50#ifndef __LIBCPU_POWERPC_UTILITY_H
51#define __LIBCPU_POWERPC_UTILITY_H
57#include <rtems/score/cpu.h>
69#include <libcpu/cpuIdent.h>
71#define LINKER_SYMBOL(sym) extern char sym [];
76static inline uint8_t ppc_read_byte(
const volatile void *src)
92static inline uint16_t ppc_read_half_word(
108static inline uint32_t ppc_read_word(
124static inline void ppc_write_byte(uint8_t value,
volatile void *dest)
129 :
"r" (value),
"b" (dest)
136static inline void ppc_write_half_word(uint16_t value,
141 :
"r" (value),
"b" (dest)
148static inline void ppc_write_word(uint32_t value,
152 :
"r" (value),
"b" (dest)
157static inline void *ppc_stack_pointer(
void)
169static inline void ppc_set_stack_pointer(
void *
sp)
178static inline void *ppc_link_register(
void)
190static inline void ppc_set_link_register(
void *lr)
199static inline uint32_t ppc_machine_state_register(
void)
211static inline void ppc_set_machine_state_register(uint32_t msr)
220static inline void ppc_synchronize_data(
void)
224 __asm__
volatile (
"sync");
227static inline void ppc_light_weight_synchronize(
void)
231 __asm__
volatile (
"lwsync");
234static inline void ppc_synchronize_instructions(
void)
238 __asm__
volatile (
"isync");
241static inline void ppc_enforce_in_order_execution_of_io(
void)
246 ".machine \"push\"\n"
253static inline void ppc_data_cache_block_flush(
void *addr)
263static inline void ppc_data_cache_block_flush_2(
271 :
"b" (base),
"r" (offset)
276static inline void ppc_data_cache_block_invalidate(
void *addr)
286static inline void ppc_data_cache_block_invalidate_2(
294 :
"b" (base),
"r" (offset)
299static inline void ppc_data_cache_block_store(
const void *addr)
308static inline void ppc_data_cache_block_store_2(
316 :
"b" (base),
"r" (offset)
320static inline void ppc_data_cache_block_touch(
const void *addr)
329static inline void ppc_data_cache_block_touch_2(
337 :
"b" (base),
"r" (offset)
341static inline void ppc_data_cache_block_touch_for_store(
const void *addr)
350static inline void ppc_data_cache_block_touch_for_store_2(
358 :
"b" (base),
"r" (offset)
362static inline void ppc_data_cache_block_clear_to_zero(
void *addr)
372static inline void ppc_data_cache_block_clear_to_zero_2(
380 :
"b" (base),
"r" (offset)
385static inline void ppc_instruction_cache_block_invalidate(
void *addr)
394static inline void ppc_instruction_cache_block_invalidate_2(
402 :
"b" (base),
"r" (offset)
412static inline uint32_t ppc_external_exceptions_enable(
void)
414 uint32_t current_msr;
421 "ori %1, %0, 0x8000;"
423 :
"=r" (current_msr),
"=r" (new_msr)
434static inline void ppc_external_exceptions_disable(uint32_t msr)
436 ppc_set_machine_state_register(msr);
441static inline uint32_t ppc_count_leading_zeros(uint32_t value)
459#if defined(mpx8xx) || defined(mpc860) || defined(mpc821)
473#define CPU_Get_timebase_low( _value ) \
474 __asm__ volatile( "mftb %0" : "=r" (_value) )
476#define CPU_Get_timebase_low( _value ) \
477 __asm__ volatile( "mfspr %0,268" : "=r" (_value) )
483#define rtems_bsp_delay( _microseconds ) \
485 uint32_t start, ticks, now; \
486 CPU_Get_timebase_low( start ) ; \
487 ticks = (_microseconds) * bsp_clicks_per_usec; \
489 CPU_Get_timebase_low( now ) ; \
490 while (now - start < ticks); \
493#define rtems_bsp_delay_in_bus_cycles( _cycles ) \
495 uint32_t start, now; \
496 CPU_Get_timebase_low( start ); \
498 CPU_Get_timebase_low( now ); \
499 while (now - start < (_cycles)); \
506#define PPC_Set_decrementer( _clicks ) \
508 __asm__ volatile( "mtdec %0" : : "r" ((_clicks)) ); \
511#define PPC_Get_decrementer( _clicks ) \
512 __asm__ volatile( "mfdec %0" : "=r" (_clicks) )
518static inline uint64_t PPC_Get_timebase_register(
void )
522 uint32_t tbr_high_old;
526#if defined(mpx8xx) || defined(mpc860) || defined(mpc821)
528 __asm__
volatile(
"mftbu %0" :
"=r" (tbr_high_old));
529 __asm__
volatile(
"mftb %0" :
"=r" (tbr_low));
530 __asm__
volatile(
"mftbu %0" :
"=r" (tbr_high));
532 __asm__
volatile(
"mfspr %0, 269" :
533 __asm__
volatile(
"mfspr %0, 268" :
"=r" (tbr_low));
534 __asm__
volatile(
"mfspr %0, 269" :
"=r" (tbr_high));
536 }
while ( tbr_high_old != tbr_high );
544static inline void PPC_Set_timebase_register (uint64_t tbr)
549 tbr_low = (uint32_t) tbr;
550 tbr_high = (uint32_t) (tbr >> 32);
551 __asm__
volatile(
"mtspr 284, %0" : :
"r" (tbr_low));
552 __asm__
volatile(
"mtspr 285, %0" : :
"r" (tbr_high));
556static inline uint32_t ppc_decrementer_register(
void)
560 PPC_Get_decrementer(dec);
565static inline void ppc_set_decrementer_register(uint32_t dec)
567 PPC_Set_decrementer(dec);
573#define PPC_STRINGOF(x) #x
580#define PPC_SPECIAL_PURPOSE_REGISTER(spr, val) \
582 "mfspr %0, " PPC_STRINGOF(spr) \
590#define PPC_SET_SPECIAL_PURPOSE_REGISTER(spr, val) \
593 "mtspr " PPC_STRINGOF(spr) ", %0" \
605#define PPC_SET_SPECIAL_PURPOSE_REGISTER_BITS(spr, bits) \
609 uint32_t mybits = bits; \
610 _ISR_Local_disable(level); \
611 PPC_SPECIAL_PURPOSE_REGISTER(spr, val); \
613 PPC_SET_SPECIAL_PURPOSE_REGISTER(spr, val); \
614 _ISR_Local_enable(level); \
624#define PPC_SET_SPECIAL_PURPOSE_REGISTER_BITS_MASKED(spr, bits, mask) \
628 uint32_t mybits = bits; \
629 uint32_t mymask = mask; \
630 _ISR_Local_disable(level); \
631 PPC_SPECIAL_PURPOSE_REGISTER(spr, val); \
634 PPC_SET_SPECIAL_PURPOSE_REGISTER(spr, val); \
635 _ISR_Local_enable(level); \
644#define PPC_CLEAR_SPECIAL_PURPOSE_REGISTER_BITS(spr, bits) \
648 uint32_t mybits = bits; \
649 _ISR_Local_disable(level); \
650 PPC_SPECIAL_PURPOSE_REGISTER(spr, val); \
652 PPC_SET_SPECIAL_PURPOSE_REGISTER(spr, val); \
653 _ISR_Local_enable(level); \
661#define PPC_THREAD_MGMT_REGISTER(tmr) \
665 "mftmr %0, " PPC_STRINGOF(tmr) \
675#define PPC_SET_THREAD_MGMT_REGISTER(tmr, val) \
678 "mttmr " PPC_STRINGOF(tmr) ", %0" \
691#define PPC_DEVICE_CONTROL_REGISTER(dcr) \
695 "mfdcr %0, " PPC_STRINGOF(dcr) \
707#define PPC_SET_DEVICE_CONTROL_REGISTER(dcr, val) \
710 "mtdcr " PPC_STRINGOF(dcr) ", %0" \
722#define PPC_SET_DEVICE_CONTROL_REGISTER_BITS(dcr, bits) \
726 uint32_t mybits = bits; \
727 _ISR_Local_disable(level); \
728 val = PPC_DEVICE_CONTROL_REGISTER(dcr); \
730 PPC_SET_DEVICE_CONTROL_REGISTER(dcr, val); \
731 _ISR_Local_enable(level); \
741#define PPC_SET_DEVICE_CONTROL_REGISTER_BITS_MASKED(dcr, bits, mask) \
745 uint32_t mybits = bits; \
746 uint32_t mymask = mask; \
747 _ISR_Local_disable(level); \
748 val = PPC_DEVICE_CONTROL_REGISTER(dcr); \
751 PPC_SET_DEVICE_CONTROL_REGISTER(dcr, val); \
752 _ISR_Local_enable(level); \
761#define PPC_CLEAR_DEVICE_CONTROL_REGISTER_BITS(dcr, bits) \
765 uint32_t mybits = bits; \
766 _ISR_Local_disable(level); \
767 val = PPC_DEVICE_CONTROL_REGISTER(dcr); \
769 PPC_SET_DEVICE_CONTROL_REGISTER(dcr, val); \
770 _ISR_Local_enable(level); \
773static inline uint32_t ppc_time_base(
void)
777 CPU_Get_timebase_low(val);
782static inline void ppc_set_time_base(uint32_t val)
787static inline uint32_t ppc_time_base_upper(
void)
794static inline void ppc_set_time_base_upper(uint32_t val)
799static inline uint64_t ppc_time_base_64(
void)
801 return PPC_Get_timebase_register();
804static inline void ppc_set_time_base_64(uint64_t val)
806 PPC_Set_timebase_register(val);
809static inline uint32_t ppc_alternate_time_base(
void)
816static inline uint32_t ppc_alternate_time_base_upper(
void)
823static inline uint64_t ppc_alternate_time_base_64(
void)
830 atbu_0 = ppc_alternate_time_base_upper();
831 atbl = ppc_alternate_time_base();
832 atbu_1 = ppc_alternate_time_base_upper();
833 }
while (atbu_0 != atbu_1);
835 return (((uint64_t) atbu_1) << 32) | ((uint64_t) atbl);
838static inline uint32_t ppc_processor_id(
void)
845static inline void ppc_set_processor_id(uint32_t val)
850static inline uint32_t ppc_fsl_system_version(
void)
857static inline uint32_t ppc_fsl_system_version_cid(uint32_t svr)
859 return (svr >> 28) & 0xf;
862static inline uint32_t ppc_fsl_system_version_sid(uint32_t svr)
864 return (svr >> 16) & 0xfff;
867static inline uint32_t ppc_fsl_system_version_proc(uint32_t svr)
869 return (svr >> 12) & 0xf;
872static inline uint32_t ppc_fsl_system_version_mfg(uint32_t svr)
874 return (svr >> 8) & 0xf;
877static inline uint32_t ppc_fsl_system_version_mjrev(uint32_t svr)
879 return (svr >> 4) & 0xf;
882static inline uint32_t ppc_fsl_system_version_mnrev(uint32_t svr)
884 return (svr >> 0) & 0xf;
887static inline void ppc_msync(
void)
897static inline void ppc_tlbre(
void)
907static inline void ppc_tlbwe(
void)
917static inline void ppc_tlbsx(
void *addr)
927static inline void ppc_mtivpr(
void *prefix)
936#define ppc_mtivor(x, vec) __asm__ volatile ( \
937 "mtivor" RTEMS_XSTRING(x) " %0" \
942void ppc_code_copy(
void *dest,
const void *src,
size_t n);
945void printBAT(
int bat, uint32_t upper, uint32_t lower);
953#include <rtems/asm.h>
956#if defined(__powerpc64__)
957 lis \reg, (\addr)@highest
958 ori \reg, \reg, (\addr)@higher
959 rldicr \reg, \reg, 32, 31
960 oris \reg, \reg, (\addr)@h
961 ori \reg, \reg, (\addr)@l
964 ori \reg, \reg, (\addr)@l
970 ori \reg, \reg, (\addr)@l
975 ori \reg, \reg, (\value)@l
980 lwz \reg, \addr@l(\reg)
988.macro TSTBITS reg1, reg2, mask
990 and \reg1, \reg1, \reg2
994.macro SETBITS reg1, reg2, mask
996 or \reg1, \reg1, \reg2
999.macro CLRBITS reg1, reg2, mask
1001 andc \reg1, \reg1, \reg2
1004.macro GLOBAL_FUNCTION name
1006 .type \name, @function
1013.macro GET_INTERRUPT_MASK mask
1022.macro INTERRUPT_DISABLE level, mask
1024 GET_INTERRUPT_MASK mask=\mask
1025 andc \mask, \level, \mask
1032.macro INTERRUPT_ENABLE level
1036.macro SET_SELF_CPU_CONTROL reg_0, reg_1
1037#if defined(RTEMS_SMP)
1040 slwi \reg_0, \reg_0, PER_CPU_CONTROL_SIZE_LOG2
1041#if defined(__powerpc64__)
1043 add \reg_0, \reg_0, \reg_1
1048 mtspr PPC_PER_CPU_CONTROL_REGISTER, \reg_0
1052.macro GET_SELF_CPU_CONTROL reg
1053#if defined(RTEMS_SMP)
1054 mfspr \reg, PPC_PER_CPU_CONTROL_REGISTER
1061.macro SHIFT_RIGHT_IMMEDIATE rd, rs, imm
1062#if defined(__powerpc64__)
1069.macro COMPARE_LOGICAL cr,
ra, rb
1070#if defined(__powerpc64__)
1077.macro CLEAR_RIGHT_IMMEDIATE rd, rs, imm
1078#if defined(__powerpc64__)
1079 clrrdi \rd, \rs, \imm
1081 clrrwi \rd, \rs, \imm
1085#define LINKER_SYMBOL(sym) .extern sym
This header file provides the kernel character input/output support API.
#define RTEMS_COMPILER_MEMORY_BARRIER()
This macro forbids the compiler to reorder read and write commands around it.
Definition: basedefs.h:258
uint32_t bsp_clicks_per_usec
Time base clicks per micro second.
Definition: bspstart.c:103
Sets the Special Purpose Register with number spr to the value in val.
Definition: powerpc-utility.h:590
Returns the value of the Special Purpose Register with number spr.
Definition: powerpc-utility.h:580
CPU_STRUCTURE_ALIGNMENT Per_CPU_Control_envelope _Per_CPU_Information[]
Set of Per CPU Core Information.
Definition: asm.h:171
#define ra
return address */
Definition: regs.h:66
#define sp
stack-pointer */
Definition: regs.h:64
char _PPC_INTERRUPT_DISABLE_MASK[]
A global symbol used to disable interrupts in the MSR.
