| Enumerator |
| Reset_IRQn | -15 Reset Vector, invoked on Power up and warm reset
| NonMaskableInt_IRQn | -14 Non maskable Interrupt, cannot be stopped or preempted
| HardFault_IRQn | -13 Hard Fault, all classes of Fault
| MemoryManagement_IRQn | -12 Memory Management, MPU mismatch, including Access Violation and No Match
| BusFault_IRQn | -11 Bus Fault, Pre-Fetch-, Memory Access Fault, other address/memory related Fault
| UsageFault_IRQn | -10 Usage Fault, i.e. Undef Instruction, Illegal State Transition
| SecureFault_IRQn | -9 Secure Fault
| SVCall_IRQn | -5 System Service Call via SVC instruction
| DebugMonitor_IRQn | -4 Debug Monitor
| PendSV_IRQn | -2 Pendable request for system service
| SysTick_IRQn | -1 System Tick Timer
| WWDG_IRQn | Window WatchDog interrupt
| PVD_PVM_IRQn | PVD/PVM through EXTI Line detection Interrupt
| RTC_IRQn | RTC non-secure interrupt
| RTC_S_IRQn | RTC secure interrupt
| TAMP_IRQn | Tamper global interrupt
| RAMCFG_IRQn | RAMCFG global interrupt
| FLASH_IRQn | FLASH non-secure global interrupt
| FLASH_S_IRQn | FLASH secure global interrupt
| GTZC_IRQn | Global TrustZone Controller interrupt
| RCC_IRQn | RCC non secure global interrupt
| RCC_S_IRQn | RCC secure global interrupt
| EXTI0_IRQn | EXTI Line0 interrupt
| EXTI1_IRQn | EXTI Line1 interrupt
| EXTI2_IRQn | EXTI Line2 interrupt
| EXTI3_IRQn | EXTI Line3 interrupt
| EXTI4_IRQn | EXTI Line4 interrupt
| EXTI5_IRQn | EXTI Line5 interrupt
| EXTI6_IRQn | EXTI Line6 interrupt
| EXTI7_IRQn | EXTI Line7 interrupt
| EXTI8_IRQn | EXTI Line8 interrupt
| EXTI9_IRQn | EXTI Line9 interrupt
| EXTI10_IRQn | EXTI Line10 interrupt
| EXTI11_IRQn | EXTI Line11 interrupt
| EXTI12_IRQn | EXTI Line12 interrupt
| EXTI13_IRQn | EXTI Line13 interrupt
| EXTI14_IRQn | EXTI Line14 interrupt
| EXTI15_IRQn | EXTI Line15 interrupt
| IWDG_IRQn | IWDG global interrupt
| SAES_IRQn | Secure AES global interrupt
| GPDMA1_Channel0_IRQn | GPDMA1 Channel 0 global interrupt
| GPDMA1_Channel1_IRQn | GPDMA1 Channel 1 global interrupt
| GPDMA1_Channel2_IRQn | GPDMA1 Channel 2 global interrupt
| GPDMA1_Channel3_IRQn | GPDMA1 Channel 3 global interrupt
| GPDMA1_Channel4_IRQn | GPDMA1 Channel 4 global interrupt
| GPDMA1_Channel5_IRQn | GPDMA1 Channel 5 global interrupt
| GPDMA1_Channel6_IRQn | GPDMA1 Channel 6 global interrupt
| GPDMA1_Channel7_IRQn | GPDMA1 Channel 7 global interrupt
| ADC1_2_IRQn | ADC1_2 global interrupt
| DAC1_IRQn | DAC1 global interrupt
| FDCAN1_IT0_IRQn | FDCAN1 interrupt 0
| FDCAN1_IT1_IRQn | FDCAN1 interrupt 1
| TIM1_BRK_IRQn | TIM1 Break interrupt
| TIM1_UP_IRQn | TIM1 Update interrupt
| TIM1_TRG_COM_IRQn | TIM1 Trigger and Commutation interrupt
| TIM1_CC_IRQn | TIM1 Capture Compare interrupt
| TIM2_IRQn | TIM2 global interrupt
| TIM3_IRQn | TIM3 global interrupt
| TIM4_IRQn | TIM4 global interrupt
| TIM5_IRQn | TIM5 global interrupt
| TIM6_IRQn | TIM6 global interrupt
| TIM7_IRQn | TIM7 global interrupt
| TIM8_BRK_IRQn | TIM8 Break interrupt
| TIM8_UP_IRQn | TIM8 Update interrupt
| TIM8_TRG_COM_IRQn | TIM8 Trigger and Commutation interrupt
| TIM8_CC_IRQn | TIM8 Capture Compare interrupt
| I2C1_EV_IRQn | I2C1 Event interrupt
| I2C1_ER_IRQn | I2C1 Error interrupt
| I2C2_EV_IRQn | I2C2 Event interrupt
| I2C2_ER_IRQn | I2C2 Error interrupt
| SPI1_IRQn | SPI1 global interrupt
| SPI2_IRQn | SPI2 global interrupt
| USART1_IRQn | USART1 global interrupt
| USART2_IRQn | USART2 global interrupt
| USART3_IRQn | USART3 global interrupt
| UART4_IRQn | UART4 global interrupt
| UART5_IRQn | UART5 global interrupt
| LPUART1_IRQn | LPUART1 global interrupt
| LPTIM1_IRQn | LPTIM1 global interrupt
| LPTIM2_IRQn | LPTIM2 global interrupt
| TIM15_IRQn | TIM15 global interrupt
| TIM16_IRQn | TIM16 global interrupt
| TIM17_IRQn | TIM17 global interrupt
| COMP_IRQn | COMP1 and COMP2 through EXTI Lines interrupts
| OTG_HS_IRQn | USB OTG HS global interrupt
| CRS_IRQn | CRS global interrupt
| FMC_IRQn | FSMC global interrupt
| OCTOSPI1_IRQn | OctoSPI1 global interrupt
| PWR_S3WU_IRQn | PWR wake up from Stop3 interrupt
| SDMMC1_IRQn | SDMMC1 global interrupt
| SDMMC2_IRQn | SDMMC2 global interrupt
| GPDMA1_Channel8_IRQn | GPDMA1 Channel 8 global interrupt
| GPDMA1_Channel9_IRQn | GPDMA1 Channel 9 global interrupt
| GPDMA1_Channel10_IRQn | GPDMA1 Channel 10 global interrupt
| GPDMA1_Channel11_IRQn | GPDMA1 Channel 11 global interrupt
| GPDMA1_Channel12_IRQn | GPDMA1 Channel 12 global interrupt
| GPDMA1_Channel13_IRQn | GPDMA1 Channel 13 global interrupt
| GPDMA1_Channel14_IRQn | GPDMA1 Channel 14 global interrupt
| GPDMA1_Channel15_IRQn | GPDMA1 Channel 15 global interrupt
| I2C3_EV_IRQn | I2C3 event interrupt
| I2C3_ER_IRQn | I2C3 error interrupt
| SAI1_IRQn | Serial Audio Interface 1 global interrupt
| SAI2_IRQn | Serial Audio Interface 2 global interrupt
| TSC_IRQn | Touch Sense Controller global interrupt
| AES_IRQn | AES global interrupt
| RNG_IRQn | RNG global interrupt
| FPU_IRQn | FPU global interrupt
| HASH_IRQn | HASH global interrupt
| PKA_IRQn | PKA global interrupt
| LPTIM3_IRQn | LPTIM3 global interrupt
| SPI3_IRQn | SPI3 global interrupt
| I2C4_ER_IRQn | I2C4 Error interrupt
| I2C4_EV_IRQn | I2C4 Event interrupt
| MDF1_FLT0_IRQn | MDF1 Filter 0 global interrupt
| MDF1_FLT1_IRQn | MDF1 Filter 1 global interrupt
| MDF1_FLT2_IRQn | MDF1 Filter 2 global interrupt
| MDF1_FLT3_IRQn | MDF1 Filter 3 global interrupt
| UCPD1_IRQn | UCPD1 global interrupt
| ICACHE_IRQn | Instruction cache global interrupt
| OTFDEC1_IRQn | OTFDEC1 global interrupt
| OTFDEC2_IRQn | OTFDEC2 global interrupt
| LPTIM4_IRQn | LPTIM4 global interrupt
| DCACHE1_IRQn | Data cache global interrupt
| ADF1_IRQn | ADF interrupt
| ADC4_IRQn | ADC4 (12bits) global interrupt
| LPDMA1_Channel0_IRQn | LPDMA1 SmartRun Channel 0 global interrupt
| LPDMA1_Channel1_IRQn | LPDMA1 SmartRun Channel 1 global interrupt
| LPDMA1_Channel2_IRQn | LPDMA1 SmartRun Channel 2 global interrupt
| LPDMA1_Channel3_IRQn | LPDMA1 SmartRun Channel 3 global interrupt
| DMA2D_IRQn | DMA2D global interrupt
| DCMI_PSSI_IRQn | DCMI/PSSI global interrupt
| OCTOSPI2_IRQn | OCTOSPI2 global interrupt
| MDF1_FLT4_IRQn | MDF1 Filter 4 global interrupt
| MDF1_FLT5_IRQn | MDF1 Filter 5 global interrupt
| CORDIC_IRQn | CORDIC global interrupt
| FMAC_IRQn | FMAC global interrupt
| LSECSSD_IRQn | LSECSSD and MSI_PLL_UNLOCK global interrupts
| USART6_IRQn | USART6 global interrupt
| I2C5_ER_IRQn | I2C5 Error interrupt
| I2C5_EV_IRQn | I2C5 Event interrupt
| I2C6_ER_IRQn | I2C6 Error interrupt
| I2C6_EV_IRQn | I2C6 Error interrupt
| HSPI1_IRQn | HSPI1 global interrupt
| GPU2D_IRQn | GPU2D global interrupt
| GPU2D_ER_IRQn | GPU2D Error interrupt
| GFXMMU_IRQn | GFXMMU global interrupt
| LTDC_IRQn | LCD-TFT global interrupt
| LTDC_ER_IRQn | LCD-TFT Error interrupt
| DSI_IRQn | DSIHOST global interrupt
| DCACHE2_IRQn | DCACHE2 Data cache global interrupt
| GFXTIM_IRQn | GFXTIM global interrupt
| JPEG_IRQn | JPEG sync interrupt
