RTEMS 7.0-rc1
Low-level assembly code for PPC exceptions. More...
| macro PPC_EXC_MIN_PROLOG_ASYNC _NAME _VEC _PRI _FLVR global ppc_exc_min_prolog_async_ _NAME ppc_exc_min_prolog_async_ ppc_exc_lock_ _PRI | sdarel (r13) stw VECTOR_REGISTER |
| macro PPC_EXC_MIN_PROLOG_ASYNC _NAME _VEC _PRI _FLVR global ppc_exc_min_prolog_async_ _NAME ppc_exc_min_prolog_async_ ppc_exc_lock_ _PRI ppc_exc_vector_register_ _PRI _VEC int ppc_exc_wrap_ _FLVR endm macro PPC_EXC_MIN_PROLOG_SYNC _NAME _VEC _PRI _FLVR global ppc_exc_min_prolog_sync_ _NAME ppc_exc_min_prolog_sync_ | EXCEPTION_FRAME_END (r1) stw VECTOR_REGISTER |
| macro PPC_EXC_MIN_PROLOG_ASYNC _NAME _VEC _PRI _FLVR global ppc_exc_min_prolog_async_ _NAME ppc_exc_min_prolog_async_ ppc_exc_lock_ _PRI ppc_exc_vector_register_ _PRI _VEC int ppc_exc_wrap_ _FLVR endm macro PPC_EXC_MIN_PROLOG_SYNC _NAME _VEC _PRI _FLVR global ppc_exc_min_prolog_sync_ _NAME ppc_exc_min_prolog_sync_ | VECTOR_OFFSET (r1) li VECTOR_REGISTER |
| macro PPC_EXC_MIN_PROLOG_ASYNC _NAME _VEC _PRI _FLVR global ppc_exc_min_prolog_async_ _NAME ppc_exc_min_prolog_async_ ppc_exc_lock_ _PRI ppc_exc_vector_register_ _PRI _VEC int ppc_exc_wrap_ _FLVR endm macro PPC_EXC_MIN_PROLOG_SYNC _NAME _VEC _PRI _FLVR global ppc_exc_min_prolog_sync_ _NAME ppc_exc_min_prolog_sync_ _VEC int ppc_exc_wrap_nopush_ _FLVR endm macro TEST_1ST_OPCODE_crit _REG lwz | SRR0_FRAME_OFFSET (FRAME_REGISTER) lwz \_REG |
| macro PPC_EXC_MIN_PROLOG_ASYNC _NAME _VEC _PRI _FLVR global ppc_exc_min_prolog_async_ _NAME ppc_exc_min_prolog_async_ ppc_exc_lock_ _PRI ppc_exc_vector_register_ _PRI _VEC int ppc_exc_wrap_ _FLVR endm macro PPC_EXC_MIN_PROLOG_SYNC _NAME _VEC _PRI _FLVR global ppc_exc_min_prolog_sync_ _NAME ppc_exc_min_prolog_sync_ _VEC int ppc_exc_wrap_nopush_ _FLVR endm macro TEST_1ST_OPCODE_crit _REG lwz _REG subis | STW_R1_R13 (0) @h cmplwi cr0 |
| macro PPC_EXC_MIN_PROLOG_ASYNC _NAME _VEC _PRI _FLVR global ppc_exc_min_prolog_async_ _NAME ppc_exc_min_prolog_async_ ppc_exc_lock_ _PRI ppc_exc_vector_register_ _PRI _VEC int ppc_exc_wrap_ _FLVR endm macro PPC_EXC_MIN_PROLOG_SYNC _NAME _VEC _PRI _FLVR global ppc_exc_min_prolog_sync_ _NAME ppc_exc_min_prolog_sync_ _VEC int ppc_exc_wrap_nopush_ _FLVR endm macro TEST_1ST_OPCODE_crit _REG lwz _REG subis ppc_exc_lock_std sdarel endm macro TEST_LOCK_std _FLVR creqv | EQ (CR_LOCK) |
| macro PPC_EXC_MIN_PROLOG_ASYNC _NAME _VEC _PRI _FLVR global ppc_exc_min_prolog_async_ _NAME ppc_exc_min_prolog_async_ ppc_exc_lock_ _PRI ppc_exc_vector_register_ _PRI _VEC int ppc_exc_wrap_ _FLVR endm macro PPC_EXC_MIN_PROLOG_SYNC _NAME _VEC _PRI _FLVR global ppc_exc_min_prolog_sync_ _NAME ppc_exc_min_prolog_sync_ _VEC int ppc_exc_wrap_nopush_ _FLVR endm macro TEST_1ST_OPCODE_crit _REG lwz _REG subis ppc_exc_lock_std sdarel endm macro TEST_LOCK_std _FLVR creqv MSR_CE h beq TEST_LOCK_crit_done_ _FLVR TEST_1ST_OPCODE_crit ppc_exc_lock_std TEST_LOCK_crit_done_ | EQ (0) .endm .macro TEST_LOCK_mchk _SRR0 _FLVR crxor EQ(CR_LOCK) |
| macro PPC_EXC_MIN_PROLOG_ASYNC _NAME _VEC _PRI _FLVR global ppc_exc_min_prolog_async_ _NAME ppc_exc_min_prolog_async_ ppc_exc_lock_ _PRI ppc_exc_vector_register_ _PRI _VEC int ppc_exc_wrap_ _FLVR endm macro PPC_EXC_MIN_PROLOG_SYNC _NAME _VEC _PRI _FLVR global ppc_exc_min_prolog_sync_ _NAME ppc_exc_min_prolog_sync_ _VEC int ppc_exc_wrap_nopush_ _FLVR endm macro TEST_1ST_OPCODE_crit _REG lwz _REG subis ppc_exc_lock_std sdarel endm macro TEST_LOCK_std _FLVR creqv MSR_CE h beq TEST_LOCK_crit_done_ _FLVR TEST_1ST_OPCODE_crit ppc_exc_lock_std TEST_LOCK_crit_done_ | SRR1_FRAME_OFFSET (FRAME_REGISTER) lwz SCRATCH_REGISTER_1 |
| macro PPC_EXC_MIN_PROLOG_ASYNC _NAME _VEC _PRI _FLVR global ppc_exc_min_prolog_async_ _NAME ppc_exc_min_prolog_async_ | _NAME |
| macro PPC_EXC_MIN_PROLOG_ASYNC _NAME _VEC _PRI _FLVR global ppc_exc_min_prolog_async_ _NAME ppc_exc_min_prolog_async_ ppc_exc_lock_ _PRI ppc_exc_vector_register_ _PRI _VEC int ppc_exc_wrap_ _FLVR endm macro PPC_EXC_MIN_PROLOG_SYNC _NAME _VEC _PRI _FLVR global ppc_exc_min_prolog_sync_ _NAME ppc_exc_min_prolog_sync_ _VEC int ppc_exc_wrap_nopush_ _FLVR endm macro TEST_1ST_OPCODE_crit _REG lwz | _REG |
| macro PPC_EXC_MIN_PROLOG_ASYNC _NAME _VEC _PRI _FLVR global ppc_exc_min_prolog_async_ _NAME ppc_exc_min_prolog_async_ ppc_exc_lock_ _PRI ppc_exc_vector_register_ _PRI _VEC int ppc_exc_wrap_ _FLVR endm macro PPC_EXC_MIN_PROLOG_SYNC _NAME _VEC _PRI _FLVR global ppc_exc_min_prolog_sync_ _NAME ppc_exc_min_prolog_sync_ _VEC int ppc_exc_wrap_nopush_ _FLVR endm macro TEST_1ST_OPCODE_crit _REG lwz _REG subis ppc_exc_lock_std sdarel endm macro TEST_LOCK_std _FLVR creqv | SCRATCH_REGISTER_1 |
| macro PPC_EXC_MIN_PROLOG_ASYNC _NAME _VEC _PRI _FLVR global ppc_exc_min_prolog_async_ _NAME ppc_exc_min_prolog_async_ ppc_exc_lock_ _PRI ppc_exc_vector_register_ _PRI _VEC int ppc_exc_wrap_ _FLVR endm macro PPC_EXC_MIN_PROLOG_SYNC _NAME _VEC _PRI _FLVR global ppc_exc_min_prolog_sync_ _NAME ppc_exc_min_prolog_sync_ _VEC int ppc_exc_wrap_nopush_ _FLVR endm macro TEST_1ST_OPCODE_crit _REG lwz _REG subis ppc_exc_lock_std sdarel endm macro TEST_LOCK_std _FLVR creqv MSR_CE h beq TEST_LOCK_crit_done_ _FLVR TEST_1ST_OPCODE_crit ppc_exc_lock_std TEST_LOCK_crit_done_ | _FLVR |
| macro PPC_EXC_MIN_PROLOG_ASYNC _NAME _VEC _PRI _FLVR global ppc_exc_min_prolog_async_ _NAME ppc_exc_min_prolog_async_ ppc_exc_lock_ _PRI ppc_exc_vector_register_ _PRI _VEC int ppc_exc_wrap_ _FLVR endm macro PPC_EXC_MIN_PROLOG_SYNC _NAME _VEC _PRI _FLVR global ppc_exc_min_prolog_sync_ _NAME ppc_exc_min_prolog_sync_ _VEC int ppc_exc_wrap_nopush_ _FLVR endm macro TEST_1ST_OPCODE_crit _REG lwz _REG subis ppc_exc_lock_std sdarel endm macro TEST_LOCK_std _FLVR creqv MSR_CE h beq TEST_LOCK_crit_done_ _FLVR TEST_1ST_OPCODE_crit ppc_exc_lock_std TEST_LOCK_crit_done_ ppc_exc_msr_bits SCRATCH_REGISTER_0 andi | SCRATCH_REGISTER_0 |
This file was written with the goal to eliminate ALL #ifdef <cpu_flavor> conditionals – please do not reintroduce such statements.
| macro PPC_EXC_MIN_PROLOG_ASYNC _NAME _VEC _PRI _FLVR global ppc_exc_min_prolog_async_ _NAME ppc_exc_min_prolog_async_ ppc_exc_lock_ _PRI ppc_exc_vector_register_ _PRI _VEC int ppc_exc_wrap_ _FLVR endm macro PPC_EXC_MIN_PROLOG_SYNC _NAME _VEC _PRI _FLVR global ppc_exc_min_prolog_sync_ _NAME ppc_exc_min_prolog_sync_ _VEC int ppc_exc_wrap_nopush_ _FLVR endm macro TEST_1ST_OPCODE_crit _REG lwz _REG subis ppc_exc_lock_std sdarel endm macro TEST_LOCK_std _FLVR creqv MSR_CE h beq TEST_LOCK_crit_done_ _FLVR TEST_1ST_OPCODE_crit ppc_exc_lock_std TEST_LOCK_crit_done_ EQ | ( | CR_LOCK | ) |
| macro PPC_EXC_MIN_PROLOG_ASYNC _NAME _VEC _PRI _FLVR global ppc_exc_min_prolog_async_ _NAME ppc_exc_min_prolog_async_ ppc_exc_lock_ _PRI ppc_exc_vector_register_ _PRI _VEC int ppc_exc_wrap_ _FLVR endm macro PPC_EXC_MIN_PROLOG_SYNC _NAME _VEC _PRI _FLVR global ppc_exc_min_prolog_sync_ _NAME ppc_exc_min_prolog_sync_ _VEC int ppc_exc_wrap_nopush_ _FLVR endm macro TEST_1ST_OPCODE_crit _REG lwz _REG subis ppc_exc_lock_std sdarel endm macro TEST_LOCK_std _FLVR creqv MSR_CE h beq TEST_LOCK_crit_done_ _FLVR TEST_1ST_OPCODE_crit _REG |
