RTEMS 7.0-rc1
pci.c File Reference
#include <inttypes.h>
#include <bsp.h>
#include <bsp/pci.h>
#include <bsp/irq.h>
#include <rtems/bspIo.h>
#include <rtems/endian.h>
#define PCI_CONFIG_ADDR   0xcf8
#define PCI_CONFIG_DATA   0xcfc
#define pci   BSP_pci_configuration
#define PCI_CONFIG_ADDR_VAL(bus, slot, funcion, offset)    (0x80000000|((bus)<<16)|(PCI_DEVFN((slot),(function))<<8)|(((offset)&~3)))
#define JPRINTK(fmt, ...)   do { } while (0)
#define PCI_CONFIG_WR_ADDR(addr, val)   out_le32((uint32_t)(addr), (val))
#define PCI_CONFIG_SET_ADDR(addr, bus, slot, function, offset)
#define PRINT_MSG()
void print_bars (unsigned char slot, unsigned char func)
int direct_pci_read_config_byte (unsigned char bus, unsigned char slot, unsigned char function, unsigned char offset, uint8_t *val)
int direct_pci_read_config_word (unsigned char bus, unsigned char slot, unsigned char function, unsigned char offset, uint16_t *val)
int direct_pci_read_config_dword (unsigned char bus, unsigned char slot, unsigned char function, unsigned char offset, uint32_t *val)
int direct_pci_write_config_byte (unsigned char bus, unsigned char slot, unsigned char function, unsigned char offset, uint8_t val)
int direct_pci_write_config_word (unsigned char bus, unsigned char slot, unsigned char function, unsigned char offset, uint16_t val)
int direct_pci_write_config_dword (unsigned char bus, unsigned char slot, unsigned char function, unsigned char offset, uint32_t val)
int test_intname (const struct _int_map *row, int pbus, int pslot, int pfun, int int_pin, int int_name)
void pci_memory_enable (unsigned char bus, unsigned char slot, unsigned char function)
void pci_io_enable (unsigned char bus, unsigned char slot, unsigned char function)
void pci_busmaster_enable (unsigned char bus, unsigned char slot, unsigned char function)
void pci_out_32 (uint32_t base, uint32_t addr, uint32_t val)
void pci_out_le32 (uint32_t base, uint32_t addr, uint32_t val)
uint8_t pci_in_8 (uint32_t base, uint32_t addr)
int16_t pci_in_le16 (uint32_t base, uint32_t addr)
int16_t pci_in_16 (uint32_t base, uint32_t addr)
uint32_t pci_in_32 (uint32_t base, uint32_t addr)
uint32_t pci_in_le32 (uint32_t base, uint32_t addr)
void pci_out_8 (uint32_t base, uint32_t addr, uint8_t val)
void pci_out_le16 (uint32_t base, uint32_t addr, uint16_t val)
void pci_out_16 (uint32_t base, uint32_t addr, uint16_t val)
int indirect_pci_read_config_byte (unsigned char bus, unsigned char slot, unsigned char function, unsigned char offset, uint8_t *val)
int indirect_pci_read_config_word (unsigned char bus, unsigned char slot, unsigned char function, unsigned char offset, uint16_t *val)
int indirect_pci_read_config_dword (unsigned char bus, unsigned char slot, unsigned char function, unsigned char offset, uint32_t *val)
int indirect_pci_write_config_byte (unsigned char bus, unsigned char slot, unsigned char function, unsigned char offset, uint8_t val)
int indirect_pci_write_config_word (unsigned char bus, unsigned char slot, unsigned char function, unsigned char offset, uint16_t val)
int indirect_pci_write_config_dword (unsigned char bus, unsigned char slot, unsigned char function, unsigned char offset, uint32_t val)
int FindPCIbridge (int mybus, struct pcibridge *pb)
void FixupPCI (const struct _int_map *bspmap, int(*swizzler)(int, int))
int pci_initialize (void)
unsigned char pci_bus_count (void)
unsigned char ucMaxPCIBus
const pci_config_access_functions pci_indirect_functions
rtems_pci_config_t BSP_pci_configuration
const pci_config_access_functions pci_direct_functions
This file was based on the powerpc.
◆ PCI_CONFIG_SET_ADDR
#define PCI_CONFIG_SET_ADDR (   addr,
  bus,
  slot,
  function,
  offset
Value:
PCI_CONFIG_WR_ADDR( \
(addr), \
PCI_CONFIG_ADDR_VAL((bus), (slot), (function), (offset))\
◆ PRINT_MSG
#define PRINT_MSG ( )
Value:
printk("pci : Device %d:0x%02x:%d routed to interrupt_line %d\n", \
pbus, pslot, pfun, int_name )
Variable Documentation
◆ BSP_pci_configuration
Initial value:
(volatile unsigned char*)PCI_CONFIG_ADDR,
(volatile unsigned char*)PCI_CONFIG_DATA,
&pci_indirect_functions
◆ pci_direct_functions
Initial value:
direct_pci_read_config_byte,
direct_pci_read_config_word,
direct_pci_read_config_dword,
direct_pci_write_config_byte,
direct_pci_write_config_word,
◆ pci_indirect_functions
Initial value:
indirect_pci_read_config_byte,
indirect_pci_read_config_word,
indirect_pci_read_config_dword,
indirect_pci_write_config_byte,
indirect_pci_write_config_word,
