPD_Msk
#define USB_OTG_GUSBCFG_FHMOD_Pos   (29U)
#define USB_OTG_GUSBCFG_FHMOD_Msk   (0x1U << USB_OTG_GUSBCFG_FHMOD_Pos)
#define USB_OTG_GUSBCFG_FHMOD   USB_OTG_GUSBCFG_FHMOD_Msk
#define USB_OTG_GUSBCFG_FDMOD_Pos   (30U)
#define USB_OTG_GUSBCFG_FDMOD_Msk   (0x1U << USB_OTG_GUSBCFG_FDMOD_Pos)
#define USB_OTG_GUSBCFG_FDMOD   USB_OTG_GUSBCFG_FDMOD_Msk
#define USB_OTG_GUSBCFG_CTXPKT_Pos   (31U)
#define USB_OTG_GUSBCFG_CTXPKT_Msk   (0x1U << USB_OTG_GUSBCFG_CTXPKT_Pos)
#define USB_OTG_GUSBCFG_CTXPKT   USB_OTG_GUSBCFG_CTXPKT_Msk
#define USB_OTG_GRSTCTL_CSRST_Pos   (0U)
#define USB_OTG_GRSTCTL_CSRST_Msk   (0x1U << USB_OTG_GRSTCTL_CSRST_Pos)
#define USB_OTG_GRSTCTL_CSRST   USB_OTG_GRSTCTL_CSRST_Msk
#define USB_OTG_GRSTCTL_HSRST_Pos   (1U)
#define USB_OTG_GRSTCTL_HSRST_Msk   (0x1U << USB_OTG_GRSTCTL_HSRST_Pos)
#define USB_OTG_GRSTCTL_HSRST   USB_OTG_GRSTCTL_HSRST_Msk
#define USB_OTG_GRSTCTL_FCRST_Pos   (2U)
#define USB_OTG_GRSTCTL_FCRST_Msk   (0x1U << USB_OTG_GRSTCTL_FCRST_Pos)
#define USB_OTG_GRSTCTL_FCRST   USB_OTG_GRSTCTL_FCRST_Msk
#define USB_OTG_GRSTCTL_RXFFLSH_Pos   (4U)
#define USB_OTG_GRSTCTL_RXFFLSH_Msk   (0x1U << USB_OTG_GRSTCTL_RXFFLSH_Pos)
#define USB_OTG_GRSTCTL_RXFFLSH   USB_OTG_GRSTCTL_RXFFLSH_Msk
#define USB_OTG_GRSTCTL_TXFFLSH_Pos   (5U)
#define USB_OTG_GRSTCTL_TXFFLSH_Msk   (0x1U << USB_OTG_GRSTCTL_TXFFLSH_Pos)
#define USB_OTG_GRSTCTL_TXFFLSH   USB_OTG_GRSTCTL_TXFFLSH_Msk
#define USB_OTG_GRSTCTL_TXFNUM_Pos   (6U)
#define USB_OTG_GRSTCTL_TXFNUM_Msk   (0x1FU << USB_OTG_GRSTCTL_TXFNUM_Pos)
#define USB_OTG_GRSTCTL_TXFNUM   USB_OTG_GRSTCTL_TXFNUM_Msk
#define USB_OTG_GRSTCTL_TXFNUM_0   (0x01U << USB_OTG_GRSTCTL_TXFNUM_Pos)
#define USB_OTG_GRSTCTL_TXFNUM_1   (0x02U << USB_OTG_GRSTCTL_TXFNUM_Pos)
#define USB_OTG_GRSTCTL_TXFNUM_2   (0x04U << USB_OTG_GRSTCTL_TXFNUM_Pos)
#define USB_OTG_GRSTCTL_TXFNUM_3   (0x08U << USB_OTG_GRSTCTL_TXFNUM_Pos)
#define USB_OTG_GRSTCTL_TXFNUM_4   (0x10U << USB_OTG_GRSTCTL_TXFNUM_Pos)
#define USB_OTG_GRSTCTL_DMAREQ_Pos   (30U)
#define USB_OTG_GRSTCTL_DMAREQ_Msk   (0x1U << USB_OTG_GRSTCTL_DMAREQ_Pos)
#define USB_OTG_GRSTCTL_DMAREQ   USB_OTG_GRSTCTL_DMAREQ_Msk
#define USB_OTG_GRSTCTL_AHBIDL_Pos   (31U)
#define USB_OTG_GRSTCTL_AHBIDL_Msk   (0x1U << USB_OTG_GRSTCTL_AHBIDL_Pos)
#define USB_OTG_GRSTCTL_AHBIDL   USB_OTG_GRSTCTL_AHBIDL_Msk
#define USB_OTG_DIEPMSK_XFRCM_Pos   (0U)
#define USB_OTG_DIEPMSK_XFRCM_Msk   (0x1U << USB_OTG_DIEPMSK_XFRCM_Pos)
#define USB_OTG_DIEPMSK_XFRCM   USB_OTG_DIEPMSK_XFRCM_Msk
#define USB_OTG_DIEPMSK_EPDM_Pos   (1U)
#define USB_OTG_DIEPMSK_EPDM_Msk   (0x1U << USB_OTG_DIEPMSK_EPDM_Pos)
#define USB_OTG_DIEPMSK_EPDM   USB_OTG_DIEPMSK_EPDM_Msk
#define USB_OTG_DIEPMSK_TOM_Pos   (3U)
#define USB_OTG_DIEPMSK_TOM_Msk   (0x1U << USB_OTG_DIEPMSK_TOM_Pos)
#define USB_OTG_DIEPMSK_TOM   USB_OTG_DIEPMSK_TOM_Msk
#define USB_OTG_DIEPMSK_ITTXFEMSK_Pos   (4U)
#define USB_OTG_DIEPMSK_ITTXFEMSK_Msk   (0x1U << USB_OTG_DIEPMSK_ITTXFEMSK_Pos)
#define USB_OTG_DIEPMSK_ITTXFEMSK   USB_OTG_DIEPMSK_ITTXFEMSK_Msk
#define USB_OTG_DIEPMSK_INEPNMM_Pos   (5U)
#define USB_OTG_DIEPMSK_INEPNMM_Msk   (0x1U << USB_OTG_DIEPMSK_INEPNMM_Pos)
#define USB_OTG_DIEPMSK_INEPNMM   USB_OTG_DIEPMSK_INEPNMM_Msk
#define USB_OTG_DIEPMSK_INEPNEM_Pos   (6U)
#define USB_OTG_DIEPMSK_INEPNEM_Msk   (0x1U << USB_OTG_DIEPMSK_INEPNEM_Pos)
#define USB_OTG_DIEPMSK_INEPNEM   USB_OTG_DIEPMSK_INEPNEM_Msk
#define USB_OTG_DIEPMSK_TXFURM_Pos   (8U)
#define USB_OTG_DIEPMSK_TXFURM_Msk   (0x1U << USB_OTG_DIEPMSK_TXFURM_Pos)
#define USB_OTG_DIEPMSK_TXFURM   USB_OTG_DIEPMSK_TXFURM_Msk
#define USB_OTG_DIEPMSK_BIM_Pos   (9U)
#define USB_OTG_DIEPMSK_BIM_Msk   (0x1U << USB_OTG_DIEPMSK_BIM_Pos)
#define USB_OTG_DIEPMSK_BIM   USB_OTG_DIEPMSK_BIM_Msk
#define USB_OTG_HPTXSTS_PTXFSAVL_Pos   (0U)
#define USB_OTG_HPTXSTS_PTXFSAVL_Msk   (0xFFFFU << USB_OTG_HPTXSTS_PTXFSAVL_Pos)
#define USB_OTG_HPTXSTS_PTXFSAVL   USB_OTG_HPTXSTS_PTXFSAVL_Msk
#define USB_OTG_HPTXSTS_PTXQSAV_Pos   (16U)
#define USB_OTG_HPTXSTS_PTXQSAV_Msk   (0xFFU << USB_OTG_HPTXSTS_PTXQSAV_Pos)
#define USB_OTG_HPTXSTS_PTXQSAV   USB_OTG_HPTXSTS_PTXQSAV_Msk
#define USB_OTG_HPTXSTS_PTXQSAV_0   (0x01U << USB_OTG_HPTXSTS_PTXQSAV_Pos)
#define USB_OTG_HPTXSTS_PTXQSAV_1   (0x02U << USB_OTG_HPTXSTS_PTXQSAV_Pos)
#define USB_OTG_HPTXSTS_PTXQSAV_2   (0x04U << USB_OTG_HPTXSTS_PTXQSAV_Pos)
#define USB_OTG_HPTXSTS_PTXQSAV_3   (0x08U << USB_OTG_HPTXSTS_PTXQSAV_Pos)
#define USB_OTG_HPTXSTS_PTXQSAV_4   (0x10U << USB_OTG_HPTXSTS_PTXQSAV_Pos)
#define USB_OTG_HPTXSTS_PTXQSAV_5   (0x20U << USB_OTG_HPTXSTS_PTXQSAV_Pos)
#define USB_OTG_HPTXSTS_PTXQSAV_6   (0x40U << USB_OTG_HPTXSTS_PTXQSAV_Pos)
#define USB_OTG_HPTXSTS_PTXQSAV_7   (0x80U << USB_OTG_HPTXSTS_PTXQSAV_Pos)
#define USB_OTG_HPTXSTS_PTXQTOP_Pos   (24U)
#define USB_OTG_HPTXSTS_PTXQTOP_Msk   (0xFFU << USB_OTG_HPTXSTS_PTXQTOP_Pos)
#define USB_OTG_HPTXSTS_PTXQTOP   USB_OTG_HPTXSTS_PTXQTOP_Msk
#define USB_OTG_HPTXSTS_PTXQTOP_0   (0x01U << USB_OTG_HPTXSTS_PTXQTOP_Pos)
#define USB_OTG_HPTXSTS_PTXQTOP_1   (0x02U << USB_OTG_HPTXSTS_PTXQTOP_Pos)
#define USB_OTG_HPTXSTS_PTXQTOP_2   (0x04U << USB_OTG_HPTXSTS_PTXQTOP_Pos)
#define USB_OTG_HPTXSTS_PTXQTOP_3   (0x08U << USB_OTG_HPTXSTS_PTXQTOP_Pos)
#define USB_OTG_HPTXSTS_PTXQTOP_4   (0x10U << USB_OTG_HPTXSTS_PTXQTOP_Pos)
#define USB_OTG_HPTXSTS_PTXQTOP_5   (0x20U << USB_OTG_HPTXSTS_PTXQTOP_Pos)
#define USB_OTG_HPTXSTS_PTXQTOP_6   (0x40U << USB_OTG_HPTXSTS_PTXQTOP_Pos)
#define USB_OTG_HPTXSTS_PTXQTOP_7   (0x80U << USB_OTG_HPTXSTS_PTXQTOP_Pos)
#define USB_OTG_HAINT_HAINT_Pos   (0U)
#define USB_OTG_HAINT_HAINT_Msk   (0xFFFFU << USB_OTG_HAINT_HAINT_Pos)
#define USB_OTG_HAINT_HAINT   USB_OTG_HAINT_HAINT_Msk
#define USB_OTG_DOEPMSK_XFRCM_Pos   (0U)
#define USB_OTG_DOEPMSK_XFRCM_Msk   (0x1U << USB_OTG_DOEPMSK_XFRCM_Pos)
#define USB_OTG_DOEPMSK_XFRCM   USB_OTG_DOEPMSK_XFRCM_Msk
#define USB_OTG_DOEPMSK_EPDM_Pos   (1U)
#define USB_OTG_DOEPMSK_EPDM_Msk   (0x1U << USB_OTG_DOEPMSK_EPDM_Pos)
#define USB_OTG_DOEPMSK_EPDM   USB_OTG_DOEPMSK_EPDM_Msk
#define USB_OTG_DOEPMSK_STUPM_Pos   (3U)
#define USB_OTG_DOEPMSK_STUPM_Msk   (0x1U << USB_OTG_DOEPMSK_STUPM_Pos)
#define USB_OTG_DOEPMSK_STUPM   USB_OTG_DOEPMSK_STUPM_Msk
#define USB_OTG_DOEPMSK_OTEPDM_Pos   (4U)
#define USB_OTG_DOEPMSK_OTEPDM_Msk   (0x1U << USB_OTG_DOEPMSK_OTEPDM_Pos)
#define USB_OTG_DOEPMSK_OTEPDM   USB_OTG_DOEPMSK_OTEPDM_Msk
#define USB_OTG_DOEPMSK_B2BSTUP_Pos   (6U)
#define USB_OTG_DOEPMSK_B2BSTUP_Msk   (0x1U << USB_OTG_DOEPMSK_B2BSTUP_Pos)
#define USB_OTG_DOEPMSK_B2BSTUP   USB_OTG_DOEPMSK_B2BSTUP_Msk
#define USB_OTG_DOEPMSK_OPEM_Pos   (8U)
#define USB_OTG_DOEPMSK_OPEM_Msk   (0x1U << USB_OTG_DOEPMSK_OPEM_Pos)
#define USB_OTG_DOEPMSK_OPEM   USB_OTG_DOEPMSK_OPEM_Msk
#define USB_OTG_DOEPMSK_BOIM_Pos   (9U)
#define USB_OTG_DOEPMSK_BOIM_Msk   (0x1U << USB_OTG_DOEPMSK_BOIM_Pos)
#define USB_OTG_DOEPMSK_BOIM   USB_OTG_DOEPMSK_BOIM_Msk
#define USB_OTG_GINTSTS_CMOD_Pos   (0U)
#define USB_OTG_GINTSTS_CMOD_Msk   (0x1U << USB_OTG_GINTSTS_CMOD_Pos)
#define USB_OTG_GINTSTS_CMOD   USB_OTG_GINTSTS_CMOD_Msk
#define USB_OTG_GINTSTS_MMIS_Pos   (1U)
#define USB_OTG_GINTSTS_MMIS_Msk   (0x1U << USB_OTG_GINTSTS_MMIS_Pos)
#define USB_OTG_GINTSTS_MMIS   USB_OTG_GINTSTS_MMIS_Msk
#define USB_OTG_GINTSTS_OTGINT_Pos   (2U)
#define USB_OTG_GINTSTS_OTGINT_Msk   (0x1U << USB_OTG_GINTSTS_OTGINT_Pos)
#define USB_OTG_GINTSTS_OTGINT   USB_OTG_GINTSTS_OTGINT_Msk
#define USB_OTG_GINTSTS_SOF_Pos   (3U)
#define USB_OTG_GINTSTS_SOF_Msk   (0x1U << USB_OTG_GINTSTS_SOF_Pos)
#define USB_OTG_GINTSTS_SOF   USB_OTG_GINTSTS_SOF_Msk
#define USB_OTG_GINTSTS_RXFLVL_Pos   (4U)
#define USB_OTG_GINTSTS_RXFLVL_Msk   (0x1U << USB_OTG_GINTSTS_RXFLVL_Pos)
#define USB_OTG_GINTSTS_RXFLVL   USB_OTG_GINTSTS_RXFLVL_Msk
#define USB_OTG_GINTSTS_NPTXFE_Pos   (5U)
#define USB_OTG_GINTSTS_NPTXFE_Msk   (0x1U << USB_OTG_GINTSTS_NPTXFE_Pos)
#define USB_OTG_GINTSTS_NPTXFE   USB_OTG_GINTSTS_NPTXFE_Msk
#define USB_OTG_GINTSTS_GINAKEFF_Pos   (6U)
#define USB_OTG_GINTSTS_GINAKEFF_Msk   (0x1U << USB_OTG_GINTSTS_GINAKEFF_Pos)
#define USB_OTG_GINTSTS_GINAKEFF   USB_OTG_GINTSTS_GINAKEFF_Msk
#define USB_OTG_GINTSTS_BOUTNAKEFF_Pos   (7U)
#define USB_OTG_GINTSTS_BOUTNAKEFF_Msk   (0x1U << USB_OTG_GINTSTS_BOUTNAKEFF_Pos)
#define USB_OTG_GINTSTS_BOUTNAKEFF   USB_OTG_GINTSTS_BOUTNAKEFF_Msk
#define USB_OTG_GINTSTS_ESUSP_Pos   (10U)
#define USB_OTG_GINTSTS_ESUSP_Msk   (0x1U << USB_OTG_GINTSTS_ESUSP_Pos)
#define USB_OTG_GINTSTS_ESUSP   USB_OTG_GINTSTS_ESUSP_Msk
#define USB_OTG_GINTSTS_USBSUSP_Pos   (11U)
#define USB_OTG_GINTSTS_USBSUSP_Msk   (0x1U << USB_OTG_GINTSTS_USBSUSP_Pos)
#define USB_OTG_GINTSTS_USBSUSP   USB_OTG_GINTSTS_USBSUSP_Msk
#define USB_OTG_GINTSTS_USBRST_Pos   (12U)
#define USB_OTG_GINTSTS_USBRST_Msk   (0x1U << USB_OTG_GINTSTS_USBRST_Pos)
#define USB_OTG_GINTSTS_USBRST   USB_OTG_GINTSTS_USBRST_Msk
#define USB_OTG_GINTSTS_ENUMDNE_Pos   (13U)
#define USB_OTG_GINTSTS_ENUMDNE_Msk   (0x1U << USB_OTG_GINTSTS_ENUMDNE_Pos)
#define USB_OTG_GINTSTS_ENUMDNE   USB_OTG_GINTSTS_ENUMDNE_Msk
#define USB_OTG_GINTSTS_ISOODRP_Pos   (14U)
#define USB_OTG_GINTSTS_ISOODRP_Msk   (0x1U << USB_OTG_GINTSTS_ISOODRP_Pos)
#define USB_OTG_GINTSTS_ISOODRP   USB_OTG_GINTSTS_ISOODRP_Msk
#define USB_OTG_GINTSTS_EOPF_Pos   (15U)
#define USB_OTG_GINTSTS_EOPF_Msk   (0x1U << USB_OTG_GINTSTS_EOPF_Pos)
#define USB_OTG_GINTSTS_EOPF   USB_OTG_GINTSTS_EOPF_Msk
#define USB_OTG_GINTSTS_IEPINT_Pos   (18U)
#define USB_OTG_GINTSTS_IEPINT_Msk   (0x1U << USB_OTG_GINTSTS_IEPINT_Pos)
#define USB_OTG_GINTSTS_IEPINT   USB_OTG_GINTSTS_IEPINT_Msk
#define USB_OTG_GINTSTS_OEPINT_Pos   (19U)
#define USB_OTG_GINTSTS_OEPINT_Msk   (0x1U << USB_OTG_GINTSTS_OEPINT_Pos)
#define USB_OTG_GINTSTS_OEPINT   USB_OTG_GINTSTS_OEPINT_Msk
#define USB_OTG_GINTSTS_IISOIXFR_Pos   (20U)
#define USB_OTG_GINTSTS_IISOIXFR_Msk   (0x1U << USB_OTG_GINTSTS_IISOIXFR_Pos)
#define USB_OTG_GINTSTS_IISOIXFR   USB_OTG_GINTSTS_IISOIXFR_Msk
#define USB_OTG_GINTSTS_PXFR_INCOMPISOOUT_Pos   (21U)
#define USB_OTG_GINTSTS_PXFR_INCOMPISOOUT_Msk   (0x1U << USB_OTG_GINTSTS_PXFR_INCOMPISOOUT_Pos)
#define USB_OTG_GINTSTS_PXFR_INCOMPISOOUT   USB_OTG_GINTSTS_PXFR_INCOMPISOOUT_Msk
#define USB_OTG_GINTSTS_DATAFSUSP_Pos   (22U)
#define USB_OTG_GINTSTS_DATAFSUSP_Msk   (0x1U << USB_OTG_GINTSTS_DATAFSUSP_Pos)
#define USB_OTG_GINTSTS_DATAFSUSP   USB_OTG_GINTSTS_DATAFSUSP_Msk
#define USB_OTG_GINTSTS_HPRTINT_Pos   (24U)
#define USB_OTG_GINTSTS_HPRTINT_Msk   (0x1U << USB_OTG_GINTSTS_HPRTINT_Pos)
#define USB_OTG_GINTSTS_HPRTINT   USB_OTG_GINTSTS_HPRTINT_Msk
#define USB_OTG_GINTSTS_HCINT_Pos   (25U)
#define USB_OTG_GINTSTS_HCINT_Msk   (0x1U << USB_OTG_GINTSTS_HCINT_Pos)
#define USB_OTG_GINTSTS_HCINT   USB_OTG_GINTSTS_HCINT_Msk
#define USB_OTG_GINTSTS_PTXFE_Pos   (26U)
#define USB_OTG_GINTSTS_PTXFE_Msk   (0x1U << USB_OTG_GINTSTS_PTXFE_Pos)
#define USB_OTG_GINTSTS_PTXFE   USB_OTG_GINTSTS_PTXFE_Msk
#define USB_OTG_GINTSTS_LPMINT_Pos   (27U)
#define USB_OTG_GINTSTS_LPMINT_Msk   (0x1U << USB_OTG_GINTSTS_LPMINT_Pos)
#define USB_OTG_GINTSTS_LPMINT   USB_OTG_GINTSTS_LPMINT_Msk
#define USB_OTG_GINTSTS_CIDSCHG_Pos   (28U)
#define USB_OTG_GINTSTS_CIDSCHG_Msk   (0x1U << USB_OTG_GINTSTS_CIDSCHG_Pos)
#define USB_OTG_GINTSTS_CIDSCHG   USB_OTG_GINTSTS_CIDSCHG_Msk
#define USB_OTG_GINTSTS_DISCINT_Pos   (29U)
#define USB_OTG_GINTSTS_DISCINT_Msk   (0x1U << USB_OTG_GINTSTS_DISCINT_Pos)
#define USB_OTG_GINTSTS_DISCINT   USB_OTG_GINTSTS_DISCINT_Msk
#define USB_OTG_GINTSTS_SRQINT_Pos   (30U)
#define USB_OTG_GINTSTS_SRQINT_Msk   (0x1U << USB_OTG_GINTSTS_SRQINT_Pos)
#define USB_OTG_GINTSTS_SRQINT   USB_OTG_GINTSTS_SRQINT_Msk
#define USB_OTG_GINTSTS_WKUINT_Pos   (31U)
#define USB_OTG_GINTSTS_WKUINT_Msk   (0x1U << USB_OTG_GINTSTS_WKUINT_Pos)
#define USB_OTG_GINTSTS_WKUINT   USB_OTG_GINTSTS_WKUINT_Msk
#define USB_OTG_GINTMSK_MMISM_Pos   (1U)
#define USB_OTG_GINTMSK_MMISM_Msk   (0x1U << USB_OTG_GINTMSK_MMISM_Pos)
#define USB_OTG_GINTMSK_MMISM   USB_OTG_GINTMSK_MMISM_Msk
#define USB_OTG_GINTMSK_OTGINT_Pos   (2U)
#define USB_OTG_GINTMSK_OTGINT_Msk   (0x1U << USB_OTG_GINTMSK_OTGINT_Pos)
#define USB_OTG_GINTMSK_OTGINT   USB_OTG_GINTMSK_OTGINT_Msk
#define USB_OTG_GINTMSK_SOFM_Pos   (3U)
#define USB_OTG_GINTMSK_SOFM_Msk   (0x1U << USB_OTG_GINTMSK_SOFM_Pos)
#define USB_OTG_GINTMSK_SOFM   USB_OTG_GINTMSK_SOFM_Msk
#define USB_OTG_GINTMSK_RXFLVLM_Pos   (4U)
#define USB_OTG_GINTMSK_RXFLVLM_Msk   (0x1U << USB_OTG_GINTMSK_RXFLVLM_Pos)
#define USB_OTG_GINTMSK_RXFLVLM   USB_OTG_GINTMSK_RXFLVLM_Msk
#define USB_OTG_GINTMSK_NPTXFEM_Pos   (5U)
#define USB_OTG_GINTMSK_NPTXFEM_Msk   (0x1U << USB_OTG_GINTMSK_NPTXFEM_Pos)
#define USB_OTG_GINTMSK_NPTXFEM   USB_OTG_GINTMSK_NPTXFEM_Msk
#define USB_OTG_GINTMSK_GINAKEFFM_Pos   (6U)
#define USB_OTG_GINTMSK_GINAKEFFM_Msk   (0x1U << USB_OTG_GINTMSK_GINAKEFFM_Pos)
#define USB_OTG_GINTMSK_GINAKEFFM   USB_OTG_GINTMSK_GINAKEFFM_Msk
#define USB_OTG_GINTMSK_GONAKEFFM_Pos   (7U)
#define USB_OTG_GINTMSK_GONAKEFFM_Msk   (0x1U << USB_OTG_GINTMSK_GONAKEFFM_Pos)
#define USB_OTG_GINTMSK_GONAKEFFM   USB_OTG_GINTMSK_GONAKEFFM_Msk
#define USB_OTG_GINTMSK_ESUSPM_Pos   (10U)
#define USB_OTG_GINTMSK_ESUSPM_Msk   (0x1U << USB_OTG_GINTMSK_ESUSPM_Pos)
#define USB_OTG_GINTMSK_ESUSPM   USB_OTG_GINTMSK_ESUSPM_Msk
#define USB_OTG_GINTMSK_USBSUSPM_Pos   (11U)
#define USB_OTG_GINTMSK_USBSUSPM_Msk   (0x1U << USB_OTG_GINTMSK_USBSUSPM_Pos)
#define USB_OTG_GINTMSK_USBSUSPM   USB_OTG_GINTMSK_USBSUSPM_Msk
#define USB_OTG_GINTMSK_USBRST_Pos   (12U)
#define USB_OTG_GINTMSK_USBRST_Msk   (0x1U << USB_OTG_GINTMSK_USBRST_Pos)
#define USB_OTG_GINTMSK_USBRST   USB_OTG_GINTMSK_USBRST_Msk
#define USB_OTG_GINTMSK_ENUMDNEM_Pos   (13U)
#define USB_OTG_GINTMSK_ENUMDNEM_Msk   (0x1U << USB_OTG_GINTMSK_ENUMDNEM_Pos)
#define USB_OTG_GINTMSK_ENUMDNEM   USB_OTG_GINTMSK_ENUMDNEM_Msk
#define USB_OTG_GINTMSK_ISOODRPM_Pos   (14U)
#define USB_OTG_GINTMSK_ISOODRPM_Msk   (0x1U << USB_OTG_GINTMSK_ISOODRPM_Pos)
#define USB_OTG_GINTMSK_ISOODRPM   USB_OTG_GINTMSK_ISOODRPM_Msk
#define USB_OTG_GINTMSK_EOPFM_Pos   (15U)
#define USB_OTG_GINTMSK_EOPFM_Msk   (0x1U << USB_OTG_GINTMSK_EOPFM_Pos)
#define USB_OTG_GINTMSK_EOPFM   USB_OTG_GINTMSK_EOPFM_Msk
#define USB_OTG_GINTMSK_EPMISM_Pos   (17U)
#define USB_OTG_GINTMSK_EPMISM_Msk   (0x1U << USB_OTG_GINTMSK_EPMISM_Pos)
#define USB_OTG_GINTMSK_EPMISM   USB_OTG_GINTMSK_EPMISM_Msk
#define USB_OTG_GINTMSK_IEPINT_Pos   (18U)
#define USB_OTG_GINTMSK_IEPINT_Msk   (0x1U << USB_OTG_GINTMSK_IEPINT_Pos)
#define USB_OTG_GINTMSK_IEPINT   USB_OTG_GINTMSK_IEPINT_Msk
#define USB_OTG_GINTMSK_OEPINT_Pos   (19U)
#define USB_OTG_GINTMSK_OEPINT_Msk   (0x1U << USB_OTG_GINTMSK_OEPINT_Pos)
#define USB_OTG_GINTMSK_OEPINT   USB_OTG_GINTMSK_OEPINT_Msk
#define USB_OTG_GINTMSK_IISOIXFRM_Pos   (20U)
#define USB_OTG_GINTMSK_IISOIXFRM_Msk   (0x1U << USB_OTG_GINTMSK_IISOIXFRM_Pos)
#define USB_OTG_GINTMSK_IISOIXFRM   USB_OTG_GINTMSK_IISOIXFRM_Msk
#define USB_OTG_GINTMSK_PXFRM_IISOOXFRM_Pos   (21U)
#define USB_OTG_GINTMSK_PXFRM_IISOOXFRM_Msk   (0x1U << USB_OTG_GINTMSK_PXFRM_IISOOXFRM_Pos)
#define USB_OTG_GINTMSK_PXFRM_IISOOXFRM   USB_OTG_GINTMSK_PXFRM_IISOOXFRM_Msk
#define USB_OTG_GINTMSK_FSUSPM_Pos   (22U)
#define USB_OTG_GINTMSK_FSUSPM_Msk   (0x1U << USB_OTG_GINTMSK_FSUSPM_Pos)
#define USB_OTG_GINTMSK_FSUSPM   USB_OTG_GINTMSK_FSUSPM_Msk
#define USB_OTG_GINTMSK_PRTIM_Pos   (24U)
#define USB_OTG_GINTMSK_PRTIM_Msk   (0x1U << USB_OTG_GINTMSK_PRTIM_Pos)
#define USB_OTG_GINTMSK_PRTIM   USB_OTG_GINTMSK_PRTIM_Msk
#define USB_OTG_GINTMSK_HCIM_Pos   (25U)
#define USB_OTG_GINTMSK_HCIM_Msk   (0x1U << USB_OTG_GINTMSK_HCIM_Pos)
#define USB_OTG_GINTMSK_HCIM   USB_OTG_GINTMSK_HCIM_Msk
#define USB_OTG_GINTMSK_PTXFEM_Pos   (26U)
#define USB_OTG_GINTMSK_PTXFEM_Msk   (0x1U << USB_OTG_GINTMSK_PTXFEM_Pos)
#define USB_OTG_GINTMSK_PTXFEM   USB_OTG_GINTMSK_PTXFEM_Msk
#define USB_OTG_GINTMSK_LPMINTM_Pos   (27U)
#define USB_OTG_GINTMSK_LPMINTM_Msk   (0x1U << USB_OTG_GINTMSK_LPMINTM_Pos)
#define USB_OTG_GINTMSK_LPMINTM   USB_OTG_GINTMSK_LPMINTM_Msk
#define USB_OTG_GINTMSK_CIDSCHGM_Pos   (28U)
#define USB_OTG_GINTMSK_CIDSCHGM_Msk   (0x1U << USB_OTG_GINTMSK_CIDSCHGM_Pos)
#define USB_OTG_GINTMSK_CIDSCHGM   USB_OTG_GINTMSK_CIDSCHGM_Msk
#define USB_OTG_GINTMSK_DISCINT_Pos   (29U)
#define USB_OTG_GINTMSK_DISCINT_Msk   (0x1U << USB_OTG_GINTMSK_DISCINT_Pos)
#define USB_OTG_GINTMSK_DISCINT   USB_OTG_GINTMSK_DISCINT_Msk
#define USB_OTG_GINTMSK_SRQIM_Pos   (30U)
#define USB_OTG_GINTMSK_SRQIM_Msk   (0x1U << USB_OTG_GINTMSK_SRQIM_Pos)
#define USB_OTG_GINTMSK_SRQIM   USB_OTG_GINTMSK_SRQIM_Msk
#define USB_OTG_GINTMSK_WUIM_Pos   (31U)
#define USB_OTG_GINTMSK_WUIM_Msk   (0x1U << USB_OTG_GINTMSK_WUIM_Pos)
#define USB_OTG_GINTMSK_WUIM   USB_OTG_GINTMSK_WUIM_Msk
#define USB_OTG_DAINT_IEPINT_Pos   (0U)
#define USB_OTG_DAINT_IEPINT_Msk   (0xFFFFU << USB_OTG_DAINT_IEPINT_Pos)
#define USB_OTG_DAINT_IEPINT   USB_OTG_DAINT_IEPINT_Msk
#define USB_OTG_DAINT_OEPINT_Pos   (16U)
#define USB_OTG_DAINT_OEPINT_Msk   (0xFFFFU << USB_OTG_DAINT_OEPINT_Pos)
#define USB_OTG_DAINT_OEPINT   USB_OTG_DAINT_OEPINT_Msk
#define USB_OTG_HAINTMSK_HAINTM_Pos   (0U)
#define USB_OTG_HAINTMSK_HAINTM_Msk   (0xFFFFU << USB_OTG_HAINTMSK_HAINTM_Pos)
#define USB_OTG_HAINTMSK_HAINTM   USB_OTG_HAINTMSK_HAINTM_Msk
#define USB_OTG_GRXSTSP_EPNUM_Pos   (0U)
#define USB_OTG_GRXSTSP_EPNUM_Msk   (0xFU << USB_OTG_GRXSTSP_EPNUM_Pos)
#define USB_OTG_GRXSTSP_EPNUM   USB_OTG_GRXSTSP_EPNUM_Msk
#define USB_OTG_GRXSTSP_BCNT_Pos   (4U)
#define USB_OTG_GRXSTSP_BCNT_Msk   (0x7FFU << USB_OTG_GRXSTSP_BCNT_Pos)
#define USB_OTG_GRXSTSP_BCNT   USB_OTG_GRXSTSP_BCNT_Msk
#define USB_OTG_GRXSTSP_DPID_Pos   (15U)
#define USB_OTG_GRXSTSP_DPID_Msk   (0x3U << USB_OTG_GRXSTSP_DPID_Pos)
#define USB_OTG_GRXSTSP_DPID   USB_OTG_GRXSTSP_DPID_Msk
#define USB_OTG_GRXSTSP_PKTSTS_Pos   (17U)
#define USB_OTG_GRXSTSP_PKTSTS_Msk   (0xFU << USB_OTG_GRXSTSP_PKTSTS_Pos)
#define USB_OTG_GRXSTSP_PKTSTS   USB_OTG_GRXSTSP_PKTSTS_Msk
#define USB_OTG_DAINTMSK_IEPM_Pos   (0U)
#define USB_OTG_DAINTMSK_IEPM_Msk   (0xFFFFU << USB_OTG_DAINTMSK_IEPM_Pos)
#define USB_OTG_DAINTMSK_IEPM   USB_OTG_DAINTMSK_IEPM_Msk
#define USB_OTG_DAINTMSK_OEPM_Pos   (16U)
#define USB_OTG_DAINTMSK_OEPM_Msk   (0xFFFFU << USB_OTG_DAINTMSK_OEPM_Pos)
#define USB_OTG_DAINTMSK_OEPM   USB_OTG_DAINTMSK_OEPM_Msk
#define USB_OTG_CHNUM_Pos   (0U)
#define USB_OTG_CHNUM_Msk   (0xFU << USB_OTG_CHNUM_Pos)
#define USB_OTG_CHNUM   USB_OTG_CHNUM_Msk
#define USB_OTG_CHNUM_0   (0x1U << USB_OTG_CHNUM_Pos)
#define USB_OTG_CHNUM_1   (0x2U << USB_OTG_CHNUM_Pos)
#define USB_OTG_CHNUM_2   (0x4U << USB_OTG_CHNUM_Pos)
#define USB_OTG_CHNUM_3   (0x8U << USB_OTG_CHNUM_Pos)
#define USB_OTG_BCNT_Pos   (4U)
#define USB_OTG_BCNT_Msk   (0x7FFU << USB_OTG_BCNT_Pos)
#define USB_OTG_BCNT   USB_OTG_BCNT_Msk
#define USB_OTG_DPID_Pos   (15U)
#define USB_OTG_DPID_Msk   (0x3U << USB_OTG_DPID_Pos)
#define USB_OTG_DPID   USB_OTG_DPID_Msk
#define USB_OTG_DPID_0   (0x1U << USB_OTG_DPID_Pos)
#define USB_OTG_DPID_1   (0x2U << USB_OTG_DPID_Pos)
#define USB_OTG_PKTSTS_Pos   (17U)
#define USB_OTG_PKTSTS_Msk   (0xFU << USB_OTG_PKTSTS_Pos)
#define USB_OTG_PKTSTS   USB_OTG_PKTSTS_Msk
#define USB_OTG_PKTSTS_0   (0x1U << USB_OTG_PKTSTS_Pos)
#define USB_OTG_PKTSTS_1   (0x2U << USB_OTG_PKTSTS_Pos)
#define USB_OTG_PKTSTS_2   (0x4U << USB_OTG_PKTSTS_Pos)
#define USB_OTG_PKTSTS_3   (0x8U << USB_OTG_PKTSTS_Pos)
#define USB_OTG_EPNUM_Pos   (0U)
#define USB_OTG_EPNUM_Msk   (0xFU << USB_OTG_EPNUM_Pos)
#define USB_OTG_EPNUM   USB_OTG_EPNUM_Msk
#define USB_OTG_EPNUM_0   (0x1U << USB_OTG_EPNUM_Pos)
#define USB_OTG_EPNUM_1   (0x2U << USB_OTG_EPNUM_Pos)
#define USB_OTG_EPNUM_2   (0x4U << USB_OTG_EPNUM_Pos)
#define USB_OTG_EPNUM_3   (0x8U << USB_OTG_EPNUM_Pos)
#define USB_OTG_FRMNUM_Pos   (21U)
#define USB_OTG_FRMNUM_Msk   (0xFU << USB_OTG_FRMNUM_Pos)
#define USB_OTG_FRMNUM   USB_OTG_FRMNUM_Msk
#define USB_OTG_FRMNUM_0   (0x1U << USB_OTG_FRMNUM_Pos)
#define USB_OTG_FRMNUM_1   (0x2U << USB_OTG_FRMNUM_Pos)
#define USB_OTG_FRMNUM_2   (0x4U << USB_OTG_FRMNUM_Pos)
#define USB_OTG_FRMNUM_3   (0x8U << USB_OTG_FRMNUM_Pos)
#define USB_OTG_GRXFSIZ_RXFD_Pos   (0U)
#define USB_OTG_GRXFSIZ_RXFD_Msk   (0xFFFFU << USB_OTG_GRXFSIZ_RXFD_Pos)
#define USB_OTG_GRXFSIZ_RXFD   USB_OTG_GRXFSIZ_RXFD_Msk
#define USB_OTG_DVBUSDIS_VBUSDT_Pos   (0U)
#define USB_OTG_DVBUSDIS_VBUSDT_Msk   (0xFFFFU << USB_OTG_DVBUSDIS_VBUSDT_Pos)
#define USB_OTG_DVBUSDIS_VBUSDT   USB_OTG_DVBUSDIS_VBUSDT_Msk
#define USB_OTG_NPTXFSA_Pos   (0U)
#define USB_OTG_NPTXFSA_Msk   (0xFFFFU << USB_OTG_NPTXFSA_Pos)
#define USB_OTG_NPTXFSA   USB_OTG_NPTXFSA_Msk
#define USB_OTG_NPTXFD_Pos   (16U)
#define USB_OTG_NPTXFD_Msk   (0xFFFFU << USB_OTG_NPTXFD_Pos)
#define USB_OTG_NPTXFD   USB_OTG_NPTXFD_Msk
#define USB_OTG_TX0FSA_Pos   (0U)
#define USB_OTG_TX0FSA_Msk   (0xFFFFU << USB_OTG_TX0FSA_Pos)
#define USB_OTG_TX0FSA   USB_OTG_TX0FSA_Msk
#define USB_OTG_TX0FD_Pos   (16U)
#define USB_OTG_TX0FD_Msk   (0xFFFFU << USB_OTG_TX0FD_Pos)
#define USB_OTG_TX0FD   USB_OTG_TX0FD_Msk
#define USB_OTG_DVBUSPULSE_DVBUSP_Pos   (0U)
#define USB_OTG_DVBUSPULSE_DVBUSP_Msk   (0xFFFU << USB_OTG_DVBUSPULSE_DVBUSP_Pos)
#define USB_OTG_DVBUSPULSE_DVBUSP   USB_OTG_DVBUSPULSE_DVBUSP_Msk
#define USB_OTG_GNPTXSTS_NPTXFSAV_Pos   (0U)
#define USB_OTG_GNPTXSTS_NPTXFSAV_Msk   (0xFFFFU << USB_OTG_GNPTXSTS_NPTXFSAV_Pos)
#define USB_OTG_GNPTXSTS_NPTXFSAV   USB_OTG_GNPTXSTS_NPTXFSAV_Msk
#define USB_OTG_GNPTXSTS_NPTQXSAV_Pos   (16U)
#define USB_OTG_GNPTXSTS_NPTQXSAV_Msk   (0xFFU << USB_OTG_GNPTXSTS_NPTQXSAV_Pos)
#define USB_OTG_GNPTXSTS_NPTQXSAV   USB_OTG_GNPTXSTS_NPTQXSAV_Msk
#define USB_OTG_GNPTXSTS_NPTQXSAV_0   (0x01U << USB_OTG_GNPTXSTS_NPTQXSAV_Pos)
#define USB_OTG_GNPTXSTS_NPTQXSAV_1   (0x02U << USB_OTG_GNPTXSTS_NPTQXSAV_Pos)
#define USB_OTG_GNPTXSTS_NPTQXSAV_2   (0x04U << USB_OTG_GNPTXSTS_NPTQXSAV_Pos)
#define USB_OTG_GNPTXSTS_NPTQXSAV_3   (0x08U << USB_OTG_GNPTXSTS_NPTQXSAV_Pos)
#define USB_OTG_GNPTXSTS_NPTQXSAV_4   (0x10U << USB_OTG_GNPTXSTS_NPTQXSAV_Pos)
#define USB_OTG_GNPTXSTS_NPTQXSAV_5   (0x20U << USB_OTG_GNPTXSTS_NPTQXSAV_Pos)
#define USB_OTG_GNPTXSTS_NPTQXSAV_6   (0x40U << USB_OTG_GNPTXSTS_NPTQXSAV_Pos)
#define USB_OTG_GNPTXSTS_NPTQXSAV_7   (0x80U << USB_OTG_GNPTXSTS_NPTQXSAV_Pos)
#define USB_OTG_GNPTXSTS_NPTXQTOP_Pos   (24U)
#define USB_OTG_GNPTXSTS_NPTXQTOP_Msk   (0x7FU << USB_OTG_GNPTXSTS_NPTXQTOP_Pos)
#define USB_OTG_GNPTXSTS_NPTXQTOP   USB_OTG_GNPTXSTS_NPTXQTOP_Msk
#define USB_OTG_GNPTXSTS_NPTXQTOP_0   (0x01U << USB_OTG_GNPTXSTS_NPTXQTOP_Pos)
#define USB_OTG_GNPTXSTS_NPTXQTOP_1   (0x02U << USB_OTG_GNPTXSTS_NPTXQTOP_Pos)
#define USB_OTG_GNPTXSTS_NPTXQTOP_2   (0x04U << USB_OTG_GNPTXSTS_NPTXQTOP_Pos)
#define USB_OTG_GNPTXSTS_NPTXQTOP_3   (0x08U << USB_OTG_GNPTXSTS_NPTXQTOP_Pos)
#define USB_OTG_GNPTXSTS_NPTXQTOP_4   (0x10U << USB_OTG_GNPTXSTS_NPTXQTOP_Pos)
#define USB_OTG_GNPTXSTS_NPTXQTOP_5   (0x20U << USB_OTG_GNPTXSTS_NPTXQTOP_Pos)
#define USB_OTG_GNPTXSTS_NPTXQTOP_6   (0x40U << USB_OTG_GNPTXSTS_NPTXQTOP_Pos)
#define USB_OTG_DTHRCTL_NONISOTHREN_Pos   (0U)
#define USB_OTG_DTHRCTL_NONISOTHREN_Msk   (0x1U << USB_OTG_DTHRCTL_NONISOTHREN_Pos)
#define USB_OTG_DTHRCTL_NONISOTHREN   USB_OTG_DTHRCTL_NONISOTHREN_Msk
#define USB_OTG_DTHRCTL_ISOTHREN_Pos   (1U)
#define USB_OTG_DTHRCTL_ISOTHREN_Msk   (0x1U << USB_OTG_DTHRCTL_ISOTHREN_Pos)
#define USB_OTG_DTHRCTL_ISOTHREN   USB_OTG_DTHRCTL_ISOTHREN_Msk
#define USB_OTG_DTHRCTL_TXTHRLEN_Pos   (2U)
#define USB_OTG_DTHRCTL_TXTHRLEN_Msk   (0x1FFU << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_TXTHRLEN   USB_OTG_DTHRCTL_TXTHRLEN_Msk
#define USB_OTG_DTHRCTL_TXTHRLEN_0   (0x001U << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_TXTHRLEN_1   (0x002U << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_TXTHRLEN_2   (0x004U << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_TXTHRLEN_3   (0x008U << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_TXTHRLEN_4   (0x010U << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_TXTHRLEN_5   (0x020U << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_TXTHRLEN_6   (0x040U << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_TXTHRLEN_7   (0x080U << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_TXTHRLEN_8   (0x100U << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_RXTHREN_Pos   (16U)
#define USB_OTG_DTHRCTL_RXTHREN_Msk   (0x1U << USB_OTG_DTHRCTL_RXTHREN_Pos)
#define USB_OTG_DTHRCTL_RXTHREN   USB_OTG_DTHRCTL_RXTHREN_Msk
#define USB_OTG_DTHRCTL_RXTHRLEN_Pos   (17U)
#define USB_OTG_DTHRCTL_RXTHRLEN_Msk   (0x1FFU << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_RXTHRLEN   USB_OTG_DTHRCTL_RXTHRLEN_Msk
#define USB_OTG_DTHRCTL_RXTHRLEN_0   (0x001U << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_RXTHRLEN_1   (0x002U << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_RXTHRLEN_2   (0x004U << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_RXTHRLEN_3   (0x008U << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_RXTHRLEN_4   (0x010U << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_RXTHRLEN_5   (0x020U << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_RXTHRLEN_6   (0x040U << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_RXTHRLEN_7   (0x080U << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_RXTHRLEN_8   (0x100U << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_ARPEN_Pos   (27U)
#define USB_OTG_DTHRCTL_ARPEN_Msk   (0x1U << USB_OTG_DTHRCTL_ARPEN_Pos)
#define USB_OTG_DTHRCTL_ARPEN   USB_OTG_DTHRCTL_ARPEN_Msk
#define USB_OTG_DIEPEMPMSK_INEPTXFEM_Pos   (0U)
#define USB_OTG_DIEPEMPMSK_INEPTXFEM_Msk   (0xFFFFU << USB_OTG_DIEPEMPMSK_INEPTXFEM_Pos)
#define USB_OTG_DIEPEMPMSK_INEPTXFEM   USB_OTG_DIEPEMPMSK_INEPTXFEM_Msk
#define USB_OTG_DEACHINT_IEP1INT_Pos   (1U)
#define USB_OTG_DEACHINT_IEP1INT_Msk   (0x1U << USB_OTG_DEACHINT_IEP1INT_Pos)
#define USB_OTG_DEACHINT_IEP1INT   USB_OTG_DEACHINT_IEP1INT_Msk
#define USB_OTG_DEACHINT_OEP1INT_Pos   (17U)
#define USB_OTG_DEACHINT_OEP1INT_Msk   (0x1U << USB_OTG_DEACHINT_OEP1INT_Pos)
#define USB_OTG_DEACHINT_OEP1INT   USB_OTG_DEACHINT_OEP1INT_Msk
#define USB_OTG_GCCFG_CHGDET_Pos   (0U)
#define USB_OTG_GCCFG_CHGDET_Msk   (0x1U << USB_OTG_GCCFG_CHGDET_Pos)
#define USB_OTG_GCCFG_CHGDET   USB_OTG_GCCFG_CHGDET_Msk
#define USB_OTG_GCCFG_FSVPLUS_Pos   (1U)
#define USB_OTG_GCCFG_FSVPLUS_Msk   (0x1U << USB_OTG_GCCFG_FSVPLUS_Pos)
#define USB_OTG_GCCFG_FSVPLUS   USB_OTG_GCCFG_FSVPLUS_Msk
#define USB_OTG_GCCFG_FSVMINUS_Pos   (2U)
#define USB_OTG_GCCFG_FSVMINUS_Msk   0x1U << USB_OTG_GCCFG_FSVMINUS_Pos)
#define USB_OTG_GCCFG_FSVMINUS   USB_OTG_GCCFG_FSVMINUS_Msk
#define USB_OTG_GCCFG_SESSVLD_Pos   (3U)
#define USB_OTG_GCCFG_SESSVLD_Msk   (0x1U << USB_OTG_GCCFG_SESSVLD_Pos)
#define USB_OTG_GCCFG_SESSVLD   USB_OTG_GCCFG_SESSVLD_Msk
#define USB_OTG_GCCFG_H_CDPEN_Pos   (16U)
#define USB_OTG_GCCFG_H_CDPEN_Msk   (0x1U << USB_OTG_GCCFG_H_CDPEN_Pos)
#define USB_OTG_GCCFG_H_CDPEN   USB_OTG_GCCFG_H_CDPEN_Msk
#define USB_OTG_GCCFG_H_CDPDETEN_Pos   (17U)
#define USB_OTG_GCCFG_H_CDPDETEN_Msk   (0x1U << USB_OTG_GCCFG_H_CDPDETEN_Pos)
#define USB_OTG_GCCFG_H_CDPDETEN   USB_OTG_GCCFG_H_CDPDETEN_Msk
#define USB_OTG_GCCFG_H_VDMSRCEN_Pos   (18U)
#define USB_OTG_GCCFG_H_VDMSRCEN_Msk   (0x1U << USB_OTG_GCCFG_H_VDMSRCEN_Pos)
#define USB_OTG_GCCFG_H_VDMSRCEN   USB_OTG_GCCFG_H_VDMSRCEN_Msk
#define USB_OTG_GCCFG_DCDEN_Pos   (19U)
#define USB_OTG_GCCFG_DCDEN_Msk   (0x1U << USB_OTG_GCCFG_DCDEN_Pos)
#define USB_OTG_GCCFG_DCDEN   USB_OTG_GCCFG_DCDEN_Msk
#define USB_OTG_GCCFG_PDEN_Pos   (20U)
#define USB_OTG_GCCFG_PDEN_Msk   (0x1U << USB_OTG_GCCFG_PDEN_Pos)
#define USB_OTG_GCCFG_PDEN   USB_OTG_GCCFG_PDEN_Msk
#define USB_OTG_GCCFG_VBDEN_Pos   (21U)
#define USB_OTG_GCCFG_VBDEN_Msk   (0x1U << USB_OTG_GCCFG_VBDEN_Pos)
#define USB_OTG_GCCFG_VBDEN   USB_OTG_GCCFG_VBDEN_Msk
#define USB_OTG_GCCFG_SDEN_Pos   (22U)
#define USB_OTG_GCCFG_SDEN_Msk   (0x1U << USB_OTG_GCCFG_SDEN_Pos)
#define USB_OTG_GCCFG_SDEN   USB_OTG_GCCFG_SDEN_Msk
#define USB_OTG_GCCFG_VBVALOVAL_Pos   (23U)
#define USB_OTG_GCCFG_VBVALOVAL_Msk   (0x1U << USB_OTG_GCCFG_VBVALOVAL_Pos)
#define USB_OTG_GCCFG_VBVALOVAL   USB_OTG_GCCFG_VBVALOVAL_Msk
#define USB_OTG_GCCFG_VBVALEXTOEN_Pos   (24U)
#define USB_OTG_GCCFG_VBVALEXTOEN_Msk   (0x1U << USB_OTG_GCCFG_VBVALEXTOEN_Pos)
#define USB_OTG_GCCFG_VBVALEXTOEN   USB_OTG_GCCFG_VBVALEXTOEN_Msk
#define USB_OTG_GCCFG_PULLDOWNEN_Pos   (25U)
#define USB_OTG_GCCFG_PULLDOWNEN_Msk   (0x1U << USB_OTG_GCCFG_PULLDOWNEN_Pos)
#define USB_OTG_GCCFG_PULLDOWNEN   USB_OTG_GCCFG_PULLDOWNEN_Msk
#define USB_OTG_GPWRDN_DISABLEVBUS_Pos   (6U)
#define USB_OTG_GPWRDN_DISABLEVBUS_Msk   (0x1U << USB_OTG_GPWRDN_DISABLEVBUS_Pos)
#define USB_OTG_GPWRDN_DISABLEVBUS   USB_OTG_GPWRDN_DISABLEVBUS_Msk
#define USB_OTG_DEACHINTMSK_IEP1INTM_Pos   (1U)
#define USB_OTG_DEACHINTMSK_IEP1INTM_Msk   (0x1U << USB_OTG_DEACHINTMSK_IEP1INTM_Pos)
#define USB_OTG_DEACHINTMSK_IEP1INTM   USB_OTG_DEACHINTMSK_IEP1INTM_Msk
#define USB_OTG_DEACHINTMSK_OEP1INTM_Pos   (17U)
#define USB_OTG_DEACHINTMSK_OEP1INTM_Msk   (0x1U << USB_OTG_DEACHINTMSK_OEP1INTM_Pos)
#define USB_OTG_DEACHINTMSK_OEP1INTM   USB_OTG_DEACHINTMSK_OEP1INTM_Msk
#define USB_OTG_CID_PRODUCT_ID_Pos   (0U)
#define USB_OTG_CID_PRODUCT_ID_Msk   (0xFFFFFFFFU << USB_OTG_CID_PRODUCT_ID_Pos)
#define USB_OTG_CID_PRODUCT_ID   USB_OTG_CID_PRODUCT_ID_Msk
#define USB_OTG_GHWCFG3_LPMMode_Pos   (14U)
#define USB_OTG_GHWCFG3_LPMMode_Msk   (0x1U << USB_OTG_GHWCFG3_LPMMode_Pos)
#define USB_OTG_GHWCFG3_LPMMode   USB_OTG_GHWCFG3_LPMMode_Msk /* LPM mode specified for Mode of Operation */
#define USB_OTG_GLPMCFG_ENBESL_Pos   (28U)
#define USB_OTG_GLPMCFG_ENBESL_Msk   (0x1U << USB_OTG_GLPMCFG_ENBESL_Pos)
#define USB_OTG_GLPMCFG_ENBESL   USB_OTG_GLPMCFG_ENBESL_Msk /* Enable best effort service latency */
#define USB_OTG_GLPMCFG_LPMRCNTSTS_Pos   (25U)
#define USB_OTG_GLPMCFG_LPMRCNTSTS_Msk   (0x7U << USB_OTG_GLPMCFG_LPMRCNTSTS_Pos)
#define USB_OTG_GLPMCFG_LPMRCNTSTS   USB_OTG_GLPMCFG_LPMRCNTSTS_Msk /* LPM retry count status */
#define USB_OTG_GLPMCFG_SNDLPM_Pos   (24U)
#define USB_OTG_GLPMCFG_SNDLPM_Msk   (0x1U << USB_OTG_GLPMCFG_SNDLPM_Pos)
#define USB_OTG_GLPMCFG_SNDLPM   USB_OTG_GLPMCFG_SNDLPM_Msk /* Send LPM transaction */
#define USB_OTG_GLPMCFG_LPMRCNT_Pos   (21U)
#define USB_OTG_GLPMCFG_LPMRCNT_Msk   (0x7U << USB_OTG_GLPMCFG_LPMRCNT_Pos)
#define USB_OTG_GLPMCFG_LPMRCNT   USB_OTG_GLPMCFG_LPMRCNT_Msk /* LPM retry count */
#define USB_OTG_GLPMCFG_LPMCHIDX_Pos   (17U)
#define USB_OTG_GLPMCFG_LPMCHIDX_Msk   (0xFU << USB_OTG_GLPMCFG_LPMCHIDX_Pos)
#define USB_OTG_GLPMCFG_LPMCHIDX   USB_OTG_GLPMCFG_LPMCHIDX_Msk /* LPMCHIDX: */
#define USB_OTG_GLPMCFG_L1ResumeOK_Pos   (16U)
#define USB_OTG_GLPMCFG_L1ResumeOK_Msk   (0x1U << USB_OTG_GLPMCFG_L1ResumeOK_Pos)
#define USB_OTG_GLPMCFG_L1ResumeOK   USB_OTG_GLPMCFG_L1ResumeOK_Msk /* Sleep State Resume OK */
#define USB_OTG_GLPMCFG_SLPSTS_Pos   (15U)
#define USB_OTG_GLPMCFG_SLPSTS_Msk   (0x1U << USB_OTG_GLPMCFG_SLPSTS_Pos)
#define USB_OTG_GLPMCFG_SLPSTS   USB_OTG_GLPMCFG_SLPSTS_Msk /* Port sleep status */
#define USB_OTG_GLPMCFG_LPMRSP_Pos   (13U)
#define USB_OTG_GLPMCFG_LPMRSP_Msk   (0x3U << USB_OTG_GLPMCFG_LPMRSP_Pos)
#define USB_OTG_GLPMCFG_LPMRSP   USB_OTG_GLPMCFG_LPMRSP_Msk /* LPM response */
#define USB_OTG_GLPMCFG_L1DSEN_Pos   (12U)
#define USB_OTG_GLPMCFG_L1DSEN_Msk   (0x1U << USB_OTG_GLPMCFG_L1DSEN_Pos)
#define USB_OTG_GLPMCFG_L1DSEN   USB_OTG_GLPMCFG_L1DSEN_Msk /* L1 deep sleep enable */
#define USB_OTG_GLPMCFG_BESLTHRS_Pos   (8U)
#define USB_OTG_GLPMCFG_BESLTHRS_Msk   (0xFU << USB_OTG_GLPMCFG_BESLTHRS_Pos)
#define USB_OTG_GLPMCFG_BESLTHRS   USB_OTG_GLPMCFG_BESLTHRS_Msk /* BESL threshold */
#define USB_OTG_GLPMCFG_L1SSEN_Pos   (7U)
#define USB_OTG_GLPMCFG_L1SSEN_Msk   (0x1U << USB_OTG_GLPMCFG_L1SSEN_Pos)
#define USB_OTG_GLPMCFG_L1SSEN   USB_OTG_GLPMCFG_L1SSEN_Msk /* L1 shallow sleep enable */
#define USB_OTG_GLPMCFG_REMWAKE_Pos   (6U)
#define USB_OTG_GLPMCFG_REMWAKE_Msk   (0x1U << USB_OTG_GLPMCFG_REMWAKE_Pos)
#define USB_OTG_GLPMCFG_REMWAKE   USB_OTG_GLPMCFG_REMWAKE_Msk /* bRemoteWake value received with last ACKed LPM Token */
#define USB_OTG_GLPMCFG_BESL_Pos   (2U)
#define USB_OTG_GLPMCFG_BESL_Msk   (0xFU << USB_OTG_GLPMCFG_BESL_Pos)
#define USB_OTG_GLPMCFG_BESL   USB_OTG_GLPMCFG_BESL_Msk /* BESL value received with last ACKed LPM Token */
#define USB_OTG_GLPMCFG_LPMACK_Pos   (1U)
#define USB_OTG_GLPMCFG_LPMACK_Msk   (0x1U << USB_OTG_GLPMCFG_LPMACK_Pos)
#define USB_OTG_GLPMCFG_LPMACK   USB_OTG_GLPMCFG_LPMACK_Msk /* LPM Token acknowledge enable*/
#define USB_OTG_GLPMCFG_LPMEN_Pos   (0U)
#define USB_OTG_GLPMCFG_LPMEN_Msk   (0x1U << USB_OTG_GLPMCFG_LPMEN_Pos)
#define USB_OTG_GLPMCFG_LPMEN   USB_OTG_GLPMCFG_LPMEN_Msk /* LPM support enable */
#define USB_OTG_DIEPEACHMSK1_XFRCM_Pos   (0U)
#define USB_OTG_DIEPEACHMSK1_XFRCM_Msk   (0x1U << USB_OTG_DIEPEACHMSK1_XFRCM_Pos)
#define USB_OTG_DIEPEACHMSK1_XFRCM   USB_OTG_DIEPEACHMSK1_XFRCM_Msk
#define USB_OTG_DIEPEACHMSK1_EPDM_Pos   (1U)
#define USB_OTG_DIEPEACHMSK1_EPDM_Msk   (0x1U << USB_OTG_DIEPEACHMSK1_EPDM_Pos)
#define USB_OTG_DIEPEACHMSK1_EPDM   USB_OTG_DIEPEACHMSK1_EPDM_Msk
#define USB_OTG_DIEPEACHMSK1_TOM_Pos   (3U)
#define USB_OTG_DIEPEACHMSK1_TOM_Msk   (0x1U << USB_OTG_DIEPEACHMSK1_TOM_Pos)
#define USB_OTG_DIEPEACHMSK1_TOM   USB_OTG_DIEPEACHMSK1_TOM_Msk
#define USB_OTG_DIEPEACHMSK1_ITTXFEMSK_Pos   (4U)
#define USB_OTG_DIEPEACHMSK1_ITTXFEMSK_Msk   (0x1U << USB_OTG_DIEPEACHMSK1_ITTXFEMSK_Pos)
#define USB_OTG_DIEPEACHMSK1_ITTXFEMSK   USB_OTG_DIEPEACHMSK1_ITTXFEMSK_Msk
#define USB_OTG_DIEPEACHMSK1_INEPNMM_Pos   (5U)
#define USB_OTG_DIEPEACHMSK1_INEPNMM_Msk   (0x1U << USB_OTG_DIEPEACHMSK1_INEPNMM_Pos)
#define USB_OTG_DIEPEACHMSK1_INEPNMM   USB_OTG_DIEPEACHMSK1_INEPNMM_Msk
#define USB_OTG_DIEPEACHMSK1_INEPNEM_Pos   (6U)
#define USB_OTG_DIEPEACHMSK1_INEPNEM_Msk   (0x1U << USB_OTG_DIEPEACHMSK1_INEPNEM_Pos)
#define USB_OTG_DIEPEACHMSK1_INEPNEM   USB_OTG_DIEPEACHMSK1_INEPNEM_Msk
#define USB_OTG_DIEPEACHMSK1_TXFURM_Pos   (8U)
#define USB_OTG_DIEPEACHMSK1_TXFURM_Msk   (0x1U << USB_OTG_DIEPEACHMSK1_TXFURM_Pos)
#define USB_OTG_DIEPEACHMSK1_TXFURM   USB_OTG_DIEPEACHMSK1_TXFURM_Msk
#define USB_OTG_DIEPEACHMSK1_BIM_Pos   (9U)
#define USB_OTG_DIEPEACHMSK1_BIM_Msk   (0x1U << USB_OTG_DIEPEACHMSK1_BIM_Pos)
#define USB_OTG_DIEPEACHMSK1_BIM   USB_OTG_DIEPEACHMSK1_BIM_Msk
#define USB_OTG_DIEPEACHMSK1_NAKM_Pos   (13U)
#define USB_OTG_DIEPEACHMSK1_NAKM_Msk   (0x1U << USB_OTG_DIEPEACHMSK1_NAKM_Pos)
#define USB_OTG_DIEPEACHMSK1_NAKM   USB_OTG_DIEPEACHMSK1_NAKM_Msk
#define USB_OTG_HPRT_PCSTS_Pos   (0U)
#define USB_OTG_HPRT_PCSTS_Msk   (0x1U << USB_OTG_HPRT_PCSTS_Pos)
#define USB_OTG_HPRT_PCSTS   USB_OTG_HPRT_PCSTS_Msk
#define USB_OTG_HPRT_PCDET_Pos   (1U)
#define USB_OTG_HPRT_PCDET_Msk   (0x1U << USB_OTG_HPRT_PCDET_Pos)
#define USB_OTG_HPRT_PCDET   USB_OTG_HPRT_PCDET_Msk
#define USB_OTG_HPRT_PENA_Pos   (2U)
#define USB_OTG_HPRT_PENA_Msk   (0x1U << USB_OTG_HPRT_PENA_Pos)
#define USB_OTG_HPRT_PENA   USB_OTG_HPRT_PENA_Msk
#define USB_OTG_HPRT_PENCHNG_Pos   (3U)
#define USB_OTG_HPRT_PENCHNG_Msk   (0x1U << USB_OTG_HPRT_PENCHNG_Pos)
#define USB_OTG_HPRT_PENCHNG   USB_OTG_HPRT_PENCHNG_Msk
#define USB_OTG_HPRT_POCA_Pos   (4U)
#define USB_OTG_HPRT_POCA_Msk   (0x1U << USB_OTG_HPRT_POCA_Pos)
#define USB_OTG_HPRT_POCA   USB_OTG_HPRT_POCA_Msk
#define USB_OTG_HPRT_POCCHNG_Pos   (5U)
#define USB_OTG_HPRT_POCCHNG_Msk   (0x1U << USB_OTG_HPRT_POCCHNG_Pos)
#define USB_OTG_HPRT_POCCHNG   USB_OTG_HPRT_POCCHNG_Msk
#define USB_OTG_HPRT_PRES_Pos   (6U)
#define USB_OTG_HPRT_PRES_Msk   (0x1U << USB_OTG_HPRT_PRES_Pos)
#define USB_OTG_HPRT_PRES   USB_OTG_HPRT_PRES_Msk
#define USB_OTG_HPRT_PSUSP_Pos   (7U)
#define USB_OTG_HPRT_PSUSP_Msk   (0x1U << USB_OTG_HPRT_PSUSP_Pos)
#define USB_OTG_HPRT_PSUSP   USB_OTG_HPRT_PSUSP_Msk
#define USB_OTG_HPRT_PRST_Pos   (8U)
#define USB_OTG_HPRT_PRST_Msk   (0x1U << USB_OTG_HPRT_PRST_Pos)
#define USB_OTG_HPRT_PRST   USB_OTG_HPRT_PRST_Msk
#define USB_OTG_HPRT_PLSTS_Pos   (10U)
#define USB_OTG_HPRT_PLSTS_Msk   (0x3U << USB_OTG_HPRT_PLSTS_Pos)
#define USB_OTG_HPRT_PLSTS   USB_OTG_HPRT_PLSTS_Msk
#define USB_OTG_HPRT_PLSTS_0   (0x1U << USB_OTG_HPRT_PLSTS_Pos)
#define USB_OTG_HPRT_PLSTS_1   (0x2U << USB_OTG_HPRT_PLSTS_Pos)
#define USB_OTG_HPRT_PPWR_Pos   (12U)
#define USB_OTG_HPRT_PPWR_Msk   (0x1U << USB_OTG_HPRT_PPWR_Pos)
#define USB_OTG_HPRT_PPWR   USB_OTG_HPRT_PPWR_Msk
#define USB_OTG_HPRT_PTCTL_Pos   (13U)
#define USB_OTG_HPRT_PTCTL_Msk   (0xFU << USB_OTG_HPRT_PTCTL_Pos)
#define USB_OTG_HPRT_PTCTL   USB_OTG_HPRT_PTCTL_Msk
#define USB_OTG_HPRT_PTCTL_0   (0x1U << USB_OTG_HPRT_PTCTL_Pos)
#define USB_OTG_HPRT_PTCTL_1   (0x2U << USB_OTG_HPRT_PTCTL_Pos)
#define USB_OTG_HPRT_PTCTL_2   (0x4U << USB_OTG_HPRT_PTCTL_Pos)
#define USB_OTG_HPRT_PTCTL_3   (0x8U << USB_OTG_HPRT_PTCTL_Pos)
#define USB_OTG_HPRT_PSPD_Pos   (17U)
#define USB_OTG_HPRT_PSPD_Msk   (0x3U << USB_OTG_HPRT_PSPD_Pos)
#define USB_OTG_HPRT_PSPD   USB_OTG_HPRT_PSPD_Msk
#define USB_OTG_HPRT_PSPD_0   (0x1U << USB_OTG_HPRT_PSPD_Pos)
#define USB_OTG_HPRT_PSPD_1   (0x2U << USB_OTG_HPRT_PSPD_Pos)
#define USB_OTG_DOEPEACHMSK1_XFRCM_Pos   (0U)
#define USB_OTG_DOEPEACHMSK1_XFRCM_Msk   (0x1U << USB_OTG_DOEPEACHMSK1_XFRCM_Pos)
#define USB_OTG_DOEPEACHMSK1_XFRCM   USB_OTG_DOEPEACHMSK1_XFRCM_Msk
#define USB_OTG_DOEPEACHMSK1_EPDM_Pos   (1U)
#define USB_OTG_DOEPEACHMSK1_EPDM_Msk   (0x1U << USB_OTG_DOEPEACHMSK1_EPDM_Pos)
#define USB_OTG_DOEPEACHMSK1_EPDM   USB_OTG_DOEPEACHMSK1_EPDM_Msk
#define USB_OTG_DOEPEACHMSK1_TOM_Pos   (3U)
#define USB_OTG_DOEPEACHMSK1_TOM_Msk   (0x1U << USB_OTG_DOEPEACHMSK1_TOM_Pos)
#define USB_OTG_DOEPEACHMSK1_TOM   USB_OTG_DOEPEACHMSK1_TOM_Msk
#define USB_OTG_DOEPEACHMSK1_ITTXFEMSK_Pos   (4U)
#define USB_OTG_DOEPEACHMSK1_ITTXFEMSK_Msk   (0x1U << USB_OTG_DOEPEACHMSK1_ITTXFEMSK_Pos)
#define USB_OTG_DOEPEACHMSK1_ITTXFEMSK   USB_OTG_DOEPEACHMSK1_ITTXFEMSK_Msk
#define USB_OTG_DOEPEACHMSK1_INEPNMM_Pos   (5U)
#define USB_OTG_DOEPEACHMSK1_INEPNMM_Msk   (0x1U << USB_OTG_DOEPEACHMSK1_INEPNMM_Pos)
#define USB_OTG_DOEPEACHMSK1_INEPNMM   USB_OTG_DOEPEACHMSK1_INEPNMM_Msk
#define USB_OTG_DOEPEACHMSK1_INEPNEM_Pos   (6U)
#define USB_OTG_DOEPEACHMSK1_INEPNEM_Msk   (0x1U << USB_OTG_DOEPEACHMSK1_INEPNEM_Pos)
#define USB_OTG_DOEPEACHMSK1_INEPNEM   USB_OTG_DOEPEACHMSK1_INEPNEM_Msk
#define USB_OTG_DOEPEACHMSK1_TXFURM_Pos   (8U)
#define USB_OTG_DOEPEACHMSK1_TXFURM_Msk   (0x1U << USB_OTG_DOEPEACHMSK1_TXFURM_Pos)
#define USB_OTG_DOEPEACHMSK1_TXFURM   USB_OTG_DOEPEACHMSK1_TXFURM_Msk
#define USB_OTG_DOEPEACHMSK1_BIM_Pos   (9U)
#define USB_OTG_DOEPEACHMSK1_BIM_Msk   (0x1U << USB_OTG_DOEPEACHMSK1_BIM_Pos)
#define USB_OTG_DOEPEACHMSK1_BIM   USB_OTG_DOEPEACHMSK1_BIM_Msk
#define USB_OTG_DOEPEACHMSK1_BERRM_Pos   (12U)
#define USB_OTG_DOEPEACHMSK1_BERRM_Msk   (0x1U << USB_OTG_DOEPEACHMSK1_BERRM_Pos)
#define USB_OTG_DOEPEACHMSK1_BERRM   USB_OTG_DOEPEACHMSK1_BERRM_Msk
#define USB_OTG_DOEPEACHMSK1_NAKM_Pos   (13U)
#define USB_OTG_DOEPEACHMSK1_NAKM_Msk   (0x1U << USB_OTG_DOEPEACHMSK1_NAKM_Pos)
#define USB_OTG_DOEPEACHMSK1_NAKM   USB_OTG_DOEPEACHMSK1_NAKM_Msk
#define USB_OTG_DOEPEACHMSK1_NYETM_Pos   (14U)
#define USB_OTG_DOEPEACHMSK1_NYETM_Msk   (0x1U << USB_OTG_DOEPEACHMSK1_NYETM_Pos)
#define USB_OTG_DOEPEACHMSK1_NYETM   USB_OTG_DOEPEACHMSK1_NYETM_Msk
#define USB_OTG_HPTXFSIZ_PTXSA_Pos   (0U)
#define USB_OTG_HPTXFSIZ_PTXSA_Msk   (0xFFFFU << USB_OTG_HPTXFSIZ_PTXSA_Pos)
#define USB_OTG_HPTXFSIZ_PTXSA   USB_OTG_HPTXFSIZ_PTXSA_Msk
#define USB_OTG_HPTXFSIZ_PTXFD_Pos   (16U)
#define USB_OTG_HPTXFSIZ_PTXFD_Msk   (0xFFFFU << USB_OTG_HPTXFSIZ_PTXFD_Pos)
#define USB_OTG_HPTXFSIZ_PTXFD   USB_OTG_HPTXFSIZ_PTXFD_Msk
#define USB_OTG_DIEPCTL_MPSIZ_Pos   (0U)
#define USB_OTG_DIEPCTL_MPSIZ_Msk   (0x7FFU << USB_OTG_DIEPCTL_MPSIZ_Pos)
#define USB_OTG_DIEPCTL_MPSIZ   USB_OTG_DIEPCTL_MPSIZ_Msk
#define USB_OTG_DIEPCTL_USBAEP_Pos   (15U)
#define USB_OTG_DIEPCTL_USBAEP_Msk   (0x1U << USB_OTG_DIEPCTL_USBAEP_Pos)
#define USB_OTG_DIEPCTL_USBAEP   USB_OTG_DIEPCTL_USBAEP_Msk
#define USB_OTG_DIEPCTL_EONUM_DPID_Pos   (16U)
#define USB_OTG_DIEPCTL_EONUM_DPID_Msk   (0x1U << USB_OTG_DIEPCTL_EONUM_DPID_Pos)
#define USB_OTG_DIEPCTL_EONUM_DPID   USB_OTG_DIEPCTL_EONUM_DPID_Msk
#define USB_OTG_DIEPCTL_NAKSTS_Pos   (17U)
#define USB_OTG_DIEPCTL_NAKSTS_Msk   (0x1U << USB_OTG_DIEPCTL_NAKSTS_Pos)
#define USB_OTG_DIEPCTL_NAKSTS   USB_OTG_DIEPCTL_NAKSTS_Msk
#define USB_OTG_DIEPCTL_EPTYP_Pos   (18U)
#define USB_OTG_DIEPCTL_EPTYP_Msk   (0x3U << USB_OTG_DIEPCTL_EPTYP_Pos)
#define USB_OTG_DIEPCTL_EPTYP   USB_OTG_DIEPCTL_EPTYP_Msk
#define USB_OTG_DIEPCTL_EPTYP_0   (0x1U << USB_OTG_DIEPCTL_EPTYP_Pos)
#define USB_OTG_DIEPCTL_EPTYP_1   (0x2U << USB_OTG_DIEPCTL_EPTYP_Pos)
#define USB_OTG_DIEPCTL_STALL_Pos   (21U)
#define USB_OTG_DIEPCTL_STALL_Msk   (0x1U << USB_OTG_DIEPCTL_STALL_Pos)
#define USB_OTG_DIEPCTL_STALL   USB_OTG_DIEPCTL_STALL_Msk
#define USB_OTG_DIEPCTL_TXFNUM_Pos   (22U)
#define USB_OTG_DIEPCTL_TXFNUM_Msk   (0xFU << USB_OTG_DIEPCTL_TXFNUM_Pos)
#define USB_OTG_DIEPCTL_TXFNUM   USB_OTG_DIEPCTL_TXFNUM_Msk
#define USB_OTG_DIEPCTL_TXFNUM_0   (0x1U << USB_OTG_DIEPCTL_TXFNUM_Pos)
#define USB_OTG_DIEPCTL_TXFNUM_1   (0x2U << USB_OTG_DIEPCTL_TXFNUM_Pos)
#define USB_OTG_DIEPCTL_TXFNUM_2   (0x4U << USB_OTG_DIEPCTL_TXFNUM_Pos)
#define USB_OTG_DIEPCTL_TXFNUM_3   (0x8U << USB_OTG_DIEPCTL_TXFNUM_Pos)
#define USB_OTG_DIEPCTL_CNAK_Pos   (26U)
#define USB_OTG_DIEPCTL_CNAK_Msk   (0x1U << USB_OTG_DIEPCTL_CNAK_Pos)
#define USB_OTG_DIEPCTL_CNAK   USB_OTG_DIEPCTL_CNAK_Msk
#define USB_OTG_DIEPCTL_SNAK_Pos   (27U)
#define USB_OTG_DIEPCTL_SNAK_Msk   (0x1U << USB_OTG_DIEPCTL_SNAK_Pos)
#define USB_OTG_DIEPCTL_SNAK   USB_OTG_DIEPCTL_SNAK_Msk
#define USB_OTG_DIEPCTL_SD0PID_SEVNFRM_Pos   (28U)
#define USB_OTG_DIEPCTL_SD0PID_SEVNFRM_Msk   (0x1U << USB_OTG_DIEPCTL_SD0PID_SEVNFRM_Pos)
#define USB_OTG_DIEPCTL_SD0PID_SEVNFRM   USB_OTG_DIEPCTL_SD0PID_SEVNFRM_Msk
#define USB_OTG_DIEPCTL_SODDFRM_Pos   (29U)
#define USB_OTG_DIEPCTL_SODDFRM_Msk   (0x1U << USB_OTG_DIEPCTL_SODDFRM_Pos)
#define USB_OTG_DIEPCTL_SODDFRM   USB_OTG_DIEPCTL_SODDFRM_Msk
#define USB_OTG_DIEPCTL_EPDIS_Pos   (30U)
#define USB_OTG_DIEPCTL_EPDIS_Msk   (0x1U << USB_OTG_DIEPCTL_EPDIS_Pos)
#define USB_OTG_DIEPCTL_EPDIS   USB_OTG_DIEPCTL_EPDIS_Msk
#define USB_OTG_DIEPCTL_EPENA_Pos   (31U)
#define USB_OTG_DIEPCTL_EPENA_Msk   (0x1U << USB_OTG_DIEPCTL_EPENA_Pos)
#define USB_OTG_DIEPCTL_EPENA   USB_OTG_DIEPCTL_EPENA_Msk
#define USB_OTG_HCCHAR_MPSIZ_Pos   (0U)
#define USB_OTG_HCCHAR_MPSIZ_Msk   (0x7FFU << USB_OTG_HCCHAR_MPSIZ_Pos)
#define USB_OTG_HCCHAR_MPSIZ   USB_OTG_HCCHAR_MPSIZ_Msk
#define USB_OTG_HCCHAR_EPNUM_Pos   (11U)
#define USB_OTG_HCCHAR_EPNUM_Msk   (0xFU << USB_OTG_HCCHAR_EPNUM_Pos)
#define USB_OTG_HCCHAR_EPNUM   USB_OTG_HCCHAR_EPNUM_Msk
#define USB_OTG_HCCHAR_EPNUM_0   (0x1U << USB_OTG_HCCHAR_EPNUM_Pos)
#define USB_OTG_HCCHAR_EPNUM_1   (0x2U << USB_OTG_HCCHAR_EPNUM_Pos)
#define USB_OTG_HCCHAR_EPNUM_2   (0x4U << USB_OTG_HCCHAR_EPNUM_Pos)
#define USB_OTG_HCCHAR_EPNUM_3   (0x8U << USB_OTG_HCCHAR_EPNUM_Pos)
#define USB_OTG_HCCHAR_EPDIR_Pos   (15U)
#define USB_OTG_HCCHAR_EPDIR_Msk   (0x1U << USB_OTG_HCCHAR_EPDIR_Pos)
#define USB_OTG_HCCHAR_EPDIR   USB_OTG_HCCHAR_EPDIR_Msk
#define USB_OTG_HCCHAR_LSDEV_Pos   (17U)
#define USB_OTG_HCCHAR_LSDEV_Msk   (0x1U << USB_OTG_HCCHAR_LSDEV_Pos)
#define USB_OTG_HCCHAR_LSDEV   USB_OTG_HCCHAR_LSDEV_Msk
#define USB_OTG_HCCHAR_EPTYP_Pos   (18U)
#define USB_OTG_HCCHAR_EPTYP_Msk   (0x3U << USB_OTG_HCCHAR_EPTYP_Pos)
#define USB_OTG_HCCHAR_EPTYP   USB_OTG_HCCHAR_EPTYP_Msk
#define USB_OTG_HCCHAR_EPTYP_0   (0x1U << USB_OTG_HCCHAR_EPTYP_Pos)
#define USB_OTG_HCCHAR_EPTYP_1   (0x2U << USB_OTG_HCCHAR_EPTYP_Pos)
#define USB_OTG_HCCHAR_MC_Pos   (20U)
#define USB_OTG_HCCHAR_MC_Msk   (0x3U << USB_OTG_HCCHAR_MC_Pos)
#define USB_OTG_HCCHAR_MC   USB_OTG_HCCHAR_MC_Msk
#define USB_OTG_HCCHAR_MC_0   (0x1U << USB_OTG_HCCHAR_MC_Pos)
#define USB_OTG_HCCHAR_MC_1   (0x2U << USB_OTG_HCCHAR_MC_Pos)
#define USB_OTG_HCCHAR_DAD_Pos   (22U)
#define USB_OTG_HCCHAR_DAD_Msk   (0x7FU << USB_OTG_HCCHAR_DAD_Pos)
#define USB_OTG_HCCHAR_DAD   USB_OTG_HCCHAR_DAD_Msk
#define USB_OTG_HCCHAR_DAD_0   (0x01U << USB_OTG_HCCHAR_DAD_Pos)
#define USB_OTG_HCCHAR_DAD_1   (0x02U << USB_OTG_HCCHAR_DAD_Pos)
#define USB_OTG_HCCHAR_DAD_2   (0x04U << USB_OTG_HCCHAR_DAD_Pos)
#define USB_OTG_HCCHAR_DAD_3   (0x08U << USB_OTG_HCCHAR_DAD_Pos)
#define USB_OTG_HCCHAR_DAD_4   (0x10U << USB_OTG_HCCHAR_DAD_Pos)
#define USB_OTG_HCCHAR_DAD_5   (0x20U << USB_OTG_HCCHAR_DAD_Pos)
#define USB_OTG_HCCHAR_DAD_6   (0x40U << USB_OTG_HCCHAR_DAD_Pos)
#define USB_OTG_HCCHAR_ODDFRM_Pos   (29U)
#define USB_OTG_HCCHAR_ODDFRM_Msk   (0x1U << USB_OTG_HCCHAR_ODDFRM_Pos)
#define USB_OTG_HCCHAR_ODDFRM   USB_OTG_HCCHAR_ODDFRM_Msk
#define USB_OTG_HCCHAR_CHDIS_Pos   (30U)
#define USB_OTG_HCCHAR_CHDIS_Msk   (0x1U << USB_OTG_HCCHAR_CHDIS_Pos)
#define USB_OTG_HCCHAR_CHDIS   USB_OTG_HCCHAR_CHDIS_Msk
#define USB_OTG_HCCHAR_CHENA_Pos   (31U)
#define USB_OTG_HCCHAR_CHENA_Msk   (0x1U << USB_OTG_HCCHAR_CHENA_Pos)
#define USB_OTG_HCCHAR_CHENA   USB_OTG_HCCHAR_CHENA_Msk
#define USB_OTG_HCSPLT_PRTADDR_Pos   (0U)
#define USB_OTG_HCSPLT_PRTADDR_Msk   (0x7FU << USB_OTG_HCSPLT_PRTADDR_Pos)
#define USB_OTG_HCSPLT_PRTADDR   USB_OTG_HCSPLT_PRTADDR_Msk
#define USB_OTG_HCSPLT_PRTADDR_0   (0x01U << USB_OTG_HCSPLT_PRTADDR_Pos)
#define USB_OTG_HCSPLT_PRTADDR_1   (0x02U << USB_OTG_HCSPLT_PRTADDR_Pos)
#define USB_OTG_HCSPLT_PRTADDR_2   (0x04U << USB_OTG_HCSPLT_PRTADDR_Pos)
#define USB_OTG_HCSPLT_PRTADDR_3   (0x08U << USB_OTG_HCSPLT_PRTADDR_Pos)
#define USB_OTG_HCSPLT_PRTADDR_4   (0x10U << USB_OTG_HCSPLT_PRTADDR_Pos)
#define USB_OTG_HCSPLT_PRTADDR_5   (0x20U << USB_OTG_HCSPLT_PRTADDR_Pos)
#define USB_OTG_HCSPLT_PRTADDR_6   (0x40U << USB_OTG_HCSPLT_PRTADDR_Pos)
#define USB_OTG_HCSPLT_HUBADDR_Pos   (7U)
#define USB_OTG_HCSPLT_HUBADDR_Msk   (0x7FU << USB_OTG_HCSPLT_HUBADDR_Pos)
#define USB_OTG_HCSPLT_HUBADDR   USB_OTG_HCSPLT_HUBADDR_Msk
#define USB_OTG_HCSPLT_HUBADDR_0   (0x01U << USB_OTG_HCSPLT_HUBADDR_Pos)
#define USB_OTG_HCSPLT_HUBADDR_1   (0x02U << USB_OTG_HCSPLT_HUBADDR_Pos)
#define USB_OTG_HCSPLT_HUBADDR_2   (0x04U << USB_OTG_HCSPLT_HUBADDR_Pos)
#define USB_OTG_HCSPLT_HUBADDR_3   (0x08U << USB_OTG_HCSPLT_HUBADDR_Pos)
#define USB_OTG_HCSPLT_HUBADDR_4   (0x10U << USB_OTG_HCSPLT_HUBADDR_Pos)
#define USB_OTG_HCSPLT_HUBADDR_5   (0x20U << USB_OTG_HCSPLT_HUBADDR_Pos)
#define USB_OTG_HCSPLT_HUBADDR_6   (0x40U << USB_OTG_HCSPLT_HUBADDR_Pos)
#define USB_OTG_HCSPLT_XACTPOS_Pos   (14U)
#define USB_OTG_HCSPLT_XACTPOS_Msk   (0x3U << USB_OTG_HCSPLT_XACTPOS_Pos)
#define USB_OTG_HCSPLT_XACTPOS   USB_OTG_HCSPLT_XACTPOS_Msk
#define USB_OTG_HCSPLT_XACTPOS_0   (0x1U << USB_OTG_HCSPLT_XACTPOS_Pos)
#define USB_OTG_HCSPLT_XACTPOS_1   (0x2U << USB_OTG_HCSPLT_XACTPOS_Pos)
#define USB_OTG_HCSPLT_COMPLSPLT_Pos   (16U)
#define USB_OTG_HCSPLT_COMPLSPLT_Msk   (0x1U << USB_OTG_HCSPLT_COMPLSPLT_Pos)
#define USB_OTG_HCSPLT_COMPLSPLT   USB_OTG_HCSPLT_COMPLSPLT_Msk
#define USB_OTG_HCSPLT_SPLITEN_Pos   (31U)
#define USB_OTG_HCSPLT_SPLITEN_Msk   (0x1U << USB_OTG_HCSPLT_SPLITEN_Pos)
#define USB_OTG_HCSPLT_SPLITEN   USB_OTG_HCSPLT_SPLITEN_Msk
#define USB_OTG_HCINT_XFRC_Pos   (0U)
#define USB_OTG_HCINT_XFRC_Msk   (0x1U << USB_OTG_HCINT_XFRC_Pos)
#define USB_OTG_HCINT_XFRC   USB_OTG_HCINT_XFRC_Msk
#define USB_OTG_HCINT_CHH_Pos   (1U)
#define USB_OTG_HCINT_CHH_Msk   (0x1U << USB_OTG_HCINT_CHH_Pos)
#define USB_OTG_HCINT_CHH   USB_OTG_HCINT_CHH_Msk
#define USB_OTG_HCINT_AHBERR_Pos   (2U)
#define USB_OTG_HCINT_AHBERR_Msk   (0x1U << USB_OTG_HCINT_AHBERR_Pos)
#define USB_OTG_HCINT_AHBERR   USB_OTG_HCINT_AHBERR_Msk
#define USB_OTG_HCINT_STALL_Pos   (3U)
#define USB_OTG_HCINT_STALL_Msk   (0x1U << USB_OTG_HCINT_STALL_Pos)
#define USB_OTG_HCINT_STALL   USB_OTG_HCINT_STALL_Msk
#define USB_OTG_HCINT_NAK_Pos   (4U)
#define USB_OTG_HCINT_NAK_Msk   (0x1U << USB_OTG_HCINT_NAK_Pos)
#define USB_OTG_HCINT_NAK   USB_OTG_HCINT_NAK_Msk
#define USB_OTG_HCINT_ACK_Pos   (5U)
#define USB_OTG_HCINT_ACK_Msk   (0x1U << USB_OTG_HCINT_ACK_Pos)
#define USB_OTG_HCINT_ACK   USB_OTG_HCINT_ACK_Msk
#define USB_OTG_HCINT_NYET_Pos   (6U)
#define USB_OTG_HCINT_NYET_Msk   (0x1U << USB_OTG_HCINT_NYET_Pos)
#define USB_OTG_HCINT_NYET   USB_OTG_HCINT_NYET_Msk
#define USB_OTG_HCINT_TXERR_Pos   (7U)
#define USB_OTG_HCINT_TXERR_Msk   (0x1U << USB_OTG_HCINT_TXERR_Pos)
#define USB_OTG_HCINT_TXERR   USB_OTG_HCINT_TXERR_Msk
#define USB_OTG_HCINT_BBERR_Pos   (8U)
#define USB_OTG_HCINT_BBERR_Msk   (0x1U << USB_OTG_HCINT_BBERR_Pos)
#define USB_OTG_HCINT_BBERR   USB_OTG_HCINT_BBERR_Msk
#define USB_OTG_HCINT_FRMOR_Pos   (9U)
#define USB_OTG_HCINT_FRMOR_Msk   (0x1U << USB_OTG_HCINT_FRMOR_Pos)
#define USB_OTG_HCINT_FRMOR   USB_OTG_HCINT_FRMOR_Msk
#define USB_OTG_HCINT_DTERR_Pos   (10U)
#define USB_OTG_HCINT_DTERR_Msk   (0x1U << USB_OTG_HCINT_DTERR_Pos)
#define USB_OTG_HCINT_DTERR   USB_OTG_HCINT_DTERR_Msk
#define USB_OTG_DIEPINT_XFRC_Pos   (0U)
#define USB_OTG_DIEPINT_XFRC_Msk   (0x1U << USB_OTG_DIEPINT_XFRC_Pos)
#define USB_OTG_DIEPINT_XFRC   USB_OTG_DIEPINT_XFRC_Msk
#define USB_OTG_DIEPINT_EPDISD_Pos   (1U)
#define USB_OTG_DIEPINT_EPDISD_Msk   (0x1U << USB_OTG_DIEPINT_EPDISD_Pos)
#define USB_OTG_DIEPINT_EPDISD   USB_OTG_DIEPINT_EPDISD_Msk
#define USB_OTG_DIEPINT_TOC_Pos   (3U)
#define USB_OTG_DIEPINT_TOC_Msk   (0x1U << USB_OTG_DIEPINT_TOC_Pos)
#define USB_OTG_DIEPINT_TOC   USB_OTG_DIEPINT_TOC_Msk
#define USB_OTG_DIEPINT_ITTXFE_Pos   (4U)
#define USB_OTG_DIEPINT_ITTXFE_Msk   (0x1U << USB_OTG_DIEPINT_ITTXFE_Pos)
#define USB_OTG_DIEPINT_ITTXFE   USB_OTG_DIEPINT_ITTXFE_Msk
#define USB_OTG_DIEPINT_INEPNE_Pos   (6U)
#define USB_OTG_DIEPINT_INEPNE_Msk   (0x1U << USB_OTG_DIEPINT_INEPNE_Pos)
#define USB_OTG_DIEPINT_INEPNE   USB_OTG_DIEPINT_INEPNE_Msk
#define USB_OTG_DIEPINT_TXFE_Pos   (7U)
#define USB_OTG_DIEPINT_TXFE_Msk   (0x1U << USB_OTG_DIEPINT_TXFE_Pos)
#define USB_OTG_DIEPINT_TXFE   USB_OTG_DIEPINT_TXFE_Msk
#define USB_OTG_DIEPINT_TXFIFOUDRN_Pos   (8U)
#define USB_OTG_DIEPINT_TXFIFOUDRN_Msk   (0x1U << USB_OTG_DIEPINT_TXFIFOUDRN_Pos)
#define USB_OTG_DIEPINT_TXFIFOUDRN   USB_OTG_DIEPINT_TXFIFOUDRN_Msk
#define USB_OTG_DIEPINT_BNA_Pos   (9U)
#define USB_OTG_DIEPINT_BNA_Msk   (0x1U << USB_OTG_DIEPINT_BNA_Pos)
#define USB_OTG_DIEPINT_BNA   USB_OTG_DIEPINT_BNA_Msk
#define USB_OTG_DIEPINT_PKTDRPSTS_Pos   (11U)
#define USB_OTG_DIEPINT_PKTDRPSTS_Msk   (0x1U << USB_OTG_DIEPINT_PKTDRPSTS_Pos)
#define USB_OTG_DIEPINT_PKTDRPSTS   USB_OTG_DIEPINT_PKTDRPSTS_Msk
#define USB_OTG_DIEPINT_BERR_Pos   (12U)
#define USB_OTG_DIEPINT_BERR_Msk   (0x1U << USB_OTG_DIEPINT_BERR_Pos)
#define USB_OTG_DIEPINT_BERR   USB_OTG_DIEPINT_BERR_Msk
#define USB_OTG_DIEPINT_NAK_Pos   (13U)
#define USB_OTG_DIEPINT_NAK_Msk   (0x1U << USB_OTG_DIEPINT_NAK_Pos)
#define USB_OTG_DIEPINT_NAK   USB_OTG_DIEPINT_NAK_Msk
#define USB_OTG_HCINTMSK_XFRCM_Pos   (0U)
#define USB_OTG_HCINTMSK_XFRCM_Msk   (0x1U << USB_OTG_HCINTMSK_XFRCM_Pos)
#define USB_OTG_HCINTMSK_XFRCM   USB_OTG_HCINTMSK_XFRCM_Msk
#define USB_OTG_HCINTMSK_CHHM_Pos   (1U)
#define USB_OTG_HCINTMSK_CHHM_Msk   (0x1U << USB_OTG_HCINTMSK_CHHM_Pos)
#define USB_OTG_HCINTMSK_CHHM   USB_OTG_HCINTMSK_CHHM_Msk
#define USB_OTG_HCINTMSK_AHBERR_Pos   (2U)
#define USB_OTG_HCINTMSK_AHBERR_Msk   (0x1U << USB_OTG_HCINTMSK_AHBERR_Pos)
#define USB_OTG_HCINTMSK_AHBERR   USB_OTG_HCINTMSK_AHBERR_Msk
#define USB_OTG_HCINTMSK_STALLM_Pos   (3U)
#define USB_OTG_HCINTMSK_STALLM_Msk   (0x1U << USB_OTG_HCINTMSK_STALLM_Pos)
#define USB_OTG_HCINTMSK_STALLM   USB_OTG_HCINTMSK_STALLM_Msk
#define USB_OTG_HCINTMSK_NAKM_Pos   (4U)
#define USB_OTG_HCINTMSK_NAKM_Msk   (0x1U << USB_OTG_HCINTMSK_NAKM_Pos)
#define USB_OTG_HCINTMSK_NAKM   USB_OTG_HCINTMSK_NAKM_Msk
#define USB_OTG_HCINTMSK_ACKM_Pos   (5U)
#define USB_OTG_HCINTMSK_ACKM_Msk   (0x1U << USB_OTG_HCINTMSK_ACKM_Pos)
#define USB_OTG_HCINTMSK_ACKM   USB_OTG_HCINTMSK_ACKM_Msk
#define USB_OTG_HCINTMSK_NYET_Pos   (6U)
#define USB_OTG_HCINTMSK_NYET_Msk   (0x1U << USB_OTG_HCINTMSK_NYET_Pos)
#define USB_OTG_HCINTMSK_NYET   USB_OTG_HCINTMSK_NYET_Msk
#define USB_OTG_HCINTMSK_TXERRM_Pos   (7U)
#define USB_OTG_HCINTMSK_TXERRM_Msk   (0x1U << USB_OTG_HCINTMSK_TXERRM_Pos)
#define USB_OTG_HCINTMSK_TXERRM   USB_OTG_HCINTMSK_TXERRM_Msk
#define USB_OTG_HCINTMSK_BBERRM_Pos   (8U)
#define USB_OTG_HCINTMSK_BBERRM_Msk   (0x1U << USB_OTG_HCINTMSK_BBERRM_Pos)
#define USB_OTG_HCINTMSK_BBERRM   USB_OTG_HCINTMSK_BBERRM_Msk
#define USB_OTG_HCINTMSK_FRMORM_Pos   (9U)
#define USB_OTG_HCINTMSK_FRMORM_Msk   (0x1U << USB_OTG_HCINTMSK_FRMORM_Pos)
#define USB_OTG_HCINTMSK_FRMORM   USB_OTG_HCINTMSK_FRMORM_Msk
#define USB_OTG_HCINTMSK_DTERRM_Pos   (10U)
#define USB_OTG_HCINTMSK_DTERRM_Msk   (0x1U << USB_OTG_HCINTMSK_DTERRM_Pos)
#define USB_OTG_HCINTMSK_DTERRM   USB_OTG_HCINTMSK_DTERRM_Msk
#define USB_OTG_DIEPTSIZ_XFRSIZ_Pos   (0U)
#define USB_OTG_DIEPTSIZ_XFRSIZ_Msk   (0x7FFFFU << USB_OTG_DIEPTSIZ_XFRSIZ_Pos)
#define USB_OTG_DIEPTSIZ_XFRSIZ   USB_OTG_DIEPTSIZ_XFRSIZ_Msk
#define USB_OTG_DIEPTSIZ_PKTCNT_Pos   (19U)
#define USB_OTG_DIEPTSIZ_PKTCNT_Msk   (0x3FFU << USB_OTG_DIEPTSIZ_PKTCNT_Pos)
#define USB_OTG_DIEPTSIZ_PKTCNT   USB_OTG_DIEPTSIZ_PKTCNT_Msk
#define USB_OTG_DIEPTSIZ_MULCNT_Pos   (29U)
#define USB_OTG_DIEPTSIZ_MULCNT_Msk   (0x3U << USB_OTG_DIEPTSIZ_MULCNT_Pos)
#define USB_OTG_DIEPTSIZ_MULCNT   USB_OTG_DIEPTSIZ_MULCNT_Msk
#define USB_OTG_HCTSIZ_XFRSIZ_Pos   (0U)
#define USB_OTG_HCTSIZ_XFRSIZ_Msk   (0x7FFFFU << USB_OTG_HCTSIZ_XFRSIZ_Pos)
#define USB_OTG_HCTSIZ_XFRSIZ   USB_OTG_HCTSIZ_XFRSIZ_Msk
#define USB_OTG_HCTSIZ_PKTCNT_Pos   (19U)
#define USB_OTG_HCTSIZ_PKTCNT_Msk   (0x3FFU << USB_OTG_HCTSIZ_PKTCNT_Pos)
#define USB_OTG_HCTSIZ_PKTCNT   USB_OTG_HCTSIZ_PKTCNT_Msk
#define USB_OTG_HCTSIZ_DOPING_Pos   (31U)
#define USB_OTG_HCTSIZ_DOPING_Msk   (0x1U << USB_OTG_HCTSIZ_DOPING_Pos)
#define USB_OTG_HCTSIZ_DOPING   USB_OTG_HCTSIZ_DOPING_Msk
#define USB_OTG_HCTSIZ_DPID_Pos   (29U)
#define USB_OTG_HCTSIZ_DPID_Msk   (0x3U << USB_OTG_HCTSIZ_DPID_Pos)
#define USB_OTG_HCTSIZ_DPID   USB_OTG_HCTSIZ_DPID_Msk
#define USB_OTG_HCTSIZ_DPID_0   (0x1U << USB_OTG_HCTSIZ_DPID_Pos)
#define USB_OTG_HCTSIZ_DPID_1   (0x2U << USB_OTG_HCTSIZ_DPID_Pos)
#define USB_OTG_DIEPDMA_DMAADDR_Pos   (0U)
#define USB_OTG_DIEPDMA_DMAADDR_Msk   (0xFFFFFFFFU << USB_OTG_DIEPDMA_DMAADDR_Pos)
#define USB_OTG_DIEPDMA_DMAADDR   USB_OTG_DIEPDMA_DMAADDR_Msk
#define USB_OTG_HCDMA_DMAADDR_Pos   (0U)
#define USB_OTG_HCDMA_DMAADDR_Msk   (0xFFFFFFFFU << USB_OTG_HCDMA_DMAADDR_Pos)
#define USB_OTG_HCDMA_DMAADDR   USB_OTG_HCDMA_DMAADDR_Msk
#define USB_OTG_DTXFSTS_INEPTFSAV_Pos   (0U)
#define USB_OTG_DTXFSTS_INEPTFSAV_Msk   (0xFFFFU << USB_OTG_DTXFSTS_INEPTFSAV_Pos)
#define USB_OTG_DTXFSTS_INEPTFSAV   USB_OTG_DTXFSTS_INEPTFSAV_Msk
#define USB_OTG_DIEPTXF_INEPTXSA_Pos   (0U)
#define USB_OTG_DIEPTXF_INEPTXSA_Msk   (0xFFFFU << USB_OTG_DIEPTXF_INEPTXSA_Pos)
#define USB_OTG_DIEPTXF_INEPTXSA   USB_OTG_DIEPTXF_INEPTXSA_Msk
#define USB_OTG_DIEPTXF_INEPTXFD_Pos   (16U)
#define USB_OTG_DIEPTXF_INEPTXFD_Msk   (0xFFFFU << USB_OTG_DIEPTXF_INEPTXFD_Pos)
#define USB_OTG_DIEPTXF_INEPTXFD   USB_OTG_DIEPTXF_INEPTXFD_Msk
#define USB_OTG_DOEPCTL_MPSIZ_Pos   (0U)
#define USB_OTG_DOEPCTL_MPSIZ_Msk   (0x7FFU << USB_OTG_DOEPCTL_MPSIZ_Pos)
#define USB_OTG_DOEPCTL_MPSIZ   USB_OTG_DOEPCTL_MPSIZ_Msk
#define USB_OTG_DOEPCTL_USBAEP_Pos   (15U)
#define USB_OTG_DOEPCTL_USBAEP_Msk   (0x1U << USB_OTG_DOEPCTL_USBAEP_Pos)
#define USB_OTG_DOEPCTL_USBAEP   USB_OTG_DOEPCTL_USBAEP_Msk
#define USB_OTG_DOEPCTL_NAKSTS_Pos   (17U)
#define USB_OTG_DOEPCTL_NAKSTS_Msk   (0x1U << USB_OTG_DOEPCTL_NAKSTS_Pos)
#define USB_OTG_DOEPCTL_NAKSTS   USB_OTG_DOEPCTL_NAKSTS_Msk
#define USB_OTG_DOEPCTL_SD0PID_SEVNFRM_Pos   (28U)
#define USB_OTG_DOEPCTL_SD0PID_SEVNFRM_Msk   (0x1U << USB_OTG_DOEPCTL_SD0PID_SEVNFRM_Pos)
#define USB_OTG_DOEPCTL_SD0PID_SEVNFRM   USB_OTG_DOEPCTL_SD0PID_SEVNFRM_Msk
#define USB_OTG_DOEPCTL_SODDFRM_Pos   (29U)
#define USB_OTG_DOEPCTL_SODDFRM_Msk   (0x1U << USB_OTG_DOEPCTL_SODDFRM_Pos)
#define USB_OTG_DOEPCTL_SODDFRM   USB_OTG_DOEPCTL_SODDFRM_Msk
#define USB_OTG_DOEPCTL_EPTYP_Pos   (18U)
#define USB_OTG_DOEPCTL_EPTYP_Msk   (0x3U << USB_OTG_DOEPCTL_EPTYP_Pos)
#define USB_OTG_DOEPCTL_EPTYP   USB_OTG_DOEPCTL_EPTYP_Msk
#define USB_OTG_DOEPCTL_EPTYP_0   (0x1U << USB_OTG_DOEPCTL_EPTYP_Pos)
#define USB_OTG_DOEPCTL_EPTYP_1   (0x2U << USB_OTG_DOEPCTL_EPTYP_Pos)
#define USB_OTG_DOEPCTL_SNPM_Pos   (20U)
#define USB_OTG_DOEPCTL_SNPM_Msk   (0x1U << USB_OTG_DOEPCTL_SNPM_Pos)
#define USB_OTG_DOEPCTL_SNPM   USB_OTG_DOEPCTL_SNPM_Msk
#define USB_OTG_DOEPCTL_STALL_Pos   (21U)
#define USB_OTG_DOEPCTL_STALL_Msk   (0x1U << USB_OTG_DOEPCTL_STALL_Pos)
#define USB_OTG_DOEPCTL_STALL   USB_OTG_DOEPCTL_STALL_Msk
#define USB_OTG_DOEPCTL_CNAK_Pos   (26U)
#define USB_OTG_DOEPCTL_CNAK_Msk   (0x1U << USB_OTG_DOEPCTL_CNAK_Pos)
#define USB_OTG_DOEPCTL_CNAK   USB_OTG_DOEPCTL_CNAK_Msk
#define USB_OTG_DOEPCTL_SNAK_Pos   (27U)
#define USB_OTG_DOEPCTL_SNAK_Msk   (0x1U << USB_OTG_DOEPCTL_SNAK_Pos)
#define USB_OTG_DOEPCTL_SNAK   USB_OTG_DOEPCTL_SNAK_Msk
#define USB_OTG_DOEPCTL_EPDIS_Pos   (30U)
#define USB_OTG_DOEPCTL_EPDIS_Msk   (0x1U << USB_OTG_DOEPCTL_EPDIS_Pos)
#define USB_OTG_DOEPCTL_EPDIS   USB_OTG_DOEPCTL_EPDIS_Msk
#define USB_OTG_DOEPCTL_EPENA_Pos   (31U)
#define USB_OTG_DOEPCTL_EPENA_Msk   (0x1U << USB_OTG_DOEPCTL_EPENA_Pos)
#define USB_OTG_DOEPCTL_EPENA   USB_OTG_DOEPCTL_EPENA_Msk
#define USB_OTG_DOEPINT_XFRC_Pos   (0U)
#define USB_OTG_DOEPINT_XFRC_Msk   (0x1U << USB_OTG_DOEPINT_XFRC_Pos)
#define USB_OTG_DOEPINT_XFRC   USB_OTG_DOEPINT_XFRC_Msk
#define USB_OTG_DOEPINT_EPDISD_Pos   (1U)
#define USB_OTG_DOEPINT_EPDISD_Msk   (0x1U << USB_OTG_DOEPINT_EPDISD_Pos)
#define USB_OTG_DOEPINT_EPDISD   USB_OTG_DOEPINT_EPDISD_Msk
#define USB_OTG_DOEPINT_STUP_Pos   (3U)
#define USB_OTG_DOEPINT_STUP_Msk   (0x1U << USB_OTG_DOEPINT_STUP_Pos)
#define USB_OTG_DOEPINT_STUP   USB_OTG_DOEPINT_STUP_Msk
#define USB_OTG_DOEPINT_OTEPDIS_Pos   (4U)
#define USB_OTG_DOEPINT_OTEPDIS_Msk   (0x1U << USB_OTG_DOEPINT_OTEPDIS_Pos)
#define USB_OTG_DOEPINT_OTEPDIS   USB_OTG_DOEPINT_OTEPDIS_Msk
#define USB_OTG_DOEPINT_B2BSTUP_Pos   (6U)
#define USB_OTG_DOEPINT_B2BSTUP_Msk   (0x1U << USB_OTG_DOEPINT_B2BSTUP_Pos)
#define USB_OTG_DOEPINT_B2BSTUP   USB_OTG_DOEPINT_B2BSTUP_Msk
#define USB_OTG_DOEPINT_NYET_Pos   (14U)
#define USB_OTG_DOEPINT_NYET_Msk   (0x1U << USB_OTG_DOEPINT_NYET_Pos)
#define USB_OTG_DOEPINT_NYET   USB_OTG_DOEPINT_NYET_Msk
#define USB_OTG_DOEPTSIZ_XFRSIZ_Pos   (0U)
#define USB_OTG_DOEPTSIZ_XFRSIZ_Msk   (0x7FFFFU << USB_OTG_DOEPTSIZ_XFRSIZ_Pos)
#define USB_OTG_DOEPTSIZ_XFRSIZ   USB_OTG_DOEPTSIZ_XFRSIZ_Msk
#define USB_OTG_DOEPTSIZ_PKTCNT_Pos   (19U)
#define USB_OTG_DOEPTSIZ_PKTCNT_Msk   (0x3FFU << USB_OTG_DOEPTSIZ_PKTCNT_Pos)
#define USB_OTG_DOEPTSIZ_PKTCNT   USB_OTG_DOEPTSIZ_PKTCNT_Msk
#define USB_OTG_DOEPTSIZ_STUPCNT_Pos   (29U)
#define USB_OTG_DOEPTSIZ_STUPCNT_Msk   (0x3U << USB_OTG_DOEPTSIZ_STUPCNT_Pos)
#define USB_OTG_DOEPTSIZ_STUPCNT   USB_OTG_DOEPTSIZ_STUPCNT_Msk
#define USB_OTG_DOEPTSIZ_STUPCNT_0   (0x1U << USB_OTG_DOEPTSIZ_STUPCNT_Pos)
#define USB_OTG_DOEPTSIZ_STUPCNT_1   (0x2U << USB_OTG_DOEPTSIZ_STUPCNT_Pos)
#define USB_OTG_PCGCCTL_STOPCLK_Pos   (0U)
#define USB_OTG_PCGCCTL_STOPCLK_Msk   (0x1U << USB_OTG_PCGCCTL_STOPCLK_Pos)
#define USB_OTG_PCGCCTL_STOPCLK   USB_OTG_PCGCCTL_STOPCLK_Msk
#define USB_OTG_PCGCCTL_GATECLK_Pos   (1U)
#define USB_OTG_PCGCCTL_GATECLK_Msk   (0x1U << USB_OTG_PCGCCTL_GATECLK_Pos)
#define USB_OTG_PCGCCTL_GATECLK   USB_OTG_PCGCCTL_GATECLK_Msk
#define USB_OTG_PCGCCTL_PHYSUSP_Pos   (4U)
#define USB_OTG_PCGCCTL_PHYSUSP_Msk   (0x1U << USB_OTG_PCGCCTL_PHYSUSP_Pos)
#define USB_OTG_PCGCCTL_PHYSUSP   USB_OTG_PCGCCTL_PHYSUSP_Msk
#define USART_CR1_UE_Pos   (0U)
#define USART_CR1_UE_Msk   (0x1UL << USART_CR1_UE_Pos)
#define USART_CR1_UE   USART_CR1_UE_Msk
#define USART_CR1_UESM_Pos   (1U)
#define USART_CR1_UESM_Msk   (0x1UL << USART_CR1_UESM_Pos)
#define USART_CR1_UESM   USART_CR1_UESM_Msk
#define USART_CR1_RE_Pos   (2U)
#define USART_CR1_RE_Msk   (0x1UL << USART_CR1_RE_Pos)
#define USART_CR1_RE   USART_CR1_RE_Msk
#define USART_CR1_TE_Pos   (3U)
#define USART_CR1_TE_Msk   (0x1UL << USART_CR1_TE_Pos)
#define USART_CR1_TE   USART_CR1_TE_Msk
#define USART_CR1_IDLEIE_Pos   (4U)
#define USART_CR1_IDLEIE_Msk   (0x1UL << USART_CR1_IDLEIE_Pos)
#define USART_CR1_IDLEIE   USART_CR1_IDLEIE_Msk
#define USART_CR1_RXNEIE_Pos   (5U)
#define USART_CR1_RXNEIE_Msk   (0x1UL << USART_CR1_RXNEIE_Pos)
#define USART_CR1_RXNEIE   USART_CR1_RXNEIE_Msk
#define USART_CR1_RXNEIE_RXFNEIE_Pos   USART_CR1_RXNEIE_Pos
#define USART_CR1_RXNEIE_RXFNEIE_Msk   USART_CR1_RXNEIE_Msk
#define USART_CR1_RXNEIE_RXFNEIE   USART_CR1_RXNEIE_Msk
#define USART_CR1_TCIE_Pos   (6U)
#define USART_CR1_TCIE_Msk   (0x1UL << USART_CR1_TCIE_Pos)
#define USART_CR1_TCIE   USART_CR1_TCIE_Msk
#define USART_CR1_TXEIE_Pos   (7U)
#define USART_CR1_TXEIE_Msk   (0x1UL << USART_CR1_TXEIE_Pos)
#define USART_CR1_TXEIE   USART_CR1_TXEIE_Msk
#define USART_CR1_TXEIE_TXFNFIE_Pos   (7U)
#define USART_CR1_TXEIE_TXFNFIE_Msk   (0x1UL << USART_CR1_TXEIE_Pos)
#define USART_CR1_TXEIE_TXFNFIE   USART_CR1_TXEIE
#define USART_CR1_PEIE_Pos   (8U)
#define USART_CR1_PEIE_Msk   (0x1UL << USART_CR1_PEIE_Pos)
#define USART_CR1_PEIE   USART_CR1_PEIE_Msk
#define USART_CR1_PS_Pos   (9U)
#define USART_CR1_PS_Msk   (0x1UL << USART_CR1_PS_Pos)
#define USART_CR1_PS   USART_CR1_PS_Msk
#define USART_CR1_PCE_Pos   (10U)
#define USART_CR1_PCE_Msk   (0x1UL << USART_CR1_PCE_Pos)
#define USART_CR1_PCE   USART_CR1_PCE_Msk
#define USART_CR1_WAKE_Pos   (11U)
#define USART_CR1_WAKE_Msk   (0x1UL << USART_CR1_WAKE_Pos)
#define USART_CR1_WAKE   USART_CR1_WAKE_Msk
#define USART_CR1_M_Pos   (12U)
#define USART_CR1_M_Msk   (0x10001UL << USART_CR1_M_Pos)
#define USART_CR1_M   USART_CR1_M_Msk
#define USART_CR1_M0_Pos   (12U)
#define USART_CR1_M0_Msk   (0x1UL << USART_CR1_M0_Pos)
#define USART_CR1_M0   USART_CR1_M0_Msk
#define USART_CR1_MME_Pos   (13U)
#define USART_CR1_MME_Msk   (0x1UL << USART_CR1_MME_Pos)
#define USART_CR1_MME   USART_CR1_MME_Msk
#define USART_CR1_CMIE_Pos   (14U)
#define USART_CR1_CMIE_Msk   (0x1UL << USART_CR1_CMIE_Pos)
#define USART_CR1_CMIE   USART_CR1_CMIE_Msk
#define USART_CR1_OVER8_Pos   (15U)
#define USART_CR1_OVER8_Msk   (0x1UL << USART_CR1_OVER8_Pos)
#define USART_CR1_OVER8   USART_CR1_OVER8_Msk
#define USART_CR1_DEDT_Pos   (16U)
#define USART_CR1_DEDT_Msk   (0x1FUL << USART_CR1_DEDT_Pos)
#define USART_CR1_DEDT   USART_CR1_DEDT_Msk
#define USART_CR1_DEDT_0   (0x01UL << USART_CR1_DEDT_Pos)
#define USART_CR1_DEDT_1   (0x02UL << USART_CR1_DEDT_Pos)
#define USART_CR1_DEDT_2   (0x04UL << USART_CR1_DEDT_Pos)
#define USART_CR1_DEDT_3   (0x08UL << USART_CR1_DEDT_Pos)
#define USART_CR1_DEDT_4   (0x10UL << USART_CR1_DEDT_Pos)
#define USART_CR1_DEAT_Pos   (21U)
#define USART_CR1_DEAT_Msk   (0x1FUL << USART_CR1_DEAT_Pos)
#define USART_CR1_DEAT   USART_CR1_DEAT_Msk
#define USART_CR1_DEAT_0   (0x01UL << USART_CR1_DEAT_Pos)
#define USART_CR1_DEAT_1   (0x02UL << USART_CR1_DEAT_Pos)
#define USART_CR1_DEAT_2   (0x04UL << USART_CR1_DEAT_Pos)
#define USART_CR1_DEAT_3   (0x08UL << USART_CR1_DEAT_Pos)
#define USART_CR1_DEAT_4   (0x10UL << USART_CR1_DEAT_Pos)
#define USART_CR1_RTOIE_Pos   (26U)
#define USART_CR1_RTOIE_Msk   (0x1UL << USART_CR1_RTOIE_Pos)
#define USART_CR1_RTOIE   USART_CR1_RTOIE_Msk
#define USART_CR1_EOBIE_Pos   (27U)
#define USART_CR1_EOBIE_Msk   (0x1UL << USART_CR1_EOBIE_Pos)
#define USART_CR1_EOBIE   USART_CR1_EOBIE_Msk
#define USART_CR1_M1_Pos   (28U)
#define USART_CR1_M1_Msk   (0x1UL << USART_CR1_M1_Pos)
#define USART_CR1_M1   USART_CR1_M1_Msk
#define USART_CR1_FIFOEN_Pos   (29U)
#define USART_CR1_FIFOEN_Msk   (0x1UL << USART_CR1_FIFOEN_Pos)
#define USART_CR1_FIFOEN   USART_CR1_FIFOEN_Msk
#define USART_CR1_TXFEIE_Pos   (30U)
#define USART_CR1_TXFEIE_Msk   (0x1UL << USART_CR1_TXFEIE_Pos)
#define USART_CR1_TXFEIE   USART_CR1_TXFEIE_Msk
#define USART_CR1_RXFFIE_Pos   (31U)
#define USART_CR1_RXFFIE_Msk   (0x1UL << USART_CR1_RXFFIE_Pos)
#define USART_CR1_RXFFIE   USART_CR1_RXFFIE_Msk
#define USART_CR2_SLVEN_Pos   (0U)
#define USART_CR2_SLVEN_Msk   (0x1UL << USART_CR2_SLVEN_Pos)
#define USART_CR2_SLVEN   USART_CR2_SLVEN_Msk
#define USART_CR2_DIS_NSS_Pos   (3U)
#define USART_CR2_DIS_NSS_Msk   (0x1UL << USART_CR2_DIS_NSS_Pos)
#define USART_CR2_DIS_NSS   USART_CR2_DIS_NSS_Msk
#define USART_CR2_ADDM7_Pos   (4U)
#define USART_CR2_ADDM7_Msk   (0x1UL << USART_CR2_ADDM7_Pos)
#define USART_CR2_ADDM7   USART_CR2_ADDM7_Msk
#define USART_CR2_LBDL_Pos   (5U)
#define USART_CR2_LBDL_Msk   (0x1UL << USART_CR2_LBDL_Pos)
#define USART_CR2_LBDL   USART_CR2_LBDL_Msk
#define USART_CR2_LBDIE_Pos   (6U)
#define USART_CR2_LBDIE_Msk   (0x1UL << USART_CR2_LBDIE_Pos)
#define USART_CR2_LBDIE   USART_CR2_LBDIE_Msk
#define USART_CR2_LBCL_Pos   (8U)
#define USART_CR2_LBCL_Msk   (0x1UL << USART_CR2_LBCL_Pos)
#define USART_CR2_LBCL   USART_CR2_LBCL_Msk
#define USART_CR2_CPHA_Pos   (9U)
#define USART_CR2_CPHA_Msk   (0x1UL << USART_CR2_CPHA_Pos)
#define USART_CR2_CPHA   USART_CR2_CPHA_Msk
#define USART_CR2_CPOL_Pos   (10U)
#define USART_CR2_CPOL_Msk   (0x1UL << USART_CR2_CPOL_Pos)
#define USART_CR2_CPOL   USART_CR2_CPOL_Msk
#define USART_CR2_CLKEN_Pos   (11U)
#define USART_CR2_CLKEN_Msk   (0x1UL << USART_CR2_CLKEN_Pos)
#define USART_CR2_CLKEN   USART_CR2_CLKEN_Msk
#define USART_CR2_STOP_Pos   (12U)
#define USART_CR2_STOP_Msk   (0x3UL << USART_CR2_STOP_Pos)
#define USART_CR2_STOP   USART_CR2_STOP_Msk
#define USART_CR2_STOP_0   (0x1UL << USART_CR2_STOP_Pos)
#define USART_CR2_STOP_1   (0x2UL << USART_CR2_STOP_Pos)
#define USART_CR2_LINEN_Pos   (14U)
#define USART_CR2_LINEN_Msk   (0x1UL << USART_CR2_LINEN_Pos)
#define USART_CR2_LINEN   USART_CR2_LINEN_Msk
#define USART_CR2_SWAP_Pos   (15U)
#define USART_CR2_SWAP_Msk   (0x1UL << USART_CR2_SWAP_Pos)
#define USART_CR2_SWAP   USART_CR2_SWAP_Msk
#define USART_CR2_RXINV_Pos   (16U)
#define USART_CR2_RXINV_Msk   (0x1UL << USART_CR2_RXINV_Pos)
#define USART_CR2_RXINV   USART_CR2_RXINV_Msk
#define USART_CR2_TXINV_Pos   (17U)
#define USART_CR2_TXINV_Msk   (0x1UL << USART_CR2_TXINV_Pos)
#define USART_CR2_TXINV   USART_CR2_TXINV_Msk
#define USART_CR2_DATAINV_Pos   (18U)
#define USART_CR2_DATAINV_Msk   (0x1UL << USART_CR2_DATAINV_Pos)
#define USART_CR2_DATAINV   USART_CR2_DATAINV_Msk
#define USART_CR2_MSBFIRST_Pos   (19U)
#define USART_CR2_MSBFIRST_Msk   (0x1UL << USART_CR2_MSBFIRST_Pos)
#define USART_CR2_MSBFIRST   USART_CR2_MSBFIRST_Msk
#define USART_CR2_ABREN_Pos   (20U)
#define USART_CR2_ABREN_Msk   (0x1UL << USART_CR2_ABREN_Pos)
#define USART_CR2_ABREN   USART_CR2_ABREN_Msk
#define USART_CR2_ABRMODE_Pos   (21U)
#define USART_CR2_ABRMODE_Msk   (0x3UL << USART_CR2_ABRMODE_Pos)
#define USART_CR2_ABRMODE   USART_CR2_ABRMODE_Msk
#define USART_CR2_ABRMODE_0   (0x1UL << USART_CR2_ABRMODE_Pos)
#define USART_CR2_ABRMODE_1   (0x2UL << USART_CR2_ABRMODE_Pos)
#define USART_CR2_RTOEN_Pos   (23U)
#define USART_CR2_RTOEN_Msk   (0x1UL << USART_CR2_RTOEN_Pos)
#define USART_CR2_RTOEN   USART_CR2_RTOEN_Msk
#define USART_CR2_ADD_Pos   (24U)
#define USART_CR2_ADD_Msk   (0xFFUL << USART_CR2_ADD_Pos)
#define USART_CR2_ADD   USART_CR2_ADD_Msk
#define USART_CR3_EIE_Pos   (0U)
#define USART_CR3_EIE_Msk   (0x1UL << USART_CR3_EIE_Pos)
#define USART_CR3_EIE   USART_CR3_EIE_Msk
#define USART_CR3_IREN_Pos   (1U)
#define USART_CR3_IREN_Msk   (0x1UL << USART_CR3_IREN_Pos)
#define USART_CR3_IREN   USART_CR3_IREN_Msk
#define USART_CR3_IRLP_Pos   (2U)
#define USART_CR3_IRLP_Msk   (0x1UL << USART_CR3_IRLP_Pos)
#define USART_CR3_IRLP   USART_CR3_IRLP_Msk
#define USART_CR3_HDSEL_Pos   (3U)
#define USART_CR3_HDSEL_Msk   (0x1UL << USART_CR3_HDSEL_Pos)
#define USART_CR3_HDSEL   USART_CR3_HDSEL_Msk
#define USART_CR3_NACK_Pos   (4U)
#define USART_CR3_NACK_Msk   (0x1UL << USART_CR3_NACK_Pos)
#define USART_CR3_NACK   USART_CR3_NACK_Msk
#define USART_CR3_SCEN_Pos   (5U)
#define USART_CR3_SCEN_Msk   (0x1UL << USART_CR3_SCEN_Pos)
#define USART_CR3_SCEN   USART_CR3_SCEN_Msk
#define USART_CR3_DMAR_Pos   (6U)
#define USART_CR3_DMAR_Msk   (0x1UL << USART_CR3_DMAR_Pos)
#define USART_CR3_DMAR   USART_CR3_DMAR_Msk
#define USART_CR3_DMAT_Pos   (7U)
#define USART_CR3_DMAT_Msk   (0x1UL << USART_CR3_DMAT_Pos)
#define USART_CR3_DMAT   USART_CR3_DMAT_Msk
#define USART_CR3_RTSE_Pos   (8U)
#define USART_CR3_RTSE_Msk   (0x1UL << USART_CR3_RTSE_Pos)
#define USART_CR3_RTSE   USART_CR3_RTSE_Msk
#define USART_CR3_CTSE_Pos   (9U)
#define USART_CR3_CTSE_Msk   (0x1UL << USART_CR3_CTSE_Pos)
#define USART_CR3_CTSE   USART_CR3_CTSE_Msk
#define USART_CR3_CTSIE_Pos   (10U)
#define USART_CR3_CTSIE_Msk   (0x1UL << USART_CR3_CTSIE_Pos)
#define USART_CR3_CTSIE   USART_CR3_CTSIE_Msk
#define USART_CR3_ONEBIT_Pos   (11U)
#define USART_CR3_ONEBIT_Msk   (0x1UL << USART_CR3_ONEBIT_Pos)
#define USART_CR3_ONEBIT   USART_CR3_ONEBIT_Msk
#define USART_CR3_OVRDIS_Pos   (12U)
#define USART_CR3_OVRDIS_Msk   (0x1UL << USART_CR3_OVRDIS_Pos)
#define USART_CR3_OVRDIS   USART_CR3_OVRDIS_Msk
#define USART_CR3_DDRE_Pos   (13U)
#define USART_CR3_DDRE_Msk   (0x1UL << USART_CR3_DDRE_Pos)
#define USART_CR3_DDRE   USART_CR3_DDRE_Msk
#define USART_CR3_DEM_Pos   (14U)
#define USART_CR3_DEM_Msk   (0x1UL << USART_CR3_DEM_Pos)
#define USART_CR3_DEM   USART_CR3_DEM_Msk
#define USART_CR3_DEP_Pos   (15U)
#define USART_CR3_DEP_Msk   (0x1UL << USART_CR3_DEP_Pos)
#define USART_CR3_DEP   USART_CR3_DEP_Msk
#define USART_CR3_SCARCNT_Pos   (17U)
#define USART_CR3_SCARCNT_Msk   (0x7UL << USART_CR3_SCARCNT_Pos)
#define USART_CR3_SCARCNT   USART_CR3_SCARCNT_Msk
#define USART_CR3_SCARCNT_0   (0x1UL << USART_CR3_SCARCNT_Pos)
#define USART_CR3_SCARCNT_1   (0x2UL << USART_CR3_SCARCNT_Pos)
#define USART_CR3_SCARCNT_2   (0x4UL << USART_CR3_SCARCNT_Pos)
#define USART_CR3_TXFTIE_Pos   (23U)
#define USART_CR3_TXFTIE_Msk   (0x1UL << USART_CR3_TXFTIE_Pos)
#define USART_CR3_TXFTIE   USART_CR3_TXFTIE_Msk
#define USART_CR3_TCBGTIE_Pos   (24U)
#define USART_CR3_TCBGTIE_Msk   (0x1UL << USART_CR3_TCBGTIE_Pos)
#define USART_CR3_TCBGTIE   USART_CR3_TCBGTIE_Msk
#define USART_CR3_RXFTCFG_Pos   (25U)
#define USART_CR3_RXFTCFG_Msk   (0x7UL << USART_CR3_RXFTCFG_Pos)
#define USART_CR3_RXFTCFG   USART_CR3_RXFTCFG_Msk
#define USART_CR3_RXFTCFG_0   (0x1UL << USART_CR3_RXFTCFG_Pos)
#define USART_CR3_RXFTCFG_1   (0x2UL << USART_CR3_RXFTCFG_Pos)
#define USART_CR3_RXFTCFG_2   (0x4UL << USART_CR3_RXFTCFG_Pos)
#define USART_CR3_RXFTIE_Pos   (28U)
#define USART_CR3_RXFTIE_Msk   (0x1UL << USART_CR3_RXFTIE_Pos)
#define USART_CR3_RXFTIE   USART_CR3_RXFTIE_Msk
#define USART_CR3_TXFTCFG_Pos   (29U)
#define USART_CR3_TXFTCFG_Msk   (0x7UL << USART_CR3_TXFTCFG_Pos)
#define USART_CR3_TXFTCFG   USART_CR3_TXFTCFG_Msk
#define USART_CR3_TXFTCFG_0   (0x1UL << USART_CR3_TXFTCFG_Pos)
#define USART_CR3_TXFTCFG_1   (0x2UL << USART_CR3_TXFTCFG_Pos)
#define USART_CR3_TXFTCFG_2   (0x4UL << USART_CR3_TXFTCFG_Pos)
#define USART_BRR_LPUART_Pos   (0U)
#define USART_BRR_LPUART_Msk   (0xFFFFFUL << USART_BRR_LPUART_Pos)
#define USART_BRR_LPUART   USART_BRR_LPUART_Msk
#define USART_BRR_BRR   ((uint16_t)0xFFFF)
#define USART_GTPR_PSC_Pos   (0U)
#define USART_GTPR_PSC_Msk   (0xFFUL << USART_GTPR_PSC_Pos)
#define USART_GTPR_PSC   USART_GTPR_PSC_Msk
#define USART_GTPR_GT_Pos   (8U)
#define USART_GTPR_GT_Msk   (0xFFUL << USART_GTPR_GT_Pos)
#define USART_GTPR_GT   USART_GTPR_GT_Msk
#define USART_RTOR_RTO_Pos   (0U)
#define USART_RTOR_RTO_Msk   (0xFFFFFFUL << USART_RTOR_RTO_Pos)
#define USART_RTOR_RTO   USART_RTOR_RTO_Msk
#define USART_RTOR_BLEN_Pos   (24U)
#define USART_RTOR_BLEN_Msk   (0xFFUL << USART_RTOR_BLEN_Pos)
#define USART_RTOR_BLEN   USART_RTOR_BLEN_Msk
#define USART_RQR_ABRRQ   ((uint16_t)0x0001)
#define USART_RQR_SBKRQ   ((uint16_t)0x0002)
#define USART_RQR_MMRQ   ((uint16_t)0x0004)
#define USART_RQR_RXFRQ   ((uint16_t)0x0008)
#define USART_RQR_TXFRQ   ((uint16_t)0x0010)
#define USART_ISR_PE_Pos   (0U)
#define USART_ISR_PE_Msk   (0x1UL << USART_ISR_PE_Pos)
#define USART_ISR_PE   USART_ISR_PE_Msk
#define USART_ISR_FE_Pos   (1U)
#define USART_ISR_FE_Msk   (0x1UL << USART_ISR_FE_Pos)
#define USART_ISR_FE   USART_ISR_FE_Msk
#define USART_ISR_NE_Pos   (2U)
#define USART_ISR_NE_Msk   (0x1UL << USART_ISR_NE_Pos)
#define USART_ISR_NE   USART_ISR_NE_Msk
#define USART_ISR_ORE_Pos   (3U)
#define USART_ISR_ORE_Msk   (0x1UL << USART_ISR_ORE_Pos)
#define USART_ISR_ORE   USART_ISR_ORE_Msk
#define USART_ISR_IDLE_Pos   (4U)
#define USART_ISR_IDLE_Msk   (0x1UL << USART_ISR_IDLE_Pos)
#define USART_ISR_IDLE   USART_ISR_IDLE_Msk
#define USART_ISR_RXNE_Pos   (5U)
#define USART_ISR_RXNE_Msk   (0x1UL << USART_ISR_RXNE_Pos)
#define USART_ISR_RXNE   USART_ISR_RXNE_Msk
#define USART_ISR_RXNE_RXFNE_Pos   USART_ISR_RXNE_Pos
#define USART_ISR_RXNE_RXFNE_Msk   USART_ISR_RXNE_Msk
#define USART_ISR_RXNE_RXFNE   USART_ISR_RXNE_Msk
#define USART_ISR_TC_Pos   (6U)
#define USART_ISR_TC_Msk   (0x1UL << USART_ISR_TC_Pos)
#define USART_ISR_TC   USART_ISR_TC_Msk
#define USART_ISR_TXE_Pos   (7U)
#define USART_ISR_TXE_Msk   (0x1UL << USART_ISR_TXE_Pos)
#define USART_ISR_TXE   USART_ISR_TXE_Msk
#define USART_ISR_TXE_TXFNF_Pos   USART_ISR_TXE_Pos
#define USART_ISR_TXE_TXFNF_Msk   USART_ISR_TXE_Msk
#define USART_ISR_TXE_TXFNF   USART_ISR_TXE_Msk
#define USART_ISR_LBDF_Pos   (8U)
#define USART_ISR_LBDF_Msk   (0x1UL << USART_ISR_LBDF_Pos)
#define USART_ISR_LBDF   USART_ISR_LBDF_Msk
#define USART_ISR_CTSIF_Pos   (9U)
#define USART_ISR_CTSIF_Msk   (0x1UL << USART_ISR_CTSIF_Pos)
#define USART_ISR_CTSIF   USART_ISR_CTSIF_Msk
#define USART_ISR_CTS_Pos   (10U)
#define USART_ISR_CTS_Msk   (0x1UL << USART_ISR_CTS_Pos)
#define USART_ISR_CTS   USART_ISR_CTS_Msk
#define USART_ISR_RTOF_Pos   (11U)
#define USART_ISR_RTOF_Msk   (0x1UL << USART_ISR_RTOF_Pos)
#define USART_ISR_RTOF   USART_ISR_RTOF_Msk
#define USART_ISR_EOBF_Pos   (12U)
#define USART_ISR_EOBF_Msk   (0x1UL << USART_ISR_EOBF_Pos)
#define USART_ISR_EOBF   USART_ISR_EOBF_Msk
#define USART_ISR_UDR_Pos   (13U)
#define USART_ISR_UDR_Msk   (0x1UL << USART_ISR_UDR_Pos)
#define USART_ISR_UDR   USART_ISR_UDR_Msk
#define USART_ISR_ABRE_Pos   (14U)
#define USART_ISR_ABRE_Msk   (0x1UL << USART_ISR_ABRE_Pos)
#define USART_ISR_ABRE   USART_ISR_ABRE_Msk
#define USART_ISR_ABRF_Pos   (15U)
#define USART_ISR_ABRF_Msk   (0x1UL << USART_ISR_ABRF_Pos)
#define USART_ISR_ABRF   USART_ISR_ABRF_Msk
#define USART_ISR_BUSY_Pos   (16U)
#define USART_ISR_BUSY_Msk   (0x1UL << USART_ISR_BUSY_Pos)
#define USART_ISR_BUSY   USART_ISR_BUSY_Msk
#define USART_ISR_CMF_Pos   (17U)
#define USART_ISR_CMF_Msk   (0x1UL << USART_ISR_CMF_Pos)
#define USART_ISR_CMF   USART_ISR_CMF_Msk
#define USART_ISR_SBKF_Pos   (18U)
#define USART_ISR_SBKF_Msk   (0x1UL << USART_ISR_SBKF_Pos)
#define USART_ISR_SBKF   USART_ISR_SBKF_Msk
#define USART_ISR_RWU_Pos   (19U)
#define USART_ISR_RWU_Msk   (0x1UL << USART_ISR_RWU_Pos)
#define USART_ISR_RWU   USART_ISR_RWU_Msk
#define USART_ISR_TEACK_Pos   (21U)
#define USART_ISR_TEACK_Msk   (0x1UL << USART_ISR_TEACK_Pos)
#define USART_ISR_TEACK   USART_ISR_TEACK_Msk
#define USART_ISR_REACK_Pos   (22U)
#define USART_ISR_REACK_Msk   (0x1UL << USART_ISR_REACK_Pos)
#define USART_ISR_REACK   USART_ISR_REACK_Msk
#define USART_ISR_TXFE_Pos   (23U)
#define USART_ISR_TXFE_Msk   (0x1UL << USART_ISR_TXFE_Pos)
#define USART_ISR_TXFE   USART_ISR_TXFE_Msk
#define USART_ISR_RXFF_Pos   (24U)
#define USART_ISR_RXFF_Msk   (0x1UL << USART_ISR_RXFF_Pos)
#define USART_ISR_RXFF   USART_ISR_RXFF_Msk
#define USART_ISR_TCBGT_Pos   (25U)
#define USART_ISR_TCBGT_Msk   (0x1UL << USART_ISR_TCBGT_Pos)
#define USART_ISR_TCBGT   USART_ISR_TCBGT_Msk
#define USART_ISR_RXFT_Pos   (26U)
#define USART_ISR_RXFT_Msk   (0x1UL << USART_ISR_RXFT_Pos)
#define USART_ISR_RXFT   USART_ISR_RXFT_Msk
#define USART_ISR_TXFT_Pos   (27U)
#define USART_ISR_TXFT_Msk   (0x1UL << USART_ISR_TXFT_Pos)
#define USART_ISR_TXFT   USART_ISR_TXFT_Msk
#define USART_ICR_PECF_Pos   (0U)
#define USART_ICR_PECF_Msk   (0x1UL << USART_ICR_PECF_Pos)
#define USART_ICR_PECF   USART_ICR_PECF_Msk
#define USART_ICR_FECF_Pos   (1U)
#define USART_ICR_FECF_Msk   (0x1UL << USART_ICR_FECF_Pos)
#define USART_ICR_FECF   USART_ICR_FECF_Msk
#define USART_ICR_NECF_Pos   (2U)
#define USART_ICR_NECF_Msk   (0x1UL << USART_ICR_NECF_Pos)
#define USART_ICR_NECF   USART_ICR_NECF_Msk
#define USART_ICR_ORECF_Pos   (3U)
#define USART_ICR_ORECF_Msk   (0x1UL << USART_ICR_ORECF_Pos)
#define USART_ICR_ORECF   USART_ICR_ORECF_Msk
#define USART_ICR_IDLECF_Pos   (4U)
#define USART_ICR_IDLECF_Msk   (0x1UL << USART_ICR_IDLECF_Pos)
#define USART_ICR_IDLECF   USART_ICR_IDLECF_Msk
#define USART_ICR_TXFECF_Pos   (5U)
#define USART_ICR_TXFECF_Msk   (0x1UL << USART_ICR_TXFECF_Pos)
#define USART_ICR_TXFECF   USART_ICR_TXFECF_Msk
#define USART_ICR_TCCF_Pos   (6U)
#define USART_ICR_TCCF_Msk   (0x1UL << USART_ICR_TCCF_Pos)
#define USART_ICR_TCCF   USART_ICR_TCCF_Msk
#define USART_ICR_TCBGTCF_Pos   (7U)
#define USART_ICR_TCBGTCF_Msk   (0x1UL << USART_ICR_TCBGTCF_Pos)
#define USART_ICR_TCBGTCF   USART_ICR_TCBGTCF_Msk
#define USART_ICR_LBDCF_Pos   (8U)
#define USART_ICR_LBDCF_Msk   (0x1UL << USART_ICR_LBDCF_Pos)
#define USART_ICR_LBDCF   USART_ICR_LBDCF_Msk
#define USART_ICR_CTSCF_Pos   (9U)
#define USART_ICR_CTSCF_Msk   (0x1UL << USART_ICR_CTSCF_Pos)
#define USART_ICR_CTSCF   USART_ICR_CTSCF_Msk
#define USART_ICR_RTOCF_Pos   (11U)
#define USART_ICR_RTOCF_Msk   (0x1UL << USART_ICR_RTOCF_Pos)
#define USART_ICR_RTOCF   USART_ICR_RTOCF_Msk
#define USART_ICR_EOBCF_Pos   (12U)
#define USART_ICR_EOBCF_Msk   (0x1UL << USART_ICR_EOBCF_Pos)
#define USART_ICR_EOBCF   USART_ICR_EOBCF_Msk
#define USART_ICR_UDRCF_Pos   (13U)
#define USART_ICR_UDRCF_Msk   (0x1UL << USART_ICR_UDRCF_Pos)
#define USART_ICR_UDRCF   USART_ICR_UDRCF_Msk
#define USART_ICR_CMCF_Pos   (17U)
#define USART_ICR_CMCF_Msk   (0x1UL << USART_ICR_CMCF_Pos)
#define USART_ICR_CMCF   USART_ICR_CMCF_Msk
#define USART_RDR_RDR   ((uint16_t)0x01FF)
#define USART_TDR_TDR   ((uint16_t)0x01FF)
#define USART_PRESC_PRESCALER_Pos   (0U)
#define USART_PRESC_PRESCALER_Msk   (0xFUL << USART_PRESC_PRESCALER_Pos)
#define USART_PRESC_PRESCALER   USART_PRESC_PRESCALER_Msk
#define USART_PRESC_PRESCALER_0   (0x1UL << USART_PRESC_PRESCALER_Pos)
#define USART_PRESC_PRESCALER_1   (0x2UL << USART_PRESC_PRESCALER_Pos)
#define USART_PRESC_PRESCALER_2   (0x4UL << USART_PRESC_PRESCALER_Pos)
#define USART_PRESC_PRESCALER_3   (0x8UL << USART_PRESC_PRESCALER_Pos)
#define USART_AUTOCR_TDN_Pos   (0U)
#define USART_AUTOCR_TDN_Msk   (0xFFFFUL << USART_AUTOCR_TDN_Pos)
#define USART_AUTOCR_TDN   USART_AUTOCR_TDN_Msk
#define USART_AUTOCR_TRIGPOL_Pos   (16U)
#define USART_AUTOCR_TRIGPOL_Msk   (0x1UL << USART_AUTOCR_TRIGPOL_Pos)
#define USART_AUTOCR_TRIGPOL   USART_AUTOCR_TRIGPOL_Msk
#define USART_AUTOCR_TRIGEN_Pos   (17U)
#define USART_AUTOCR_TRIGEN_Msk   (0x1UL << USART_AUTOCR_TRIGEN_Pos)
#define USART_AUTOCR_TRIGEN   USART_AUTOCR_TRIGEN_Msk
#define USART_AUTOCR_IDLEDIS_Pos   (18U)
#define USART_AUTOCR_IDLEDIS_Msk   (0x1UL << USART_AUTOCR_IDLEDIS_Pos)
#define USART_AUTOCR_IDLEDIS   USART_AUTOCR_IDLEDIS_Msk
#define USART_AUTOCR_TRIGSEL_Pos   (19U)
#define USART_AUTOCR_TRIGSEL_Msk   (0xFUL << USART_AUTOCR_TRIGSEL_Pos)
#define USART_AUTOCR_TRIGSEL   USART_AUTOCR_TRIGSEL_Msk
#define USART_AUTOCR_TRIGSEL_0   (0x0001UL << USART_AUTOCR_TRIGSEL_Pos)
#define USART_AUTOCR_TRIGSEL_1   (0x0002UL << USART_AUTOCR_TRIGSEL_Pos)
#define USART_AUTOCR_TRIGSEL_2   (0x0004UL << USART_AUTOCR_TRIGSEL_Pos)
#define USART_AUTOCR_TRIGSEL_3   (0x0008UL << USART_AUTOCR_TRIGSEL_Pos)
#define USART_HWCFGR2_CFG1_Pos   (0U)
#define USART_HWCFGR2_CFG1_Msk   (0xFUL << USART_HWCFGR2_CFG1_Pos)
#define USART_HWCFGR2_CFG1   USART_HWCFGR2_CFG1_Msk
#define USART_HWCFGR2_CFG2_Pos   (4U)
#define USART_HWCFGR2_CFG2_Msk   (0xFUL << USART_HWCFGR2_CFG2_Pos)
#define USART_HWCFGR2_CFG2   USART_HWCFGR2_CFG2_Msk
#define USART_HWCFGR1_CFG1_Pos   (0U)
#define USART_HWCFGR1_CFG1_Msk   (0xFUL << USART_HWCFGR1_CFG1_Pos)
#define USART_HWCFGR1_CFG1   USART_HWCFGR1_CFG1_Msk
#define USART_HWCFGR1_CFG2_Pos   (4U)
#define USART_HWCFGR1_CFG2_Msk   (0xFUL << USART_HWCFGR1_CFG2_Pos)
#define USART_HWCFGR1_CFG2   USART_HWCFGR1_CFG2_Msk
#define USART_HWCFGR1_CFG3_Pos   (8U)
#define USART_HWCFGR1_CFG3_Msk   (0xFUL << USART_HWCFGR1_CFG3_Pos)
#define USART_HWCFGR1_CFG3   USART_HWCFGR1_CFG3_Msk
#define USART_HWCFGR1_CFG4_Pos   (12U)
#define USART_HWCFGR1_CFG4_Msk   (0xFUL << USART_HWCFGR1_CFG4_Pos)
#define USART_HWCFGR1_CFG4   USART_HWCFGR1_CFG4_Msk
#define USART_HWCFGR1_CFG5_Pos   (16U)
#define USART_HWCFGR1_CFG5_Msk   (0xFUL << USART_HWCFGR1_CFG5_Pos)
#define USART_HWCFGR1_CFG5   USART_HWCFGR1_CFG5_Msk
#define USART_HWCFGR1_CFG6_Pos   (20U)
#define USART_HWCFGR1_CFG6_Msk   (0xFUL << USART_HWCFGR1_CFG6_Pos)
#define USART_HWCFGR1_CFG6   USART_HWCFGR1_CFG6_Msk
#define USART_HWCFGR1_CFG7_Pos   (24U)
#define USART_HWCFGR1_CFG7_Msk   (0xFUL << USART_HWCFGR1_CFG7_Pos)
#define USART_HWCFGR1_CFG7   USART_HWCFGR1_CFG7_Msk
#define USART_HWCFGR1_CFG8_Pos   (28U)
#define USART_HWCFGR1_CFG8_Msk   (0xFUL << USART_HWCFGR1_CFG8_Pos)
#define USART_HWCFGR1_CFG8   USART_HWCFGR1_CFG8_Msk
#define USART_VERR_MINREV_Pos   (0U)
#define USART_VERR_MINREV_Msk   (0xFUL << USART_VERR_MINREV_Pos)
#define USART_VERR_MINREV   USART_VERR_MINREV_Msk
#define USART_VERR_MAJREV_Pos   (4U)
#define USART_VERR_MAJREV_Msk   (0xFUL << USART_VERR_MAJREV_Pos)
#define USART_VERR_MAJREV   USART_VERR_MAJREV_Msk
#define USART_IPIDR_ID_Pos   (0U)
#define USART_IPIDR_ID_Msk   (0xFFFFFFFFUL << USART_IPIDR_ID_Pos)
#define USART_IPIDR_ID   USART_IPIDR_ID_Msk
#define USART_SIDR_ID_Pos   (0U)
#define USART_SIDR_ID_Msk   (0xFFFFFFFFUL << USART_SIDR_ID_Pos)
#define USART_SIDR_ID   USART_SIDR_ID_Msk
#define I2C_CR1_PE_Pos   (0U)
#define I2C_CR1_PE_Msk   (0x1UL << I2C_CR1_PE_Pos)
#define I2C_CR1_PE   I2C_CR1_PE_Msk
#define I2C_CR1_TXIE_Pos   (1U)
#define I2C_CR1_TXIE_Msk   (0x1UL << I2C_CR1_TXIE_Pos)
#define I2C_CR1_TXIE   I2C_CR1_TXIE_Msk
#define I2C_CR1_RXIE_Pos   (2U)
#define I2C_CR1_RXIE_Msk   (0x1UL << I2C_CR1_RXIE_Pos)
#define I2C_CR1_RXIE   I2C_CR1_RXIE_Msk
#define I2C_CR1_ADDRIE_Pos   (3U)
#define I2C_CR1_ADDRIE_Msk   (0x1UL << I2C_CR1_ADDRIE_Pos)
#define I2C_CR1_ADDRIE   I2C_CR1_ADDRIE_Msk
#define I2C_CR1_NACKIE_Pos   (4U)
#define I2C_CR1_NACKIE_Msk   (0x1UL << I2C_CR1_NACKIE_Pos)
#define I2C_CR1_NACKIE   I2C_CR1_NACKIE_Msk
#define I2C_CR1_STOPIE_Pos   (5U)
#define I2C_CR1_STOPIE_Msk   (0x1UL << I2C_CR1_STOPIE_Pos)
#define I2C_CR1_STOPIE   I2C_CR1_STOPIE_Msk
#define I2C_CR1_TCIE_Pos   (6U)
#define I2C_CR1_TCIE_Msk   (0x1UL << I2C_CR1_TCIE_Pos)
#define I2C_CR1_TCIE   I2C_CR1_TCIE_Msk
#define I2C_CR1_ERRIE_Pos   (7U)
#define I2C_CR1_ERRIE_Msk   (0x1UL << I2C_CR1_ERRIE_Pos)
#define I2C_CR1_ERRIE   I2C_CR1_ERRIE_Msk
#define I2C_CR1_DNF_Pos   (8U)
#define I2C_CR1_DNF_Msk   (0xFUL << I2C_CR1_DNF_Pos)
#define I2C_CR1_DNF   I2C_CR1_DNF_Msk
#define I2C_CR1_ANFOFF_Pos   (12U)
#define I2C_CR1_ANFOFF_Msk   (0x1UL << I2C_CR1_ANFOFF_Pos)
#define I2C_CR1_ANFOFF   I2C_CR1_ANFOFF_Msk
#define I2C_CR1_SWRST_Pos   (13U)
#define I2C_CR1_SWRST_Msk   (0x1UL << I2C_CR1_SWRST_Pos)
#define I2C_CR1_SWRST   I2C_CR1_SWRST_Msk
#define I2C_CR1_TXDMAEN_Pos   (14U)
#define I2C_CR1_TXDMAEN_Msk   (0x1UL << I2C_CR1_TXDMAEN_Pos)
#define I2C_CR1_TXDMAEN   I2C_CR1_TXDMAEN_Msk
#define I2C_CR1_RXDMAEN_Pos   (15U)
#define I2C_CR1_RXDMAEN_Msk   (0x1UL << I2C_CR1_RXDMAEN_Pos)
#define I2C_CR1_RXDMAEN   I2C_CR1_RXDMAEN_Msk
#define I2C_CR1_SBC_Pos   (16U)
#define I2C_CR1_SBC_Msk   (0x1UL << I2C_CR1_SBC_Pos)
#define I2C_CR1_SBC   I2C_CR1_SBC_Msk
#define I2C_CR1_NOSTRETCH_Pos   (17U)
#define I2C_CR1_NOSTRETCH_Msk   (0x1UL << I2C_CR1_NOSTRETCH_Pos)
#define I2C_CR1_NOSTRETCH   I2C_CR1_NOSTRETCH_Msk
#define I2C_CR1_WUPEN_Pos   (18U)
#define I2C_CR1_WUPEN_Msk   (0x1UL << I2C_CR1_WUPEN_Pos)
#define I2C_CR1_WUPEN   I2C_CR1_WUPEN_Msk
#define I2C_CR1_GCEN_Pos   (19U)
#define I2C_CR1_GCEN_Msk   (0x1UL << I2C_CR1_GCEN_Pos)
#define I2C_CR1_GCEN   I2C_CR1_GCEN_Msk
#define I2C_CR1_SMBHEN_Pos   (20U)
#define I2C_CR1_SMBHEN_Msk   (0x1UL << I2C_CR1_SMBHEN_Pos)
#define I2C_CR1_SMBHEN   I2C_CR1_SMBHEN_Msk
#define I2C_CR1_SMBDEN_Pos   (21U)
#define I2C_CR1_SMBDEN_Msk   (0x1UL << I2C_CR1_SMBDEN_Pos)
#define I2C_CR1_SMBDEN   I2C_CR1_SMBDEN_Msk
#define I2C_CR1_ALERTEN_Pos   (22U)
#define I2C_CR1_ALERTEN_Msk   (0x1UL << I2C_CR1_ALERTEN_Pos)
#define I2C_CR1_ALERTEN   I2C_CR1_ALERTEN_Msk
#define I2C_CR1_PECEN_Pos   (23U)
#define I2C_CR1_PECEN_Msk   (0x1UL << I2C_CR1_PECEN_Pos)
#define I2C_CR1_PECEN   I2C_CR1_PECEN_Msk
#define I2C_CR1_FMP_Pos   (24U)
#define I2C_CR1_FMP_Msk   (0x1UL << I2C_CR1_FMP_Pos)
#define I2C_CR1_FMP   I2C_CR1_FMP_Msk
#define I2C_CR1_ADDRACLR_Pos   (30U)
#define I2C_CR1_ADDRACLR_Msk   (0x1UL << I2C_CR1_ADDRACLR_Pos)
#define I2C_CR1_ADDRACLR   I2C_CR1_ADDRACLR_Msk
#define I2C_CR1_STOPFACLR_Pos   (31U)
#define I2C_CR1_STOPFACLR_Msk   (0x1UL << I2C_CR1_STOPFACLR_Pos)
#define I2C_CR1_STOPFACLR   I2C_CR1_STOPFACLR_Msk
#define I2C_CR2_SADD_Pos   (0U)
#define I2C_CR2_SADD_Msk   (0x3FFUL << I2C_CR2_SADD_Pos)
#define I2C_CR2_SADD   I2C_CR2_SADD_Msk
#define I2C_CR2_RD_WRN_Pos   (10U)
#define I2C_CR2_RD_WRN_Msk   (0x1UL << I2C_CR2_RD_WRN_Pos)
#define I2C_CR2_RD_WRN   I2C_CR2_RD_WRN_Msk
#define I2C_CR2_ADD10_Pos   (11U)
#define I2C_CR2_ADD10_Msk   (0x1UL << I2C_CR2_ADD10_Pos)
#define I2C_CR2_ADD10   I2C_CR2_ADD10_Msk
#define I2C_CR2_HEAD10R_Pos   (12U)
#define I2C_CR2_HEAD10R_Msk   (0x1UL << I2C_CR2_HEAD10R_Pos)
#define I2C_CR2_HEAD10R   I2C_CR2_HEAD10R_Msk
#define I2C_CR2_START_Pos   (13U)
#define I2C_CR2_START_Msk   (0x1UL << I2C_CR2_START_Pos)
#define I2C_CR2_START   I2C_CR2_START_Msk
#define I2C_CR2_STOP_Pos   (14U)
#define I2C_CR2_STOP_Msk   (0x1UL << I2C_CR2_STOP_Pos)
#define I2C_CR2_STOP   I2C_CR2_STOP_Msk
#define I2C_CR2_NACK_Pos   (15U)
#define I2C_CR2_NACK_Msk   (0x1UL << I2C_CR2_NACK_Pos)
#define I2C_CR2_NACK   I2C_CR2_NACK_Msk
#define I2C_CR2_NBYTES_Pos   (16U)
#define I2C_CR2_NBYTES_Msk   (0xFFUL << I2C_CR2_NBYTES_Pos)
#define I2C_CR2_NBYTES   I2C_CR2_NBYTES_Msk
#define I2C_CR2_RELOAD_Pos   (24U)
#define I2C_CR2_RELOAD_Msk   (0x1UL << I2C_CR2_RELOAD_Pos)
#define I2C_CR2_RELOAD   I2C_CR2_RELOAD_Msk
#define I2C_CR2_AUTOEND_Pos   (25U)
#define I2C_CR2_AUTOEND_Msk   (0x1UL << I2C_CR2_AUTOEND_Pos)
#define I2C_CR2_AUTOEND   I2C_CR2_AUTOEND_Msk
#define I2C_CR2_PECBYTE_Pos   (26U)
#define I2C_CR2_PECBYTE_Msk   (0x1UL << I2C_CR2_PECBYTE_Pos)
#define I2C_CR2_PECBYTE   I2C_CR2_PECBYTE_Msk
#define I2C_OAR1_OA1_Pos   (0U)
#define I2C_OAR1_OA1_Msk   (0x3FFUL << I2C_OAR1_OA1_Pos)
#define I2C_OAR1_OA1   I2C_OAR1_OA1_Msk
#define I2C_OAR1_OA1MODE_Pos   (10U)
#define I2C_OAR1_OA1MODE_Msk   (0x1UL << I2C_OAR1_OA1MODE_Pos)
#define I2C_OAR1_OA1MODE   I2C_OAR1_OA1MODE_Msk
#define I2C_OAR1_OA1EN_Pos   (15U)
#define I2C_OAR1_OA1EN_Msk   (0x1UL << I2C_OAR1_OA1EN_Pos)
#define I2C_OAR1_OA1EN   I2C_OAR1_OA1EN_Msk
#define I2C_OAR2_OA2_Pos   (1U)
#define I2C_OAR2_OA2_Msk   (0x7FUL << I2C_OAR2_OA2_Pos)
#define I2C_OAR2_OA2   I2C_OAR2_OA2_Msk
#define I2C_OAR2_OA2MSK_Pos   (8U)
#define I2C_OAR2_OA2MSK_Msk   (0x7UL << I2C_OAR2_OA2MSK_Pos)
#define I2C_OAR2_OA2MSK   I2C_OAR2_OA2MSK_Msk
#define I2C_OAR2_OA2NOMASK   (0x00000000UL)
#define I2C_OAR2_OA2MASK01_Pos   (8U)
#define I2C_OAR2_OA2MASK01_Msk   (0x1UL << I2C_OAR2_OA2MASK01_Pos)
#define I2C_OAR2_OA2MASK01   I2C_OAR2_OA2MASK01_Msk
#define I2C_OAR2_OA2MASK02_Pos   (9U)
#define I2C_OAR2_OA2MASK02_Msk   (0x1UL << I2C_OAR2_OA2MASK02_Pos)
#define I2C_OAR2_OA2MASK02   I2C_OAR2_OA2MASK02_Msk
#define I2C_OAR2_OA2MASK03_Pos   (8U)
#define I2C_OAR2_OA2MASK03_Msk   (0x3UL << I2C_OAR2_OA2MASK03_Pos)
#define I2C_OAR2_OA2MASK03   I2C_OAR2_OA2MASK03_Msk
#define I2C_OAR2_OA2MASK04_Pos   (10U)
#define I2C_OAR2_OA2MASK04_Msk   (0x1UL << I2C_OAR2_OA2MASK04_Pos)
#define I2C_OAR2_OA2MASK04   I2C_OAR2_OA2MASK04_Msk
#define I2C_OAR2_OA2MASK05_Pos   (8U)
#define I2C_OAR2_OA2MASK05_Msk   (0x5UL << I2C_OAR2_OA2MASK05_Pos)
#define I2C_OAR2_OA2MASK05   I2C_OAR2_OA2MASK05_Msk
#define I2C_OAR2_OA2MASK06_Pos   (9U)
#define I2C_OAR2_OA2MASK06_Msk   (0x3UL << I2C_OAR2_OA2MASK06_Pos)
#define I2C_OAR2_OA2MASK06   I2C_OAR2_OA2MASK06_Msk
#define I2C_OAR2_OA2MASK07_Pos   (8U)
#define I2C_OAR2_OA2MASK07_Msk   (0x7UL << I2C_OAR2_OA2MASK07_Pos)
#define I2C_OAR2_OA2MASK07   I2C_OAR2_OA2MASK07_Msk
#define I2C_OAR2_OA2EN_Pos   (15U)
#define I2C_OAR2_OA2EN_Msk   (0x1UL << I2C_OAR2_OA2EN_Pos)
#define I2C_OAR2_OA2EN   I2C_OAR2_OA2EN_Msk
#define I2C_TIMINGR_SCLL_Pos   (0U)
#define I2C_TIMINGR_SCLL_Msk   (0xFFUL << I2C_TIMINGR_SCLL_Pos)
#define I2C_TIMINGR_SCLL   I2C_TIMINGR_SCLL_Msk
#define I2C_TIMINGR_SCLH_Pos   (8U)
#define I2C_TIMINGR_SCLH_Msk   (0xFFUL << I2C_TIMINGR_SCLH_Pos)
#define I2C_TIMINGR_SCLH   I2C_TIMINGR_SCLH_Msk
#define I2C_TIMINGR_SDADEL_Pos   (16U)
#define I2C_TIMINGR_SDADEL_Msk   (0xFUL << I2C_TIMINGR_SDADEL_Pos)
#define I2C_TIMINGR_SDADEL   I2C_TIMINGR_SDADEL_Msk
#define I2C_TIMINGR_SCLDEL_Pos   (20U)
#define I2C_TIMINGR_SCLDEL_Msk   (0xFUL << I2C_TIMINGR_SCLDEL_Pos)
#define I2C_TIMINGR_SCLDEL   I2C_TIMINGR_SCLDEL_Msk
#define I2C_TIMINGR_PRESC_Pos   (28U)
#define I2C_TIMINGR_PRESC_Msk   (0xFUL << I2C_TIMINGR_PRESC_Pos)
#define I2C_TIMINGR_PRESC   I2C_TIMINGR_PRESC_Msk
#define I2C_TIMEOUTR_TIMEOUTA_Pos   (0U)
#define I2C_TIMEOUTR_TIMEOUTA_Msk   (0xFFFUL << I2C_TIMEOUTR_TIMEOUTA_Pos)
#define I2C_TIMEOUTR_TIMEOUTA   I2C_TIMEOUTR_TIMEOUTA_Msk
#define I2C_TIMEOUTR_TIDLE_Pos   (12U)
#define I2C_TIMEOUTR_TIDLE_Msk   (0x1UL << I2C_TIMEOUTR_TIDLE_Pos)
#define I2C_TIMEOUTR_TIDLE   I2C_TIMEOUTR_TIDLE_Msk
#define I2C_TIMEOUTR_TIMOUTEN_Pos   (15U)
#define I2C_TIMEOUTR_TIMOUTEN_Msk   (0x1UL << I2C_TIMEOUTR_TIMOUTEN_Pos)
#define I2C_TIMEOUTR_TIMOUTEN   I2C_TIMEOUTR_TIMOUTEN_Msk
#define I2C_TIMEOUTR_TIMEOUTB_Pos   (16U)
#define I2C_TIMEOUTR_TIMEOUTB_Msk   (0xFFFUL << I2C_TIMEOUTR_TIMEOUTB_Pos)
#define I2C_TIMEOUTR_TIMEOUTB   I2C_TIMEOUTR_TIMEOUTB_Msk
#define I2C_TIMEOUTR_TEXTEN_Pos   (31U)
#define I2C_TIMEOUTR_TEXTEN_Msk   (0x1UL << I2C_TIMEOUTR_TEXTEN_Pos)
#define I2C_TIMEOUTR_TEXTEN   I2C_TIMEOUTR_TEXTEN_Msk
#define I2C_ISR_TXE_Pos   (0U)
#define I2C_ISR_TXE_Msk   (0x1UL << I2C_ISR_TXE_Pos)
#define I2C_ISR_TXE   I2C_ISR_TXE_Msk
#define I2C_ISR_TXIS_Pos   (1U)
#define I2C_ISR_TXIS_Msk   (0x1UL << I2C_ISR_TXIS_Pos)
#define I2C_ISR_TXIS   I2C_ISR_TXIS_Msk
#define I2C_ISR_RXNE_Pos   (2U)
#define I2C_ISR_RXNE_Msk   (0x1UL << I2C_ISR_RXNE_Pos)
#define I2C_ISR_RXNE   I2C_ISR_RXNE_Msk
#define I2C_ISR_ADDR_Pos   (3U)
#define I2C_ISR_ADDR_Msk   (0x1UL << I2C_ISR_ADDR_Pos)
#define I2C_ISR_ADDR   I2C_ISR_ADDR_Msk
#define I2C_ISR_NACKF_Pos   (4U)
#define I2C_ISR_NACKF_Msk   (0x1UL << I2C_ISR_NACKF_Pos)
#define I2C_ISR_NACKF   I2C_ISR_NACKF_Msk
#define I2C_ISR_STOPF_Pos   (5U)
#define I2C_ISR_STOPF_Msk   (0x1UL << I2C_ISR_STOPF_Pos)
#define I2C_ISR_STOPF   I2C_ISR_STOPF_Msk
#define I2C_ISR_TC_Pos   (6U)
#define I2C_ISR_TC_Msk   (0x1UL << I2C_ISR_TC_Pos)
#define I2C_ISR_TC   I2C_ISR_TC_Msk
#define I2C_ISR_TCR_Pos   (7U)
#define I2C_ISR_TCR_Msk   (0x1UL << I2C_ISR_TCR_Pos)
#define I2C_ISR_TCR   I2C_ISR_TCR_Msk
#define I2C_ISR_BERR_Pos   (8U)
#define I2C_ISR_BERR_Msk   (0x1UL << I2C_ISR_BERR_Pos)
#define I2C_ISR_BERR   I2C_ISR_BERR_Msk
#define I2C_ISR_ARLO_Pos   (9U)
#define I2C_ISR_ARLO_Msk   (0x1UL << I2C_ISR_ARLO_Pos)
#define I2C_ISR_ARLO   I2C_ISR_ARLO_Msk
#define I2C_ISR_OVR_Pos   (10U)
#define I2C_ISR_OVR_Msk   (0x1UL << I2C_ISR_OVR_Pos)
#define I2C_ISR_OVR   I2C_ISR_OVR_Msk
#define I2C_ISR_PECERR_Pos   (11U)
#define I2C_ISR_PECERR_Msk   (0x1UL << I2C_ISR_PECERR_Pos)
#define I2C_ISR_PECERR   I2C_ISR_PECERR_Msk
#define I2C_ISR_TIMEOUT_Pos   (12U)
#define I2C_ISR_TIMEOUT_Msk   (0x1UL << I2C_ISR_TIMEOUT_Pos)
#define I2C_ISR_TIMEOUT   I2C_ISR_TIMEOUT_Msk
#define I2C_ISR_ALERT_Pos   (13U)
#define I2C_ISR_ALERT_Msk   (0x1UL << I2C_ISR_ALERT_Pos)
#define I2C_ISR_ALERT   I2C_ISR_ALERT_Msk
#define I2C_ISR_BUSY_Pos   (15U)
#define I2C_ISR_BUSY_Msk   (0x1UL << I2C_ISR_BUSY_Pos)
#define I2C_ISR_BUSY   I2C_ISR_BUSY_Msk
#define I2C_ISR_DIR_Pos   (16U)
#define I2C_ISR_DIR_Msk   (0x1UL << I2C_ISR_DIR_Pos)
#define I2C_ISR_DIR   I2C_ISR_DIR_Msk
#define I2C_ISR_ADDCODE_Pos   (17U)
#define I2C_ISR_ADDCODE_Msk   (0x7FUL << I2C_ISR_ADDCODE_Pos)
#define I2C_ISR_ADDCODE   I2C_ISR_ADDCODE_Msk
#define I2C_ICR_ADDRCF_Pos   (3U)
#define I2C_ICR_ADDRCF_Msk   (0x1UL << I2C_ICR_ADDRCF_Pos)
#define I2C_ICR_ADDRCF   I2C_ICR_ADDRCF_Msk
#define I2C_ICR_NACKCF_Pos   (4U)
#define I2C_ICR_NACKCF_Msk   (0x1UL << I2C_ICR_NACKCF_Pos)
#define I2C_ICR_NACKCF   I2C_ICR_NACKCF_Msk
#define I2C_ICR_STOPCF_Pos   (5U)
#define I2C_ICR_STOPCF_Msk   (0x1UL << I2C_ICR_STOPCF_Pos)
#define I2C_ICR_STOPCF   I2C_ICR_STOPCF_Msk
#define I2C_ICR_BERRCF_Pos   (8U)
#define I2C_ICR_BERRCF_Msk   (0x1UL << I2C_ICR_BERRCF_Pos)
#define I2C_ICR_BERRCF   I2C_ICR_BERRCF_Msk
#define I2C_ICR_ARLOCF_Pos   (9U)
#define I2C_ICR_ARLOCF_Msk   (0x1UL << I2C_ICR_ARLOCF_Pos)
#define I2C_ICR_ARLOCF   I2C_ICR_ARLOCF_Msk
#define I2C_ICR_OVRCF_Pos   (10U)
#define I2C_ICR_OVRCF_Msk   (0x1UL << I2C_ICR_OVRCF_Pos)
#define I2C_ICR_OVRCF   I2C_ICR_OVRCF_Msk
#define I2C_ICR_PECCF_Pos   (11U)
#define I2C_ICR_PECCF_Msk   (0x1UL << I2C_ICR_PECCF_Pos)
#define I2C_ICR_PECCF   I2C_ICR_PECCF_Msk
#define I2C_ICR_TIMOUTCF_Pos   (12U)
#define I2C_ICR_TIMOUTCF_Msk   (0x1UL << I2C_ICR_TIMOUTCF_Pos)
#define I2C_ICR_TIMOUTCF   I2C_ICR_TIMOUTCF_Msk
#define I2C_ICR_ALERTCF_Pos   (13U)
#define I2C_ICR_ALERTCF_Msk   (0x1UL << I2C_ICR_ALERTCF_Pos)
#define I2C_ICR_ALERTCF   I2C_ICR_ALERTCF_Msk
#define I2C_PECR_PEC_Pos   (0U)
#define I2C_PECR_PEC_Msk   (0xFFUL << I2C_PECR_PEC_Pos)
#define I2C_PECR_PEC   I2C_PECR_PEC_Msk
#define I2C_RXDR_RXDATA_Pos   (0U)
#define I2C_RXDR_RXDATA_Msk   (0xFFUL << I2C_RXDR_RXDATA_Pos)
#define I2C_RXDR_RXDATA   I2C_RXDR_RXDATA_Msk
#define I2C_TXDR_TXDATA_Pos   (0U)
#define I2C_TXDR_TXDATA_Msk   (0xFFUL << I2C_TXDR_TXDATA_Pos)
#define I2C_TXDR_TXDATA   I2C_TXDR_TXDATA_Msk
#define I2C_AUTOCR_TCDMAEN_Pos   (6U)
#define I2C_AUTOCR_TCDMAEN_Msk   (0x1UL << I2C_AUTOCR_TCDMAEN_Pos)
#define I2C_AUTOCR_TCDMAEN   I2C_AUTOCR_TCDMAEN_Msk
#define I2C_AUTOCR_TCRDMAEN_Pos   (7U)
#define I2C_AUTOCR_TCRDMAEN_Msk   (0x1UL << I2C_AUTOCR_TCRDMAEN_Pos)
#define I2C_AUTOCR_TCRDMAEN   I2C_AUTOCR_TCRDMAEN_Msk
#define I2C_AUTOCR_TRIGSEL_Pos   (16U)
#define I2C_AUTOCR_TRIGSEL_Msk   (0xFUL << I2C_AUTOCR_TRIGSEL_Pos)
#define I2C_AUTOCR_TRIGSEL   I2C_AUTOCR_TRIGSEL_Msk
#define I2C_AUTOCR_TRIGPOL_Pos   (20U)
#define I2C_AUTOCR_TRIGPOL_Msk   (0x1UL << I2C_AUTOCR_TRIGPOL_Pos)
#define I2C_AUTOCR_TRIGPOL   I2C_AUTOCR_TRIGPOL_Msk
#define I2C_AUTOCR_TRIGEN_Pos   (21U)
#define I2C_AUTOCR_TRIGEN_Msk   (0x1UL << I2C_AUTOCR_TRIGEN_Pos)
#define I2C_AUTOCR_TRIGEN   I2C_AUTOCR_TRIGEN_Msk
#define IWDG_KR_KEY_Pos   (0U)
#define IWDG_KR_KEY_Msk   (0xFFFFUL << IWDG_KR_KEY_Pos)
#define IWDG_KR_KEY   IWDG_KR_KEY_Msk
#define IWDG_PR_PR_Pos   (0U)
#define IWDG_PR_PR_Msk   (0xFUL << IWDG_PR_PR_Pos)
#define IWDG_PR_PR   IWDG_PR_PR_Msk
#define IWDG_PR_PR_0   (0x1UL << IWDG_PR_PR_Pos)
#define IWDG_PR_PR_1   (0x2UL << IWDG_PR_PR_Pos)
#define IWDG_PR_PR_2   (0x4UL << IWDG_PR_PR_Pos)
#define IWDG_PR_PR_3   (0x8UL << IWDG_PR_PR_Pos)
#define IWDG_RLR_RL_Pos   (0U)
#define IWDG_RLR_RL_Msk   (0xFFFUL << IWDG_RLR_RL_Pos)
#define IWDG_RLR_RL   IWDG_RLR_RL_Msk
#define IWDG_SR_PVU_Pos   (0U)
#define IWDG_SR_PVU_Msk   (0x1UL << IWDG_SR_PVU_Pos)
#define IWDG_SR_PVU   IWDG_SR_PVU_Msk
#define IWDG_SR_RVU_Pos   (1U)
#define IWDG_SR_RVU_Msk   (0x1UL << IWDG_SR_RVU_Pos)
#define IWDG_SR_RVU   IWDG_SR_RVU_Msk
#define IWDG_SR_WVU_Pos   (2U)
#define IWDG_SR_WVU_Msk   (0x1UL << IWDG_SR_WVU_Pos)
#define IWDG_SR_WVU   IWDG_SR_WVU_Msk
#define IWDG_SR_EWU_Pos   (3U)
#define IWDG_SR_EWU_Msk   (0x1UL << IWDG_SR_EWU_Pos)
#define IWDG_SR_EWU   IWDG_SR_EWU_Msk
#define IWDG_SR_EWIF_Pos   (14U)
#define IWDG_SR_EWIF_Msk   (0x1UL << IWDG_SR_EWIF_Pos)
#define IWDG_SR_EWIF   IWDG_SR_EWIF_Msk
#define IWDG_WINR_WIN_Pos   (0U)
#define IWDG_WINR_WIN_Msk   (0xFFFUL << IWDG_WINR_WIN_Pos)
#define IWDG_WINR_WIN   IWDG_WINR_WIN_Msk
#define IWDG_EWCR_EWIT_Pos   (0U)
#define IWDG_EWCR_EWIT_Msk   (0xFFFUL << IWDG_EWCR_EWIT_Pos)
#define IWDG_EWCR_EWIT   IWDG_EWCR_EWIT_Msk
#define IWDG_EWCR_EWIC_Pos   (14U)
#define IWDG_EWCR_EWIC_Msk   (0x1UL << IWDG_EWCR_EWIC_Pos)
#define IWDG_EWCR_EWIC   IWDG_EWCR_EWIC_Msk
#define IWDG_EWCR_EWIE_Pos   (15U)
#define IWDG_EWCR_EWIE_Msk   (0x1UL << IWDG_EWCR_EWIE_Pos)
#define IWDG_EWCR_EWIE   IWDG_EWCR_EWIE_Msk
#define SPI_CR1_SPE_Pos   (0U)
#define SPI_CR1_SPE_Msk   (0x1UL << SPI_CR1_SPE_Pos)
#define SPI_CR1_SPE   SPI_CR1_SPE_Msk
#define SPI_CR1_MASRX_Pos   (8U)
#define SPI_CR1_MASRX_Msk   (0x1UL << SPI_CR1_MASRX_Pos)
#define SPI_CR1_MASRX   SPI_CR1_MASRX_Msk
#define SPI_CR1_CSTART_Pos   (9U)
#define SPI_CR1_CSTART_Msk   (0x1UL << SPI_CR1_CSTART_Pos)
#define SPI_CR1_CSTART   SPI_CR1_CSTART_Msk
#define SPI_CR1_CSUSP_Pos   (10U)
#define SPI_CR1_CSUSP_Msk   (0x1UL << SPI_CR1_CSUSP_Pos)
#define SPI_CR1_CSUSP   SPI_CR1_CSUSP_Msk
#define SPI_CR1_HDDIR_Pos   (11U)
#define SPI_CR1_HDDIR_Msk   (0x1UL << SPI_CR1_HDDIR_Pos)
#define SPI_CR1_HDDIR   SPI_CR1_HDDIR_Msk
#define SPI_CR1_SSI_Pos   (12U)
#define SPI_CR1_SSI_Msk   (0x1UL << SPI_CR1_SSI_Pos)
#define SPI_CR1_SSI   SPI_CR1_SSI_Msk
#define SPI_CR1_CRC33_17_Pos   (13U)
#define SPI_CR1_CRC33_17_Msk   (0x1UL << SPI_CR1_CRC33_17_Pos)
#define SPI_CR1_CRC33_17   SPI_CR1_CRC33_17_Msk
#define SPI_CR1_RCRCINI_Pos   (14U)
#define SPI_CR1_RCRCINI_Msk   (0x1UL << SPI_CR1_RCRCINI_Pos)
#define SPI_CR1_RCRCINI   SPI_CR1_RCRCINI_Msk
#define SPI_CR1_TCRCINI_Pos   (15U)
#define SPI_CR1_TCRCINI_Msk   (0x1UL << SPI_CR1_TCRCINI_Pos)
#define SPI_CR1_TCRCINI   SPI_CR1_TCRCINI_Msk
#define SPI_CR1_IOLOCK_Pos   (16U)
#define SPI_CR1_IOLOCK_Msk   (0x1UL << SPI_CR1_IOLOCK_Pos)
#define SPI_CR1_IOLOCK   SPI_CR1_IOLOCK_Msk
#define SPI_CR2_TSIZE_Pos   (0U)
#define SPI_CR2_TSIZE_Msk   (0xFFFFUL << SPI_CR2_TSIZE_Pos)
#define SPI_CR2_TSIZE   SPI_CR2_TSIZE_Msk
#define SPI_CFG1_DSIZE_Pos   (0U)
#define SPI_CFG1_DSIZE_Msk   (0x1FUL << SPI_CFG1_DSIZE_Pos)
#define SPI_CFG1_DSIZE   SPI_CFG1_DSIZE_Msk
#define SPI_CFG1_DSIZE_0   (0x01UL << SPI_CFG1_DSIZE_Pos)
#define SPI_CFG1_DSIZE_1   (0x02UL << SPI_CFG1_DSIZE_Pos)
#define SPI_CFG1_DSIZE_2   (0x04UL << SPI_CFG1_DSIZE_Pos)
#define SPI_CFG1_DSIZE_3   (0x08UL << SPI_CFG1_DSIZE_Pos)
#define SPI_CFG1_DSIZE_4   (0x10UL << SPI_CFG1_DSIZE_Pos)
#define SPI_CFG1_FTHLV_Pos   (5U)
#define SPI_CFG1_FTHLV_Msk   (0xFUL << SPI_CFG1_FTHLV_Pos)
#define SPI_CFG1_FTHLV   SPI_CFG1_FTHLV_Msk
#define SPI_CFG1_FTHLV_0   (0x1UL << SPI_CFG1_FTHLV_Pos)
#define SPI_CFG1_FTHLV_1   (0x2UL << SPI_CFG1_FTHLV_Pos)
#define SPI_CFG1_FTHLV_2   (0x4UL << SPI_CFG1_FTHLV_Pos)
#define SPI_CFG1_FTHLV_3   (0x8UL << SPI_CFG1_FTHLV_Pos)
#define SPI_CFG1_UDRCFG_Pos   (9U)
#define SPI_CFG1_UDRCFG_Msk   (0x1UL << SPI_CFG1_UDRCFG_Pos)
#define SPI_CFG1_UDRCFG   SPI_CFG1_UDRCFG_Msk
#define SPI_CFG1_RXDMAEN_Pos   (14U)
#define SPI_CFG1_RXDMAEN_Msk   (0x1UL << SPI_CFG1_RXDMAEN_Pos)
#define SPI_CFG1_RXDMAEN   SPI_CFG1_RXDMAEN_Msk
#define SPI_CFG1_TXDMAEN_Pos   (15U)
#define SPI_CFG1_TXDMAEN_Msk   (0x1UL << SPI_CFG1_TXDMAEN_Pos)
#define SPI_CFG1_TXDMAEN   SPI_CFG1_TXDMAEN_Msk
#define SPI_CFG1_CRCSIZE_Pos   (16U)
#define SPI_CFG1_CRCSIZE_Msk   (0x1FUL << SPI_CFG1_CRCSIZE_Pos)
#define SPI_CFG1_CRCSIZE   SPI_CFG1_CRCSIZE_Msk
#define SPI_CFG1_CRCSIZE_0   (0x01UL << SPI_CFG1_CRCSIZE_Pos)
#define SPI_CFG1_CRCSIZE_1   (0x02UL << SPI_CFG1_CRCSIZE_Pos)
#define SPI_CFG1_CRCSIZE_2   (0x04UL << SPI_CFG1_CRCSIZE_Pos)
#define SPI_CFG1_CRCSIZE_3   (0x08UL << SPI_CFG1_CRCSIZE_Pos)
#define SPI_CFG1_CRCSIZE_4   (0x10UL << SPI_CFG1_CRCSIZE_Pos)
#define SPI_CFG1_CRCEN_Pos   (22U)
#define SPI_CFG1_CRCEN_Msk   (0x1UL << SPI_CFG1_CRCEN_Pos)
#define SPI_CFG1_CRCEN   SPI_CFG1_CRCEN_Msk
#define SPI_CFG1_MBR_Pos   (28U)
#define SPI_CFG1_MBR_Msk   (0x7UL << SPI_CFG1_MBR_Pos)
#define SPI_CFG1_MBR   SPI_CFG1_MBR_Msk
#define SPI_CFG1_MBR_0   (0x1UL << SPI_CFG1_MBR_Pos)
#define SPI_CFG1_MBR_1   (0x2UL << SPI_CFG1_MBR_Pos)
#define SPI_CFG1_MBR_2   (0x4UL << SPI_CFG1_MBR_Pos)
#define SPI_CFG1_BPASS_Pos   (31U)
#define SPI_CFG1_BPASS_Msk   (0x1UL << SPI_CFG1_BPASS_Pos)
#define SPI_CFG1_BPASS   SPI_CFG1_BPASS_Msk
#define SPI_CFG2_MSSI_Pos   (0U)
#define SPI_CFG2_MSSI_Msk   (0xFUL << SPI_CFG2_MSSI_Pos)
#define SPI_CFG2_MSSI   SPI_CFG2_MSSI_Msk
#define SPI_CFG2_MSSI_0   (0x1UL << SPI_CFG2_MSSI_Pos)
#define SPI_CFG2_MSSI_1   (0x2UL << SPI_CFG2_MSSI_Pos)
#define SPI_CFG2_MSSI_2   (0x4UL << SPI_CFG2_MSSI_Pos)
#define SPI_CFG2_MSSI_3   (0x8UL << SPI_CFG2_MSSI_Pos)
#define SPI_CFG2_MIDI_Pos   (4U)
#define SPI_CFG2_MIDI_Msk   (0xFUL << SPI_CFG2_MIDI_Pos)
#define SPI_CFG2_MIDI   SPI_CFG2_MIDI_Msk
#define SPI_CFG2_MIDI_0   (0x1UL << SPI_CFG2_MIDI_Pos)
#define SPI_CFG2_MIDI_1   (0x2UL << SPI_CFG2_MIDI_Pos)
#define SPI_CFG2_MIDI_2   (0x4UL << SPI_CFG2_MIDI_Pos)
#define SPI_CFG2_MIDI_3   (0x8UL << SPI_CFG2_MIDI_Pos)
#define SPI_CFG2_RDIMM_Pos   (13U)
#define SPI_CFG2_RDIMM_Msk   (0x1UL << SPI_CFG2_RDIMM_Pos)
#define SPI_CFG2_RDIMM   SPI_CFG2_RDIMM_Msk
#define SPI_CFG2_RDIOP_Pos   (14U)
#define SPI_CFG2_RDIOP_Msk   (0x1UL << SPI_CFG2_RDIOP_Pos)
#define SPI_CFG2_RDIOP   SPI_CFG2_RDIOP_Msk
#define SPI_CFG2_IOSWP_Pos   (15U)
#define SPI_CFG2_IOSWP_Msk   (0x1UL << SPI_CFG2_IOSWP_Pos)
#define SPI_CFG2_IOSWP   SPI_CFG2_IOSWP_Msk
#define SPI_CFG2_COMM_Pos   (17U)
#define SPI_CFG2_COMM_Msk   (0x3UL << SPI_CFG2_COMM_Pos)
#define SPI_CFG2_COMM   SPI_CFG2_COMM_Msk
#define SPI_CFG2_COMM_0   (0x1UL << SPI_CFG2_COMM_Pos)
#define SPI_CFG2_COMM_1   (0x2UL << SPI_CFG2_COMM_Pos)
#define SPI_CFG2_SP_Pos   (19U)
#define SPI_CFG2_SP_Msk   (0x7UL << SPI_CFG2_SP_Pos)
#define SPI_CFG2_SP   SPI_CFG2_SP_Msk
#define SPI_CFG2_SP_0   (0x1UL << SPI_CFG2_SP_Pos)
#define SPI_CFG2_SP_1   (0x2UL << SPI_CFG2_SP_Pos)
#define SPI_CFG2_SP_2   (0x4UL << SPI_CFG2_SP_Pos)
#define SPI_CFG2_MASTER_Pos   (22U)
#define SPI_CFG2_MASTER_Msk   (0x1UL << SPI_CFG2_MASTER_Pos)
#define SPI_CFG2_MASTER   SPI_CFG2_MASTER_Msk
#define SPI_CFG2_LSBFRST_Pos   (23U)
#define SPI_CFG2_LSBFRST_Msk   (0x1UL << SPI_CFG2_LSBFRST_Pos)
#define SPI_CFG2_LSBFRST   SPI_CFG2_LSBFRST_Msk
#define SPI_CFG2_CPHA_Pos   (24U)
#define SPI_CFG2_CPHA_Msk   (0x1UL << SPI_CFG2_CPHA_Pos)
#define SPI_CFG2_CPHA   SPI_CFG2_CPHA_Msk
#define SPI_CFG2_CPOL_Pos   (25U)
#define SPI_CFG2_CPOL_Msk   (0x1UL << SPI_CFG2_CPOL_Pos)
#define SPI_CFG2_CPOL   SPI_CFG2_CPOL_Msk
#define SPI_CFG2_SSM_Pos   (26U)
#define SPI_CFG2_SSM_Msk   (0x1UL << SPI_CFG2_SSM_Pos)
#define SPI_CFG2_SSM   SPI_CFG2_SSM_Msk
#define SPI_CFG2_SSIOP_Pos   (28U)
#define SPI_CFG2_SSIOP_Msk   (0x1UL << SPI_CFG2_SSIOP_Pos)
#define SPI_CFG2_SSIOP   SPI_CFG2_SSIOP_Msk
#define SPI_CFG2_SSOE_Pos   (29U)
#define SPI_CFG2_SSOE_Msk   (0x1UL << SPI_CFG2_SSOE_Pos)
#define SPI_CFG2_SSOE   SPI_CFG2_SSOE_Msk
#define SPI_CFG2_SSOM_Pos   (30U)
#define SPI_CFG2_SSOM_Msk   (0x1UL << SPI_CFG2_SSOM_Pos)
#define SPI_CFG2_SSOM   SPI_CFG2_SSOM_Msk
#define SPI_CFG2_AFCNTR_Pos   (31U)
#define SPI_CFG2_AFCNTR_Msk   (0x1UL << SPI_CFG2_AFCNTR_Pos)
#define SPI_CFG2_AFCNTR   SPI_CFG2_AFCNTR_Msk
#define SPI_IER_RXPIE_Pos   (0U)
#define SPI_IER_RXPIE_Msk   (0x1UL << SPI_IER_RXPIE_Pos)
#define SPI_IER_RXPIE   SPI_IER_RXPIE_Msk
#define SPI_IER_TXPIE_Pos   (1U)
#define SPI_IER_TXPIE_Msk   (0x1UL << SPI_IER_TXPIE_Pos)
#define SPI_IER_TXPIE   SPI_IER_TXPIE_Msk
#define SPI_IER_DXPIE_Pos   (2U)
#define SPI_IER_DXPIE_Msk   (0x1UL << SPI_IER_DXPIE_Pos)
#define SPI_IER_DXPIE   SPI_IER_DXPIE_Msk
#define SPI_IER_EOTIE_Pos   (3U)
#define SPI_IER_EOTIE_Msk   (0x1UL << SPI_IER_EOTIE_Pos)
#define SPI_IER_EOTIE   SPI_IER_EOTIE_Msk
#define SPI_IER_TXTFIE_Pos   (4U)
#define SPI_IER_TXTFIE_Msk   (0x1UL << SPI_IER_TXTFIE_Pos)
#define SPI_IER_TXTFIE   SPI_IER_TXTFIE_Msk
#define SPI_IER_UDRIE_Pos   (5U)
#define SPI_IER_UDRIE_Msk   (0x1UL << SPI_IER_UDRIE_Pos)
#define SPI_IER_UDRIE   SPI_IER_UDRIE_Msk
#define SPI_IER_OVRIE_Pos   (6U)
#define SPI_IER_OVRIE_Msk   (0x1UL << SPI_IER_OVRIE_Pos)
#define SPI_IER_OVRIE   SPI_IER_OVRIE_Msk
#define SPI_IER_CRCEIE_Pos   (7U)
#define SPI_IER_CRCEIE_Msk   (0x1UL << SPI_IER_CRCEIE_Pos)
#define SPI_IER_CRCEIE   SPI_IER_CRCEIE_Msk
#define SPI_IER_TIFREIE_Pos   (8U)
#define SPI_IER_TIFREIE_Msk   (0x1UL << SPI_IER_TIFREIE_Pos)
#define SPI_IER_TIFREIE   SPI_IER_TIFREIE_Msk
#define SPI_IER_MODFIE_Pos   (9U)
#define SPI_IER_MODFIE_Msk   (0x1UL << SPI_IER_MODFIE_Pos)
#define SPI_IER_MODFIE   SPI_IER_MODFIE_Msk
#define SPI_SR_RXP_Pos   (0U)
#define SPI_SR_RXP_Msk   (0x1UL << SPI_SR_RXP_Pos)
#define SPI_SR_RXP   SPI_SR_RXP_Msk
#define SPI_SR_TXP_Pos   (1U)
#define SPI_SR_TXP_Msk   (0x1UL << SPI_SR_TXP_Pos)
#define SPI_SR_TXP   SPI_SR_TXP_Msk
#define SPI_SR_DXP_Pos   (2U)
#define SPI_SR_DXP_Msk   (0x1UL << SPI_SR_DXP_Pos)
#define SPI_SR_DXP   SPI_SR_DXP_Msk
#define SPI_SR_EOT_Pos   (3U)
#define SPI_SR_EOT_Msk   (0x1UL << SPI_SR_EOT_Pos)
#define SPI_SR_EOT   SPI_SR_EOT_Msk
#define SPI_SR_TXTF_Pos   (4U)
#define SPI_SR_TXTF_Msk   (0x1UL << SPI_SR_TXTF_Pos)
#define SPI_SR_TXTF   SPI_SR_TXTF_Msk
#define SPI_SR_UDR_Pos   (5U)
#define SPI_SR_UDR_Msk   (0x1UL << SPI_SR_UDR_Pos)
#define SPI_SR_UDR   SPI_SR_UDR_Msk
#define SPI_SR_OVR_Pos   (6U)
#define SPI_SR_OVR_Msk   (0x1UL << SPI_SR_OVR_Pos)
#define SPI_SR_OVR   SPI_SR_OVR_Msk
#define SPI_SR_CRCE_Pos   (7U)
#define SPI_SR_CRCE_Msk   (0x1UL << SPI_SR_CRCE_Pos)
#define SPI_SR_CRCE   SPI_SR_CRCE_Msk
#define SPI_SR_TIFRE_Pos   (8U)
#define SPI_SR_TIFRE_Msk   (0x1UL << SPI_SR_TIFRE_Pos)
#define SPI_SR_TIFRE   SPI_SR_TIFRE_Msk
#define SPI_SR_MODF_Pos   (9U)
#define SPI_SR_MODF_Msk   (0x1UL << SPI_SR_MODF_Pos)
#define SPI_SR_MODF   SPI_SR_MODF_Msk
#define SPI_SR_SUSP_Pos   (11U)
#define SPI_SR_SUSP_Msk   (0x1UL << SPI_SR_SUSP_Pos)
#define SPI_SR_SUSP   SPI_SR_SUSP_Msk
#define SPI_SR_TXC_Pos   (12U)
#define SPI_SR_TXC_Msk   (0x1UL << SPI_SR_TXC_Pos)
#define SPI_SR_TXC   SPI_SR_TXC_Msk
#define SPI_SR_RXPLVL_Pos   (13U)
#define SPI_SR_RXPLVL_Msk   (0x3UL << SPI_SR_RXPLVL_Pos)
#define SPI_SR_RXPLVL   SPI_SR_RXPLVL_Msk
#define SPI_SR_RXPLVL_0   (0x1UL << SPI_SR_RXPLVL_Pos)
#define SPI_SR_RXPLVL_1   (0x2UL << SPI_SR_RXPLVL_Pos)
#define SPI_SR_RXWNE_Pos   (15U)
#define SPI_SR_RXWNE_Msk   (0x1UL << SPI_SR_RXWNE_Pos)
#define SPI_SR_RXWNE   SPI_SR_RXWNE_Msk
#define SPI_SR_CTSIZE_Pos   (16U)
#define SPI_SR_CTSIZE_Msk   (0xFFFFUL << SPI_SR_CTSIZE_Pos)
#define SPI_SR_CTSIZE   SPI_SR_CTSIZE_Msk
#define SPI_IFCR_EOTC_Pos   (3U)
#define SPI_IFCR_EOTC_Msk   (0x1UL << SPI_IFCR_EOTC_Pos)
#define SPI_IFCR_EOTC   SPI_IFCR_EOTC_Msk
#define SPI_IFCR_TXTFC_Pos   (4U)
#define SPI_IFCR_TXTFC_Msk   (0x1UL << SPI_IFCR_TXTFC_Pos)
#define SPI_IFCR_TXTFC   SPI_IFCR_TXTFC_Msk
#define SPI_IFCR_UDRC_Pos   (5U)
#define SPI_IFCR_UDRC_Msk   (0x1UL << SPI_IFCR_UDRC_Pos)
#define SPI_IFCR_UDRC   SPI_IFCR_UDRC_Msk
#define SPI_IFCR_OVRC_Pos   (6U)
#define SPI_IFCR_OVRC_Msk   (0x1UL << SPI_IFCR_OVRC_Pos)
#define SPI_IFCR_OVRC   SPI_IFCR_OVRC_Msk
#define SPI_IFCR_CRCEC_Pos   (7U)
#define SPI_IFCR_CRCEC_Msk   (0x1UL << SPI_IFCR_CRCEC_Pos)
#define SPI_IFCR_CRCEC   SPI_IFCR_CRCEC_Msk
#define SPI_IFCR_TIFREC_Pos   (8U)
#define SPI_IFCR_TIFREC_Msk   (0x1UL << SPI_IFCR_TIFREC_Pos)
#define SPI_IFCR_TIFREC   SPI_IFCR_TIFREC_Msk
#define SPI_IFCR_MODFC_Pos   (9U)
#define SPI_IFCR_MODFC_Msk   (0x1UL << SPI_IFCR_MODFC_Pos)
#define SPI_IFCR_MODFC   SPI_IFCR_MODFC_Msk
#define SPI_IFCR_SUSPC_Pos   (11U)
#define SPI_IFCR_SUSPC_Msk   (0x1UL << SPI_IFCR_SUSPC_Pos)
#define SPI_IFCR_SUSPC   SPI_IFCR_SUSPC_Msk
#define SPI_AUTOCR_TRIGSEL_Pos   (16U)
#define SPI_AUTOCR_TRIGSEL_Msk   (0xFUL << SPI_AUTOCR_TRIGSEL_Pos)
#define SPI_AUTOCR_TRIGSEL   SPI_AUTOCR_TRIGSEL_Msk
#define SPI_AUTOCR_TRIGSEL_0   (0x01UL << SPI_AUTOCR_TRIGSEL_Pos)
#define SPI_AUTOCR_TRIGSEL_1   (0x02UL << SPI_AUTOCR_TRIGSEL_Pos)
#define SPI_AUTOCR_TRIGSEL_2   (0x04UL << SPI_AUTOCR_TRIGSEL_Pos)
#define SPI_AUTOCR_TRIGSEL_3   (0x08UL << SPI_AUTOCR_TRIGSEL_Pos)
#define SPI_AUTOCR_TRIGPOL_Pos   (20U)
#define SPI_AUTOCR_TRIGPOL_Msk   (0x1UL << SPI_AUTOCR_TRIGPOL_Pos)
#define SPI_AUTOCR_TRIGPOL   SPI_AUTOCR_TRIGPOL_Msk
#define SPI_AUTOCR_TRIGEN_Pos   (21U)
#define SPI_AUTOCR_TRIGEN_Msk   (0x1UL << SPI_AUTOCR_TRIGEN_Pos)
#define SPI_AUTOCR_TRIGEN   SPI_AUTOCR_TRIGEN_Msk
#define SPI_TXDR_TXDR_Pos   (0U)
#define SPI_TXDR_TXDR_Msk   (0xFFFFFFFFUL << SPI_TXDR_TXDR_Pos)
#define SPI_TXDR_TXDR   SPI_TXDR_TXDR_Msk /* Transmit Data Register */
#define SPI_RXDR_RXDR_Pos   (0U)
#define SPI_RXDR_RXDR_Msk   (0xFFFFFFFFUL << SPI_RXDR_RXDR_Pos)
#define SPI_RXDR_RXDR   SPI_RXDR_RXDR_Msk /* Receive Data Register */
#define SPI_CRCPOLY_CRCPOLY_Pos   (0U)
#define SPI_CRCPOLY_CRCPOLY_Msk   (0xFFFFFFFFUL << SPI_CRCPOLY_CRCPOLY_Pos)
#define SPI_CRCPOLY_CRCPOLY   SPI_CRCPOLY_CRCPOLY_Msk /* CRC Polynomial register */
#define SPI_TXCRC_TXCRC_Pos   (0U)
#define SPI_TXCRC_TXCRC_Msk   (0xFFFFFFFFUL << SPI_TXCRC_TXCRC_Pos)
#define SPI_TXCRC_TXCRC   SPI_TXCRC_TXCRC_Msk /* CRCRegister for transmitter */
#define SPI_RXCRC_RXCRC_Pos   (0U)
#define SPI_RXCRC_RXCRC_Msk   (0xFFFFFFFFUL << SPI_RXCRC_RXCRC_Pos)
#define SPI_RXCRC_RXCRC   SPI_RXCRC_RXCRC_Msk /* CRCRegister for receiver */
#define SPI_UDRDR_UDRDR_Pos   (0U)
#define SPI_UDRDR_UDRDR_Msk   (0xFFFFFFFFUL << SPI_UDRDR_UDRDR_Pos)
#define SPI_UDRDR_UDRDR   SPI_UDRDR_UDRDR_Msk /* Data at slave underrun condition */
#define VREFBUF_CSR_ENVR_Pos   (0U)
#define VREFBUF_CSR_ENVR_Msk   (0x1UL << VREFBUF_CSR_ENVR_Pos)
#define VREFBUF_CSR_ENVR   VREFBUF_CSR_ENVR_Msk
#define VREFBUF_CSR_HIZ_Pos   (1U)
#define VREFBUF_CSR_HIZ_Msk   (0x1UL << VREFBUF_CSR_HIZ_Pos)
#define VREFBUF_CSR_HIZ   VREFBUF_CSR_HIZ_Msk
#define VREFBUF_CSR_VRS_Pos   (4U)
#define VREFBUF_CSR_VRS_Msk   (0x7UL << VREFBUF_CSR_VRS_Pos)
#define VREFBUF_CSR_VRS   VREFBUF_CSR_VRS_Msk
#define VREFBUF_CSR_VRS_0   (0x01UL<< VREFBUF_CSR_VRS_Pos)
#define VREFBUF_CSR_VRS_1   (0x02UL<< VREFBUF_CSR_VRS_Pos)
#define VREFBUF_CSR_VRS_2   (0x04UL<< VREFBUF_CSR_VRS_Pos)
#define VREFBUF_CSR_VRR_Pos   (3U)
#define VREFBUF_CSR_VRR_Msk   (0x1UL << VREFBUF_CSR_VRR_Pos)
#define VREFBUF_CSR_VRR   VREFBUF_CSR_VRR_Msk
#define VREFBUF_CCR_TRIM_Pos   (0U)
#define VREFBUF_CCR_TRIM_Msk   (0x3FUL << VREFBUF_CCR_TRIM_Pos)
#define VREFBUF_CCR_TRIM   VREFBUF_CCR_TRIM_Msk
#define WWDG_CR_T_Pos   (0U)
#define WWDG_CR_T_Msk   (0x7FUL << WWDG_CR_T_Pos)
#define WWDG_CR_T   WWDG_CR_T_Msk
#define WWDG_CR_T_0   (0x01UL << WWDG_CR_T_Pos)
#define WWDG_CR_T_1   (0x02UL << WWDG_CR_T_Pos)
#define WWDG_CR_T_2   (0x04UL << WWDG_CR_T_Pos)
#define WWDG_CR_T_3   (0x08UL << WWDG_CR_T_Pos)
#define WWDG_CR_T_4   (0x10UL << WWDG_CR_T_Pos)
#define WWDG_CR_T_5   (0x20UL << WWDG_CR_T_Pos)
#define WWDG_CR_T_6   (0x40UL << WWDG_CR_T_Pos)
#define WWDG_CR_WDGA_Pos   (7U)
#define WWDG_CR_WDGA_Msk   (0x1UL << WWDG_CR_WDGA_Pos)
#define WWDG_CR_WDGA   WWDG_CR_WDGA_Msk
#define WWDG_CFR_W_Pos   (0U)
#define WWDG_CFR_W_Msk   (0x7FUL << WWDG_CFR_W_Pos)
#define WWDG_CFR_W   WWDG_CFR_W_Msk
#define WWDG_CFR_W_0   (0x01UL << WWDG_CFR_W_Pos)
#define WWDG_CFR_W_1   (0x02UL << WWDG_CFR_W_Pos)
#define WWDG_CFR_W_2   (0x04UL << WWDG_CFR_W_Pos)
#define WWDG_CFR_W_3   (0x08UL << WWDG_CFR_W_Pos)
#define WWDG_CFR_W_4   (0x10UL << WWDG_CFR_W_Pos)
#define WWDG_CFR_W_5   (0x20UL << WWDG_CFR_W_Pos)
#define WWDG_CFR_W_6   (0x40UL << WWDG_CFR_W_Pos)
#define WWDG_CFR_WDGTB_Pos   (11U)
#define WWDG_CFR_WDGTB_Msk   (0x7UL << WWDG_CFR_WDGTB_Pos)
#define WWDG_CFR_WDGTB   WWDG_CFR_WDGTB_Msk
#define WWDG_CFR_WDGTB_0   (0x1UL << WWDG_CFR_WDGTB_Pos)
#define WWDG_CFR_WDGTB_1   (0x2UL << WWDG_CFR_WDGTB_Pos)
#define WWDG_CFR_WDGTB_2   (0x4UL << WWDG_CFR_WDGTB_Pos)
#define WWDG_CFR_EWI_Pos   (9U)
#define WWDG_CFR_EWI_Msk   (0x1UL << WWDG_CFR_EWI_Pos)
#define WWDG_CFR_EWI   WWDG_CFR_EWI_Msk
#define WWDG_SR_EWIF_Pos   (0U)
#define WWDG_SR_EWIF_Msk   (0x1UL << WWDG_SR_EWIF_Pos)
#define WWDG_SR_EWIF   WWDG_SR_EWIF_Msk
#define PKA_CR_EN_Pos   (0U)
#define PKA_CR_EN_Msk   (0x1UL << PKA_CR_EN_Pos)
#define PKA_CR_EN   PKA_CR_EN_Msk
#define PKA_CR_START_Pos   (1U)
#define PKA_CR_START_Msk   (0x1UL << PKA_CR_START_Pos)
#define PKA_CR_START   PKA_CR_START_Msk
#define PKA_CR_MODE_Pos   (8U)
#define PKA_CR_MODE_Msk   (0x3FUL << PKA_CR_MODE_Pos)
#define PKA_CR_MODE   PKA_CR_MODE_Msk
#define PKA_CR_MODE_0   (0x01UL << PKA_CR_MODE_Pos)
#define PKA_CR_MODE_1   (0x02UL << PKA_CR_MODE_Pos)
#define PKA_CR_MODE_2   (0x04UL << PKA_CR_MODE_Pos)
#define PKA_CR_MODE_3   (0x08UL << PKA_CR_MODE_Pos)
#define PKA_CR_MODE_4   (0x10UL << PKA_CR_MODE_Pos)
#define PKA_CR_MODE_5   (0x20UL << PKA_CR_MODE_Pos)
#define PKA_CR_PROCENDIE_Pos   (17U)
#define PKA_CR_PROCENDIE_Msk   (0x1UL << PKA_CR_PROCENDIE_Pos)
#define PKA_CR_PROCENDIE   PKA_CR_PROCENDIE_Msk
#define PKA_CR_RAMERRIE_Pos   (19U)
#define PKA_CR_RAMERRIE_Msk   (0x1UL << PKA_CR_RAMERRIE_Pos)
#define PKA_CR_RAMERRIE   PKA_CR_RAMERRIE_Msk
#define PKA_CR_ADDRERRIE_Pos   (20U)
#define PKA_CR_ADDRERRIE_Msk   (0x1UL << PKA_CR_ADDRERRIE_Pos)
#define PKA_CR_ADDRERRIE   PKA_CR_ADDRERRIE_Msk
#define PKA_CR_OPERRIE_Pos   (21U)
#define PKA_CR_OPERRIE_Msk   (0x1UL << PKA_CR_OPERRIE_Pos)
#define PKA_CR_OPERRIE   PKA_CR_OPERRIE_Msk
#define PKA_SR_INITOK_Pos   (0U)
#define PKA_SR_INITOK_Msk   (0x1UL << PKA_SR_INITOK_Pos)
#define PKA_SR_INITOK   PKA_SR_INITOK_Msk
#define PKA_SR_BUSY_Pos   (16U)
#define PKA_SR_BUSY_Msk   (0x1UL << PKA_SR_BUSY_Pos)
#define PKA_SR_BUSY   PKA_SR_BUSY_Msk
#define PKA_SR_PROCENDF_Pos   (17U)
#define PKA_SR_PROCENDF_Msk   (0x1UL << PKA_SR_PROCENDF_Pos)
#define PKA_SR_PROCENDF   PKA_SR_PROCENDF_Msk
#define PKA_SR_RAMERRF_Pos   (19U)
#define PKA_SR_RAMERRF_Msk   (0x1UL << PKA_SR_RAMERRF_Pos)
#define PKA_SR_RAMERRF   PKA_SR_RAMERRF_Msk
#define PKA_SR_ADDRERRF_Pos   (20U)
#define PKA_SR_ADDRERRF_Msk   (0x1UL << PKA_SR_ADDRERRF_Pos)
#define PKA_SR_ADDRERRF   PKA_SR_ADDRERRF_Msk
#define PKA_SR_OPERRF_Pos   (21U)
#define PKA_SR_OPERRF_Msk   (0x1UL << PKA_SR_OPERRF_Pos)
#define PKA_SR_OPERRF   PKA_SR_OPERRF_Msk
#define PKA_CLRFR_PROCENDFC_Pos   (17U)
#define PKA_CLRFR_PROCENDFC_Msk   (0x1UL << PKA_CLRFR_PROCENDFC_Pos)
#define PKA_CLRFR_PROCENDFC   PKA_CLRFR_PROCENDFC_Msk
#define PKA_CLRFR_RAMERRFC_Pos   (19U)
#define PKA_CLRFR_RAMERRFC_Msk   (0x1UL << PKA_CLRFR_RAMERRFC_Pos)
#define PKA_CLRFR_RAMERRFC   PKA_CLRFR_RAMERRFC_Msk
#define PKA_CLRFR_ADDRERRFC_Pos   (20U)
#define PKA_CLRFR_ADDRERRFC_Msk   (0x1UL << PKA_CLRFR_ADDRERRFC_Pos)
#define PKA_CLRFR_ADDRERRFC   PKA_CLRFR_ADDRERRFC_Msk
#define PKA_CLRFR_OPERRFC_Pos   (21U)
#define PKA_CLRFR_OPERRFC_Msk   (0x1UL << PKA_CLRFR_OPERRFC_Pos)
#define PKA_CLRFR_OPERRFC   PKA_CLRFR_OPERRFC_Msk
#define PKA_RAM_OFFSET   (0x0400UL)
#define PKA_MONTGOMERY_PARAM_IN_MOD_NB_BITS   ((0x0408UL - PKA_RAM_OFFSET)>>2)
#define PKA_MONTGOMERY_PARAM_IN_MODULUS   ((0x1088UL - PKA_RAM_OFFSET)>>2)
#define PKA_MONTGOMERY_PARAM_OUT_PARAMETER   ((0x0620UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_EXP_IN_EXP_NB_BITS   ((0x0400UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_EXP_IN_OP_NB_BITS   ((0x0408UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_EXP_IN_MONTGOMERY_PARAM   ((0x0620UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_EXP_IN_EXPONENT_BASE   ((0x0C68UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_EXP_IN_EXPONENT   ((0x0E78UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_EXP_IN_MODULUS   ((0x1088UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_EXP_PROTECT_IN_EXPONENT_BASE   ((0x16C8UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_EXP_PROTECT_IN_EXPONENT   ((0x14B8UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_EXP_PROTECT_IN_MODULUS   ((0x0838UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_EXP_PROTECT_IN_PHI   ((0x0C68UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_EXP_OUT_RESULT   ((0x0838UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_EXP_OUT_ERROR   ((0x1298UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_EXP_OUT_MONTGOMERY_PARAM   ((0x0620UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_EXP_OUT_EXPONENT_BASE   ((0x0C68UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_SCALAR_MUL_IN_EXP_NB_BITS   ((0x0400UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_SCALAR_MUL_IN_OP_NB_BITS   ((0x0408UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_SCALAR_MUL_IN_A_COEFF_SIGN   ((0x0410UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_SCALAR_MUL_IN_A_COEFF   ((0x0418UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_SCALAR_MUL_IN_B_COEFF   ((0x0520UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_SCALAR_MUL_IN_MOD_GF   ((0x1088UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_SCALAR_MUL_IN_K   ((0x12A0UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_SCALAR_MUL_IN_INITIAL_POINT_X   ((0x0578UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_SCALAR_MUL_IN_INITIAL_POINT_Y   ((0x0470UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_SCALAR_MUL_IN_N_PRIME_ORDER   ((0x0F88UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_SCALAR_MUL_OUT_RESULT_X   ((0x0578UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_SCALAR_MUL_OUT_RESULT_Y   ((0x05D0UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_SCALAR_MUL_OUT_ERROR   ((0x0680UL - PKA_RAM_OFFSET)>>2)
#define PKA_POINT_CHECK_IN_MOD_NB_BITS   ((0x0408UL - PKA_RAM_OFFSET)>>2)
#define PKA_POINT_CHECK_IN_A_COEFF_SIGN   ((0x0410UL - PKA_RAM_OFFSET)>>2)
#define PKA_POINT_CHECK_IN_A_COEFF   ((0x0418UL - PKA_RAM_OFFSET)>>2)
#define PKA_POINT_CHECK_IN_B_COEFF   ((0x0520UL - PKA_RAM_OFFSET)>>2)
#define PKA_POINT_CHECK_IN_MOD_GF   ((0x0470UL - PKA_RAM_OFFSET)>>2)
#define PKA_POINT_CHECK_IN_INITIAL_POINT_X   ((0x0578UL - PKA_RAM_OFFSET)>>2)
#define PKA_POINT_CHECK_IN_INITIAL_POINT_Y   ((0x05D0UL - PKA_RAM_OFFSET)>>2)
#define PKA_POINT_CHECK_IN_MONTGOMERY_PARAM   ((0x04C8UL - PKA_RAM_OFFSET)>>2)
#define PKA_POINT_CHECK_OUT_ERROR   ((0x0680UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_SIGN_IN_ORDER_NB_BITS   ((0x0400UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_SIGN_IN_MOD_NB_BITS   ((0x0408UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_SIGN_IN_A_COEFF_SIGN   ((0x0410UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_SIGN_IN_A_COEFF   ((0x0418UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_SIGN_IN_B_COEFF   ((0x0520UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_SIGN_IN_MOD_GF   ((0x1088UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_SIGN_IN_K   ((0x12A0UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_SIGN_IN_INITIAL_POINT_X   ((0x0578UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_SIGN_IN_INITIAL_POINT_Y   ((0x0470UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_SIGN_IN_HASH_E   ((0x0FE8UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_SIGN_IN_PRIVATE_KEY_D   ((0x0F28UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_SIGN_IN_ORDER_N   ((0x0F88UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_SIGN_OUT_ERROR   ((0x0FE0UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_SIGN_OUT_SIGNATURE_R   ((0x0730UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_SIGN_OUT_SIGNATURE_S   ((0x0788UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_SIGN_OUT_FINAL_POINT_X   ((0x1400UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_SIGN_OUT_FINAL_POINT_Y   ((0x1458UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_VERIF_IN_ORDER_NB_BITS   ((0x0408UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_VERIF_IN_MOD_NB_BITS   ((0x04C8UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_VERIF_IN_A_COEFF_SIGN   ((0x0468UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_VERIF_IN_A_COEFF   ((0x0470UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_VERIF_IN_MOD_GF   ((0x04D0UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_VERIF_IN_INITIAL_POINT_X   ((0x0678UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_VERIF_IN_INITIAL_POINT_Y   ((0x06D0UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_VERIF_IN_PUBLIC_KEY_POINT_X   ((0x12F8UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_VERIF_IN_PUBLIC_KEY_POINT_Y   ((0x1350UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_VERIF_IN_SIGNATURE_R   ((0x10E0UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_VERIF_IN_SIGNATURE_S   ((0x0C68UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_VERIF_IN_HASH_E   ((0x13A8UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_VERIF_IN_ORDER_N   ((0x1088UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECDSA_VERIF_OUT_RESULT   ((0x05D0UL - PKA_RAM_OFFSET)>>2)
#define PKA_RSA_CRT_EXP_IN_MOD_NB_BITS   ((0x0408UL - PKA_RAM_OFFSET)>>2)
#define PKA_RSA_CRT_EXP_IN_DP_CRT   ((0x0730UL - PKA_RAM_OFFSET)>>2)
#define PKA_RSA_CRT_EXP_IN_DQ_CRT   ((0x0E78UL - PKA_RAM_OFFSET)>>2)
#define PKA_RSA_CRT_EXP_IN_QINV_CRT   ((0x0948UL - PKA_RAM_OFFSET)>>2)
#define PKA_RSA_CRT_EXP_IN_PRIME_P   ((0x0B60UL - PKA_RAM_OFFSET)>>2)
#define PKA_RSA_CRT_EXP_IN_PRIME_Q   ((0x1088UL - PKA_RAM_OFFSET)>>2)
#define PKA_RSA_CRT_EXP_IN_EXPONENT_BASE   ((0x12A0UL - PKA_RAM_OFFSET)>>2)
#define PKA_RSA_CRT_EXP_OUT_RESULT   ((0x0838UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_REDUC_IN_OP_LENGTH   ((0x0400UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_REDUC_IN_MOD_LENGTH   ((0x0408UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_REDUC_IN_OPERAND   ((0x0A50UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_REDUC_IN_MODULUS   ((0x0C68UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_REDUC_OUT_RESULT   ((0xE78UL - PKA_RAM_OFFSET)>>2)
#define PKA_ARITHMETIC_ADD_IN_OP_NB_BITS   ((0x0408UL - PKA_RAM_OFFSET)>>2)
#define PKA_ARITHMETIC_ADD_IN_OP1   ((0x0A50UL - PKA_RAM_OFFSET)>>2)
#define PKA_ARITHMETIC_ADD_IN_OP2   ((0x0C68UL - PKA_RAM_OFFSET)>>2)
#define PKA_ARITHMETIC_ADD_OUT_RESULT   ((0x0E78UL - PKA_RAM_OFFSET)>>2)
#define PKA_ARITHMETIC_SUB_IN_OP_NB_BITS   ((0x0408UL - PKA_RAM_OFFSET)>>2)
#define PKA_ARITHMETIC_SUB_IN_OP1   ((0x0A50UL - PKA_RAM_OFFSET)>>2)
#define PKA_ARITHMETIC_SUB_IN_OP2   ((0x0C68UL - PKA_RAM_OFFSET)>>2)
#define PKA_ARITHMETIC_SUB_OUT_RESULT   ((0x0E78UL - PKA_RAM_OFFSET)>>2)
#define PKA_ARITHMETIC_MUL_NB_BITS   ((0x0408UL - PKA_RAM_OFFSET)>>2)
#define PKA_ARITHMETIC_MUL_IN_OP1   ((0x0A50UL - PKA_RAM_OFFSET)>>2)
#define PKA_ARITHMETIC_MUL_IN_OP2   ((0x0C68UL - PKA_RAM_OFFSET)>>2)
#define PKA_ARITHMETIC_MUL_OUT_RESULT   ((0x0E78UL - PKA_RAM_OFFSET)>>2)
#define PKA_COMPARISON_IN_OP_NB_BITS   ((0x0408UL - PKA_RAM_OFFSET)>>2)
#define PKA_COMPARISON_IN_OP1   ((0x0A50UL - PKA_RAM_OFFSET)>>2)
#define PKA_COMPARISON_IN_OP2   ((0x0C68UL - PKA_RAM_OFFSET)>>2)
#define PKA_COMPARISON_OUT_RESULT   ((0x0E78UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_ADD_NB_BITS   ((0x0408UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_ADD_IN_OP1   ((0x0A50UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_ADD_IN_OP2   ((0x0C68UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_ADD_IN_OP3_MOD   ((0x1088UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_ADD_OUT_RESULT   ((0x0E78UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_INV_NB_BITS   ((0x0408UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_INV_IN_OP1   ((0x0A50UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_INV_IN_OP2_MOD   ((0x0C68UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_INV_OUT_RESULT   ((0x0E78UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_SUB_IN_OP_NB_BITS   ((0x0408UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_SUB_IN_OP1   ((0x0A50UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_SUB_IN_OP2   ((0x0C68UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_SUB_IN_OP3_MOD   ((0x1088UL - PKA_RAM_OFFSET)>>2)
#define PKA_MODULAR_SUB_OUT_RESULT   ((0x0E78UL - PKA_RAM_OFFSET)>>2)
#define PKA_MONTGOMERY_MUL_IN_OP_NB_BITS   ((0x0408UL - PKA_RAM_OFFSET)>>2)
#define PKA_MONTGOMERY_MUL_IN_OP1   ((0x0A50UL - PKA_RAM_OFFSET)>>2)
#define PKA_MONTGOMERY_MUL_IN_OP2   ((0x0C68UL - PKA_RAM_OFFSET)>>2)
#define PKA_MONTGOMERY_MUL_IN_OP3_MOD   ((0x1088UL - PKA_RAM_OFFSET)>>2)
#define PKA_MONTGOMERY_MUL_OUT_RESULT   ((0x0E78UL - PKA_RAM_OFFSET)>>2)
#define PKA_ARITHMETIC_ALL_OPS_NB_BITS   ((0x0408UL - PKA_RAM_OFFSET)>>2)
#define PKA_ARITHMETIC_ALL_OPS_IN_OP1   ((0x0A50UL - PKA_RAM_OFFSET)>>2)
#define PKA_ARITHMETIC_ALL_OPS_IN_OP2   ((0x0C68UL - PKA_RAM_OFFSET)>>2)
#define PKA_ARITHMETIC_ALL_OPS_IN_OP3   ((0x1088UL - PKA_RAM_OFFSET)>>2)
#define PKA_ARITHMETIC_ALL_OPS_OUT_RESULT   ((0x0E78UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_COMPLETE_ADD_IN_MOD_NB_BITS   ((0x0408UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_COMPLETE_ADD_IN_A_COEFF_SIGN   ((0x0410UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_COMPLETE_ADD_IN_A_COEFF   ((0x0418UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_COMPLETE_ADD_IN_MOD_P   ((0x0470UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_COMPLETE_ADD_IN_POINT1_X   ((0x0628UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_COMPLETE_ADD_IN_POINT1_Y   ((0x0680UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_COMPLETE_ADD_IN_POINT1_Z   ((0x06D8UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_COMPLETE_ADD_IN_POINT2_X   ((0x0730UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_COMPLETE_ADD_IN_POINT2_Y   ((0x0788UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_COMPLETE_ADD_IN_POINT2_Z   ((0x07E0UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_COMPLETE_ADD_OUT_RESULT_X   ((0x0D60UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_COMPLETE_ADD_OUT_RESULT_Y   ((0x0DB8UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_COMPLETE_ADD_OUT_RESULT_Z   ((0x0E10UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_DOUBLE_LADDER_IN_PRIME_ORDER_NB_BITS   ((0x0400UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_DOUBLE_LADDER_IN_MOD_NB_BITS   ((0x0408UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_DOUBLE_LADDER_IN_A_COEFF_SIGN   ((0x0410UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_DOUBLE_LADDER_IN_A_COEFF   ((0x0418UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_DOUBLE_LADDER_IN_MOD_P   ((0x0470UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_DOUBLE_LADDER_IN_K_INTEGER   ((0x0520UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_DOUBLE_LADDER_IN_M_INTEGER   ((0x0578UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_DOUBLE_LADDER_IN_POINT1_X   ((0x0628UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_DOUBLE_LADDER_IN_POINT1_Y   ((0x0680UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_DOUBLE_LADDER_IN_POINT1_Z   ((0x06D8UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_DOUBLE_LADDER_IN_POINT2_X   ((0x0730UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_DOUBLE_LADDER_IN_POINT2_Y   ((0x0788UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_DOUBLE_LADDER_IN_POINT2_Z   ((0x07E0UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_DOUBLE_LADDER_OUT_RESULT_X   ((0x0578UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_DOUBLE_LADDER_OUT_RESULT_Y   ((0x05D0UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_DOUBLE_LADDER_OUT_ERROR   ((0x0520UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_PROJECTIVE_AFF_IN_MOD_NB_BITS   ((0x0408UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_PROJECTIVE_AFF_IN_MOD_P   ((0x0470UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_PROJECTIVE_AFF_IN_POINT_X   ((0x0D60UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_PROJECTIVE_AFF_IN_POINT_Y   ((0x0DB8UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_PROJECTIVE_AFF_IN_POINT_Z   ((0x0E10UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_PROJECTIVE_AFF_IN_MONTGOMERY_PARAM_R2   ((0x04C8UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_PROJECTIVE_AFF_OUT_RESULT_X   ((0x0578UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_PROJECTIVE_AFF_OUT_RESULT_Y   ((0x05D0UL - PKA_RAM_OFFSET)>>2)
#define PKA_ECC_PROJECTIVE_AFF_OUT_ERROR   ((0x0680UL - PKA_RAM_OFFSET)>>2)
#define IS_ADC_ALL_INSTANCE(INSTANCE)
#define IS_ADC_MULTIMODE_MASTER_INSTANCE(INSTANCE)
#define IS_ADC_COMMON_INSTANCE(INSTANCE)
#define IS_AES_ALL_INSTANCE(INSTANCE)   (((INSTANCE) == AES_NS) || ((INSTANCE) == AES_S))
#define IS_PKA_ALL_INSTANCE(INSTANCE)   (((INSTANCE) == PKA_NS) || ((INSTANCE) == PKA_S))
#define IS_FDCAN_ALL_INSTANCE(INSTANCE)   (((INSTANCE) == FDCAN1_NS) || ((INSTANCE) == FDCAN1_S))
#define IS_COMP_ALL_INSTANCE(INSTANCE)
#define IS_COMP_WINDOWMODE_INSTANCE(INSTANCE)
#define IS_CORDIC_ALL_INSTANCE(INSTANCE)   (((INSTANCE) == CORDIC_NS) || ((INSTANCE) == CORDIC_S))
#define IS_CRC_ALL_INSTANCE(INSTANCE)   (((INSTANCE) == CRC_NS) || ((INSTANCE) == CRC_S))
#define IS_DAC_ALL_INSTANCE(INSTANCE)   (((INSTANCE) == DAC1_NS) || ((INSTANCE) == DAC1_S))
#define IS_DLYB_ALL_INSTANCE(INSTANCE)
#define IS_DMA_ALL_INSTANCE(INSTANCE)
#define IS_GPDMA_INSTANCE(INSTANCE)
#define IS_LPDMA_INSTANCE(INSTANCE)
#define IS_DMA_2D_ADDRESSING_INSTANCE(INSTANCE)
#define IS_OTFDEC_ALL_INSTANCE(INSTANCE)
#define IS_RAMCFG_ALL_INSTANCE(INSTANCE)
#define IS_RAMCFG_ECC_INSTANCE(INSTANCE)
#define IS_RAMCFG_IT_INSTANCE(INSTANCE)
#define IS_RAMCFG_WP_INSTANCE(INSTANCE)   (((INSTANCE) == RAMCFG_SRAM2_NS) || ((INSTANCE) == RAMCFG_SRAM2_S))
#define IS_FMAC_ALL_INSTANCE(INSTANCE)   (((INSTANCE) == FMAC_NS) || ((INSTANCE) == FMAC_S))
#define IS_GFXMMU_ALL_INSTANCE(INSTANCE)   (((INSTANCE) == GFXMMU_NS) || ((INSTANCE) == GFXMMU_S))
#define IS_GPIO_ALL_INSTANCE(INSTANCE)
#define IS_LPGPIO_ALL_INSTANCE(INSTANCE)   (((INSTANCE) == LPGPIO1_NS) || ((INSTANCE) == LPGPIO1_S))
#define IS_LTDC_ALL_INSTANCE(__INSTANCE__)   (((__INSTANCE__) == LTDC_NS) || ((__INSTANCE__) == LTDC_S))
#define IS_DSI_ALL_INSTANCE(__INSTANCE__)   (((__INSTANCE__) == DSI_NS) || ((__INSTANCE__) == DSI_S))
#define IS_DMA2D_ALL_INSTANCE(__INSTANCE__)   (((__INSTANCE__) == DMA2D_NS) || ((__INSTANCE__) == DMA2D_S))
#define IS_DCMI_ALL_INSTANCE(__INSTANCE__)   (((__INSTANCE__) == DCMI_NS) || ((__INSTANCE__) == DCMI_S))
#define IS_DCACHE_ALL_INSTANCE(INSTANCE)
#define IS_PSSI_ALL_INSTANCE(__INSTANCE__)   (((__INSTANCE__) == PSSI_NS) || ((__INSTANCE__) == PSSI_S))
#define IS_GPIO_AF_INSTANCE(INSTANCE)   IS_GPIO_ALL_INSTANCE(INSTANCE)
#define IS_GPIO_LOCK_INSTANCE(INSTANCE)   IS_GPIO_ALL_INSTANCE(INSTANCE)
#define IS_I2C_ALL_INSTANCE(INSTANCE)
#define IS_I2C_WAKEUP_FROMSTOP_INSTANCE(INSTANCE)   IS_I2C_ALL_INSTANCE(INSTANCE)
#define IS_I2C_GRP1_INSTANCE(INSTANCE)
#define IS_I2C_GRP2_INSTANCE(INSTANCE)   (((INSTANCE) == I2C3_NS) || ((INSTANCE) == I2C3_S))
#define IS_OPAMP_ALL_INSTANCE(INSTANCE)
#define IS_OSPI_ALL_INSTANCE(INSTANCE)
#define IS_HSPI_ALL_INSTANCE(INSTANCE)   (((INSTANCE) == HSPI1_NS) || ((INSTANCE) == HSPI1_S))
#define IS_RNG_ALL_INSTANCE(INSTANCE)   (((INSTANCE) == RNG_NS) || ((INSTANCE) == RNG_S))
#define IS_RTC_ALL_INSTANCE(INSTANCE)   (((INSTANCE) == RTC_NS) || ((INSTANCE) == RTC_S))
#define IS_SAI_ALL_INSTANCE(INSTANCE)
#define IS_SDMMC_ALL_INSTANCE(INSTANCE)
#define IS_SMBUS_ALL_INSTANCE(INSTANCE)
#define IS_SMBUS_GRP1_INSTANCE(INSTANCE)
#define IS_SMBUS_GRP2_INSTANCE(INSTANCE)   (((INSTANCE) == I2C3_NS) || ((INSTANCE) == I2C3_S))
#define IS_SPI_ALL_INSTANCE(INSTANCE)
#define IS_SPI_LIMITED_INSTANCE(INSTANCE)   (((INSTANCE) == SPI3_NS) || ((INSTANCE) == SPI3_S))
#define IS_SPI_FULL_INSTANCE(INSTANCE)
#define IS_SPI_GRP1_INSTANCE(INSTANCE)
#define IS_SPI_GRP2_INSTANCE(INSTANCE)   (((INSTANCE) == SPI3_NS) || ((INSTANCE) == SPI3_S))
#define IS_LPTIM_INSTANCE(INSTANCE)
#define IS_LPTIM_DMA_INSTANCE(INSTANCE)
#define IS_LPTIM_CC1_INSTANCE(INSTANCE)
#define IS_LPTIM_CC2_INSTANCE(INSTANCE)
#define IS_LPTIM_ENCODER_INTERFACE_INSTANCE(INSTANCE)
#define IS_LPTIM_INPUT_CAPTURE_INSTANCE(INSTANCE)
#define IS_TIM_INSTANCE(INSTANCE)
#define IS_TIM_32B_COUNTER_INSTANCE(INSTANCE)
#define IS_TIM_BREAK_INSTANCE(INSTANCE)
#define IS_TIM_BREAKSOURCE_INSTANCE(INSTANCE)
#define IS_TIM_BKIN2_INSTANCE(INSTANCE)
#define IS_TIM_CC1_INSTANCE(INSTANCE)
#define IS_TIM_CC2_INSTANCE(INSTANCE)
#define IS_TIM_CC3_INSTANCE(INSTANCE)
#define IS_TIM_CC4_INSTANCE(INSTANCE)
#define IS_TIM_CC5_INSTANCE(INSTANCE)
#define IS_TIM_CC6_INSTANCE(INSTANCE)
#define IS_TIM_DMA_INSTANCE(INSTANCE)
#define IS_TIM_DMA_CC_INSTANCE(INSTANCE)
#define IS_TIM_DMABURST_INSTANCE(INSTANCE)
#define IS_TIM_CCX_INSTANCE(INSTANCE, CHANNEL)
#define IS_TIM_CCXN_INSTANCE(INSTANCE, CHANNEL)
#define IS_TIM_CLOCK_DIVISION_INSTANCE(INSTANCE)
#define IS_TIM_CLOCKSOURCE_ETRMODE1_INSTANCE(INSTANCE)
#define IS_TIM_CLOCKSOURCE_ETRMODE2_INSTANCE(INSTANCE)
#define IS_TIM_CLOCKSOURCE_TIX_INSTANCE(INSTANCE)
#define IS_TIM_CLOCKSOURCE_ITRX_INSTANCE(INSTANCE)
#define IS_TIM_COMBINED3PHASEPWM_INSTANCE(INSTANCE)
#define IS_TIM_COMMUTATION_EVENT_INSTANCE(INSTANCE)
#define IS_TIM_COUNTER_MODE_SELECT_INSTANCE(INSTANCE)
#define IS_TIM_ENCODER_INTERFACE_INSTANCE(INSTANCE)
#define IS_TIM_HALL_SENSOR_INTERFACE_INSTANCE(INSTANCE)
#define IS_TIM_ETR_INSTANCE(INSTANCE)
#define IS_TIM_MASTER_INSTANCE(INSTANCE)
#define IS_TIM_SLAVE_INSTANCE(INSTANCE)
#define IS_TIM_OCXREF_CLEAR_INSTANCE(INSTANCE)
#define IS_TIM_REMAP_INSTANCE(INSTANCE)
#define IS_TIM_REPETITION_COUNTER_INSTANCE(INSTANCE)
#define IS_TIM_TRGO2_INSTANCE(INSTANCE)
#define IS_TIM_XOR_INSTANCE(INSTANCE)
#define IS_TIM_TISEL_INSTANCE(INSTANCE)
#define IS_TIM_HSE32_INSTANCE(INSTANCE)
#define IS_TIM_ADVANCED_INSTANCE(INSTANCE)
#define IS_TIM_SYNCHRO_INSTANCE(__INSTANCE__)
#define IS_TSC_ALL_INSTANCE(INSTANCE)   (((INSTANCE) == TSC_NS) || ((INSTANCE) == TSC_S))
#define IS_USART_INSTANCE(INSTANCE)
#define IS_UART_INSTANCE(INSTANCE)
#define IS_UART_FIFO_INSTANCE(INSTANCE)
#define IS_UART_SPI_SLAVE_INSTANCE(INSTANCE)
#define IS_USART_AUTOBAUDRATE_DETECTION_INSTANCE(INSTANCE)
#define IS_UART_DRIVER_ENABLE_INSTANCE(INSTANCE)
#define IS_UART_HALFDUPLEX_INSTANCE(INSTANCE)
#define IS_UART_HWFLOW_INSTANCE(INSTANCE)
#define IS_UART_LIN_INSTANCE(INSTANCE)
#define IS_UART_WAKEUP_FROMSTOP_INSTANCE(INSTANCE)
#define IS_IRDA_INSTANCE(INSTANCE)
#define IS_SMARTCARD_INSTANCE(INSTANCE)
#define IS_LPUART_INSTANCE(INSTANCE)   (((INSTANCE) == LPUART1_NS) || ((INSTANCE) == LPUART1_S))
#define IS_UART_AUTONOMOUS_INSTANCE(INSTANCE)
#define IS_IWDG_ALL_INSTANCE(INSTANCE)   (((INSTANCE) == IWDG_NS) || ((INSTANCE) == IWDG_S))
#define IS_WWDG_ALL_INSTANCE(INSTANCE)   (((INSTANCE) == WWDG_NS) || ((INSTANCE) == WWDG_S))
#define IS_UCPD_ALL_INSTANCE(INSTANCE)   (((INSTANCE) == UCPD1_NS) || ((INSTANCE) == UCPD1_S))
#define IS_HCD_ALL_INSTANCE(INSTANCE)   (((INSTANCE) == USB_OTG_HS_NS) || ((INSTANCE) == USB_OTG_HS_S))
#define IS_PCD_ALL_INSTANCE(INSTANCE)   (((INSTANCE) == USB_OTG_HS_NS) || ((INSTANCE) == USB_OTG_HS_S))
#define IS_MDF_ALL_INSTANCE(INSTANCE)
#define IS_GPU2D_ALL_INSTANCE(__INSTANCE__)   (((__INSTANCE__) == GPU2D_BASE_NS) || ((__INSTANCE__) == GPU2D_BASE_S))
#define IS_JPEG_ALL_INSTANCE(__INSTANCE__)   (((__INSTANCE__) == JPEG_NS) || ((__INSTANCE__) == JPEG_S))
#define IS_GFXTIM_ALL_INSTANCE(__INSTANCE__)   (((__INSTANCE__) == GFXTIM_NS) || ((__INSTANCE__) == GFXTIM_S))
typedef XSPI_TypeDef OCTOSPI_TypeDef
typedef XSPI_TypeDef HSPI_TypeDef
typedef XSPIM_TypeDef OCTOSPIM_TypeDef
typedef uint32_t(* RSSLIB_S_CloseExitHDP_TypeDef) (uint32_t HdpArea, uint32_t VectorTableAddr)
 Prototype of RSSLIB Close and exit HDP Function @detail This function close the requested hdp area passed in input parameter and jump to the reset handler present within the Vector table. The function does not return on successful execution.
enum  IRQn_Type {
  Reset_IRQn = -15 , NonMaskableInt_IRQn = -14 , HardFault_IRQn = -13 , MemoryManagement_IRQn = -12 ,
  BusFault_IRQn = -11 , UsageFault_IRQn = -10 , SecureFault_IRQn = -9 , SVCall_IRQn = -5 ,
  DebugMonitor_IRQn = -4 , PendSV_IRQn = -2 , SysTick_IRQn = -1 , WWDG_IRQn = 0 ,
  PVD_PVM_IRQn = 1 , RTC_IRQn = 2 , RTC_S_IRQn = 3 , TAMP_IRQn = 4 ,
  RAMCFG_IRQn = 5 , FLASH_IRQn = 6 , FLASH_S_IRQn = 7 , GTZC_IRQn = 8 ,
  RCC_IRQn = 9 , RCC_S_IRQn = 10 , EXTI0_IRQn = 11 , EXTI1_IRQn = 12 ,
  EXTI2_IRQn = 13 , EXTI3_IRQn = 14 , EXTI4_IRQn = 15 , EXTI5_IRQn = 16 ,
  EXTI6_IRQn = 17 , EXTI7_IRQn = 18 , EXTI8_IRQn = 19 , EXTI9_IRQn = 20 ,
  EXTI10_IRQn = 21 , EXTI11_IRQn = 22 , EXTI12_IRQn = 23 , EXTI13_IRQn = 24 ,
  EXTI14_IRQn = 25 , EXTI15_IRQn = 26 , IWDG_IRQn = 27 , SAES_IRQn = 28 ,
  GPDMA1_Channel0_IRQn = 29 , GPDMA1_Channel1_IRQn = 30 , GPDMA1_Channel2_IRQn = 31 , GPDMA1_Channel3_IRQn = 32 ,
  GPDMA1_Channel4_IRQn = 33 , GPDMA1_Channel5_IRQn = 34 , GPDMA1_Channel6_IRQn = 35 , GPDMA1_Channel7_IRQn = 36 ,
  ADC1_2_IRQn = 37 , DAC1_IRQn = 38 , FDCAN1_IT0_IRQn = 39 , FDCAN1_IT1_IRQn = 40 ,
  TIM1_BRK_IRQn = 41 , TIM1_UP_IRQn = 42 , TIM1_TRG_COM_IRQn = 43 , TIM1_CC_IRQn = 44 ,
  TIM2_IRQn = 45 , TIM3_IRQn = 46 , TIM4_IRQn = 47 , TIM5_IRQn = 48 ,
  TIM6_IRQn = 49 , TIM7_IRQn = 50 , TIM8_BRK_IRQn = 51 , TIM8_UP_IRQn = 52 ,
  TIM8_TRG_COM_IRQn = 53 , TIM8_CC_IRQn = 54 , I2C1_EV_IRQn = 55 , I2C1_ER_IRQn = 56 ,
  I2C2_EV_IRQn = 57 , I2C2_ER_IRQn = 58 , SPI1_IRQn = 59 , SPI2_IRQn = 60 ,
  USART1_IRQn = 61 , USART2_IRQn = 62 , USART3_IRQn = 63 , UART4_IRQn = 64 ,
  UART5_IRQn = 65 , LPUART1_IRQn = 66 , LPTIM1_IRQn = 67 , LPTIM2_IRQn = 68 ,
  TIM15_IRQn = 69 , TIM16_IRQn = 70 , TIM17_IRQn = 71 , COMP_IRQn = 72 ,
  OTG_HS_IRQn = 73 , CRS_IRQn = 74 , FMC_IRQn = 75 , OCTOSPI1_IRQn = 76 ,
  PWR_S3WU_IRQn = 77 , SDMMC1_IRQn = 78 , SDMMC2_IRQn = 79 , GPDMA1_Channel8_IRQn = 80 ,
  GPDMA1_Channel9_IRQn = 81 , GPDMA1_Channel10_IRQn = 82 , GPDMA1_Channel11_IRQn = 83 , GPDMA1_Channel12_IRQn = 84 ,
  GPDMA1_Channel13_IRQn = 85 , GPDMA1_Channel14_IRQn = 86 , GPDMA1_Channel15_IRQn = 87 , I2C3_EV_IRQn = 88 ,
  I2C3_ER_IRQn = 89 , SAI1_IRQn = 90 , SAI2_IRQn = 91 , TSC_IRQn = 92 ,
  AES_IRQn = 93 , RNG_IRQn = 94 , FPU_IRQn = 95 , HASH_IRQn = 96 ,
  PKA_IRQn = 97 , LPTIM3_IRQn = 98 , SPI3_IRQn = 99 , I2C4_ER_IRQn = 100 ,
  I2C4_EV_IRQn = 101 , MDF1_FLT0_IRQn = 102 , MDF1_FLT1_IRQn = 103 , MDF1_FLT2_IRQn = 104 ,
  MDF1_FLT3_IRQn = 105 , UCPD1_IRQn = 106 , ICACHE_IRQn = 107 , OTFDEC1_IRQn = 108 ,
  OTFDEC2_IRQn = 109 , LPTIM4_IRQn = 110 , DCACHE1_IRQn = 111 , ADF1_IRQn = 112 ,
  ADC4_IRQn = 113 , LPDMA1_Channel0_IRQn = 114 , LPDMA1_Channel1_IRQn = 115 , LPDMA1_Channel2_IRQn = 116 ,
  LPDMA1_Channel3_IRQn = 117 , DMA2D_IRQn = 118 , DCMI_PSSI_IRQn = 119 , OCTOSPI2_IRQn = 120 ,
  MDF1_FLT4_IRQn = 121 , MDF1_FLT5_IRQn = 122 , CORDIC_IRQn = 123 , FMAC_IRQn = 124 ,
  LSECSSD_IRQn = 125 , USART6_IRQn = 126 , I2C5_ER_IRQn = 127 , I2C5_EV_IRQn = 128 ,
  I2C6_ER_IRQn = 129 , I2C6_EV_IRQn = 130 , HSPI1_IRQn = 131 , GPU2D_IRQn = 132 ,
  GPU2D_ER_IRQn = 133 , GFXMMU_IRQn = 134 , LTDC_IRQn = 135 , LTDC_ER_IRQn = 136 ,
  DSI_IRQn = 137 , DCACHE2_IRQn = 138 , GFXTIM_IRQn = 139 , JPEG_IRQn = 140
CMSIS STM32U5G9xx Device Peripheral Access Layer Header File.
Author
MCD Application Team
     This file contains:
      - Data structures and the address mapping for all peripherals
      - Peripheral's registers declarations and bits definition
      - Macros to access peripheral's registers hardware
Attention
Copyright (c) 2023 STMicroelectronics. All rights reserved.
